03-二层技术-以太网交换命令参考
07-M-LAG命令
本章节下载 07-M-LAG命令  (692.97 KB)
07-M-LAG命令
  录
1 M-LAG
1.1 M-LAG配置命令
1.1.1 display m-lag consistency
1.1.2 display m-lag consistency-check status
1.1.3 display m-lag drcp statistics
1.1.4 display m-lag keepalive
1.1.5 display m-lag mad verbose
1.1.6 display m-lag role
1.1.7 display m-lag summary
1.1.8 display m-lag system
1.1.9 display m-lag troubleshooting
1.1.10 display m-lag uplink-port information
1.1.11 display m-lag verbose
1.1.12 display m-lag virtual-ip
1.1.13 m-lag authentication key
1.1.14 m-lag auto-recovery reload-delay
1.1.15 m-lag consistency-check disable
1.1.16 m-lag consistency-check mode
1.1.17 m-lag default-auto-recovery enable
1.1.18 m-lag drcp period short
1.1.19 m-lag extra-vlan
1.1.20 m-lag peer-link mac-address hold
1.1.21 m-lag peer-link reserved
1.1.22 m-lag keepalive { ip | ipv6 }
1.1.23 m-lag keepalive hold-time
1.1.24 m-lag keepalive interval
1.1.25 m-lag keepalive standby { ip | ipv6 }
1.1.26 m-lag keepalive track
1.1.27 m-lag mad default-action
1.1.28 m-lag mad exclude interface
1.1.29 m-lag mad exclude logical-interfaces
1.1.30 m-lag mad include interface
1.1.31 m-lag mad persistent
1.1.32 m-lag mad restore
1.1.33 m-lag restore-delay
1.1.34 m-lag role priority
1.1.35 m-lag sequence enable
1.1.36 m-lag standalone enable
1.1.37 m-lag system-mac
1.1.38 m-lag system-number
1.1.39 m-lag system-priority
1.1.40 m-lag uplink-port enable
1.1.41 port m-lag active-standby election
1.1.42 port m-lag group
1.1.43 port m-lag peer-link
1.1.44 port m-lag ipv6 virtual-ip
1.1.45 port m-lag system-mac
1.1.46 port m-lag system-priority
1.1.47 port m-lag virtual-ip
1.1.48 reset m-lag drcp statistics
1.1.49 reset m-lag troubleshooting history
1 M-LAG
对于M-LAG相关业务,为了兼容旧版本,设备默认支持M-LAG和DRNI两种风格的命令行。有关两种命令行差异的详细说明,请参见“M-LAG配置指导”。
1.1  M-LAG配置命令
display m-lag consistency命令用来显示M-LAG配置一致性信息。
display m-lag consistency { type1 | type2 } { global | interface interface-type interface-number }
type1:显示Type 1类型的配置一致性信息。
type2:显示Type 2类型的配置一致性信息。
global:显示全局的配置一致性信息。
interface interface-type interface-number:显示指定M-LAG接口的配置一致性信息。interface-type表示接口类型,interface-number表示接口编号。
当两台M-LAG设备上Type 1和Type 2类型配置不匹配时,显示两台M-LAG设备的配置信息。关于Type 1和Type 2类型配置信息的匹配情况,具体请参见M-LAG配置手册。
Type 2类型全局和接口的配置一致性信息中无效的VLAN相关信息不会参与M-LAG配置一致性检查。
显示全局的Type 2类型的配置一致性信息时,仅当VLANs或Vlan-int字段Local和Peer不一致时,以下字段的配置信息才能显示:
·     Vlan-int(shutdown)
·     Vlan-int(IPv4)
·     Vlan-int(IPv6)
·     Vlan-int(VRRPv4)
# 显示全局的Type 1类型的配置一致性信息。
<Sysname> display m-lag consistency type1 global
Configuration       Local                         Peer
Link type           Access                        Trunk
PVID                10                            20
Global STP          Enabled                       Disabled
STP mode            MSTP                          RSTP
MST region          abc                           def
Revision level      100                           200
MSTI(VLANs)         1(1,64,127,190,316,379,442,   1(2,4,61,121,261,291,362)
                    505,568,631)
STP-enabled VLANs   10,12,14,16,18                20,22,24,26,28
# 显示全局的Type 2类型的配置一致性信息。
<Sysname> display m-lag consistency type2 global
VLANs               1,3,5,7,9                     2,4,6,8,10
Vlan-int            10,12,14,17,22,33             11,19,23,27,47
Vlan-int(shutdown)  100,103,107,200,301           200,261,290,333,465
Vlan-int(IPv4)      1019(192.168.1.1/29)          -
Vlan-int(IPv6)      40(fc00:0:0:102:0:0:0:1/64)   -
Vlan-int(VRRPv4)    100(192.168.100.1/24)         -
Global BPDU guard   Enabled                       Disabled
MAC aging time      100s                          No-aging
Port security       Enabled                       Disabled
Psec load sharing   Local                         Odd-MAC
Psec MAC move state Enabled                       Disabled
Psec MAC move mode  Port                          All
Psec traffic stats  Enabled                       Disabled
Dot1x               Enabled                       Disabled
802.1X auth method  Chap                          Pap
802.1X UniTrigQuiet 60s                           300s
802.1X EAD timeout  60                            30
802.1X hand-sh tmr  30                            15
802.1X off-det tmr  600                           300
802.1X quiet-period 120                           60
802.1X reau-period  4800                          3600
802.1X server tmr   200                           100
802.1X supp-timer   60                            30
802.1X tx-period    60                            30
802.1X failvlan tmr 2000                          1000
802.1X failvsi tmr  3000                          1000
802.1X crt-seg tmr  4000                          1000
802.1X crt-vlan tmr 5000                          1000
802.1X crt-vsi tmr  6000                          1000
802.1X gst-vlan tmr 7000                          1000
802.1X gst-vsi tmr  8000                          1000
MAC-authentication  Enabled                       Disabled
MAC auth method     Chap                          Pap
MAC off-det tmr     600                           300
MAC quiet-period    120                           60
MAC reauth-period   4800                          3600
MAC server-timeout  200                           100
MAC tmp-user-aging  120                           60
MAC crt-seg tmr     2000                          1000
MAC crt-vlan tmr    3000                          1000
MAC crt-vsi tmr     4000                          1000
MAC guest-vlan tmr  5000                          1000
MAC guest-vsi tmr   6000                          1000
Web tmp-entry-aging 1200                          60
VSI name            vpna
VNI                 10
Gateway interface   VSI-interface1
VSI name            vpnb                          vpnb
VNI                 20                            30
VSI interface       1                             1
MAC address         1-1-1                         2-2-2
IPv4 address        192.168.0.1/24                192.168.0.2/24
IPv6 address        1::1/64                       1::2/64
Physical state      UP                            DOWN
Protocol state      UP                            DOWN
VSI interface       2                             2
MAC address         1-1-1                         2-2-3
IPv4 address        192.168.1.1/24                192.168.1.2/24
IPv6 address        2::2/64                       2::2/128
R2 mode             Single                        Disabled
R2 statistics       Global                        ACL
R2 ACL name         a                             b
R2 drop             Enabled                       Disabled
R2 report interval  10                            20
R2 inactive timeout 30                            50
# 显示二层聚合接口1的Type 1类型的配置一致性信息。
<Sysname> display m-lag consistency type1 interface bridge-aggregation 1
LAGG mode           Static                        Dynamic
PVID                10                            20
# 显示二层聚合接口1的Type 2类型的配置一致性信息。
<Sysname> display m-lag consistency type2 interface bridge-aggregation 1
LACP select speed   Enabled                       Disabled
LAGG ignore speed   Enabled                       Disabled
LACP edge port      Enabled                       Disabled
Root guard          Enabled                       Disabled
Psec port mode      Autolearn                     Mac-else-userlogin-secure-ext
Psec mac aging-type inactivity                    periodical
Psec flexible mac   Enabled                       Disabled
Dot1x handshake     Enabled                       Disabled
Dot1x multi-trigger Enabled                       Disabled
Dot1x uni-trigger   Enabled                       Disabled
Dot1x off-detect    Enabled                       Disabled
Dot1x reauth-period 60                            0
Dot1x crt-segment   1                             0
Dot1x crt-profile   abc
Dot1x crt-vlan      100
Dot1x packet-detect Enabled                       Disabled
Dot1x pkt-det retry 2                             5
Dot1x critical VSI  vpna                          vpnb
MAC crt microseg    1                             2
MAC URL user logoff Enabled                       Disabled
MAC with dot1x      Enabled                       Disabled
MAC offline-detect  Enabled                       Disabled
MAC multi-vlan      Multiple                      Single
MAC auth-delay tmr  20                            10
MAC reauth-period   1200                          1000
MAC crt-profile     abc
MAC crt-vlan        100
MAC packet-detect   Enabled                       Disabled
MAC pkt-det retry   2                             5
MAC critical VSI    vpna                          vpnb
Web-auth            Enabled                       Disabled
Web auth-fail VLAN  1                             2
Web-auth P server   serverA                       serverB
Web-auth S server   serverB                       serverA
Web off-det intvl   3600
表1-1 display m-lag consistency命令显示信息描述表
The module module failed the check. Cannot obtain configuration.
