H3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
07-MLD Snooping Commands
07-MLD Snooping Commands 133.33 KB
Chapter 1  MLD Snooping Configuration Commands
1.1  MLD Snooping Configuration Commands
1.1.1  debugging mld-snooping
debugging mld-snooping { all | event | abnormal | driver | group | timer | ipc { receive | send } | packet [ vlan vlan-id [ port port-type port-number ] ] }
undo debugging mld-snooping { all | event | abnormal | driver | group | timer | ipc { receive | send } | packet }
View
Default Level
1: Monitor level
all: Turns on/off all types of debugging for MLD Snooping.
event: Turns on/off MLD Snooping event debugging.
abnormal: Turns on/off debugging for abnormal MLD-Snooping information.
driver: Turns on/off MLD Snooping driver debugging.
group: Turns on/off MLD Snooping group debugging.
timer: Turns on/off MLD Snooping timer debugging.
ipc: Turns on/off IPC packet debugging.
receive: Turns on/off debugging for received IPC packets.
send: Turns on/off debugging for sent IPC packets.
packet: Turns on/off MLD message debugging.
vlan vlan-id: Specifies a VLAN.
port port-type port-number: Specifies a port.
Use the debugging mld-snooping command to turn on debugging for MLD Snooping. Use the undo debugging mld-snooping command to turn off debugging for MLD Snooping.
By default, MLD Snooping debugging is off.
Table 1-1 debugging mld-snooping driver command output description
mask boardmask
Destination board mask for adding entry to driver
(saddr, gaddr)
(S, G) entry
Table 1-2 debugging mld-snooping event command output description
Succeed to enable/disable MLD snooping drop-unknown globally
Enable/disable the function of dropping unknown multicast packets globally
Table 1-3 debugging mld-snooping group command output description
(saddr, gaddr)
(S, G) entry
on vlan vlanid
VLAN to which the (S, G) entry belongs
Table 1-4 debugging mld-snooping packet command output description
MLDv1/ MLDv2 general query/ special query/ group-and-source-specific query/report/done packet
MLDv1/MLDv2 general query/multicast-address-specific query/multicast-address-and-source specific query/report/done message
port portname
Number of the port that processes the message
on vlan vlanid
ID of the VLAN to which the port belongs
destination address dstaddr
Destination address of the message
Table 1-5 debugging mld-snooping timer command output description
host port aging timer/time
router port aging timer/time
aggregation host port aging timer/time
aggregation router port aging timer/time
querier timer/interval
MLD-Snooping timers
# Turn on all types of debugging for MLD Snooping.
<Sysname> debugging mld-snooping all
1.1.2  display mld-snooping group
display mld-snooping group [ vlan vlan-id ] [ slot slot-id ] [ verbose ]
View
Default Level
1: Monitor level
vlan vlan-id: Displays the MLD Snooping multicast group information in the specified VLAN. If you do not specify a VLAN, this command will display the MLD Snooping multicast group information in all VLANs.
slot slot-id: Displays the MLD Snooping multicast group information for the specified card. If you do not specify a slot, this command will display the MLD Snooping multicast group information on the switching and routing processing unit (SRPU) only.
verbose: Displays the detailed MLD Snooping multicast group information.
Use the display mld-snooping group command to view the MLD Snooping multicast group information.
# View the detailed IGMP Snooping multicast group information on the card slot 7.
<Sysname> display mld-snooping group slot 7 verbose
    Total 1 IP Group(s).
    Total 1 IP Source(s).
    Total 1 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, A-Aggregation port, C-Copy port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):22.
    Router port unit board: Mask(0x0)
    Router port(s):total 0 port.
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:FF1E::101:101
        (::, FF1E::101:101):
          Attribute:    Host Port
          Host port unit board: Mask(0x0)
          Host port(s):total 1 port.
