H3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
02-IGMP Snooping Commands
02-IGMP Snooping Commands 137.36 KB
Chapter 1  IGMP Snooping Configuration Commands
1.1  IGMP Snooping Configuration Commands
1.1.1  debugging igmp-snooping
debugging igmp-snooping { all | event | abnormal | driver | group | timer | ipc { receive | send } | packet [ vlan vlan-id [ port port-type port-number ] ] }
undo debugging igmp-snooping { all | event | abnormal | driver | group | timer | ipc { receive | send } | packet }
View
Default Level
1: Monitor level
all: Specifies all types of debugging for IGMP Snooping.
event: Specifies event debugging for IGMP-Snooping.
abnormal: Specifies abnormal information debugging for IGMP-Snooping.
driver: Specifies driver debugging for IGMP-Snooping.
group: Specifies group debugging for IGMP-Snooping.
timer: Specifies timer debugging for IGMP-Snooping.
ipc: Specifies debugging for IPC packets.
receive: Specifies debugging for received IPC packets.
send: Specifies debugging for sent IPC packets.
packet: Specifies debugging for IGMP messages.
vlan vlan-id: Specifies a VLAN ID.
port port-type port-number: Specifies a port by its type and number.
Use the debugging igmp-snooping command to enable debugging for IGMP Snooping.
Use the undo debugging igmp-snooping command to disable debugging for IGMP Snooping.
By default, debugging for IGMP Snooping is disabled.
Table 1-1 debugging igmp-snooping driver command output description
mask boardmask
Adding/deleting the target board mask of an entry
(saddr, gaddr)
(S, G) entry
Table 1-2 debugging igmp-snooping event command output description
Succeed to enable/disable IGMP snooping drop-unknown globally
The function of dropping unknown multicast packets globally enabled/disabled
Table 1-3 debugging igmp-snooping group command output description
(saddr, gaddr)
(S, G) entry
on vlan vlanid
VLAN to which the (S, G) belongs
Table 1-4 debugging igmp-snooping packet command output description
IGMP general query/ special query/ group-and-source-specific query/report/done packet
IGMP general query/group-specific query/group-and-source-specific query/report/leave message
port portname
Number of the port that processes the message
on vlan vlanid
ID of the VLAN to which the port belongs
destination address dstaddr
Destination address of the message
Table 1-5 debugging igmp-snooping timer command output description
host port aging timer/time
router port aging timer/time
aggregation host port aging timer/time
aggregation router port aging timer/time
querier timer/interval
IGMP-Snooping timers
# Enable all types of debugging for IGMP Snooping.
<Sysname> debugging igmp-snooping all
1.1.2  display igmp-snooping group
display igmp-snooping group [ vlan vlan-id ] [ slot slot-id ] [ verbose ]
View
Default Level
1: Monitor level
vlan vlan-id: Displays the IGMP Snooping multicast group information in the specified VLAN. If you do not specify a VLAN, this command will display the IGMP Snooping multicast group information in all VLANs.
slot slot-id: Displays the IGMP Snooping multicast group information for the specified board. If you do not specify a slot, this command will display the IGMP Snooping multicast group information on the switching and routing processing unit (SRPU) only.
verbose: Specifies to display the detailed IGMP Snooping multicast group information.
Use the display igmp-snooping group command to view the IGMP Snooping multicast group information.
# View the detailed IGMP Snooping multicast group information on the board in slot 7.
<Sysname> display igmp-snooping group slot 7 verbose
    Total 1 IP Group(s).
    Total 1 IP Source(s).
    Total 1 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, A-Aggregation port, C-Copy port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):3000.
    Router port unit board: Mask(0x0)
    Router port(s):total 0 port.
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:232.1.0.1
        (0.0.0.0, 232.1.0.1):
          Attribute:    Host Port
          Host port unit board: Mask(0x0)
          Host port(s):total 1 port.