模块module检测失败,因为无法获取到配置信息
Configuration
一致性检查的配置类型
Local
本端M-LAG设备配置信息
本端配置信息和对端配置信息一致时显示“-”
当本端未配置时,显示为空
Peer
对端M-LAG设备配置信息
对端配置信息和本端配置信息一致时显示“-”
当对端未配置时,显示为空
Link type
peer-link接口链路类型:
·     Access
·     Hybrid
·     Trunk
PVID
peer-link接口的PVID
Global STP
生成树功能全局是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
STP mode
生成树模式:
·     STP
·     RSTP
·     PVST
·     MSTP
MST region
MST域的域名
Revision level
MSTP的修订级别
MSTI(VLANs)
MSTI与VLAN的映射关系
当检查不一致且获取不到MSTI与VLAN的映射关系时,显示Inconsistent
STP-enabled VLANs
开启生成树功能的VLAN
VLANs
接口所属的VLAN
先比较接口上携带Tag的VLAN,再比较接口上未携带Tag的VLAN
Vlan-int
VLAN接口
Vlan-int(shutdown)
被手工shutdown的VLAN接口
Vlan-int(IPv4)
VLAN接口的IPv4地址
Vlan-int(IPv6)
VLAN接口的IPv6地址
Vlan-int(VRRPv4)
Master上VLAN接口的IPv4 VRRP备份组虚拟IP地址
Global BPDU guard
全局的BPDU保护功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
MAC aging time
MAC地址老化时间,单位为秒
不老化时显示No-aging
Port security
全局端口安全使能功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Psec load sharing
端口安全的M-LAG接口上用户认证的负载分担模式:
·     Centralized:集中处理
·     Local:分布处理本地上送用户
·     Odd-MAC:分布处理奇MAC用户
·     Even-MAC:分布处理偶MAC用户
Psec MAC move state
允许MAC迁移功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Psec MAC move state
允许MAC迁移的方式:
·     Port:允许用户进行端口迁移
·     VLAN:允许用户进行VLAN迁移
·     All:允许用户进行端口和VLAN迁移
Psec traffic stats
端口安全接入用户的流量统计功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Dot1x
全局802.1X认证功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
802.1X auth method
802.1X系统的认证方法:
·     Chap:启用EAP终结方式,并支持与RADIUS服务器之间采用CHAP类型的认证方法
·     Eap:启用EAP中继方式,并支持客户端与RADIUS服务器之间所有类型的EAP认证方法
·     Pap:启用EAP终结方式,并支持与RADIUS服务器之间采用PAP类型的认证方法
802.1X UniTrigQuiet
802.1X单播触发静默定时器的值,单位为秒
802.1X EAD timeout
802.1X认证的EAD超时定时器
802.1X hand-sh tmr
802.1X认证的握手定时器
802.1X off-det tmr
802.1X认证的下线检测定时器
802.1X quiet-period
802.1X认证的静默定时器
802.1X reau-period
802.1X认证的周期性重认证定时器
802.1X server tmr
802.1X认证的认证服务器超时定时器
802.1X supp-timer
802.1X认证的客户端认证超时定时器
802.1X tx-period
802.1X认证的用户名请求超时定时器
802.1X failvlan tmr
802.1X认证的加入到Auth-Fail VLAN中用户的老化定时器
802.1X failvsi tmr
802.1X认证的加入到Auth-Fail VSI中用户的老化定时器
802.1X crt-seg tmr
802.1X认证的加入到Critical微分段中用户的老化定时器
802.1X crt-vlan tmr
802.1X认证的加入到Critical VLAN中用户的老化定时器
802.1X crt-vsi tmr
802.1X认证的加入到Critical VSI中用户的老化定时器
802.1X gst-vlan tmr
802.1X认证的加入到Guest VLAN中用户的老化定时器
802.1X gst-vsi tmr
802.1X认证的加入到Guest VSI中用户的老化定时器
MAC-authentication
全局MAC地址认证功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
MAC auth method
MAC地址认证采用的认证方法:
·     Chap:采用CHAP类型的认证方法
·     Pap:采用PAP类型的认证方法
MAC off-det tmr
MAC地址认证的下线检测定时器
MAC quiet-period
MAC地址认证的静默定时器
MAC reauth-period
MAC地址认证的周期性重认证定时器
MAC server-timeout
MAC地址认证的服务器超时定时器
MAC tmp-user-aging
临时MAC地址认证用户的老化定时器
MAC crt-seg tmr
MAC地址认证的加入到Critical微分段中用户的老化定时器
MAC crt-vlan tmr
MAC地址认证的加入到Critical VLAN中用户的老化定时器
MAC crt-vsi tmr
MAC地址认证的加入到Critical VSI中用户的老化定时器
MAC guest-vlan tmr
MAC地址认证的加入到Guest VLAN中用户的老化定时器
MAC guest-vsi tmr
MAC地址认证的加入到Guest VSI中用户的老化定时器
Web tmp-entry-aging
MAC地址临时表项的老化时间
VSI name
M-LAG接口上AC关联的VSI的名称
VNI
VSI的VXLAN ID
Gateway interface
VSI关联的网关接口编号
VSI interface
VSI关联的VSI虚接口编号
MAC address
VSI关联的VSI虚接口的MAC地址
IPv4 address
VSI关联的VSI虚接口的IPv4地址
IPv6 address
VSI关联的VSI虚接口的IPv6地址
Physical state
VSI关联的VSI虚接口物理状态:
·     ADM:表示该接口已经通过shutdown命令被关闭,即管理状态为关闭down
·     DOWN:该接口的管理状态为开启,但物理状态为关闭
·     UP:该接口的管理状态和物理状态均为开启
Protocol state
VSI关联的VSI虚接口协议状态:
·     DOWN:表示该接口的链路层协议状态为关闭
·     UP:表示该接口的链路层协议状态为开启
R2 mode
(暂不支持)RoCEv2流量NetAnalysis功能的工作模式:
·     Disabled:表示未开启
·     Single:表示单向模式
·     Bidir:表示双向模式
R2 statistics
(暂不支持)RoCEv2流量的NetAnalysis统计功能:
·     Disabled:表示未开启
·     Global:表示对设备入端口的所有RoCEv2流量进行NetAnalysis统计功能
·     ACL:表示对设备入端口的匹配高级ACL的RoCEv2流量进行NetAnalysis统计功能
R2 ACL name
(暂不支持)RoCEv2流量的NetAnalysis统计功能采用ACL统计模式时,ACL的名称
R2 drop
(暂不支持)全局RoCEv2流量丢包分析功能:
·     Enabled:表示开启
·     Disabled:表示关闭
R2 report interval
(暂不支持)RoCEv2流统计信息发送给NDA的时间间隔,单位为秒
R2 inactive timeout
(暂不支持)RoCEv2流的非活跃老化时间,单位为秒
LAGG mode
聚合组工作模式:
·     Static:表示静态聚合
·     Dynamic:表示动态聚合
STP
M-LAG接口上的生成树功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
LACP select speed
M-LAG接口上的端口速率作为优先选择参考端口功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
LAGG ignore speed
M-LAG接口上的选择选中端口时忽略端口速率功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
LACP edge port
M-LAG接口上的边缘端口功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Root guard
根保护功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Psec port mode
端口安全模式:
·     Autolearn
·     Mac-authentication
·     Mac-and-userlogin-secure-ext
·     Mac-else-userlogin-secure
·     Mac-else-userlogin-secure-ext
·     Secure
·     Userlogin
·     Userlogin-mab
·     Userlogin-secure
·     Userlogin-secure-ext
·     Userlogin-secure-or-mac
·     Userlogin-secure-or-mac-ext
·     Userlogin-withoui
Psec mac aging-type
安全MAC地址的老化方式:
·     inactivity:无流量老化
·     periodical:按老化时间老化
Psec flexible mac
灵活安全MAC功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Dot1x
接口下802.1X认证功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Dot1x handshake
802.1X的在线用户握手功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Dot1x multi-trigger
802.1X的组播触发功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Dot1x uni-trigger
802.1X的单播触发功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Dot1x off-detect
端口的802.1X认证下线检测功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Dot1x reauth-period
802.1X认证的周期性重认证定时器
Dot1x crt-segment
端口的802.1X Critical微分段
Dot1x crt-profile
802.1X用户使用的逃生策略模板
Dot1x crt-vlan
端口的802.1X Critical VLAN
Dot1x packet-detect
802.1X的报文探测功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Dot1x pkt-det retry
802.1X报文探测次数
Dot1x critical VSI
802.1X指定的Critical VSI名称
MAC-authentication
接口下MAC地址认证功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
MAC crt microseg
MAC地址认证的Critical微分段ID
MAC URL user logoff
是否开启,在添加第一个Critical微分段用户时,强制当前端口下授权了重定向URL的MAC地址认证的所有用户均下线:
·     Enabled:表示开启
·     Disabled:表示关闭
MAC with dot1x
端口MAC地址认证和802.1X认证并行处理功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
MAC offline-detect
端口的MAC地址认证下线检测功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
MAC multi-vlan
端口工作在MAC地址认证的模式:
·     Multiple:多VLAN模式
·     Single:单VLAN模式
MAC auth-delay tmr
MAC地址认证延迟定时器
MAC reauth-period
MAC地址认证周期性重认证定时器
MAC crt-profile
MAC地址认证用户使用的逃生策略模板
MAC crt-vlan
MAC地址认证用户使用的Critical VLAN
MAC packet-detect
MAC地址认证的报文探测功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
MAC pkt-det retry
MAC地址认证报文探测次数
MAC critical VSI
MAC地址认证的Critical VSI名称
Web-auth
接口下Web认证功能是否开启:
·     Enabled:表示开启
·     Disabled:表示关闭
Web auth-fail VLAN
Web认证的Auth-Fail VLAN
Web-auth P server
Web认证的主Web服务器名称
Web-auth S server
Web认证的备Web服务器名称
Web off-det intvl
Web认证用户的在线检测时间间隔
display m-lag consistency-check status命令用来显示M-LAG配置一致性检查状态。
# 显示M-LAG配置一致性检查状态。
<Sysname> display m-lag consistency-check status
                 Global Consistency Check Configuration
Local status     : Enabled           Peer status     : Enabled
Local check mode : Strict            Peer check mode : Strict
                 Consistency Check on Modules
Module           Type1           Type2
LAGG             Check           Check
VLAN             Check           Check
STP              Check           Check
MAC              Not Check       Check
L2VPN            Not Check       Check
PORTSEC          Not Check       Check
DOT1X            Not Check       Check
MACA             Not Check       Check
WEBAUTH          Not Check       Check
                 Type1 Consistency Check Result
Global consistency check result: SUCCESS
Inconsistent global modules: -
M-LAG IF         M-LAG group ID  Check Result      Inconsistency modules
BAGG4            4               SUCCESS           -
表1-2 display m-lag consistency-check status命令显示信息描述表
Local status
本端配置一致性检查功能开启状态
·     Enabled:开启
·     Disabled:关闭
Peer status
对端配置一致性检查功能开启状态
·     Enabled:开启
·     Disabled:关闭
Local check mode
本端配置一致性检查模式
·     Loose:松散模式
·     Strict:严格模式
Peer check mode
对端配置一致性检查模式
·     Loose:松散模式
·     Strict:严格模式
Module
进行一致性检查的模块
Type1
Type 1类型的检查状态
·     Check:检查
·     Not Check:不检查
Type2
Type 2类型的检查状态
·     Check:检查
·     Not Check:不检查
Type 1类型一致性检查信息
全局配置一致性检查结果
·     FAILURE:失败
·     SUCCESS:成功
全局配置一致性检查失败模块
全局配置一致性检查成功时,显示为“-”
M-LAG IF
M-LAG接口简名
M-LAG group ID
M-LAG组ID
Check result
接口配置一致性检查结果
·     FAILURE:失败
·     SUCCESS:成功
接口检查失败的模块
接口检查成功时,显示为“-”
display m-lag drcp statistics命令用来显示M-LAG系统DRCP报文的统计信息。
display m-lag drcp statistics [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上的信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示peer-link接口和所有M-LAG接口上的DRCP报文统计信息。
# 显示M-LAG系统DRCP报文的统计信息。
<Sysname> display m-lag drcp statistics
 * indicates the port is the peer-link interface.
Interface type:
BAGG -- Bridge-Aggregation, Tun -- Tunnel
Interface     State     Sent     Received(Normal/Error/Unknown)
*BAGG3        UP        30       26/0/0
 BAGG4        UP        29       26/0/0
# 显示聚合接口4的DRCP报文的统计信息。
<Sysname> display m-lag drcp statistics interface bridge-aggregation 4
Interface type:
Interface  : BAGG4
State      : UP
Sent       : 31
Received (Normal/Error/Unknown): 28/0/0
Last received packet information:
  Source MAC address: 3cd4-437d-0300
  Time: 2019/09/11 09:19:58
  Action: Accept
表1-3 display m-lag drcp statistics命令显示信息描述表
Interface type
接口类型
·     BAGG:表示二层聚合接口
接口简名,*表示该接口为peer-link接口
接口状态
·     UP:表示该接口的物理状态为开启
·     DOWN:表示该接口的物理状态为关闭
Sent
发送的DRCPDU报文数量
收到的DRCPDU报文数量,按照正常报文、错误报文、未知报文数量显示
最近一次收到的DRCP报文的信息
Source MAC address
报文源MAC地址
Time
最近一次收到的DRCP报文时间,时间显示格式为YYYY/MM/DD HH:MM:SS
Action
报文处理方式
·     Accept:正常接收
·     Drop:丢弃报文(reason
报文丢弃原因reason
·     Incorrect incoming port:错误的接收接口
·     Incorrect packet type:报文类型错误
·     Incorrect packet version:报文版本错误
·     Incorrect packet length:报文长度校验失败
·     Packets from local device:收到设备自己发送的报文
·     Local M-LAG interface not configured:未配置本地M-LAG接口
·     System MAC inconsistency:系统MAC地址和本端不一致
·     System priority inconsistency:系统优先级和本端不一致
·     Incorrect system number:错误的系统编号
·     Incorrect sequence number:序列号校验失败
·     Failed authentication:认证失败
·     Other error:其他错误
·     reset m-lag drcp statistics
display m-lag keepalive命令用来显示M-LAG系统Keepalive报文的信息。
# 显示M-LAG系统Keepalive报文的信息。
<Sysname> display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 135642 s 501 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 10.0.0.2
  Time: 2019/09/11 09:21:51
  Action: Accept
M-LAG keepalive parameters:
Destination IP address: 10.0.0.2
Source IP address: 10.0.0.1
Standby destination IP address: 10.0.0.3
Standby source IP address: 10.0.0.4
Keepalive UDP port : 6400
Keepalive VPN name : vpn1
Standby keepalive VPN name : vpn2
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
表1-4 display m-lag keepalive命令显示信息描述表
对端设备状态
·     Unknown:未检测到对端,未配置Keepalive报文的IP地址
