H3C S9500 Series Routing Switches Command Manual-(V1.01)
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Series Routing Switches Command Manual-(V1.01)
08-MPLS Command
08-MPLS Command 378 KB
Table of Contents
Chapter 1 MPLS Basic Configuration Commands. 1-1
1.1 MPLS Basic Configuration Commands. 1-1
1.1.1 debugging mpls lspm.. 1-1
1.1.2 display mpls interface. 1-2
1.1.3 display mpls lsp. 1-2
1.1.4 display mpls static-lsp. 1-3
1.1.5 display mpls statistics. 1-4
1.1.6 lsp-trigger 1-5
1.1.7 mpls. 1-6
1.1.8 mpls lsr-id. 1-7
1.1.9 snmp-agent trap enable ldp. 1-7
1.1.10 snmp-agent trap enable lsp. 1-8
1.1.11 static-lsp egress. 1-8
1.1.12 static-lsp ingress. 1-9
1.1.13 static-lsp transit 1-10
1.2 LDP Configuration Commands. 1-11
1.2.1 debugging mpls ldp. 1-11
1.2.2 display mpls ldp. 1-12
1.2.3 display mpls ldp buffer-info. 1-12
1.2.4 display mpls ldp interface. 1-13
1.2.5 display mpls ldp lsp. 1-15
1.2.6 display mpls ldp peer 1-16
1.2.7 display mpls ldp remote. 1-18
1.2.8 display mpls ldp session. 1-19
1.2.9 mpls ldp. 1-20
1.2.10 mpls ldp enable. 1-20
1.2.11 mpls ldp hops-count 1-21
1.2.12 mpls ldp loop-detect 1-22
1.2.13 mpls ldp password. 1-23
1.2.14 mpls ldp path-vectors. 1-23
1.2.15 mpls ldp remote-peer 1-24
1.2.16 mpls ldp reset-session. 1-25
1.2.17 mpls ldp timer 1-25
1.2.18 mpls ldp transport-ip. 1-27
1.2.19 remote-ip. 1-28
Chapter 2 BGP/MPLS VPN Configuration Commands. 2-1
2.1.1 aggregate. 2-1
2.1.2 apply mpls-label 2-2
2.1.3 debugging bgp. 2-3
2.1.4 default local-preference. 2-4
2.1.5 default med. 2-5
2.1.6 description. 2-5
2.1.7 display bgp vpnv4. 2-6
2.1.8 display bgp routing-table label 2-7
2.1.9 display ip routing-table vpn-instance. 2-8
2.1.10 display ip vpn-instance. 2-8
2.1.11 display mpls l3vpn-lsp. 2-9
2.1.12 display rip vpn-instance. 2-11
2.1.13 domain-id. 2-12
2.1.14 filter-policy export 2-13
2.1.15 filter-policy import 2-14
2.1.16 group. 2-15
2.1.17 if-match mpls-label 2-15
2.1.18 if-match vpn-target 2-16
2.1.19 import-route. 2-17
2.1.20 ip binding vpn-instance. 2-18
2.1.21 ip route-static vpn-instance. 2-19
2.1.22 ip vpn-instance. 2-20
2.1.23 ipv4-family. 2-20
2.1.24 nesting-vpn. 2-22
2.1.25 network. 2-22
2.1.26 ospf 2-23
2.1.27 peer advertise-community. 2-25
2.1.28 peer allow-as-loop. 2-26
2.1.29 peer as-number 2-26
2.1.30 peer as-path-acl export 2-27
2.1.31 peer as-path-acl import 2-28
2.1.32 peer connect-interface. 2-29
2.1.33 peer default-route-advertise. 2-29
2.1.34 peer default-route-advertise vpn-instance. 2-30
2.1.35 peer description. 2-31
2.1.36 peer ebgp-max-hop. 2-31
2.1.37 peer enable. 2-32
2.1.38 peer filter-policy export 2-33
2.1.39 peer filter-policy import 2-33
2.1.40 peer group. 2-34
2.1.41 peer ip-prefix export 2-35
2.1.42 peer ip-prefix import 2-36
2.1.43 peer label-route-capability. 2-36
2.1.44 peer next-hop-local 2-37
2.1.45 peer password. 2-38
2.1.46 peer public-as-only. 2-39
2.1.47 peer reflect-client 2-39
2.1.48 peer route-policy export 2-40
2.1.49 peer route-policy import 2-41
2.1.50 peer route-update-interval 2-42
2.1.51 peer timer 2-42
2.1.52 peer upe. 2-43
2.1.53 peer vpn-instance enable. 2-44
2.1.54 peer vpn-instance group. 2-44
2.1.55 peer vpn-instance route-policy import 2-45
2.1.56 peer vpn-instance substitute-as. 2-46
2.1.57 policy vpn-target 2-47
2.1.58 port trunk mpls vlan. 2-47
2.1.59 preference. 2-48
2.1.60 reflect between-clients. 2-49
2.1.61 reflector cluster-id. 2-49
2.1.62 route-distinguisher 2-50
2.1.63 route-tag. 2-51
2.1.64 timer 2-52
2.1.65 traffic-redirect 2-53
2.1.66 routing-table limit 2-54
2.1.67 sham-link. 2-55
2.1.68 summary. 2-57
2.1.69 vpn-instance-capability simple. 2-58
2.1.70 vpn-target 2-59
Chapter 3 MPLS L2VPN Configuration Commands. 3-1
3.1 CCC Configuration Commands. 3-1
3.1.1 ccc. 3-1
3.1.2 debugging mpls l2vpn. 3-2
3.1.3 display ccc. 3-3
3.1.4 static-lsp egress l2vpn. 3-3
3.1.5 static-lsp ingress. 3-4
3.1.6 static-lsp transit l2vpn. 3-5
3.2 Martini MPLS L2VPN Configuration Commands. 3-6
3.2.1 display mpls l2vc. 3-6
3.2.2 mpls l2vc. 3-9
3.3 Kompella MPLS L2VPN Configuration Commands. 3-10
3.3.1 ce. 3-10
3.3.2 connection. 3-11
3.3.3 display bgp l2vpn. 3-11
3.3.4 display mpls l2vpn. 3-12
3.3.5 l2vpn-family. 3-14
3.3.6 mpls l2vpn. 3-14
3.3.7 mpls l2vpn encapsulation. 3-15
3.3.8 mtu. 3-16
3.3.9 peer enable. 3-16
debugging mpls lspm { agent | all | event | ftn | interface | packet | policy | process | vpn }
undo debugging mpls lspm { agent | all | event | ftn | interface | packet | policy | process | vpn }
View
Parameter
agent: Enables all MPLS Agent debugging.
all: Enables all MPLS-related debugging.
event: Enables debugging for various MPLS events.
ftn: Enables MPLS FTN debugging.
interface: Enables the MPLS debugging on the message sending/receiving interface.
packet: Enables MPLS packet debugging.
policy: Enables MPLS policy debugging.
process: Enables debugging of MPLS internal processing.
vpn: Enables all MPLS VPN debugging.
Use the debugging mpls lspm command to enable various LSPM debugging.
Use the undo debugging mpls lspm command to disable the corresponding debugging.
By default, all debugging is disabled.
This command is used to the debug MPLS LSPM. As running the debugging will affect the performance of the H3C S9500 Series Routing Switches, you are advised to use the command with caution.
Example
# Enable all MPLS VPN debugging.
<H3C> debugging mpls lspm vpn
View
Parameter
None
Use the display mpls interface command to view the information of all MPLS-enabled interfaces.
Related command: display mpls lsp, display mpls statistics and display static-lsp.
Example
# Display the information of all MPLS-enabled interface.
<H3C> display mpls interface
MPLS interface information:
  Interface Vlan-interface12 ( Label Range : 0-44800 )
  Interface Vlan-interface23 ( Label Range : 0-44800 )
  Interface Vlan-interface21 ( Label Range : 0-44800 )
  Interface Vlan-interface20 ( Label Range : 0-44800 )
  Interface Vlan-interface194 ( Label Range : 0-44800 )
  Interface Vlan-interface104 ( Label Range : 0-44800 )
  Interface Vlan-interface76 ( Label Range : 0-44800 )
  Interface Vlan-interface22 ( Label Range : 0-44800 )
  Interface Vlan-interface193 ( Label Range : 0-44800 )
  Interface Vlan-interface27 ( Label Range : 0-44800 )
display mpls lsp [ include text | verbose ]
View
Parameter
include text: Displays the matching string including the specified information.
verbose: Displays detailed information.
Use the display mpls lsp command to display LSP information.
By default, the display mpls lsp command displays all LSP information.
Related command: display mpls interface, display mpls statistics and display static-lsp.
Example
# Display all the LSPs including “-----------”.
<H3C-Vlan-interface2000> display mpls lsp include ----------------
-------------------------------------------------------------------------- LSP Information: Ldp Lsp
NO        FEC               NEXTHOP         I/O-LABEL    OUT-INTERFACE
1     10.110.1.0/24       10.110.1.1      3/-----         -------
2     10.10.10.0/24       10.10.10.1      3/-----         -------
3     10.100.20.20/32     127.0.0.1       3/-----         -------
4     5.5.5.5/32           127.0.0.1       3/-----         -------
5     10.100.20.0/24      10.100.20.20    3/-----        -------
6     80.80.80.80/32      127.0.0.1        3/-----        -------
7     70.70.70.70/32      200.5.5.4       -----/3        Vlan2000
TOTAL:  7 Record(s) Found.
display mpls static-lsp [ include text | verbose ]
View
Parameter
include text: Displays the matching string including the specified information .
Use the display mpls static-lsp command to view the information of one static LSP or all.
Related command: display mpls interface, display mpls lsp and display mpls statistics.
Example
# Display the static LSP information.
<H3C-mpls> display mpls static-lsp
                 LSP Information: Static Lsp
1     1.1.1.1/32          200.5.5.4       -----/1000   Vlan2000
TOTAL:  1 Record(s) Found.
display mpls statistics { interface { Vlan-interface | all } | lsp { lsp-Index | all | lsp-name }}
View
Parameter
interface { Vlan-interface | all }: Specifies one interface or all interfaces.
lsp { lsp-Index | all | lsp-name }: Specifies one label switching path or all label switching paths. Where lsp-Index is an LSP index, lsp-name is an LSP name, and all represents all LSPs.
Use the display mpls statistics command to view the MPLS statistics about one specific VLAN interface/LSP or all interfaces/LSPs.
Related command: display mpls interface and display mpls lsp.
Example
# Display MPLS statistics about all LSPs
<H3C> display mpls statistics lsp all
Building the information...
  LSP Index/LSP Name :  10240/dynamic-lsp
  There is no information of LSP incoming segment!
  The statistics of lsp Out :
    OutSegment octets of LSP is: 162876
    OutSegment packets of LSP is: 2943
    OutSegment errors of LSP is: 0
    OutSegment discard packets of LSP is: 0
1.1.6  lsp-trigger
lsp-trigger { all | ip-prefix ip-prefix }
undo lsp-trigger { all | ip-prefix ip-prefix }
View
MPLS view
Parameter
all: Triggers LSPs at any route.
ip-prefix: Triggers LSPs only at the routes matching the specified IP prefix list.
ip-prefix: IP prefix list, ranging from 1 to 19.
Use the lsp-trigger command to configure topology-triggered LSP creation policy.
Use the undo lsp-trigger command to remove the filtering conditions specified by parameters and disable LSP trigger creation at any route.
By default, all kinds of routing protocols are filtered out.
&  Note:
If no route-triggered policy is configured, LSPs can be triggered at all host routes with 32-bit masks.
If you import an IP-prefix rule without contents, LSPs can be triggered at all routes.
Related command: ip ip-prefix.
Example
# Triggers LSPs at all routes.
<H3C>system-view
[H3C] mpls
[H3C-mpls] lsp-trigger all
1.1.7  mpls
mpls
undo mpls
View
System view, VLAN interface view
Parameter
None
In system, input the mpls command for an initial use to enable MPLS function globally and enter MPLS view. Later you can go straight to the MPLS view with this command.
Use the mpls command in VLAN interface view to enable MPLS on the VLAN interface.
Use the undo mpls command to disable MPLS function in the system view or on the VLAN interface.
By default, you cannot enter this view.
After executing the command, you can enter MPLS view. Only after you enter MPLS view, can you configure other MPLS commands.
You must configure the mpls lsr-id command first and then you can enter MPLS view.
Example
# Enter MPLS view from system view.
<H3C>system-view
[H3C] mpls
[H3C-mpls]
# Execute the mpls command in interface view.
[H3C] vlan 201
[H3C-Vlan201] port gigabitethernet 2/1/1
[H3C-Vlan201] quit
[H3C] interface vlan-interface 201
[H3C-vlan-interface201] mpls
% Info: MPLS in the interface is starting, please wait...OK
1.1.8  mpls lsr-id
mpls lsr-id ip-address
undo mpls lsr-id
View
Parameter
ip-address: LSR ID, in the format of IP address, used to identify an LSR.
Use the mpls lsr-id command to configure an LSR ID.
Use the undo mpls lsr-id command to delete an LSR ID.
By default, no LSR has an ID.
You must configure the mpls lsr-id command first and then you can use the other MPLS-related commands.
An LSR ID is in the format of IP address, thus a loopback address is recommended.
Related command: display mpls interface.
Example
# Set the LSR ID to 202.17.41.246.
<H3C>system-view
[H3C] mpls lsr-id 202.17.41.246
% Info: Mpls lsr-id changed.
undo snmp-agent trap enable ldp
View
Parameter
None
Use the snmp-agent trap enable ldp command to enable Trap function in MPLS LDP creation.
Use the undo snmp-agent trap enable ldp command to disable Trap function in MPLS LDP creation.
By default, Trap function is not enabled during MPLS LDP creation.
Example
# Enable the Trap function during MPLS LDP creation.
<H3C>system-view
[H3C] snmp-agent trap enable ldp
undo snmp-agent trap enable lsp
View
Parameter
None
Use the snmp-agent trap enable lsp command to enable Trap function in MPLS LSP creation.
Use the undo snmp-agent trap enable lsp command to disable Trap function in MPLS LSP creation.
By default, Trap function is disabled during MPLS LSP creation.
Example
# Enable the Trap function during MPLS LSP creation.
[H3C] snmp-agent trap enable lsp
static-lsp egress lsp-name [ l2vpn ] incoming-interface interface-type interface-number in-label in-label-value
undo static-lsp egress lsp-name
View
MPLS view
Parameter
lsp-name: LSP name
interface-type Interface-number: Interface type, interface number.
in-label-value: Value of inbound label, ranging 3 (implicit empty label) and from 16 to 1023.
Use the static-lsp egress command to configure a static LSP for an egress LSR.
Use the undo static-lsp egress command to delete an LSP for an egress LSR.
Related command: static-lsp ingress, static-lsp transit and debugging mpls.
Example
# Configure a static LSP named bj-sh on the egress LSR.
<H3C>system-view
[H3C-mpls] static-lsp egress bj-sh incoming-interface vlan-interface 201 in-label 233
static-lsp ingress lsp-name { destination dest-addr { addr-mask | mask-length } | l2vpn } nexthop next-hop-addr } } out-label out-label-value
undo static-lsp ingress lsp-name
View
MPLS view
Parameter
lsp-name: LSP name
dest-addr: Destination IP address.
addr-mask: Destination IP address mask.
mask-length: Mask length of destination IP address
next-hop-addr: Next-hop address.
out-label-value: Value of outbound label, ranging 3 (implicit empty label) and from 16 to 1023.
