H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesS3600 SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
06-Management VLAN Command
06-Management VLAN Command 130 KB
Chapter 1  Management VLAN Configuration Commands
1.1  Management VLAN Configuration Commands
1.1.1  description
View
VLAN view, VLAN interface view
Parameter
text: Description string to be assigned to the current VLAN or current VLAN interface.
l           The description string of a VLAN comprises 1 to 32 characters and defaults to the ID of the VLAN (for example, VLAN 0001).
l           The description string of a VLAN interface comprises 1 to 80 characters and defaults to the name of the VLAN interface (for example, Vlan-interface1 Interface).
Use the description command to assign a description string to a VLAN or a VLAN interface.
Use the undo description command to restore the default description string.
Related command: display vlan, display interface Vlan-interface.
Example
# Configure VLAN 2 to be the management VLAN and specify the description string of the VLAN 2 interface to be RESEARCH.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] quit
[H3C] management-vlan 2
[H3C] interface Vlan-interface 2
[H3C-Vlan-interface2] description RESEARCH
1.1.2  display interface Vlan-interface
display interface Vlan-interface [ vlan-id ]
View
Parameter
vlan-id: ID of the management VLAN interface the information about which is to be displayed.
Use the display interface Vlan-interface command to display the information about the management VLAN interface, including the physical and link status, the format of the sent frames, the MAC address, IP address (and subnet mask), description string and MTU (maximum transmit unit) of the management VLAN.
Related command: interface Vlan-interface.
Example
# Display the information about the management VLAN interface. (Assume that VLAN 1 is the management VLAN.)
<H3C> display interface Vlan-interface 1
Vlan-interface1 current state : DOWN
Line protocol current state : DOWN
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 000f-e20f-4101
Internet Address is 192.168.0.39/24 Primary
Description : Vlan-interface1 Interface
The Maximum Transmit Unit is 1500
Table 1-1 Description on the fields of the display interface Vlan-interface command
Vlan-interface current state
Current state of Vlan-interface1
Current state of the line protocol
Format of the sent IP packets
Hardware address
MAC address corresponding to the management VLAN interface
Internet Address Primary
Primary IP address
Description string assigned to the VLAN interface
The maximum transmit unit (MTU)
1.1.3  display ip interface Vlan-interface
display ip interface [ brief [ Vlan-interface [ vlan-id ] ] | [ Vlan-interface vlan-id ] ]
View
Parameter
vlan-id: ID of the management VLAN interface, in the range of 1 to 4094.
brief: Displays the configuration of a specified VLAN interface in brief.
Use the display ip interface Vlan-interface command to display the information about a specified VLAN interface.
Example
# Display the information about Vlan-interface1.
<H3C> display ip interface Vlan-interface 1
Vlan-interface1 current state :UP
Line protocol current state :UP
Broadcast address : 192.168.0.255
The Maximum Transmit Unit : 1500 bytes
IP packets input number: 7420, bytes: 557679, multicasts: 1
IP packets output number: 7509, bytes: 385809, multicasts: 0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
Table 1-2 Description on the fields of the display ip interface command
Internet Address
IP address
Broadcast address
Broadcast address
IP input packets : 0, bytes : 0, multicasts : 0
IP output packets : 0, bytes : 0, multicasts : 0
The number of input/output unicast packets, the corresponding bytes, and the number of multicast packets are all 0.
Number of received packets with TTL errors
  Echo reply:                      0
  Unreachable:                    0
  Source quench:                  0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                    0
  IP header bad:                   0
  Timestamp reply:                 0
  Netmask request:                0
  Netmask reply:                   0
  Unknown type:                   0
The statistics on different types of ICMP packets received, including:
l      Echo reply packets
l      Unreachable packets
l      Source quench packets
l      Routing redirect packets
l      Echo request packets
l      Router advert packets
l      Router solicit packets
l      Time exceed packets
l      IP header bad packets
l      Timestamp request packets
l      Timestamp reply packets
l      Information request packets
l      Information reply packets
l      Netmask request packets
l      Netmask reply packets
l      Unknown type packets
1.1.4  display ip routing-table
View
Parameter
None
Use the display ip routing-table command to display the summary information about the routing table.
This command displays the summary information about a routing table, with the items of a routing entry contained in one line. The information displayed includes destination IP address/mask length, protocol, preference, cost, next hop and outbound interface.
