H3C S9500 Command Manual-Release2132[V2.03]-08 System Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-08 System Volume
16-PoE Commands
16-PoE Commands 142.15 KB
Chapter 1  PoE Configuration Commands
&  Note:
l      If the PoE power is shut down or unavailable, all PoE related configuration commands will fail.
l      The remaining PSE power displayed with the display poe interface command includes the power consumed by the PoE dual inline memory module (DIMM). That is, the available remaining power is lower than the displayed remaining power. PoE DIMM consumes about 8.5 W power at full load.
1.1  PoE Configuration Commands
1.1.1  apply poe-profile
apply poe-profile { index index | name profile-name }
undo apply poe-profile { index index | name profile-name }
View
PoE interface view
Default Level
2: System level
index: Specifies the index number of the PoE configuration file. The PoE configuration file corresponding to the index must exist.
profile-name: Specifies the name of the PoE configuration file. The PoE configuration file must exist.
Use the apply poe-profile command to apply the PoE configuration file to the current PoE interface.
Use the undo apply poe-profile command to remove the application of the PoE configuration file from the current PoE interface.
Note that the index number, instead of the name, of the PoE configuration file will be displayed when you execute the display this command.
Related commands: display poe-profile, apply poe-profile interface.
# Apply the PoE configuration file named A20 to PoE interface GigabitEthernet 1/1/1.
[Sysname] interface GigabitEthernet 1/1/1
[Sysname-GigabitEthernet1/1/1] apply poe-profile name A20
[Sysname-GigabitEthernet1/1/1] display this
interface GigabitEthernet1/1/1
 port link-mode bridge
 apply poe-profile index 1
1.1.2  apply poe-profile interface
apply poe-profile { index index | name profile-name } interface interface-range
undo apply poe-profile { index index | name profile-name } interface interface-range
View
Default Level
2: System level
interface-range: Range of Ethernet interface numbers, indicating multiple Ethernet interfaces. The expression is interface-range = interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number represents the interface type and interface number. The start interface number should be less than the end interface number. Ethernet interface numbers can be in any range. If any interface in the specified range does not support PoE, it will be ignored when the PoE configuration file is applied.
Use the apply poe-profile interface command to apply the PoE configuration file to one or more PoE interfaces.
Use the undo apply poe-profile interface command to remove the application of the PoE configuration file from specified PoE interface(s).
Related commands: display poe-profile interface, apply poe-profile.
# Apply the PoE configuration file named ABC to PoE interface GigabitEthernet 1/1/1.
[Sysname] apply poe-profile name ABC interface GigabitEthernet 1/1/1
# Apply the PoE configuration file with index 5 to PoE interfaces GigabitEthernet 1/1/2 to GigabitEthernet 1/1/8.
[Sysname] apply poe-profile index 5 interface GigabitEthernet 1/1/2 to GigabitEthernet 1/1/8
1.1.3  display poe device
display poe device
View
Default Level
1: Monitor level
None
Use the display poe device command to display the mapping between ID, module, and slot of the power sourcing equipment (PSE).
# Display the mapping between ID, module, and slot of each PSE.
<Sysname> display poe device
 PSE ID  SlotNo SubSNo PortNum  MaxPower(W)  State  Model
 7       2      1      48       806          off    LSB1GV48DB0
Table 1-1 display poe device command output description
PSE ID
ID of the PSE
SlotNo
Slot number of the PSE
SubNo
Subslot number of the PSE
PortNum
Number of PoE interfaces on the PSE
MaxPower(W)
Maximum power of the PSE (W)
PSE state:
on: The PSE is supplying power.
off: The PSE stops supplying power.
faulty: The PSE is faulty
Model
PSE model
&  Note:
The relation between the ID and the slot number of a PSE is: PSE ID = SlotNo x 3 + 1.
1.1.4  display poe interface
display poe interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
interface-type interface-number: Interface type and interface number.
Use the display poe interface command to display the power information of the specified interface.
If no interface is specified, the power information of all PoE interfaces will be displayed.
# Display the power status of GigabitEthernet 1/1/1.
<Sysname> display poe interface gigabitethernet 1/1/1
Port Power Enabled                 : enable
 Port Power Priority               : critical
 Port Operating Status             : on
 Port IEEE Class                   : 0
 Port Detection Status             : delivering-power
 Port Current Power                : 11592    mW
 Port Average Power                : 11610    mW
 Port Peak Power                   : 11684    mW
 Port Max Power                    : 15400    mW
 Port Current                      : 244      mA
 Port Voltage                      : 51.7     V
 Port PD Description               : IP Phone For Room 101
Table 1-2 display poe interface gigabitethernet command output description
Port Power Enabled
PoE enabled/disabled status on the interface:
l      enable: PoE is enabled.
l      disable: PoE is disabled.
Port Power Priority
Power priority of the PoE interface:
l      critical (highest)
l      high
l      low
Operating state of the PoE interface:
l      off: PoE is disabled.
l      on: Power is supplied for a PoE interface normally.
l      power lack: The guaranteed remaining power of the PSE is not enough to supply power to a critical PoE interface.
l      power-deny: The PSE refuses to supply power. The power required by the powered device (PD) is higher than the configured power.
l      power-itself: The external equipment is supplying power to itself.
l      power-limit: The PSE is supplying a limited power. The power required by the PD is higher than the configured power and the PSE still supplies the configured power.
