H3C S9500 Operation Manual-Release2132[V2.03]-01 Access Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release2132[V2.03]-01 Access Volume
10-QinQ Configuration
10-QinQ Configuration 151.4 KB
Chapter 1  QinQ Configuration
When configuring QinQ, go to these sections for information you are interested in:
l           QinQ Configuration
l           Configuring Basic QinQ
l           Setting TPID Value for QinQ Frames
l           QinQ Configuration Examples
1.1  Introduction to QinQ
1.1.1  Understanding QinQ
In the VLAN tag field defined in IEEE 802.1Q, only 12 bits are used for VLAN IDs, so a device can support a maximum of 4,094 VLANs. This is far from enough for isolating users in actual networks like metropolitan area networks (MANs).
QinQ is a simple and flexible Layer-2 VPN technology. It allows packets to be transmitted with double VLAN tags, allowing for up to 4094 × 4094 VLANs, thus satisfying the demand for large amount of VLANs in MANs.
QinQ encapsulates the private network VLAN tag in the public network VLAN tag, and enables the frame to be transmitted through the service provider backbone network (the public network) with double VLAN tags. The inner VLAN tag is the customer network VLAN tag while the outer one is the VLAN tag assigned by the service provider to the customer. In the public network, switches forward tagged frames based on the outer VLAN tag without checking the inner tag.
&  Note:
l      To implement QinQ, configuration is required on devices in the service provider network only.
l      The QinQ feature is implemented based on the 802.1q standard, so it is necessary that all the devices along the tunnel support the 802.1q standard.
Figure 1-1 shows the structure of a single-tagged frame and a double-tagged frame.
Figure 1-1 Single-tagged frame structure vs. double-tagged Ethernet frame structure
QinQ delivers these benefits:
l           Saving public network VLAN ID resources.
l           Enabling customers to plan their own private network VLAN IDs, without running into conflicts with public network VLAN IDs.
l           Providing simple Layer 2 VPN solutions for small-sized MANs or Enterprise networks.
1.1.2  Implementations of QinQ
For S9500 series switches, the QinQ feature is implemented through enabling the basic QinQ feature on ports.
With the basic QinQ feature enabled on a port, when a frame arrives at the port, the port will tag it with the port’s default VLAN tag, regardless of whether the frame is tagged or untagged. If the received frame is already tagged, this frame becomes a double-tagged frame; if it is an untagged frame, it is tagged with the port’s default VLAN tag.
1.1.3  Adjustable TPID Value of QinQ Frames
A VLAN tag uses the tag protocol identifier (TPID) field to identify the protocol type of the tag. The value of this field, as defined in IEEE 802.1Q, is 0x8100.
Figure 1-2 shows the structure of a VLAN-tagged Ethernet frame defined in IEEE 802.1Q.
Figure 1-2 Structure of a VLAN-tagged Ethernet frame
&  Note:
Refer to VLAN Configuration in the Access Volume for the description on the TPID, Priority, CFI, and VLAN ID fields.
On devices of different vendors, the TPID of the outer VLAN tag in QinQ frames may have different default values. For interoperability with other vendors’ devices, you are allowed to modify the TPID value in a QinQ frame so that the frame carries the TPID value of the specific vendor on the public network.
The TPID in an Ethernet frame has the same position with the protocol type field in a frame without a VLAN tag. To avoid chaotic packet forwarding and receiving, you cannot set the TPID value to any of the values in the table below.
Table 1-1 Protocol type values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86DD
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
802.1x
0x888E
Cluster
0x88A7
Reserved
0xFFFD/0xFFFE/0xFFFF
1.2  Configuring Basic QinQ
Follow these steps to configure basic QinQ:
To do...
Use the command...
Remarks
Enter system view
Enter Ethernet interface view or port group view
Use either command
Configured in Ethernet interface view, the setting is effective on the current port only; configured in port group view, the setting is effective on all ports in the port group
Enter interface group view
port-group { manual port-group-name | aggregation agg-id }
Enable the basic QinQ function for the Ethernet port or the port group
qinq enable
Required
Disabled by default.
  Caution:
l      The basic QinQ function must be enabled on ports (of devices in the service provider network) with customer networks connected to them.
l      As basic QinQ function affects layer-3 packet forwarding and MPLS switching, do not enable layer-3 packet forwarding or MPLS switching on ports with basic QinQ function enabled.
l      Enabling basic QinQ on a port may invalidate the QoS policy applied to the port.
l      Do not enable QinQ on a reflector port configured for port mirroring.
1.3  Setting TPID Value for QinQ Frames
Follow these steps to set the TPID value for QinQ frames:
To do...
Use the command...
Remarks
Enter system view
Use either command
Enter port group view
Set the TPID value in the outer VLAN tag that the port adds to frames
qinq ethernet-type hex-value
Optional
0x8100 by default
  Caution:
l      Perform the above configuration on ports (of devices in the service provider network) with customer networks connected to them.
l      The qinq ethernet-type command needs to be coupled with the qinq enable command.
l      Currently, the ports on LSB1XP4B and LSB1XP4CA boards do not support setting TPID.
1.4  QinQ Configuration Examples
I. Network requirements
l           Provider A and Provider B are service provider network access devices.
l           Customer A and Customer B are customer network access devices.
l           Provider A and Provider B, belonging to VLAN 10 created in the service provider network, are interconnected through trunk ports.
l           In between Provider A and Provider B are devices with the TPID being 0x8200.
It is required that Customer A and Customer B can communicate with each other across the service provider network.
II. Network diagram
Figure 1-3 Network diagram for QinQ configuration
III. Configuration procedure
1)         Configuration on Provider A
# Enter system view.
[Sysname] vlan 10
[Sysname-vlan10] quit
# Enter Ethernet 1/1/2 port view.
[Sysname] interface ethernet 1/1/2
[Sysname-Ethernet1/1/2] port access vlan 10
# Enable the basic QinQ function on Ethernet 1/1/2.
[Sysname-Ethernet1/1/2] qinq enable
[Sysname-Ethernet1/1/2] quit
# Configure Ethernet 1/1/4 as a trunk port and configure the port to permit frames of VLAN 10.
[Sysname] interface ethernet 1/1/4
[Sysname-Ethernet1/1/4] port link-type trunk
[Sysname-Ethernet1/1/4] port trunk permit vlan 10
# Set the TPID value of Ethernet 1/1/4 to 0x8200 to ensure that Provider A can communicate with the other devices in the service provider network.
[Sysname-Ethernet1/1/4] qinq ethernet-type 8200
2)         Configuration on Provider B
[Sysname] vlan 10
After the above configuration finishes, Customer A and Customer B should be able to exchange frames across the service provider network to communicate with other.