The display ip routing-table command only displays the routes currently in use, that is, the optimal routes.
Example
# Display the summary information about the routing table.
<H3C> display ip routing-table
 Routing Table: public net
Destination/Mask Protocol        Pre Cost        Nexthop     Interface
127.0.0.0/8      DIRECT      0   0       127.0.0.1   InLoopBack0
127.0.0.1/32     DIRECT      0   0       127.0.0.        InLoopBack0
192.168.0.0/24   DIRECT      0   0       192.168.0.91    Vlan-interface1
192.168.0.91/32  DIRECT      0   0       127.0.0.1   InLoopBack0
Table 1-3 Description on the fields of the display ip routing-table command
Destination/Mask
Destination IP address/mask length
Protocol
Routing protocol that discovers the route
Pre
Route preference
Cost
Route cost
Nexthop
Next hop IP address of the route
Outbound interface, through which packets destined for the destination network segment are to be transmitted
1.1.5  display ip routing-table ip-address
display ip routing-table ip-address [ mask ] [ longer-match ] [ verbose ]
View
Parameter
ip-address: Destination IP address, in dotted decimal notation.
mask: Mask of the destination IP address, which can be in dotted decimal notation or be an integer ranging from 0 to 32.
longer-match: Displays all the routes leading to the destination coupled with the default mask.
verbose: Displays the detailed information about the active and inactive routes leading to the destination. If this keyword is not specified, only the summary information about the active routes is displayed.
Use the display ip routing-table ip-address command to display the information about the routes leading to a specified destination.
The output information of this command differs with the arguments/keywords specified as follows:
l           display ip routing-table ip-address
For the destination address ip-address, if there are some routes matched within the natural mask range, all the subnet routes are displayed. Otherwise, only the active routes which best match ip-address are displayed.
l           display ip routing-table ip-address mask
Only the routes which match exactly the specified destination address and mask are displayed.
l           display ip routing-table ip-address longer-match
All routes with their destination addresses matched within the natural mask range are displayed.
l           display ip routing-table ip-address mask longer-match
All routes with their destination addresses matched within the specified mask range are displayed.
Example
# Display the summary information of the routes with their destination addresses matched within the natural mask range.
<H3C> display ip routing-table 169.0.0.0
169.0.0.0/16         Static  60  0       2.1.1.1     LoopBack1
Refer to Table 1-3for the description on the output fields.
# Display the summary information about the routes that best match the specified IP address (assuming that no route in the natural subnet mask range matches the specified IP address).
<H3C> display ip routing-table 169.253.0.0
169.0.0.0/8          Static  60      0       2.1.1.1     LoopBack1
# Display the detailed information of the routes with their destination addresses matched within the natural mask range.
<H3C> display ip routing-table 169.0.0.0 verbose
Routing Tables:
Generate Default: no
+ = Active Route, - = Last Active, # = Both  * = Next hop in use
Summary count:2
**Destination: 169.0.0.0     Mask: 255.0.0.0
Protocol: #Static       Preference: 60
*NextHop: 2.1.1.1       Interface: 2.1.1.1(LoopBack1)
Vlinkindex: 0
State: <Int ActiveU Static Unicast>
Age: 3:47   Cost: 0/0   Tag: 0
**Destination: 169.0.0.0     Mask: 255.254.0.0
Vlinkindex: 0
# Display the detailed information of the routes that best match the specified IP address (assuming that no route in the natural subnet mask range matches the specified IP address).
<H3C> display ip routing-table 169.253.0.0 verbose
Routing Tables:
Summary count:1
Protocol: #Static       Preference: -60
*NextHop: 2.1.1.1
Vlinkindex: 0
1.1.6  display ip routing-table ip-address1 ip-address2
display ip routing-table ip-address1 mask1 ip-address2 mask2 [ verbose ]
View
Parameter
ip-address1, ip-address2: Destination IP addresses in dotted decimal notation. ip-address1 and mask1, together with ip-address2 and mask2, determine an IP address range. The starting address of the IP address range is determined by the ip-address1 and mask1 arguments; and the end address of the IP address range is determined by the ip-address2 and mask2 arguments.
mask1, mask2: IP address masks. These two arguments can be in dotted decimal notation or two integers ranging from 0 to 32.
verbose: Displays the detailed information about the active and inactive routes. If you do not specify this keyword, only the summary information about the active routes is displayed.