            Eth7/1/8              (D) ( 00:04:01 )
    MAC group(s):
      MAC group address:0100-5e01-0001
            Eth7/1/8
Table 1-6 display igmp-snooping group command output description
Total 1 IP Group(s)
Total number of IP multicast groups
Total number of multicast sources
Total number of MAC multicast groups
Port flags: D for dynamic port, S for static port, A for aggregation port, C for port copied from a (*, G) entry to an (S, G) entry
Sub-VLAN flags: R for real egress sub-VLAN under the current entry, C for sub-VLAN copied from a (*, G) entry to an (S, G) entry
Mask (0x0)
Board mask (0x0 indicates that at least one port on the current board has joined the multicast group, while no ports of other boards have joined the group
Router port(s):
Number of router ports
IP group(s):
Information about IP multicast group(s)
IP group address
Address of IP multicast group
(S, G) entry
Attribute
Attribute of the IP multicast group
Host port(s)
Number of host member port(s)
( 00:04:01 )
Remaining aging time of the port
MAC group(s):
Information about MAC multicast group(s)
MAC group address
Address of the MAC multicast group
1.1.3  display igmp-snooping statistics
View
Default Level
1: Monitor level
None
Use the display igmp-snooping statistics command to view the statistics information of IGMP messages learned by IGMP Snooping.
# View the statistics information of IGMP messages learned by IGMP Snooping.
<Sysname> display igmp-snooping statistics
  Received IGMP general  query packet(s) number:0.
  Received IGMP V1 report packet(s) number:0.
  Received IGMP V2 report packet(s) number:19.
  Received IGMP leave  packet(s) number:0.
  Received IGMP V2 specific query packet(s) number:0.
  Sent     IGMP V2 specific query packet(s) number:0.
  Received IGMP V3 report packet(s) number:0.
  Received IGMP V3 specific query packet(s) number:0.
  Received IGMP V3 specific sg query packet(s) number:0.
  Sent     IGMP V3 specific query packet(s) number:0.
  Sent     IGMP V3 specific sg query packet(s) number:0.
  Received error IGMP packet(s) number:19.
Table 1-7 display igmp-snooping statistics command output description
General query message(s)
Group-specific query message(s)
report packet(s)
Report message(s)
leave packet(s)
Leave message(s)
Group-and-source-specific query message(s)
error IGMP packets
IGMP messages with errors
1.1.4  drop-unknown
drop-unknown
undo drop-unknown
View
IGMP-Snooping view
Default Level
2: System level
None
Use the drop-unknown command to enable globally the function of dropping unknown multicast data.
Use the undo drop-unknown command to disable globally the function of dropping unknown multicast data.
By default, this function is disabled, that is, unknown multicast data is flooded.
This command works only on an IGMP Snooping–enabled VLAN, but not on a VLAN with IGMP enabled on its VLAN interface.
# Globally enable the device to drop unknown multicast data.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] drop-unknown
1.1.5  fast-leave
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
View
IGMP-Snooping view
Default Level
2: System level
vlan vlan-list: Configures the fast leave feature for the specified VLAN(s). You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id or a VLAN range in the form of start-vlan-id to end-vlan-id, where the start VLAN ID must be greater than the end VLAN ID.
Use the fast-leave command to enable the fast leave feature globally.
Use the undo fast-leave command to disable the fast leave feature globally.
By default, the fast leave feature is globally disabled.
Note that:
l           This command works on an IGMP Snooping–enabled VLAN or on a VLAN with IGMP enabled on its VLAN interface.
l           If you do not specify any VLAN, the command will take effect for all VLANs; if you specify a VLAN or multiple VLANs, the command will take effect for the specified VLAN(s) only.
Related commands: igmp-snooping fast-leave.
# Enable the fast leave feature globally in VLAN 2.
[Sysname-igmp-snooping] fast-leave vlan 2
1.1.6  group-policy
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
View
IGMP-Snooping view
Default Level
2: System level
acl-number: Basic ACL number.
vlan vlan-list: Configures a multicast group filter for the specified VLAN(s). You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id or a VLAN range in the form of start-vlan-id to end-vlan-id, where the start VLAN ID must be greater than the end VLAN ID.
Use the group-policy command to configure a global multicast group filter.
Use the undo group-policy command to remove the configured global multicast group filter.
By default, no global multicast group filter is configured, namely a host can join any multicast group.
Note that:
l           If the specified ACL does not exist or the ACL rule is null, all multicast groups will be filtered out.
l           You can configure different ACL rules for a port in different VLANs; for a given VLAN, a newly configured ACL rule will override the existing one.
Related commands: igmp-snooping group-policy.
# Configure ACL 2000 as the multicast group filter in VLAN 2.
[Sysname-igmp-snooping] group-policy 2000 vlan 2
1.1.7  host-aging-time
host-aging-time interval
undo host-aging-time
View
IGMP-Snooping view
Default Level
2: System level
interval: Dynamic member port aging time, in units of seconds.
Use the host-aging-time command to configure the aging time of dynamic member ports globally.
Use the undo host-aging-time command to restore the default setting.
