H3C S9500 Series Routing Switches Command Manual-(V1.01)
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Series Routing Switches Command Manual-(V1.01)
06-Multicast Protocol Command
06-Multicast Protocol Command 431 KB
Table of Contents
Chapter 1 IGMP Snooping Configuration Commands. 1-1
1.1 IGMP Snooping Configuration Commands. 1-1
1.1.1 debugging mpm.. 1-1
1.1.2 display igmp-snooping configuration. 1-2
1.1.3 display igmp-snooping group. 1-2
1.1.4 display igmp-snooping statistics. 1-3
1.1.5 igmp-snooping. 1-4
1.1.6 igmp-snooping fast-leave. 1-6
1.1.7 igmp-snooping group-policy. 1-9
1.1.8 igmp-snooping host-aging-time. 1-10
1.1.9 igmp-snooping max-response-time. 1-10
1.1.10 igmp-snooping nonflooding-enable. 1-11
1.1.11 igmp-snooping router-aging-time. 1-12
1.1.12 reset igmp-snooping statistics. 1-12
1.2 Multicast Static Routing Port Configuration Commands. 1-13
1.2.1 igmp-snooping mrouter port 1-13
1.2.2 igmp-snooping mrouter vlan. 1-14
Chapter 2 Multicast VLAN Configuration Commands. 2-1
2.1 Multicast VLAN Configuration Commands. 2-1
2.1.1 service-type multicast 2-1
Chapter 3 Multicast Common Configuration Commands. 3-1
3.1 Multicast Common Configuration Commands. 3-1
3.1.1 broadcast-suppression. 3-1
3.1.2 debugging multicast forwarding. 3-2
3.1.3 debugging multicast kernel-routing. 3-3
3.1.4 debugging multicast status-forwarding. 3-3
3.1.5 display mpm forwarding-table. 3-4
3.1.6 display mpm group. 3-5
3.1.7 display multicast forwarding-table. 3-7
3.1.8 display multicast routing-table. 3-9
3.1.9 ip managed-multicast 3-11
3.1.10 local-user multicast 3-11
3.1.11 multicast 3-12
3.1.12 multicast route-limit 3-13
3.1.13 multicast routing-enable. 3-14
3.1.14 multicast-suppression. 3-15
3.1.15 reset multicast forwarding-table. 3-16
3.1.16 reset multicast routing-table. 3-17
Chapter 4 IGMP Configuration Commands. 4-1
4.1 IGMP Configuration Commands. 4-1
4.1.1 debugging igmp. 4-1
4.1.2 display igmp group. 4-1
4.1.3 display igmp interface. 4-2
4.1.4 igmp enable. 4-4
4.1.5 igmp fast-leave. 4-5
4.1.6 igmp group-limit 4-7
4.1.7 igmp group-policy. 4-8
4.1.8 igmp host-join port 4-9
4.1.9 igmp host-join vlan. 4-9
4.1.10 igmp lastmember-queryinterval 4-10
4.1.11 igmp max-response-time. 4-11
4.1.12 igmp robust-count 4-12
4.1.13 igmp timer other-querier-present 4-12
4.1.14 igmp timer query. 4-13
4.1.15 igmp version. 4-14
4.1.16 reset igmp group. 4-15
4.2 IGMP Proxy Configuration Commands. 4-15
4.2.1 igmp proxy. 4-15
Chapter 5 PIM Configuration Commands. 5-1
5.1 PIM Configuration Commands. 5-1
5.1.1 bsr-policy. 5-1
5.1.2 c-bsr 5-2
5.1.3 c-rp. 5-3
5.1.4 crp-policy. 5-4
5.1.5 debugging pim common. 5-5
5.1.6 debugging pim dm.. 5-6
5.1.7 debugging pim sm.. 5-7
5.1.8 display pim bsr-info. 5-8
5.1.9 display pim interface. 5-8
5.1.10 display pim neighbor 5-10
5.1.11 display pim routing-table. 5-11
5.1.12 display pim rp-info. 5-12
5.1.13 pim.. 5-13
5.1.14 pim bsr-boundary. 5-14
5.1.15 pim dm.. 5-15
5.1.16 pim neighbor-limit 5-16
5.1.17 pim neighbor-policy. 5-16
5.1.18 pim sm.. 5-17
5.1.19 pim timer hello. 5-18
5.1.20 register-policy. 5-19
5.1.21 reset pim neighbor 5-20
5.1.22 reset pim routing-table. 5-20
5.1.23 source-policy. 5-21
5.1.24 static-rp. 5-22
Chapter 6 MSDP Configuration Commands. 6-1
6.1 MSDP Configuration Commands. 6-1
6.1.1 cache-sa-enable. 6-1
6.1.2 debugging msdp. 6-2
6.1.3 display msdp brief 6-2
6.1.4 display msdp peer-status. 6-3
6.1.5 display msdp sa-cache. 6-4
6.1.6 display msdp sa-count 6-5
6.1.7 import-source. 6-5
6.1.8 msdp. 6-6
6.1.9 msdp-tracert 6-7
6.1.10 originating-rp. 6-9
6.1.11 peer 6-10
6.1.12 peer description. 6-11
6.1.13 peer mesh-group. 6-11
6.1.14 peer minimum-ttl 6-12
6.1.15 peer request-sa-enable. 6-13
6.1.16 peer sa-cache-maximum.. 6-13
6.1.17 peer sa-policy. 6-14
6.1.18 peer sa-request-policy. 6-15
6.1.19 reset msdp peer 6-16
6.1.20 reset msdp sa-cache. 6-17
6.1.21 reset msdp statistics. 6-17
6.1.22 shutdown. 6-18
6.1.23 static-rpf-peer 6-18
6.1.24 timer retry. 6-19
Chapter 7 MBGP Multicast Extension Configuration Commands. 7-1
7.1 MBGP Multicast Extension Configuration Commands. 7-1
7.1.1 aggregate. 7-1
7.1.2 compare-different-as-med. 7-2
7.1.3 debugging bgp mp-update. 7-3
7.1.4 default local-preference. 7-3
7.1.5 default med. 7-4
7.1.6 display bgp multicast group. 7-5
7.1.7 display bgp multicast network. 7-5
7.1.8 display bgp multicast peer 7-6
7.1.9 display bgp multicast routing-table. 7-6
7.1.10 display bgp multicast routing-table as-path-acl 7-7
7.1.11 display bgp multicast routing-table cidr 7-7
7.1.12 display bgp multicast routing-table community. 7-8
7.1.13 display bgp multicast routing-table community-list 7-8
7.1.14 display bgp multicast routing-table different-origin-as. 7-9
7.1.15 display bgp multicast routing-table peer 7-9
7.1.16 display bgp multicast routing-table regular-expression. 7-10
7.1.17 filter-policy export 7-10
7.1.18 filter-policy import 7-11
7.1.19 import-route. 7-12
7.1.20 ipv4-family multicast 7-13
7.1.21 network. 7-14
7.1.22 peer advertise-community. 7-14
7.1.23 peer allow-as-loop. 7-15
7.1.24 peer as-path-acl export 7-16
7.1.25 peer as-path-acl import 7-17
7.1.26 peer enable. 7-17
7.1.27 peer filter-policy export 7-18
7.1.28 peer filter-policy import 7-19
7.1.29 peer group. 7-20
7.1.30 peer ip-prefix export 7-21
7.1.31 peer ip-prefix import 7-21
7.1.32 peer next-hop-local 7-22
7.1.33 peer public-as-only. 7-23
7.1.34 peer reflect-client 7-24
7.1.35 peer route-policy export 7-24
7.1.36 peer route-policy import 7-25
7.1.37 preference. 7-26
7.1.38 reflect between-clients. 7-27
7.1.39 refresh bgp multicast 7-27
7.1.40 reflector cluster-id. 7-28
7.1.41 summary. 7-29
1.1.1  debugging mpm
debugging mpm { abnormal | all | event | forward | groups | packets | timer }
undo debugging mpm { abnormal | all | event | forward | groups | packets | timer }
View
Parameter
abnormal: Enables IGMP snooping abnormal debugging
all: Turns on all IGMP snooping debugging switches
events: Enables IGMP snooping events debugging
forward: Enables IGMP snooping forwarding debugging
groups: Enables IGMP snooping multicast groups debugging
packets: Enables IGMP snooping packets debugging
timers: Enables IGMP snooping timers debugging
Use the debugging mpm command to enable IGMP snooping debugging. Use the undo debugging mpm to disable IGMP snooping debugging.
By default, IGMP snooping debugging is disabled.
Example
# Enable IGMP snooping timers debugging.
<H3C> debugging mpm timers
MPM timers debugging switch is on.
View
Parameter
None
Use the display igmp-snooping configuration command to view the IGMP Snooping configuration information.
When IGMP Snooping is enabled, the information displayed includes whether IGMP Snooping is enabled, router port aging time, maximum response time of a query, multicast group port aging time, and whether unknown multicast packets are disabled from flooding within VLANs.
Related command: igmp-snooping.
Example
# Display the IGMP Snooping configuration information of the switch.
<H3C> display igmp-snooping configuration
Enable IGMP-Snooping.
The router port timeout  is 105 second(s).
The max response timeout is 1 second(s).
The host port timeout is 260 second(s).
Enable IGMP-Snooping Non-Flooding.
The information above tells us that: IGMP Snooping is enabled; the router port aging time is set to be 105 seconds; the max response time of a query is set to be 1 seconds; the aging time of a multicast group member is set to be 260 seconds. Non-broadcasting of unknown multicast data packets in a VLAN is enabled.
display igmp-snooping group [ vlan vlan-id ]
View
Parameter
vlan vlan-id: Specifies the VLAN where the multicast group to be viewed is located. When the parameter is omitted, the command will display the information about all the multicast groups on the VLAN.
Use the display igmp-snooping group command to view the IP multicast group and MAC multicast group information of a VLAN or all the VLAN where the Ethernet switch is located. It displays the information such as VLAN ID, router port, IP multicast group address, member ports in the IP multicast group, MAC multicast group, MAC multicast group address, and the member ports in the MAC multicast group.
Example
# Display the multicast group information about VLAN2.
<H3C> display igmp-snooping group vlan 2
***************Multicast group table***************
Vlan(id):2.
Router port(s):Ethernet3/1/1
IP group(s):the following ip group(s) match to one mac group.
IP group address:230.45.45.1
Member port(s):Ethernet3/1/12
MAC group(s):
MAC group address:01-00-5e-2d-2d-01
We can know from the information listed above that:
l           There is a multicast group in VLAN 2;
l           The router port is Ethernet 2/1/1;
l           The IP multicast group address is 230.45.45.1;
l           The member of the IP multicast group is Ethernet 2/1/2;
l           MAC multicast group is 0100-5e2d-2d01;
l           The member of the MAC multicast group is Ethernet 2/1/2.
View
Parameter
None
Use the display igmp-snooping statistics command to view the statistics information on IGMP Snooping.
This command displays the information such as the number of received general IGMP query packets, received IGMP group-specific query packets, received IGMP v1 packets, received IGMP v2 packets, received IGMP leave packets and error packets, and sent IGMP group-specific query packets.
Example
# Display statistics information about IGMP Snooping.
<H3C> display igmp-snooping statistics
Received IGMP general query packet(s) number:0.
Received IGMP specific query packet(s) number:0.
Received IGMP V1 report packet(s) number:0.
Received IGMP V2 report packet(s) number:0.
Received IGMP leave packet(s) number:0.
Received error IGMP packet(s) number:0.
Sent IGMP specific query packet(s) number:0.
The information above shows that:
IGMP Snooping receives:
l           0 IGMP general query packets
l           0 IGMP group-specific query packets
l           0 IGMP v1 report packets
l           0 IGMP v2 report packets
l           0 IGMP leave packets
l           o IGMP error packets
IGMP Snooping sends:
1.1.5  igmp-snooping
igmp-snooping { enable | disable }
View
System view, VLAN view
Parameter
enable: Enables IGMP Snooping.
disable: Disables IGMP Snooping;
Use the igmp-snooping enable command to enable IGMP Snooping.
Use the igmp-snooping disable command to disable IGMP Snooping.
By default, the switch disables IGMP Snooping.
  Caution:
l      When configuring IGMP Snooping, first enable global IGMP Snooping in system view, and then enable IGMP Snooping in VLAN view. Otherwise the IGMP Snooping function will not take effect.
l      If the VLAN VPN is enabled on a port, the IGMP Snooping feature cannot be enabled on the VLAN for the port or the IGMP feature cannot be enabled on the corresponding VLAN interface.
l      If IGMP Snooping feature is enabled on a VLAN, or IGMP is enabled on the VLAN interface, you cannot add the member port on which VLAN VPN is enabled into the VLAN.
l      Isolate-user-VLAN supports the IGMP-Snooping function. After IGMP-Snooping is enabled under isolate-user-VLAN, all secondary VLANs are IGMP-Snooping enabled. It makes no sense to enable IGMP-Snooping for a secondary VLAN.
l      In a secondary VLAN, IGMP packets will be directly converted and processed in isolate-user-VLAN, namely all the multicast services are implemented within isolate-user-VLAN.
l      Ports in secondary VLANs cannot be used as source addresses of multicast.
Example
# Enable IGMP Snooping in system view.
<H3C> system-view
[H3C] igmp-snooping enable
# Enable IGMP Snooping on VLAN 10
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] igmp-snooping enable
igmp-snooping fast-leave [ vlan { vlan-id [ to vlan-id ] }&<1-10> ]
undo igmp-snooping fast-leave [ vlan { vlan-id [ to vlan-id ] } &<1-10> ]
View
System view, Ethernet port view
Parameter
vlan { vlan-id [ to vlan-id ] }&<1-10>: Specifies any VLAN or VLAN scope for port you want to enable/disable the IGMP Snooping fast leave feature on. The vlan-id argument ranges from 1 to 4094.
Use the igmp-snooping fast-leave command to enable IGMP Snooping fast leave on ports or VLANs.
Use the undo igmp-snooping fast-leave command to disable IGMP Snooping fast leave.
An IGMP Snooping-enabled Layer 2 switch directly removes a fast leave–enabled port from the list of member ports of the multicast group when the port receives a leave packet. That is, the switch peels off the port from the multicast group immediately and does not forward multicast data to the port any longer.
You can optionally specify multiple vlan keywords for the igmp-snooping fast-leave command, through which you can enable IGMP Snooping fast leave in corresponding VLANs. If you do not specify the vlan keyword, IGMP Snooping fast leave is enabled in all VLANs. As mentioned earlier, the igmp-snooping fast-leave command can be executed in both system view and Ethernet port view. When you execute the command in system view, fast leave is enabled on all ports of the specified VLANs, otherwise, it is only enabled on the current port in the specified VLANs.
&  Note:
l      Fast leaves that are configured in system view and Ethernet port view operate separately.
l      Fast leave works on all ports of the specified VLANs if you configure it in system view. However, it only works on the current port (e.g., a port operates as a trunk of multiple VLANs) in the specified VLANs if you configure it in Ethernet port view.
  Caution:
l      Fast leave configured for a port takes effect only when the VLAN it belongs to is IGMP Snooping-enabled.
l      Fast leave does not work if the corresponding specified VLANs do not exist, the port does not belongs to any of the specified VLANs, or the VLANs do not have IGMP Snooping enabled.
l      A newly configured IGMP Snooping clears all existing fast leave configurations.
l      The igmp-snooping fast-leave command is useless if you do not enable IGMP Snooping globally. (You can enable IGMP Snooping globally by executing the igmp-snooping enable command in system view.)
l      When you configure IGMP Snooping fast leave on aggregation ports, the configuration takes effect only on primary aggregation ports.
l      If you add an IGMP V1 host of the same multicast group to the port, the switch does not remove the port when the port receives an IGMP Leave packet of the multicast group even you enable IGMP Snooping fast leave for the port.
