Fundamentals Configuration Guide
HomeSupportWirelessWA2200 Series WLAN Access PointsConfigure & DeployConfiguration GuidesH3C WA Series WLAN Access Points Configuration Guide-6W100Fundamentals Configuration Guide
03-Controlling Login Users
03-Controlling Login Users 88.49 KB
l          The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l          Support of the H3C WA series WLAN access points (APs) for features may vary by AP model. For more information, see Feature Matrix.
l          The interface types and the number of interfaces vary by AP model.
l          The term AP in this document refers to common APs, wireless bridges, and mesh APs.
This chapter includes these sections:
l          Introduction
l          Controlling Telnet Users
l          Controlling Network Management Users by Source IP Addresses
l          Controlling Web Users by Source IP Addresses
Introduction
Multiple ways are available for controlling different types of login users, as listed in Table 1-1.
Table 1-1 Ways to control different types of login users
Login mode
Control method
Implementation
Related section
Telnet
By SSIDs
Through WLAN ACLs
Controlling Telnet Users by SSIDs
By source IP addresses
Through basic ACLs
Controlling Telnet Users by Source IP Addresses
By source and destination IP addresses
Through advanced ACLs
 Controlling Telnet Users by Source and Destination IP Addresses
By source MAC addresses
Through Layer 2 ACLs
Controlling Telnet Users by Source MAC Addresses
SNMP
Through basic ACLs
The source and destination IP addresses to be controlled and the controlling actions (permit or deny) are determined.
This configuration needs to reference WLAN ACLs, the numbers of which range from 100 to 199. For more information about ACLs, see ACL in the ACL and QoS Configuration Guide.
Follow these steps to control Telnet users by WLAN ACLs:
To do…
Use the command…
Remarks
Enter system view
Create a WLAN ACL or enter WLAN ACL view
acl number acl-number
Required
For this command, the config keyword is specified by default.
Define rules for the ACL
rule [ rule-id ] { permit | deny } [ ssid ssid-name ]
Required
Return to system view
Enter user interface view
user-interface { first-num1 [ last-num1 ] | { console | vty } first-num2 [ last-num2 ] }
Apply the ACL to control Telnet users by SSIDs
acl acl-number inbound
Required
The inbound keyword specifies to filter the users trying to Telnet to the current access point.
This configuration needs to be implemented by basic ACL; a basic ACL ranges from 2000 to 2999. For more information about ACLs, see ACL in the ACL and QoS Configuration Guide.
Follow these steps to control Telnet users by source IP addresses:
To do…
Use the command…
Remarks
Enter system view
Create a basic ACL or enter basic ACL view
acl [ ipv6 ] number acl-number [ name acl-name ] [ match-order { auto | config } ]
As for the acl number command, the config keyword is specified by default.
rule [ rule-id ] { deny | permit } [ fragment | logging | source { sour-addr sour-wildcard | any } | time-range time-range-name ] *
Required
Apply the ACL to control Telnet users by source IP addresses
acl [ ipv6 ] acl-number { inbound | outbound }
Required
The outbound keyword specifies to filter users trying to Telnet to other switches from the current access point.
This configuration needs to be implemented by advanced ACL; an advanced ACL ranges from 3000 to 3999. For more information about ACLs, see ACL in the ACL and QoS Configuration Guide.
Follow these steps to control Telnet users by source and destination IP addresses:
To do…
Use the command…
Remarks
Enter system view
Create an advanced ACL or enter advanced ACL view
rule [ rule-id ] { permit | deny } rule-string
Required
You can define rules as needed to filter by specific source and destination IP addresses.
Quit to system view
Apply the ACL to control Telnet users by specified source and destination IP addresses
Required
This configuration needs to be implemented by Layer 2 ACL; a Layer 2 ACL ranges from 4000 to 4999. For more information about ACLs, see ACL in the ACL and QoS Configuration Guide.
Follow these steps to control Telnet users by source MAC addresses:
To do…
Use the command…
Remarks
Enter system view
acl number acl-number [ name acl-name ] [ match-order { auto | config } ]
Required
You can define rules as needed to filter by specific source MAC addresses.
