H3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
04-PIM Commands
04-PIM Commands 236.06 KB
Table of Contents
Chapter 1 PIM Configuration Commands. 1-1
1.1 PIM Configuration Commands. 1-1
1.1.1 auto-rp enable. 1-1
1.1.2 bsr-policy. 1-1
1.1.3 c-bsr 1-2
1.1.4 c-bsr admin-scope. 1-3
1.1.5 c-bsr global 1-4
1.1.6 c-bsr group. 1-5
1.1.7 c-bsr hash-length. 1-6
1.1.8 c-bsr holdtime. 1-6
1.1.9 c-bsr interval 1-7
1.1.10 c-bsr priority. 1-8
1.1.11 c-rp. 1-9
1.1.12 c-rp advertisement-interval 1-10
1.1.13 c-rp holdtime. 1-11
1.1.14 crp-policy. 1-12
1.1.15 debugging pim.. 1-13
1.1.16 display pim bsr-info. 1-21
1.1.17 display pim claimed-route. 1-23
1.1.18 display pim control-message counters. 1-24
1.1.19 display pim grafts. 1-26
1.1.20 display pim interface. 1-27
1.1.21 display pim join-prune. 1-28
1.1.22 display pim neighbor 1-29
1.1.23 display pim routing-table. 1-30
1.1.24 display pim rp-info. 1-34
1.1.25 hello-option dr-priority. 1-35
1.1.26 hello-option holdtime. 1-36
1.1.27 hello-option lan-delay. 1-37
1.1.28 hello-option neighbor-tracking. 1-38
1.1.29 hello-option override-interval 1-38
1.1.30 holdtime join-prune. 1-39
1.1.31 jp-pkt-size. 1-40
1.1.32 jp-queue-size. 1-40
1.1.33 pim.. 1-41
1.1.34 pim bsr-boundary. 1-42
1.1.35 pim dm.. 1-43
1.1.36 pim hello-option dr-priority. 1-44
1.1.37 pim hello-option holdtime. 1-45
1.1.38 pim hello-option lan-delay. 1-45
1.1.39 pim hello-option neighbor-tracking. 1-46
1.1.40 pim hello-option override-interval 1-47
1.1.41 pim holdtime join-prune. 1-48
1.1.42 pim require-genid. 1-49
1.1.43 pim sm.. 1-50
1.1.44 pim state-refresh-capable. 1-51
1.1.45 pim timer graft-retry. 1-51
1.1.46 pim timer hello. 1-52
1.1.47 pim timer join-prune. 1-53
1.1.48 pim triggered-hello-delay. 1-54
1.1.49 probe-interval 1-54
1.1.50 register-whole-checksum.. 1-55
1.1.51 register-policy. 1-56
1.1.52 register-suppression-timeout 1-57
1.1.53 reset pim control-message counters. 1-58
1.1.54 source-lifetime. 1-58
1.1.55 source-policy. 1-59
1.1.56 spt-switch-threshold. 1-60
1.1.57 ssm-policy. 1-61
1.1.58 state-refresh-interval 1-62
1.1.59 state-refresh-rate-limit 1-63
1.1.60 state-refresh-ttl 1-63
1.1.61 static-rp. 1-64
1.1.62 timer hello. 1-65
1.1.63 timer join-prune. 1-66
auto-rp enable
undo auto-rp enable
View
PIM view
Default Level
2: System level
None
Use the auto-rp enable command to enable auto-RP.
Use the undo auto-rp enable command to disable auto-RP.
By default, auto-RP is disabled.
Related commands: static-rp.
# Enable auto-RP.
[Sysname] pim
[Sysname-pim] auto-rp enable
1.1.2  bsr-policy
bsr-policy acl-number
undo bsr-policy
View
PIM view
Default Level
2: System level
acl-number: Basic ACL number. When an ACL is defined, the source keyword in the rule command specifies a legal BSR source address range.
Use the bsr-policy command to configure a legal BSR address range to guard against BSR spoofing.
Use the undo bsr-policy command to remove the restriction of the BSR address range.
By default, there are no restrictions on the BSR address range, namely the BSR messages from any source are regarded to be valid.
# Configure a BSR filtering policy so that only the devices on the segment 10.1.1.0/24 can become the BSR.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.1.1.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] pim
[Sysname-pim] bsr-policy 2001
1.1.3  c-bsr
c-bsr interface-type interface-number [ hash-length [ priority ] ]
undo c-bsr
View
PIM view
Default Level
2: System level
interface-type interface-number: Specifies an interface by its type and number. This configuration can take effect only if PIM-SM is enabled on the interface.
hash-length: Hash mask length, 30 by default. If you do not include this keyword in your command, the corresponding global setting will be used.
priority: Priority of the C-BSR, 0 by default. If you do not include this keyword in your command, the corresponding global setting will be used. A larger value of this argument means a higher priority.
Use the c-bsr command to configure the specified interface as a C-BSR.
Use the undo c-bsr command to remove the related C-BSR configuration.
No C-BSR is configured by default.
Note that any interface serving as a C-BSR must be PIM-SM enabled.
Related commands: pim sm, c-bsr priority, c-rp.
# Configure VLAN-interface 4 to be a C-BSR.
[Sysname] pim
[Sysname-pim] c-bsr vlan-interface 4
c-bsr admin-scope
undo c-bsr admin-scope
View
PIM view
Default Level
2: System level
None
Use the c-bsr admin-scope command to enable administrative scoping.
Use the undo c-bsr admin-scope command to disable administrative scoping.
By default, administrative scoping is disabled, namely only one BSR can exist in each PIM-SM domain.
Related commands: c-bsr, c-bsr group, c-bsr global.
# Enable administrative scoping.
[Sysname] pim
[Sysname-pim] c-bsr admin-scope
1.1.5  c-bsr global
c-bsr global [ hash-length hash-length | priority priority ] *
undo c-bsr global
View
PIM view
Default Level
2: System level
hash-length: Hash mask length in the global scope zone. If you do not include this keyword in your command, the corresponding global setting will be used.
priority: Priority of the C-BSR in the global scope zone. If you do not include this keyword in your command, the corresponding global setting will be used.  A larger value of this argument means a higher priority.
Use the c-bsr global command to configure a C-BSR for the global scope zone.
Use the undo c-bsr global command to remove the C-BSR configuration for the global scope zone.
By default, no C-BSRs are configured for the global scope zone.
Related commands: c-bsr group, c-bsr hash-length, c-bsr priority.
# Configure the device to be a C-BSR for the global scope zone, with the priority of 1.
[Sysname] pim
[Sysname-pim] c-bsr global priority 1
1.1.6  c-bsr group
c-bsr group group-address { mask | mask-length } [ hash-length hash-length | priority priority ] *
undo c-bsr group group-address
View
PIM view
Default Level
2: System level
group-address: Multicast group address.
mask: Mask of the multicast group address.
mask-length: Mask length of the multicast group address.
hash-length: Hash mask length in the admin-scope region corresponding to the specified multicast group. If you do not include this keyword in your command, the corresponding global setting will be used.
priority: Priority of the C-BSR in the admin-scope region corresponding to a multicast group. If you do not include this keyword in your command, the corresponding global setting will be used.  A larger value of this argument means a higher priority.
Use the c-bsr group command to configure a C-BSR for the admin-scope region associated with the specified group.
Use the undo c-bsr group command to remove the C-BSR configuration for the admin-scope region associated with the specified group.
By default, no C-BSRs are configured for admin-scope regions.
Related commands: c-bsr global, c-bsr admin-scope, c-bsr hash-length, c-bsr priority.
# Configure the device to be a C-BSR in the admin-scope region associated with the multicast group address 239.0.0.0/8, with the priority of 10.
[Sysname] pim
[Sysname-pim] c-bsr group 239.0.0.0 255.0.0.0 priority 10
c-bsr hash-length hash-length
undo c-bsr hash-length
View
PIM view
Default Level
2: System level
hash-length: Hash mask length.
Use the c-bsr hash-length command to configure the global Hash mask length.
Use the undo c-bsr hash-length command to restore the system default.
By default, the Hash mask length is 30.
Related commands: c-bsr, c-bsr global, c-bsr group.