Fast leave is disabled by default.
Example
# Enable IGMP Snooping fast leave on the Ethernet2/1/1 port in VLAN 5 only.
<H3C> system-view
[H3C] interface Ethernet2/1/1
[H3C-Ethernet2/1/1] igmp-snooping fast-leave vlan 5
# Enable IGMP Snooping fast leave on the Ethernet2/1/1 port in VLAN 5, VLAN 7, VLAN 8, VLAN 30 through VLAN 40, VLAN 50, VLAN 55, VLAN 60, and VLAN 61.
<H3C> system-view
[H3C-Ethernet2/1/1] igmp-snooping fast-leave vlan 5 7 to 8 30 to 40 50 55 60 to 61
# Enable IGMP Snooping fast leave on the Ethernet2/1/1 port in all VLANs.
<H3C> system-view
[H3C]interface Ethernet2/1/1
# Enable IGMP Snooping fast leave on the Ethernet2/1/1 port in all VLANs. Then disable the feature in VLAN 3.
<H3C> system-view
[H3C-Ethernet2/1/1] undo igmp-snooping fast-leave vlan 3
# Disable IGMP Snooping fast leave on the Ethernet2/1/1 port in all VLANs.
<H3C> system-view
# Enable IGMP Snooping fast leave on all Ethernet ports in VLAN 5.
<H3C> system-view
[H3C] igmp-snooping fast-leave vlan 5
# Enable IGMP Snooping fast leave on all Ethernet ports in all VLANs.
<H3C> system-view
# Enable IGMP Snooping fast leave for all Ethernet ports except those in VLAN 5.
<H3C> system-view
[H3C] undo igmp-snooping fast-leave vlan 5
# Disable IGMP Snooping fast leave in all VLANs.
<H3C> system-view
igmp-snooping group-policy acl-number
undo igmp-snooping group-policy
View
VLAN view
Parameter
acl-number: Number of basic ACL, in the range of 2,000 to 2,999.
Use the igmp-snooping group-policy command to configure the filtering rule of multicast groups on a specified VLAN so as to control the access to IP multicast groups. You can configure only one ACL rule for each VLAN, and the new configured rule will replace the old one.
Use the undo igmp-snooping group-policy command to cancel the configuration.
By default, no filtering rule is set in a VLAN. In this case, a host can join any multicast group.
Example
# Create ACL2001 and configure the flow rule for basic ACL, using the source IP address serves as the destination multicast address.
<H3C> system-view
[H3C]acl number 2001
[H3C-acl-basic-2001]rule 0 permit source 224.1.1.1 0
[H3C-acl-basic-2001]quit
# Create VLAN 2.
<H3C> system-view
[H3C]vlan 2
# Configure the filtering rule of multicast groups in VLAN2.
[H3C-vlan2]igmp-snooping group-policy 2001
# Cancel the filtering rule in VLAN2.
[H3C-vlan2]undo igmp-snooping group-policy
igmp-snooping host-aging-time seconds
undo igmp-snooping host-aging-time
View
Parameter
seconds: Port aging time for the multicast group member, ranging from 200 to 1000 seconds. By default, it is 260 seconds.
Use the igmp-snooping host-aging-time command to configure the port aging time of the multicast group members.
Use the undo igmp-snooping host-aging-time command to restore the default value.
This command is used to set the aging time of the multicast group member so that the refresh frequency can be controlled. When the group members change frequently, the aging time should be comparatively short, and vice versa.
Example
# Set the aging time to 300 seconds.
<H3C> system-view
[H3C] igmp-snooping host-aging-time 300
igmp-snooping max-response-time seconds
undo igmp-snooping max-response-time
View
Parameter
seconds: Maximum response time for a query, ranging from 1 to 25 seconds. By default, it is 1 second.
Use the igmp-snooping max-response-time command to configure the maximum response time for a query.
Use the undo igmp-snooping max-response-time command to restore the default value.
The set maximum response time decides the time limit for the switch to respond to IGMP Snooping query packets.
Related command: igmp-snooping and igmp-snooping router-aging-time.
Example
# Set the maximum response time for the IGMP Snooping packet to 15s.
<H3C> system-view
[H3C] igmp-snooping max-response-time 15
undo igmp-snooping nonflooding-enable
View
Parameter
None
Use the igmp-snooping nonflooding-enable command to enable unknown multicast data packets not to be broadcasted within a VLAN.
Use the undo igmp-snooping nonflooding-enable command to disable unknown multicast data packets not to be broadcasted within a VLAN.
Note that if IGMP snooping is not enabled on the VLAN (nor Layer 3 multicast), unknown multicast packets are broadcasted within the VLAN no matter whether this function is enabled or not. To make unknown multicast data packets not be broadcasted within the VLAN, you need to enable igmp-snooping in this VLAN and enable igmp-snooping nonflooding-enable globally.
By default, unknown multicast data packets are broadcasted within the VLAN.
Example
# Enable multicast packets not to be broadcasted within the VLAN.
<H3C> system-view
[H3C] igmp-snooping nonflooding-enable
igmp-snooping router-aging-time seconds
undo igmp-snooping router-aging-time
View
Parameter
seconds: Specifies the router port aging time, ranging from 1 to 1000 measured in seconds; By default, it is 105.
Use the igmp-snooping router-aging-time command to configure the router port aging time of IGMP Snooping.
Use the undo igmp-snooping router-aging-time command to restore the default value.
The port here refers to the Ethernet switch port connected to the multicast router. The Layer-2 Ethernet switch receives general query packets from the router via this port. The timer should be set to about 2.5 times of the general query period of the router.
Related command: igmp-snooping and igmp-snooping max-response-time.
Example
# Set the aging time of the IGMP Snooping router port to 500 seconds.
<H3C> system-view
[H3C] igmp-snooping router-aging-time 500
View
Parameter
None
Using reset igmp-snooping statistics command, you can reset the IGMP Snooping statistic information.
Example
# Clear IGMP Snooping statistic information.
<H3C> reset igmp-snooping statistics
igmp-snooping mrouter port port-number
undo igmp-snooping mrouter port port-number
View
VLAN view
Parameter
port-number: Port number of the port to be configured as a static routing port. Provide this argument in the format of interface-type interface-number, where the interface-type argument can only be Ethernet port type.
Use the igmp-snooping mrouter port command to configure a port in a VLAN as a static routing port, through which IGMP packets can be transparently transmitted, so as to meet the requirements of specific networks.
Use the undo igmp-snooping mrouter port command to remove static routing port configuration.
By default, no static routing port is configured.
  Caution:
l      You will fail to configure a port to be a static routing port if the port identified by the port-number argument does not exist or does not belong to the VLAN.
l      You can configure multiple ports in a VLAN to be static routing ports by executing the igmp-snooping mrouter port command repeatedly. The newly configured ports do not replace the existing static routing ports.
l      The configuration of a static routing port takes effect on the current port only, no matter whether the current port is an aggregated port or not. To configure all ports in an aggregation group as static routing ports, you can enable the static routing port function on all the ports in the aggregation group.
Related command: igmp-snooping mrouter vlan.
Example
# Configure GigabitEthernet 5/1/1 port to be a static routing port (assuming that GigabitEthernet 5/1/1 port belongs to VLAN 1).
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] igmp-snooping mrouter port GigabitEthernet 5/1/1
# Cancel the static routing port GigabitEthernet 5/1/1 port in VLAN10.
[H3C-vlan10] undo igmp-snooping mrouter port GigabitEthernet 5/1/1
igmp-snooping mrouter vlan vlan-id
undo igmp-snooping mrouter vlan vlan-id
View
Ethernet port view
Parameter
vlan-id: ID of the VLAN to which the static routing port belongs.
Use the igmp-snooping mrouter vlan command to configure the port to be a static routing port of the specified VLAN, through which IGMP packets can be transparently transmitted, so as to meet the requirements of specific networks.
Use the undo igmp-snooping mrouter vlan command to remove static routing port configuration.
  Caution:
l      You will fail to configure a port to be a static routing port if the VLAN identified by the vlan-id argument does not exist or the port does not belong to the VLAN.
Related command: igmp-snooping mrouter port
Example
# Configure Ethernet5/1/1 port to be a static routing port (assuming that Ethernet5/1/1 port belongs to VLAN 1).
<H3C> system-view
[H3C]interface Ethernet 5/1/1
[H3C-Ethernet5/1/1]igmp-snooping mrouter vlan 1
# Cancel the static routing port GigabitEthernet 5/1/1 port in VLAN1.
[H3C-Ethernet5/1/1]undo igmp-snooping mrouter vlan 1
undo service-type multicast
View
VLAN view
Parameter
None
Use the service-type multicast command to configure the current VLAN as multicast VLAN.
Use the undo service-type multicast command to remove the configuration.
By default, all VLANs are not multicast VLANs.
If you configure multicast VLAN, add the corresponding switch ports to the multicast VLAN and enable IGMP Snooping, users in different VLANs can share one multicast VLAN, and multicast flow can be transmitted in the multicast VLAN only, thus saving bandwidth. The completely isolated multicast VLAN and user VLAN can effectively ensure security.
&  Note:
l      A port can belong to only one multicast VLAN.
l      The type of port connected with user terminals must be hybrid untagged.
l      The current system supports up to three multicast VLANs.
Example
# Configure VLAN 2 as multicast VLAN.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] service-type multicast
broadcast-suppression { ratio | bandwidth bandwidth }
undo broadcast-suppression
View
Ethernet port view
Parameter
ratio: Specifies the maximum wire speed ratio of the broadcast traffic allowed on the port. The value range is 1 to 100, and the default value is 50. The smaller the ratio is, the smaller the broadcast traffic is allowed to pass.
bandwidth: Specifies broadcast suppression bandwidth on the port. The value range is 1 to the maximum value of port bandwidth.
Use the broadcast-suppression command to set the broadcast suppression ratio or broadcast suppression bandwidth.
Use the undo broadcast-suppression command to disable the broadcast suppression function.
The default broadcast suppression ratio is 50%.
You can use the broadcast-suppression command repeatedly. The effective broadcast suppression ratio value is the one last updated.
  Caution:
You cannot enable both broadcast suppression and multicast suppression simultaneously on the same card. Namely, once you have enabled broadcast suppression on some ports of a card, you cannot enable multicast suppression on the other ports of the card, and vice versa.
If multicast suppression is enabled, broadcast packets are also suppressed at the same time, while broadcast suppression does not work on multicast packets.
No distinction is made between known multicast and unknown multicast for multicast suppression.
Related command: multicast-suppression.
Example
# Set the broadcast suppression ratio to 40%.
<H3C> system-view
[H3C] interface Ethernet 2/1/1
[H3C-Ethernet2/1/1] broadcast-suppression 40
# Set the broadcast suppression bandwidth to 40Mbit.
[H3C-Ethernet2/1/1] broadcast-suppression bandwidth 40
# Disable broadcast suppression.
[H3C-Ethernet2/1/1] undo broadcast-suppression
undo debugging multicast forwarding
View
Parameter
None
Use the debugging multicast forwarding command to enable multicast packet forwarding debugging functions.
Use the undo debugging multicast forwarding command to disable the debugging functions.
By default, the debugging function is disabled.
Example
# Enable multicast packet forwarding debugging functions.
<H3C> debugging multicast forwarding
undo debugging multicast kernel-routing
View
Parameter
None
Use the debugging multicast kernel-routing command to enable multicast kernel routing debugging functions.
Use the undo debugging multicast kernel-routing command to disable the debugging functions.
By default, the multicast kernel routing debugging is disabled.
Example
# Enable multicast kernel routing debugging functions.
<H3C> debugging multicast kernel-routing
undo debugging multicast status-forwarding
View
Parameter
None
Use the debugging multicast status-forwarding command to enable multicast forwarding status debugging functions.
Use the undo debugging multicast status-forwarding command to disable the debugging functions.
By default, the multicast forwarding status debugging is disabled.
Example
# Enable multicast forwarding status debugging functions.
<H3C> debugging multicast status-forwarding
display mpm forwarding-table [ group-address | source-address ]
View
Parameter
group-address: Multicast group address, used to specify a multicast group, ranging from 224.0.0.0 to 239.255.255.255.
source-address: IP address of the multicast source.
Use the display mpm forwarding-table command to view the port-carrying multicast forwarding table information.
When a group address or a source address is specified, this command shows only the matched (S, G) entry; otherwise, this command shows all entries.
Related command: display multicast forwarding-table
Example
# View the port-carrying multicast forwarding table information.
<H3C> display mpm forwarding-table
Multicast Forwarding Cache Table
Total 1 entry (entries)
00001. (10.11.113.110, 226.1.1.1)
 in-vlan Vlan1
 2 out-vlan(s):
  Vlan20
   Ethernet5/1/33
  Vlan10
   Ethernet5/1/31
Total 1 entry(entries) Listed
The descriptions about the displayed information are shown in Table 3-3.
Table 3-1 Description of information generated by the command display mpm forwarding-table
Multicast forwarding cache table
Total number of entries
00001
Sequence number of entries
(s,g), namely (source address, group address)
in-vlan Vlan1
The in-VLAN of the multicast forwarding table is VLAN 1
2 out-vlan(s):
The multicast forwarding table has two out-VLANs
  Vlan20
   Ethernet5/1/33
  Vlan10
   Ethernet5/1/31
The first out-VLAN is VLAN 20, of which the egress port is Ethernet 5/1/33
The second out-VLAN is VLAN 10, of which the egress port is Ethernet5/1/31
Totally 1 (S, G) entry is listed.
display mpm group [ vlan vlan-id [ ip-address ] ]
View
Parameter
vlan vlan-id: Specifies the VLAN the desired multicast group resides in.
ip-address: IP address of the desired multicast group.
Use the display mpm group command to display the information about the IP multicast groups or MAC multicast groups in a specified VLAN. If you do not specify the vlan-id argument, this command displays the information about multicast groups in all VLANs.
The information displayed contains the following fields:
l           VLAN ID
l           Router port
l           IP multicast group
l           IP multicast group address
l           Member port of IP multicast group
l           MAC multicast group address
l           Member port of MAC multicast group
  Caution:
l      The information displayed by this command includes that displayed by the display igmp group command and port information.
l      The information displayed by this command is the same as that displayed by the display igmp-snooping group command except the VLAN properties. The display igmp-snooping group command displays the information about the ports that join Layer 2 multicast groups in VLANs that have the IGMP-snooping function enabled. The display mpm group command displays the information about the ports that join Layer 3 multicast groups in VLANs that have the IGMP function enabled.
Example
# Display the multicast group information about VLAN 2.
<H3C> display mpm group vlan 2
Vlan(id):2.
Router port(s):Ethernet2/1/1
Member port(s):Ethernet2/1/2
MAC group(s):
Table 3-2 Description on the fields of the display mpm group command
Vlan(id):2.
The output information is about VLAN 2.
The router port concerned is Ethernet2/1/1.
Lists the IP multicast groups matching the same MAC multicast group.
The IP address of the IP multicast group is 230.45.45.1.
Ethernet2/1/2 port is a member port of the IP multicast group.
The MAC address of the MAC multicast group is 01-00-5e-2d-2d-01.
Ethernet2/1/2 port is a member port of the MAC multicast group.
display multicast forwarding-table [ group-address [ mask { mask | mask-length } ] | source-address [ mask { mask | mask-length } ] | incoming-interface{ interface-type interface-number | null NULL-interface- number | register} ] *
View
Parameter
source-address: Unicast IP address of the multicast source.
incoming-interface: Incoming interface of the multicast forwarding table entry.
interface-type interface-number: Interface type and interface number.
null: Incoming-interface is null.
NULL-interface-number: The only number is 0.
register: Register interface of PIM-SM.
