H3C S9500 Operation Manual-Release2132[V2.03]-01 Access Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release2132[V2.03]-01 Access Volume
11-BPDU Tunneling Configuration
11-BPDU Tunneling Configuration 81.84 KB
Chapter 1  BPDU Tunneling Configuration
1.1  Introduction to BPDU Tunneling
1.1.1  Why BPDU Tunneling
To avoid loops in your network, you can enable the spanning tree protocol (STP) on your device. However, STP gets aware of the topological structure of a network by means of bridge protocol data units (BPDUs) exchanged between different devices and the BPDUs are Layer 2 multicast packets, which can be received and processed by all STP-enabled devices on the network. This prevents each network from correctly calculating its spanning tree. As a result, when redundant links exist in a network, data loops will unavoidably occur.
By allowing each network has its own spanning tree while running STP, BPDU tunneling can resolve this problem. It has the following functions:
l           It can isolate BPDUs of different customer networks, so that one network is not affected by others while calculating the topological structure.
l           It enables BPDUs of the same customer network to be multicast over specific VLAN VPNs in the service provider network, so that the same, geographically dispersed customer network can implement consistent spanning tree calculation across the service provider network.
&  Note:
At present, the S9500 series switches only support BPDU tunneling for STP packets (in a broad sense). For description about STP packets in a broad sense, refer to the MSTP Configuration in the Access Volume.
1.1.2  How BPDU Tunneling Works
The BPDU tunneling works implements the following two functions:
l           BPDU isolation
l           BPDU transparent transmission
The work process of IGMP is as follows:
I. BPDU isolation
When a port receives BPDUs of other networks, the port will discard the BPDUs, so that they will not take part in spanning tree calculation. Refer to Configuring BPDU Isolation.
II. BPDU transparent transmission
As shown in Figure 1-1, the upper part is the service provider network, and the lower part represents the customer networks. The customer networks include network A and network B. Enabling the BPDU tunneling function on the edge devices across the service provider network allows BPDUs of the customer networks to be transparently transmitted in the service provider network, and allows each customer network to implement independent spanning tree calculation, without interfering each other. Refer to Configuring BPDU Transparent Transmission.
Figure 1-1 Network hierarchy of BPDU tunneling
The BPDU packet is processed in the service provider network as follows:
l           At the input side of the service provider network, the edge device changes the destination MAC address of a BPDU from a customer network from 0x0180-C200-0000 to a special multicast MAC address, 0x0100-0CCD-CDD0. In the service provider’s network, the modified BPDUs are forwarded as data packets in the user VLAN.
l           At the output side of the service provider network, the edge device recognizes the BPDU with the destination MAC address of 0x0100-0CCD-CDD0 and restores its original destination MAC address 0x0180-C200-0000. Then, the device removes the out-layer VLAN tag, and sends the BPDU to the destination customer network.
&  Note:
Make sure, through configuration, that the VLAN tag of the BPDU is neither changed nor removed during its transparent transmission in the service provider network; otherwise, the system will fail to transparently transmit the customer network BPDU correctly.
1.2  Configuring BPDU Isolation
Perform the following tasks to configure BPDU isolation:
To do...
Use the command...
Remarks
Enter system view
Enable BPDU tunneling globally
bpdu-tunnel dot1q enable
Optional
Enabled by default
The configured BPDU tunneling on a port cannot take effect unless BPDU tunneling is enabled globally.
Enter Ethernet interface view or port group view
Use either command
Configured in Ethernet interface view, the setting is effective on the current port only; configured in port group view, the setting is effective on all ports in the port group
Enter port group view
port-group { manual port-group-name | aggregation agg-id }
Enable BPDU tunneling for the Ethernet port
Required
Disabled by default
&  Note:
l      The BPDU tunneling feature is incompatible with the GVRP feature, so these two features cannot be enabled at the same time. For information about GVRP, refer to GVRP Configuration in the Access Volume.
l      The configured BPDU tunneling on a port cannot take effect unless BPDU tunneling is enabled globally.
1.3  Configuring BPDU Transparent Transmission
Perform the following tasks to configure BPDU transparent transmission:
To do...
Use the command...
Remarks
Enter system view
Optional
Enabled by default
Use either command
Enable BPDU tunneling for the port
Required
Disabled by default
Disable STP for the port
stp disable
Required
Enable STP BPDU tunneling for the port
bpdu-tunnel dot1q stp
Required
Disabled by default
&  Note:
l      BPDU tunneling must be enabled globally before the BPDU tunneling configuration for a port can take effect.
l      The BPDU tunneling feature is incompatible with the GVRP feature, so these two features cannot be enabled at the same time. For introduction to GVRP, refer to GVRP Configuration in the Access Volume.
1.4  BPDU Tunneling Configuration Example
I. Network requirements
l           Customer A, Customer B, Customer C, and Customer D are customer network edge devices.
l           Provider A, Provider B, and Provider C are service provider network edge devices, which are interconnected through configured trunk ports.
The configuration is required to satisfy the following requirements:
l           Geographically dispersed customer networks Customer A, Customer C and Customer D can implement consistent spanning tree calculation across the service provider network.
l           BPDU packets are isolated for the customer network Customer B, so it does not take part in the spanning tree calculation.
II. Network diagram
Figure 1-2 Network diagram for BPDU tunneling configuration
III. Configuration procedure
1)         Configuration on Provider A
# Configure BPDU transparent transmission on Ethernet 1/1/1.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname] interface ethernet 1/1/1
[Sysname-Ethernet1/1/1] port access vlan 2
[Sysname-Ethernet1/1/1] stp disable
[Sysname-Ethernet1/1/1] bpdu-tunnel dot1q enable
[Sysname-Ethernet1/1/1] bpdu-tunnel dot1q stp
2)         Configuration on Provider B
# Configure BPDU isolation on Ethernet 1/1/2.
[Sysname] vlan 4
[Sysname-vlan4] quit
[Sysname] interface ethernet 1/1/2
[Sysname-Ethernet1/2] port access vlan 4
[Sysname-Ethernet1/1/2] undo ntdp enable
[Sysname-Ethernet1/1/2] bpdu-tunnel dot1q enable
3)         Configuration on Provider C
# Configure BPDU transparent transmission on Ethernet 1/1/3.
[Sysname] vlan 2
[Sysname] interface ethernet 1/1/3
[Sysname-Ethernet1/1/3] port access vlan 2
[Sysname-Ethernet1/1/3] stp disable
[Sysname-Ethernet1/1/3] bpdu-tunnel dot1q enable
[Sysname-Ethernet1/1/3] bpdu-tunnel dot1q stp
# Configure BPDU transparent transmission on Ethernet 1/4.
[Sysname-Ethernet1/1/3] quit
[Sysname] interface ethernet 1/1/4
[Sysname-Ethernet1/1/4] port access vlan 2
[Sysname-Ethernet1/1/4] stp disable
[Sysname-Ethernet1/1/4] undo ntdp enable
[Sysname-Ethernet1/1/4] bpdu-tunnel dot1q enable
[Sysname-Ethernet1/1/4] bpdu-tunnel dot1q stp
