| 03-DHCP Commands | 231.66 KB |
Table of Contents
1 DHCP Server Configuration Commands
dhcp select server global-pool
dhcp server relay information enable
display dhcp server forbidden-ip
display dhcp server statistics
2 DHCP Relay Agent Configuration Commands
dhcp relay information circuit-id format-type
dhcp relay information circuit-id string
dhcp relay information remote-id format-type
dhcp relay information remote-id string
dhcp relay information strategy
display dhcp relay information
display dhcp relay security statistics
display dhcp relay security tracker
display dhcp relay server-group
3 DHCP Client Configuration Commands
4 DHCP Snooping Configuration Commands
dhcp-snooping information circuit-id format-type
dhcp-snooping information circuit-id string
dhcp-snooping information enable
dhcp-snooping information format
dhcp-snooping information remote-id format-type
dhcp-snooping information remote-id string
dhcp-snooping information strategy
display dhcp-snooping information
display dhcp-snooping packet statistics
reset dhcp-snooping packet statistics
l The DHCP server configuration is supported only on VLAN interfaces and loopback interfaces. The subaddress pool configuration is not supported on loopback interfaces.
l DHCP snooping must be disabled on the DHCP server.
bims-server
bims-server ip ip-address [ port port-number ] sharekey key
undo bims-server
View
DHCP address pool view
Default Level
2: System level
ip ip-address: Specifies an IP address for the BIMS server.
port port-number: Specifies a port number for the BIMS server in the range 1 to 65534.
sharekey key: Specifies a shared key for the BIMS server, which is a string of 1 to 16 characters.
Use the bims-server command to specify the IP address, port number, and shared key of the BIMS server in the DHCP address pool for the client.
Use the undo bims-server command to remove the specified BIMS server information.
By default, no BIMS server information is specified.
If you execute the bims-server command repeatedly, the latest configuration will overwrite the previous one.
Related commands: dhcp server ip-pool.
# Specify the IP address 1.1.1.1, port number 80, shared key aabbcc of the BIMS server in DHCP address pool 0 for the client.
[Sysname] dhcp server ip-pool 0
[Sysname-dhcp-pool-0] bims-server ip 1.1.1.1 port 80 sharekey aabbcc
bootfile-name
bootfile-name bootfile-name
undo bootfile-name
View
Default Level
2: System level
bootfile-name: Boot file name, a string of 1 to 63 characters.
Use the bootfile-name command to specify a bootfile name in the DHCP address pool for the client.
Use the undo bootfile-name command to remove the specified bootfile name.
By default, no bootfile name is specified.
If you execute the bootfile-name command repeatedly, the latest configuration will overwrite the previous one.
# Specify the bootfile name aaa in DHCP address pool 0.
[Sysname-dhcp-pool-0] bootfile-name aaa
dhcp enable
dhcp enable
undo dhcp enable
View
Default Level
2: System level
None
Use the dhcp enable command to enable DHCP.
Use the undo dhcp enable command to disable DHCP.
By default, DHCP is disabled.
You need to enable DHCP before performing DHCP server and relay agent configurations.
# Enable DHCP.
[Sysname] dhcp enable
dhcp select server global-pool [ subaddress ]
undo dhcp select server global-pool subaddress
View
Interface view
Default Level
2: System level
subaddress: Supports subaddress allocation. That is, the DHCP server and clients are on the same network segment, and the server allocates IP addresses from the address pool containing the network segment of the first subaddress if several subaddresses exist.
Use the dhcp select server global-pool command to enable the DHCP server on specified interface(s). After the interface receives a DHCP request, the DHCP server will allocate an IP address from the address pool.
Use the undo dhcp select server global-pool subaddress command to cancel the support for subaddress allocation.
By default, the DHCP server is enabled on an interface.
# Enable the DHCP server on VLAN-interface 1.
[Sysname-Vlan-interface1] dhcp select server global-pool
dhcp server detect
dhcp server detect
undo dhcp server detect
View
Default Level
2: System level
None
Use the dhcp server detect command to enable unauthorized DHCP server detection.
Use the undo dhcp server detect command to disable the function.
By default, the function is disabled.
# Enable unauthorized DHCP server detection.
[Sysname] dhcp server detect
dhcp server forbidden-ip low-ip-address [ high-ip-address ]
undo dhcp server forbidden-ip low-ip-address [ high-ip-address ]
View
Default Level
2: System level
low-ip-address: Start IP address of the IP address range to be excluded from dynamic allocation.
high-ip-address: End IP address of the IP address range to be excluded from dynamic allocation. The end IP address must have a higher sequence than the start one.
Use the dhcp server forbidden-ip command to exclude IP addresses from dynamic allocation.
Use the undo dhcp server forbidden-ip command to remove the configuration.
By default, all IP addresses in a DHCP address pool are assignable except IP addresses of the DHCP server interfaces.
Note that:
l When you use the dhcp server forbidden-ip command to exclude an IP address that is bound to a user from dynamic assignment, the address can be still assigned to the user.
l When you use the undo dhcp server forbidden-ip command to remove the configuration, the specified address/address range must be consistent with the one specified with the dhcp server forbidden-ip command. If you have configured to exclude an address range from dynamic assignment, you need to specify the same address range in the undo dhcp server forbidden-ip command instead of specifying one IP address.
l Using the dhcp server forbidden-ip command repeatedly can exclude multiple IP address ranges from allocation.
Related commands: dhcp server ip-pool, network, static-bind ip-address.
# Exclude the IP address range 10.110.1.1 to 10.110.1.63 from dynamic allocation.
[Sysname] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
dhcp server ip-pool
dhcp server ip-pool pool-name
undo dhcp server ip-pool pool-name
View
Default Level
2: System level
pool-name: Global address pool name, which is a unique pool identifier, a string of 1 to 35 characters.
Use the dhcp server ip-pool command to create a DHCP address pool and enter its view. If the pool was created, you will directly enter its view.
Use the undo dhcp server ip-pool command to remove the specified DHCP address pool.
By default, no DHCP address pool is created.
Related commands: dhcp enable.
# Create the DHCP address pool identified by 0.
dhcp server ping packets
undo dhcp server ping packets
View
Default Level
2: System level
number: Number of ping packets, in the range of 0 to 10. 0 means no ping operation.
Use the dhcp server ping packets command to specify the maximum number of ping packets on the DHCP server.
Use the undo dhcp server ping packets command to restore the default.
The number defaults to 1.
# Specify the maximum number of ping packets as 10.
[Sysname] dhcp server ping packets 10
dhcp server ping timeout
undo dhcp server ping timeout
View
Default Level
2: System level
milliseconds: Response timeout value for ping packets in milliseconds, in the range of 0 to 10,000. 0 means no ping operation.
Use the dhcp server ping timeout command to configure response timeout time of the ping packet on the DHCP server.
Use the undo dhcp server ping timeout command to restore the default.
The time defaults to 500 ms.
# Specify the response timeout time as 1000 ms.
[Sysname] dhcp server ping timeout 1000
undo dhcp server relay information enable
View
Default Level
2: System level
None
Use the dhcp server relay information enable command to enable the DHCP server to handle Option 82.
Use the undo dhcp server relay information enable command to configure the DHCP server to ignore Option 82.
By default, the DHCP server handles Option 82.
# Configure the DHCP server to ignore Option 82.
[Sysname] undo dhcp server relay information enable
display dhcp server conflict
display dhcp server conflict { all | ip ip-address }
View
Default Level
1: Monitor level
all: Displays information about all IP address conflicts.
ip-address: Displays conflict information for the IP address.
Use the display dhcp server conflict command to display information about IP address conflicts.
Related commands: reset dhcp server conflict.