By default, the aging time of dynamic member ports is 260 seconds.
Related commands: igmp-snooping host-aging-time.
# Set the aging time of dynamic member ports globally to 300 seconds.
[Sysname-igmp-snooping] host-aging-time 300
1.1.8  igmp-snooping
igmp-snooping
undo igmp-snooping
View
Default Level
2: System level
None
Use the igmp-snooping command to enable IGMP Snooping globally and enter IGMP-Snooping view.
Use the undo igmp-snooping command to disable IGMP Snooping globally.
By default, IGMP Snooping is disabled.
Related commands: igmp-snooping enable.
  Caution:
If you execute the undo igmp-snooping command on the IGMP Snooping–enabled switch, all the IGMP Snooping configurations will be lost.
# Enable IGMP Snooping globally and enter IGMP-Snooping view.
1.1.9  igmp-snooping enable
undo igmp-snooping enable
View
VLAN view
Default Level
2: System level
None
Use the igmp-snooping enable command to enable IGMP Snooping in the current VLAN.
Use the undo igmp-snooping enable command to disable IGMP Snooping in the current VLAN.
By default, IGMP Snooping is disabled in a VLAN.
Note that:
l           IGMP Snooping must be enabled globally before it can be enabled in a VLAN.
l           After enabling IGMP Snooping in a VLAN, you cannot enable IGMP and/or PIM on the corresponding VLAN interface, and vice versa.
Related commands: igmp-snooping.
# Enable IGMP Snooping in VLAN 2.
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
1.1.10  igmp-snooping fast-leave
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
View
Ethernet interface view, port group view
Default Level
2: System level
Use the igmp-snooping fast-leave command to enable the fast leave feature on the current port or group of ports.
Use the undo igmp-snooping fast-leave command to disable the fast leave feature on the current port or group of ports.
By default, the fast leave feature is disabled.
Note that:
l           If you do not specify any VLAN in Ethernet interface view, the command will take effect on the port no matter which VLAN the port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect on the port only if the port belongs to the specified VLAN(s).
l           If you do not specify any VLAN in manual port group view, the command will take effect on all the ports in this group no matter which VLANs these ports belong to; if you specify a VLAN or multiple VLANs, the command will take effect on those ports in this group that belong to the specified VLAN(s).
l           Configurations made in aggregation port group view are effective only for the master port in the group. If you do not specify any VLAN in aggregation port group view, the command will take effect no matter which VLAN the master port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect only if the master port belongs to the specified VLAN(s).
Related commands: fast-leave.
# Enable the fast leave feature on Ethernet 1/1/1, which belongs to VLAN 2.
[Sysname] interface ethernet 1/1/1
[Sysname-Ethernet1/1/1] igmp-snooping fast-leave vlan 2
1.1.11  igmp-snooping general-query source-ip
igmp-snooping general-query source-ip { current-interface | ip-address }
undo igmp-snooping general-query source-ip
View
VLAN view
Default Level
2: System level
current-interface: Sets the source address of IGMP general queries to the address of the current VLAN interface. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 will be used as the source IP address of IGMP general queries.
ip-address: Specifies the source address of IGMP general queries, which can be any legal IP address.
Use the igmp-snooping general-query source-ip command to configure the source address of IGMP general queries.
Use the undo igmp-snooping general-query source-ip command to restore the default configuration.
By default, the source IP address of IGMP general queries is 0.0.0.0.
This command takes effect only if IGMP Snooping is enabled in the VLAN.
# Set the IP address of the interface of VLAN 2 to 10.1.1.1, with the subnet mask of 255.255.255.0, and specify this IP address as the source IP address of IGMP general queries.
[Sysname-Vlan-interface2] ip address 10.1.1.1 255.255.255.0
[Sysname-Vlan-interface2] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip current-interface
1.1.12  igmp-snooping group-limit
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
View
Default Level
2: System level
limit: Maximum number of multicast groups that can be joined on a port.
vlan vlan-list: Defines one or multiple VLANs. You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id or a VLAN range in the form of start-vlan-id to end-vlan-id, where the start VLAN ID must be greater than the end VLAN ID.
Use the igmp-snooping group-limit command to configure the maximum number of multicast groups that can be joined on a port.
Use the undo igmp-snooping group-limit command to restore the default setting.
The default value is 512.
Note that:
l           Configurations made in aggregation port group view are effective only for the master port of the group. If you do not specify any VLAN in aggregation port group view, the command will take effect no matter which VLAN the master port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect only if the master port belongs to the specified VLAN(s).