Port IEEE class
PD power class
Power detection state of the PoE interface:
l      disabled: The PoE function is disabled.
l      searching: The PoE interface is searching for the PD.
l      delivering-power: The PoE interface is supplying power to the PD.
l      fault: There is a fault defined in 802.3af.
l      test: The PoE interface is under test.
l      other-fault: There is a fault other than defined in 802.3af.
l      pd-disconnect: No PD is connected.
Port Current Power
Current power of the PoE interface
Port Average Power
Average power of the PoE interface
Port Peak Power
Peak power of the PoE interface
Port Max Power
Maximum power of the PoE interface
Port Current
Current of the PoE interface
Port Voltage
Voltage of the PoE interface
Port PD Description
Description of the PD connected to the PoE interface, which is used to identify the type and location of the PD.
# Display the state of all PoE interfaces.
 Interface  Enable   Priority  CurPower  Operating    IEEE   Detection
                               (W)        Status      class  Status
 GE1/1/1     enable    low        4.4       on         0  delivering-power
 GE1/1/2     enable    critical   0         on         0      disabled
 GE1/1/3     enable    low        0         on         0      disabled
 GE1/1/4     enable    critical   0         on         0      searching
 GE1/1/5     enable    low        4.0       on         0  delivering-power
 GE1/1/6     enable    low        0         on         0      disabled
 GE1/1/7     disable   low        0         off        0      fault
 GE1/1/8     disable   low        0         off        0      disabled
 GE1/1/9     disable   low        0         off        0      disabled
 GE1/1/10    disable   low        0         off        0      disabled
 GE1/1/11    disable   low        0         off        0      disabled
 GE1/1/12    disable   low        0         off        0      disabled
---  2 port(s) on,    8.4(W) consumed,   171.6(W) remaining ---
Table 1-3 display poe interface command output description
Shortened form of a PoE interface
Enable
PoE enabled/disabled status:
Priority
Power priority of a PoE interface:
l      high
l      low
CurPower
Current power of a PoE interface
Operating Status
Operating state of a PoE interface
l      power lack: The guaranteed remaining power of the PSE is not high enough to supply power to a critical PoE interface.
IEEE class
PD power class stipulated by IEEE
Detection Status
Power detection state of a PoE interface:
l      There is a fault other than defined in 802.3af.
l      pd-disconnect: The PD is disconnected.
port(s) on
Number of PoE interfaces that are supplying power
consumed
Power consumed by the current PoE interface
remaining
Total remaining power of the system
1.1.5  display poe interface power
display poe interface power [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display poe interface power command to display the power information of a PoE interface(s).
# Display the power information of GigabitEthernet 1/1/1.
<Sysname> display poe interface power GigabitEthernet 1/1/1
Interface  CurPower PeakPower MaxPower PD Description
            (W)        (W)        (W)
 GE1/1/1    15.0       15.3       15.4      Acess Point on Room 509 for Peter
# Display the power information of all PoE interfaces.
            (W)        (W)       (W)
 GE2/1/25    4.4        4.5       4.6         IP Phone on Room 309 for Peter Smith....
 GE2/1/26    4.4        4.5       15.4        IP Phone on Room 409 for Peter Pan
 GE2/1/27    15.0      15.3       15.4       Acess Point on Room 509 for Peter
 GE2/1/28    0          0           0          IP Phone on Room 609 for Peter John....
 GE2/1/29    0          0           0          IP Phone on Room 709 for Jack
 GE2/1/30    0          0           0          IP Phone on Room 809 for Alien
---  3 port(s) on,   23.8(W) consumed,   776.2(W) remaining ---
Table 1-4 display poe interface power command output description
CurPower
PeakPower
Peak power of a PoE interface
MaxPower
Maximum power of a PoE interface
PD Description
Description of the PD connected with a PoE interface When the description contains more than 34 characters, the first 30 characters followed by four dots will be displayed.
port(s) on
consumed
Power currently consumed by all PoE interfaces
remaining
1.1.6  display poe power-usage
View
Default Level
1: Monitor level
None
Use the display poe power-usage command to display the power information of the PoE power and all PSEs
# Display the power information of the PoE power and all PSEs.
<Sysname> display poe power-usage
 PoE Current Power                : 49    W
 PoE Max Power                    : 1125  W
 PoE Max Guaranteed Power         : 1125  W
 PoE Remaining Allocated Power    : 319   W
 PoE Remaining Guaranteed Power   : 1125  W
 PoE Total Powered Port Number    : 4
 Detailed power usage of PSE(s):
 PSE ID  Max     Current  Peak     Average  Remaining     Powered
         (W)     (W)      (W)      (W)      Guaranteed(W) PortNum
 1       806     49       49       49       806           4
 28      806     0        0        0        0             0
Table 1-5 display poe power-usage command output description
PoE Current Power
Total consumption power of the PSE
PoE Max Power
Maximum PoE power
Guaranteed maximum PoE power, namely, the maximum power supplied to critical PSEs.
