H3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
06-IPv6 Multicast Routing and Forwarding Commands
Chapter 1  IPv6 Multicast Routing and Forwarding Configuration Commands
&  Note:
The term “router” in this document refers to a router in a generic sense or an S9500 series routing switch running an IP multicast routing protocol.
1.1  IPv6 Multicast Routing and Forwarding Configuration Commands
1.1.1  debugging mfib ipv6
debugging mfib ipv6 { all | { driver | no-cache | packet | register | route | sync | upcall | wrong-iif } [ advanced-acl6-number ] } [ slot slot-id ]
undo debugging mfib ipv6 { all | { driver | no-cache | packet | register | route | sync | upcall | wrong-iif } [ advanced-acl6-number ] } [ slot slot-id ]
View
Default Level
1: Monitor level
all: Turns on/off all types of IPv6 MFIB debugging.
driver: Turns on/off IPv6 MFIB interface driver debugging.
no-cache: Turns on/off IPv6 MFIB unmatched packet debugging.
packet: Turns on/off IPv6 MFIB packet debugging.
register: Turns on/off IPv6 MFIB register message debugging.
route: Turns on/off IPv6 MFIB route debugging.
sync: Turns on/off IPv6 MFIB synchronization message debugging.
upcall: Turns on/off debugging for packets that IPv6 MFIB reports to IPv6 MRM.
wrong-iif: Turns on/off IPv6 MFIB debugging for incoming interface errors. Currently, S9500 series routing switches do not support this function.
advanced-acl6-number: Advanced IPv6 ACL number.
slot slot-id: Specifies the number of the slot where the interface card resides.
Use the debugging mfib ipv6 command to turn on IPv6 MFIB debugging.
Use the undo debugging mfib ipv6 command to turn off IPv6 MFIB debugging.
By default, IPv6 MFIB debugging is off.
Table 1-1 debugging mfib ipv6 packet command output description
Receive packet
Received IPv6 packets
Drop packet
Dropped IPv6 packets
(sadd, gadd)
(S, G) entry
The TTL
TTL value of the IPv6 packet
Forward multicast packet
Forwarded IPv6 packets
Table 1-2 debugging mfib ipv6 route command output description
receive Add entry message from MRM
An Add entry message is received from IPv6 MRM.
receive Del entry message from MRM
A Del entry message is received from IPv6 MRM.
receive Set IIF message from MRM
A Set IIF message is received from IPv6 MRM.
receive Del OIF message from MRM
A Del OIF message is received from IPv6 MRM.
receive Add OIF message from MRM
An Add OIF message is received from IPv6 MRM.
The Following OIFs are added
The following OIFs are added.
(sadd, gadd)
(S, G) entry
Table 1-3 debugging mfib ipv6 sync command output description
added to updated list
An entry is added into the update list.
deleted from updated list
An entry is deleted from the updated list.
Encoded the ADD message
The ADD message is encapsulated.
Encoded the DEL message
The DEL message is encapsulated.
Encoded the MOD message
The MOD message is encapsulated.
(sadd, gadd)
(S, G) entry
Table 1-4 debugging mfib ipv6 no-cache command output description
Receive no cache report
An unmatched IPv6 packet is received.
No MFIB entry matches
No matching entries
(sadd, gadd)
(S, G) entry
Cache the packet
IPv6 packets are cached.
Table 1-5 debugging mfib ipv6 register command output description
Send register
An IPv6 register message is sent.
(sadd, gadd)
(S, G) entry
Dropping received register packet
An error IPv6 register messages is dropped.
Table 1-6 debugging mfib ipv6 upcall command output description
Send No cache up call
The corresponding message is sent to IPv6 MRM.
(sadd, gadd)
(S, G) entry
Table 1-7 debugging mfib ipv6 driver command output description
call driver
The driver interface is called.
Do not add to driver
Not adding entries to driver
downloaded to driver Failed
Failed to deliver to driver
(sadd, gadd)
(S, G) entry
# Enable debugging for packets that IPv6 MFIB reports to IPv6 MRM.
<Sysname> debugging mfib ipv6 upcall
*Jan 24 17:24:22:842 2006 Sysname MFIB/7/MFIB UPCALL:
IPv6 Send No cache up call (40::2, FF1E::101:101) to MRM.(A14624)
// IPv6 MFIB reports an unmatched packet to IPv6 MRM.
