00-1Cover | 65.57 KB |
H |
Installation Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h Manual Version:
T2-20080526-C-1.07 |
Copyright © 2006-2008, Hangzhou H
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, ,
Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G,
VnG, PSPT, XGbus,
N-Bus, TiGem, InnoVision and
HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
http://www. h3c.com
About This Manual
Related Documentation
In addition
to this manual, each H
Manual |
H |
It is used for assisting the users in data configurations and typical applications. |
H |
It is used for assisting the users in using various commands. |
Organization
H
Chapter |
Contents |
1 Product Overview |
Introduces the characteristics and technical specifications of S3610 Series Ethernet Switches. |
2 Installation Preparation |
Introduces the installation preparation and precaution of S3610 Series Ethernet Switches. |
3 Installing the Switch |
Introduces the procedures to install an S3610 Series Ethernet Switch, including the setup of the mainframe, cards and cables. |
4
Starting up the Switch at the Initial Boot |
Introduces the booting process of an S3610 Series
Ethernet Switch, including the power-on booting of the switch and the system
initialization. |
5
Loading Boot ROM and Host Software |
Introduces how to load Boot ROM and host
software for an S3610 Series Ethernet Switch. |
6
Maintenance and Troubleshooting |
Introduces the problems that might occur during the installation
and the booting of an
S3610 Series Ethernet Switch and the related
solution. |
Introduces
the optional interface modules supported by S3610 Series Ethernet Switch. |
Appendix
A Lightning Protection of the Switch |
Introduces lightning protection of S3610 Series
Conventions
The manual uses the following conventions:
I. Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped
in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and
separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
II. GUI conventions
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square
brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
III. Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or
damage to equipment. |
& Note |
Means a complementary description. |
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