# Display information about all IP address conflicts.
<Sysname> display dhcp server conflict all
Address Discover time
4.4.4.1 Apr 25 2007 16:57:20
4.4.4.2 Apr 25 2007 17:00:10
--- total 2 entry ---
Table 1-1 display dhcp server conflict command output description
Address |
Conflicted IP address |
Discover Time |
Time when the conflict was discovered |
display dhcp server expired
display dhcp server expired { all | ip ip-address | pool [ pool-name ] }
View
Default Level
1: Monitor level
all: Displays the lease expiration information of all DHCP address pools.
ip ip-address: Displays the lease expiration information of a specified IP address.
pool [ pool-name ]: Displays the lease expiration information of a specified address pool. The pool name is a string of 1 to 35 characters. If the pool name is not specified, the lease expiration information of all address pools is displayed.
Use the display dhcp server expired command to display the lease expiration information of specified DHCP address pool(s) or an IP address.
DHCP will assign these expired IP addresses to DHCP clients after all addresses have been assigned.
# Display information about lease expirations in all DHCP address pools.
<Sysname> display dhcp server expired all
Global pool:
IP address Client-identifier/ Lease expiration Type
Hardware address
4.4.4.6 3030-3066-2e65-3230- Apr 25 2007 17:10:47 Release
302e-3130-3234-2d45-
7468-6572-6e65-7430-
2f31
--- total 1 entry ---
Table 1-2 display dhcp server expired command output description
Global pool |
Information about lease expiration of a DHCP address pool |
IP address |
Expired IP addresses |
Client-identifier/Hardware address |
IDs or MACs of clients whose IP addresses were expired |
Lease expiration |
The lease expiration time |
Type |
Types of lease expirations. Currently, this field is set to Release. |
display dhcp server free-ip
View
Default Level
1: Monitor level
None
Use the display dhcp server free-ip command to display information about assignable IP addresses which have never been assigned.
# Display information about assignable IP addresses.
<Sysname> display dhcp server free-ip
IP Range from 10.0.0.0 to 10.0.0.255
View
Default Level
1: Monitor level
None
Use the display dhcp server forbidden-ip command to display IP addresses excluded from dynamic allocation in DHCP address pool.
# Display IP addresses excluded from dynamic allocation in the DHCP address pool.
<Sysname> display dhcp server forbidden-ip
IP Range from 1.1.1.1 to 1.1.1.1
IP Range from 2.2.2.2 to 2.2.2.5
display dhcp server ip-in-use
display dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] }
View
Default Level
1: Monitor level
all: Displays the binding information of all DHCP address pools.
ip ip-address: Displays the binding information of a specified IP address.
pool [ pool-name ]: Displays the binding information of a specified address pool. The pool name is a string of 1 to 35 characters. If no pool name is specified, the binding information of all address pools is displayed.
Use the display dhcp server ip-in-use command to display the binding information of DHCP address pool(s) or an IP address.
Related commands: reset dhcp server ip-in-use.
# Display the binding information of all DHCP address pools.
<Sysname> display dhcp server ip-in-use all
Global pool:
Hardware address
10.1.1.1 4444-4444-4444 NOT Used Manual
Table 1-3 display dhcp server ip-in-use command output description
Global pool |
Binding information of a DHCP address pool |
IP address |
Bound IP address |
Client’s ID or MAC of the binding |
Lease expiration |
Lease expiration time |
Type |
Binding types, including Manual, Auto:OFFERED and Auto:COMMITTED. l Manual: Static binding l Auto:OFFERED: The binding sent in the DHCP-OFFER message from the server to the client. l Auto:COMMITTED: The binding sent in the DHCP-ACK message from the server to the client. |
View
Default Level
1: Monitor level
None
Use the display dhcp server statistics command to display the statistics of the DHCP server.
Related commands: reset dhcp server statistics.
# Display the statistics on the DHCP server.
<Sysname> display dhcp server statistics
Global Pool:
Pool Number: 1
Binding:
Auto: 1
Manual: 0
Expire: 0
BOOTP Request: 10
DHCPDISCOVER: 5
DHCPREQUEST: 3
DHCPDECLINE: 0
DHCPRELEASE: 2
DHCPINFORM: 0
BOOTPREQUEST: 0
BOOTP Reply: 6
DHCPOFFER: 3
DHCPACK: 3
DHCPNAK: 0
BOOTPREPLY: 0
Bad Messages: 0
Table 1-4 display dhcp server statistics command output description
Global Pool |
Statistics of a DHCP address pool |
Pool Number |
The number of address pools |
Auto |
The number of dynamic bindings |
Manual |
The number of static bindings |
Expire |
The number of expired bindings |
BOOTP Request |
The number of DHCP requests sent from DHCP clients to the DHCP server, including: l DHCPDISCOVER l DHCPREQUEST l DHCPDECLINE l DHCPRELEASE l DHCPINFORM l BOOTPREQUEST |
BOOTP Reply |
The number of DHCP replies sent from the DHCP server to DHCP clients, including: l DHCPOFFER l DHCPACK l DHCPNAK l BOOTPREPLY |
Bad Messages |
The number of erroneous messages |
display dhcp server tree
display dhcp server tree { all | pool [ pool-name ] }
View
Default Level
1: Monitor level
all: Displays the tree organization information of all DHCP address pools.
pool [ pool-name ]: Displays the tree organization information of a specified address pool. The pool name is a string of 1 to 35 characters. If no pool name is specified, the tree organization information of all address pools will be displayed.
Use the display dhcp server tree command to display the tree organization information of DHCP address pool(s).
# Display the tree organization information of all DHCP address pools.
<Sysname> display dhcp server tree all
Global pool:
Pool name: 0
network 20.1.1.0 mask 255.255.255.0
Sibling node:1
option 2 ip-address 1.1.1.1
expired 1 0 0
Pool name: 1
static-bind ip-address 10.10.1.2 mask 255.0.0.0
static-bind mac-address 00e0-00fc-0001
PrevSibling node:0
expired unlimited
Table 1-5 display dhcp server tree command output description
Global pool |
Information of a address pool |
Pool name |
Address pool name |
network |
Network segment for address allocation |
static-bind ip-address 10.10.1.2 mask 255.0.0.0 static-bind mac-address 00e0-00fc-0001 |
The IP address and MAC address of the static binding |
Sibling node |
The sibling node of the current node, nodes of this kind in the output information include: l Child node: The child node (subnet segment) address pool of the current node l Parent node: The parent node (nature network segment) address pool of the current node l Sibling node: The latter sibling node of the current node (another subnet of the same nature network). The earlier the sibling node is configured, the higher order the sibling node has. l PrevSibling node: The previous sibling node of the current node |
option |
Self-defined DHCP options |
expired |
The lease duration, in the format of day, hour, and minute |
dns-list
dns-list ip-address&<1-8>
undo dns-list { ip-address | all }
View
Default Level
2: System level
ip-address&<1-8>: DNS server IP address. &<1-8> means you can specify up to eight DNS server addresses separated by spaces.
all: Specifies all DNS server addresses to be removed.
Use the dns-list command to specify DNS server addresses in a DHCP address pool.
Use the undo dns-list command to remove DNS server addresses from a DHCP address pool.
By default, no DNS server address is specified.
If you repeatedly use the dns-list command, the latest configuration will overwrite the previous one.
# Specify the DNS server address 10.1.1.254 for the DHCP client in DHCP address pool 0.
[Sysname-dhcp-pool-0] dns-list 10.1.1.254
domain-name
domain-name domain-name
undo domain-name
View
Default Level
2: System level
domain-name: Domain name suffix for DHCP clients, a string of 1 to 50 characters.
Use the domain-name command to specify a domain name suffix for the DHCP clients in the DHCP address pool.
Use the undo domain-name command to remove the specified domain name suffix.
No domain name suffix is specified by default.
