07-二层技术-以太网交换
11-LLDP-EXT-DOT1-V2-MIB
本章节下载 11-LLDP-EXT-DOT1-V2-MIB  (455.99 KB)
  录
功能介绍
MIB文件名
根节点
表节点详细描述
lldpV2Xdot1ConfigPortVlanTable
lldpV2Xdot1ConfigVlanNameTable
lldpV2Xdot1ConfigProtoVlanTable
lldpV2Xdot1ConfigManVidTable
lldpV2Xdot1LocTable
lldpV2Xdot1LocProtoVlanTable
lldpV2Xdot1LocVlanNameTable
lldpV2Xdot1LocManVidTable
lldpV2Xdot1LocLinkAggTable
lldpV2Xdot1RemTable
lldpV2Xdot1RemProtoVlanTable
lldpV2Xdot1RemVlanNameTable
lldpV2Xdot1RemProtocolTable
lldpV2Xdot1RemVidUsageDigestTable
lldpV2Xdot1RemManVidTable
lldpV2Xdot1RemLinkAggTable
lldpXdot1dcbxConfigETSConfigurationTable
lldpXdot1dcbxConfigETSRecommendationTable
lldpXdot1dcbxConfigPFCTable
lldpXdot1dcbxConfigApplicationPriorityTable
lldpXdot1dcbxLocETSBasicConfigurationTable
lldpXdot1dcbxLocETSConPriorityAssignmentTable
lldpXdot1dcbxLocETSConTrafficClassBandwidthTable
lldpXdot1dcbxLocETSConTrafficSelectionAlgorithmTable
lldpXdot1dcbxLocETSRecoTrafficClassBandwidthTable
lldpXdot1dcbxLocETSRecoTrafficSelectionAlgorithmTable
lldpXdot1dcbxLocPFCBasicTable
lldpXdot1dcbxLocPFCEnableTable
lldpXdot1dcbxLocApplicationPriorityAppTable
lldpXdot1dcbxRemETSBasicConfigurationTable
lldpXdot1dcbxRemETSConPriorityAssignmentTable
lldpXdot1dcbxRemETSConTrafficClassBandwidthTable
lldpXdot1dcbxRemETSConTrafficSelectionAlgorithmTable
lldpXdot1dcbxRemETSRecoTrafficClassBandwidthTable
lldpXdot1dcbxRemETSRecoTrafficSelectionAlgorithmTable
lldpXdot1dcbxRemPFCBasicTable
lldpXdot1dcbxRemPFCEnableTable
lldpXdot1dcbxRemApplicationPriorityAppTable
lldpXdot1dcbxAdminETSBasicConfigurationTable
lldpXdot1dcbxAdminETSConPriorityAssignmentTable
lldpXdot1dcbxAdminETSConTrafficClassBandwidthTable
lldpXdot1dcbxAdminETSConTrafficSelectionAlgorithmTable
lldpXdot1dcbxAdminETSRecoTrafficClassBandwidthTable
lldpXdot1dcbxAdminETSRecoTrafficSelectionAlgorithmTable
lldpXdot1dcbxAdminPFCBasicTable
lldpXdot1dcbxAdminPFCEnableTable
lldpXdot1dcbxAdminApplicationPriorityAppTable
功能介绍
LLDP协议可以方便网络管理以标准的方式发现并利用网络物理拓扑信息,并且使网络管理有办法发现一些影响上层应用交互的配置不一致或错误,我公司数通产品已经实现LLDP-2009标准版本,但是所支持的MIB仍然还是LLDP-2005标准的版本。
LLDP-2009标准的MIB又称为LLDP-V2-MIB是实现LLDP-2009标准版本对应的MIB,此MIB为标准公有MIB,简单介绍如下:
·     LLDP配置信息
¡     LLDP报文发送周期
LLDP报文的发送周期,用户可配置,单位为s,取值范围为5~32768s,默认为30s。
¡     LLDP报文发送的LLDPDU的存活时间乘数
LLDP报文发送的LLDPDU的存活时间乘数,用来改变发送LLDPDU中TTL TLV的存活时间的值。用户可以配置,取值范围为2~10,默认为4。
¡     LLDP重新初始化延时
LLDP接口重新初始化延时时间,用户可配置,单位是s,取值范围是1~10s,默认为2s。
¡     LLDP发送Trap时间间隔
LLDP发送Trap时间间隔,用户可配置,单位为s,取值范围为5~3600s,默认为30s。
¡     LLDP发送报文令牌桶大小
LLDP发送报文令牌桶大小,用来限制LLDP连续发送报文的个数,取值范围是1~100,默认是5。
¡     LLDP报文快发周期
LLDP报文的快速发送周期,用户可配置,单位为s,取值范围为1~3600s,默认为1s。
¡     LLDP报文快发次数
LLDP报文快发次数,用户可配置,取值范围1~8,默认值为4。
¡     LLDP接口配置表
设备上接口的LLDP特性配置信息,包括接口索引、MAC地址索引即Agent ID,接口的发送接收状态、Trap是否使能及接口上能够发送哪些可选TLV。
¡     LLDP管理地址配置表
设备的管理地址配置信息,管理地址用户可以创建,可以配置是否使能。
·     LLDP统计信息
¡     LLDP更新邻居信息的时间
设备最后一次更新邻居信息的时间。当邻居信息被创建、修改或删除的时候,都需要更新邻居信息,记录最后一次更新邻居信息的时间。
¡     LLDP添加邻居信息的数量
系统启动后,添加的邻居信息的数量。LLDP agent根据报文中的MSAP ID(由Chassis ID和Port ID 构成)在本地邻居信息库中查找对应的邻居信息,如果确定是新的邻居信息且邻居信息的数量没有达到最大值,则需要添加新的邻居信息到邻居信息表中,记录添加的邻居信息的数量。
¡     LLDP删除邻居信息的数量
系统需要删除的邻居信息的数量。当接口的状态发生变化或LLDP工作模式发生变化时,都会有邻居信息的删除操作,统计删除的邻居信息的数量。
¡     LLDP丢弃邻居信息的数量
