05-MPLS Volume
HomeSupportSwitchesH3C S7500E Switch SeriesReference GuidesCommand ReferencesH3C S7500E Series Ethernet Switches Command Manual(Release 6300 series V1.03)05-MPLS Volume
00-MPLS Volume Organization
00-MPLS Volume Organization 24.58 KB
Manual Version
20091105-C-1.03
Product Version
Release 6300 series
Organization
The MPLS Volume is organized as follows:
Features
MCE
Multi-CE (MCE) enables a switch to function as the CEs of multiple VPN instances in a BGP/MPLS VPN network, thus reducing the investment on network equipment. This document introduces the commands for MCE configuration.
MPLS Basics
MPLS (Multiprotocol Label Switching) brings together the advantages of the connectionless control with IP and the connection-oriented forwarding with ATM. In addition to the support from IP routing and control protocols, its powerful and flexible routing functions allows it to accommodate to various emerging applications. This document introduces the commands for MPLS Basics configuration.
MPLS L2VPN
MPLS L2VPN provides Layer 2 VPN services on the MPLS network. This document introduces the commands for MPLS L2VPN configuration.
MPLS L3VPN
MPLS L3VPN is a kind of PE-based L3VPN technology for service provider VPN solutions. This document introduces the commands for MPLS L3VPN configuration.
