05-MPLS Volume
HomeSupportSwitchesH3C S7500E Switch SeriesReference GuidesCommand ReferencesH3C S7500E Series Ethernet Switches Command Manual(Release 6300 series V1.03)05-MPLS Volume
03-MPLS L2VPN Commands
03-MPLS L2VPN Commands 110.25 KB
MPLS L2VPN Configuration Commands
ccc interface in-label out-label
ccc ccc-connection-name interface interface-type interface-number in-label in-label-value out-label out-label-value nexthop ip-address [ control-word | no-control-word ]
undo ccc ccc-connection-name
View
Default Level
2: System level
ccc-connection-name: Name for the CCC connection, a string of 1 to 20 characters. It is used for uniquely identifying a CCC connection on a PE.
interface-type interface-number: Specifies the interface connecting the local CE by its type and number.
in-label-value: Incoming label, in the range 16 to 1023.
out-label-value: Outgoing label, in the range 16 to 1023.
nexthop ip-address: Specifies the IP address of the next hop.
control-word: Enables the control word option.
no-control-word: Disables the control word option.
At present, the S7500E series Ethernet switches do not support the control word option.
Use the ccc interface in-label out-label command to create a remote CCC connection between CEs connected to different PEs.
Use the undo ccc command to delete a CCC connection.
This command must be configured on both of the PEs.
A PE uses connection names to identify different CCC connections. A CCC connection can have different names on different PEs.
If a P router is connected with a PE, you must configure a static LSPs between them.
# Create a remote CCC connection from CEA to CEB, setting the incoming interface to that connecting CEA, namely VLAN-interface 10; the next hop to 20.1.1.2; the incoming label to 100; and the outgoing label to 200.
[Sysname] ccc CEA-CEB interface vlan-interface 10 in-label 100 out-label 200 nexthop 20.1.1.2
ce
ce ce-name [ id ce-id [ range ce-range ] [ default-offset ce-offset ] ]
undo ce ce-name
View
MPLS L2VPN view, MPLS L2VPN CE view
Default Level
2: System level
ce-name: Unique name for a CE in the current VPN of the current PE, a string of 1 to 20 characters that cannot include the character of “-”.
ce-id: ID for the CE in the VPN, the range of valid values varies by device.
ce-range: Maximum number of CEs that the current PE can support. The default is 10. The value range varies by device.
ce-offset: Original CE offset. It can be either 0 or 1. The default is 0.
Use the ce command in MPLS L2VPN view to create a CE and enter MPLS L2VPN CE view.
Use the undo ce command to delete a CE.
To create a CE, you need to specify the id keyword in the command; to enter the view of an existing CE, you do not need to do so.
# Create a CE named ce1 for a VPN.
[Sysname] mpls l2vpn vpn1 encapsulation ethernet
[Sysname-mpls-l2vpn-vpn1] route-distinguisher 100:1
[Sysname-mpls-l2vpn-vpn1] ce ce1 id 1
[Sysname-mpls-l2vpn-ce-vpn1-ce1]
# Create a CE named ce2 for a VPN.
[Sysname-mpls-l2vpn-ce-vpn1-ce1] ce ce1 id 2
[Sysname-mpls-l2vpn-ce-vpn1-ce2]
connection
connection [ ce-offset id ] interface interface-type interface-number [ tunnel-policy tunnel-policy-name ]
undo connection { ce-offset id | interface interface-type interface-number }
View
MPLS L2VPN CE view
Default Level
2: System level
ce-offset id: Specifies the ID of the peer CE of the L2VPN connection, in the range 0 to 199.
interface-type interface-number: Specifies the interface connecting the CE by its type and number. The encapsulation type must be same as that of the VPN.
tunnel-policy tunnel-policy-name: Specifies a tunneling policy for the VC, which is a string of 1 to 19 characters.
Use the connection command to create a Kompella connection.
Use the undo connection command to delete a Kompella connection on a CE interface.
When creating a Kompella connection, you must specify the ID of the peer CE and the local CE interface.