# Set the global Hash mask length to 16.
[Sysname] pim
[Sysname-pim] c-bsr hash-length 16
c-bsr holdtime interval
undo c-bsr holdtime
View
PIM view
Default Level
2: System level
interval: Bootstrap timeout in seconds.
Use the c-bsr holdtime command to configure the bootstrap timeout time, namely the length of time a C-BSR waits before it must receive a bootstrap message from the BSR.
Use the undo c-bsr holdtime command to restore the default setting.
By default, the bootstrap timeout value is determined by this formula: Bootstrap timeout = Bootstrap interval × 2 + 10.
&  Note:
The default bootstrap interval is 60 seconds, so the default bootstrap timeout = 60 × 2 + 10 = 130 (seconds).
Related commands: c-bsr and c-bsr interval.
# Set the bootstrap timeout time to 150 seconds.
[Sysname] pim
[Sysname-pim] c-bsr holdtime 150
c-bsr interval interval
undo c-bsr interval
View
PIM view
Default Level
2: System level
interval: Bootstrap interval in seconds.
Use the c-bsr interval command to configure the bootstrap interval, namely the interval at which the BSR sends bootstrap messages.
Use the undo c-bsr interval command to restore the default setting.
By default, the bootstrap interval value is determined by this formula: Bootstrap interval = (Bootstrap timeout – 10) / 2.
&  Note:
The default bootstrap timeout is 130 seconds, so the default bootstrap interval = (130 – 10) / 2 = 60 (seconds).
Related commands: c-bsr, c-bsr holdtime.
# Set the bootstrap interval to 30 seconds.
[Sysname] pim
[Sysname-pim] c-bsr interval 30
c-bsr priority priority
undo c-bsr priority
View
PIM view
Default Level
2: System level
priority: Priority of the C-BSR. A larger value of this argument means a higher priority.
Use the c-bsr priority command to configure the global C-BSR priority.
Use the undo c-bsr priority command to restore the default setting.
By default, the C-BSR priority is 0.
# Set the global C-BSR priority to 5.
[Sysname] pim
[Sysname-pim] c-bsr priority 5
1.1.11  c-rp
c-rp interface-type interface-number [ group-policy acl-number | priority priority | holdtime hold-interval | advertisement-interval adv-interval ] *
undo c-rp interface-type interface-number
View
PIM view
Default Level
2: System level
interface-type interface-number: Specifies an interface, the IP address of which will be advertised as a C-RP address.
acl-number: Basic ACL number. This ACL defines a range of multicast groups the C-RP is going to serve, rather than defining a filtering rule. Any group range matching the permit statement in the ACL will be advertised as an RP served group, while configurations matching other statements like deny will not take effect.
priority: Priority of the C-RP, defaulting to 0. A larger value of this argument means a lower priority.
hold-interval: C-RP timeout time, in seconds. The default value is 150 seconds. If you do not provide this argument in your command, the corresponding global setting will be used.
adv-interval: C-RP-Adv interval in seconds. The default value is 60 seconds. If you do not provide this argument in your command, the corresponding global setting will be used.
Use the c-rp command to configure the specified interface a C-RP.
Use the undo c-rp command to remove the related C-RP configuration.
No C-RPs are configured by default.
Note that:
l           Any interface serving as a C-RP must be PIM-SM enabled.
l           If you do not specify a group range for the C-RP, the C-RP will serve all multicast groups.
l           If you wish a device to be a C-RP for multiple group ranges, you need to include these multiple group ranges in multiple rules in the ACL corresponding to the group-policy keyword.
l           If you carry out this command repeatedly on the same interface, the last configuration will take effect.
Related commands: c-bsr.
# Configure VLAN-interface 100 to be a C-RP for multicast groups 225.1.0.0/16 and 226.2.0.0/16, with a priority of 10.
[Sysname] acl number 2069
[Sysname-acl-basic-2069] rule permit source 225.1.0.0 0.0.255.255
[Sysname-acl-basic-2069] rule permit source 226.2.0.0 0.0.255.255
[Sysname-acl-basic-2069] quit
[Sysname] pim
[Sysname-pim] c-rp vlan-interface 100 group-policy 2069 priority 10
c-rp advertisement-interval interval
undo c-rp advertisement-interval
View
PIM view
Default Level
2: System level
Use the c-rp advertisement-interval command to configure the interval at which C-RP-Adv messages are sent.
Use the undo c-rp advertisement-interval command to restore the default setting.
By default, the C-RP-Adv interval is 60 seconds.
Related commands: c-rp.
# Set the global C-RP-Adv interval to 30 seconds.
[Sysname] pim
[Sysname-pim] c-rp advertisement-interval 30
c-rp holdtime interval
undo c-rp holdtime
View
PIM view
Default Level
2: System level
interval: C-RP timeout in seconds.
Use the c-rp holdtime command to configure the global C-RP timeout time, namely the length of time the BSR waits before it must receive a C-RP-Adv message from C-RPs.
Use the undo c-rp holdtime command to restore the default setting.
By default, the C-RP timeout time is 150 seconds.
Because a non-BSR router refreshes its C-RP timeout time through BSR bootstrap messages, to prevent loss of C-RP information in BSR bootstrap messages, make sure that the C-RP timeout time is not smaller than the interval at which the BSR sends bootstrap messages. The recommended C-RP timeout setting is 2.5 times the bootstrap interval or longer.
Related commands: c-rp, c-bsr interval.
# Set the global C-RP timeout time to 200 seconds.
[Sysname] pim
[Sysname-pim] c-rp holdtime 200
1.1.14  crp-policy
crp-policy acl-number
undo crp-policy
View
PIM view
Default Level
2: System level
acl-number: Advanced ACL number. When the ACL is defined, the source keyword in the rule command specifies the address of a C-RP and the destination keyword specifies the address range of the multicast groups that the C-RP will serve.
Use the crp-policy command to configure a legal C-RP address range and the range of served multicast groups, so as to guard against C-RP spoofing.
Use the undo crp-policy command to remove the restrictions in C-RP address ranges and the ranges of served multicast groups.
By default, there are no restrictions on C-RP address ranges and the address ranges of served groups, namely all received C-RP messages are accepted.
# Configure a C-RP address range and a range of served multicast groups so that only routers in the address range of 1.1.1.1/32 can be C-RPs and these C-RPs can serve only multicast groups in the address range of 225.1.0.0/16.
[Sysname] acl number 3100
[Sysname-acl-adv-3100] rule permit ip source 1.1.1.1 0 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3100] quit
[Sysname] pim
[Sysname-pim] crp-policy 3100
debugging pim { all | event [ advanced-acl-number ] | routing-table [ advanced-acl-number ] | neighbor [ basic-acl-number ] [ receive | send ] | assert [ advanced-acl-number ] [ receive | send ] | rp [ receive | send  ] | join-prune [ advanced-acl-number ] [ receive | send ] | register [ advanced-acl-number ] | msdp [ advanced-acl-number ] | state-refresh [ advanced-acl-number ] [ receive | send ] }
undo debugging pim { all | event | routing-table | neighbor [ receive | send ] | assert [ receive | send ] | state-refresh [ receive | send ] | rp [ receive | send ] | join-prune [ receive | send ] | register | msdp }
View
Default Level
1: Monitor level
all: All types of PIM debugging.
event: PIM event debugging.
advanced-acl-number: Advanced ACL number.
routing-table: PIM Debugging for routing table state changes.
neighbor: PIM neighbor debugging.
basic-acl-number: Basic ACL number.
receive: PIM debugging for received messages.
send: PIM debugging for sent messages.
assert: PIM debugging for assert messages. Currently, S9500 series routing switches do not support this parameter.
rp: Specifies PIM RP debugging.
join-prune: Specifies PIM debugging for join-prune messages.
register: Specifies PIM debugging for register messages.
msdp: Specifies PIM-MSDP interaction debugging.
state-refresh: Specifies PIM state-refresh debugging.
Use the debugging pim command to enable PIM debugging.
Use the undo debugging pim command to disable PIM debugging.
By default, PIM debugging is disabled.