系统需要丢弃的邻居信息的数量。当本地LLDP agent维护的邻居信息数量达到规格规定的最大值时,收到新邻居报文则丢弃新邻居信息,统计丢弃的邻居信息的数量。
¡     LLDP老化邻居信息的数量
邻居信息老化的数量。当邻居信息的生存时间定时器超时,则对应的邻居信息老化,统计老化的邻居信息的数量。
¡     LLDP接口发送报文的统计表
LLDP接口发送报文的统计信息表。统计LLDP发送报文的数量并记录结果到该统计表中。
¡     LLDP接口接收报文的统计表
LLDP接口接收报文的统计信息表。统计LLDP接收报文的数量并记录结果到该统计信息表中。
·     LLDP本地系统信息
¡     LLDP本地Chassis ID Subtype信息
Chassis ID Subtype信息定义了本地Chassis ID Subtype的信息。
¡     LLDP本地Chassis ID信息
该字符串的值定义了本地Chassis ID的信息。
¡     LLDP本地系统名称
该字符串的值定义了本地系统的系统名称。取值范围是1~255octets。
¡     LLDP本地系统描述
该字符串的值定义了本地系统的系统描述。取值范围是1~255octets。
¡     LLDP本地系统支持的功能
该位图的值定义了本地系统支持那些系统功能。取值为2octets。
¡     LLDP本地系统使能的功能
该位图的值定义了本地系统中的哪些主要功能被使能了。取值为2octets。
¡     LLDP本地接口信息表
LLDP本地接口的信息,包括LLDP agent所能识别的与本地系统相关的接口信息。
¡     LLDP本地管理地址信息表
LLDP本地管理地址的信息,包括LLDP agent所能识别的与本地系统相关的管理地址的信息。
·     LLDP系统邻居信息
¡     LLDP系统邻居信息表
LLDP系统邻居信息描述,包括LLDP agent所能识别邻居的基本信息。
¡     LLDP系统邻居的管理地址信息表
LLDP系统邻居的管理地址信息,包括LLDP agent所能识别的邻居系统中含有本地Chassis值的接口的管理地址信息。
¡     LLDP系统邻居信息不能识别的TLV的信息表
LLDP agent不能识别的TLV的信息,该表中包含了接收方的LLDP agent不能识别收到的TLV的信息。
¡     LLDP系统邻居的组织级定义信息表
LLDP系统邻居的组织级定义的信息,包括每一个物理拓扑结构广播的组织级定义的信息。该表包括不能被本地LLDP agent识别的组织级定义的信息。
·     802.1扩展部分
¡     接口Agent选择发送Port VLAN TLV的配置表
设备接口上Agent是否可以发送Port VLAN TLV的配置信息。
¡     接口Agent选择发送VLAN Name TLV的配置表
设备接口上Agent是否可以发送VLAN Name TLV的配置信息。
¡     接口Agent选择发送Port And Protocol VLAN ID TLV的配置表
设备接口上Agent是否可以发送Port And Protocol VLAN ID TLV的配置信息。
¡     接口Agent选择发送Protocol Identity TLV的配置表
设备接口上Agent是否可以发送Protocol Identity TLV的配置信息。
¡     接口Agent选择发送LLDP VID Usage Digest TLV的配置表
设备接口上Agent是否可以发送LLDP VID Usage Digest TLV的配置信息。
¡     接口Agent选择发送Management VID TLV的配置表
设备接口上Agent是否可以发送Management VID TLV的配置信息。
¡     LLDP 802.1本地PVID数据表
本地Port VLAN ID信息。
¡     本地Port and Protocol VLAN表
记录本地Port and Protocol VLAN的相关信息。
¡     本地VLAN Name表
本地VLAN名称和VLAN ID的对应关系信息。
¡     本地Protocol Identity表
本地系统中的协议ID信息。
¡     本地VID Usage表
本地系统中VID 使用情况信息。
¡     本地Management VID表
本地管理VLAN信息。
¡     本地链路聚合表
本地链路聚合信息。
¡     LLDP邻居802.1数据表
邻居VLAN ID信息。
¡     邻居Protocol VLAN表
记录邻居协议VLAN的相关信息。
¡     邻居VLAN Name表
记录邻居VLAN名称和VLAN ID的对应关系信息。
¡     邻居Protocol表
记录邻居协议ID信息。
¡     邻居VID Usage表
记录邻居VID使用现状信息。
¡     邻居Management VID表
记录邻居管理VLAN信息。
¡     邻居链路聚合表
记录邻居链路聚合信息。
·     DCBX扩展部分
¡     DCBX TLV使能信息
标识接口上Agent是否能够发送ETS Configuration TLV、ETS Recommendation TLV、Priority-based Flow Control TLV、Application Priority TLV。
¡     DCBX本地信息
本地设备上ETS Configuration TLV、ETS Recommendation TLV、Priority-based Flow Control TLV、Application Priority TLV的信息。
¡     DCBX邻居信息
本地设备上保存的邻居的ETS Configuration TLV、ETS Recommendation TLV、Priority-based Flow Control TLV、Application Priority TLV的信息。
¡     DCBX配置信息
本地设备上ETS Configuration TLV、ETS Recommendation TLV、Priority-based Flow Control TLV、Application Priority TLV的配置信息。
·     802.3扩展部分
¡     LLDP接口配置表
设备上接口的LLDP特性配置信息,标识接口上Agent能够发送哪些IEEE 802.3组织定义的可选TLV。
¡     LLDP本地接口信息表
设备上接口支持的速率、双工、自动协商信息。
¡     LLDP本地供电能力信息表
设备上接口的接口类型、MDI信息、供电管脚信息、供电能力信息。
¡     本地报文最大帧长度信息表
报文最大帧长度信息。
¡     LLDP邻居设备接口配置表
邻居设备接口的LLDP特性配置信息,包括支持的速率、双工、自动协商信息。
¡     LLDP邻居设备供电能力信息表
邻居设备接口的接口类型、MDI信息、供电管脚信息、供电能力信息。
¡     邻居设备报文最大帧长度信息表
邻居设备报文最大帧长度信息。
·     CNP扩展部分
Comware V700R001整体不支持CNP相关的表。
MIB文件名
