H3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
05-MSDP Commands
05-MSDP Commands 94.82 KB
Chapter 1  MSDP Configuration Commands
1.1  MSDP Configuration Commands
1.1.1  cache-sa-enable
cache-sa-enable
undo cache-sa-enable
View
MSDP view
Default Level
2: System level
None
Use the cache-sa-enable command to enable the SA message cache mechanism, so that the device caches the (S, G) entries in the SA messages it receives.
Use the undo cache-sa-enable command to disable the SA message cache mechanism.
By default, the SA message cache mechanism is enabled.
# Disable the SA message cache mechanism.
[Sysname] msdp
[Sysname-msdp] undo cache-sa-enable
1.1.2  debugging msdp
debugging msdp { all | connect | event | packet | source-active }
undo debugging msdp { all | connect | event | packet | source-active }
View
Default Level
1: Monitor level
all: Specifies all types of debugging for MSDP.
connect: Specifies debugging for MSDP peer connection resets.
event: Specifies debugging for MSDP events.
packets: Specifies debugging for MSDP messages.
source-active: Specifies MSDP source-active debugging.
Use the debugging msdp command to enable debugging for MSDP.
Use the undo debugging msdp command to disable debugging for MSDP.
By default, debugging for MSDP is disabled.
Table 1-1 debugging msdp event command output description
Originating/adding/sending SA message
Creating/adding/sending SA message
SA/SA with data
Notification
SA request
SA response
SA message/SA message with data
Notification
SA request
SA response
(sadd, gadd)
(S,G) entry
Creating/Deleting
Creating/Deleting timer
TCP listening
Connection accepted
TCP connection established
TCP connect
ConnectRetry
Connection reset
State error
Peer reset
SessionRetry
TCP listening
Connection accepted
TCP connection
Connection retry
Connection reset
State error
Session retry
Can not pass acl filter/passed acl filter
SA message failed ACL filtering/SA messages passed ACL filtering
Static RPF peer
E-MBGP peer
I-MBGP peer
NOT BGP peer
NOT MBGP peer
Static RPF neighbor
E-MBGP neighbor
I-MBGP neighbor
NOT BGP neighbor
NOT MBGP neighbor
Table 1-2 debugging msdp packet command output description
Reading from peer blocked
Retrying read
Reading from peer failed
Received illegal message from peer
Received n-bytes message
Message reading blocked
Retrying reading
Reading failed
Illegal character read
Total size of messages read is n bytes
SA-TLV
SA-Request TLV
SA-Response TLV
KeepAlive TLV
Notification TLV
Types of messages read:
SA
SA request
SA response
KeepAlive
Notification
Sending
Received
SA message discarded
Forwarding
Sending SA
Received SA
Discarded SA
Forwarding SA
Table 1-3 debugging msdp source-active command output description
RPF check failed
RPF check passed
RPF check failed
RPF check succeeded
Only one peer
Peer is original RP
Peer belongs mesh-group
Static RPF peer
MSDP Peer is E-MBGP peer
Peer's AS is the next-AS to RP
MSDP Peer is I-MBGP peer
Peer is the next-hop to RP
Conditions for a successful RPF check:
Only one MSDP peer
MSDP peer is a source-side RP
MSDP peer belongs to a mesh group
Static RPF peer
MSDP peer is an E-MBGP neighbor
MSDP peer is in the next AS to the RP
MSDP peer is an I-MBGP neighbor
MSDP peer is the next hop to the RP
# Enable MSDP event debugging.
<Sysname> debugging msdp event
*Aug 25 09:33:13:130 2006 Sysname MSDP/7/EVENT:
11.11.11.11: TCP listening (H12726)
// Server 11.11.11.11 starts TCP listening
*Aug 25 09:35:45:790 2006 Sysname MSDP/7/EVENT:
11.11.11.11: Connection accepted (H12850)
11.11.11.11: TCP connection established (H12854)
// TCP connection established
11.11.11.11: Sending message to peer: keepalive (H101045)
// Sending KeepAlive message to MSDP peer
11.11.11.11: Originating SA message for peer (H10859)