# Configure to allow up to 10 multicast groups to be joined on Ethernet 1/1/1, which belongs to VLAN 2.
[Sysname-Ethernet1/1/1] igmp-snooping group-limit 10 vlan 2
1.1.13  igmp-snooping group-policy
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
View
Default Level
2: System level
vlan vlan-list: Configures a multicast group filter in the specified VLAN(s). You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id or a VLAN range in the form of start-vlan-id to end-vlan-id, where the start VLAN ID must be greater than the end VLAN ID.
 Use the igmp-snooping group-policy command to configure a multicast group filter on the current port(s).
Use the undo igmp-snooping group-policy command to remove a multicast group filter on the current port(s).
Be default, no multicast group filter is configured on an interface, namely a host can join any multicast group
Note that:
Related commands: group-policy.
# Configure ACL 2000 as the multicast group filter on Ethernet 1/1/1, which belongs to VLAN 2.
[Sysname-Ethernet1/1/1] igmp-snooping group-policy 2000 vlan 2
1.1.14  igmp-snooping host-aging-time
igmp-snooping host-aging-time interval
undo igmp-snooping host-aging-time
View
VLAN view
Default Level
2: System level
Use the igmp-snooping host-aging-time command to configure the aging time of dynamic member ports in the current VLAN.
Use the undo igmp-snooping host-aging-time command to restore the default setting.
Related commands: host-aging-time.
# Set the aging time of dynamic member ports to 300 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
1.1.15  igmp-snooping host-join
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
View
Default Level
2: System level
vlan vlan-id: Specifies the VLAN that comprises the Ethernet port(s).
group-address: Address of the multicast group that the simulated host is to join, in the range of 224.0.1.0 to 239.255.255.255.
source-address: Address of the multicast source that the simulated host is to join. The value of this argument should be a valid unicast address or 0.0.0.0. If the value is 0.0.0.0, this means that no multicast source is specified.
Use the igmp-snooping host-join command to configure simulated (*, G) or (S, G) joining on the current port or ports.
Use the undo igmp-snooping host-join command to restore the default.
By default, no ports are configured as simulated hosts for any multicast groups or sources-groups.
Note that:
l           The source-ip source-address option in the command is meaningful only for IGMP Snooping version 3. If IGMP Snooping version 2 is running, although you can include source-ip source-address in your command, the simulated host does not make a response when receiving a query message.
l           If configured in Ethernet interface view, this feature takes effect on the port only if the port belongs to the specified VLAN. If configured in manual port group view, this feature takes effect on all the ports in the current port group that belong to the specified VLAN. When used in aggregation port group view, the command will take effect on the master port that belongs to the specified VLAN..
# Configure Ethernet 1/1/1 in VLAN 2 to join (1.1.1.1, 232.1.1.1) as a simulated host.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-Ethernet1/1/1] igmp-snooping host-join 232.1.1.1 source-ip 1.1.1.1 vlan 2
1.1.16  igmp-snooping last-member-query-interval
igmp-snooping last-member-query-interval interval
undo igmp-snooping last-member-query-interval
View
VLAN view
Default Level
2: System level
interval: Interval between IGMP last-member queries, in units of seconds.
Use the igmp-snooping last-member-query-interval command to configure the interval between IGMP last-member queries in the VLAN.
Use the undo igmp-snooping last-member-query-interval command to restore the default setting.
By default, the IGMP last-member query interval is 1 second.
Related commands: last-member-query-interval.
# Set the interval between IGMP last-member queries to 3 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
1.1.17  igmp-snooping max-response-time
igmp-snooping max-response-time interval
undo igmp-snooping max-response-time
View
VLAN view
Default Level
2: System level
interval: Maximum response time to IGMP general queries, in units of seconds.
Use the igmp-snooping max-response-time command to configure the maximum response time to IGMP general queries in the VLAN.
Use the undo igmp-snooping max-response-time command to restore the default setting.
By default, the maximum response time to IGMP general queries is 10 seconds.
Related commands: max-response-time, igmp-snooping query-interval.
# Set the maximum response time to IGMP general queries to 5 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
1.1.18  igmp-snooping overflow-replace
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
View
Default Level
2: System level
vlan vlan-list: Configures the multicast group replacement function in the specified VLAN(s). You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id or a VLAN range in the form of start-vlan-id to end-vlan-id, where the start VLAN ID must be greater than the end VLAN ID.
