00-Feature List and Command Index
HomeSupportSwitchesH3C S7500E Switch SeriesReference GuidesCommand ReferencesH3C S7500E Series Ethernet Switches Command Manual(Release 6300 series V1.03)00-Feature List and Command Index
01-Feature List and Command Index
01-Feature List and Command Index 189.88 KB
The S7500E series support abundant features and the related documents are divided into the volumes as listed in Table 1-1.
Table 1-1 Feature list
Volume
Features
01-Access Volume
Ethernet Interface
Link Aggregation
Port Isolation
Service Loopback Group
DLDP
Smart Link
LLDP
VLAN
GVRP
QinQ
BPDU Tunneling
VLAN Mapping
Ethernet OAM
Connectivity Fault Detection
EPON OLT
MSTP
RRPP
Mirroring
02-IP Services Volume
IP Addressing
ARP
DHCP
DNS
IP Performance
UDP Helper
URPF
IPv6 Basics
Tunneling
sFlow
03-IP Routing Volume
IP Routing Table Display
Static Routing
RIP
OSPF
IS-IS
BGP
IPv6 Static Routing
IPv6 RIPng
IPv6 OSPFv3
IPv6 IS-IS
IPv6 BGP
Route Policy
04-IP Multicast Volume
Multicast Routing and Forwarding
IGMP
PIM
MSDP
MBGP
Multicast VPN
IGMP Snooping
Multicast VLAN
IPv6 Multicast Routing and Forwarding
MLD
IPv6 PIM
IPv6 MBGP
MLD Snooping
IPv6 Multicast VLAN
05-MPLS Volume
MCE
MPLS Basics
MPLS L2VPN
MPLS L3VPN
06-QoS Volume
QoS
07-Security Volume
AAA
802.1X
MAC Authentication
Portal
Port Security
IP Source Guard
SSH2.0
ACL
08-System Volume
Login
Basic System Configuration
Device Management
File System Management
SNMP
RMON
MAC Address Table Management
System Maintaining and Debugging
Information Center
PoE
Track
NQA
NTP
VRRP
HA
Hotfix
Command Index
The command index includes all the commands in the Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
abr-summary (OSPF area view)
IP Routing Volume-04-OSPF Commands
1-1
abr-summary (OSPFv3 area view)
IP Routing Volume-09-IPv6 OSPFv3 commands
1-1
access-limit
Security Volume-01-AAA Commands
1-1
accounting
QoS Volume-01-QoS Commands
2-5
accounting default
1-1
accounting lan-access
1-3
accounting login
1-3
accounting optional
1-4
accounting portal
1-5
acl
Security Volume-08-ACL Commands
1-5
acl
System Volume-01-Login Commands
2-1
acl copy
1-7
acl ipv6
1-20
acl ipv6 copy
1-22
acl ipv6 name
1-23
acl name
1-8
activation-key
1-1
active region-configuration
Access Volume-16-MSTP Commands
1-1
aggregate
IP Routing Volume-06-BGP Commands
1-1
aggregate (MBGP family view)
IP Multicast Volume-05-MBGP Commands
1-1
alarm bit-error-rate
Access Volume-15-EPON OLT Commands
3-1
alarm bit-error-rate enable
3-2
alarm device-fatal-error enable
3-2
alarm frame-error-rate
3-3
alarm frame-error-rate enable
3-4
alarm llid-mismatch enable
3-4
alarm llid-mismatch threshold
3-5
alarm local-stable enable
3-6
alarm oam critical-event enable
3-6
alarm oam dying-gasp enable
3-7
alarm oam error-frame
3-11
alarm oam error-frame enable
3-12
alarm oam error-frame-period
3-10
alarm oam error-frame-period enable
3-11
alarm oam error-frame-seconds-summary
3-13
alarm oam error-frame-seconds-summary enable
3-14
alarm oam error-symbol-period
3-8
alarm oam error-symbol-period enable
3-9
alarm oam local-link-fault enable
3-15
alarm oam-vendor-specific enable
3-15
alarm onu-over-limitation enable
3-16
alarm port bit-error-rate enable
3-17
alarm registration-error enable
3-17
alarm remote-stable enable
3-18
alarm software-error enable
3-19
apply as-path
IP Routing Volume-12-Route Policy Commands
1-1
apply comm-list delete
1-2
apply community
1-2
apply cost
1-3
apply cost-type
1-4
apply extcommunity
1-5
apply ip-address next-hop
1-22
apply ipv6 next-hop
1-27
apply isis
1-6
apply local-preference
1-6
apply mpls-label
1-7
apply origin
1-8
apply poe-profile
System Volume-10-PoE Commands
1-1
apply poe-profile interface
1-2
apply preference
1-8
apply preferred-value
1-9
apply tag
1-10
area (OSPF view)
1-2
area (OSPFv3 view)
1-2
area-authentication-mode
IP Routing Volume-05-IS-IS Commands
1-1
arp check enable
IP Services Volume-02-ARP Commands
1-1
arp detection enable
3-3
arp detection trust
3-4
arp detection validate
3-5
arp max-learning-num
1-1
arp rate-limit
3-5
arp resolving-route enable
3-3
arp source-suppression enable
3-1
arp source-suppression limit
3-1
arp static
1-2
arp timer aging
1-3
asbr-summary
1-2
ascii
System Volume-04-File System Management Commands
2-6
attribute
1-6
authentication default
1-7
authentication lan-access
1-8
authentication login
1-9
authentication portal
1-10
authentication-mode
1-4
authentication-mode
1-2
authorization command
1-10
authorization default
1-11
authorization lan-access
1-12
authorization login
1-13
authorization portal
1-14
auto-cost enable
1-2
auto-execute command
1-3
auto-rp enable
IP Multicast Volume-03-PIM Commands
1-1
B
backup startup-configuration
1-15
balance (BGP/BGP-VPN instance view)
1-2
balance (IPv6 address family view)
IP Routing Volume-11-IPv6 BGP Commands
1-1
balance (IPv6 MBGP address family view)
IP Multicast Volume-12-IPv6 MBGP Commands
1-1
balance (MBGP family view)
1-2
bandwidth downstream
6-1
bandwidth downstream high-priority enable
6-2
bandwidth downstream policy enable
6-2
bandwidth downstream priority-queue
6-3
bandwidth-reference
1-2
bandwidth-reference (IS-IS view)
1-3
bandwidth-reference (OSPF view)
1-4
bestroute as-path-neglect (BGP/BGP-VPN instance view)
1-3
bestroute as-path-neglect (IPv6 address family view)
1-2
bestroute as-path-neglect (IPv6 MBGP address family view)
1-1
bestroute as-path-neglect (MBGP family view)
1-3
bestroute compare-med (BGP/BGP-VPN instance view)
1-4
bestroute compare-med (IPv6 address family view)
1-2
bestroute compare-med (IPv6 MBGP address family view)
1-2
bestroute compare-med (MBGP family view)
1-4
bestroute med-confederation (BGP/BGP-VPN instance view)
1-5
bestroute med-confederation (IPv6 address family view)
1-3
bestroute med-confederation (IPv6 MBGP address family view)
1-3
bestroute med-confederation (MBGP family view)
1-4
bgp
1-5
bims-server
IP Services Volume-03-DHCP Commands
1-1
binary
2-6
bind onuid
2-1
bootfile-name
1-2
boot-loader
System Volume-03-Device Management Commands
1-1
bootrom
1-2
bpdu-tunnel dot1q stp
Access Volume-11-BPDU Tunneling Commands
1-1
bpdu-tunnel tunnel-dmac
1-2
broadcast-suppression
Access Volume-01-Ethernet Interface Commands
1-1
bsr-policy (IPv6 PIM view)
IP Multicast Volume-11-IPv6 PIM Commands
1-1
bsr-policy (PIM view)
1-2
bye
Security Volume-07-SSH2.0 Commands
1-27
bye
2-7
C
cache-sa-enable
IP Multicast Volume-04-MSDP Commands
1-1
car
2-6
c-bsr (IPv6 PIM view)
1-2
c-bsr (PIM view)
1-2
c-bsr admin-scope
1-3
c-bsr global
1-4
c-bsr group
1-4
c-bsr hash-length (IPv6 PIM view)
1-2
c-bsr hash-length (PIM view)
1-5
c-bsr holdtime (IPv6 PIM view)
1-3
c-bsr holdtime (PIM view)
1-6
c-bsr interval (IPv6 PIM view)
1-4
c-bsr interval (PIM view)
1-7
c-bsr priority (IPv6 PIM view)
1-5
c-bsr priority (PIM view)
1-7
ccc interface in-label out-label
MPLS Volume-03-MPLS L2VPN Commands
1-1
cd
1-28
cd
1-1
cd
2-7
cdup
1-28
cdup
2-8
ce
1-2
cfd cc enable
Access Volume-14-Connectivity Fault Detection Commands
1-1
cfd cc interval
1-1
cfd enable
1-2
cfd linktrace
1-3
cfd linktrace auto-detection
1-4
cfd loopback
1-5
cfd ma
1-6
cfd md
1-7
cfd mep
1-7
cfd mep enable
1-8
cfd mip-rule
1-9
cfd remote-mep
1-10
cfd service-instance
1-11
check region-configuration
1-1
checkzero
IP Routing Volume-03-RIP Commands
1-1
checkzero
IP Routing Volume-08-IPv6 RIPng Commands
1-1
circuit-cost
1-3
classifier behavior
Access Volume-10-QinQ Commands
1-1
classifier behavior
2-17
clock datetime
System Volume-02-Basic System Configuration Commands
1-1
clock summer-time one-off
1-1
clock summer-time repeating
1-2
clock timezone
1-4
close
2-8
command-privilege level
1-5
compare-different-as-med (BGP/BGP-VPN instance view)
1-6
compare-different-as-med (IPv6 address family view)
1-4
compare-different-as-med (IPv6 MBGP address family view)
1-4
compare-different-as-med (MBGP family view)
1-5
confederation id
1-7
confederation nonstandard
1-8
confederation peer-as
1-8
connection
1-3
control-vlan
Access Volume-17-RRPP Commands
1-1
copy
1-2
cost-style
1-4
c-rp (IPv6 PIM view)
1-5
c-rp (PIM view)
1-8
c-rp advertisement-interval (IPv6 PIM view)
1-6
c-rp advertisement-interval (PIM view)
1-9
c-rp holdtime (IPv6 PIM view)
1-7
c-rp holdtime (PIM view)
1-10
crp-policy (IPv6 PIM view)
1-8
crp-policy (PIM view)
1-11
cut connection
1-15
D
dampening (BGP/BGP-VPN instance view)
1-9
dampening (IPv6 address family view)
1-4
dampening (IPv6 MBGP address family view)
1-4
dampening (MBGP family view)
1-6
databits
1-4
data-fill
System Volume-12-NQA Commands
1-1
data-flow-format (HWTACACS scheme view)
3-1
data-flow-format (RADIUS scheme view)
2-1
data-size
1-2
dba-algorithm enable
1-1
dba-algorithm update
1-2
dba-parameters
1-3
dba-report queue-id threshold
2-2
dba-report queue-set-number
2-2
debugging
2-9
debugging
System Volume-08-System Maintaining and Debugging Commands
1-6
default
1-5