Use the display ip routing-table ip-address1 ip-address2 command to display the information about the routes with their destinations within the specified destination IP address range.
Example
# Display the information about the routes with their destinations within the range of 1.1.1.0 to 2.2.2.0.
<H3C> display ip routing-table 1.1.1.0 24 2.2.2.0 24
Routing tables:
  Summary count: 1
1.1.1.0/24          DIRECT       0  0          1.1.1.1      Vlan-interface1
1.1.7  display ip routing-table protocol
display ip routing-table protocol protocol [ inactive | verbose ]
View
Parameter
protocol: This argument can be one of the following:
l           direct: Displays the information about the direct routes.
l           ospf: Displays the information about OSPF routes.
l           ospf-ase: Displays the information about ASE routes.
l           ospf-nssa: Displays the information about NSSA routes.
l           rip: Displays the information about RIP routes.
l           static: Displays the information about the static routes.
inactive: Displays the information about the inactive routes. If you do not specify this keyword, the information about both active and inactive routes is displayed.
verbose: Displays the detailed route information. If you do not specify this keyword, only the summary route information is displayed.
Use the display ip routing-table protocol command to display the information about specified type of routes.
&  Note:
The OSPF-related information cannot be displayed on S3600-SI series switches.
Example
# Display the summary information about all the direct routes.
<H3C> display ip routing-table protocol direct
DIRECT Routing tables:
  Summary count: 4
DIRECT Routing tables status:<active>:
  Summary count: 3
20.1.1.1/32          DIRECT          0   0       127.0.0.1   InLoopBack0
127.0.0.1/32         DIRECT          0   0       127.0.0.1   InLoopBack0
DIRECT Routing tables status:<inactive>:
  Summary count: 1
210.0.0.1/32         DIRECT      0       0       127.0.0.1   InLoopBack0
# Display the summary information about the static routing table.
<H3C> display ip routing-table protocol static
STATIC Routing tables:
  Summary count: 1
STATIC Routing tables status:<active>:
  Summary count: 0
STATIC Routing tables status:<inactive>:
  Summary count: 1
1.2.3.0/24          STATIC     60  0         1.2.4.5      Vlan-interface1
1.1.8  display ip routing-table radix
View
Parameter
None
Use the display ip routing-table radix command to display the information about the routes in a routing table in a hierarchical way.
Example
<H3C> display ip routing-table radix
Radix tree for INET (2) inodes 2 routes 2:
                   +--8+--{127.0.0.0
                      +-32+--{127.0.0.1
Table 1-4 Description on the fields of the display ip routing-table radix command
INET
Address family
inodes
Number of nodes
routes
Number of routes
1.1.9  display ip routing-table statistics
View
Parameter
None
Use the display ip routing-table statistics command to display the statistics of a routing table.
The statistics information displayed by this command includes:
l           The total number of the routes
l           The number of the active routes
l           The number of the added routes
l           The number of the routes with deleted flags
Example
# Display the statistics information about the routing table.
<H3C> display ip routing-table statistics
Routing tables:
Proto     route     active      added       deleted
DIRECT     4           4           20          16
STATIC     2           2           2            0
RIP        0           0           0            0
OSPF       0           0           0            0
O_ASE      0           0           0            0
O_NSSA     0           0           0            0
Total      6           6           22          16
Table 1-5 Description on the fields of the display ip routing-table statistics command
Proto
Routing protocol
route
Total number of routes
active
Number of the active routes that are currently in use
added
Number of the routes that are added to the routing table after the switch starts or the routing table is cleared last time
deleted
Number of the routes with deleted flags (this type of routes will be removed after a period of time)
Total
Total numbers of various routes
1.1.10  display ip routing-table verbose
View
Parameter
None
Use the display ip routing-table verbose command to display the detailed information about a routing table.
This command displays the detailed information about the routing table, in the order of route state, statistics of the routing table, and the information about each route.
You can use this command to display all the routes, including the inactive and invalid routes.
Example
# Display the detailed information about the routing table.
<H3C> display ip routing-table verbose
Routing Tables:
  Destinations: 2       Routes: 2
  Holddown: 0   Delete: 0       Hidden: 0
**Destination: 127.0.0.0        Mask: 255.0.0.0
        Protocol: #DIRECT       Preference: 0
        *NextHop: 127.0.0.1        Interface: 127.0.0.1(InLoopBack0)
        State: <NoAdvise Int ActiveU Retain Unicast>
        Age: 57:12      Cost: 0/0
**Destination: 127.0.0.1        Mask: 255.255.255.255
        State: <NotInstall NoAdvise Int ActiveU Retain Gateway Unicast>
The statistics of the routing table are displayed first, and then the detailed descriptions of each route. Table 1-5 describes the route states and Table 1-6 describes the statistics information about the routing table.