# Specify a domain name suffix of mydomain.com for the DHCP clients in DHCP address pool 0.
[Sysname-dhcp-pool-0] domain-name mydomain.com
expired
expired { day day [ hour hour [ minute minute ] ] | unlimited }
undo expired
View
Default Level
2: System level
day day: Specifies the number of days, in the range of 0 to 365.
hour hour: Specified the number of hours, in the range of 0 to 23.
minute minute: Specifies the number of minutes, in the range of 0 to 59.
unlimited: Specifies the infinite duration, which is actually 136 years.
Use the expired command to specify the lease duration in a DHCP address pool.
Use the undo expired command to restore the default lease duration in a DHCP address pool.
The lease duration defaults to one day.
Note that if the lease duration you specified is beyond the year 2106, the system regards the lease as expired.
# Specify the lease duration as one day, two hours and three minutes in DHCP address pool 0.
[Sysname-dhcp-pool-0] expired day 1 hour 2 minute 3
gateway-list
gateway-list ip-address&<1-8>
undo gateway-list { ip-address | all }
View
Default Level
2: System level
ip-address&<1-8>: Gateway IP address. &<1-8> means you can specify up to eight gateway addresses separated by spaces.
all: Specifies all gateway IP addresses to be removed.
Use the gateway-list command to specify gateway address(es) in a DHCP address pool.
Use the undo gateway-list command to remove specified gateway address(es) specified for the DHCP client from a DHCP address pool.
By default, no gateway address is specified.
If you use the gateway-list command repeatedly, the latest configuration will overwrite the previous one.
# Specify the gateway address 10.110.1.99 in DHCP address pool 0.
[Sysname-dhcp-pool-0] gateway-list 10.110.1.99
nbns-list
nbns-list ip-address&<1-8>
undo nbns-list { ip-address | all }
View
Default Level
2: System level
ip-address&<1-8>: WINS server IP address. &<1-8> means you can specify up to eight WINS server addresses separated by spaces.
all: Specifies all WINS server addresses to be removed.
Use the nbns-list command to specify WINS server address(es) in a DHCP address pool.
Use the undo nbns-list command to remove the specified WINS server address(es).
By default, no WINS server address is specified.
If you use the nbns-list command repeatedly, the latest configuration will overwrite the previous one.
Related commands: dhcp server ip-pool, netbios-type.
# Specify WINS server address 10.12.1.99 in DHCP address pool 0.
[Sysname-dhcp-pool-0] nbns-list 10.12.1.99
netbios-type
undo netbios-type
View
Default Level
2: System level
b-node: Broadcast node. A b-node client sends the destination name in a broadcast message. The destination returns the name-to-IP mapping to the client after receiving the message.
p-node: Peer-to-peer node. A p-node client sends the destination name in a unicast message to the WINS server, and the WINS server returns the mapping to the client.
m-node: Mixed node, a combination of a b-node first and p-node second. An m-node client broadcasts the destination name, if there is no response, and then unicasts the destination name to the WINS server to get the mapping.
h-node: Hybrid node, a combination of a p-node first and b-node second. An h-node is a b-node with the peer-to-peer communication mechanism. An h-node client unicasts the destination name to the WINS server, if there is no response, and then broadcasts it to get the mapping from the destination.
Use the netbios-type command to specify the client NetBIOS node type in a DHCP address pool.
Use the undo netbios-type command to remove the specified client NetBIOS node type.
By default, no NetBIOS node type is specified.
Related commands: dhcp server ip-pool, nbns-list.
# Specify the NetBIOS node type as b-node in DHCP address pool 0.
[Sysname-dhcp-pool-0] netbios-type b-node
network
network network-address [ mask-length | mask mask ]
undo network
View
Default Level
2: System level
network-address: IP address range for dynamic allocation. If no mask length and mask is specified, the natural mask will be used.
mask-length: Mask length, in the range of 1 to 30.
mask mask: Specifies the IP address network mask, in dotted decimal format.
Use the network command to specify the IP address range for dynamic allocation in a DHCP address pool.
Use the undo network command to remove the specified address range.
No IP address range is specified by default.
Note that you can specify only one network segment for each DHCP global address pool. If you use the network command repeatedly, the latest configuration will overwrite the previous one.
Related commands: dhcp server ip-pool, dhcp server forbidden-ip.
# Specify 192.168.8.0/24 as the address range for dynamic allocation in DHCP address pool 0.
[Sysname-dhcp-pool-0] network 192.168.8.0 mask 255.255.255.0
option
option code { ascii ascii-string | hex hex-string&<1-16> | ip-address ip-address&<1-8> }
undo option code
View
Default Level
2: System level
code: Self-defined option number, in the range of 2 to 254, excluding 12, 50 to 55, 57 to 61, and 82.
ascii ascii-string: Specifies an ASCII string with 1 to 63 characters.
hex hex-string&<1-16>: Specifies hex digit strings. &<1-16> indicates that you can specify up to 16 hex digit strings, separated by spaces. Each string contains 2, 4, 6 or 8 hex digits.
ip-address ip-address&<1-8>: Specifies IP addresses. &<1-8> indicates that you can specify up to eight IP addresses, separated by spaces.
Use the option command to configure a self-defined DHCP option in a DHCP address pool.
Use the undo option command to remove a self-defined DHCP option from a DHCP address pool.
The option command is not configured by default.
If you use the option command repeatedly, the latest configuration will overwrite the previous one.
# Configure the hex digits 0x11 and 0x22 for the self-defined DHCP Option 100 in DHCP address pool 0.
[Sysname-dhcp-pool-0] option 100 hex 11 22
reset dhcp server conflict { all | ip ip-address }
View
Default Level
2: System level
all: Clears the statistics of all IP address conflicts.
ip ip-address: Clears the conflict statistics of a specified IP address.
Use the reset dhcp server conflict command to clear statistics of IP address conflict(s).
Related commands: display dhcp server conflict.
# Clears the statistics of all IP address conflicts.
<Sysname> reset dhcp server conflict all
reset dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] }
View
Default Level
2: System level
all: Clears the IP address dynamic binding information of all DHCP address pools.
ip ip-address: Clears the dynamic binding information of a specified IP address.
pool [ pool-name ]: Clears the dynamic binding information of a specified address pool. The pool name is a string of 1 to 35 characters. If no pool name is specified, the dynamic binding information of all address pools is cleared.
Use the reset dhcp server ip-in-use command to clear dynamic IP address binding information.
Related commands: display dhcp server ip-in-use
# Clear the binding information of IP address 10.110.1.1.
<Sysname> reset dhcp server ip-in-use ip 10.110.1.1
View
Default Level
2: System level
None
Use the reset dhcp server statistics command to clear the statistics of the DHCP server.
Related commands: display dhcp server statistics.
# Clear the statistics of the DHCP server.
<Sysname> reset dhcp server statistics
static-bind client-identifier
static-bind client-identifier client-identifier
undo static-bind client-identifier
View
Default Level
2: System level
client-identifier: The client ID of a static binding, a string with 4 to 160 characters in the format of H-H-H…, each H indicates 4 hex digits except the last H indicates 2 or 4 hex digits. For example, aabb-cccc-dd is a valid ID, while aabb-c-dddd and aabb-cc-dddd are both invalid.
Use the static-bind client-identifier command to specify the client ID of a static binding in a DHCP address pool.
Use the undo static-bind client-identifier command to remove the client ID of a static binding from a DHCP address pool.
By default, no client ID is specified.
Note that:
l Use the static-bind client-identifier command together with the static-bind ip-address command to accomplish a static binding configuration.
l The ID of the static binding of a client must be identical to the ID displayed by using the display dhcp client verbose command on the client. Otherwise, the client cannot obtain an IP address.
l If you use the static-bind client-identifier or static-bind mac-address command repeatedly, the latest configuration will overwrite the previous one.
Related commands: dhcp server ip-pool, static-bind ip-address, static-bind mac-address, display dhcp client verbose.