default cost
1-3
default cost (RIP view)
1-2
default cost (RIPng view)
1-2
default ipv4-unicast
1-10
default local-preference (BGP/BGP-VPN instance view)
1-11
default local-preference (BGP-VPNv4 subaddress family view)
MPLS Volume-04-MPLS L3VPN Commands
1-1
default local-preference (IPv6 address family view)
1-5
default local-preference (IPv6 MBGP address family view)
1-5
default local-preference (MBGP family view)
1-6
default med (BGP/BGP-VPN instance view)
1-12
default med (BGP-VPNv4 subaddress family view)
1-2
default med (IPv6 address family view)
1-6
default med (IPv6 MBGP address family view)
1-6
default med (MBGP family view)
1-7
default-cost (OSPF area view)
1-6
default-cost (OSPFv3 area view)
1-4
default-route
1-2
default-route imported (BGP/BGP-VPN instance view)
1-13
default-route imported (IPv6 address family view)
1-7
default-route imported (IPv6 MBGP address family view)
1-7
default-route imported (MBGP family view)
1-8
default-route-advertise
1-5
default-route-advertise (IS-IS view)
1-5
default-route-advertise (OSPF view)
1-6
delete
1-29
delete
1-2
delete
2-10
delete ipv6 static-routes all
IP Routing Volume-07-IPv6 Static Routing Commands
1-1
delete static-routes all
IP Routing Volume-02-Static Routing Commands
1-1
deregister onu
2-3
description
1-2
description
Access Volume-02-Link Aggregation Commands
1-1
description
Access Volume-08-VLAN Commands
1-1
description
MPLS Volume-01-MCE Commands
1-1
description (any NQA test type view)
1-2
description (for IPv4)
1-8
description (for IPv6)
1-23
description (OSPF/OSPF area view)
1-7
description (VPN instance view)
1-2
destination
IP Services Volume-09-Tunneling Commands
1-1
destination ip
1-3
destination port
1-4
dhcp enable
1-2
dhcp relay address-check
2-1
dhcp relay information circuit-id format-type
2-2
dhcp relay information circuit-id string
2-2
dhcp relay information enable
2-3
dhcp relay information format
2-4
dhcp relay information remote-id format-type
2-5
dhcp relay information remote-id string
2-5
dhcp relay information strategy
2-6
dhcp relay release ip
2-7
dhcp relay security static
2-7
dhcp relay security tracker
2-8
dhcp relay server-detect
2-9
dhcp relay server-group
2-10
dhcp relay server-select
2-10
dhcp select relay
2-11
dhcp select server global-pool
1-3
dhcp server detect
1-4
dhcp server forbidden-ip
1-4
dhcp server ip-pool
1-5
dhcp server ping packets
1-6
dhcp server ping timeout
1-6
dhcp server relay information enable
1-7
dhcp-snooping
4-1
dhcp-snooping information circuit-id format-type
4-2
dhcp-snooping information circuit-id string
4-2
dhcp-snooping information enable
4-3
dhcp-snooping information format
4-4
dhcp-snooping information remote-id format-type
4-5
dhcp-snooping information remote-id string
4-6
dhcp-snooping information strategy
4-7
dhcp-snooping trust
4-7
dir
1-30
dir
1-3
dir
2-11
disconnect
2-12
display acl
1-9
display acl ipv6
1-24
display acl resource
1-1
display arp
1-3
display arp detection
3-6
display arp detection statistics
3-7
display arp ip-address
1-5
display arp source-suppression
3-2
display arp timer aging
1-6
display arp vpn-instance
1-6
display bgp group
1-13
display bgp ipv6 group
1-7
display bgp ipv6 multicast group
1-11
display bgp ipv6 multicast network
1-12
display bgp ipv6 multicast paths
1-13
display bgp ipv6 multicast peer
1-14
display bgp ipv6 multicast routing-table
1-15
display bgp ipv6 multicast routing-table as-path-acl
1-17
display bgp ipv6 multicast routing-table community
1-18
display bgp ipv6 multicast routing-table community-list
1-19
display bgp ipv6 multicast routing-table dampened
1-19
display bgp ipv6 multicast routing-table dampening parameter
1-20
display bgp ipv6 multicast routing-table different-origin-as
1-21
display bgp ipv6 multicast routing-table flap-info
1-22
display bgp ipv6 multicast routing-table peer
1-23
display bgp ipv6 multicast routing-table regular-expression
1-24
display bgp ipv6 multicast routing-table statistic
1-25
display bgp ipv6 network
1-9
display bgp ipv6 paths
1-10
display bgp ipv6 peer
1-11
display bgp ipv6 routing-table
1-12
display bgp ipv6 routing-table as-path-acl
1-14
display bgp ipv6 routing-table community
1-14
display bgp ipv6 routing-table community-list
1-15
display bgp ipv6 routing-table dampened
1-16
display bgp ipv6 routing-table dampening parameter
1-17
display bgp ipv6 routing-table different-origin-as
1-18
display bgp ipv6 routing-table flap-info
1-19
display bgp ipv6 routing-table peer
1-20
display bgp ipv6 routing-table regular-expression
1-21
display bgp ipv6 routing-table statistic
1-21
display bgp l2vpn
1-4
display bgp multicast group
1-12
display bgp multicast network
1-14
display bgp multicast paths
1-15
display bgp multicast peer
1-16
display bgp multicast routing-table
1-18
display bgp multicast routing-table as-path-acl
1-19
display bgp multicast routing-table cidr
1-20
display bgp multicast routing-table community
1-21
display bgp multicast routing-table community-list
1-22
display bgp multicast routing-table dampened
1-23
display bgp multicast routing-table dampening parameter
1-23
display bgp multicast routing-table different-origin-as
1-24
display bgp multicast routing-table flap-info
1-25
display bgp multicast routing-table peer
1-26
display bgp multicast routing-table regular-expression
1-27
display bgp multicast routing-table statistic
1-28
display bgp network
1-15
display bgp paths
1-16
display bgp peer
1-17
display bgp routing-table
1-19
display bgp routing-table as-path-acl
1-20
display bgp routing-table cidr
1-21
display bgp routing-table community
1-22
display bgp routing-table community-list
1-23
display bgp routing-table dampened
1-24
display bgp routing-table dampening parameter
1-24
display bgp routing-table different-origin-as
1-25
display bgp routing-table flap-info
1-26
display bgp routing-table label
1-27
display bgp routing-table peer
1-28
display bgp routing-table regular-expression
1-29
display bgp routing-table statistic
1-29
display bgp vpnv4 all routing-table
1-3
display bgp vpnv4 group
1-6
display bgp vpnv4 network
1-8
display bgp vpnv4 paths
1-9
display bgp vpnv4 peer
1-10
display bgp vpnv4 route-distinguisher routing-table
1-15
display bgp vpnv4 routing-table label
1-19
display bgp vpnv4 vpn-instance group
1-1
display bgp vpnv4 vpn-instance network
1-3
display bgp vpnv4 vpn-instance paths
1-4
display bgp vpnv4 vpn-instance peer
1-5
display bgp vpnv4 vpn-instance routing-table
1-7
1-20
display boot-loader
1-3
display brief interface
1-3
display ccc
1-9
display cfd linktrace-reply
1-12
display cfd linktrace-reply auto-detection
1-13
display cfd ma
1-14
display cfd md
1-15
display cfd mep
1-16
display cfd mp
1-18
display cfd remote-mep
1-20
display cfd service-instance
1-21
display cfd status
1-22
display channel
System Volume-09-Information Center Commands
1-1
display clipboard
1-6
display clock
1-7
display connection
1-16
display cpu-usage
1-3
display cpu-usage history
1-5
display current-configuration
1-7
display debugging
1-7
display device
1-7
display device manuinfo
1-8
display dhcp client
3-1
display dhcp relay
2-12
display dhcp relay information
2-12
display dhcp relay security
2-13
display dhcp relay security statistics
2-14
display dhcp relay security tracker
2-15
display dhcp relay server-group
2-15
display dhcp relay statistics
2-16
display dhcp server conflict
1-8
display dhcp server expired
1-8
display dhcp server forbidden-ip
1-10
display dhcp server free-ip
1-9
display dhcp server ip-in-use
1-10
display dhcp server statistics
1-11
display dhcp server tree
1-13
display dhcp-client
2-3
display dhcp-snooping
4-8
display dhcp-snooping information
4-9
display dhcp-snooping packet statistics
4-10
display dhcp-snooping trust
4-11
display diagnostic-information
1-9
display dldp
Access Volume-05-DLDP Commands
1-1
display dldp statistics
1-3
display dns domain
IP Services Volume-04-DNS Commands
1-1
display dns dynamic-host
1-2
display dns ipv6 dynamic-host
IP Services Volume-08-IPv6 Basics Commands
1-1
display dns ipv6 server
1-2
display dns proxy table
1-3
display dns server
1-3
display domain
1-17
display dot1x
Security Volume-02-802.1X Commands
1-1
display environment
1-9
display epon statistics interface
1-10
display epon-capability interface
1-3
display epon-multicast information
2-5
display epon-oam interface
1-5
display epon-parameter slot
1-6
display epon-version interface
1-8
display epon-workmode interface
1-9
display fan
1-10
display fib
IP Services Volume-05-IP Performance Commands
1-1
display fib ip-address
1-3
display fib statistics
1-4
display fib statistics vpn-instance
1-22
display fib vpn-instance
1-9
1-23
display fiber-backup group
1-11
display ftp client configuration
2-12
display ftp-server
2-1
display ftp-user
2-1
display garp statistics
Access Volume-09-GVRP Commands
1-1
display garp timer
1-2
