H3C S9500 Command Manual-Release2132[V2.03]-08 System Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-08 System Volume
07-NTP Commands
07-NTP Commands 143.61 KB
Chapter 1  NTP Configuration Commands
1.1  NTP Configuration Commands
1.1.1  debugging ntp-service
debugging ntp-service { access | adjustment | all | authentication | event | filter | packet | parameter | refclock | selection | synchronization | validity }
undo debugging ntp-service { access | adjustment | all | authentication | event | filter | packet | parameter | refclock | selection | synchronization | validity }
View
Default Level
1: Monitor level
access: Enables debugging for NTP access control.
adjustment: Enables debugging for NTP clock adjustment.
all: Enables all NTP debugging.
authentication: Enables debugging for NTP authentication.
event: Enables debugging for NTP events.
filter: Enables debugging for NTP clock filtering.
packet: Enables debugging for NTP packets.
parameter: Enables debugging for NTP clock parameters.
refclock: Enables debugging for NTP reference clock.
selection: Enables debugging for NTP clock selection information.
synchronization: Enables debugging for NTP clock synchronization information.
validity: Enables debugging for NTP remote server validity.
Use the debugging ntp-service command to enable the corresponding NTP debugging function(s).
Use the undo debugging ntp-service command to disable the corresponding NTP debugging function(s).
By default, all NTP debugging is disabled.
&  Note:
access and synchronization debugging are for extension use.
Table 1-1 debugging ntp-service adjustment command output description
NTP: gradual systime
Adjust system time by steps
NTP: step systime
Adjust system time in a single step
adj: string
Adjustment value of this time
residual: string
Residual value of last time
offset: string
Offset of single step adjustment
Table 1-2 debugging ntp-service authentication command output description
session_key
Session key
srcadr: string
Source IP address
dstadr: string
Destination IP address
keyid: string
Key ID
life: string
Life time of the key
auth_agekeys
State of the key life time
time: string
Current time of the key life time
trusted keynum: string
Number of trusted keys
expired keynum: string
Number of keys to be expired
Authentication keyID: string
Authentication key ID
Table 1-3 debugging ntp-service event command output description
NTP: control event
NTP control event
event: string
Event code
eventnum: string
Number of events
peer: string
IP address of the peer
Table 1-4 debugging ntp-service filter command output description
NTP: adj freq
Adjustment frequency
last clockoffset: string
Last clock offset
last drift_comp: string
Last frequency
new clockOffset: string
New clock offset
new drift_comp: string
New frequency
The offset string is larger than the value permitted, no adjustment.
Adjustment cannot be made, because the offset is larger than the value that can be adjusted.
Table 1-5 debugging ntp-service packet command output description
NTP: titleAndTip control packet from sourceIPAddress to DestIPAddress
titleAndTip: Title and prompt information
sourceIPAddress: Source IP address of the control packet
DestIPAddress: Destination IP address of the control packet
version: string
Protocol version in the control packet
r: string
Response bit in the control packet
e: string
Error bit in the control packet
m: string
Meet bit in the control packet
o: string
Operation code in the control packet
sequence: string
Sequence number in the control packet
status: string
Status word in the control packet
associationID: string
Association ID in the control packet
data: string
Data information in the control packet
authenticator: string
Message authenticator in the control packet
packet to string
Destination IP address of the packet sent
leap: string
Trap information in the packet
version: string
Protocol version in the packet
mode: string
Working mode in the packet
vrfindex: string
VPN index of the packets received or sent
stratum: string
Stratum in the packet
poll: string
Poll interval in the packet
precision: string
Precision in the packet
rdel: string
Root delay in the packet
rdsp: string
Root dispersion in the packet
refid: string
Reference clock identity  in the packet
reftime: string
Reference timestamp in the packet
orgtime: string
Originate timestamp in the packet
rectime: string
Receive timestamp in the packet
xmttime: string
Transmit timestamp in the packet
inptime: string
Input timestamp
packet from SourceIPAddress to DestIPAddress on InterfaceName
SourceIPAddress: Source IP address of the packet
DestIPAddress: Destination IP address of the packet
InterfaceName: Name of the interface that receives the packet
Table 1-6 debugging ntp-service parameter command output description
NTP: popcorn spike: string
Popcorn spike of the offset when calculating time sample
NTP: discard: string
A new time sample is discarded when the new time sample is smaller than or equals the select time sample. The lifetime of the dropped sample is displayed here.
