H3C S9500 Command Manual-Release2132[V2.03]-08 System Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-08 System Volume
09-SNMP Commands
09-SNMP Commands 111.98 KB
Chapter 1  SNMP Configuration Commands
1.1  SNMP Configuration Commands
1.1.1  debugging snmp-agent
debugging snmp-agent { header | packet | process | trap }
undo debugging snmp-agent { header | packet | process | trap }
View
Default Level
2: System level
header: Enables SNMP packet header debugging.
packet: Enables SNMP packet debugging.
process: Enables SNMP packet process debugging.
trap: Enables trap packet debugging.
Use the debugging snmp-agent command to enable debugging for SNMP agent.
Use the undo debugging snmp-agent command to disable debugging for SNMP agent.
By default, debugging for SNMP agent is disabled.
Table 1-1 debugging snmp-agent header command output description
Incoming
SNMP packets received
SNMPversion packet
SNMP packets of a specific version (At present, three SNMP versions are available: v1, v2c, and v3)
community name: communityName
SNMPv1/v2c community name
security model: v3
SNMPv3 security model
security level: securityLevel
SNMPv3 security level, which falls into three types:
noAuthNoPriv: No authentication, no privacy
authNoPriv: Authentication without privacy
authPriv: Authentication with privacy
user name: userName
SNMPv3 username
snmpEngineID: engineID
SNMP engine ID
snmpEngineBoots: n
Number of reboot times of SNMP engine
snmpEngineTime: n
Running time of SNMP engine
Table 1-2 debugging snmp-agent packet command output description
PACKETS
Information contained in SNMP packets
PACKETS_SRC:Packet received from address via UDP
SNMP packets received through UDP from address. Address represents the source address of the SNMP packets.
PACKETS_DES: Packet sent to address via UDP
SNMP packets sent through UDP to address. Address represents the destination address of the SNMP packets.
PACKETS_BULK:
Information contained in the SNMP GetBulk Request
get request
SNMP Get packets (including request and response)
reqid: reqid
Request ID, SNMP request ID, used to match a request to a response.
errstat: errstat
Error State, SNMP packet error type
erridx: erridx
Error Index, SNMP packet error index, indicating the poison of a wrong variable in the list of the bound variables.
VBLIST
Variable List, variable list of the operation objects
set request
SNMP Set packet, including Set request and Set response
get-next request
SNMP GetNext packet, including GetNext request and GetNext response
get-bulk request
SNMP GetBulk packet, including GetBulk request and GetBulk response
nonrptr: nonrptr
Non Repeaters: Parameter of the GetBulk operation
Maxreps: maxreps
Max Repetitions: Parameter of the GetBulk operation
Table 1-3 debugging snmp-agent process command output description
PROCESS: object-name
Debugging information during SNMP processing. object-name is the object to be processed by SNMP.
operation: operation
SNMP operation type, such as Get, Set, and Get Next.
error type: errtype
Error type of an SNMP operation, such as toobig, no error and so on
Table 1-4 debugging snmp-agent trap command output description
TRAPversion:
SNMP trap messages of a specific SNMP version
trap-name trap<version> send to:address
A trap message was sent, where trap-name represents the name of the trap message, version represents the version (including v1 and v2) of the trap message, address represents the destination address of the trap message.
reqid: request ID
The reqid field is an invalid value and is always 0 in a trap message.
errorstate: errorState
The errorstate field is an invalid value and is always 0 in a trap message.
errorIndex: errorIindex
The errorIndex field is an invalid value and is always 0 in a trap message.
udp_port: port number
UDP port for the destination host to receive SNMP traps
send OK
SNMP Trap was successfully sent
VBLIST
Variable List, list of the variables bound with SNMP trap messages
# Enable debugging for SNMP agent packet header on a device enabled with SNMPv1/v2c/v3 and configured with related community names, and use MIB Browser to perform Get/Set operations.
<Sysname> debugging snmp-agent header
0.3557781 Sysname SNMP/7/V12HEADERS:
   Incoming SNMPv2c packet
   community name:public
// SNMP Agent received SNMPv2c Get packet headers with the community name public.
