H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesS3600 SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
33-SNMP-RMON Command
33-SNMP-RMON Command 218 KB
Chapter 1  SNMP Configuration Commands
1.1  SNMP Configuration Commands
1.1.1  display snmp-agent
display snmp-agent { local-engineid | remote-engineid }
View
Parameter
local-engineid: Displays the local SNMP entity Engine ID.
remote-engineid: Displays all the remote SNMP entity Engine IDs.
Use the display snmp-agent command to display the local SNMP entity engine ID or all the remote SNMP entity engine IDs.
An SNMP engine ID identifies an SNMP entity uniquely within an SNMP domain. As an indispensable part of an SNMP entity, an SNMP engine performs the function of sending, receiving and authenticating SNMP messages, extracting PDUs, packet assembling and the communication with SNMP applications.
Example
# Display the local SNMP entity engine ID.
<H3C> display snmp-agent local-engineid
SNMP local EngineID: 800007DB000FE20F12346877
SNMP local EngineID in the above information represents the local SNMP entity engine ID.
1.1.2  display snmp-agent community
View
Parameter
read: Displays the information about the SNMP communities with read-only permission.
write: Displays the information about the SNMP communities with read-write permission.
Use the display snmp-agent community command to display the information about the SNMPv1/SNMPv2C communities with the specific access permission.
If you specify no keyword when executing this command, the information about all the existing SNMPv1/SNMPv2C communities is displayed.
Example
# Display the information about all the existing SNMPv1/SNMPv2c communities.
<H3C> display snmp-agent community
   Community name:public
       Group name:public
       Storage-type: nonVolatile
   Community name:private
       Group name:private
Table 1-1 Description on the fields of the display snmp-agent community command
Community name
Community name
Group name
Group name
Storage-type
Storage type, which can be “volatile”, “nonVolatile”, “permanent”, “readOnly”, and “other”.
1.1.3  display snmp-agent group
display snmp-agent group [ group-name ]
View
Parameter
group-name: Name of the desired SNMP group, a string of 1 to 32 characters.
Use the display snmp-agent group command to display the information about a SNMP group, including group name, security mode, states of various views, and storage mode.
If you do not specify the group-name argument, this command displays the information about all the existing SNMP groups.
Example
# Display the information about all the SNMP groups.
<H3C> display snmp-agent group
   Group name: v3r2
       Security model: v3 noAuthnoPriv
       Readview: ViewDefault
       Writeview: <no specified>
       Notifyview :<no specified>
       Storage-type: nonvolatile
Table 1-2 Description on the fields of the display snmp-agent group command
Group name
SNMP group name of the user
Security model
SNMP group security mode, which can be “AuthPriv” (authorization and encryption), “AuthnoPriv” (authorization and no encryption), and “noAuthnoPriv” (no authorization and no encryption).
Readview
Read-only MIB view corresponding to the SNMP group
Writeview
Writable MIB view corresponding to the SNMP group
Notifyview
Notify MIB view corresponding to the SNMP group
storage-type
1.1.4  display snmp-agent mib-view
display snmp-agent mib-view [ exclude | include | viewname view-name ]
View
Parameter
exclude: Specifies the SNMP MIB views that are of the excluded type.
Include: Specifies the SNMP MIB views that are of the included type.
view-name: Name of an SNMP MIB view.
Use the display snmp-agent mib-view command to display the MIB view configuration of the current Ethernet switch.
If you specify no keyword when executing this command, the configuration of all the MIB views is displayed.
Example
# Display the information about the currently configured MIB view.
<H3C> display snmp-agent mib-view
   View name:ViewDefault
       MIB Subtree:internet
       Subtree mask:
       View Type:included
       View status:active
       MIB Subtree:snmpUsmMIB
       Subtree mask:
       View Type:excluded
       View status:active
       MIB Subtree:snmpVacmMIB
       Subtree mask:
       View Type:excluded
       View status:active
       MIB Subtree:snmpModules.18
       Subtree mask:
       View Type:excluded
       View status:active
1.1.5  display snmp-agent statistics
View
Parameter
None
Use the display snmp-agent statistics command to display the statistics on SNMP packets.
Example
# Display the statistics on SNMP packets.
<H3C> display snmp-agent statistics
  1276 Messages delivered to the SNMP entity
  0 Messages which were for an unsupported version
  0 Messages which used a SNMP community name not known
  0 Messages which represented an illegal operation for the community supplied
  0 ASN.1 or BER errors in the process of decoding
  1291 Messages passed from the SNMP entity
  0 SNMP PDUs which had badValue error-status
  0 SNMP PDUs which had genErr error-status
  7 SNMP PDUs which had noSuchName error-status
  0 SNMP PDUs which had tooBig error-status (Maximum packet size 1500)
  3669 MIB objects retrieved successfully
  26 MIB objects altered successfully
  420 GetRequest-PDU accepted and processed
  832 GetNextRequest-PDU accepted and processed
  0 GetBulkRequest-PDU accepted and processed
  1276 GetResponse-PDU accepted and processed
  24 SetRequest-PDU accepted and processed
  15 Trap PDUs accepted and processed
  0 Alternate Response Class PDUs droped silently
  0 Forwarded Confirmed Class PDUs droped silently
1.1.6  display snmp-agent sys-info
display snmp-agent sys-info [ contact | location | version ]*
View
Parameter
contact: Displays the contact information of the current device.
location: Displays the physical location of the current device.
version: Displays the version information about the SNMP running in the system.