Table 1-1 debugging pim event command output description
unsupported PIM version
PIM version not supported
PIM packet too short
The PIM message length is too short
checksum error
Checksum error
non-pim interface
A PIM message is received on a non-PIM-enabled interface.
unsupported type
PIM messages of the specified type are not supported
Socket set option error
Failed to set socket option
Packet send error
Failed to send PIM message
Source address is one of the interfaces address
The source address is the address of the local interface
Source address address is invalid
The source address is invalid
Invalid source mask
Incorrect source address mask
Active event received
A source-active event was received.
Inactive event received
A source-inactive event was received.
Clear event received
A clear-entry event was received.
Wrong IIF
Incorrect incoming interface
NoInfo
The downstream state machine is in the Noinfo state.
PPending
The downstream state machine is in the Prune Pending state.
Pruned
The PIM-DM downstream state machine is in the Pruned state.
Joined
The PIM-SM downstream state machine is in the Joined state.
Forwarding
The PIM-DM upstream state machine is in the Forward state.
Pruned
The PIM-DM upstream state machine is in the Pruned state.
AckPending
The PIM-DM upstream state machine is in the Ack Pending state.
Joined
The PIM-SM (S, G) or (*, G) upstream state machine is in the Joined state.
NotJoined
The PIM-SM (S, G) or (*, G) upstream state machine is in the Not Joined state.
PruneTmp
The PIM-SM (S, G, RPT) downstream state machine is in the Prune Tmp state.
PPendingTmp
The PIM-SM (S, G, RPT) downstream state machine is in the Prune Pending Tmp state.
PPT Expired
The prune pending timer timed out.
RPF_Interface changed
The RPF interface changed.
Genid changed
The neighbor generation ID changed.
PT Expired
The prune timer timed out.
Failed to pass MSF
Failed to pass multicast source filtering
NotOriginator
The originator state machine is in the Not Originator state.
Originator
The originator state machine is in the Originator state.
SAT Expired
The source-alive timer timed out.
Join suppressed
The device received a join message to the upstream neighbor on the incoming interface and suppressed its own join message
Override it
The device received a prune message to the upstream neighbor on the incoming interface and sent a join message
ET Expired
The PIM-SM downstream interface aging timer timed out.
register downstream
Registering the outgoing interface
Mcast-Boundary-Changed
Multicast boundary change event
Table 1-2 debugging pim join-assert command output description
JP
Join/prune message
GFT
Graft message
GAK
Graft-ack message
receiving
Message received
sending
Message sent
unknown address
Unknown address, address decoding failed
bad group address, mask or family
Incorrect group address, mask or family
Bad source address, mask or family
Incorrect source address, mask or family
Upstream
Upstream neighbor information in the message
Groups
Number of groups in the message
Group: addr/mask ---  m joins n prunes
Group information in the message: group address/mask length --- m joins and n prunes
Join: addr/mask  flag
Join: source address/ mask flag
Message truncated. Ignoring message
The message was dropped due to invalid message length
Unable to decode address
Address decoding failed
Upstream neighbor is not this router. Ignoring
The message was dropped because the upstream neighbor is not this device.
group boundary detected for address1 on address2
address1 is within the multicast boundary configured on the interface corresponding to address2
Group address1 ignored in message on address2
address1 is within the multicast boundary configured on the interface corresponding to address2, and this group is ignored
Message from unknown neighbor
A message was received from an unknown neighbor.
Join/Prune received for non-local neighbor
A join/prune message for a non-local upstream neighbor was received
Override timer expires
The prune override timer timed out.
Table 1-3 debugging pim neighbor command output description
HEL
PIM hello message
hello packet
PIM hello message
receiving
Message received
sending
Message sent
on interfacename
Interface on which the message was received or sent
Option: m, length: n
PIM hello message option: option value, option length: length value
Holdtime:
Holdtime field of the PIM hello message
Tbit
Tbit option
Lan delay
LAN delay option
Override interval
Override interval option
DR priority
DR priority option
Genid
Generation ID option
Version
Version field of the state refresh option
Refresh interval
State refresh interval field
Reserved
Reserved field of the state refresh option
Secondary address(es)
Address in the address list option
Unknown option value
Unknown option
without SR capability
No state refresh capability
Elected as DR on interface interfacename
Elected as the DR for the network attached to interfacename
Unelected as DR on
No longer the DR for the network attached to interfacename
PIM Neighbor  address on interface
interfacename  timed out
Neighbor address on interfacename timed out
Table 1-4 debugging pim register command output description
REG
Register message
RSP
Register-stop message
Register Stop
Register stopped
receiving
Message received
sending
Message sent
Border bit
Boundary bit
Null bit
Null bit
src
Source address of the IP packet
dst
Destination address of the IP packet
Non-DR interface
Non-DR interface
probe
Probe message
ignored
Message dropped
Table 1-5 debugging pim routing-table command output description
Creating
Creating entries
Deleting
Deleting entries
mrt
Multicast routing table
Add oil
Adding outgoing interfaces
Del oil
Deleting outgoing interfaces
Null iif
Null incoming interface
Adding iif
Adding incoming interfaces
Deleting iif
Deleting incoming interfaces
RP is not found
RP is not found
Table 1-6 debugging pim rp command output description
receiving
Message received
sending
Message sent
auto-RP announce
auto-RP announce message
auto-RP discovery
auto-RP discovery message
C-RP
Candidate RP
CRP
Candidate RP
BSR
Bootstrap router
prefix count
Prefix count field in the C-RP advertisement message
priority
Priority field in the C-RP advertisement message
holdtime
Holdtime field in the C-RP advertisement message
Admin Scope Zone
admin-scope region
Bad BSR address
Incorrect BSR address
frag
Fragment tag field in the BSR bootstrap message
pri
Priority field in the BSR bootstrap message
hash mask len
Hash mask length field in the BSR bootstrap message
Group  address/length: frags  m, C-RP's n
The frags filed corresponding to address/length in the BSR bootstrap message is set to m. The number of C-RPs is n.
address pri: m, holdtime: n
The priority of C-RP address in the BSR bootstrap message is m and holdtime is n
Auto-RP discovery packet: RP agent
address,  RP count m, Holdtime n
An auto-RP discovery message was received: RP agent is address; RP count is m; and holdtime is n
delete RP-Set
Deleting an RP set
too short length
Message length is too short.
wrong RP agent address
Incorrect RP agent address
wrong RP address
Incorrect RP address
bad group address
bad group mask length
Incorrect group mask
bad BSR address
bad BSR address family
Incorrect BSR address family
bad BSR hash mask length
Incorrect BSR hash mask length
bad scope zone mask
Incorrect admin-scope mask
Unknown group address family
Incorrect group address family
not directly connected source
Address of a source not directly connected
unknown neighbor
Unknown neighbor
ACL
Access control list
Bad frag-rp-count field
Incorrect frag-rp-count field in the BSR bootstrap message
Bad frag-rp field length
Incorrect total length of frag-rp fields in the BSR bootstrap message
BSR mechanism
BSR mechanism independent of administrative scoping
Upstream to BSR
Upstream to the BSR
no BSR is available
No available BSR.
add register vif
Adding a register virtual interface
Remove register vif
Removing a register virtual interface
Expiring CRP
Aged C-RP
Lose the ASBSR election
Device lost the BSR election for the admin-scope region
Lose the BSR election
locally scoped
Node-local or link-local scope
RP changed
The RP changed.
pending state
The BSR changed to the pending state.
Update the BSR's state to elected
The BSR changed to the elected state.
RPF Failure
RPF check failed.
admin scope multicast address
Address in the admin-scope range
Table 1-7 debugging pim state refresh command output description
SRM
State refresh message
sending
Message sent
receiving
Message received
Message truncated
Message length is invalid
bad group address
Invalid group mask length
Incorrect group mask length
Group address
Group address
Source address
Source address
Originator address
Address of the state refresh message originator
preference
Preference field of the message
metric
Metric field of the message
mask length
Mask length field of the message
ttl
TTL value of the message
prune indicator
Prune indicator flag bit
prune now
Prune now indicator flag bit
assert override
Assert override flag bit
# Enable debugging for PIM events.
<Sysname> debugging pim event
*Mar 26 14:18:10:635 2007 Sysname PIM/7/EVENT: PIM-SM: Downstream (*, 229.0.0.1) on interface Vlan-interface10 (10.1.1.2) FSM transited from Joined to PPending. Prune Received (S151270)
// A prune message was received. The downstream state machine of the outgoing interface VLAN-interface 10 (10.1.1.2) of the PIM-SM entry (*, 229.0.0.1) transferred from Joined to Prune Pending.