·     Up:对端设备存在,可以正常收发Keepalive报文
·     Down:对端设备故障
Keepalive链路DOWN的原因
·     M-LAG system init:M-LAG系统初始化
·     Local IP not configured:本端未配置IP地址
·     Local Tx failed:本端发送报文失败
·     Local Rx timeout:本端接收报文超时
·     Peer Rx timeout:对端接收报文超时
邻居存活时间
Keepalive报文收发状态
Sent
Keepalive报文发包是否成功
·     Successful:发包成功
·     Failed:发包失败
Received
Keepalive报文收包是否成功
·     Successful:收包成功
·     Failed:收包失败
最近一次收到的Keepalive报文的信息
Time
Keepalive报文收包时间,当未收到keepalive报文时显示为N/A
Action
报文处理方式
·     Accept:正常接收
·     Drop:丢弃报文(reason
报文丢弃原因reason
·     Invalid packet Interval:无效的报文周期
Keepalive报文目的IP地址
Source IP address
Keepalive报文源IP地址
备用Keepalive报文目的IP地址
备用Keepalive报文源IP地址
Keepalive UDP port
Keepalive报文的UDP发送端口号
Keepalive VPN name
Keepalive报文所属的VPN实例名,当未指定Keepalive链路所属的VPN实例时显示为N/A
备用Keepalive报文所属的VPN实例名,当未指定Keepalive链路所属的VPN实例时显示为N/A
Keepalive interval
Keepalive报文发送间隔
Keepalive timeout
Keepalive报文超时时间
Keepalive hold time
peer-link链路DOWN后等待检测故障原因的时间
·     m-lag keepalive { ip | ipv6 }
·     m-lag keepalive hold-time
·     m-lag keepalive interval
display m-lag mad verbose命令用来显示M-LAG MAD的详细信息。
# 显示M-LAG MAD的详细信息。
<Sysname> display m-lag mad verbose
M-LAG MAD DOWN state    : No
Restore delay          : 30 s
Remaining restore delay: -
M-LAG MAD default action: DOWN
M-LAG MAD DOWN persistence: Disabled
Excluding logical interfaces: Disabled
Port configuration for M-LAG MAD DOWN action:
 Included ports(user-configured):
   Bridge-Aggregation1
   Ten-GigabitEthernet1/0/5(ineffective)
 Included ports(system-configured):
   Member interfaces of M-LAG Bridge-Aggregation3:
     Ten-GigabitEthernet1/0/3
 Excluded ports(user-configured):
   Bridge-Aggregation2
   Ten-GigabitEthernet1/0/4
 Excluded ports(system-configured):
   Management interfaces:
     M-GigabitEthernet0/0/0
   M-LAG interfaces:
     Bridge-Aggregation4
   Peer-link interface:
     Bridge-Aggregation3
   Member interfaces of peer-link interface Bridge-Aggregation3:
     Ten-GigabitEthernet1/0/1
     Ten-GigabitEthernet1/0/2
表1-5 display m-lag mad verbose命令显示信息描述表
当前设备接口是否被设置为M-LAG MAD DOWN状态:
·     Yes:设备上存在处于M-LAG MAD DOWN状态的接口
·     No:设备上不存在处于M-LAG MAD DOWN状态的接口
Restore delay
延迟恢复时间,单位为秒
延迟恢复剩余时间,单位为秒
当未启动定时器时,显示为“-”
M-LAG系统分裂时的接口状态处理原则:
·     DOWN:接口在M-LAG系统分裂后处于M-LAG MAD DOWN状态
·     NONE:接口在M-LAG系统分裂后保持原状态不变
M-LAG MAD DOWN状态保持功能状态:
·     Enabled:开启M-LAG MAD DOWN保持功能
·     Disabled:关闭M-LAG MAD DOWN保持功能
所有逻辑接口是否配置为M-LAG保留接口:
·     Enabled:所有逻辑接口配置为M-LAG保留接口
·     Disabled:未将所有逻辑接口配置为M-LAG保留接口
用户配置的在M-LAG系统分裂后处于M-LAG MAD DOWN状态的接口
当显示为ineffective时,表示配置以下接口在M-LAG系统分裂后处于M-LAG MAD DOWN状态时,配置不生效:
·     M-LAG系统保留接口
·     配置了强制端口up功能的接口
系统配置的在M-LAG系统分裂后处于M-LAG MAD DOWN状态的接口:
·     Member interfaces of M-LAG Bridge-Aggregation interface-number:M-LAG接口所对应的二层聚合接口的成员接口
用户配置的在M-LAG系统分裂后仍然处于UP状态的接口
当显示为ineffective时,表示M-LAG接口所对应的二层聚合接口的成员接口已经配置为保留接口,配置不生效
系统配置的在M-LAG系统分裂后仍然处于UP状态的接口:
·     Management interfaces:管理以太网接口
·     M-LAG接口
·     peer-link接口
·     Member interfaces of peer-link interface Bridge-Aggregation interface-number:peer-link接口所对应的二层聚合接口的成员接口
·     m-lag mad default-action
·     m-lag mad exclude logical-interfaces
·     m-lag mad exclude interface
·     m-lag mad include interface
·     m-lag mad persistent
display m-lag role命令用来显示M-LAG设备角色信息。
display m-lag role
# 显示M-LAG设备角色信息。
<Sysname> display m-lag role
                    Effective role information
Factors                          Local                    Peer
Effective role                   Primary                  Secondary
Status of M-LAG uplink interfacesUP                       DOWN
Initial role                     None                     None
MAD DOWN state                   Yes                      Yes
Health level                     0                        0
Role priority                    32768                    32768
Bridge MAC                       3cd4-3ce1-0200           3cd4-437d-0300
Effective role trigger: Peer link calculation
Effective role reason: Bridge MAC
                    Configured role information
Factors                          Local                    Peer
Configured role                  Primary                  Secondary
表1-6 display m-lag role命令显示信息描述表
生效的角色信息
Factors
计算角色的因素
Local
·     本端角色相关信息
Peer
·     对端角色相关信息
Effective role
生效的设备角色
·     None:设备状态未知
·     Primary:主设备
·     Secondary:从设备
Status of M-LAG interfaces
所有M-LAG接口的状态:
·     DOWN:所有M-LAG接口均处于DOWN状态
·     UP:存在处于UP状态的M-LAG接口
·     Nonexistent:不存在M-LAG接口
需要注意的是,仅peer-link链路DOWN时,本字段才会显示
本端和对端M-LAG设备上行链路接口的状态:
·     DOWN:所有M-LAG上行链路接口均处于DOWN状态
·     UP:存在处于UP状态的M-LAG上行链路接口
·     Nonexistent:不存在上行链路接口
Initial role
计算角色时,设备的角色
·     None:设备状态未知
·     Primary:主设备
·     Secondary:从设备
MAD DOWN state
计算角色时,设备上是否存在处于M-LAG MAD DOWN状态的接口:
·     Yes:存在
·     No:不存在
当邻居不存在时,显示为N/A
Health level
计算角色时,设备的健康等级,该值越大,越不健康
当邻居不存在时,显示为N/A
Role priority
角色优先级
Bridge MAC
设备桥MAC地址
计算生效角色的触发条件:
·     Peer link calculation:本端设备角色通过peer-link链路计算
·     Peer link down and role calculation over keepalive link:peer-link链路故障时,本端设备角色通过Keepalive链路计算
·     Peer link and keepalive link down:peer-link链路和keeplive链路均故障
·     Peer link and keepalive link down. All local M-LAG interfaces down:peer-link链路和keeplive链路均故障,且本端所有M-LAG接口down
协商生效角色的决策原因:
·     -:邻居不存在
·     a M-LAG member device init:M-LAG成员设备初始化
·     Status of M-LAG interfaces:M-LAG接口的状态
·     Single None role:M-LAG系统中,一台M-LAG设备角色为None,另一台M-LAG设备角色为Primary
·     MAD status:设备M-LAG MAD DOWN状态
·     Health level:设备健康级别
·     Role priority:设备角色优先级
·     Bridge MAC:设备桥MAC地址
·     Status of M-LAG uplink interfaces:M-LAG上行链路接口的状态
配置的角色信息
Configured role
配置的设备角色:
·     None:设备状态未知
·     Primary:主设备
·     Secondary:从设备
·     m-lag role priority
display m-lag summary命令用来显示M-LAG系统的接口摘要信息。
# 显示所有M-LAG系统的接口摘要信息。
<Sysname> display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
       C -- Configuration consistency check failed
       D –- Standby status in active/standby mode
Peer-link interface: BAGG3
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
                     M-LAG interface information
M-LAG IF    M-LAG group  Local state (cause)  Peer state  Remaining down time(s)
BAGG4       4            UP                   UP          -
表1-7 display m-lag summary命令显示信息描述表
Peer-link interface
peer-link接口简名
peer-link接口状态(DOWN状态的原因)
·     UP:表示处于UP状态
·     DOWN:表示处于DOWN状态
本地peer-link接口DOWN的原因:
·     Aggregate interface down:peer-link接口所在聚合接口状态变为down
·     No correct DRCPDUs received:未收到正常的DRCPDU
·     System MAC inconsistency:与对端系统MAC不一致
·     System number inconsistency:与对端系统编号不符合要求
·     System priority inconsistency:与对端系统优先级不一致
Keepalive链路状态
·     UP:表示处于UP状态
·     DOWN:表示处于DOWN状态
Keepalive链路DOWN的原因:
·     Local track negative:本端Track状态down
M-LAG接口信息
M-LAG IF
M-LAG接口
M-LAG group
M-LAG组ID
Local state (cause)
M-LAG接口状态:
·     UP:表示处于UP状态
·     DOWN:表示处于DOWN状态
M-LAG接口DOWN的原因,以A~D的字母表示,每个字母表示的原因如下:
·     A:M-LAG接口所在聚合接口状态变为down
·     B:对端不存在对应M-LAG接口
·     C:配置一致性检查失败
·     D:作为备用M-LAG接口
Peer state
对端M-LAG接口状态:
·     UP:表示处于UP状态
·     DOWN:表示未配置或处于DOWN状态
·     UNKNOWN:表示peer-link链路故障时,对端M-LAG接口状态未知
Remaining down time (s)
M-LAG DOWN恢复定时器的剩余时间,单位为秒
当未启动定时器时,显示为“-”
display m-lag system命令用来显示M-LAG系统信息。
# 显示M-LAG系统信息。
<Sysname> display m-lag system
                     System information
Local system number: 1                      Peer system number: 2
Local system MAC: 0001-0001-0001            Peer system MAC: 0001-0001-0001
Local system priority: 123                  Peer system priority: 123
Local bridge MAC: 3cd4-3ce1-0200            Peer bridge MAC: 3cd4-437d-0300
Local effective role: Primary               Peer effective role: Secondary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: Yes
                     System timer information
Timer                      State       Value (s)    Remaining time (s)
Auto recovery              Disabled    -            -
Restore delay              Disabled    30           -
Consistency-check delay    Disabled    15           -
Standalone delay           Disabled    -            -
Role to None delay         Disabled    60           -
表1-8 display m-lag system命令显示信息描述表
Local system number
本端系统编号,未配置时为N/A
Peer system number
对端系统编号,未配置或邻居不存在时为N/A
Local system MAC
本端系统MAC地址,未配置时为N/A
Peer system MAC
对端系统MAC地址,未配置或邻居不存在时为N/A
本端系统优先级,未配置时为N/A
对端系统优先级,未配置或邻居不存在时为N/A
Local bridge MAC
本端桥MAC
Peer bridge MAC
对端桥MAC,邻居不存在时为N/A
本端生效角色:
·     None:设备状态未知
·     Primary:主设备
·     Secondary:从设备
Peer effective role
对端生效角色:
·     None:设备状态未知
·     Primary:主设备
·     Secondary:从设备
Health level
本端设备当前健康级别,值越大越不健康
M-LAG系统分裂后M-LAG设备独立工作功能开启状态
·     Enabled:开启
·     Disabled:关闭
In standalone state
设备是否处于独立运行状态
·     Yes:是
·     No:否
System Timer information
定时器信息
Timer
定时器类型
·     Auto recovery:设备重启后自动恢复定时器
·     Restore delay:延迟恢复定时器
·     Consistency check delay:一致性检查延迟定时器
·     Standalone delay:M-LAG设备切换到独立运行模式的延迟定时器
·     Role to None delay:M-LAG系统角色变为None的延时定时器
定时器启动状态
·     Enabled:已启动
·     Disabled:未启动
Value (s)
定时器的配置时间,单位为秒
Remaining time (s)
定时器的剩余时间,单位为秒
当未启动定时器时,显示为“-”
display m-lag troubleshooting命令用来显示M-LAG故障信息。
display m-lag troubleshooting [ m-lag-interface | peer-link | keepalive ] [ history ] [ count ]
m-lag-interface:显示M-LAG接口的故障信息。
peer-link:显示peer-link接口的故障信息。
keepalive:显示Keepalive链路的故障信息。
history:显示M-LAG历史故障信息。如果不指定本参数,则显示当前故障信息。
count:显示指定数量的故障信息,取值范围为1~200。如果不指定本参数,则显示最近20条故障信息。
如果未指定m-lag-interfacepeer-linkkeepalive参数,则表示显示M-LAG接口、peer-link接口和Keepalive链路的故障信息。
# 显示M-LAG系统的历史故障信息。
<Sysname> display m-lag troubleshooting history
Total: 3
Time                     Event description
2019-09-10 14:13:53.103  Peer-link interface BAGG10 went down because the
                         peer-link interface role of the interface was removed.
                         Please reconfigure an interface as the peer-link interface.
2019-09-10 14:23:53.102  Keepalive link went down because the peer keepalive
                         timeout timer expired. Please check the keepalive
                         packet transmission and reception status at the two
                         ends.
2019-09-10 14:53:53.103  Local M-LAG interface state of BAGG1024 in M-LAG group 1024
                         changed to down because the aggregate interface went
                         down. Please check the aggregate link status.
表1-9 display m-lag troubleshooting命令显示信息描述表
Total
M-LAG系统故障记录总数
Time
故障发生的日期和时间,格式为YYYY-MM-DD HH:MM:SS.MS
Event description
故障描述信息:
·     peer-link接口故障描述信息,详细信息请参见表1-10
·     Keepalive故障描述信息,详细信息请参见表1-11
·     M-LAG接口故障描述信息,详细信息请参见表1-12
表1-10 peer-link接口故障描述信息
Peer-link interface interface-name went down because the aggregate interface went down. Please check the aggregate link status.