*0.3621250 Sysname SNMP/7/V12HEADERS:
   community name:private
// SNMP Agent received SNMPv2c Set packet headers with the community name private.
*0.56365500 Sysname-Comware SNMP/7/V3HEADERS:
   Incoming SNMPv3 packet
   security model:v3
   security level:AuthNoPriv
   user name:John
   snmpEngineID:800063A203000056000000
   snmpEngineBoots:0   snmpEngineTime:0
// SNMP Agent received SNMPv3 Get/Set packet headers. The security model is v3, security level is authentication without privacy, username is John, SNMP engine ID is 800063A203000056000000, number of SNMP engine reboot times is 0 and SNMP engine running time is 0.
# Enable SNMP agent packet debugging on a device enabled with SNMPv1/v2c/v3 and configured with related community name, and use MIB Browser to perform Get operation.
<Sysname> debugging snmp-agent packet
*0.176281 Sysname SNMP/7/PACKETS_SRC:Packet received from 169.254.76.211 via UDP
*0.176281 Sysname SNMP/7/PACKETS:
   get request
   reqid:77,errstat:0,erridx:0
*0.176281 Sysname SNMP/7/VBLIST:
   sysObjectID.0 =
// SNMP agent received UDP packets from 169.254.76.211. The operation type is Get request, request ID is 77, error state is 0, error index is 0, and the bound variable is sysObjectID.
   get request
   sysObjectID.0 = 1.3.6.1.4.1.2011
*0.176281 Sysname SNMP/7/PACKETS_DES:Packet sent to 169.254.76.211 via UDP
// SNMP agent sent UDP packets to 169.254.76.211. The operation type is Get response, request ID is 77, error state is 0, error index is 0, and the bound variable is sysObjectID. The value retrieved in this Get operation is 1.3.6.1.4.1.2011.
# Enable SNMP agent packet processing debugging on a device enabled with SNMPv1/v2c/v3 and configured with related community name, and use MIB Browser to perform Get/Set operations.
<Sysname> debugging snmp-agent process
    *0.1317000 Sysname SNMP/7/PROCESS:sysDescr
     operation:get request   error type:no error
// SNMP agent received debugging information of the Get request. The operation type is Get request and the error type is no error.
# Enable SNMP Trap packet debugging on a device enabled with SNMPv1/v2c/v3 and configured with related community name.
<Sysname> debugging snmp-agent trap
*0.4065343 Sysname SNMP/7/TRAPV2:
   warmStart trap<v2> send to:169.254.76.211
   reqid:0
   errorstate:0
   errorIndex:0
   udp_port:162
   send OK
*0.4065343 Sysname SNMP/7/VBLIST:
   sysUpTime.0 = 406320
   snmpTrapOID.0 = 1.3.6.1.6.3.1.1.5.2
// SNMP sent UDP packets to the host with the IP address 169.254.76.211. The packet is a warmStart Trap message. The ID of the request corresponding to the trap message is 0, error state is 0, error index is 0, and the UDP port of the destination host is 162. The trap message was successfully sent to the destination host. The values of the bound variables sysUpTime and snmpTrapOID are 406320 and 1.3.6.1.6.3.1.1.5.2.
1.1.2  display snmp-agent community
View
Default Level
1: Monitor level
read: Displays the information of communities with read-only access right.
write: Displays the information of communities with read and write access right.
Use the display snmp-agent community command to display community information for SNMPv1 or SNMPv2c.
# Display the information for all the current communities.
<Sysname> display snmp-agent community
   Community name:aa
       Group name:aa
       Acl:2001
       Storage-type: nonVolatile
   Community name:bb
       Group name:bb
Table 1-5 display snmp-agent community command output description
Community name
Community name
Group name
SNMP group name
Acl
The number of the ACL in use
Storage-type
Storage type, which could be:
l      volatile: Information will be lost if the system is rebooted
l      nonVolatile: Information will not be lost if the system is rebooted
l      permanent: Modification permitted, but deletion forbidden
l      readOnly: Read only, that is, no modification, no deletion
l      other: Other storage types
1.1.3  display snmp-agent group
display snmp-agent group [ group-name ]
View
Default Level
1: Monitor level
group-name: Specifies the SNMP group name, a string of 1 to 32 characters, case sensitive.
