H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesS3600 SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
10-Link Aggregation Command
10-Link Aggregation Command 70 KB
Chapter 1  Link Aggregation Configuration Commands
1.1  Link Aggregation Configuration Commands
1.1.1  display link-aggregation interface
display link-aggregation interface interface-type interface-number [ to interface-type interface-number ]
View
Parameter
interface-type: Port type.
interface-number: Port number.
to: Specifies a group of contiguous ports..
Use the display link-aggregation interface command to display the link aggregation details about a specified port or port range, including:
l           Link aggregation group ID, port priority, operation key and protocol status flag of the port at the local end;
l           Device ID, port number, port priority, operation key and protocol status flag at the remote end, and,
l           LACP protocol packet statistics.
Note that, for a manual aggregation group, value 0 is displayed for all the above items of the remote end (which does not indicate the real information of the remote end), since information about the remote end cannot be obtained for a manual aggregation group.
Example
# Display the link aggregation details on Ethernet1/0/1.
<H3C> display link-aggregation interface Ethernet1/0/1
 Ethernet1/0/1:
   Selected AggID: 1
   Local:
     Port-Priority: 32768, Oper key: 2, Flag: 0x45
   Remote:
     System ID: 0x8000, 0000-0000-0000
     Port Number: 0, Port-Priority: 32768 , Oper-key: 0, Flag: 0x38
   Received LACP Packets: 0 packet(s), Illegal: 0 packet(s)
   Sent LACP Packets: 0 packet(s)
Table 1-1 Description on the fields of the display link-aggregation interface command
Selected AggID
ID of the aggregation group to which the specified port belongs
Local
Information about the local end
Port-Priority
Port priority
Oper key
Operation key
Flag
Protocol status flag
Remote
Information about the remote end
System ID
Remote device ID
Port number
Port number
Statistics about LACP packets
1.1.2  display link-aggregation summary
View
Parameter
None
Use the display link-aggregation summary command to display summary information of all aggregation groups, including device ID of the local end, aggregation group ID, aggregation group type, device ID of the remote end, number of the selected ports, number of the unselected ports, load sharing type and master port number.
Example
# Display summary information of all aggregation groups.
<H3C> display link-aggregation summary
Aggregation Group Type:D -- Dynamic, S -- Static , M -- Manual
Actor ID: 0x8000, 000f-e20f-5104
  AL  AL   Partner ID            Select Unselect Share Master
  ID  Type                         Ports  Ports     Type  Port
  1   S    0x8000,0000-0000-0000 0      1        NonS  Ethernet1/0/2
  2   M    none                     0       1        NonS  Ethernet1/0/3
Table 1-2 Description on the fields of the display link-aggregation summary command
Aggregation group type
Actor ID
Local device ID
AL ID
Aggregation group ID
AL Type
Aggregation group type: D (dynamic), S (static), or M (manual)
Partner ID
ID of the remote device, including the system priority and system MAC address of the remote device (in the dynamic or static aggregation group, if the LACP protocol is disabled on the remote port of the logical master port, the partner ID displays 0x8000,0000-0000-0000 )
Select Ports
Number of the selected ports
Unselect Ports
Number of the unselected ports
Share Type
Load sharing type: Shar (load-sharing), or NonS (non-load-sharing)
Master Port
Number of the master port
1.1.3  display link-aggregation verbose
display link-aggregation verbose [ agg-id ]
View
Parameter
agg-id: Aggregation group ID to be displayed, which ranges from 1 to 416 and must be the ID of an existing aggregation group.
Use the display link-aggregation verbose command to display the details about a specified aggregation group or all aggregation groups, including:
l           Aggregation group ID, aggregation group type, load sharing type, aggregation group description string, and device ID;
l           Local end details: local port, port status, port priority, operation key and protocol status flag;
l           Remote end details: local port, remote port index, remote port priority, operation key, device ID and protocol status flag.