clock_filter(PeerAddr, SampleOffset, SampleDelay, SampleDisp)
Peer IP address, time sample offset, time sample delay, and time sample dispersion in clock filtering
offset: string
Peer offset
delay: string
Peer delay
dispersion: string
Peer dispersion
std: string
Peer jitter
Table 1-7 debugging ntp-service refclock command output description
Report Event:
Reference clock event
Clock: string
Reference clock IP address
Event: string
Description on the clock event
Code: string
Clock event code
RefClock Transmit: At CurrentTime IPAddr
Reference clock transmits analog information.
CurrentTime: Current system time
IPAddr: IP address of the reference clock.
RefClock Sample:
Time sample of the reference clock
sampleNum: string
Number of samples
offset: string
Offset
disp: string
Dispersion
std: string
Jitter
RefClock Receive: At CurrentTime IPAddr
Reference clock receives analog information.
Table 1-8 debugging ntp-service selection command output description
nlist: string
Number of candidate clocks in the candidate clock list
allow: string
Number of allowed candidate clocks
found: string
Number of dropped candidate clocks
low: string
Lower threshold of the sample time difference
high: string
Upper threshold of the sample time difference
candidate: string
IP address of a candidate clock
cdist: string
Synchronization distance of a candidate clock
disp: string
Dispersion of a candidate clock
survivor: string
IP address of the survivor (the candidate clock that has passed the checks)
offset: string
Offset of the survivor
cdist: string
Dispersion of the survivor
syspeer: string
IP address of the system select clock source
offset: string
Offset of the system select clock source
Table 1-9 debugging ntp-service validity command output description
NTP: packet from SourceIPAddr, TestResult validity tests TestCode
SourceIPAddr: Source IP address of the packet
TestResult: Test result, succeed or fail
TestCode: Code of the test item
Description of specific test item codes:
l      0x0001: Receives the copied information
l      0x0002: Receives forged information
l      0x0004: The information is not synchronized.
l      0x0008: The peer delay/dispersion is out of range.
l      0x0010: Peer authentication fails.
l      0x0020: Peer clock is not synchronized
l      0x0040: Peer stratum is out of range.
l      0x0080: Root delay/dispersion is out of range.
l      0x0100: Peer is not authenticated.
l      0x0200: Access is denied.
# Two network devices Sysname A and Sysname B:
l           The IP address of VLAN-interface 1 of Sysname A is 10.1.1.1.
l           The IP address of VLAN-interface 1 of Sysname B is 10.1.1.2.
l           There is a route between 10.1.1.1 and 10.1.1.2.
l           Sysname B uses local clock as the reference clock, with the stratum of 8.
l           Enable NTP packet debugging on Sysname A.
l           Sysname A is synchronized to Sysname B in the symmetric peers mode.