由于peer-link接口所在的聚合接口DOWN导致peer-link接口DOWN,请检查聚合接口的链路状态
Peer-link interface interface-name went down because no DRCPDUs were received. Please check the DRCPDU transmission and reception status at the two ends.
由于接收不到有效DRCP报文导致的peer-link接口DOWN,请检查两端DRCP报文收发状态
Peer-link interface interface-name went down because the peer failed to receive DRCPDUs. Please check the DRCPDU transmission and reception status at the two ends.
由于对端设备接收不到有效DRCP报文导致的peer-link接口DOWN,请检查两端DRCP报文收发状态
Peer-link interface interface-name went down because the peer-link interface role of the interface was removed. Please reconfigure an interface as the peer-link interface.
由于接口取消配置为peer-link接口,导致peer-link接口DOWN,请重新配置peer-link接口
表1-11 Keepalive故障描述信息
Keepalive link went down because keepalive parameters were not configured. Please configure keepalive parameters.
由于未配置Keepalive报文参数导致的Keepalive链路DOWN,请先配置Keepalive报文参数
Keepalive link went down because the device failed to send keepalive packets. Please check Layer 3 reachability to the peer.
由于本端发送报文失败导致的Keepalive链路文DOWN,请检查三层路由是否可达
Keepalive link went down because the local keepalive timeout timer expired. Please check the keepalive packet transmission and reception status at the two ends.
由于本端接收报文超时导致的Keepalive链路DOWN,请检查两端Keepalive报文收发状态
Keepalive link went down because the peer keepalive timeout timer expired. Please check the keepalive packet transmission and reception status at the two ends.
由于对端接收报文超时导致的Keepalive链路DOWN,请检查两端Keepalive报文收发状态
The keepalive link went down, because the associated local track entry became negative. Please check the track entry state.
由于track项为negative状态导致关联的keepalive链路DOWN,请检查本端Keepalive关联track项状态
表1-12 M-LAG接口故障描述信息
Local M-LAG interface state of interface-name in M-LAG group group-id changed to down because the aggregate interface went down. Please check the aggregate link status.
由于M-LAG接口对应的聚合接口DOWN导致M-LAG接口DOWN,请检查聚合接口链路状态
Local M-LAG interface state of interface-name in M-LAG group group-id changed to down because no peer M-LAG interface was detected. Please check peer M-LAG interface configuration.
由于未检测到对端M-LAG接口导致的M-LAG接口DOWN,请检查对端M-LAG设备的配置情况
Local M-LAG interface state of interface-name in M-LAG group group-id changed to down because of configuration consistency check failure. Please check the type 1 configuration of the peer devices for inconsistencies.
由于配置一致性检查失败导致的M-LAG接口DOWN,请检查M-LAG设备的Type 1配置情况
Local M-LAG interface state of interface-name changed to down because it was removed from M-LAG group group-id. Please reconfigure the M-LAG interface settings as needed.
由于聚合接口取消配置为M-LAG接口,导致M-LAG接口DOWN,请根据需求重新配置M-LAG接口
Local M-LAG interface state of interface-name in M-LAG group group-id changed to down because the role of the M-LAG interface is standby.
由于M-LAG接口是备用M-LAG接口,导致本地M-LAG接口中的interface-name在M-LAG组(group-id)中的状态变为down
·     reset m-lag troubleshooting history
display m-lag uplink-port information命令用来显示M-LAG上行链路接口信息。
# 显示M-LAG上行口信息。
<Sysname> display m-lag uplink-port information
Local total uplink-port state : UP
Peer total uplink-port state  : DOWN
Interfaces                   State
 Bridge-Aggregation3         UP
 Ten-GigabitEthernet1/0/1        UP
表1-13 display m-lag uplink-port information命令显示信息描述表
Local toltal uplink-port state
本地上行链路接口总状态,取值包括:
Peer toltal uplink-port state
对端上行链路接口总状态,取值包括:
Interfaces
配置为上行链路接口的接口名称
接口的物理状态,取值包括:
·     UP:接口处于开启状态
·     DOWN:接口处于关闭状态
·     m-lag uplink-port enable
display m-lag verbose命令用来显示M-LAG系统的接口详细信息。
display m-lag verbose [ interface interface-type interface-number ]
interface interface-type interface-number:显示二层聚合接口所对应M-LAG接口或peer-link接口的详细信息。interface-number表示二层聚合接口的编号,该编号必须已经存在。若不指定该参数,则显示设备上的peer-link接口和所有M-LAG接口的相关信息。
当指定的接口为peer-link接口时,仅显示peer-link接口的详细信息。当指定的接口既不是peer-link接口,也不是M-LAG接口时,则无显示。
# 显示二层聚合接口1所对应M-LAG接口的详细信息。
<Sysname> display m-lag verbose interface bridge-aggregation 1
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
       D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
       G -- Port_Sync, H -- Expired
M-LAG interface/M-LAG group ID: BAGG1/1
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG role election type: ARP
Peer M-LAG role election type: ARP
Local M-LAG interface role: Standby
Peer M-LAG interface role: Standby
Local M-LAG interface down cause: -
Remaining M-LAG DOWN time: -
Local M-LAG interface LACP MAC: Config=0001-0001-0001, Effective=0001-0001-0001
Peer M-LAG interface LACP MAC: Config=0001-0001-0001, Effective=0001-0001-0001
Local M-LAG interface LACP priority: Config=200, Effective=200
Peer M-LAG interface LACP priority: Config=200, Effective=200
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): XGE1/0/1 (260), XGE1/0/2 (261)
Peer Selected ports indexes: 260, 261
# 显示二层聚合接口2所对应的peer-link接口的详细信息。
<Sysname> display m-lag verbose interface bridge-aggregation 2
Peer-link interface/Peer-link interface ID: BAGG2/1
State: UP
Cause: -
Local Selected ports (index): XGE1/0/1 (258), XGE1/0/2 (259)
Peer Selected ports indexes: 258, 259
Reserved VLANs: 1, 3-10
表1-14 display m-lag verbose命令显示信息描述表
Flags
DRCP协议的状态标志,长度为1字节,该字节自低位至高位分别以字母A~H表示,取值为1的标志位显示为对应的字母,取值为0的标志为不显示。各标志位的含义如下
·     A:本端设备DRCP是否开启标志。1表示是;0表示否
·     B:邻居设备DRCP是否开启标志。1表示是;0表示否
·     C:其他邻居设备DRCP是否开启标志。1表示是;0表示否
·     D:本端设备peer-link接口认为邻居设备DRCP是否处于开启状态。1表示是;0表示否
·     E:DRCP长/短超时标志。1表示短超时;0表示长超时
·     F: 本端设备认为peer-link接口是否可以通过指定网关会话ID的报文。1表示是;0表示否
·     G:本端设备认为peer-link接口是否可以通过指定端口会话ID的报文。1表示是;0表示否
·     H:本端设备的接收状态机是否处于默认状态或超时状态。1表示是;0表示否
Peer-link interface
peer-link接口简名
peer-link接口ID
M-LAG interface
M-LAG接口
M-LAG group ID
M-LAG组ID
本端M-LAG接口的状态
·     UP:当M-LAG接口对应的聚合接口所在聚合组中存在选中端口时,M-LAG接口处于UP状态
·     DOWN:当M-LAG接口对应的聚合接口所在聚合组中不存在选中端口时,M-LAG接口处于DOWN状态
对端M-LAG接口状态
·     UNKNOWN:peer-link链路故障时,对端M-LAG接口状态未知
M-LAG group state
M-LAG组的状态
·     UP:当本端M-LAG接口和对端M-LAG接口中存在UP状态接口时,M-LAG组状态为UP
·     DOWN:当本端M-LAG接口和对端M-LAG接口均为DOWN状态时,M-LAG组状态为DOWN
本端M-LAG主备选举使用的协议报文类型,取值包括:
·     -:未配置类型
·     IGMP:通过IGMP报文选举
·     ARP:通过ARP报文选举
·     ND:通过ND报文选举
·     DHCP:通过DHCP报文选举
·     MLD:通过MLD报文选举
对端M-LAG主备选举使用的协议报文类型,取值包括:
·     -:未配置类型
·     IGMP:通过IGMP报文选举
·     ARP:通过ARP报文选举
·     ND:通过ND报文选举
·     DHCP:通过DHCP报文选举
·     MLD:通过MLD报文选举
本端M-LAG接口角色,取值包括:
·     -:非主备模式
·     Active:主用M-LAG接口
·     Standby:备用M-LAG接口
对端M-LAG接口角色,取值包括:
·     -:非主备模式
·     Active:主用M-LAG接口
·     Standby:备用M-LAG接口
本地M-LAG接口DOWN的原因
·     -:未发生故障
·     Aggregate interface down:M-LAG接口所在聚合接口状态变为down
·     No peer M-LAG interface configured:对端不存在对应M-LAG接口
·     Configuration consistency check failed:配置一致性检查失败
·     The role of the M-LAG interface is standby:作为备用M-LAG接口
M-LAG DOWN恢复剩余时间,单位为秒
当未启动定时器时,显示为“-”
peer-link接口状态
Cause
peer-link接口DOWN的原因
·     -:未发生故障
·     No correct DRCPDUs received by peer:对端未收到正常的DRCPDU
本端M-LAG接口指定发送LACP报文携带的系统MAC地址
对端M-LAG接口指定发送LACP报文携带的系统MAC地址
本端M-LAG接口指定发送LACP报文携带的系统优先级
对端M-LAG接口指定发送LACP报文携带的系统优先级
Config
配置值
Effective
生效值
Local DRCP flags
本端设备的DRCP协议状态标志,如果DRCP协议的状态标志取值都为0,则显示为Unknown
Peer DRCP flags
邻居设备的DRCP协议状态标志,如果邻居不存在或DRCP协议的状态标志取值都为0,则显示为Unknown
本端当前聚合组选中成员端口简名(端口索引)
对端当前聚合组选中成员端口索引
Reserved VLANs
peer-link链路的保留VLAN
display m-lag virtual-ip命令用来显示M-LAG虚拟IP地址信息。