Use the static-lsp ingress command to configure a static LSP for an ingress LSR.
Use the undo static-lsp ingress command to delete an LSP for an ingress LSR.
Related command: static-lsp egress, static-lsp transit and debugging mpls.
Example
# Configure a static LSP for the ingress LSR heading for the destination address 202.25.38.1.
<H3C>system-view
[H3C] mpls
[H3C-mpls] static-lsp ingress bj-sh destination 202.25.38.1 24 nexthop 202.55.25.33 out-label 237
static-lsp transit lsp-name [ l2vpn ] incoming-interface interface-type interface-number in-label in-label-value nexthop next-hop-addr out-label out-label-value
undo static-lsp transit lsp-name
View
MPLS view
Parameter
lsp-name: LSP name
in-label-value: Value of inbound label, ranging from 16 to 1023.
Use the static-lsp transit command to configure a static LSP for a transit LSR.
Use the undo static-lsp transit command to delete an LSP for a transit LSR.
Related command: static-lsp egress and static-lsp ingress.
Example
# Configure a static LSP for the VLAN201 interface on a transit LSR, with an inbound label of 123 and an outbound label of 253.
<H3C>system-view
[H3C] mpls
[H3C-mpls] static-lsp transit bj-sh incoming-interface vlan-interface 201 in-label 123 nexthop 202.34.114.7 out-label 253
debugging mpls ldp { all | main | advertisement | session | pdu | notification | remote } [ interface interface-type interface-number ]
undo debugging mpls ldp { all | main | advertisement | session | pdu | notification | remote } [ interface interface-type interface-number ]
View
Parameter
all: Displays all debugging information related to LDP.
main: Displays the debugging information of LDP main tasks.
advertisement: Displays the debugging information during LDP advertising.
session: Displays debugging information during LDP session processing.
pdu: Displays the debugging information during PDU packet processing.
notification: Displays the debugging information during notification.
remote: Displays debugging information of all Remote Peers.
interface-type interface-number: Interface type, interface number.
Use the debugging ldp command to enable the debugging of various LDP messages. Use the undo debugging ldp command to disable the debugging of various LDP messages.
You are advised to use the debugging command cautiously.
Example
# Enable LDP debugging.
<H3C> debugging mpls ldp all
display mpls ldp
View
Parameter
None
Use the display mpls ldp command to display LDP and LSR information.
By default, it displays information of LDP and LSR.
Related command: mpls ldp, mpls ldp hops-count, mpls ldp loop-detection and mpls ldp path-vectors.
Example
# Display LDP and LSR information.
<H3C> display mpls ldp
Label Distribution Protocol: V1
LSR ID: 10.10.10.10      LSR Status: Active
Loop Detection: Disabled.
Path Vector Limit: 32              Hop Count Limit: 32
DU Readvertisement: On             Request   Retry: Off
Label Retention Mode: Liberal      DU Explicit Request: Off
Label Distribution Control Mode: Ordered.
View
Parameter
None
Use the display mpls ldp buffer-info command to view the LDP buffer information.
Example
# Display the LDP buffer information.
<H3C> display mpls ldp buffer-info
Buffer-Name     Buffer-ID    Buffer-Size  Total-Count  Free-Count
ENTITY          0            292          199          195
LOCAL-IF        1            36           200          196
PEER-IF         2            40           201          195
PDU                  3            204          249          249
ADJACENCY        4            56           201          198
PEER-INF             5            116          201          198
SESSION              6            176          201          198
US-BLK               7            264          1052         1028
DS-BLK               8            240          1052         1042
FEC                  9            40           1042         1032
US-LIST         10           16           1052         1028
TRIG-BLK        11           56           2076         2071
LABEL-RANGE     12           20           198          198
CR-TUNNEL       13           124          128          128
ER-HOP          14           40           4096         4096
IF-MSG          15           24           9999         9999
Buffer no error.
display mpls ldp interface [ | begin text | exclude text | include text ]
View
Parameter
|: Displays matched outputs.
begin: Displays the outputs matching the regular expression from the first line.
exclude: Displays the outputs excluding those lines matching the regular expression.
include: Displays only those outputs matching the regular expression.
text: Contents of the regular expression.
Use the display mpls ldp interface command to display information of the interface with LDP enabled and in the Up state.
Related command: mpls ldp enable and display mpls ldp session.
Example
# Display the information of the interface with LDP enabled and in the UP state.
<H3C-Ethernet3/1/0> display mpls ldp interface
Displaying information about all Ldp interface:
     Interface Vlan-interface12(address=12.12.12.2):
     Label distributing enabled,bound to entity:2.2.2.2:0
     Generic label range configured:16 -  44800
     Label Advertisement Mode: Downstream-Unsolicited
     Configured KeepAlive hold time:60, Configured Hello hold time:15
     Negotiated Hello hold time:15
     Hello packets sent/rcv:21158/21136
     Interface Vlan-interface21(address=21.21.21.2):
     Negotiated Hello hold time:0
     Hello packets sent/rcv:16929/0
     Interface Vlan-interface22(address=22.22.22.2):
     Hello packets sent/rcv:21175/21159
     Interface Vlan-interface23(address=23.23.23.2):
     Hello packets sent/rcv:20970/20949
     Interface Vlan-interface194(address=192.4.1.1):
     Hello packets sent/rcv:15296/0
display mpls ldp lsp [ | begin text | exclude text | include text ]
View
Parameter
Use the display mpls ldp lsp command to view relevant LSP information created via LDP.
Related command: display mpls lsp.
Example
# Display LSP.
<H3C-Ethernet3/1/0> display mpls ldp lsp
                              LDP LSP Information
No.  FECType  DestAddress        InLab OLab  UHC DHC Next-Hop       OutInterface
1    PREFIX   2.2.2.2            3     ----  0   1   127.0.0.1      InLoop0
2    PREFIX   2.2.2.2            3     ----  0   1   127.0.0.1      InLoop0
3    PREFIX   192.4.1.0/24       3     ----  0   1   192.4.1.1      Vlan194
4    PREFIX   192.4.1.0/24       3     ----  0   1   192.4.1.1      Vlan194
     Liberal  12.12.12.0/24      ----  3     --- 1   --------       Vlan22
5    PREFIX   12.12.12.0/24      3     ----  0   1   12.12.12.2     Vlan12
6    PREFIX   12.12.12.0/24      3     ----  0   1   12.12.12.2     Vlan12
     Liberal  16.16.16.0/24      ----  1026  --- 2   --------       Vlan23
     Liberal  16.16.16.0/24      ----  3     --- 1   --------       Vlan22
7    PREFIX   16.16.16.0/24      3     ----  0   1   16.16.16.16    Vlan16
8    PREFIX   16.16.16.0/24      3     ----  0   1   16.16.16.16    Vlan16
9    PREFIX   22.22.22.0/24      3     ----  0   1   22.22.22.2     Vlan22
     Liberal  1.1.0.5/32         ----  1024  --- 2   --------        ------
10   PREFIX   1.1.0.5            1024  3     0   1   23.23.23.3     Vlan23
11   PREFIX   1.1.0.5            ----  3     1   1   23.23.23.3     Vlan23
     Liberal  85.12.0.1/32       ----  1025  --- 2   --------        ------
12   PREFIX   85.12.0.1          1025  3     0   1   23.23.23.3     Vlan23
13   PREFIX   85.12.0.1          ----  3     1   1   23.23.23.3     Vlan23
display mpls ldp peer [ | begin text | exclude text | include text ]
View
Parameter
Use the display mpls ldp peer command to view peer information.
By default, it displays all the peer information.
Example
# Display peer information.
<H3C> display mpls ldp peer
Displaying information about all peers:
   Local LDP ID: 2.2.2.2:0
   Peer LDP ID: 1.1.1.1:0
   Internetwork Address Type: IPv4
   Internetwork Address: 1.1.1.1
   Maximum Peer PDU length: 4096
   Peer KeepAlive hold time: 60
   Peer Distribution Method: Downstream Unsolicited
   Peer Type: Remote
   Peer RowStatus: Active
   Peer LDP ID: 3.3.3.3:0
   Internetwork Address: 3.3.3.3
   Peer Type: Remote
   Peer Type: Local
   Peer Type: Local
   Peer Type: Local
display mpls ldp remote [ | begin text | exclude text | include text ]
View
Parameter
Use the display mpls ldp remote command to view the configured Remote-peer information.
By default, you can view all the Remote-peer configurations.
Related command: mpls ldp remote-peer and remote-ip.
Example
# Display the Remote-peer configuration.
<H3C> display mpls ldp remote
Displaying information about all Ldp Remote Peers:
     Remote Index: 1
     Peer Address: 1.1.1.1  Transport Address: 2.2.2.2
     Configured KeepAlive hold time:60, Configured Hello hold time:45
     Negotiated Hello hold time:45
     Hello packets sent/rcv:6515/6509
     Remote Index: 3
     Peer Address: 3.3.3.3  Transport Address: 2.2.2.2
     Hello packets sent/rcv:6457/6453
     Remote Index: 4
     Peer Address: 1.1.0.3  Transport Address: 2.2.2.2
     Hello packets sent/rcv:0/0
     Remote Index: 7
     Peer Address: 1.1.1.7  Transport Address: 2.2.2.2
display mpls ldp session [ | begin text | exclude text | include text ]
View
Parameter
Use the display mpls ldp session command to know the session between peer entities.
By default, it displays the session between peer entities.
Related command: mpls ldp enable.
Example
# Display the session between peer entities.
<H3C> display mpls ldp session
Local LDP ID: 1.1.1.9:5;   Peer LDP ID: 4.4.4.9:0
   TCP Connection: 1.1.1.9 <- 4.4.4.9
   Session State: Operational
   Session Role: Passive
   Session existed time:
   Basic Hello Packets Sent/Received: 85/67
   KeepAlive Packets Sent/Received: 1/1
   Negotiated Keepalive hold time: 60   Peer PV Limit: 0
   LDP Basic Discovery Source((A) means active):
   Inter vlan113(A)            Inter vlan112
   Inter vlan111
1.2.9  mpls ldp
mpls ldp
undo mpls ldp
View
Parameter
None
Use the mpls ldp command to enable LDP.
Use the undo mpls ldp command to disable LDP.
By default, LDP is disabled.
Before enabling LDP, you must enable MPLS and configure LSR ID first.
Related command: mpls lsr-id.
Example
# Enable LDP.
<H3C>system-view
[H3C] mpls ldp
mpls ldp enable
mpls ldp disable
View
VLAN interface view
Parameter
None
Use the mpls ldp enable command to enable LDP on a VLAN interface.
Use the mpls ldp disable command to disable LDP on a VLAN interface.
By default, LDP is disabled on an interface.
To enable an interface, you must enable LDP first. After LDP is enabled on an interface, peer discovery and session creation proceed.
Example
# Enable LDP on a VLAN interface.
<H3C> system-view
[H3C] vlan 201
[H3C-Vlan201] quit
[H3C-Vlan-interface201] mpls
[H3C-vlan-interface201] mpls ldp enable
mpls ldp hops-count hop-number
undo mpls ldp hops-count
View
Parameter
hop-number: Maximum hop count of loop detection, ranging from 1 to 32.
Use the mpls ldp hops-count command to set the maximum hop count of loop detection.
Use the undo mpls ldp hops-count command to restore the default value of the maximum hop count of loop detection.
By default, the maximum hop count of loop detection is 32.
This command should be configured before LDP is enabled on all interfaces. Its value, which depends on actual networking, determines the loop detection speed during LSP creation
Related command: mpls ldp loop-detection and mpls ldp path-vector.
Example
# Set the maximum hop count of loop detection to 22.
<H3C> system-view
[H3C] mpls ldp hops-count 22
# Set the maximum hop count of loop detection to its default value 32.
[H3C] undo mpls ldp hops-count
undo mpls ldp loop-detect
View
Parameter
None
Use the mpls ldp loop-detect command to enable loop detection.
Use the undo mpls ldp loop-detect command to disable loop detection.
By default, loop detection is not enabled in the system.
This command should be configured before LDP is enabled on any interface.
Related command: mpls ldp hops-count and mpls ldp path-vectors.
Example
# Enable loop detection.
<H3C>system-view
[H3C] mpls ldp loop-detect
# Disable loop detection.
[H3C] undo mpls ldp loop-detect
mpls ldp password [ cipher | simple ] password
undo mpls ldp password
View
VLAN interface view, remote-peer view
Parameter
cipher: The password in configuration file will be displayed in cipher-text.
simple: The password in configuration file will be displayed in plain-text.
password: User password.
Use the mpls ldp password command to configure MD5 authentication password for the LDP. After this configuration, the MD5 authentication is adopted for LDP on the interface.
Use the undo mpls ldp password command to delete the configuration.
Example
# Configure the LDP authentication mode as MD5, plain-text password 123.
<H3C>system-view
[H3C-vlan-interface201] mpls ldp password simple 123
mpls ldp path-vectors pv-number
undo mpls ldp path-vectors
View
Parameter
pv-number: Maximum value of path vector, ranging from 1 to 32.
Use the mpls ldp path-vectors command to set the maximum value of path vector.
Use the undo mpls ldp path-vectors command to restore the default maximum value of path vector.
By default, pv-number is 32.
This command should be configured before LDP is enabled on all interfaces. Its value, which depends on actual networking situation, determines the loop detection speed during LSP creation
Related command: mpls ldp loop-detection and mps ldp hops-count.
Example
# Set the maximum value of path vector to 23
<H3C>system-view
[H3C] mpls ldp path-vectors 23
# Restore the default maximum value of path vector.
[H3C] undo mpls ldp path-vectors
mpls ldp remote-peer index
undo mpls ldp remote-peer index
View
System view or remote-peer view
Parameter
index: Index that identifies a remote peer entity, ranging from 0 to 99.
Use the mpls ldp remote-peer command to create a Remote-peer entity and enter remote-peer view.
Use the undo mpls ldp remote-peer command to delete a Remote-peer entity.
You can use this command to create a Remote-peer and accordingly create a Remote-session.
Related command: remote-ip.
Example
# Create a Remote-peer.
<H3C>system-view
[H3C] mpls ldp remote-peer 22
[H3C-mpls-remote22]
# Delete a Remote-peer.
[H3C-mpls-remote22] undo mpls ldp remote-peer 22
[H3C]
mpls ldp reset-session peer-address
View
VLAN interface view
Parameter
peer-address: Corresponding remote LDP Peer address (in IP address format).
Use the mpls ldp reset-session command to reset a specified session on an interface.
After LDP is configured on an interface and LDP session is created, this command can be used to reset a specific session on the interface. You only need to specify the address of the peer corresponding to the session to be reset.
Related command: mpls ldp and mpls ldp enable.