lldp-ext-dot1-v2.mib
根节点
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).lldpV2MIB(13).lldpV2Objects(1).lldpV2Extensions(5).lldpV2Xdot1MIB(32962)
表节点详细描述
【功能描述】
该表用来实现接口Agent是否发送Port VLAN TLV配置的功能。
【操作支持情况】
创建约束:不支持
修改约束:支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2PortConfigIfIndex、lldpV2PortConfigDestAddressIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1ConfigPortVlanTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.1.1.1)
read-write
TruthValue
true(1),
false(2)
设备接口上Agent是否可以发送Port VLAN TLV信息
对于最近桥接或最近客户桥代理模式的第2层以太网接口,对于最近客户桥代理模式的第2层聚合接口,默认值为True
【功能描述】
该表用来实现接口Agent是否发送VLAN Name TLV配置的功能。
【操作支持情况】
创建约束:不支持
修改约束:支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpV2Xdot1LocVlanId。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1ConfigVlanNameTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
设备接口上Agent是否可以发送VLAN Name TLV信息
默认情况下将添加值0,并且状态始终为“ FALSE”
设置为“ TRUE”时,将启用具有最小VLAN ID的VLAN;否则,将启用VLAN
设置为“ FALSE”时,将删除启用的VLAN
LLDP数据包中仅支持一个VLAN名称TLV
不建议从MIB浏览器进行walking操作,因为遍历所有端口和VLAN需要很长时间
【功能描述】
该表用来实现接口Agent是否发送Port And Protocol VLAN ID TLV配置的功能。
【操作支持情况】
创建约束:不支持
修改约束:支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpV2Xdot1LocProtoVlanId。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1ConfigProtoVlanTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.3.1.1)
read-write
TruthValue
true(1),
false(2)
设备接口上Agent是否可以发送Port And Protocol VLAN ID TLV信息
LLDP数据包中仅支持一个PROTOVLAN TLV
不建议从MIB浏览器进行漫游操作,因为扫描所有端口和VLAN需要很长时间
【功能描述】
该表用来实现接口Agent选择发送Management VID TLV的配置的功能。
【操作支持情况】
创建约束:不支持
修改约束:支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1ConfigManVidTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.6.1.1)
read-write
TruthValue
true(1),
false(2)
设备接口上Agent是否可以发送Management VID TLV信息
实现与MIB文件定义一致
lldpV2Xdot1LocTable
【功能描述】
该表用来实现显示本地接口的VLAN ID信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1LocPortVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.1.1.1)
read-only
Unsigned32
Unsigned32(0|1..4094)
本地接口的VLAN ID信息
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地接口的Port and Protocol VLAN信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex 、lldpV2Xdot1LocProtoVlanId。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1LocProtoVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.1)
not-accessible
Unsigned32
Unsigned320|1..4094
接口的协议VLAN ID
实现与MIB文件定义一致
lldpV2Xdot1LocProtoVlanSupported (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.2)
read-only
TruthValue
true(1),
false(2)
接口是否支持协议VLAN
实现与MIB文件定义一致
lldpV2Xdot1LocProtoVlanEnabled (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.3)
read-only
TruthValue
true(1),
false(2)
接口是否使能了协议VLAN
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地接口的VLAN Name信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1LocVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.3.1.1)
not-accessible
VlanId
同MIB标准取值
接口所属VLAN的VLAN ID
实现与MIB文件定义一致
lldpV2Xdot1LocVlanName (1.3.111.2.802.1.1.13.1.5.32962.1.2.3.1.2)
read-only
SnmpAdminString
OCTET STRING (1..32)
与VLAN ID相对应的VLAN名称
实现与MIB文件定义一致
【功能描述】
该表用来实现显示系统中的管理VLAN信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1LocManVid (1.3.111.2.802.1.1.13.1.5.32962.1.2.6.1.1)
