02-虚拟化技术命令参考
03-Context命令
本章节下载 03-Context命令  (431.22 KB)
03-Context命令
  录
1 Context
1.1 缺省Context上支持的Context配置命令
1.1.1 allocate interface
1.1.2 allocate vlan
1.1.3 allocate vxlan
1.1.4 capability security-policy-rule maximum
1.1.5 capability session maximum
1.1.6 capability session maximum threhold
1.1.7 capability session rate
1.1.8 capability session rate threshold
1.1.9 capability sslvpn-user maximum
1.1.10 capability throughput
1.1.11 context
1.1.12 context start
1.1.13 context-capability inbound broadcast single
1.1.14 context-capability inbound broadcast total
1.1.15 context-capability inbound drop-logging enable
1.1.16 context-capability inbound multicast single
1.1.17 context-capability inbound multicast total
1.1.18 context-capability throughput alarm enable
1.1.19 context-capability throughput drop-logging enable
1.1.20 description
1.1.21 display context
1.1.22 display context capability
1.1.23 display context capability inbound broadcast
1.1.24 display context capability inbound multicast
1.1.25 display context configuration
1.1.26 display context interface
1.1.27 display context online-users sslvpn
1.1.28 display context reboot
1.1.29 display context resource
1.1.30 display context statistics
1.1.31 display context vlan
1.1.32 limit-resource cpu
1.1.33 limit-resource memory
1.1.34 reset context capability inbound broadcast
1.1.35 reset context capability inbound multicast
1.1.36 reset context reboot
1.1.37 snmp-agent trap enable sib
1.1.38 switchto context
1.1.39 tar context log
1.2 非缺省Context上支持的Context配置命令
1.2.1 display context interface
1.2.2 display context reboot
1.2.3 reset context reboot
1 Context
本特性的支持情况与设备型号有关,请以设备的实际情况为准。
系列
型号
F5000系列
F5000-AI-160-G、F5000-AI-130-G、F5000-AI-120-G、F5000-AI-110-G、F5000-AI-55-G、F5000-AI-25-G、F5000-AI-15-G、F5000-CN160-G、F5000-E-G、F5000-E-G2、F5000-S-G2、F5000-M-G2、F5000-A-G2、F5000-AI160、F5000-CN160、F5000-CN-G55、F5080、F5030
支持
F1000系列
F1000-AK9130、F1000-AI-15、F1000-AI-10、F1000-AI-05-G、F1000-AI-03-G、F1000-AI-05-GS、F1000-AK1080-G、F1000-AK1050-G
不支持
F1000-AI-90、F1000-AI-55、F1000-AI-35、F1000-AI-25、F1000-AI-03-E、F1000-AI-90-G、F1000-AI-80-G、F1000-AI-75-G、F1000-AI-65-G、F1000-AI-55-G、F1000-AI-35-G、F1000-AI-25-G、F1000-AK1380-G、F1000-AK1300-G、F1000-AK1220-G、F1000-AK1180-G
支持
插卡
LSEM1FWESD0
支持
本章节描述的是登录到物理设备(即缺省Context)后,在缺省Context上可以执行的Context配置命令。
allocate interface命令用来为Context分配接口。
undo allocate interface命令用来取消为Context分配的接口。
allocate interface { interface-type interface-number }&<1-24> [ share ]
undo allocate interface { interface-type interface-number }&<1-24>
allocate interface interface-type interface-number1 to interface-type interface-number2 [ share ]
undo allocate interface interface-type interface-number1 to interface-type interface-number2
设备上的所有接口都属于缺省Context,不属于任何非缺省Context。
Context视图
{ interface-type interface-number }&<1-24>:表示给Context分配非连续的接口。interface-type interface-number表示接口类型和编号,&<1-24>表示前面的参数最多可以输入24次。
interface-type interface-number1 to interface-type interface-number2:表示给Context分配一组连续的接口。其中,interface-type表示接口类型,interface-number1表示起始接口的编号,interface-number2表示结束接口的编号。起始接口和结束接口的类型必须相同,并且处于同一接口板上,否则将配置失败。
share:表示接口是否共享。不指定该参数表示独占。
·     独占方式分配(不带share参数)。使用该方式分配的接口仅归该Context所有、使用。用户登录该Context后,能查看到该接口,并执行接口支持的所有命令。
·     共享方式分配(带share参数)。使用该方式分配的接口归多个Context所有、使用。在缺省Context内仍然存在该接口,可执行接口支持的所有命令;在分配给的非缺省Context内,会新建同名接口,用户登录这些Context后,能查看到该接口,但只能执行description以及网络/安全相关的命令。
·     逻辑接口仅支持共享方式分配,物理接口支持独占和共享两种方式分配。
# 将接口GigabitEthernet1/0/1和GigabitEthernet1/0/3以共享的方式分配给context sub1。
[Sysname] context sub1
[Sysname-context-2-sub1] allocate interface gigabitethernet 1/0/1 gigabitethernet 1/0/3 share
1.1.2  allocate vlan
allocate vlan命令用来为Context分配VLAN。
undo allocate vlan命令用来取消为Context分配的VLAN。
allocate vlan vlan-id&<1-24>
undo allocate vlan vlan-id&<1-24>
allocate vlan vlan-id1 to vlan-id2