Example
# Reset a specified session on the VLAN201 interface.
<H3C>system-view
[H3C-Vlan-interface201] mpls ldp reset-session 10.1.1.1
In VLAN interface view:
mpls ldp timer { session-hold session-holdtime | hello hello-holdtime }
undo mpls ldp timer { session-hold | hello }
In remote-peer view:
mpls ldp timer { targeted-session-hold | targeted-hello } { holdtime holdtime | interval interval }
undo mpls ldp timer { targeted-session-hold | targeted-hello } { holdtime | interval }
View
Parameter
hello hello-holdtime: Hold time (i.e. timeout time) of the Hello hold timer, in the range of 6~65535 (seconds). By default it is 15 seconds.
session-hold session-holdtime: Time interval for Session hold timer to send a session packet, in the range of 1~65535 (seconds). By default it is 60 seconds.
targeted-hello: Hold time (i.e. timeout time) of the Targeted-hello hold timer, in the range of 1~65535 (seconds). By default holdtime is 45 seconds and interval is 13 seconds.
targeted-session-hold: Time interval for Targeted-session hold timer to send a session packet, in the range of 1~65535 (seconds). By default holdtime is 60 seconds and interval is 24 seconds.
holdtime: Time interval for the hold timer.
interval: Time interval to send a Keepalive packet.
Use the mpls ldp timer command to set the hold time for the Hello hold timer and Session hold timer.
Use the undo mpls ldp timer command to restore the default values.
The timeout of the Hello hold timer means that the adjacency with the peer goes down; the timeout of the Session hold timer means the session with the peer goes down.
targeted-hello interval refers to the time interval to send a targeted-hello packet. It cannot be greater than (targeted-hello holdtime) ´ 0.3, so the maximum value is 65535´ 0.3 = 19660.5.
targeted-session-hold interval refers to the time interval to send a Keepalive packet. It cannot be greater than (targeted-session-hold holdtime) ´ 0.4.
In general, the time interval to send a hello/keepalive packet is one third of the hold time of Hello/Session hold timer.
You can usually use the default values if not in special cases, Note that you must reset the session to validate new values if you do modify these timer parameters.
Example
# Modify the hold time of the Hello timer to 30 seconds.
<H3C>system-view
[H3C-Vlan-interface201] mpls ldp timer hello 30
mpls ldp transport-ip { interface | ip-address }
undo mpls ldp transport-ip
View
VLAN interface
Parameter
interface: Sets the IP address of the current interface as the transport address.
ip-address: Sets the IP address as the transport address.
Use the mpls ldp transport-ip command to configure an LDP transport address.
Use the undo mpls ldp transport-ip command to restore the default LDP transport address.
By default, LSR ID is set as a transport address.
When there are multiple directly-connected and MPLS LDP-enabled links between two LSR neighbors, all these links must be configured with the same transport address (it is recommended to adopt the default LSR ID as the transport address). Otherwise, the system may be unable to set up a steady LDP session.
For a Remote-peer, the transport address cannot be configured and is fixed to the LSR ID.
By default, an LSR ID is the address of some Loopback interface and the Remote peer can route to this address for a session. For a Local peer, the address of the local interface or the Router ID of LSR can be adopted as its transport address.
Example
# Set the address of the current interface as a transport address.
<H3C>system-view
[Quidwa-Vlan-interface201] mpls ldp transport-ip interface
# Set the address of another interface as a transport address.
[H3C-Vlan-interface201] mpls ldp transport-ip 10.1.11.2
1.2.19  remote-ip
remote-ip remoteip
View
remote-peer view
Parameter
remoteip: IP address of the Remote-peer.
Use the remote-ip command to configure a Remote-IP address. The address should be the lsr-id of the remote LSR. As Remote Peers adopt LSR ID as their transport addresses, the last two Remote Peers use the lsr-id as their transport addresses for creating TCP connection.
Related command: mpls ldp remote-peer.
Example
# Configure the address of remote-peer.
<H3C>system-view
[H3C] mpls ldp remote-peer 12
[H3C-mpls-remote12] remote-ip 192.168.1.1
&  Note:
Refer to the 05-Routing Protocol Commands Module of the H3C S9500 Switches  Command Manual for the details about the if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, apply ip next-hop, apply local-preference, apply origin, apply tag commands and the related commands.
2.1.1  aggregate
aggregate address mask [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ]*
undo aggregate address mask [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ]*
View
VPN-instance subaddress family view
Parameter
address: IP address of an aggregated route, in dotted decimal format.
mask: Network mask of an aggregated route, in dotted decimal format.
as-set: Generates routes with AS sets.
detail-suppressed: Advertises only aggregated routes.
suppress-policy route-policy-name: Suppresses advertisement of some selected specific routes.
origin-policy route-policy-name: Selects source route for aggregation.
attribute-policy route-policy-name: Sets the attributes of an aggregated route.
Use the aggregate command to create an aggregation entry in the BGP routing table of VPN instance.
Use the undo aggregate command to disable this function.
By default, route aggregation is not enabled.
The function of the keywords involved in the above commands is shown in the following table:
Table 2-1 Keywords function
Keyword
Function
as-set
By setting this keyword, you can create an aggregated route whose AS path contains the information of all the aggregation routes. This keyword is not recommended when aggregating many AS paths because frequent changes of the specific route may result in routing oscillation.
detail-suppressed
This keyword suppresses advertisement of all the specific routes, but not of the aggregated routes. Using the peer filter-policy command, you can suppress some specific routes.
suppress-policy
This keyword enables the creation of an aggregate route but disables the advertising of the specified routes. Using the if-match clause in the route-policy command, you can choose to suppress advertisement of some specific routes.
origin-policy
Using this command, you can only choose the specific routes matching the Route-policy to create aggregated route.
attribute-policy
Using this keyword, you can set the attributes of the aggregation route. The peer route-policy command can also enables you to complete the same setting.
Example
# Create an aggregation entry in the BGP routing table of VPN instance.
[H3C-bgp-af-vpn-instance] aggregate 192.213.0.0 255.255.0.0
apply mpls-label
undo apply mpls-label
View
Route-policy view
Parameter
None
Use the apply mpls-label command to configure the system to assign MPLS labels to the public network routes that meet the filer condition of Route-policy.
Use the undo apply mpls-label command to cancel this configuration.
By default, the public network routes carry no labels.
Related command: if-match mpls-label.
Example
# Define an Apply clause to assign labels to routes meeting the Route-policy filter condition.
[H3C-route-policy] apply mpls-label
2.1.3  debugging bgp
debugging bgp { all | event | normal | { keepalive | mp-update | open | packet | route-refresh | update } [ receive | send ] [ verbose ] }
undo debugging bgp { all | event | normal | keepalive | mp-update | open | packet | route-refresh | update }
View
Parameter
all: Enables all types of BGP debugging.
event: Enables BGP event debugging.
normal: Enables BGP common function debugging.
keepalive: Enables BGP Keepalive packet debugging.
mp-update: Enables multi-protocol BGP Update packet debugging.
open: Enables BGP Open packet debugging.
packet: Enables BGP packet debugging.
route-refresh: Enables BGP Route-Refresh packet debugging.
update: Enables BGP Update packet debugging.
receive: Displays receive information.
send: Displays send information.
Use the debugging bgp command to enable BGP debugging..
Use the undo debugging bgp command to disable BGP debugging.
Caution should be taken in deciding to enable BGP debugging, since debugging affects system performance. Remember to disable the debugging when it is completed.
Example
# Enable the debugging on the detailed information about BGP Keepalive packets.
<H3C> debugging bgp keepalive verbose
undo default local-preference
View
VPNv4 subaddress family view
Parameter
value: Value of the local precedence, ranging from 0 to 4294967295. A greater value enjoys higher precedence. The default local precedence is 100.
Use the default local-preference command to configure the local precedence for BGP routing in VPN.
Use the undo default local-preference command to restore the default configuration.
The value of the local precedence is advertised between IBGP peers and you can affect the BGP routing in VPN by changing the precedence.
Example
# Set the local precedence to be 180, so that the system-advertised routing information will be preferred.
[H3C-bgp-af-vpn] default local-preference 180
2.1.5  default med
default med med-value
undo default med
View
VPNv4 subaddress family view, VPN-instance subaddress family view
Parameter
med-value: MED value, ranging from 0 to 4294967295. The default value is 0.
Use the default med command to configure the MED value of the system.
Use the undo default med command to restore the default value.
MED attributes, switched between autonomous system (AS), is an external measurement for routes and does not leave AS once entering it. The route with smaller MED value will be selected as the external one for AS when other conditions hold.
Example
# The routers RTA and RTB belong to AS100 and the router RTC belongs to AS200. RTC associates with RTA and RTB. Set the MED value of RTA 25. This makes the RTC prefer the route sent by RTB.
[H3C-bgp-af-vpn-instance] default med 25
2.1.6  description
description vpn-instance-description
View
VPN-instance view
Parameter
vpn-instance-description: Specifies the description of a specified VPN instance.
Use the description command to configure description for a specified VPN instance.
Use the undo description command to remove the description of this VPN instance.
Example
# Display the VPN description.
[H3C-vpn-vpna] description test
display bgp vpnv4 { all | route-distinguisher rd-value | vpn-instance vpn-instance-name } { group [ group-name ] | network | peer [ [ peer-address ] verbose ] | routing-table [ options ] }
View
Parameter
all: Displays all the VPNv4 routings.
route-distinguisher rd-value: Displays the information related to RD.
vpn-instance vpn-instance-name: Displays the information related to VPN instance.
group: Displays the information of a neighbor peer group.
network: Displays the advertised routing information.
peer: Displays the peer information.
verbose: Displays detailed peer information.
routing-table: Displays routing information.
options: Configures to view the routing information.
Use the display bgp vpnv4 command to view the VPN address in BGP table.
Example
# Display all the BGP VPNv4 routing tables.
<H3C> display bgp vpnv4 all routing-table
Flags:   # - valid       ^ - active      I - internal
         D - damped      H - history     S - aggregate suppressed
In/out   As
    Dest/mask        Next-hop        Med Local-pref      label   path
    Route Distinguisher:1.1.1.1:1 (VPN instance:v1)
#^  1.0.0.0      0.0.0.0                      -/1024
  Routes total: 1
View
None
Use the display bgp routing-table label command to view the routing information and label information in the BGP routing table. For an unlabelled common IPv4 route, the label in the displayed information is null. If you use the display bgp routing-table address [ mask ] command to view the BGP routing information, the label information will be displayed if the route has a label.
Example
# View the BGP routing information.
<H3C> display bgp routing-table label
                                          In/out
    Dest/Mask          Next-Hop        Label
#^  9.0.0.1/32         0.0.0.0        1024/-
# View the detailed BGP routing information.
<H3C> display bgp routing-table 9.0.0.1
BGP routing table entry information of 9.0.0.1/32
Age          : 00:00:32
State        : valid, sourced, active,
Nexthop      : 0.0.0.0
Origin       : INC
As-path      : (null)
Med          : 1563
In/Out label :   1024/-
display ip routing-table vpn-instance vpn-instance-name [ [ ip-address ] | [ verbose ] statistics ]
View
Parameter
vpn-instance-name: Name assigned to VPN-instance.
ip-address: Displays information of the a specified address.
statistics: Displays statistics of routes.
Use the display ip routing-table VPN-instance command to view the specified information in the IP routing table of vpn-instance.
Example
# Display the IP routing table associated with the VPN-instance.
<PEA> disp ip routing-table vpn-instance vpna-ce1
 vpna-ce1   Route Information
 Routing Table:  vpna-ce1   Route-Distinguisher:   100:1
Destination/Mask  Protocol Pre    Cost     Nexthop         Interface
20.20.20.0/24       BGP      256     0      40.40.40.40  Vlan-interface24
40.40.40.0/24       DIRECT   0       0      40.40.40.10  Vlan-interface24
40.40.40.10/32      DIRECT   0           0      127.0.0.1      InLoopBack0
80.80.80.0/24       BGP     256     0      40.40.40.40  Vlan-interface24
200.200.200.0/24   BGP       256     0      40.40.40.40  Vlan-interface24
 VPN Routing Table:   Route-Distinguisher:   100:2
20.20.20.0/24        BGP         256     0      2.2.2.2     InLoopBack0
30.30.30.0/24        BGP         256     0      2.2.2.2     InLoopBack0
display ip vpn-instance [ vpn-instance-name | verbose ]
View
Parameter
Use the display ip vpn-instance command to view the information related to VPN-instance, such as RD, description, and interfaces of the VPN instance.
Example
# Display the information about VPN-instance VPN 1.
<H3C> display ip vpn-instance vpn1
VPN-Instance : vpn1
   No description
   Route-Distinguisher :    100:6
   Interfaces :
   Vlan-interface1100
display mpls l3vpn-lsp [ vpn-instance vpn-instance-name ] [ transit | egress | ingress ] [ include text | verbose ]
View
Parameter
transit: LSP for the ASBR (Autonomous System Boundary Router).
egress: LSP of egress VPN.
ingress: LSP of ingress VPN.
vpn-instance: Specifies the name of VPN routing/forwarding VPN-instance
include text: Only matches the string including the specified information.
Use the display mpls l3vpn-lsp command to view the information of MPLS L3VPN LSPs of the specified VPN-instance.
Example
# Display MPLS L3VPN transit lsp information on the ASBR.
<H3C> display mpls l3vpn-lsp transit
                 LSP Information: Ebgp Transit Lsp
NO    I/O-LABEL        NEXTHOP         IN-INTERFACE         OUT-INTERFACE
1     1025/3              30.30.1.2            -------       Vlan20
2     1024/3              10.10.1.2            -------       Vlan10
3     1026/1024           30.30.1.2            -------       Vlan20
TOTAL:  3 Record(s) Found.
Table 2-2 Description of the command information on display
NO
Number
I/O-LABEL
Incoming/Outgoing label. VPN labels (labels advertised with VPNV4 routes) will be displayed in case of uni-hop EBGP cross-AS MPLS L3 VPN networking, and tunneling labels (labels advertised with unicast routes and labels advertised by LDP protocol) will be displayed in case of multi-hop EBGP cross-AS MPLS L3 VPN networking.
NEXTHOP
Next hop
IN-INTERFACE
Ingress interface
OUT-INTERFACE
Egress interface
# Display MPLS L3VPN ingress lsp information on PE (Provider Edge).
<H3C> display mpls l3vpn-lsp ingress
                 LSP Information: L3vpn Ingress Lsp
Vpn-instance Name: vpna     Route Distinguisher: 100:1
NO    FEC                 NEXTHOP      OUTER-LABEL OUT-INTERFACE
1     168.3.1.0/24        10.10.1.1       1026(vpn)    Vlan10
Table 2-3 Description of command information on display
NO
Number
FEC
Forwarding equivalent class
NEXTHOP
Next hop
OUTER-LABEL
Outer label (MPLS Tunneling Label)
OUT-INTERFACE
Egress interface
# Display MPLS L3VPN egress lsp information on PE
<H3C> display mpls l3vpn-lsp egress
                 LSP Information: L3vpn Egress Lsp
NO    VRFNAME             INNER-LABEL   NEXTHOP         OUT-INTERFACE
1        vpna              4096         0.0.0.0           InLoop0
Table 2-4 Description of command information on display
NO
Number
VRFNAME
Name of VPN Instance
INNER-LABEL
Inner label (VPN label)
NEXTHOP
Next hop
OUT-INTERFACE
Egress interface
display rip vpn-instance vpn-instance-name
View
Parameter
vpn-instance vpn-instance-name: Specifies a VPN instance name.