Example
# Display the details about aggregation group 1.
<H3C> display link-aggregation verbose 1
Flags:  A -- LACP_Activity, B -- LACP_timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation ID: 1,  AggregationType: Static,   Loadsharing Type: NonS
Aggregation Description: abc
System ID: 0x16, 0012-a990-2240
Port Status: S -- Selected,  U -- Unselected
Local:
Port                     Status  Priority  Key    Flag
Ethernet1/0/4            S       32768     2      {ACDEFG}
Ethernet1/0/5            U       32768     2      {ACG}
Remote:
Actor                    Partner Priority Key   SystemID              Flag
Ethernet1/0/4            0       32768    0     0x8000,0000-0000-0000 {DEF}
Ethernet1/0/5            0       32768    0     0x8000,0000-0000-0000 {DEF}
Table 1-3 Description on the fields of the display link-aggregation verbose command
Loadsharing Type
Loadsharing type, including Loadsharing and Non-Loadsharing
Flags
Flag types of LACP
Aggregation ID
Aggregation group description string
AggregationType
System ID
Device ID
Port Status
Port status, including selected and unselected
1.1.4  display lacp system-id
View
Parameter
None
Use the display lacp system-id command to display the device ID of the local system, including the system priority and the MAC address.
Related command: link-aggregation.
Example
# Display the device ID of the local system.
<H3C> display lacp system-id
 Actor System ID: 0x8000, 000f-e20f-0100
Table 1-4 Description on the fields of the display lacp system-id command
Actor System ID
Device ID of the local system, including the system priority and the system MAC address
1.1.5  lacp enable
lacp enable
undo lacp enable
View
Ethernet port view
Parameter
None
Use the lacp enable command to enable the LACP protocol.
Use the undo lacp enable command to disable the LACP protocol.
Example
# Enable the LACP protocol on Ethernet1/0/1.
<H3C> system-view
[H3C] interface Ethernet1/0/1
[H3C-Ethernet1/0/1] lacp enable
1.1.6  lacp port-priority
lacp port-priority port-priority
undo lacp port-priority
View
Ethernet port view
Parameter
port-priority: Port priority, ranging from 0 to 65,535 and defaulting to 32,768.
Use the lacp port-priority command to set the priority of the current port.
Use the undo lacp port-priority command to restore the default port priority.
Related command: display link-aggregation verbose, and display link-aggregation interface.
Example
# Set the priority of Ethernet1/0/1 to 64.
<H3C> system-view
[H3C-Ethernet1/0/1] lacp port-priority 64
1.1.7  lacp system-priority
lacp system-priority system-priority
undo lacp system-priority
View
Parameter
system-priority: System priority, ranging from 0 to 65,535 and defaulting to 32,768.
Use the lacp system-priority command to set the system priority.
Use the undo lacp system-priority command to restore the default system priority.
Example
# Set the system priority to 64.
<H3C> system-view
[H3C] lacp system-priority 64
1.1.8  link-aggregation group agg-id description
link-aggregation group agg-id description agg-name
undo link-aggregation group agg-id description
View
Parameter
agg-id: Aggregation group ID, in the range of 1 to 416.
agg-name: Aggregation group name, a string of 1 to 32 characters.
Use the link-aggregation group agg-id description command to set a description for an aggregation group.
Use the undo link-aggregation group agg-id description command to remove the description of the aggregation group.
&  Note:
If you have saved the current configuration with the save command, after system reboot, the manual and static aggregation groups and their descriptions still exist, but the dynamic aggregation groups and their descriptions disappear.
Related command: display link-aggregation verbose.
Example
# Set the description "abc" for aggregation group 1.
<H3C> system-view
[H3C] link-aggregation group 1 description abc
1.1.9  link-aggregation group agg-id mode
link-aggregation group agg-id mode { manual | static }
View
Parameter
manual: Creates a manual aggregation group.
static: Creates a static aggregation group.
Use the link-aggregation group agg-id mode command to create a manual or static aggregation group.
Use the undo link-aggregation group command to remove an aggregation group.
Related command: display link-aggregation summary.
Example
# Create manual aggregation group 22
<H3C> system-view
[H3C] link-aggregation group 22 mode manual
1.1.10  port link-aggregation group
port link-aggregation group agg-id
undo port link-aggregation group
View
Ethernet port view
Parameter
Use the port link-aggregation group command to add the current Ethernet port to a manual or static aggregation group.
Use the undo port link-aggregation group command to remove the current Ethernet port from the aggregation group.
Example
# Add Ethernet 1/0/1 to aggregation group 22.
<H3C> system-view
[H3C-Ethernet1/0/1] port link-aggregation group 22
1.1.11  reset lacp statistics
reset lacp statistics [ interface interface-type interface-number [ to interface-type interface-number ] ]
View
Parameter
Use the reset lacp statistics command to clear LACP statistics on specified port(s), or on all ports if no port is specified.
Related command: display link-aggregation interface.
Example
# Clear LACP statistics on all Ethernet ports.
<H3C> reset lacp statistics