undo allocate vlan vlan-id1 to vlan-id2
没有为Context分配VLAN。
Context视图
vlan-id&<1-24>表示给Context分配非连续的VLAN。vlan-id表示VLAN的编号,&<1-24>表示前面的参数最多可以输入24次。
vlan-id1 to vlan-id2表示给Context分配一组连续的VLAN。其中,vlan-id1表示起始VLAN的编号,vlan-id2表示结束VLAN的编号。
创建Context时,通过vlan-unshared参数可选择是否和其它Context共享VLAN:
·     如果选择和其它Context共享VLAN,可以通过本命令将设备上存在的除VLAN 1以外的静态VLAN分配给非缺省Context。共享VLAN由多个Context共同所有。VLAN被分配后,用户须在缺省Context内对该VLAN配置,非缺省Context内不能配置该VLAN,只能查看该VLAN的相关信息。
·     如果选择不和其它Context共享VLAN,请登录该Context,并使用vlan命令创建VLAN 2~VLAN 4094。VLAN 1为缺省VLAN,用户不能手工创建和删除。Context各自使用和管理VLAN,互不干扰。
# 将VLAN100分配给context sub1。
[Sysname-context-2-sub1] allocate vlan 100
·     display context vlan
allocate vxlan命令用来为Context分配VXLAN。
undo allocate vxlan命令用来取消为Context分配的VXLAN。
allocate vxlan vxlan-id&<1-24>
undo allocate vxlan vxlan-id&<1-24>
allocate vxlan vxlan-id1 to vxlan-id2
undo allocate vxlan vxlan-id1 to vxlan-id2
没有为Context分配VXLAN。
Context视图
vxlan-id&<1-24>:表示给Context分配非连续的VXLAN。vxlan-id表示VXLAN的编号,取值范围为0~16777215,&<1-24>表示前面的参数最多可以输入24次。
vxlan-id1 to vxlan-id2:表示给Context分配一组连续的VXLAN。其中,vxlan-id1表示起始VXLAN的编号,vxlan-id2表示结束VXLAN的编号,vxlan-id1vxlan-id2的取值范围为0~16777215。
为Context分配的VXLAN仅归该Context所有,其他Context不能对其进行使用、配置。
# 将VXLAN 100分配给Context sub1。
[Sysname-context-2-sub1] allocate vxlan 100
capability security-policy-rule maximum命令用来设置Context的安全策略规则总数限制。
undo capability security-policy-rule maximum命令用来恢复缺省情况。
capability security-policy-rule maximum max-number
未对Context的安全策略规则总数进行限制。
Context视图
max-number:表示Context内可配置的安全策略规则最大数目,取值范围为1~4294967295。
一个Context内可以配置多个安全策略规则。如果不加限制,会出现大量规则占用过多的内存的情况,影响Context的其它功能正常运行。所以,请根据需要为Context设置安全策略规则总数限制。当规则总数达到限制值时,后续不能新增规则。
如果设置的最大值比当前存在的规则总数小,配置仍会成功,多出的规则不会删除,依然生效,但不能新增规则。
# 配置Context的安全策略规则数最多为1000条。
[Sysname] context cnt2
[Sysname-context-2-cnt2] capability security-policy-rule maximum 1000
·     display security-policy ip(安全命令参考/安全策略)
capability session maximum命令用来设置Context的单播会话并发数限制。
undo capability session maximum命令用来恢复缺省情况。
capability session maximum max-number
未对Context允许的单播会话并发数进行限制。
Context视图
max-number:允许同时存在的最大单播会话数目,取值范围为1~4294967295。
如果一个Context建立了太多会话会导致其他Context的会话由于内存不够而无法建立,为了防止这种情况,需要限制Context建立会话的数量,当会话总数达到限制值时,后续不能新建会话。
如果设置的最大值比当前存在的会话总数小,配置仍会成功,但不允许新建会话,且已经创建的会话不会被删除,依然生效。直到已建立的会话通过老化机制使得会话总数低于配置的最大值后,系统才允许新建会话。
Context会话并发数限制对本机流量不生效,例如:FTP、Telnet、SSH、HTTP和HTTP类型的七层负载均衡等业务。
# 配置Context cnt2上的单播会话并发数为1000000。
[Sysname-context-2-cnt2] capability session maximum 1000000
·     context
·     display session statistics(安全命令参考/会话管理)
capability session maximum threhold命令用来设置Context的单播会话并发数上限使用率告警阈值。
undo capability session maximum threhold命令用来恢复缺省情况。
capability session maximum threshold threshold-value
undo capability session maximum threshold
Context的单播会话并发数上限使用率告警阈值为95%。
Context视图
threshold-value:Context的单播会话并发数上限使用率告警阈值,取值范围为1~99,单位为百分比。
当Context下单播会话并发数上限使用率超过指定阈值时,发送会话并发数上限使用率超过阈值告警;当会话并发数上限使用率下降至指定阈值时,会发送会话并发数上限使用率低于阈值告警。
# 配置Context 1上的单播会话并发数上限使用率告警阈值为80%。
[Sysname] context 1
[Sysname-context-2-1] capability session maximum threshold 80
·     context
capability session rate命令用来设置Context的会话新建速率限制。
undo capability session rate命令用来恢复缺省情况。
capability session rate max-value
undo capablility session rate
未对Context允许的会话新建速率进行限制。
Context视图
max-value:允许的会话新建速率最大值,单位为每秒会话个数。
如果一个Context的会话新建速率过快会导致其他Context由于CPU处理能力不够而无法建立会话,为了防止这种情况,需要限制Context的会话新建速率,当会话新建速率达到限制值时,后续不能新建会话。
Context会话新建速率限制对本机流量不生效,例如:FTP、Telnet、SSH、HTTP和HTTP类型的七层负载均衡等业务。
# 配置Context cnt2上的会话新建速率最大值为每秒20000个会话数。
[Sysname-context-2-cnt2] capability session rate 20000
·     context
capability session rate threshold命令用来设置Context的会话新建速率上限使用率告警阈值。
undo capability session rate threshold命令用来恢复缺省情况。
capability session rate threshold threshold-value
Context的会话新建速率上限使用率告警阈值为95%。
Context视图
threshold-value:Context的会话新建速率上限使用率告警阈值,取值范围为1~99,单位为百分比。
当Context会话新建速率上限使用率超过指定阈值时,发送会话新建速率上限使用率超过阈值告警;当会话新建速率上限使用率下降至指定阈值时,会发送会话新建速率上限使用率低于阈值告警。