Use the display rip vpn-instance command to view the configuration related to VPN instance of RIP.
Example
# View the specified VPN instance configuration of RIP.
<H3C> disp rip vpn vpn1
  RIP is running
  private net VPN-Instance: vpn1
    Checkzero is on         Default cost : 1
    Summary is on           Preference : 100
    Period update timer : 30
    Timeout timer : 180
    Garbage-collection timer : 120
    No peer router
    Network :
    192.168.0.0
2.1.13  domain-id
domain-id { id-number | id-addr }
undo domain-id
View
OSPF protocol view
Parameter
id-number: Domain-id for a VPN instance, an integer in the range of 0 to 4294967295. By default, it is 0.
id-addr: IP address format of Domain-id for a VPN instance. By default, it is 0.0.0.0.
Use the domain-id command to specify Domain-id for a VPN instance.
Use the undo domain-id command to restore the default Domain-id.
For standard BGP/OSPF interoperability, when BGP routes are imported to OSPF at PE, their original OSPF attributes cannot be restored. As these BGP VPN IP routes are issued to CE as ASE LSA (type-5 LSA), OSPF cannot distinguish them from the routes imported from other route domains. In order to distinguish external routes from OSPF internal routes, it is required to restore the attributes of BGP routes when they are imported to OSPF at the remote end. To achieve this goal, we can configure a Domain-id for each OSPF domain. A Domain-id is attached to a BGP/VPN route when an OSPF route is imported into BGP/VPN for transmission over BGP/VPN routes. Then when BGP routes are imported to the peer PE, LAS values are filled in according to the extended community attributes. If the received BGP VPN IP routes have the same Domain-id, they are from the same VPN instance route.
By default, Domain-id is 0.
  Caution:
The specified Domain-id will not take effect until the reset ospf command is executed.
Example
# Set Domain-id 100 to OSPF process 100.
[H3C-ospf-100] domain-id 100
[H3C-ospf-100] domain-id 0.0.0.100
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol ]
undo filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol ]
View
VPNv4 subaddress family view, VPN instance subaddress family view
Parameter
acl-number: ACL number, ranging from 2000 to 3999, matching the destination address of routing.
ip-prefix-name: Name of IP prefix to match the destination of routing information.
protocol: Specifies the routing protocol whose routing information will be filtered. You can specify one of the following protocols: direct, static, isis, ospf, ospf-ase, ospf-nssa, or rip. If you specify ospf, ospf-ase, or ospf-nssa, the OSPF process ID is needed.
Use the filter-policy export command to configure to filter routing information redistribute by a certain protocol. Only the filtered routing information can be advertised. Use the undo filter-policy export command to cancel the configuration.
By default, the redistribute routing will not be filtered.
Related command: filter-policy import.
Example
# Define that only the routes that can pass the filtering of ACL 3 can be received by BGP.
[H3C-bgp-af-vpn-instance] filter-policy 3 export
filter-policy [ ip-prefix ip-prefix-name ] gateway ip-prefix-name import
undo filter-policy [ ip-prefix ip-prefix-name ] gateway ip-prefix-name import
filter-policy { acl-number | ip-prefix ip-prefix-name } import
undo filter-policy { acl-number | ip-prefix ip-prefix-name } import
View
Parameter
acl-number: ACL number, ranging from 2000 to 3999 to match the destination address of routing.
ip-prefix ip-prefix-name: Name of IP prefix list to match destination of routing.
gateway ip-prefix-name: Name of the IP prefix list for the neighboring routers whose routing information will be filtered.
Use the filter-policy gateway import command to filter the information imported from specified routers.
Use the undo filter-policy gateway import command to cancel the setting.
Use the filter-policy import command to set the filtering conditions to filter routing information.
Use the undo filter-policy import command to cancel the setting on filtering conditions.
By default, no filtering is performed to the received information.
Related command: filter-policy export.
Example
# Define a filtering rule for receiving routing information: Only the routing information matching the IP prefix ACL P1 can it be received by VPN.
[H3C-bgp-af-vpn-instance] filter-policy ip-prefix p1 import
2.1.16  group
syntax
group group-name [ internal | external ]
undo group group-name
View
Parameter
group-name: Name of a neighbor peer group. It can be expressed in string of letters and numbers from 1 to 47 in length.
internal: Creates an internal peer group.
external: Creates an external peer group including other sub-AS groups in federation.
Use the group command to create a BGP peer group in VPN-instance.
Use the undo group command to delete a specified BGP peer group.
By default, the MP-IBGP peer is created.
Members in one peer group must have the same routing export policy as the group does, but can have different ingress policies.
Example
# Create an MP-EBGP peer group named test.
[H3C-bgp-af-vpn-instance] group test external
if-match mpls-label
undo if-match mpls-label
View
Route-policy view
Parameter
None
Use the if-match mpls-label command to configure the system to match only the public network routes that carries an MPLS label.
Use the undo if-match mpls-label command to cancel this configuration.
Related command: apply mpls-label.
Example
# Define an if-match clause to allow label-carrying routes to pass the filtering of this clause.
[H3C-route-policy] if-match mpls-label
if-match vpn-target { vpn-target | begin vpn-target count }
undo if-match vpn-target
View
route-policy view
Parameter
vpn-target: Route VPN-target attribute values used for matching, in ASN:nn or IP-address:nn format.
count: Number of the route VPN-target values used for matching, in the range of 2 to 65535.
Use the if-match vpn-target command to match the route's vpn-target attribute. The match for a route succeeds only when the route's vpn-target attribute is a subset of the configured values, otherwise, if the route has no vpn-target attribute or has at least one attribute value that is not in the configuration range, the match fails. The if-match vpn-target command applicable only to the PE devices on nested VPN network to limit VPNV4 routes with the VPN-Target attribute from the CE devices.
Use the undo if-match vpn-target command to cancel the configuration.
Use the if-match vpn-target vpn-target command to list up to 10 vpn-target attribute values to be matched.
Use the if-match vpn-target begin vpn-target count command to set the start value and the total number of the vpn-target values to be matched.
Example
# Define an if-match clause to match the following VPN-target attribute values: 100:1, 200:1, 300:1, 300:2 and 400:3.
[H3C-route-policy] if-match vpn-target 100:1 200:1 300:1 300:2 400:3
With the above configuration, if a route's attribute value is 100:1 300:1, the route will pass the matching; if the route's attribute value is 200:1 500:1, it will not pass the matching because 500:1 is not one of the attribute values that have been configured.
# Define an if-match clause to match ten VPN-target attribute values starting from 100:1, that is, 100:1 to 100:10.
[H3C-route-policy] if-match vpn-target begin 100:1 10
# Define an if-match clause to match five VPN-target attribute values starting from 1.1.1.1:65533, that is, 1.1.1.1:65533, 1.1.1.1:65534, 1.1.1.1:65535, 1.1.1.2:0, and 1.1.1.2:1.
[H3C-route-policy] if-match vpn-target begin 1.1.1.1:65533 5
2.1.19  import-route
syntax
import-route { { ospf | ospf-ase | ospf-nssa } [ process-id ] | direct | rip | static } [med value | route-policy route-policyname ]
undo import-route { { ospf | ospf-ase | ospf-nssa } [ process-id ] | direct | rip | static }
View
Parameter
process-id: OSPF process ID, ranging from 1 to 65535. By default, it is 1.
ospf: Imports only the ASE internal route discovered by the OSPF process process-id as the external route.
ospf-ase: Imports only the OSPF-ASE route discovered by OSPF process with process-id as the external route.
ospf-nssa: Imports only the OSPF-NSSA route discovered by OSPF process with process-id as the external route.
med value: Route cost value, ranging from 0 to 4294967295.
route-policyname: name of Route-policy, consisting of 1 to 19 characters
Use the import-route ospf command to enable to import OSPF route.
Use the undo import-route ospf command to disable to import OSPF route.
  Caution:
By default, the process ID is 1.
Example
# Enable to import an OSPF route with process ID 100.
[H3C]ip vpn-instance sphinx
[H3C-vpn-sphinx]route-distinguisher 168.168.55.1:85
[H3C-vpn-sphinx]quit
[H3C]bgp 352
[H3C-bgp]ip vpn-instance sphinx
[H3C-bgp-af-vpn-instance] import-route ospf 100
undo ip binding vpn-instance vpn-instance-name
View
VLAN interface view
Parameter
Use the ip binding vpn-instance command to bind a VLAN interface to a VPN-instance.
Use the undo ip binding vpn-instance command to delete the binding.
By default, global routing table is used.
You need to reconfigure the IP address for an interface since this command deletes the original IP address.
Example
# Bind the VLAN201 interface to the VPN-instance VPN 1.
[H3C-Vlan-interface201] ip binding vpn-instance vpn1
ip route-static vpn-instance vpn-instance-name [ vpn-instance-name ] … destination-ip-address { mask | mask-length } [ interface-name | vpn-instance vpn-nexthop-name ] nexthop-ip-address [ preference preference-value | public ] [ reject | blackhole ]
undo ip route-static vpn-instance vpn-instance-name [vpn-instance-name] … destination-ip-address { mask | mask-length } [ interface-name | vpn-instance vpn-nexthop-name ] nexthop-ip-address [ preference preference-value| public ] [ reject | blackhole ]
View
Parameter
vpn-instance-name: Name of VPN-instance. 6 names can be configured at most, and this value of character string is ranging from 1 to 19 characters.
destination-ip-address: Destination address of a static route.
mask: Subnet mask.
mask-length: Length of the mask, ranging to 0 to 32. As it requires consecutive 1s in a 32-bit mask, the mask in dotted decimal format can be substituted by mask-length (mask-length is represented by the number of consecutive 1s in the mask).
interface-name: Outgoing interface name of a static route. You can specify the interface of a public network or other VPN-instance as the outgoing-interface of the static route .NULL 0 shows the outgoing-interface is null.
vpn-nexthop-name: Specifies VPN-instance of the next hop for the static route.
nexthop-ip-address: Specifies IP address of the next hop for the static route.
preference-value: Specifies preference value, ranging from 1 to 255, By default it is 60.
public: Configures a route as public network route.
reject: Configures a route as unreachable.
blackhole: Configures a route as blackhole.
Use the ip route-static vpn-instance command to configure a static route by specifying an interface of a private network as a egress interface.
Use the undo ip route-static vpn-instance command to delete the configuration of this static route.
Example
# Configure a static route with destination address 100.1.1.1 and next hop address 1.1.1.2.
[H3C] ip route-static vpn-instance vpn1 100.1.1.1 16 vpn-instance vpn1 1.1.1.2
View
Parameter
Use the ip vpn-instance command to create a VPN instance and enter VPN instance view.
Use the undo ip vpn-instance command to delete the specified VPN instance.
By default, VPN-instance is not defined. Neither input nor output list is associated with VPN-instance. No Route-map is associated with VPN-instance.
Use the ip vpn-instance command to create a VPN-instance named vpn-name.
Example
# Create the VPN instance VPN 1.
[H3C] ip vpn-instance vpn1
[H3C-vpn-vpn1]
2.1.23  ipv4-family
BGP view, VPN-instance sub-address family view or VPNv4 sub-address family view:
ipv4-family { vpn-instance vpn-instance-name | vpnv4 [ unicast ] }
undo ipv4-family { vpn-instance vpn-instance-name | vpnv4 [ unicast ] }
RIP view:
ipv4-family [ unicast ] vpn-instance vpn-instance-name
undo ipv4-family [ unicast ] vpn-instance vpn-instance-name
View
BGP view, VPN-instance sub-address family view or VPNv4 sub-address family view, and RIP view.
Parameter
vpn-instance vpn-instance-name: Associates a specified VPN-instance with the MBGP address family. This parameter is used to enter MBGP VPN-instance subaddress family view.
vpnv4: Enters MBGP VPNv4 address family view.
unicast: Uses unicast sub–address family.
Use the ipv4-family vpn-instance command to enter MBGP VPN-instance subaddress family view.
Use the undo ipv4-family vpn-instance command to delete the association of a VPN-instance with MBGP address family, and return to BGP unicast view.
Use the ipv4-family vpnv4 command to enter MBGP VPNv4 subaddress family view. Use the undo ipv4-family vpnv4 command to delete the configuration of MBGP VPNv4 subaddress family view.
By default, unicast address is used when VPNv4 address family is configured.
By default, use the unicast address when configuring the MBGP address family.
Use this command to enter address family view and configure parameters related to BGP address family in this view.
Related command: peer enable.
Example
# Associate a specified VPN-instance with MBGP address family to enter MBGP VPN-instance subaddress family view. You must first configure VPN-instance before you perform that configuration.
[H3C] bgp 100
[H3C–bgp] ipv4-family vpn-instance abc
# Enter VPNv4 subaddress family view.
[H3C] bgp 100
[H3C-bgp] ipv4-family vpnv4 unicast
[H3C-bgp-af-vpn]
2.1.24  nesting-vpn
nesting-vpn
undo nesting-vpn
View
BGP-VPNv4 sub-address family view
Parameter
None
Use the nesting-vpn command to enable the nested VPN function.
Use the undo nesting-vpn command to disable this function.
By default, the nested VPN function is disabled.
If VPNv4 route advertisement is needed for a CE connected to a PE, the nested VPN function must be enabled on the PE.
Example
# Enable the nested VPN function.
[H3C-bgp-af-vpn] nesting-vpn
2.1.25  network
network ip-address [ address-mask ] [ route-policy policy-name ]
undo network ip-address [ address-mask ] [ route-policy policy-name ]
View
Parameter
ip-address: Network address advertised by BGP in dotted decimal format.
address-mask: Mask of the network address.
policy-name: Name of the routing policy applied to the advertised route.
Use the network command to configure the network route advertised to the outside by local BGP.
Use the undo network command to cancel the configuration.
By default, local BGP does not advertise any route to the outside.
Example
# Configure local router to advertise the routing with the destination network segment 10.0.0.0/16.
[H3C-bgp-af-vpn-instance] network 10.0.0.1 255.255.0.0
2.1.26  ospf
ospf process-id [ router-id router-id-number ] [ vpn-instance vpn-instance-name ]
undo ospf process-id
View
Parameter
process-id: OSPF Process ID. The default process ID is 1.
router-id-number: Router ID for an OSPF process. It is optional.
vpn-instance-name: VPN instance bound to an OSPF process.
Use the ospf command to enable an OSPF process.
Use the undo ospf command to disable an OSPF process.
After enabling an OSPF process, you can perform the configuration related to OSPF in the OSPF protocol view.
By default, OSPF protocol is not used in the system.
COMWARE Software supports multiple OSPF processes, so you can specify different process IDs to enable multiple OSPF processes on a router.
You are recommended to specify Route-id in a process using Router-id when enabling the OSPF process. If you want to enable multiple processes on a router, you are recommended to specify different Router IDs for different processes.
To enable an OSPF process belonging to a public network without a Router ID, the following conditions should be satisfied:
l           RM (Route Manage) is configured with a Router ID.
l           There is an interface that is configured with an IP address.
If you enable an OSPF process without specifying a Router ID, and the process is to be bound to a VPN instance, the VPN instance should have an interface that is configured with an IP address.