<SysnameA> debugging ntp-service packet
<SysnameA> terminal debugging
<SysnameA> terminal monitor
<SysnameA> system-view
[SysnameA] ntp-service unicast-peer 10.1.1.2
# After the above configuration, the following packet debugging information is displayed on Sysname A:
*0.91612291 Sysname A NTP/8/debug_NTP_packet_xmt:
 packet to 10.1.1.2
 leap: 3, version: 3, mode: 3, vrfindex: 0
 stratum: 0, poll: 64, precision: 2**18
 rdel: 0.000, rdsp: 0.000, refid: 0.0.0.0
 reftime: 03:43:57.233 UTC Jan 17 2001(BE0F937D.3BB2031C)
 orgtime: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
 rectime: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
 xmttime: 03:48:34.289 UTC Jan 17 2001(BE0F9492.4A273929)
// NTP module sends an NTP request to Sysname B, with the destination IP address being 10.1.1.2; the local clock trap bit (leap) is 3, local NTP version number is 3; working mode is 3; the VPN index of the packets sent is 0 (namely, the public network); local clock stratum is 0; the polling interval is 64 seconds, clock precision is the eighteenth power of 1/2 seconds; local delay is 0.000; root dispersion is 0.000; reference source ID is 0.0.0.0, which indicates there is no reference source; the follow-up information includes reference timestamp, originate timestamp, receive timestamp, and transmit timestamp respectively.
%Jan 17 03:48:34:320 2001 Sysname A NTP/5/NTP_LOG:
System leap changes from 3 to 0 after clock update.
%Jan 17 03:48:34:331 2001 Sysname A NTP/5/NTP_LOG:
System stratum changes from 16 to 9 after clock update.
// Log information about system clock trap (leap) and stratum changes.
*0.91612341 Sysname A NTP/8/debug_NTP_packet_rcv:
 packet from 10.1.1.2 to 10.1.1.1 on Vlan-interface1
 leap: 0, version: 3, mode: 4, vrfindex: 0
 stratum: 8, poll: 64, precision: 2**18
 rdel: 0.000, rdsp: 10.941, refid: 127.127.1.0
 reftime: 03:48:08.827 UTC Jan 17 2001(BE0F9478.D3C69728)
 orgtime: 03:48:34.289 UTC Jan 17 2001(BE0F9492.4A273929)
 rectime: 03:48:34.287 UTC Jan 17 2001(BE0F9492.497A4617)
 xmttime: 03:48:34.287 UTC Jan 17 2001(BE0F9492.49983947)
 inptime: 03:48:34.302 UTC Jan 17 2001(BE0F9492.4D592D98)
// Sysname A receives the NTP response from Sysname B. The IP address of VLAN-interface 1 of Sysname B is 10.1.1.2 and that of Sysname A is 10.1.1.1, and the packet ingress interface is VLAN-interface 1; Sysname B’s trap bit (leap) is 0, indicating that Sysname B is synchronized; Sysname B’s NTP version number is 3, working mode is 4, the VPN index corresponding to the packet egress interface is 0; the peer clock stratum is 8; the polling interval is 64 seconds; clock precision is the eighteenth power of 1/2 seconds, root delay is 0.000, root dispersion is 10.941, reference source ID is 127.127.1.0, which indicates the reference source is the local clock; the follow-up information includes reference timestamp, originate timestamp, receive timestamp, transmit timestamp, and the input timestamp (the timestamp when the packet is processed locally) respectively.
&  Note:
The example here just shows the information of the first two packets. Actually, the above packet interactive process will proceed for multiple times.
1.1.2  display ntp-service sessions
display ntp-service sessions [ verbose ]
View
Default Level
1: Monitor level
verbose: Displays the detailed information of all NTP sessions.
Use the display ntp-service sessions command to view the information of all NTP sessions. Without the verbose keyword, this command displays only the brief information of all NTP service sessions.
# View the brief information of NTP service sessions.
<Sysname> display ntp-service sessions
source          reference      stra  reach   poll    now    offset delay disper
[12345]1.1.1.1  127.127.1.0  3       377     64   178  0.0   40.1      22.8
note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured
Total associations :  1
Table 1-10 display ntp-service sessions command output description
source
IP address of the clock source
reference
Reference clock ID of the clock source
1)        If the reference clock is the local clock, the value of this field is related to the value of the stra field:
l      When the value of the stra field is 0 or 1, this field will be “LOCL”;
l      When the stra field has another value, this filed will be the IP address of the local clock
2)        If the reference clock is the clock of another device on the network, the value of this field will be the IP address of that device.