If you do not specify the tunneling policy, or specify the tunneling policy name but do not configure the policy, the default policy is used. The default tunneling policy uses LSP tunnels and the load balance number of one.
Related commands: tunnel select-seq load-balance-number in MPLS L3VPN Commands of the MPLS Volume.
# Create a Kompella connection.
[Sysname-mpls-l2vpn-ce-vpn1-ce1] connection ce-offset 1 interface vlan-interface 10
display bgp l2vpn
display bgp l2vpn { all | group [ group-name ] | peer [ [ ip-address ] verbose ] | route-distinguisher route-distinguisher [ ce-id ce-id [ label-offset label-offset ] ] }
View
Default Level
1: Monitor level
all: Displays all L2VPN information.
group-name: Name of the peer group, a string of 1 to 47 characters.
ip-address: IP address of the peer.
verbose: Displays detailed information.
route-distinguisher: Route distinguisher in the format of nn:nn or IP-address:nn. It can be a string of 3 to 21 characters.
ce-id: VPN CE ID of the MPLS L2VPN connection, in the range 0 to 199. A remote connection requires the remote CE number.
label-offset: Label offset, in the range 0 to 65,535.
Use the display bgp l2vpn command to display information about BGP L2VPN in the BGP routing table.
Related commands: route-distinguisher.
# Display all information about L2VPN in the BGP routing table.
<Sysname> display bgp l2vpn all
BGP Local router ID : 2.2.2.9, local AS number : 100
 Origin codes:i - IGP, e - EGP, ? - incomplete
 bgp.l2vpn: 1 destination
 Route Distinguisher: 100:1
 CE ID   Label Offset   Label Base    nexthop          pref   as-path
 1       0              8202          3.3.3.9          100
Table 1-1 display bgp l2vpn all command output description
Origin codes
Route origin codes, which can be:
i – IGP: Indicates that the network layer reachability information is from within the AS
e – EGP: Indicates that the network layer reachability information is learned through EGP
? – incomplete: Indicates that the network layer reachability information is learned through other ways
bgp.l2vpn
Number of BGP L2VPNs
CE ID
CE number in the VPN
nexthop
pref
Local preference
as-path
AS-PATH of the route
# Display brief information about L2VPN peers in the BGP routing table.
<Sysname> display bgp l2vpn peer
 BGP local router ID : 4.4.4.9
 Local AS number : 100
 Total number of peers : 1                 Peers in established state : 0
  Peer        V   AS   MsgRcvd   MsgSent  OutQ PrefRcv Up/Down  State
  3.3.3.9     4   100        0        0     0       0  00:01:07 Active
Table 1-2 display bgp l2vpn peer command output description
BGP local router ID
ID of the local BGP router
Number of peers with BGP sessions in the state of established
Peer
V
BGP version that the peer is using
AS
AS number
MsgRcvd
Number of messages received
MsgSent
Number of messages sent
OutQ
Number of messages waiting to be sent to the peer
PrefRcv
Number of prefixes received
Up/Down
Duration that the BGP session is in the current status
Status of the peer
# Display detailed information about L2VPN peer 3.3.3.9 in the BGP routing table.
<Sysname> display bgp l2vpn peer 3.3.3.9 verbose
         Peer: 3.3.3.9   Local: 2.2.2.9
         Type: IBGP link
         BGP version 4, remote router ID 3.3.3.9
         BGP current state: Established, Up for   00:21:15
         BGP last state: OpenConfirm
         Port:  Local - 179      Remote - 1034
         Configured: Active Hold Time: 180 sec   Keep Alive Time:60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Address family IPv4 Unicast: advertised and received
         Address family L2VPN: advertised and received
 Received: Total 26 messages, Update messages 2
 Sent: Total 28 messages, Update messages 2
 Maximum allowed prefix number: 150000
 Threshold: 75%
 Minimum time between advertisement runs is 15 seconds
 Peer Preferred Value: 0
  BFD: Enabled
 Routing policy configured:
Table 1-3 display bgp l2vpn peer verbose command output description
Peer
Local
IP address of the local router
BGP type
BGP current state
Current status of the BGP session
BGP current event
Current event of the BGP session
BGP last state
Last status of the BGP session
Port
Ports used by the BGP session, one is local or the other remote
Configured
Settings of the local timers
Received
Settings of the remote timers
Negotiated
Negotiated settings of the timers
Optional peer capabilities, including the support for BGP multicast protocol extension and the support for BGP route refreshing
