H3C S9500 Series Routing Switches Command Manual-(V1.01)
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Series Routing Switches Command Manual-(V1.01)
13-PoE Command
13-PoE Command 88 KB
Chapter 1  PoE Configuration Commands
1.1  PoE Configuration Commands
1.1.1  display poe interface
display poe interface { interface-name | interface-type interface-num }
View
Parameter
interface-name | interface-type interface-num: Port on the switch; refer to Command Manual – Port for details.
Use the display poe interface{ interface-name | interface-type interface-num } command to display the PoE status of a specific port on the switch.
Use the display poe interface command without any option to display the PoE status of all the PoE-capable ports on the switch.
Example
# Display the PoE status of the port GigabitEthernet3/1/1.
<H3C> display poe interface GigabitEthernet3/1/1
Port power status            :delivering
Port power mode              :signal
Port PD class                :2
port power priority          :high
Port max power               :16800 mW
Port current power           :552 mW
Port remaining power         :16248 mW
Port average power           :717 mW
Port peak power              :1196 mW
Port current                 :13 mA
Port voltage                 :53.7 V
Table 1-1 Description on the fields of the display poe interface command
Port power status
PoE status of the port:
1)        disabled: PoE is disabled on the port.
2)        searching: the port is searching for a PD.
3)        delivering: the port is supplying power to the PD.
4)        PD disconnected: the port is not connected with a PD.
5)        testing: the port is in testing.
6)        fault: the port detected an nonstandard or fault PD.
Port power mode
PoE mode of the port:
1)        auto: the system automatically selects the PoE mode.
2)        signal
3)        spare
Port PD class
The class of the power the port supplies to the PD
Port power priority
Port priority:
1)        critical (the highest)
2)        high
3)        low
Port max power
Maximum power on the port
Port current power
Present power on the port
Port average power
Average power on the port
Port peak power
Peak power on the port
Port current
Present current on the port
Port voltage
Present voltage on the port
Remaining power on the port
&  Note:
l      The sampling cycle of the power, current and voltage of ports is 1 second;
l      The sampling cycle of the peak power and average power of ports is 5 minutes
1.1.2  display poe interface power
display poe interface power { interface-name | interface-type interface-num }
View
Parameter
Use the display poe interface power command to display the PoE power information of a specific port or all ports on the switch.
Example
# Display the power information of the port GigabitEthernet3/1/1.
<H3C> display poe interface power GigabitEthernet3/1/1
Port power                   :700 mW
1.1.3  display poe pse
display poe pse
View
Parameter
None
Use the display poe pse command to display the parameters of all the PoE cards in the switch that serve as a power sourcing equipment (PSE).
Example
# Display the parameters of all the PoE cards in the switch.
<H3C> display poe pse
PSE Information of board 6:
  Power Current Value     :67 W
  Power Remaining Value   :738 W
  Power Max Value         :806 W
  Power Peak Value        :1 W
  Power Average Value     :0 W
  Software Version        :290
  Hardware Version        :000
  CPLD Version            :021
Table 1-2 Description on the fields of the display poe pse command
Power Current Value
Current power of the card
Remaining power of the card
Power Max Value
Maximum power of the card
Power Peak Value
Peak power of the card
Power Average Value
Average power of the card
Software Version
PSE software version
Hardware Version
PSE hardware version
&  Note:
The sampling cycle of the current power of the interface card is 1 minute, and the sampling cycle of the peak power and average power is 5 minutes.
1.1.4  display poe slot
display poe slot slotnum
View
Parameter
slotnum: Slot number of a PoE card
Use the display poe slot slotnum command to display the information of a PoE card in the switch.
Example
# Display the information of the PoE card in slot 8 of the switch.
[H3C] display poe slot 8
PSE Information of board 8:
  Power Current Value     :33 W
  Power Remaining Value :772 W
  Power Peak Value        :34 W
  Power Average Value     :33 W
1.1.5  poe enable
poe enable
undo poe enable
View
Ethernet port view
Parameter
None
Use the poe enable command to enable the PoE feature on a port.
Use the undo poe enable command to disable the PoE feature on a port.
By default, PoE is disabled on port.
Example
# Enable PoE on current port.
[H3C-GigabitEthernet3/1/1] poe enable
# Disable PoE on current port.
[H3C-GigabitEthernet3/1/1] undo poe enable
1.1.6  poe max-power
poe max-power max-power
undo poe max-power
View
Ethernet port view
Parameter
max-power: Maximum power distributed to the port, ranging from 3000 mW to 16800 mW.
Use the poe max-power command to set the maximum PoE power on the current port.
