H3C S9500 Command Manual-Release2132[V2.03]-08 System Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-08 System Volume
17-Clock Monitoring Commands
17-Clock Monitoring Commands 76.09 KB
Chapter 1  Clock Monitoring Configuration Commands
&  Note:
The clock monitoring configuration commands are available when the SRPUs are installed with a clock module. If the SRPUs are not installed with a clock module, all these commands are invisible. For information about SRPUs installed with a clock module, refer to the S9500 Series Routing Switches  Installation Manual.
1.1  Clock Monitoring Configuration Commands
1.1.1  clock
clock { auto | manual source source-number }
undo clock work-mode
View
Default Level
2: System level
auto: Sets the clock monitoring module to work in auto mode.
manual source source-number: Sets the clock monitoring module to work in manual mode. source-number indicates the primary clock source number in manual mode.
Use the clock command to set the work mode of the SRPU clock monitoring module, that is, the mode the clock monitoring module uses to choose clock source, either auto mode or manual mode.
Use the undo clock work-mode command to restore the default.
By default, the work mode is auto.
Note that:
l           Before configuring the work mode as manual, you should use the display clock source command to view the clock source state. Only clock sources working normally can be successfully configured as the primary clock source.
l           After you set the work mode of the clock monitoring module, it takes a period of time for device response. In this case, you can check whether your configuration takes effect through the display clock device command and the logging information.
# Set the working mode of the SRPU clock monitoring module to manual, and the primary clock source to 1.
[Sysname] clock manual source 1
1.1.2  clock forcessm
clock forcessm { on | off } source source-number
View
Default Level
2: System level
on: Specifies not to derive the SSM levels from the clock source, namely, uses the SSM levels manually configured by users.
off: Derives the SSM levels from the clock source. The user-configured SSM levels are not effective.
source-number: Number of clock source.
Use the clock forcessm command to set whether to derive the SSM levels from clock source or to configure the SSM levels manually by users.
By default, the SSM levels are manually configured.
Related commands: clock ssm.
# Derive SSM level from the clock source 1.
[Sysname] clock forcessm off source 1
1.1.3  clock lpuport
clock lpuport interface-type interface-number
undo clock lpuport interface-type interface-number
View
Default Level
2: System level
interface-type interface-number: Specifies a port by its type and number.
Use the clock lpuport command to specify the input port of the line clock source (LPU port).
Use the undo clock lpuport command to restore the default.
By default, the LPU port is the first configurable port by port name in lexical order of the ports on the interface card.
&  Note:
l      For a WAN interface card, if you set the port clock to work in slave mode, you must use this command to select the LPU port of the clock source of the interface card.
l      The clock mode of the LPU port of the line clock source must be slave.
# Set the LPU port of the line clock source as interface POS 3/1/1.
[Sysname] clock lpuport pos 3/1/1
1.1.4  clock priority
clock priority value source source-number
undo clock priority source source-number
View
Default Level
2: System level
value: Priority value.
Use the clock priority command to the reference source priority.
Use the undo clock priority command to the restore the default.
By default, the priority of all reference sources is 255.
# Set the priority of reference source 2 to 3.
[Sysname] clock priority 3 source 2
1.1.5  clock sa-bit
clock sa-bit { sa4 | sa5 | sa6 | sa7 | sa8 } source source-number
undo clock sa-bit source source-number
View
Default Level
2: System level
sa4: Indicates that the bit position is sa4.
sa5: Indicates that the bit position is sa5.
sa6: Indicates that the bit position is sa6.
sa7: Indicates that the bit position is sa7.
sa8: Indicates that the bit position is sa8.
source-number: Number of Bits clock source.
Use the clock sa-bit command to set the bit position used to transmit Bits clock source information.
Use the undo clock sa-bit command to restore the default.
By default, sa4 is used to carry the SSM information.
# Set the bit position used to transmit the SSM information of Bits clock source 1 to sa5.
[Sysname] clock sa-bit sa5 source 1
1.1.6  clock ssm
clock ssm { dnu | lnc | prc | sets | tnc | unknown } source source-number
undo clock ssm source source-number
View
Default Level
2: System level
dnu: Specifies the SSM level to DNU. (DoNotUse).
lnc: Specifies the SSM level to LNC (G.812 local node clock signal).
prc: Specifies the SSM level to PRC (G.811 clock signal).
sets: Specifies the SSM level to SETS (SDH device clock source signal).
tnc: Specifies the SSM level to TNC (G.812 transit node clock signal).
unknown: Specifies the SSM level to unknown (Unknown synchronization quality).
source-number: Number of reference source.