# 配置Context 1上的会话新建速率上限使用率告警阈值为80%。
[Sysname] context 1
[Sysname-context-2-1] capability session rate threshold 80
·     context
capability sslvpn-user maximum命令用来设置Context的SSL VPN登录用户数限制。
undo capability sslvpn-user maximum命令用来恢复缺省情况。
capability sslvpn-user maximum max-number
未对Context的SSL VPN登录用户总数进行限制,由设备上SSL VPN Licence使用情况决定。
Context视图
max-number:最大SSL VPN登录用户数,取值范围为1~1048575。
配置本命令对Context的最大SSL VPN登录用户数进行限制后,当该Context的SSL VPN登录用户数达到最大数目时,该Context将不允许新的用户登录。
如果设置的数值小于当前Context的SSL VPN登录用户总数,则配置可以成功,但不再允许新的用户登录,且已经登录的用户不会被删除,依然生效。直到已登录的用户通过老化机制下线或用户主动下线,使得用户总数低于配置的最大值后,系统才允许新的用户登录。
# 配置Context cnt2上的最大SSL VPN登录用户数为1000000。
[Sysname-context-2-cnt2] capability sslvpn-user maximum 1000000
·     context
capability throughput命令用来设置Context出方向的吞吐量限制。
undo capability throughput命令用来恢复缺省情况。
capability throughput { gbps | kbps | mbps | pps } threshold
各Context出方向不做吞吐量限制,按实际能力转发。
Context视图
gbps threshold:表示出方向吞吐量按每秒吉比特计算,threshold:表示出方向吞吐量限制值,取值范围为1~1000。
kbps threshold:表示出方向吞吐量按每秒千比特计算,threshold:表示出方向吞吐量限制值,取值范围为1000~1000000000。
mbps threshold:表示出方向吞吐量按每秒兆比特计算,threshold:表示出方向吞吐量限制值,取值范围为1~1000000。
pps threshold:表示吞出方向吐量按每秒报文数计算,threshold:表示出方向吞吐量限制值,取值范围为1000~1000000000。
# 配置名称为cnt2的Context的出方向吞吐量为100000kbps。
[Sysname-context-2-cnt2] capability throughput kbps 100000
# 配置名称为cnt3的Context的出方向吞吐量为10000pps。
[Sysname] context cnt3
[Sysname-context-3-cnt3] capability throughput pps 10000
1.1.11  context
context命令用来创建Context,并进入Context视图。如果指定的Context已经存在,则直接进入Context视图。
undo context命令用来删除指定Context。
context context-name [ id context-id ] [ vlan-unshared ]
undo context context-name
存在缺省Context,名称为Admin,编号为1。
context-name:Context的名称,为1~15个字符的字符串,区分大小写。
context-id:Context的编号。不指定该参数时,系统会自动给Context分配一个当前空闲的最小编号。
vlan-unshared:不和其它Context共享VLAN。不指定该参数时,表示和其它Context共享VLAN。
·     如果选择和其它Context共享VLAN,需要在缺省Context内创建并配置VLAN,再分配给非缺省Context。共享VLAN由多个Context共同所有。
·     如果选择不和其它Context共享VLAN,请登录该Context,并使用vlan命令创建VLAN 1~VLAN 4094。Context各自使用和管理VLAN,互不干扰。
# 创建一个名称为test的Context。
[Sysname] context test
[Sysname-context-2-test]
# 创建一个名称为test,ID为2的Context。
[Sysname] context test id 2
context start命令用来启动Context。
undo context start命令用来停止该Context。
context start [ force ]
undo context start [ force ]
未启动Context。
Context视图
force:强制启动/停止Context。不指定该参数时,表示按正常程序启动Context。
停止Context会导致该Context的业务中断,以及登录该Context的用户自动退出,请谨慎使用。为避免Context的当前配置丢失,停止Context前请保存Context的配置。
Context创建后需要执行context start命令,才能完成新Context的初始化,相当于上电启动。启动后,用户可以登录到该Context执行配置。
# 启动Context cnt2。
[Sysname-context-2-cnt2] context start
context-capability inbound broadcast single命令用来配置单个Context入方向广播报文的速率限制。
undo context-capability inbound broadcast single命令用来恢复缺省情况。
context-capability inbound broadcast single pps threshold
单个Context入方向广播报文限速速率为广播报文总速率阈值除以使用共享接口Context的总数。
Context视图
pps threshold:入方向广播报文的速率阈值,取值范围为1000~100000,单位为pps。
此功能仅对设备上使用共享接口且处于Active状态的Context生效。
在系统视图下执行此命令用来配置缺省Context入方向广播报文限速速率的阈值;在Context视图下执行此命令式用来配置非缺省Context入方向广播报文限速速率的阈值。
当广播报文总速率和单个Context入方向广播报文速率均达到各自的阈值后,发往此Context的广播报文会被设备丢弃,否则不会被丢弃。广播报文总速率限制由context-capability inbound broadcast total命令设置。
# 配置缺省Context入方向广播报文的速率最大值为10000pps。
[Sysname] context-capability inbound broadcast single pps 10000
# 配置Context ctx1入方向广播报文的速率最大值为10000pps。
[Sysname] context ctx1
[Sysname-context-1-ctx1] context-capability inbound broadcast single pps 10000
·     context-capability inbound broadcast total
context-capability inbound broadcast total命令用来配置所有Context入方向广播报文的总速率限制。
undo context-capability inbound broadcast total命令用来恢复缺省情况。
context-capability inbound broadcast total pps threshold
所有Context入方向广播报文总速率限制为20000pps。
pps threshold:入方向广播报文的总速率阈值,取值范围为0,1000~100000,单位为pps。取值为0时表示不限速。
此功能仅对使用共享接口且处于Active状态的Context生效。
所有Context入方向广播报文总速率是指所有使用共享接口的Context接收广播报文的速率之和,简称“广播报文总速率”。
当广播报文总速率和单个Context入方向广播报文速率均达到各自的阈值后,发往此Context的广播报文会被设备丢弃,否则不会被丢弃。单个Context入方向广播报文速率由context-capability inbound broadcast single命令设置。