*Mar 26 14:18:12:635 2007 Sysname PIM/7/EVENT: PIM-SM: Downstream (*, 229.0.0.1) on interface Vlan-interface10 (10.1.1.2) FSM transited from PPending to NoInfo. PPT Expired (S15760)
// Since the Prune Pending timer timed out, the downstream state machine of the outgoing interface VLAN-interface 10 (10.1.1.2) of the PIM-SM entry (*, 229.0.0.1) transferred from Prune Pending to NoInfo.
View
Default Level
1: Monitor level
None
Use the display pim bsr-info command to view the BSR information in the PIM-SM domain and the locally configured C-RP information in effect.
Related commands: c-bsr and c-rp.
# View the BSR information in the current PIM-SM domain and the locally configured C-RP information in effect.
<Sysname> display pim bsr-info
Elected BSR Address: 12.12.12.9
          Priority: 0
          Hash mask length: 30
          State: Accept Preferred
          Scope: Not scoped
          Uptime: 00:01:16
          Next BSR message scheduled at: 00:01:54
   Candidate BSR Address: 12.1.1.1
          Priority: 0
          State: Candidate
          Scope: Not scoped
Candidate RP: 12.12.12.9(LoopBack1)
     Priority: 0
     HoldTime: 150
     Advertisement Interval: 60
     Next advertisement scheduled at: 00:00:48
Table 1-8 display pim bsr-info command output description
Elected BSR Address
Address of the elected BSR
Address of a candidate BSR
Priority
BSR priority
Hash mask length
Hash mask length
BSR state
Scope
Scope of the BSR
Uptime
Length of time for which this BSR has been up
Length of time in which the BSR will expire
Candidate RP
Address of the C-RP
Priority
HoldTime
Timeout time of the C-RP
Interval at which the C-RP sends advertisement messages
Length of time in which the C-RP will send the next advertisement message
display pim claimed-route [ source-address ]
View
Default Level
1: Monitor level
source-address: Multicast source address persistent to which the unicast route information is to be displayed. If you do not provide this argument, this command will display the information about all unicast routes used by PIM.
Use the display pim claimed-route command to view the information of unicast routes used by PIM.
If an (S, G) is marked SPT, this (S, G) entry uses a unicast route.
# View the information of all unicast routes used by PIM.
<Sysname> display pim claimed-route
RPF information about: 172.168.0.0
     RPF interface: Vlan-interface22, RPF neighbor: 172.168.0.2
     Referenced route/mask: 172.168.0.0/24
     Referenced route type: unicast (direct)
     RPF-route selecting rule: preference-preferred
     The (S,G) or (*,G) list dependent on this route entry
     (172.168.0.12, 227.0.0.1)
Table 1-9 display pim claimed-route command output description
RPF interface:
RPF interface type and number
RPF neighbor:
IP address of the RPF neighbor
Address/mask of the referenced route
Type of the referenced route
Rule of RPF route selection
(S, G) or (*, G) entries based on this RPF route
display pim control-message counters [ message-type { probe | register | register-stop } | [ interface interface-type interface-number | message-type { assert | bsr | crp | graft | graft-ack | hello | join-prune | state-refresh } ] * ]
View
Default Level
1: Monitor level
probe: Displays the number of null register messages.
register: Displays the number of register messages.
register-stop: Displays the number of register-stop messages.
interface interface-type interface-number: Displays the number of PIM control messages on the specified interface.
assert: Assert message. Currently, S9500 series routing switches do not support this parameter.
bsr: Bootstrap message.
crp: C-RP-Adv message.
graft: Graft message.
graft-ack: Graft-ack message
hello: Hello message
join-prune: Join/prune message
state-refresh: State refresh message.
Use the display pim control-message counters command to view the statistics information of PIM control messages.
&  Note:
Register messages, register-stop messages, and probe messages are for global statistics, so you cannot view the statistics of these messages on the specified interface.
# View the statistics information of all types of PIM control messages on all interfaces.
<Sysname> display pim control-message counters
PIM global control-message counters:
Received     Sent            Invalid
Register         20          37          2
Register-Stop        25          20          1
Probe                10          5           0
PIM control-message counters for interface: Pos4/1/1
Assert           0           0           0
Graft                20          37          2
Graft-Ack            25          20          1
Hello                1232            453         0
Join/Prune       15          30          21
State-Refresh        8           7           1
BSR              3243            589         1
CRP              53          32          0
Table 1-10 Description on the fields of display pim control-message counters
Received
Number of messages received
Sent
Number of messages sent
Invalid
Number of invalid messages
Register
Register messages
Register-Stop
Register-stop messages
Probe
Null register messages
Assert
Assert messages
Graft
Graft messages
Graft-Ack
Graft-ack messages
Hello
Hello messages
Join/Prune
Join/prune messages
State Refresh
State refresh messages
BSR
Bootstrap messages
CRP
C-RP-Adv messages
display pim grafts
View
Default Level
1: Monitor level
None
Use the display pim grafts command to view the information about unacknowledged graft messages.
# View the information about unacknowledged graft messages.
<Sysname> display pim grafts
Source                Group               Age              RetransmitIn
192.168.10.1          224.1.1.1           00:00:24         00:00:02
Table 1-11 display pim grafts command output description
Source
Multicast source address in the graft message
Group
Multicast group address in the graft message
Age
Time in which the graft message will get aged out, in hours:minutes:seconds
RetransmitIn
Time in which the graft message will be retransmitted, in hours:minutes:seconds
display pim interface [ interface-type interface-number ] [ verbose ]
View
Default Level
1: Monitor level
interface-type interface-number: Displays the PIM information on a particular interface.
verbose: Displays the detailed PIM information.
Use the display pim interface command to view the PIM information on the specified interface or all interfaces.
# View the PIM information on all interfaces.
<Sysname> display pim interface
 Interface           NbrCnt HelloInt   DR-Pri     DR-Address
 Vlan10              0      30         1          10.1.1.1
 Vlan12              1      30         1          12.1.1.2
Table 1-12 display pim interface command output description
Interface name
NbrCnt
Number of PIM neighbors
HelloInt
Hello interval
DR-Pri
Priority for DR election
DR-Address
DR IP address
display pim join-prune mode { sm [ flags flag-value ] | ssm } [ interface interface-type interface-number | neighbor neighbor-address ] * [ verbose ]
View
Default Level
1: Monitor level
mode: Displays the information of joint/prune messages to send in the specified PIM mode. PIM modes include sm and ssm, which represent PIM-SM and PIM-SSM respectively.
flags flag-value: Displays PIM routing entries containing the specified flag. Values and meanings of flag-value are as follows:
l           rpt: Specifies routing entries on the RPT.
l           spt: Specifies routing entries on the SPT.
l           wc: Specifies wildcard routing entries.
interface-type interface-number: Displays the information of joint/prune messages to send on the specified interface.
neighbor-address: Displays the information of joint/prune messages to send to the specified PIM neighbor.
verbose: Displays the detailed information of joint/prune messages to send.
Use the display pim join-prune command to view the information about the join/prune messages to send.
# View the information of joint/prune messages to send in the PIM-SM mode.
<Sysname> display pim join-prune mode sm
 Expiry Time: 14 sec
 Upstream nbr: 12.1.1.1 (Vlan-interface12)
 0 (*, G) join(s), 1 (S, G) join(s), 0 (S, G, rpt) prune(s)
 Expiry Time: 46 sec
 1 (*, G) join(s), 0 (S, G) join(s), 0 (S, G, rpt) prune(s)
 Total (*, G) join(s): 1, (S, G) join(s): 1, (S, G, rpt) prune(s): 0
Table 1-13 display pim join-prune command output description
Expiry Time:
Expiry time of sending join/prune messages
Upstream nbr:
IP address of the upstream PIM neighbor and the interface connecting to it
(*, G) join(s)
Number of (*,  G) joins to send
(S, G) join(s)
Number of (S,  G) joins to send
Number of (S,  G, rpt) prunes
display pim neighbor [ interface interface-type interface-number | neighbor-address | verbose ] *
View
Default Level
1: Monitor level
interface-type interface-number: Displays the PIM neighbor information on a particular interface.
neighbor-address: Displays the information of a particular PIM neighbor.
verbose: Displays the detailed PIM neighbor information.