Use the display snmp-agent group command to display information for the SNMP agent group, including group name, security model, MIB view, storage type, and so on. Absence of the group-name parameter indicates that information for all groups will be displayed.
# Display the information of all SNMP agent groups.
<Sysname> display snmp-agent group
   Group name: mygroup
       Security model: v1 noAuthnoPriv
       Readview: ViewDefault
       Writeview: <no specified>
       Notifyview:<no specified>
   Group name: managev3group
       Security model: v3 noAuthnoPriv
       Writeview: internet
       Notifyview :<no specified>
Table 1-6 display snmp-agent group command output description
Group name
SNMP group name
Security model
Security model of the SNMP group, which can be: authPriv (authentication with privacy), authNoPriv (authentication without privacy), or noAuthNoPriv (no authentication no privacy).
Readview
The read only MIB view associated with the SNMP group
Writeview
The writable MIB view associated with the SNMP group
Notifyview
The notify MIB view associated with the SNMP group, the view with entries that can generate Trap messages
Storage-type
Storage type, which includes: volatile, nonVolatile, permanent, readOnly, and other. For detailed information, refer to Table 1-5.
1.1.4  display snmp-agent local-engineid
View
Default Level
1: Monitor level
None
Use the display snmp-agent local-engineid command to display the local SNMP agent engine ID.
SNMP engine ID uniquely identifies an SNMP entity within an SNMP domain. SNMP engine is an indispensable part of an SNMP entity. It provides SNMP message allocation, message handling, authentication, and access control.
# Display the local SNMP agent engine ID.
<Sysname> display snmp-agent local-engineid
SNMP local EngineID: 000063A27F00000100006822
1.1.5  display snmp-agent mib-view
display snmp-agent mib-view [ exclude | include | viewname view-name ]
View
Default Level
1: Monitor level
exclude: Specifies to display SNMP MIB views of the “excluded" type.
include: Specifies to display SNMP MIB views of the “included" type.
viewname view-name: Name of the specified MIB view.
Use the display snmp-agent mib-view command to display SNMP MIB view information. Absence of the view-name parameter indicates that information for all MIB views will be displayed.
# Display the current SNMP MIB views.
<Sysname> display snmp-agent mib-view
   View name:ViewDefault
       MIB Subtree:iso
       Subtree mask:
       View Type:included
       View status:active
       MIB Subtree:snmpUsmMIB
       Subtree mask:
       View Type:excluded
       View status:active
       MIB Subtree:snmpVacmMIB
       Subtree mask:
       View Type:excluded
       View status:active
       MIB Subtree:snmpModules.18
       Subtree mask:
       View Type:excluded
       View status:active
Table 1-7 display snmp-agent mib-view command output description
View name
MIB view name
MIB Subtree
MIB subtree
Subtree mask
MIB subtree mask
Storage-type
Storage type
View Type
View type, which can be “included” or “excluded”
Included indicates that all nodes of the MIB subtree are included in current view.
Excluded indicates that not all nodes of the MIB subtree are included in current view.
View status
The status of MIB view
1.1.6  display snmp-agent statistics
View
Default Level
1: Monitor level
None
Use the display snmp-agent statistics command to display SNMP statistics.