stra
Stratum level of the clock source
reach
Reachability count of the clock source. 0 indicates that the clock source in unreachable
poll
Poll interval, namely the maximum interval between successive NTP messages.
now
The length of time from when the last NTP message was received or when the local clock was last updated to the current time
The time is in second by default. If the time length is greater than 2048 seconds, it is displayed in minutes (m); if greater than 300 minutes, in hours (h); if greater than 96 hours, in days (d).
offset
The offset of the system clock relative to the reference clock, in milliseconds
delay
the roundtrip delay from the local device to the clock source, in milliseconds
disper
The maximum error of the system clock relative to the reference source.
[12345]
1: Clock source selected by the system, namely the current reference source, with a system clock stratum level of ≤ 15
2: Stratum level of this system source is ≤ 15
3: This clock source has passed the clock selection process
4: This clock source is a candidate clock source
5: This clock source was created by a configuration command
Total associations
Total number of associations
&  Note:
When a device is working in the NTP broadcast/multicast server mode, the display ntp-service sessions command executed on the device will not display the NTP session information corresponding to the broadcast/multicast server, but the sessions will be counted in the total number of associations.
1.1.3  display ntp-service status
View
Default Level
1: Monitor level
None
Use the display ntp-service status command to view the NTP service status information.
# View the NTP service status information.
<Sysname> display ntp-service status
Clock status: unsynchronized
 Clock stratum: 16
 Reference clock ID: none
 Nominal frequency: 100.0000 Hz
 Actual frequency: 100.0000 Hz
 Clock precision: 2^17
 Clock offset: 0.0000 ms
 Root delay: 0.00 ms
 Root dispersion: 0.00 ms
 Peer dispersion: 0.00 ms
 Reference time: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
Table 1-11 display ntp-service status command output description
Clock status
Status of the system clock
Clock stratum
Stratum level of the local clock
Reference clock ID
If the system clock is synchronized to a remote time server, this field indicates the address of the remote time server; if the system clock is synchronized to a local reference source, this field indicates the identifier of the local clock source:
l      When the local clock has a stratum level of 1, the value of this field is “LOCL”;
l      When the local clock has another value, the value of this filed is the IP address of the local clock.
Nominal frequency
The nominal frequency of the local system hardware clock
Actual frequency
The actual frequency of the local system hardware clock
Clock precision
The precision of the system clock.
Clock offset
The offset of the system clock relative to the NTP server
Root delay
The roundtrip delay from the local device to the primary reference clock
Root dispersion
The maximum error of the system clock relative to the primary reference clock.
Peer dispersion
The maximum error of the system clock relative to the reference clock
Reference time
Reference timestamp
1.1.4  display ntp-service trace
View
Default Level
1: Monitor level
None
Use the display ntp-service trace command view the brief information of each NTP server along the NTP server chain from the local device back to the primary reference source.
The display ntp-service trace command is available only if the local device can ping through all the devices on the NTP server chain; otherwise, this command will fail to display all the NTP servers on the NTP chain due to timeout.
<Sysname> display ntp-service trace
 server 127.0.0.1,stratum 2, offset -0.013500, synch distance 0.03154
 server 133.1.1.1,stratum 1, offset -0.506500, synch distance 0.03429
 refid LOCL
The information above shows an NTP server synchronization chain for the server 127.0.0.1: The server 127.0.0.1 is synchronized to the server 133.1.1.1, and the server 133.1.1.1 is synchronized to the local clock source.
Table 1-12 display ntp-service trace command output description
server
IP address of the NTP time server
stratum
The stratum of the corresponding local clock reference
offset
The clock offset relative to the upper-level clock reference
synch distance
The synchronization distance relative to the upper-level clock reference
refid
Identifier of the primary reference source. When the stratum level of the primary reference clock is 0, it is displayed as LOCL; otherwise, it is displayed as the IP address of the primary reference clock.