Use the display multicast forwarding-table command to view the information of multicast forwarding table.
  Caution:
You must use multicast routing-enable command in system view to enable IP multicast routing before you can view the multicast forwarding table information.
Related command: display multicast routing-table.
Example
# View the multicast forwarding table information.
<H3C> display multicast forwarding-table
Total 2 entries
00001. (4.4.4.4, 224.2.254.84), iif Vlan-interface1, 0 oifs
     Matched 240 pkts(11288 bytes), Wrong If 0 pkts
     Forwarded 232 pkts(11288 bytes)
00002. (4.4.4.4, 224.2.149.17), iif Vlan-interface1, 1 oifs
     List of outgoing interface:
       01: Vlan-interface2
     Matched 236 pkts(3267 bytes), Wrong If 0 pkts
     Forwarded 233 pkts(3267 bytes)
Matched 2 entries
Table 3-3 Description of information generated by the command display multicast forwarding-table
Total 2 entries
00002
(s,g)
Multicast forwarding cache table has an incoming interface Vlan-interface 1 and one outgoing interface
       01: Vlan-interface2
List of outgoing interface has an outgoing interface Vlan-interface 2
236 matched packets (3267 bytes); 0 matched packets means wrong; 233 forwarded packets (3267 bytes)
Matched 2 entries
2 matched entries
display multicast routing-table [ group-address [ mask { mask | mask-length } ] | source-address [ mask { mask | mask-length } ] | incoming-interface { interface-type vlan-interface | register } ]*
View
Parameter
group-address: Multicast group address, used to specify a multicast group and display the corresponding routing table information of the group. The value ranges from 224.0.0.0 to 239.255.255.255.
incoming-interface: Incoming interface of the multicast route entry.
vlan-interface interface-number: VLAN interface number.
Use the display multicast routing-table command to view the information of IP multicast routing table.
  Caution:
You must use multicast routing-enable command in system view to enable IP multicast routing before you can view the multicast routing table information.
Example
# View the route entry information in the multicast routing table.
<H3C> display multicast routing-table
Multicast Routing Table
Total 3 entries
    Uptime: 00:15:16, Timeout in 272 sec
    Upstream interface: Vlan-interface1(4.4.4.6)
    Downstream interface list:
      Vlan-interface2(2.2.2.4), Protocol 0x1: IGMP
    Downstream interface list: NULL
(4.4.4.4, 239.255.2.2)
    Uptime: 00:02:57, Timeout in 123 sec
Matched 3 entries
The descriptions about the displayed information are shown in Table 3-4.
Table 3-4 Description of output information of the command display multicast routing-table
Multicast routing table
Total 3 entries
3 entries in total
(s, g)
Multicast routing table lasts 15’16” and times out in 272 seconds.
Upstream interface vlan-interface 1 (its IP address is 4.4.4.6).
Downstream interface list: has an interface Vlan-interface 2 (its IP address is 2.2.2.4). The downstream interface is configured with IGMP groups.
Matched 3 entries
3 entries in total meeting the requirement
undo ip managed-multicast
View
Parameter
None
Use the ip managed-multicast command to enable the managed multicast function of the system.
Use the undo ip managed-multicast to disable the managed multicast function.
Related command: display local-user, service-type lan-access.
Example
# Enable the managed multicast function of the system.
<H3C> system-view
[H3C]ip managed-multicast
local-user multicast [ domain domain-name ] ip-address [ mask-length ]
undo local-user [ domain domain-name ] ip-address
View
Parameter
ip-address: IP address of the multicast group.
mask-length: Mask length of the multicast group.
domain domain-name: Domain name of the multicast group.
Use the local-user multicast command to specify the multicast group(s) that users in a specified domain can join.
Use the undo local-user multicast command to cancel the configuration.
Related command: display local-user, service-type lan-access, multicast.
Example
# Grant users permission to join the multicast group with the IP address of 225.10.10.10.
<H3C> system-view
[H3C] local-user multicast 225.10.10.10.
3.1.11  multicast
multicast ip-address [ ip-address &<1-9> | mask-length ]
undo multicast { ip-address [ ip-address &<1-9> ] | all }
View
Local user view
Parameter
ip-address &<1-9>: Multicast group IP address. &<1-9> implies that the preceding parameter can repeatedly input up to 9 times.
mask-length: Mask length. The default value of this argument is to 32. If you do not specify this argument, this command specifies a specific multicast group instead of a network segment.
Use the multicast command to configure the multicast groups so that users can join the multicast group (the managed multicast).
Use the undo multicast command to remove the configuration.
If you do not specify the mask-length argument, you can configure up to ten multicast group addresses at one time. And if you specify the mask-length argument, you can configure only one multicast group address at one time. You can configure up to 64 network segments.
Managed multicast is based on the port mode. It implements authority control for users to a multicast group. Users must pass the 802.1x authentication for the port first. Moreover, users can only join the multicast group configured particularly for them. The port-based managed multicast prohibits users without authority from joining, controlling users’ access to the specific multicast group.
  Caution:
In local user view, before configuring this command, you must configure user service type as LAN-ACCESS, which the managed multicast supports exclusively at present.
You can use the service-type lan-access command to configure service type in local user view.
Example
# Allow users to join the multicast group with the IP address of 225.10.10.10.
<H3C>system-view
[H3C]local-user test
[H3C-luser-test] multicast 225.10.10.10.
multicast route-limit limit
undo multicast route-limit
View
Parameter
limit: Limits the capacity of multicast routing table.
Use the multicast route-limit command to limit the capacity of multicast routing table. When the preset capacity is exceeded, the router will discard new (S, G) protocol and data packets.
Use the undo multicast route-limit command to restore the limit to the default value.
By default, the capacity of multicast routing table is set to 512.
If the existing route entries exceed the capacity value you configured during using this command, the system will not delete the existing entries, but prompts the information “Existing route entries exceed the configured capacity value”.
The new configuration overwrites the old one if you run the command for a second time.
Example
# Limit multicast routing table capacity at 128.
<H3C> system-view
[H3C] multicast route-limit 128
undo multicast routing-enable
View
Parameter
None
Use the multicast routing-enable command to enable multicast routing.
Use the undo multicast routing-enable command to disable multicast routing.
By default, multicast routing is disabled.
Related commands: pim dm, pim sm, igmp enable.
Example
# Enable multicast routing.
<H3C> system-view
[H3C] multicast routing-enable
multicast-suppression { ratio | bandwidth bandwidth }
undo multicast-suppression
View
Ethernet port view
Parameter
ratio: Specifies the maximum wire speed ratio of the multicast traffic allowed on the port. The value range is 1 to 100, and the default value is 50. The smaller the ratio is, the smaller the multicast traffic is allowed to pass.
bandwidth: Specifies multicast suppression bandwidth on the port. The value range is 1 to the maximum value of port bandwidth.
Use the multicast-suppression command to set the multicast suppression ratio or multicast suppression bandwidth.
Use the undo multicast-suppression command to disable the multicast suppression function.
The default multicast suppression ratio is 100%.
You can use the multicast-suppression command repeatedly. The effective multicast suppression ratio value is the one last updated.
  Caution:
l      You cannot enable both broadcast suppression and multicast suppression simultaneously on the same card. Namely, once you have enabled broadcast suppression on some ports of a card, you cannot enable multicast suppression on the other ports of the card, and vice versa. Although the commands are based on ports, the mutual exclusion between these two commands is based on cards.
l      If multicast suppression is enabled, broadcast packets are also suppressed at the same time, while broadcast suppression does not work on multicast packets.
l      No distinction is made between known multicast and unknown multicast for multicast suppression.
Related command: broadcast-suppression.
Example
# Set the multicast suppression ratio to 40%.
<H3C> system-view
[H3C]interface Ethernet 2/1/1
[H3C-Ethernet2/1/1] multicast-suppression 40
# Set the multicast suppression bandwidth to 40Mbit.
[H3C-Ethernet2/1/1] multicast-suppression bandwidth 40
# Disable multicast suppression.
[H3C-Ethernet2/1/1] undo multicast-suppression
reset multicast forwarding-table [ statistics ] { all | { group-address [ mask { group-mask | group-mask-length } ] | source-address [ mask { source-mask | source-mask-length } ] | incoming-interface { null NULL-interface-number | interface-type interface-number } }* }
View
Parameter
statistics: If it is selected, the system clears the statistic information of MFC forward entries. Otherwise, the system clears MFC forward entries.
all: All MFC forward entries.
group-address: Specifies multicast group address.
group-mask: Specifies Mask of multicast group address
group-mask-length: Specifies mask length of multicast group address.
source-address: Specifies source address.
source-mask: Specifies mask of source address.
source-mask-length: Specifies mask length of source address.
incoming-interface: Specifies incoming interface for the multicast forward entry.
Use the reset multicast forwarding-table command to clear MFC forwarding entries or the statistic information of MFC forwarding entries.
You can type in source address first and group address after in the command, as long as they both are valid addresses. The system prompts error information if you type in invalid addresses.
Related command:: reset pim routing-table, reset multicast routing-table, display multicast forwarding-table.
Example
# Clear the forwarding entry with address of 225.5.4.3 from the MFC forwarding table.
<H3C> reset multicast forwarding-table 225.5.4.3
# Clear statistic information of the forwarding entry with address of 225.5.4.3 from the MFC forwarding table.
<H3C> reset multicast forwarding-table statistics 225.5.4.3
reset multicast routing-table { all | { group-address [ mask { group-mask | group-mask-length } ] | source-address [ mask { source-mask | source-mask-length } ] | incoming-interface vlan-interface interface-number } * }
View
Parameter
all: All route entries in the core multicast routing table.
vlan-interface-type interface-number: Interface type and VLAN virtual interface number.
Use the reset multicast routing-table command to clear route entries from the core multicast routing table, as well as MFC forwarding entries.
Related command: reset pim routing-table, reset multicast forwarding-table and display multicast forwarding-table.
Example
# Clear the route entry with address of 225.5.4.3 from the core multicast routing table.
<H3C> reset multicast routing-table 225.5.4.3
debugging igmp { all | event | host | packet | timer }
undo debugging igmp { all | event | host | packet | timer }
View
Parameter
all: All the debugging information of IGMP.
event: Debugging information of IGMP event.
host: Debugging information of IGMP host.
packet: Debugging information of IGMP packets.
timer: Debugging information of IGMP timers.
Use the debugging igmp command to enable IGMP debugging functions.
Use the undo debugging igmp command to disable the debugging functions.
By default, IGMP debugging functions are disabled.
Example
# Enable all IGMP debugging functions
<H3C> debugging igmp all
display igmp group [ group-address | interface vlan-interface interface-number ]
View
Parameter
group-address: Address of the multicast group.
Use the display igmp group command to view the member information of the IGMP multicast group.
You can specify to show the information of a group or the member information of the multicast group on a VLAN interface. The information displayed contains the multicast groups which the downstream hosts join through IGMP or through command line.
Related command: igmp host-join.
Example
# Display the IGMP group members in a directly-connected subnet.
<H3C> display igmp group
LoopBack0 (20.20.20.20): Total 3 IGMP Groups reported:
  Group Address      Last Reporter   Uptime      Expires
  225.1.1.1           20.20.20.20     00:02:04    00:01:15
  225.1.1.3           20.20.20.20     00:02:04    00:01:15
  225.1.1.2           20.20.20.20     00:02:04    00:01:17
Table 4-1 Description of the output information of the display igmp group command
Group address
Last Reporter
The last host reporting to join the multicast group
Uptime
Time passed since multicast group is discovered (hh: mm: ss).
Expires
Specifies when the member will be removed from the multicast group (hh: mm: ss).
display igmp interface [ vlan-interface interface-number ]
View
Parameter
vlan-interface interface-number: VLAN interface number of the router, used to specify the interface. If the parameters are omitted, information about all the interfaces running IGMP will be displayed.
Use the display igmp interface command to view the IGMP configuration and running information on an interface.
Example
# View the IGMP configuration and running information of all interfaces.
<H3C> display igmp interface
Vlan-interface1 (10.153.17.99):
  IGMP is enabled
  Current IGMP version is 2
  Value of query interval for IGMP(in seconds): 60
  Value of other querier time out for IGMP(in seconds): 120
  Value of maximum query response time for IGMP(in seconds): 10
  Value of robust count for IGMP: 2
  Value of startup query interval for IGMP(in seconds): 15
  Value of last member query interval for IGMP(in seconds): 1
  Value of query timeout for IGMP version 1(in seconds): 400
  Policy to accept IGMP reports: none
  Querier for IGMP: 10.153.17.99 (this router)
  IGMP group limit is 1024
  No IGMP group reported
Table 4-2 Description on the fields of the display igmp interface command
IGMP version
IGMP version
query interval
General query interval
querier timeout
Querier timeout time
max query response time
Maximum query response time
robust count
IGMP robust count, namely the number of times IGMP querier sends IGMP specific group query packet when it receives an IGMP Leave packet from a host
Startup query interval
The interval at which the IGMP querier sends IGMP specific group query packets when it receives an IGMP leave packet from a host
query timeout
Query timeout for IGMP V1
Filter policy for the IGMP multicast group to control the accesses to the IP multicast group
Querier for IGMP
IGMP querier
IGMP group limit
Quantity limit of IGMP groups added to the interface. After the limit is reached, the router does not process the IGMP join messages
4.1.4  igmp enable
igmp enable
undo igmp enable
View
VLAN interface view
Parameter
None
Use the igmp enable command to enable IGMP on an interface.
Use the undo igmp enable command to disable IGMP on the interface.
By default, IGMP is disabled on an interface.
You must enable the multicast function before this command can work, you must use this command first before you can configure other IGMP features.
Related command: multicast routing-enable.
  Caution:
l      If the VLAN VPN is enabled on a port, the IGMP Snooping feature cannot be enabled on the VLAN to which the port belongs, and the IGMP feature cannot be enabled on the corresponding VLAN interface.
l      If IGMP Snooping feature is enabled on a VLAN, or IGMP is enabled on the VLAN interface, you cannot add VLAN VPN enabled ports into the VLAN, and vice versa.
Example
# Enable IGMP on Vlan-interface 10.
<H3C> system-view
[H3C]interface vlan-interface 10
[H3C-Vlan-interface10] igmp enable
igmp fast-leave [ vlan { vlan-id [ to vlan-id ] } &<1-10> ]
undo igmp fast-leave [ vlan { vlan-id [ to vlan-id ] } &<1-10> ]
View
Ethernet port view, system view
Parameter
vlan-id: Specifies the VLAN you want to configure the IGMP Snooping fast leave feature on. The value range is from 1 to 4094.
Use the igmp fast-leave command to enable IGMP fast leave on ports or VLANs.
Use the undo igmp fast-leave command to disable IGMP fast leave.
An IGMP-enabled Layer 3 switch does not query packets of the specific multicast group to a fast leave-enabled port any longer when the port receives an IGMP leave packet. Instead, the switch peels off the port from the multicast group immediately.
You can optionally specify multiple vlan keywords for the igmp fast-leave command, through which you can enable IGMP fast leave in corresponding VLANs. If you do not specify the vlan keyword, IGMP fast leave is enabled in all VLANs. As mentioned earlier, the igmp fast-leave command can be executed in both system view and Ethernet port view. When you execute the command in system view, fast leave is enabled on all ports of the specified VLANs, otherwise, it is only enabled on the current port in the specified VLANs.
&  Note:
l      Fast leave works on all ports of the specified VLANs if you configure it in system view. However, it only works on the current port (e.g., when a Trunk port belong to multiple VLANs) in the specified VLANs if you configure it in Ethernet port view.