            Eth7/1/7              (D) ( 00:03:37 )
    MAC group(s):
        MAC group address:3333-0101-0101
            Eth7/1/7
Table 1-6 display mld-snooping group command output description
Total 1 IP Group(s)
Total number of IPv6 multicast groups
Total number of IPv6 multicast sources
Total number of MAC multicast groups
Port flags: D for dynamic port, S for static port, A for aggregation port, C for port copied from a (*, G) entry to an (S, G) entry
Sub-VLAN flags: R for real egress sub-VLAN under the current entry, C for sub-VLAN copied from a (*, G) entry to an (S, G) entry
Mask (0x0)
Board mask (0x0 indicates that ports on the current board have joined the multicast group; while no ports of other boards did not)
Router port(s):
Number of router ports
Information about the IPv6 multicast groups
IP group address
Address of the IPv6 multicast group
(::, FF1E::101:101)
(*, G) entry
Attribute
Attribute of the IPv6 multicast group
Host port(s)
Number of host member ports
( 00:03:37 )
Remaining aging time of the port
MAC group(s):
Information about the MAC multicast group
MAC group address
Address of the MAC multicast group
1.1.3  display mld-snooping statistics
View
Default Level
1: Monitor level
None
Use the display mld-snooping statistics command to view the statistics information of MLD messages learned by MLD Snooping.
# View the statistics information of all kinds of MLD messages learned by MLD Snooping.
<Sysname> display mld-snooping statistics
  Received MLD general queries:0.
  Received MLDv1 specific queries:0.
  Received MLDv1 reports:0.
  Received MLD dones:0.
  Sent     MLDv1 specific queries:0.
  Received MLDv2 reports:0.
  Received MLDv2 reports with right and wrong records:0.
  Received MLDv2 specific queries:0.
  Received MLDv2 specific sg queries:0.
  Sent     MLDv2 specific queries:0.
  Sent     MLDv2 specific sg queries:0.
  Received error MLD messages:0.
Table 1-7 display mld-snooping statistics command output description
general queries
General query messages
specific queries
Multicast-address-specific query messages
reports
Report messages
dones
Done messages
Reports containing correct and incorrect records
specific sg queries
Multicast-address-and-group-specific query messages
error MLD messages
Error MLD messages
1.1.4  drop-unknown
drop-unknown
undo drop-unknown
View
MLD Snooping view
Default Level
2: System level
None
Use the drop-unknown command to enable globally the function of dropping unknown IPv6 multicast data.
Use the undo drop-unknown command to disable globally the function of dropping unknown IPv6 multicast data.
By default, this function is disabled, that is, unknown IPv6 multicast traffic is flooded within the VLAN.
Note that this command works only on an MLD Snooping–enabled VLAN, but not on a VLAN with MLD enabled on its VLAN interface.
# Globally enable the function of dropping unknown IPv6 multicast data.
[Sysname] mld-snooping
[Sysname-mld-snooping] drop-unknown
1.1.5  fast-leave
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
View
MLD Snooping view
Default Level
2: System level
vlan vlan-list: Defines one or multiple VLANs. You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID.
Use the fast-leave command to enable fast leave processing globally.
Use the undo fast-leave command to disable fast leave processing globally.
By default, fast leave processing is disabled globally.
Note that:
l           This command works on an MLD Snooping–enabled VLAN or on a VLAN with MLD enabled on its VLAN interface.
l           If you do not specify any VLAN, the command will take effect for all VLANs; if you specify a VLAN or multiple VLANs, the command will take effect for the specified VLAN(s) only.
Related commands: mld-snooping fast-leave.
# Enable fast leave processing globally in VLAN 2.
[Sysname-mld-snooping] fast-leave vlan 2
1.1.6  group-policy
group-policy acl6-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
View
MLD Snooping view
Default Level
2: System level
Acl6-number: Basic IPv6 ACL number.
Use the group-policy command to configure a global IPv6 multicast group filter.
Use the undo group-policy command to remove the configured global IPv6 multicast group filter.
By default, no IPv6 multicast group filter is configured globally, namely, a host can join any IPv6 multicast group.
Note that:
l           If the specified IPv6 ACL does not exist or the ACL rule is null, all IPv6 multicast groups will be filtered out.
l           You can configure different IPv6 ACL rules for each port in different VLANs; for a given VLAN, a newly configured IPv6 ACL rule will override the existing one.
Related commands: mld-snooping group-policy.
# Configure ACL 2000 as the IPv6 multicast group filter in VLAN 2.
[Sysname-mld-snooping] group-policy 2000 vlan 2
1.1.7  host-aging-time
host-aging-time interval
undo host-aging-time
View
MLD Snooping view
Default Level
2: System level
interval: Dynamic member port aging time, in seconds.
Use the host-aging-time command to configure the global aging time of dynamic member ports.
Use the undo host-aging-time command to restore the default setting.