# 配置所有Context入方向广播报文的总速率最大值为10000pps。
[Sysname] context-capability inbound broadcast total pps 10000
·     context-capability inbound broadcast single
context-capability inbound drop-logging enable命令用来开启Context入方向报文限速丢包日志功能。
undo context-capability inbound drop-logging enable命令用来关闭Context入方向报文限速丢包日志功能。
Context入方向报文限速丢包日志功能处于关闭状态。
开启此功能后,当Context接收到的广播报文或组播报文因达到系统设置的阈值而被丢弃时,设备将会对丢弃的报文生成日志信息。此日志信息将会被输出到信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。有关信息中心的详细介绍,请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启Context入方向报文限速丢包日志功能。
[Sysname] context-capability inbound drop-logging enable
context-capability inbound multicast single命令用来配置单个Context入方向组播报文的速率限制。
undo context-capability inbound multicast single命令用来恢复缺省情况。
context-capability inbound multicast single pps threshold
单个Context入方向组播报文限速速率为组播报文总速率阈值除以使用共享接口Context的总数。
Context视图
pps threshold:Context入方向组播报文的速率阈值,取值范围为1000~100000,单位为pps。
在系统视图下执行此命令用来配置缺省Context入方向组播报文限速速率的阈值;在Context视图下执行此命令式用来配置非缺省Context入方向组播报文限速速率的阈值。
当组播报文总速率和单个Context入方向组播报文速率均达到各自的阈值后,发往此Context的组播报文会被设备丢弃,否则不会被丢弃。组播报文总速率限制由context-capability inbound multicast total命令设置。
# 配置缺省Context入方向组播报文的限速速率是10000pps。
[Sysname] context-capability inbound multicast single pps 10000
# 配置Context ctx1入方向组播报文的限速速率是10000pps。
[Sysname-context-1-ctx1] context-capability inbound multicast single pps 10000
·     context-capability inbound multicast total
context-capability inbound multicast total命令用来配置所有Context入方向组播报文的总速率限制。
undo context-capability inbound multicast total命令用来恢复缺省情况。
context-capability inbound multicast total pps threshold
所有Context入方向组播报文总速率限制为0pps。
pps threshold:入方向组播报文的总速率阈值,取值范围为0,1000~100000,单位为pps。取值为0时表示不限速。
所有Context入方向组播报文总速率是指所有使用共享接口的Context接收组播报文的速率之和,简称“组播报文总速率”。
当组播报文总速率和单个Context入方向组播报文速率均达到各自的阈值后,发往此Context的组播报文会被设备丢弃,否则不会被丢弃。单个Context入方向组播报文速率由context-capability inbound multicast single命令设置。
# 配置所有Context入方向组播报文的总速率最大值为10000pps。
[Sysname] context-capability inbound multicast total pps 10000
·     context-capability inbound multicast single
context-capability throughput alarm enable alarm-threshold命令用来开启Context出方向吞吐量告警功能并设置告警阈值。
undo context-capability throughput alarm enable命令用来关闭Context出方向吞吐量告警功能。
context-capability throughput alarm enable alarm-threshold alarm-threshold
Context出方向吞吐量告警功能处于关闭状态。
alarm-threshold usage-threshold:吞吐量告警阈值,取值范围为1~99,单位为百分比。
本功能开启后对设备上所有Context都生效。
本功能的生效依赖于开启Context出方向吞吐量限制功能,可执行capability throughput命令设置Context出方向的吞吐量限制。
开启Context出方向吞吐量告警功能并设置告警阈值后,当Context的出方向吞吐量与出方向吞吐量限制值的比值超过了所设置的告警阈值,设备会生成告警日志;之后,当Context的出方向吞吐量与出方向吞吐量限制值的比值恢复到告警阈值以下,设备会生成恢复日志。生成的日志信息将会被输出到信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。有关信息中心的详细介绍,请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启Context出方向吞吐量告警功能并设置告警阈值为80%。
[Sysname] context-capability throughput alarm enable alarm-threshold 80
·     capability throughput
context-capability throughput drop-logging enable命令用来开启Context出方向吞吐量限速丢包日志功能。
undo context-capability throughput drop-logging enable命令用来关闭Context出方向吞吐量限速丢包日志功能。
Context出方向吞吐量限速丢包日志功能处于关闭状态。
本功能的生效依赖于配置Context出方向吞吐量限制功能,可执行capability throughput命令设置Context出方向的吞吐量限制。
开启本功能后,当Context的出方向吞吐量达到出方向吞吐量限制值,设备会将超出限制值的报文丢弃,并对丢弃的报文生成日志信息;之后,如果该Context的出方向吞吐量降低到出方向吞吐量限制值以下,设备会生成恢复日志。生成的日志信息将会被输出到信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。有关信息中心的详细介绍,请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启Context出方向吞吐量限速丢包日志功能。
[Sysname] context-capability throughput drop-logging enable
1.1.20  description
description命令用来配置Context的描述信息。
undo description命令用来恢复缺省情况。
缺省Context描述信息为DefaultContext。非缺省Context没有配置描述信息。
Context视图
text:Context的描述信息,为1~255个字符的字符串,区分大小写。
当设备上配置的Context较多时,用户可以为Context配置特定的描述信息,以便记忆和管理Context。
# 将Context的描述信息配置为test。
[Sysname-context-2-cnt2] description test
display context命令用来显示已经创建的Context的信息,包括编号和状态等。