display m-lag virtual-ip [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口(目前仅支持VLAN接口和Loopback接口)上的信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,则显示所有接口的M-LAG虚拟IP地址信息。
# 显示所有接口的M-LAG虚拟IP地址信息。
<Sysname> display m-lag virtual-ip
Interface   IP address                MAC address       Effective State
Vlan2       10.10.10.10/24            0001-0001-0001    ACTIVE
            10.10.20.10/24            0001-0001-0002    STANDBY
Loop1       1::20/124                 0001-0001-0003    STANDBY
            1::10/124                 0001-0001-0004    ACTIVE
表1-15 display m-lag virtual-ip命令显示信息描述表
接口简名
IP address
虚拟IP地址
MAC address
虚拟MAC地址
Effective State
虚拟IP地址状态:
·     ACTIVE:虚拟IPv4地址在当前设备处于可用状态
·     STANDBY:虚拟IPv4地址在当前设备处于不可用状态
m-lag authentication key命令用来开启M-LAG报文认证功能,并配置认证密钥。
undo m-lag authentication key命令用来关闭M-LAG报文认证功能。
m-lag authentication key { simple | cipher } string
M-LAG报文认证功能处于关闭状态。
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~32个字符的字符串;密文密钥为1~73个字符的字符串。
开启M-LAG报文认证功能,即开启DRCP报文和Keepalive报文的认证功能。
为防止攻击者篡改DRCP报文或Keepalive报文内容引起链路震荡,M-LAG提供报文认证功能,提高安全性。本端M-LAG设备发送的报文中会携带一个消息摘要,该消息摘要是对报文内容经Hash计算得到。对端M-LAG设备收到该报文时,会与自己计算的该报文的消息摘要进行比对,如果一致,则认为其合法。如果认证失败,则设备丢弃该报文。
两台M-LAG设备需要配置相同密钥,否则认证失败。
# 开启M-LAG报文认证功能,并配置明文密钥为abcdefg。
[Sysname] m-lag authentication key simple abcdefg
m-lag auto-recovery reload-delay命令用来配置设备重启后的自动恢复时间。
undo m-lag auto-recovery reload-delay命令用来恢复缺省情况。
m-lag auto-recovery reload-delay delay-value
未配置设备重启后的自动恢复时间。
delay-value:自动恢复的时间,取值范围为240~3600,单位为秒。
M-LAG系统中主从设备由于故障重启,仅一台M-LAG设备恢复启动后,缺省情况下,该设备处于None角色,所有M-LAG接口处于M-LAG DOWN状态。此时用户流量无法通过M-LAG接口转发。
为了避免上述情况出现,可以配置本功能,在设备重启后启动自动恢复定时器。当自动恢复定时器超时后,该设备上M-LAG接口被置为非M-LAG DOWN状态:
·     如果该设备上配置了上行链路接口,则需要设备上存在处于up状态的上行链路接口,设备才能升级为主设备,用户流量可以正常转发;否则,设备保持None角色,用户流量无法转发。
·     如果该设备上未配置上行链路接口,则需要设备上存在处于up状态的M-LAG接口,设备才能升级为主设备,用户流量可以正常转发;否则,设备保持None角色,用户流量无法转发。
M-LAG系统中主从设备由于故障重启,两台M-LAG设备均恢复启动时,如果设备在自动恢复定时器超时前未收到DRCP报文或Keepalive报文,且均存在处于up状态的M-LAG接口或上行链路接口(存在上行链路接口时仅考虑上行链路接口,不存在上行链路接口时考虑M-LAG接口),则两台M-LAG设备均升级为主设备,此时需要用户检查peer-link链路和Keepalive链路,并排除故障。
请配置本定时器的值大于整机重启时间,避免M-LAG设备间出现角色抢占。
# 配置设备重启后的自动恢复时间为245秒。
[Sysname] m-lag auto-recovery reload-delay 245
·     display m-lag system
m-lag consistency-check disable命令用来关闭M-LAG配置一致性检查功能。
undo m-lag consistency-check disable命令用来开启M-LAG配置一致性检查功能。
M-LAG配置一致性检查功能处于开启状态。
为保证系统正常运行,M-LAG缺省会在M-LAG系统建立过程中进行配置一致性检查。
当M-LAG系统中两台M-LAG设备因为版本升级等原因,导致M-LAG设备配置不一致。此时,为了避免因配置一致性检查而关闭M-LAG接口,用户可以通过m-lag consistency-check disable命令关闭M-LAG配置一致性检查,保证M-LAG接口正常工作。
请用户保证两端M-LAG设备配置一致性检查功能开启状态一致。
# 关闭M-LAG配置一致性检查。
[Sysname] m-lag consistency-check disable
m-lag consistency-check mode命令用来配置M-LAG配置一致性检查的模式。
undo m-lag consistency-check mode命令用来恢复缺省情况。
m-lag consistency-check mode { loose | strict }
M-LAG配置一致性检查缺省处于严格模式。
loose:松散模式。
strict:严格模式。
进行配置一致性检查,检查到配置不匹配时,根据配置一致性检查类型的不同,处理方式为:
·     当检查到Type 1类型不匹配时,不同的配置一致性检查模式处理方式为:
¡     松散模式:打印配置一致性检查失败的日志信息。
¡     严格模式:关闭M-LAG接口,并打印配置一致性检查失败的日志信息。
·     当检查到Type 2类型不匹配时,在松散模式和严格模式下,都仅打印配置一致性检查失败的日志信息。
# 配置M-LAG配置一致性检查的模式为松散模式。
[Sysname] m-lag consistency-check mode loose
m-lag default-auto-recovery enable命令用来开启缺省自动恢复功能。
undo m-lag default-auto-recovery enable命令用来关闭缺省自动恢复功能。
缺省自动恢复功能处于开启状态。
M-LAG系统中主从设备由于故障重启,仅一台M-LAG设备恢复启动后:
·     如果开启本功能,则该M-LAG设备将启动自动恢复定时器。在定时器未超时前,该设备处于None角色,所有M-LAG接口处于M-LAG DOWN状态。此时用户流量无法通过M-LAG接口转发。在定时器超时后,该设备上M-LAG接口被置为非M-LAG DOWN状态:
¡     如果该设备上配置了上行链路接口,则需要设备上存在处于up状态的上行链路接口,设备才能升级为主设备,用户流量可以正常转发;否则,设备保持None角色,用户流量无法转发。
¡     如果该设备上未配置上行链路接口,则需要设备上存在处于up状态的M-LAG接口,设备才能升级为主设备,用户流量可以正常转发;否则,设备保持None角色,用户流量无法转发。
·     如果关闭本功能,则该M-LAG设备处于None角色,所有M-LAG接口处于M-LAG DOWN状态,该M-LAG设备不会自动恢复。
如果同时配置本命令和m-lag auto-recovery reload-delay命令,则m-lag auto-recovery reload-delay命令配置的自动恢复时间生效。
# 开启缺省自动恢复功能。
[Sysname] m-lag default-auto-recovery enable
·     m-lag auto-recovery reload-delay
m-lag drcp period short命令用来配置端口的DRCP超时时间为短超时(3秒)。
undo m-lag drcp period命令用来恢复缺省情况。
端口的DRCP超时时间为长超时(90秒)。
二层聚合接口视图
本命令仅在配置为peer-link接口的二层聚合接口或者加入M-LAG组的二层聚合接口下配置生效。
若DRCP超时时间为短超时,则对端将快速发送DRCPDU(每1秒发送1个DRCPDU);若DRCP超时时间为长超时,则对端将慢速发送DRCPDU(每30秒发送1个DRCPDU)。
请不要在M-LAG进程重启时或ISSU升级前配置DRCP超时时间为短超时,否则在M-LAG进程重启时或ISSU升级期间会出现网络流量中断,导致流量转发不通。有关ISSU升级的详细介绍请参见“基础配置指导”中的“ISSU配置”。
# 配置二层聚合接口1的DRCP超时时间为短超时(3秒)。
[Sysname-Bridge-Aggregation1] m-lag drcp period short
m-lag extra-vlan命令用来配置M-LAG的额外VLAN。
undo m-lag extra-vlan命令用来取消M-LAG的额外VLAN。
m-lag extra-vlan vlan-id-list
undo m-lag extra-vlan vlan-id-list
未配置M-LAG的额外VLAN。
vlan-id-list:额外VLAN列表。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
额外VLAN是指M-LAG接口未允许通过的VLAN。在业务流量通过非M-LAG接口接入M-LAG设备的场景中,业务流量仅在本端接入的M-LAG设备上进行处理。如果业务流量通过非M-LAG接口接入M-LAG设备且需要在M-LAG设备间同步表项,则可以将该业务流量所属的VLAN配置为M-LAG的额外VLAN,使该业务流量相关的转发表项(例如属于额外VLAN的ARP表项等表项)同步到对端M-LAG设备上。当本端M-LAG设备上行链路故障时,业务流量可以通过peer-link链路绕行到对端M-LAG设备上进行处理。
本命令配置的额外VLAN,必须已经创建,否则无法处理接入设备的业务。
# 配置M-LAG的额外VLAN为VLAN 1。
<Sysname> system
[Sysname] m-lag extra-vlan 1
m-lag peer-link mac-address hold命令用来开启M-LAG peer-link接口的MAC地址保持功能。
undo m-lag peer-link mac-address hold命令用来关闭M-LAG peer-link接口的MAC地址保持功能。
M-LAG peer-link接口的MAC地址保持功能处于关闭状态。
当设备单归接入M-LAG系统时,如果设备连接M-LAG设备的接口状态变为DOWN,本端peer-link接口需要删除其MAC地址,并向对端peer-link接口发送MAC地址删除消息,使对端peer-link接口立即同步删除对应的MAC地址表项。如果单归设备连接M-LAG设备的接口反复震荡,则peer-link接口将反复删除和添加MAC地址表项。
当M-LAG设备收到去往单归设备的流量时,由于peer-link接口反复删除和添加MAC地址表项,M-LAG设备将对流量进行多次广播,造成单播流量泛洪。
通过配置本命令,可以使peer-link接口不立即删除MAC地址表项,而根据mac-address timer配置的MAC地址老化时间刷新MAC地址表。
# 开启M-LAG peer-link接口的MAC地址保持功能。
[Sysname] m-lag peer-link mac-address hold
·     mac-address timer(二层技术-以太网交换命令参考/MAC地址表)
m-lag peer-link reserved命令用来配置peer-link链路的保留VLAN。
undo m-lag peer-link reserved命令用来删除指定的保留VLAN。
未配置peer-link链路的保留VLAN。
VLAN视图
在三层组播和组播VXLAN支持M-LAG场景下,当M-LAG上行链路故障时,三层组播流量无法通过peer-link链路绕行到另一台M-LAG设备,导致组播流量转发异常。此时,可以通过配置本命令,将peer-link接口加入保留VLAN中,使peer-link接口可以作为组播表项的出接口,实现将peer-link作为逃生链路,避免三层组播流量转发失败。
# 配置VLAN 10为peer-link链路的保留VLAN。
[Sysname] vlan 10
[Sysname-vlan10] m-lag peer-link reserved
m-lag keepalive { ip | ipv6 }命令用来配置M-LAG Keepalive报文的参数。
undo m-lag keepalive { ip | ipv6 }命令用来恢复缺省情况。
m-lag keepalive { ip | ipv6 } destination { ipv4-address | ipv6-address } [ source { ipv4-address | ipv6-address } | udp-port udp-number | vpn-instance vpn-instance-name ] *
未配置M-LAG Keepalive报文的参数。
ip:Keepalive报文IPv4地址。
ipv6:Keepalive报文IPv6地址。
destination:Keepalive报文目的地址,指定的目的IP地址为对端设备接口的IP地址。
source:Keepalive报文源地址,指定的源IP地址为本地设备接口的IP地址。如果不指定本参数,则Keepalive报文中源IP地址为出接口的IP地址。
ipv4-address:IPv4地址。
ipv6-address:IPv6地址。
udp-port udp-number:Keepalive报文的目的UDP端口。udp-number表示UDP端口号,取值为1~65535,缺省值为6400。
vpn-instance vpn-instance-name:指定Keepalive链路所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则Keepalive报文地址属于公网。如果指定的VPN实例不存在,则相当于不指定本参数。
本地设备仅能识别以目的IP地址为源地址的Keepalive报文。当收到源IP地址为其他IP地址的Keepalive报文时,Keepalive链路变为down。
本地设备和邻居设备的UDP端口号需配置一致,否则无法收到对端的Keepalive报文。
配置Keepalive报文的参数时,如果不指定source参数,则Keepalive接口可能无法作为系统保留接口而被置为MAD DOWN状态,要确保Keepalive接口作为系统保留接口,请在配置Keepalive报文参数时指定source参数并将源IP地址配置为本地设备接口的真实IP地址。
多次执行本命令,最后一次执行的命令生效。
# 配置Keepalive报文的目的IPv4地址为192.168.68.125,源IPv4地址为192.168.68.100。
[Sysname] m-lag keepalive ip destination 192.168.68.125 source 192.168.68.100
·     display m-lag keepalive