IPv4 unicast address family capability
L2VPN address family
Received
Total number of received messages and that of received update messages
Sent
Total number of sent messages and that of received update messages
Maximum number of routes allowed
Threshold
Threshold value
BFD
Whether BFD is enabled for the peer
Routing policy specified for the peer
# Display L2VPN information with the RD being 100:1 in the BGP routing table.
<Sysname> display bgp l2vpn route-distinguisher 100:1
 4       0              132096        3.3.3.9        100
Table 1-4 display bgp l2vpn route-distinguisher command output description
Origin codes
bgp.l2vpn
CE ID
nexthop
pref
Preference
as-path
# Display L2VPN information with the RD being 100:1 and the CE ID being 4 in the BGP routing table.
<Sysname> display bgp l2vpn route-distinguisher 100:1 ce-id 4
Table 1-5 display bgp l2vpn route-distinguisher ce-id command output description
Origin codes
CE ID
nexthop
pref
Preference
as-path
# Display L2VPN information with the RD being 100:1, the CE ID being 4, and the label offset being 0 in the BGP routing table.
<Sysname> display bgp l2vpn route-distinguisher 100:1 ce-id 4 label-offset 0
 nexthop:3.3.3.9,  pref :100,     as-path :
 label base:132096,label range:10,layer-2 mtu:0,encap type:Unknown or Reserved
  label            state
  132096           down
  132097           up
  132098           down
  132099           down
  132100           down
  132101           down
  132102           down
  132103           down
  132104           down
  132105           down
The following table gives the description on the fields of the display bgp l2vpn route-distinguisher ce-id label-offset command.
Table 1-6 Output description
Origin codes
nexthop
pref
Preference
as-path
encap type
Encapsulation type
display ccc
display ccc [ ccc-name ccc-name | type { local | remote } ]
View
Default Level
1: Monitor level
ccc-name: CCC connection name, a string of 1 to 20 characters..
type: Specifies the type of the CCC connections.
local: Specifies local CCC connections.
remote: Specifies remote CCC connections.
Use the display ccc command to display information about CCC connections.
If you do not specify the connection name or type, this command displays information about all CCC connections.
# Display information about CCC connection c1.
<Sysname> display ccc ccc-name c1
     ***Name                   : c1
        Type                   : remote
        State                  : down
        Intf                   : Vlan-interface2 (up)
        In-label               : 100
        Out-label              : 200
        Nexthop                : 20.1.1.1
# Display information about all CCC connections.
    Total  ccc vc          : 1
    Local  ccc vc          : 0,  0 up
    Remote ccc vc          : 1,  0 up
 ***Name                   : c1
    Type                   : remote
    State                  : down
    In-label               : 100
    Out-label              : 200
    Nexthop                : 20.1.1.1
Table 1-7 display ccc command output description
Total  ccc vc
Total number of CCC connections
Local  ccc vc
Number of local CCC connections
Remote ccc vc
Number of remote CCC connections
Name
Name of the CCC connection
Type of the CCC connection
Status of the CCC connection
Intf
Interface of the CCC connection
In-label
Incoming label
Out-label
Outgoing label
Nexthop
display l2vpn ccc-interface vc-type
display l2vpn ccc-interface vc-type { all | bgp-vc | ccc | ldp-vc | static-vc } [ up | down ]
View
Default Level
1: Monitor level
all: Specifies interfaces of any encapsulation types.
bgp-vc: Specifies interfaces of Kompella L2VPN VCs.
ccc: Specifies interfaces of CCC L2VPN VCs.
ldp-vc: Specifies interfaces of Martini L2VPN VCs.
static-vc: Specifies interfaces of SVC L2VPN VCs.
up: Specifies CCC interfaces in the state of UP.
down: Specifies CCC interfaces in the state of DOWN.