Use the clock ssm command to set the SSM levels of the reference sources.
Use the undo clock ssm command to restore the default.
By default, the SSM level of all reference sources is unknown.
Note that:
l           For the line clock source, the SSM level configured is that of the clock source.
l           For Bits clock source, if the input signal is a 2048 kbps (E1) signal and the clock forcessm off source is executed, the clock source adopts the SSM level derived from the input signals and the SSM configured is omitted.
l           For Bits clock source, if the input signal is a 2048 kHz signal or a 2048 kbps signal and the clock forcesssm on source command is executed, the clock source adopts the SSM level configured.
l           After you set the SSM levels of the reference sources, it takes a period of time for device response. In this case, you can check whether your configuration takes effect through the display clock ssm-level command and the logging information.
# Set the SSM level of clock source 1 to DNU.
[Sysname] clock ssm dnu source 1
1.1.7  clock ssmcontrol
clock ssmcontrol { on | off }
undo clock ssmcontrol
View
Default Level
2: System level
on: Activates SSM level.
off: Deactivates SSM level.
Use the clock ssmcontrol command to activate or deactivate SSM level.
Use the undo clock ssmcontrol command to restore the default.
By default, SSM level is deactivated.
Note that:
l           When SSM level is activated, the SSM level becomes the decisive factor in reference source automatic selection.
l           When SSM level is not activated, you can still set and view the SSM levels, but they are ignored in reference source automatic selection are decided by reference source priority.
# Activate SSM of clock monitoring module.
[Sysname] clock ssmcontrol on
1.1.8  clock stop warm-up
clock stop warm-up
View
Default Level
2: System level
None
Use the clock stop warm-up command to manually stop the clock monitoring module from warming up and enable it to work normally.
# Manually stop the clock monitoring module from warming up and enable it to work normally.
[Sysname] clock stop warm-up
1.1.9  display clock basephase
View
Default Level
1: Monitor level
None
Use the display clock basephase command to view the synchronized clock base phase.
# View the synchronized clock base phase
<Sysname> display clock basephase
clock base phase : 0x0
The above prompt information indicates that the synchronized clock base phase is 0.
1.1.10  display clock config
View
Default Level
1: Monitor level
None
Use the display clock config command to display the current configurations of the clock monitoring module.
# View the current configurations of the clock monitoring module.
<Sysname> display clock config
Clock module current configuration:
         Work mode : auto
         SSM participate in control : no
Reference  Priority  SSM level Forcessm  Sa-bit  Lpu port
    1         255       UNKNOWN      yes        4        N/A
    2         255       UNKNOWN      yes        4        N/A
    3         255       UNKNOWN      N/A       N/A        -
    4         255       UNKNOWN      N/A       N/A        -
    5         255       UNKNOWN      N/A       N/A        -
    6         255       UNKNOWN      N/A       N/A        -
    7         255       UNKNOWN      N/A       N/A        -
    8         255       UNKNOWN      N/A       N/A        -
    9         255       UNKNOWN      N/A       N/A        -
   10         255       UNKNOWN      N/A       N/A        -
   11         255       UNKNOWN      N/A       N/A        -
   12         255       UNKNOWN      N/A       N/A        -
   13         255       UNKNOWN      N/A       N/A        -
   14         255       UNKNOWN      N/A       N/A        -
   15         255       UNKNOWN      N/A       N/A        -
   16         255       UNKNOWN      N/A       N/A        -
   17         255       UNKNOWN      N/A       N/A        -
   18         255       UNKNOWN      N/A       N/A        -
Table 1-1 display clock config command output description
Current configuration of the clock monitoring module
Work mode
Work mode of the clock monitoring module, with auto indicating the auto mode and manual indicating the manual mode.)
Whether SSM is activated
Reference
Serial number of the reference source
Priority
Priority of the reference source
SSM level
SSM level of the reference source
Forcessm
Derive mode of the SSM level, with yes meaning derived from Bits clock source and N/A meaning this function is not supported.
