H3C S9500 Series Routing Switches Command Manual-(V1.01)
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Series Routing Switches Command Manual-(V1.01)
04-Network Protocol Command
04-Network Protocol Command 298 KB
Table of Contents
Chapter 1 IP Address Configuration Commands. 1-1
1.1 IP Address Configuration Commands. 1-1
1.1.1 display ip host 1-1
1.1.2 display ip interface. 1-1
1.1.3 ip address. 1-3
1.1.4 ip host 1-5
1.1.5 ip-protect enable. 1-6
Chapter 2 ARP Configuration Commands. 2-1
2.1 ARP Configuration Commands. 2-1
2.1.1 arp proxy enable. 2-1
2.1.2 arp static. 2-1
2.1.3 arp static multi-port 2-3
2.1.4 arp timer aging. 2-4
2.1.5 debugging arp. 2-5
2.1.6 display arp. 2-6
2.1.7 display arp multi-port 2-7
2.1.8 display arp proxy. 2-8
2.1.9 display arp timer aging. 2-9
2.1.10 gratuitous-arp-learning enable. 2-9
2.1.11 reset arp. 2-10
Chapter 3 ARP Table Size Configuration Commands. 3-1
3.1 ARP Table Size Configuration Commands. 3-1
3.1.1 arp max-entry. 3-1
3.1.2 arp max-aggregation-entry. 3-2
3.1.3 arp enable size. 3-2
3.1.4 display arp max-entry. 3-3
Chapter 4 DHCP Configuration Commands. 4-1
4.1 General DHCP Configuration Commands. 4-1
4.1.1 dhcp enable. 4-1
4.1.2 dhcp select 4-1
4.1.3 dhcp server detect 4-3
4.2 DHCP Server Configuration Commands. 4-3
4.2.1 debugging dhcp server 4-3
4.2.2 display dhcp server forbidden-ip. 4-4
4.2.3 dhcp server dns-list 4-5
4.2.4 dhcp server domain-name. 4-6
4.2.5 dhcp server expired. 4-7
4.2.6 dhcp server forbidden-ip. 4-8
4.2.7 dhcp server ip-pool 4-9
4.2.8 dhcp server nbns-list 4-9
4.2.9 dhcp server netbios-type. 4-10
4.2.10 dhcp server option. 4-11
4.2.11 dhcp server ping. 4-13
4.2.12 dhcp server static-bind. 4-14
4.2.13 display dhcp server conflict 4-14
4.2.14 display dhcp server expired. 4-15
4.2.15 display dhcp server free-ip. 4-16
4.2.16 display dhcp server ip-in-use. 4-17
4.2.17 display dhcp server statistics. 4-18
4.2.18 display dhcp server tree. 4-20
4.2.19 dns-list 4-22
4.2.20 domain-name. 4-23
4.2.21 expired. 4-23
4.2.22 gateway-list 4-24
4.2.23 nbns-list 4-25
4.2.24 netbios-type. 4-26
4.2.25 network. 4-27
4.2.26 option. 4-28
4.2.27 reset dhcp server conflict 4-28
4.2.28 reset dhcp server ip-in-use. 4-29
4.2.29 reset dhcp server statistics. 4-30
4.2.30 static-bind ip-address. 4-30
4.2.31 static-bind mac-address. 4-31
4.3 DHCP Relay Configuration Commands. 4-32
4.3.1 debugging dhcp relay. 4-32
4.3.2 dhcp relay security. 4-33
4.3.3 dhcp relay security address-check. 4-34
4.3.4 dhcp-server detect 4-35
4.3.5 display dhcp relay address. 4-35
4.3.6 display dhcprelay-security. 4-36
4.3.7 ip relay address. 4-37
Chapter 5 DHCP Option 82 Configuration Commands. 5-1
5.1 DHCP Option 82 Configuration Commands. 5-1
5.1.1 dhcp relay information enable. 5-1
5.1.2 dhcp relay information strategy. 5-2
5.1.3 dhcp server relay information enable. 5-2
Chapter 6 DNS Configuration Commands. 6-1
6.1 Static DNS Configuration Commands. 6-1
6.1.1 ip host 6-1
6.1.2 display ip host 6-1
6.2 Dynamic DNS Configuration Commands. 6-2
6.2.1 debugging dns. 6-2
6.2.2 display dns domain. 6-3
6.2.3 display dns dynamic-host 6-4
6.2.4 display dns server 6-5
6.2.5 dns domain. 6-5
6.2.6 dns resolve. 6-6
6.2.7 dns server 6-7
6.2.8 reset dns dynamic-host 6-7
Chapter 7 IP Performance Configuration Commands. 7-1
7.1 IP Performance Configuration Commands. 7-1
7.1.1 display fib. 7-1
7.1.2 display fib ip-address. 7-2
7.1.3 display fib acl 7-3
7.1.4 display fib | 7-4
7.1.5 display fib ip-prefix. 7-4
7.1.6 display fib statistics. 7-5
7.1.7 display icmp statistics. 7-5
7.1.8 display ip socket 7-7
7.1.9 display ip statistics. 7-8
7.1.10 display tcp statistics. 7-10
7.1.11 display tcp status. 7-12
7.1.12 display udp statistics. 7-13
7.1.13 reset ip statistics. 7-14
7.1.14 reset tcp statistics. 7-15
7.1.15 reset udp statistics. 7-15
7.1.16 tcp timer fin-timeout 7-16
7.1.17 tcp timer syn-timeout 7-16
7.1.18 tcp window. 7-17
display ip host
View
Parameter
None
Use the display ip host command to display all the host names and the corresponding IP addresses.
Example
# Display all host names and the corresponding IP addresses of the hosts.
<H3C> display ip host
Host         Age     Flags       Address
My           0       static      1.1.1.1
Aa           0       static      2.2.2.4
Table 1-1 Description on the fields of the display ip host command
Host
Host name
Age
Valid period
Flags
Flags
Address
Host IP address
display ip interface interface-type interface-number
View
Parameter
interface-type interface-number: interface-type refers to the interface type, and interface-number refers to the interface number. Refer to the interface command in Port Command Manual for more information.
Use the display ip interface command to display information about an interface.
Example
# Display the information about interface VLAN-interface 1.
<H3C> display ip interface vlan-interface 1
Vlan-interface1 current state : DOWN
Line protocol current state : DOWN
Internet Address is 1.1.1.1/8 Primary
Broadcast address : 1.255.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
DHCP packet deal mode:  global
Table 1-2 Description on the fields of the display ip interface command
Current state of the VLAN interface 1
Current state of the Line protocol
Internet Address
IP address
Broadcast address
Broadcast address
Maximum transmission unit
The number of the input/output unicast packets, bytes and broadcast packets are all 0
The number of the received packets with invalid TTLs
  Echo reply:
  Unreachable:
  Source quench:
  Routing redirect:
  Echo request:
  Router advert:
  Router solicit:
  Time exceed:
  IP header bad:
  Timestamp request:
  Timestamp reply:
  Information reply:
  Netmask request:
  Netmask reply:
  Unknown type:
Total received ICMP packets, including:
Echo reply packets, unreachable packets, source quench packets, routing redirect packets, echo request packets, route advertisement packets, route solicitation packets, packets that exceed the time, packets with bad IP headers, timestamp request packets, timestamp reply packets, information request packets, information reply packets, netmask request packets, netmask reply packets and unknown packets.
DHCP packet processing mode
1.1.3  ip address
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
View
VLAN interface view, loopback interface view, or console view
Parameter
ip-address: IP address of VLAN interface in dotted decimal format.
mask: Corresponding subnet mask in dotted decimal format.
mask-length: Mask length. That is, the number of bits with a value of 1.
sub: Specifies the IP address to be configured to be the secondary IP address of the VLAN interface/loopback interface.
Use the ip address command to assign an IP address and the corresponding subnet mask to the VLAN interface/loopback interface/console interface.
Use the undo ip address command to remove the IP address and the corresponding subnet mask assigned to the VLAN interface/loopback interface/console interface.
By default, a VLAN interface/loopback interface/console interface does not have an IP address configured.
Normally, a VLAN interface/loopback interface/console interface only needs to be configured with one IP address. But you can also assign up to 21 IP addresses to a VLAN interface/loopback interface/console interface to enable it to connect to multiple subnets. Of all the IP addresses assigned to a VLAN interface/loopback interface/console interface, one is the primary IP address, and the other are secondary IP addresses. The relationship between primary and secondary addresses is:
l           When you configure a primary IP address for an interface already has a primary IP address configured, the newly configured one replaces the old one.
l           If you execute the undo ip address command without providing any parameter, the switch removes both primary and secondary IP addresses of the interface. The undo ip address [ ip-address { mask | mask-length } command can be used to delete the primary IP address, while the undo ip address [ ip-address { mask | mask-length } sub command can be used to delete the secondary IP address.
&  Note:
When you use the ip address command to configure IP addresses of VLAN interfaces, the system will prompts if you continue if the IP address you configure is in different network segment from the existing IP address. If you do continue, the IP address of the VLAN interface will be modified. In addition, if the ARP entries (including dynamic ARP entries and static ARP entries) in the original network segment match the new network segment, they will not be removed; otherwise, the ARP entries in the original network segment will be removed.
Related command: display ip interface.
Example
# Assign 129.12.0.1 to VLAN interface 1, with a subnet mask of 255.255.255.0.
<H3C> system-view
[H3C] interface vlan-interface 1
[H3C-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
# Assign 129.12.0.10 to Ethernet4/0/0, with a 24-bit subnet mask.
<H3C> system-view
[H3C] interface M-Ethernet4/0/0
[H3C-M-Ethernet4/0/0] ip address 129.12.0.10 24
1.1.4  ip host
ip host hostname ip-address
undo ip host hostname [ ip-address ]
View
Parameter
hostname: Name of the host. It is a character string that consists of 1 to 20 characters, including letters, numbers, "_", or ",", and it must contain at least one letter.
ip-address: Host IP address (the corresponding IP address to the host name) in dotted decimal notation.
Use the ip host command to configure the host name and the host IP address.
Use the undo ip host command to cancel the host name and the host IP address.
By default, host name and corresponding IP address are null.
Related command: display ip host.
Example
# Set Lanswtich1’s IP address to be 10.110.0.1.
<H3C> system-view
[H3C] ip host Lanswitch1 10.110.0.1
ip-protect enable
undo ip-protect
View
VLAN interface view
Parameter
None
Use the ip-protect enable command to enable IP address protection.
Use the undo ip-protect command to disable IP address protection.
After IP address protection is enabled, the current interface will no longer dynamically learn ARP mapping entries, and existing dynamic ARP mapping entries will be removed. At the same time, the switch will enable the MAC address auto filling function, so that the user can configure static ARP entries that have only IP address.
By default, IP address protection is disabled.
You can use the display this command to view the status of IP address protection (enabled/disabled) for the current VLAN interface.
Example
# Enable IP address protection for Vlan-interface 2.
<H3C> system-view
[H3C]interface Vlan-interface 2
[H3C-Vlan-interface2]ip-protect enable
arp proxy enable
undo arp proxy enable
View
VLAN view
Parameter
None
Use the arp proxy enable command to enable ARP proxy function.