  Caution:
l      Fast leave configured for a port takes effect only when the VLAN it belongs to is IGMP-enabled.
l      Fast leave does not work if the corresponding specified VLANs do not exist, the port does not belongs to any of the specified VLANs, or the VLANs do not have IGMP enabled.
l      You can enable multicast routing globally by executing the multicast routing-enable command before you can configure the fast leave feature.
l      Disabling globally-enabled multicast routing results in all existing IGMP fast leave-related configurations being cleared.
l      When you configure IGMP fast leave on aggregation ports, the configuration takes effect only on primary aggregation ports.
l      If you add an IGMP V1 host of the same multicast group to the port, or configure a static host of the same multicast group by using the igmp host-join command, the switch does not remove the port when the port receives an IGMP Leave packet of the multicast group even you enable IGMP fast leave for the port.
Example
# Enable IGMP fast leave on the Ethernet2/1/1 port in VLAN 5 only.
<H3C> system-view
[H3C-Ethernet2/1/1] igmp fast-leave vlan 5
# Disable IGMP fast leave on the Ethernet2/1/1 port in all VLANs.
<H3C> system-view
[H3C-Ethernet2/1/1] undo igmp fast-leave
# Enable IGMP fast leave on all Ethernet ports in VLAN 5.
<H3C> system-view
[H3C] igmp fast-leave vlan 5
# Enable IGMP fast leave for on all Ethernet ports except those in VLAN 5.
<H3C> system-view
[H3C] undo igmp fast-leave vlan 5
# Disable IGMP fast leave in all VLANs.
<H3C> system-view
igmp group-limit limit
undo igmp group-limit
View
VLAN interface view
Parameter
limit: Quantity of multicast groups, in the range of 0 to 512.
Use the igmp group-limit command to limit multicast groups to be added on an interface. After the limit is reached, the router does not process IGMP join messages.
Use the undo igmp group-limit command to restore the default setting.
By default, the maximum number is 512.
Example
# Limit the maximum number of IGMP groups to be added on Vlan-interface10 to 100.
<H3C> system-view
[H3C-Vlan-interface10] igmp group-limit 100
igmp group-policy acl-number
undo igmp group-policy
View
VLAN view
Parameter
Use the igmp group-policy command to configure the filtering rule of multicast groups on a specified VLAN so as to control the access to IP multicast groups. You can configure only one ACL rule for each VLAN, and the new configured rule will replace the old one.
Use the undo igmp group-policy command to cancel the configuration.
Example
<H3C> system-view
# Create VLAN 2.
<H3C> system-view
[H3C]vlan 2
# Configure the filtering rule of multicast groups on VLAN2.
[H3C-vlan2]igmp group-policy 2001
[H3C-vlan2]undo igmp group-policy
igmp host-join group-address port interface-type interface- number [ to { interface-type interface- number ]
undo igmp host-join group-address port { interface-type interface-number [ to { interface-type interface- number ]
View
VLAN interface view
Parameter
group-address: Multicast address of the multicast group that an interface will join.
interface-type interface-number [ to interface-type interface-number ]: Specifies the port under the VLAN interface.
Use the igmp host-join command to enable a port in the VLAN interface of an Ethernet switch to join a multicast group.
Use the undo igmp host-join command to disable the configuration.
By default, an interface does not join any multicast group.
Related command: igmp group-policy.
Example
# Add port Ethernet 2/1/1 under VLAN-interface10 to the multicast group 225.0.0.1.
<H3C> system-view
[H3C-Vlan-interface10] igmp host-join 225.0.0.1 port Ethernet 2/1/1
igmp host-join group-address vlan vlan-id
undo igmp host-join group-address vlan vlan-id
View
Ethernet port view
Parameter
group-address: Address of the multicast group to be joined.
vlan-id: VLAN where the port belongs to.
Use the igmp host-join vlan command to make an Ethernet join a multicast group.
Use the undo igmp host-join vlan command to cancel the configuration.
By default, an Ethernet port does not join any multicast group.
Example
# Add port Ethernet 2/1/1 to the multicast group at 225.0.0.1
<H3C> system-view
[H3C-Vlan-interface10] quit
[H3C-Ethernet2/1/1] port access vlan 10
[H3C-Ethernet2/1/1] igmp host-join 225.0.0.1 vlan 10
igmp lastmember-queryinterval seconds
undo igmp lastmember-queryinterval
View
Interface view
Parameter
seconds: Time interval before IGMP query router sends the IGMP group query message after it receives the IGMP Leave message from the host. It is in the range of 1 to 5 seconds. By default, it is 1 second.
Use the igmp lastmember-queryinterval command to set the time interval at which IGMP query router sends the IGMP group query message after it receives the IGMP Leave message from the host.
Use the undo igmp lastmember-queryinterval command to restore the default value.
This command is valid only when the query router runs IGMP v2. If the host runs IGMP v1 , it does not send an IGMP Leave message when it leaves a group, so this command is invalid for the IGMP query router.
Related command: igmp robust-count and display igmp interface.
Example
# Set the query interval at the Vlan-interface10 as 3 seconds.
<H3C> system-view
[H3C-Vlan-interface10] igmp lastmember-queryinterval 3
igmp max-response-time seconds
undo igmp max-response-time
View
VLAN Interface view
Parameter
seconds: Maximum response time in the IGMP query messages in second in the range from 1 to 25. By default, the value is 10 seconds.
Use the igmp max-response-time command to configure the maximum response time contained in the IGMP query messages.
Use the undo igmp max-response-time command to restore the default value.
The maximum query response time determines the period for a router to quickly detect that there are no more directly connected group members in a LAN.
Related command: display igmp group.
Example
# Set the maximum response time carried in host-query message to 8 seconds.
<H3C> system-view
[H3C-Vlan-interface10] igmp max-response-time 8
igmp robust-count robust-value
undo igmp robust-count
View
VLAN interface view
Parameter
robust-value: IGMP robust value, number of times the IGMP query router sends IGMP group query message after it receives the IGMP Leave message from the host. the value range is 2 to 5. The default value is 2.
Use the igmp robust-count command to set the number of times the IGMP query router sends IGMP group query message after it receives the IGMP Leave message from the host.
Use the undo igmp robust-count command to restore the default value.
Related commands: igmp lastmember-queryinterval, display igmp interface.
Example
# Set the robust value at the Vlan-interface 10 as 3.
<H3C> system-view
[H3C-Vlan-interface10] igmp robust-count 3
igmp timer other-querier-present seconds
undo igmp timer other-querier-present
View
VLAN interface view
Parameter
seconds: IGMP querier present timer value in second ranging from 1 to 131070. By default, the value is twice the value of IGMP query message interval, i.e., 120 seconds.
Use the igmp timer other-querier-present command to configure the timer of presence of the IGMP querier.
Use the undo igmp timer other-querier-present command to restore the default value.
On a shared network, i.e., there are multiple multicast routers on the same network segment, the query router (querier for short) takes charge of sending query messages periodically on the interface. If other non-queriers receive no query messages within the valid period, the router will consider the previous query to be invalid and the router itself becomes a querier.
In IGMP version 1, the selection of a query is determined by the multicast routing protocol. In IGMP version 2, the router with the lowest IP address on the shared network segment acts as the querier.
Related command: igmp timer query and display igmp interface.
Example
# Set querier to expire after 300 seconds.
<H3C> system-view
[H3C-Vlan-interface10] igmp timer other-querier-present 300
igmp timer query seconds
undo igmp timer query
View
VLAN interface view
Parameter
seconds: Interval at which a router transmits IGMP query messages in second in the range from 1 to 65535. By default, the value is 60 seconds.
Use the igmp timer query command to configure the interval at which a router interface sends IGMP query messages.
Use the undo igmp timer query command to restore the default value.
A multicast router periodically sends out IGMP query messages to check whether there are multicast group members on the network. The query interval can be modified according to the practical conditions of the network.
Related command: igmp timer other-querier-present.
Example
# Configure to transmit the host-query message every 150 seconds via VLAN-interface2.
<H3C> system-view
[H3C]interface vlan-interface 2
[H3C-Vlan-interface2] igmp timer query 150
4.1.15  igmp version
igmp version { 1 | 2 }
undo igmp version
View
VLAN interface view
Parameter
1: IGMP version 1.
2: IGMP version 2. The default setting is IGMP version 2.
Use the igmp version command to specify the version of IGMP that a router uses.
Use the undo igmp version command to restore the default value.
The system does not automatic switching between different IGMP versions. Therefore, all routers on a subnet must be configured to run the same IGMP version.
Example
# Run IGMP Version 1 on VLAN-interface10.
<H3C> system-view
[H3C-Vlan-interface10] igmp version 1
reset igmp group { all | interface vlan-interface interface-number { all | group-address [ group-mask ] } }
View
Parameter
all: All IGMP groups.
interface vlan-interface interface-number: VLAN virtual interface type and number.
group-address: IGMP group address.
group-mask: Segment mask of the IGMP group address.
Use the reset igmp group command to delete an existing IGMP group from the interface. The deleted group can added again on the interface.
Example
# Delete all IGMP groups on all the interfaces.
<H3C> reset igmp group all
# Delete all IGMP groups on the Vlan-intrface10.
<H3C> reset igmp group interface Vlan-interface10 all
# Delete the group 225.0.0.1 from the Vlan-interface10.
<H3C> reset igmp group interface Vlan-interface10 225.0.0.1
# Delete the IGMP groups ranging from 225.1.1.0 to 225.1.1.255 on the Vlan-interface10.
<H3C> reset igmp group interface Vlan-interface10 225.1.1.0 255.255.255.0
4.2.1  igmp proxy
igmp proxy interface-type interface-number
undo igmp proxy
View
VLAN interface view
Parameter
interface-type: Proxy interface type.
interface-number: Proxy interface number.
Use the igmp proxy command to enable IGMP proxy for the VLAN interface and specify the IGMP proxy interface of the VLAN interface.
Use the undo igmp proxy command to remove IGMP proxy configuration.
By default, IGMP proxy is disabled on a VLAN interface.
  Caution:
l      You need to enable PIM protocol for a VLAN interface before executing the igmp proxy command in its VLAN interface view.
l      If you configure the IGMP proxy interface for a VLAN interface multiple times, the latest configured IGMP proxy interface will take effect.
l      A VLAN interface cannot be the IGMP proxy interface for two or more other VLAN interfaces simultaneously.
Example
# Enable IGMP proxy for the interface of VLAN 100 and specify the interface of VLAN 200 to be its IGMP proxy interface.
<H3C> system-view
[H3C] interface vlan-interface 100
[H3C-vlan-interface100] igmp proxy vlan-interface 200
5.1.1  bsr-policy
bsr-policy acl-number
undo bsr-policy
View
PIM view
Parameter
acl-number: ACL number imported in BSR filtering policy, in the range of 2000 to 2999.
Use the bsr-policy command to limit the range of legal BSRs to prevent BSR proofing.
Use the undo bsr-policy command to restore the default setting, that is, no range limit is set and all received messages are taken as legal.
In the PIM SM network using BSR (bootstrap router) mechanism, every router can set itself as C-BSR (candidate BSR) and take the authority to advertise RP information in the network once it wins in the contention. To prevent the legal BSR from being replaced maliciously in the network, the following two measures need to be taken:
l           Prevent the router from being spoofed by hosts though faking legal BSR messages to modify RP mapping. BSR messages are of multicast type and their TTL is 1, so this type of attacks often hit edge routers. Fortunately, BSRs are inside the network, while assaulting hosts are outside, therefore neighbor and RPF checks can be used to stop this type of attacks.
l           If a router in the network is manipulated by an attacker, or an illegal router is accessed into the network, the attacker may set itself as C-BSR and try to win the contention and gain authority to advertise RP information among the network. Since the router configured as C-BSR shall propagate BSR messages, which are multicast messages sent hop by hop with TTL as 1, among the network, then the network cannot be affected as long as the peer routers do not receive these BSR messages. One way is to configure bsr-policy on each router to limit legal BSR range, for example, only 1.1.1.1/32 and 1.1.1.2/32 can be BSR, thus the routers cannot receive or forward BSR messages other than these two. Even legal BSRs cannot contest with them.
Problems may still exist if a legal BSR is attacked, though these two measures can effectively guarantee high BSR security.
The source parameter in the rule command is translated as BSR address in the bsr-policy command.
Related command: acl and rule.
Example
# Configure BSR filtering policy on routers, only 101.1.1.1/32 can be BSR and all others are illegal.
<H3C> system-view
[H3C]pim
[H3C-pim] bsr-policy 2000
[H3C-pim] quit
[H3C] acl number 2000
[H3C-acl-basic-2000] rule 0 permit source 101.1.1.1 0
5.1.2  c-bsr
c-bsr interface-type interface-number hash-mask-len [ priority ]
undo c-bsr
View
PIM view
Parameter
interface-type interface-number: Specifies the interface. The candidate BSR is configured on the interface. PIM-SM must be enabled on the interface first.
hash-mask-len: Length of the mask. The value ranges from 0 to 32.
priority: Priority of the candidate BSR. The larger the value of the priority, the higher the priority of the BSR. The value ranges from 0 to 255. By default, the priority is 0.
Use the c-bsr command to configure a candidate BSR.
Use the undo c-bsr command to remove the candidate BSR configured.
By default, no candidate BSR is set.
When configure the candidate BSR, the larger bandwidth should be guaranteed since a great amount of information will be exchanged between BSR and other devices in the PIM domain.
Related command: pim sm.
Example
# Configure the Ethernet switch as C-BSR with priority 2 (and the C-BSR address is designated as the IP address of VLAN-interface10).
<H3C> system-view
[H3C] pim
[H3C-pim] c-bsr vlan-interface 10 24 2
5.1.3  c-rp
c-rp interface-type interface-number [ group-policy acl-number | priority priority-value ]*
undo c-rp { interface-type interface-number | all }
View
PIM view
Parameter
interface-type interface-number: Specifies interface with the IP address advertised as a candidate RP address.
acl-number: Number of the basic ACL that defines a group range, which is the service range of the advertised RP. The value ranges from 2000 to 2999.
priority-value: Priority value of candidate RP, in the range of 0 to 255. By default, it is 0. The greatest value corresponds to the lowest priority level
all: Removes all candidate RP configurations.
Use the c-rp command to configure the router to advertise itself as a candidate RP.
Use the undo c-rp command to remove the configuration.
By default, no candidate RP is configured.
When configuring the candidate RP, a relatively large bandwidth should be reserved for the router and other devices in the PIM domain.
Related command: c-bsr.
Example
# Configure the switch to advertise itself as a C-RP in the PIM domain to BSR. The standard access list 2000 defines the groups related to the RP. The address of C-RP is designated as the IP address of VLAN-interface10.
<H3C> system-view
[H3C-acl-basic-2000] rule permit source 225.0.0.0 0.255.255.255
[H3C-acl-basic-2000]quit
[H3C] pim
[H3C-pim] c-rp vlan-interface 10 group-policy 2000
5.1.4  crp-policy
crp-policy acl-number
undo crp-policy
View
PIM view
Parameter
acl-number: ACL number imported in C-RP filtering policy, ranging from 3000 to 3999.
Use the crp-policy command to limit the range of legal C-RP, as well as target service group range of each C-RP, and prevent C-RP proofing.
Use the undo crp-policy command to restore the default setting, that is, no range limit is set and all received messages are taken as legal.
In the PIM SM network using BSR mechanism, every router can set itself as C-RP (candidate rendezvous point) servicing particular groups. If elected, a C-RP becomes the RP servicing the current group.
In BSR mechanism, a C-RP router unicasts C-RP messages to the BSR, which then propagates the C-RP messages among the network by BSR message.
To prevent C-RP spoofing, you need to configure crp-policy on the BSR to limit legal C-RP range and their service group range. Since each C-BSR has the chance to become BSR, you must configure the same filtering policy on each C-BSR router.