Use the display l2vpn ccc-interface vc-type command to display information about specified L2VPN VC interfaces.
# Display information about interfaces of any encapsulation types.
<Sysname> display l2vpn ccc-interface vc-type all
Total ccc-interface of CCC VC: 3
up (3), down (0)
Interface     Encap Type  State   VC Type
Vlan2         ethernet     up      CCC
Vlan3         ethernet     up      bgp-vc
Vlan4         ethernet     up      static-vc
# Display information about interfaces of Kompella L2VPN VCs.
<Sysname> display l2vpn ccc-interface vc-type bgp-vc
Total ccc-interface of BGP VC: 1
up (1), down (0)
# Display information about interfaces of SVC L2VPN VCs that are in the state of UP.
<Sysname> display l2vpn ccc-interface vc-type svc-vc up
Total ccc-interface of SVC VC: 1,
up (1), down (0)
Vlan4         VLAN         up      static-vc
Table 1-8 display l2vpn ccc-interface vc-type command output description
Total ccc-interface of XXX VC
Total interface number of L2VPN VCs of type xxx
Name of the interface
Encap Type
Encapsulation type of the interface
Status of the interface
VC Type
Encapsulation type of the L2VPN VC interface
display mpls l2vc
display mpls l2vc [ interface interface-type interface-number | remote-info ]
View
Default Level
1: Monitor level
interface interface-type interface-number: Specifies the interface connecting the CE by its type and number.
remote-info: Specifies Martini VCs from the remote peer.
Use the display mpls l2vc command to display information about Martini VCs configured on the router.
If you specify an interface, the command displays information about Martini VCs configured on the CE interface.
# Display information about all Martini VCs configured on the router.
<Sysname> display mpls l2vc
total  ldp vc : 3     0 up       3 down
Transport  Client       VC      Local      Remote     Tunnel
VC ID      Intf         State   VC Label   VC Label   Policy
5          Vlan2        down    0          0          lsp3
6          Vlan3        down    0          0          lsp2
7          Vlan4        down    0          0          plcy3
Table 1-9 display mpls l2vc command output description
total  ldp vc
Total number of Martini VCs
Transport VC ID
Remote VC ID
Client Intf
Interface connected with the CE
VC State
Status of the VC
Remote VC Label
Remote VC label
Tunnel Policy
Tunnel policy configured
# Display information about Martini VCs received from the remote peer.
<Sysname> display mpls l2vc remote-info
total remote ldp vc : 1
Transport  Group      Peer            Remote     Remote     C     Remote
VC ID      ID         Addr            Encap      VC Label   Bit   MTU
100        0          3.3.3.9         ethernet   1025       0     1500
Table 1-10 display mpls l2vc remote-info command output description
total remote ldp vc
Total number of remote LDP VCs
Transport VC ID
Remote VC ID
Group ID
Remote VC group ID, used for the L2VPN  VC FEC TLV field of LDP messages
Peer Addr
Remote Encap
Encapsulation type of the remote interface
C Bit
Control word, which can be 0 or 1
Remote MTU
MTU of the remote interface
display mpls l2vpn
display mpls l2vpn [ export-route-target-list | import-route-target-list | vpn-name vpn-name [ local-ce | remote-ce ] ]
View
Default Level
1: Monitor level
export-route-target-list: Displays the export route target list.
import-route-target-list: Displays the import route target list.
vpn-name: VPN name, a case insensitive string of 1 to 31 characters that cannot include the character of “-“.
local-ce: Displays the configurations and status of all local CEs of a specified VPN.
remote-ce: Displays the configurations and status of remote CEs learned from other PEs.
Use the display mpls l2vpn command to display information about L2VPNs configured on a PE.
If you do not specify a VPN, the command displays information about all L2VPNs.