# Bind the client ID aaaa-bbbb to the IP address 10.1.1.1 with the mask 255.255.255.0 in DHCP address pool 0.
[Sysname-dhcp-pool-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0
[Sysname-dhcp-pool-0] static-bind client-identifier aaaa-bbbb
static-bind ip-address ip-address [ mask-length | mask mask ]
undo static-bind ip-address
View
Default Level
2: System level
ip-address: IP address of a static binding. If no mask and mask length is specified, the natural mask is used.
mask-length: Mask length of the IP address, that is, the number of ones in the mask, in the range of 0 to 32.
mask mask: Specifies the IP address mask, in dotted decimal format.
Use the static-bind ip-address command to specify an IP address in a DHCP address pool for a static binding.
Use the undo static-bind ip-address command to remove the statically bound IP address.
By default, no IP address is statically bound in a DHCP address pool.
Note that:
l Use the static-bind ip-address command together with the static-bind mac-address or static-bind client-identifier command to accomplish a static binding configuration.
l If the statically bound IP address is an interface address of the DHCP server, the static binding does not take effect.
l If you use the static-bind ip-address command repeatedly, the latest configuration will overwrite the previous one.
Related commands: dhcp server ip-pool, static-bind client-identifier, static-bind mac-address.
# Bind the client MAC address 0000-e03f-0305 to the IP address 10.1.1.1 with the mask 255.255.255.0 in DHCP address pool 0.
[Sysname-dhcp-pool-0] static-bind mac-address 0000-e03f-0305
static-bind mac-address mac-address
undo static-bind mac-address
View
Default Level
2: System level
mac-address: The MAC address of a static binding, in the format of H-H-H.
Use the static-bind mac-address command to statically bind a MAC address to an IP address in a DHCP address pool.
Use the undo static-bind mac-address command to remove the statically bound MAC address.
By default, no MAC address is statically bound.
Note that:
l Use the static-bind mac-address command together with the static-bind ip-address command to complete a static binding configuration.
l If you use the static-bind mac-address or static-bind client-identifier command repeatedly, the latest configuration will overwrite the previous one.
Relate command: dhcp server ip-pool, static-bind client-identifier and static-bind ip-address.
tftp-server domain-name
undo tftp-server domain-name
View
Default Level
2: System level
domain-name: TFTP server name, a string of 1 to 63 characters.
Use the tftp-server domain-name command to specify a TFTP server name in a DHCP address pool.
Use the undo tftp-server domain-name command to remove the TFTP server name from a DHCP address pool.
By default, no TFTP server name is specified.
Using the tftp-server domain-name command repeatedly will overwrite the previous configuration.
# Specify the TFTP server name as aaa in DHCP address pool 0.
[Sysname-dhcp-pool-0] tftp-server domain-name aaa
tftp-server ip-address
undo tftp-server ip-address
View
Default Level
2: System level
ip-address: TFTP server IP address.
Use the tftp-server ip-address command to specify the TFTP server IP address in a DHCP address pool.
Use the undo tftp-server ip-address command to remove the TFTP server IP address from a DHCP address pool.
By default, no TFTP server address is specified.
Using the tftp-server ip-address command repeatedly will overwrite the previous configuration.
# Specify the TFTP server address 10.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] tftp-server ip-address 10.1.1.1
voice-config
voice-config { as-ip ip-address | fail-over ip-address dialer-string | ncp-ip ip-address | voice-vlan vlan-id { disable | enable } }
undo voice-config [ as-ip | fail-over | ncp-ip | voice-vlan ]
View
Default Level
2: System level
as-ip ip-address: Specifies IP address for the backup network calling processor.
fail-over ip-address dialer-string: Specifies the failover IP address and dialer string. The dialer-string is a string of 1 to 39 characters, which can be 0 to 9, and “*”.
ncp-ip ip-address: Specifies IP address for the primary network calling processor.
voice-vlan vlan-id: Specifies the voice VLAN ID, in the range of 2 to 4094.
l disable: Disables the specified voice VLAN ID, meaning DHCP clients will not take this ID as their voice VLAN.
l enable: Enables the specified voice VLAN ID, meaning DHCP clients will take this ID as their voice VLAN.
Use the voice-config command to configure specified Option 184 contents in a DHCP address pool.
Use the undo voice-config command to remove specified Option 184 contents from a DHCP address pool.
By default, no Option 184 content is configured.
Note that specifying the IP address of a network calling processor first is necessary to make other configured parameters take effect.
# Configure Option 184 in DHCP address pool 0: the primary network calling processor 10.1.1.1, backup network calling processor 10.2.2.2, voice VLAN ID 3 that is enabled, the failover IP address 10.3.3.3 and dialer string 99*.
[Sysname-dhcp-pool-0] voice-config ncp-ip 10.1.1.1
[Sysname-dhcp-pool-0] voice-config as-ip 10.2.2.2
[Sysname-dhcp-pool-0] voice-config voice-vlan 3 enable
[Sysname-dhcp-pool-0] voice-config fail-over 10.3.3.3 99*
l The DHCP relay agent configuration is supported only on VLAN interfaces.
l DHCP snooping cannot be configured on the DHCP relay agent.
dhcp relay address-check
dhcp relay address-check { disable | enable }
View
Interface view
Default Level
2: System level
disable: Disables IP address match check on the relay agent.
enable: Enables IP address match check on the relay agent.
Use the dhcp relay address-check enable command to enable IP address match check on the relay agent.
Use the dhcp relay address-check disable command to disable IP address match check on the relay agent.
Note that: The dhcp relay address-check enable command only checks IP and MAC addresses of clients.
# Enable IP address match check on the DHCP relay agent.
[Sysname-Vlan-interface1] dhcp relay address-check enable
dhcp relay information circuit-id format-type { ascii | hex }
undo dhcp relay information circuit-id format-type
View
Interface view
Default Level
2: System level
ascii: Specifies the code type for the circuit ID sub-option as ascii.
hex: Specifies the code type for the circuit ID sub-option as hex.
Use the dhcp relay information circuit-id format-type command to configure the code type for the non-user-defined circuit ID sub-option.
Use the undo dhcp relay information circuit-id format-type command to restore the default.
By default, the code type for the circuit ID sub-option depends on the specified padding format of Option 82. Each field has its own code type.
Note that:
This command applies to configuring the non-user-defined circuit ID sub-option only. After you configure the padding content for the circuit ID sub-option using the dhcp relay information circuit-id string command, ASCII is adopted as the code type.
# Configure the code type for the non-user-defined circuit ID sub-option as ascii.
[Sysname-Vlan-interface1] dhcp relay information circuit-id format-type ascii
dhcp relay information circuit-id string circuit-id
undo dhcp relay information circuit-id string
View
Interface view
Default Level
2: System level
circuit-id: Padding content for the user-defined circuit ID sub-option, a case-sensitive string of 3 to 63 characters.
Use the dhcp relay information circuit-id string command to configure the padding content for the user-defined circuit ID sub-option.
Use the undo dhcp relay information circuit-id string command to restore the default.
By default, the padding content for the circuit ID sub-option depends on the padding format of Option 82.
Note that:
After you configure the padding content for the circuit ID sub-option using this command, ASCII is adopted as the code type.
Related commands: dhcp relay information format.
# Configure the padding content for the circuit ID sub-option as company001.
[Sysname-Vlan-interface1] dhcp relay information circuit-id string company001
dhcp relay information enable
undo dhcp relay information enable
View
Interface view
Default Level
2: System level
None
Use the dhcp relay information enable command to enable the relay agent to support Option 82.
Use the undo dhcp relay information enable command to disable Option 82 support.
By default, Option 82 support is disabled on DHCP relay agent.