PoE Remaining Allocate Power
Remaining allocable PoE power = Maximum PoE power – the sum of the maximum power of all PoE-enabled PSEs
Guaranteed remaining PoE power = Guaranteed maximum PoE power – the sum of the maximum power of critical PSEs
Number of PoE interfaces that are currently supplying power
PSE ID
ID of the PSE
Max
Current
Current power of the PSE
Peak
Peak power of the PSE
Average
Average power of the PSE
Guaranteed remaining power of the PSE = Guaranteed maximum power of the PSE – the sum of the maximum power of critical PoE interfaces of the PSE
Powered PortNum
Number of PoE interfaces to which the PSE is supplying power
1.1.7  display poe pse
display poe pse [ pse-id ]
View
Default Level
1: Monitor level
pse-id: PSE ID. The relation between the ID and the slot number of a PSE is: PSE ID = SlotNo × 3 + 1. If you enter a PSE ID, the information of the PSE will be displayed. Otherwise, the information of all PSEs on the device will be displayed.
Use the display poe pse command to display the information of the specified PSE.
# Display the information of PSE 1.
<Sysname> display poe pse 1
 PSE ID                           : 1
 PSE Slot No                      : 0
 PSE SubSlot No                   : 1
 PSE Model                        : LSB1GV48DB0
 PSE Power Enabled                : enable
 PSE Power Preempted              : no
 PSE Power Priority               : low
 PSE Current Power                : 49       W
 PSE Average Power                : 49       W
 PSE Peak Power                   : 49       W
 PSE Max Power                    : 806      W
 PSE Remaining Guaranteed         : 806      W
 PSE CPLD Version                 : 21
 PSE Software Version             : 290
 PSE Hardware Version             : 0
 PSE Legacy Detection             : disable
 PSE Utilization-threshold        : 80
 PSE Pse-policy Mode              : priority
 PSE Pd-policy Mode               : priority
Table 1-6 display poe pse command output description
PSE ID
ID of the PSE
PSE Slot No
PSE SubSlot No
Sub-slot number of the PSE
PSE Model
Model of the PSE module
PSE Power Enabled
PoE is enabled for the PSE
PSE Power Preempted
PSE power preempted state
l      no: The power of the PSE is not preempted.
l      yes: The power of the PSE is preempted so that it can supply power, although PoE is enabled for the PSE
PSE Power Priority
Power priority of the PSE
PSE Current Power
PSE Average Power
PSE Peak Power
PSE Max Power
Guaranteed remaining power of the PSE = Maximum power of the PSE– the sum of the maximum power of the critical PoE interfaces of the PSE
PSE CPLD Version
PSE CPLD version
PSE software version number
PSE hardware version number
Nonstandard PD detection by the PSE:
l      enable: Enabled
l      disable: Disabled
PSE power alarm threshold
PSE Pse-policy Mode
PSE power management policy mode
PSE Pd-policy Mode
PD power management policy mode
1.1.8  display poe pse interface
display poe pse pse-id interface
View
Default Level
1: Monitor level
pse pse-id: Specifies a PSE ID. The relation between the ID and the slot number of a PSE is: PSE ID = SlotNo × 3 + 1.
Use the display poe pse interface command to display the state of all PoE interfaces connected to the specified PSE.
# Display the state of all PoE interfaces connected to PSE 1.
<Sysname> display poe pse 1 interface
                               (W)       Status      Class  Status
 GE0/1/1    enable   low       12.3      on          0    delivering-power
 GE0/1/2    disable  low       0.0       off         0      disabled
 GE0/1/3    disable  low       0.0       off         0      disabled
 GE0/1/4    disable  low       0.0       off         0      disabled
 GE0/1/5    disable  low       0.0       off         0      disabled
 GE0/1/6    disable  low       0.0       off         0      disabled
 GE0/1/7    disable  low       0.0       off         0      disabled
 GE0/1/8    disable  low       0.0       off         0      disabled
 GE0/1/9    disable  low       0.0       off         0      disabled
 GE0/1/10   disable  low       0.0       off         0      disabled
 GE0/1/11   disable  low       0.0       off         0      disabled
 GE0/1/12   disable  low       0.0       off         0      disabled
 GE0/1/13   disable  low       0.0       off         0      disabled
 GE0/1/14   disable  low       0.0       off         0      disabled
 GE0/1/15   disable  low       0.0       off         0      disabled
 GE0/1/16   disable  low       0.0       off         0      disabled
 GE0/1/17   enable   low       12.3      on          0    delivering-power
 GE0/1/18   disable  low       0.0       off         0      disabled
 GE0/1/19   disable  low       0.0       off         0      disabled
 GE0/1/20   disable  low       0.0       off         0      disabled
 GE0/1/21   disable  low       0.0       off         0      disabled
 GE0/1/22   disable  low       0.0       off         0      disabled
 GE0/1/23   disable  low       0.0       off         0      disabled
 GE0/1/24   disable  low       0.0       off         0      disabled
 GE0/1/25   disable  low       0.0       off         0      disabled
 GE0/1/26   disable  low       0.0       off         0      disabled
 GE0/1/27   disable  low       0.0       off         0      disabled
 GE0/1/28   disable  low       0.0       off         0      disabled
 GE0/1/29   disable  low       0.0       off         0      disabled
 GE0/1/30   disable  low       0.0       off         0      disabled
 GE0/1/31   disable  low       0.0       off         0      disabled
 GE0/1/32   disable  low       0.0       off         0      disabled
 GE0/1/33   disable  low       0.0       off         0      disabled
 GE0/1/34   disable  low       0.0       off         0      disabled
 GE0/1/35   enable   low       12.3      on          0    delivering-power
 GE0/1/36   disable  low       0.0       off         0      disabled
 GE0/1/37   disable  low       0.0       off         0      disabled
 GE0/1/38   disable  low       0.0       off         0      disabled
 GE0/1/39   disable  low       0.0       off         0      disabled
 GE0/1/40   disable  low       0.0       off         0      disabled
 GE0/1/41   disable  low       0.0       off         0      disabled
 GE0/1/42   disable  low       0.0       off         0      disabled
 GE0/1/43   disable  low       0.0       off         0      disabled
 GE0/1/44   disable  low       0.0       off         0      disabled
 GE0/1/45   disable  low       0.0       off         0      disabled
 GE0/1/46   disable  low       0.0       off         0      disabled
 GE0/1/47   enable   low       12.3      on          0    delivering-power
 GE0/1/48   disable  low       0.0       off         0      disabled
  ---  4 port(s) on,    49.2 (W) consumed,   756.9 (W) remaining ---
Table 1-7 display poe pse interface command output description
Enable
PoE enabled/disabled state on a PoE interface. For the value, see Table 1-2.