If you want to bind a process to a VPN instance, you must specify the VPN instance name.
One VPN instance may include several processes. For example, for VPN1, you can configure the commands OSPF 1 VPN-instance VPN1, OSPF2 VPN-instance VPN1, and OSPF3 VPN-instance VPN1. Accordingly, VPN instance VPN1 will include the OSPF processes 1, 2, and 3.
But one process belongs to one instance only. If you have configured OSPF 1 VPN-instance VPN1, you cannot configure OSPF 1 VPN-instance VPN2. Otherwise, the system prompts: “Wrong configuration. Process 1 has been bound to VPN-instance VPN-instance 1”. If you configure OSPF 1 first and then OSPF 1 VPN-instance VPN1, the system prompts: “Wrong configuration. Process 1 has been running in public domain”.
If you configure OSPF 1 VPN-instance VPN1 first and then OSPF 1, the system enters OSPF 1 VPN-instance VPN1 mode. That is, the commands OSPF 1 and OSPF 1 VPN-instance VPN1 are equivalent.
When an OSPF process is bound to a VPN instance, the default OSPF router is PE router. After executing the display OSPF process-id brief command, you will view the information: “PE router, connected to VPN backbone”.
  Caution:
l      A router can run no more than 1024 OSPF processes, with up to 10 processes enabled in each VPN instance.
l      If you bind an OSPF process to a nonexistent VPN instance, the configuration for the command fails and display the errors: The specified VPN-Instance does not exist, or the VPN-Instance's Route-Distinguisher is not specified.
l      When a VPN instance is deleted, all the related OSPF processes will be deleted. For example, the VPN instance VPN 1 includes the OSPF processes 1, 2 and 3. If VPN instance VPN 1 is deleted, the OSPF processes 1, 2 and 3 will all be deleted at the same time.
Related command: network.
Example
# Enable OSPF protocol with the default process ID 1.
[H3C] router id 10.110.1.8
[H3C] ospf
# Enable OSPF protocol with the process ID 120.
[H3C] ospf 120
[H3C-ospf-120]
# Enable OSPF process with the process ID 100, specify its Route ID to 2.2.2.2, and bind it to VPN instance VPN1.
[H3C] ospf 100 router-id 2.2.2.2 vpn-instance vpn1
[H3C-ospf-100]
2.1.27  peer advertise-community
peer group-name advertise-community
undo peer group-name advertise-community
View
VPNv4 subaddress family view, VPN-instance sub-address family view
Parameter
group-name: Name of a neighbor peer group, consisting of 1 to 47 alphanumeric characters.
Use the peer advertise-community command to configure to transmit the community attributes to a specified peer group.
Use the undo peer advertise-community command to cancel this configuration.
By default, the BGP advertiser does not transmit the community attributes to peer group.
Related command: if-match community-list and apply community.
Example
# Transmit the community attributes to the peer group test.
[H3C-bgp-af-vpn] peer test advertise-community
2.1.28  peer allow-as-loop
peer { group-name | peer-address } allow-as-loop [asn-limit]
undo peer { group-name | peer-address } allow-as-loop
View
Parameter
group-name: Name of a peer group, consisting of 1 to 47 alphanumeric characters.
peer-address: IP address of a specified peer.
asn-limit: Maximum times for which autonomous system (AS) number is allowed to receive in route updates.
Use the peer allow-as-loop command to allow loop in the route updates in the Hub & Spoke networking mode.
Use the undo peer allow-as-loop command to prohibit loop in the route updates.
By default, loop is prohibited in the received routing updates; by using the peer allow-as-loop command, loop is allowed in the received routing updates. The default value of asn-limit argument is 3.
Standard BGP tests loop using AS number. However, on a Hub & Spoke network running EBGP between PE and CE, PE carries its own AS number when advertising route information to CE. Accordingly, the updated route information will contain PE’s AS number when it is sent from CE. In this case, PE will not accept the route updates.
You can avoid this by using the peer allow-as-loop command, which makes PE router allow the route updates from CE to contain its AS number. You can define asn-imit to control the maximum times for which AS number is received by PE.
Example
# Enable route loop.
[H3C-bgp-af-vpn] peer 1.1.1.1 allow-as-loop 1
2.1.29  peer as-number
peer { group-name | [ peer-address group group-name ] }as-number as-number
undo peer { group-name | [ peer-address group group-name ] }as-number as-number
View
Parameter
peer-address: IP address of peer group.
as-number: Opposite AS number of a peer (group).
Use the peer as-number command to configure the opposite AS number of a specified peer (group).
Use the undo peer as-number command to remove the opposite AS number of a specified peer (group).
By default, the opposite end of a peer (group) has no AS number.
Example
# Set the opposite AS number of a specified peer (group) to 100.
[H3C-bgp] ipv4-family vpn-instance test
[H3C-bgp-af-vpn-instance] peer test as-number 100
2.1.30  peer as-path-acl export
peer group-name as-path-acl acl-number export
undo peer group-name as-path-acl acl-number export
View
Parameter
acl-number: AS regular expression ACL number, ranging 1 to 199.
Use the peer as-path-acl export command to apply the routing filtering policy based on AS path list to the advertised routing information.
Use the undo peer as-path-acl export command to cancel the configuration.
By default, there is no filtering policy based on AS path list.
You can only use the peer as-path-acl export command in the peer group.
Related command: peer as-path-acl import.
Example
# Configure the test peer group to filter the advertised routing information with the AS path ACL 3.
[H3C-bgp-af-vpn] peer test as-path-acl 3 export
2.1.31  peer as-path-acl import
peer { group-name | peer-address } as-path-acl acl-number import
undo peer { group-name | peer-address } as-path-acl acl-number import
View
Parameter
peer-address: IP address of the peer group in dotted decimal format.
import: Filters the received routes with AS path list.
Use the peer as-path-acl import command to configure peers from filter received routing information with routing filtering policy based on AS path list.
Use the undo peer as-path-acl import command to cancel the configuration.
The incoming filtering policy applied to peers takes precedence over the configuration to peer groups.
Example
# Configure the test peer group to filter the received routes with AS path ACL 3.
[H3C-bgp-af-vpn] peer test as-path-acl 3 import
2.1.32  peer connect-interface
peer { group-name | ip-address } connect-interface { interface-type interface_num }
undo peer { group-name | ip-address } connect-interface
View
Parameter
ip-address: Peer IP address.
Use the peer connect-interface command to configure to allow the internal BGP session to use any operable interface for a TCP connection.
Use the undo peer connect-interface command to restore the optimum local address for a TCP connection.
By default, BGP uses the optimum local address to implement a TCP connection.
Generally, BGP uses the optimum local address to implement a TCP connection. In order to make the TCP connection valid even when the interface fails, you can configure to allow the internal BGP session to use any operable interface for the TCP connection. Usually, Loopback interface is used.
Example
# Allow the internal BGP session to use any operable interface for a TCP connection.
[H3C-bgp-af-vpn-instance] peer 1.1.1.1 connect-interface loopback 0
2.1.33  peer default-route-advertise
peer group-name default-route-advertise
undo peer group-name default-route-advertise
View
Parameter
Use the peer default-route-advertise command to enable a peer (group) to transmit a default route.
Use the undo peer default-route-advertise command to remove the existing configuration.
By default, a peer (group) does not transmit a default route.
This command does not require any default route in the routing table but transmits a default route whose next hop address is itself to the peer unconditionally.
Example
# Enable the peer group test to transmit a default route.
[H3C-bgp] ipv4-family vpn-instance a
[H3C-bgp-af-vpn-instance] peer test default-route-advertise
2.1.34  peer default-route-advertise vpn-instance
peer ip-address default-route-advertise vpn-instance vpn-instance name
undo peer ip-address default-route-advertise vpn-instance vpn-instance name
View
Parameter
vpn-instance name: Name of the created VPN instance.
Use the peer default-route-advertise vpn-instance command to enable a peer to import a default route.
Use the undo peer default-route-advertise vpn-instance to restore the configuration.
By default, a peer does not import a default route.
Example
# Enable the peer test to import a default route.
[H3C-bgp-af-vpn] peer 10.1.1.1 default-route-advertise vpn-instance test
2.1.35  peer description
peer { group-name | peer-address } description description-line
undo peer { group-name | peer-address } description
View
Parameter
peer-address: Peer IP address, in dotted decimal format.
description-line: Description of the configuration, up to 79 characters in length.
Use the peer description command to set the description of a peer (group).
Use the undo peer description command to delete the description.
By default, there is no description for a peer (group).
The peer description is independent of the peer's group description.
Related command: display bgp peer verbose and display bgp group.
Example
# Set description of the peer group group1 to be city 1.
[H3C-bgp-af-vpn-instance] peer group1 description city1
2.1.36  peer ebgp-max-hop
peer group-name ebgp-max-hop [ ttl ]
undo peer group-name ebgp-max-hop
View
Parameter
peer-address: Peer IP address.
ttl: The maximum hops, in the rang of 1 to 255 and is 64 by default.
Use the peer ebgp-max-hop command to enable to establish an EBGP connection with a specified neighbor which is attached to the network indirectly.
Use the undo peer ebgp-max-hop command to restore the default setting.
By default, you can only make a connection with a direct accessing EBGP neighbor.
Example
# Enable the router to connect the EBGP peer group test that is attached to the network indirectly.
[H3C-bgp-af-vpn-instance] peer test ebgp-max-hop
2.1.37  peer enable
peer group-name enable
undo peer group-name enable
View
Parameter
Use the peer enable command to enable a specified peer group.
Use the undo peer enable command to disable a specified peer group.
For IPv4 address family, address switching is enabled by default.
Example
# Enable the peer group 168.
[H3C-bgp-af-vpn] peer 168 enable
2.1.38  peer filter-policy export
peer group-name filter-policy acl-number export
undo peer group-name filter-policy acl-number export
View
Parameter
acl-number: IP ACL number ranging from 2000 to 3999. That is, you can use basic ACL or advanced ACL.
export: Uses the filtering policy for the advertised route and this policy is only effective for peer groups.
Use the peer filter-policy export command to apply the ACL-based filtering policy to the advertised route for the peer group.
Use the undo peer filter-policy export command to cancel the configuration.
By default, there is no ACL-based filtering policy.
You can only use the peer filter-policy export command to configure peer group.
Related command: ip as-path-acl, peer as-path-acl and peer filter-policy export.
Example
# Configure the test peer group to filter the advertised route with ACL 3000.
[H3C-bgp-af-vpn] peer test filter-policy 3000 export
2.1.39  peer filter-policy import
peer { group-name | peer-address } filter-policy acl-number import
undo peer { group-name | peer-address } filter-policy acl-number import
View
Parameter
acl-number: IP ACL number from 2000 to 3999, that is, you can use basic or advanced ACL.
import: Performs the filtering policy on the received routes.
Use the peer filter-policy import command to apply the ACL-based filtering policy to the received routing information for peers.
Use the undo peer filter-policy import command to cancel the application.
Related command: ip as-path-acl and peer as-path-acl.
The incoming filtering policy configured for peers take precedence over the configuration for peer groups.
Example
# Configure the test peer group to filter the received route with ACL 3000.
[H3C-bgp-af-vpn] peer test filter-policy 3000 import
2.1.40  peer group
peer peer-address group group-name [ as-number as-number ]
undo peer peer-address
View
Parameter
peer-address: Peer IP address in dotted decimal format.
as-number: Peer AS number in the range of 1 to 65535. This parameter is only effective in the BGP view and VPN-instance subaddress family view.
Use the peer group command to add a peer to an existing peer group.
Use the undo peer command to delete a specified peer from the group.
In BGP view and VPN-instance subaddress family view, when adding a peer to an external group out of an AS, you need to specify an AS number. When adding a peer to an internal group or an external group in an AS, the AS number is not needed.
A peer must have been added in a group in BGP view before it can be added to another group in multicast subaddress family view or VPNv4 subaddress family view.
In different address families, one peer can be in different groups and one group may have different peers.
Example
# Add the peer with IP address 10.1.1.1 to the peer group test. In this example, the peer group is IBGP peer by default, thus you need not to specify the AS number when adding peers.
[H3C-bgp-af-vpn] peer 10.1.1.1 group test
2.1.41  peer ip-prefix export
peer group-name ip-prefix prefixname export
undo peer group-name ip-prefix prefixname export
View
Parameter
prefixname: Name of prefix list, a string of one to 19 characters.
Use the peer ip-prefix export command to apply the routing filtering policy based on IP prefix list to advertised routing information for peer groups.
Use the undo peer ip-prefix export command to cancel the setting.
By default, the peer group does not perform the routing filtering policy.
you can only configure the peer ip-prefix export command to the peer group.
Related command: peer ip-prefix import.
Example
# Configure the peer group group1 to filter the advertised routing information with the IP prefix list list1.
[H3C-bgp-af-vpn] peer group1 ip-prefix list1 export
2.1.42  peer ip-prefix import
peer { group-name | peer-addess } ip-prefix prefixname import
undo peer { group-name | peer-addess } ip-prefix prefixname import
View
Parameter
prefixname: Name of the prefix list, a string of one to 19 characters.
Use the peer ip-prefix import command to apply the filtering policy based on IP prefix list to the advertised route for peer groups.
Use the undo peer ip-prefix import command to cancel the configuration.
By default, the peer dose not use the routing filtering policy.
Related command: peer ip-prefix export.
Example
# Configure the peer group group1 to filter the received route with the IP prefix list 1.
[H3C-bgp-af-vpn] peer group1 ip-prefix list1 import
2.1.43  peer label-route-capability
peer group-name label-route-capability
undo peer group-name label-route-capability
View
BGP view
Parameter
Use the peer label-route-capability command to enable a peer group to handle the label-carried IPv4 routes.
Use the undo peer label-route-capability command to disable a peer group from handling the label-carried IPv4 routes.
By default, a BGP peer group cannot handle label-carried IPv4 routes.
Example
# Enable IBGP peer group and EBGP peer group to handle the label-carried IPv4 routes.
[H3C-bgp] group ibgp internal
[H3C-bgp] peer ibgp label-route-capability
[H3C-bgp] group ebgp external
[H3C-bgp] peer ebgp label-route-capability
2.1.44  peer next-hop-local
peer group-name next-hop-local
undo peer group-name next-hop-local
View
Parameter
Use the peer next-hop-local command to cancel the processing of the next hop in the routes that BGP advertises to a peer group and configure to use its own address as the next-hop.
Use the undo peer next-hop-local command to cancel the existing setting.
Example
# Specify the current BGP address as the next-hop in its route advertising to a peer group.
[H3C-bgp-af-vpn] peer test next-hop-local
2.1.45  peer password
peer { group-name | peer-address } password { cipher | simple } password
undo peer { group-name | peer-address } password
View
Parameter
cipher: Displays the password in cipher text.
simple: Displays the password in plain text.
password: Password string. When you choose the cipher parameter and input the password in plain text, or you choose the simple parameter, the password is one to 16 characters in length. When you choose the cipher parameter, and input the password in cipher text, the password is to be 24 in length.
Use the peer password command to enable BGP to perform the MD5 authentication when making a TCP connection.
Use the undo peer password command to cancel this function.
By default, BGP does not perform the MD5 authentication when setting up a TCP connection.
