H3C S9500 Operation Manual-Release2132[V2.03]-01 Access Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release2132[V2.03]-01 Access Volume
07-Ethernet OAM Configuration
07-Ethernet OAM Configuration 72.08 KB
Chapter 1  OAM Configuration
When configuring the OAM function, go to these sections for information you are interested in:
l           OAM Overview
l           OAM Configuration Task List
l           Configuring Basic OAM Functions
l           Configuring Link Monitoring
l           Enabling OAM Loopback Testing
l           Displaying and Maintaining OAM Configuration
l           OAM Configuration Example
1.1  OAM Overview
Ethernet OAM (operations, administration, and maintenance) is a tool monitoring Layer-2 link status by sending OAM protocol data units (OAMPDUs) between devices. It helps network administrators manage their networks effectively.
Currently, Ethernet OAM is mainly used to address common link-related issues on the “last mile.” By enabling Ethernet OAM on two devices connected by a point-to-point connection, you can monitor the status of the link. Ethernet OAM provides the following functions:
l           Link performance monitoring, for detecting link errors
l           Fault detection and alarm, for reporting link errors to the administrators
l           Loopback testing, for detecting link errors through non-OAMPDUs
1.1.1  Types of OAMPDUs
Figure 1-1 shows the format of different types of OAMPDUs.
Figure 1-1 The format of different types of OAMPDUs
The fields in an OAMPDU are described as follows.
Table 1-1 Description of the fields in an OAMPDU
Value
Dest addr
Destination MAC address of the Ethernet OAMPDU
Multicast MAC address 0180c2000002
Source addr
Source MAC address of the Ethernet OAMPDU
The bridge MAC address of the sending side
Type of the encapsulated protocol in the Ethernet OAMPDU
0x8809
Subtype
The specific protocol being encapsulated in the Ethernet OAMPDU
0x03
Flags
Information about an Ethernet OAM entity
Code
Type of the Ethernet OAMPDU
0x00: Information OAMPDU
0x01: Event notification OAMPDU
0x04: Loopback control OAMPDU
As mentioned above, Information OAMPDUs, Event Notification OAMPDUs, and Loopback control OAMPDUs are commonly used, which are described as follows.
l           Information OAMPDUs are used for passing the state information about an Ethernet OAM entity (including the information about the local device and remote devices, and customized information) to another Ethernet OAM entity and maintain OAM connections.
l           Event notification OAMPDUs are used for link monitoring. They are sent as an alarm in case a failure occurs to the link connecting the local OAM entity and a remote OAM entity.
l           Loopback control OAMPDUs are used for remote loopback control. By the information in a Loopback control OAMPDU, you can enable/disable loopback on a remote OAM entity.
1.1.2  OAM Connection Establishment
Following are the four OAM functions.
l           OAM connection establishment
l           Link monitoring
l           Remote fault detection
l           Remote loopback testing
Note that OAM connection is the base of all the other Ethernet OAM functions.
I. OAM connection establishment
OAM connection establishment is also known as the Discovery phase, where an OAM entity discovers other OAM entities and sessions between OAM entities are established.
In this phase, interconnected OAM entities notify the peer of their OAM configuration information and the OAM capabilities of the local nodes to support OAM by exchanging Information OAMPDUs and determine whether OAM connections can be established. An OAM connection can be established only when the settings concerning Loopback, link detecting, and link event of the both side match. After an OAM connection is established, OAM takes effect on it.
As for OAM connection establishment, a device can operate in two modes: active OAM mode and passive OAM mode. Only devices operating in active OAM mode can initiate OAM connection establishment processes. Those operating in passive OAM mode, however, wait and respond to OAM connection establishment requests and take corresponding operations. The following table compares active OAM mode with passive OAM mode.
Item
Active OAM mode
Passive OAM mode
Initiating OAM Discovery
Available
Unavailable
Responding to OAM Discovery
Available
Available
Transmitting Information OAMPDUs
Available
Available
Transmitting Event Notification OAMPDUs
Available
Available
Transmitting Information OAMPDUs with the Data/Pad field being empty
Available
Available
Transmitting Loopback Control OAMPDUs
Available
Unavailable
Responding to Loopback Control OAMPDUs
Available (if both sides operate in active OAM mode)
Available
Transmitting organization-specific OAMPDUs
Available
Available
After an OAM connection is established, the OAM entities on both sides exchange Information OAMPDUs periodically to keep the OAM connection valid. If an OAM entity receives no Information OAMPDU for five seconds, the OAM connection is considered invalid. In this case, to enable the OAM entities to communicate with each other again, a new OAM connection is required.