Priority
Priority of a PoE interface. For the value, see Table 1-2.
CurPower
Operating
Operating state of a PoE interface. For the value, see Table 1-2.
IEEE
PD power class
Detection
Power detection state of a PoE interface. For the value, see Table 1-2.
port(s) on
consumed
Power consumed by PoE interfaces on the PSE
remaining
Remaining power on the PSE
1.1.9  display poe pse interface power
display poe [ pse pse-id ] interface power
View
Default Level
1: Monitor level
Use the display poe pse interface power command to display the power information of PoE interfaces connected with the PSE.
# Display the power information of PoE interfaces connected with PSE 1.
<Sysname> display poe pse 1 interface power
             (W)       (W)         (W)
 GE0/1/1     12.3      12.3        15.4
 GE0/1/2     0.0       0.0         15.4
 GE0/1/3     0.0       0.0         15.4
 GE0/1/4     0.0       0.0         15.4
 GE0/1/5     0.0       0.0         15.4
 GE0/1/6     0.0       0.0         15.4
 GE0/1/7     0.0       0.0         15.4
 GE0/1/8     0.0       0.0         15.4
 GE0/1/9     0.0       0.0         15.4
 GE0/1/10    0.0       0.0         15.4
 GE0/1/11    0.0       0.0         15.4
 GE0/1/12    0.0       0.0         15.4
 GE0/1/13    0.0       0.0         15.4
 GE0/1/14    0.0       0.0         15.4
 GE0/1/15    0.0       0.0         15.4
 GE0/1/16    0.0       0.0         15.4
 GE0/1/17    12.3      12.3        15.4
 GE0/1/18    0.0       0.0         15.4
 GE0/1/19    0.0       0.0         15.4
 GE0/1/20    0.0       0.0         15.4
 GE0/1/21    0.0       0.0         15.4
 GE0/1/22    0.0       0.0         15.4
 GE0/1/23    0.0       0.0         15.4
 GE0/1/24    0.0       0.0         15.4
 GE0/1/25    0.0       0.0         15.4
 GE0/1/26    0.0       0.0         15.4
 GE0/1/27    0.0       0.0         15.4
 GE0/1/28    0.0       0.0         15.4
 GE0/1/29    0.0       0.0         15.4
 GE0/1/30    0.0       0.0         15.4
 GE0/1/31    0.0       0.0         15.4
 GE0/1/32    0.0       0.0         15.4
 GE0/1/33    0.0       0.0         15.4
 GE0/1/34    0.0       0.0         15.4
 GE0/1/35    12.1      12.3        15.4
 GE0/1/36    0.0       0.0         15.4
 GE0/1/37    0.0       0.0         15.4
 GE0/1/38    0.0       0.0         15.4
 GE0/1/39    0.0       0.0         15.4
 GE0/1/40    0.0       0.0         15.4
 GE0/1/41    0.0       0.0         15.4
 GE0/1/42    0.0       0.0         15.4
 GE0/1/43    0.0       0.0         15.4
 GE0/1/44    0.0       0.0         15.4
 GE0/1/45    0.0       0.0         15.4
 GE0/1/46    0.0       0.0         15.4
 GE0/1/47    12.3      12.3        15.4
 GE0/1/48    0.0       0.0         15.4
Table 1-8 display poe pse interface power command output description
CurPower
PeakPower
MaxPower
PD Description
Description of the PD connected with a PoE interface. When the description contains more than 34 characters, the first 30 characters followed by four dots will be displayed.
port(s) on
consumed
remaining
1.1.10  display poe-power
display poe-power
View
Default Level
1: Monitor level
None
Use the display poe-power command to display the information of the PoE power.