1.1.2  debugging mrm ipv6
debugging mrm ipv6 { all | event | packet [ advanced-acl6-number ] | route [ advanced-acl6-number ] }
undo debugging mrm ipv6 { all | event | packet | route }
View
Default Level
2: System level
all: Turns on/off all types of debugging for IPv6 multicast routing management (MRM).
event: Turns on/off IPv6 MRM event debugging.
packet: Turns on/off IPv6 MRM packet debugging.
route: Turns on/off IPv6 MRM route debugging.
Use the debugging mrm ipv6 command to turn on IPv6 MRM debugging.
Use the undo debugging mrm ipv6 command to turn off IPv6 MRM debugging.
By default, IPv6 MRM debugging is off.
Table 1-8 debugging mrm ipv6 packet command output description
Received
MFIB information(NOCACHE)
MFIB information(WRONGIF)
MFIB information(ACTIVE)
MFIB information(INACTIVE)
MFIB information(SPT)
MFIB information(CLEAR)
MFIB information(REG-Timeout)
Pim
Types of received IPv6 packets
(sadd, gadd)
(S, G) entry
Table 1-9 debugging mrm ipv6 route command output description
lost the route
A route is deleted.
a new route
A new route is added.
(sadd, gadd)
(S, G) entry
Table 1-10 debugging mrm ipv6 event command output description
register interest/unregistered interest
Register/deregister
(sadd, gadd)
(S, G) entry
failed
Operation failed.
# Enable IPv6 MRM route debugging.
<Sysname> debugging mrm ipv6 route
*Jan 24 17:24:22:842 2006 Sysname MRM/7/ROUTE:
IPv6 AUX_SG: get a new route for (100::1, FF3E::1)(C155471)
*Jan 24 17:24:24:842 2006 Sysname MRM/7/ROUTE:
IPv6 AUX_SG: 100::1 is reachable, move (100::1, FF3E::1) aux join from null list(C155484)
// The route to 100::1 is reachable.
*Jan 24 17:24:23:842 2006 Sysname MRM/7/ROUTE:
IPv6 Received a creation alert for (100::1, FF3E::1)(C181103)
// An IPv6 multicast forwarding entry creation alert is received..
1.1.3  display multicast ipv6 boundary
display multicast ipv6 boundary [ ipv6-group-address [ prefix-length ] | interface interface-type interface-number ]
View
Default Level
1: Monitor level
ipv6-group-address: Displays the multicast boundary information persistent to a particular IPv6 multicast group.
prefix-length: Prefix length of an IPv6 multicast group address, in the range of 8 to 128. The system default is 128.
interface-type interface-number: Displays the multicast boundary information on a particular interface.
Use the display multicast ipv6 boundary command to view the IPv6 multicast boundary information.
Related commands: multicast ipv6 boundary.
# View the IPv6 multicast boundary information configured on all interfaces.
<Sysname> display multicast ipv6 boundary
 Boundary                                                 Interface
 FF1E::/64                                                Vlan40
Table 1-11 display multicast ipv6 boundary command output description
Boundary
IPv6 multicast group corresponding to the IPv6 multicast boundary
IPv6 boundary interface corresponding to the IPv6 multicast boundary
1.1.4  display multicast ipv6 forwarding-table
display multicast ipv6 forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { { exclude | include | match } { interface-type interface-number | register } } | statistics | slot slot-id ] * [ port-info ]
View
Default Level
1: Monitor level
ipv6-source-address: Specifies an IPv6 multicast source.
ipv6-group-address: Specifies an IPv6 multicast group.
prefix-length: Prefix length of an IPv6 multicast group address or an IPv6 multicast source address. For an IPv6 multicast group address, this argument has an effective value range of 8 to 128; for an IPv6 multicast source address, this argument has an effective value range of 0 to 128. The system default is 128 in both cases.
incoming-interface: Displays the routing entries whose incoming interface is the specified ones.
interface-type interface-number: Interface type and interface number. Currently, only VLAN interfaces are supported for the S9500 series routing switches.
register: Specifies the register interface.
outgoing-interface: Displays the forwarding entries whose outgoing interface is the specified one.
exclude: Displays the forwarding entries whose outgoing interface list excludes the specified interface.
include: Displays the forwarding entries whose outgoing interface list includes the specified interface.
match: Displays the forwarding entries whose outgoing interface list includes and includes only the specified interface.
statistics: Specifies to display the statistics information of IPv6 multicast forwarding table.
slot slot-id: Specifies the slot number of an interface card. If you do not provide this option, this command displays the multicast forwarding table information on the switching and routing processing unit (SRPU) only.
port-info: Displays Layer 2 port information.
