Title | Size | Downloads |
Layer 3 - IP Services Command Reference-book.pdf | 609.66 KB |
Click the link on the right to download the complete book.
Preface
The H3C S5500-SI documentation set includes 9 command references, which describe the commands and command syntax options for the S5500-SI Release 2202.
The Layer 3 – IP Services Command Reference describes IP services configuration commands. It covers the commands for configuring IP addresses, adjusting IP parameters, resolving an IP address to a MAC address, configuring DNS, and relaying the IP broadcasts from the specified UDP port.
This preface includes:
l Audience
l About the H3C S5500-SI Documentation Set
Audience
This documentation set is intended for:
l Network planners
l Field technical support and servicing engineers
l Network administrators working with the S5500-SI series
Document Organization
The Layer 3 – IP Services Command Reference comprises these parts:
ARP Configuration Commands |
Proxy ARP Configuration Commands |
IP Addressing Configuration Commands |
DHCP Relay Agent Configuration Commands |
DHCP Client Configuration Commands |
DHCP Snooping Configuration Commands |
BOOTP Client Configuration Commands |
DNS Configuration Commands |
IP Performance Optimization Configuration Commands |
UDP Helper Configuration Commands |
IPv6 Basics Configuration Commands |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none. |
&<1-n> |
Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
Means a complementary description. |
The H3C S5500-SI documentation set also includes:
Category |
Documents |
Purposes |
Product description and specifications |
Describe product specifications and benefits. |
Provide an in-depth description of software features and technologies. |
Describes the appearances, features, and specifications of the RPS units available for the products. |
Provides the RPS and switch compatibility matrix and RPS cable specifications. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the models, appearances, and specifications of the pluggable modules available for the products. |
Describes the appearance and specifications of the interface card. |
Hardware installation |
Provides regulatory information and the safety instructions that must be followed during installation. Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration. |
Provides a complete guide to hardware installation and hardware specifications. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Guides you through installing SFP/SFP+/XFP transceiver modules. |
Describes how to install the interface card. |
Software configuration |
Describe software features and configuration procedures. |
Provide a quick reference to all available commands. |
Operations and maintenance |
Tells how to find the lost password or recover the password when the login password is lost. |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