// Sending SA messag to peer
# Enable MSDP message debugging.
<Sysname> debugging msdp packet
*Aug 25 09:39:07:162 2006 Sysname MSDP/7/PACKET:
11.11.11.11: Sending a 3-bytes message to peer (H17119)
// Sending a 3-byte message to MSDP peer
11.11.11.11: Sending to peer success, 3-bytes sent (H17143)
// Message successfully sent to MSDP peer
11.11.11.11: Received 3-bytes message 1 from peer (H13471)
// MSDP peer received 1 message, total size being 3 bytes
11.11.11.11: KeepAlive TLV (H131441)
// This message is a KeepAlive message
# Enable MSDP source-active debugging.
<Sysname> debugging msdp source-active
*Aug 25 09:52:08:924 2006 Sysname MSDP/7/SOURCE-ACTIVE:
11.11.11.11: Only one peer, passed RPF check (H132426)
// Because there is only one MSDP peer, the SA message passed the RPF check
1.1.3  display msdp brief
display msdp brief [ state { connect | down | listen | shutdown | up } ]
View
Default Level
1: Monitor level
state: Displays the information of MSDP peers in the specified state.
connect: Displays the information of MSDP peers in the connecting state.
down: Displays the information of MSDP peers in the down state.
listen: Displays the information of MSDP peers in the listening state.
shutdown: Displays the information of MSDP peers in the deactivated state.
up: Displays the information of MSDP peers in the in-session state.
Use the display msdp brief command to view the brief information of MSDP peers.
# View the brief information of MSDP peers in all states.
<Sysname> display msdp brief
MSDP Peer Brief Information
  Configured   Up           Listen       Connect      Shutdown     Down
  1            1            0            0            0            0
  Peer's Address     State   Up/Down time   AS     SA Count  Reset Count
  20.20.20.20        Up      00:00:13       100    0         0
Table 1-4 display msdp brief command output description
Configured
Number of MSDP peers configured
Up
Number of MSDP peers in the up state
Listen
Number of MSDP peers in the listen state
Connect
Number of MSDP peers in the connect state
Shutdown
Number of MSDP peers in the shutdown state
Down
Number of MSDP peers in the down state
Peer's Address
MSDP peer address
MSDP peer status:
l      Up: Session set up; MSDP peer in session
l      Listen: Session set up; local device as server, in listening state
l      Connect: Session not set up; local device as client, in connecting state
l      Shutdown: Deactivated
l      Down: Connection failed
Up/Down time
Length of time since MSDP peer connection was established/failed
AS
Number of the AS where the MSDP peer is located. “?” indicates that the system was unable to obtain the AS number.
SA Count
Number of (S, G) entries
Reset Count
MSDP peer connection reset times
1.1.4  display msdp peer-status
display msdp peer-status [ peer-address ]
View
Default Level
1: Monitor level
peer-address: Specifies an MSDP peer by its address. If you do not provide this argument, this command will display the detailed status information of all MSDP peers.
Use the display msdp peer-status command to view the detailed MSDP peer status information.
Related commands: peer connect-interface, peer description, peer mesh-group, peer minimum-ttl, peer request-sa-enable, peer sa-cache-maximum, peer sa-policy, peer sa-request-policy.
# View the detailed status information of all MSDP peers.
<Sysname> display msdp peer-status
  MSDP Peer 20.20.20.20, AS 100
  Description:
  Information about connection status:
    State: Up
    Up/down time: 14:41:08
    Resets: 0
    Connection interface: LoopBack0 (20.20.20.30)
    Number of sent/received messages: 867/947
    Number of discarded output messages: 0
    Elapsed time since last connection or counters clear: 14:42:40
  Information about (Source, Group)-based SA filtering policy:
    Import policy: none
    Export policy: none
  Information about SA-Requests:
    Policy to accept SA-Request messages: none
    Sending SA-Requests status: disable
  Minimum TTL to forward SA with encapsulated data: 0
  SAs learned from this peer: 0, SA-cache maximum for the peer: none
  Input queue size: 0, Output queue size: 0
  Counters for MSDP message:
    Count of RPF check failure: 0
    Incoming/outgoing SA messages: 0/0
    Incoming/outgoing SA requests: 0/0
    Incoming/outgoing SA responses: 0/0
    Incoming/outgoing data packets: 0/0
Table 1-5 display msdp peer-status command output description
MSDP Peer
MSDP peer address
AS
MSDP peer status:
Resets
Number of times the MSDP peer connection is reset
Up/Down time
Time passed since MSDP peer connection establishment/failure
Interface and its IP address used for setting up a TCP connection with the remote MSDP peer
Number of SA messages sent and received through this connection
Number of discarded outgoing messages
Time passed since the information of the MSDP peer was last cleared
SA message filtering list information
l      Import policy: Filter list for receiving SA messages from the specified MSDP peer
l      Export policy: Filter list for forwarding SA messages from the specified MSDP peer
SA requests information
l      Policy to accept SA-Request messages: Filtering rule for receiving or forwarding SA messages from the specified MSDP peer
l      Sending SA-Requests status: Whether enabled to send an SA request message to the designated MSDP peer upon receiving a new Join message
Minimum TTL of multicast packet encapsulated in SA messages
Number of cached (S, G) entries learned from this MSDP peer
Maximum number of (S, G) entries learned from this MSDP peer that the device can cache
Input queue size
Data size cached in the input queue
Output queue size
Data size cached in the output queue
MSDP peer statistics:
l      Count of RPF check failure: Number of SA messages discarded due to RPF check failure
l      Incoming/outgoing SA messages: Number of SA messages received and sent
l      Incoming/outgoing SA requests: Number of SA request received and sent
l      Incoming/outgoing SA responses: Number of SA responses received and sent
l      Incoming/outgoing data packets: Number of received and sent SA messages encapsulated with multicast data
1.1.5  display msdp sa-cache
display msdp sa-cache [ group-address | source-address | as-number ] *
View
Default Level
1: Monitor level
group-address: Multicast group address in the (S, G) entry.