display gvrp local-vlan interface
1-5
display gvrp state
1-6
display gvrp statistics
1-6
display gvrp status
1-7
display gvrp vlan-operation interface
1-8
display history-command
1-10
display hotkey
1-10
display hwtacacs
3-1
display icmp statistics
1-4
display igmp group
IP Multicast Volume-02-IGMP Commands
1-1
display igmp group port-info
1-3
display igmp interface
1-4
display igmp routing-table
1-6
display igmp ssm-mapping
1-7
display igmp ssm-mapping group
1-8
display igmp-snooping group
IP Multicast Volume-07-IGMP Snooping Commands
1-1
display igmp-snooping statistics
1-3
display info-center
1-2
display interface
1-6
display interface tunnel
1-2
display interface vlan-interface
1-2
display ip as-path
1-10
display ip check source
Security Volume-06-IP Source Guard Command
1-1
display ip community-list
1-11
display ip extcommunity-list
1-12
display ip host
1-4
display ip interface
IP Services Volume-01-IP Addressing Commands
1-1
display ip interface brief
1-3
display ip ip-prefix
1-23
display ip ipv6-prefix
1-28
display ip multicast routing-table
1-9
display ip multicast routing-table ip-address
1-11
display ip relay-route
IP Routing Volume-01-IP Routing Table Display Commands
1-13
display ip relay-tunnel
1-13
display ip routing-table
1-1
display ip routing-table acl
1-4
display ip routing-table ip-address
1-7
display ip routing-table ip-prefix
1-9
display ip routing-table protocol
1-10
display ip routing-table statistics
1-12
display ip routing-table vpn-instance
1-10
display ip socket
1-6
display ip statistics
1-9
display ip vpn-instance
1-11
1-24
display ip-subnet-vlan interface
1-28
display ip-subnet-vlan vlan
1-29
display ipv6 fib
1-3
display ipv6 host
1-4
display ipv6 interface
1-5
display ipv6 interface tunnel
1-3
display ipv6 multicast routing-table
1-7
display ipv6 multicast routing-table ipv6-address prefix-length
1-9
display ipv6 neighbors
1-8
display ipv6 neighbors count
1-10
display ipv6 pathmtu
1-11
display ipv6 relay-route
1-22
display ipv6 relay-tunnel
1-22
display ipv6 routing-table
1-14
display ipv6 routing-table acl
1-15
display ipv6 routing-table ipv6-address
1-16
display ipv6 routing-table ipv6-address1 ipv6-address2
1-17
display ipv6 routing-table ipv6-prefix
1-18
display ipv6 routing-table protocol
1-19
display ipv6 routing-table statistics
1-19
display ipv6 routing-table verbose
1-20
display ipv6 socket
1-11
display ipv6 statistics
1-13
display isis brief
1-6
display isis debug-switches
1-7
display isis graceful-restart status
1-8
display isis interface
1-9
display isis license
1-12
display isis lsdb
1-14
display isis mesh-group
1-16
display isis name-table
1-17
display isis peer
1-18
display isis route
1-21
display isis route ipv6
IP Routing Volume-10-IPv6 IS-IS Commands
1-1
display isis spf-log
1-23
display isis statistics
1-25
display isolate-user-vlan
3-1
display l2vpn ccc-interface vc-type
1-10
display lacp system-id
1-2
display link-aggregation member-port
1-2
display link-aggregation summary
1-4
display link-aggregation verbose
1-6
display lldp local-information
Access Volume-07-LLDP Commands
1-1
display lldp neighbor-information
1-5
display lldp statistics
1-10
display lldp status
1-12
display lldp tlv-config
1-14
display local-proxy-arp
2-1
display local-user
1-18
display logbuffer
1-4
display logbuffer summary
1-6
display logfile buffer
1-7
display logfile summary
1-7
display loopback-detection
1-10
display mac-address
System Volume-07-MAC Address Table Management Commands
1-1
display mac-address aging-time
1-2
display mac-address mac-learning
1-3
display mac-authentication
Security Volume-03-MAC Authentication Commands
1-1
display mac-vlan
1-18
display mac-vlan interface
1-19
display memory
1-10
display mib-style
System Volume-05-SNMP Commands
2-1
display mirroring-group
Access Volume-18-Mirroring Commands
1-1
display mld group
IP Multicast Volume-10-MLD Commands
1-1
display mld group port-info
1-2
display mld interface
1-4
display mld routing-table
1-6
display mld ssm-mapping
1-7
display mld ssm-mapping group
1-8
display mld-snooping group
IP Multicast Volume-13-MLD Snooping Commands
1-1
display mld-snooping statistics
1-2
display mpls ilm
MPLS Volume-02-MPLS Basics Commands
1-1
display mpls interface
1-2
display mpls l2vc
1-11
display mpls l2vpn
1-13
display mpls l2vpn connection
1-15
display mpls l2vpn forwarding-info
1-18
display mpls label
1-3
display mpls ldp
1-4
display mpls ldp interface
1-5
display mpls ldp Isp
1-7
display mpls ldp peer
1-8
display mpls ldp remote-peer
1-9
display mpls ldp session
1-10
display mpls ldp vpn-instance
1-12
display mpls lsp
1-14
display mpls lsp statistics
1-16
display mpls nhlfe
1-17
display mpls route-state
1-18
display mpls static-l2vc
1-19
display mpls static-lsp
1-19
display mpls statistics interface
1-20
display mpls statistics lsp
1-22
display msdp brief
1-2
display msdp peer-status
1-3
display msdp sa-cache
1-6
display msdp sa-count
1-7
display multicast boundary
IP Multicast Volume-01-Multicast Routing and Forwarding Commands
1-1
display multicast forwarding-table
1-2
display multicast ipv6 boundary
IP Multicast Volume-09-IPv6 Multicast Routing and Forwarding Commands
1-1
display multicast ipv6 forwarding-table
1-2
display multicast ipv6 routing-table
1-4
display multicast ipv6 rpf-info
1-6
display multicast routing-table
1-5
display multicast routing-table static
1-6
display multicast rpf-info
1-8
display multicast-domain vpn-instance share-group
IP Multicast Volume-06-Multicast VPN Commands
1-1
display multicast-vlan
IP Multicast Volume-08-Multicast VLAN Commands
1-1
display multicast-vlan ipv6
IP Multicast Volume-14-IPv6 Multicast VLAN Commands
1-1
display nqa
1-4
display nqa server status
1-28
display ntp-service sessions
System Volume-13-NTP Commands
1-1
display ntp-service status
1-2
display ntp-service trace
1-4
display oam
Access Volume-13-Ethernet OAM Commands
1-1
display oam configuration
1-5
display oam critical-event
1-7
display oam link-event
1-7
display onu-event interface
1-12
display onuinfo
1-13
display onuinfo mac-address
1-15
display onuinfo silent
1-16
display onu-protocol
2-6
display optics-parameters interface
1-17
display ospf abr-asbr
1-8
display ospf asbr-summary
1-9
display ospf brief
1-11
display ospf cumulative
1-13
display ospf error
1-15
display ospf interface
1-16
display ospf lsdb
1-18
display ospf nexthop
1-21
display ospf peer
1-22
display ospf peer statistics
1-24
display ospf request-queue
1-25
display ospf retrans-queue
1-26
display ospf routing
1-28
display ospf sham-link
1-25
display ospf vlink
1-29
display ospfv3
1-6
display ospfv3 interface
1-7
display ospfv3 lsdb
1-8
display ospfv3 lsdb statistic
1-11
display ospfv3 next-hop
1-12
display ospfv3 peer
1-12
display ospfv3 peer statistic
1-14
display ospfv3 request-list
1-15
display ospfv3 retrans-list
1-17
display ospfv3 routing
1-18
display ospfv3 statistics
1-20
display ospfv3 topology
1-21
display ospfv3 vlink
1-22
display patch-information
System Volume-16-Hotfix Commands
1-1
display pim bsr-info
1-11
display pim claimed-route
1-13
display pim control-message counters
1-15
display pim grafts
1-16
display pim interface
1-17
display pim ipv6 bsr-info
1-8
display pim ipv6 claimed-route
1-10
display pim ipv6 control-message counters
1-11
display pim ipv6 grafts
1-13
display pim ipv6 interface
1-14
display pim ipv6 join-prune
1-15
display pim ipv6 neighbor
1-17
display pim ipv6 routing-table
1-18
display pim ipv6 rp-info
1-20
display pim join-prune
1-20
display pim neighbor
1-21
display pim routing-table
1-23
display pim rp-info
1-25
display poe device
1-2
display poe interface
1-3
display poe interface power
1-6
display poe power-usage
1-8
display poe pse
1-9
display poe pse interface
1-10
display poe pse interface power
1-12
display poe-power
1-13
display poe-power ac-input state
1-14
display poe-power alarm
1-16
display poe-power dc-output state
1-16
display poe-power dc-output value
1-17
display poe-power status
1-18
display poe-power supervision-module
1-19
display poe-power switch state
1-20
display poe-profile
1-21
display poe-profile interface
1-23
display port
1-8
display port combo
1-11
display portal acl
Security Volume-04-Portal Commands
1-1
display portal connection statistics
1-3
display portal free-rule
1-6
display portal interface
1-7
display portal server
1-8
display portal server statistics
1-9
display portal tcp-cheat statistics
1-11
display portal user
1-12
display port-group manual
1-12
display port-isolate group
Access Volume-03-Port Isolation Commands
1-1
display port-security
Security Volume-05-Port Security Commands
1-1
display port-security mac-address block
1-3
display port-security mac-address security
1-4
display power
1-11
display protocol-vlan interface
1-22
display protocol-vlan vlan
1-23
display proxy-arp
2-1
display public-key local
1-1