m-lag keepalive hold-time命令用来配置peer-link链路down后等待检测故障原因的时间。
undo m-lag keepalive hold-time命令用来恢复缺省情况。
m-lag keepalive hold-time value
peer-link链路down后等待检测故障原因的时间为3秒。
value:peer-link链路down后等待检测故障原因的时间,取值范围为3~10,单位为秒。
peer-link链路down后,设备启动本定时器。设备需要检测peer-link链路down的原因,是设备故障即本端M-LAG设备未收到对端M-LAG设备的Keepalive报文,还是peer-link链路故障。
在定时器超时前收到对端的Keepalive报文,则认为是peer-link链路故障,否则认为设备故障。
通过配置本命令,等待链路上Keepalive报文收发完全,防止因为延迟造成错误检测。
# 配置peer-link链路down后等待检测故障原因的时间为5秒。
[Sysname] m-lag keepalive hold-time 5
m-lag keepalive interval命令用来设置Keepalive报文发送间隔和超时时间。
undo m-lag keepalive interval命令用来恢复缺省情况。
m-lag keepalive interval interval [ timeout timeout ]
Keepalive报文发送的时间间隔为1000毫秒,超时时间间隔为5秒。
interval interval:Keepalive报文发送间隔,取值范围为100~10000,单位为毫秒。
timeout timeout:Keepalive报文的超时时间,取值范围为3~20,单位为秒。本端M-LAG设备的Keepalive报文超时时间必须配置成对端M-LAG设备的Keepalive报文发送间隔的2倍以上。
当对端M-LAG设备在超时时间内没有收到本端M-LAG设备发送的Keepalive报文,则认为对端M-LAG设备状态为down。
为了保证M-LAG正常运行,用户需要将本端M-LAG设备和对端M-LAG设备的Keepalive报文的发送间隔配置一致,否则可能引起功能异常。
# 配置Keepalive报文发送的间隔为2000毫秒和超时时间为6秒。
[Sysname] m-lag keepalive interval 2000 timeout 6
Changing the keepalive interval might cause system setup failure. Continue? [Y/N]:y
m-lag keepalive standby { ip | ipv6 }命令用来配置M-LAG的Keepalive备用链路。
undo m-lag standby keepalive { ip | ipv6 }命令用来恢复缺省情况。
m-lag keepalive standby { ip | ipv6 } destination { ipv4-address | ipv6-address } [ source { ipv4-address | ipv6-address } | vpn-instance vpn-instance-name ] *
undo m-lag keepalive standby { ip | ipv6 }
未配置M-LAG 的Keepalive备用链路。
ip:Keepalive报文使用IPv4地址。
ipv6:Keepalive报文使用IPv6地址。
destination:Keepalive报文的目的地址,指定的目的IP地址为对端设备接口的IP地址。
source:Keepalive报文的源地址,指定的源IP地址为本地设备接口的IP地址。如果不指定本参数,则Keepalive报文中源IP地址为出接口的IP地址。
应用场景
本命令配置的Keepalive备用链路用于增强Keepalive机制的可靠性。
工作机制
同时通过m-lag keepalive { ip | ipv6 }命令以及m-lag keepalive standby { ip | ipv6 }命令配置了Keepalive的主备链路后,正常情况下,使用Keepalive主用链路交互Keepalive报文。当Keepalive主用链路的IP地址在一定时间内未接收到Keepalive报文时,可以使用备用链路来交互Keepalive报文。
如果在一定时间内主备Keepalive链路均未收到Keepalive报文,则主备Keepalive链路均DOWN,系统认为Keepalive链路出现故障。
注意事项
Keepalive备用链路使用的目的UDP端口与主链路相同,无需配置。
多次执行本命令时,最后一次执行的命令生效。
# 配置Keepalive的备用链路的目的IPv4地址为192.168.68.125,源IPv4地址为192.168.68.100。
[Sysname] m-lag keepalive standby ip destination 192.168.68.125 source 192.168.68.100
m-lag keepalive track命令用来配置Keepalive链路与Track项关联。
undo m-lag keepalive track命令用来恢复缺省情况。
m-lag keepalive track track-entry-number
未配置Keepalive链路与Track项关联。
track-entry-number:指定Track项序号,取值范围为1~1024。
通过配置Keepalive链路与Track项关联,通过Track项来监测Keepalive链路的状态,从而可以使设备根据网络环境的变化快速感知到Keepalive链路的状态并进行更新。关于Track项的详细介绍,请参见“可靠性配置指导”中“Track”。
建议在配置本命令时,避免指定与M-LAG MAD关联的Track项,以防止M-LAG系统状态发生震荡。
# 配置Keepalive链路与Track项1关联。
<Sysname> system
[Sysname] m-lag keepalive track 1
m-lag mad default-action命令用来配置在M-LAG系统分裂后接口是否处于M-LAG MAD DOWN状态。
undo m-lag mad default-action命令用来恢复缺省情况。
m-lag mad default-action { down | none }
在M-LAG系统分裂后接口处于M-LAG MAD DOWN状态。
down:表示M-LAG系统分裂后接口处于M-LAG MAD DOWN状态。
none:表示M-LAG系统分裂后接口保持原状态不变。
缺省情况下,peer-link链路故障后,为了防止从设备继续转发流量,从设备会自动关闭本设备上除M-LAG保留接口外的所有接口。如果希望M-LAG系统中有特殊用途的接口(比如Keepalive接口)保持UP状态,可以通过m-lag mad exclude interface命令将其配置为保留接口。
为了保证M-LAG系统分裂后M-LAG设备能够正常工作,需要将大量逻辑接口(除物理接口外的所有接口,例如聚合接口及其成员口、Loopback接口、Tunnel接口等)配置为保留接口。此时,为了减少配置工作量,可以通过m-lag mad default-action none命令配置设备上的接口在M-LAG系统分裂后保持原状态不变,然后使用m-lag mad include interface命令配置M-LAG系统分裂后需要处于M-LAG MAD DOWN状态的接口。
对于以下接口,不受本命令的影响:
·     M-LAG系统保留接口。
·     在接口上配置了强制端口up功能:
¡     通过loopback命令开启接口的环回功能。
¡     通过mirroring-group reflector-port命令为远程源镜像组配置反射端口。
¡     通过port up-mode命令强制开启光口。
# 配置在M-LAG系统分裂后接口处于M-LAG MAD DOWN状态。
[Sysname] m-lag mad default-action down
·     display m-lag mad verbose
·     loopback(二层技术-以太网交换命令参考/以太网接口)
·     mirroring-group reflector-port(网络管理和监控命令参考/端口镜像)
·     port up-mode(二层技术-以太网交换命令参考/以太网接口)
m-lag mad exclude interface命令用来配置保留接口。
undo m-lag mad exclude interface命令用来将接口配置为非保留接口。
m-lag mad exclude interface interface-type interface-number
undo m-lag mad exclude interface interface-type interface-number
未配置保留接口。
peer-link链路故障后,为了防止从设备继续转发流量,从设备会自动关闭本设备上除M-LAG保留接口外的所有接口。如果希望M-LAG系统中有特殊用途的接口(比如Keepalive接口)保持UP状态,可以将其配置为保留接口。
M-LAG保留接口包括系统保留接口和用户配置的保留接口。系统保留接口包括:
·     peer-link接口
·     peer-link接口所对应的二层聚合接口的成员接口
·     M-LAG接口
·     管理以太网接口
·     Keepalive接口
·     VLAN接口
·     VSI虚接口
配置M-LAG保留接口时,建议将逻辑接口与其绑定的物理接口均配置为保留接口。
# 配置Keepalive链路接口为保留接口。
[Sysname] m-lag mad exclude interface ten-gigabitethernet 1/0/1
·     display fib(三层技术-IP业务/IP转发基础)
·     display ip routing-table(三层技术-IP路由/IP路由基础)
m-lag mad exclude logical-interfaces命令用来配置所有逻辑接口为M-LAG保留接口。
undo m-lag mad exclude logical-interfaces命令用来恢复缺省情况。
所有逻辑接口未配置为M-LAG保留接口。
为了保证M-LAG系统分裂后M-LAG设备能够正常工作,需要将大量逻辑接口(除物理接口外的所有接口,例如聚合接口及其成员口、Loopback接口、Tunnel接口等)配置为保留接口。此时,为了减少配置工作量,可以通过本命令将所有逻辑接口配置为M-LAG保留接口。
如果同时存在本命令、m-lag mad exclude interface命令和m-lag mad include interface命令,则m-lag mad exclude interface命令和m-lag mad include interface命令优先生效。
# 配置所有的逻辑接口为M-LAG保留接口。
[Sysname] m-lag mad exclude logical-interfaces
m-lag mad include interface命令用来配置接口在M-LAG系统分裂后处于M-LAG MAD DOWN状态。
undo m-lag mad include interface命令用来取消接口在M-LAG系统分裂后处于M-LAG MAD DOWN状态的配置。
m-lag mad include interface interface-type interface-number
undo m-lag mad include interface interface-type interface-number
未指定在M-LAG系统分裂后处于M-LAG MAD DOWN状态的接口。
为了保证M-LAG系统分裂后M-LAG设备能够正常工作,需要将大量逻辑接口(除物理接口外的所有接口,例如聚合接口及其成员口、Loopback接口、Tunnel接口等)配置为保留接口。此时,为了减少配置工作量,可以先通过m-lag mad default-action none命令配置设备上的接口在M-LAG系统分裂后保持原状态不变,然后使用本命令配置M-LAG系统分裂后需要处于M-LAG MAD DOWN状态的接口。
系统自动配置M-LAG接口的成员口在M-LAG系统分裂后处于M-LAG MAD DOWN状态,不需要使用本命令配置。
·     M-LAG系统保留接口,通过display m-lag mad verbose命令查看。
·     在接口上配置了强制端口up功能:
# 配置二层聚合口1在M-LAG系统分裂后处于M-LAG MAD DOWN状态。
[Sysname] m-lag mad include interface bridge-aggregation 1
m-lag mad persistent命令用来开启M-LAG MAD DOWN状态保持功能。
undo m-lag mad persistent命令用来关闭M-LAG MAD DOWN状态保持功能。
M-LAG MAD DOWN状态保持功能处于关闭状态。
当peer-link链路故障,Keepalive链路正常工作时,主设备正常工作,从设备会自动关闭本设备上除M-LAG保留接口外的所有接口,将这些接口置为M-LAG MAD DOWN状态。如果此时Keepalive链路也发生故障,从设备上的接口会解除M-LAG MAD DOWN状态,并升级为主设备,使M-LAG系统中的两台设备都作为主设备转发流量,引起网络故障。为了避免以上情况,可以在设备上配置本命令,使设备上的接口一直处于M-LAG MAD DOWN状态,不参与流量转发。
当peer-link链路故障恢复后,为了防止丢包,从设备尽可能在延迟恢复时间内完成表项(MAC地址表、ARP表等)同步,其后该设备上处于M-LAG MAD DOWN状态的接口将恢复为up状态。
# 开启M-LAG MAD DOWN状态保持功能。
[Sysname] m-lag mad persistent
·     m-lag mad restore
m-lag mad restore命令用来解除设备上所有接口的M-LAG MAD DOWN状态。
m-lag mad restore
在开启M-LAG MAD DOWN状态保持功能场景下,如果负责转发流量的M-LAG设备故障,则可以强制解除另一台M-LAG设备上所有接口的M-LAG MAD DOWN状态,使设备正常转发流量,避免业务长时间中断。
当peer-link链路或Keepalive链路处于up状态时,不能执行本命令。
# 解除设备上所有接口的M-LAG MAD DOWN状态。
[Sysname] m-lag mad restore
To avoid network issues, make sure the primary device has failed and cannot forward traffic. Continue? [Y/N]:y
m-lag restore-delay命令用来配置延迟恢复时间。
undo m-lag restore-delay命令用来恢复缺省情况。
m-lag restore-delay value
定时器超时时间为300秒。
value:定时器超时时间,取值范围1~3600,单位为秒。
本定时器用来设置设备作为Secondary设备加入M-LAG系统时进行MAC地址表项等信息同步的最大时间。定时器超时之前,业务口(除M-LAG保留接口外的接口)状态为M-LAG MAD DOWN。定时器超时后,业务口状态变为up。
在表项较多或者进行ISSU升级时,可延长本定时器,以避免出现丢包或者其它转发问题。
# 配置延迟恢复定时器超时时间为50秒。
[Sysname] m-lag restore-delay 50
m-lag role priority命令用来指定M-LAG设备的角色优先级。
undo m-lag role priority命令用来恢复缺省情况。
m-lag role priority priority-value
M-LAG设备的角色优先级为32768。
priority-value:设备角色优先级,取值范围0~65535。该数值越小,优先级越高。
设备角色优先级用于两台设备间进行主从协商,值越小优先级越高,优先级高的为Primary设备。