Sa-bit
Bits used to transmit SSM level information of the Bits clock source
Lpu port
Input port of the line clock source (N/A indicates this function is not supported and (;) indicates this port is not configured)
1.1.11  display clock d/a
display clock d/a
View
Default Level
1: Monitor level
None
Use the display clock d/a command to view the D/A value of the Digital to Analog Converter (DAC) in the clock monitoring module.
# View the D/A value of the DAC in the clock monitoring converter.
<Sysname> display clock d/a
DAC Voltage : 2048
The above prompt information indicates that the D/A value of the DAC in the clock monitoring converter is 2048 V.
1.1.12  display clock device
View
Default Level
1: Monitor level
None
Use the display clock device command to view detailed information of the clock monitoring module.
# View detailed information of the clock monitoring module.
<Sysname> display clock device
Clock module detail information:
Clock module state is OK
         SRAM state: OK
         Output 38.88Mhz signal state: OK
         PLL tru050 state: OK
         PLL 88915 state: OK
         OSC state: OK
         I2C bus state: OK
         EPLD state: OK
         HDLC state: OK
         E1 A state: OK
         E1 B state: OK
Reference state
         Work mode : auto
         Traced reference : 0
         Lock mode : freerun
         OSC state : normal
         SSM output level : LNC
         SSM participate in control : No
Reference   State   Priority  SSM-level Forcessm  Sa-bit  Lpu port
   1         lost      255     UNKNOWN      yes       4        N/A
   2         lost      255     UNKNOWN      yes       4        N/A
   3         lost      255     UNKNOWN      N/A       N/A       -
   4         lost      255     UNKNOWN      N/A       N/A       -
   5         lost      255     UNKNOWN      N/A       N/A       -
   6         lost      255     UNKNOWN      N/A       N/A       -
   7         lost      255     UNKNOWN      N/A       N/A       -
   8         lost      255     UNKNOWN      N/A       N/A       -
   9         lost      255     UNKNOWN      N/A       N/A       -
  10         lost      255     UNKNOWN      N/A       N/A       -
  11         lost      255     UNKNOWN      N/A       N/A       -
  12         lost      255     UNKNOWN      N/A       N/A       -
  13         lost      255     UNKNOWN      N/A       N/A       -
  14         lost      255     UNKNOWN      N/A       N/A       -
  15         lost      255     UNKNOWN      N/A       N/A       -
  16         lost      255     UNKNOWN      N/A       N/A       -
  17         lost      255     UNKNOWN      N/A       N/A       -
  18         lost      255     UNKNOWN      N/A       N/A       -
Table 1-2 display clock device command output description
Displaying detailed information of the clock monitoring module
Clock module state
Current state of the clock monitoring module
SRAM state
State of SRAM
State of output 38.88 MHz signal
PLL tru050 state
State of PLL tru050
PLL 88915 state
State of PLL 88915
OSC state
State of OSC
I2C bus state
Bus state of I2C
EPLD state
State of EPLD
HDLC state
State of HDLC
E1 A state
State of E1 A
E1 B state
State of E1 B
Reference state
Reference state
Work mode
Work mode
Traced reference
Traced reference
Lock mode
Lock mode
OSC state
State of OSC
SSM output level
SSM output level
Reference
Number of the reference source
State of the reference source
Priority
SSM-level
SSM of the reference source
Forcessm
Whether the SSM level of the reference source is activated or not
Sa-bit
Lpu port
1.1.13  display clock lpuport
View
Default Level
1: Monitor level
None
Use the display clock lpuport command to view the LPU port of the line clock source.
# View the LPU port of the line clock source.
<Sysname> display clock lpuport
The LPU port(s) which output(s) clock reference:
  Reference        Lpu port(portname)
      3            Pos6/1/1
     11            Pos8/1/2
Table 1-3 display clock lpuport command output description
Input port information of the line clock source
Reference
Lpu port (portname)
Input port of the line clock source (port name)
1.1.14  display clock phase-lock-state
View
Default Level
1: Monitor level
None
Use the display clock phase-lock-state command to view the phase lock state of the clock monitoring module, including free run, lock, fast lock, and hold.
# View the phase lock state of the clock monitoring module.
<Sysname> display clock phase-lock-state
Phase lock state: hold
Osc state: normal, finished warm-up
Table 1-4 display clock phase-lock-state command output description
Phase lock state:
The phase lock state of the clock monitoring module, including free-run, lock, fast lock, and hold
Osc state:
Osc state
finished warm-up
Warm-up is finished.