# Enable Option 82 support on the relay agent.
[Sysname-Vlan-interface1] dhcp relay information enable
dhcp relay information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
undo dhcp relay information format [ verbose node-identifier ]
View
Interface view
Default Level
2: System level
normal: Specifies the normal padding format.
verbose: Specifies the verbose padding format.
node-identifier { mac | sysname | user-defined node-identifier }: Specifies access node identifier. By default, the node MAC address is used as the node identifier.
l mac indicates using MAC address as the node identifier.
l sysname indicates using the device name of a node as the node identifier.
l user-defined node-identifier indicates using a specified character string as the node identifier, in which node-identifier is a string with 1 to 50 characters.
Use the dhcp relay information format command to specify a padding format for Option 82.
Use the undo dhcp relay information format command to restore the default padding format.
The Option 82 padding format defaults to normal.
l Using the undo dhcp relay information format command without the keyword verbose node-identifier restores the default normal padding format, or with the keyword verbose node-identifier restores the mac mode of the verbose padding format.
l If configuring the handling strategy of the DHCP relay agent as replace, you need to configure a padding format of Option 82. If the handling strategy is keep or drop, you need not configure any padding format.
l If sub-option 1 (node identifier) of Option 82 is padded with the device name (sysname) of a node, the device name must contain no spaces. Otherwise, the DHCP relay agent will drop the message.
# Specify the verbose padding format for Option 82.
[Sysname-Vlan-interface1] dhcp relay information strategy replace
[Sysname-Vlan-interface1] dhcp relay information format verbose
dhcp relay information remote-id format-type { ascii | hex }
undo dhcp relay information remote-id format-type
View
Interface view
Default Level
2: System view
ascii: Specifies the code type for the remote ID sub-option as ascii.
hex: Specifies the code type for the remote ID sub-option as hex.
Use the dhcp relay information remote-id format-type command to configure the code type for the non-user-defined remote ID sub-option.
Use the undo dhcp relay information remote-id format-type command to restore the default.
By default, the code type for the remote ID sub-option is HEX.
Note that:
This command applies to configuring the non-user-defined remote ID sub-option only. After you configure the padding content for the remote ID sub-option using the dhcp relay information remote-id string command, ASCII is adopted as the code type.
# Configure the code type for the non-user-defined remote ID sub-option as ascii.
[Sysname-Vlan-interface1] dhcp relay information remote-id format-type ascii
dhcp relay information remote-id string { remote-id | sysname }
undo dhcp relay information remote-id string
View
Interface view
Default Level
2: System level
remote-id: Padding content for the user-defined remote ID sub-option, a case sensitive string of 1 to 63 characters.
sysname: Specifies the device name as the padding content for the remote ID sub-option.
Use the dhcp relay information remote-id string command to configure the padding content for the user-defined remote ID sub-option.
Use the undo dhcp relay information remote-id string command to restore the default.
By default, the padding content for the remote ID sub-option depends on the padding format of Option 82.
Note that: After you configure the padding content for the remote ID sub-option using this command, ASCII is adopted as the code type.
If you want to specify the character string sysname (a case-insensitive character string) as the padding content for the remote ID sub-option, you need to use quotation marks to make it take effect. For example, if you want to specify Sysname as the padding content for the remote ID sub-option, you need to enter the dhcp relay information remote-id string “Sysname” command.
# Configure the padding content for the remote ID sub-option as device001.
[Sysname-Vlan-interface1] dhcp relay information remote-id string device001
undo dhcp relay information strategy
View
Interface view
Default Level
2: System level
drop: Specifies to drop messages containing Option 82.
keep: Specifies to forward messages containing Option 82 without any change.
replace: Specifies to forward messages containing Option 82 after replacing the original Option 82 with the Option 82 padded in the specified padding format.
Use the dhcp relay information strategy command to configure DHCP relay agent handling strategy for messages containing Option 82.
Use the undo dhcp relay information strategy command to restore the default handling strategy.
The handling strategy for messages containing Option 82 defaults to replace.
# Configure the DHCP relay agent handling strategy for messages containing Option 82 as keep.
[Sysname-Vlan-interface1] dhcp relay information strategy keep
dhcp relay release ip
dhcp relay release ip client-ip
View
Default Level
2: System level
client-ip: DHCP client IP address.
Use the dhcp relay release ip command to request the DHCP server to release a specified client IP address.
# Request the DHCP server to release the IP address 1.1.1.1.
[Sysname] dhcp relay release ip 1.1.1.1
dhcp relay security static
dhcp relay security static ip-address mac-address [ interface interface-type interface-number ]
undo dhcp relay security { ip-address | all | dynamic | static }
View
Default Level
2: System level
ip-address: Client IP address for creating a static binding.
mac-address: Client MAC address for creating a static binding, in the format H-H-H.
interface interface-type interface-number: Specifies a Layer 3 interface connecting to the DHCP client. interface-type interface-number specifies the interface type and interface number.
all: Specifies all client entries to be removed.
dynamic: Specifies dynamic client entries to be removed.
static: Specifies manual client entries to be removed.
Use the dhcp relay security static command to configure a static client entry, that is, the binding between IP address, MAC address, and Layer 3 interface on the relay agent.
Use the undo dhcp relay security command to remove specified client entries from the relay agent.
No manual client entry is configured on the DHCP relay agent by default.
Note that: When using the dhcp relay security static command to bind an interface to a static client entry, make sure that the interface is configured as a DHCP relay agent; otherwise, entry conflicts may occur.
Related commands: display dhcp relay security.
# Bind DHCP relay interface VLAN-interface 2 to IP address 10.10.1.1 and MAC address 0005-5d02-f2b3 of the client.
[Sysname] dhcp relay security static 10.10.1.1 0005-5d02-f2b3 interface vlan-interface 2
dhcp relay security tracker { interval | auto }
undo dhcp relay security tracker [ interval ]
View
Default Level
2: System level
interval: Refreshing interval in seconds, in the range of 1 to 120.
auto: Specifies the auto refreshing interval, which is the value of 60 seconds divided by the number of binding entries. Thus, the more entries are, the shorter interval is, but the shortest interval is no less than 500 ms.
Use the dhcp relay security tracker command to set a refreshing interval at which the relay agent contacts the DHCP server for refreshing dynamic bindings.
Use the undo dhcp relay security tracker command to restore the default interval.
The default refreshing interval is auto, the value of 60 seconds divided by the number of binding entries.
# Set the refreshing interval as 100 seconds.
[Sysname] dhcp relay security tracker 100
dhcp relay server-detect
undo dhcp relay server-detect
View
Default Level
2: System level
None
Use the dhcp relay server-detect command to enable unauthorized DHCP server detection.
Use the undo dhcp relay server-detect command to disable unauthorized DHCP server detection.
By default, unauthorized DHCP server detection is disabled.
[Sysname] dhcp relay server-detect
dhcp relay server-group group-id ip ip-address
undo dhcp relay server-group group-id [ ip ip-address ]
View
Default Level
2: System level
group-id: DHCP server group number, in the range of 0 to 19.
ip ip-address: DHCP server IP address.
Use the dhcp relay server-group command to specify a DHCP server for a DHCP server group.
Use the undo dhcp relay server-group command to remove a DHCP server from a DHCP server group, if no ip ip-address is specified, all servers in the DHCP server group and the server group itself will be removed.
By default, no DHCP server is specified for a DHCP server group.
Note that:
l The IP address of any DHCP server and any interface’s IP address of the DHCP relay agent cannot be in the same network segment. Otherwise, the client may fail to obtain an IP address.
l If a server group has been correlated to multiple interfaces, you need to cancel these correlations before removing the server group.
Related commands: display dhcp relay server-group.
# Specify DHCP server 1.1.1.1 for DHCP server group 1 on the relay agent.
[Sysname] dhcp relay server-group 1 ip 1.1.1.1
dhcp relay server-select
dhcp relay server-select group-id
undo dhcp relay server-select
View
Interface view
Default Level
2: System level
group-id: DHCP server group number to be correlated, in the range of 0 to 19. The specified server group must be an existing group containing at least a DHCP server.