Use the undo arp proxy enable command to disable ARP proxy function.
By default, ARP proxy function is disabled.
You can configure these commands for a VLAN and sub-VLAN. If you enable ARP proxy for a VLAN, the device with ARP proxy function directly forwards received ARP requests in the VLAN. If you enable ARP proxy for a sub-VLAN, the device with ARP proxy function directly forwards received ARP requests in other sub-VLANs which belong to the same super-VLAN and also have the ARP proxy function enabled.
Related command: display arp proxy.
Example
# Enable ARP proxy function for VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] arp proxy enable
2.1.2  arp static
arp static ip-address [ mac-address [ vlan-id { interface-type interface-number } ] [ vpn-instance vpn-instance-name ]
undo arp ip-address
View
Parameter
ip-address: IP address of the ARP mapping entry.
mac-address: MAC address of the ARP mapping entry, whose format is H-H-H ( H indicates a hexadecimal number).
vlan-id: VLAN to which the static ARP entry belongs, in the range of 1 to 4094.
interface-type interface-number: The type and number of the port to which the static ARP entry belongs.
vpn-instance vpn-instance-name: VPN instance name in MPLS VPN.
Use the arp static command to configure the static ARP mapping entries in an ARP mapping table.
Use the undo arp static command to delete a static ARP mapping entry from the ARP table.
By default, the mapping table of the system ARP is empty and the switch can obtain its address mapping by means of dynamic ARP.
The arp static command can be used to configure auto filling of ARP entries. When configuring an ARP entry, if you input on the IP address, the switch will automatically set the MAC address to 0. Such a mapping entry is auto-fill ARP mapping entry. When an auto-fill ARP entry is resolved, the switch can automatically fill it with the learned MAC address as the MAC address corresponding to the IP address in this mapping entry.
Note that:
l           When the switch works normally, its static ARP mapping entries remain valid and work unless you perform operations that invalidate ARP entries, such as changing or removing VLAN interfaces, removing a VLAN, or removing an port from a VLAN. These operations will cause the corresponding ARP mapping entries to be automatically removed.
l           The argument vlan-id must be the ID of an existing VLAN, and the Ethernet port specified behind this parameter must belong to the VLAN.
l           The argument vpn-instance-name must be the VPN-instance name of an existing MPLS VPN.
l           ARP mapping entries with port parameters can be configured on manually aggregated ports or static aggregated ports, but cannot be configured on LACP-enabled dynamic aggregated ports.
l           If the mac-address of an ARP entry is a multicast MAC address, the system will assume this ARP entry to be multicast ARP entry.
l           The MAC address auto filling function is enabled only when the IP address protection function is enabled on the interface.
l           Once after the initial auto filling, the auto-fill ARP entry becomes a normal static ARP entry and cannot be filled again.
l           Long static ARP can be configured only on manually aggregated ports, but not on static aggregated ported or dynamic aggregated ports.
Related commands: reset arp, display arp, debugging arp.
Example
# Configure the MAC address corresponding to the IP address 202.38.10.2 to 00e0-fc01-0000. This static ARP mapping entry is on Ethernet port Ethernet2/1/1, which belongs to VLAN1.
[H3C] arp static 202.38.0.10 00e0-fc01-0000 1 ethernet2/1/1
arp static ip-address mac-address vlan-id multi-port interface-type interface-number [ vpn-instance vpn-instance-name ] ]
undo arp ip-address multi-port interface-type interface-number [ vpn-instance vpn-instance-name ]
View
Parameter
mac-address: MAC address of the ARP mapping entry, in the format of H-H-H. For a multiple-outgoing-port ARP entry, this is a multicast MAC address.
vlan-id: ID of the VLAN of the static ARP entry, in the range of 1 to 4094.
interface-type: Port type.
interface-number: Port number.
For details about the above two parameters, refer to the interface command in port command manual.
vpn-instance-name: The VPN instance name of the VPN which the IP address belongs to.
Use the arp static multi-port command to add a multicast ARP port. When you add the first port, the system generates a multicast ARP entry.
Use the undo arp multi-port command to remove a multicast ARP port. When you remove the last port, the system removes the multicast ARP entry.
The multicast ARP feature allows you to associate a common unicast route to a Layer 2 multicast group, that is, add multiple outgoing ports for an outgoing ARP packet so that the packet can be sent to multiple ports. As a result, a static multicast ARP entry is generated. In brief, a multicast ARP entry is a static ARP entry with a multicast MAC address, which may correspond to multiple ports.
By the multi-port keyword in this command, the switch decides that the port to be added is for a multicast ARP entry. Only one port can be added every time the command is executed. If the ARP entry does not exist, a new entry is generated. If the port has already been in the entry, no further processing is made.
Note that:
l           You cannot configure multicast ARP for aggregation ports. Otherwise, the system will prompt error message.
l           At present, the outgoing ports in the same multicast ARP entry cannot be in different boards.
You can add multiple ports one by one by setting the multicast static ARP entry. To view the configuration, use the display arp multi-port command.
Related commands: reset arp, display arp, debugging arp, arp static.
Example
# In an ARP entry, the IP address is 10.10.10.98, and the MAC address is 0150-0098-0098. Add the outgoing ports Ethernet 6/1/1, Ethernet 6/1/2 and Ethernet 6/1/3 to the ARP entry.
[H3C] arp static 10.10.10.98 0150-0098-0098 20 multi-port Ethernet 6/1/1
[H3C] arp static 10.10.10.98 0150-0098-0098 20 multi-port Ethernet 6/1/2
[H3C] arp static 10.10.10.98 0150-0098-0098 20 multi-port Ethernet 6/1/3
arp timer aging aging-time
undo arp timer aging
View
Parameter
aging-time: Aging time of dynamic ARP aging timer, which is in the range of 1 to 1440 minutes. By default, the aging time is 20 minutes.
Use the arp timer aging command to configure the dynamic ARP aging timer.
Use the undo arp timer aging command to restore the default dynamic ARP aging timer.
Related command: display arp timer aging.
Example
# Configure the dynamic ARP aging timer to 10 minutes.
<H3C> system-view
[H3C] arp timer aging 10
2.1.5  debugging arp
debugging arp { error | info | packet }
undo debugging arp { error | info | packet }
View
Parameter
error: ARP error debugging.
info: ARP mapping table and information management debugging.
packet: ARP packet debugging.
Use the debugging arp command to enable ARP debugging.
Use the undo debugging arp command to disable the corresponding ARP debugging.
By default, no ARP debugging is enabled.
Related command: arp static, display arp.
Example
# Enable ARP packet debugging.
<H3C> debugging arp packet
*0.771346-ARP-8-S1-arp_send:Send an ARP Packet, operation : 1, sender_eth_addr : 00e0-fc00-3500,sender_ip_addr : 10.110.91.159, target_eth_addr : 0000-0000-0000, target_ip_addr : 10.110.91.193
*0.771584-ARP-8-S1-arp_rcv:Receive an ARP Packet, operation : 2, sender_eth_addr : 0050-ba22-6fd7, sender_ip_addr : 10.110.91.193, target_eth_addr : 00e0-fc00-3500, target_ip_addr : 10.110.91.159
Table 2-1 Description on the fields of the debugging arp command
operation
Kind of ARP packets: 1 ARP request packet; 2 ARP reply packet
sender_eth_addr
Ethernet address of the sender
sender_ip_addr
IP address of the sender
target_eth_addr
Target Ethernet address. If the packet is a ARP request packet, the target IP address will be 0. It changes to the correct address when the target responds.
target_ip_addr
Target IP address
2.1.6  display arp
display arp [ ip-address | [ dynamic | static ] [ | { begin | include | exclude } text ] ]
View
Parameter
dynamic: Displays the dynamic ARP entries in ARP mapping table.
static: Displays the static ARP entries in ARP mapping table.
ip-address: Displays ARP mapping entries according to specified IP address.
begin: Starts displaying from the first ARP entry that contains the specified character string “text”.
include: Displays only the ARP entries that contain the specified character string “text”.
exclude: Displays only the ARP entries that do not contain the specified character string “text”.
text: Character string. The ARP entries that contain this character string are displayed.
Use the display arp command to view the ARP mapping table.
Related command: arp static, reset arp, debugging arp.
Example
# Display all the ARP entries.
<H3C> display arp | inc 2.2.1
            Type: S-Static   D-Dynamic
IP Address   MAC Address VLAN ID Port Name   Aging   Type
2.2.2.231      0001-0001-0001    N/A        N/A             N/A   S
2.2.1.2        0002-0002-0002    N/A        N/A             N/A   S
--   2 entries found   ---
&  Note:
Character of “.” in a regular expression is a wildcard. So, as for “2.2.2.231”, “2.2.1” matches its sub-string “2.231” and thus the ARP mapping entry with an IP address of 2.2.2.231 is displayed as a matched entry.
Table 2-2 Description on the fields of the display arp command
IP Address
MAC Address
VLAN ID
ID of the VLAN to which the static ARP entry belongs
Port Name
Name of the port to which the static ARP entry belongs
Aging
Aging time of dynamic ARP entry in minutes
Type of ARP entry
display arp multi-port [ ip-address ]
View
Parameter
ip-address: IP address of an ARP mapping entry.
Use the display arp multi-port command to display configuration information about multicast ARP. The multicast ARP (that is, multiple-port ARP) feature allows one ARP entry to correspond to multiple outgoing ports; it is used to send one packet to multiple ports simultaneously.
Related command: arp static.
Example
# Display configuration information about the multicast ARP entry with the IP address of 10.10.10.98.
<H3C> display arp multi-port 10.10.10.98
IP Address   :10.10.10.98
Mac Address :0150-0098-0098
VLAN  ID    :20
ARP Port-List : Ethernet6/1/2      Ethernet6/1/3
Ethernet6/1/4     *Ethernet6/1/5
Ethernet6/1/6      Ethernet6/1/7
Ethernet6/1/8      Ethernet6/1/9
Ethernet6/1/1
VPN-Name   :Public-ARP
When a “*” precedes a port, the port is in the Up state; otherwise, the port is in the Down state.
display arp proxy [ vlan vlan-id ]
View
Parameter
vlan-id: Specifies the VLAN ID.
Use the display arp proxy command to display the state of the ARP proxy of a specified VLAN. An ARP proxy can be in enabled or disabled state.
Related command: arp proxy enable.
Example
# Display the state of the ARP proxy of VLAN 3.
<H3C> display arp proxy vlan 3
vlan 3
Proxy ARP status: disabled
View
Parameter
None
Use the display arp timer aging command to view the current setting of the dynamic ARP aging timer.
Related command: arp timer aging.
Example
# Display the current setting of the ARP aging timer.
<H3C> display arp timer aging
Current ARP aging time is 10 minute(s)
You can see that the ARP aging time is 10 minutes.
undo gratuitous-arp-learning enable
View
Parameter
None
Use the gratuitous-arp-learning enable command to enable the gratuitous ARP packet learning function.