如果优先级相同,那么比较两台设备的桥MAC地址,桥MAC地址较小的为Primary设备。
仅部分业务模块(如生成树)报文需要区分主从设备:
·     业务模块报文统一在主设备上处理,主设备M-LAG接口获取业务模块报文所携带信息后,将该信息的处理结果发送给从设备。
·     从设备的M-LAG接口收到业务模块报文时,会将该报文透传到主设备上,由主设备处理。
M-LAG系统建立后,不建议修改M-LAG设备的角色优先级,避免主从设备重新选举,导致网络震荡。
# 配置M-LAG设备的角色优先级为66。
[Sysname] m-lag role priority 66
·     display m-lag role
m-lag sequence enable命令用来开启M-LAG序列号校验功能。
undo m-lag sequence enable命令用来关闭M-LAG序列号校验功能。
M-LAG序列号校验功能处于关闭状态。
开启M-LAG序列号校验功能,即开启DRCP报文和Keepalive报文的序列号校验功能。
为了防止重放攻击,保证流量正常转发,可以通过配置本命令,识别非法攻击报文。配置本命令后,设备会在发送的报文中携带序列号,每次发送报文时其序列号均会增加,如果本端M-LAG设备收到报文的序列号与已经收到报文的序列号相同,或者小于上次收到的报文的序列号,则认为发生重放攻击。M-LAG设备会丢弃序列号校验失败的报文。
序列号校验的防攻击能力比较差,攻击者只要将侦听到的报文序列号增加,就可以欺骗报文接收者。同时使用认证功能,防止攻击者篡改报文内容,才可以提供更好的安全性。
设备整机重启后,如果攻击者使用之前获取的报文进行攻击,则对端未重启设备可能认可攻击报文。建议设备重启后更换认证密钥。
# 开启M-LAG序列号校验功能。
[Sysname] m-lag sequence enable
m-lag standalone enable命令用来开启M-LAG设备独立工作功能。
undo m-lag standalone enable命令用来关闭M-LAG设备独立工作功能。
m-lag standalone enable [ delay delay-time ]
undo m-lag standalone enable [ delay ]
M-LAG设备独立工作功能处于关闭状态。
delay delay-time:M-LAG设备切换到独立工作状态的延迟时间,取值范围为0~3600,单位为秒。如果不指定本参数,则延迟切换时间为0,即立即切换。
当M-LAG系统分裂时,为避免出现M-LAG系统中的两台设备都作为主设备转发流量的情况,可配置本命令,使M-LAG设备立即或经过一段时间切换到独立运行模式。
M-LAG设备切换到独立运行模式后,聚合接口发送的LACP报文中携带的M-LAG系统参数还原为聚合接口的LACP系统MAC地址和LACP优先级,使同一M-LAG组中的两个聚合接口的LACP系统MAC地址和LACP优先级不一致。这样只有一边聚合接口的成员端口可以被选中,被选中的设备独立运行转发业务流量,避免流量转发异常。
当peer-link链路和Keepalive链路均发生故障时,本命令才会生效。当对端M-LAG设备整机重启时,会通知本端M-LAG设备,本端M-LAG设备感知到peer-link链路和Keepalive链路未故障,此时本功能不会生效。对于设备下电引起peer-link链路和Keepalive链路均故障场景,建议配置的M-LAG设备切换到独立工作状态的延迟时间大于设备整机重启的时间,以避免M-LAG接口震荡引起流量转发异常;对于其他非设备下电引起peer-link链路和Keepalive链路均故障场景,建议配置较小的M-LAG设备切换到独立工作状态的延迟时间,以使设备尽快切换为独立工作模式。
建议M-LAG设备均配置本功能。
如果M-LAG系统的MAC地址不为任何一台M-LAG设备上实际存在的MAC地址,并且M-LAG接口中包含多个聚合成员端口时,开启M-LAG设备独立工作功能可能会导致M-LAG接口中的聚合成员端口状态发生震荡,请您充分了解其对网络产生的影响。
在单级M-LAG组网中,配置本命令前,需要保证M-LAG设备的LACP系统优先级大于连接M-LAG系统设备的LACP系统优先级,使参考端口位于连接M-LAG系统的设备上,避免连接M-LAG系统的设备的端口频繁震荡。
# 开启M-LAG设备独立工作功能。
[Sysname] m-lag standalone enable
m-lag system-mac命令用来配置M-LAG系统MAC地址。
undo m-lag system-mac命令用来恢复缺省情况。
m-lag system-mac { bridge-address | mac-address }
未配置M-LAG系统MAC地址。
bridge-address:桥MAC地址,格式为H-H-H。
mac-address:MAC地址,格式为H-H-H,不支持组播MAC地址、全0的MAC地址和全F的MAC地址。
为了能够让对端设备将M-LAG组中的两台设备看成一台设备,需要同一M-LAG组中,所有M-LAG设备的系统MAC地址必须相同。建议用户将系统MAC地址配置为其中一台M-LAG设备的桥MAC地址,防止MAC地址冲突。
修改M-LAG设备的系统MAC地址将会导致当前设备从已经建立的M-LAG组中分裂。因此,不建议在M-LAG组正常工作的情况下,修改系统MAC地址。
# 配置M-LAG系统MAC地址为0001-0001-0001。
[Sysname] m-lag system-mac 1-1-1
Changing the system MAC address might flap the intra-portal link and cause M-LAG system setup failure. Continue? [Y/N]:y
[Sysname]
m-lag system-number命令用来配置M-LAG系统编号。
undo m-lag system-number命令用来恢复缺省情况。
m-lag system-number system-number
未配置M-LAG系统编号。
system-number:系统编号,取值为1或2。
同一M-LAG组中的M-LAG设备应配置不同的系统编号。
修改M-LAG设备的系统编号将会导致当前设备从已经建立的M-LAG组中分裂。因此,不建议在M-LAG组正常工作的情况下,修改系统编号。
# 配置M-LAG系统编号为1。
[Sysname] m-lag system-number 1
Changing the system number might flap the intra-portal link and cause M-LAG system setup failure. Continue? [Y/N]:y
[Sysname]
m-lag system-priority命令用来配置M-LAG系统优先级。
undo m-lag system-priority命令用来恢复缺省情况。
m-lag system-priority priority
M-LAG系统优先级为32768。
priority:系统优先级,取值范围0~65535。该数值越小,优先级越高。
为了组成M-LAG组,同一M-LAG组中,所有M-LAG设备的系统优先级必须相同。
M-LAG组正常工作的情况下,为了能够让对端设备将M-LAG组中的两台设备看成一台设备,在与对端设备交互聚合组信息时,LACPDU中系统LACP优先级为本命令配置的M-LAG系统优先级。
修改M-LAG设备的系统优先级将会导致当前设备从已经建立的M-LAG组中分裂。因此,不建议在M-LAG组正常工作的情况下,修改系统优先级。
# 配置M-LAG系统优先级为64。
[Sysname] m-lag system-priority 64
Changing the system priority might flap the intra-portal link and cause M-LAG system setup failure. Continue? [Y/N]:y
[Sysname]
m-lag uplink-port enable命令用来配置指定接口为M-LAG上行链路接口。
undo m-lag uplink-port enable命令用来取消配置指定接口为M-LAG上行链路功能。
未配置M-LAG上行链路接口
二层以太网接口视图
三层以太网接口视图
二层聚合接口视图
三层聚合接口视图
应用场景
本命令用于配置M-LAG设备连接上行网络的接口,并根据该接口的状态来影响M-LAG系统的角色选举。
工作机制
M-LAG系统的peer-link链路down但可以收到Keepalive报文时,如果两台M-LAG设备都配置了上行链路接口,则上行链路接口先up的M-LAG设备会成为主设备,后续用户与上行网络间的流量全部仅通过主设备转发。
如果在指定时间内,本端M-LAG设备未收到对端M-LAG设备发送的Keepalive报文,且此时peer-link链路状态为down,则本端M-LAG设备认为对端M-LAG设备状态为down:
·     本端设备为主设备,且本端设备上配置了上行链路接口时,如果本端设备存在处于up状态的上行链路接口,则本端仍为主设备;否则,本端设备角色变为None角色。
·     本端设备为主设备,且本端设备上未配置上行链路接口时,如果本端设备存在处于up状态的M-LAG接口,则本端仍为主设备;否则,本端设备角色变为None角色。
·     本端设备为从设备时,升级为主设备。如果本端设备上配置了上行链路接口,则此后只要本端设备上存在处于up状态的上行链路接口,就保持为主设备,否则本端设备角色变为None角色。
·     本端设备为从设备时,升级为主设备。如果本端设备上未配置上行链路接口,则此后只要本端设备上存在处于up状态的M-LAG接口,就保持为主设备,否则本端设备角色变为None角色。
当设备为None角色时,设备不能收发Keepalive报文,Keepalive链路处于down状态。
注意事项
无法通过本命令将聚合成员端口以及peer-link接口配置为上行链路接口。
如需配置M-LAG上行链路接口,请在M-LAG系统两端设备上均配置M-LAG上行链路接口,以免M-LAG设备角色选举发生异常。
# 配置接口Ten-GigabitEthernet1/0/1为M-LAG的上行链路接口。
[System-Ten-GigabitEthernet1/0/1] m-lag uplink-port enable
port m-lag active-standby election命令用来配置主备模式M-LAG用于选举的协议报文类型。
undo port m-lag active-standby election命令用来恢复缺省情况。
port m-lag active-standby election { arp | dhcp | igmp | mld | nd } *
未配置主备模式M-LAG用于选举的协议报文类型,主备模式无法生效。
二层聚合接口视图
arp:基于ARP报文进行M-LAG主备选举。
dhcp:基于DHCP报文进行M-LAG主备选举。
igmp:基于IGMP报文进行M-LAG主备选举。
mld:基于MLD报文进行M-LAG主备选举。
nd:基于ND报文进行M-LAG主备选举。
应用场景
缺省情况下,两台M-LAG设备上的M-LAG接口对流量进行负载分担,都可以参与转发,但M-LAG系统接入的是使用主备网卡的设备时,这些设备只有主网卡可以收发和处理流量,M-LAG接口进行负载分担的双活模式已经不再适用。在此场景中,需要配置M-LAG接口为主备模式,使得只有与主网卡连接的M-LAG接口能够转发流量。
工作机制
在主备模式下,正常情况下仅主网卡连接的M-LAG接口链路收发流量,该M-LAG接口被称为主用M-LAG接口;备网卡连接的M-LAG接口链路仅起到备份作用,不收发流量,该M-LAG接口被称为备用M-LAG接口。主用M-LAG接口链路故障时,才使用备用M-LAG接口转发流量。
M-LAG系统的主备M-LAG接口需要根据主网卡发出的协议报文进行选举。收到了主网卡发出的协议报文的M-LAG接口成为主用M-LAG接口,另一端的M-LAG接口则成为备用M-LAG接口。主备M-LAG接口的角色不会主动变化或恢复,如果M-LAG接口接入的设备对主备网卡进行了切换,则收到选举协议报文的M-LAG接口发生变化,触发重新选举,主备M-LAG接口的角色才会发生变化。
目前支持用于选举的协议报文为:ARP、DHCP、IGMP、MLD以及ND报文。
注意事项
本命令需要在配置为M-LAG接口的二层聚合接口视图下配置,M-LAG接口必须通过port m-lag group active-standby命令被配置为主备模式,本命令才能执行成功。反之,主备模式的M-LAG接口必须配置本命令,且两端M-LAG设备要配置一致。
# 配置主备模式M-LAG的选举报文类型是IGMP。
<Sysname> system
[Sysname-Bridge-Aggregation1] port m-lag active-standby election igmp
·     port m-lag group
port m-lag group命令用来配置聚合接口加入M-LAG组。
undo port m-lag group命令用来恢复缺省情况。
port m-lag group group-id [ active-standby | allow-single-member ]
聚合接口未配置为M-LAG接口。
二层聚合接口视图
group-id:指定M-LAG聚合组的编号,取值范围为1~1024。
active-standby:将M-LAG接口配置为主备模式。
allow-single-member:允许M-LAG接口单边接入。当M-LAG接口单边接入时,不将该M-LAG接口置为M-LAG DOWN状态。如果未指定本参数,则M-LAG接口单边接入时,将该M-LAG接口置为M-LAG DOWN状态。建议在动态聚合接口下指定本参数。
应用场景
allow-single-member参数仅支持在部署控制器的组网环境中使用。以A设备与B设备组成M-LAG系统为例,A设备、B设备分别与控制器建立OpenFlow channel。当A设备与控制器建立的OpenFlow channel断开时,控制器通知B设备,A设备已断开连接,此时B设备上allow-single-member参数生效(M-LAG端口不会被置为MAD down状态),B设备将允许配置该参数的M-LAG接口单边接入B设备,继续正常工作。
但M-LAG系统接入的是使用主备网卡的设备时,这些设备只有主网卡可以收发和处理流量,M-LAG接口进行负载分担的双活模式已经不再适用。在此场景中,需要指定active-standby参数,配置M-LAG接口为主备模式,使得只有与主网卡连接的M-LAG接口能够转发流量。
注意事项
未指定任何参数时,M-LAG接口为双活模式,即两端M-LAG设备上的M-LAG接口都可以收发流量,并进行负载分担转发。
本端M-LAG接口指定了active-standby参数时,对端相同编号的M-LAG接口也必须指定active-standby参数。指定了active-standby参数后,必须要通过port m-lag active-standby election命令配置主备模式M-LAG用于选举的协议报文类型,主备模式才能正常生效。
M-LAG主备模式仅适用于M-LAG接口下挂主备网卡的场景,且M-LAG接口所在的二层聚合组需要工作在静态聚合模式下。
如果当前二层聚合接口已经配置为peer-link接口,则不允许再将其配置为M-LAG接口。
一个二层聚合接口与M-LAG组一一对应,不允许多个二层聚合接口加入同一个M-LAG组,也不允一个二层聚合组加入多个M-LAG组。
指定allow-single-member参数后,接入设备将当作单挂设备来处理。
为了避免环路,配置M-LAG接口单边接入配置时,需要先配置M-LAG接口,再将成员端口加入聚合;取消配置M-LAG接口单边接入时,需要先将成员端口退出聚合组,再取消配置为M-LAG接口。
# 将二层聚合接口1加入M-LAG组100。
[Sysname-Bridge-Aggregation1] port m-lag group 100
·     display m-lag summary
·     display m-lag verbose