Table 1-6 Description on the fields of the display ip routing-table verbose command
Holddown
Number of the routes that are held down
Delete
Number of the deleted routes
Hidden
Number of the hidden routes
1.1.11  interface Vlan-interface
interface Vlan-interface vlan-id
undo interface Vlan-interface vlan-id
View
Parameter
vlan-id: ID of the management VLAN, in the range of 1 to 4094.
Use the interface Vlan-interface command to create a management VLAN interface and enter management VLAN interface view.
Use the undo interface Vlan-interface command to remove the management VLAN interface.
Before creating a management VLAN interface, make sure the VLAN identified by the vlan-id argument is created and is configured as the management VLAN.
Note that:
To create the VLAN interface for the management VLAN on a switch operating as the management device in a cluster, make sure the ID of the management VLAN is consistent with that of the cluster management VLAN, that is, the vlan-id argument in the management-vlan vlan-id command when you configure the cluster management VLAN.
Example
# Create VLAN 10 and configure it as the management VLAN. Create VLAN 10 interface and enter VLAN 10 interface view.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
[H3C] management-vlan 10
[H3C] interface Vlan-interface 10
[H3C-Vlan-interface10]
1.1.12  ip address
ip address ip-address mask [ sub ]
undo ip address [ ip-address mask [ sub ] ]
View
VLAN interface view
Parameter
ip-address: IP address to be assigned to the management VLAN interface.
mask: Mask of the IP address to be assigned to the management VLAN interface. The mask can be in dotted decimal notation or an integer in the range of 0 to 32.
sub: Specifies the IP address is to be configured as a secondary IP address of the VLAN interface.
Use the ip address command to assign an IP address (and mask) to a management VLAN interface.
Use the undo ip address command to remove the IP address assigned to a management VLAN interface.
Related command: display interface Vlan-interface.
Example
# Assign an IP address (and the mask) to the management VLAN interface. (Assume that VLAN 1 is the management VLAN.)
<H3C> system-view
[H3C-Vlan-interface1] ip address 192.168.0.39 255.255.255.0
1.1.13  ip route-static
ip route-static ip-address mask { NULL null-interface-number | next-hop } [ preference preference-value ] [ reject | blackhole ] [ detect-group detect-group-id ] [ description text ]
undo ip route-static ip-address mask [ NULL null-interface-number | next-hop ] [ preference preference-value ]
View
Parameter
mask: IP address mask, which can be in dotted decimal notation or an integer in the range of 0 to 32.
NULL null-interface-number: Specifies a null interface. A null interface is a virtual interface. Packets destined for a null interface is discarded. Null interface helps to reduce system load.
next-hop: IP address of the next hop of this route, in dotted decimal notation.
preference-value: Preference of this route, in the range of 1 to 255.
reject: Specifies the route as an unreachable route.
blackhole: Specifies the route as a black hole route.
detect-group: Specifies a detect group for the route.
detect-group-id: Detect group number, in the range of 1 to 25.
description text: Specifies a descriptive string for the static route. The text argument is a string comprising 1 to 60 characters.
Use the ip route-static command to configure a static route.
Use the undo ip route-static command to remove a static route.
By default, the system can obtain the routes to the subnets directly connected to a router. If you do not specify the preference when configuring a static route, the default value is 60. Note that routes with the same destinations, the same next hops, but different preferences are different routes. Among these routes, the one with least preference (which means the highest preference) is chosen to be the current route. A route configured using the ip route-static command is a reachable route if neither of the reject and blackhole keywords is specified.
Note the following when configuring a static route:
l           The next hop address of a static route cannot be the VLAN interface address of the local switch.
l           A static route with both its destination IP address and mask both being 0.0.0.0 is the default route. When no matched entry is found in the routing table, a received packet is forwarded according to the default route.
Related command: display ip routing-table.
Example
# Configure the next hop of the default route to be 129.102.0.2.
<H3C> system-view
[H3C] ip route-static 0.0.0.0 0.0.0.0 129.102.0.2
1.1.14  management-vlan
undo management-vlan
View
Parameter
Use the management-vlan command to configure a VLAN as the management VLAN.