Use the display snmp-agent sys-info command to display the system SNMP information about the current device.
This command displays all the system SNMP information if you execute it with no keyword specified.
Example
# Display the system SNMP information about the device.
<H3C> display snmp-agent sys-info
   The contact person for this managed node:
           R&D Hangzhou, H3C Technologies Co.,Ltd.
   The physical location of this node:
           Hangzhou China
   SNMP version running in the system:
           SNMPv1 SNMPv2c SNMPv3
1.1.7  display snmp-agent trap-list
View
Parameter
None
Use the display snmp-agent trap-list command to display the states of the Traps.
Related command: snmp-agent trap enable.
Example
# Display the states of the Traps.
<H3C> display snmp-agent trap-list
   configuration trap enable
   flash trap enable
   ospf trap enable
   standard trap enable
   system trap enable
   vrrp trap disable
   Enable traps :5; Disable traps 1
1.1.8  display snmp-agent usm-user
display snmp-agent usm-user [ engineid engineid | username user-name | group group-name ]*
View
Parameter
engineid: Engine ID, a string comprising of 10 to 64 hexadecimal digits.
user-name: SNMPv3 user name, a string comprising of 1 to 32 characters.
group-name: Name of an SNMP group, a string comprising of 1 to 32 characters.
Use the display snmp-agent usm-user command to display the information about a specific type of SNMP users.
If you execute this command with no keyword specified, the information about all the SNMP users is displayed.
Example
# Display the information about all the SNMP users.
<H3C> display snmp-agent usm-user
   User name: usm-user
   Group name: usm-group
       Engine ID: 800007DB000FE20F12346877
       UserStatus: active
Table 1-3 Description on the fields of the display snmp-agent usm-user command
User name
SNMP user name
Group name
The name of the SNMP group which the SNMP user belongs to
Engine ID
SNMP engine ID of the device
Storage-type
UserStatus
SNMP user status
1.1.9  enable snmp trap updown
undo enable snmp trap updown
View
Ethernet port view, interface view
Parameter
None
Use the enable snmp trap updown command to enable the sending of port/interface Link Up and Link Down traps.
Use the undo enable snmp trap updown command to disable the sending of Link Up and Link Down traps.
By default, the sending of port/interface Link Up and Link Down traps is enabled.
The enable snmp trap updown command need to be coupled with the snmp-agent target-host command. You can use the snmp-agent target-host command to specify the hosts that can receive Trap messages. To enable the sending of Trap messages, you need to specify at least one host that is to receive the Trap messages using the snmp-agent target-host command.
Example
# Enable the port Ethernet 1/0/1 to send Link Up and Link Down SNMP Trap massages to the NMS whose IP address is 10.1.1.1 using the community name “public”.
<H3C> system-view
[H3C] snmp-agent trap enable
[H3C] snmp-agent target-host trap address udp-domain 10.1.1.1 params securityname public
[H3C] interface Ethernet1/0/1
[H3C-Ethernet1/0/1] enable snmp trap updown
1.1.10  snmp-agent
snmp-agent
undo snmp-agent
View
Parameter
None
Use the snmp-agent command to enable the SNMP agent.
Use the undo snmp-agent command to disable the SNMP agent.
By default, the SNMP agent is disabled.
Example
# Disable the SNMP agent (assuming that the SNMP agent is currently enabled).
<H3C> system-view
[H3C] undo snmp-agent
&  Note:
An S3600 Ethernet switch acts as the following to prevent attacks through unused sockets.
l      Opening UDP port 161 (which is used by SNMP agents) and UDP port 1024 (which is used by SNMP-trap clients) only when SNMP is enabled.
l      Closing UDP port 161 and UDP port 1024 when SNMP is disabled.
This function is achieved in the following way.
l      Executing the snmp-agent command or any of the commands used to configure the SNMP agent causes the SNMP agent being enabled and UDP port 161 and UDP port 1024 being opened.
l      Executing the undo snmp-agent command causes UDP port 161 and UDP port 1024 being closed as well.
1.1.11  snmp-agent community
snmp-agent community { read | write } community-name [ [ acl acl-number ] [ mib-view view-name ] ]*
undo snmp-agent community community-name
View
Parameter
read: Specifies that the community to be created has read-only permission to MIB objects. Communities of this type can only query MIBs for device information.
write: Specifies that the community to be created has read-write permission to MIB objects. Communities of this type are capable of configuring devices.
community-name: Name of the community to be created, a string of 1 to 32 characters.
view-name: MIB view name, a string of 1 to 32 characters.
acl-number: ID of the ACL to be applied to the community, in the range 2000 to 2999.
Use the snmp-agent community command to create an SNMP community for accessing MIB objects.
Use the undo snmp-agent community command to remove an SNMP community.
Example
# Create an SNMP community named “comaccess”, which has read-only permission to MIB objects.
<H3C> system-view
[H3C] snmp-agent community read comaccess
# Create an SNMP community named “mgr”, which has read-write permission to MIB objects
[H3C] snmp-agent community write mgr
# Remove the community named “comaccess”.
[H3C] undo snmp-agent community comaccess
1.1.12  snmp-agent group
1)         Version 1 and version 2C
snmp-agent group { v1 | v2c } group-name [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
undo snmp-agent group { v1 | v2c } group-name
2)         Version 3
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
undo snmp-agent group v3 group-name [ authentication | privacy ]
View
Parameter
v1: Specifies SNMPv1.
v2c: Specifies SNMPv2C.
v3: Specifies SNMPv3.
group-name: Name of the SNMP group to be created, a string of 1 to 32 characters.
authentication: Configures to authenticate but do not encrypt the packets.
privacy: Configures to authenticate and encrypt the packets.
read-view: Read-only view name, a string of 1 to 32 characters.
write-view: Read-write view name, a string of 1 to 32 characters.
notify-view: Notification view name, a string of 1 to 32 characters.
acl-number: ID of a basic ACL, in the range 2000 to 2999.