Quit to system view
Apply the ACL to control Telnet users by source MAC addresses
Required
Layer 2 ACL is invalid for this function if the source IP address of the Telnet client and the interface IP address of the Telnet server are not in the same subnet.
Configuration Example
Network requirements
Only the Telnet users sourced from the IP addresses of 10.110.100.52 and 10.110.100.46 are permitted to log in to the AP.
Figure 1-1 Network diagram for controlling Telnet users using ACLs
Configuration procedure
# Define a basic ACL.
[Sysname] acl number 2000 match-order config
[Sysname-acl-basic-2000] rule 1 permit source 10.110.100.52 0
[Sysname-acl-basic-2000] rule 2 permit source 10.110.100.46 0
[Sysname-acl-basic-2000] rule 3 deny source any
[Sysname-acl-basic-2000] quit
# Apply the ACL to only permit Telnet users sourced from the IP addresses of 10.110.100.52 and 10.110.100.46 to access the AP.
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] acl 2000 inbound
You can manage a WA series WLAN access point through network management software. Network management users can access APs through SNMP.
Perform the following two operations to control network management users by source IP addresses.
l          Defining an ACL
l          Applying the ACL to control users accessing the access point through SNMP
The controlling policy against network management users is determined, including the source IP addresses to be controlled and the controlling actions (permitting or denying).
This configuration needs to be implemented by basic ACLs; a basic ACL ranges from 2000 to 2999. For more information about ACLs, see ACL in the ACL and QoS Configuration Guide.
Follow these steps to control network management users by source IP addresses:
To do…
Use the command…
Remarks
Enter system view
Required
Quit to system view
Apply the ACL while configuring the SNMP community name
snmp-agent community { read | write } community-name [ acl acl-number | mib-view view-name ]*
Required
According to the SNMP version and configuration customs of NMS users, you can reference an ACL when configuring community name, group name or username. For the detailed configuration, see SNMP in the Network Management and Monitoring Configuration Guide.
Apply the ACL while configuring the SNMP group name
snmp-agent group { v1 | v2c } group-name [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
Apply the ACL while configuring the SNMP user name
snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number ]
snmp-agent usm-user v3 user-name group-name [ [ cipher ] authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | des56 | 3des } priv-password ] ] [ acl acl-number ]
Only SNMP users sourced from the IP addresses of 10.110.100.52 and 10.110.100.46 are permitted to access the AP .
Figure 1-2 Network diagram for controlling SNMP users using ACLs
# Apply the ACL to only permit SNMP users sourced from the IP addresses of 10.110.100.52 and 10.110.100.46 to access the AP.
[Sysname] snmp-agent community read h3c acl 2000
[Sysname] snmp-agent group v2c h3cgroup acl 2000
[Sysname] snmp-agent usm-user v2c h3cuser h3cgroup acl 2000
The WA series WLAN access points support Web-based remote management, which allows Web users to access the access points using the HTTP protocol. By referencing access control lists (ACLs), you can control the access of Web users to the access points.
The control policies to be implemented on Web users are decided, including the source IP addresses to be controlled and the control action, that is, whether to allow or deny the access.
Follow these steps to configure controlling Web users by source IP addresses:
To do…
Use the command…
Remarks
Enter system view
Required
The config keyword is specified by default.
Required
Quit to system view
Reference the ACL to control Web users
ip http acl acl-number
Required
Logging off Online Web Users
Perform the following operation to log off online Web users:
To do…
Use the command…
Remarks
Log off online Web users
free web-users { all | user-id user-id | user-name user-name }
Required
Use this command in user view
Configure a basic ACL to allow only Web users that use IP address 10.110.100.52 to access the AP.
Figure 1-3 Configure an ACL to control the access of HTTP users to the AP
# Create a basic ACL.
[Sysname] acl number 2030 match-order config
[Sysname-acl-basic-2030] rule 1 permit source 10.110.100.52 0
# Reference the ACL to allow only Web users using IP address 10.110.100.52 to access the AP.
[Sysname] ip http acl 2030