display context [ name context-name ]
name context-name:Context的名称,为1~15个字符的字符串,区分大小写。
在缺省Context中,可使用name context-name参数查看指定Context的信息。不指定name context-name参数时,则显示设备上创建的所有Context的信息。
# 显示已经创建的Context的信息。
<Sysname> display context
ID     Name          Status           Description
1      cnt1          active           context1
2      cnt2          inactive         context2
3      cnt3          inactive         context3
表1-1 display context命令显示信息描述表
ID
Context的编号
Name
Context的名称
Status
Context的状态:
·     active:表示Context正常运行
·     inactive:表示Context处于未启动状态
·     starting:表示Context正在启动
·     stopping:表示Context正在停止
Context描述信息
display context capability命令用来显示Context内可分配业务资源的使用情况。
display context [ name context-name ] capability [ security-policy | { session | throughout } [ slot slot-number ] | sslvpn-user ]
name context-name:显示指定Context内可分配业务资源的使用情况,context-name是Context的名称,为1~15个字符的字符串,区分大小写。若不指定该参数,则表示显示所有Context内可分配业务资源的使用情况。
security-policy:显示可分配安全策略规则资源的使用情况。
session:显示可分配会话资源的使用情况。
sslvpn-user:显示可分配SSL VPN用户资源的使用情况。
throughout:显示可分配出方向吞吐量资源的使用情况。
slot slot-number:显示指定成员设备上的Context内可分配会话资源的使用情况,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上的Context内可分配会话资源的使用情况。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。
此命令仅支持在缺省Context中使用。
# 显示所有Context内可分配业务资源的使用情况。
<Sysname> display context capability
Session usage and establishment rate:
 Slot 1 CPU 0:
  ID    Name     Maximum    Used    Free    Total(/s)  Rate(/s)   Usage(%)
  1    Admin     NA         500     NA      NA         1000       NA
  2    conetxt1  10000      300     9700    1000       100        10
  3    context2  2000       1000    1000    2000       1000       50
Security policy rule usage:
  1     Admin           NA             500                  NA
Online SSL VPN users:
  1     Admin           NA             0              NA
  2     conetxt1        10000          3000           7000
  3     context2        2000           0              2000
Throughout usage:
 Slot 1 CPU 0:
  ID    Name      Maximum    Used    Free   Usage(%)   Unit
  1     Admin     NA         500     NA     NA         kbps
  2     conetxt1  10000      1000    9000   10         kbps
  3     context2  200000     10000   10000  50         kbps
表1-2 display context capability命令显示信息描述表
Session usage
表示可分配会话连接数的使用情况
Session establishment rate
表示可分配会话新建速率的使用情况
表示可分配安全策略规则资源的使用情况
表示可分配SSL VPN用户上线资源的使用情况
ID
表示Context的ID
Name
表示Context的名称
Maximum
表示当前Context内可分配资源的最大值
Used
表示当前Context内可分配资源已被使用的数量
Free
表示当前Context内可分配资源未被使用的数量
Total
表示当前Context内会话新建速率的最大值,单位为每秒连接数
Rate
表示当前Context内会话的当前新建速率,单位为每秒连接数
Usage
表示当前Context内会话新建速率或实时出方向吞吐量所占的百分比
Unit
表示出方向吞吐量资源的单位
Throughout usage
表示可分配出方向吞吐量资源的使用情况
·     capability security-policy-rule maximum
·     capability session maximum
·     capability session rate
·     capability sslvpn-user maximum
display context capability inbound broadcast命令用来显示Context入方向广播报文的速率限制的统计信息。
display context name context-name capability inbound broadcast slot slot-number
name context-name:显示指定Context上入方向广播报文的速率限制的统计信息。context-name表示Context的名称,为1~15个字符的字符串,区分大小写。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。对于本产品,slot-number只能为固定取值,表示整台设备。‌‌
# 显示Context abc在指定Slot上的入方向广播报文的速率限制的统计信息。‌‌
<Sysname> display context name abc capability inbound broadcast slot 1
Context name: abc
Context ID: 2
 Drop Rate: 1000 pps
 Inbound throughput limit: 8000 pps
 Total inbound throughput limit: 10000 pps
表1-3 display context capability inbound broadcast命令显示信息描述表
Context name
表示Context的名称
Context ID
表示Context的ID
Drop Rate
表示此Context丢弃广播报文的速率,单位为pps
表示此Context入方向广播报文的总速率阈值,单位为pps
表示所有Context入方向广播报文的速率阈值,单位为pps
display context capability inbound multicast命令用来显示Context入方向组播报文的速率限制的统计信息。
display context name context-name capability inbound multicast slot slot-number