Use the snmp-agent group command to create an SNMP group to map SNMP users to the corresponding SNMP views.
Use the undo snmp-agent group command to remove an SNMP group.
By default, the SNMP groups created using the snmp-agent group v3 command do not authenticate or encrypt packets.
Related command: snmp-agent mib-view, snmp-agent usm-user.
Example
# Create an SNMPv3 group named “group1”.
<H3C> system-view
[H3C] snmp-agent group v3 group1
1.1.13  snmp-agent local-engineid
undo snmp-agent local-engineid
View
Parameter
engineid: Engine ID to be set, a string comprising of 10 to 64 hexadecimal digits.
Use the snmp-agent local-engineid command to set an engine ID for the local SNMP entity.
Use the undo snmp-agent local-engineid command to restore the default engine ID.
By default, the engine ID of an SNMP entity is formed by appending the device information to the enterprise number. The device information can be determined according to the device, which can be an IP address, a MAC address, or a user-defined string comprising of hexadecimal digits.
Related command: snmp-agent usm-user.
Example
# Set the local SNMP entity engine ID to 123456789A.
<H3C> system-view
[H3C] snmp-agent local-engineid 123456789A
1.1.14  snmp-agent log
snmp-agent log { set-operation | get-operation | all }
undo snmp-agent log { set-operation | get-operation | all }
View
Parameter
set-operation: Logs the set operations.
get-operation: Logs the get operations.
all: Logs both the set operations and get operations.
Use the snmp-agent log command to enable network management operation logging.
Use the undo snmp-agent log command to disable network management operation logging.
By default, network management operation logging is disabled.
&  Note:
l      In the environment of a single device, use the display logbuffer command to view the log of the get and set operations performed on the NMS.
l      In the fabric environment, use the display logbuffer command on the master device to view the log of the set operations. Use the display logbuffer command on the devices receiving the get messages to view the log of the get operations performed on the NMS.
Example
# Enable logging for both the get and the set operations performed on the NMS.
<H3C> system-view
[H3C] snmp-agent log all
1.1.15  snmp-agent mib-view
snmp-agent mib-view { included | excluded } view-name oid-tree
undo snmp-agent mib-view view-name
View
Parameter
view-name: View name.
oid-tree: OID MIB subtree of a MIB object subtree. It can be the ID of a node in OID MIB subtree (such as 1.4.5.3.1) or an OID (such as “system”). This argument can contain wildcards (such as 1.4.5.*.*.1).
included: Includes this MIB subtree.
excluded: Excludes this MIB subtree.
Use snmp-agent mib-view command to create or update the information about a MIB view to limit the MIB objects the NMS can access.
Use the undo snmp-agent mib-view command to cancel the current setting.
By default, the view name is “ViewDefault” and the OID is 1.
Related command: snmp-agent group.
Example
# Create an SNMP MIB view that contain all the objects of the MIB subtree mib2 (assuming that the corresponding OID is 1.3.6.1.2.1).
<H3C> system-view
[H3C] snmp-agent mib-view included mib2 1.3.6.1.2.1
1.1.16  snmp-agent packet max-size
undo snmp-agent packet max-size
View
Parameter
byte-count: Maximum SNMP packet size (in bytes) to be set, ranging from 484 to 17,940.
Use the snmp-agent packet max-size command to set the maximum SNMP packet size allowed by an agent.
Use undo snmp-agent packet max-size command to restore the default maximum SNMP packet size.
 By default, the maximum SNMP packet size allowed by an agent is 1,500 bytes.
Example
# Set the maximum SNMP packet size allowed by the agent to 1,042 bytes.
<H3C> system-view
[H3C] snmp-agent packet max-size 1042
1.1.17  snmp-agent sys-info
snmp-agent sys-info { contact sys-contact | location sys-location | version { { v1 | v2c | v3 }* | all } }
undo snmp-agent sys-info { contact | location | version { { v1 | v2c | v3 }* | all } }
View
Parameter
sys-contact: Contact information for system maintenance.
sys-location: Geographical location of the device.
version: Specifies the SNMP version to be employed.
all: Specifies all the SNMP versions available, that is, SNMPv1, SNMPv2C, and SNMPv3.
Use the snmp-agent sys-info command to set the system information, including geographical location of the device, contact information for system maintenance, and the SNMP version employed.
Use the undo snmp-agent sys-info location command to restore the default settings.
If the device fails, you can contact the device manufacturer according to the system information.
By default, the contact information of an S3600 Ethernet switch is "R&D Hangzhou, H3C Technologies Co.,Ltd.", the geographical location is "Hangzhou China", the SNMP version employed is SNMPv3.
Related command: display snmp-agent sys-info.