1.1.5  ntp-service access
ntp-service access { peer | query | server | synchronization } acl-number
undo ntp-service access { peer | query | server | synchronization }
View
Default Level
2: System level
peer: Specifies to permit full access.
query: Specifies to permit control query.
server: Specifies to permit server access and query.
synchronization: Specifies to permit server access only.
acl-number: ACL number, in the range of 2000 to 2999
Use the ntp-service access command to configure the NTP service access-control right to the local device.
Use the undo ntp-service access command to remove the configured NTP service access-control right to the local device.
By default, the local NTP service access-control right is set to peer.
From the highest NTP service access-control right to the lowest one are peer, server, synchronization, and query. When a device receives an NTP request, it will perform an access-control right match and will use the first matched right.
&  Note:
l      The ntp-service access command provides only a minimum degree of security protection. A more secure method is identity authentication.
l      Before specifying an ACL number in the ntp-service access command, make sure you have already created and configured this ACL.
# Configure devices on the subnet 10.10.0.0/16 to have the full access right to the local device.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ntp-service access peer 2001
1.1.6  ntp-service authentication enable
undo ntp-service authentication enable
View
Default Level
2: System level
None
Use the ntp-service authentication enable command to enable NTP authentication.
Use the undo ntp-service authentication enable command to disable NTP authentication.
By default, NTP authentication is disabled.
# Enable NTP authentication.
[Sysname] ntp-service authentication enable
1.1.7  ntp-service authentication-keyid
ntp-service authentication-keyid keyid authentication-mode md5 value
undo ntp-service authentication-keyid keyid
View
Default Level
2: System level
keyid: Authentication key ID.
authentication-mode md5 value: Specifies to use the MD5 algorithm for key authentication. value is the MD5 authentication key, a string of 1 to 32 characters.
Use the ntp-service authentication-keyid command to set the NTP authentication key.
Use the undo ntp-service authentication-keyid command to remove the set NTP authentication key.
By default, no NTP authentication key is set.
  Caution:
l      Presently the system supports only the MD5 algorithm for key authentication.
l      You can set a maximum of 1,024 keys for each device.
# Set an MD5 authentication key, with the key ID of 10 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 10 authentication-mode md5 BetterKey
1.1.8  ntp-service broadcast-client
undo ntp-service broadcast-client
View
Interface view
Default Level
2: System level
None
Use the ntp-service broadcast-client command to configure the device to work in the NTP broadcast client mode.
Use the undo ntp-service broadcast-client command to remove the device as an NTP broadcast client.
# Configure the device to receive NTP broadcast messages on VLAN-interface 1.
[Sysname-Vlan-interface1] ntp-service broadcast-client
1.1.9  ntp-service broadcast-server
undo ntp-service broadcast-server
View
Interface view
Default Level
2: System level
authentication-keyid keyid: Specifies the key ID to be used for sending broadcast messages to broadcast clients. This keyword and argument combination is not needed if authentication is not required.
version number: Specifies the NTP version, where number defaults to 3.
Use the ntp-service broadcast-server command to configure the device to work in the NTP broadcast server mode.
Use the undo ntp-service broadcast-server command to remove the device as an NTP broadcast server.
# Configure the device to send NTP broadcast messages on VLAN-interface 1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service broadcast-server authentication-keyid 4 version 3
1.1.10  ntp-service in-interface disable
undo ntp-service in-interface disable
View
Interface view
Default Level
2: System level
None
Use the ntp-service in-interface disable command to disable an interface from receiving NTP messages.
Use the undo ntp-service in-interface disable command to restore the default.
By default, an interface is enabled to receive NTP messages.
# Disable VLAN-interface 1 from receiving NTP messages.
[Sysname-Vlan-interface1] ntp-service in-interface disable
1.1.11  ntp-service max-dynamic-sessions
undo ntp-service max-dynamic-sessions
View
Default Level
2: System level
number: Maximum number of dynamic NTP sessions to be set up.