Use the undo gratuitous-arp-learning enable command to disable the gratuitous ARP packet learning function.
By default, the gratuitous ARP packet learning function is enabled.
By sending gratuitous ARP packets, a network device can:
l           Determine whether or not IP address conflicts exist between it and other network devices.
l           Trigger other network devices to update its hardware address stored in their caches.
Example
# Enable the gratuitous ARP packet learning function on the switch.
<H3C> system-view
[H3C] gratuitous-arp-learning enable
2.1.11  reset arp
reset arp [ dynamic | static | interface { interface-type interface-number } | all ]
View
Parameter
dynamic: Clears the dynamic ARP mapping entries.
static: Clears the static ARP mapping entries
interface-type is port type and interface-number is port number. For details, refer to the description of interface command in the Port Command Manual.
all: Clears all the ARP mapping entries.
Use the reset arp command to reset the ARP mapping entries.
Example
# Reset the static ARP entries.
<H3C> reset arp static
3.1.1  arp max-entry
arp max-entry slot-num max-num
undo arp max-entry slot-num
View
Parameter
slot-num: Slot number of the card.
max-num: Maximum number of ARP entries that can be supported by the specified card. This argument counts in K (1K = 1024) and ranges from 4K to 8K.
Use the arp max-entry command to configure the maximum number of ARP entries that can be supported by a specified card in the system.
Use the undo arp max-entry command to cancel the configuration.
By default, each card supports up to 4K ARP entries.
If the system does not contain cards with their model names being suffixed with B, DA, DB or DC, you can configure the maximum number of ARP entries to be 4K, 5K, 6K, 7K or 8K for the card. Otherwise, you can only configure the maximum number to be 4K for the card.
Example
# Configure the maximum number of ARP entries that can be supported by the interface card in slot 12 to 8K (assuming that the system does not contain cards with their model name being suffixed with B, DA, DB or DC).
<H3C> system-view
[H3C]arp max-entry 12 8
The configuration won't be enabled until the system is rebooted.
arp max-aggregation-entry max-aggnum
undo arp max-aggregation-entry
View
Parameter
max-aggnum: Maximum number of ARP entries for aggregation port (that is, aggregation ARP entries) supported by each card. This argument counts in K (1K = 1024).
Use the arp max-aggregation-entry command to configure the maximum number of aggregation ARP entries that can be supported by each card of the switch.
Use the undo arp max-aggregation-entry command to restore the default maximum number of aggregation ARP entries supported by each card.
If the system does not contain cards whose model name are suffixed with B, DA, DB or DC, you can configure the maximum number of aggregation ARP entries to 0K, 1K, 3K, 7K or 8K. Otherwise, you can only configure the maximum number to 0K, 1K or 3K.
By default, each card supports up to 1K aggregation ARP entries.
Example
# Configure the maximum number of aggregation ARP entries that can be supported by each card of the switch to 8K (assuming that the system does not contain cards whose model name are suffixed with B, DA, DB or DC).
<H3C> system-view
[H3C]arp max-aggregation-entry 8
The configuration won't be enables until the system is rebooted.
arp enable size { 4 | 64 }
undo arp enable size
View
Parameter
4: Configures the maximum number of ARP entries of the whole switch to 4K (1K = 1024).
64: Configure the maximum number of ARP entries of the whole switch to 64K.
Use the arp enable size command to configure the maximum number of ARP entries that can be supported by the whole switch.
Use the undo arp enable size command to restore the default maximum number of ARP entries supported by the whole switch.
By default, the whole switch supports up to 4K ARP entries, each card supports up to 4K ARP entries, and each card supports up to 1K aggregation ARP entries.
Example
# Configure the maximum number of ARP entries of the whole switch to 64K.
<H3C> system-view
[H3C] arp enable size 64
  Caution:
l      You must restart the system for each of the three configurations to take effect.
l      Do not remove a card or change the place of a card from one slot to another before restarting the system. Otherwise, the configuration may fail to take effect.
l      After the configurations, do not perform active/standby switchover before restarting the system. Otherwise, the configurations will not take effect even if you restart the system.
View
Parameter
None
Use the display arp max-entry command to display the current maximum numbers of ARP entries and the intending counterparts that will take effect after the switch restarts next time.
Example
# Display the current maximum numbers of ARP entries and the intending counterparts that will take effect after the switch restarts next time.
<H3C> display arp max-entry
The current max arp entry config information:
  max arp entry config(Main Board): 65536
  max link aggregation arp entry config: 0
  max arp entry config of slot 0: 8192
  max arp entry config of slot 13: 8192
The next max arp entry config information:
  max link aggregation arp entry config: 8192
4.1.1  dhcp enable
dhcp enable
undo dhcp enable
View
Parameter
None
Use the dhcp enable command to enable DHCP service.
Use the undo dhcp enable command to disable the DHCP service.
For both DHCP server and DHCP relay, you must enable DHCP service first before performing other DHCP configurations. The other related DHCP configurations take effect only after DHCP service is enabled.
Example
# Enable DHCP service.
<H3C> system-view
[H3C] dhcp enable
4.1.2  dhcp select
In VLAN interface view:
dhcp select { global | interface | relay }
undo dhcp select
In system view:
dhcp select { global | interface | relay } { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
undo dhcp select { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
View
VLAN interface view, system view
Parameter
global: Specifies to forward DHCP packets to local DHCP server and let the local server assign IP addresses in global address pools to DHCP clients.
interface: Specifies to forward DHCP packets to local DHCP server and let the local server assign IP addresses in VLAN interface address pool to DHCP clients.
relay: Specifies to forward DHCP packets to remote DHCP servers and let remote servers assign IP addresses to DHCP clients. In this case, the current switch operates as a DHCP relay.
interface vlan-interface vlan-id [ to vlan-interface vlan-id ]: Specifies a VLAN interface or a range of VLAN interfaces.
all: Specifies all the VLAN interfaces.
  Caution:
The dhcp select interface command cannot be used together with the ip relay address or dhcp relay security address-check enable command.
Use the dhcp select command to specify a method used by the switch to process the DHCP packets it received. You can use this command in VLAN interface view to specify a processing method of DHCP packets for current VLAN interface, or in system view to specify a processing method for multiple VLAN interfaces.
Use the undo dhcp select command to revert to the default processing mode of DHCP packets.
By default, the switch forwards the DHCP packets it received to the local DHCP server and let the local server assign IP addresses in global address pools to DHCP clients. (That is, the switch processes the DHCP packets in the global method.)
Example
# Specify to forward DHCP packets to the local DHCP server and let the local server assign IP addresses in global address pools to DHCP clients.
<H3C> system-view
[H3C-Vlan-interface1] dhcp select global
dhcp server detect
undo dhcp server detect
View
Parameter
None
Use the dhcp server detect command to enable fake DHCP server detection.
Use the undo dhcp server detect command to disable fake DHCP server detection.
Fake DHCP server detection is disabled by default.
Example
# Enable fake DHCP server detection.
<H3C> system-view
[H3C] dhcp server detect
debugging dhcp server { all | error | event | packet }
undo debugging dhcp server { all | error | event | packet }
View
Parameter
all: Used to enable/disable all types of debugging for DHCP server.
error: Used to enable/disable error debugging for DHCP server errors, including those occur when a DHCP server processes DHCP packets or assigns IP addresses.
event: Used to enable/disable debugging for DHCP server events, including the assigning of IP addresses and timing out of ping packets.
packet: Specifies debugging for packets received/sent by DHCP servers, including DHCP packets and ping packets.
Use the debugging dhcp server command to enable debugging for DHCP server.
Use the undo debugging dhcp server command to disable debugging for DHCP server.
Each type of debugging concerning DHCP servers is disabled by default.
Example
# Enable debugging for DHCP server events.
<H3C> debugging dhcp server event
View
Parameter
None
Use the display dhcp server forbidden-ip command to display forbidden IP addresses in the DHCP address pool.
Example
# Display forbidden IP addresses in the DHCP address pool.
<H3C> display dhcp server forbidden-ip
Forbidden IP Range from 3.3.3.1              to  3.3.3.1
Forbidden IP Range from 3.3.3.4              to  3.3.3.99
Forbidden IP Range from 3.3.3.101          to  3.3.3.254
Forbidden IP Range from 17.9.0.1            to  17.9.0.1
Forbidden IP Range from 17.9.0.3            to  17.9.0.5
Forbidden IP Range from 17.9.0.8            to  17.9.255.254
dhcp server dns-list ip-address [ ip-address ]
undo dhcp server dns-list { ip-address | all }
In system view:
dhcp server dns-list ip-address [ ip-address ] { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
undo dhcp server dns-list { ip-address | all } { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
View
Parameter
ip-address: IP address of a DHCP server. You can specify up to eight IP addresses (separated by spaces) in one command.
interface vlan-interface vlan-id [ to vlan-interface vlan-id ]: Specifies one VLAN interface, or a range of VLAN interfaces.
all: Specifies all VLAN interfaces or all configured IP addresses.
Use the dhcp server dns-list command to configure one or more DNS server addresses for the DHCP address pool of current VLAN interface, or for the DHCP address pool(s) of the specified VLAN interface(s).
Use the undo dhcp server dns-list command to remove one or more DNS server addresses configured for the DHCP address pool of current VLAN interface, or for the DHCP address pool(s) of the specified VLAN interface(s).
By default, no DNS server address is configured.
With eight DNS server addresses already configured, if you add a new DNS server address by executing the dhcp server dns-list command, the newly configured one overwrites the oldest one.
Related command: dns-list.
Example
# Configure the DNS server address 1.1.1.254 for the DHCP address pool of VLAN interface 1.
<H3C> system-view
[H3C] interface Vlan-interface 1
[H3C-Vlan-interface1] dhcp server dns-list 1.1.1.254
dhcp server domain-name domain-name
undo dhcp server domain-name
In system view:
dhcp server domain-name domain-name { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
undo dhcp server domain-name domain-name { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
View
DHCP address pool view, VLAN interface view, system view
Parameter
domain-name: DHCP client domain name for DHCP address pool of specified VLAN interface, a string that is of 3 to 50 characters in length.
all: Specifies all VLAN interfaces.
Use the dhcp server domain-name command to configure a DHCP client domain name for the DHCP address pool of the current VLAN interface, or for the DHCP address pool(s) of the specified VLAN interface(s).
Use the undo dhcp server domain-name command to remove the DHCP client domain name configured for the DHCP address pool of the current VLAN interface, or for the DHCP address pool(s) of the specified VLAN interface(s).
No DHCP client domain name is configured by default.
Related command: domain-name.
Example
# Configure the DHCP client domain name of the DHCP address pool of the current VLAN interface to vlan-interface1.com.
<H3C> system-view
[H3C-Vlan-interface1] dhcp server domain-name vlan-interface1.com
dhcp server expired { day day [ hour hour [ minute minute ] ] | unlimited }
undo dhcp server expired
In system view:
dhcp server expired { day day [ hour hour [ minute minute ] ] | unlimited } { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
undo dhcp server expired { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
View
Parameter
day day: Sets the number of days. The day argument ranges from 0 to 365.
hour hour: Sets the number of hours. The hour argument ranges from 0 to 23.
minute minute: Sets the number of minutes. The minute argument ranges from 0 to 59.
unlimited: Sets an unlimited lease time.