Use the display pim neighbor command to view the PIM neighbor information.
# View the information of all PIM neighbors.
<Sysname> display pim neighbor
 Total Number of Neighbors = 1
 Neighbor        Interface           Uptime   Expires  Dr-Priority
 12.1.1.1        Vlan12              00:07:28 00:01:33 1
Table 1-14 display pim neighbor command output description
Total number of PIM neighbors
Neighbor
Ip address of the PIM neighbor
Interface connecting the PIM neighbor
Uptime
Length of time for which the PIM neighbor has been up, in hours:minutes:seconds
Expires
Length of time in which the PIM neighbor will expire, in hours:minutes:seconds
Dr-Priority
Designated router priority
display pim routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | incoming-interface [ interface-type interface-number | register ] | outgoing-interface { include | exclude | match } { interface-type interface-number | register } | mode mode-type | flags flag-value | fsm ] *
View
Default Level
1: Monitor level
mask: Mask of the multicast group/source address, 255.255.255.255 by default.
mask-length: Mask length of the multicast group/source address, 32 by default.
source-address: Multicast source address.
incoming-interface: Displays routing entries that contain the specified interface as the incoming interface
register: Specifies the register interface. This keyword is valid only if mode-type is not specified or is sm.
outgoing-interface: Displays routing entries of which the outgoing interface is the specified interface.
include: Displays routing entries of which the outgoing interface list includes the specified interface.
exclude: Displays routing entries of which the outgoing interface list does not includes the specified interface.
match: Displays routing entries of which the outgoing interface list includes only the specified interface.
mode mode-type: Specifies a PIM mode, where mode-type can have the following values:
l           dm: Specifies PIM-DM
l           sm: Specifies PIM-SM
l           ssm: Specifies PIM-SSM
flags flag-value: Displays routing entries containing the specified flag(s). The values of flag-value and their meanings are as follows:
l           2msdp: Specifies routing entries to be contained in the next SA message to notify an MSDP peer.
l           act: Specifies multicast routing entries to which actual data has arrived
l           del: Specifies multicast routing entries scheduled to be deleted
l           ext: Specifies routing entries containing outgoing interfaces contributed by other multicast routing protocols
l           loc: Specifies multicast routing entries on devices directly connecting to the same subnet with the multicast source
l           msdp: Specifies to routing entries learned from MSDP SA messages
l           niif: Specifies multicast routing entries containing unknown incoming interfaces
l           nonbr: Specifies routing entries with PIM neighbor searching failure
l           rpt: Specifies routing entries on RPT branches where (S, G) prunes have been sent to the RP.
l           swt: Specifies routing entries in the process of RPT-to-SPT switchover.
fsm: Displays the detailed information of the finite state machine (FSM).
Use the display pim routing-table command to view PIM routing table information.
Related commands: display multicast routing-table (Multicast Routing and Forwarding Commands in the IP Multicast Volume).
# View the content of the PIM routing table.
<Sysname> display pim routing-table
Total 4 (*, G) entries; 1 (S, G) entry
(*, 225.1.1.1)
     RP: 12.1.1.2 (local)
     Protocol: pim-sm, Flag: WC
     UpTime: 00:16:19
     Upstream interface: Register
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: LoopBack0
             Protocol: static, UpTime: 00:16:19, Expires: -
 (10.1.1.3, 225.1.1.1)
     Protocol: pim-sm, Flag: SPT 2MSDP ACT
     UpTime: 00:07:16
     Upstream interface: Vlan-interface12
         Upstream neighbor: 12.1.1.1
         RPF prime neighbor: 12.1.1.1
         1: LoopBack0
             Protocol: pim-sm, UpTime:  - , Expires:  -
 (*, 239.192.0.1)
     UpTime: 00:06:53
         1: Vlan-interface245
             Protocol: igmp, UpTime: 00:06:52, Expires: -
(*, 239.192.245.1)
     RP: 12.1.1.1
     UpTime: 00:06:45
             Protocol: igmp, UpTime: 00:06:45, Expires: -
 (*, 239.255.255.250)
     UpTime: 00:06:53
             Protocol: igmp, UpTime: 00:06:53, Expires: -
Table 1-15 display pim routing-table command output description
Total 4 (*, G) entry; 1 (S, G) entry
Number of (S, G) and (*, G) entries in the PIM routing table
An (S, G) entry in the PIM routing table
(*, 239.192.0.1)
A (*, G) entry in the PIM routing table
Protocol
PIM mode, PIM-SM or PIM-DM
Flag
Flag of an (S, G) or (*, G) entry in the PIM routing table, WC: Indicates a (*, G) entry
For more information, see the description of the flags flag-value parameter
Uptime
Length of time for which the (S, G) or (*, G) entry has existed, in hours:minutes:seconds
Upstream interface
Upstream (incoming) interface of the (S, G) or (*, G) entry
Upstream neighbor
Upstream neighbor of the (S, G) or (*, G) entry
RPF prime neighbor
RPF neighbor of the (S, G) or (*, G) entry
l      For a (*, G) entry, if this device is the RP, the RPF neighbor of this (*, G) entry is NULL
l      For a (S, G) entry, if this device directly connects to the multicast source, the RPF neighbor of this (S, G) entry is NULL
Information of the downstream interface(s), including:
l      Number of downstream interfaces
l      Downstream interface name
l      Type of the multicast protocol enabled on the downstream interface(s)
l      Uptime of the downstream interface(s)
l      Expiry time of the downstream interface(s)
display pim rp-info [ group-address ]
View
Default Level
1: Monitor level
group-address: Address of the multicast group of which the RP information is to be displayed. If you do not provide a group address, this command will display the RP information corresponding to all multicast groups.
Use the display pim rp-info command to view the RP information.
Note that:
l           The RP information includes the information of RPs dynamically found by the BSR mechanism and static RPs.
l           Because a non-BSR router refreshes its local RP-Set only based on the received BSR bootstrap messages, the system does not delete an RP even if its expiry time is 0. Instead, the system waits for the next bootstrap message from the BSR: if the bootstrap message does not contain information of the RP, the system will delete it.
# View the RP information corresponding to the multicast group 224.0.1.1.
<Sysname> display pim rp-info 224.0.1.1
BSR RP Address is: 2.2.2.2
     Priority: 0
     HoldTime: 150
     Uptime: 03:01:10
     Expires: 00:02:30
 RP mapping for this group is: 2.2.2.2
# View the RP information corresponding to all multicast groups.
PIM-SM BSR RP information:
 Group/MaskLen: 224.0.0.0/4
     RP: 2.2.2.2
     Priority: 0
     HoldTime: 150
     Uptime: 03:01:36
     Expires: 00:02:29
Table 1-16 display pim rp-info command output description
BSR RP Address is
Group/MaskLen
The multicast group served by the RP
RP
Priority
RP priority
HoldTime
RP timeout time
Uptime
Length of time for which the RP has been up, in hours:minutes:seconds
Expires
Length of time in which the RP will expire, in hours:minutes:seconds
The IP address of the RP serving the current multicast group
undo hello-option dr-priority
View
PIM view
Default Level
2: System level
priority: Router priority for DR election. A larger value of this argument means a higher priority.
Use the hello-option dr-priority command to configure the global value of the router priority for DR election.
Use the undo hello-option dr-priority command to restore the default setting.
By default, the router priority for DR election is 1.
Related commands: pim hello-option dr-priority.
# Set the router priority for DR election to 3.
[Sysname] pim
[Sysname-pim] hello-option dr-priority 3
hello-option holdtime interval
undo hello-option holdtime
View
PIM view
Default Level
2: System level
interval: PIM neighbor timeout time in seconds.
Use the hello-option holdtime command to configure the PIM neighbor timeout time.
Use the undo hello-option holdtime command to restore the default setting.
By default, the PIM neighbor timeout time is 105 seconds.
This command is effective for both PIM-DM and PIM-SM.
Related commands: pim hello-option holdtime.
