Title | Size | Downloads |
H3C SR6600 SPE-SSL-200 Card Manual -APW100
1 Front view
Front view of SPE-SSL-200
2 Specifications
The SPE-SSL-200 card provides one console port, one external CF card slot, and two USB interfaces.
Table1 Card specifications
Item | Specification |
Interface | 1 Console port |
2 USB interfaces | |
Interface transmission speed | Console port: 9600 bps to 115200 bps (default: 9600 bps) |
Cable and maximum transmission distance | Console port: Asynchronous serial cable with maximum transmission distance of 15 meters |
CF card and slot | 1 CF card slot supporting 256MB, 512MB and 1GB CF cards |
Applied to | SR6604/SR6608/SR6616 |
3 Upgrading SPE-SSL-200
The SPE-SSL-200 card supports software upgrade through the console port or one of the Ethernet interfaces on the back card connected on the backplane of the router. For details, refer to H3C SecBlade Cards Software Upgrade Manual.
4 Note
If the host software version does not match the one applicable to the card, contact the local dealer or the integrator for the right version.
For the introduction of card installation, see the related part in H3C SR6604[6608] Installation Manual and H3C SR6616 Installation Manual.
As board types or specifications might change with product versions, you may need to obtain the latest documents from Technical Support & Document link on H3C website http://www.h3c.com.
Copyright © 2010 Hangzhou H3C Technologies Co., Ltd.