# Display the statistics on the current SNMP.
<Sysname> display snmp-agent statistics
  0 Messages delivered to the SNMP entity
  0 Messages which were for an unsupported version
  0 Messages which used a SNMP community name not known
  0 Messages which represented an illegal operation for the community supplied
  0 ASN.1 or BER errors in the process of decoding
  0 Messages passed from the SNMP entity
  0 SNMP PDUs which had badValue error-status
  0 SNMP PDUs which had genErr error-status
  0 SNMP PDUs which had noSuchName error-status
  0 SNMP PDUs which had tooBig error-status (Maximum packet size 1500)
  0 MIB objects retrieved successfully
  0 MIB objects altered successfully
  0 GetRequest-PDU accepted and processed
  0 GetNextRequest-PDU accepted and processed
  0 GetBulkRequest-PDU accepted and processed
  0 GetResponse-PDU accepted and processed
  0 SetRequest-PDU accepted and processed
  0 Trap PDUs accepted and processed
  0 Alternate Response Class PDUs dropped silently
  0 Forwarded Confirmed Class PDUs dropped silently
Table 1-8 display snmp-agent statistics command output description
Number of packets delivered to the SNMP agent
Number of packets from a device with an SNMP version that is not supported by the current SNMP agent
Number of packets that use an unknown community name
Number of packets with operations that breach the access right of a community
Number of packets with ASN.1 or BER errors
Number of packets sent by an SNMP Agent
Number of SNMP PDUs with a badValue error
Number of SNMP PDUs with a genErr error
Number of PDUs with a noSuchName error
 Number of PDUs with a tooBig error (the maximum packet size is 1,500 bytes)
Number of MIB objects that have been successfully retrieved
Number of MIB objects that have been successfully modified
Number of get requests that have been received and processed
Number of getNext requests that have been received and processed
Number of getBulk requests that have been received and processed
Number of get responses that have been received and processed
Number of set requests that have been received and processed
Number of Trap messages that have been received and processed
Number of dropped response packets
Number of forwarded packets that have been dropped
1.1.7  display snmp-agent sys-info
display snmp-agent sys-info [ contact | location | version ] *
View
Default Level
1: Monitor level
contact: Displays the contact information of the current network administrator.
location: Displays the location information of the current device.
version: Displays the version of the current SNMP agent.
Use the display snmp-agent sys-info command to display the current SNMP system information.
If no keyword is specified, all SNMP agent system information will be displayed.
# Display the current SNMP agent system information.
<Sysname> display snmp-agent sys-info
   The contact person for this managed node:
          Hangzhou H3C Technologies Co., Ltd.
   The physical location of this node:
           Hangzhou, China
   SNMP version running in the system:
           SNMPv3
1.1.8  display snmp-agent trap-list
View
Default Level
1: Monitor level
None
Use the display snmp-agent trap-list command to display the modules that can send the Trap messages and whether their Trap sending is enabled or not. If a module comprises of multiple sub-modules, then as long as one sub-module has the sending of Trap messages enabled, the whole module will be displayed as being enabled with the Trap sending.
Related commands: snmp-agent trap enable.
# Display the modules that can send the Trap messages and whether their Trap sending is enabled or not.
<Sysname> display snmp-agent trap-list
   bgp trap enable
   configuration trap enable
   flash trap enable
   isdn trap enable
   mpls trap enable
   ospf trap enable
   standard trap enable
   system trap enable
   vrrp trap enable
   Enable traps: 8; Disable traps: 0
In the above output, enable indicates that the module is enabled with the Trap sending whereas disable indicates the Trap sending is disabled. By default, Trap sending is enabled on all modules that can send Trap messages. Use the snmp-agent trap enable command to manually configure whether the Trap sending is enabled or not.
1.1.9  display snmp-agent usm-user
display snmp-agent usm-user [ engineid engineid | username user-name | group group-name ] *
View
Default Level
1: Monitor level
engineid engineid: Displays SNMPv3 user information for a specified engine ID.
username user-name: Displays SNMPv3 user information for a specified user name. It is case sensitive.
group group-name: Displays SNMPv3 user information for a specified SNMP group name. It is case sensitive.
Use the display snmp-agent usm-user command to display SNMPv3 user information.
 # Display SNMPv3 information for the user aa.
<Sysname> display snmp-agent usm-user username aa
   User name: aa
   Group name: mygroupv3
       Engine ID: 800007DB0000000000006877
       UserStatus: active
Table 1-9 display snmp-agent usm-user command output description
User name
SNMP user name
Group name
SNMP group name
Engine ID
Engine ID for an SNMP entity
Storage-type
Storage type
UserStatus
SNMP user status
1.1.10  enable snmp trap updown
undo enable snmp trap updown
View
Interface view
Default Level
2: System level
None
Use the enable snmp trap updown command to enable the sending of Trap messages for interface state change (linkup/linkdown SNMP Trap messages).