read-only
Unsigned32
本地管理VLAN信息
实现与MIB文件定义一致
【功能描述】
该表用来实现显示系统中的链路聚合信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1LocLinkAggStatus (1.3.111.2.802.1.1.13.1.5.32962.1.2.7.1.1)
read-only
LldpV2LinkAggStatusMap
同MIB标准取值
当前系统支持聚合的能力与聚合链路状态
实现与MIB文件定义一致
lldpV2Xdot1LocLinkAggPortId (1.3.111.2.802.1.1.13.1.5.32962.1.2.7.1.2)
read-only
Unsigned32
Unsigned32(0|1..2147483647)
聚合的接口ID
实现与MIB文件定义一致
lldpV2Xdot1RemTable
【功能描述】
该表用来实现显示邻居接口的VLAN标识符信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、 lldpV2RemIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1RemPortVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.1.1.1)
read-only
Unsigned32
邻居接口的PVID
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居的接口的协议VLAN信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、 lldpV2RemIndex、lldpV2Xdot1RemProtoVlanId。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1RemProtoVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.1)
not-accessible
Unsigned32
邻居接口的协议VLAN ID
实现与MIB文件定义一致
lldpV2Xdot1RemProtoVlanSupported (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
邻居上关联的接口上是否支持接口和协议VLAN
实现与MIB文件定义一致
lldpV2Xdot1RemProtoVlanEnabled (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.3)
read-only
TruthValue
true(1),
false(2)
邻居上关联的接口上是否使能了接口和协议VLAN
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居的接口VLAN Name信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、 lldpV2RemIndex、lldpV2Xdot1RemVlanId 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1RemVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.3.1.1)
not-accessible
VlanId
同MIB标准取值
邻居接口所属VLAN的VLAN ID
实现与MIB文件定义一致
lldpV2Xdot1RemVlanName (1.3.111.2.802.1.1.13.1.5.32962.1.3.3.1.2)
read-only
SnmpAdminString
邻居上关联VLAN标识符对应的VLAN名字
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居接口的协议信息功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddres, lldpV2RemIndex, lldpV2Xdot1RemProtocolIndex 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1RemProtocolIndex (1.3.111.2.802.1.1.13.1.5.32962.1.3.4.1.1)
not-accessible
Unsigned32
Unsigned32(1..2147483647)
协议的索引
实现与MIB文件定义一致
lldpV2Xdot1RemProtocolId (1.3.111.2.802.1.1.13.1.5.32962.1.3.4.1.2)
read-only
OCTET STRING
OCTET STRING (1..255)
邻居接口的协议的标识符
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居接口Agent的Vid Usage信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1RemVidUsageDigest (1.3.111.2.802.1.1.13.1.5.32962.1.3.5.1.1)
read-only
Unsigned32
同MIB标准取值
邻居接口的Vid Usage信息
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居接口的管理VLAN信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1RemManVid (1.3.111.2.802.1.1.13.1.5.32962.1.3.6.1.1)
read-only
Unsigned32
邻居接口的管理VLAN信息
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居接口Agent的链路聚合信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、 lldpV2RemIndex 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpV2Xdot1RemLinkAggStatus (1.3.111.2.802.1.1.13.1.5.32962.1.3.7.1.1)
read-only
同MIB标准取值
邻居系统支持聚合的能力与聚合链路状态
实现与MIB文件定义一致
lldpV2Xdot1RemLinkAggPortId (1.3.111.2.802.1.1.13.1.5.32962.1.3.7.1.2)
read-only
Unsigned32
聚合的接口ID
实现与MIB文件定义一致
【功能描述】