1.1.15  display clock priority
View
Default Level
1: Monitor level
None
Use the display clock priority command to view the priority of all reference sources.
# View the priority of all reference sources.
<Sysname> display clock priority
Reference  Priority
     1        255
     2          4
     3        255
     4        255
     5        255
     6        255
     7        255
     8        255
     9        255
    10        255
    11        255
    12        255
    13        255
    14        255
    15        255
    16        255
    17        255
    18        255
1.1.16  display clock self-test-result
View
Default Level
1: Monitor level
None
Use the display clock self-test-result command to view the self-test result of the clock monitoring module.
# View the self-test result of the clock monitoring module.
<Sysname> display clock self-test-result
Clock module work mode: normal
Detail test report:
         SRAM        : normal
         Output 38.88MHz signal: normal
         PLL TRU050  : normal
         PLL 88915   : normal
         OSC         : normal
         I2C bus     : normal
         EPLD        : normal
         HDLC        : normal
         E1a         : normal
         E1b         : normal
Table 1-5 display clock self-test-result command output description
Detail test report
Detailed test report
SRAM
SRAM state
Output 38.88 MHz signal
Whether 38.88 MHz signal can be output
PLL TRU050
PLL TRU050 state
PLL 88915
PLL 88915 state
OSC
OSC state
I2C bus
I2C bus state
EPLD
EPLD state
HDLC
HDLC state
E1a
E1a state
E1b
E1b state
1.1.17  display clock source
View
Default Level
1: Monitor level
None
Use the display clock source command to view the status of all reference sources.
# View the status of all reference sources.
<Sysname> display clock source
No primary reference is traced
 Reference       State       Lpu port(portname)
     1            lost         N/A
     2            lost         N/A
     3            lost         -
     4            lost         -
     5            lost         -
     6            lost         -
     7            lost         -
     8            lost         -
     9            lost         -
    10            lost         -
    11            lost         -
    12            lost         -
    13            lost         -
    14            lost         -
    15            lost         -
    16            lost         -
    17            lost         -
18            lost         -
Table 1-6 display clock source command output description
No primary reference is traced, meaning no primary reference is manually specified.
Reference
Serial number of the clock source
Lpu port (portname)
Input port of the line clock corresponding with the reference source (port name)
1.1.18  display clock ssm-level
View
Default Level
1: Monitor level
None
Use the display clock ssm-level command to view the SSM level of all reference sources.
#View the SSM level of all reference sources.
<Sysname> display clock ssm-level
Reference SSM level
    1        LNC
    2      UNKNOWN
    3      UNKNOWN
    4        LNC
    5      UNKNOWN
    6      UNKNOWN
    7      UNKNOWN
    8      UNKNOWN
    9      UNKNOWN
   10      UNKNOWN
   11      UNKNOWN
   12      UNKNOWN
   13      UNKNOWN
   14      UNKNOWN
   15      UNKNOWN
   16      UNKNOWN
   17      UNKNOWN
   18      UNKNOWN
In the above prompt information, the Reference field indicates the serial number of the reference source and the SSM level field indicates the SSM level of the reference source.
1.1.19  display clock ssm-output
View
Default Level
1: Monitor level
None
Use the display clock ssm-output command to view the SSM level of the output clock signal.
# View the SSM level of the output clock signal.
<Sysname> display clock ssm-output
SSM output level is UNKNOWN.
1.1.20  display clock version
View
Default Level
1: Monitor level
None
Use the display clock version command to view clock monitoring module version.
# View clock monitoring module version.
<Sysname> display clock version
Clock module version
         Software version: v010
         Hardware version: Rev.A
         CPLD version: v009
         Release date: 2006-02-26
Table 1-7 display clock version command output description
Version of the clock monitoring module
Software version
Software version of the clock monitoring module
Hardware version
Hardware version of the clock monitoring module
CPLD version
CPLD version of the clock monitoring module
Release date
Release version of the clock monitoring module
1.1.21  display clock work-mode
View
Default Level
1: Monitor level
None
Use the display clock work-mode command to view the work mode of the clock monitoring module.
# View the work mode of the clock monitoring module.
<Sysname> display clock work-mode
Clock working in auto mode.
The above prompt information indicates that the clock monitoring module works in auto mode.