Use the undo enable snmp trap updown command to disable the sending of linkup/linkdown SNMP Trap messages on an interface.
By default, the sending of linkup/linkdown SNMP Trap messages is enabled.
Note that:
To enable an interface to send SNMP Trap packets when its state changes, you need to enable the Link up/down Trap packet transmission function on an interface and globally. Use the enable snmp trap updown command to enable this function on an interface, and use the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command to enable this function globally.
Related commands: snmp-agent target-host, snmp-agent trap enable.
# Enable the sending of linkup/linkdown SNMP Trap messages on the port Ethernet 6/1/1 and use the community name public.
[Sysname] snmp-agent target-host trap address udp-domain 10.1.1.1 params securityname public
[Sysname] interface ethernet 6/1/1
[Sysname-Ethernet6/1/1] enable snmp trap updown
1.1.11  snmp-agent
snmp-agent
undo snmp-agent
View
Default Level
3: Manage level
None
Use the snmp-agent command to enable SNMP agent.
Use the undo snmp-agent command to disable SNMP agent.
By default, SNMP agent is disabled.
# Disable the current SNMP agent.
[Sysname] undo snmp-agent
1.1.12  snmp-agent community
snmp-agent community { read | write } community-name [ acl acl-number | mib-view view-name ] *
undo snmp-agent community community-name
View
Default Level
3: Manage level
read: Indicates that the community has read only access right to the MIB objects, that is, the community can only inquire MIB information.
write: Indicates that the community has read and write access right to the MIB objects, that is, the community can configure MIB information.
community-name: Community name, a string of 1 to 32 characters.
mib-view view-name: MIB view name, a string of 1 to 32 characters. If no keyword is specified, the default view is ViewDefault (The view created by the system after SNMP Agent is enabled).
acl acl-number: ACL for the community name, in the range 2,000 to 2,999.
Use the snmp-agent community command to configure a new SNMP community. Default Level
2: System level
Parameters to be configured include access right, community name, ACL, and accessible MIB views.
Use the undo snmp-agent community command to delete a specified community.
The community name configured with this command is only valid for the SNMP v1 and v2c agent.
# Configure a community with the name of comaccess that has read-only access right.
[Sysname] snmp-agent community read comaccess
# Delete the community comaccess.
[Sysname] undo snmp-agent community comaccess
1.1.13  snmp-agent group
The following syntax applies to SNMPv1 and SNMP v2c:
snmp-agent group { v1 | v2c } group-name [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
undo snmp-agent group { v1 | v2c } group-name
The following syntax applies to SNMPv3:
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
undo snmp-agent group v3 group-name [ authentication | privacy ]
View
Default Level
3: Manage level
v1: SNMPv1.
v2c: SNMPv2c.
v3: SNMPv3.
group-name: Group name, a string of 1 to 32 characters.
authentication: Specifies the security model of the SNMP group to be authentication only (without privacy).
privacy: Specifies the security model of the SNMP group to be authentication and privacy.
read-view read-view: Read view, a string of 1 to 32 characters.
write-view write-view: Write view, a string of 1 to 32 characters.
notify-view notify-view: Notify view, for sending Trap messages, a string of 1 to 32 characters.
acl acl-number: Specifies an ACL by its number, in the range 2000 to 2999.
Use the snmp-agent group command to configure a new SNMP group and specify its access right.
Use the undo snmp-agent group command to delete a specified SNMP group.
By default, SNMP groups configured by the snmp-agent group v3 command use a no-authentication-no-privacy security model.
Related commands: snmp-agent mib-view, snmp-agent usm-user.