Use the igmp-snooping overflow-replace command to enable the multicast group replacement function on the current port(s).
Use the undo igmp-snooping overflow-replace command to disable the multicast group replacement function on the current port(s).
By default, the multicast group replacement function is disabled.
Note that:
Related commands: overflow-replace.
# Enable the multicast group replacement function on Ethernet 1/1/1, which belongs to VLAN 2.
[Sysname-Ethernet1/1/1] igmp-snooping overflow-replace vlan 2
1.1.19  igmp-snooping querier
undo igmp-snooping querier
View
VLAN view
Default Level
2: System level
None
Use the igmp-snooping querier command to enable the IGMP Snooping querier function.
Use the undo igmp-snooping querier command to disable the IGMP Snooping querier function.
By default, the IGMP Snooping querier function is disabled.
# Enable the IGMP Snooping querier function in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
1.1.20  igmp-snooping query-interval
igmp-snooping query-interval interval
undo igmp-snooping query-interval
View
VLAN view
Default Level
2: System level
interval: Interval between IGMP general queries, in units of seconds.
Use the igmp-snooping query-interval command to configure the interval between IGMP general queries.
Use the undo igmp-snooping query-interval command to restore the default setting.
By default, the IGMP general query interval is 60 seconds.
  Caution:
In the configuration, make sure that the IGMP general query interval is larger than the maximum response time for IGMP general queries.
Related commands: igmp-snooping querier, igmp-snooping max-response-time, max-response-time.
# Set the interval between IGMP general queries to 20 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
1.1.21  igmp-snooping router-aging-time
igmp-snooping router-aging-time interval
undo igmp-snooping router-aging-time
View
VLAN view
Default Level
2: System level
interval: Dynamic router port aging time, in units of seconds.
Use the igmp-snooping router-aging-time command to configure the aging time of dynamic router ports in the current VLAN.
Use the undo igmp-snooping router-aging-time command to restore the default setting.
By default, the aging time of dynamic router ports is 105 seconds.
Related commands: router-aging-time.
# Set the aging time of dynamic router ports to 100 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
1.1.22  igmp-snooping special-query source-ip
igmp-snooping special-query source-ip { current-interface | ip-address }
undo igmp-snooping special-query source-ip
View
VLAN view
Default Level
2: System level
current-interface: Sets the source address of IGMP group-specific queries to the address of the current VLAN interface. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 will be used as the source IP address of IGMP group-specific queries.
ip-address: Sets the source address of IGMP group-specific queries to the specified address.
Use the igmp-snooping special-query source-ip command to configure the source IP address of IGMP group-specific queries.
Use the undo igmp-snooping special-query source-ip command to restore the default configuration.
By default, the source IP address of IGMP group-specific queries is 0.0.0.0.
# Set the IP address of the interface of VLAN 2 to 10.1.1.1, with the subnet mask of 255.255.255.0, and specify this IP address as the source IP address of IGMP group-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip current-interface
1.1.23  igmp-snooping static-group
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
View
Default Level
2: System level
group-address: Address of the multicast group to be statically joined, in the range of 224.0.0.0 to 239.255.255.255.
source-address: Address of multicast source to be statically joined. The value of this argument should be a valid unicast address or 0.0.0.0. If the value is 0.0.0.0, this means no multicast source is specified.
Use the igmp-snooping static-group command to configure the current port(s) as static member ports for the specified multicast group or source-group.
Use the undo igmp-snooping static-group command to restore the default.
By default, no ports are static member ports.
Note that:
l           The source-ip source-address option in the command is meaningful only for IGMP Snooping version 3. If IGMP Snooping version 2 is running, although you can include the source-ip source-address option in your command, the configuration will not take effect.
l           If configured in Ethernet interface view, this feature takes effect on the port only if the port belongs to the specified VLAN. If configured in manual port group view, this feature takes effect only on those ports in this port group that belong to the specified VLAN. When used in aggregation port group view, the command will take effect only if the master port belongs to the specified VLAN(s).
# Configure Ethernet 1/1/1 in VLAN 2 as a static member port for (1.1.1.1, 232.1.1.1).
[Sysname] vlan 2
[Sysname-Ethernet1/1/1] igmp-snooping static-group 232.1.1.1 source-ip 1.1.1.1 vlan 2
1.1.24  igmp-snooping static-router-port
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port vlan vlan-id
View
Default Level
2: System level
vlan vlan-id: Specifies a VLAN in which one or more static router ports are to be configured.