Use the display multicast ipv6 forwarding-table command to display information of the IPv6 multicast forwarding table.
Related commands: multicast ipv6 forwarding-table downstream-limit, multicast ipv6 forwarding-table route-limit, display multicast ipv6 routing-table.
# Display information of an IPv6 multicast forwarding table.
<Sysname> display multicast ipv6 forwarding-table
IPv6 Multicast Forwarding Table
Total 1 entry
Total 1 entry matched
00001. (2001::10, FF0E::101:101)
     MID: 406, Flags: 0x100000:0
     Uptime: 00:19:09, Timeout in: 00:03:23
     Incoming interface: Vlan-interface511
     List of 2 outgoing interfaces:
       1: Vlan-interface20
       2: Vlan-interface21
     Matched 96 packets(1545 bytes), Wrong If 0 packets
     Forwarded 75 packets(75 bytes)
Table 1-12 display multicast ipv6 forwarding-table command output description
Total 1 entry
Total number of (S, G) entries in the IPv6 multicast forwarding table
Total number of matched (S, G) entries in the IPv6 multicast forwarding table
00001
Sequence number the (S, G) entry
An (S, G) entry in the IPv6 multicast forwarding table
MID
(S, G) entry ID. Each (S, G) entry has a unique MID
Flags
Current state of the (S, G) entry. Different bits are used to indicate different states of the (S, G) entry, in the format of X:Y. Major values of X are described in Table 1-13. Y is 0, indicating that the (S, G) entry is stable.
Uptime
Length of time since the (S, G) entry was installed
Timeout in
Remaining time of the (S, G) entry
Incoming interface
Incoming interface of the (S, G) entry
Outgoing interface of the (S, G) entry
Number of matched IPv6 packets (number of bytes), number of packets with incoming interface errors
These values are for reference only.
Number of forwarded IPv6 multicast packets (number of bytes)
Table 1-13 Values and meanings of the X field
Value
Meaning
0x000001
Indicates that a register-stop message needs to be sent.
0x000002
Indicates whether the IPv6 multicast source corresponding to the (S, G) entry is active.
0x000004
Indicates a null forwarding entry.
0x000008
Indicates whether the RP is a border router or a border routing switch in an IPv6 PIM domain.
0x000010
Indicates a register outgoing interface is present
0x000400
Indicates a packet to be deleted
0x008000
Indicates that the (S,G) entry  is in smoothening process after active/standby switchover
0x010000
Indicates that the (S, G) entry has been updated during the smoothening process.
0x080000
Indicates that the (S, G) entry has been repeatedly updated and needs to be deleted before adding a new entry is added.
0x100000
Indicates that a (S, G) entry is added successfully
1.1.5  display multicast ipv6 routing-table
display multicast ipv6 routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { { exclude | include | match } { interface-type interface-number | register } } ] *
View
Default Level
1: Monitor level
ipv6-source-address: IPv6 multicast source address.
ipv6-group-address: IPv6 multicast group address.
prefix-length: Prefix length of a multicast group address or an IPv6 multicast source address. For an IPv6 multicast group address, this argument has an effective value range of 8 to 128; for an IPv6 multicast source address, this argument has an effective value range of 0 to 128. The system default is 128 in both cases.
incoming-interface: Displays routing entries whose incoming interface is the specified one.
interface-type interface-number: Specifies an interface. Currently, only VLAN interfaces are supported for the S9500 series routing switches.
outgoing-interface: Displays routing entries whose outgoing interface is the specified ones.
exclude: Displays routing entries whose outgoing interface list excludes the specified interface.
include: Displays routing entries whose outgoing interface list includes the specified interface.
match: Displays routing entries whose outgoing interface list includes only the specified interface.
Use the display multicast ipv6 routing-table command to display the information of the IPv6 multicast routing table.
Related commands: display multicast ipv6 forwarding-table.