# Create an SNMP group group1 on an SNMPv3 enabled device, no authentication, no privacy.
[Sysname] snmp-agent group v3 group1
1.1.14  snmp-agent local-engineid
undo snmp-agent local-engineid
View
Default Level
3: Manage level
engineid: Engine ID, an even number of hexadecimal characters, in the range 10 to 64. Its length must not be an odd number, and the all-zero and all-F strings are invalid.
Use the snmp-agent local-engineid command to configure a local engine ID for an SNMP entity.
Use the undo snmp-agent local-engineid command to restore the default local engine ID.
By default, the engine ID of a device is the combination of company ID and device ID. Note that if the newly configured engine ID is not the same as the one used for creating the USM user, the user is invalid.
Related commands: snmp-agent usm-user.
# Configure the local engine ID to be 123456789A.
[Sysname] snmp-agent local-engineid 123456789A
1.1.15  snmp-agent mib-view
snmp-agent mib-view { included | excluded } view-name oid-tree [ mask mask-value ]
undo snmp-agent mib-view view-name
View
Default Level
3: Manage level
included: Indicates that all nodes of the MIB tree are included in current view.
excluded: Indicates that not all nodes of the MIB tree are included in current view.
view-name: View name, a string of 1 to 32 characters.
oid-tree: MIB subtree. It can only be an OID string of 1 to 25 characters, such as 1.4.5.3.1, or an object name string, such as “system”. OID is made up of a series of integers, which marks the position of the node in the MIB tree and uniquely identifies a MIB object.
mask mask-value: Mask for an object tree, in the range 1 to 32 hexadecimal digits.
Use the snmp-agent mib-view command to create or update MIB view information so that MIB objects can be specified.
Use the undo snmp-agent mib-view command to delete the current configuration.
By default, MIB view name is ViewDefault.
Related commands: snmp-agent group.
# Create a MIB view mibtest, which includes all objects of the subtree mib2.
[Sysname] snmp-agent mib-view included mib2 1.3.6.1
1.1.16  snmp-agent packet max-size
undo snmp-agent packet max-size
View
Default Level
3: Manage level
byte-count: Maximum number of bytes of an SNMP packet that can be received or sent by an agent, in the range 484 to 17,940. The default value is 1,500 bytes.
Use the snmp-agent packet max-size command to configure the maximum number of bytes in an SNMP packet that can be received or sent by an agent.
Use the undo snmp-agent packet max-size command to restore the default packet size.
# Configure the maximum number of bytes that can be received or sent by an SNMP agent to 1,042 bytes.
[Sysname] snmp-agent packet max-size 1042
1.1.17  snmp-agent sys-info
snmp-agent sys-info { contact sys-contact | location sys-location | version { all | { v1 | v2c | v3 }* } }
undo snmp-agent sys-info { contact | location | version { all | { v1 | v2c | v3 }* } }
View
Default Level
3: Manage level
contact sys-contact: A string that describes the contact information for system maintenance.
location sys-location: A string that describes the location of the device.
version: The SNMP version in use.
l           v1: SNMPv1.
l           v2c: SNMPv2c.
l           v3: SNMPv3.
l           all: Specifies SNMPv1, SNMPv2c, and SNMPv3.
Use the snmp-agent sys-info command to configure system information, including the contact information, the location, and the SNMP version in use.
Use the undo snmp-agent sys-info command to restore the default configuration.
By default, the location information is Hangzhou, China, version is <NONE>, and the contact is Hangzhou H3C Technologies Co., Ltd.
Related commands: display snmp-agent sys-info.
&  Note:
Network maintenance engineers can use the system contact information to get in touch with the manufacturer in case of network failures. The system location information is a management variable under the system branch as defined in RFC 1213-MIB, it identifies the location of the managed object.