# Set the global value of the PIM neighbor timeout time to 120 seconds.
[Sysname] pim
[Sysname-pim] hello-option holdtime 120
hello-option lan-delay interval
undo hello-option lan-delay
View
PIM view
Default Level
2: System level
interval: Prune delay in milliseconds.
Use the hello-option lan-delay command to configure the global value of prune delay time.
Use the undo hello-option lan-delay command to restore the default setting.
By default, the prune delay to 500 milliseconds.
Related commands: hello-option override-interval, pim hello-option override-interval, pim hello-option lan-delay.
# Set the prune delay to 200 milliseconds globally.
[Sysname] pim
[Sysname-pim] hello-option lan-delay 200
undo hello-option neighbor-tracking
View
PIM view
Default Level
2: System level
None
Use the hello-option neighbor-tracking command to globally disable join suppression, namely enable neighbor tracking.
Use the undo hello-option neighbor-tracking command to enable join suppression.
By default, join suppression is enabled, namely neighbor tracking is disabled.
Related commands: pim hello-option neighbor-tracking.
# Disable join suppression globally.
[Sysname] pim
[Sysname-pim] hello-option neighbor-tracking
undo hello-option override-interval
View
PIM view
Default Level
2: System level
interval: Prune override interval in milliseconds.
Use the hello-option override-interval command to configure the global value of the prune override interval.
Use the undo hello-option override-interval command to restore the default setting.
By default, the prune override interval is 2,500 milliseconds.
Related commands: hello-option lan-delay, pim hello-option lan-delay, pim hello-option override-interval.
# Set the prune override interval to 2,000 milliseconds globally.
[Sysname] pim
[Sysname-pim] hello-option override-interval 2000
holdtime join-prune interval
undo holdtime join-prune
View
PIM view
Default Level
2: System level
interval: Join/prune timeout time in seconds.
Use the holdtime join-prune command to configure the global value of the join/prune timeout time.
Use the undo holdtime join-prune command to restore the default setting.
By default, the join/prune timeout time is 210 seconds.
Related commands: pim holdtime join-prune.
# Set the global value of the join/prune timeout time to 280 seconds.
[Sysname] pim
[Sysname-pim] holdtime join-prune 280
1.1.31  jp-pkt-size
jp-pkt-size packet-size
undo jp-pkt-size
View
PIM view
Default Level
2: System level
packet-size: Maximum size of join/prune messages in bytes.
Use the jp-pkt-size command to configure the maximum size of join/prune messages.
Use the undo jp-pkt-size command to restore the default setting.
By default, the maximum size of join/prune messages is 8,100 bytes.
Related commands: jp-queue-size.
# Set the maximum size of join/prune messages to 1,500 bytes.
[Sysname] pim
[Sysname-pim] jp-pkt-size 1500
jp-queue-size queue-size
undo jp-queue-size
View
PIM view
Default Level
2: System level
queue-size: Maximum number of (S, G) entries in a join/prune message.
Use the jp-queue-size command to configure the maximum number of (S, G) entries in a join/prune message.
Use the undo jp-queue-size command to restore the default setting.
By default, a join/prune messages contains a maximum of 1,020 (S, G) entries.
When you use this command, you need to take into account the (S, G) join/prune timeout time on the upstream device. If you configure a small queue size, the outgoing interface of the corresponding entry may have been pruned due to timeout before the last join/prune message in a queue reaches the upstream device.
Related commands: jp-pkt-size, holdtime join-prune, pim holdtime join-prune.
# Configure a join/prune messages to contain a maximum of 2,000 (S, G) entries.
[Sysname] pim
[Sysname-pim] jp-queue-size 2000
1.1.33  pim
pim
undo pim
View
Default Level
2: System level
None
Use the pim command to enter PIM view.
Use the undo pim command to remove all configurations performed in PIM view and return to system view.
IP multicast must be enabled on the device before this command can take effect.
Related commands: multicast routing-enable in Multicast Routing and Forwarding Commands of the IP Multicast Volume.
# Enable IP multicast routing and enter PIM view.
[Sysname] multicast routing-enable
[Sysname] pim
[Sysname-pim]
pim bsr-boundary
undo pim bsr-boundary
View
VLAN interface view, POS interface view
Default Level
2: System level
None
Use the pim bsr-boundary command to configure a PIM-SM domain border, namely a PIM bootstrap message boundary..
Use the undo pim bsr-boundary command to remove the configured PIM-SM domain border.
By default, no PIM-SM domain border is configured.
Related commands: c-bsr, and multicast boundary in Multicast Routing and Forwarding Commands of the IP Multicast Volume.
# Configure VLAN-interface 100 as a PIM-SM domain border.
[Sysname-Vlan-interface100] pim bsr-boundary
1.1.35  pim dm
pim dm
undo pim dm
View
Default Level
2: System level
None
Use the pim dm command to enable PIM-DM.
Use the undo pim dm command to disable PIM-DM.
By default, PIM-DM is disabled.
  Caution:
l      After PIM-DM is enabled on a VLAN interface, IGMP snooping cannot be enabled in the VLAN corresponding to the VLAN interface, and vice versa.
l      Multicast groups within the SSM group address range cannot be used for PIM-DM.
l      This command can take effect only after IP multicast routing is enabled.
Related commands: pim sm, ssm-policy.
# Enable PIM-DM on VLAN-interface 4.
[Sysname] interface vlan-interface 4
[Sysname-Vlan-interface4] pim dm
pim hello-option dr-priority priority
undo pim hello-option dr-priority
View
Default Level
2: System level
Use the pim hello-option dr-priority command to configure the router priority for DR election on the current interface.
Use the undo pim hello-option dr-priority command to restore the default setting.
This command is the same as the hello-option dr-priority command for PIM view, with the exception of the view in which it is carried out. Configurations performed in PIM view are effective to all interfaces, while configurations performed in interface view are effective to the current interface only. The system gives priority to configurations made in interface view. Configurations made in PIM view are used only if the corresponding configurations have not been carried out in interface view.
Related commands: hello-option dr-priority.
# Set the router priority for DR election to 3 on VLAN-interface 4.
[Sysname-Vlan-interface4] pim hello-option dr-priority 3
pim hello-option holdtime interval
undo pim hello-option holdtime
View
Default Level
2: System level
Use the pim hello-option holdtime command to configure the PIM neighbor timeout time on the current interface.
Use the undo pim hello-option holdtime command to restore the default setting.
This command is the same as the hello-option holdtime command for PIM view, with the exception of the view in which it is carried out. Configurations performed in PIM view are effective to all interfaces, while configurations performed in interface view are effective to the current interface only. The system gives priority to configurations made in interface view. Configurations made in PIM view are used only if the corresponding configurations have not been carried out in interface view.
Related commands: hello-option holdtime.
# Set the PIM neighbor timeout time to 120 seconds on VLAN-interface 4.
[Sysname-Vlan-interface4] pim hello-option holdtime 120
pim hello-option lan-delay interval
undo pim hello-option lan-delay
View
Default Level
2: System level
Use the pim hello-option lan-delay command to configure the prune delay time on the current interface.
Use the undo pim hello-option lan-delay command to restore the default setting.
This command is the same as the hello-option lan-delay command for PIM view, with the exception of the view in which it is carried out. Configurations performed in PIM view are effective to all interfaces, while configurations performed in interface view are effective to the current interface only. The system gives priority to configurations made in interface view. Configurations made in PIM view are used only if the corresponding configurations have not been carried out in interface view.
Related commands: pim hello-option override-interval, hello-option override-interval, hello-option lan-delay.
# Set the prune delay time to 200 milliseconds on VLAN-interface 4.
[Sysname-Vlan-interface4] pim hello-option lan-delay 200
undo pim hello-option neighbor-tracking
View
Default Level
2: System level
None
Use the pim hello-option neighbor-tracking command to disable join suppression, namely enable neighbor tracking, on the current interface.
Use the undo pim hello-option neighbor-tracking command to enable join suppression.
This command is the same as the hello-option neighbor-tracking command for PIM view, with the exception of the view in which it is carried out. Configurations performed in PIM view are effective to all interfaces, while configurations performed in interface view are effective to the current interface only. The system gives priority to configurations made in interface view. Configurations made in PIM view are used only if the corresponding configurations have not been carried out in interface view.