该表用来实现LLDP DCBX特性ETS Configuration TLV发送使能配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2PortConfigIfIndex、lldpV2PortConfigDestAddressIndex 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxConfigETSConfigurationTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.1.1.1)
read-write
TruthValue
true(1),
false(2)
接口上Agent上是否能够发送ETS Configuration TLV
为此节点设置的值也适用于其他三个节点:lldpXdot1dcbxConfigETSRecommendationTxEnable,lldpXdot1dcbxConfigPFCTxEnable和lldpXdot1dcbxConfigApplicationPriorityTxEnable
【功能描述】
该表用来实现LLDP DCBX特性ETS Recommendation TLV发送使能配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxConfigETSRecommendationTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
接口上Agent上是否能够发送ETS Recommendation TLV
为此节点设置的值也适用于其他三个节点:lldpXdot1dcbxConfigETSConfigurationTxEnable,lldpXdot1dcbxConfigPFCTxEnable和lldpXdot1dcbxConfigApplicationPriorityTxEnable
【功能描述】
该表用来实现LLDP DCBX特性Priority-based Flow Control TLV发送使能配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxConfigPFCTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.3.1.1)
read-write
TruthValue
true(1),
false(2)
接口上Agent上是否能够发送PFC TLV
为此节点设置的值也适用于其他三个节点:lldpXdot1dcbxConfigETSConfigurationTxEnable,lldpXdot1dcbxConfigETSRecommendationTxEnable
【功能描述】
该表用来实现LLDP DCBX特性Application Priority TLV发送使能配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxConfigApplicationPriorityTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.4.1.1)
read-write
TruthValue
true(1),
false(2)
接口上Agent上是否能够发送APP TLV
为此节点设置的值也适用于其他三个节点:lldpXdot1dcbxConfigETSConfigurationTxEnable,lldpXdot1dcbxConfigETSRecommendationTxEnable和lldpXdot1dcbxConfigPFCTxEnable
【功能描述】
该表用来实现显示本地的ETS Configuration TLV的信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxLocETSConCreditBasedShaperSupport (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.1.1)
read-only
TruthValue
true(1),
false(2)
本地是否支持令牌桶限速算法
实现与MIB文件定义一致
lldpXdot1dcbxLocETSConTrafficClassesSupported (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.1.2)
read-only
LldpXdot1dcbxSupportedCapacity
同MIB标准取值
本地支持的支持的最大优先级数目
实现与MIB文件定义一致
lldpXdot1dcbxLocETSConWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.1.3)
read-only
TruthValue
true(1),
false(2)
本地是否支持根据邻居配置信息修改本地ETS运行信息
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地ETS Configuration TLV信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxLocETSConPriority 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxLocETSConPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.2.1.1)
not-accessible
IEEE8021PriorityValue
同MIB标准取值
dot1p优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxLocETSConPriTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.2.1.2)
read-only
LldpXdot1dcbxTrafficClassValue
同MIB标准取值
dot1p优先级对应的本地优先级信息
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地ETS Configuration TLV带宽分配信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、 lldpXdot1dcbxLocETSConTrafficClass 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxLocETSConTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.3.1.1)
not-accessible
同MIB标准取值
本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxLocETSConTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.3.1.2)