# Display the information of the IPv6 multicast routing table.
<Sysname> display multicast ipv6 routing-table
 Total 1 entry
 00001. (2001::2, FF1E::101:101)
       Uptime: 00:00:14
       Upstream Interface: Vlan-interface55
       List of 2 downstream interfaces
           1:  Vlan-interface66
           2:  Vlan-interface99
Table 1-14 display multicast ipv6 routing-table command output description
Total 1 entry
Total number of matched (S, G) entries in the IPv6 multicast routing table
00001
Uptime
Length of time since the (S, G) entry was installed.
Upstream Interface
Upstream interface of the (S, G) entry. IPv6 multicast packets for this (S, G) entry should arrive through this interface
Downstream interface list. These interfaces need to forward multicast packets for this (S, G) entry.
1.1.6  display multicast ipv6 rpf-info
display multicast ipv6 rpf-info ipv6-source-address [ ipv6-group-address ]
View
Default Level
1: Monitor level
ipv6-source-address: Specify an IPv6 multicast source.
Use the display multicast ipv6 rpf-info command to display RPF information for an IPv6 multicast source.
Related commands: display multicast ipv6 routing-table and display multicast ipv6 forwarding-table.
# Display all RPF information for the multicast source 2001::101.
<Sysname> display multicast ipv6 rpf-info 2001::101
RPF information about source 2001::101
     RPF interface: Vlan-interface5
     Referenced route/prefix length: 2001::101/64
     Referenced route type: igp
     Load splitting rule: disable
Table 1-15 display multicast ipv6 rpf-info command output description
RPF information of the IPv6 multicast source 2001::101
RPF interface
The RPF interface
Referenced route and prefix length
Type of the referenced route
Route-route selecting rule
RPF route selection rule: by the priority of the routing protocol or by the longest match of the destination address in the routing table.
Load splitting rule
Load sharing rule
1.1.7  multicast ipv6 boundary
multicast ipv6 boundary ipv6-group-address prefix-length
undo multicast ipv6 boundary { ipv6-group-address prefix-length | all }
View
VLAN interface view
Default Level
2: System level
prefix-length: Prefix length of an IPv6 multicast group address.
all: Deletes all IPv6 multicast boundaries configured on the interface.
Use the multicast ipv6 boundary command to configure a multicast forwarding boundary.
Use the undo multicast ipv6 boundary command to delete the specified multicast forwarding boundary or all IPv6 multicast forwarding boundaries.
By default, no multicast forwarding boundary is configured.
Note that:
l           A multicast forwarding boundary sets the boundary condition for the IPv6 multicast groups in the specified range. If the destination address of an IPv6 multicast packet matches the set boundary condition, the packet will not be forwarded.
l           If an interface needs to act as forwarding boundary for multiple IPv6 multicast groups, just carry out this command on the interface once for each group.
l           Assume that Set A and Set B are both multicast forwarding boundary sets to be configured, and that B is a subset of A. If A has been configured on an interface, it is not allowed to configure B on the interface; if B has been configured on the interface before A is configured, the previously configured B needs to be removed.
Related commands: display multicast ipv6 boundary.
# Configure VLAN-interface 100 to be the forwarding boundary for IPv6 multicast group FF35::101:101/16.
[Sysname-Vlan-interface100] multicast ipv6 boundary FF35::101:101 16
1.1.8  multicast ipv6 forwarding-table downstream-limit
multicast ipv6 forwarding-table downstream-limit limit
undo multicast ipv6 forwarding-table downstream-limit
View
Default Level
2: System level
limit: Maximum number of downstream nodes for a single entry in the IPv6 multicast forwarding table.
Use the multicast ipv6 forwarding-table downstream-limit command to configure the maximum number of downstream nodes for a single entry in the IPv6 multicast forwarding table.
Use the undo multicast ipv6 forwarding-table downstream-limit command to restore the default.
By default, the maximum number of downstream nodes for a single entry in the IPv6 multicast forwarding table is 128.
# Set the maximum number of downstream nodes for a single entry in the IPv6 multicast forwarding table to 120.
[Sysname] multicast ipv6 forwarding-table downstream-limit 120
1.1.9  multicast ipv6 forwarding-table route-limit
multicast ipv6 forwarding-table route-limit limit
undo multicast ipv6 forwarding-table route-limit
View
Default Level
2: System level
limit: Maximum number of entries in the IPv6 multicast forwarding table.