This command uses the ACLs numbered between 3000 and 3999. The source parameter in the rule command is translated as C-RP address in the crp-policy command, and the destination parameter as the service group range of this C-RP address. For the C-RP messages received, only when their C-RP addresses match the source address and their server group addresses are subset of those in ACL, can the be considered as matched.
Example
# Configure C-RP filtering policy on the C-BSR routers, allowing only 1.1.1.1/32 as C-RP and to serve only for the groups 225.1.0.0/16.
<H3C> system-view
[H3C] pim
[H3C-pim] crp-policy 3000
[H3C-pim] quit
[H3C] acl number 3000
[H3C-acl-adv-3000] rule 0 permit source 1.1.1.1 0 destination 225.1.0.0 0.0.255.255
5.1.5  debugging pim common
debugging pim common { all | event | packet | timer }
undo debugging pim common { all | event | packet | timer }
View
Parameter
all: All the common debugging information of PIM.
event: Debugging information of common PIM event.
packet: Debugging information of PIM hello packet.
timer: Debugging information of common PIM timer.
Use the debugging pim common command to enable common PIM debugging functions.
Use the undo debugging pim common command to disable the debugging functions.
By default, common PIM debugging functions are disabled.
Example
# Enable all common PIM debugging functions
<H3C> debugging pim common all
5.1.6  debugging pim dm
debugging pim dm { alert | all | mrt | timer | warning | { recv | send } { all | assert | graft | graft-ack | join | prune } }
undo debugging pim dm { alert | all | mrt | timer | warning | { recv | send } { all | assert | graft | graft-ack | join | prune } }
View
Parameter
alert: Interoperation event debugging information of PIM-DM
all: All the debugging information of PIM-DM.
mrt: Debugging information of PIM-DM multicast routing table.
timer: Debugging information of PIM-DM timer.
warning: Debugging information of PIM-DM warning message.
recv: Debugging information of PIM-DM receiving packets.
send: Debugging information of PIM-DM sending packets.
assert | graft | graft-ack | join | prune: Packets type.
Use the debugging pim dm command to enable PIM-DM debugging functions.
Use the undo debugging pim dm command to disable the debugging functions.
By default, PIM-DM debugging functions are disabled.
Example
# Enable all PIM-DM debugging functions
<H3C> debugging pim dm all
5.1.7  debugging pim sm
debugging pim sm { all | mbr { alert | fresh } | verbose | mrt | msdp | timer { assert | bsr | crpadv | jp | jpdelay | mrt | probe | spt } | warning | { recv | send } { assert | bootstrap | crpadv | jp | reg | regstop } }
undo debugging pim sm { all | mbr { alert | fresh } | verbose | mrt | msdp | timer { assert | bsr | crpadv | jp | jpdelay | mrt | probe | spt } | warning | { recv | send } { assert | bootstrap | crpadv | jp | reg | regstop } }
View
Parameter
all: All debugging information of PIM-SM.
mbr: Debugging information of PIM-SM multicast border router event. Alert stands for debugging alert information of PIM-SM multicast border router fresh stands for debugging renew information of PIM-SM multicast.
verbose: Debugging detail information of PIM-SM.
mrt: Debugging information of PIM-SM multicast routing table.
msdp: Debugging information of correspondence between PIM SM and MSDP.
timer: Debugging information of PIM-SM timer.
assert | bsr | crpadv | jp | jpdelay | mrt | probe | spt: PIM-SM timer type.
warning: Debugging information of PIM-SM warning message.
recv: Debugging information of PIM-SM receiving packets.
send: Debugging information of PIM-SM sending packets.
assert | bootstrap | crpadv | jp | reg | regstop: Packets type.
Use the debugging pim sm command to enable PIM-SM debugging functions.
Use the undo debugging pim sm command to disable the debugging functions.
By default, PIM-SM debugging functions are disabled.
Example
# Enable all PIM-SM debugging functions
<H3C> debugging pim sm all
5.1.8  display pim bsr-info
View
Parameter
None
Use the display pim bsr command to view the BSR information.
Related command: c-bsr, c-rp.
Example
<H3C> display pim bsr-info
  Current BSR Address: 192.168.1.1
             Priority: 0
          Mask Length: 30
              Expires: 00:01:26
     Bootstrap-Period: 60 seconds
    Bootstrap-Timeout: 130 seconds
  Local host is BSR
Table 5-1 Output description of the display pim bsr command
BSR
Boot strap router
Priority
Priority of BSR
Mask Length: 30
Length of mask
Expires: 00:01:55
Expire time
BootStrap-Period: 60 seconds
Boot strap interval
Bootstrap-timeout: 130 second
Boot strap timeout
5.1.9  display pim interface
display pim interface [interface-type interface-number ]
View
Parameter
interface-type interface-number: Interface type and interface number, used to specify the interface.
Use the display pim interface command to view the PIM interface configuration information.
If no interface type or interface number is specified, this command displays the PIM configurations on all interfaces. If the interface type and interface number are specified, only the PIM configuration on the specified interface is displayed.
Example
# Display the PIM configuration information on an interface.
<H3C> display pim interface vlan 2
PIM information of VLAN-interface 2:
  IP address of the interface is 10.10.1.20
  PIM is enabled on interface
  PIM version is 2
  PIM mode is Sparse
  PIM query interval is 30 seconds
  PIM neighbor hold-time is 105 seconds
PIM neighbor limit is 128
  PIM neighbor policy is none
  Total 1 PIM neighbor on interface
  PIM DR(designated router) is 10.10.1.20
Table 5-2 Description output information of the display pim interface command
PIM version
Version of PIM
PIM mode
PIM mode enabled on the interface (DM or SM)
PIM query interval
Hello packet interval
Hold-time of PIM neighbor
PIM neighbor limit
Limit of the PIM neighbors on an interface. No neighbor can be added any more when the limit is reached
PIM neighbor policy
Filtering policy of the PIM neighbors on the current interface
PIM DR
Designated router
5.1.10  display pim neighbor
display pim neighbor [ interface interface-type interface-number ]
View
Parameter
interface interface-type interface-number: Interface type and interface number, used to specify the interface.
Use the display pim neighbor command to view the PIM neighbor information discovered by the switch interface. If the interface type and interface number are specified, this command only displays the PIM neighbor information on the specified interface.
Example
# Display PIM neighbor information discovered by the switch interface.
<H3C> display pim neighbor
Neighbor's Address  Interface Name               Uptime    Expires
90.0.0.2            Vlan-interface90              00:00:36  00:01:40
Table 5-3 Description of output information of display pim neighbor command
Neighbor Address
Neighbor address
Interface where the neighbor has been discovered
Uptime
Time passed since the multicast group has been discovered
Expires
Specifies when the member will be removed from the group
5.1.11  display pim routing-table
display pim routing-table [ { { *g [ group-address [ mask { mask-length | mask } ] ] | **rp [ rp-address [ mask { mask-length | mask } ] ] } | { group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] } * } | incoming-interface { interface interface-type interface-number | null } | { dense-mode | sparse-mode } ] *
View
Parameter
*g: (*, G) route entry.
mask: IP address mask.
mask-length: Length of the IP address mask.
**rp: (*, *, p) route entry.
rp-address: Address of the RP.
incoming-interface interface interface-type interface-number: Route entry with the specified incoming interface.
null: Specifies the incoming interface type as Null.
dense-mode: Specifies the multicast routing protocol as PIM-DM.
sparse-mode: Specifies the multicast routing protocol as PIM-SM.
Use the display pim routing-table command to view the contents of the PIM multicast routing table. The displayed information of the PIM multicast routing table includes the SPT and RPF information.
Example
# View the contents of the PIM multicast routing table on the router.
<H3C> display pim routing-table
PIM-SM Routing Table
Total 0 (*,*,RP)entry, 0 (*,G)entry, 2 (S,G)entries
(192.168.1.2, 224.2.178.130),
Protocol 0x20: PIMSM, Flag 0x4: SPT
UpTime: 23:59, Timeout after 196 seconds
Upstream interface: VLAN-interface2, RPF neighbor: NULL
(192.168.1.2, 224.2.181.90),
Total 2 entries listed
Table 5-4 Description of output information of display pim routing-table
RP
Rendezvous Point
(S,G)
(source address, multicast group)
PIM-SM
PIM Sparse Mode
SPT
Shortest Path Tree
RPF
Reverse Path Forwarding
5.1.12  display pim rp-info
display pim rp-info [ group-address ]
View
Parameter
group-address: Specifies the group address to display. If no multicast group is specified, the RP information about all multicast groups will be displayed.
Use the display pim rp-info command to view the RP information of multicast group.
In addition, this command can also display the BSR and static RP information.
Example
# View the RP information of multicast group.
<H3C> display pim rp-info
PIM-SM RP-SET information:
    BSR is: 20.20.20.20
    Group/MaskLen: 224.0.0.0/4
      RP 20.20.20.20
        Version: 2
        Priority: 0
        Uptime: 00:00:05
        Expires: 00:02:25
        Adv-Period: 60 seconds
        Holdtime: 150 seconds
The following table details the display information.
Table 5-5 Description of output information of display pim rp-info
 RP information
BSR is: 4.4.4.6
BSR is the virtual interface of the node 4.4.4.6.
      RP 4.4.4.6
        Version: 2
        Priority: 0
        Uptime: 00:39:50
        Expires: 00:01:40
The RP with IP address 224.0.0.0 and mask length of 4 is the virtual interface of the node 4.4.4.6, in version 2 and priority 0; it has been active for 39 minutes and 50 seconds and shall expire in one minute and 40 seconds; the advertisement interval is 60 seconds and holdtime is 150 seconds.
5.1.13  pim
pim
undo pim
View
Parameter
None
Use the pim command to enter the PIM view and configure the PIM global parameters. Note that the command does not enable the PIM protocol.
Use the undo pim command to return to system view, clear the PIM global parameters configured before and clear the PIM view.
Example
# Enter the PIM view.
<H3C> system-view
[H3C] pim
[H3C-pim]
5.1.14  pim bsr-boundary
pim bsr-boundary
undo pim bsr-boundary
View
VLAN interface view
Parameter
None
Use the pim bsr-boundary command to configure an interface to be the PIM domain border.
Use the undo pim bsr-boundary command to remove the border.
By default, no domain border is set.
You can use this command to set border of bootstrap messages, that is to say, bootstrap messages cannot pass interfaces that are configured with pim bsr-boundary command while other PIM messages can. In this way, the network is divided into different BSR domains. Each domain uses a different bootstrap router.
  Caution:
The pim bsr-boundary command cannot build a multicast boundary. It just sets up a PIM bootstrap message boundary.
Example
# Configure domain border on VLAN-interface10.
<H3C> system-view
[H3C-Vlan-interface10] pim bsr-boundary
5.1.15  pim dm
pim dm
undo pim dm
View
VLAN interface view
Parameter
None
Use the pim dm command to enable PIM-DM.
Use the undo pim dm command to disable PIM-DM.
By default, PIM-DM is disabled.
Before enabling PIM-DM, you must execute the multicast routing-enable command in system view to enable the multicast routing first.
Example
# Enable PIM-DM on VLAN-interface10 of the Ethernet switch.
<H3C> system-view
[H3C-Vlan-interface10] pim dm
5.1.16  pim neighbor-limit
pim neighbor-limit limit
undo pim neighbor-limit
View
VLAN interface view
Parameter
limit: Limits of PIM neighbors on the interface, in the range of 0~128.
Use the pim neighbor-limit command to limit the PIM neighbors on an interface. No neighbor can be added any more when the limit is reached.
Use the undo pim neighbor-limit command to restore the default setting.
By default, the PIM neighbors on the interface are limited to 128.
If the existing PIM neighbors exceed the configured value during configuration, they will not be deleted.
Example
# Limit the PIM neighbors on the Vlan-interface10 to 50.
<H3C> system-view
[H3C-Vlan-interface10] pim neighbor-limit 50
5.1.17  pim neighbor-policy
pim neighbor-policy acl-number
undo pim neighbor-policy
View
VLAN interface view
Parameter
acl-number: Basic ACL number, in the range of 2000 to 2999.
Use the pim neighbor-policy command to set to filter the PIM neighbors on the current interface.
Use the undo pim neighbor-policy command to remove the setting.
Only the routers that match the filtering rule in the ACL can serve as a PIM neighbor of the current interface.
Example
# Configure that 10.10.1.2 can serve as a PIM neighbor of the Vlan-interface10, but not 10.10.1.1.
<H3C> system-view
[H3C-Vlan-interface10] pim neighbor-policy 2000
[H3C-acl-basic-2000] rule permit source 10.10.1.2 0
[H3C-acl-basic-2000] rule deny source 10.10.1.1 0
5.1.18  pim sm
pim sm
undo pim sm
View
VLAN interface view
Parameter
None
Use the pim sm command to enable the PIM-SM protocol on an interface.
Use the undo pim sm command to disable the PIM-SM protocol.
By default, PIM-SM is disabled.
Users need to configure the PIM-SM protocol on each interface. Generally, the PIM-SM protocol needs to be enabled on each interface.
Example
# Enable PIM-SM on VLAN-interface10.
<H3C> system-view
[H3C-Vlan-interface10] pim sm
5.1.19  pim timer hello
pim timer hello seconds
undo pim timer hello
View
VLAN interface view
Parameter
seconds: Time interval for a port to send Hello packets, in the range of 1 to 18,000 (in seconds). By default, the time interval is 30 seconds.
Use the pim timer hello command to configure the time interval for a port to send Hello packets.
Use the undo pim timer hello command to restore the default time interval.
After the protocol independent multicast-sparse mode (PIM-SM) protocol is enabled for a port, a switch sends Hello packets periodically to all network devices supporting protocol independent multicast (PIM) to find its neighbors. If a port receives the Hello packets, it indicates the port has a neighbor network device supporting PIM, and the port adds the neighbor to its port neighbor list. If a port does not receive the Hello packets from the existing neighbors in its neighbor list in the specified time, the system assumes the neighbor has left the multicast group.
&  Note:
l      You must enable a PIM protocol (PIM-DM or PIM-SM) in VLAN interface view before you can proceed with this configuration.
l      When you configure the time interval for a port to send Hello packets, the PIM neighbor hold-time value is automatically set to 3.5 times the Hello interval. Therefore you need not configure the PIM neighbor hold-time separately.
Example
# Set the time interval to send Hello packets for VLAN-interface10 to 40 seconds.
<H3C> system-view
[H3C-Vlan-interface10] pim timer hello 40
5.1.20  register-policy
register-policy acl-number
undo register-policy
View
PIM view
Parameter
acl-number: Number of IP advanced ACL, defining the rule of filtering the source and group addresses. The value ranges from 3000 to 3999.
Use the register-policy command to configure a RP to filter the register messages sent by the DR in the PIM-SM network and to accept the specified messages only.
Use the undo register-policy command to remove the configured message filtering.
Example
# If the local device is the RP in the network, using the following command can only accept multicast message register of the source sending multicast address in the range of 225.1.0.0/16 on network segment 10.10.0.0/16.
<H3C> system-view
[H3C] acl number 3010
[H3C-acl-adv-3010] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[H3C-acl-adv-3010] quit
[H3C] pim
[H3C-pim] register-policy 3010
5.1.21  reset pim neighbor
reset pim neighbor { all | { neighbor-address | interface interface-type interface-number } * }
View
Parameter
all: All PIM neighbors
neighbor-address: Specifies neighbor address.
interface interface-type interface-number: Specifies interface.
Use the reset pim neighbor command to clear a PIM neighbor.
Related command: display pim neighbor.