Use the undo poe max-power command to restore the default PoE power on current port.
By default, the maximum PoE power on a port is 16800 mW.
Example
# Set the maximum PoE power on current port to 12000 mW.
[H3C-GigabitEthernet3/1/1] poe max-power 12000
# Restore the default PoE power on current port.
[H3C-GigabitEthernet3/1/1] undo poe max-power
1.1.7  poe max-power slot
poe max-power max-power slot slot-num
undo poe max-power slot slot-num
View
Parameter
max-power: Maximum power distributed to the card, ranging from 37 W to 806 W.
slot-num: Slot number of a card.
Use the poe max-power command to set the maximum power on a card.
Use the undo poe max-power command to restore the default maximum power on the card.
By default, the maximum power on a card is 806 W.
Example
# Set the maximum power on the card in slot 3 to 400 W.
[H3C] poe max-power 400 slot 3
# Restore the default maximum power on the card.
[H3C] undo poe max-power slot 3
1.1.8  poe mode
poe mode { signal | spare | auto }
undo poe mode
View
Ethernet port view
Parameter
signal: The port supplies power through signal lines.
spare: The port supplies power through spare lines.
auto: The port supplies power in automatically selected mode.
Use the poe mode command to configure the PoE mode on the current port.
Use the undo poe mode command to restore the default PoE mode on current port.
By default, the port adopts signal lines to supply power.
  Caution:
H3C S9500 series routing switches currently do not support the spare mode. If a PD only supports the spare mode, a conversion will be needed.
Example
# Configure the PoE mode on current port to signal.
[H3C-GigabitEthernet3/1/1] poe mode signal
1.1.9  poe priority
poe priority { critical | high | low }
undo poe priority
View
Ethernet port view
Parameter
critical: Sets the port priority to critical (the highest).
high: Sets the port priority to high.
low: Sets the port priority to low.
Use the poe priority command to set the PoE priority on a port.
Use the undo poe priority command to restore the default priority.
By default, the PoE priority on each port is low.
  Caution:
When the PoE power of the switch is not enough to support all the port, the switch supplies power to ports with higher priority, and powers down some ports with lower priority.
Example
# Set the PoE priority of current port to critical.
[H3C-GigabitEthernet3/1/1] poe priority critical
# Restore the default priority.
[H3C-GigabitEthernet3/1/1] undo poe priority
Chapter 2  PoE PSU Supervision Commands
2.1  PoE PSU Supervision Display Commands
2.1.1  display poe-power ac-input state
View
Parameter
None
Use the display poe-power ac-input state command to display the AC input state of each power supply unit (PSU).
Example
# Display the AC input state of each PSU.
<H3C> display poe-power ac-input state
PSU 1 AC Input State : Lack Phase
PSU 2 AC Input State : Normal
PSU 3 AC Input State : Lack Phase
Table 2-1 Description on the fields of the display poe-power ac-input state command
NORMAL
The AC input is normal.
Under Limit
The AC input is below the lower threshold.
Upper Limit
The AC input is above the upper threshold.
Lack Phase
The AC input is lack of phase.
Fuse Broken
The fuse is blown.
Switch Off
The switch is off.
2.1.2  display poe-power alarm
View
Parameter
None
Use the display poe-power alarm command to display detailed alarm information about the PoE PSUs.
Example
# Display detailed alarm information about the PoE PSUs.
<H3C> display poe-power alarm
 PSU alarm detail, PSU number : 2
 PSU 1 alarm : NORMAL
 PSU 2 alarm : NOTLINK      Controller/Rectifer communication  Fail/Rectifier not in present
Table 2-2 Description on the fields of the display poe-power alarm command
NORMAL
Normal
NOTLINK
The PSU is disconnected. That is, the controller was able to communicate with the PSU; but it cannot now. Power-cycling the unit or re-inserting a new PSU can resolve this problem.
INERROR
The PSU input is in trouble. Restoring the AC input can resolve this problem.
OUTERROR
The PSU output is in trouble, the PSU cannot output normal DC voltage.
HIGHVOL
The PSU is over-voltage. The PSU is shut down because the output voltage is too high.
HIGHTEP
It is overheated in the PSU.
FANERROR
The PSU fan is in trouble.
CLOSE
The PSU is shut down remotely.
CURLIMIT
The PSU is current limited.
2.1.3  display poe-power dc-output state
View
Parameter
None
Use the display poe-power dc-output state command to display the current DC output state of the PoE PSUs.