Use the dhcp server expired command to set the IP address lease time for the DHCP address pool of current VLAN interface, or for the DHCP address pool(s) of the specified VLAN interface(s).
Use the undo dhcp server expired command to revert to the default IP address lease time for the DHCP address pool of current VLAN interface, or for the DHCP address pool(s) of the specified VLAN interface(s).
The default lease time is one day.
Related command: expired.
Example
# Set the IP address lease time of the DHCP address pool of VLAN interface 1 to unlimited.
<H3C> system-view
[H3C-Vlan-interface1] dhcp server expired unlimited
dhcp server forbidden-ip low-ip-address [ high-ip-address ]
undo dhcp server forbidden-ip low-ip-address [ high-ip-address ]
View
Parameter
low-ip-address: Minimum IP address in the forbidden IP address range.
high-ip-address: The highest IP address in the forbidden IP address range. Note that the value of this argument must be larger than (or equal to) that of the low-ip-address argument. If you do not provide this argument, then the forbidden IP address range contains only the IP address specified by the low-ip-address argument.
Use the dhcp server forbidden-ip command to forbid a range of IP addresses to be automatically assigned to DHCP clients.
Use the undo dhcp server forbidden-ip command to cancel the forbiddance.
All IP addresses in a DHCP address pool can be automatically assigned by default.
Related command: dhcp server ip-pool, network, static-bind ip-address, and dhcp server static-bind.
Example
# Forbid the IP addresses from 10.110.1.1 to 10.110.1.63 to be automatically assigned.
<H3C> system-view
[H3C] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
dhcp server ip-pool pool-name
undo dhcp server ip-pool pool-name
View
Parameter
pool-name: Name of the address pool, a string that is of 1 to 64 characters in length. An address pool name uniquely identifies an address pool.
Use the dhcp server ip-pool command to create a global DHCP address pool and enter the corresponding DHCP address pool view.
Use the undo dhcp server ip-pool command to remove a specified global DHCP address pool.
No global DHCP address pool is created by default.
Related command: dhcp enable.
Example
# Create a global DHCP address pool with a name of 0.
<H3C> system-view
[H3C] dhcp server ip-pool 0
[H3C-dhcp-0]
dhcp server nbns-list ip-address [ ip-address ]
undo dhcp server nbns-list { ip-address | all }
In system view:
dhcp server nbns-list ip-address [ ip-address ] { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
undo dhcp server nbns-list { ip-address | all } { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
View
Parameter
ip-address: NetBIOS server IP address. You can specify up to eight IP addresses (separated by spaces) in one command.
Use the dhcp server nbns-list command to configure one or more NetBIOS server IP addresses for the DHCP address pool of current VLAN interface, or for the DHCP address pool(s) of the specified VLAN interface(s).
Use the undo dhcp server nbns-list command to remove one or all NetBIOS server IP addresses configured for the DHCP address pool of current VLAN interface, or for the DHCP address pool(s) of the specified VLAN interface(s)..
By default, no NetBIOS server IP address is configured.
With eight NetBIOS server addresses already configured, if you add a new one by executing the dhcp server nbns-list command, the newly configured one overwrites the oldest one.
Related command: nbns-list, dhcp server netbios-type.
Example
# Configure the NetBIOS server with an IP address of 10.12.1.99 for the DHCP address pool of VLAN interface 1.
<H3C> system-view
[H3C-Vlan-interface1] dhcp server nbns-list 10.12.1.99
dhcp server netbios-type { b-node | h-node | m-node | p-node }
undo dhcp server netbios-type
In system view:
dhcp server netbios-type { b-node | h-node | m-node | p-node } { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
undo dhcp server netbios-type { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
View
Parameter
b-node: Specifies b-node to be the NetBIOS node type. DHCP clients of this node type establish host name-to-IP address mapping by broadcasting. (b stands for broadcast.)
p-node: Specifies p-node to be the NetBIOS node type. DHCP clients of this node type establish host name-to-IP address mapping by communicating with NetBIOS server. (p stands for peer-to-peer.)
m-node: Specifies m-node to be the NetBIOS node type. DHCP clients of this node type are p nodes which take some broadcast features. (m stands for mixed.)
h-node: Specifies h-node to be the NetBIOS node type. DHCP clients of this node type are b nodes which take peer-to-peer mechanism. (h stands for hybrid.)
Use the dhcp server netbios-type command to configure the NetBIOS node type for DHCP clients of DHCP address pool of current or specified VLAN interface.
Use the undo dhcp server netbios-type command to remove the NetBIOS node type configured for DHCP clients of DHCP address pool of current or specified VLAN interface.
The default DHCP client NetBIOS node type is h-node.
Related command: netbios-type, dhcp server nbns-list.
Example
# Configure p-node as the NetBIOS node type for DHCP clients of the DHCP address pool of VLAN interface 1.
<H3C> system-view
[H3C-Vlan-interface1] dhcp server netbios-type p-node
dhcp server option code { ascii ascii-string | hex hex-string | ip-address ip-address [ ip-address ] }
undo dhcp server option code
In system view:
dhcp server option code { ascii ascii-string | hex hex-string | ip-address ip-address [ ip-address ] } { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
undo dhcp server option code { interface vlan-interface vlan-id [ to vlan-interface vlan-id ] | all }
View
Parameter
code: Option code customized by user. This argument ranges from 2 to 254.
ascii ascii-string: Specifies a string comprising ASCII characters. The string can be of 1 to 63 characters in length.
hex hex-string: Specifies a numeric string containing 2 or 4 hexadecimal digits (hh or hhhh).
ip-address ip-address [ ip-address ]: Specifies one or more IP addresses. You can specify up to eight IP addresses (separated by spaces) in one command.
interface vlan-interface vlan-id [ to vlan-interface vlan-id ]: Specifies one or more VLAN interfaces.
Use the dhcp server option command to configure a custom DHCP option for the DHCP address pool of current VLAN interface, or for the DHCP address pool(s) of the specified VLAN interface(s).
Use the undo dhcp server option command to remove a custom DHCP option configured for the DHCP address pool of current VLAN interface, or for the DHCP address pool(s) of the specified VLAN interface(s).
If you execute the dhcp server option command multiple times, the new configurations overwrite the corresponding old ones.
Related command: option.
Example
# Configure a custom DHCP option for the DHCP address pool of VLAN interface 1, with the code argument of 100 and the hex-string argument of 0x11 and 0x22.
<H3C> system-view
[H3C-Vlan-interface1] dhcp server option 100 hex 11 22
dhcp server ping { packets number | timeout milliseconds }
undo dhcp server ping { packets | timeout }
View
Parameter
packets number: Sets the maximum times to send ping packets. The number argument ranges from 0 to 10 and defaults to 2. Value of 0 specifies not to send any ping packet.
timeout milliseconds: Sets the maximum time to wait for a response to a ping packet. The milliseconds argument is in the unit of milliseconds; it ranges from 0 to 10000 and defaults to 500.
Use the dhcp server ping command to set the maximum times to send ping packets or the maximum time for the DHCP server to wait for a response after sending a ping packet.
Use the undo dhcp server ping command to revert to the corresponding default setting.
Example
# Set the maximum times to send ping packets to 10.
<H3C> system-view
[H3C] dhcp server ping packets 10
# Set the maximum time to wait for a response to a ping packet to 600 milliseconds.
<H3C> system-view
[H3C] dhcp server ping timeout 600
dhcp server static-bind ip-address ip-address mac-address mac-address
undo dhcp server static-bind { ip-address ip-address | mac-address mac-address }
View
VLAN interface view
Parameter
ip-address: IP address to be bound statically. Note that the IP address must be a valid IP address in the address pool of the current VLAN interface.
mac-address: MAC address for the IP address to be bound to.
Use the dhcp server static-bind command to statically bind an IP address in the address pool of the current VLAN interface to a MAC address.
Use the undo dhcp server static-bind command to remove a statically bound IP address entry.
IP addresses in the address pool of a VLAN interface are not statically bound by default.
 VLAN interface address pool only supports one-to-one MAC-IP binding.
Example
# Statically bind the IP address 10.1.1.1 to the MAC address 0000-e03f-0305.
<H3C> system-view
[H3C-Vlan-interface1] dhcp server static-bind ip-address 10.1.1.1 mac-address 0000-e03f-0305
display dhcp server conflict { all | ip ip-address }
View
Parameter
all: Specifies all IP addresses.
ip ip-address: Specifies an IP address.
Use the display dhcp server conflict command to display the statistics about DHCP address conflicts.
Related command: reset dhcp server conflict.
Example
# Display the statistics about DHCP address conflicts.
<H3C> display dhcp server conflict all
Address             Discover Time
10.110.1.2         Jan 11 2003 11:57: 7 PM
Table 4-1 Description on the fields of the display dhcp server conflict command
Address
The IP address that causes the conflict
Discover Time
The time when the conflict is discovered
display dhcp server expired { ip ip-address | pool [ pool-name ] | interface [ vlan-interface vlan-id ] | all }
View
Parameter
pool [ pool-name ]: Specifies a global address pool. If you do not input a pool-name, all global address pools are included.
interface [ vlan-interface vlan-id ]: Specifies a VLAN interface address pool. If you do not input a vlan-id, all VLAN interface address pools are included.
all: Specifies all DHCP address pools.
Use the display dhcp server expired command to display information about lease-expired addresses. If no available IP address exists in a DHCP address pool, the DHCP server assigns the lease-expired IP addresses in the pool to DHCP clients as needed.
Example
# Display information about lease-expired addresses.
<H3C> display dhcp server expired all
Global pool:
 IP address     Hardware address    Lease expiration          Type
Interface pool:
Table 4-2 Description on the fields of the display dhcp server expired command
Global pool
The information followed is about expired IP addresses in global address pool(s)
Interface pool
The information followed is about lease-expired IP addresses in VLAN interface address pool(s)
IP address
Bound IP addresses
Hardware address
Bound MAC addresses
Lease expiration
The time when an IP address expires
Binding type
View
Parameter
None
Use the display dhcp server free-ip command to display the ranges of available (unassigned) IP addresses in DHCP address pools.
Example
# Display the ranges of available (unassigned) IP addresses in DHCP address pools.
<H3C> display dhcp server free-ip
IP Range from 1.0.0.0              to  2.2.2.1
IP Range from 2.2.2.3              to  2.255.255.255
IP Range from 4.0.0.0              to  4.255.255.255
IP Range from 5.5.5.0              to  5.5.5.0
IP Range from 5.5.5.2              to  5.5.5.255
display dhcp server ip-in-use { ip ip-address | pool [ pool-name ] | interface [ vlan-interface vlan-id ] | all }
View
Parameter
Use the display dhcp server ip-in-use command to display information about IP address binding in DHCP address pool(s).
Related command: reset dhcp server ip-in-use.