# Display the information of the PoE power.
<Sysname> display poe-power
 PoE Current Power           : 67       W
 PoE Average Power           : 48       W
 PoE Peak Power              : 62       W
 PoE Nominal Power           : 2250     W
 PoE Current Current         : 1.15     A
 PoE Current Voltage         : 53.96    V
 PoE Input-threshold Lower   : 90.00    V
 PoE Input-threshold Upper   : 264.00   V
 PoE Output-threshold Lower  : 47.00    V
 PoE Output-threshold Upper  : 55.00    V
 PoE Power Number            : 1
 PoE Power 1:
     Manufacturer            : Tyco electronics Com
     Type                    : PSE4500-A
     Status                  : Normal
Table 1-9 display poe-power command output description
PoE Current Power
Current PoE power
PoE Average Power
Average PoE power
PoE Peak Power
Peak PoE power
PoE Max Power
Maximum PoE power
PoE Nominal Power
Nominal PoE power
PoE Current Current
Current PoE current, with measurement precision of 1 ampere
PoE Current Voltage
Current PoE voltage
AC input under-voltage threshold
AC input over-voltage threshold
DC output under-voltage threshold
DC output over-voltage threshold
PoE Power Number
Number of PoE power supply units
PoE Power Manufacturer
Manufacturer of the PoE power
PoE Power Type
Type of the PoE power
PoE Power Status
PoE power state:
l      Normal
l      Absent
l      Off
l      Master
l      Slave
l      Balance
l      Redundant
l      Alarm
l      Faulty
1.1.11  display poe-power ac-input state
View
Default Level
1: Monitor level
None
Use the display poe-power ac-input state command to display the state information of the AC input power
# Display the state information of the AC input power.
<Sysname> display poe-power ac-input state
 Module Number               : 1
 Output AC Current A Alarm   : Normal
 Output AC Current B Alarm   : Normal
 Output AC Current C Alarm   : Normal
 Module 1:
     Volt Phase AB Alarm     : Normal
     Volt Phase BC Alarm     : Lack Phase
     Volt Phase CA Alarm     : Normal
Table 1-10 display poe-power ac-input state command output description
Module Number
Number of modules that a power supply unit contains
Output AC Current A/B/C Alarm
Output three-phase AC current state:
l      Normal: The current is normal.
l      Under Limit: The current is below the lower limit.
l      Above Limit: The current is above the upper limit.
l      Lack Phase: A phase is lost.
l      Fuse Broken: The fuse is broken.
l      Switch Off: The switch is turned off.
l      Other Error: Other faults
Volt Phase AB/BC/CA Alarm
AC voltage input state:
l      Normal: The voltage is normal.
l      Under Limit: The voltage is below the lower limit.
l      Above Limit: The voltage is above the upper limit.
1.1.12  display poe-power alarm
View
Default Level
1: Monitor level
None
Use the display poe-power alarm command to display the alarm information of the PoE power.
# Display the alarm information of the PoE power.
<Sysname> display poe-power alarm
 PSU Number                  : 3
 PSU 1 State                 : Normal
 PSU 2 State                 : Disconnect
 PSU 3 State                 : Over Voltage
                               Over Temperature
Table 1-11 display poe-power alarm command output description
PSU Number
Number of power supply units
PSU x State
PSU state:
l      Normal: The PSU is normal.
l      Disconnect: The PSU is disconnected.
l      Input Error: An input error occurs to the PSU.
l      Output Error: An output error occurs to the PSU.
l      Over Voltage: An over-voltage occurs to the PSU.
l      Over Temperature: An over-temperature occurs to the PSU.
l      Fan Error: A fault occurs to the fan of the PSU.
l      Shut Down: The PSU is shut down.
l      Current Restricted: The current of the PSU is restricted.
1.1.13  display poe-power dc-output state
View
Default Level
1: Monitor level
None
Use the display poe-power dc-output state command to display the state information of the DC output power
# Display the state information of the DC output power.
<Sysname> display poe-power dc-output state
DC Output State              : Normal
Table 1-12 display poe-power dc-output state command output description
DC Output State
DC output state:
l      Normal: The output voltage is normal.
l      Under Limit: The output voltage is below the lower limit.
l      Above Limit: The output voltage is above the upper limit.
l      Fuse Broken: The output fuse is broken.
l      Switch Off: The output switch is turned off.
1.1.14  display poe-power dc-output value
View
Default Level
1: Monitor level
None
Use the display poe-power dc-output value command to display the parameter values of the DC output power.
# Display the parameter values of the DC output power.
<Sysname> display poe-power dc-output value
 DC Output Voltage           : 54.05 V
 DC Output Current           : 0.35  A
Table 1-13 display poe-power dc-output value command output description
DC Output Voltage
DC output voltage
DC Output Current
DC output current, with measurement precision of 1 ampere
1.1.15  display poe-power status
View
Default Level
1: Monitor level
None
Use the display poe-power status command to display the status information of the PoE power.
# Display the status information of the PoE power.
<Sysname> display poe-power status
 Switch Number               : 1
 Switch 1 State               : AC Switch High Voltage
 DC Output Voltage           : 53.97    V
 DC Output Current           : 1.25     A
 Module Number               : 1
 Module 1:
Table 1-14 display poe-power status command output description
Switch Number
Number of power switches
Switch State
State of a power switch
DC Output State
DC output state
DC Output Voltage
DC output voltage
DC Output Current
Module Number
Volt Phrase AB/BC/CA Alarm
1.1.16  display poe-power supervision-module
View
Default Level
1: Monitor level
None
Use the display poe-power supervision-module command to display the information of the monitoring module of the PoE power.