source-address: Multicast source address in the (S, G) entry.
as-number: AS number.
Use the display msdp sa-cache command to view the information of (S, G) entries in the SA cache.
Note that:
l           This command gives the corresponding output only after the cache-sa-enable command is executed.
l           If you provide a group address, this command will display the (S, G) entry information for all multicast groups.
l           If you do not provide a source address, this command will display the (S, G) entry information for all sources.
l           If you provide neither a group address nor a source address, this command will display the information of all cached (S, G) entries.
l           If you do not provide an AS number, this command will display the (S, G) entry information related to all ASs.
Related commands: cache-sa-enable.
# View the information of (S, G) entries in the SA cache.
<Sysname> display msdp sa-cache
 MSDP Total Source-Active Cache - 5 entries
 MSDP matched 5 entries
 (Source, Group)                 Origin RP      Pro  AS    Uptime   Expires
 (10.10.1.2, 225.1.1.1)            10.10.10.10     BGP  100   00:00:10 00:05:50
 (10.10.1.3, 225.1.1.1)            10.10.10.10     BGP  100   00:00:11 00:05:49
 (10.10.1.2, 225.1.1.2)            10.10.10.10     BGP  100   00:00:11 00:05:49
 (10.10.2.1, 225.1.1.2)            10.10.10.10     BGP  100   00:00:11 00:05:49
 (10.10.1.2, 225.1.2.2)            10.10.10.10     BGP  100   00:00:11 00:05:49
Table 1-6 display msdp sa-cache command output description
Total number of (S, G) entries in the SA cache
Total number of (S, G) entries matched by MSDP
(Source, Group)
(S, G) entry: (source address, group address)
Origin RP
Address of the RP that generated the (S, G) entry
Pro
Type of protocol from which the AS number is originated. “?” indicates that the system was unable to obtain the protocol type
AS
AS number of the origin RP. “?” indicates that the system was unable to obtain the AS number
Uptime
Length of time for which the cached (S, G) entry has been existing, in hours: minutes: seconds
Expires
Length of time in which the cached (S, G) entry will expire, in hours: minutes: seconds
1.1.6  display msdp sa-count
display msdp sa-count [ as-number ]
View
Default Level
1: Monitor level
Use the display msdp sa-count command to view the number of (S, G) entries in the SA cache.
# View the number of (S, G) entries in the SA cache.
<Sysname> display msdp sa-count
Number of cached Source-Active entries, counted by Peer
  Peer's Address     Number of SA
  10.10.10.10        5
  Number of source and group, counted by AS
  AS     Number of source    Number of group
  ?      3                   3
  Total 5 Source-Active entries
Table 1-7 display msdp sa-count command output description
Number of (S, G) entries counted by peer
Peer's Address
Address of the MSDP peer that sent SA messages
Number of SA
Number of (S, G) entries from this peer
Number of cached (S, G) entries, counted by AS
AS
AS number. “?” indicates that the system was unable to obtain the AS number.
Number of source
Number of multicast sources from this AS
Number of group
Number of multicast groups from this AS
1.1.7  encap-data-enable
encap-data-enable
undo encap-data-enable
View
MSDP view
Default Level
2: System level
None
Use the encap-data-enable command to enable register message encapsulation in SA messages.