Use the dhcp relay server-select command to correlate specified interface(s) to a specified DHCP server group.
Use the undo dhcp relay server-select command to remove a configured correlation.
By default, no DHCP server group is correlated with an interface on the relay agent.
Note that an interface on the relay agent can only be correlated to one DHCP server group, and a newly configured correlation overwrites the previous one. If the server group in the new correlation does not exist, the new configuration will not work. The interface still maintains the previous correlation.
# Correlate VLAN-interface 1 to DHCP server group 1.
[Sysname-Vlan-interface1] dhcp relay server-select 1
dhcp select relay
dhcp select relay
undo dhcp select relay
View
Interface view
Default Level
2: System level
None
Use the dhcp select relay command to enable the relay agent on the current interface. Upon receiving requests from an enabled interface, the relay agent will forward these requests to outside DHCP servers for IP address allocation.
Use the undo dhcp select relay command to restore the default.
After DHCP is enabled, the DHCP server is enabled on an interface by default. That is, upon receiving a client’s request from the interface, the DHCP server allocates an IP address from the DHCP address pool to the client.
# Enable the DHCP relay agent on VLAN-interface 1.
[Sysname-Vlan-interface1] dhcp select relay
display dhcp relay
display dhcp relay { all | interface interface-type interface-number }
View
Default Level
1: Monitor level
all: Displays information of DHCP server groups that all interfaces correspond to.
interface interface-type interface-number: Displays information of the DHCP server group that a specified interface corresponds to.
Use the display dhcp relay command to display information about DHCP server groups correlated to an interface or all interfaces.
# Display information about DHCP server groups correlated to all interfaces.
<Sysname> display dhcp relay all
Interface name Server-group
Vlan-interface2 2
Table 2-1 display dhcp relay all command output description
Interface name |
Interface name |
Server-group |
DHCP server group number correlated to the interface. |
display dhcp relay information { all | interface interface-type interface-number }
View
Default Level
1: Monitor level
all: Displays the Option 82 configuration information of all interfaces.
interface interface-type interface-number: Displays the Option 82 configuration information of a specified interface.
Use the display dhcp relay information command to display Option 82 configuration information on the DHCP relay agent.
# Display the Option 82 configuration information of all interfaces.
<Sysname> display dhcp relay information all
Interface: Vlan-interface100
Status: Enable
Strategy: Replace
Format: Verbose
Circuit ID format-type: HEX
Remote ID format-type: ASCII
Node identifier: abaci
User defined:
Circuit ID: company001
Interface: Vlan-interface200
Status: Enable
Strategy: Keep
Format: Normal
User defined:
Remote ID: device001
display dhcp relay security [ ip-address | dynamic | static ]
View
Default Level
1: Monitor level
ip-address: Displays the binding information of an IP address.
dynamic: Displays information about dynamic bindings.
static: Displays information about static bindings.
Use the display dhcp relay security command to display information about bindings of DHCP relay agents. If no parameter is specified, information about all bindings will be displayed.
# Display information about all bindings.
<Sysname> display dhcp relay security
IP Address MAC Address Type Interface
10.1.1.1 00e0-0000-0001 Static Eth1/1
10.1.1.5 00e0-0000-0000 Static Vlan2
--- 2 dhcp-security item(s) found ---
Table 2-2 display dhcp relay security command output description
IP Address |
Client IP address |
MAC Address |
Client MAC address |
Type |
Type of binding, including dynamic, static, and temporary. |
Layer 3 interface connecting to the DHCP client. If no interface is recorded in the binding entry, “N/A” is displayed. |
View
Default Level
1: Monitor level
None
Use the display dhcp relay security statistics command to display statistics information about bindings of DHCP relay agents.
# Display statistics about bindings of DHCP relay agents.
<Sysname> display dhcp relay security statistics
Static Items :1
Dynamic Items :0
Temporary Items :0
All Items :1
Table 2-3 display dhcp relay security statistics command output description
Static Items |
Static binding items |
Dynamic Items |
Dynamic binding items |
Temporary Items |
Temporary binding items |
All Items |
All binding items |
View
Default Level
1: Monitor level
None
Use the display dhcp relay security tracker command to display the interval for refreshing dynamic bindings on the relay agent.
# Display the interval for refreshing dynamic bindings on the relay agent.
<Sysname> display dhcp relay security tracker
Current tracker interval : 10s
The interval is 10 seconds.
display dhcp relay server-group { group-id | all }
View
Default Level
1: Monitor level
group-id: Displays the information of the specified DHCP server group numbered from 0 to 19.
all: Displays the information of all DHCP server groups.
Use the display dhcp relay server-group command to display the configuration information of a specified or all DHCP server groups.
# Display IP addresses of DHCP servers in DHCP server group 1.
<Sysname> display dhcp relay server-group 1
No. Group IP
1 1.1.1.1
2 1.1.1.2
Table 2-4 display dhcp relay server-group command output description
No. |
Sequence number |
Group IP |
IP address in the server group |
display dhcp relay statistics
display dhcp relay statistics [ server-group { group-id | all } ]
View
Default Level
1: Monitor level
group-id: Specifies a server group number in the range of 0 to 19 about which to display DHCP packet statistics.
all: Specifies all server groups about which to display DHCP packet statistics. Information for each group will be displayed.
Use the display dhcp relay statistics command to display DHCP packet statistics related to a specified or all DHCP server groups.
Note that if no parameter (server-group and all) is specified, all DHCP packet statistics on the relay agent will be displayed.
# Display all DHCP packet statistics on the relay agent.
<Sysname> display dhcp relay statistics
Bad packets received: 0
DHCP packets received from clients: 0
DHCPDISCOVER packets received: 0
DHCPREQUEST packets received: 0
DHCPINFORM packets received: 0
DHCPRELEASE packets received: 0
DHCPDECLINE packets received: 0
BOOTPREQUEST packets received: 0
DHCP packets received from servers: 0
DHCPOFFER packets received: 0
DHCPACK packets received: 0
DHCPNAK packets received: 0
BOOTPREPLY packets received: 0
DHCP packets relayed to servers: 0
DHCPDISCOVER packets relayed: 0
DHCPREQUEST packets relayed: 0
DHCPINFORM packets relayed: 0
DHCPRELEASE packets relayed: 0
DHCPDECLINE packets relayed: 0
BOOTPREQUEST packets relayed: 0
DHCP packets relayed to clients: 0
DHCPOFFER packets relayed: 0
DHCPACK packets relayed: 0
DHCPNAK packets relayed: 0
BOOTPREPLY packets relayed: 0
DHCP packets sent to servers: 0
DHCPDISCOVER packets sent: 0
DHCPREQUEST packets sent: 0
DHCPINFORM packets sent: 0
DHCPRELEASE packets sent: 0
DHCPDECLINE packets sent: 0
BOOTPREQUEST packets sent: 0
DHCP packets sent to clients: 0
DHCPOFFER packets sent: 0
DHCPACK packets sent: 0
DHCPNAK packets sent: 0
BOOTPREPLY packets sent: 0
# Display DHCP packet statistics related to every server group on the relay agent.
<Sysname> display dhcp relay statistics server-group all
DHCP relay server-group #0
Packet type Packet number
Client -> Server:
DHCPDISCOVER 0
DHCPREQUEST 0
DHCPINFORM 0
DHCPRELEASE 0
DHCPDECLINE 0
BOOTPREQUEST 0
Server -> Client:
DHCPOFFER 0
DHCPACK 0
DHCPNAK 0
BOOTPREPLY 0
reset dhcp relay statistics
reset dhcp relay statistics [ server-group group-id ]
View
Default Level
1: Monitor level
server-group group-id: Specifies a server group ID (in the range of 0 to 19) about which to remove statistics from the relay agent.
