Title | Size | Downloads |
About the S5500-SI Configuration Guides-books(CHM).rar | 5.49 MB | |
About the S5500-SI Configuration Guides-books_PDF.rar | 9.65 MB |
Click the links on the right to download all the configuration guides.
The S5500-SI configuration guides are part of the S5500-SI documentation set. They describe the software features for the S5500-SI Release 2202, and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply the software features to different network scenarios. The S5500-SI documentation set includes 9 configuration guides:
Configuration guide | Content |
Fundamentals Configuration Guide | Describes how to use the command line interface of the switch, log in to and set up the switch, and use the automatic configuration function. This guide includes: l CLI Configuration l Login Methods l CLI Login l Web Login l NMS Login l User Login Control l FTP Configuration l TFTP Configuration l File Management Configuration l Configuration File Management l Upgrading Software Configuration l Device Management Configuration l Automatic Configuration |
Layer 2 – LAN Switching Configuration Guide | Covers Layer 2 technologies and features used on a LAN switched network, such as VLAN technology, port isolation, MSTP. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN, re-mark VLAN tags, and so on. This guide includes: l Ethernet Interface Configuration l Loopback Interface and Null Interface Configuration l MAC Address Table Configuration l MAC Information Configuration" l Ethernet Link Aggregation Configuration l Port Isolation Configuration l MSTP Configuration l BPDU Tunneling Configuration l VLAN Configuration l Isolate-User-VLAN Configuration l Voice VLAN Configuration l GVRP Configuration l QinQ Configuration l LLDP Configuration |
Layer 3 – IP Services Configuration Guide | Describes IP address assignment, IP parameter adjustment, ARP, DNS, UDP Helper. This guide includes: l ARP Configuration l Proxy ARP Configuration l IP Addressing Configuration l DHCP Overview l DHCP Relay Agent Configuration l DHCP Client Configuration l DHCP Snooping Configuration l BOOTP Client Configuration l DNS Configuration l IP Performance Optimization Configuration l UDP Helper Configuration l IPv6 Basics Configuration l Dual Stack Configuration |
Layer 3 – IP Routing Configuration Guide | Covers the routing technologies for IPv4 and IPv6 networks of different sizes. This guide includes: l IP Routing Overview l Static Routing Configuration l RIP Configuration l IPv6 Static Routing Configuration l RIPng Configuration l Route Policy Configuration |
IP Multicast Configuration Guide | Describes Layer 2 multicast fundamentals and configuration. This guide includes: l Mulitcast Overview l IGMP Snooping Configuration l Multicast VLAN Configuration l MLD Snooping Configuration l IPv6 Multicast VLAN Configuration |
ACL and QoS Configuration Guide | Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. This guide includes: l ACL Configuration l QoS Overview l QoS Configuration Approaches l Priority Mapping Configuration l Traffic Policing, Traffic Shaping, and Line Rate Configuration l Congestion Management Configuration l Traffic Filtering Configuration l Priority Marking Configuration l Traffic Redirecting Configuration l Class-Based Accounting Configuration |
Security Configuration Guide | Covers security features. The major security features available on the switch include identity authentication (AAA and PKI), access security (802.1X, MAC authentication, portal, and port security), secure management (SSH), SSL, and attack protection (IP source guard, and ARP attack protection, MFF). This guide includes: l AAA Overview l AAA Configuration l AAA Configuration Examples l Troubleshooting AAA l 802.1X Configuration l 802.1X-Based EAD Fast Deployment Configuration l MAC Authentication Configuration l Port Security Configuration l User Profile Configuration l HABP Configuration l Public Key Configuration l PKI Configuration l SSH2.0 Configuration l SFTP Configuration l SSL Configuration l IP Source Guard Configuration l ARP Attack Protection Configuration |
High Availability Configuration Guide | Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes: l High Availability Overview l Ethernet OAM Configuration l CFD Configuration l DLDP Configuration l RRPP Configuration l Smart Link Configuration l Monitor Link Configuration l Track Configuration |
Network Management and Monitoring Configuration Guide | Describes features that help you manage and monitor your network, for example, manage system events, assess network performance, synchronize the clock for all devices with the clock in the network, supply power for attached devices by using PoE, perform cluster management for switches, and test network connectivity. This guide includes: l System Maintenance and Debugging l NQA Configuration l NTP Configuration l PoE Configuration l SNMP Configuration l MIB Style Configuration l RMON Configuration l Cluster Management Configuration l Stack Management Configuration l Port Mirroring Configuration l Traffic Mirroring Configuration l sFlow Configuration l Information Center Configuration |