Example
# Display information about IP address binding in all DHCP address pools.
<H3C> display dhcp server ip-in-use all
Global pool:
 2.2.2.2 44444-4444-4444 NOT Used    Manual
Interface pool:
 5.5.5.1 0050-ba28-930a  Jun 5 2003 10:56: 7 AM  Auto:COMMITED
Table 4-3 Description on the fields of the display dhcp server ip-in-use command
Fields
Global pool
The information followed is about bound IP addresses in global address pool(s)
Interface pool
The information followed is about bound IP addresses in VLAN interface address pool(s)
IP address
Bound IP addresses
Hardware address
Bound MAC addresses
Lease expiration
Binding type
View
Parameter
None
Use the display dhcp server statistics command to display statistics information about the DHCP server.
Related command: reset dhcp server statistics.
Example
# Display statistics information about the DHCP server.
<H3C> display dhcp server statistics
    Global Pool:
     Pool Number:             5
     Binding
      Auto:                   0
      Manual:                 1
      Expire:                 0
    Interface Pool:
     Pool Number:             1
     Binding
      Auto:                   1
      Manual:                 0
      Expire:                 0
    Boot Request:             6
     Dhcp Discover:           1
     Dhcp Request:            4
     Dhcp Decline:            0
     Dhcp Release:            1
     Dhcp Inform:             0
    Boot Reply:               4
     Dhcp Offer:              1
     Dhcp Ack:                3
     Dhcp Nak:                0
Bad Messages:             0
Table 4-4 Description on the fields of the display dhcp server statistics command
Global Pool
The information followed is about the statistics of the global address pools
Interface Pool
The information followed is about the statistics of the address pools of VLAN interfaces
Pool Number
Number of address pools
Auto
Number of automatically bound IP addresses
Manual
Number of manually bound IP addresses
Expire
Number of expired IP addresses
Boot Request:             6
    Dhcp Discover:       1
    Dhcp Request:        4
    Dhcp Decline:         0
    Dhcp Release:        1
    Dhcp Inform:           0
Total and categorized DHCP packets received by the DHCP server
Boot Reply:               4
     Dhcp Offer:          1
     Dhcp Ack:            3
     Dhcp Nak:            0
Total and categorized DHCP packets sent by the DHCP server
Bad Messages
Number of bad DHCP packets
display dhcp server tree { pool [ pool-name ] | interface [ vlan-interface vlan-id ] | all }
View
Parameter
pool [ pool-name ]: Specifies a global address pool. If you do not specify a global address pool, all global address pools are included.
interface [ vlan-interface vlan-id ]: Specifies the address pool of a VLAN interface. If you do not specify a VALN interface, address pools of all VLAN interfaces are included.
all: Specifies all addresses pools.
Use the display dhcp server tree command to display information about DHCP address pool hierarchy.
Example
# Display information about DHCP address pool hierarchy.
<H3C> display dhcp server tree all
Global pool:
Pool name: 5
network 10.10.1.0 mask 255.255.255.0
Child node:6
Sibling node:7
  option 1 ip-address 255.0.0.0
  expired 1 0 0
  option 58 hex 00 00 A8 C0
  option 59 hex 00 00 00 3C
Pool name: 6
  static-bind ip-address 10.10.1.2 mask 255.0.0.0
  static-bind mac-address 00e0-00fc-0001
Parent node:5
  option 1 ip-address 255.255.0.
  expired 1 0 0
Pool name: 7
network 10.10.1.64 mask 255.255.255.192
PrevSibling node:5
  gateway-list 2.2.2.2
  dns-list 1.1.1.1
  domain-name 444444
  nbns-list 3.3.3.3
  expired 1 0 0
Table 4-5 Description on the fields of the display dhcp server tree command
Global pool
The information followed is about global address pools
Interface pool
The information followed is about VLAN interface address pools
Pool Name
The name of an address pool
Network
Range of addresses available for assigning
An IP address and the corresponding MAC address statically bound to it
child node:6
The address pool named 6 is a child node of the one named 5
Based on the node position of the address pool named 5, the node type displayed here includes the following:
Child node: Indicates the node to which the address pool named 6 corresponds is a child node of that of the address pool named 5. In this case, node 6 stands for a subnet of the network node 5 stands for
Parent node: Indicates the node to which the address pool named 6 corresponds is the parent node of that of the address pool named 5. In this case, node 6 stands for the network segment
Sibling node: Indicates the node to which the address pool named 6 corresponds is the next sibling node of that of the address pool named 5. Information about these address pools is displayed in the order they are established
PrevSibling node: Indicates the node to which the address pool named 6 corresponds is the previous sibling node of that of the address pool named 5
Option
Customized DHCP options
expired
The valid period of the leased IP addresses in the address pool, including number of days, hours and minutes
gateway-list
The list of outbound gateways configured for the DHCP clients
dns-list
The list of DNS servers configured for the DHCP clients
domain-name
The domain name configured for the DHCP clients
nbns-list
The NetBIOS server configured for the DHCP clients
4.2.19  dns-list
undo dns-list { ip-address | all }
View
Parameter
ip-address: IP address of a DNS server. You can specify up to eight IP addresses (separated by spaces) in one command.
all: Specifies all configured DNS server IP addresses.
Use the dns-list command to configure one or more DNS server IP addresses for a global DHCP address pool.
Use the undo dns-list command to remove one or all DNS server IP addresses configured for a global DHCP address pool.
By default, no DNS server IP address is configured for a global DHCP address pool.
With eight DNS server addresses already configured, if you add a new one by executing the dns-list command, the new one overwrites the oldest one.
Related command: dhcp server dns-list, dhcp server ip-pool.
Example
# Configure a DNS server with an IP address of 1.1.1.254 for the global DHCP address pool 0.
<H3C> system-view
[H3C-dhcp-0] dns-list 1.1.1.254
4.2.20  domain-name
undo domain-name
View
Parameter
domain-name: Domain name, a string that is of 3 to 50 characters in length.
Use the domain-name command to configure a domain name for the DHCP clients of a global DHCP address pool.
Use the undo domain-name command to remove the domain name configured for the DHCP clients of a global DHCP address pool.
By default, no domain name is configured for the DHCP clients of a global DHCP address pool.
Related command: dhcp server ip-pool, dhcp server domain-name.
Example
# Configure a domain name (mydomain.com) for the DHCP clients of the global DHCP address pool 0.
<H3C> system-view
[H3C-dhcp-0] domain-name mydomain.com
4.2.21  expired
undo expired
View
Parameter
day day: Specifies the number of days. The day argument ranges from 0 to 365.
hour hour: Specifies the number of hours. The hour argument ranges from 0 to 23.
minute minute: Specifies the number of minutes. The minute argument ranges from 0 to 59.
unlimited: Specifies an unlimited lease time.
Use the expired command to set the valid period for a global DHCP address pool.
Use the undo expired command to revert to the default valid period.
The default valid period is 1 day.
Related command: dhcp server ip-pool, dhcp server expired.
Example
# Set the IP address lease time of the global DHCP address pool 0 to one day plus two hours and three minutes.
<H3C> system-view
[H3C-dhcp-0] expired day 1 hour 2 minute 3
4.2.22  gateway-list
gateway-list ip-address [ ip-address ]
undo gateway-list { ip-address | all }
View
Parameter
ip-address: IP address of an outbound gateway. You can specify up to eight IP addresses (separated by spaces) in one command.
all: Specifies all outbound gateway IP addresses.
Use the gateway-list command to configure one or more outbound gateway addresses for DHCP clients.
Use the undo gateway-list command to remove one or all outbound gateway addresses configured for DHCP clients.
By default, no outbound gateway address is configured for DHCP clients.
With eight outbound gateway addresses already configured, if you add a new outbound gateway address by executing the gateway-list command, the new one overwrites the oldest one.
Example
# Configure an outbound gateway with an IP address of 10.110.1.99 for DHCP clients of global DHCP address pool 0.
<H3C> system-view
[H3C-dhcp-0] gateway-list 10.110.1.99
4.2.23  nbns-list
undo nbns-list { ip-address | all }
View
Parameter
ip-address: IP address of a NetBIOS server. You can specify up to eight IP addresses (separated by spaces) in one command.
all: Specifies all configured NetBIOS server IP addresses.
Use the nbns-list command to configure one or more NetBIOS server addresses for a global DHCP address pool.
Use the undo nbns-list command to remove one or all NetBIOS server addresses configured for a global DHCP address pool.
By default, no NetBIOS server address is configured for a global DHCP address pool.
With eight NetBIOS server addresses already configured, if you add a new NetBIOS server address by executing the nbns-list command, the new one overwrites the oldest one.
Related command: dhcp server ip-pool, dhcp server nbns-list, netbios-type.
Example
# Configure a NetBIOS server with an IP address of 10.12.1.99 for the global DHCP address pool named 0.
<H3C> system-view
[H3C-dhcp-0] nbns-list 10.12.1.99
4.2.24  netbios-type
undo netbios-type
View
Parameter
b-node: Specifies the NetBIOS node type of DHCP clients to be b-node (b stands for broadcast). Nodes of this type establish their host name-to-IP address mappings by broadcasting.
p-node: Specifies the NetBIOS node type of DHCP clients to be p-node (p stands for peer-to-peer). Nodes of this type establish their host name-to-IP address mappings by communicating with NetBIOS server.
m-node: Specifies the NetBIOS node type of DHCP clients to be m-node (m stands for mixed). Nodes of this type are p nodes which take some broadcast features.
h-node: Specifies the NetBIOS node type of DHCP clients to be h-node (h stands for hybrid). Nodes of this type are b nodes which take peer-to-peer mechanism.
Use the netbios-type command to configure the NetBIOS node type for DHCP clients of a global DHCP address pool.
Use the undo netbios-type command to remove NetBIOS node type configuration of a global DHCP address pool.
By default, the DHCP clients are of h-node type.
Related command: dhcp server ip-pool, dhcp server netbios-byte, nbns-list.
Example
# Configure the NetBIOS node type of DHCP clients of the global DHCP address pool 0 to b-node.
<H3C> system-view
[H3C-dhcp-0] netbios-type b-node
4.2.25  network
network ip-address [ mask netmask ]
undo network
View
Parameter
ip-address: Address range for dynamic IP address assigning.
mask netmask: Specifies the subnet mask of the address pool. If you do not provide this argument, the default subnet mask is used.
Use the network command to configure an address range for dynamic IP address assignment.
Use the undo network command to remove the address range configured for dynamic IP address assignment.
By default, no IP address range is configured for dynamic IP address assignment.
Each DHCP address pool can be configured with only one address range. If you execute the network command multiple times, then only the last configured address range works.
Related command: dhcp server ip-pool, dhcp server forbidden-ip.
Example
# Configure 192.168.8.0/24 as the address range for the global DHCP address pool 0.
<H3C> system-view
[H3C-dhcp-0] network 192.168.8.0 mask 255.255.255.0
4.2.26  option
undo option code
View
Parameter
code: Customized option value, a number ranging from 2 to 254.
ascii ascii-string: Specifies an ASCII string. The ascii-string argument is a string that is of 1 to 63 characters in length.
hex hex-string: Specifies a numeric string containing two or four hexadecimal digits (hh or hhhh).