Example
# Set the contact information for system maintenance as “Dial System Operator # 1234”.
<H3C> system-view
[H3C] snmp-agent sys-info contact Dial System Operator # 1234
1.1.18  snmp-agent target-host
snmp-agent target-host trap address udp-domain { ip-address } [ udp-port port-number ] params securityname security-string [ v1 | v2c | v3 [authentication | privacy ] ]
undo snmp-agent target-host ip-address securityname security-string
View
Parameter
trap: Enables the host to receive SNMP Traps.
address: Specifies the destination for the SNMP Traps.
udp-domain: Specifies to use UDP to communicate with the target host.
ip-address: The IPv4 address of the host that is to receive the Traps.
port-number: Number of the port that is to receive the Traps.
params: Specifies SNMP target host information to be used in the generation of SNMP Traps.
security-string: SNMPv1/SNMPv2C community name or SNMPv3 user name, a string of 1 to 32 characters.
authentication: Configures to authenticate the packets without encryption.
Use snmp-agent target-host command to configure a destination for the SNMP Traps generated by the local device.
Use undo snmp-agent target-host command to cancel the current setting.
To enable a device to send SNMP Traps, the snmp-agent target-host command need to be coupled with a command among the snmp-agent trap enable command and the enable snmp trap updown command.
1)         Use the snmp-agent trap enable or enable snmp trap updown command to specify the types of the SNMP Traps a device can send (By default, a device can send all types of SNMP Traps).
2)         Use the snmp-agent target-host command to set the address of the destination for the SNMP Traps.
Related command: snmp-agent trap enable, snmp-agent trap source, and snmp-agent trap life.
Example
# Enable sending SNMP Traps to 10.1.1.1, setting the community name as “public”.
<H3C> system-view
[H3C] snmp-agent trap enable standard
1.1.19  snmp-agent trap enable
snmp-agent trap enable [ configuration | flash | ospf [ process-id ] [ ospf-trap-list ] | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
undo snmp-agent trap enable [ configuration | flash | ospf [ process-id ] [ ospf-trap-list ] | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
View
Parameter
configuration: Configures to send configuration Traps.
flash: Configures to send Flash Traps.
ospf [ process-id ] [ ospf-trap-list ]: Configures to send OSPF Traps. The process-id argument is a process ID. The ospf-trap-list argument indicates a list of Traps to be sent.
standard: Configures to send SNMP standard notification or Traps.
authentication: Sends SNMP authentication failure Traps in cases of authentication failures.
coldstart: Configures to send SNMP cold start Traps when the device is rebooted.
linkdown: Configures to send SNMP LinkDown Traps when a port becomes down.
linkup: Configures to send SNMP LinkUp Traps when a port becomes up.
warmstart: Configures to send SNMP warm start Traps when SNMP is newly launched.
system: Configures to send system management MIB (proprietary MIB) Traps.
vrrp [ authfailure | newmaster ]: Configures to send VRRP Traps.
Use the snmp-agent trap enable command to enable a device to send SNMP Traps that are of specified types.
Use the undo snmp-agent trap enable command to disable a device from sending SNMP Traps that are of specified types.
By default, a device sends all types of SNMP Traps.
The snmp-agent trap enable command need to be coupled with the snmp-agent target-host command. The snmp-agent target-host command specifies the destination hosts for SNMP Traps. At least one destination host is required for SNMP Traps.
Example
# Enable sending of SNMP authentication failure Traps, with the destination IP address being 10.1.1.1 and the community name being “public”.
<H3C> system-view
[H3C] snmp-agent trap enable authentication
1.1.20  snmp-agent trap life
snmp-agent trap life seconds
undo snmp-agent trap life
View
Parameter
seconds: SNMP Trap aging time (in seconds) to be set, ranging from 1 to 2,592,000.
Use the snmp-agent trap life command to set the SNMP Trap aging time. SNMP Traps exceeding the aging time will be discarded.
Use the undo snmp-agent trap life command to restore the default SNMP Trap aging time.
By default, the SNMP Trap aging time is 120 seconds.
Related command: snmp-agent trap enable, snmp-agent target-host.
Example
# Set the SNMP Trap aging time as 60 seconds.
<H3C> system-view
[H3C] snmp-agent trap life 60
1.1.21  snmp-agent trap queue-size
undo snmp-agent trap queue-size
View
Parameter
size: Length of an SNMP Trap queue (that is, the maximum number of Traps the queue can contain), an integer ranging from 1 to 1,000.
Use the snmp-agent trap queue-size command to set the length of the queue of the SNMP Traps to be sent to the destination.
Use the undo snmp-agent trap queue-size command to restore the default queue length.
By default, an SNMP Trap queue can contain up to 100 SNMP Traps.
Related command: snmp-agent trap enable, snmp-agent target-host, and snmp-agent trap life.
Example
# Set the SNMP Trap queue length to 200.
<H3C> system-view
[H3C] snmp-agent trap queue-size 200
1.1.22  snmp-agent trap source
snmp-agent trap source interface-type interface-number
undo snmp-agent trap source
View
Parameter
nterface-type: Interface type.
interface-number: Interface number.
Use the snmp-agent trap source command to configure the source address for the SNMP Traps sent.
Use the undo snmp-agent trap source command to cancel the configuration.
SNMP Traps sent by a server share the same source IP address regardless of the interfaces through which they are sent. You can use the snmp-agent trap source command to specify the source IP address.
By default, the outbound interface is determined by SNMP.
You can configure this command to track a specific event by the source addresses of SNMP Traps.
&  Note:
Before configuring an interface to be the source interface for the SNMP traps sent, make sure the interface is assigned an IP address.