·     port m-lag active-standby election
port m-lag peer-link命令用来配置二层聚合接口为peer-link接口。
undo port m-lag peer-link命令用来恢复缺省情况。
port m-lag peer-link port-id [ auto-negotiate ]
聚合接口不为peer-link接口。
二层聚合接口视图
port-id:表示peer-link接口索引,取值为1。
auto-negotiate:表示开启M-LAG系统参数自动协商功能。如果未指定本参数,则用户必须手工配置M-LAG系统参数,否则,M-LAG设备将无法进行角色计算。
配置peer-link接口时,可以通过指定auto-negotiate参数,开启M-LAG系统参数自动协商功能后。开启该功能后,M-LAG设备会对未手工配置的M-LAG系统参数进行自动协商,M-LAG系统参数的生成原则为:
·     M-LAG系统MAC地址:采用M-LAG设备中较小的桥MAC地址作为M-LAG系统MAC地址。
·     M-LAG系统编号:M-LAG设备中桥MAC较小的一端的M-LAG系统编号为1,另外一端为2。
·     M-LAG系统优先级:M-LAG设备均采用缺省的M-LAG优先级。
每台M-LAG设备上只能配置一个peer-link接口。
peer-link接口的带宽要大于M-LAG接口的带宽。
如果当前二层聚合接口已经配置为M-LAG接口,则不允许再将其配置为peer-link接口。
配置聚合接口为peer-link接口时:
·     如果该聚合接口上VLAN配置为缺省配置,则该聚合接口的链路类型改为Trunk类型,允许所有VLAN通过该Trunk端口,并将PVID设置为4094。
·     如果该聚合接口的链路类型为Trunk类型,则该聚合接口额外允许VLAN 4094通过,并将PVID修改为4094。
·     如果该聚合接口上的VLAN配置不属于上述两种情况,则不改变VLAN配置。
取消配置聚合接口为peer-link接口时,不修改该聚合接口上VLAN配置。
建议在peer-link接口上配置link-delay命令,以减少接口震荡对上层业务的影响。
配置peer-link接口后,需要配置undo mac-address static source-check enable命令,否则M-LAG功能不可用。
peer-link接口不允许开启或者关闭MAC地址学习功能。
对于peer-link接口对应的聚合组的成员端口,在其退出聚合组前需要先使用shutdown命令手工关闭。
# 配置二层聚合接口2为peer-link接口1。
[Sysname] interface bridge-aggregation 2
[Sysname-Bridge-Aggregation2] port m-lag peer-link 1
·     link-delay(二层技术-以太网交换命令参考/以太网链路聚合)
·     mac-address mac-learning enable(二层技术-以太网交换命令参考/MAC地址表)
port m-lag ipv6 virtual-ip命令用来配置接口的M-LAG虚拟IPv6地址。
undo port m-lag ipv6 virtual-ip命令用来恢复缺省情况。
VLAN接口视图:
port m-lag ipv6 virtual-ip ipv6-address { prefix-length [ active | standby ] [ virtual-mac mac-address ] | link-local }
undo port m-lag ipv6 virtual-ip [ ipv6-address ]
LoopBack接口视图:
port m-lag ipv6 virtual-ip ipv6-address { prefix-length [ active | standby ] | link-local }
VSI接口视图:
未配置接口的M-LAG虚拟IPv6地址。
VLAN接口视图
LoopBack接口视图
VSI接口视图
ipv6-address:虚拟IPv6地址。只能为全球单播地址。
prefix-length:前缀长度,取值范围为1~128。
active:虚拟IPv6地址在当前设备处于可用状态。
standby:虚拟IPv6地址在当前设备处于不可用状态。
virtual-mac mac-address:MAC地址,格式为H-H-H,不支持组播MAC地址、全0的MAC地址和全F的MAC地址。
link-local:指定链路本地地址为虚拟IPv6地址。仅用于双活网关中OSPFv3邻居建立场景。
不同类型接口的M-LAG虚拟IP地址用于不同组网场景:
·     VLAN接口:双活网关场景。
·     Loopback接口:用户通过AAA、802.1X等接入M-LAG设备场景。
·     VSI接口:EVPN分布式网关支持M-LAG场景。
如果未指定activestandby参数,则该虚拟IPv6地址只在角色为Primary的M-LAG设备上处于可用状态。
执行undo port m-lag ipv6 virtual-ip命令时,如果未指定ipv6-address参数,则表示删除接口下所有M-LAG虚拟IPv6地址。
当peer-link接口故障时,配置为standby的虚拟IPv6地址在角色为Primary的M-LAG设备上转为可用状态。如果配置为standby的虚拟IPv6地址未指定虚拟MAC地址,则使用接口的MAC地址作为虚拟MAC地址。此时,与M-LAG设备相连的其他设备会更新ND表项。
在同一接口下,多次执行本命令:
·     只能配置2个M-LAG虚拟IPv6地址。
·     同一虚拟IPv6地址配置不同虚拟MAC地址时,最后一次执行的命令生效。
·     不同虚拟IPv6地址不能配置同一虚拟MAC地址。
·     配置VLAN接口的M-LAG虚拟IPv6地址时,两台M-LAG设备相同的虚拟IPv6需要配置相同的虚拟MAC地址。
配置VLAN接口的M-LAG虚拟IPv4/IPv6地址时,对于同一虚拟MAC地址,虚拟IPv4地址和虚拟IPv6地址在M-LAG设备上的状态必须一致,同为active或同为standby
在用户侧设备通过M-LAG双归接入网关的场景中,M-LAG设备作为网关进行三层转发。由于不同M-LAG设备上的网关接口(例如VLAN接口、VSI虚接口)需要具有相同的IP地址和MAC地址,M-LAG设备与用户侧设备之间无法建立路由邻居关系。为了解决上述问题,可以在M-LAG设备上配置本功能,并配置路由协议(例如BGP和OSPFv3)使用虚拟IP地址与其他设备建立邻居关系。
M-LAG设备与其他设备建立BGP邻居关系时,需要在M-LAG设备上进行以下配置:
·     配置port m-lag ipv6 virtual-ip ipv6-address prefix-length [ active | standby ] [ virtual-mac mac-address ]命令。
·     配置peer source-address命令并将虚拟IPv6地址作为源IPv6地址。
M-LAG设备与其他设备建立OSPFv3邻居关系时,需要M-LAG设备上配置port m-lag ipv6 virtual-ip ipv6-address link-local命令。
在双活网关场景下,配置本命令时,需要在两台M-LAG设备上配置不同的虚拟IPv6地址,且均配置为active状态。在VLAN接口下配置本命令时,如果配置虚拟MAC地址,则指定的虚拟MAC地址需要和VLAN接口下通过mac-address命令配置的MAC地址保持一致。
# 配置VLAN接口的M-LAG虚拟IPv6地址为1::10/64,该地址处于可用状态。
[Sysname-Vlan-interface2] port m-lag ipv6 virtual-ip 1::10 64 active virtual-mac 1-1-1
·     nas-ip(安全命令参考/AAA)
·     peer source-address(三层技术-IP路由命令参考/BGP)
·     port-security m-lag load-sharing-mode(安全命令参考/端口安全)
port m-lag system-mac命令用来配置M-LAG系统MAC地址。
undo port m-lag system-mac命令用来恢复缺省情况。
port m-lag system-mac mac-address
未配置M-LAG系统MAC地址。
聚合接口视图
为了能够让对端设备将M-LAG组中的两台设备看成一台设备,同一M-LAG组中,相互配对的M-LAG接口的系统MAC地址必须相同。建议用户将系统MAC地址配置为其中一台M-LAG设备的桥MAC地址,防止MAC地址冲突。
修改M-LAG接口的系统MAC地址将会导致当前设备从已经建立的M-LAG组中分裂。因此,不建议在M-LAG组正常工作的情况下,修改系统MAC地址。
只有聚合接口配置为M-LAG接口后,才允许在该聚合接口视图下配置本命令。
M-LAG系统MAC地址支持在系统视图和聚合接口视图下配置。对于一个聚合接口来说,优先采用该聚合接口下的配置,只有该聚合接口下未进行配置时,才采用系统视图下的配置。
# 在二层聚合接口1下配置M-LAG系统MAC地址为0001-0001-0001。
[Sysname-Bridge-Aggregation1] port m-lag system-mac 1-1-1
·     m-lag system-mac
port m-lag system-priority命令用来配置M-LAG系统优先级。
undo port m-lag system-priority命令用来恢复缺省情况。
port m-lag system-priority priority
M-LAG系统优先级为32768。
聚合接口视图
为了组成M-LAG组,同一M-LAG组中,相互配对的M-LAG接口的系统优先级必须相同。
M-LAG系统优先级支持在系统视图和聚合接口视图下配置。对于一个聚合接口来说,优先采用该聚合接口下的配置,只有该聚合接口未进行配置或配置为缺省值时,才采用系统视图下的配置。
# 在二层聚合接口1下配置M-LAG系统优先级为64。
[Sysname-Bridge-Aggregation1] port m-lag system-priority 64
·     m-lag system-priority
port m-lag virtual-ip命令用来配置接口的M-LAG虚拟IPv4地址。
undo port m-lag virtual-ip命令用来恢复缺省情况。
VLAN接口视图:
port m-lag virtual-ip ipv4-address { mask-length | mask } [ active | standby ] [ virtual-mac mac-address ]
undo port m-lag virtual-ip [ ipv4-address ]
LoopBack接口视图:
VSI接口视图:
未配置接口的M-LAG虚拟IPv4地址。
VLAN接口视图
LoopBack接口视图
VSI接口视图
ipv4-address:M-LAG虚拟IPv4地址。
mask-length:掩码长度,取值范围为1~31。
mask:网络掩码,为点分十进制格式。
active:虚拟IPv4地址在当前设备处于可用状态。
standby:虚拟IPv4地址在当前设备处于不可用状态。
virtual-mac mac-address:虚拟MAC地址,格式为H-H-H,不支持组播MAC地址、全0的MAC地址和全F的MAC地址。
·     VLAN接口:双活网关场景。
如果未指定activestandby参数,则该虚拟IPv4地址只在角色为Primary的M-LAG设备上处于可用状态。
执行undo port m-lag virtual-ip命令时,如果未指定ipv4-address参数,则表示删除接口下所有M-LAG虚拟IPv4地址。
当peer-link接口故障时,配置为standby的虚拟IPv4地址在角色为Primary的M-LAG设备上转为可用状态。如果配置为standby的虚拟IPv4地址未指定虚拟MAC地址,则使用接口的MAC地址作为虚拟MAC地址。此时,与M-LAG设备相连的其他设备会更新ARP表项。
在同一接口下,多次执行本命令:
·     只能配置2个M-LAG虚拟IPv4地址。
·     同一虚拟IPv4地址配置不同虚拟MAC地址时,最后一次执行的命令生效。
·     不同虚拟IPv4地址不能配置同一虚拟MAC地址。
·     配置VLAN接口的M-LAG虚拟IPv4地址时,两台M-LAG设备相同的虚拟IPv4需要配置相同的虚拟MAC地址。
在用户侧设备通过M-LAG双归接入网关的场景中,M-LAG设备作为网关进行三层转发。由于不同M-LAG设备上的网关接口(例如VLAN接口、VSI虚接口)需要具有相同的IP地址和MAC地址,M-LAG设备与用户侧设备之间无法建立路由邻居关系。为了解决上述问题,可以在M-LAG设备上配置本功能,并配置路由协议(例如BGP和OSPF)使用虚拟IP地址与其他设备建立邻居关系。
·     配置port m-lag virtual-ip ipv4-address { mask-length | mask } [ active | standby ] [ virtual-mac mac-address ]命令。
·     配置peer source-address命令并将虚拟IPv4地址作为源IPv4地址。
M-LAG设备与其他设备建立OSPF邻居关系时,需要在M-LAG设备上进行以下配置:
·     配置ospf peer sub-address enable命令并将虚拟IPv4地址作为从IPv4地址。
在双活网关场景下,配置本命令时,需要在两台M-LAG设备上配置不同的虚拟IPv4地址,且均配置为active状态。在VLAN接口下配置本命令时,如果配置虚拟MAC地址,则指定的虚拟MAC地址需要和VLAN接口下通过mac-address命令配置的MAC地址保持一致。
# 配置VLAN接口2的M-LAG虚拟IPv4地址为10.10.10.10/24,该地址处于可用状态。
[Sysname-Vlan-interface2] port m-lag virtual-ip 10.10.10.10 24 active virtual-mac 1-1-1
·     ospf peer sub-address enable(三层技术-IP路由命令参考/OSPF)
1.1.48  reset m-lag drcp statistics
reset m-lag drcp statistics命令用来清除M-LAG的DRCP统计信息。
reset m-lag drcp statistics [ interface interface-list ]
interface interface-list:表示清除指定M-LAG接口或peer-link接口上的DRCP统计信息。interface-list为M-LAG端口列表,表示一个或多个M-LAG端口。表示方式为interface-list = interface-type interface-number1 [ to interface-type interface-number2 ]。其中,interface-type为接口类型,interface-number1interface-number2为接口编号。interface-number2的值要大于等于interface-number1的值。若未指定本参数,则清除所有M-LAG端口上的DRCP统计信息。
# 清除所有M-LAG接口上的DRCP统计信息。
<Sysname> reset m-lag drcp statistics
·     display m-lag drcp statistics
1.1.49  reset m-lag troubleshooting history
reset m-lag troubleshooting history命令用来清除M-LAG历史故障信息。
# 清除M-LAG历史故障信息。
<Sysname> reset m-lag troubleshooting history
·     display m-lag troubleshooting
