H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesS3600 SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
07-Voice VLAN Command
07-Voice VLAN Command 67 KB
Chapter 1  Voice VLAN Configuration Commands
1.1  Voice VLAN Configuration Commands
1.1.1  display voice vlan error-info
View
Parameter
None
Use the display voice vlan error-info command to display the ports on which the voice VLAN function fails to be enabled.
&  Note:
When ACL number applied to a port reaches to its threshold, voice VLAN cannot be enabled on this port.
Example
# Display the ports on which voice VLAN fails to be enabled.
<H3C> display voice vlan error-info
 Fail to apply voice VLAN ACL rules to the following port(s):
  Ethernet1/0/10    Ethernet1/0/15
1.1.2  display voice vlan oui
View
Parameter
None
Use the display voice vlan oui command to display the currently supported OUI addresses and the related information.
Related command: voice vlan, voice vlan enable.
Example
# Display the OUI addresses and the related information of the voice VLAN.
<H3C> display voice vlan oui
Oui Address      Mask              Description
0003-6b00-0000  ffff-ff00-0000  Cisco phone
000f-e200-0000  ffff-ff00-0000  H3C Aolynk phone
00d0-1e00-0000  ffff-ff00-0000  Pingtel phone
00e0-7500-0000  ffff-ff00-0000  Polycom phone
00e0-bb00-0000  ffff-ff00-0000  3Com phone
1.1.3  display voice vlan status
View
Parameter
None
Use the display voice vlan status command to display voice VLAN-related information, including voice VLAN operation mode, port mode (manual or automatic ), and so on.
Example
# Display the information about the voice VLAN.
<H3C> display voice vlan status
Voice Vlan status: ENABLE
Voice Vlan ID: 2
Voice Vlan security mode: Security
Voice Vlan aging time: 100 minutes
Current voice vlan enabled port mode:
PORT                     MODE
Ethernet1/0/2            AUTO
Ethernet1/0/3            MANUAL
Table 1-1 Description on the fields of the display voice vlan status command
Voice Vlan status
The status of global voice VLAN function: enabled or disabled.
Voice Vlan ID
The VLAN which is currently enabled with voice VLAN.
The status of voice VLAN security mode: enabled or disabled.
The voice VLAN aging time
Current voice vlan enable port mode
The ports on which the voice VLAN function is enabled.
  Caution:
The “Current voice vlan enable port mode” field lists the ports with the voice VLAN function enabled. Note that a port listed in this field may not currently operate in a voice VLAN. To view the ports operating in the voice VLAN currently, use the display vlan command, which is described in section 1.1.4  “display vlan”.
1.1.4  display vlan
display vlan vlan-id
View
Parameter
vlan-id: Voice VLAN ID in the range of 1 to 4094. VLAN 1 can not be enabled with voice VLAN function.
Use the display vlan command to display all the ports in the voice VLAN currently.
Related command: voice vlan.
Example
# Display all the ports in the current voice VLAN, assuming that the current voice VLAN is VLAN 6.
<H3C> display vlan 6
 VLAN ID: 6
 VLAN Type: static
 Route Interface: not configured
 Description: VLAN 0006
 Tagged   Ports:
  Ethernet1/0/5
 Untagged Ports:
  Ethernet1/0/6
The output indicates that Ethernet1/0/5 and Ethernet1/0/6 are in the voice VLAN currently.
1.1.5  voice vlan
voice vlan vlan-id enable
undo voice vlan enable
View
Parameter
vlan-id: ID of the VLAN that needs to be enabled with the voice VLAN function, ranging from 2 to 4094.
Use the voice vlan command to enable voice VLAN globally.
Use the undo voice vlan enable command to disable voice VLAN globally.
  Caution:
l      If you enable the voice VLAN function for a specified VLAN, the specified VLAN must exist, otherwise, your configuration fails.
l      If you want to delete a VLAN with voice VLAN function enabled, you must disable the voice VLAN function first.
l      The voice VLAN function can be enabled for only one VLAN at one time.