Use the option command to configure a custom DHCP option for a global DHCP address pool.
Use the undo option command to remove a custom DHCP option configured for the global DHCP address pool.
If you execute the option command multiple times, the new configurations overwrite the corresponding old ones
Related command: dhcp server ip-pool, dhcp server option.
Example
# Configure a custom option for the global DHCP address pool, with an option value of 100 and two hexadecimal numbers of 0x11 and 0x22.
<H3C> system-view
[H3C-dhcp-0] option 100 hex 11 22
reset dhcp server conflict { ip ip-address | all }
View
Parameter
ip-address: Clears statistics about the specified IP address conflicts.
all: Clears all statistics about address conflicts.
Use the reset dhcp server conflict command to clear statistics information about DHCP address conflicts.
Related command: display dhcp server conflict.
Example
# Clear all statistics information about DHCP address conflicts.
<H3C> reset dhcp server conflict all
reset dhcp server ip-in-use{ all | interface [ vlan-interface vlan-id ] | ip ip-address | pool [ pool-name ] }
View
Parameter
all: Specifies all binding entries.
ip-address: Specifies the binding entry that contains the specified IP address.
pool-name: Specifies a global DHCP address pool. If you do not provide this argument, then all global DHCP address pools are included.
vlan-id: Specifies a VLAN interface DHCP address pool. If you do not provide this argument, then all VLAN interface DHCP address pools are included.
Use the reset dhcp server ip-in-use command to clear configuration about dynamically bound DHCP addresses.
Related command: display dhcp server ip-in-use.
Example
# Clear the binding entries that contain the IP address of 10.110.1.1.
<H3C> reset dhcp server ip-in-use ip 10.110.1.1
View
Parameter
None
Use the reset dhcp server statistics command to clear statistics information about the DHCP servers, such as the number of DHCP address pools, the number of automatically bound, manually bound IP addresses and expired IP addresses, and the number of unrecognized packets, DHCP_Request packets and DHCP_ACK packets.
Related command: display dhcp server statistics.
Example
# Clear statistics information about the DHCP servers.
<H3C> reset dhcp server statistics
4.2.30  static-bind ip-address
static-bind ip-address ip-address [ mask netmask ]
undo static-bind ip-address
View
Parameter
ip-address: IP address to be bound.
mask netmask: Specifies the subnet mask of the IP address to be bound. If you do not provide the argument, the default subnet mask is used.
Use the static-bind ip-address command to specify the IP address to be statically bound.
Use the undo static-bind ip-address command to free a statically bound IP address.
By default, no IP address is statically bound.
The static-bind ip-address command and the static-bind mac-address command must be coupled when you configure statically bound entries to specify the corresponding IP address bound to the MAC address specified by the static-bind mac-address command.
Related command: dhcp server ip-pool, static-bind mac-address.
Example
# Bind the PC with a MAC address of 0000-e03f-0305 to 10.1.1.1, whose subnet mask is 255.255.255.0.
<H3C> system-view
[H3C-dhcp-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0
[H3C-dhcp-0] static-bind mac-address 0000-e03f-0305
4.2.31  static-bind mac-address
static-bind mac-address mac-address
undo static-bind mac-address
View
Parameter
mac-address: MAC address to be bound.
Use the static-bind mac-address command to specify the MAC address to be statically bound.
Use the undo static-bind mac-address command to free a statically bound MAC address.
By default, no MAC address is statically bound.
The static-bind mac-address command and the static-bind ip-address command must be coupled when you configure statically bound entries to specify the corresponding MAC address bound to the IP address specified by the static-bind ip-address command.
Related command: dhcp server ip-pool and static-bind ip-address.
Example
<H3C> system-view
4.3  DHCP Relay Configuration Commands
4.3.1  debugging dhcp relay
debugging dhcp relay { all| packet | error | event }
undo debugging dhcp relay { all| packet | error | event }
View
Parameter
all: Enables all types of debugging concerning DHCP Relay.
packet: Enables debugging for packets.
error: Enables debugging for error messages.
event: Enables debugging for events.
Use the debugging dhcp-relay command to enable debugging for DHCP Relay.
Use the undo debugging dhcp-relay command to disable specified type of debugging concerning DHCP Relay.
Debugging for DHCP Relay is disabled by default.
Example
# Enable debugging for DHCP Relay.
<H3C> debugging dhcp relay
*0.7200205-DHCP-8-dhcp_debug:
From client to server:
Interface: VLAN-Interface 1
Type: dhcp-request
ClientHardAddress: 0010-dc19-695d
          ServerIpAddress: 192.168.1.2
*0.7200230-DHCP-8-dhcp_debug:
From server to client:
ServerGroupNo: 0
Type: dhcp-ack
         your ip address: 10.1.1.1
*0.7200580-DHCP-8-largehop:
Discard DHCP request packet because of too large hop count!
*0.7200725-DHCP-8-invalidpkt:
Wrong DHCP packet!
Table 4-6 Description on the fields of the debugging dhcp-relay command
The VLAN interface that forwards DHCP packets
Type of the forwarded DHCP packet
ClientHardAddress
The MAC address of the DHCP client
ServerIpAddress
The IP address of the DHCP server
your ip address
The IP address assigned to the DHCP client
4.3.2  dhcp relay security
dhcp relay security ip-address mac-address static
undo dhcp relay security ip-address
View
Parameter
ip-address: IP address the user uses.
mac-address: MAC address the user owns.
static: Specifies the user address entry is static.
Use the dhcp relay security command to add a user address entry for the DHCP server.
Use the undo dhcp relay security command to remove a user address entry configured for the DHCP server.
Before adding/removing a user address entry, you can check user address entries configured for the DHCP server using the display dhcprelay-security command.
Example
# Configure a user address entry for a DHCP server, with an IP address of 1.1.1.1 and a MAC address of 0005-5D02-F2B3.
<H3C> system-view
[H3C] dhcp relay security 1.1.1.1 0005-5D02-F2B3 static
4.3.3  dhcp relay security address-check
dhcp relay security address-check { enable | disable }
View
VLAN interface view
Parameter
None
Use the dhcp relay security address-check enable command to enable security address checking on a VLAN interface.
Use the dhcp relay security address-check disable command to disable security address checking on a VLAN interface.
For a VLAN interface, security address checking is disabled by default.
Example
# Enable security address checking on VLAN interface 1.
<H3C> system-view
[H3C]interface vlan-interface 1
[H3C-Vlan-interface1] dhcp relay security address-check enable
4.3.4  dhcp-server detect
dhcp server detect
View
Parameter
None
Use the dhcp server detect command to enable fake DHCP server detecting.
Use the undo dhcp server detect command to disable fake DHCP server detecting.
A private DHCP server in a network also answers IP address request packets and issues IP addresses to DHCP clients. However, the IP addresses they issued always bring addresses conflicts and cause users cannot access networks. This kind of DHCP servers are known as fake DHCP servers.
Example
# Enable fake DHCP server detecting.
<H3C> system-view
4.3.5  display dhcp relay address
display dhcp relay address { interface vlan-interface vlan-id | all }
View
Parameter
vlan-id: VLAN number.
interface vlan-interface: Specifies to display information about the DHCP servers configured for the VLAN interface.
all: Specifies to display information about the DHCP servers configured for all VLAN interfaces.
Use the display dhcp relay address command to display information about DHCP servers configured for a VLAN interface.
Example
# Display information about DHCP servers configured for all VLAN interfaces.
<H3C> display dhcp relay address all
    **  Vlan-interface192 DHCP Relay Address  **
    Relay Address [0] :    193.193.1.1
    Relay Address [1] :    1.1.1.1
# Display information about DHCP servers configured for VLAN interface 192.
<H3C> display dhcp relay address interface vlan 192
4.3.6  display dhcprelay-security
display dhcprelay-security [ ip-address ]
View
Parameter
ip-address: User IP address.
Use the display dhcprelay-security command to display information about specific or all user address entries that the DHCP server maintains.
Example
# Display information about all user address entries that the DHCP server maintains.
<H3C> display dhcprelay-security
IP Address      MAC Address IP Address Type
2.2.2.2  0005-5d02-f2b2  Static
3.3.3.3  0005-5d02-f2b3  Dynamic
---   2 dhcp-security item(s) found   ---
Table 4-7 Description on the fields of the display dhcp-security command
IP Address
User IP address
MAC Address
User MAC address
IP Address Type
Type of the user address entry, which can be static or dynamic
4.3.7  ip relay address
ip relay address ip-address
undo ip relay address { ip-address | all }
View
VLAN interface view
Parameter
ip-address: IP address of the DHCP server to which the DHCP packets received by this VLAN interface are forwarded.
all: Specifies all DHCP servers configured for the VLAN interface to forward DHCP packets to.
Use the ip relay address command to specify the VLAN interface to operate in DHCP Relay mode and to specify the DHCP server to which the DHCP packets received by this VLAN interface are forwarded.
Use the undo ip relay address command to remove the DHCP server configured for the VLAN interface to forward DHCP packets.
No DHCP server is configured for a VLAN interface by default.
  Caution:
The IP address of the intended DHCP server for the Dhcp relay feature cannot be the IP address of the VLAN interface corresponding to the DHCP Relay. Otherwise, the system gives the information such as “Can't set ip relay address as interface address on interface Vlan-interface 100!”.
Example
# Specify users belonging to VLAN interface 1 to acquire their IP addresses from a specified DHCP server.
<H3C> system-view
[H3C]interface vlan1
[H3C-Vlan-interface1] ip relay address 10.9.0.3
Chapter 5  DHCP Option 82 Configuration Commands
5.1  DHCP Option 82 Configuration Commands
5.1.1  dhcp relay information enable
undo dhcp relay information enable
View
Parameter
None
Use the dhcp relay information enable command to enable the function of Option 82 support on DHCP relay.
Use the undo dhcp relay information enable command to disable the function of Option 82 support on DHCP relay.
By default, this function is enabled. In this case, the DHCP relay will add Option 82 into the request packets sent from the DHCP clients and then forward the packets to the DHCP server.
Related command: dhcp server relay information enable.
Example
# Enable Option 82 support on DHCP relay so that the relay adds Option 82 into the request packets from the DHCP clients before it forwards these packets to a DHCP server.
<H3C> system-view
[H3C] dhcp relay information enable
# Disable Option 82 support on DHCP relay so that the relay does not add Option 82 into the request packets from the DHCP clients before it forwards these packets to a DHCP server.
[H3C] undo dhcp relay information enable
5.1.2  dhcp relay information strategy
undo dhcp relay information strategy
View
Parameter
drop: Indicates that the DHCP relay will drop the packets carrying Option 82.
keep: Indicates that the DHCP relay DHCP relay does not change the packets carrying Option 82.
replace: Indicates that the DHCP relay replaces Option 82 carried by the packets with its own Option 82.
Use the dhcp relay information strategy command to configure the strategy for the DHCP relay to process the packets carrying Option 82.
Use the undo dhcp relay information strategy command to restore the default strategy.
By default, the replace strategy is adopted.