Related commands: hello-option neighbor-tracking.
# Disable join suppression on VLAN-interface 4.
[Sysname-Vlan-interface4] pim hello-option neighbor-tracking
pim hello-option override-interval interval
undo pim hello-option override-interval
View
Default Level
2: System level
Use the pim hello-option override-interval command to configure the prune override interval on the current interface.
Use the undo pim hello-option override-interval command to restore the default setting.
This command is the same as the hello-option override-interval command for PIM view, with the exception of the view in which it is carried out. Configurations performed in PIM view are effective to all interfaces, while configurations performed in interface view are effective to the current interface only. The system gives priority to configurations made in interface view. Configurations made in PIM view are used only if the corresponding configurations have not been carried out in interface view.
Related commands: pim hello-option lan-delay, hello-option lan-delay, hello-option override-interval.
# Set the  prune override interval to 2,000 milliseconds on VLAN-interface 4.
[Sysname-Vlan-interface4] pim hello-option override-interval 2000
pim holdtime join-prune interval
undo pim holdtime join-prune
View
Default Level
2: System level
interval: Join/prune timeout time in seconds, with an effective range of 1 to 65,535.
Use the pim holdtime join-prune command to configure the join/prune timeout time on the interface.
Use the undo pim holdtime join-prune command to restore the default setting.
This command is the same as the holdtime join-prune command for PIM view, with the exception of the view in which it is carried out. Configurations performed in PIM view are effective to all interfaces, while configurations performed in interface view are effective to the current interface only. The system gives priority to configurations made in interface view. Configurations made in PIM view are used only if the corresponding configurations have not been carried out in interface view.
Related commands: holdtime join-prune.
# Set the join/prune timeout time to 280 seconds on VLAN-interface 4.
[Sysname-Vlan-interface4] pim holdtime join-prune 280
pim require-genid
undo pim require-genid
View
Default Level
2: System level
None
Use the pim require-genid command enable rejection of hello messages without Generation_ID.
Use the undo pim require-genid command to restore the default configuration.
By default, hello messages without Generation_ID are accepted.
# Enable VLAN-interface 4 to reject hello messages without Generation_ID.
[Sysname-Vlan-interface4] pim require-genid
1.1.43  pim sm
pim sm
undo pim sm
View
Default Level
2: System level
None
Use the pim sm command to enable PIM-SM.
Use the undo pim sm command to disable PIM-SM.
By default, PIM-SM is disabled.
  Caution:
l      After PIM-SM is enabled on a VLAN interface, IGMP snooping cannot be enabled in the VLAN corresponding to the VLAN interface, and vice versa.
Related commands: pim dm, ssm-policy.
# Enable PIM-SM on VLAN-interface 4.
[Sysname-Vlan-interface4] pim sm
undo pim state-refresh-capable
View
Default Level
2: System level
None
Use the pim state-refresh-capable command to enable the state fresh feature on the interface.
Use the undo pim state-refresh-capable command to disable the state fresh feature.
By default, the state refresh feature is enabled.
Related commands: state-refresh-interval, state-refresh-rate-limit, state-refresh-ttl.
# Disable state refresh on VLAN-interface 4.
[Sysname-Vlan-interface4] undo pim state-refresh-capable
pim timer graft-retry interval
undo pim timer graft-retry
View
Default Level
2: System level
interval: Graft retry period in seconds.
Use the pim timer graft-retry command to configure the graft retry period.
Use the undo pim timer graft-retry command to restore the default setting.
By default, the graft retry period is 3 seconds.
# Set the graft retry period to 80 seconds on VLAN-interface 4.
[Sysname-Vlan-interface4] pim timer graft-retry 80
pim timer hello interval
undo pim timer hello
View
Default Level
2: System level
interval: Hello interval in seconds.
Use the pim timer hello command to configure on the current interface the interval at which hello messages are sent.
Use the undo pim timer hello command to restore the default setting.
By default, hello messages are sent at the interval of 30 seconds.
This command is the same as the timer hello command for PIM view, with the exception of the view in which it is carried out. Configurations performed in PIM view are effective to all interfaces, while configurations performed in interface view are effective to the current interface only. The system gives priority to configurations made in interface view. Configurations made in PIM view are used only if the corresponding configurations have not been carried out in interface view.
Related commands: timer hello.
# Set the hello interval to 40 seconds on VLAN-interface 4.
[Sysname-Vlan-interface4] pim timer hello 40
pim timer join-prune interval
undo pim timer join-prune
View
Default Level
2: System level
interval: Join/prune interval in seconds.
Use the pim timer join-prune command to configure on the current interface the interval at which join/prune messages are sent.
Use the undo pim timer join-prune command to restore the default setting.
By default, the join/prune interval is 60 seconds.
This command is the same as the timer join-prune command for PIM view, with the exception of the view in which it is carried out. Configurations performed in PIM view are effective to all interfaces, while configurations performed in interface view are effective to the current interface only. The system gives priority to configurations made in interface view. Configurations made in PIM view are used only if the corresponding configurations have not been carried out in interface view.
Related commands: timer join-prune.
# Set the join/prune interval to 80 seconds on VLAN-interface 4.
[Sysname-Vlan-interface4] pim timer join-prune 80
pim triggered-hello-delay interval
undo pim trigged-hello-delay
View
Default Level
2: System level
interval: Maximum delay in seconds between hello messages.
Use the pim triggered-hello-delay command to configure the maximum delay between hello messages.
Use the undo pim triggered-hello-delay command to restore the default setting.
By default, the maximum delay between hello messages is 5 seconds.
# Set the maximum delay between hello messages to 3 seconds on VLAN-interface 4.
[Sysname-Vlan-interface4] pim trigged-hello-delay 3
probe-interval interval
undo probe-interval
View
PIM view
Default Level
2: System level
interval: Probe time in seconds.
Use the probe-interval command to configure the probe time, namely the interval at which the source-side DR sends null register messages before the register suppression timer expires.
Use the undo probe-interval command to restore the default setting.
By default, the probe time is 5 seconds.
Related commands: register-suppression-timeout.
# Set the probe time to 6 seconds.
[Sysname] pim
[Sysname-pim] probe-interval 6
undo register-whole-checksum
View
PIM view
Default Level
2: System level
None
Use the register-whole-checksum command to configure the router to calculate the checksum based on the entire register messages.
Use the undo register-whole-checksum command to restore the default configuration.
By default, the checksum is calculated based on the header in the register message.
Related commands: register-policy, register-suppression-timeout.
# Configure the router to calculate the checksum based on the entire register messages.
[Sysname] pim
[Sysname-pim] register-whole-checksum
register-policy acl-number
undo register-policy
View
PIM view
Default Level
2: System level
acl-number: Advanced ACL number. Only register messages that match the permit statement of the ACL can be accepted by the RP.
Use the register-policy command to configure an ACL rule to filter register messages.
Use the undo register-policy command to remove the configured register filtering rule.
By default, no register filtering rule is configured.
  Caution:
If you specify an undefined advanced ACL, the RP will reject all register messages.
# Configure the RP to accept only those register messages for multicast traffic from multicast sources in the range of 10.10.0.0/16 to multicast groups in the range of 225.1.0.0/16.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3000] quit
[Sysname] pim
[Sysname-pim] register-policy 3000
1.1.52  register-suppression-timeout
undo register-suppression-timeout
View
PIM view
Default Level
2: System level
interval: Register suppression time in seconds.
Use the register-suppression-timeout command to configure the register suppression time.
Use the undo register-suppression-timeout command to restore the default setting.
By default, the register suppression time is 60 seconds.
Related commands: probe-interval, register-policy.
# Set the register suppression time to 70 seconds.
[Sysname] pim
[Sysname-pim] register-suppression-timeout 70
1.1.53  reset pim control-message counters
reset pim control-message counters [ interface interface-type interface-number ]
View
Default Level
1: Monitor level
interface interface-type interface-number: Specifies an interface on which the PIM control message counter is to be reset. If no interface is specified, this command will clear the statistics information of PIM control messages on all interfaces.
Use the reset pim control-message counters command to reset PIM control message counters.