# Display the information of the monitoring module of the PoE power.
<Sysname> display poe-power supervision-module
 Supervision Version         : 2.0
 Supervision Name            : Spring Pms
 PoE Power Type              : PSE4500-A
 PSU Available Number        : 2
 PSU 1:
     Nominal Output Power    : 2500(W)(220V)/1250(W)(110V)
     Hardware Version Info   : NP 2500
 PSU 2:
Table 1-15 display poe-power supervision-module command output description
Supervision Version
Software version number of the monitoring module of the PoE power
Supervision Name
Name of the monitoring module of the PoE power
PoE Power Type
PoE Current Power
Current consumption power
PoE Average Power
Average power
PoE Peak Power
Peak power
PoE Nominal Power
Nominal power
Number of available PSUs
Nominal output power of a PSU
Hardware version information of the PSU
1.1.17  display poe-power switch state
View
Default Level
1: Monitor level
None
Use the display poe-power switch state command to display the switch information of the PoE power.
# Display the switch information of the PoE power.
<Sysname> display poe-power switch state
 Switch Number               : 3
 Switch 1 State              : AC Switch Off
 Switch 2 State              : AC Switch High Voltage
 Switch 3 State              : AC Switch Off
Table 1-16 display poe-power switch state command output description
Switch Number
Switch state:
l      AC Switch On: The AC switch is turned on.
l      AC Switch High Voltage: The voltage of the AC switch is high.
l      AC Switch High Voltage: The voltage of the AC switch is low.
1.1.18  display poe-profile
display poe-profile [ index index | name profile-name ]
View
Default Level
1: Monitor level
name profile-name: Specifies the name of the PoE configuration file.
Use the display poe-profile command to display all information of the configurations and applications of the PoE configuration file.
Note that:
l           If no argument is specified, all information of the configurations and applications of existing PoE configuration files will be displayed.
l           If the specified PoE configuration file index or name does not exist, the related information cannot be displayed.
# Display all information of the configurations and applications of the current PoE configuration file.
<Sysname> display poe-profile
 Poe-profile     Index   ApplyNum  Interface   Configuration
 x               1       1         GE0/1/2     poe enable
                                               poe max-power 12000
 ---  1 poe-profile(s) created, 1 port(s) applied  ---
Table 1-17 display poe-profile command output description
Poe-profile
Name of the PoE configuration file
Index
Index number of the PoE configuration file
ApplyNum
Number of PoE interfaces to which a PoE configuration file is applied
Shortened form of the PoE interface to which the PoE configuration is applied
Configuration
Configurations of the PoE configuration file
Number of PoE configuration files
port(s) applied
Sum of the number of PoE interfaces to which all PoE configuration files are respectively applied
# Display all information of the configurations and applications of the PoE configuration file whose index number is 1.
<Sysname> display poe-profile index 1
 AA3456789012345  1      2           GE1/1/2     poe enable
                                     GE1/1/4     poe priority critical
                                                 poe max-power 12300
---  2 port(s) applied  ---
Table 1-18 display poe-profile index command output description
Poe-profile
Index
ApplyNum
Configuration
port(s) applied
# Display all information of the configurations and applications of the PoE configuration file named AA.
<Sysname> display poe-profile name AA
 AA               1      2         GE1/1/1    poe enable
                                   GE1/1/2    poe priority critical
                                              poe max-power 12300
Table 1-19 display poe-profile name command output description
Poe-profile
Index
ApplyNum
Configuration
port(s) applied
1.1.19  display poe-profile interface
display poe-profile interface interface-type interface-number
View
Default Level
1: Monitor level
Use the display poe-profile interface command to display all information of the configurations and applications of the PoE configuration file that currently take effect on the specified PoE interface.
# Display all information of the configurations and applications of the current PoE configuration file applied to GigabitEthernet 1/1/1.
<Sysname> display poe-profile interface GigabitEthernet 1/1/1
Poe-profile      Index  ApplyNum   Interface     Current Configuration
AA3456789012345  1      2          GE1/1/1       poe enable
Table 1-20 display poe-profile interface command output description
Poe-profile
Index
ApplyNum
Number of PoE interfaces to which the PoE configuration file is applied
Configurations of the PoE configuration file that currently take effect on a PoE interface
&  Note:
Because not all the configurations of a PoE configuration file are applied successfully, only the configurations that currently take effect on the interface are displayed.
1.1.20  poe enable
poe enable
undo poe enable
View
PoE interface view, PoE-profile file view
Default Level
2: System level
None
Use the poe enable command to enable PoE on a PoE interface.
Use the undo poe enable command to disable PoE on a PoE interface.
By default, PoE is disabled on a PoE interface.
# Enable PoE on a PoE interface.
[Sysname] interface gigabitEthernet 1/1/1
[Sysname-GigabitEthernet1/1/1] poe enable
# Enable PoE through a PoE configuration file on a PoE interface.
[Sysname] poe-profile abc
[Sysname-poe-profile-abc-1] poe enable
[Sysname-poe-profile-abc-1] quit
[Sysname-GigabitEthernet1/1/1] apply poe-profile name abc
1.1.21  poe enable pse
poe enable pse pse-id
undo poe enable pse pse-id
View
Default Level
2: System level
Use the poe enable pse command to enable PoE for the PSE.
Use the undo poe enable pse command to disable PoE for the PSE.
By default, PoE is disabled for the PSE.
# Enable PoE for PSE 10.
[Sysname] poe enable pse 10
1.1.22  poe legacy enable pse
poe legacy enable pse pse-id
undo poe legacy enable pse pse-id
View
Default Level
2: System level
Use the poe legacy enable command to enable the PSE to detect nonstandard PDs.
Use the undo poe legacy enable command to disable the PSE from detecting nonstandard PDs.
By default, the PSE is disabled from detecting nonstandard PDs.