# Configure the contact information as “Dial System Operator at beeper # 27345”.
[Sysname] snmp-agent sys-info contact Dial System Operator at beeper # 27345
1.1.18  snmp-agent target-host
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] params securityname security-string [ v1 | v2c | v3 [ authentication | privacy ] ]
undo snmp-agent target-host { ip-address | ipv6 ipv6-address } securityname security-string
View
Default Level
3: Manage level
trap: Specifies the host to be the Trap host.
address: Specifies the IP address of the target host for the SNMP messages.
udp-domain: Indicates that the Trap message is transmitted using UDP.
ip-address: The IPv4 address of the Trap host.
ipv6: Specifies that the target host that receives Trap messages uses the IPv6 address.
ipv6-address: The IPv6 address of the Trap host.
port-number: Specifies the number of the port that receives Trap packets.
params securityname security-string: Specifies authentication related parameters, which is SNMPv1 or SNMPv2c community name or an SNMPv3 user name, a string of 1 to 32 characters.
v1: SNMPv1.
v2c: SNMPv2c.
v3: SNMPv3.
authentication: Specifies the security model to be authentication without privacy.
privacy: Specifies the security model to be authentication with privacy.
Use the snmp-agent target-host command to configure the related settings for a Trap target host.
Use the undo snmp-agent target-host command to remove the current settings.
To enable the device to send Traps, you need to use the snmp-agent target-host command in combination with the snmp-agent trap enable and the enable snmp trap updown commands.
Related commands: enable snmp trap updown, snmp-agent trap enable, snmp-agent trap source, snmp-agent trap life.
# Enable the device to send SNMP Traps to 10.1.1.1, using the community name of “public”.
[Sysname] snmp-agent trap enable standard
1.1.19  snmp-agent trap enable
snmp-agent trap enable [ bgp | configuration | flash | mpls | ospf [ process-id ] [ ospf-trap-list ] | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
undo snmp-agent trap enable [ bgp | configuration | flash | mpls | ospf [ process-id ] [ ospf-trap-list ] | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
View
Default Level
3: Manage level
bgp: Enables the sending of BGP Trap packets.
configuration: Enables the sending of configuration Trap packets.
flash: Enables the sending of FLASH Trap packets.
mpls: Enables the sending of LSP Trap packets.
ospf [ process-id ] [ ospf-trap-list ]: Enables the sending of OSPF Trap packets. The parameter process-id is the process ID and spf-trap-list is the Trap packet list.
standard: Enables the sending of standard Trap packets.
l           authentication: Enables the sending of authentication failure Trap packets in the event of authentication failure.
l           coldstart: Sends coldstart Trap packets when the device restarts.
l           linkdown: Sends linkdown Trap packets when the port is in a linkdown status. It should be configured globally.
l           linkup: Sends linkup Trap packets when the port is in a linkup status. It should be configured globally.
warmstart: Sends warmstart Trap packets when the SNMP restarts.
system: Sends H3C-SYS-MAN-MIB (a private MIB) Trap packets.
vrrp [ authfailure | newmaster ]: Sends VRRP Trap packets.
l           authfailure: Sends authentication failure VRRP Trap packets.
l           newmaster: Enables the sending of VRRP newmaster Trap packets when the device becomes the Master.
Use the snmp-agent trap enable command to enable the device to send Trap messages globally.
Use the undo snmp-agent trap enable command to disable the device from sending Trap messages.
By default, the device is enabled to send Trap messages.
Note that:
Related commands: snmp-agent target-host, enable snmp trap updown.
# Enable the device to send SNMP authentication failure packets to 10.1.1.1, using the community name of “public”.
[Sysname] snmp-agent trap enable standard authentication
1.1.20  snmp-agent trap life
snmp-agent trap life seconds
undo snmp-agent trap life
View
Default Level
3: Manage level
seconds: Time-out time, in the range 1 to 2,592,000 seconds.
Use the snmp-agent trap life command to configure the life time for Traps, which will be discarded when their life time expires.
Use the undo snmp-agent trap life command to restore the default life time for Trap packets.
By default, the life time for SNMP Traps is 120 seconds.
Related commands: snmp-agent trap enable, snmp-agent target-host.
# Configure the life time for Trap packets as 60 seconds.
[Sysname] snmp-agent trap life 60
1.1.21  snmp-agent trap queue-size
undo snmp-agent trap queue-size
View
Default Level
3: Manage level
size: The queue size for the Trap messages, in the range 1 to 1,000.