Use the undo encap-data-enable command to disable register message encapsulation in SA messages.
By default, an SA messages contains only a (S, G) entry. No register message is encapsulated in an SA message.
# Enable register message encapsulation in SA messages.
[Sysname] msdp
[Sysname-msdp] encap-data-enable
1.1.8  import-source
import-source [ acl acl-number ]
undo import-source
View
MSDP view
Default Level
2: System level
acl-number: Basic or advanced ACL number. A basic ACL is used to filter the multicast sources; while an advanced ACL is used to the multicast sources or multicast groups. If you do not provide this argument in your command, no multicast source information will be advertised.
&  Note:
During ACL matching, the protocol ID in the ACL rule is not checked.
Use the import-source command to configure a rule of creating (S, G) entries.
Use the undo import-source command to remove any rule of creating (S, G) entries.
By default, when an SA message is created, there are no restrictions on the (S, G) entries to be advertised in it, namely all the (S, G) entries within the domain are advertised in the SA message.
In addition to controlling SA message creation by using this command, you can also configure a filtering rule for forwarding and receiving SA messages by using the peer sa-policy command.
Related commands: peer sa-policy.
# Configure the MSDP peer to advertise only the (S, G) entries of multicast sources on the 10.10.0.0/16 subnet and with multicast group address of 225.1.0.0/16 when creating an SA message.
[Sysname] acl number 3101
[Sysname-acl-adv-3101] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3101] quit
[Sysname] msdp
[Sysname-msdp] import-source acl 3101
1.1.9  msdp
msdp
undo msdp
View
Default Level
2: System level
None
Use the msdp command to enable MSDP and enter MSDP view.
Use the undo msdp command to disable MSDP and remove the configurations performed in MSDP view to free the resources occupied by MSDP.
By default, MSDP is disabled.
IP multicast must be enabled on the device before this command can take effect.
Related commands: multicast routing-enable in Multicast Routing and Forwarding Commands of the IP Multicast Volume.
# Enable MSDP and enter MSDP view
[Sysname] multicast routing-enable
[Sysname] msdp
[Sysname-msdp]
1.1.10  originating-rp
originating-rp interface-type interface-number
undo originating-rp
View
MSDP view
Default Level
2: System level
Use the originating-rp command to configure the address of the specified interface as the RP address of SA messages.
Use the undo originating-rp command to remove the configuration of using the interface address as the RP address of SA messages.
Be default, the PIM RP address is used as the RP address of SA messages.
# Specify the IP address of VLAN-interface 4 as the RP address of SA messages.
[Sysname] msdp
[Sysname-msdp] originating-rp ethernet 4
1.1.11  peer connect-interface
peer peer-address connect-interface interface-type interface-number
undo peer peer-address
View
MSDP view
Default Level
2: System level
peer-address: MSDP peer address.
interface-type interface-number: Specifies an interface by its type and number. The local routing switch will use the IP address of the specified interface as the source IP address when setting up a TCP connection with the remote MSDP peer.
Use the peer connect-interface command to create an MSDP peer connection.
Use the undo peer connect-interface command to remove an MSDP peer.
No MSDP peer connection created by default.
Be sure to carry out this command before you use any other peer command; otherwise the system will prompt that the peer does not exist.
Related commands: static-rpf-peer.
# Configure the router with the IP address of 125.10.7.6 as the MSDP peer of the local routing switch, with interface VLAN-interface 4 as the local connection port.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 connect-interface vlan-interface 4
1.1.12  peer description
peer peer-address description text
undo peer peer-address description
View
MSDP view
Default Level
2: System level
text: Descriptive string of 1 to 80 case sensitive characters.
Use the peer description command to configure a descriptive string that describes the specified MSDP peer.
Use the undo peer description command to delete the configured descriptive string of the specified MSDP peer.
By default, an MSDP peer has no description information.
Related commands: display msdp peer-status.
# Configure a descriptive string “SWITCH CstmrA” for the switch with the IP address of 125.10.7.6.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 description SWITCH CstmrA
1.1.13  peer mesh-group
peer peer-address mesh-group name
undo peer peer-address mesh-group
View
MSDP view
Default Level
2: System level
name: Mesh group name, a case-sensitive string of 1 to 32 characters.
Use the peer mesh-group command to configure an MSDP peer as a mesh group member.
Use the undo peer mesh-group command to remove an MSDP peer as a mesh group member.