When the MD5 authentication is enabled, both parties must have the same authentication mode and password, otherwise, no TCP connection can be established because the MD5 authentication cannot be passed.
A specified peer can perform the MD5 authentication only when the group to which the peer belongs is not set the authentication. Otherwise, the configuration of the peer group applies.
Example
# Assign MD5 authentication to a TCP connection between the local router 10.1.100.1 and the peer 10.1.100.2.
[H3C-bgp-af-vpn-instance] peer 10.1.100.2 password simple test
# Perform a similar configuration to the remote end.
[H3C-bgp-af-vpn-instance] peer 10.1.100.1 password simple test
2.1.46  peer public-as-only
peer group-name public-as-only
undo peer group-name public-as-only
View
Parameter
Use the peer public-as-only command to configure BGP not to carry private AS numbers when transmitting update packets.
Use the undo peer public-as-only command to configure BGP to carry private AS numbers when transmitting update packets.
By default, private AS numbers are carried when BGP transmits update packets.
Generally, BGP carries AS number (either public or private AS number) when transmitting BGP update packets. BGP can be configured not to carry private AS number so that some egress routers may ignore private AS number when transmitting BGP update packets.
Example
# Send MBGP update packets without bearing private AS numbers.
[H3C-bgp-af-vpn] peer 168 public-as-only
2.1.47  peer reflect-client
peer group-name reflect-client
undo peer group-name reflect-client
View
Parameter
Use the peer reflect-client command to set a specified peer group to be a client of a router reflector.
Use the undo peer reflect-client command to cancel this setting.
By default, no router reflector exists in AS.
This configuration only applies to IBGP peer group.
Related command: reflect between-clients and reflect cluster-id.
Example
# Set the peer group test as a client of a router reflector.
[H3C-bgp-af-vpn] peer test reflect-client
2.1.48  peer route-policy export
peer group-name route-policy policy-name export
undo peer group-name route-policy policy-name export
View
Parameter
policy-name: Name of a routing policy.
Use the peer route-policy export command to apply the routing policy to peer group for advertised routing information.
Use the undo peer route-policy export command to cancel the configuration.
By default, there is no routing policy.
The peer route-policy export command is only used to configure peer groups.
Related command: peer route-policy import.
Example
# Apply the routing policy test-policy to the outgoing routes of the peer group test.
[H3C-bgp-af-vpn] peer test route-policy test-policy export
2.1.49  peer route-policy import
peer { group-name | peer-address } route-policy policy-name import
undo peer { group-name | peer-address } route-policy policy-name import
View
Parameter
policy-name: Name of the applied routing policy.
Use the peer route-policy import command to apply a routing policy to peer for received routing information.
Use the undo peer route-policy import command to delete the setting.
Related command: peer route-policy export.
Example
# Apply the routing policy test-policy to the incoming routes of the peer group test.
[H3C-bgp-af-vpn] peer test route-policy test-policy import
2.1.50  peer route-update-interval
peer group-name route-update-interval seconds
undo peer group-name route-update-interval
View
Parameter
seconds: Update interval in seconds, ranging from 0 to 600.
Use the peer route-update-interval command to set the Update interval for peers.
Use the undo peer route-update-interval command to restore the default setting.
By default, the Update interval is 5 seconds for IBGP peer group, and for EBGP it is 30 seconds.
Example
# Set the minimum interval for sending routing update packet to the BGP peer group group1 to be 10 seconds.
[H3C-bgp-af-vpn-instance] peer group1 route-update-interval 10
2.1.51  peer timer
peer { group-name | peer-address } timer keep-alive keepalive-interval hold holdtime-interval
undo peer { group-name | peer-address } timer
View
Parameter
keepalive-interval: Interval of sending the Keepalive message. It is in seconds, ranging from 1 to 65535, and with the default value 60.
holdtime-interval: Holdtime, ranging from 3 to 65535 in seconds, and with the default value 180 seconds.
Use the peer timer command to set the Keepalive interval and holdtime for peers.
Use the undo peer timer command to restore the default setting.
The timer set with the peer timer command enjoys higher precedence than the timer with the timer command.
Related command: timer keep-alive hold.
Example
# Set the Keepalive interval and holdtime for the peer group test.
[H3C-bgp-af-vpn-instance] peer test timer keep-alive 60 hold 180
2.1.52  peer upe
peer peer-address upe
undo peer peer-address upe
View
Parameter
Use the peer upe command to configure BGP peer as the UPE of hierarchical BGP/MPLS VPN.
Use the undo peer upe command to delete this configuration.
Example
# Configure BGP peer as the UPE of hierarchical BGP/MPLS VPN.
[H3C-bgp-af-vpn] peer 1.1.1.1 upe
2.1.53  peer vpn-instance enable
peer group-name vpn-instance vpn-instance-name enable
undo peer group-name vpn-instance vpn-instance-name enable
View
Parameter
group-name: Name of a peer group.
vpn-instance-name: Name of the VPN instance the CE peer belongs to.
enable: Enable VPNv4 function for the CE.
Use the peer vpn-instance enable command to enable the VPNv4 function for the BGP peer group of a CE.
Use the undo peer vpn-instance enable command to disable the function.
By default, the VPNv4 function is disabled.
Example
# Enable the VPNv4 function for the peer group of a CE.
[H3C-bgp] ipv4-family vpn-instance vrf1
[H3C-bgp-af-vpn-instance] group ebgp external
[H3C-bgp-af-vpn-instance] quit
[H3C-bgp-af-vpn] peer ebgp vpn-instance vrf1 enable
2.1.54  peer vpn-instance group
peer peer-address vpn-instance vpn-instance-name group group-name
undo peer peer-address vpn-instance vpn-instance-name
View
Parameter
peer-address: IP address of a peer, in dotted decimal notation.
Use the peer vpn-instance group command to join a CE neighbor into a BGP peer group.
Use the undo peer vpn-instance group command to clear the CE neighbor from the BGP peer group.
By default, a CE neighbor does not belong to any peer group.
Example
# Join a CE neighbor into a peer group.
[H3C-bgp-af-vpn-instance] peer 1.1.1.1 group ebgp as-number 600
[H3C-bgp-af-vpn] peer 1.1.1.1 vpn-instance vrf1 group ebgp
2.1.55  peer vpn-instance route-policy import
peer { peer-address | group-name } vpn-instance vpn-instance-name route-policy policy-name import
undo peer { peer-address | group-name } vpn-instance vpn-instance-name route-policy policy-name import
View
Parameter
peer-address: IP address of a peer, in dotted decimal.
policy-name: Name of the routing policy to be applied.
Use the peer vpn-instance route-policy import command to configure the routing policy applied by the CE peer to VPNv4 routes it received.
Use the undo peer vpn-instance route-policy import command to cancel the configuration.
By default, no routing policy is configured.
The ingress routing policy configured for a peer takes precedence over the configuration for the peer group.
Example
# Configure the peer group ebgp to apply the routing policy named comtest to the ingress routes.
[H3C-bgp-af-vpn] peer ebgp vpn-instance vrf1 route-policy comtest import
2.1.56  peer vpn-instance substitute-as
peer group-name vpn-instance vpn-instance-name substitute-as
undo peer group-name vpn-instance vpn-instance-name substitute-as
View
Parameter
Use the peer vpn-instance substitute-as command to enable the BGP AS number substitution on the PE.
Use the undo peer vpn-instance substitute-as command to disable the function.
By default, the BGP AS number substitution function is disabled.
After this function is enabled, when the PE advertises the specified peer the route information and the routed AS path has the same AS number as that of the peer, the AS number in the AS path will be replaced by the AS number of the PE before being advertised.
These commands take effect once being executed.
Example
# Enable the BGP AS number substitution for the peer group 20.
[H3C-bgp-af-vpn] peer 20 vpn-instance vrf1 substitute-as
2.1.57  policy vpn-target
policy vpn-target
undo policy vpn-target
View
BGP-VPNv4 subaddress family view
Parameter
None
Use the policy vpn-target command to configure to filter the VPN-target extended community attributes of received routing information.
Use the undo policy vpn-target command to cancel the setting.
By default, the filtering of VPN-target extended community attribute is conducted.
Example
# Filter the VPN-target extended community attributes of the received routing information.
[H3C-bgp-af-vpn] policy vpn-target
2.1.58  port trunk mpls vlan
port trunk mpls vlan from vlan-id [ to ] vlanid
undo port trunk mpls
View
Ethernet port view
vlan-id: The vlan-id range of MPLS/VPN VLANs allowed to the port. The value ranges from vlan-id to vlan-id+1023.
Use the port trunk mpls vlan command to set the vlan-id range of MPLS/VPN VLANs allowed to pass the port. The port trunk mpls vlan command is only applicable to fast Ethernet ports of cards with the suffix of C.
Use the undo port trunk mpls command to restore the default value of vlan-id. The default value is 0.
By default, the range of MPLS/VPN VLANs is from 0 to 1023 and the range of vlan-id is from 1 to 3071. The command must be executed on a Trunk port. MPLS/VPN enabled VLANs and VLANs out of the configured range are excluded (By default, the Trunk port contains VLAN1, so it is not judged).
Example
# Configure the start vlan-id of the Trunk fast Ethernet port 1.
<H3C>system-view
[H3C]interface Ethernet 3/1/1
[H3C-Ethernet2/1/1] port trunk mpls vlan 3071
2.1.59  preference
preference ebgp-preference ibgp-preference local-preference
undo preference
View
Parameter
ebgp-preference: Preference of the routes learned from the EBGP peer, in the range 1 to 256.
ibgp-preference: Preference of the routes learned from the IBGP peer, in the range 1 to 256.
local-preference: Preference of the Local routes, in the range 1 to 256.
Use the preference command to set preference value for a BGP route.
Use the undo preference command to remove the setting.
Example
# Set the preference of the preference of the routes learned from the EBGP peer to 2, the preference of the routes learned from the IBGP peer to 3 and the preference of the local routes to 4.
[H3C-bgp-af-vpn-instance] preference 2 3 4
2.1.60  reflect between-clients
undo reflect between-clients
View
Parameter
None
Use the reflect between-clients command to allow the routing reflection between clients.
Use the undo reflect between-clients command to forbid routing reflection between clients (PE to PE).
By default, the routing reflection between clients is allowed.
The router reflector reflects one client’s route to others after configuration.
Related command: reflect cluster-id and peer reflect-client.
Example
# Disable the routing reflection from client to client.
[H3C-bgp-af-vpn] undo reflect between-clients
2.1.61  reflector cluster-id
reflector cluster-id { cluster-id | address }
undo reflect cluster-id
View
Parameter
cluster-id: Router reflector cluster ID in number format, in the range of 1 to 4294967295.
address: Router reflector cluster ID in IP address format.
Use the reflector cluster-id command to configure a cluster ID of router reflector.
Use the undo reflector cluster-id command to delete the configuration.
By default, each router reflector uses his own ID as a cluster ID.
Usually, one cluster has one router reflector. And it is the router ID of the reflector to identify this cluster. Several router reflectors make the network more stable. If one cluster has several router reflectors, set the same cluster to all the reflectors ID with this command.
Related command: reflect between-clients and peer reflect-client.
Example
# The local router is one of the reflectors in the cluster and identifies this cluster with the cluster ID.
[H3C-bgp-af-vpn] reflect cluster-id 80
[H3C-bgp-af-vpn] peer 11.128.160.10 reflect-client
2.1.62  route-distinguisher
View
VPN-instance view
Parameter
route-distinguisher: Configures a VPN IPv4 prefix by adding an 8-byte value to a VPN IPv4 prefix.
Use the route-distinguisher command to configure RD for an MPLS VPN instance. A VPN-instance cannot run until it is configured with an RD.
A route distinguisher (RD) creates route and forwarding list for a VPN and specifies the default route identifier. Add an RD to the beginning of a specific IPv4 prefix to make it a globally unique VPN IPv4 prefix.
If an RD is associated with an autonomous system number (ASN), it is composed of the ASN and an arbitrary number; if the RD is associated with an IP address, it is a combination of the IP address and an arbitrary number.
RD has the following formats:
16-bit ASN (can be 0 here): A custom 32-bit number, for example, 101:3.
32-bit IP address (can be 0.0.0.0 here): A custom 16-bit number, for example, 192.168.122.15:1.
Example
# Configure RD for an MPLS VPN instance.
[H3C] ip vpn-instance vpn-instance_blue
[H3C-vpn-vpn-instance_blue] route-distinguisher 100:3
[H3C] ip vpn-instance vpn-instance_red
[H3C-vpn-vpn-instance_red] route-distinguisher 173.13.0.12:200
2.1.63  route-tag
route-tag tag-number
undo route-tag
View
OSPF protocol view
Parameter
tag-number: Tag value to identify VPN import route, in the range of 0 to 4294967295. By default, its first two bytes are fixed to 0xD000, while the last two bytes are the ASN of local BGP. For example, if the local BGP ASN is 100, then the default tag value in decimal is 3489661028. The value is an integer from 0 to 4294967295.
Use the route-tag command to specify a tag value to identify VPN import route.
Use the undo route-tag command to restore the default value.
If a VPN Site is linked to multiple PEs, when a route learned from MPLS/BGP is advertised by a PE router via its type-5 or type-7 LSA to the VPN Site, the route may be received by another PE router. This will result in routing loop. To avoid routing loop, you should configure Route-tag and you are recommended to configure the same route-tag for the PEs in the same VPN domain. The Route-tag is included in the type-5/-7 LSA. It is not transmitted in the extended community attributes of BGP, and thus it is limited in the local area. Therefore, it can only be configured and function on the PE router which receives BGP routes and generates OSPF LSA.
Configure Route-tag in OSPF protocol view. Different processes can be configured with a same Route-tag. You can configure the same Route-tag using different commands, but they are different in priority.
l           Those configured with the import-route command are of the highest priority.
l           Those configured with the route-tag command are in the second place in terms of priority.
l           Those configure with the default tag command are of the lowest priority.
If the Tag included in the type-5/-7 LSA is identical with its existing Tag, the LSA received will be neglected in route calculation.
  Caution:
The Route-tag configured will not be validated until the reset ospf command is executed.
Related command: import-route and default.
Example
# Configure Route-tag 100 to OSPF process 100.
[H3C-ospf-100] route-tag 100
  OSPF: Process 100's route tag has been changed
  OSPF: Reboot the system or use the 'reset ospf ID' command for this to take
        effect
2.1.64  timer
undo timer
View
Parameter
keepalive-interval: Time interval to send Keepalive messages, in seconds and ranging 1 to 65535. It defaults to 60 seconds.
holdtime-interval: Hold time, in seconds and ranging 3 to 65535. It defaults to 180 seconds.
Use the timer command to specify the time interval and hold time for sending Keepalive messages.
Use the undo timer command to restore the default value.
The timer defined with the peer timer command takes preference over that with the timer command.
Related command: peer timer.