Example
# Configure VLAN-interface 1 as the source interface for the SNMP Traps sent.
<H3C> system-view
[H3C] snmp-agent trap source Vlan-interface 1
1.1.23  snmp-agent usm-user
1)         SNMPv1 and SNMPv2C
snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number ]
undo snmp-agent usm-user { v1 | v2c } user-name group-name
2)         SNMPv3
snmp-agent usm-user v3 user-name group-name [ authentication-mode { md5 | sha } auth-password [ privacy-mode des56 priv-password ] ] [ acl acl-number ]
undo snmp-agent usm-user v3 user-name group-name { local | engineid engineid-string }
View
Parameter
v1: Configures to use SNMPv1 security mode.
v2c: Configures to use SNMPv2C security mode.
v3: Configures to use SNMPv3 security mode.
user-name: Name of the user to be added, a string of 1 to 32 characters.
group-name: Name of the group corresponding to the user, a string of 1 to 32 characters.
authentication-mode: Specifies the safety level as authentication required. If you do not specify this keyword, neither authentication nor encryption is performed.
md5: Uses HMAC MD5 algorithm for authentication.
sha: Uses HMAC SHA algorithm for authentication.
auth-password: Authentication password, a string of 1 to 64 characters.
privacy-mode: Specifies the security level as encrypted.
des56: Specifies the encryption protocol as data encryption standard (DES).
priv-password: Encryption password, a string of 1 to 64 characters.
local: Specifies a local entity user.
engineid-string: Engine ID associated with the user, a string comprising of 10 to 64 hexadecimal digits.
Use the snmp-agent usm-user command to add a user to an SNMP group.
Use the undo snmp-agent usm-user command to remove a user from an SNMP group.
While using SNMPv3, SNMP engine ID (for authentication) is required when you configure a remote user for an agent. If you change the engine ID after configuring a user, the user corresponding to the original engine ID becomes invalid.
For SNMPv1 and SNMPv2C, the snmp-agent usm-user command creates a new community. For SNMPv3, the command adds a user to an SNMP group.
Related command: snmp-agent group, snmp-agent community, and snmp-agent local-engineid.
Example
# Add a user named “John” to the SNMPv3 group named “Johngroup”. And set:
l           security to the level of needing authentication and encryption
l           authentication protocol to HMAC-MD5
l           authentication password to hello
l           encryption protocol to DES
l           encryption password to cfb128cfb128
<H3C> system-view
[H3C] snmp-agent group v3 Johngroup privacy
[H3C] snmp-agent usm-user v3 John Johngroup authentication-mode md5 hello privacy-mode des56 cfb128cfb128
Chapter 2  RMON Configuration Commands
2.1  RMON Configuration Commands
2.1.1  display rmon alarm
display rmon alarm [ entry-number ]
View
Parameter
entry-number: Alarm entry index, in the range 1 to 65535.
Use the display rmon alarm command to display the configuration of a specified alarm entry or all the alarm entries. If you do not specify the entry-number argument, the configuration of all the alarm entries is displayed.
Related command: rmon alarm.
Example
# Display the configuration of all the alarm entries.
<H3C> display rmon alarm
Alarm table 1 owned by user1 is Valid.
  Samples type          : absolute
  Variable formula      : 1.3.6.1.2.1.2.2.1.10.4228009<ifInOctets.4228009>
  Sampling interval     : 6(sec)
  Rising threshold      : 10000(linked with event 1)
  Falling threshold     : 2000(linked with event 1)
  When startup enables  : risingOrFallingAlarm
  Latest value          : 0
Table 2-1 Description on the fields of the display rmon alarm command
Alarm table
Index of an entry in the alarm entry
user1
Entry owner: user1
Valid
The alarm entry identified by the index is valid.
Samples type
Sample type: increment or absolute value
Variable formula
Variable form of the sampled node
Sampling interval
Sampling interval
Rising threshold
Rising threshold
Falling threshold
Falling threshold
The condition under which an alarm is triggered, which can be:
l      risingOrFallingAlarm: An alarm is triggered when the rising or falling threshold is reached.
l      risingAlarm: An alarm is triggered when the rising threshold is reached.
l      FallingAlarm: An alarm is triggered when the falling threshold is reached.
Latest value
The value of the latest sample
2.1.2  display rmon event
display rmon event [ event-entry ]
View
Parameter
event-entry: RMON event entry index, in the range 1 to 65535.
Use the display rmon event command to display the configuration of a specified RMON event entry. If you do not specify the event-entry argument, the configuration of all the RMON event entries is displayed.
This command displays the following information:
l           Event entry index
l           Event entry owner
l           Event description
l           The action triggered by the event (log or alarm messages)
l           The time (in seconds) when the latest event is triggered (in terms of the time elapsed since the system is started/initialized).
Related command: rmon event.
Example
# Display the configuration of all the RMON event entries.
<H3C> display rmon event
Event table 1 owned by user1 is VALID.
  Description: null.
  Will cause log-trap when triggered, last triggered at 0days 00h:02m:27s.
Table 2-2 Description on the fields of the display rmon event command
Event table
Index of an entry in the RMON event table
VALID
The status of the entry identified by the index is valid.
RMON event description
The event triggers logging and an alarm trap.
last triggered at
Time the latest event is triggered
2.1.3  display rmon eventlog
display rmon eventlog [ event-entry ]
View
Parameter
event-entry: RMON event entry index, in the range of 1 to 65535.
Use the display rmon eventlog command to display the log of an RMON event. If you do not specify the event-entry argument, the log of all the RMON events is displayed.
l           RMON event entry Index
l           Current RMON event entry status
l           The time (in seconds) when an event log is generated (in terms of the time elapsed since the system is started or initialized)
l           RMON event description.