read-only
LldpXdot1dcbxTrafficClassBandwidthValue
同MIB标准取值
本地优先级分配的带宽
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地ETS Configuration TLV队列调度信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxLocETSConTSATrafficClass 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxLocETSConTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.4.1.1)
not-accessible
同MIB标准取值
本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxLocETSConTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.4.1.2)
read-only
LldpXdot1dcbxTrafficSelectionAlgorithm
同MIB标准取值
队列调度算法
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地ETS Recommendation TLV带宽分配信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxLocETSRecoTrafficClass 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxLocETSRecoTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.1.1.1)
not-accessible
同MIB标准取值
本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxLocETSRecoTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.1.1.2)
read-only
同MIB标准取值
本地优先级分配的带宽
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地ETS Recommendation TLV队列调度信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxLocETSRecoTSATrafficClass 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxLocETSRecoTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.2.1.1)
not-accessible
同MIB标准取值
本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxLocETSRecoTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.2.1.2)
read-only
同MIB标准取值
队列调度算法
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地PFC TLV信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxLocPFCWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.1.1)
read-only
TruthValue
true(1),
false(2)
本地是否支持根据邻居配置信息修改本地PFC运行信息
实现与MIB文件定义一致
lldpXdot1dcbxLocPFCMBC (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.1.2)
read-only
TruthValue
true(1),
false(2)
本地MAC安全功能关闭后是否能透传MAC安全报文
实现与MIB文件定义一致
lldpXdot1dcbxLocPFCCap (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.1.3)
read-only
同MIB标准取值
本地支持的本地优先级的数目
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地PFC优先级有无使能信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxLocPFCEnablePriority 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxLocPFCEnablePriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.2.1.1)
not-accessible
同MIB标准取值
dot1p优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxLocPFCEnableEnabled (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
PFC功能是否使能
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地APP TLV信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxLocApplicationPriorityAESelector、 lldpXdot1dcbxLocApplicationPriorityAEProtocol 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxLocApplicationPriorityAESelector (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.1.1)
not-accessible
LldpXdot1dcbxAppSelector
同MIB标准取值
协议对象索引
实现与MIB文件定义一致
lldpXdot1dcbxLocApplicationPriorityAEProtocol (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.1.2)
not-accessible
LldpXdot1dcbxAppProtocol
同MIB标准取值
协议ID索引
若DCBX协议版本为预标准版1.0,则该值固定为35078.