# Enable PSE 10 to detect nonstandard PDs.
[Sysname] poe legacy enable pse 10
1.1.23  poe max-power
poe max-power max-power
undo poe max-power
View
Default Level
2: System level
max-power: Maximum power in milliwatts allocated to a PoE interface.
Use the poe max-power command to configure the maximum power for a PoE interface.
Use the undo poe max-power command to restore the default maximum power of a PoE interface.
By default, the maximum power of the PoE interface is 15,400 milliwatts.
# Set the maximum power of Ethernet 1/0 to 12,000 milliwatts.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] poe max-power 12000
# Set the maximum power of Ethernet 1/0 to 12,000 milliwatts through a PoE configuration file.
[Sysname-poe-profile-abc-1] poe max-power 12000
[Sysname-GigabitEthernet3/1/1] apply poe-profile name abc
1.1.24  poe max-power (system view)
poe max-power max-power pse pse-id
undo poe max-power pse pse-id
View
Default Level
2: System level
max-power: Maximum power in watts of the PSE.
Use the poe max-power command to configure the maximum power for the PSE.
Use the undo poe max-power command to restore the default maximum power of the PSE.
The default maximum power of a PSE is 806 watts.
Note that:
l           The maximum power of the PSE must be greater than or equal to the sum of the maximum power of all critical PoE interfaces on the PSE so as to guarantee the power supply to these PoE interfaces. When the consumption power of all PDs connected to the PSE is greater than the maximum power of the PSE, some PDs will be powered off.
l           The sum of the maximum power of all PSEs must be less than the maximum PoE power.
Related commands: poe priority (system view).
# Set the maximum power of PSE 10 to 150 watts.
[Sysname] poe max-power 150 pse 10
1.1.25  poe mode
poe mode signal
undo poe mode
View
Default Level
2: System level
signal: Specifies the PoE mode as signal (powering over signal cables). That is, lines in Category 3 and 5 twisted pair cables used for transmitting data are used for supplying DC power.
Use the poe mode command to configure a PoE mode.
Use the undo poe mode command to restore the default PoE mode.
By default, the PoE mode is signal (powering over signal cables).
# Set the PoE mode to signal (powering over signal cables).
[Sysname-GigabitEthernet1/1/1] poe mode signal
# Set the PoE mode to signal (powering over signal cables) through a PoE configuration file.
[Sysname-poe-profile-abc-1] poe mode signal
1.1.26  poe pd-description
poe pd-description string
undo poe pd-description
View
PoE interface view
Default Level
2: System level
string: Description of the PD connected to a PoE interface, up to 80 characters.
Use the poe pd-description command to configure a description for the PD connected to a PoE interface.
Use the undo poe pd-description command to restore the default.
By default, no description is configured.
# Describe the PD connected to GigabitEthernet 3/1/1 as IP Phone For Room 101.
[Sysname] interface GigabitEthernet3/1/1
[Sysname-GigabitEthernet3/1/1] poe pd-description IP Phone For Room 101
1.1.27  poe pd-policy priority
undo poe pd-policy priority
View
Default Level
2: System level
None
Use the poe pd-policy priority command to configure a PD power management priority policy.
Use the undo poe pd-policy priority command to remove the PD power management priority policy.
By default, no PD power management priority policy is configured.
# Configure a PD power management priority policy
[Sysname] poe pd-policy priority
1.1.28  poe power max-value
poe power max-value max-power
undo poe power max-value
View
Default Level
2: System level
max-power: Maximum PoE power, namely, maximum power that the device can provide for all PSEs. In consideration of the transient peak power effect, the actual maximum power is 5% higher than the configured one. In the case of 220 VAC input, when the switch uses single or dual power supply modules, you can set at most 2250 W as the maximum PoE power; when the switch uses triple power modules, you can set at most 4500 W as the maximum PoE power. In the case of 110 VAC input, when the switch uses single or dual power supply modules, you can set at most 1125 W as the maximum PoE power; when the switch uses triple power modules, you can set at most 2250 W as the maximum PoE power.
Use the poe power max-value command to configure the maximum PoE power.
Use the undo poe power max-value command to restore the default maximum PoE power.
The default maximum PoE power is 1125 for 220 VAC input and 562 for 110 VAC input.
Note that the configured maximum PoE power cannot exceed the rated PoE power.
# Set the maximum PoE power to 2,000 watts for the device.
[Sysname] poe power max-value 2000
1.1.29  poe priority
poe priority { critical | high | low }
undo poe priority
View
Default Level
2: System level
critical: Sets the power priority of a PoE interface to critical. The PoE interface whose power priority level is critical works in guaranteed mode, that is, power is first supplied to the PD connected to this critical PoE interface.
high: Sets the power priority of a PoE interface to high.
low: Sets the power priority of a PoE interface to low.
Use the poe priority command to configure a power priority level for a PoE interface.
Use the undo poe priority command to restore the default power priority level.
By default, the power priority of a PoE interface is low.
  Caution:
l      When the PoE power is insufficient, power is first supplied to PoE interfaces with a higher priority level.
l      If a PoE configuration file is already applied to a PoE interface, you need to remove the application of the file to the PoE interface before configuring the interface in PoE-profile view.
l      If a PoE configuration file is applied to a PoE interface, you need to remove the application of the file to the PoE interface before configuring the interface in PoE interface view.
l      If two PoE interfaces have the same priority level, the PoE interface with a smaller ID takes precedence over the other one. The priority levels of any two PoE interfaces are comparable only when the two interfaces are on the same PSE.