Use the igmp-snooping static-router-port command to configure the current port(s) as static router port(s).
Use the undo igmp-snooping static-router-port command to restore the default.
By default, no ports are static router ports.
Note that:
# Configure Ethernet 1/1/1 in VLAN 2 as a static router port.
[Sysname-Ethernet1/1/1] igmp-snooping static-router-port vlan 2
1.1.25  igmp-snooping version
igmp-snooping version version-number
undo igmp-snooping version
View
VLAN view
Default Level
2: System level
version-number: IGMP snooping version.
Use the igmp-snooping version command to configure the IGMP Snooping version.
Use the undo igmp-snooping version command to restore the default setting.
By default, the IGMP version is 2.
This command can take effect only if IGMP Snooping is enabled in the VLAN.
# Enable IGMP Snooping in VLAN 2, and set the IGMP Snooping version to version 3.
[Sysname] vlan 2
1.1.26  last-member-query-interval
undo last-member-query-interval
View
IGMP-Snooping view
Default Level
2: System level
Use the last-member-query-interval command to configure the interval between IGMP last-member queries globally.
Use the undo last-member-query-interval command to restore the default setting.
By default, the interval between IGMP last-member queries is 1 second.
Related commands: igmp-snooping last-member-query-interval.
# Set the interval between IGMP last-member queries globally to 3 seconds.
[Sysname-igmp-snooping] last-member-query-interval 3
1.1.27  max-response-time
undo max-response-time
View
IGMP-Snooping view
Default Level
2: System level
Use the max-response-time command to configure the maximum response time to IGMP general queries globally.
Use the undo max-response-time command to restore the default value.
Related commands: igmp-snooping max-response-time, igmp-snooping query-interval.
# Set the maximum response time to IGMP general queries globally to 5 seconds.
[Sysname-igmp-snooping] max-response-time 5
1.1.28  overflow-replace
undo overflow-replace [ vlan vlan-list ]
View
IGMP-Snooping view
Default Level
2: System level
vlan vlan-list: Configures the multicast group replacement function for the specified VLAN(s). You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id or a VLAN range in the form of start-vlan-id to end-vlan-id, where the start VLAN ID must be greater than the end VLAN ID.
Use the overflow-replace command to enable the multicast group replacement function.
Use the undo overflow-replace command to disable the multicast group replacement function.
Note that:
Related commands: igmp-snooping overflow-replace.
# Enable the multicast group replacement function in VLAN 2.
[Sysname-igmp-snooping] overflow-replace vlan 2
1.1.29  report-aggregation
report-aggregation
undo report-aggregation
View
IGMP-Snooping view
Default Level
2: System level
None
Use the report-aggregation command to enable IGMP report suppression.
Use the undo report-aggregation command to disable IGMP report suppression.
By default, IGMP report suppression is enabled.
# Disable IGMP report suppression.
[Sysname-igmp-snooping] undo report-aggregation
1.1.30  reset igmp-snooping group
reset igmp-snooping group { group-address | all } [ vlan vlan-id ]
View
Default Level
2: System level
group-address: Clears the information about the specified IGMP Snooping multicast group. The value range of group-address  is 224.0.1.0 to 239.255.255.255.
all: Clears all IGMP Snooping multicast group information.
vlan vlan-id: Clears the IGMP Snooping multicast group information in the specified VLAN.
Use the reset igmp-snooping group command to clear IGMP Snooping multicast group information.
Note that:
l           This command works only on an IGMP Snooping–enabled VLAN, but not on a VLAN with IGMP enabled on its VLAN interface.
l           This command cannot clear IGMP Snooping multicast group information of static joins.
# Clear all IGMP Snooping multicast group information saved in the switch.
<Sysname> reset igmp-snooping group all
1.1.31  reset igmp-snooping statistics
View
Default Level
2: System level
None
Use the reset igmp-snooping statistics command to clear the statistics information of IGMP messages learned by IGMP Snooping.
# Clear the statistics information of all kinds of IGMP messages learned by IGMP Snooping.
<Sysname> reset igmp-snooping statistics
1.1.32  router-aging-time
undo router-aging-time
View
IGMP-Snooping view
Default Level
2: System level
Use the router-aging-time command to configure the aging time of dynamic router ports globally.
Use the undo router-aging-time command to restore the default setting.
Related commands: igmp-snooping router-aging-time.
# Set the aging time of dynamic router ports globally to 100 seconds.
[Sysname-igmp-snooping] router-aging-time 100