The interval to send Information OAMPDUs is determined by a timer. Up to ten Information OAMPDUs can be sent in a second.
II. Link monitoring
Link monitoring is used to detect and locate link faults in various environments. In OAM, link faults are categorized into link events. OAM implements link monitoring through the exchange of Event Notification OAMPDUs. Upon detecting a link fault, the local device sends an Event Notification OAMPDU to the remote OAM entity to report the fault event. With the log information, network administrators can keep track of network status in time. The following table describes the link events.
OAM link events
Error symbol event
An error signal event occurs when the number of detected signal errors over a specific detection interval exceeds the threshold.
Error frame event
An error frame event occurs when the number of detected error frames over a specific interval exceeds the threshold.
Error frame period event
An error frame period event occurs if the number of frame errors in specific number of received frames exceeds the threshold
Error frame seconds event
When the number of error frame seconds detected on a port over a detection interval reaches the error threshold, an error frame seconds event occurs.
(Error frame seconds are the seconds within which error frames are detected.)
III. Remote fault detection
Error detection in an Ethernet is difficult, especially when the physical connection in the network is not interrupted but network performance degrades gradually. The flag field defined in OAMPDUs allows an OAM entity to send error information to its peer. It can identify the following link faults.
l           Link Fault: Peer link signal is lost.
l           Dying Gasp: An unexpected fault, such as power failure, occurred.
l           Critical Event: An undetermined critical event happened.
As Information OAMPDUs are sent periodically across OAM connections, an OAM entity can inform one of its OAM peers of link faults through Information OAMPDUs. Therefore, the network administrator can keep track of link status in time through the log information and troubleshoot in time.
&  Note:
l      Currently, the S9500 series only support link fault detection.
l      If the receiving optical fiber of the local end is broken, only a 10 GE optical interface reports the link signal loss.
l      The LSB1XK1 series cards and XP4B/CA-type cards do not support the OAM unidirectional link events.
IV. Remote loopback testing
Remote loopback testing is available only after the OAM connection is established. With remote loopback enabled, the OAM entity operating in active OAM mode issues remote loopback requests and the peer responds to them. If the peer operates in the loopback mode, it returns all the PDUs to the senders along the original paths.
Performing remote loopback testing periodically helps to detecting network faults in time. Furthermore, performing remote loopback testing by network segments helps to locate network faults.
&  Note:
Currently, on an S9500 series switch, you can perform remote loopback only on Gigabit electrical interfaces.
1.1.3  OAM Standards
OAM is defined in IEEE 802.3h.
1.2  OAM Configuration Task List
Complete the following tasks to configure OAM:
Remarks
Required
Optional
Optional
1.3  Configuring Basic OAM Functions
Follow the following steps to configure basic OAM functions:
To do…
Use the command…
Remarks
Enter system view
Enter Ethernet port view
Set OAM operating mode
oam mode { active | passive }
Optional
The default is active OAM mode.
Enable OAM on the current port
oam enable
Required
OAM is disabled by default.
After OAM is enabled, the OAM entity tries to establish OAM connection with its peer.
&  Note:
l      OAM connections can be initiated only by OAM entities operating in active OAM mode, while those operating in passive mode wait and respond to the connection requests sent by their peers.
l      No OAM connection can be established between two OAM entities operating in passive OAM mode.
l      With OAM enabled, you cannot change the OAM operating mode. To do so, you need to disable OAM first.
1.4  Configuring Link Monitoring
Follow these steps to configure the error detection intervals and the error event triggering thresholds that OAM uses for link monitoring:
To do…
Use the command…
Remarks
Enter system view
Configure the error symbol detection interval
oam errored-symbol period period-value
Optional
The default is one second.
Configure the error symbol event triggering threshold for an error symbol detection interval
oam errored-symbol threshold threshold-value
Optional
The default is 1.
Configure the error frame detection interval
oam errored-frame period period-value
Optional
Configure the error frame event triggering threshold
oam errored-frame threshold threshold-value
Optional
The default is 1.
Configure the error frame period detection interval
oam errored-frame-period period period-value
Optional
The default is 1,000 milliseconds.
Configure the error frame period event triggering threshold
oam errored-frame-period threshold threshold-value
Optional
The default is 1.
Configure the error frame second detection interval
oam errored-frame-seconds period period-value
Optional
The default is 60 seconds.