Use the ntp-service max-dynamic-sessions command to set the maximum number of dynamic NTP sessions that allowed to be established locally.
Use the undo ntp-service max-dynamic-sessions command to restore the allowed maximum number of dynamic NTP sessions to the default.
By default, the number is 100.
# Set the maximum number of dynamic NTP sessions allowed to be established locally to 50.
[Sysname] ntp-service max-dynamic-sessions 50
1.1.12  ntp-service multicast-client
undo ntp-service multicast-client [ ip-address ]
View
Interface view
Default Level
2: System level
ip-address: Multicast IP address, which must be 224.0.1.1.
Use the ntp-service multicast-client command to configure the device to work in the NTP multicast client mode.
Use the undo ntp-service multicast-client command to remove the device as an NTP multicast client.
# Configure the device to work in the multicast client mode and receive NTP multicast messages on VLAN-interface 1, and set the multicast address to 224.0.1.1.
[Sysname-Vlan-interface1] ntp-service multicast-client 224.0.1.1
1.1.13  ntp-service multicast-server
undo ntp-service multicast-server [ ip-address ]
View
Interface view
Default Level
2: System level
authentication-keyid keyid: Specifies the key ID to be used for sending multicast messages to multicast clients. This keyword and argument combination is not needed if authentication is not required.
ttl ttl-number: Specifies the TTL of NTP multicast messages, where ttl-number defaults to 16.
Use the ntp-service multicast-server command to configure the device to work in the NTP multicast server mode.
Use the undo ntp-service multicast-server command to remove the device as an NTP multicast server.
# Configure the device to send NTP multicast messages on VLAN-interface 1 to the multicast address 224.0.1.1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service multicast-server 224.0.1.1 version 3 authentication-keyid 4
1.1.14  ntp-service refclock-master
undo ntp-service refclock-master [ ip-address ]
View
Default Level
2: System level
ip-address: IP address of the local reference clock, which is 127.127.1.u, where u is the NTP process ID. If you do not specify ip-address, it defaults to 127.127.1.0.
stratum: Stratum level of the local clock. The default value of this argument is 8.
Use the ntp-service refclock-master command to configure the local clock as a reference source for other devices.
Use the undo ntp-service refclock-master command to remove the local clock as a reference source.
&  Note:
The stratum level of a clock defines the clock accuracy. The value range is 1 to 16. The clock accuracy decreases from stratum 1 to stratum 16. A stratum 1 clock has the highest accuracy, and a stratum 16 clock is not synchronized and cannot be used as a reference clock.
# Specify the local clock as the NTP primary reference clock, with the stratum level of 3.
[Sysname] ntp-service refclock-master 3
1.1.15  ntp-service reliable authentication-keyid
undo ntp-service reliable authentication-keyid keyid
View
Default Level
2: System level
keyid: Authentication key number.
Use the ntp-service reliable authentication-keyid command to specify that the authentication key is a trusted key. When NTP authentication enabled, a client can be synchronized only to a server that can provide the trusted authentication key.
Use the ntp-service reliable authentication-keyid command to cancel the configuration.
No trusted authentication key is configured by default.
# Enable NTP authentication, specify to use MD5 encryption algorithm, with the key ID of 37 and key value of BetterKey, and specify that this key is a trusted key.
[Sysname] ntp-service authentication-keyid 37 authentication-mode md5 BetterKey
[Sysname] ntp-service reliable authentication-keyid 37
1.1.16  ntp-service source-interface
ntp-service source-interface interface-type interface-number
undo ntp-service source-interface
View
Default Level
2: System level
interface-type interface-number: Interface type and interface number of the interface that sends the NTP messages.
Use the ntp-service source-interface command to specify a local interface for sending NTP messages.
Use the undo ntp-service source-interface command to remove the configured interface for sending NTP messages.
You can use this command to specify a particular interface for sending all NTP messages. In this case, the source address in all NTP messages is the primary IP address of this interface, so that IP addresses of other interfaces will not be the destination IP addresses of the NTP response messages.