# Display the L2VPN export route target list.
<Sysname> display mpls l2vpn export-route-target-list
export vpn target list: 755:7  888:8
Table 1-11 display mpls l2vpn export-route-target-list command output description
BGP VPN export route target list
# Display information about all L2VPNs configured on the PE.
VPN Number: 1
 vpn-name  encap-type  route-distinguisher     mtu   ce(L)  ce(R)
 vpn2      ethernet    500:1                   888   0      0
Table 1-12 display mpls l2vpn command output description
VPN Number
Number of created VPNs
vpn-name
Name of the VPN
encap-type
Encapsulation type
mtu
Maximum transmission unit
ce(L)
Local CE number
ce(R)
Remote CE number
# Display information about L2VPN vpn1.
<Sysname> display mpls l2vpn vpn-name vpn1
 ***VPN name               : vpn1
    Encap type             : vlan
    Local ce number(s)     : 0
    Remote ce number(s)    : 0
    Route distinguisher    : 100:2
    MTU                    : 1500
    Import vpn target      : 111:1
    Export vpn target      : 111:1
Table 1-13 display mpls l2vpn vpn-name command output description
VPN Name
Name of the VPN
Encap type
Encapsulation type
MTU
Import vpn target
Incoming VPN target
Export vpn target
Outgoing VPN target
# Display information about local CEs of L2VPN vpn1.
<Sysname> display mpls l2vpn vpn-name vpn1 local-ce
ce-name              ce-id   range   conn-num  LB
ce1                  1       10      0         132096/0/10
LB stands for label block
Table 1-14 display mpls l2vpn vpn-name local-ce command output description
ce-name
Name of the CE
ce-id
CE number
range
CE range
conn-num
Number of connections
LB
Label block
# Display information about remote CEs of L2VPN vpn1.
<Sysname> display mpls l2vpn vpn-name vpn1 remote-ce
no.  ce-id peer-id         route-distinguisher     LB
1    4     3.3.3.9         100:1                   132096/0/10
Table 1-15 display mpls l2vpn vpn-name remote-ce command output description
no
Sequence number
ce-id
CE ID
peer-id
LB
Label block
display mpls l2vpn connection
display mpls l2vpn connection [ vpn-name vpn-name [ remote-ce ce-id | down | up | verbose ] ]
display mpls l2vpn connection [ interface interface-type interface-number | summary]
View
Default Level
1: Monitor level
ce-id: ID of the remote CE for the L2VPN connection, in the range 0 to 249.
down: Displays detailed information about the connections that are down.
up: Displays detailed information about the connections that are up. If you specify neither the down nor the up keyword, the command displays detailed information about connections that are either up or down.
verbose: Displays detailed information. This keyword is valid only when displaying information about all connections in a VPN.
summary: Displays summary information about connections.
Use the display mpls l2vpn connection command to display information about Kompella L2VPN connections.
If you do not specify any argument, the command displays information about all Kompella L2VPN connections.
# Display information about all Kompella L2VPN connections.
<Sysname> display mpls l2vpn connection
1 total connections,
connections: 1 up, 0 down, 0 local, 1 remote, 0 unknown
VPN name: vpn1,
  CE name: ce1, id: 1,
  Rid type status peer-id         route-distinguisher   intf
  4   rmt  up     3.3.3.9         100:1                 Vlan2
Table 1-16 display mpls l2vpn connection command output description
connections
Statistics about connections, including the number of connections in the state of Up, the number of connections in the state of Down, the number of local connections, the number of remote connections, and the number of unknown connections
VPN name
Name of the VPN
CE name
Name of the CE
id
ID of the CE
Rid
ID of the remote CE
type
Type of the connection
status
Status of the connection
peer-id
intf
Interface for the connection
# Display information about Kompella L2VPN connections for VPN vpn1.
<Sysname> display mpls l2vpn connection vpn-name vpn1
VPN name: vpn1,
For descriptions of the output fields of the command, see Table 1-16.
