| 06-UDP Helper Commands | 24.68 KB |
UDP Helper Configuration Commands
display udp-helper server
display udp-helper server [ interface interface-type interface-number ]
View
Default Level
2: System level
interface interface-type interface-number: Displays information of forwarded UDP packets on the specified interface.
Use the display udp-helper server command to display the information of forwarded UDP packets on the specified interface or all interfaces.
If interface-type interface-number is not specified, this command displays the information of forwarded UDP packets on all interfaces.
# Display the information of forwarded UDP packets on the interface VLAN-interface 1.
<Sysname> display udp-helper server interface vlan-interface 1
Interface name Server address Packets sent
Vlan-interface1 192.1.1.2 0
reset udp-helper packet
View
Default Level
2: System level
None
Use the reset udp-helper packet command to clear the statistics of UDP packets forwarded.
Related commands: display udp-helper server.
# Clear the statistics of the forwarded UDP packets.
<Sysname> reset udp-helper packet
udp-helper enable
udp-helper enable
undo udp-helper enable
View
Default Level
2: System level
None
Use the udp-helper enable command to enable UDP Helper. The device enabled with UDP Helper functions as a relay agent that converts UDP broadcast packets into unicast packets and forwards them to a specified destination server.
Use the undo udp-helper enable command to disable UDP Helper.
By default, UDP Helper is disabled.
# Enable UDP Helper
[Sysname] udp-helper enable
udp-helper port
undo udp-helper port { port-number | dns | netbios-ds | netbios-ns | tacacs | tftp | time }
View
Default Level
2: System level
port-number: UDP port number with which packets need to be forwarded, in the range of 1 to 65535 (except 67 and 68).
dns: Forwards DNS data packets. The corresponding UDP port number is 53.
netbios-ds: Forwards NetBIOS data packets. The corresponding UDP port number is 138.
netbios-ns: Forwards NetBIOS name service data packets. The corresponding UDP port number is 137.
tacacs: Forwards terminal access controller access control system (TACACS) data packet. The corresponding UDP port number is 49.
tftp: Forwards TFTP data packets. The corresponding UDP port number is 69.
time: Forwards time service data packets. The corresponding UDP port number is 37.
Use the udp-helper port command to enable the forwarding of packets with the specified UDP port number.
Use the undo udp-helper port command to remove the configured UDP port numbers.
By default, no UDP port number is specified.
The specified UDP port numbers will all be removed if UDP Helper is disabled.
# Forward broadcast packets with the UDP destination port number 100.
[Sysname] udp-helper port 100
udp-helper server
udp-helper server ip-address
undo udp-helper server [ ip-address ]
View
Interface view
Default Level
2: System level
ip-address: IP address of the destination server, in dotted decimal notation.
Use the udp-helper server command to specify the destination server which UDP packets need to be forwarded to.
Use the undo udp-helper server command to remove the destination server.
No destination server is configured by default.
Currently, you can configure up to 20 destination servers on an interface.
Note that you will remove all the destination servers on an interface if you carry out the undo udp-helper server command without the ip-address argument.
# Specify the IP address of the destination server as 192.1.1.2 on the interface VLAN-interface 100.
[Sysname-Vlan-interface100] udp-helper server 192.1.1.2