# Set the power priority of Gigabit Ethernet 1/1/1 to critical.
[Sysname-GigabitEthernet1/1/1] poe priority critical
# Set the power priority of Gigabit Ethernet 1/1/1 to critical through a PoE configuration file.
[Sysname-poe-profile-abc-1] poe priority critical
1.1.30  poe priority (system view)
poe priority { critical | high | low } pse pse-id
undo poe priority pse pse-id
View
Default Level
2: System level
critical: Sets the power priority level of the PSE to critical. The PSE whose power priority level is critical works in guaranteed mode, that is, power is first supplied to the PSE.
high: Sets the power priority of the PSE to high.
low: Sets the power priority of the PSE to low.
Use the poe priority command to configure a power priority level for the PSE.
Use the undo poe priority command to restore the default power priority level of the PSE.
By default, the power priority level of the PSE is low.
When the PoE power is insufficient, power is first supplied to PSE with a higher power priority level.
# Set the power priority of PSE 10 to critical.
[Sysname] poe priority critical pse 10
1.1.31  poe pse-policy priority
undo poe pse-policy priority
View
Default Level
2: System level
None
Use the poe pse-policy priority command to configure a PSE power management priority policy.
Use the undo poe pse-policy priority command to remove the PSE power management priority policy.
By default, no PSE power management priority policy is configured.
# Configure a PSE power management priority policy.
[Sysname] poe pse-policy priority
1.1.32  poe utilization-threshold
poe utilization-threshold utilization-threshold-value pse pse-id
undo poe utilization-threshold pse pse-id
View
Default Level
2: System level
utilization-threshold-value: Power alarm threshold in percentage, in the range of 1 to 99.
Use the poe utilization-threshold command to configure a power alarm threshold for the PSE.
Use the undo poe utilization-threshold command to restore the default power alarm threshold of the PSE.
By default, the power alarm threshold for the PSE is 80%.
  Caution:
The system will send a Trap message when the percentage of power utilization exceeds the alarm threshold. If the percentage of the power utilization always keeps above the alarm threshold, the system will not send any Trap message. Instead, when the percentage of the power utilization drops below the alarm threshold, the system will send a Trap message again.
# Set the power alarm threshold of PSE 10 to 90%.
[Sysname] poe utilization-threshold 90 pse 10
1.1.33  poe-power input-threshold
poe-power input-threshold { lower | upper } value
undo poe-power input-threshold { lower | upper }
View
Default Level
2: System level
lower value: Specifies an under-voltage threshold in volts. The recommended under-voltage threshold is 181 for 220 VAC input and 90 for 110 VAC input. For the S9500 Series Routing Switches, the default value equals the recommended value.
upper value: Specifies an over-voltage threshold in volts. The recommended over-voltage threshold is 264 for 220 VAC input and 132 for 110 VAC input. For the S9500 Series Routing Switches, the default value equals the recommended value.
Use the poe-power input-threshold command to configure an AC input under-voltage/over-voltage threshold.
Use the undo poe-power input-threshold command to restore the default AC input under-voltage/over-voltage threshold.
# Set the AC input under-voltage threshold to 181 V.
[Sysname] poe-power input-threshold lower 181
# Set the AC input over-voltage threshold to 264 V.
[Sysname] poe-power input-threshold upper 264
1.1.34  poe-power output-threshold
poe-power output-threshold { lower value | upper value }
undo poe-power output-threshold { lower | upper }
View
Default Level
2: System level
lower value: Specifies an under-voltage threshold in volts. The recommended under-voltage threshold is 45 for both 220 VAC input and 110 VAC input. For the S9500 Series Routing Switches, the default value equals the recommended value.
upper value: Specifies an over-voltage threshold in volts. The recommended over-voltage threshold is 57 for both 220 VAC input and 110 VAC input. For the S9500 Series Routing Switches, the default value equals the recommended value.
Use the poe-power output-threshold command to configure a DC output under-voltage/over-voltage threshold.
Use the undo poe-power output-threshold command to restore the default DC output under-voltage/over-voltage threshold.
# Set a DC output under-voltage threshold to 45 V.
[Sysname] poe-power output-threshold lower 45
# Set a DC output over-voltage threshold to 57 V.
[Sysname] poe-power output-threshold upper 57
1.1.35  poe-profile
poe-profile profile-name [ index ]
undo poe-profile { index index | name profile-name }
View
Default Level
2: System level
profile-name: Name of a PoE configuration file, a string of 1 to 15 characters. A PoE configuration file name begins with a letter (a through z or A through Z) and must not contain reserved keywords such as undo, all, name, interface, user, poe, disable, max-power, mode, priority and enable.
index: Index number of a PoE configuration file.
Use the poe-profile profile-name command to create a PoE configuration file and enter PoE-profile view.
Use the undo poe-profile command to delete the specified PoE configuration file.
If no index is specified, the system will automatically assign an index to the PoE configuration file, starting from 1.
  Caution:
If a PoE configuration file is already applied to a PoE interface, you cannot delete it. To delete the file, you must first execute the undo apply poe-profile command to remove the application of the PoE configuration file to the PoE interface.
# Create a PoE configuration file named abc with index 3.
[Sysname] poe-profile abc 3