# Display information about Kompella L2VPN connections on interface Vlan-interface 2.
<Sysname> display mpls l2vpn connection interface Vlan-interface 2
     ***Conn-type              : remote
        Local vc state         : up
        Remote vc state        : up
        Local ce-id            : 1
        Local ce name          : ce1
        Remote ce-id           : 4
        Intf(state,encap)      : Vlan-interface2 (up,vlan)
        Peer id                : 3.3.3.9
        Route-distinguisher    : 100:1
        Local vc label         : 132100
        Remote vc label        : 132097
        Tunnel policy          : policy1
        Tunnel Type            : lsp
        Tunnel ID              : 0x226013
Table 1-17 display mpls l2vpn connection interface command output description
Conn-type
Local vc state
Local VC status
Remote vc state
Remote VC status
Local ce-id
ID of the local CE
Local ce name
Name of the local CE
Remote ce-id
ID of the remote CE
Intf(state,encap)
Interface name (interface status, interface encapsulation type)
Peer id
Local vc label
Local VC label
Remote vc label
Remote VC label
Tunnel policy
Name of the tunneling policy
Tunnel type
Type of the tunnel
Tunnel ID
ID of the tunnel
# Display summary information about all Kompella L2VPN connections.
<Sysname> display mpls l2vpn connection summary
connections: 1 up,  0 down , 0 local, 1 remote, 0 unknown
No.   vpn-name    local-num remote-num unknown-num up-num total-num
1     vpn1        0         1          0           1      1
Table 1-18 mpls l2vpn connection summary command output description
connections
No.
Sequence number
vpn-name
Name of the VPN
local-num
Number of local connections
remote-num
Number of remote connections
unknown-num
Number of unknown connections
up-num
Number of connections that are up
total-num
Total number of connections
display mpls l2vpn forwarding-info
display mpls l2vpn forwarding-info [ vc-label ] interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
vc-label: L2VPN VC label, in the range 16 to 4294967295.
|: Uses a regular expression to filter the output information. For details about regular expression, refer to Basic System Configuration in the System Volume.
begin: Displays all lines starting with the line that matches the regular expression.
exclude: Displays all lines other than those matching the regular expression..
include: Displays all lines matching the regular expression.
regular-expression: Regular expression, a case-sensitive string of 1 to 80 characters.
Use the display mpls l2vpn forwarding-info command to display MPLS L2VPN forwarding information.
# Display MPLS L2VPN forwarding information.
<Sysname> display mpls l2vpn forwarding-info interface Vlan-interface 2
  In interface      : Vlan-interface2
  Encapsulation type: vlan
  MTU               : 1500
  Control word      : 1
  Entry type        : send
  Out VC label      : 8193
  Tunnel ID         : 0x110002
Table 1-19 display mpls l2vpn forwarding-info command output description
In interface
Incoming interface, which is bound to L2VPN
MTU
Control word
Whether control word is enabled. 0 means disabled, and 1 means enabled.
Out VC label
Outgoing VC label
Tunnel ID
ID of the public tunnel
display mpls static-l2vc
display mpls static-l2vc [ interface interface-type interface-number ]
View
Default Level
1: Monitor level
interface interface-type interface-number: Specifies a CE interface by its type and number.
Use the display mpls static-l2vc command to display information about static VCs configured on the router.
If you specify an interface, the command displays only information about static VCs configured on the CE interface.
# Display information about all static VCs configured on the router.
<Sysname> display mpls static-l2vc
total connections:  1,  1 up,  0 down
ce-intf         state destination     tr-label  rcv-label tnl-policy
Vlan2            up    3.3.3.9         100       200       policy1
Table 1-20 display mpls static-l2vc command output description
total connections
Statistics about connection, including the total number of connections, number of connections that are up, and number of connections that are down
ce-intfe
CE interface
Status of the VC
destination
Destination IP address
tr-label
Outgoing label
rcv-label
Incoming label
tnl-policy
# Display information about static VCs configured on interface Vlan-interface 2.
<Sysname> display mpls static-l2vc interface Vlan-interface 2
     ***CE-interface           : Vlan-interface2 is up
        VC State               : up
        Destination            : 3.3.3.9
        Transmit-vpn-label     : 100
        Receive-vpn-label      : 400
        Tunnel Policy          : policy1
        Tunnel Type            : lsp
Table 1-21 display mpls static-l2vc interface command output description
CE-interface
Name of the CE interface
VC State
Status of the VC
Destination
Transmit-vpn-label
Outgoing label
Receive-vpn-label
Incoming label
Tunnel Policy
Tunnel Type
Type of the tunnel
Tunnel ID
ID of the tunnel
l2vpn-family
l2vpn-family
undo l2vpn-family
View
BGP view
Default Level
2: System level
None
Use the l2vpn-family command to enter BGP L2VPN address family view.