By default, the aging time of dynamic member ports is 260 seconds.
This command works only on an MLD Snooping–enabled VLAN, but not on a VLAN with MLD enabled on its VLAN interface.
Related commands: mld-snooping host-aging-time.
# Set the aging time of dynamic member ports globally to 300 seconds.
[Sysname-mld-snooping] host-aging-time 300
1.1.8  last-listener-query-interval
undo last-listener-query-interval
View
MLD Snooping view
Default Level
2: System level
interval: MLD last listener query interval, namely the interval between MLD multicast-address-specific queries, in seconds.
Use the last-listener-query-interval command to configure the MLD last listener query interval globally.
Use the undo last-listener-query-interval command to restore the system default.
By default, the MLD last listener query interval is 1 second.
Related commands: mld-snooping last-listener-query-interval.
# Set the MLD last listener query interval to 3 seconds globally.
[Sysname-mld-snooping] last-listener-query-interval 3
1.1.9  max-response-time
max-response-time interval
undo max-response-time
View
MLD Snooping view
Default Level
2: System level
interval: Maximum response delay, namely the maximum length of time in seconds member hosts are allowed to wait before sending MLD reports in response to an MLD general query.
Use the max-response-time command to configure the maximum response delay globally.
Use the undo max-response-time command to restore the system default.
By default, the maximum response delay is 10 seconds.
Related commands: mld-snooping max-response-time, mld-snooping query-interval.
# Set the maximum response delay to 5 seconds globally.
[Sysname-mld-snooping] max-response-time 5
1.1.10  mld-snooping
mld-snooping
undo mld-snooping
View
Default Level
2: System level
None
Use the mld-snooping command to enable MLD Snooping globally and enter MLD Snooping view.
Use the undo mld-snooping command to disable MLD Snooping globally.
By default, MLD Snooping is disabled.
Related commands: mld-snooping enable.
# Enable MLD Snooping and enter MLD Snooping view.
1.1.11  mld-snooping enable
mld-snooping enable
undo mld-snooping enable
View
VLAN view
Default Level
2: System level
None
Use the mld-snooping enable command to enable MLD Snooping in the current VLAN.
Use the undo mld-snooping enable command to disable MLD Snooping in the current VLAN.
By default, MLD Snooping is disabled in a VLAN.
&  Note:
l      Before enabling MLD Snooping in a VLAN, you must globally enable MLD Snooping in system view.
l      After MLD Snooping is enabled in a VLAN, it is not allowed to enable MLD or IPv6 PIM on the corresponding VLAN interface, and vice versa.
Related commands: mld-snooping.
# Enable MLD Snooping in VLAN 2.
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
1.1.12  mld-snooping fast-leave
undo mld-snooping fast-leave [ vlan vlan-list ]
View
Ethernet interface view, port group view
Default Level
2: System level
Use the mld-snooping fast-leave command to enable fast leave processing on the current port or group of ports.
Use the undo mld-snooping fast-leave command to disable fast leave processing on the current port or group of ports.
By default, fast leave processing is disabled.
Note that:
l           If you do not specify any VLAN in Ethernet interface view, the command will take effect for the port no matter which VLAN the port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect for the port only if the port belongs to the specified VLAN(s).
l           If you do not specify any VLAN in manual port group view, the command will take effect on all the ports in this group no matter which VLANs these ports belong to; if you specify a VLAN or multiple VLANs, the command will take effect on those ports in this group that belong to the specified VLAN(s).
l           Configurations made in aggregation port group view are effective only for the master port in the group. If you do not specify any VLAN in aggregation port group view, the command will take effect no matter which VLAN the master port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect only if the master port belongs to the specified VLAN(s).
Related commands: fast-leave.
# Enable fast leave processing on Ethernet 1/1/1, which belongs to VLAN 2.
[Sysname] interface ethernet 1/1/1
[Sysname-Ethernet1/1/1] mld-snooping fast-leave vlan 2
1.1.13  mld-snooping general-query source-ip
mld-snooping general-query source-ip { current-interface | ipv6-address }
undo mld-snooping general-query source-ip
View
VLAN view
Default Level
2: System level
current-interface: Specifies the IPv6 link-local address of the current VLAN interface as the source IPv6 address of MLD general queries..
ipv6-address: Specifies the source IPv6 address of MLD general queries, which can be any legal IPv6 link-local address.