Example
# Configure the DHCP relay to drop the request packets carrying Option 82.
<H3C> system-view
[H3C] dhcp relay information strategy  drop
# Restore the default strategy for the DHCP relay to process the request packets.
[H3C]undo dhcp relay information strategy
5.1.3  dhcp server relay information enable
undo dhcp server relay information enable
View
Parameter
None
Use the dhcp server relay information enable command to enable the function of Option 82 support on DHCP server.
Use the undo dhcp server relay information enable command to disable the function of Option 82 support on DHCP server.
When a client connected to a DHCP relay broadcasts a DHCP request packet, the DHCP relay is responsible for forwarding the packet to a DHCP server. After Option 82 support is enabled on the DHCP server, if the request packet forwarded by the DHCP relay to the DHCP server carries Option 82, the response packet sent by the DHCP server will carry a response Option 82.
After receiving the response packet from the DHCP server to the DHCP client, the DHCP relay check whether Option 82 exists in the packet. If yes, it strips Option 82. That is, the response packet sent to the client does not carry Option 82.
By default, the function is enabled. That is, the DHCP server will return Option 82 carried in the request packet to the DHCP relay.
Related command: dhcp relay information enable.
Example
# Enable the DHCP server to return Option 82 carried in the request packets to the DHCP relay.
<H3C> system-view
[H3C] dhcp server relay information enable
# Disable the DHCP server from returning Option 82 carried in the request packets to the DHCP relay.
[H3C] undo dhcp server relay information enable
Chapter 6  DNS Configuration Commands
6.1  Static DNS Configuration Commands
6.1.1  ip host
ip host hostname ip-address
undo ip host hostname [ ip-address ]
View
Parameter
hostname: Name of the host. It is a character string that consists of 1 to 20 characters, including letters, numbers, "_" or “,”, and it must contain at least one letter.
ip-address: Host IP address (the corresponding IP address to the host name) in dotted decimal notation.
Use the ip host command to configure the host name and the host IP address.
Use the undo ip host command to cancel the host name and the host IP address.
By default, Host name and corresponding IP address are null.
Related command: display ip host.
Example
# Set swtich1’s IP address to be 10.110.0.1.
[H3C] ip host switch1 10.110.0.1
6.1.2  display ip host
display ip host
View
Parameter
None
Use the display ip host command to view all the host names and the corresponding IP addresses.
Example
# Display all host names and the corresponding IP addresses of the hosts.
<H3C> display ip host
Host         Age     Flags       Address
My           0       static      1.1.1.1
Aa           0       static      2.2.2.4
Table 6-1 Description on the fields of the display ip host command
Host
Host name
Age
Valid period
Flags
Flags
Address
Host IP address
6.2  Dynamic DNS Configuration Commands
6.2.1  debugging dns
debugging dns
undo debugging dns
View
Parameter
None
Use the debugging dns command to enable DNS debugging.
Use the undo debugging dns command to disable DNS debugging.
By default, DNS debugging is disabled.
Example
# Enable DNS debugging
<H3C> debugging dns
make DNS packet for name adcd.com succeed
The information above indicates that the query packet for the domain name “abcd.com” is generated.
send the packet to 172.16.1.1 DNS server for 1 time
The information above indicates that the first query is performed to the domain name with the IP address of “172.16.1.1”.
receive a right answer from server 0xAC100101
The information above indicates that a correct answer packet is received from the server.
query timeout
The information above indicates that the query for a domain name from a server times out because no answer is received.
6.2.2  display dns domain
display dns domain
View
Parameter
None
Use the display dns domain command to view the domain name suffix list.
Related command: dns domain.
Example
# View domain name suffix list.
<H3C> display dns domain
No         Domain-name
0          abcd.com
Table 6-2 Description on the fields of the display dns domain command
No
Sequence number
Domain-name
Domain name suffix name
6.2.3  display dns dynamic-host
View
Parameter
None
Use the display dns dynamic-host command to view the dynamic domain name buffer.
Example
# View the dynamic domain name buffer.
<H3C> display dns dynamic-host
No  Domain-name             Ipaddress            RR‑TTL(S)      Alias
0   www.baidu.com           202.108.249.134     63000
1   www.yahoo.akadns.net    66.94.230.39        24
2   www.hotmail.com         207.68.172.239      3585
3   www.eyou.com            61.136.62.70        3591
Table 6-3 Description on the fields of the display dns dynamic-host command
No
Sequence number
Domain-name
Domain name
Ipaddress
Corresponding IP name of the domain name
RR–TTL(S)
Time to live, that is, the time for an entry to be stored, in seconds.
Alias
Alias of the domain name. There can be four of them at the most.
6.2.4  display dns server
display dns server
View
Parameter
None
Use the display dns server command to view the related information of the domain name server.
Related command: dns server.
Example
# View the related information of the domain name server.
<H3C> display dns server
Domain-server                Ipaddress
0                            172.16.1.1
1                            172.16.1.2
Table 6-4 Description on the fields of the display dns server command
Domain-server
Domain name server
Ipaddress
Corresponding IP address of the domain name server
6.2.5  dns domain
dns domain domain-name
undo dns domain [ domain-name ]
View
Parameter
domain-name: Domain name suffix.
Use the dns domain command to add the domain name suffix.
Use the undo dns domain command to delete the domain name suffix.
The system supports up to 10 domain name suffixes. To delete the domain name suffix, input the suffix name, and the specific suffix is deleted. Otherwise, all of the suffixes are deleted.
Related command: display dns domain.
Example
# Configure a domain name suffix “com”.
<H3C> system-view
[H3C] dns domain com
6.2.6  dns resolve
dns resolve
undo dns resolve
View
Parameter
None
Use the dns resolve command to enable the dynamic domain name resolution function.
Use the undo dns resolve command to disable the dynamic domain name resolution function.
By default, the dynamic domain name resolution function is disabled.
Example
# Enable dynamic domain name resolution.
<H3C> system-view
[H3C] dns resolve
6.2.7  dns server
dns server ip-address
undo dns server [ ip-address ]
View
Parameter
ip-address: IP address of the domain name server.
Use the dns server command to configure the IP address of a domain name server.
Use the undo dns server command to delete the IP address of a domain name server.
The system supports up to six domain name server. To delete the domain name server, input the IP address, and the specific server is deleted. Otherwise, all of the servers are deleted.
Related command: display dns server.
Example
# Configure a domain name server, with an IP address of 172.16.1.1.
<H3C> system-view
[H3C] dns server 172.16.1.1
6.2.8  reset dns dynamic-host
View
Parameter
None
Use the reset dns dynamic-host command to clear the dynamic domain name buffer.
Related command: display dns dynamic-host.
Example
# Clear the dynamic domain name buffer.
<H3C> reset dns dynamic-host
Chapter 7  IP Performance Configuration Commands
7.1  IP Performance Configuration Commands
7.1.1  display fib
display fib
View
Parameter
None
Use the display fib command to view the entries of the forwarding information base. Each line outputs indicates a FIB entry. The information includes destination address/mask length, next hop, current flag, timestamp and outbound interface.
Example
# Display the entries of the Forwarding Information Base.
<H3C> display fib
Destination/Mask   Nexthop         Flag TimeStamp     Interface
10.153.17.0/24     10.153.17.99    U    t[0]          Vlan-interface1
10.153.18.88/32    127.0.0.1       GHU  t[0]          InLoopBack0
10.153.18.0/24     10.153.18.88    U    t[0]          LoopBack0
10.153.17.99/32    127.0.0.1       GHU  t[0]          InLoopBack0
127.0.0.0/8        127.0.0.1       U    t[0]          InLoopBack0
Table 7-1 Description on the fields of the display fib command
Destination/Mask
Destination address/Mask length
Nexthop
The forwarding next hop address
Flag
The flag options include:
B – Blackhole route
D – Dynamic route
G – Gateway route
H – Local host route
S – Static route
U – Route in UP status
R – Unreachable route
L – Route generated by ARP or ESIS
Timestamp
Timestamp
The forwarding interface
7.1.2  display fib ip-address
display fib [ ip-address1 { mask1 | mask-length1 } [ ip-address2 { mask2 | mask-length2 } | longer ] | longer ]
View
Parameter
ip-address1, ip-address2: Destination IP address, in dotted decimal format. ip-address1 and ip-address2 jointly define an address range. The FIB entries in this address range are displayed.
mask1, mask2: IP address mask, in dotted decimal format.
mask-length1, mask-length2: An integer in the range of 0 to 32 to represent the mask length.
longer: Specifies to display the FIB entries that match the specified IP address/subnet mask pairs.
Use the display fib ip-address command to view the FIB entries matching the destination IP address (range). Each line outputs a FIB entry and the display contents for each entry include destination address/mask length, next hop, current flag, timestamp and outbound interface.
Example
# Display the FIB entries whose destination addresses match 169.253.0.0 in the natural mask range or which match most of 169.253.0.0..
<H3C> display fib 169.253.0.0
  Route Entry Count: 1
169.253.0.0/16       2.1.1.1         U       t[0]            Vlan-interface1
# Display the FIB entries whose destination addresses are in the range of 169.254.0.0/16 to 169.254.0.6/16.
<H3C> display fib 169.254.0.0 255.255.0.0 169.254.0.6 255.255.0.0
169.254.0.1/16   2.1.1.1     U       t[0]            Vlan-interface1
For the descriptions of the displayed fields, refer to Table 7-1.
7.1.3  display fib acl
display fib acl { number | name }
View
Parameter
number: ACL in number form, in the range 2000 to 2999
name: ACL in name form, a string of 1 to 32 characters.
Use the display fib command to view the FIB entries matching a specific ACL.
Example
# Display the FIB entries matching ACL 2000.
<H3C> display fib acl 2000
Route entry matched by access-list 2000:
Summary counts: 1
7.1.4  display fib |
display fib | { { begin | include | exclude } text }
View
Parameter
begin: Displays the FIB entries from the first one containing the character string text.
include: Displays only those FIB entries containing the character string text.
exclude: Displays only those FIB entries excluding the character string text.
text: Character string.
Use the display fib | command to view the FIB entries which are output from the buffer according to regular expression and related to the specific character string.
Example
# Display the lines starting from the first one containing the string 169.254.0.0
<H3C> display fib | begin 169.254.0.0
169.254.0.0/16   2.1.1.1     U       t[0]            Vlan-interface1
2.0.0.0/16       2.1.1.1     U       t[0]            Vlan-interface1
7.1.5  display fib ip-prefix
display fib ip-prefix listname
View
Parameter
listname: Prefix list name, a string of 1 to 19 characters in length.
Use the display fib command to view the FIB entries matching the specific prefix list.
Example
# Display the FIB entries matching the prefix list abc0.
<H3C> display fib ip-prefix abc0
Route Entry matched by prefix-list abc0:
Summary count: 3
127.0.0.1/32     127.0.0.1   U       t[0]            InLoopBack0
169.0.0.0/8      2.1.1.1     SU      t[0]            Vlan-interface1
7.1.6  display fib statistics
View
Parameter
None
Use the display fib statistics command to view the total number of FIB entries.