Use the undo l2vpn-family command to delete all configurations for the BGP L2VPN address family.
# Enter BGP L2VPN address family view.
[Sysname] bgp 100
[Sysname-bgp] l2vpn-family
[Sysname-bgp-af-l2vpn]
mpls l2vc
mpls l2vc destination vcid [ tunnel-policy tunnel-policy-name ] [ control-word | no-control-word ]
undo mpls l2vc
View
Interface view
Default Level
2: System level
destination: IP address of the peer PE.
vc-id: VC ID of the L2VPN connection, in the range 1 to 4294967295.
tunnel-policy-name: Tunneling policy for the VC, a string of 1 to 19 characters.
Use the mpls l2vc command to create a Martini L2VPN connection.
Use the undo mpls l2vc command to delete the Martini connection on the CE interface.
l          If you do not specify the tunneling policy, or specify the tunneling policy name but do not configure the policy, the default policy is used. The default tunneling policy uses LSP tunnels and the load balance number of one.
l          At present, the S7500E series Ethernet switches do not support the control word option.
# Create a Martini MPLS L2VPN connection.
[Sysname-Vlan-interface10] mpls l2vc 2.2.2.9 999
mpls l2vpn
mpls l2vpn
undo mpls l2vpn
View
Default Level
2: System level
None
Use the mpls l2vpn command to enable MPLS L2VPN.
Use the undo mpls l2vpn command to disable MPLS L2VPN and delete all L2VPN configurations.
You must use the mpls l2vpn command to enable MPLS L2VPN before configuring the other L2VPN commands.
# Enable MPLS L2VPN.
mpls l2vpn vpn-name
mpls l2vpn vpn-name [ encapsulation { ethernet | vlan } [ control-word | no-control-word ] ]
undo mpls l2vpn vpn-name
View
System view, MPLS L2VPN view
Default Level
2: System level
vpn-name: Name for the VPN, a case insensitive string of 1 to 31 characters that cannot include the character of “-“. It is used to identify a VPN uniquely on a PE.
encapsulation: Specifies the VPN encapsulation type.
ethernet: Uses Ethernet encapsulation.
vlan: Uses VLAN encapsulation.
Use the mpls l2vpn command to create a Kompella VPN and enter MPLS L2VPN view.
Use the undo mpls l2vpn command to delete a VPN.
The encapsulation type specified here must match that of the CE interface.
# Create Kompella VPN named vpn1 and enter MPLS L2VPN view.
# Create Kompella VPN named vpn2 and enter MPLS L2VPN view.
[Sysname-mpls-l2vpn-vpn1] mpls l2vpn vpn2 encapsulation ethernet
[Sysname-mpls-l2vpn-vpn2]
mpls static-l2vc destination
mpls static-l2vc destination destination-router-id transmit-vpn-label transmit-label-value receive-vpn-label receive-label-value [ tunnel-policy tunnel-policy-name ] [ control-word | no-control-word ]
undo mpls static-l2vc
View
Interface view
Default Level
2: System level
dest-router-id: Destination router ID.
transmit-label-value: Outgoing label for the VPN, namely the outgoing label for the static level 2 VC. The value ranges from 16 to 1023.
receive-label-value: Incoming label for the VPN, namely the incoming label for the static level 2 VC. The value ranges from 16 to 1023.
Use the mpls static-l2vc destination command to create a static VC between CEs connected to different PEs.