Example
# Display the log generated by the event entry numbered 1.
<H3C> display rmon eventlog 1
Generates eventLog 1.1 at 0days 00h:01m:39s.
Description: The 1.3.6.1.2.1.16.1.1.1.4.1 defined in alarm table 1,
less than(or =) 100 with alarm value 0. Alarm sample type is absolute.
Generates eventLog 1.2 at 0days 00h:02m:27s.
Description: The alarm formula defined in private alarm table 1,
Table 2-3 Description on the fields of the display rmon eventlog command
Event table
VALID
Generates eventLog 1.1 at 0days 00h:02m:27s
Time when the event is triggered. The event can be triggered for multiple times. 1.1 indicates the time when event 1 is first triggered.
Description of the RMON event log
2.1.4  display rmon history
display rmon history [ interface-type interface-number | unit unit-number ]
View
Parameter
interface-type: Interface type.
unit unit-number: Specifies a unit number.
Use the display rmon history command to display the RMON history information about a specified port. The information about the latest sample, including bandwidth utilization, the number of errors, the total number of packets, and so on, is also displayed. If you do not provide the interface-type interface-number or unit-number argument, this command displays the RMON history information about all the ports/units.
Related command: rmon history.
Example
# Display the RMON history information about Ethernet1/0/1.
<H3C> display rmon history Ethernet 1/0/1
History control entry 1 owned by user1 is VALID
  Samples interface     : Ethernet1/0/1<ifIndex.4227817>
  Sampling interval     : 5(sec) with 10 buckets max
  Latest sampled values :
  dropevents        : 0         , octets               : 0
  packets           : 0         , broadcast packets    : 0
  multicast packets : 0         , CRC alignment errors : 0
  undersize packets : 0         , oversize packets     : 0
  fragments         : 0         , jabbers              : 0
  collisions        : 0         , utilization          : 0
Table 2-4 Description on the fields of the display rmon history command
Index of an entry in the history control table
VALID
Samples interface
Sampled interface
Sampling interval
Sampling interval
buckets
Number of the records in the history control table
dropevents
Number of the packet-dropping events
octets
Number of the received/transmitted bytes during sampling duration
packets
Number of the received/transmitted packets during sampling duration
broadcastpackets
Number of the broadcast packets
multicastpackets
Number of the multicast packets
Number of the packet with CRC errors
undersize packets
Number of the undersize packets
oversize packets
Number of the oversize packets
fragments
Number of the undersize packets with CRC errors
jabbers
Number of the oversize packets with CRC errors
collisions
Number of the packets that cause collisions
utilization
Bandwidth utilization
2.1.5  display rmon prialarm
display rmon prialarm [ prialarm-entry-number ]
View
Parameter
prialarm-entry-number: Extended alarm entry Index, in the range of 1 to 65535.
Use the display rmon prialarm command to display the configuration of a RMON extended alarm entry. If you do not specify the prialarm-entry-number argument, the configuration of all the extended alarm entries is displayed.
Related command: rmon prialarm.
Example
# Display the configuration of all the extended RMON alarm entries.
<H3C> display rmon prialarm
Prialarm table 1 owned by user1 is VALID.
  Variable formula      : .1.3.6.1.2.1.16.1.1.1.4.1
  Description           :
  Sampling interval     : 10(sec)
  This entry will exist : forever.
  Latest value          : 0
Table 2-5 Description on the fields of the display rmon prialarm command
Prialarm table
Index of an entry in the extended alarm table
owned by user1
Entry owner: user 1
VALID
Samples type
Variable formula
Sampling interval
Sampling interval
Rising threshold
Rising threshold
Falling threshold
Falling threshold
Linked with event
Event index corresponding to an alarm
When startup enables: risingOrFallingAlarm
This entry will exist: forever
Existing period. This entry can exist forever or exist in the specified cycle
Latest value
2.1.6  display rmon statistics
display rmon statistics [ interface-type interface-number | unit unit-number ]
View
Parameter
Use the display rmon statistics command to display the RMON statistics on a specified port or a specified unit. If you do not specify the port or the unit, this command displays the RMON statistics on all the ports or units.
The information displayed includes the number of:
l           Collisions
l           Packets with CRC errors
l           Undersize/Oversize packets
l           Broadcast/multicast packets
l           Received bytes
l           Received packets
Related command: rmon statistics.
Example
# Display the RMON statistics on Ethernet1/0/1 port.
<H3C> display rmon statistics Ethernet 1/0/1
Statistics entry 1 owned by user1-rmon is VALID.
  Interface : Ethernet1/0/1<ifIndex.4227817>
  etherStatsOctets         : 0         , etherStatsPkts          : 0
  etherStatsBroadcastPkts  : 0         , etherStatsMulticastPkts : 0
  etherStatsUndersizePkts  : 0         , etherStatsOversizePkts  : 0
  etherStatsFragments      : 0         , etherStatsJabbers       : 0
  etherStatsCRCAlignErrors : 0         , etherStatsCollisions    : 0
  etherStatsDropEvents (insufficient resources): 0
  Packets received according to length:
  64     : 0         ,  65-127  : 0         ,  128-255  : 0
  256-511: 0         ,  512-1023: 0         ,  1024-1518: 0
Table 2-6 Description on the fields of the display rmon statistics command
Statistics entry
Index of the statistics information entry
VALID
The statistics table is valid.