Example
# Clear the PIM neighbor 25.5.4.3.
<H3C> reset pim neighbor 25.5.4.3
5.1.22  reset pim routing-table
reset pim routing-table { all | { group-address [ mask group-mask | mask-length group-mask-length ] | source-address [ mask source-mask | mask-length source-mask-length ] | { incoming-interface interface-type interface number | null } } * }
View
Parameter
all: All PIM neighbors.
group-address: Specifies group address.
mask group-mask: Specifies group mask.
mask-length group-mask-length: Specifies mask length of the group address.
mask source-mask: Specifies source mask.
mask-length source-mask-length: Specifies mask length of the group address.
incoming-interface: Specifies incoming interface for the route entry in PIM routing table.
Use the reset pim routing-table command to clear a PIM route entry.
You can type in source address first and group address after in the command, as long as they are valid. Error information will be given if you type in invalid addresses.
If in this command, the group-address is 224.0.0.0/24 and source-address is the RP address (where group address can have a mask, but the resulted IP address must be 224.0.0.0, and source address has no mask), then it means only the (*, *, RP) item will be cleared.
If in this command, the group-address is any a group address, and source-address is 0 (where group address can have a mask, and source address has no mask), then only the (*, G) item will be cleared.
This command shall clear not only multicast route entries from PIM routing table, but also the corresponding route entries and forward entries in the multicast core routing table and MFC.
Related command: reset multicast routing-table, reset multicast forwarding-table and display pim routing-table.
Example
# Clear the route entries with group address 225.5.4.3 from the PIM routing table.
5.1.23  source-policy
source-policy acl-number
undo source-policy
View
PIM view
Parameter
acl-number: Basic or advanced ACL, in the range of 2000 to 3999.
Use the source-policy command to set the router to filter the multicast data packets based on source (or group) address.
Use the undo static-rp command to remove the configuration.
If resource address filtering is configured, as well as basic ACLs, then the router filters the resource addresses of all multicast data packets received. Those not matched will be discarded.
If resource address filtering is configured, as well as advanced ACLs, then the router filters the resource and group addresses of all multicast data packets received. Those not matched will be discarded.
When this feature is configured, the router filters not only multicast data, but the multicast data encapsulated in the registration packets.
Example
# Set to receive the multicast data packets from source address 10.10.1.2, but discard those from 10.10.1.1.
<H3C> system-view
[H3C] pim
[H3C-pim] source-policy 2000
[H3C-pim] quit
5.1.24  static-rp
static-rp rp-address [ acl-number ]
undo static-rp
View
PIM view
Parameter
rp-address: Static RP address, only being legal unicast IP address.
acl-number: Basic ACL, used to control the range of multicast group served by static RP, which ranges from 2000 to 2999. If an ACL is not specified upon configuration, static RP will serve all multicast groups; if an ACL is specified, static RP will only serve the multicast group passing the ACL.
Use the static-rp command to configure static RP.
Static RP functions as the backup of dynamic RP so as to improve the network robustness. If the RP elected by BSR mechanism is valid, static RP will not work.
All routers in the PIM domain should be configured with this command and be specified with the same RP address.
  Caution:
l      When the BSR-elected RP is effective, the static RP does not work.
l      All routers in the PIM domain must be configured with this command simultaneously, with the same RP address specified.
l      The system supports up to ten different static RP addresses. When more than ten static RP addresses are configured, the system will give this prompt information: “Cannot config static-rp, exceeded static-rp  limit 10”.
Related command: display pim rp-info.
Example
# Configure 10.110.0.6 as a static RP.
<H3C> system-view
[H3C] pim
[H3C-pim] static-rp 10.110.0.6
# Remove the static RP with the IP address of 10.110.0.6.
<H3C> system-view
[H3C] pim
[H3C-pim] undo static-rp 10.110.0.6
Chapter 6  MSDP Configuration Commands
&  Note:
An Ethernet switch functions as a router when it supports the layer 3 protocols. A router that is referred to in the following represents a generalized router or a layer 3 Ethernet switch running related protocols.
6.1  MSDP Configuration Commands
6.1.1  cache-sa-enable
cache-sa-enable
undo cache-sa-enable
View
MSDP view
Parameter
None
Use the cache-sa-enable command to enable the router to cache SA state.
Use the undo cache-sa-enable command to remove the cache from the router.
By default, the router caches the SA state, i.e., (S, G) entry after it receives SA messages.
If the router is in cache state, it will not send SA request message to the specified MSDP peer when it receives a new group join message.
Example
# Configure the router to cache all the SA states.
<H3C> system-view
[H3C] msdp
[H3C-msdp] cache-sa-enable
6.1.2  debugging msdp
debugging msdp { all | connect | event | packet | source-active }
undo debugging msdp { all | connect | event | packet | source-active }
View
Parameter
all: All the debugging information of MSDP.
connect: Debugging information of MSDP peer connection reset.
event: Debugging information of MSDP event.
packet: Debugging information of MSDP packet.
source-active: Debugging information of active MSDP source.
Use the debugging msdp command to enable MSDP debugging functions.
Use the undo debugging msdp command to disable MSDP debugging functions.
By default, MSDP debugging functions are disabled.
Example
# Enable all common MSDP debugging functions.
<H3C> debugging msdp all
6.1.3  display msdp brief
display msdp brief
View
Parameter
None
Use the display msdp brief command to view the state of MSDP peer.
Example
# Display the state of MSDP peer.
<H3C> display msdp brief
MSDP Peer Brief Information
  Peer's Address     State   Up/Down time   AS     SA Count  Reset Count
  20.20.20.20        Up       00:00:13        100    0          0
6.1.4  display msdp peer-status
display msdp peer-status [ peer-address ]
View
Parameter
peer-address: Address of MSDP peer.
Use the display msdp peer-status command to view the detailed information of MSDP peer.
Related command: peer.
Example
# Display the detailed information of the MSDP peer 10.110.11.11.
<H3C> display msdp peer-status 10.110.11.11
MSDP Peer 20.20.20.20, AS 100
  Description:
  Information about connection status:
    State: Up
    Up/down time: 14:41:08
    Resets: 0
    Connection interface: LoopBack0 (20.20.20.30)
    Number of sent/received messages: 867/947
    Number of discarded output messages: 0
    Elapsed time since last connection or counters clear: 14:42:40
  Information about (Source, Group)-based SA filtering policy:
    Import policy: none
    Export policy: none
  Information about SA-Requests:
    Policy to accept SA-Request messages: none
    Sending SA-Requests status: disable
  Minimum TTL to forward SA with encapsulated data: 0
  SAs learned from this peer: 0, SA-cache maximum for the peer: none
  Input queue size: 0, Output queue size: 0
  Counters for MSDP message:
    Count of RPF check failure: 0
    Incoming/outgoing SA messages: 0/0
    Incoming/outgoing SA requests: 0/0
    Incoming/outgoing SA responses: 0/0
    Incoming/outgoing data packets: 0/0
6.1.5  display msdp sa-cache
display msdp sa-cache [ group-address | source-address | autonomous-system-number ]*
View
Parameter
group-address: Group address of (S, G) entry.
source-address: Source address of (S, G) entry. With no source address specified, all the source information of the specified group will be displayed.
If neither group address nor source address is determined, all SA caches will be displayed.
autonomous-system-number: Displays (S, G) entries from specified autonomous system.
Use the display msdp sa-cache command to view (S, G) state learnt from MSDP peer.
Only cache-sa-enable command is configured, can cache state be displayed.
Example
# Display the (S, G) state learned from MSDP peer.
<H3C> display msdp sa-cache
MSDP Total Source-Active Cache - 5 entries
(Source, Group)                  Origin RP       Pro   AS   Uptime   Expires
(10.10.1.2, 225.1.1.1)             10.10.10.10     BGP  100   00:00:10 00:05:50
(10.10.1.3, 225.1.1.1)             10.10.10.10     BGP  100   00:00:11 00:05:49
(10.10.1.2, 225.1.1.2)             10.10.10.10     BGP  100   00:00:11 00:05:49
(10.10.2.1, 225.1.1.2)             10.10.10.10     BGP  100   00:00:11 00:05:49
(10.10.1.2, 225.1.2.2)             10.10.10.10     BGP  100   00:00:11 00:05:49
MSDP matched 5 entries
6.1.6  display msdp sa-count
display msdp sa-count [ as-number ]
View
Parameter
as-number: Number of sources and groups from the specified autonomous system.
Use the display msdp sa-count command to view the number of sources and groups in MSDP cache.
The cache-sa-enable command must be configured before the configuration of this command.
Example
# view the number of sources and groups in MSDP cache.
<H3C> display msdp sa-count
Number of cached Source-Active entries, counted by Peer
  Peer's Address     Number of SA
  10.10.10.10        5
  Number of source and group, counted by AS
  AS     Number of source    Number of group
  ?      3                      3
  Total Source-Active entries: 5
6.1.7  import-source
import-source [ acl acl-number ]
undo import-source
View
MSDP view
Parameter
acl-number: Number of basic or advanced IP ACL, ranging from 2000 to 3999, controlling which sources SA messages will advertise and to which groups it will be sent in the domain. Basic ACL performs filtering to source and advanced ACL performs filtering to source/group. If no ACL is specified, no multicast source will be advertised.
Use the import-source command to configure which (S, G) entries in the domain need to be advertised when a MSDP originates an SA message.
Use the undo import-source command to remove the configuration.
By default, all the (S, G) entries in the domain are advertised by the SA message.
Besides controlling SA messages creation, you can filter the forwarded SA messages by the commands peer sa-policy import and peer sa-policy export.
Example
# Configure which (S, G) entries from the multicast routing table will be advertised in SA messages originated by the MSDP peer.
<H3C> system-view
[H3C] acl number 3001
[H3C-acl-adv-3001] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[H3C-acl-adv-3001] quit
[H3C] msdp
[H3C-msdp] import-source acl 3001
6.1.8  msdp
msdp
undo msdp
View
Parameter
None
Use the msdp command to enable MSDP and enter the MSDP view.
Use the undo msdp command to clear all configurations of MSDP, release all resources that MSDP occupies, and restore the initial state.
Example
# Clear all configurations of MSDP.
<H3C> system-view
[H3C] undo msdp
6.1.9  msdp-tracert
msdp-tracert source-address group-address rp-address [ max-hops max-hops | next-hop-info | sa-info | peer-info | skip-hops skip-hops ]*
View
Parameter
source-address: Multicast source address.
group-address: Multicast group address.
rp-address: IP address of RP.
max-hops: The maximum number of hops that are traced, ranging from 1 to 255. By default, the value is 16.
next-hop-info: Flag bit for collecting the next hop information.
sa-info: Flag bit for collecting SA entity information.
peer-info: Flag bit for collecting MSDP peer information.
skip-hops: Number of hops that are skipped before collecting detailed information, ranging from 0 to 255. By default, the value is 0.
Use the msdp-tracert command to trace the transmission path of SA messages in the network, which helps to locate the faults such as information loss and configuration error. After the transmission path of SA messages is determined, correct configuration can avoid the overflow of SA messages.
Example
# Trace (10.10.1.1, 225.2.2.2, 20.20.20.20) path information.
<H3C> msdp-tracert 10.10.1.1 225.2.2.2 20.20.20.20
# Specify the maximum number of hops that are traced and collect detailed information of SA and MSDP peer.
<H3C> msdp-tracert 10.10.1.1 225.2.2.2 20.20.20.20 max-hops 10 sa-info peer-info
MSDP tracert: press CTRL_C to break
 D-bit:  set if have this (S,G) in cache but with a different RP
 RP-bit: set if this router is an RP
 NC-bit: set if this router is not caching SA's
 C-bit:  set if this (S,G,RP) tuple is in the cache
 MSDP Traceroute path information:
   Router Address:  20.20.1.1
     Fixed-length response info:
       Peer Uptime: 10 minutes,  Cache Entry Uptime: 30 minutes
       D-bit: 0,  RP-bit: 1,  NC-bit: 0,  C-bit: 1
       Return Code: Reached-max-hops
     Next Hop info:
       Next-Hop Router Address: 0.0.0.0
     SA info:
       Count of SA messages received for this (S,G,RP): 0
       Count of encapsulated data packets received for this (S,G,RP):0
       SA cache entry uptime: 00:30:00 ,  SA cache entry expiry time: 00:03:32
     Peering info:
       Peering Uptime: 10 minutes,  Count of Peering Resets: 3
Table 6-1 Description of msdp-tracert command domain
Item
Router Address
Address where the local router creates Peering session with Peer-RPF neighbor.
Peer Uptime
Time for which the local router performs Peering session with Peer-RPF neighbor in minute, with the maximum value of 255.
Cache Entry Uptime
Present time of (S, G, RP) entry in SA cache of the local router, in minute, with the maximum value of 255.
D-bit: 1
(S, G, RP) entry existing in SA cache of the local router.
But the RP is different from the RP specified in the request message.
RP-bit: 1
The local router is an RP, but it is not necessarily the source RP in (S, G, RP) entry.
NC-bit: 0
The local router enables SA cache.
C-bit: 1
(S, G, RP) entry exists in SA cache of the local router.
Return reason is the reached maximum hops and other possible value includes:
Hit-src-RP: The local hop router is the source RP in (S, G, RP) entry.
If the parameter next-hop-info is used, Peer-RPF neighbor address will be displayed.
Number of SA messages received for tracing this (S, G, RP) entry.
Number of encapsulated data packets received for tracing this (S, G, RP) entry.
Present time of SA cache entry.
Expiry time of SA cache entry.
Time for which the local router performs Peering session with Peer-RPF neighbor.
Number of Peering session resets.
6.1.10  originating-rp
originating-rp interface-type interface-number
undo originating-rp
View
MSDP view
Parameter
interface-type: Interface type.
interface-number: Interface number.
Use the originating-rp command to allow a MSDP to use the IP address of specified interface as the RP address when the SA message originated.
Use the undo originating-rp command to remove the configuration.
By default, the RP address in the SA message is the RP address configured by PIM.
Configure logical RP by using this command.
Example
# Configure IP address of the interface Vlan-interface10 as the RP address in the SA message originated.
<H3C> system-view
[H3C] msdp
[H3C-msdp] originating-rp Vlan-interface 10
6.1.11  peer
peer peer-address connect-interface interface-type interface-number
undo peer peer-address
View
MSDP view
Parameter
connect-interface interface-type interface-number: Interface type and number whose primary address is used by the local router as the source IP address to establish TCP connection with remote MSDP peers.
Use the peer command to configure an MSDP peer.
Use the undo peer command to remove the MSDP peer configured.
If the local router is also in BGP peer relation with a MSDP peer, the MSDP peer and the BGP peer should use the same IP address.
Related command: static-rpf-peer.
Example
# Configure the router using IP address 125.10.7.6 as an MSDP peer of the local router.
<H3C> system-view
[H3C] msdp
[H3C-msdp] peer 125.10.7.6 connect-interface Vlan-interface 10
6.1.12  peer description
peer peer-address description text
undo peer peer-address description
View
MSDP view
Parameter
text: Descriptive text, being case sensitive. The maximum length is 80 characters.
Use the peer description command to configure descriptive text to MSDP peer.
Use the undo peer description command to remove the descriptive text configured.
By default, an MSDP peer has no descriptive text.
Administrator can conveniently differentiate MSDP peers by configuring descriptive text.
Related command: display msdp peer-status.
Example
# Add descriptive text CstmrA to router 125.10.7.6 to specify that the router is Client A.
<H3C> system-view
[H3C] msdp
[H3C-msdp] peer 125.10.7.6 description router CstmrA
6.1.13  peer mesh-group
peer peer-address mesh-group name
undo peer peer-address mesh-group name
View
MSDP view
Parameter
name: Name of a Mesh Group, being case sensitive. The maximum length is 32 characters.
peer-address: Address of an MSDP peer to be a member of the Mesh Group.
Use the peer mesh-group command to configure an MSDP peer to join an Mesh Group.
Use the undo peer mesh-group command to remove the configuration.
By default, an MSDP peer is not a member of any Mesh Group.
