H3C S9500 Operation Manual-Release1648[v1.24]-03 IP Routing Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release1648[v1.24]-03 IP Routing Volume
09-Recursive Routing Configuration
09-Recursive Routing Configuration 23.54 KB
Chapter 1  Recursive Routing Configuration
When configuring recursive routing, go to these sections for information you are interested in:
l           Recursive Routing Overview
l           Recursive Routing Configuration
&  Note:
The term “router” or the router icon in this document refers to a router in a generic sense or an S9500 switch running routing protocols.
1.1  Recursive Routing Overview
Every route entry must have its next hop address. For a common route, its next hop address is within the network segment to which the router is directly connected; for a route requiring recursion, its next hop address is not directly connected. During route forwarding, this non-directly connected next hop address must be recursion-processed once or several times to find out a directly connected next hop address to enable L2 path searching. A recursive route can be a static route or BGP route. Recursive routing can make route entries flexible, independent of a specific interface.
1.2  Recursive Routing Configuration
Follow these steps to configure recursive routing:
To do…
Use the command…
Remarks
Enter system view
Enable recursive routing
route-rely [ bgp | static ]
By default, both routes learned by the BGP and static routes support recursive routing.
&  Note:
Currently, only 2-layer recursive routing is supported.