Interface which the statistics is on
etherStatsOctets
Number of bytes received
etherStatsPkts
Number of the packets received
Number of broadcast packets received
Number of multicast packets received
Number of undersize packets received
Number of oversize packets received
etherStatsFragments
Number of undersize packets received with CRC errors
etherStatsJabbers
Number of oversize packets received with CRC errors
Number of packets received with CRC errors
Number of the received packets that cause collisions
Event about dropping packets
Number of the received packets that are of different lengths
2.1.7  rmon alarm
rmon alarm entry-number alarm-variable sampling-time { delta | absolute } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 [ owner text ]
undo rmon alarm entry-number
View
Parameter
entry-number: Index of the alarm entry to be added/removed, in the range 1 to 65535.
alarm-variable: Alarm variable, a string comprising 1 to 256 characters in dotted node OID format (such as 1.3.6.1.2.1.2.1.10.1). Only the variables that can be resolved to ASN.1 INTEGER data type (that is, INTEGER, Counter, Gauge, or TimeTicks) can be used as alarm variables.
sampling-time: Sampling interval (in seconds), in the range 5 to 65,535.
delta: Specifies to sample increments (that is, the current increment with regard to the latest sample)
absolute: Specifies to sample absolute values.
rising-threshold threshold-value1: Specifies the upper threshold. The threshold-value1 argument ranges from 0 to 2,147,483,647.
event-entry1: Index of the event entry corresponding to the upper threshold, in the range of 0 to 65535.
falling-threshold threshold-value2: Specifies the lower threshold. The threshold-value2 argument ranges from 0 to 2,147,483,647.
event-entry2: Index of the event entry corresponding to the lower threshold, in the range of 0 to 65535.
owner text: Specifies the owner of the entry, a string of 1 to 127 characters.
Use the rmon alarm command to add an alarm entry to the alarm table. If you do not specify the owner text keyword/argument combination, the owner of the entry is displayed as “null”.
Use the undo rmon alarm command to remove an alarm entry from the alarm table.
You can use the rmon alarm command to define an alarm entry so that a specific alarm event can be triggered under specific circumstances. The act (such as logging and sending Traps to NMS) taken after an alarm event occurs is determined by the corresponding alarm entry.
&  Note:
Before adding an alarm entry, make sure the events to be referenced in the alarm entry exist. Refer to the rmon event command for related information.
With an alarm entry defined in an alarm group, a network device performs the following operations accordingly:
l           Sample the defined alarm variables (alarm-variable) once in each specified period, which is specified by the sampling-time argument.
l           Comparing the sampled value with the set thresholds and performing the corresponding operations, as described in Table 2-7.
Table 2-7 Sample value and the corresponding operation
Comparison
Operation
The sample value is larger than or equal to the set upper threshold (threshold-value1)
Triggering the event identified by the event-entry1 argument
The sample value is smaller than the set lower threshold (threshold-value2)
Triggering the event identified by the event-entry2 argument
&  Note:
l      Before adding an alarm entry, you need to use the rmon event command to define the events to be referenced by the alarm entry.
l      Make sure the node to be monitored exists before executing the rmon alarm command.
Example
# Add the alarm entry numbered 1 as follows:
l           The node to be monitored: 1.3.6.1.2.1.16.1.1.1.4.1
l           Sampling interval: 10 seconds
l           Upper threshold: 50
l           The event-entry1 argument identifies event 1.
l           Lower threshold: 5
l           The event-entry2 argument identifies event 2
l           Owner: user1.
<H3C> system-view
[H3C] rmon event 1 log
[H3C] rmon event 2 none
[H3C] interface Ethernet 1/0/1
[H3C-Ethernet1/0/1] rmon statistics 1
[H3C-Ethernet1/0/1] quit
[H3C] rmon alarm 1 1.3.6.1.2.1.16.1.1.1.4.1 10 absolute rising-threshold 50 1 falling-threshold 5 2 owner user1
# Remove the alarm entry numbered 15 from the alarm table.
[H3C] undo rmon alarm 15
2.1.8  rmon event
rmon event event-entry [ description string ] { log | trap trap-community | log-trap log-trapcommunity | none } [ owner text ]
undo rmon event event-entry
View
Parameter
event-entry: Event entry index, in the range of 1 to 65535.
description string: Specifies the event description, a string of 1 to 127 characters.
log: Logs events.
trap: Sends Traps to the NMS.
trap-community: Community name of the NMS that receives the Traps, a string of 1 to 127 characters.
log-trap: Logs the event and sends Traps to NMS.
log-trapcommunity: Community name of the NMS that receives the Traps, a character string of 1 to 127 characters.
none: Specifies that the event triggers no action.
owner text: Specifies the owner of the event entry, a string of 1 to 127 characters.
Use the rmon event command to add an entry to the event table. If you do not specify the owner text keyword/argument combination, the owner of the entry is displayed as “null”.
Use the undo rmon event command to remove an entry from the event table.
When adding an event entry to an event table, you need to specify the event index. You need also to specify the corresponding actions, including logging the event, sending Traps to the NMS, and the both, for the network device to perform corresponding operation when an alarm referencing the event is triggered.
Example
# Add the event entry numbered 10 to the event table and configure it to be a log event.
<H3C> system-view
[H3C] rmon event 10 log
2.1.9  rmon history
rmon history entry-number buckets number interval sampling-interval [ owner text ]
undo rmon history entry-number
View
Ethernet port view
Parameter
entry-number: History entry index, in the range of 1 to 65535.
buckets number: Specifies the size of the history table that corresponds to the entry, in the range 1 to 65535 (The device supports 1 to 10 currently. If the input parameter is bigger than 10, the real size of the history table is 10).
interval sampling-interval: Specifies the sampling interval (in seconds). The sampling-interval argument ranges from 5 to 3,600.