Example
# Configure the MSDP peer with address 125.10.7.6 to be a member of the Mesh Group Grp1.
<H3C> system-view
[H3C] msdp
[H3C-msdp] peer 125.10.7.6 mesh-group Grp1
6.1.14  peer minimum-ttl
peer peer-address minimum-ttl ttl
undo peer peer-address minimum-ttl
View
MSDP view
Parameter
peer-address: Address of the MSDP peer to which the TTL limitation applies.
ttl: TTL threshold, ranging from 0 to 255.
Use the peer minimum-ttl command to configure the minimum TTL (Time-to-Live) value of the multicast data packets encapsulated in SA messages to be sent to specified MSDP peer.
Use the undo peer minimum-ttl command to restore the default TTL threshold.
By default, the value of TTL threshold is 0.
Example
# Configure the TTL threshold value to 10, i.e., only those multicast data packets with a TTL value greater than or equal to 10 can be forwarded to the MSDP peer 110.10.10.1.
<H3C> system-view
[H3C] msdp
[H3C-msdp] peer 110.10.10.1 minimum-ttl 10
6.1.15  peer request-sa-enable
peer peer-address request-sa-enable
undo peer peer-address request-sa-enable
View
MSDP view
Parameter
Use the peer request-sa-enable command to enable the router to send SA request message to the specified MSDP peer when receiving a new group join message.
Use the undo peer request-sa-enable command to remove the configuration.
By default, when receiving a new group join message, the router sends no SA request messages to MSDP peers but waits to receive the next SA message.
Related command: cache-sa-enable.
Example
# Configure to send SA request message to the MSDP peer 125.10.7.6.
<H3C> system-view
[H3C] msdp
[H3C-msdp] peer 125.10.7.6 request-sa-enable
6.1.16  peer sa-cache-maximum
peer peer-address sa-cache-maximum sa-limit
undo peer peer-address sa-cache-maximum
View
MSDP view
Parameter
sa-limit: Maximum value that the SA cache allows, ranging from 1 to 2048.
Use the peer sa-cache-maximum command to limit the number of caches originated when the router receives SA messages from an MSDP peer.
Use the undo peer sa-cache-maximum command to restore the default configuration.
By default, the maximum number of SA caches is 2048.
This configuration is recommended for all MSDP peers in the networks possibly attacked by DoS.
Related command:: display msdp, sa-count, display msdp peer-status, display msdp brief.
Example
# Limit the number of caches originated to 100 when the router receives SA messages from the MSDP peer 125.10.7.6.
<H3C> system-view
[H3C] msdp
[H3C-msdp] peer 125.10.7.6 sa-cache-maximum 100
6.1.17  peer sa-policy
peer peer-address sa-policy { import | export } [ acl acl-number ]
undo peer peer-address sa-policy { import | export }
View
MSDP view
Parameter
import: Receives SA messages from the specified MSDP peer.
export: Forwards SA messages from the specified MSDP peer.
peer-address: Address of the MSDP peer whose SA messages need to be filtered.
acl acl-number: Number of advanced IP ACL, ranging from 3000 to 3999. If no ACL is specified, all (S, G) entries are filtered.
Use the peer sa-policy command to configure a filter list for SA messages received or forwarded from the specified MSDP peer.
Use the undo peer sa-policy command to remove the configuration.
By default, messages received or forwarded will not be filtered. All SA messages are received or forwarded from an MSDP peer.
Example
# Forward only those SA messages that passed the advanced IP ACL.
<H3C> system-view
[H3C-acl-adv-3000] rule permit ip source 170.15.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[H3C-acl-adv-3000] quit
[H3C] msdp
[H3C-msdp] peer 125.10.7.6 sa-policy export acl 3000
6.1.18  peer sa-request-policy
peer peer-address sa-request-policy [ acl acl-number ]
undo peer peer-address sa-request-policy
View
MSDP view
Parameter
peer-address: Address from which the local router receives SA request messages sent by the specified MSDP peer.
acl acl-number: Number of basic IP ACL, describing multicast group address, ranging from 2000 to 2999. If no ACL is specified, all SA request messages will be ignored.
Use the peer sa-request-policy command to limit SA request messages that the router receives from MSDP peers.
Use the undo peer sa-request-policy command to remove the limitation.
By default, the router receives all SA request messages from the MSDP peer.
If no ACL is specified, all SA requests will be ignored. If ACL is specified, only those SA request messages from the groups permitted by the ACL will be processed and all the others will be ignored.
Example
# Configure the ACL for filtering SA request messages from the MSDP peer 175.58.6.5. The SA request messages from group address range 225.1.1.0/8 will be received and all the others will be ignored.
<H3C> system-view
[H3C-acl-basic-2000] rule permit source 225.1.1.0 0.0.0.255
[H3C-acl-basic-2000] quit
[H3C] msdp
[H3C-msdp] peer 175.58.6.5 sa-request-policy acl 2000
6.1.19  reset msdp peer
reset msdp peer peer-address
View
Parameter
Use the reset msdp peer command to reset TCP connection with the specified MSDP peer, and clear all the statistics of the specified MSDP peer.
Example
# Clear TCP connection and statistics of the MSDP peer 125.10.7.6.
<H3C> reset msdp peer 125.10.7.6
6.1.20  reset msdp sa-cache
reset msdp sa-cache [ group-address ]
View
Parameter
group-address: Address of the group, (S, G) entries matching this address are cleared from the SA cache. If no multicast group address is specified, all SA cache entries will be cleared.
Use the reset msdp sa-cache command to clear SMDP SA cache entries.
Related command: cache-sa-enable and display msdp sa-cache.
Example
# Clear the cache entries with group address 225.5.4.3 from the SA cache.
<H3C> reset msdp sa-cache 225.5.4.3
6.1.21  reset msdp statistics
reset msdp statistics [ peer-address ]
View
Parameter
peer-address: Address of the MSDP peer whose statistics, resetting information and input/output information will be cleared. If no MSDP peer address is specified, all MSDP peers statistics will be cleared.
Use the reset msdp statistics command to clear statistics of one or more MSDP peers without resetting the MSDP peer.
Example
# Clear the statistics of the MSDP peer 25.10.7.6.
<H3C> reset msdp statistics 125.10.7.6
6.1.22  shutdown
shutdown peer-address
undo shutdown peer-address
View
MSDP view
Parameter
peer-address: IP address of MSDP peer.
Use the shutdown command to disable the MSDP peer specified.
Use the undo shutdown command to remove the configuration.
By default, no MSDP peer is disabled.
Example
# Disable the MSDP peer 125.10.7.6.
<H3C> system-view
[H3C] msdp
[H3C-msdp] shutdown 125.10.7.6
6.1.23  static-rpf-peer
static-rpf-peer peer-address [ rp-policy ip-prefix-name ]
undo static-rpf-peer peer-address
View
MSDP view
Parameter
peer-address: Address of the static RPF peer to receive SA messages.
rp-policy ip-prefix-name: Filter policy based on RP address, which filters the RP in SA messages. If the parameter is not specified, all SA messages from static RPF peer will be accepted. If the parameter rp-policy ip-prefix-name is specified and filter policy is configured, the router will only accept SA messages from the RP which passes filtering. If no filter policy is configured, the router will still accept all SA messages from the static RPF peer.
Use the static-rpf-peer command to configure static RPF peer.
Use the undo static-rpf-peer command to remove the static RPF peer.
By default, no static RPF peer is configured.
&  Note:
l      You must configure the peer command before using the static-rpf-peer command.
l      If only one MSDP peer is configured on a router, this MSDP peer will be regarded as a static RPF peer.
Related command: peer and ip prefix-list.
Example
# Configure two static RPF peers.
<H3C> system-view
[H3C] ip ip-prefix list1 permit 130.10.2.3 32
[H3C] ip ip-prefix list2 permit 130.10.2.4 32
[H3C] msdp
[H3C-msdp] peer 130.10.7.6 connect-interface Vlan-interface 10
[H3C-msdp] peer 130.10.7.5 connect-interface Vlan-interface 10
[H3C-msdp] static-rpf-peer 130.10.7.6 rp-policy list1
[H3C-msdp] static-rpf-peer 130.10.7.5 rp-policy list2
In the above commands, 130.10.2.3 is the IP address of the RP for 130.10.7.5 and 130.10.2.4 is the IP address of the RP of 130.10.7.6.
6.1.24  timer retry
timer retry seconds
undo timer retry
View
MSDP view
Parameter
seconds: Value of connection request retry period in second, ranging from 1 to 60.
Use the timer retry command to configure the value of connection request re-try period.
Use the undo timer retry command to restore the default value.
By default, the value of connection request re-try period is 30 seconds.
Example
# Configure the connection request re-try period to 60 seconds.
<H3C> system-view
[H3C] msdp
[H3C-msdp] timer retry 60
Chapter 7  MBGP Multicast Extension Configuration Commands
7.1  MBGP Multicast Extension Configuration Commands
7.1.1  aggregate
aggregate address mask [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ]*
undo aggregate address mask [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ]*
View
IPv4 multicast sub-address family view
Parameter
address: Address of the aggregated route.
mask: Network mask of the aggregated route.
as-set: Generates a route with AS_SET segment. This parameter is not recommended when aggregating many AS paths.
attribute-policy route-policy-name: Sets aggregate attribute.
detail-suppressed: Advertises the aggregated routes rather than the specific routes.
origin-policy route-policy-name: Filters the originate routes of the aggregate.
suppress-policy route-policy-name: Does not advertise the specific routes selected.
Use the aggregate command to create a multicast aggregated record in the BGP routing table.
Use the undo aggregate command to disable this function.
By default, no route is aggregated.
Use the aggregate command without parameters to create one local aggregated route and set atomic aggregation attributes.
Example
# Create an aggregation entry in the MBGP routing table, with aggregated route address as 192.213.0.0.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp] ipv4-family multicast
[H3C-bgp-af-mul] aggregate 192.213.0.0 255.255.0.0
7.1.2  compare-different-as-med
undo compare-different-as-med
View
Parameter
None
Use the compare-different-as-med command to enable to compare the route MED values of neighbors from different ASs.
Use the undo compare-different-as-med command to disable this function.
By default, the comparison function is disabled.
If there are multiple routes available to the same destination address, you can select the route with the smallest MED value.
This command is not recommended unless you make sure that different ASs use the same IGP and route selection modes.
Example
# Enable to compare the route MED values of neighbors from different ASs.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] compare-different-as-med
7.1.3  debugging bgp mp-update
debugging bgp mp-update [ receive | send ] [ verbose ]
undo debugging bgp mp-update
View
Parameter
receive: Debugs the MBGP Update messages received.
send: Debugs the MBGP Update messages sent.
verbose: Debugs detailed information.
Use the debugging bgp mp-update command to enable to debug MBGP Update messages.
Use the undo debugging bgp mp-update command to disable the debugging.
By default, the debugging function is disabled.
Example
# Enable MBGP Update message debugging.
<H3C> debugging bgp mp-update
7.1.4  default local-preference
undo default local-preference
View
Parameter
value: Configures default local precedence, in the range of 0 to 4294967295. By default, it is 100. The greatest value corresponds to the highest precedence level.
Use the default local-preference command to configure the default local precedence.
Use the undo default local-preference command to restore the default value.
You can affect BGP route selection by configuring different local precedence values.
Example
# Configure the default local precedence value as 180.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] default local-preference 180
7.1.5  default med
default med med-value
undo default med
View
Parameter
med-value: Specifies MED value, in the range of 0 to 4294967295. By default, it is 0.
Use the default med command to configure system MED value.
Use the display bgp multicast group command to restore the default value.
Multi-exit discriminator (MED) attribute is the external metric for a route. Unlike local precedence attribute, MED is exchanged, between ASs, and one it enters an AS, it does not leave the AS. MED attribute is used in best route selection. When a router running BGP travels through different external peers and get the routes with identical destination, but different next-hop addresses, it selects these routes according to their MED values. The route with smaller MED value will be selected as the external AS route if other attributes are the same.
Example
# Configure system MED value as 25.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] default med 25
7.1.6  display bgp multicast group
display bgp multicast group [ group-name ]
View
Parameter
group-name: Specified peer group. If no peer group is specified, the information about all peer groups will be displayed.
Use the display bgp multicast group command to view the information about peer groups.
Example
# View the information about the peer group named my_peer.
<H3C> display bgp multicast group my_peer
7.1.7  display bgp multicast network
View
Parameter
None
Use the display bgp multicast network command to view the routing information that MBGP advertises.
Example
# View the network segment routing information MBGP advertises.
<H3C> display bgp multicast network
7.1.8  display bgp multicast peer
display bgp multicast peer [ peer-address ] [ verbose ]
View
Parameter
peer-address: Peer address, in dotted decimal format.
verbose: Displays detailed information.
Use the display bgp multicast peer command to view the MBGP peer information.
Example
# View the MBGP peer detailed information.
<H3C> display bgp multicast peer verbose
7.1.9  display bgp multicast routing-table
display bgp multicast routing-table [ ip-address [ mask ] ]
View
Parameter
ip-address: Displays the MBGP routing information with specified IP address.
Use the display bgp multicast routing-table command to view MBGP routing information.
Example
# Display MBGP routing information of network segment 14.1.0.0.
<H3C> display bgp multicast routing-table 14.1.0.0
7.1.10  display bgp multicast routing-table as-path-acl
display bgp multicast routing-table as-path-acl acl-number
View
Parameter
acl-number: Specifies matched AS path list number ranging from 1 to 199.
Use the display bgp multicast routing-table as-path-acl command to view routes that match an as-path acl.
Example
# Display routes that match the as-path-acl 2.
<H3C> display bgp multicast routing-table as-path-acl 2
7.1.11  display bgp multicast routing-table cidr
View
Parameter
None
Use the display bgp multicast routing-table cidr command to view the non-natural network mask, namely the classless inter-domain routing (CIDR) information.
Example
# View CIDR routing information.
<H3C> display bgp multicast routing-table cidr
7.1.12  display bgp multicast routing-table community
display bgp multicast routing-table community [ aa:nn | no-export-subconfed | no-advertise | no-export ]* [ whole-match ]
View
Parameter
aa:nn: Specified community number.
no-export-subconfed: Does not send matched routes outside the local autonomous system.
no-advertise: Does not advertise matched routes to any peer.
no-export: Does not advertise routes outside the local autonomous system but advertise routes to other sub-autonomous systems.
whole-match: Exact match.
Use the display bgp multicast routing-table community command to view routing information of a specified MBGP community.
Example
# Display routing information of the specified MBGP community
<H3C> display bgp multicast routing-table community 600:1
7.1.13  display bgp multicast routing-table community-list
display bgp multicast routing-table community-list community-list-number [ whole-match ]
View
Parameter
community-list-number: Number of the specified community list.
exact-match: Exact match.
Use the display bgp multicast routing-table community-list command to view the routing information of a specified MBGP community list.
Example
# Display routing information of the specified MBGP community list.
<H3C> display bgp multicast routing-table community-list 1
7.1.14  display bgp multicast routing-table different-origin-as
View
Parameter
None
Use the display bgp multicast routing-table different-origin-as command to view AS routes of different origins.
Example
# Display AS routes of different origins.
<H3C> display bgp multicast routing-table different-origin-as
7.1.15  display bgp multicast routing-table peer
display bgp multicast routing-table peer peer-address { received | advertised } [ network-address [ mask ] | statistic ]
View
Parameter
peer-address: Specified peer address, in dotted decimal format.
received: Routing information received from a specified peer.
advertised: Routing information advertised from a specified peer.
network-address: IP address of the destination network.
mask: Mask of the destination network.
statistic: Displays statistic information of the route.
Use the display bgp multicast routing-table peer command to view the routes received/advertised at/to the specified peer.