By default, an MSDP peer does not belong to any mesh group.
# Configure the MSDP peer with the IP address of 125.10.7.6 as a member of the mesh group “Grp1”.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 mesh-group Grp1
1.1.14  peer minimum-ttl
peer peer-address minimum-ttl ttl-value
undo peer peer-address minimum-ttl
View
MSDP view
Default Level
2: System level
ttl-value: Minimum time-to-Live (TTL) value.
Use the peer minimum-ttl command to configure the TTL threshold of multicast packets encapsulated in SA messages.
Use the undo peer minimum-ttl command to restore the default.
By default, the TTL threshold of a multicast packet encapsulated in an SA message is 0.
# Set the TTL threshold of multicast packets to be encapsulated in SA messages to 10 so that only multicast packets whose TTL value is larger than or equal to 10 can be forwarded to the MSDP peer 110.10.10.1.
[Sysname] msdp
[Sysname-msdp] peer 110.10.10.1 minimum-ttl 10
1.1.15  peer request-sa-enable
peer peer-address request-sa-enable
undo peer peer-address request-sa-enable
View
MSDP view
Default Level
2: System level
Use the peer request-sa-enable command to enable the device to send an SA request message to the specified MSDP peer upon receiving a new join message.
Use the undo peer request-sa-enable command to disable the device from sending SA request messages to the specified MSDP peer.
By default, upon receiving a new join message, the router does not send an SA request message to any MSDP peer; instead, it waits for the next SA message to come.
Note that before you can enable the device to send SA requests, you must disable the SA message cache mechanism.
# Disable the SA message cache mechanism, and enable the switch to send an SA request message to the MSDP peer 125.10.7.6 upon receiving a new Join message.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 request-sa-enable
1.1.16  peer sa-cache-maximum
peer peer-address sa-cache-maximum sa-limit
undo peer peer-address sa-cache-maximum
View
MSDP view
Default Level
2: System level
sa-limit: Maximum number of (S, G) entries that the device can cache.
Use the peer sa-cache-maximum command to configure the maximum number of (S, G) entries learned from the specified MSDP peer that the device can cache.
Use the undo peer sa-cache-maximum command to restore the default.
By default, the device can cache a maximum of 8,192 (S, G) entries learned from any MSDP peer.
Related commands: display msdp sa-count, display msdp peer-status, display msdp brief.
# Allow the device to cache a maximum of 100 (S, G) entries learned from MSDP peer 125.10.7.6.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-cache-maximum 100
1.1.17  peer sa-policy
peer peer-address sa-policy { import | export } [ acl acl-number ]
undo peer peer-address sa-policy { import | export }
View
MSDP view
Default Level
2: System level
import: Specifies to filter SA messages from the specified MSDP peer.
export: Specifies to filter SA messages forwarded to the specified MSDP peer.
acl-number: Advanced ACL number. If you do not provide an ACL number, all SA messages carrying (S, G) entries will be filtered off.
Use the peer sa-policy command to configure a filtering rule for receiving or forwarding SA messages.
Use the undo peer sa-policy command to restore the default setting.
By default, SA messages received or to be forwarded are not filtered, namely, all SA messages are accepted or forwarded.
In addition to controlling SA message receiving and forwarding by using this command, you can also configure a filtering rule for creating SA messages using the import-source command.
Related commands: display msdp peer-status, import-source.
# Configure a filtering rule so that SA messages will forwarded to MSDP peer 125.10.7.6 only if they match ACL 3100.
[Sysname] acl number 3100
[Sysname-acl-adv-3100] rule permit ip source 170.15.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3100] quit
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-policy export acl 3100
1.1.18  peer sa-request-policy
peer peer-address sa-request-policy [ acl acl-number ]
undo peer peer-address sa-request-policy
View
MSDP view
Default Level
2: System level
acl-number: Basic ACL number. If you provide this argument, the SA requests of only the multicast groups that match the ACL will be accepted and other SA requests will be ignored; if you do not provide this argument, all SA requests will be ignored.
Use the peer sa-request-policy command to configure a filtering rule for SA request messages.
Use the undo peer sa-request-policy command to remove the configured SA request filtering rule.
Be default, SA request messages are not filtered.