display public-key peer
1-2
display qos gts interface
1-1
display qos lr interface
1-2
display qos map-table
5-1
display qos policy
2-18
display qos policy global
2-19
display qos policy interface
2-20
display qos sp interface
3-1
display qos trust interface
5-4
display qos vlan-policy
2-21
display qos wfq interface
3-1
display qos wred interface
4-1
display qos wred table
4-1
display qos wrr interface
3-3
display radius scheme
2-2
display radius statistics
2-4
display rip
1-3
display rip database
1-5
display rip interface
1-6
display rip route
1-7
display ripng
1-2
display ripng database
1-3
display ripng interface
1-4
display ripng route
1-6
display rmon alarm
System Volume-06-RMON Commands
1-1
display rmon event
1-2
display rmon eventlog
1-3
display rmon history
1-4
display rmon prialarm
1-7
display rmon statistics
1-8
display route-policy
1-12
display router id
1-23
display rrpp brief
1-2
display rrpp ring-group
1-3
display rrpp statistics
1-4
display rrpp verbose
1-7
display saved-configuration
1-16
display schedule job
1-12
display schedule reboot
1-12
display service-loopback group
Access Volume-04-Service Loopback Group Commands
1-1
display sflow
IP Services Volume-10-sFlow Commands
1-1
display sftp client source
1-3
display smart-link flush
Access Volume-06-Smart Link Commands
1-1
display smart-link group
1-2
display snmp-agent community
1-1
display snmp-agent group
1-2
display snmp-agent local-engineid
1-3
display snmp-agent mib-view
1-4
display snmp-agent statistics
1-5
display snmp-agent sys-info
1-7
display snmp-agent trap queue
1-8
display snmp-agent trap-list
1-8
display snmp-agent usm-user
1-9
display ssh client source
1-4
display ssh server
1-4
display ssh server-info
1-6
display ssh user-information
1-7
display startup
1-18
display stop-accounting-buffer
2-6
3-3
display storm-constrain
1-13
display stp
1-2
display stp abnormal-port
1-5
display stp down-port
1-6
display stp history
1-7
display stp region-configuration
1-8
display stp root
1-9
display stp tc
1-10
display supervlan
2-1
display switch-mode status
1-13
display switchover state
System Volume-15-HA Commands
1-1
display tcp ipv6 statistics
1-16
display tcp ipv6 status
1-18
display tcp statistics
1-10
display tcp status
1-13
display telnet client configuration
1-5
display tftp client configuration
3-1
display this
1-12
display time-range
1-3
display track
System Volume-11-Track Commands
1-1
display traffic behavior
2-7
display traffic classifier
2-1
display transceiver
1-18
display transceiver alarm
1-14
display transceiver diagnosis
1-17
display transceiver manuinfo
1-19
display trapbuffer
1-8
display tunnel-policy
1-27
display udp ipv6 statistics
1-19
display udp statistics
1-14
display udp-helper server
IP Services Volume-06-UDP Helper Commands
1-1
display uni-information
2-10
display user-bind
1-2
display user-interface
1-5
display users
1-7
display vendor-specific information
2-7
display version
1-13
display vlan
1-3
display voice vlan oui
4-1
display voice vlan state
4-2
display vrrp
System Volume-14-VRRP Commands
1-1
display vrrp ipv6
1-14
display vrrp ipv6 statistics
1-16
display vrrp statistics
1-3
dldp authentication-mode
1-4
dldp delaydown-timer
1-5
dldp enable
1-5
dldp interval
1-6
dldp reset
1-7
dldp unidirectional-shutdown
1-8
dldp work-mode
1-8
dns domain
1-5
dns proxy enable
1-6
dns resolve
1-6
dns server
1-7
dns server ipv6
1-20
dns-list
1-14
domain
1-20
domain default
1-21
domain ring
1-9
domain-authentication-mode
1-26
domain-id
1-13
domain-id
1-27
domain-name
1-15
dot1x
1-4
dot1x authentication-method
1-5
dot1x free-ip
2-1
dot1x guest-vlan
1-6
dot1x handshake
1-8
dot1x mandatory-domain
1-8
dot1x max-user
1-9
dot1x multicast-trigger
1-10
dot1x port-control
1-11
dot1x port-method
1-12
dot1x quiet-period
1-13
dot1x retry
1-14
dot1x supp-proxy-check
1-14
dot1x timer
1-16
dot1x timer ead-timeout
2-2
dot1x url
2-2
drop-unknown (IGMP-Snooping view)
1-4
drop-unknown (MLD-Snooping view)
1-3
duplex
1-14
du-readvertise
1-24
du-readvertise timer
1-24
E
ebgp-interface-sensitive
1-30
embedded-rp
1-21
enable link-local-signaling
1-30
enable log
1-30
enable out-of-band-resynchronization
1-31
enable snmp trap updown
1-8
1-10
encap-data-enable
1-9
encrypt enable
2-12
encrypt key
2-13
encryption timer
1-19
epon-parameter ouilist
1-20
escape-key
1-8
execute
1-4
exit
1-30
expired
1-16
export route-policy
1-14
export route-policy
1-28
ext-community-type
1-14
ext-community-type
1-29
F
fast-leave (IGMP-Snooping view)
1-5
fast-leave (MLD-Snooping view)
1-4
fiber-backup group
1-21
file prompt
1-5
filename
1-8
filter
1-32
filter
2-8
filter-policy export
1-7
1-15
filter-policy export (BGP/BGP-VPN instance view)
1-31
filter-policy export (BGP-VPNv4 subaddress family view)
1-30
filter-policy export (IPv6 address family view)
1-22
filter-policy export (IPv6 MBGP address family view)
1-25
filter-policy export (IS-IS view)
1-27
filter-policy export (MBGP family view)
1-28
filter-policy export (OSPF view)
1-33
filter-policy export (OSPFv3 view)
1-23
filter-policy export (RIP view)
1-9
filter-policy import
1-16
filter-policy import (BGP/BGP-VPN instance view)
1-32
filter-policy import (BGP-VPNv4 subaddress family view)
1-31
filter-policy import (IPv6 address family view)
1-23
filter-policy import (IPv6 MBGP address family view)
1-26
filter-policy import (IS-IS view)
1-28
filter-policy import (MBGP Family view)
1-29
filter-policy import (OSPF view)
1-33
filter-policy import (OSPFv3 view)
1-24
filter-policy import (RIP view)
1-10
filter-policy import (RIPng view)
1-7
fixdisk
1-6
flash-flood
1-29
flow-control
1-14
flow-control
1-9
flow-interval
1-15
flush enable
1-3
format
1-6
forward-error-correction enable
2-14
free ftp user
2-2
free user-interface
1-10
frequency
1-8
ftp
2-13
ftp client source
2-14
ftp ipv6
2-15
ftp server acl
2-3
ftp server enable
2-3
ftp timeout
2-4
ftp update
2-5
G
garp timer
1-2
garp timer leaveall
1-4
gateway-list
1-16
get
1-31
get
2-16
graceful-restart (BGP view)
1-33
graceful-restart (IS-IS view)
1-30
graceful-restart (MPLS LDP view)
1-25
graceful-restart (OSPF view)
1-34
graceful-restart help
1-35
graceful-restart interval (IS-IS view)
1-30
graceful-restart interval (OSPF view)
1-36
graceful-restart mpls ldp
1-26
graceful-restart suppress-sa
1-31
graceful-restart timer neighbor-liveness
1-26
graceful-restart timer reconnect
1-27
graceful-restart timer recovery
1-28
graceful-restart timer restart
1-33
graceful-restart timer wait-for-rib
1-34
grant-filtering enable
1-21
gratuitous-arp-learning enable
1-9
gratuitous-arp-sending enable
1-8
group (BGP/BGP-VPN instance view)
1-35
group (IPv6 address family view)
1-23
group member
1-22
group-member
1-16
group-policy (IGMP-Snooping view)
1-5
group-policy (MLD-Snooping view)
1-5
gvrp
1-8
gvrp registration
1-9
H
header
1-14
hello-option dr-priority (IPv6 PIM view)
1-22
hello-option dr-priority (PIM view)
1-27
hello-option holdtime (IPv6 PIM view)
1-23
hello-option holdtime (PIM view)
1-27
hello-option lan-delay (IPv6 PIM view)
1-24
hello-option lan-delay (PIM view)
1-28
hello-option neighbor-tracking (IPv6 PIM view)
1-24
hello-option neighbor-tracking (PIM view)
1-29
hello-option override-interval (IPv6 PIM view)
1-25
hello-option override-interval (PIM view)
1-29
help
1-31
history-command max-size
1-11
history-records
1-9
holdtime assert (IPv6 PIM view)
1-26
holdtime assert (PIM view)
1-30
holdtime join-prune (IPv6 PIM view)
1-26
holdtime join-prune (PIM view)
1-31
hops-count
1-28
host-advertise
1-37
host-aging-time (IGMP-Snooping view)
1-7
host-aging-time (MLD-Snooping view)
1-6
host-route
1-11
hotkey
1-16
http-version
1-10
hwtacacs nas-ip
3-4
hwtacacs scheme
3-5
I
idle-cut
1-21
idle-timeout
1-11
if-match
2-2
if-match acl
1-23
if-match as-path
1-13
if-match community
1-14
if-match cost
1-14
if-match customer-vlan-id
1-2
if-match extcommunity
1-15
if-match interface
1-16
if-match ip
1-24
if-match ip-prefix
1-25
if-match ipv6
1-29
if-match mpls-label
1-16
if-match route-type
1-17
if-match tag
1-18
igmp
1-10
igmp enable
1-11
igmp group-policy
1-12
igmp last-member-query-interval
1-13
igmp max-response-time
1-13
igmp require-router-alert
1-14
igmp robust-count
1-15
igmp send-router-alert
1-15
igmp ssm-mapping enable
1-16
igmp startup-query-count
1-17
igmp startup-query-interval
1-17
igmp static-group
1-18
igmp timer other-querier-present
1-19
igmp timer query
1-20
igmp version
1-21
igmp-snooping
1-7
igmp-snooping drop-unknown
1-8
igmp-snooping enable
1-9
igmp-snooping fast-leave
1-9
igmp-snooping general-query source-ip
1-10
igmp-snooping group-limit
1-11
igmp-snooping group-policy
1-12
igmp-snooping host-aging-time
1-13
igmp-snooping host-join
1-14
igmp-snooping last-member-query-interval
1-15
igmp-snooping max-response-time
1-16
igmp-snooping overflow-replace
1-16
igmp-snooping querier
1-17
igmp-snooping query-interval