Use the snmp-agent trap queue-size command to configure the size of the Trap queue.
Use the undo snmp-agent trap queue-size command to restore the default queue size.
By default, up to 100 Trap messages can be stored in the Trap queue.
Related commands: snmp-agent trap enable, snmp-agent target-host, snmp-agent trap life.
# Configure the size of the Trap queue to 200.
[Sysname] snmp-agent trap queue-size 200
1.1.22  snmp-agent trap source
snmp-agent trap source { interface-type interface-number }
undo snmp-agent trap source
View
Default Level
3: Manage level
interface type interface-number: Interface type and interface number.
Use the snmp-agent trap source command to specify the source IP address contained in the Trap message.
Use the undo snmp-agent trap source command to restore the default.
By default, SNMP chooses the IP address of an interface to be the source IP address of the Trap message.
Use this command to trace a specific event by the source IP address of a Trap message.
Note: Before you can configure the IP address of a particular interface as the source IP address of the Trap message, ensure that the interface already exists and that it has a legal IP address. Otherwise, it is likely that the configurations will either fail or be invalid.
# Configure the IP address for the port Ethernet 1/1/1 as the source address for Trap packets.
[Sysname] snmp-agent trap source ethernet 1/1/1
1.1.23  snmp-agent usm-user
The following syntax applies to SNMPv1 and SNMPv2c:
snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number ]
undo snmp-agent usm-user { v1 | v2c } user-name group-name
snmp-agent usm-user v3 user-name group-name [ authentication-mode { md5 | sha } auth-password  [ privacy-mode { des56 | aes128 } priv-password ] ] [ acl acl-number ]
undo snmp-agent usm-user v3 user-name group-name { local | engineid engineid-string }
View
Default Level
3: Manage level
v1: SNMPv1.
v2c: SNMPv2c.
v3: SNMPv3.
user-name: User name, a string of 1 to 32 characters. It is case sensitive.
group-name: Group name, a string of 1 to 32 characters. It is case sensitive.
authentication-mode: Specifies that the security mode is authentication.
md5: Specifies the authentication protocol to be HMAC-MD5-96.
sha: Specifies the authentication protocol to be HMAC-SHA-96.
auth-password: Authentication password, a string of 1 to 64 characters.
privacy: Specifies that the security mode is privacy.
des56: Specifies the privacy protocol to be data encryption standard (DES).
aes128: Specifies the privacy protocol to be advanced encryption standard (AES).
priv-password: The privacy password, a string of 1 to 64 characters.
acl-number: Basic ACL, in the range 2,000 to 2,999.
local: Represents a local SNMP entity user.
engineid-string: The engine ID string, an even number of hexadecimal characters, in the range 10 to 64. Its length must not be an odd number, and the all-zero and all-F strings are invalid.
Use the snmp-agent usm-user command to add a user to an SNMP group.
Use the undo snmp-agent usm-user command to delete a user from an SNMP group.
Engine ID is used in authentication after you configure a user for a remote agent. If the engine ID is changed after a user is configured, the user corresponding to the original engine ID is invalid.
Note that the validity of a user depends on the engine ID of the SNMP agent. If the engine ID used for creating the user is not identical to the current engine ID, the user is invalid.
For SNMPv1 and SNMPv2c, this command means adding of a new SNMP group. For SNMPv3, this command adds a new user to an SNMP group.
Related commands: snmp-agent group, snmp-agent community, snmp-agent local-engineid.
# Add a user John to the SNMP group Johngroup. Configure the security mode as authentication, the authentication protocol as HMAC-MD5-96, and the authentication password as hello.
[Sysname] snmp-agent group v3 Johngroup
[Sysname] snmp-agent usm-user v3 John Johngroup authentication-mode md5 hello
# Specify SNMPv2c users to access the SNMP agent through reading v2cReadCommunity.
[Sysname] snmp-agent usm-user v2c v2cReadCommunity v2cGroup
[Sysname] snmp-agent group v2c v2cGroup read-view internet
[Sysname] snmp-agent mib-view included internet internet