Example
# Set the time interval and hold time for sending Keepalive messages.
[H3C-bgp-af-vpn-instance] timer keep-alive 60 hold 180
2.1.65  traffic-redirect
traffic-redirect inbound { link-group { acl-number | acl-name } [ rule rule [ system-index index ] ] | ip-group { acl-number | acl-name } [ rule rule [ system-index index ] ] } interface { interface-name | interface-type interface-number } destination-vlan l3-vpn
undo traffic-redirect inbound { link-group { acl-number | acl-name } [ rule rule ] | ip-group { acl-number | acl-name } [ rule rule ] }
View
Ethernet port view
Parameter
link-group { acl-number | acl-name } [ rule rule ]: Layer 2 ACL, acl-number is in the range of 4000 to 4999. acl-name is a string beginning with English letters (a to z and A to Z) with no spaces or quotation marks between. rule rule: Optional, ACL matching statement, in the range of 0 to 127. All matching statements will be selected if you skip this keyword.
ip-group { acl-number | acl-name } [ rule rule ]: Basic or advanced ACL. acl-number is in the range of 2000 to 3999. acl-name is a string beginning with English letters (a to z and A to Z) with no spaces or quotation marks between. rule rule: Optional, ACL matching statement, in the range of 0 to 127. All matching statements will be selected if you skip this keyword.
interface { interface-name | interface-type interface-number }: Redirect a packet to a specified Ethernet port. interface-type can be GigabitEthernet and Ethernet. interface-number suggests a complete port name with interface-type.
system-index index: Intra-system index of the rule, in the range of 0~4294967295. The system assigns automatically an index to it when delivering an ACL rule, for later retrieval. You can also assign a system index to it when delivering an ACL rule with this command. However, generally you are not recommended to do so.
Use the traffic-redirect command to redirect the data flow at the port of the EX card to the port of the MX card and make the port on the EX card act as an MPLS VPN CE side interface.
Use the undo traffic-redirect command to cancel this configuration.
Example
# Redirect the data flow at the Ethernet3/1/4 of the EX card to the MX card and set the port belong to VLAN 24.
[H3C-Ethernet3/1/4] traffic-redirect inbound ip-group 2000 rule 0 system-index 1 interface Ethernet5/1/4 24 l3-vpn
# Cancel the redirection configuration.
[H3C-Ethernet5/1/4] undo traffic-redirect inbound ip-group 2000 rule 0
2.1.66  routing-table limit
routing-table limit integer { alarm-integer | syslog-alert }
undo routing-table limit
View
VPN-instance view
Parameter
integer: The Maximum routes allowed for a VPN-instance, ranging from 1 to 65536.
alarm-integer: Route threshold for alarming.
syslog-alert: When the route maximum specified for a VPN-instance exceeds the threshold, routes can be added and only a SYSLOG error message is sent out.
Use the routing-table limit command to limit the route maximum in a VPN-instance.
Use the undo routing-table limit command to cancel the limitation.
It is necessary to enter a VPN-instance sub-view before using the routing-table command. Create a VPN-instance routing table in this view and allocate a route distinguisher (RD) in either of the following formats:
16-bit ASN: A 32-bit user-defined number, for example, 100:1.
32-bit IP address: A 16-bit user-defined number, for example, 172.1.1.1:1.
Create a VPN-target extended community for a VPN-instance and specify ingress or egress interface or both of them for the vpn-target command. These parameters can be used to configure ingress/egress routing information of the VPN-target extended community for a router.
Example
# Configure the maximum routes in VPN instance vpn1 to 1000.
[H3C-vpn-vpn1] route-distinguisher 100:1
[H3C-vpn-vpn1] vpn-target 100:1 import-extcommunity
[H3C-vpn-vpn1] routing-table limit 1000 syslog-alert
2.1.67  sham-link
sham-link source-addr destination-addr [ cost cost-value ] [ dead seconds ] [ hello seconds ] [ md5 keyid key seconds ] [ retransimit seconds ] [ simple passwor ] [ trans-delay seconds ]
undo sham-link source-addr destination-addr
View
OSPF area view
Parameter
source-addr: Source address of a Sham-link, a Loopback interface address with a 32-bit mask.
destination-addr: Destination address of a Sham-link, a Loopback interface address with a 32-bit mask.
cost-value: Cost at Sham-link, in the range of 1 to 65535. By default, it is 1.
password: Specifies authentication in plain text at the interface, 8 characters at most. It must be consistent with the authentication of a Sham-link peer.
keyid: Specifies the MD5 authentication identifier at the interface. The keyed is in the range of 1 to 255. It must be consistent with the authentication string of Sham-link peer.
key: Specifies the authentication at the interface. keyid is from 1 to 255 and key is a string up to 16 characters. It must be consistent with the authentication of a Sham-link peer. When the display current-configuration command is executed, the system displays the 24-character MD5 authentication in cipher text. You can also input a 24-character authentication in cipher text.
dead seconds: Specifies interval for the dead timer, in the range of 1 to 8192 seconds. By default, it is 40 seconds. It must be consistent with the value of dead seconds for a Sham-link peer router.
hello seconds: Specifies interval between Hello message transmission at the interface, in the range of 1 to 8192 seconds. By default, it is 10 seconds. It must be consistent with the value of hello seconds for a Sham-link peer router.
retransmit seconds: Specifies internal for LSA packet retransmission at the interface, in the range of 1 to 8192 seconds. By default, it is 5 seconds.
trans-delay seconds: Specifies delay period for LSA packet transmission at the interface, in the range of 1 to 8192 seconds. By default, it is 1 second.
Use the sham-link command to configure a Sham-link.
Use the undo sham-link command to delete a Sham-link.
In the OSPF PE-CE connection, suppose that in an OSPF area there are two sites which belong to the same VPN. They are connected to different PE routers and there is an intra-domain OSPF link (Backdoor) between them. Though there may be other routes connecting the two sites via PE routers, these routes are intra-domain routes, and OSPF will first select those routes through the Backdoor link. Sometimes, users desire to first select the routes through VPN Backbone. Hence it is required to establish Sham-links between PE routers. In this case, the routes through VPN Backbone are of the highest priority within the OSPF area.
If a Backdoor link (an OSPF link that does not pass the MPLS backbone) exists between two PE routers and you want the data to be transported over the MPLS backbone, you need to configure a Sham-link between the two PE routers. The sham link between VPN PE routers is taken as a link within the OSPF area. When configuring the Sham-link command, the optional parameters are not mutually exclusive. You can only choose in the undo command those parameters which are selected in the corresponding sham-link command.
  Caution:
l      The source and destination addresses of a sham link are both Loopback interface addresses with a 32-bit mask, which must be bound to a VPN instance and imported into BGP through a direct-connect route.
l      In an OSPF processes of VPN, the Loopback interface routes used by the Sham-link cannot be imported directly (so the import direct command cannot be used in the OSPF processes of VPN). OSPF can only advertise the route by importing a BGP route.
l      The source and destination addresses of a sham link cannot be the same.
l      The same sham link cannot be configured for different OSPF processes.
l      50 sham links can be configured for an OSPF process at most.
Example
# Configure a Sham-link, with its source address 1.1.1.1 and destination address 2.2.2.2.
[H3C-ospf-100-area-0.0.0.1] sham-link 1.1.1.1 2.2.2.2 cost 100
2.1.68  summary
summary
undo summary
View
Parameter
None
Use the summary command to enable BGP to perform auto summary to subnet routes.
Use the undo summary command to cancel this summary.
By default, BGP does not perform the auto summary to subnet routes.
After auto summary is enabled, BGP cannot receive the subnet routes imported from IGP. Using this feature, you can reduce the amount of routing information.
Example
# Perform auto summary to subnet routes.
[H3C-bgp-af-vpn-instance] summary
2.1.69  vpn-instance-capability simple
undo vpn-instance-capability
View
OSPF protocol view
Parameter
None
Use the vpn-instance-capability simple command to configure a router as Multi-VPN-Instance CE.
Use the undo vpn-instance-capability command to cancel the configuration.
OSPF multi-VPN-instance is often run at a PE router. So a CE router, on which OSPF multi-VPN-instance runs, is called Multi-VPN-Instance CE. Though they both support multi-VPN-instance, Multi-VPN-Instance CE does not necessarily support BGP/OSPF interoperability.
When an OSPF process is bound to a VPN instance, the default OSPF router is PE router. This command will remove the default setting and change a router into a Multi-VPN-Instance CE. . After the configuration, OSPF processes will reestablish all its neighbors. DN bits and Route-tag will not be checked in routing calculation. To prevent route loss, routing loop test is disabled on PE routes. MGP/OSPF interoperability is also disabled to save system resources.
After the display ospf brief command is executed successfully, the system prompts the information:
Multi-VPN-Instance enable on CE router.
  Caution:
OSPF processes will set up all its neighbors again after this command is executed.
Example
# Configure OSPF process 100 as Multi-VPN-Instance CE.
[H3C-ospf-100] vpn-instance-capability simple
# Restore the OSPF process 100 as PE.
[H3C-ospf-100] undo vpn-instance-capability
2.1.70  vpn-target
vpn-target vpn-target-ext-community [ import-extcommunity | export-extcommunity | both ]
undo vpn-target vpn-target-ext-community [ import-extcommunity | export-extcommunity | both ]
View
VPN-instance view
Parameter
import-extcommunity: Ingress route information from the extended community of target VPN.
export-extcommunity: Egress route information to the extended community of target VPN.
both: Imports both ingress and egress route information to the extended community of target VPN.
vpn-target-ext-community: Adds VPN-target extended community attributes to the ingress and egress of VPN-instance or the VPN-target extended community list of ingress and egress.
Use the vpn-target command to create a VPN-target extended community for VPN-instance.
Use the undo vpn-target command to remove the VPN-target extended community attributes.
By default, the default value is both.
Use the vpn-target command you can create ingress and egress route target extended community lists for a specified VPN-instance. Execute this command once for each target community. Import the received routing information bearing the specific VPN-target extended community to all VPN-instances, for which an extended community is configured as ingress VPN-target. VPN-target specifies a target VPN extended community. The same as RD, an extended community is either composed of an ASN and an arbitrary number, or composed of an IP address and an arbitrary number.
RD is in either of the following formats:
Example
# Create a VPN-target extended community for the VPN-instance.
[H3C-vpn-vpn-instance_blue] vpn-target 1000:1 both
[H3C-vpn-vpn-instance_blue] vpn-target 1000:2 export-extcommunity
[H3C-vpn-vpn-instance_blue] vpn-target 173.27.0.130:2 import-extcommunity
Chapter 3  MPLS L2VPN Configuration Commands
3.1  CCC Configuration Commands
3.1.1  ccc
ccc ccc-connection-name interface vlan-interface vlan-id { transmit-lsp transmit-lsp-name receive-lsp receive-lsp-name | out-interface outinterface-type outinterface-number }
undo ccc ccc-connection-name
View
Parameter
ccc-connection-name: Name of the CCC (circuit cross connect) connection, which is used to uniquely identify the CCC connection in the PE (provider edge). This argument is 1 to 20 characters in length.
vlan-id: ID of the VLAN whose interface is used to establish the connection. It must be the ID of an existing VLAN.
transmit-lsp-name: Name of transmitting LSP (the ingress LSP).
receive-lsp-name: Name of receiving LSP (the egress LSP).
outinterface-type outinterface-number: Name of the interface connecting to the second CE (custom edge).
Use the ccc ccc-connection-name interface vlan-interface vlan-id transmit-lsp receive-lsp command to create a remote CCC connection.
Use the ccc ccc-connection-name interface vlan-interface vlan-id out-interface command to create a local CCC connection.
Use the undo ccc command to remove a local/remote CCC connection.
When the interface is a VLAN interface, a CCC connection encapsulates data as Ethernet packets by default.
Example
# Create a remote CCC connection, with the name of clink, the transmitting LSP of tlsp, and the receiving LSP of rlsp.
[H3C] ccc clink interface vlan-interface 201 transmit-lsp tlsp receive-lsp rlsp
# Create a local CCC connection, with the name of clink, and the interfaces connecting to the two CEs being the interfaces of VLAN 201 and VLAN 301 respectively.
[H3C] ccc clink interface vlan-interface 201 out-interface interface vlan-interface 301
3.1.2  debugging mpls l2vpn
debugging mpls l2vpn { all | advertisement | error | event | connections [ interface vlan-interface vlan-id ] }
undo debugging mpls l2vpn { all | advertisement | error | event | connections [ interface vlan-interface vlan-id ] }
View
Parameter
all: Enables/Disables all types of L2VPN Debugging.
advertisement: Enables/Disables Debugging for L2VPN BGP/LDP advertisement messages.
error: Enables/Disables Debugging for L2VPN error messages.
event: Enables/Disables Debugging for L2VPN event messages.
connections: Enables/Disables Debugging for connection messages.
Use the debugging mpls l2vpn command to enable specific type of L2VPN debugging.
Use the undo debugging mpls l2vpn command to disable specific type of L2VPN debugging.
Example
# Enable all types of L2VPN Debugging.
<H3C> debugging mpls l2vpn all
3.1.3  display ccc
display ccc [ ccc-name | type [ local | remote ] ]
View
Parameter
ccc-name: Name of the CCC connection whose information is to be displayed.
type local: Displays information about the local CCC connections only.
type remote: Displays information about the remote CCC connections only.
Use the display ccc command to display the information about specified CCC connections.
Example
# Display information about the CCC connection named c-link.
<H3C> display ccc c-link
name: c-link, type: remote, state: down,
intf: Vlan-interface1003 (down), tran-lsp: ccc2 (up), rcv-lsp: ccc1 (up)
3.1.4  static-lsp egress l2vpn
static-lsp egress lsp-name l2vpn incoming-interface vlan-interface vlan-id in-label in-label
undo static-lsp egress lsp-name
View
MPLS view
Parameter
lsp-name: Name of the label switching path (LSP).
vlan-id: ID of the VLAN whose interface is to be used to create the LSP.
in-label-value: Value of the in-label, ranging from 16 to 1,023.
Use the static-lsp egress l2vpn command to create a static L2VPN LSP for the egress label switching router (LSR).
Use the undo static-lsp egress command to remove a L2VPN LSP created for the egress LSR.
You need to create two LSPs (for transmitting and receiving) before creating a remote CCC connection.
Related command: static-lsp ingress l2vpn, static-lsp transit l2vpn, debugging mpls.
Example
# Create a static LSP named bj-sh on the egress LSR.
[H3C-mpls] static-lsp egress bj-sh l2vpn incoming-interface vlan-interface 201 in-label 233
3.1.5  static-lsp ingress
static-lsp ingress lsp-name l2vpn nexthop next-hop-addr out-label out-label
undo static-lsp ingress lsp-name
View
MPLS view
Parameter
lsp-name: Name of the LSP.
next-hop-addr: Address of the next hop.
out-label: Value of the out-label, ranging from 16 to 1,023.
Use the static-lsp ingress l2vpn command to create a static L2VPN LSP for the ingress LSR.
Use the undo static-lsp command to remove a static L2VPN LSP.
Related command: static-lsp engress l2vpn, static-lsp transit, debugging mpls.
Example
# Create a static LSP with the destination IP address of 202.25.38.1 for the ingress LSR.
[H3C-mpls] static-lsp ingress bj-sh l2vpn nexthop 1.1.1.1 out-label 100
3.1.6  static-lsp transit l2vpn
static-lsp transit lsp-name l2vpn incoming-interface vlan-interface vlan-id in-label in-label nexthop next-hop-addr out-label out-label
undo static-lsp transit lsp-name
View
MPLS view
Parameter
in-label: Value of the in-label, ranging from 16 to 1,023.