1-18
igmp-snooping router-aging-time
1-19
igmp-snooping source-deny
1-20
igmp-snooping special-query source-ip
1-20
igmp-snooping static-group
1-21
igmp-snooping static-router-port
1-22
igmp-snooping version
1-23
import
5-2
import route-policy
1-17
import route-policy
1-31
import-route
1-8
import-route (BGP/BGP-VPN instance view)
1-36
import-route (IPv6 address family view)
1-24
import-route (IPv6 MBGP address family view)
1-27
import-route (IS-IS view)
1-32
import-route (MBGP family view)
1-30
import-route (OSPF view)
1-37
import-route (OSPFv3 view)
1-25
import-route (RIP view)
1-11
import-route isis level-2 into level-1
1-33
import-route limit (IS-IS view)
1-34
import-source
1-9
info-center channel name
1-10
info-center console channel
1-11
info-center enable
1-11
info-center logbuffer
1-12
info-center logfile enable
1-13
info-center logfile frequency
1-13
info-center logfile size-quota
1-14
info-center logfile switch-directory
1-14
info-center loghost
1-15
info-center loghost source
1-16
info-center monitor channel
1-17
info-center snmp channel
1-18
info-center source
1-18
info-center synchronous
1-21
info-center timestamp
1-22
info-center timestamp loghost
1-23
info-center trapbuffer
1-24
instance
1-11
interface
1-16
interface bridge-aggregation
1-9
interface tunnel
1-7
1-4
ip address
1-5
ip address
2-14
ip address
1-4
ip address dhcp-alloc
3-3
ip as-path
1-18
ip binding vpn-instance
1-17
1-32
ip check source
1-3
ip community-list
1-19
1-20
ip forward-broadcast (interface view)
1-15
ip forward-broadcast (system view)
1-16
ip host
1-7
ip ip-prefix
1-25
ip ipv6-prefix
1-29
ip redirects enable
1-16
ip route-static
1-2
ip route-static default-preference
1-4
ip rpf-route-static
1-9
ip ttl-expires enable
1-17
ip unreachables enable
1-17
ip urpf strict
IP Services Volume-07-URPF Commands
1-1
ip vpn-instance
1-18
ip vpn-instance
1-32
ip-subnet-vlan
1-29
ipv4-family
1-33
ipv4-family multicast
1-31
ipv4-family vpn-instance
1-18
ipv6
1-21
ipv6 address
1-21
ipv6 address auto link-local
1-22
ipv6 address eui-64
1-23
ipv6 address link-local
1-23
ipv6 default-route-advertise
1-3
ipv6 enable
1-4
ipv6 filter-policy export
1-5
ipv6 filter-policy import
1-6
ipv6 hoplimit-expires enable
1-24
ipv6 host
1-25
ipv6 icmp-error
1-25
1-26
ipv6 import-route
1-7
ipv6 import-route isisv6 level-2 into level-1
1-8
ipv6 import-route limit
1-9
ipv6 maximum load-balancing
1-9
1-26
ipv6 nd autoconfig other-flag
1-27
ipv6 nd dad attempts
1-28
ipv6 nd hop-limit
1-28
ipv6 nd ns retrans-timer
1-29
ipv6 nd nud reachable-time
1-30
ipv6 nd ra halt
1-30
ipv6 nd ra interval
1-31
ipv6 nd ra prefix
1-32
ipv6 nd ra router-lifetime
1-32
ipv6 neighbor
1-33
ipv6 neighbors max-learning-num
1-34
ipv6 pathmtu
1-35
ipv6 pathmtu age
1-35
ipv6 preference
1-10
ipv6 route-static
1-2
ipv6 summary
1-11
ipv6-family
1-25
ipv6-family multicast
1-27
isis
1-35
isis authentication-mode
1-35
isis circuit-level
1-36
isis circuit-type p2p
1-37
isis cost
1-38
isis dis-name
1-39
isis dis-priority
1-40
isis enable
1-41
isis ipv6 enable
1-12
isis mesh-group
1-41
isis silent
1-42
isis small-hello
1-43
isis timer csnp
1-44
isis timer hello
1-45
isis timer holding-multiplier
1-45
isis timer lsp
1-46
isis timer retransmit
1-47
is-level
1-48
is-name
1-49
is-name map
1-50
isolate-user-vlan
3-2
isolate-user-vlan enable
3-4
is-snmp-traps enable
1-50
J
jp-pkt-size (IPv6 PIM view)
1-27
jp-pkt-size (PIM view)
1-31
jp-queue-size (IPv6 PIM view)
1-27
jp-queue-size (PIM view)
1-32
jumboframe enable
1-17
K
key (HWTACACS scheme view)
3-6
key (RADIUS scheme view)
2-7
L
l2vpn-family
1-20
label advertise
1-29
label-distribution
1-30
lacp port-priority
1-9
lacp system-priority
1-10
last-listener-query-interval (MLD view)
1-9
last-listener-query-interval (MLD-Snooping view)
1-6
last-member-query-interval (IGMP view)
1-21
last-member-query-interval (IGMP-Snooping view)
1-24
lcd
2-17
level
1-22
link-aggregation mode
1-10
link-delay
1-18
linktest
2-15
lldp admin-status
1-16
lldp check-change-interval
1-16
lldp compliance admin-status cdp
1-17
lldp compliance cdp
1-18
lldp enable
1-18
lldp encapsulation snap
1-19
lldp fast-count
1-20
lldp hold-multiplier
1-20
lldp management-address-format string
1-21
lldp management-address-tlv
1-22
lldp notification remote-change enable
1-22
lldp timer notification-interval
1-23
lldp timer reinit-delay
1-24
lldp timer tx-delay
1-24
lldp timer tx-interval
1-25
lldp tlv-enable
1-25
loadsharing enable
1-20
local-proxy-arp enable
2-2
local-user
1-23
local-user password-display-mode
1-24
lock
1-12
logfile save
1-25
log-peer-change
1-39
log-peer-change
1-37
log-peer-change
1-26
log-peer-change (IS-IS view)
1-51
loopback
1-19
loopback enable
2-16
loopback-detection control enable
1-19
loopback-detection enable
1-20
loopback-detection interval-time
1-21
loopback-detection per-vlan enable
1-22
loop-detect
1-31
ls
1-32
ls
2-17
lsa-arrival-interval
1-39
lsa-generation-interval
1-40
lsdb-overflow-limit
1-41
lsp-fragments-extend
1-51
lsp-length originate
1-52
lsp-length receive
1-53
lsp-trigger
1-32
lsr-id
1-33
M
mac-address (Ethernet interface view)
1-3
mac-address (system view)
1-4
mac-address mac-learning disable
1-5
mac-address max-mac-count
1-6
mac-address timer
1-7
mac-authentication
1-3
mac-authentication domain
1-4
mac-authentication timer
1-4
mac-authentication user-name-format
1-5
mac-vlan enable
1-20
mac-vlan mac-address
1-20
management-vlan
2-17
maximum load-balancing (IS-IS view)
1-54
maximum load-balancing (OSPF view)
1-41
maximum load-balancing (OSPFv3 view)
1-26
maximum load-balancing (RIP view)
1-13
maximum load-balancing (RIPng view)
1-9
maximum-routes
1-42
max-response-time (IGMP view)
1-22
max-response-time (IGMP-Snooping view)
1-24
max-response-time (MLD view)
1-10
max-response-time (MLD-Snooping view)
1-7
max-rtt
1-23
md5-password
1-33
mdi
1-23
mib-style
2-1
mirroring-group
1-2
mirroring-group mirroring-port
1-3
mirroring-group monitor-egress
1-4
mirroring-group monitor-port
1-5
mirroring-group remote-probe vlan
1-6
mirroring-port
1-7
mirror-to
2-9
mkdir
1-33
mkdir
1-7
mkdir
2-18
mld
1-10
mld enable
1-11
mld group-policy
1-12
mld last-listener-query-interval
1-13
mld max-response-time
1-13
mld require-router-alert
1-14
mld robust-count
1-15
mld send-router-alert
1-15
mld ssm-mapping enable
1-16
mld startup-query-count
1-17
mld startup-query-interval
1-17
mld static-group
1-18
mld timer other-querier-present
1-19
mld timer query
1-20
mld version
1-21
mld-snooping
1-8
mld-snooping drop-unknown
1-8
mld-snooping enable
1-9
mld-snooping fast-leave
1-10
mld-snooping general-query source-ip
1-11
mld-snooping group-limit
1-11
mld-snooping group-policy
1-12
mld-snooping host-aging-time
1-14
mld-snooping host-join
1-14
mld-snooping last-listener-query-interval
1-15
mld-snooping max-response-time
1-16
mld-snooping overflow-replace
1-17
mld-snooping querier
1-18
mld-snooping query-interval
1-18
mld-snooping router-aging-time
1-19
mld-snooping source-deny
1-20
mld-snooping special-query source-ip
1-20
mld-snooping static-group
1-21
mld-snooping static-router-port
1-22
mld-snooping version
1-23
mmu-monitor enable
1-22
modem
1-13
modem auto-answer
1-13
modem timer answer
1-14
monitor enable
3-19
monitor handshake-timeout disable-port
1-21
monitor-port
1-7
more
1-8
mount
1-8
move
1-9
mpls
1-34
mpls l2vc
1-21
mpls l2vpn
1-22
mpls l2vpn vpn-name
1-22
mpls ldp (interface view)
1-36
mpls ldp (system view)
1-35
1-37
mpls ldp timer hello-hold
1-37
mpls ldp timer keepalive-hold
1-38
mpls ldp transport-address
1-39
mpls lsr-id
1-40
mpls static-l2vc destination
1-23
msdp
1-10
mtracert
1-11
mtu (MPLS L2VPN view)
1-24
multicast boundary
1-12
multicast forwarding-table downstream-limit
1-13
multicast forwarding-table route-limit
1-14
1-7
multicast ipv6 forwarding-table downstream-limit
1-8
multicast ipv6 forwarding-table route-limit
1-8
multicast ipv6 load-splitting
1-9
multicast ipv6 longest-match
1-10
multicast ipv6 routing-enable
1-10
multicast load-splitting
1-15
multicast longest-match
1-15
multicast routing-enable
1-16
multicast vlan-id dest-ip
1-23
multicast-control host-aging-time
2-18
multicast-domain share-group
1-2
multicast-mode
2-18
multicast-suppression
1-23
multicast-vlan
1-2
multicast-vlan ipv6
1-2
N
nas-ip (HWTACACS scheme view)
3-6
nas-ip (RADIUS scheme view)
2-8
naturemask-arp enable
1-7
nbns-list
1-17
nest
2-10
nest top-most vlan-id
1-2
nesting-vpn
1-34
netbios-type
1-18
network
1-19
network
1-13
network (BGP/BGP-VPN instance view)
1-37
network (IPv6 address family view)
1-25
network (IPv6 MBGP address family view)
1-28
network (MBGP family view)
1-31
network (OSPF area view)
1-43
network short-cut (BGP/BGP-VPN instance view)
1-38
network-entity
1-54
next-hop
1-11
nqa
1-11
nqa agent enable
1-12
nqa agent max-concurrent
1-12
nqa schedule
1-13
nqa server enable
1-29
nqa server tcp-connect
1-30