Example
# Display the current DC output state.
<H3C> display poe-power dc-output state
DC Output State : Normal
2.1.4  display poe-power dc-output value
View
Parameter
None
Use the display poe-power dc-output value command to display the DC output voltage/current value of the PoE PSUs.
Example
# Display the DC output voltage/current value of the PoE PSUs.
<H3C> display poe-power dc-output value
DC Output Voltage : 53.997 V
DC Output Current : 0.000 A
2.1.5  display poe-power switch state
View
Parameter
None
Use the display poe-power switch state command to display the number and current state of the AC power distribution switches of the PSUs.
Example
# Display the number and current state of the AC power distribution switches.
<H3C>display poe-power switch state
 Switch Number : 0
Table 2-3 Description on the fields of the display poe-power switch state command
On
The switch is on.
Off
The switch is off.
High Volt Input
The input is high voltage.
Low Volt Input
The input is low voltage.
2.1.6  display supervision-module information
View
Parameter
None
Use the display supervision-module information command to display the name of the supervision module, power supply model, specifications and output power, and other information.
Example
# Display current information about the power system
<H3C> display supervision-module information
Supervision Module Version  : 2.0
 Supervision Module Name  :Spring Pms
 Power Type  :PSE4500-A
 Power Rating Value          : 2250 W (220V)/1125 W(110V)
 Power Current Value         : 53 W
 Power Remaining Value : 2197 W
 Power Peak Value            : 0 W
 Power Average Value         : 0 W
 PSU Number                  : 2
 PSU 1
      Rating Output Power    : 2500 W
      Hard Version Info  :NP 2500
 PSU 2
Table 2-4 Description on the fields of the display supervision-module information command
Software version of the supervision module
Name of the supervision module
Power Type
Power type
Power Rating Value
Rated power of the power system
Power Current Value
Current consumption power of the power system
Current remaining power of the power system
Power Peak Value
Peak power of the power system
Power Average Value
Average power of the power system
Rating Output Power
Rated output power. When one or two PSUs are available, it is 2250 W for 220 VAC input and 1125 W for 110 VAC input. When three PSUs are available, it is 4500 W for 220 VAC input and 2250 W for 110 VAC input.
2.2  PoE PSU Supervision Configuration Commands
2.2.1  poe-power input-thresh lower
poe-power input-thresh lower string
View
Parameter
string: Undervoltage alarm threshold. It ranges from 90.00 V to 264.00 V in the format of X.X and within the accuracy of the second decimal.
Use the poe-power input-thresh lower command to set the undervoltage alarm threshold of AC input for the PoE PSUs (lower threshold):
l           For 220 VAC input, it is recommended to set the threshold to 181.0 V.
l           For 110 VAC input, it is recommended to set the threshold to 90.0 V.
Example
# Set the undervoltage alarm threshold of AC input to 181.0 V.
[H3C] poe-power input-thresh lower 181.0
Set lower input-threshold power successfully!
2.2.2  poe-power input-thresh upper
poe-power input-thresh upper string
View
Parameter
string: Overvoltage alarm threshold. It ranges from 90 V to 264 V in the format of X.X.
Use the poe-power input-thresh upper command to set overvoltage alarm threshold of AC input (upper threshold):
l           For 220 VAC input, it is recommended to set the threshold to 264.0 V.
l           For 110 VAC input, it is recommended to set the threshold to 132.0 V.
Example
# Set the overvoltage alarm threshold of AC input to 264.0 V.
[H3C] poe-power input upper 264.0
Set upper input-threshold power successfully!
2.2.3  poe-power output-thresh lower
poe-power output-thresh lower string
View
Parameter
string: Undervoltage alarm threshold. It ranges from 45.00 V to 47.00 V in the format of x.x.
Use the poe-power output-thresh lower command to set the undervoltage alarm threshold of DC output (lower threshold):
For both 220 VAC and 110 VAC input, it is recommended to set the threshold to 45.00 V.
Example
# Set the undervoltage alarm threshold of DC output to 45.00 V.
[H3C] poe-power output-thresh upper 57.0
Set lower output-threshold power successfully!
2.2.4  poe-power output-thresh upper
poe-power output-thresh upper string
View
Parameter
string: Overvoltage alarm threshold. It ranges from 55.00 V to 57.00 V in the format of X.X.
Use the poe-power output-thresh upper command to set the overvoltage alarm threshold of DC output (upper threshold):
For both 220 VAC and 110 VAC input, it is recommended to set the threshold to 57.00 V.
Example
# Set the overvoltage alarm threshold of DC output to 57.00V.
[H3C] poe-power output upper 57.00
Set upper output-threshold power successfully!