Use the mld-snooping general-query source-ip command to configure the source IPv6 address of MLD general queries.
Use the undo mld-snooping general-query source-ip command to restore the default configuration.
By default, the source IPv6 address of MLD general queries is FE80::02FF:FFFF:FE00:0001.
This command takes effect only if MLD Snooping is enabled in the VLAN.
# In VLAN 2, specify FE80:0:0:1::1 as the source IPv6 address of MLD general queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping general-query source-ip fe80:0:0:1::1
1.1.14  mld-snooping group-limit
undo mld-snooping group-limit [ vlan vlan-list ]
View
Default Level
2: System level
limit: Maximum number of IPv6 multicast groups that can be joined on a port.
vlan vlan-list: Defines one or multiple VLANs. You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id. If you do not provide this option, the command will take effect on each VLAN to which this port belongs.
Use the mld-snooping group-limit command to configure the maximum number of IPv6 multicast groups that can pass the port(s).
Use the undo mld-snooping group-limit command to restore the default setting.
By default, the maximum number of IPv6 multicast groups allowed to pass the port (s) is 1024.
Note that:
l           Configurations made in aggregation port group view are effective only for the master port of the group. If you do not specify any VLAN in aggregation port group view, the command will take effect no matter which VLAN the master port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect only if the master port belongs to the specified VLAN(s).
# Specify to allow a maximum of ten IPv6 multicast groups to be joined on Ethernet 1/1/1, which belongs to VLAN 2.
[Sysname-Ethernet1/1/1] mld-snooping group-limit 10 vlan 2
1.1.15  mld-snooping group-policy
mld-snooping group-policy acl6-number [ vlan vlan-list ]
undo mld-snooping group-policy [ vlan vlan-list ]
View
Default Level
2: System level
acl6-number: Basic IPv6 ACL number.
Use the mld-snooping group-policy command to configure an IPv6 multicast group filter on the current port(s).
Use the undo mld-snooping group-policy command to remove the configured IPv6 multicast group filter on the current port(s).
By default, no IPv6 multicast group filter is configured on a port, namely a host can join any IPv6 multicast group.
Note that:
l           If the specified ACL does not exist or the ACL rule is null, all IPv6 multicast groups will be filtered out.
Related commands: group-policy.
# Configure ACL 2000 as the IPv6 multicast group filter on Ethernet 1/1/1, which belongs to VLAN 2.
[Sysname-Ethernet1/1/1] mld-snooping group-policy 2000 vlan 2
1.1.16  mld-snooping host-aging-time
mld-snooping host-aging-time interval
undo mld-snooping host-aging-time
View
VLAN view
Default Level
2: System level
Use the mld-snooping host-aging-time command to configure the aging time of IPv6 multicast group dynamic member ports in the current VLAN.
Use the undo mld-snooping host-aging-time command to restore the system default.
By default, the dynamic member port aging time is 260 seconds.
Related commands: host-aging-time.
# Set the aging time of dynamic member ports in VLAN 2 to 300 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-aging-time 300
1.1.17  mld-snooping host-join
undo mld-snooping host-join ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
View
Default Level
2: System level
ipv6-group-address: Address of the IPv6 multicast group the current port(s) will join as simulated member host(s).
source-ip ipv6-source-address: Specifies the address of the IPv6 multicast source that the simulated host is to join.
vlan vlan-id: Specifies a VLAN that comprises the Ethernet port(s)
Use the mld-snooping host-join command to configure the current port(s) as simulated member host(s) for the specified IPv6 multicast group or source and group.
Use the undo mld-snooping host-join command to remove the current port(s) as simulated member host(s) for the specified IPv6 multicast group or source and group.
By default, no ports are configured as static member ports for any IPv6 multicast group or source and group.
Note that:
l           If configured in Ethernet interface view, this feature takes effect on the port only if the port belongs to the specified VLAN.
l           If configured in manual port group view, this feature takes effect only on those ports in this port group that belong to the specified VLAN.
l           When used in aggregation port group view, the command will take effect only if the master port belongs to the specified VLAN and only on the master port.
l           The source-ip ipv6-source-address option in the command is meaningful only for MLD Snooping version 2. If MLD Snooping version 1 is running, although you can include source-ip ipv6-source-address in your command, the simulated host responses with only an MLDv1 report when receiving a query message.