# Reset PIM control message counters on all interfaces.
<Sysname> reset pim control-message counters
1.1.54  source-lifetime
source-lifetime interval
undo source-lifetime
View
PIM view
Default Level
2: System level
interval: Multicast source lifetime in seconds.
Use the source-lifetime command to configure the multicast source lifetime.
Use the undo source-lifetime command to restore the default setting.
By default, the lifetime of a multicast source is 210 seconds.
# Set the multicast source lifetime to 200 seconds.
[Sysname] pim
[Sysname-pim] source-lifetime 200
1.1.55  source-policy
source-policy acl-number
undo source-policy
View
PIM view
Default Level
2: System level
acl-number: Basic or advanced ACL number.
Use the source-policy command to configure a multicast data filter.
Use the undo source-policy command to remove the configured multicast data filter.
By default, no multicast data filter is configured.
Note that:
l           If you specify a basic ACL, the device filters all the received multicast packets based on the source address, and discards packets that fail the source address match.
l           If you specify an advanced ACL, the device filters all the received multicast packets based on the source and group addresses, and discards packets that fail the match.
l           If this command is executed repeatedly, the last configuration will take effect.
# Configure the router to accept multicast packets originated from 10.10.1.2 and discard multicast packets originated from 10.10.1.1.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.1.2 0
[Sysname-acl-basic-2001] rule deny source 10.10.1.1 0
[Sysname-acl-basic-2001] quit
[Sysname] pim
[Sysname-pim] source-policy 2001
1.1.56  spt-switch-threshold
spt-switch-threshold infinity [ group-policy acl-number [ order order-value ] ]
undo spt-switch-threshold [ group-policy acl-number ]
View
PIM view
Default Level
2: System level
group-policy acl-number: Disables RPT-to-SPT switchover for multicast groups that match the specified multicast policy. In this option, acl-number refers to a basic ACL number, in the range of 2000 to 2999. If you do not include this option in your command, this command will take effect for all multicast groups.
order order-value: Specifies the order of the ACL in the group-policy list, where order-value has an effective range of 1 to (the largest order value in the existing group-policy list + 1), but the value range should not include the original order value of the ACL in the group-policy list. If you have assigned an order-value to a certain ACL, do not specify the same order-value for another ACL; otherwise the system will give error information. If you do not specify an order-value, the order value of the ACL will remain the same in the group-policy list.
Use the spt-switch-threshold infinity command to disable RPT-to-SPT switchover.
Use the undo spt-switch-threshold command to restore the default configuration.
By default, the S9500 series routing switch switches to the SPT immediately after it receives the first multicast packet from the RPT.
Note that:
l           To adjust the order of an existing ACL in the group-policy list, you can use the acl-number argument to specify this ACL and set its order-value. This will insert the ACL to the position of order-value in the group-policy list. The order of the other existing ACLs in the group-policy list will remain unchanged.
l           To use an ACL that does not exist in the group-policy list, you can use the acl-number argument to specify an ACL and set its order-value. This will insert the ACL to the position of order-value in the group-policy list. If you do not include the order order-value option in your command, the ACL will be appended to the end of the group-policy list.
l           If you use this command multiple times on the same multicast group, the first traffic rate configuration matched in sequence will take effect.
l           To avoid forwarding failure, do not disable RPT-to-SPT switchover on a switch that may become an RP (namely, a static RP or a C-RP).
# Disable RPT-to-SPT switchover on a switch.
[Sysname] pim
[Sysname-pim] spt-switch-threshold infinity
1.1.57  ssm-policy
ssm-policy acl-number
undo ssm-policy
View
PIM view
Default Level
2: System level
Use the ssm-policy command to configure the SSM group range.
Use the undo ssm-policy command to restore the system default.
By default, the SSM group range is 232.0.0.0/8.
This command allows you to define an address range of permitted or denied multicast groups. If the match succeeds, the multicast mode will be PIM-SSM; otherwise the multicast mode will be PIM-SM.
# Configure the SSM group range to be 232.1.0.0/16 in the PIM-SSM domain.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 232.1.0.0 0.0.255.255
[Sysname-acl-basic-2000] quit
[Sysname] pim
[Sysname-pim] ssm-policy 2000
1.1.58  state-refresh-interval
undo state-refresh-interval
View
PIM view
Default Level
2: System level
interval: State refresh interval in seconds.
Use the state-refresh-interval command to configure the interval between state refresh messages.
Use the undo state-refresh-interval command to restore the default setting.
By default, the state refresh interval is 60 seconds.
Related commands: pim state-refresh-capable, state-refresh-rate-limit, state-refresh-ttl.
# Set the state refresh interval to 70 seconds.
[Sysname] pim
[Sysname-pim] state-refresh-interval 70
1.1.59  state-refresh-rate-limit
state-refresh-rate-limit interval
undo state-refresh-rate-limit
View
PIM view
Default Level
2: System level
interval: Time to wait before receiving a new refresh message.
Use the state-refresh-rate-limit command to configure the time the router must wait before receiving a new state refresh message.
Use the undo state-refresh-rate-limit command to restore the default setting.
By default, the device waits 30 seconds before receiving a new state refresh message.
Related commands: pim state-refresh-capable, state-refresh-interval, state-refresh-ttl.
Configure the device to wait 45 seconds before receiving a new state refresh message.
[Sysname] pim
[Sysname-pim] state-refresh-rate-limit 45
1.1.60  state-refresh-ttl
state-refresh-ttl ttl-value
undo state-refresh-ttl
View
PIM view
Default Level
2: System level
ttl-value: Time-to-live (TTL) value of state refresh messages.
Use the state-refresh-ttl command to configure the TTL value of state refresh messages.
Use the undo state-refresh-ttl command to restore the default setting.
By default, the TTL value of state refresh messages is 255.
Related commands: pim state-refresh-capable, state-refresh-interval, state-refresh-rate-limit.
# Configure the device to send PIM state refresh messages with a TTL of 45.
[Sysname] pim
[Sysname-pim] state-refresh-ttl 45
1.1.61  static-rp
static-rp rp-address [ acl-number ] [ preferred ]
undo static-rp rp-address
View
PIM view
Default Level
2: System level
rp-address: IP address of the static RP to be configured. This address must be a legal unicast IP address.
acl-number: Basic ACL number. If you provide this argument, the configured static RP will serve only those groups that pass the ACL filtering; otherwise, the configured static RP will serve the all-system group 224.0.0.0/4.
preferred: Specifies to give priority to the static RP if the static RP conflicts with the dynamic RP. If you do not include the preferred keyword in your command, the dynamic RP will be given priority, and the static RP takes effect on if no dynamic RP exists in the network or when the dynamic RP fails.
Use the static-rp command to configure a static RP.
Use the undo static-rp command to configure a static RP.
By default, no static RP is configured.
Note that:
l           PIM-SM or PIM-DM cannot be enabled on an interface that serves as a static RP.
l           When the ACL rule applied on a static RP changes, a new RP must be elected for all the multicast groups.
l           You can configure multiple static RPs by using this command repeatedly. However, if you carry out this command multiple times and specify the same static RP address or reference the same ACL rule, the last configuration will override the previous one. If multiple static RPs have been configured for the same multicast group, the one with the highest IP address will be chosen to serve the multicast group.
l           You can configure up to 50 static RPs on the same device.
Related commands: display pim rp-info, auto-rp enable.
# Configure the interface with the IP address 11.110.0.6 to be a static RP that serves the multicast groups defined in ACL 2001, and give priority to this static RP in the case of static/dynamic RP conflict.
[Sysname] pim
[Sysname-pim] static-rp 11.110.0.6 2001 preferred
1.1.62  timer hello
undo timer hello
View
PIM view
Default Level
2: System level
Use the timer hello command to configure the hello interval globally.
Use the undo timer hello command to restore the default setting.
# Set the global hello interval to 40 seconds.
[Sysname] pim
[Sysname-pim] timer hello 40
1.1.63  timer join-prune
undo timer join-prune
View
PIM view
Default Level
2: System level
Use the timer join-prune command to configure the join/prune interval globally.
Use the undo timer join-prune command to restore the default setting.
Related commands: pim timer join-prune.
# Set the global join/prune interval to 80 seconds.
[Sysname] pim
[Sysname-pim] timer join-prune 80