Configure the error frame seconds event triggering threshold
oam errored-frame-seconds threshold threshold-value
Optional
The default is 1.
This threshold value should not be greater than the corresponding detection interval; otherwise, no error frame second event can be created.
To save bandwidth, you can configure OAM to report an error event when the number of errors detected over a specified interval reaches a threshold rather than when an error is detected. For more information about the link monitoring commands in this section, refer to Ethernet OAM Commands in the accompanied command manual.
&  Note:
l      For the LSB1GV48DB0 board on an S9500 series switch, gap may exist between the number of detected error frame seconds and the actual number of error frame seconds over a detection interval due to the detection frequency restriction. The same is true of error frame detection.
l      For the LSB1GV48DB0 board on an S9500 series switch, you are recommended to set the error frame period detection interval to a value equal to or greater than 2000 ms, considering the restriction of the board on detection frequency.
1.5  Enabling OAM Loopback Testing
Follow the following steps to enable OAM loopback testing:
To do…
Use the command…
Remarks
Enter system view
Enable OAM loopback testing
oam loopback
Required
Disabled by default.
&  Note:
l      OAM loopback testing is available only after the OAM connection is established.
l      OAM loopback testing can be performed by OAM entities operating in the active OAM mode only.
l      OAM loopback testing is available only on full-duplex links.
l      OAM loopback testing needs the support of the peer hardware.
l      OAM loopback testing is only applicable to individual links. It is not applicable to aggregation links. So when performing OAM loopback testing, make sure none of the ports involved belongs to an aggregation group.
l      Enabling OAM loopback testing results in all the data communications being stopped. After OAM loopback testing is disabled, all the ports involved will be shut down and then brought up.
l      OAM loopback testing is disabled when you execute the undo oam enable command to disable OAM; when you execute the undo oam loopback command to disable OAM loopback testing; or when the OAM connection is timed out.
1.6  Displaying and Maintaining OAM Configuration
To do…
Use the command…
Remarks
Display global OAM configuration
display oam configuration
Available in any view
Display the statistics on critical events after an OAM connection is established
display oam critical-event [ interface interface-type interface-number ]
Display the statistics on OAM link error events after an OAM connection is established or after you clear the statistics
display oam link-event { local | remote } [ interface interface-type interface-number ]
Display the information about an OAM connection
display oam { local | remote } [ interface interface-type interface-number ]
Clear statistics on OAM packets and OAM link error events
reset oam [ interface interface-type interface-number ]
Available in user view only
1.7  OAM Configuration Example
I. Network requirements
l           Enable OAM on Switch A and Switch B to manage links on data link layer.
l           Monitor link performance and collect statistics about the error frames received by Switch A.
II. Network diagram
Figure 1-2 Network diagram for OAM configuration
III. Configuration procedure
1)         Configure Switch A
# Configure Ethernet 4/1/2 to operate in passive OAM mode and enable OAM for it.
[Sysname] interface ethernet 4/1/2
[Sysname-Ethernet4/1/2] oam mode passive
[Sysname-Ethernet4/1/2] oam enable
[Sysname-Ethernet4/1/2] quit
# Set the period for error frame event detection to 20 seconds.
[Sysname] oam errored-frame period 20
# Set the threshold for error frame event detection to 10.
[Sysname] oam errored-frame threshold 10
# Display global OAM configuration.
[Sysname] display oam configuration
Configuration of the errored symbol/frame event window/threshold :
Errored-symbol Event period           :     1
Errored-symbol Event threshold        :     1
Errored-frame Event period            :     20
Errored-frame Event threshold         :     10
Errored-frame-period Event period     :     1000
Errored-frame-period Event threshold  :     1
Errored-frame-seconds Event period    :     60
Errored-frame-seconds Event threshold :     1
2)         Configure Switch B
# Configure Ethernet 4/1/2 to operate in active OAM mode (the default OAM mode) and enable OAM for it.
# Display OAM link error event statistics.
[Sysname] display oam link-event remote
Port :Ethernet4/1/2
Link Status :Up
OAMRemoteErrFrameEvent : (ms = milliseconds)
Event Time Stamp          : 5789        Errored FrameWindow   : 10(100ms)
Errored Frame Threshold   : 1           Errored Frame         : 3
Error Running Total       : 35          Event Running Total   : 17
The above information indicates that 35 errors occurred since OAM is enabled on Switch A, 17 of which are caused by error frames. The link is instable.