# # Configure Ethernet 1/1/1 in VLAN 2 to join the IPv6 multicast group FF1E::101:101 as a simulated host. .
[Sysname-Ethernet1/1/1] mld-snooping host-join ff1e::101:101 vlan 2
1.1.18  mld-snooping last-listener-query-interval
undo mld-snooping last-listener-query-interval
View
VLAN view
Default Level
2: System level
Use the mld-snooping last-listener-query-interval command to configure the MLD last listener query interval in the VLAN.
Use the undo mld-snooping last-listener-query-interval command to restore the system default.
By default, the MLD last member query interval is 1 second.
Related commands: last-listener-query-interval.
# Set the MLD last member query interval to 3 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping last-listener-query-interval 3
1.1.19  mld-snooping max-response-time
mld-snooping max-response-time interval
undo mld-snooping max-response-time
View
VLAN view
Default Level
2: System level
Use the mld-snooping max-response-time command to configure the maximum response delay in the VLAN.
Use the undo mld-snooping max-response-time command to restore the system default.
Related commands: max-response-time, mld-snooping query-interval.
# Set the maximum response delay to 5 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping max-response-time 5
1.1.20  mld-snooping overflow-replace
undo mld-snooping overflow-replace [ vlan vlan-list ]
View
Default Level
2: System level
Use the mld-snooping overflow-replace command to enable the IPv6 multicast group replacement function on the current port(s).
Use the undo mld-snooping overflow-replace command to disable the IPv6 multicast group replacement function on the current port(s).
By default, the IPv6 multicast group replacement function is disabled.
Note that:
Related commands: overflow-replace.
# Enable the IPv6 multicast group replacement function on Ethernet 1/1/1, which belongs to VLAN 2.
[Sysname-Ethernet1/1/1] mld-snooping overflow-replace vlan 2
1.1.21  mld-snooping querier
undo mld-snooping querier
View
VLAN view
Default Level
2: System level
None
Use the mld-snooping querier command to enable the MLD Snooping querier function in the VLAN.
Use the undo mld-snooping querier command to disable the MLD Snooping querier function in the VLAN.
By default, the MLD Snooping querier function is disabled.
# Enable the MLD Snooping querier function in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier
1.1.22  mld-snooping query-interval
undo mld-snooping query-interval
View
VLAN view
Default Level
2: System level
interval: Interval between MLD general queries, in seconds.
Use the mld-snooping query-interval command to configure the interval between MLD general queries.
Use the undo mld-snooping query-interval command to restore the default setting.
By default, the interval between MLD general queries is 125 seconds.
Related commands: mld-snooping querier, mld-snooping max-response-time, max-response-time.
# Set the interval between MLD general queries to 20 seconds in VLAN2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping query-interval 20
1.1.23  mld-snooping router-aging-time
mld-snooping router-aging-time interval
undo mld-snooping router-aging-time
View
VLAN view
Default Level
2: System level
interval: Dynamic router port aging time, in seconds.
Use the mld-snooping router-aging-time command to configure the aging time of dynamic router ports in the current VLAN.
Use the undo mld-snooping router-aging-time command to restore the default setting.
By default, the dynamic router port aging time is 260 seconds.
Related commands: router-aging-time.
# Set the aging time of dynamic router ports in VLAN 2 to 100 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping router-aging-time 100
1.1.24  mld-snooping special-query source-ip
mld-snooping special-query source-ip { current-interface | ipv6-address }
undo mld-snooping special-query source-ip
View
VLAN view
Default Level
2: System level
current-interface: Specifies the source IPv6 link-local address of the VLAN interface of the current VLAN as the source IPv6 address of MLD multicast-address-specific queries.
ipv6-address: Specifies an IPv6 link-local address as the source IPv6 address of MLD multicast-address-specific queries.
Use the mld-snooping special-query source-ip command to configure the source IPv6 address of MLD multicast-address-specific queries.
Use the undo mld-snooping special-query source-ip command to restore the system default.
By default, the source IPv6 address of MLD multicast-address-specific queries is FE80::02FF:FFFF:FE00:0001.