lldpXdot1dcbxLocApplicationPriorityAEPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.1.3)
read-only
同MIB标准取值
指定的dot1p优先级
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居ETS Configuration TLV信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxRemETSConCreditBasedShaperSupport (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.1.1)
read-only
TruthValue
true(1),
false(2)
邻居是否支持令牌桶限速算法
实现与MIB文件定义一致
lldpXdot1dcbxRemETSConTrafficClassesSupported (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.1.2)
read-only
同MIB标准取值
邻居支持的支持的最大优先级数目
实现与MIB文件定义一致
lldpXdot1dcbxRemETSConWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.1.3)
read-only
TruthValue
true(1),
false(2)
邻居是否支持根据远端配置信息修改本地ETS运行信息
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居ETS Configuration TLV优先级分配信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、 lldpV2RemIndex、lldpXdot1dcbxRemETSConPriority 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxRemETSConPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.2.1.1)
not-accessible
同MIB标准取值
邻居的dot1p优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxRemETSConPriTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.2.1.2)
read-only
同MIB标准取值
邻居的dot1p优先级对应的本地优先级信息
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居ETS Configuration TLV带宽分配信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、 lldpV2RemIndex、lldpXdot1dcbxRemETSConTrafficClass 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxRemETSConTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.3.1.1)
not-accessible
同MIB标准取值
邻居的本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxRemETSConTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.3.1.2)
read-only
同MIB标准取值
邻居的本地优先级分配的带宽
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居ETS Configuration TLV队列调度信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、 lldpV2RemIndex、lldpXdot1dcbxRemETSConTSATrafficClass。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxRemETSConTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.4.1.1)
not-accessible
同MIB标准取值
邻居的本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxRemETSConTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.4.1.2)
read-only
同MIB标准取值
队列调度算法
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居ETS Recommendation TLV带宽分配信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、lldpV2RemIndex、lldpXdot1dcbxRemETSRecoTrafficClass 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxRemETSRecoTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.1.1.1)
not-accessible
同MIB标准取值
邻居的本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxRemETSRecoTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.1.1.2)
read-only
同MIB标准取值
邻居的本地优先级分配的带宽
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居ETS Recommendation TLV调度算法信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、lldpV2RemIndex、lldpXdot1dcbxRemETSRecoTSATrafficClass。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxRemETSRecoTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.2.1.1)
not-accessible
同MIB标准取值
邻居的本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxRemETSRecoTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.2.1.2)
read-only
同MIB标准取值
队列调度算法
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居PFC TLV信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:不支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、lldpV2RemIndex 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxRemPFCWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.1.1)
read-only
TruthValue
true(1),
false(2)
邻居是否支持根据邻居配置信息修改本地PFC运行信息
实现与MIB文件定义一致
lldpXdot1dcbxRemPFCMBC (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.1.2)
read-only
TruthValue
true(1),
false(2)
邻居MAC安全功能关闭后是否能透传MAC安全报文
实现与MIB文件定义一致
lldpXdot1dcbxRemPFCCap (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.1.3)
read-only
同MIB标准取值
邻居支持的本地优先级的数目
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居PFC优先级有无使能信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、lldpV2RemIndex、lldpXdot1dcbxRemPFCEnablePriority 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxRemPFCEnablePriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.2.1.1)
not-accessible
同MIB标准取值
邻居的dot1p优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxRemPFCEnableEnabled (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
邻居PFC功能是否使能
实现与MIB文件定义一致
【功能描述】
该表用来实现显示邻居APP TLV信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2RemTimeMark、lldpV2RemLocalIfIndex、lldpV2RemLocalDestMACAddress、 lldpV2RemIndex、 lldpXdot1dcbxRemApplicationPriorityAESelector、lldpXdot1dcbxRemApplicationPriorityAEProtocol  。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxRemApplicationPriorityAESelector (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.1.1)
not-accessible
同MIB标准取值
协议对象索引
实现与MIB文件定义一致