Use the reset dhcp relay statistics command to remove statistics from the relay agent.
If no server-group is specified, all statistics will be removed from the relay agent.
Related commands: display dhcp relay statistics.
# Remove all statistics from the DHCP relay agent.
<Sysname> reset dhcp relay statistics
l The DHCP client configuration is supported only on VLAN interfaces.
l When multiple VLAN interfaces having the same MAC address use DHCP for IP address acquisition via a relay agent, the DHCP server cannot be the Windows 2000 Server or Windows 2003 Server.
l You are not recommended to enable both the DHCP client and the DHCP snooping on the same switch. Otherwise, DHCP snooping entries may fail to be generated, or the DHCP client may fail to obtain an IP address.
l You cannot configure an interface of an aggregation group as a DHCP client.
display dhcp client
View
Default Level
1: Monitor level
verbose: Specifies verbose DHCP client information to be displayed.
interface interface-type interface-number: Specifies an interface of which to display DHCP client information.
Use the display dhcp client command to display DHCP client information. If no interface interface-type interface-number is specified, DHCP client information of all interfaces will be displayed.
# Display DHCP client information of all interfaces.
<Sysname> display dhcp client
Vlan-interface1 DHCP client information:
Current machine state: BOUND
Allocated IP: 40.1.1.20 255.255.255.0
Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
DHCP server: 40.1.1.2
# Display verbose DHCP client information.
<Sysname> display dhcp client verbose
Lease from 2005.08.13 15:37:59 to 2005.08.16 15:37:59
Transaction ID: 0x1c09322d
Default router: 40.1.1.2
DNS server: 44.1.1.11
DNS server: 44.1.1.12
Domain name: ddd.com
Boot server: 200.200.200.200 1.1.1.1
Client ID: 3030-3066-2e65-3234-
392e-3830-3438-2d56-
6c61-6e2d-696e-7465-
7266-6163-6531
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
Table 3-1 display dhcp client command output description
Vlan-interface1 DHCP client information |
Information of the interface acting as the DHCP client |
Current machine state |
DHCP client current machine state |
Allocated IP |
The IP address allocated by the DHCP server |
Allocated lease |
The allocated lease time |
T1 |
The 1/2 lease time (in seconds) of the DHCP client IP address |
T2 |
The 7/8 lease time (in seconds) of the DHCP client IP address |
Lease from….to…. |
The start and end time of the lease. |
DHCP Server |
DHCP server IP address that assigned the IP address |
Transaction ID |
Transaction ID, a random number chosen by the client to identify an IP address allocation. |
Default router |
The gateway address assigned to the client |
DNS server |
The DNS server address assigned to the client |
Domain name |
The domain name suffix assigned to the client |
Boot server |
PXE server addresses (up to 16 addresses) specified for the DHCP client, which are obtained through Option 43. |
Client ID |
Client ID |
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds. |
How long the T1 (1/2 lease time) timer will timeout. |
ip address dhcp-alloc
ip address dhcp-alloc [ client-identifier mac interface-type interface-number ]
undo ip address dhcp-alloc
View
Interface view
Default Level
2: System level
client-identifier mac interface-type interface-number: Specifies the MAC address of an interface using which as the client ID to obtain an IP address.
Use the ip address dhcp-alloc command to configure an interface to use DHCP for IP address acquisition.
Use the undo ip address dhcp-alloc command to cancel an interface from using DHCP.
By default, an interface does not use DHCP for IP address acquisition.
Note that:
l If no parameter is specified, the client uses a character string comprised of the current interface name and MAC address as its ID for address acquisition.
l The DHCP client sends a DHCP-RELEASE message for releasing the IP address obtained via DHCP, if the interface of the client is down, the message cannot be sent.
l For a sub interface that obtained an IP address via DHCP, using the shutdown command on its primary interface does not make the DHCP client send a DHCP-RELEASE message for releasing the sub interface’s IP address.
# Configure VLAN-interface 1 to use DHCP for IP address acquisition.
[Sysname-Vlan-interface1] ip address dhcp-alloc
l DHCP snooping supports no link aggregation. If an Ethernet port is added into an aggregation group, DHCP snooping configuration on it will not take effect. When the port is removed from the group, DHCP snooping can take effect.
l The DHCP snooping enabled switch does not work if it is between the DHCP relay agent and DHCP server, and it can work when it is between the DHCP client and relay agent or between the DHCP client and server.
l The DHCP snooping enabled switch cannot be a DHCP server or DHCP relay agent.
l You are not recommended to enable the DHCP client, and DHCP snooping on the same switch. Otherwise, DHCP snooping entries may fail to be generated, or the DHCP client may fail to obtain an IP address.
dhcp-snooping
dhcp-snooping
undo dhcp-snooping
View
Default Level
2: System level
None
Use the dhcp-snooping command to enable DHCP snooping.
Use the undo dhcp-snooping command to disable DHCP snooping.
With DHCP snooping disabled, all ports can forward responses from any DHCP servers and does not record binding information about MAC addresses of DHCP clients and the obtained IP addresses.
By default, DHCP snooping is disabled.
Related commands: display dhcp-snooping.
# Enable DHCP snooping.
[Sysname] dhcp-snooping
dhcp-snooping information circuit-id format-type { ascii | hex }
undo dhcp-snooping information circuit-id format-type
View
Ethernet port view
Default Level
2: System level
Use the dhcp-snooping information circuit-id format-type command to configure the code type for the non-user-defined circuit ID sub-option.
Use the undo dhcp-snooping information circuit-id format-type command to restore the default.
By default, the code type for the circuit ID sub-option depends on the padding format of Option 82. Each field has its own code type.
Note that:
This command applies to configuring the non-user-defined circuit ID sub-option only. After you configure the padding content for the circuit ID sub-option using the dhcp-snooping information circuit-id string command, ASCII is adopted as the code type.
# Configure the padding format for the non-user-defined circuit ID sub-option as ascii.
[Sysname-GigabitEthernet2/0/1] dhcp-snooping information circuit-id format-type ascii
dhcp-snooping information [ vlan vlan-id ] circuit-id string circuit-id
undo dhcp-snooping information [ vlan vlan-id ] circuit-id string
View
Ethernet port view
Default Level
2: System level
vlan vlan-id: Specifies a VLAN ID, in the range of 1 to 4094.
Use the dhcp-snooping information circuit-id string command to configure the padding content for the user-defined circuit ID sub-option.
Use the undo dhcp-snooping information circuit-id string command to restore the default.
Note that:
l After you configure the padding content for the circuit ID sub-option using this command, ASCII is adopted as the code type.
l If a VLAN is specified, the configured circuit ID sub-option only takes effect within the VLAN; if no VLAN is specified, the configured circuit ID sub-option takes effect in all VLANs. The former case has a higher priority; that is, the circuit ID sub-option specified for a VLAN will be padded for packets within the VLAN.
Related commands: dhcp-snooping information format.
# Configure the global padding content for the user-defined circuit ID sub-option as company001.
[Sysname-GigabitEthernet2/0/1] dhcp-snooping information circuit-id string company001
dhcp-snooping information enable
undo dhcp-snooping information enable
View
Ethernet port view
Default Level
2: System level
None
Use the dhcp-snooping information enable command to configure DHCP snooping to support Option 82.
Use the undo dhcp-snooping information enable command to disable this function.
By default, DHCP snooping does not support Option 82.
# Configure DHCP snooping to support Option 82.
[Sysname] interface gigabitethernet2/0/1
[Sysname-GigabitEthernet2/0/1] dhcp-snooping information enable
dhcp-snooping information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
undo dhcp-snooping information format [ verbose node-identifier ]
View
Ethernet port view
Default Level
2: System level
l user-defined node-identifier indicates using a specified character string as the node identifier, in which node-identifier is a string of 1 to 50 characters.
Use the dhcp-snooping information format command to specify the padding format for Option 82.