# In VLAN 2, specify FE80:0:0:1::1 as the source IPv6 address of MLD multicast-address-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping special-query source-ip fe80:0:0:1::1
1.1.25  mld-snooping static-group
undo mld-snooping static-group ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
View
Default Level
2: System level
ipv6-group-address: Address of an IPv6 multicast group the current port(s) will join as static member port(s).
source-ip ipv6-source-address: Specifies the address of the IPv6 multicast source the port(s) will be configured to join as static member port(s).
vlan vlan-id: Specifies a VLAN that comprises the current Ethernet port(s).
Use the mld-snooping static-group command to configure static joining on the current port(s), namely to configure the current port(s) as static IPv6 multicast group or source-group member(s).
Use the undo mld-snooping static-group command to restore the default.
By default, no ports are configured as static member ports.
Note that:
# Configure Ethernet 1/1/1 in VLAN 2 to join the IPv6 multicast group FF1E::101:101 as a static member port.
[Sysname-Ethernet1/1/1] mld-snooping static-group ff1e::101:101 vlan 2
1.1.26  mld-snooping static-router-port
undo mld-snooping static-router-port vlan vlan-id
View
Default Level
2: System level
Use the mld-snooping static-router-port command to configure the current port(s) as static router port(s).
Use the undo mld-snooping static-router-port command to restore the default.
By default, no ports are configured as static router ports.
Note that:
l           When used in aggregation port group view, the command will take effect only if the master port belongs to the specified VLAN..
# Configure Ethernet 1/1/1, which belongs to VLAN 2, as a static router port.
[Sysname-Ethernet1/1/1] mld-snooping static-router-port vlan 2
1.1.27  mld-snooping version
undo mld-snooping version
View
VLAN view
Default Level
2: System level
version-number: MLD snooping version, in the range of 1 to 2.
Use the mld-snooping version command to configure the MLD Snooping version.
Use the undo mld-snooping version command to restore the default.
By default, the MLD version is 1.
This command can take effect only if MLD Snooping is enabled in the VLAN.
# Enable MLD Snooping in VLAN 2, and set the MLD Snooping version to version 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping version 2
1.1.28  overflow-replace
undo overflow-replace [ vlan vlan-list ]
View
MLD Snooping view
Default Level
2: System level
Use the overflow-replace command to enable the IPv6 multicast group replacement function globally.
Use the undo overflow-replace command to disable the IPv6 multicast group replacement function globally.
By default, the IPv6 multicast group replacement function is disabled globally.
Note that:
Related commands: mld-snooping overflow-replace.
# Enable the IPv6 multicast group replacement function globally in VLAN2.
[Sysname-mld-snooping] overflow-replace vlan 2
1.1.29  report-aggregation
report-aggregation
undo report-aggregation
View
MLD Snooping view
Default Level
2: System level
None
Use the mld-snooping report-aggregation command to enable MLD report suppression.
Use the undo mld-snooping report-aggregation command to disable MLD report suppression.
By default, MLD report suppression is enabled.
# Disable MLD report suppression.
[Sysname] undo report-aggregation
1.1.30  reset mld-snooping group
reset mld-snooping group { ipv6-group-address | all } [ vlan vlan-id ]
View
Default Level
2: System level
ipv6-group-address: Clears the information about the specified MLD Snooping multicast group.
all: Clears all MLD Snooping multicast group information.
vlan vlan-id: Clears the MLD Snooping multicast group information in the specified VLAN.
Use the reset mld-snooping group command to clear MLD Snooping entries.
Note that:
l           This command works only on an MLD Snooping–enabled VLAN, but not on a VLAN with MLD enabled on its VLAN interface.
l           This command cannot clear MLD Snooping multicast group information of static joins.
# Clear all MLD Snooping multicast group information saved in the device.
<Sysname> reset mld-snooping group all
1.1.31  reset mld-snooping statistics
View
Default Level
2: System level
None
Use the reset mld-snooping statistics command to clear the statistics information of MLD messages learned by MLD Snooping.
# Clear the statistics information of all kinds of MLD messages learned by MLD Snooping.
<Sysname> reset mld-snooping statistics
1.1.32  router-aging-time
undo router-aging-time
View
MLD Snooping view
Default Level
2: System level
interval: Router port aging time, in seconds.
Use the router-aging-time command to configure the aging time of dynamic router ports globally.
Use the undo router-aging-time command to restore the system default.
Related commands: mld-snooping router-aging-time.
# Set the aging time of dynamic router ports to 100 seconds globally.
[Sysname-mld-snooping] router-aging-time 100
