H3C S9500 Series Routing Switches Command Manual-(V1.01)
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Series Routing Switches Command Manual-(V1.01)
00-1Cover
00-1Cover 54 KB
Command Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08192R-20071125-C-1.01
Product Version: S9500-CMW310-R1278
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S9500 Series Routing Switches documentation set includes the following:
Manual
H3C S9500 Series Routing Switches  Installation Manual
It provides information for the system installation, booting, hardware/software maintenance & monitoring.
H3C S9500 Series Routing Switches  Operation Manual
It includes getting started, port, VLAN-QinQ, network protocol, routing protocol, multicast protocol, QACL,MPLS, STP, security,reliability, system management, PoE,NAT-URPF-VPLS,integrated management, and appendix.
Organization
H3C S9500 Series Routing Switches  Command Manual is organized as follows:
Part
1 Getting Started
This module introduces the commands available in the S9500 series.
2 Port
This module focuses on the commands for the configuration on Ethernet ports, POS ports, RPR ports, link aggregation, and IDS cooperation.
3 VLAN-QinQ
This module elaborates on the commands for VLAN, GARP, super VLAN and QinQ configuration.
4 Network Protocol
This module details the commands for the configuration on network protocols, including those for IP address, ARP, DHCP, DNS and IP performance configuration..
5 Routing Protocol
This module concentrates on the commands for the configuration on routing protocols, including those for static routing, RIP, OSPF, IS-IS, BGP and routing policy configuration.management.
6 Multicast Protocol
This module presents the commands for the configuration on multicast protocols, including those for IGMP Snooping, IGMP multicast VLAN, PIM-DM, PIM-SM, MSDP and MBGP multicast extension configuration.
7 QACL
This module introduces the commands for QoS/ACL configuration.
8 MPLS
This module introduces the commands for MPLS and BGP/MPLS VPN configuration.
9 STP
This module introduces the commands for STP configuration.
10 Security
This module presents the commands for the configuration on 802.1x, AAA and RADIUS protocols, HABP, and HWTACACS protocol.
11 Reliability
This module focuses on the commands for VRRP and HA configuration.
12 System Management
This module details the commands for the configuration involved in system management and maintenance, including those for file management, system management, SNMP, RMON, NTP protocol, SSH terminal services and network management configuration.
13 PoE
This module introduces the commands for remote power-feeding configuration.
14 NAT-URPF-VPLS
This module details the commands for NAT, URPF, VPLS configurations
15 Integrated Management
This module details the commands for HGMP V1 configuration.
16 Appendix
This appendix offers an index for all the commands available in the S9500 series.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