Use the static-lsp transit command to create a static L2VPN LSP for the midway transmitting LSR.
Use the undo static-lsp transit command to remove the static L2VPN LSP created for the midway transmitting LSR.
You need to create two LSPs (for transmitting and receiving) before creating a remote CCC connection. You also need to enable the two LSPs to traverse through each of the midway LSRs.
Related command: static-lsp egress l2vpn, static-lsp ingress l2vpn.
Example
# Create a static L2VPN LSP for the interface of VLAN 201 on the midway transmitting LSR, with the in-label of 123 and the out-label of 253.
[H3C-mpls] static-lsp transit bj-sh l2vpn incoming-interface vlan-interface 201 in-label 123 nexthop 202.34.114.7 out-label 253
3.2  Martini MPLS L2VPN Configuration Commands
3.2.1  display mpls l2vc
display mpls l2vc [ interface vlan-interface vlan-id | verbose | block | peer | up | vsi ]
View
Parameter
vlan-id: ID of the VLAN whose interface is used to create the virtual circuit.
verbose: Displays the detailed information.
block: Displays only the VC information in Block state.
peer: Specifies Remote Peer.
up: Displays only the VC information in UP state.
vsi: Specifies VSI instance.
Use the display mpls l2vc command to display the information about the virtual circuit (VC) created using label distribution protocol (LDP).
Example
# Display the information about MPLS LDP connections.
<H3C> display mpls l2vc verbose
Interface: Vlan-interface1000State: down, Encapsulation: ethernet, Service: VLL
 VC-ID: 4294967295, VC State: down, Destination: 3.3.3.3
  Group ID: Local 0, Remote 0, VC Label: Local 32770, Remote 0,
  Tunnel Type: LSP, Tunnel Index: 25
Interface: Vlan-interface1001State: down, Encapsulation: ethernet, Service: VLL
 VC-ID: 10001, VC State: down, Destination: 1.1.1.1
  Group ID: Local 0, Remote 0, VC Label: Local 32771, Remote 0,
  Tunnel Type: LSP, Tunnel Index: 23
 VC-ID: 2, VC State: down, Destination: 1.1.0.3
  Group ID: Local 0, Remote 0, VC Label: Local 131072, Remote 0,
  Tunnel Type: ---, Tunnel Index: 0
 VC-ID: 2, VC State: down, Destination: 3.3.3.3
  Group ID: Local 0, Remote 0, VC Label: Local 131073, Remote 0,
 VC-ID: 2, VC State: up, Destination: 1.1.1.1
  Group ID: Local 0, Remote 0, VC Label: Local 134138, Remote 32773,
 VC-ID: 1, VC State: down, Destination: 1.1.1.1
  Group ID: Local 0, Remote 0, VC Label: Local 134142, Remote 0,
 VC-ID: 3, VC State: up, Destination: 3.3.3.3
  Group ID: Local 0, Remote 0, VC Label: Local 134137, Remote 131072,
 VC-ID: 3, VC State: down, Destination: 1.1.0.3
  Group ID: Local 0, Remote 0, VC Label: Local 131077, Remote 0,
 VC-ID: 3, VC State: up, Destination: 1.1.1.1
  Group ID: Local 0, Remote 0, VC Label: Local 134136, Remote 158987,
 VC-ID: 4, VC State: up, Destination: 1.1.1.1
  Group ID: Local 0, Remote 0, VC Label: Local 131075, Remote 131125,
 VC-ID: 4, VC State: up, Destination: 3.3.3.3
  Group ID: Local 0, Remote 0, VC Label: Local 131076, Remote 132956,
 VC-ID: 4, VC State: down, Destination: 1.1.0.3
  Group ID: Local 0, Remote 0, VC Label: Local 131081, Remote 0,
 VC-ID: 5, VC State: up, Destination: 1.1.1.1
  Group ID: Local 0, Remote 0, VC Label: Local 134139, Remote 131126,
 VC-ID: 5, VC State: up, Destination: 3.3.3.3
  Group ID: Local 0, Remote 0, VC Label: Local 131080, Remote 131075,
 VC-ID: 5, VC State: down, Destination: 1.1.0.3
  Group ID: Local 0, Remote 0, VC Label: Local 131084, Remote 0,
 VC-ID: 6, VC State: up, Destination: 1.1.1.1
  Group ID: Local 0, Remote 0, VC Label: Local 131074, Remote 131154,
 VC-ID: 6, VC State: up, Destination: 3.3.3.3
  Group ID: Local 0, Remote 0, VC Label: Local 131083, Remote 131077,
 VC-ID: 6, VC State: down, Destination: 1.1.0.3
  Group ID: Local 0, Remote 0, VC Label: Local 131087, Remote 0,
 VC-ID: 7, VC State: up, Destination: 1.1.1.1
  Group ID: Local 0, Remote 0, VC Label: Local 131078, Remote 131182,
 VC-ID: 7, VC State: up, Destination: 3.3.3.3
  Group ID: Local 0, Remote 0, VC Label: Local 131086, Remote 131079,
 VC-ID: 7, VC State: down, Destination: 1.1.0.3
  Group ID: Local 0, Remote 0, VC Label: Local 131090, Remote 0,
# Display the VC information when MPLS LDP goes up.
<H3C> display mpls l2vc up
Total l2vc : 12
 l2vc : 5 up
 l2vc : 5 block
 l2vc : 2 down
VSI name : vpn3 , Service: VPLS , Service Status : Open
VC-ID         Destination      State Lcl-Label/Rmt-Label Tunnel/Index
3             2.2.2.2          up       131072/134137       LSP/14
VSI name : vpn4 , Service: VPLS , Service Status : Open
4             2.2.2.2          up       132956/131076       LSP/14
VSI name : vpn5 , Service: VPLS , Service Status : Open
5             2.2.2.2          up       131075/131080       LSP/14
VSI name : vpn6 , Service: VPLS , Service Status : Open
6             2.2.2.2          up       131077/131083       LSP/14
VSI name : vpn7 , Service: VPLS , Service Status : Open
7             2.2.2.2          up       131079/131086       LSP/14
3.2.2  mpls l2vc
mpls l2vc ip-address vc-id
undo mpls l2vc
View
VLAN interface view
Parameter
ip-address: IP address of LSR-ID on the peer PE.
vc-id: ID of the VC, ranging from 1 to 4,294,967,295.
Use the mpls l2vc command to create a Martini MPLS L2VPN virtual connection.
Use the undo mpls l2vc command to remove a Martini MPLS L2VPN virtual connection.
You need to enable MPLS L2VPN before using the command.
Related command: mpls l2vpn, display mpls l2vc.
Example
# Create a virtual connection with the ID of 23.
[H3C-Vlan-interface201] mpls l2vc 10.0.0.11 23
3.3  Kompella MPLS L2VPN Configuration Commands
3.3.1  ce
ce name [ id id [ range range | default-offset offset ]
undo ce name
View
MPLS L2VPN view
Parameter
name: Name of the CE, which must be unique in the current VPN of the PE. This argument is 1 to 20 characters in length.
id: CE ID, which is used to uniquely identify a CE in the VPN. This argument ranges from 0 to 499.
offset: Specifies the default original CE offset.
range: CE Range, the maximum number of CEs that can be connected to the CE. This argument ranges from 1 to 500.
Use the ce command to create a CE or modify the CE Range.
Use the undo ce command to remove a CE.
The corresponding CE view is created when you create a CE. All the CE connections are configured in CE view.
For VPN capacity expansion, you can set the range argument to a value lager than the currently required number of CEs to be connected. However, this may result in the waste of tags as the system allocates tag blocks for CEs according to the value of the range argument. You can also change the CE Range to a larger number when expanding the VPN (if the previously set CE range is not large enough). For example, if the desired CE number is 20 after the expansion, but the current CE Range is 10, you can change the CE range to 20.
Related command: mpls l2vpn encapsulation, ccc.
Example
# Create a CE for VPNA named “beijing”, with the CE ID of 1. Use the default range (10).
[H3C] mpls l2vpn
[H3C] mpls l2vpn vpna encapsulation ethernet
[H3C-mpls-l2vpn-vpna] ce beijing id 1
[H3C-mpls-l2vpn-ce-vpna-beijing]
3.3.2  connection
connection [ ce-offset offset ] { interface vlan-interface vlan-id }
undo connection [ ce-offset offset ] { interface vlan-interface vlan-id }
View
MPLS L2VPN CE view
Parameter
offset: Specifies the ID of the remote CE of the L2VPN connection to create a remote CE connection.
Use the connection command to create a connection for the CE.
Use the undo connection command to remove the specified CE connection.
You need to configure the route distinguisher (RD) for the MPLS L2VPN before creating a CE connection.
Related command: mpls l2vpn encapsulation.
Example
# Create a CE connection.
[H3C-l2vpn-vpna] ce ce-a id 1 range 4
[H3C-l2vpn-vpna-ce-ce-a] connection interface vlan-interface 201
3.3.3  display bgp l2vpn
display bgp l2vpn { all | peer | route-distinguisher ASN }
View
Parameter
all: Displays all the L2VPN information about the address family.
peer: Displays the information about a specified BGP Peer in brief.
route-distinguisher: Displays the information about a specified VPN RD.
ASN: Route identifier.
Use the display bgp l2vpn command to display the information about Kompella L2VPN.
Example
# Display all the L2VPN information.
<H3C> display bgp l2vpn all
BGP local router ID is 172.16.1.5 ,   Origin codes: i - IGP, e - EGP, ? - incomplete
bgp.l2vpn: 3 destinations
CE ID    Label Offset        Label Base  nexthop     pref        as-path
Route Distinguisher: 100:1
2            1           800000      1.1.1.1     100     I   200 600
3            1           500000      1.1.1.1         100     I   200 600
Route Distinguisher: 100:2
1            1           700000      1.1.1.1     100     I   200 600
3.3.4  display mpls l2vpn
display mpls l2vpn [ vsi-name [ local-ce | remote-ce ] | connection [ vsi-name [ down | remote-ce | up | verbose ] | brief | interface Vlan-interface vlan-id ] | forwarding-info { vc-label | interface interface-type } ]
View
Parameter
vsi-name: Name of the VPN instance.
local-ce: Displays the state and configuration of the local CE of a specified VPN instance.
remote-ce: Displays the state and configuration of the remote CE of a specified VPN instance.
down: Displays the information about L2VPN whose CE interfaces are Down.
remote-ce: Displays the state and configuration of the remote CE.
up: Displays the information L2VPN whose CE interfaces are Up.
verbose: Displays detailed information about the CE interfaces.
brief: Displays the summary information about a specified connection.
Interface: Displays information about a specified CE interface.
vlan-id: ID of the VLAN whose interface is used to create the connection.
vc-label: VC label.
interface-type: Type of the interface, which can be Aux, Ethernet, LoopBack, M-Ethernet, NULL, Vlan-interface, GigabitEthernet; or 10-GigabitEthernet, Pos, and RPR.
Use the display mpls l2vpn command to display the MPLS L2VPN information. The command can display the state and configuration of the local/remote CE of a specified VPN instance, and the L2VPN information about a specified CE interface.
Example
# Display the L2VPN information about a specified interface.
[DEV-UP] dis mpls l2vpn forwarding-info 10241 interface Vlan-interface 300
VCLABEL  TUNNELTYPE   ENTRYTYPE   OUTINTERFACE   OUTSLOT    TOKEN       CTRLWORD
10241       LSP        SEND        Vlan-interface100   0          0           FA
LSE
   1   Record(s) Found.
[DEV-UP]dis mpls l2vpn connection interface Vlan-interface 300
conn-type: remote, local vc state: up, remote vc state: up,
     Local ce-id: 1, local ce name: ce1, remote ce-id: 2,
     intf(state,encap): Vlan-interface300(up,ethernet),
     peer id: 2.2.2.2, route-distinguisher: 100:1,
     local vc label: 10242, remote vc label: 10241,
     tunnel type: LSP, tunnel val: 0
3.3.5  l2vpn-family
l2vpn-family
undo l2vpn-family
View
BGP view
Parameter
None
Use the l2vpn-family command to create L2VPN address family view.
Use the undo l2vpn-family command to remove L2VPN address family view.
Example
# Create L2VPN address family view.
[H3C] bgp 100
[H3C-bgp] l2vpn-family
[H3C-bgp-af-l2vpn]
3.3.6  mpls l2vpn
mpls l2vpn
undo mpls l2vpn
View
Parameter
None
Use the mpls l2vpn command to enable L2VPN.
Use the undo mpls l2vpn command to disable L2VPN.
To execute the command, you need to enable MPLS first.
Related command: mpls, mpls lsr-id.
Example
# Configure LSR ID and enable MPLS.
[H3C] mpls lsr-id 10.0.0.1
[H3C] mpls
# Enable L2VPN.
[H3C] mpls l2vpn
3.3.7  mpls l2vpn encapsulation
mpls l2vpn vpn-name [ encapsulation { ethernet | vlan } ]
undo mpls l2vpn vpn-name
View
Parameter
vpn-name: Name of the VPN, which must be unique in the PE. This argument is 1 to 20 characters in length.
encapsulation: User access encapsulation type. Two types are supported currently: Ethernet access and VLAN access. The default encapsulation type is Ethernet.
Use the mpls l2vpn encapsulation command to create a Kompella MPLS L2VPN, specify the encapsulation type, and enter MPLS L2VPN view.
Use the undo mpls l2vpn command to remove a Kompella MPLS L2VPN.
Related command: ce, mtu.
&  Note:
You can create a Kompella MPLS L2VPN only after you enable MPLS L2VPN. All L2VPN parameters are configured in L2VPN view.
Example
# Create a Kompella MPLS L2VPN, with the name of test, the encapsulation type of Ethernet.
[H3C] mpls l2vpn test encapsulation ethernet
[H3C-mpls-l2vpn-test]
3.3.8  mtu
mtu mtu
View
MPLS L2VPN view
Parameter
mtu: Layer 2 MTU (maximum transmission unit) of the VPN. This argument ranges from 0 to 10,200 and the default value is 1,500.
Use the mtu command to set the MTU for the Kompella MPLS L2VPN.
The same MTU value must be configured for all the PE devices of the same VPN to make sure that the configuration is valid.
Example
# Set the MTU of the VPN named vpna to 1,000.
[H3C] mpls l2vpn vpna encapsulation vlan
[H3C-mpls-l2vpn-vpna] mtu 1000
3.3.9  peer enable
peer { group-name | peer-address } enable
undo peer { group-name | peer-address } enable
View
Parameter
group-name: Name of the peer group. This argument specifies the entire peer group.
peer-address: IP address of a peer. This argument specifies a specific peer.
Use the peer enable command to activate a specified peer or peer group in L2VPN address family view.
Use the undo peer enable command to deactivate a specified peer or peer group in L2VPN address family view.
By default, the unicast peers or peer groups of IPv4 address family are active. Whereas other types of peers or peer groups are inactive.
Example
# Activate peer 192 or peer group 192 in L2VPN address family view.
[H3C-bgp] group 192 internal
[H3C-bgp] peer 192.1.1.1 group 192
[H3C-bgp-af-l2vpn] peer 192 enable