nqa server udp-echo
1-31
nssa
1-43
ntp-service access
1-5
ntp-service authentication enable
1-6
ntp-service authentication-keyid
1-6
ntp-service broadcast-client
1-7
ntp-service broadcast-server
1-8
ntp-service in-interface disable
1-8
ntp-service max-dynamic-sessions
1-9
ntp-service multicast-client
1-9
ntp-service multicast-server
1-10
ntp-service refclock-master
1-11
ntp-service reliable authentication-keyid
1-12
ntp-service source-interface
1-12
ntp-service unicast-peer
1-13
ntp-service unicast-server
1-14
O
oam enable
1-10
oam errored-frame period
1-10
oam errored-frame threshold
1-11
oam errored-frame-period period
1-12
oam errored-frame-period threshold
1-12
oam errored-frame-seconds period
1-13
oam errored-frame-seconds threshold
1-14
oam loopback
1-15
oam mode
1-16
onu port-isolate enable
2-20
onu-event
2-19
onu-protocol enable
2-21
onu-protocol igmp-snooping
2-22
opaque-capability enable
1-44
open
2-19
open ipv6
2-20
operation (FTP test type view)
1-14
operation (HTTP test type view)
1-14
operation interface
1-15
option
1-19
originating-rp
1-11
ospf
1-45
ospf authentication-mode
1-46
ospf cost
1-47
ospf dr-priority
1-48
ospf mib-binding
1-49
ospf mtu-enable
1-49
ospf network-type
1-50
ospf packet-process prioritized-treatment
1-51
ospf timer dead
1-51
ospf timer hello
1-52
ospf timer poll
1-53
ospf timer retransmit
1-54
ospf trans-delay
1-54
ospfv3
1-27
ospfv3 area
1-28
ospfv3 cost
1-29
ospfv3 dr-priority
1-29
ospfv3 mtu-ignore
1-30
ospfv3 network-type
1-30
ospfv3 peer
1-31
ospfv3 timer dead
1-32
ospfv3 timer hello
1-33
ospfv3 timer poll
1-35
ospfv3 timer retransmit
1-34
ospfv3 trans-delay
1-35
output-delay
1-14
overflow-replace (IGMP-Snooping view)
1-25
overflow-replace (MLD-Snooping view)
1-24
P
parity
1-15
passive
2-21
password
1-24
password (FTP test type view)
1-16
patch active
1-2
patch deactive
1-2
patch delete
1-3
patch load
1-4
patch run
1-5
path-vectors
1-41
peer
1-15
peer
1-55
peer advertise-community (BGP/BGP-VPN instance view)
1-39
peer advertise-community (BGP-VPNv4 subaddress family view)
1-35
peer advertise-community (IPv6 address family view)
1-26
peer advertise-community (IPv6 MBGP address family view)
1-29
peer advertise-community (MBGP family view)
1-32
peer advertise-ext-community (BGP/BGP-VPN instance view)
1-40
peer advertise-ext-community (IPv6 address family view)
1-27
peer advertise-ext-community (IPv6 MBGP address family view)
1-30
peer advertise-ext-community (MBGP family view)
1-33
peer allow-as-loop
1-19
peer allow-as-loop
1-35
peer allow-as-loop (BGP/BGP-VPN instance view)
1-40
peer allow-as-loop (IPv6 address family view)
1-27
peer allow-as-loop (IPv6 MBGP address family view)
1-30
peer allow-as-loop (MBGP family view)
1-34
peer as-number (BGP/BGP-VPN instance view)
1-41
peer as-number (IPv6 address family view)
1-28
peer as-path-acl (BGP/BGP-VPN instance view)
1-42
peer as-path-acl (BGP-VPNv4 subaddress family view)
1-36
peer as-path-acl (IPv6 address family view)
1-29
peer as-path-acl (IPv6 MBGP address family view)
1-31
peer as-path-acl (MBGP family view)
1-34
peer capability-advertise conventional
1-43
peer capability-advertise route-refresh
1-44
1-30
peer connect-interface
1-12
peer connect-interface (BGP/BGP-VPN instance view)
1-45
peer connect-interface (IPv6 address family view)
1-30
peer default-route-advertise
1-31
peer default-route-advertise (BGP/BGP-VPN instance view)
1-46
peer default-route-advertise (IPv6 MBGP address family view)
1-32
peer default-route-advertise (MBGP family view)
1-35
peer default-route-advertise vpn-instance
1-37
peer description
1-13
peer description (BGP/BGP-VPN instance view)
1-46
peer description (IPv6 address family view)
1-32
peer ebgp-max-hop (BGP/BGP-VPN instance view)
1-47
peer ebgp-max-hop (IPv6 address family view)
1-33
peer enable
1-38
peer enable (BGP view)
1-48
peer enable (IPv6 MBGP address family view)
1-33
peer enable (MBGP family view)
1-36
peer fake-as (BGP/BGP-VPN instance view)
1-49
peer fake-as (IPv6 address family view)
1-33
peer filter-policy (BGP/BGP-VPN instance view)
1-50
peer filter-policy (BGP-VPNv4 subaddress family view)
1-38
peer filter-policy (IPv6 address family view)
1-34
peer filter-policy (IPv6 MBGP address family view)
1-34
peer filter-policy (MBGP family view)
1-37
peer group
1-20
peer group
1-39
peer group (BGP/BGP-VPN instance view)
1-50
peer group (IPv6 address family view)
1-35
peer group (IPv6 MBGP address family view)
1-34
peer group (MBGP family view)
1-37
peer ignore (BGP/BGP-VPN instance view)
1-51
peer ignore (IPv6 address family view)
1-36
peer ip-prefix
1-52
peer ip-prefix (BGP-VPNv4 subaddress family view)
1-40
peer ip-prefix (MBGP family view)
1-38
peer ipv6-prefix
1-36
peer ipv6-prefix (IPv6 MBGP address family view)
1-35
peer keep-all-routes (BGP/BGP-VPN instance view)
1-53
peer keep-all-routes (IPv6 address family view)
1-37
peer keep-all-routes (IPv6 MBGP address family view)
1-36
peer keep-all-routes (MBGP family view)
1-39
peer label-route-capability (BGP view, BGP VPN instance view)
1-41
peer log-change (BGP/BGP-VPN instance view)
1-54
peer log-change (IPv6 address family view)
1-38
peer mesh-group
1-13
peer minimum-ttl
1-14
peer next-hop-invariable (BGP-VPNv4 subaddress family view)
1-41
peer next-hop-local
1-42
peer next-hop-local (BGP/BGP-VPN instance view)
1-55
peer next-hop-local (IPv6 address family view)
1-38
peer next-hop-local (IPv6 MBGP address family view)
1-37
peer next-hop-local (MBGP family view)
1-40
peer password
1-55
peer preferred-value (BGP/BGP-VPN instance view)
1-57
peer preferred-value (BGP-VPNv4 subaddress family view)
1-43
peer preferred-value (IPv6 address family view)
1-39
peer preferred-value (IPv6 MBGP address family view)
1-38
peer preferred-value (MBGP family view)
1-40
peer public-as-only (BGP/BGP-VPN instance view)
1-58
peer public-as-only (BGP-VPNv4 subaddress family view)
1-44
peer public-as-only (IPv6 address family view)
1-40
peer public-as-only (IPv6 MBGP address family view)
1-39
peer public-as-only (MBGP family view)
1-41
peer reflect-client
1-44
peer reflect-client (BGP/BGP-VPN instance view)
1-58
peer reflect-client (IPv6 address family view)
1-41
peer reflect-client (IPv6 MBGP address family view)
1-39
peer reflect-client (MBGP family view)
1-42
peer request-sa-enable
1-15
peer route-limit (BGP/BGP-VPN instance view)
1-59
peer route-limit (IPv6 address family view)
1-41
peer route-limit (IPv6 MBGP address family view)
1-40
peer route-limit (MBGP family view)
1-43
peer route-policy (BGP/BGP-VPN instance view)
1-60
peer route-policy (BGP-VPNv4 subaddress family view)
1-45
peer route-policy (IPv6 address family view)
1-42
peer route-policy (IPv6 MBGP address family view)
1-41
peer route-policy (MBGP family view)
1-44
peer route-update-interval (BGP/BGP-VPN instance view)
1-61
peer route-update-interval (IPv6 address family view)
1-43
peer sa-cache-maximum
1-16
peer sa-policy
1-16
peer sa-request-policy
1-17
peer substitute-as (BGP/BGP-VPN instance view)
1-62
peer substitute-as (IPv6 address family view)
1-44
peer timer (BGP/BGP-VPN instance view)
1-63
peer timer (IPv6 address family view)
1-45
peer vpn-instance enable
1-46
peer vpn-instance group
1-47
peer vpn-instance route-policy import
1-48
peer-public-key end
1-8
pim
1-33
pim bsr-boundary
1-34
pim dm
1-34
pim hello-option dr-priority
1-35
pim hello-option holdtime
1-36
pim hello-option lan-delay
1-36
pim hello-option neighbor-tracking
1-37
pim hello-option override-interval
1-38
pim holdtime assert
1-38
pim holdtime join-prune
1-39
pim ipv6
1-28
pim ipv6 bsr-boundary
1-29
pim ipv6 dm
1-29
pim ipv6 hello-option dr-priority
1-30
pim ipv6 hello-option holdtime
1-31
pim ipv6 hello-option lan-delay
1-31
pim ipv6 hello-option neighbor-tracking
1-32
pim ipv6 hello-option override-interval
1-33
pim ipv6 holdtime assert
1-33
pim ipv6 holdtime join-prune
1-34
pim ipv6 require-genid
1-35
pim ipv6 sm
1-35
pim ipv6 state-refresh-capable
1-36
pim ipv6 timer graft-retry
1-36
pim ipv6 timer hello
1-37
pim ipv6 timer join-prune
1-38
pim ipv6 triggered-hello-delay
1-38
pim require-genid
1-39
pim sm
1-40
pim state-refresh-capable
1-41
pim timer graft-retry
1-41
pim timer hello
1-42
pim timer join-prune
1-42
pim triggered-hello-delay
1-43
ping
1-1
ping ipv6
1-3
ping lsp
1-42
poe enable
1-24
poe enable pse
1-25
poe legacy enable
1-25
poe max-power
1-26
poe max-power (system view)
1-27
poe mode
1-27
poe pd-description
1-28
poe pd-policy priority
1-29
poe power max-value
1-29
poe priority
1-30
poe priority (system view)
1-31
poe pse-policy priority
1-32
poe update
1-32
poe utilization-threshold
1-33
poe-power input-threshold
1-34
poe-power output-threshold
1-35
poe-profile
1-35
policy vpn-target
1-48
port
1-3
port
1-9
port (IPv6 multicast VLAN view)
1-3
port (multicast VLAN view)
1-3
port access vlan
1-10
port access vlan
2-23