Use the multicast ipv6 forwarding-table route-limit command to configure the maximum number of entries in the IPv6 multicast forwarding table.
Use the undo multicast ipv6 forwarding-table route-limit command to restore the default.
By default, the maximum number of entries in the IPv6 multicast forwarding table is 256.
# Set the maximum number of entries in the IPv6 multicast forwarding table to 200.
[Sysname] multicast ipv6 forwarding-table route-limit 200
1.1.10  multicast ipv6 load-splitting
multicast ipv6 load-splitting {source | source-group }
undo multicast ipv6 load-splitting
View
Default Level
2: System level
source: Specifies to implement IPv6 multicast load splitting on a per-source basis.
source-group: Specifies to implement IPv6 multicast load splitting on a per-source and per-group basis.
Use the multicast load-splitting command to enable load splitting of IPv6 multicast traffic.
Use the undo multicast load-splitting command to disable load splitting of IPv6 multicast traffic.
By default, load splitting of IPv6 multicast traffic is disabled.
# Enable load splitting of IPv6 multicast traffic on a per-source basis.
[Sysname] multicast ipv6 load-splitting source
1.1.11  multicast ipv6 routing-enable
undo multicast ipv6 routing-enable
View
Default Level
2: System level
None
Use the multicast ipv6 routing-enable command to enable IPv6 multicast routing.
Use the undo multicast ipv6 routing-enable command to disable IPv6 multicast routing.
IPv6 multicast routing is disabled by default.
Note that:
l           You must enable IPv6 multicast routing before you can carry out other Layer 3 IPv6 multicast commands.
l           The device does not forward any IPv6 multicast packets before IPv6 multicast routing is enabled.
# Enable IPv6 multicast routing.
[Sysname] multicast ipv6 routing-enable
1.1.12  reset multicast ipv6 forwarding-table
reset multicast ipv6 forwarding-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number | register } } * | all }
View
Default Level
2: System level
prefix-length: Prefix length of an IPv6 multicast group or an IPv6 multicast source address. For an IPv6 multicast group address, this argument has an effective value range of 8 to 128; for an IPv6 multicast source address, this argument has an effective value range of 0 to 128. The system default is 128 in both cases.
incoming-interface: Clears IPv6 multicast forwarding entries of which the incoming interface is the specified one.
all: Clears all forwarding entries from the IPv6 multicast forwarding table.
Use the reset multicast ipv6 forwarding-table command to clear forwarding entries from the IPv6 multicast forwarding table.
When a forwarding entry is deleted from the IPv6 multicast forwarding table, the corresponding routing entry is also deleted from the IPv6 multicast routing table.
Related commands: reset multicast IPv6 routing-table, display multicast ipv6 routing-table, display multicast ipv6 forwarding-table.
# Clear the IPv6 multicast forwarding entries related to the IPv6 multicast group FF1E::101:101 from the IPv6 multicast forwarding table.
<Sysname> reset multicast ipv6 forwarding-table ff1e::101:101
1.1.13  reset multicast IPv6 routing-table
reset multicast ipv6 routing-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number | register } } * | all }
View
Default Level
1: Monitor level
ipv6-group-address: Specifies an IPv6 multicast group address.
prefix-length: Prefix length of an IPv6 multicast group address or an IPv6 multicast source address. For an IPv6 multicast group address, this argument has an effective value range of 8 to 128 for an IPv6 multicast source address, this argument has an effective value range of 0 to 128. The system default is 128 in both cases.
incoming-interface: Clears IPv6 multicast routing entries of which the incoming interface is the specified one.
register: Specifies a registration interface.
all: Clears all routing entries from the IPv6 multicast routing table.
Use the reset multicast ipv6 routing-table command to clear IPv6 routing entries from the IPv6 multicast routing table.
When a routing entry is deleted from the IPv6 multicast routing table, the corresponding forwarding entry is also deleted from the IPv6 multicast forwarding table.
Related commands: reset multicast ipv6 forwarding-table, display multicast ipv6 forwarding-table, display multicast ipv6 routing-table.
# Clear the routing entries related to the IPv6 multicast group FF1E::101:101 from the IPv6 multicast routing table.
<Sysname> reset multicast ipv6 routing-table ff1e::101:101