# Configure an SA request filtering rule so that SA messages from the MSDP peer 175.58.6.5 will be accepted only if the multicast group address in the SA messages is in the range of 225.1.1.0/24.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] msdp
[Sysname-msdp] peer 175.58.6.5 sa-request-policy acl 2001
1.1.19  reset msdp peer
reset msdp peer [ peer-address ]
View
Default Level
2: System level
peer-address: Specifies an MSDP peer by its address. If you do not provide this argument, the TCP connections with all MSDP peers will be reset.
Use the reset msdp peer command to reset the TCP connection with the specified MSDP peer or the TCP connections with all MSDP peers and clear all the statistics information of the MSDP peer(s).
# Reset TCP connection with the MSDP peer 125.10.7.6 and clear all the statistics information of this MSDP peer.
<Sysname> reset msdp peer 125.10.7.6
1.1.20  reset msdp sa-cache
reset msdp sa-cache [ group-address ]
View
Default Level
2: System level
group-address: Address of the multicast group related to which the (S, G) entries are to be cleared from the SA cache. If you do not provide this argument, the command will clear all the cached (S, G) entries.
Use the reset msdp sa-cache command to clear (S, G) entries from the SA cache.
Related commands: cache-sa-enable, display msdp sa-cache.
# Clear the (S, G) entries related to the multicast group 225.5.4.3 from the SA cache.
<Sysname> reset msdp sa-cache 225.5.4.3
1.1.21  reset msdp statistics
reset msdp statistics [ peer-address ]
View
Default Level
2: System level
peer-address: Specifies an MSDP peer by its address. If you do not provide this argument, the command will clear the statistics information of all MSDP peers.
Use the reset msdp statistics command to clear the statistics information of the specified MSDP peer or all MSDP peers without resetting the MSDP peer(s).
# Clear the statistics information of the MSDP peer 125.10.7.6.
<Sysname> reset msdp statistics 125.10.7.6
1.1.22  shutdown
shutdown peer-address
undo shutdown peer-address
View
MSDP view
Default Level
2: System level
Use the shutdown command to deactivate manually the connection with the specified MSDP peer.
Use the undo shutdown command to reactivate the connection with the specified MSDP peer.
By default, the connections with all MSDP peers are active.
# Deactivate the connection with the MSDP peer 125.10.7.6.
[Sysname] msdp
[Sysname-msdp] shutdown 125.10.7.6
1.1.23  static-rpf-peer
static-rpf-peer peer-address [ rp-policy ip-prefix-name ]
undo static-rpf-peer peer-address
View
MSDP view
Default Level
2: System level
rp-policy ip-prefix-name: Specifies a filtering policy based on the RP address in SA messages, where ip-prefix-name is the filtering policy name, a case-sensitive string of 1 to 19 characters.
Use the static-rpf-peer command to configure a static RPF peer.
Use the undo static-rpf-peer command to remove a static RPF peer.
No static RPF peer is configured by default.
When you configure multiple static RPF peers, observe the following rules:
l           If you use the rp-policy keyword for all the static RPF peers, all the static RPF peers will be activated concurrently. SA messages will be filtered as per the configured prefix list and only those SA messages whose RP addresses pass the filtering will be accepted. If multiple static RPF peers use the same filtering policy at the same time, when a peer receives an SA message, it will forward the SA message to the other peers.
l           If you use the rp-policy keyword for none of the static RPF peers, according to the configuration sequence, only the first static RPF peer whose connection is in the UP state will be activated, and all SA messages from this peer will be accepted while the SA messages from other static RPF peers will be discarded. When this active static RPF peer fails (for example, when the configuration is removed or when the connection is torn down), based on the configuration sequence, the next RPF peer with its connection in the UP state will be selected as the activated RPF peer according to the configuration sequence.
Related commands: display msdp peer-status, ip prefix-list.
# Configure static RPF peers.
[Sysname] ip ip-prefix list1 permit 130.10.0.0 16 great-equal 16 less-equal 32
[Sysname] msdp
[Sysname-msdp] peer 130.10.7.6 connect-interface vlan-interface 4
[Sysname-msdp] static-rpf-peer 130.10.7.6 rp-policy list1
1.1.24  timer retry
timer retry interval
undo timer retry
View
MSDP view
Default Level
2: System level
interval: Interval between MSDP peer connection retries, in seconds.
Use the timer retry command to configure the interval between MSDP peer connection retries.
Use the undo timer retry command to restore the default setting.
By default, the interval between MSDP peer connection retries is 30 seconds.
# Set the MSDP peer connection retry interval to 60 seconds.
[Sysname] msdp
[Sysname-msdp] timer retry 60