Use the rmon history command to add an entry to the history control table. If you do not specify the owner text keyword/argument combination, the owner of the entry is displayed as “null”.
Use the undo rmon history command to remove an entry from the history control table.
You can use the rmon history command to sample a specific port. You can also set the sampling interval and the number of the samples that can be saved. After you execute this command, the RMON system samples the port periodically and stores the samples for later retrieval. The sampled information includes utilization, the number of errors, and total number of packets.
You can use the display rmon history command to display the statistics of the history control table.
Example
# Create the history control entry numbered 1 for Ethernet1/0/1 port, with the table size being 10, the sampling interval being 5 seconds, and the owner being “user1”.
<H3C> system-view
[H3C-Ethernet1/0/1] rmon history 1 buckets 10 interval 5 owner user1
# Remove the history control entry numbered 15.
[H3C-Ethernet1/0/1] undo rmon history 15
2.1.10  rmon prialarm
rmon prialarm entry-number prialarm-formula prialarm-des sampling-timer { delta | absolute | changeratio } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 entrytype { forever | cycle cycle-period } [ owner text ]
undo rmon prialarm entry-number
View
Parameter
entry-number: Extended alarm entry index, in the range of 1 to 65535.
prialarm-formula: Expression used to perform operations on the alarm variables, a string of 1 to 256 characters. The alarm variables in the expression must be represented by OIDs, for example, (.1.3.6.1.2.1.2.1.10.1)*8. The operations available are addition, subtraction, multiplication and division operations. The operation results are rounded to values that are of long integer type. To prevent invalid operation results, make sure the operation results of each step are valid long integers.
prialarm-des: Alarm description, a string of 1 to 128 characters.
sampling-timer: Sampling interval (in seconds), in the range of 10 to 65,535.
delta | absolute | changeratio: Specifies the sample type.
threshold-value1: Upper threshold, in the range of 0 to 2,147,483,647.
event-entry1: Index of the event entry that corresponds to the upper threshold, in the range of 0 to 65535.
threshold-value2: Lower threshold, in the range of 0 to 2,147,483,647.
event-entry2: Index of the event entry that corresponds to the lower threshold, in the range of 0 to 65535.
forever: Specifies the corresponding RMON alarm instance is valid permanently.
cycle: Specifies the corresponding RMON alarm instance is valid periodically.
cycle-period: Life time (in seconds) of the RMON alarm instance, in the range 0 to 2,147,483,647.
owner text: Specifies the owner of the alarm entry, a string of 1 to 127 characters.
Use the rmon prialarm command to create an extended entry in an extended RMON alarm table. If you do not specify the owner text keyword/argument combination, the owner of the entry is displayed as “null”.
Use the undo rmon prialarm command to remove an extended alarm entry.
&  Note:
l      Before adding an extended alarm entry, you need to use the rmon event command to define the events to be referenced by the entry.
l      Make sure the node to be monitored exists before executing the rmon event command.
l      You can define up to 50 extended alarm entries.
With an extended alarm entry defined in an extended alarm group, the device performs the following operations accordingly:
l           Sampling the alarm variables referenced in the defined extended alarm expression (prialarm-formula) once in each period specified by the sampling-timer argument.
l           Performing operations on the sampled values according to the defined extended alarm expression (prialarm-formula)
l           Comparing the operation result with the set thresholds and perform corresponding operations, as described in Table 2-8.
Table 2-8 Operation result and corresponding operation
Comparison
Operation
The operation result is larger than or equal to the set upper threshold (threshold-value1)
The operation result is smaller than or equal to the set lower threshold (threshold-value2)
Example
# Add the extended alarm entry numbered 2 as follows:
l           Perform operations on the corresponding alarm variables using the expression ((1.3.6.1.2.1.16.1.1.1.4.1)*100).
l           Event 1 is triggered when the change ratio is larger than the upper threshold.
l           Event 2 is triggered when the change ratio is less than the lower threshold.
l           The alarm entry is valid forever.
l           Entry owner: user1
<H3C> system-view
[H3C] rmon prialarm 2 ((.1.3.6.1.2.1.16.1.1.1.4.1)*100) test 10 changeratio rising-threshold 50 1 falling-threshold 5 2 entrytype forever owner user1
 # Remove the extended alarm entry numbered 2 from the extended alarm table.
[H3C] undo rmon prialarm 2
2.1.11  rmon statistics
rmon statistics entry-number [ owner text ]
undo rmon statistics entry-number
View
Ethernet port view
Parameter
entry-number: Statistics entry Index, in the range of 1 to 65535.
Use the rmon statistics command to add an entry to the statistics table. If you do not specify the owner text keyword/argument combination, the owner of the entry is displayed as “null”.
Use the undo rmon statistics command to remove an entry from the statistics table.
The RMON statistics management function is used to take statistics of the usage of the monitored ports and errors occurred on them. The statistics includes the number of the following items:
l           Collisions
l           Broadcast/Multicast packets
l           Received packets
l           Received bytes
&  Note:
For each port, only one RMON statistics entry can be created. That is, if an RMON statistics entry was already created for a given port, you will fail to create a statistics entry with a different index for the port.
You can use the display rmon statistics command to display the information about the statistics entry.
Example
# Add the statistics entry numbered 20 to take statistics of Ethernet1/0/1 port.
<H3C> system-view
[H3C-Ethernet1/0/1] rmon statistics 20
