H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesS3600 SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
42-DNS Command
42-DNS Command 58 KB
Chapter 1  DNS Configuration Commands
1.1  DNS Configuration Commands
1.1.1  display dns domain
display dns domain [ dynamic ]
View
Parameter
dynamic: Displays the DNS suffixes dynamically obtained through DHCP or other protocols.
Use the display dns domain command to display the DNS suffixes.
Related command: dns domain.
Example
# Display DNS suffixes
<H3C> display dns domain
No         Domain-name
0          aaa.com
Table 1-1 Description on fields of the display dns domain command
No
Sequence number
Domain-name
DNS suffix
1.1.2  display dns dynamic-host
View
Parameter
None
Use the display dns dynamic-host command to display the information in the dynamic domain name cache.
After a successful domain name resolution, the DNS Client saves the result in the cache. In the case of a repeated domain name resolution request, the DNS Client first searches the cache for the mapping between the domain name and the IP address. If the mapping is cleared because of timeout, the DNS Client sends the domain name resolution request to the DNS server.
Example
# Display the information in the dynamic domain name cache.
<H3C> display dns dynamic-host
No  Domain-name           IpAddress            TTL      Alias
0   www.baidu.com         202.108.249.134      63000
1   www.yahoo.akadns.net  66.94.230.39         24
2   www.hotmail.com       207.68.172.239       3585
3   www.eyou.com          61.136.62.70         3591
Table 1-2 Description on fields of the display dns dynamic-host command
No
Sequence number
Domain-name
Domain name
IpAddress
IP address of the corresponding domain name
TTL
Time for which an entry is cached in seconds.
Alias
Alias for the domain name. There can be four aliases at most.
1.1.3  display dns server
display dns server [ dynamic ]
View
Parameter
dynamic: Displays the DNS Server information dynamically obtained through DHCP or other protocols.
Use the display dns server command to display the DNS Server information.
Related command: dns server.
Example
# Display the DNS Server information.
<H3C> display dns server
Domain-server        IpAddress
     0               169.254.65.125
     1               169.254.66.15
Table 1-3 Description on fields of the display dns server command
Domain-server
Number of the DNS Server. Configured automatically by the device, starts from 0.
IpAddress
IP address of the DNS Server
1.1.4  display ip host
display ip host
View
Parameter
None
Use the display ip host command to display mappings between host names and IP addresses in the static DNS database.
Example
# Display mappings between host names and IP addresses in the static DNS database.
<H3C> display ip host
Host         Age     Flags       Address
My           0       static      1.1.1.1
Aa           0       static      2.2.2.4
Table 1-4 Description on fields of the display ip host command
Host
Host name
Age
Time to live. 0 means that a static entry is never outdated.
You can only manually remove the mappings between host names and IP addresses.
Flags
Indicates the type of mappings between host names and IP addresses, static or dynamic
Static indicates static mapping between host names and IP addresses
Address
IP address of a host
1.1.5  dns domain
dns domain domain-name
undo dns domain [ domain-name ]
View
Parameter
domain-name: DNS suffix, a string of 1 to 60 characters which can be letters, numbers, hyphens (-), underscores (_), and dots (.).
Use the dns domain command to configure a DNS suffix.
Use the undo dns domain command to delete the configured DNS suffix.
No DNS suffix is configured by default.
You can configure a maximum of 10 DNS suffixes. You must enter the DNS suffix before deleting it. Otherwise, all statically configured DNS suffixes are deleted.
Related command: display dns domain.
&  Note:
The DNS feature supported by S3600 serial Ethernet switches should be used together with a DNS server. DNS implementations vary with DNS servers. For example, S3600 serial Ethernet switches support a domain name containing “_”, while a Windows 2000 Server may not be able to resolve the domain name.
Example
# Configure com as a DNS suffix.
<H3C> system-view
[H3C] dns domain com
1.1.6  dns resolve
dns resolve
undo dns resolve
View
Parameter
None
Use the dns resolve command to enable dynamic domain name resolution.
Use the undo dns resolve command to disable dynamic domain name resolution.
Dynamic domain name resolution is disabled by default.
Example
# Enable dynamic domain name resolution.
<H3C> system-view
[H3C] dns resolve
1.1.7  dns server
dns server ip-address
undo dns server [ ip-address ]
View
Parameter
ip-address: IP address of the DNS Server.
Use the dns server command to configure an IP address for the DNS Server.
Use the undo dns server to remove the IP address of the DNS server.
No IP address is configured for the DNS Server by default.
You can configure a maximum of 6 DNS Servers.
Related command: display dns server.
Example
# Configure 172.16.1.1 for a DNS Server.
<H3C> system-view
[H3C] dns server 172.16.1.1
1.1.8  ip host
ip host hostname ip-address
undo ip host hostname [ ip-address ]
View
Parameter
hostname: Host name, a string of 1 to 20 characters which can be letters, numbers, hyphens (-), or dots (.). The host name must include at least one letter.
ip-address: IP address of the specified host, in dotted decimal notation.
Use the ip host command to create a mapping between host name and IP address in the static DNS database.
Use the undo ip host command to remove the mapping.
No mappings are created by default.
Each host name can correspond to only one IP address. When IP addresses are configured for the same host for multiple times, only the IP address configured last time is valid.
Related command: display ip host.
Example
# Configure the IP address 10.110.0.1 for the host named aaa.
<H3C> system-view
[H3C] ip host aaa 10.110.0.1
1.1.9  nslookup type
nslookup type { ptr ip-address | a domain-name }
View
Parameter
ptr ip-address: Resolves the corresponding domain name for an IP address.
a domain-name: Resolves the corresponding IP address for a DNS domain name. A domain name consists of a string of up to 30 characters. Automatic domain name addition is supported.
Use the nslookup type command to display DNS resolution result, namely, the domain name for a specified IP address or IP address for a specified domain name.
Example
# Display the corresponding domain name for 192.168.3.2.
<H3C> nslookup type ptr 192.168.3.2
Trying DNS server (10.72.66.36)
Address:  192.168.3.2
# Display the corresponding IP address for www.h3c.com.
<H3C> nslookup type a www.h3c.com
1.1.10  reset dns dynamic-host
View
Parameter
None
Use the reset dns dynamic-host command to clear information in the dynamic domain name cache.
Related command: display dns dynamic-host.
Example
# Clear the information in the dynamic domain name cache.
<H3C> reset dns dynamic-host