name context-name:显示指定Context上入方向组播报文的速率限制的统计信息。context-name表示Context的名称,为1~15个字符的字符串,区分大小写。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。‌‌
# 显示Context abc在指定Slot上的入方向组播报文的速率限制的统计信息。‌‌
<Sysname> display context name abc capability inbound multicast slot 1
Context name: abc
Context ID: 2
 Drop Rate: 1000 pps
表1-4 display context capability inbound multicast命令显示信息描述表
Context name
表示Context的名称
Context ID
表示Context的ID
Drop Rate
表示此Context丢弃组播报文的速率,单位为pps
表示此Context入方向组播报文的总速率阈值,单位为pps
表示所有Context入方向组播报文的速率阈值,单位为pps
display context configuration命令用来显示各Context的配置信息。
display context [ name context-name ] configuration [ file filename ]
name context-name:显示指定Context的配置信息,context-name是Context的名称,为1~15个字符的字符串,区分大小写。若不指定该参数,则表示显示所有Context的配置信息。
file filename:表示将显示的配置信息保存到指定文件。filename表示文件的名称,为1~255个字符的字符串(含后缀),不区分大小写,文件名不能为“.”或“..”,不能包含“"”、“/”、“:”、“\”、“?”、“\\”、“<”、“>”、“|”、“*”,首字符不能为“-”,且后缀必须为“.tar.gz”,后缀不区分大小写。不指定该参数时,用户可根据提示信息选择将配置信息保存到指定文件或直接将配置信息导出到终端显示。
执行该命令,相当于在所有Context中一次性执行display current-configuration命令。
在缺省Context中,无法对处于未启动状态的自定义Context进行配置信息收集。
# 显示所有Context的配置信息。
<Sysname> display context configuration
Save or display context configuration(Y=save, N=display)? [Y/N]:n
===========inner configuration of context Admin===========
 version 7.1.064, Feature 9321
sysname Sysname
context Admin id 1
context cnt1 id 2
return
<Sysname>
===========inner configuration of context cnt1===========
sysname Sysname
context Admin id 1
context cnt1 id 2
---- More ----
# 在交互信息时选择将配置信息保存到指定文件,并输入文件名为test.tar.gz。
Save or display context configuration (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag.tar.gz]: test.tar.gz
Saving context configuration to flash:/test.tar.gz. Please wait....
# 在命令行中直接通过参数指定将配置信息保存到文件test.tar.gz。
<Sysname> display context configuration file test.tar.gz
display context interface命令用来显示为Context分配的接口列表。
display context [ name context-name ] interface
本命令不能显示非缺省Context内创建的接口列表。
在缺省Context中,可使用name context-name参数查看为指定非缺省Context分配的接口列表;不指定name context-name参数时,则显示设备上所有为非缺省Context分配的接口列表。
# 显示所有为非缺省Context分配的接口列表。
<Sysname> display context interface
Context stub1's interfaces:
  GigabitEthernet1/0/2
Context stub2's interfaces:
·     allocate interface
display context online-users sslvpn命令用来显示所有Context内SSL VPN在线用户数。
此功能统计的SSL VPN在线用户数指的是当前在线的SSL VPN会话数。
# 显示所有Context内SSL VPN在线用户数。
<Sysname> display context online-users sslvpn
Total number of SSL VPN online users: 50
表1-5 display context online-users sslvpn命令显示信息描述表
所有Context内SSL VPN在线用户总数
display context reboot命令用来显示非缺省Context的重启信息。
display context name context-name reboot show-number [ offset ]
context-name:显示指定非缺省Context的重启信息。context-name表示非缺省Context的名称,为1~15个字符的字符串,区分大小写。
show-number:指定显示非缺省Context重启信息的条目数,取值范围为1~20。
offset:指定显示的起始条目距最近条目的偏移量,取值范围为0~19,缺省值为0。零表示从非缺省Context最近一次重启的条目开始显示。
缺省Context的重启信息,请在display version命令的Last reboot reason字段查看。有关此字段的详细介绍,请参见“基础配置命令参考”中的“设备管理”。
# 显示名称为test的非缺省Context最近一次重启的信息。
<Sysname> display context name test reboot 1
----------------- Reboot record 1 -----------------
Recorded at          : 2019-05-01  11:16:00
Reason               : 0x0
Process              : comsh (PID: 120) from Context 3 on slot 1 cpu 0
表1-6 display context name reboot命令显示信息描述表
Recorded at
非缺省Context重启的时间
Reason
重启的原因
xxx (PID: 120) from Context x on slot x cpu x
触发重启的进程信息,各字段解释如下:
·     xxx:表示触发重启的进程的名称
·     PID:表示触发重启的进程的编号
·     from Context x on slot x cpu x:表示触发重启的进程的运行位置
·     display version(基础配置命令参考/设备管理)
·     reset context name reboot
display context resource命令用来显示Context对CPU/内存资源的使用情况。
display context [ name context-name ] resource [ cpu | memory ] [ slot slot-number cpu cpu-number ]
name context-name:显示指定Context对CPU/内存资源的使用情况。context-name表示Context的名称,为1~15个字符的字符串,区分大小写。不指定该参数时,显示所有Context对CPU/内存资源的使用情况。
cpu:显示Context对CPU的使用情况。
memory:显示Context对内存的使用情况。