# Specify that all NTP messages are to be sent out from VLAN-interface 1.
[Sysname] ntp-service source-interface vlan-interface 1
1.1.17  ntp-service unicast-peer
ntp-service unicast-peer [ vpn-instance vpn-instance-name ] { ip-address | peer-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-peer [ vpn-instance vpn-instance-name ] { ip-address | server-name }
View
Default Level
2: System level
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, where vpn-instance-name is a string of 1 to 31 characters.
ip-address: IP address of the symmetric-passive peer. It must be a host address, rather than a broadcast address, a multicast address or the IP address of the local clock.
peer-name: Host name of the symmetric-passive peer.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the peer.
priority: Specifies the peer designated by ip-address or peer-name as the first choice in case that multiple clocks that are allowed to be configured with this keyword meet the following conditions:
l           The clocks have passed the checks and enter the candidate clock list.
l           The clocks are with the same stratum.
source-interface interface-type interface-number: Specifies an interface for sending NTP messages. In an NTP message the local device sends to its peer, the source IP address is the primary IP address of this interface. interface-type interface-number is the interface type and interface number.
Use the ntp-service unicast-peer command to designate a symmetric-passive peer for the device.
Use the undo ntp-service unicast-peer command to remove the symmetric-passive peer designated for the device.
No symmetric-passive peer is designated for the device by default.
&  Note:
l      If you specify a VPN instance name, this VPN must exist, and at least one local interface and the NTP server coexist in this VPN.
l      To synchronize the PE to a PE or CE in a VPN, you need to provide vpn-instance vpn-instance-name in your command.
l      If you include vpn-instance vpn-instance-name in the undo ntp unicast-peer command, the command will remove the symmetric-passive peer with the IP address of ip-address in the specified VPN; if you do not include vpn-instance vpn-instance-name in this command, the command will remove the symmetric-passive peer with the IP address of ip-address in the public network.
# Configure the local device to be synchronized to peer 128.108.22.44, and the peer also can be synchronized to the local device, and run NTPv3. Use the IP address of VLAN-interface 1 as the source IP address of the NTP messages.
[Sysname] ntp-service unicast-peer 128.108.22.44 version 3 source-interface vlan-interface 1
1.1.18  ntp-service unicast-server
ntp-service unicast-server [ vpn-instance vpn-instance-name ] { ip-address | server-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number  ] *
undo ntp-service unicast-server [ vpn-instance vpn-instance-name ] { ip-address | server-name }
View
Default Level
2: System level
vpn-instance vpn-instance-name: Specifies a VPN instance by its name.
ip-address: IP address of the NTP server. It must be a host address, rather than a broadcast address, a multicast address or the IP address of the local clock.
server-name: Host name of the NTP server.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the NTP server.
source-interface interface-type interface-number: Specifies an interface for sending NTP messages. In an NTP message the local device sends to the NTP server, the source IP address is the primary IP address of this interface. interface-type interface-number is the interface type and interface number.
Use the ntp-service unicast-server command to configure the NTP server for the local device. In this case, the local device acts as a client, and can be synchronized to the NTP server, but the NTP server cannot be synchronized to the local client.
Use the undo ntp-service unicast-server command to cancel the NTP server configuration.
No NTP server is configured for the local device by default.
&  Note:
l      The NTP version numbers of the devices to be synchronized must be the same; otherwise the synchronization may fail.
l      If you include vpn-instance vpn-instance-name in the undo ntp unicast-server command, the command will remove the NTP server with the IP address of ip-address in the specified VPN; if you do not include vpn-instance vpn-instance-name in this command, the command will remove the NTP server with the IP address of ip-address in the public network.
# Configure the local device to be synchronized to the NTP server 128.108.22.44, and set the NTP version number to 3.
[Sysname] ntp-service unicast-server 128.108.22.44 version 3