Example
# Display routing information advertised to the peer 10.10.1.11.
<H3C> display bgp multicast routing-table peer 10.10.1.11 advertised
7.1.16  display bgp multicast routing-table regular-expression
display bgp multicast routing-table regular-expression as-regular-expression
View
Parameter
as-regular-expression: AS regular expression matched.
Use the display bgp multicast routing-table regular-expression command to view the routing information matching the specified AS regular expression.
Example
# Display routing information matching AS regular expression ^600$.
<H3C> display bgp multicast routing-table regular-expression ^600$
7.1.17  filter-policy export
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol ]
undo filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol ]
View
Parameter
acl-number: Specifies the ACL used in matching the destination address domain of routing information, in the range of 2000 to 3999.
ip-prefix-name: Specifies the IP prefix used in matching the destination address domain of routing information, in the range of 1 to 19.
Protocol: Specifies which kind of routing information shall be filtered out, with options currently available include direct, ospf, ospf-ase, ospf-nssa, rip, is-is and static.
Use the filter-policy export command to set to filter the advertised routes. Only those pass through the filter can be advertised by BGP.
Use the undo filter-policy export command to cancel route filtering.
By default, filtering the advertised routes is not enabled.
The command affects route advertising by BGP. If you specify the protocol parameter, the router only filters the routes with the specified protocol imported, without influence on the routes importing other protocols. Otherwise, the router filters the routes importing any protocols.
Example
# Filter all BGP-advertised routes using ACL 2000.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] filter-policy 2000 export
7.1.18  filter-policy import
filter-policy gateway ip-prefix-name import
undo filter-policy gateway ip-prefix-name import
filter-policy { acl-number | ip-prefix ip-prefix-name } import
undo filter-policy { acl-number | ip-prefix ip-prefix-name } import
View
Parameter
ip-prefix ip-prefix-name: Specifies the IP prefix used in matching the destination address domain of routing information, in the range of 1 to 19.
gateway ip-prefix-name: IP prefix of the neighbor router, in the range of 1 to 19, to filter the routing information advertised by a specified neighbor router.
Use the filter-policy gateway import command to set to filter the routes advertised by a specified neighbor router. Only those pass through the filter can be advertised by BGP.
Use the undo filter-policy gateway import command to cancel route filtering.
Use the filter-policy import command to set to filter the global routes received.
Use the undo filter-policy import command to cancel route filtering.
By default, filtering the received routes is not enabled.
This configuration determines whether to add the routes into the BGP routing table.
Example
# Filter all BGP-received routes using ACL 2000.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] filter-policy 2000 import
7.1.19  import-route
import-route protocol [ route-policy route-policy-name | med med-value ]*
undo import-route protocol
View
Parameter
protocol: Specifies the source routing protocols that can be imported, which can be direct, ospf, ospf-ase, ospf-nssa, rip, isis and static.
med-value: Specifies the metric value loaded by an imported route, ranging from 0 to 4,294,967,295.
route-policy-name: Specifies the route policy used for importing routes.
Use the import-route command to import routing information of other protocols into MBGP.
Use the undo import-route command to cancel the importing.
By default, MBGP will not import routing information of other protocols.
Example
# Import static routes.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] import-route static
7.1.20  ipv4-family multicast
undo ipv4-family multicast
View
BGP view, VPN instance sub-address family view, VPNv4 sub-address family view
Parameter
None
Use the ipv4-family multicast command to enter the IPv4 multicast sub-address family view.
Use the undo ipv4-family multicast command to exit the IPv4 multicast sub-address family view, return to the unicast view and remove all the information in multicast.
Example
# Enter the IPv4 multicast sub-address family view.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul]
7.1.21  network
network ip-address [ address-mask ] [ route-policy route-policy-name ]
undo network ip-address [ address-mask ] [ route-policy route-policy-name ]
View
Parameter
ip-address: Network address that BGP advertises.
address-mask: Mask of the network address.
route-policy policy-name: Route-policy applied to the routes advertised.
Use the network command to configure the network addresses to be sent by the local MBGP.
Use the undo network command to remove the configuration.
By default, the local MBGP does not send any route.
Example
# Advertise routes to network segment 10.0.0.0/16.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] network 10.0.0.1 255.255.0.0
7.1.22  peer advertise-community
peer group-name advertise-community
undo peer group-name advertise-community
View
Parameter
group-name: Name of the peer group.
Use the peer advertise-community command to set to send community attributes to a peer group.
Use the undo peer advertise-community command to remove the configuration.
By default, no community attribute is sent to any peer group.
Example
# Set to send community attributes to peer group “test”.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer test advertise-community
7.1.23  peer allow-as-loop
peer { group-name | peer-address } allow-as-loop [ number ]
undo peer { group-name | peer-address } allow-as-loop
View
Parameter
peer-address: IP address of the peer.
number: Repetition number of local AS IDs, in the range of 1 to 10. By default ,the repetition number is 3.
Use the peer allow-as-loop command to specify repetition number of local AS IDs.
Use the undo peer allow-as-loop command to remove the configuration.
Related command: display current-configuration, display bgp routing-table peer and display bgp routing-table group.
Example
# Configure repetition number of local AS IDs as 2.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer 1.1.1.1 allow-as-loop 2
7.1.24  peer as-path-acl export
peer group-name as-path-acl acl-number export
undo peer group-name as-path-acl acl-number export
View
Parameter
group-name: Specifies name of the peer group.
acl-number: Specifies the filter list number of an AS regular expression. The range is 1 to 199.
export: Uses the AS path list to filter the advertised routes.
Use the peer as-path-acl export command to configure filtering Policy of MBGP advertised routes based on AS path list.
Use the undo peer as-path-acl command to cancel the existing configuration.
By default, the peer group has no AS path list.
This command can only be configured on peer group.
Related command: peer as-path-acl import, ip as-path-acl (refer to the “Routing Protocol” part).
Example
# Configure the peer group test to use AS path list 2 to filter the advertised routes.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer test as-path-acl 2 export
7.1.25  peer as-path-acl import
peer { group-name | peer-address } as-path-acl acl-number import
undo peer { group-name | peer-address } as-path-acl acl-number import
View
Parameter
peer-address: Specifies IP address of the peer.
import: Uses the AS path list to filter the received routes.
Use the peer as-path-acl import command to configure filtering Policy of MBGP received routes based on AS path list.
Use the undo peer as-path-acl import command to cancel the existing configuration.
By default, the peer/peer group has no AS path list.
The inbound filter policy configured for the peer takes precedence over the configurations for the peer group.
Related command: peer as-path-acl export, ip as-path-acl (refer to the “Routing Protocol” part).
Example
# Set the AS path ACL of the peer group test to filter BGP received routes.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer test as-path-acl 3 import
7.1.26  peer enable
peer group-name enable
undo peer group-name enable
View
Parameter
group-name: Name of the multicast peer group.
Use the peer enable command to enable the MBGP peer group.
Use the undo peer enable command to disable the MBGP peer group.
By default, the MBGP peer group is disabled.
Only after the peer group is enabled, can the router establishes connection with the multicast peer.
Example
# Enable peer group group1.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer group1 enable
7.1.27  peer filter-policy export
peer group-name filter-policy acl-number export
undo peer group-name filter-policy acl-number export
View
Parameter
group-name: Specifies the name of the peer group.
acl-number: Specifies an IP acl number, ranging from 2000 to 3999. That is, you can use basic ACLs or advanced ACLs.
export: Applies the filter policy to the advertised routes. This keyword is only valid for the peer groups.
Use the peer filter-policy export command to configure the peer group to apply the ACL-based filter policy to the advertised routes. Use the undo peer filter-policy export command to cancel the existing configuration.
By default, no ACL-based filter policy is configured.
The peer filter-policy export command can only be configured on peer groups.
Related command: peer filter-policy import, acl .
Example
# Configure the peer group test to use ACL 2000 to filter the advertised routes.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer test filter-policy 2000 export
7.1.28  peer filter-policy import
peer { group-name | peer-address } filter-policy acl-number import
undo peer { group-name | peer-address } filter-policy acl-number import
View
Parameter
peer-address: Specifies the IP address of the peer.
Use the peer filter-policy import command to configure the peer to apply the ACL-based filter policy to the received routes. Use the undo peer filter-policy import command to cancel the existing configuration.
Related command: peer filter-policy export, acl.
Example
# Configure the peer group test to use ACL 2000 to filter the received routes.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer test filter-policy 2000 import
7.1.29  peer group
peer peer-address group group-name
View
Parameter
peer-address: IP address of the peer, in dotted decimal format.
group-name: Name of the peer, consisting of one to 47 alphanumeric characters.
Use the peer group command to add a peer into a peer group.
Use the undo peer group command to delete the peer.
  Caution:
You must firstly add the specific peer in the peer group in BGP view and enable the peer group in IPv4 multicast sub-address family view before you can this command.
Example
# Add peer 10.1.1.1 to EBGP peer group TEST.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp] group TEST
[H3C-bgp] peer TEST as-number 2004
[H3C-bgp] peer 10.1.1.1 group TEST
[H3C-bgp-af-mul] peer TEST enable
[H3C-bgp-af-mul] peer 10.1.1.1 group TEST
7.1.30  peer ip-prefix export
peer group-name ip-prefix prefixname export
undo peer group-name ip-prefix prefixname export
View
Parameter
group-name: Name of peer group.
prefixname: Name of the specified ip-prefix.
Use the peer ip-prefix export command to configure the route filtering policy of routes advertised by the peer group based on the ip-prefix.
Use the undo peer ip-prefix export command to cancel the route filtering policy of the peer/peer group based on the ip-prefix.
By default, the route filtering policy of the peer group is not specified.
The peer ip-prefix export command can only be configured on the peer groups.
Related command: ip ip-prefix, peer ip-prefix import.
Example
# Configure the route filtering policy of the peer group1 based on the ip-prefix list1.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer group1 ip-prefix list1 export
7.1.31  peer ip-prefix import
peer { group-name | peer-address } ip-prefix prefixname import
undo peer { group-name | peer-address } ip-prefix prefixname import
View
Parameter
prefixname: Name of the specified ip-prefix, a character string of 1 to 19 characters.
Use the peer ip-prefix import command to configure the route filtering policy of routes received by the peer based on the ip-prefix.
Use the undo peer ip-prefix import command to cancel the route filtering policy of the peer based on the ip-prefix.
By default, the route filtering policy of the peer is not specified.
The inbound route policy configured for the peer takes precedence over the configurations for the peer group.
Related command: peer ip-prefix export.
Example
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer group1 ip-prefix list1 import
7.1.32  peer next-hop-local
peer group-name next-hop-local
undo peer group-name next-hop-local
View
Parameter
Use the peer next-hop-local command to remove the processing of the next hop in routes which BGP will advertise to the peer group and set the local address as the next hop.
Use the undo peer next-hop-local command to cancel the configuration.
Example
# Set the local address as next-hop when advertising routes to peer group named test.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer test next-hop-local
7.1.33  peer public-as-only
peer group-name public-as-only
undo peer group-name public-as-only
View
Parameter
Use the peer public-as-only command to set to contain only public AS IDs in the MBGP Update message, but not private AS IDs.
Use the undo peer public-as-only command to restore the default setting, the router contains only private AS IDs in the MBGP Update message.
By default, the private AS ID is carried when BGP sends MBGP Update message.
Generally, MBGP sends MBGP Update message with the AS ID (which can be either the public AS number or private AS number) contained. To enable some egress routers to ignore the private AS ID when sending MBGP Update message, you can configure not to carry the private AS IDs when sending MBGP Update message.
Example
# Set not to carry private AS IDs when sending MBGP Update message to peer group "test”.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer test public-as-only
7.1.34  peer reflect-client
peer group-name reflect-client
undo peer group-name reflect-client
View
Parameter
Use the peer reflect-client command to configure a peer (group) as a client of the route reflector.
Use the undo peer reflect-client command to remove the configuration.
By default, there is no route reflector in the autonomous system.
Example
# Configure peer group “test” as the client of the route reflector.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer test reflect-client
7.1.35  peer route-policy export
peer group-name route-policy policy-name export
undo peer group-name route-policy policy-name export
View
Parameter
Use the peer route-policy export command to assign the Route-policy to the routes advertised to the peer group.
Use the undo peer route-policy export command to delete the specified Route-policy.
By default, the peer/peer group has no Route-policy association.
Related command: peer route-policy import.
Example
# Apply the Route-policy named test-policy to the route coming from the peer group test.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer test route-policy test-policy export
7.1.36  peer route-policy import
peer { group-name | peer-address } route-policy policy-name import
undo peer { group-name | peer-address } route-policy policy-name import
View
Parameter
policy-name: Name of the applied route policy.
Use the peer route-policy import command to assign the Route-policy to the route coming from the peer..
Use the undo peer route-policy import command to delete the specified Route-policy.
By default, the peer has no Route-policy association.
Related command: peer route-policy export.
Example
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] peer test route-policy test-policy import
7.1.37  preference
preference ebgp-value ibgp-value local-vlaue
undo preference
View
Parameter
ebgp-value: EBGP route priority, in the range of 1 to 256. By default, it is 256.
ibgp-value: IBGP route priority, in the range of 1 to 256. By default, it is 256.
local-value: Local route priority, in the range of 1 to 256. By default, it is 130.
Use the preference command to configure MBGP protocol priority.
Use the undo preference command to restore the default priority.
You can configure different priority values for different types of MBGP routes.
Example
# Set the priority of EBGP, IBGP and local routes all as 170.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] preference 170 170 170
7.1.38  reflect between-clients
undo reflect between-clients
View
Parameter
None
Use the reflect between-clients command to enable route reflection between clients.
Use the undo reflect between-clients command to disable route reflection between clients.
When configured, the route reflector can reflect routes of a client to other clients.
By default, all-connection is not required for the clients with route reflectors configured, since the routes are by default reflected from one client to others. For all-connection clients, route reflection is unnecessary.
Related command: reflector cluster-id and peer reflect-client.
Example
# Disable route reflection function.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] undo reflect between-clients
7.1.39  refresh bgp multicast
refresh bgp { all | peer-address | group group-name } multicast { import | export }
View
Parameter
all: Refreshes multicast sub-address family router of all peer .
peer-address: Refreshes multicast sub-address family router of all specified address peer .
group-name: Refreshes multicast sub-address family router of all member of specified peer .
import: Sends ROUTE-REFRESH packets, request the peer to send all multicast sub-address family router again .
export: Sends all multicast sub-address family router again .
Use the refresh bgp multicast command to request the peer to send multicast sub-address family router again, or send multicast sub-address family router again.
Example
# Request all the peers to send multicast sub-address family router again.
<H3C> refresh bgp all multicast import
7.1.40  reflector cluster-id
reflector cluster-id { cluster-id | address }
undo reflector cluster-id
View
Parameter
cluster-id: Route reflector cluster ID, in integer number or IP address format, range 1 to 4294967295.
address: Route reflector cluster ID in IP address format.
Use the reflector cluster-id command to configure route reflector cluster ID.
Use the undo reflector cluster-id command to delete route reflector cluster ID.
By default, each route reflector uses its own route ID as cluster ID.
In general, one cluster has only one route reflector, and then the router ID for the route reflector can be used to identify the cluster. If a cluster has several route reflectors, for multiple route reflectors can improve network stability, then you can use this command to specify the same cluster ID for them all.
Related command: reflect between-clients and peer reflect-client.
Example
# Specify cluster ID for local router, one of the router reflectors.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] reflector cluster-id 80
7.1.41  summary
summary
undo summary
View
Parameter
None
Use the summary command to set to auto-aggregate subnet routes.
Use the undo summary command to remove the configuration.
By default, subnet routes can not be aggregated automatically.
After the summary command is executed, MBGP cannot receive the subnet routes imported by IGP. You can use this command to reduce route selection information.
Example
# Enable subnet route auto-aggregation.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-af-mul] summary