port fiber-backup group
1-24
port hybrid ip-subnet-vlan vlan
1-30
port hybrid protocol-vlan
1-24
port hybrid pvid vlan
1-11
1-25
port hybrid vlan
1-12
port hybrid vlan
1-26
port link-aggregation group
1-11
port link-type
1-13
port link-type
2-23
port link-type hybrid
1-26
port service-loopback group
1-2
port smart-link group
1-4
port switch-over
1-27
port trunk permit vlan
1-15
port trunk pvid vlan
1-16
2-24
portal auth-network
1-13
portal delete-user
1-14
portal free-rule
1-15
portal server
1-16
portal server method
1-17
port-group manual
1-25
port-isolate enable
1-2
port-security authorization ignore
1-5
port-security enable
1-6
port-security intrusion-mode
1-7
1-8
port-security max-mac-count
1-9
port-security ntk-mode
1-10
port-security oui
1-11
port-security port-mode
1-11
port-security timer disableport
1-13
port-security trap
1-13
preemption mode
1-5
preference
1-15
preference
1-56
preference
1-10
preference
1-36
1-64
1-45
1-42
preference (IS-IS view)
1-55
1-45
primary accounting (HWTACACS scheme view)
3-7
primary accounting (RADIUS scheme view)
2-9
primary authentication (HWTACACS scheme view)
3-8
primary authentication (RADIUS scheme view)
2-10
primary authorization
3-9
priority-queue-mapping
6-4
probe count
1-16
probe packet-interval
1-17
probe packet-number
1-18
probe packet-timeout
1-18
probe timeout
1-19
probe-interval (IPv6 PIM view)
1-39
probe-interval (PIM view)
1-44
protected-vlan
1-6
protected-vlan
1-10
protocol inbound
1-15
protocol-vlan
1-26
proxy-arp enable
2-2
public-key local create
1-10
public-key local destroy
1-11
public-key local export rsa
1-11
public-key peer
1-12
public-key peer import sshkey
1-13
public-key-code begin
1-8
public-key-code end
1-9
put
1-33
put
2-21
pwd
1-34
pwd
1-10
pwd
2-22
Q
qinq enable
1-3
qinq enable downlink
Access Volume-12-VLAN Mapping Commands
1-1
qinq enable uplink
1-2
qinq ethernet-type customer-tag
1-4
qinq ethernet-type service-tag
1-5
qos apply policy
1-5
qos apply policy
2-23
qos apply policy global
2-25
qos bandwidth queue
3-4
qos cos-local-precedence-map
6-5
qos gts
1-2
qos lr outbound
1-3
qos map-table
5-2
qos policy
1-6
qos policy
2-25
qos priority
5-3
qos sp
3-5
qos trust
5-5
qos vlan-policy
2-26
qos wfq
3-5
qos wfq weight
3-6
qos wred apply
4-3
qos wred queue table
4-3
qos wrr
3-7
qos wrr weight
3-7
queue
4-4
1-34
1-17
2-22
R
radius client
2-11
radius nas-ip
2-12
radius scheme
2-12
radius trap
2-13
reaction
1-20
reaction trap
1-21
reboot
1-22
reboot onu
2-25
redirect
2-10
reflect between-clients
1-49
reflect between-clients (BGP view)
1-64
reflect between-clients (IPv6 address family view)
1-46
reflect between-clients (IPv6 MBGP address family view)
1-43
reflect between-clients (MBGP family view)
1-45
reflector cluster-id (BGP view)
1-65
reflector cluster-id (IPv6 address family view)
1-47
reflector cluster-id (IPv6 MBGP address family view)
1-44
reflector cluster-id (MBGP family view)
1-46
reflector culster-id
1-50
refresh  bgp ipv4 multicast
1-47
refresh bgp
1-66
refresh bgp ipv6
1-48
refresh bgp ipv6 multicast
1-44
refresh bgp vpn-instance
1-20
1-51
refresh bgp vpnv4
1-52
region-name
1-12
register-policy (IPv6 PIM view)
1-39
register-policy (PIM view)
1-44
register-suppression-timeout (IPv6 PIM view)
1-40
register-suppression-timeout (PIM view)
1-45
register-whole-checksum (IPv6 PIM view)
1-41
register-whole-checksum (PIM view)
1-46
remark customer-vlan-id
2-11
remark dot1p
2-12
remark drop-precedence
2-12
remark dscp
2-13
remark ip-precedence
2-14
remark local-precedence
2-15
remark service-vlan-id
2-16
remotehelp
2-23
remote-ip
1-43
remove
1-35
rename
1-35
rename
1-11
report-aggregation (IGMP-Snooping view)
1-26
report-aggregation (MLD-Snooping view)
1-24
require-router-alert (IGMP view)
1-22
require-router-alert (MLD view)
1-21
reset acl counter
1-10
reset acl ipv6 counter
1-25
reset arp
1-8
reset arp detection statistics
3-8
reset bgp
1-67
reset bgp dampening
1-67
reset bgp flap-info
1-68
reset bgp ipv4 all
1-68
reset bgp ipv4 multicast
1-48
reset bgp ipv4 multicast dampening
1-48
reset bgp ipv4 multicast flap-info
1-49
reset bgp ipv6
1-48
reset bgp ipv6 dampening
1-49
reset bgp ipv6 flap-info
1-50
reset bgp ipv6 multicast
1-45
reset bgp ipv6 multicast dampening
1-46
reset bgp ipv6 multicast flap-info
1-46
reset bgp l2vpn
1-25
reset bgp vpn-instance
1-21
1-52
reset bgp vpn-instance dampening
1-22
1-53
reset bgp vpn-instance flap-info
1-22
1-54
reset bgp vpnv4
1-54
reset counters interface
1-26
reset counters uni
2-25
reset dhcp relay statistics
2-18
reset dhcp server conflict
1-20
reset dhcp server ip-in-use
1-21
reset dhcp server statistics
1-21
reset dhcp-snooping
4-11
reset dhcp-snooping packet statistics
4-12
reset dldp statistics
1-9
reset dns dynamic-host
1-8
reset dns ipv6 dynamic-host
1-36
reset dot1x statistics
1-17
reset garp statistics
1-5
reset hwtacacs statistics
3-10
reset igmp group
1-23
reset igmp group port-info
1-24
reset igmp ssm-mapping group
1-25
reset igmp-snooping group
1-26
reset igmp-snooping statistics
1-27
reset ip ip-prefix
1-27
reset ip ipv6-prefix
1-31
reset ip routing-table statistics protocol
1-24
reset ip statistics
1-18
reset ipv6 neighbors
1-36
reset ipv6 pathmtu
1-37
reset ipv6 routing-table statistics
1-25
reset ipv6 statistics
1-37
reset isis all
1-56
reset isis peer
1-56
reset lacp statistics
1-12
reset logbuffer
1-25
reset mac-authentication statistics
1-6
reset mld group
1-22
reset mld group port-info
1-23
reset mld ssm-mapping group
1-23
reset mld-snooping group
1-25
reset mld-snooping statistics
1-26
reset mpls ldp
1-43
reset mpls statistics interface
1-44
reset mpls statistics lsp
1-45
reset msdp peer
1-18
reset msdp sa-cache
1-19
reset msdp statistics
1-19
reset multicast forwarding-table
1-17
reset multicast ipv6 forwarding-table
1-11
reset multicast ipv6 routing-table
1-12
reset multicast routing-table
1-18
reset oam
1-16
reset ospf counters
1-56
reset ospf process
1-57
reset ospf redistribution
1-58
reset pim control-message counters
1-46
reset pim ipv6 control-message counters
1-41
reset portal connection statistics
1-18
reset portal server statistics
1-18
reset portal tcp-cheat statistics
1-19
reset qos policy global
2-27
reset qos vlan-policy
2-27
reset radius statistics
2-14
reset recycle-bin
1-11
reset rip statistics
1-16
reset rrpp statistics
1-11
reset saved-configuration
1-19
reset smart-link statistics
1-7
reset stop-accounting-buffer
2-14
3-10
reset stp
1-12
reset tcp ipv6 statistics
1-38
reset tcp statistics
1-18
reset trapbuffer
1-26
reset udp ipv6 statistics
1-38
reset udp-helper packet
1-1
reset unused porttag
1-23
reset vrrp ipv6 statistics
1-17
reset vrrp statistics
1-5
restore startup-configuration
1-20
retry
2-15
retry realtime-accounting
2-16
retry stop-accounting (HWTACACS scheme view)
3-11
retry stop-accounting (RADIUS scheme view)
2-17
return
1-18
revision-level
1-13
rfc1583 compatible
1-58
ring
1-12
ring enable
1-14
rip
1-17
rip authentication-mode
1-17
rip default-route
1-18
rip input
1-19
rip metricin
1-20
rip metricout
1-21
rip mib-binding
1-22
rip output
1-22
rip poison-reverse
1-23
rip split-horizon
1-23
rip summary-address
1-24
rip version
1-25
ripng
1-10
ripng default-route
1-11
ripng enable
1-12
ripng metricin
1-12
ripng metricout
1-13
ripng poison-reverse
1-14
ripng split-horizon
1-14
ripng summary-address
1-15
rmdir
1-36
rmdir
1-13
rmdir
2-25
rmon alarm
1-11
rmon event
1-13
rmon history
1-14
rmon prialarm
1-15
rmon statistics
1-17
robust-count (IGMP view)
1-26
robust-count (MLD view)
1-24
route-distinguisher
1-23
route-distinguisher (MPLS L2VPN view)
1-26
route-distinguisher (VPN instance view)
1-55
route-option bypass-route
1-21
route-policy
1-21
router id
1-24
router-aging-time (IGMP-Snooping view)
1-27
router-aging-time (MLD-Snooping view)
1-26
router-id
1-69
router-id
1-37
router-id
1-50
route-tag
1-56
routing-table limit
1-24
routing-table limit
1-57
rr-filter
1-57
rrpp domain
1-15
rrpp enable
1-15
rrpp ring-group
1-16
rule (in advanced IPv4 ACL view)
1-12
rule (in advanced IPv6 ACL view)
1-27
rule (in basic IPv4 ACL view)
1-11
rule (in basic IPv6 ACL view)
1-26
rule (in Ethernet frame header ACL view)
1-17
rule comment (for IPv4)
1-19
rule comment (for IPv6)
1-31
S
sample enable
3-20
save
1-20
schedule job
1-24
schedule reboot at
1-25
schedule reboot delay
1-27
screen-length
1-16
screen-length disable
1-18
secondary accounting (HWTACACS scheme view)
3-11
secondary accounting (RADIUS scheme view)
2-18
secondary authentication (HWTACACS scheme view)
3-12
secondary authentication (RADIUS scheme view)
2-19
secondary authorization
3-13
security-policy-server
2-20
self-service-url
1-25
send
1-17
send-router-alert (IGMP view)
1-27
send-router-alert (MLD view)
1-25
server-type
2-20
1-2
service-loopback-group
1-8
service-type
1-26
service-type
1-18
service-type ftp
1-27
service-type lan-access
1-28
