Title | Size | Downloads |
About the S5500-SI Command References-books(CHM).rar | 1.38 MB | |
About the S5500-SI Command References-books_PDF.rar | 3.87 MB |
Click the links on the right to download all the command references.
Command Reference | Content |
Fundamentals Command Reference | Covers the commands for logging in to and setting up the S5500-SI Ethernet Switch. This command reference includes: l CLI Configuration Commands l Logging In to the Switch Commands l FTP Commands l TFTP Commands l File Management Commands l Configuration File Management Commands l Upgrading Software Commands l Device Management Commands |
Layer 2 – LAN Switching Command Reference | Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes: l Ethernet Interface Configuration Commands l Loopback Interface and Null Interface Configuration Commands l MAC Address Table Configuration Commands l MAC Information Configuration Commands l Ethernet Link Aggregation Configuration Commands l Port Isolation Configuration Commands l MSTP Configuration Commands l BPDU Tunneling Configuration Commands l VLAN Configuration Commands l Isolate-User-VLAN Configuration Commands l Voice VLAN Configuration Commands l GVRP Configuration Commands l QinQ Configuration Commands l LLDP Configuration Commands |
Layer 3 – IP Services Command Reference | Covers the commands for configuring IP addresses, adjusting IP parameters, configuring ARP, DNS, and UDP Helper. This command reference includes: l ARP Configuration Commands l Proxy ARP Configuration Commands l IP Addressing Configuration Commands l DHCP Relay Agent Configuration Commands l DHCP Client Configuration Commands l DHCP Snooping Configuration Commands l BOOTP Client Configuration Commands l DNS Configuration Commands l IP Performance Optimization Configuration Commands l UDP Helper Configuration Commands l IPv6 Basics Configuration Commands |
Layer 3 – IP Routing Command Reference | Covers the routing configuration commands. This command reference includes: l IP Routing Table Commands l Static Routing Configuration Commands l RIP Configuration Commands l IPv6 Static Routing Configuration Commands l RIPng Configuration Commands l Route Policy Configuration Commands |
IP Multicast Command Reference | Covers the commands for configuring Layer 2 multicast services. This command reference includes: l IGMP Snooping Configuration Commands l Multicast VLAN Configuration Commands l MLD Snooping Configuration Commands l IPv6 Multicast VLAN Configuration Commands |
ACL and QoS Command Reference | Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS or hierarchical QoS (HQoS) technologies to improve network performance and network use efficiency. This command reference includes: l ACL Configuration Commands l QoS Policy Configuration Commands l Priority Mapping Configuration Commands l GTS and Line Rate Configuration Commands l Congestion Management Configuration Commands |
Security Command Reference | Covers security feature commands. Available security features include identity authentication (AAA), access security (802.1X, MAC authentication, and portal), secure management (SSH), SSL, and attack protection (IP source guard, and ARP attack protection). This command reference includes: l AAA Configuration Commands l RADIUS Configuration Commands l HWTACACS Configuration Commands l 802.1X Configuration Commands l 802.1X-Based EAD Fast Deployment Configuration Commands l MAC Authentication Configuration Commands l Port Security Configuration Commands l User Profile Configuration Commands l HABP Configuration Commands l Public Key Configuration Commands l PKI Configuration Commands l SSH2.0 Configuration Commands l SFTP Configuration Commands l SSL Configuration Commands l IP Source Guard Configuration Commands l ARP Attack Protection Configuration Commands |
High Availability Command Reference | Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes: l Ethernet OAM Configuration Commands l CFD Configuration Commands l DLDP Configuration Commands l RRPP Configuration Commands l Smart Link Configuration Commands l Monitor Link Configuration Commands l Track Configuration Commands |
Network Management and Monitoring Command Reference | Covers the commands that help you manage and monitor your network, for example, manage system events, assess network performance, synchronize the clock for all devices with the clock in the network, supply power for attached devices by using PoE, perform cluster management for switches, and test network connectivity. This command reference includes: l System Maintaining and Debugging Commands l NQA Configuration Commands l NTP Configuration Commands l PoE Configuration Commands l SNMP Configuration Commands l MIB Configuration Commands l RMON Configuration Commands l Cluster Management Configuration Commands l Stack Management Commands l Port Mirroring Configuration Commands l Traffic Mirroring Configuration Commands l sFlow Configuration Commands l Information Center Configuration Commands |