Use the undo dhcp-snooping information format command to restore the default.
By default, the padding format for Option 82 is normal.
Note that when you use the undo dhcp-snooping information format command, if the verbose node-identifier argument is not specified, the padding format will be restored to normal; if the verbose node-identifier argument is specified, the padding format will be restored to verbose with MAC address as the node identifier.
# Specify the padding format as verbose for Option 82.
[Sysname-GigabitEthernet2/0/1] dhcp-snooping information strategy replace
[Sysname-GigabitEthernet2/0/1] dhcp-snooping information format verbose
dhcp-snooping information remote-id format-type
dhcp-snooping information remote-id format-type { ascii | hex }
undo dhcp-snooping information remote-id format-type
View
Ethernet port view
Default Level
2: System level
Use the dhcp-snooping information remote-id format-type command to configure the code type for the non-user-defined remote ID sub-option.
Use the undo dhcp-snooping information remote-id format-type command to restore the default.
Note that:
This command applies to configuring a non-user-defined remote ID sub-option only. After you configure the padding content for the remote ID sub-option using the dhcp-snooping information remote-id string command, ASCII is adopted as the code type.
[Sysname-GigabitEthernet2/0/1] dhcp-snooping information remote-id format-type ascii
dhcp-snooping information [ vlan vlan-id ] remote-id string { remote-id | sysname }
undo dhcp-snooping information [ vlan vlan-id ] remote-id string
View
Ethernet port view
Default Level
2: System level
remote-id: Padding content for the user-defined circuit ID sub-option, a case-sensitive string of 1 to 63 characters.
Use the dhcp-snooping information remote-id string command to configure the padding content for the user-defined remote ID sub-option.
Use the undo dhcp-snooping information remote-id string command to restore the default.
Note that:
l After you configure the padding content for the remote ID sub-option using this command, ASCII is adopted as the code type.
l If a VLAN is specified, the configured remote ID sub-option only takes effect within the VLAN; if no VLAN is specified, the configured remote ID sub-option takes effect in all VLANs. The former case has a higher priority; that is, the remote ID sub-option configured for a VLAN will be padded for the packets within the VLAN.
[Sysname-GigabitEthernet2/0/1] dhcp-snooping information remote-id string device001
dhcp-snooping information strategy { drop | keep | replace }
undo dhcp-snooping information strategy
View
Ethernet port view
Default Level
2: System level
drop: Drops the requesting message containing Option 82.
keep: Forwards the requesting message containing Option 82 without changing Option 82.
replace: Forwards the requesting message containing Option 82 after replacing the original Option 82 with the one padded in specified format.
Use the dhcp-snooping information strategy command to configure the handling strategy for Option 82 in requesting messages.
Use the undo dhcp-snooping information strategy command to restore the default.
By default, the handling strategy for Option 82 in requesting messages is replace.
# Configure the handling strategy for Option 82 in requesting messages as keep.
[Sysname-GigabitEthernet2/0/1] dhcp-snooping information strategy keep
dhcp-snooping trust
dhcp-snooping trust [ no-user-binding ]
undo dhcp-snooping trust
View
Ethernet port view
Default Level
2: System level
no-user-binding: Specifies the port not to record the clients’ IP-to-MAC bindings in DHCP requests it receives. The command without this keyword records the IP-to-MAC bindings of clients.
Use the dhcp-snooping trust command to configure a port as a trusted port.
Use the undo dhcp-snooping trust command to restore the default state of a port.
All ports are untrusted by default.
Related commands: display dhcp-snooping trust.
# Specify GigabitEthernet 2/0/1 as a trusted port and enable it to record the IP-to-MAC bindings of clients.
[Sysname-GigabitEthernet2/0/1] dhcp-snooping trust
display dhcp-snooping [ ip ip-address ]
View
Default Level
1: Monitor level
ip ip-address: Displays the DHCP snooping IP-to-MAC binding corresponding to the specified IP address.
Use the display dhcp-snooping command to display the IP-to-MAC bindings recorded by the DHCP snooping device.
Related commands: dhcp-snooping.
Using the display dhcp-snooping command displays IP-to-MAC bindings that are present both in the DHCP-ACK and DHCP-REQUEST messages.
# Display all IP-to-MAC bindings recorded by the DHCP snooping device.
<Sysname> display dhcp-snooping
DHCP Snooping is enabled.
The client binding table for all untrusted ports.
Type : D--Dynamic , S--Static
Type IP Address MAC Address Lease VLAN Interface
D 10.1.1.1 000f-e200-0006 286 1 GigabitEthernet2/0/1
--- 1 dhcp-snooping item(s) found ---
Table 4-1 display dhcp snooping command output description
Type |
Binding type |
IP Address |
IP address assigned to the DHCP client |
MAC Address |
MAC address of the DHCP client |
Lease |
Lease period left (in seconds) |
VLAN |
VLAN where the port connecting the DHCP client resides |
Port to which the DHCP client is connected |
display dhcp-snooping information
display dhcp-snooping information { all | interface interface-type interface-number }
View
Default Level
1: Monitor level
all: Displays the Option 82 configuration information of all Ethernet ports.
Use the display dhcp-snooping information command to display Option 82 configuration information on the DHCP snooping device.
<Sysname> display dhcp-snooping information all
Interface: GigabitEthernet 2/0/1
Status: Enable
Strategy: Replace
Format: Verbose
Node identifier: aabbcc
User defined:
Interface: GigabitEthernet 2/0//2
Status: Disable
Strategy: Keep
Format: Normal
User defined:
VLAN 10:
Circuit ID: vlan10@company001
VLAN 20:
display dhcp-snooping packet statistics
display dhcp-snooping packet statistics [ slot slot-number ]
View
Default Level
1: Monitor level
slot slot-number: Displays the DHCP packet statistics of the board in a specified slot.
Use the display dhcp-snooping packet statistics command to display DHCP packet statistics on the DHCP snooping device.
On the S7500E series Ethernet switches, executing the display dhcp-snooping packet statistics command without the slot keyword only displays DHCP packet statistics on the SRPU.
# Display DHCP packet statistics on the DHCP snooping device.
<Sysname> display dhcp-snooping packet statistics
DHCP packets received : 100
DHCP packets sent : 200
Packets dropped due to rate limitation : 20
Dropped invalid packets : 0
View
Default Level
1: Monitor level
None
Use the display dhcp-snooping trust command to display information about trusted ports.
Related commands: dhcp-snooping trust.
# Display information about trusted ports.
<Sysname> display dhcp-snooping trust
DHCP Snooping trust becomes active.
Interface Trusted
GigabitEthernet2/0/1 Trusted
The above output shows that DHCP snooping is enabled, DHCP snooping trust is active, and port GigabitEthernet 2/0/1 is trusted.
reset dhcp-snooping
reset dhcp-snooping { all | ip ip-address }
View
Default Level
1: Monitor level
all: Clears all DHCP snooping binding information.
ip ip-address: Clears the DHCP snooping binding information of the specified IP address.
Use the reset dhcp-snooping command to clear DHCP snooping binding information.
For the S7500E series Ethernet switches, DHCP snooping binding information on all slots will be cleared after you execute this command.
# Clear all DHCP binding information.
<Sysname> reset dhcp-snooping all
reset dhcp-snooping packet statistics
reset dhcp-snooping packet statistics [ slot slot-number ]
View
Default Level
2: System level
slot slot-number: Clears the DHCP packet statistics of the board in a specified slot.
Use the reset dhcp-snooping packet statistics command to clear DHCP packet statistics on the DHCP snooping device.
On the S7500E series Ethernet switches, executing the reset dhcp-snooping packet statistics command without the slot keyword only clears DHCP packet statistics on the SRPU.
# Clear DHCP packet statistics on the DHCP snooping device.
<Sysname> reset dhcp-snooping packet statistics