lldpXdot1dcbxRemApplicationPriorityAEProtocol (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.1.2)
not-accessible
同MIB标准取值
协议ID索引
实现与MIB文件定义一致
lldpXdot1dcbxRemApplicationPriorityAEPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.1.3)
read-only
同MIB标准取值
指定的dot1p优先级
实现与MIB文件定义一致
【功能描述】
该表用来实现显示ETS Configuration TLV的配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxAdminETSConCreditBasedShaperSupport (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.1.1)
read-only
TruthValue
true(1),
false(2)
本地是否支持令牌桶限速算法配置信息
实现与MIB文件定义一致
lldpXdot1dcbxAdminETSConTrafficClassesSupported (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.1.2)
read-only
同MIB标准取值
本地支持的最大优先级数目配置信息
实现与MIB文件定义一致
lldpXdot1dcbxAdminETSConWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.1.3)
read-write
TruthValue
true(1),
false(2)
本地是否支持根据远端配置信息修改本地ETS运行配置信息
仅支持读操作
【功能描述】
该表用来实现显示本地ETS Configuration TLV的优先级分配配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxAdminETSConPriority 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxAdminETSConPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.2.1.1)
not-accessible
同MIB标准取值
dot1p优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxAdminETSConPriTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.2.1.2)
read-write
同MIB标准取值
dot1p优先级对应的本地优先级配置信息
仅支持读操作
【功能描述】
该表用来实现显示本地ETS Configuration TLV的带宽分配配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxAdminETSConTrafficClass 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxAdminETSConTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.3.1.1)
not-accessible
同MIB标准取值
本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxAdminETSConTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.3.1.2)
read-write
同MIB标准取值
本地优先级分配的带宽配置信息
仅支持读操作
【功能描述】
该表用来实现显示本地ETS Configuration TLV的队列调度配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxAdminETSConTSATrafficClass 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxAdminETSConTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.4.1.1)
not-accessible
同MIB标准取值
本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxAdminETSConTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.4.1.2)
read-write
同MIB标准取值
本地队列调度算法配置信息
仅支持读操作
【功能描述】
该表用来实现显示本地ETS Recommendation TLV的带宽分配配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxAdminETSRecoTrafficClass 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxAdminETSRecoTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.1.1.1)
not-accessible
同MIB标准取值
本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxAdminETSRecoTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.1.1.2)
read-write
同MIB标准取值
本地优先级分配的带宽配置信息
仅支持读操作
【功能描述】
该表用来实现显示本地ETS Recommendation TLV的调度算法配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxAdminETSRecoTSATrafficClass 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxAdminETSRecoTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.2.1.1)
not-accessible
同MIB标准取值
本地优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxAdminETSRecoTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.2.1.2)
read-write
同MIB标准取值
本地队列调度算法配置信息
仅支持读操作
【功能描述】
该表用来实现显示本地PFC TLV的配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxAdminPFCWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.1.1)
read-write
TruthValue
true(1),
false(2)
本地是否支持根据邻居配置信息修改本地PFC运行配置信息
仅支持读操作
lldpXdot1dcbxAdminPFCMBC (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.1.2)
read-only
TruthValue
true(1),
false(2)
本地MAC安全功能关闭后是否能透传MAC安全报文配置信息
实现与MIB文件定义一致
lldpXdot1dcbxAdminPFCCap (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.1.3)
read-only
同MIB标准取值
本地支持的本地优先级的数目配置信息
实现与MIB文件定义一致
【功能描述】
该表用来实现显示本地PFC优先级有无使能的配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxAdminPFCEnablePriority 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxAdminPFCEnablePriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.2.1.1)
not-accessible
同MIB标准取值
dot1p优先级索引
实现与MIB文件定义一致
lldpXdot1dcbxAdminPFCEnableEnabled (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.2.1.2)
read-write
TruthValue
true(1),
false(2)
本地的PFC功能是否使能配置信息
仅支持读操作
【功能描述】
该表用来实现显示本地APP TLV的配置信息的功能。
【操作支持情况】
创建约束:不支持
修改约束:不支持
删除约束:不支持
读取约束:支持
【表节点信息】
该表的索引节点是lldpV2LocPortIfIndex、lldpXdot1dcbxAdminApplicationPriorityAESelector、 lldpXdot1dcbxAdminApplicationPriorityAEProtocol 。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
lldpXdot1dcbxAdminApplicationPriorityAESelector (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.1.1)
not-accessible
同MIB标准取值
协议对象索引
实现与MIB文件定义一致
lldpXdot1dcbxAdminApplicationPriorityAEProtocol (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.1.2)
not-accessible
同MIB标准取值
协议ID索引
实现与MIB文件定义一致
lldpXdot1dcbxAdminApplicationPriorityAEPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.1.3)
read-create
同MIB标准取值
本指定的dot1p优先级配置信息
仅支持读操作