Use the undo management vlan command to restore the default management VLAN.
VLAN 1 is the default management VLAN.
Example
# Configure VLAN 2 as the management VLAN.
<H3C> system-view
1.1.15  shutdown
shutdown
View
VLAN interface view
Parameter
None
Use the shutdown command to shut down a management VLAN interface.
Use the undo shutdown command to bring up a management VLAN interface.
By default, a management VLAN interface is down if all the Ethernet ports in the management VLAN are down, and the management VLAN interface is up if one or more Ethernet ports in the management VLAN are up.
Example
# Bring up the management VLAN interface. (Assume that VLAN 1 is the management VLAN.)
<H3C> system-view
[H3C-Vlan-interface1] undo shutdown
Chapter 2  DHCP/BOOTP Client Configuration
2.1  DHCP/BOOTP Client Configuration Commands
2.1.1  display bootp client
display bootp client [ interface Vlan-interface vlan-id ]
View
Parameter
vlan-id: ID of the management VLAN interface.
Use the display bootp client command to display BOOTP client-related information, including the MAC address of the BOOTP client and the IP address obtained.
Example
# Display the BOOTP client-related information.
<H3C> display bootp client interface Vlan-interface 1
Vlan-interface1:
Allocated IP: 169.254.0.2 255.255.0.0
Transaction ID = 0x3d8a7431
Mac Address  000f-e20a-c3ef
Table 2-1 Description on the fields of the display bootp client command
Vlan-interface1
Management VLAN interface 1 is configured to obtain an IP address through BOOTP.
Allocated IP
IP address allocated to the VLAN interface
Transaction ID
Value of the XID field in BOOTP packets
Mac Address
2.1.2  display dhcp client
display dhcp client [ verbose ]
View
Parameter
verbose: Displays the detailed address allocation information.
Use the display dhcp client command to display the information about the address allocation of DHCP clients.
Note that as a DHCP client, an S3600 switch can occupy an IP address for up to 24 days. That is, even if the lease period of the address pool on the DHCP server is longer than 24 days, the DHCP client can only obtain a 24-day lease.
Example
# Display the information about the address allocation of DHCP clients.
<H3C> display dhcp client verbose
DHCP client statistic information:
Vlan-interface1:
Current machine state: BOUND
Allocated lease: 86400 seconds, T1: 43200 seconds, T2: 75600 seconds
Lease from 2002.09.20 01:05:03   to   2002.09.21 01:05:03
Server IP: 169.254.0.1
Default router: 2.2.2.2
Next timeout will happen after 0 days 11 hours 56 minutes 1 seconds.
Table 2-2 Description on the fields of the display dhcp client command
Vlan-interface1
VLAN interface operating as a DHCP client to obtain an IP address dynamically
The state of the client state machine
Allocated IP
IP address allocated to the DHCP client
lease
Lease period
T1
Renewal timer setting
T2
Rebinding timer setting
Lease from….to….
The starting and end time of the lease period
Server IP
IP address of the DHCP server selected
Transaction ID
Transaction ID
Default router
Gateway address
2.1.3  ip address bootp-alloc
undo ip address bootp-alloc
View
VLAN interface view
Parameter
None
Use the ip address bootp-alloc command to configure a VLAN interface to obtain an IP address through BOOTP.
Use the undo ip address bootp-alloc command to cancel the configuration.
By default, a VLAN interface does not use BOOTP to obtain an IP address.
Related command: display bootp client.
Example
# Configure the management VLAN interface to obtain an IP address through BOOTP. (Assume that VLAN 1 is the management VLAN.)
<H3C> system-view
[H3C-Vlan-interface1] ip address bootp-alloc
2.1.4  ip address dhcp-alloc
undo ip address dhcp-alloc
View
VLAN interface view
Parameter
None
Use the ip address dhcp-alloc command to configure a VLAN interface to obtain an IP address through DHCP.
Use the undo ip address dhcp-alloc command to cancel the configuration.
By default, a VLAN interface does not use DHCP to obtain an IP address.
Example
# Configure the management VLAN interface to obtain an IP address through DHCP. (Assume that VLAN 1 is the management VLAN.)
<H3C> system-view
[H3C-Vlan-interface1] ip address dhcp-alloc
