09-Security Command Reference
HomeSupportSwitchesH3C S12500-X Switch SeriesReference GuidesCommand ReferencesH3C S12500-X Switch Series Command References(R1109)-6W10009-Security Command Reference
Download Book
Title Size Downloads
09-Security Command Reference-book.pdf 1.17 MB
Preface
The H3C S12500-X documentation set includes 11 command references. These references describe the commands and command syntax options available for the H3C S12500-X Switch Series running Release 1109.
The Security Command Reference describes security configuration commands, including:
·     Commands for configuring identity authentication features (such as AAA).
·     Commands for data security features (such as public key management, IPsec, and SSH).
·     Commands for attack protection features (such as IP source guard, ARP attack protection, and uRPF).
This preface includes:
·     Audience
·     Conventions
·     Obtaining documentation
·     Technical support
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators working with the S12500-X series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
Represents a security product, such as a firewall, UTM, multiservice security gateway, or load-balancing device.
Represents a security card, such as a firewall, load-balancing, NetStream, SSL VPN, IPS, or ACG card.
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
Access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions. [Technical Support & Documents > Software Download]—Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
We appreciate your comments.