set authentication password
1-19
set-overload
1-57
sflow agent ip
1-2
sflow collector ip
1-3
sflow enable
1-3
sflow interval
1-4
sflow sampling-mode
1-5
sflow sampling-rate
1-5
sftp
1-13
sftp client ipv6 source
1-14
sftp client source
1-15
sftp ipv6
1-16
sftp server enable
1-17
sftp server idle-timeout
1-17
sham-link
1-58
shell
1-20
shutdown
1-26
shutdown
1-12
shutdown
1-6
shutdown (MSDP View)
1-20
shutdown management-vlan-interface
2-26
shutdown-interval
1-28
silent-interface (OSPF view)
IP Routing Volume-04-OSPF Commands
1-59
silent-interface (RIP view)
1-26
silent-interface(OSPFv3 view)
IP Routing Volume-09-IPv6 OSPFv3 commands
1-38
slave auto-update config
1-21
slave restart
1-1
slave switchover
1-2
slave switchover { disable | enable }
1-3
smart-link flush enable
1-7
smart-link group
1-8
snmp-agent
1-11
snmp-agent calculate-password
1-12
1-13
snmp-agent group
1-15
1-16
snmp-agent log
1-17
snmp-agent mib-view
1-18
snmp-agent packet max-size
1-19
snmp-agent sys-info
1-19
snmp-agent target-host
1-21
snmp-agent trap enable
1-22
snmp-agent trap enable ospf
1-59
snmp-agent trap if-mib link extended
1-24
snmp-agent trap life
1-25
snmp-agent trap queue-size
1-25
snmp-agent trap source
1-26
snmp-agent usm-user { v1 | v2c }
1-27
snmp-agent usm-user v3
1-28
source
1-9
source interface
1-22
source ip
1-23
source port
1-24
source-deny (IGMP-Snooping view)
1-28
source-deny (MLD-Snooping view)
1-27
source-lifetime (IPv6 PIM view)
1-42
source-lifetime (PIM view)
1-47
source-policy (IPv6 PIM view)
1-42
source-policy (PIM view)
1-47
speed
1-27
speed
System Volume-01-Login Commands
1-21
speed auto
1-28
spf timers
1-38
spf-schedule-interval
1-61
spt-switch-threshold infinity (IPv6 PIM view)
1-43
spt-switch-threshold infinity (PIM view)
1-48
ssh client authentication server
1-18
ssh client first-time enable
1-18
ssh client ipv6 source
1-19
ssh client source
1-20
ssh server authentication-retries
1-20
ssh server authentication-timeout
1-21
ssh server compatible-ssh1x enable
1-22
ssh server enable
1-22
ssh server rekey-interval
1-23
ssh user
1-24
ssh2
1-25
ssh2 ipv6
1-26
ssm-mapping (IGMP view)
1-27
ssm-mapping (MLD view)
1-25
ssm-policy (IPv6 PIM view)
1-44
ssm-policy (PIM view)
1-49
startup saved-configuration
1-22
startup-query-count (IGMP view)
1-28
startup-query-count (MLD view)
1-26
startup-query-interval (IGMP view)
1-29
startup-query-interval (MLD view)
1-27
state
Security Volume-01-AAA Commands
1-28
state
2-21
state-refresh-hoplimit
1-45
state-refresh-interval (IPv6 PIM view)
1-46
state-refresh-interval (PIM view)
1-50
state-refresh-rate-limit (IPv6 PIM view)
1-46
state-refresh-rate-limit (PIM view)
1-51
state-refresh-ttl
1-51
static-bind client-identifier
1-22
static-bind ip-address
1-23
static-bind mac-address
1-23
static-lsp egress
1-45
static-lsp ingress
1-46
static-lsp transit
1-47
static-rp (IPv6 PIM view)
1-47
static-rp (PIM view)
IP Multicast Volume-03-PIM Commands
1-52
static-rpf-peer
1-20
statistics interval
1-48
step (for IPv4)
Security Volume-08-ACL Commands
1-20
step (for IPv6)
1-32
stop-accounting-buffer enable (HWTACACS scheme view)
3-14
stop-accounting-buffer enable (RADIUS scheme view)
2-22
stopbits
1-22
storm-constrain
1-29
storm-constrain control
1-30
storm-constrain enable log
1-31
storm-constrain enable trap
1-32
storm-constrain interval
1-32
stp
Access Volume-16-MSTP Commands
1-14
stp bpdu-protection
1-15
stp bridge-diameter
1-15
stp compliance
1-16
stp config-digest-snooping
1-17
stp cost
1-18
stp edged-port
1-19
stp loop-protection
1-20
stp max-hops
1-21
stp mcheck
1-21
stp mode
1-22
stp no-agreement-check
1-23
stp pathcost-standard
1-24
stp point-to-point
1-25
stp port priority
1-26
stp port-log
1-27
stp priority
1-28
1-29
stp root primary
1-29
stp root secondary
1-30
stp root-protection
1-31
stp tc-protection
1-32
stp tc-protection threshold
1-32
stp timer forward-delay
1-33
stp timer hello
1-34
stp timer max-age
1-35
stp timer-factor
1-36
stp transmit-limit
1-36
strict-standby enable
1-29
stub (OSPF area view)
1-61
stub (OSPFv3 area view)
1-39
stub-router
1-62
subvlan
2-2
subvlan (IPv6 multicast VLAN view)
1-4
subvlan (multicast VLAN view)
1-4
summary
1-27
summary (IS-IS view)
IP Routing Volume-05-IS-IS Commands
1-58
summary automatic
IP Routing Volume-06-BGP Commands
1-70
summary automatic (MBGP family view)
IP Multicast Volume-05-MBGP Commands
1-49
super
1-19
super password
1-20
supervlan
2-3
switch-mode (for LPU)
System Volume-03-Device Management Commands
1-31
switch-mode (for SRPU)
1-30
synchronization (BGP view)
1-70
synchronization (IPv6 address family view)
IP Routing Volume-11-IPv6 BGP Commands
1-51
sysname
1-21
1-22
T
tcp ipv6 timer fin-timeout
1-39
tcp ipv6 timer syn-timeout
1-39
tcp ipv6 window
1-40
tcp timer fin-timeout
1-19
tcp timer syn-timeout
1-20
tcp window
1-20
telnet
1-22
telnet client source
1-24
telnet ipv6
1-23
telnet server enable
1-25
temperature-limit
1-32
terminal debugging
1-26
terminal logging
1-27
terminal monitor
1-28
terminal trapping
1-29
terminal type
1-25
tftp
System Volume-04-File System Management Commands
3-2
tftp client source
3-3
tftp ipv6
3-4
tftp-server acl
3-1
tftp-server domain-name
IP Services Volume-03-DHCP Commands
1-24
tftp-server ip-address
1-25
timer
1-17
1-71
1-52
timer hello (IPv6 PIM view)
IP Multicast Volume-11-IPv6 PIM Commands
1-48
timer hello (PIM view)
1-53
timer join-prune (IPv6 PIM view)
1-49
timer join-prune (PIM view)
1-54
timer lsp-generation
1-59
timer lsp-max-age
1-60
timer lsp-refresh
1-61
timer monitor
Access Volume-15-EPON OLT Commands
3-21
timer other-querier-present (IGMP view)
1-29
timer other-querier-present (MLD view)
1-28
timer query (IGMP view)
1-30
timer query (MLD view)
1-28
timer quiet (HWTACACS scheme view)
3-15
timer quiet (RADIUS scheme view)
2-23
timer realtime-accounting (HWTACACS scheme view)
3-15
timer realtime-accounting (RADIUS scheme view)
2-23
timer response-timeout (HWTACACS scheme view)
3-16
timer response-timeout (RADIUS scheme view)
2-24
timer retry
IP Multicast Volume-04-MSDP Commands
1-21
timer sample
3-21
timer spf
1-61
time-range
1-3
timers
IP Routing Volume-03-RIP Commands
1-27
timers
IP Routing Volume-08-IPv6 RIPng Commands
1-16
tnl-policy (VPN instance view)
1-60
tos
1-24
tracert
1-4
tracert ipv6
1-5
tracert lsp
1-48
track nqa
1-2
traffic behavior
Access Volume-10-QinQ Commands
1-7
traffic behavior
QoS Volume-01-QoS Commands
2-16
traffic classifier
1-7
traffic classifier
2-5
transmit-pacing
1-63
ttl
1-25
ttl expiration pop
1-49
ttl propagate
1-50
tunnel select-seq load-balance-number
1-61
tunnel-policy
1-60
tunnel-protocol
1-9
type
1-26
U
udp-helper enable
1-2
udp-helper port
1-2
udp-helper server
1-3
umount
1-14
undelete
1-14
uni auto-negotiation
2-27
uni classification-marking
6-7
uni description
2-28
uni duplex
2-28
uni flow-control
2-29
uni igmp-snooping fast-leave
2-30
uni mdi
2-30
uni mirroring-port
1-8
uni monitor-port
1-9
uni multicast vlan
2-31
uni multicast-control multicast-address
2-32
uni multicast-group-number
2-33
uni multicast-strip-tag enable
2-34
uni port-isolate
2-35
uni port-policy
6-9
uni restart auto-negotiation
2-36
uni shutdown
2-36
uni speed
2-37
uni vlan-mode tag pvid
2-38
uni vlan-mode translation pvid
2-39
uni vlan-mode transparent
2-40
unicast-suppression
Access Volume-01-Ethernet Interface Commands
1-33
update onu filename
2-42
update onu onu-type
2-43
upstream-sla
2-41
url
System Volume-12-NQA Commands
1-26
user
2-25
user privilege level
1-27
user-bind
1-4
user-interface
1-26
username (FTP test type view)
1-27
user-name-format (HWTACACS scheme view)
3-17
user-name-format (RADIUS scheme view)
2-25
using onu
1-28
V
validate-source-address
1-28
verbose
2-26
version
1-29
version (IGMP view)
1-31
version (MLD view)
1-29
virtual-cable-test
1-35
virtual-system
1-63
vlan
1-7
vlan precedence
1-21
vlan-mapping modulo
1-37
vlink-peer (OSPF area view)
1-64
vlink-peer (OSPFv3 area view)
1-40
voice vlan
4-3
voice vlan aging
4-4
voice vlan enable
4-4
voice vlan mac-address
4-5
voice vlan mode auto
4-6
voice vlan security enable
4-7
voice-config
1-26
vpn-instance (ICMP-echo test type view)
1-28
vpn-instance-capability simple
1-25
vpn-target
1-25
vpn-target (MPLS L2VPN view)
MPLS Volume-03-MPLS L2VPN Commands
1-26
vpn-target (VPN instance view)
MPLS Volume-04-MPLS L3VPN Commands
1-62
vrrp ipv6 method
1-19
vrrp ipv6 ping-enable
1-20
vrrp ipv6 vrid authentication-mode
1-18
vrrp ipv6 vrid preempt-mode
1-20
vrrp ipv6 vrid priority
1-21
vrrp ipv6 vrid timer advertise
1-22
vrrp ipv6 vrid track interface
1-23
vrrp ipv6 vrid virtual-ip
1-24
vrrp method
1-6
vrrp ping-enable
1-7
vrrp un-check ttl
1-8
vrrp vrid authentication-mode
1-5
vrrp vrid preempt-mode
1-8
vrrp vrid priority
1-9
vrrp vrid timer advertise
1-10
vrrp vrid track
1-11
vrrp vrid track interface
1-12
vrrp vrid virtual-ip
1-13
W
work-directory
1-29
X
Y
Z