Related command: display voice vlan status.
Example
# Create VLAN 2, and enable the voice VLAN function on it.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] quit
[H3C] voice vlan 2 enable
# After the voice VLAN function of VLAN 2 is enabled, if you enable the voice VLAN function for other VLANs, the system will prompt that your configuration fails.
[H3C] voice vlan 4 enable
Can't change voice vlan configuration when other voice vlan is running
1.1.6  voice vlan aging
voice vlan aging minutes
undo voice vlan aging
View
Parameter
minutes: Aging time (in minutes) to be set for a voice VLAN, ranges from 5 to 43,200.
Use the voice vlan aging command to set the aging time for a voice VLAN.
Use the undo voice vlan aging command to restore the default value.
By default, the aging time for a voice VLAN is 1,440 minites.
Example
# Set the aging time of the voice VLAN to 100 minutes.
<H3C> system-view
[H3C] voice vlan aging 100
1.1.7  voice vlan enable
voice vlan enable
View
Ethernet port view
Parameter
None
Use the voice vlan enable command to enable voice VLAN on a port.
Use the undo voice vlan enable command to disable voice VLAN on a port.
The voice VLAN function takes effect on a port only when it is enabled in both system view and port view. Note that the operation to enable the voice VLAN function for a port is independent of that to enable the function globally, which means you may first enable the function on a port and then enable it globally.
Example
# Enable the voice VLAN function on Ethernet1/0/2.
<H3C> system-view
[H3C] interface Ethernet 1/0/2
[H3C-Ethernet1/0/2] voice vlan enable
1.1.8  voice vlan mac-address
voice vlan mac-address oui mask oui-mask [ description text ]
undo voice vlan mac-address oui
View
Parameter
oui: MAC address, in the format of H-H-H.
oui-mask: MAC address valid length, indicated by a mask in the format of H-H-H.
text: Description string of the MAC address, containing 1 to 30 characters.
Use the voice vlan mac-address command to set a MAC address used by a voice VLAN to identify a voice device.
Use the undo voice vlan mac-address command to cancel the configuration.
The maximum number of MAC addresses can be identified by the OUI address system is 16. If the number increases, the system processes no more. After a switch starts, there are five default OUI addresses.
Table 1-2 Default OUI addresses of a switch
Number
OUI addresses
Vendor
1
0003-6b00-0000
Cisco phone
2
000f-e200-0000
H3C Aolynk phone
3
00d0-1e00-0000
Pingtel phone
4
00e0-7500-0000
Polycom phone
5
00e0-bb00-0000
3Com phone
Related command: display voice vlan oui.
Example
# Set 00aa-bb00-0000 as an OUI address, with the description string being “ABC”.
<H3C> system-view
[H3C] voice vlan mac-address 00aa-bb00-0000 mask ffff-ff00-0000 description ABC
1.1.9  voice vlan mode
voice vlan mode auto
undo voice vlan mode auto
View
Ethernet port view
Parameter
None
Use the voice vlan mode auto command to configure the voice VLAN operation mode on an Ethernet port to automatic.
Use the undo voice vlan mode auto command to configure the voice VLAN operation mode on an Ethernet port to manual.
By default, the voice VLAN operation mode on an Ethernet port is automatic.
Example
# Configure the voice VLAN operation mode on Ethernet1/0/2 to manual.
<H3C> system-view
[H3C-Ethernet1/0/2] undo voice vlan mode auto
1.1.10  voice vlan security enable
undo voice vlan security enable
View
Parameter
None
Use the voice vlan security enable command to enable the voice VLAN security mode.
Use the undo voice vlan security enable command to disable the voice VLAN security mode.
In security mode, the ports in a voice VLAN and with voice devices attached to can only forward voice data. Data packets with their MAC addresses not among the OUI addresses that can be identified by the system will be filtered out. This mode has no effects on other VLANs.
By default, the voice VLAN security mode is enabled.
Example
# Disable the voice VLAN security mode.
<H3C> system-view
[H3C] undo voice vlan security enable