slot slot-number:显示Context对指定成员设备上的CPU/内存资源的使用情况,slot-number表示设备在IRF中的成员编号。不指定该参数时,显示Context对所有成员设备的CPU/内存资源的使用情况。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
cpu cpu-number:指定CPU。cpu-number表示单板上CPU的编号。
若不指定cpumemory参数,则显示Context对CPU和内存的使用情况。
# 显示Context对所有成员设备上CPU资源的使用情况。‌
<Sysname> display context resource cpu
CPU usage:
Slot 1 CPU 0:
  ID   Name        Weight       Usage(%)
  1    cnt1        10           24
  2    cnt2        10           0
Slot 2 CPU 0:
  1    cnt3        10           0
  2    cnt4        10           0
表1-7 display context resource命令显示信息描述表
Memory
表示下面显示的是内存的使用情况
CPU
表示下面显示的是CPU的使用情况
Used 238.1MB, Free 249.3MB, Total 487.4MB
内存的使用情况,Used表示内存已使用空间的大小(单位为MB),Free表示当前空闲内存的大小(单位为MB),Total表示整个内存大小(单位为MB)。如果Context没有启动,则Used会显示为0
ID
Context的编号
name
Context的名称
Weight
Context使用CPU的权重值
Usage(%)
Context对CPU的实际占用率,用百分比表示
Quota(MB)
Context使用内存的限制值,单位为MB
Used(MB)
Context当前用户态进程已使用的内存空间的大小,单位为MB
Free(MB)
Context还可以使用的内存空间的大小,单位为MB
·     limit-resource cpu
·     limit-resource memory
display context statistics命令用来显示Context内资源的统计信息。
display context [ name context-name ] statistics [ file filename ]
name context-name:显示指定Context内资源的统计信息,context-name是Context的名称,为1~15个字符的字符串,区分大小写。若不指定该参数,则表示显示所有Context内资源的统计信息。
file filename:表示将收集到的资源统计信息保存到指定文件。filename表示文件的名称,为1~255个字符的字符串(含后缀),不区分大小写,文件名不能为“.”或“..”,不能包含“"”、“/”、“:”、“\”、“?”、“\\”、“<”、“>”、“|”、“*”,首字符不能为“-”,且后缀必须为“.tar.gz”,后缀不区分大小写。不指定该参数时,用户可根据提示信息选择将资源的统计信息保存到指定文件或直接将资源的统计信息导出到终端显示。
执行该命令,相当于一次性执行如下命令:
·     display context capability
·     display counters inbound interface
·     display counters outbound interface
·     display counters rate inbound interface
·     display counters rate outbound interface
·     display interface
·     display ip statistics
·     display ipv6 statistics
·     display nat statistics
有关此命令显示信息的详细介绍,请参考各个命令显示信息的介绍。
# 显示所有Context内资源的统计信息。
<Sysname> display context statistics
Save or display context statistics (Y=save, N=display)? [Y/N]:n
    =============== display session statistics =================
Slot 1:
Current sessions: 0
          TCP sessions:                    0
          UDP sessions:                    0
         ICMP sessions:                    0
       ICMPv6 sessions:                    0
     UDP-Lite sessions:                    0
         SCTP sessions:                    0
         DCCP sessions:                    0
        RAWIP sessions:                    0
---- More ----
# 将资源统计信息保存到指定文件,并输入文件名为test.tar.gz。
Save or display context statistics(Y=save, N=display)? [Y/N]:y
Saving context statistics to flash:/test.tar.gz. Please wait....
# 将资源统计信息保存到文件test.tar.gz。
<Sysname> display context statistics file test.tar.gz
·     display counters inbound interface(接口管理命令参考/以太网接口)
·     display counters outbound interface(接口管理命令参考/以太网接口)
·     display counters rate inbound interface(接口管理命令参考/以太网接口)
·     display counters rate outbound interface(接口管理命令参考/以太网接口)
·     display interface(接口管理命令参考/以太网接口)
·     display ip statistics(三层技术-IP业务命令参考/IP性能优化)
·     display ipv6 statistics(三层技术-IP业务命令参考/IPv6基础)
·     display nat statistics(NAT命令参考/NAT)
display context vlan命令用来显示Context的VLAN列表。
display context [ name context-name ] vlan
在缺省Context中,可使用name context-name参数查看指定Context的VLAN列表;不指定name context-name参数时,则显示设备上创建的所有Context的VLAN列表。
# 显示所有Context的VLAN列表。
<Sysname> display context vlan
Context stub1's VLAN(s):
Context stub2's VLAN(s):
  2,4094
Context stub3's VLAN(s):
  5,6,800-3000,3400
# 显示Context sub1的VLAN列表。
<Sysname> display context name sub1 vlan
  5,6,11-23,3400
·     allocate vlan
limit-resource cpu命令用来配置Context的CPU权重。
undo limit-resource cpu命令用来恢复缺省情况。
limit-resource cpu weight weight-value
各Context的CPU权重均为10。
Context视图
weight weight-value:配置指定Context的CPU权重,取值范围为1~10。系统根据Context的权重为Context分配CPU时间。
# 配置Context的CPU权重为2。
[Sysname-context-2-cnt2] limit-resource cpu weight 2
limit-resource memory命令用来配置Context可使用的内存空间上限(用百分比表示)。