Use the undo mpls static-l2vc command to delete the static VC.
l          You must configure the command on both PEs. The destination address is the IP address of the peer PE. The outgoing label and incoming label are respectively the incoming label and outgoing label of the peer.
l          If you do not specify the tunneling policy, or specify the tunneling policy name but do not configure the policy, the default policy is used. The default tunneling policy uses LSP tunnels and the load balance number is one.
# Create a static VC between CEs connected to different PEs.
[Sysname-Vlan-interface10] mpls static-l2vc destination 1.1.1.1 transmit-vpn-label 111 receive-vpn-label 222 tunnel-policy pol1
mtu (MPLS L2VPN view)
mtu mtu
undo mtu
View
MPLS L2VPN view
Default Level
2: System level
mtu-value: MTU for the L2VPN. It ranges from 128 to 1,500 and defaults to 1,500.
Use the mtu command to set the maximum transmission unit (MTU) for the kompella connections.
Use the undo mtu command to restore the default.
The mtu command is not recommended because it affects only negotiation of protocol parameters that may take place and does not affects the forwarding.
# Set the MTU for Kompella connections to 1000.
[Sysname-mpls-l2vpn-vpn1] mtu 1000
reset bgp l2vpn
reset bgp l2vpn { as-number | ip-address | all | external | internal }
View
Default Level
1: Monitor level
as-number: Resets L2VPN BGP connections with the peers in the AS with this number. The AS number must be in the range 1 to 65535.
ip-address: Resets the L2VPN BGP connection to the peer with this IP address.
all: Resets all L2VPN BGP connections.
external: Resets L2VPN EBGP sessions.
internal: Resets L2VPN IBGP sessions.
Use the reset bgp l2vpn command to reset L2VPN BGP connections.
# Reset all L2VPN BGP connections.
<Sysname> reset bgp l2vpn all
route-distinguisher (MPLS L2VPN view)
View
MPLS L2VPN view
Default Level
2: System level
route-distinguisher: Specifies the route distinguisher (RD) in the format of nn:nn or IP-address:nn. It can be a string of 3 to 21 characters.
An RD can be in either of the following formats:
l          16-bit AS number:32-bit user-defined number. For example, 101:3.
l          32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
Use the route-distinguisher command to configure an RD for the VPN.
Different VPNs on a PE must have different RDs, while a VPN can have the same or different RDs on different PEs.
l          You cannot change an RD directly; you can only delete the VPN and then re-create the VPN using the new RD.
l          No RD is configured by default; you must configure an RD for each VPN. A VPN takes effect only when it is configured with an RD.
l          Once you configure an RD for a VPN, you cannot remove the association between the RD and the VPN.
# Configure the RD of a VPN.
[Sysname-mpls-l2vpn-vpn1] route-distinguisher 300:1
vpn-target (MPLS L2VPN view)
vpn-target vpn-target&<1-16> [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { all | { vpn-target&<1-16> [ both | export-extcommunity | import-extcommunity ] }
View
MPLS L2VPN view
Default Level
2: System level
vpn-target: VPN target extended community attributes to be added to the import or export VPN target extended community list, in the format of nn:nn or IP-address:nn. It can be a string of 3 to 21 characters. &<1-16> means that you can specify this argument for up to 16 times.
A VPN target can be in either of the following formats:
both: Specifies both the export and import VPN extended communities. This is the default.
export-extcommunity: Specifies the export VPN extended community.
import-extcommunity: Specifies the import VPN extended community.
all: Specifies both the import and export VPN extended communities.
Use the vpn-target command to associate a particular VPN with one or more VPN targets.
Use the undo vpn-target command to delete the VPN target(s) associated with a particular VPN.
There is no default value for a VPN target. You must configure it when creating the VPN.
# Associate VPN vpn1 with VPN targets.
[Sysname] mpls l2vpn vpn1 encapsulation vlan
[Sysname-mpls-l2vpn-vpn1] vpn-target 1:1 2:2 export-extcommunity
[Sysname-mpls-l2vpn-vpn1] vpn-target 1.2.3.4:11 import-extcommunity