Example
# Display the total number of FIB entries.
<H3C> display fib statistics
Route Entry Count : 30
7.1.7  display icmp statistics
View
Parameter
None
Use the display icmp statistics command to view the statistics information about ICMP packets.
Related command: display ip interface, reset ip statistics.
Example
# View statistics about ICMP packets.
<H3C> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          5                   destination unreachable 0
         source quench 0                   redirects               0
         echo reply    10                  parameter problem       0
         timestamp     0                   information request     0
         mask requests 0                   mask replies            0
         time exceeded 0
  Output:echo          10                  destination unreachable 0
         echo reply    5                   parameter problem       0
         timestamp     0                     information reply     0
         time exceeded 0
Table 7-2 Description on the fields of the display icmp statistics command
bad formats
Number of input packets in bad format
bad checksum
Number of input packets with wrong checksum
echo
Number of input/output echo request packets
Number of input/output packets with unreachable destination
source quench
Number of input/output source quench packets
redirects
Number of input/output redirected packets
echo reply
Number of input/output echo reply packets
parameter problem
Number of input/output packets with parameter problems
timestamp
Number of input/output timestamp packets
information request
Number of input information request packets
mask requests
Number of input/output mask request packets
mask replies
Number of input/output mask reply packets
information reply
Number of output information reply packets
time exceeded
Number of packets that exceeds the time
7.1.8  display ip socket
display ip socket [ socktype sock-type ] [ task-id socket-id ]
View
Parameter
sock-type: The type of a socket (tcp:1, udp: 2, raw ip: 3).
task-id: The ID of a task, with the value ranging from 1 to 100.
socket-id: The ID of a socket, with the value ranging from 0 to 3072.
Use the display ip socket command to display the information about the sockets in the current system.
Example
# Display the information about the socket of TCP type.
<H3C> display ip socket socktype 1
SOCK_STREAM:
Task = VTYD(18), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_SENDVPNID SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(18), socketid = 2, Proto = 6,
LA = 10.153.17.99:23, FA = 10.153.17.56:1161,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_SENDVPNID SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
Task = VTYD(18), socketid = 3, Proto = 6,
LA = 10.153.17.99:23, FA = 10.153.17.82:1121,
Table 7-3 Description on the fields of the display ip socket command
SOCK_STREAM
The socket type
The ID of a task
socketid
The ID of a socket
Proto
The protocol number used by the socket
sndbuf
The sending buffer size of the socket
rcvbuf
The receiving buffer size of the socket
sb_cc
The current data size in the sending buffer. The value makes sense only for the socket of TCP type, because only TCP is able to cache data
rb_cc
The current data size in the receiving buffer
socket option
The option of the socket
socket state
The state of the socket
7.1.9  display ip statistics
View
Parameter
None
Use the display ip statistics command to view the statistics information about IP packets.
Example
# View statistics about IP packets.
<H3C> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
Table 7-4 Description on the fields of the display ip statistics command
Input:
sum
Sum of input packets
local
Number of received packets whose destination is the local device
bad protocol
Number of packets with wrong protocol number
bad format
Number of packets in bad format
bad checksum
Number of packets with wrong checksum
bad options
Number of packets that have wrong options
Output:
forwarding
Number of forwarded packets
local
Number of packets that are sent by the local device
dropped
Number of dropped packets during transmission
no route
Number of packets that cannot be routed
compress fails
Number of packets that cannot be compressed
Fragment:
input
Number of input fragments
output
Number of output fragments
dropped
Number of dropped fragments
fragmented
Number of packets that are fragmented
couldn't fragment
Number of packets that cannot be fragmented
Reassembling:
sum
Number of packets that are reassembled
timeouts
Number of packets that time out
7.1.10  display tcp statistics
View
Parameter
None
Use the display tcp statistics command to view the statistics information about TCP packets.
For the related commands, see display tcp status, reset tcp statistics.
Example
# View statistics about TCP packets.
<H3C> display tcp statistics
Received packets:
 Total: 753
 packets in sequence: 412 (11032 bytes)
 window probe packets: 0, window update packets: 0
 checksum error: 0, offset error: 0, short error: 0
 duplicate packets: 4 (88 bytes), partially duplicate packets: 5 (7 bytes)
 out-of-order packets: 0 (0 bytes)
 packets of data after window: 0 (0 bytes)
 packets received after close: 0
 ACK packets: 481 (8776 bytes)
 duplicate ACK packets: 7, too much ACK packets: 0
Sent packets:
 Total: 665
 urgent packets: 0
 control packets: 5 (including 1 RST)
 window probe packets: 0, window update packets: 2
 data packets: 618 (8770 bytes) data packets retransmitted: 0 (0 bytes)
 ACK-only packets: 40 (28 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
Table 7-5 Description on the fields of the display tcp statistics command
Received packets
Information followed is about received packets
Total:753
Total number of received packets: 753
Up to 412 packets (total of 11,032 bytes) arrive in sequence
Number of window probe packets: 0
Number of window update packets: 0
Number of checksum errors: 0
Number of offset errors: 0
Number of short errors: 0
Number of duplicate packets: 4 (total of 88 bytes)
Number of partially duplicate packets: 5 (total of 7 bytes)
Number of out-of-order packets: 0 (0 byte)
Number of packets out of receiving window: 0 (0 byte)
Number of packets received after the connection closed: 0
Number of ACK packets: 481 (total of 8776 bytes of data acknowledged)
Number of duplicate ACK packets: 7
Number of too-much ACK packets: 0 (ACK packets that acknowledge data not sent)
Sent packets
Information followed is about sent packets
Total: 665
Total number of sent packets: 665
urgent packets: 0
Number of urgent packets: 0
Number of control packets: 5 (including 1 RST packet)
Number of window update packets: 2
Number of data packets: 618 (total of 8770 bytes)
Number of data packets retransmitted: 0 (0 byte)
Number of ACK packets: 40 (28 of which delayed)
Number of retransmitted timeout events: 0
Number of connections dropped due to the number of retransmitted timeout events exceeding the specified value: 0
Number of keepalive timeout events: 0
Number of keepalive probe packets sent: 0
disconnected : 0
Number of connections disconnected when keepalive probes fail: 0
Number of initiated connections: 0
Number of accepted connections: 0
Number of established connection: 0
Number of closed connection: 0
Number of dropped connections (after SYN messages received): 0
Number of connections initiated drooped: 0
Number of packets dropped with MD5 authentication: 0
Number of packets permitted with MD5 authentication: 0
7.1.11  display tcp status
display tcp status
View
Parameter
None
Use the display tcp status command to view all TCP connection states. This helps user monitor TCP connection at any time.
Example
# Display the state of all TCP connections.
<H3C> display tcp status
TCPCB        Local Add:port      Foreign Add:port        State
03e37dc4 0.0.0.0:4001            0.0.0.0:0           Listening
04217174 100.0.0.204:23      100.0.0.253:65508   Established
The displayed information indicates that a TCP connection is established. The local IP address of this TCP connection is 100.0.0.204, and the local port number is 23. The remote IP address is 100.0.0.253, and the remote port number is 65508. In addition, there is a local server process which listens to the port 4001.
7.1.12  display udp statistics
View
Parameter
None
Use the display udp statistics command to view UDP traffic statistic information.
It displays the statistic information of all current UDP connections. The statistics information about UDP packets are divided into two major kinds which are received packets and sent packets. The packets are further divided into different types such as check packets and error packets. There are also some statistics related closely to the connections, such as the number of broadcast packets. All these displayed information are measured in packets.
Related command: reset udp statistics.
Example
# Display the UDP traffic statistic information.
<H3C> display udp statistics
Received packet:
Total:0
checksum error:0
shorter than header:0, data length larger than packet:0
no socket on port:0
broadcast:0
not delivered, input socket full:0
input packets missing pcb cache:0
Sent packet:
Total:0
Table 7-6 Description on the fields of the display udp statistics command
Received packet:
Total: 0
Total received UDP packets: 0
checksum error: 0
shorter than header: 0, data length larger than packet: 0
Cases that the length of the packets is shorter than the header: 0
Cases that the data length exceeds the packet length: 0
no socket on port: 0
Cases that there is no socket on port: 0
broadcast: 0
Number of broadcast packets: 0
not delivered, input socket full: 0
Cases that the packets are not forwarded because the socket buffer is full: 0
input packets missing pcb cache: 0
Cases that the packets cannot find pcb: 0
Sent packet:
Total: 0
Total sent UDP packets: 0
7.1.13  reset ip statistics
reset ip statistics
View
Parameter
None
Use the reset ip statistics command to clear the IP statistics information.
Related command: display ip interface, display ip statistics.
Example
# Clear the IP statistics information.
<H3C> reset ip statistics
7.1.14  reset tcp statistics
View
Parameter
None
Use the reset tcp statistics command to clear the TCP statistics information.
Related command: display tcp statistics.
Example
# Clear the TCP statistics information.
<H3C> reset tcp statistics
7.1.15  reset udp statistics
View
Parameter
None
Use the reset udp statistics command to can clear the UDP statistics information.
Example
# Clear the UDP traffic statistics information.
<H3C> reset udp statistics
7.1.16  tcp timer fin-timeout
undo tcp timer fin-timeout
View
Parameter
time-value: TCP finwait timer value in second, with the value ranging from 76 to 3600; By default, it is 675 seconds.
Use the tcp timer fin-timeout command to configure the TCP finwait timer.
Use the undo tcp timer fin-timeout command to restore the default value of the TCP finwait timer.
When the TCP connection state changes from FIN_WAIT_1 to FIN_WAIT_2, the finwait timer is enabled. If the switch does not receive FIN packets before the finwait timer times out, the TCP connection is terminated.
Related command: tcp timer syn-timeout, tcp window.
Example
# Configure the TCP finwait timer value as 800 seconds.
<H3C> system-view
[H3C] tcp timer fin-timeout 800
7.1.17  tcp timer syn-timeout
undo tcp timer syn-timeout
View
Parameter
time-value: TCP synwait timer value measured in seconds, whose value ranges from 2 to 600. The default time-value is 75 seconds.
Use the tcp timer syn-timeout command to configure the TCP synwait timer.
Use the undo tcp timer syn-timeout command to restore the default value of the timer.
TCP enables the synwait timer if a SYN packet is sent. The TCP connection is terminated if the response packet is not received.
Related command: tcp timer fin-timeout, tcp window.
Example
# Configure the TCP synwait timer value as 80 seconds.
<H3C> system-view
[H3C] tcp timer syn-timeout 80
7.1.18  tcp window
tcp window window-size
undo tcp window
View
Parameter
window-size: The size of the sending and receiving buffers measured in kilobytes (KB), whose value ranges from 1 to 32. By default, the window-size is 8KB.
Use the tcp window command to configure the size of the sending and receiving buffers of the connection-oriented Socket.
Use the undo tcp window command to restore the default size of the buffer.
Related command: tcp timer fin-timeout, tcp timer syn-timeout.
Example
# Configure the size of the sending and receiving buffers as 3KB.
<H3C> system-view
[H3C] tcp window 3