undo limit-resource memory命令用来恢复到缺省情况。
limit-resource memory slot slot-number cpu cpu-number ratio limit-ratio
undo limit-resource memory slot slot-number cpu cpu-number
所有Context共享物理设备上的所有内存空间,每个Context可使用的内存空间上限为空闲内存空间值。‌
Context视图
slot slot-number cpu cpu-number:配置Context在指定成员设备上可使用的内存空间上限。slot-number表示设备在IRF中的成员编号,cpu-number表示CPU的编号。对于本产品,slot-number只能为固定取值,表示整台设备。‌‌
ratio limit-ratio:表示Context在设备上最多可使用的内存大小与该设备整个内存大小的百分比,取值范围为1~100。
为了防止单个Context过多的占用内存而影响其它Context,特别是为防止异常情况下对内存的占用,可以为指定的Context配置内存上限,当Context占用内存达到限制值时,后续不能申请新的内存。
请在Context启动后再配置内存上限,并且配置的上限值不应过小,以免Context内业务申请不到内存而引起功能异常。
# 配置Context cnt2最多可使用1号成员设备内存的30%。‌
[Sysname-context-2-cnt2] limit-resource memory slot 1 cpu 0 ratio 30
reset context capability inbound broadcast命令用来清除Context入方向广播报文的速率限制的统计信息。
reset context name context-name capability inbound broadcast slot slot-number
name context-name:清除指定Context上入方向广播报文的速率限制的统计信息。context-name表示Context的名称,为1~15个字符的字符串,区分大小写。
# 清除Context abc在指定Slot上的广播限速统计信息。‌‌
<Sysname> reset context name abc capability inbound broadcast slot 1
reset context capability inbound multicast命令用来清除Context入方向组播报文的速率限制的统计信息。
reset context name context-name capability inbound multicast slot slot-number
name context-name:清除指定Context上入方向组播报文的速率限制的统计信息。context-name表示Context的名称,为1~15个字符的字符串,区分大小写。
# 清除Context abc在指定Slot上的组播限速统计信息。‌‌
<Sysname> reset context name abc capability inbound multicast slot 1
reset context name reboot命令用来清除非缺省Context的重启信息。
reset context [ name context-name ] reboot
name context-name:清除指定非缺省Context的重启信息。context-name表示非缺省Context的名称,为1~15个字符的字符串,区分大小写。若不指定本参数,则表示清除所有非缺省Context的重启信息。
# 清除名称为test的非缺省Context的重启信息。
<Sysname> reset context name test reboot
·     display context name reboot
snmp-agent trap enable sib命令用来开启Context出方向吞吐量限速的SNMP告警功能。
undo snmp-agent trap enable sib命令用来关闭Context出方向吞吐量限速的SNMP告警功能。
Context出方向吞吐量限速的SNMP告警功能处于关闭状态。
开启Context出方向吞吐量限速的SNMP告警功能后,设备生成的Context出方向吞吐量限速丢包日志(执行context-capability throughput drop-logging enable命令进行配置)和Context出方向吞吐量告警日志(执行context-capability throughput alarm enable命令进行配置)将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
有关SNMP的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 开启Context出方向吞吐量限速的SNMP告警功能。
[Sysname] snmp-agent trap enable sib
·     context-capability throughput drop-logging enable
·     context-capability throughput alarm enable
switchto context命令用来登录到指定的Context。
switchto context context-name
context-name:已启动的Context的名称。
只要用户和物理设备之间路由可达,就能使用该命令,通过物理设备和Context的内联接口,登录Context。
# 切换到Context test2。
[Sysname] switchto context test2
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
<H3C>
tar context log命令用来收集各Context的日志信息。
tar context [ name context-name ] log file filename
name context-name:收集指定Context的日志信息,context-name是Context的名称,为1~15个字符的字符串,区分大小写。若不指定该参数,则表示收集所有Context的日志信息。
file filename:表示将收集到的日志信息保存到指定文件。filename表示文件的名称,为1~255个字符的字符串(含后缀),不区分大小写,文件名不能为“.”或“..”,不能包含“"”、“/”、“:”、“\”、“?”、“\\”、“<”、“>”、“|”、“*”,首字符不能为“-”,且后缀必须为“.tar.gz”,后缀不区分大小写。
执行该命令会收集logfile文件夹和diagfile文件夹下的所有文件。
在缺省Context中,无法对从未启动过的自定义Context进行日志信息收集。
# 收集各Context的日志信息,并指定保存文件的名称为test.tar.gz。
<Sysname> tar context log file test.tar.gz
本章节描述的是登录到非缺省Context后,在非缺省Context上可以执行的Context配置命令。
display context interface命令用来显示Context的接口列表。
context-admin
context-operator
# 显示所有Context的接口列表。
display context reboot命令用来显示本Context的重启信息。
display context reboot show-number [ offset ]
context-admin
context-operator
show-number:指定显示本Context重启信息的条目数,取值范围为1~20。
offset:指定显示的起始条目距最近条目的偏移量,取值范围为0~19,缺省值为0。零表示从本Context最近一次重启的条目开始显示。
# 在名称为test的非缺省Context中显示本Context最近一次重启的信息。
<Sysname> display context reboot 1
Reason               : 0x0
有关display context reboot命令的显示信息请参见display context reboot
·     reset context reboot
reset context reboot命令用来清除本Context的重启信息。
context-admin
# 清除本context的重启信息。
<Sysname> reset context reboot
·     display context reboot
