01-IP路由基础命令
本章节下载: 01-IP路由基础命令 (730.85 KB)
1.1.3 display ip routing-table
1.1.4 display ip routing-table acl
1.1.5 display ip routing-table ip-address
1.1.6 display ip routing-table prefix-list
1.1.7 display ip routing-table protocol
1.1.8 display ip routing-table statistics
1.1.9 display ip routing-table summary
1.1.10 display ipv6 rib attribute
1.1.11 display ipv6 rib graceful-restart
1.1.13 display ipv6 route-direct nib
1.1.14 display ipv6 routing-table
1.1.15 display ipv6 routing-table acl
1.1.16 display ipv6 routing-table ipv6-address
1.1.17 display ipv6 routing-table prefix-list
1.1.18 display ipv6 routing-table protocol
1.1.19 display ipv6 routing-table statistics
1.1.20 display ipv6 routing-table summary
1.1.23 display rib graceful-restart
1.1.25 display route-direct nib
1.1.28 inter-protocol fast-reroute
1.1.29 ip route fast-switchover enable
1.1.30 ipv6 route fast-switchover enable
1.1.32 maintenance-probe enable
1.1.34 primary-path-detect bfd
1.1.36 protocol nexthop recursive-lookup
1.1.37 reset ip routing-table statistics protocol
1.1.38 reset ipv6 routing-table statistics protocol
1.1.41 snmp-agent trap enable ipv6 rib
1.1.42 snmp-agent trap enable rib
address-family ipv4命令用来创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
undo address-family ipv4命令用来删除RIB IPv4地址族和RIB IPv4地址族视图下的所有配置。
address-family ipv4
不存在RIB IPv4地址族。
RIB视图
# 创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6命令用来创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
undo address-family命令用来删除RIB IPv6地址族和RIB IPv6地址族视图下的所有配置。
address-family ipv6
undo address-family ipv6
不存在RIB IPv6地址族。
RIB视图
# 创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
display ip routing-table命令用来显示路由表的信息。
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ip routing-table all-routes
all-vpn-instance:显示所有VPN实例的路由表信息。
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
all-routes:显示公网和所有VPN实例的路由表信息。
verbose:显示全部路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
如果不指定任何参数时,则显示公网的信息。
# 显示路由表中当前激活路由的概要信息。
<Sysname> display ip routing-table
Destinations : 14 Routes : 14
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
1.1.1.0/24 Static 60 0 192.168.47.4 Vlan12
192.168.47.4 Vlan13
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.0/24 Direct 0 0 192.168.1.40 Vlan11
192.168.1.0/32 Direct 0 0 192.168.1.40 Vlan11
192.168.1.40/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.40 Vlan11
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# 显示公网和所有VPN实例中当前激活路由的概要信息。
<Sysname> display ip routing-table all-routes
VPN instance: public instance
Destinations : 11 Routes : 11
1.1.1.0/24 Static 60 0 192.168.47.4 Vlan11
192.168.47.4 Vlan12
VPN instance: vpn1
Destinations : 9 Routes : 9
1.1.2.0/24 Static 60 0 2.2.1.1 Vlan11
# 显示所有VPN实例下的IPv4路由信息。
<Sysname> display ip routing-table all-vpn-instance
VPN instance: vpn1
Destinations : 10 Routes : 10
2.2.1.1 Vlan13
VPN instance: vpn2
1.1.3.0/24 Static 60 0 3.3.1.1 Vlan13
表1-1 display ip routing-table命令显示信息描述表
VPN instance |
路由表所属的公网或VPN实例信息,公网路由显示为public instance,私网路由显示为VPN实例名称 |
Destinations |
目的地址个数 |
Routes |
路由条数 |
Destination/Mask |
目的地址/掩码长度 |
Proto |
发现该路由的路由协议类型 |
Pre |
路由的优先级 |
Cost |
路由的度量值 |
NextHop |
此路由的下一跳地址 |
出接口,即到该目的网段的数据包将从此接口发出 |
Summary count |
路由数目 |
# 显示路由表的全部详细信息。
<Sysname> display ip routing-table verbose
Destinations : 2 Routes : 2
Destination: 0.0.0.0/32
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 18h43m14s
Cost: 0 Preference: 0
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active NoAdv
OrigTblID: 0x2 OrigVrf: default-vrf
TableID: 0x2 OrigAs: 0
NibID: 0x10000004 LastAs: 0
AttrID: 0xffffffff
BkAttrID: 0x0 Neighbor: 0.0.0.0
Flags: 0x1000c OrigNextHop: 127.0.0.1
Label: NULL RealNextHop: 127.0.0.1
BkLabel: NULL BkNextHop: N/A
SRLabel: NULL Interface: InLoopBack0
BkSRLabel: NULL BkInterface: N/A
Tunnel ID: Invalid IPInterface: InLoopBack0
BkTunnel ID: Invalid BkIPInterface: N/A
LinkCost: 0 MicroSegID: 0
RealFIRType: Normal RealThres: 0
InLabel: 0 ColorInterface: N/A
SIDIndex: NULL BkColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: N/A
TrafficIndex: N/A BkTunnelInterface: N/A
Connector: N/A PathID: 0x0
SID Type: N/A NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid StatFlags: 0x0
SID: N/A
BkSID: N/A
CommBlockLen: 0 SRTunnelID: Invalid
MemberPort: N/A ExtFlags: 0x0
SliceID: 0 BkSliceID: 0
Destination: 1.1.1.0/24
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 04h20m37s
Cost: 0 Preference: 60
Tag: 0 State: Active Adv
NibID: 0x10000003 LastAs: 0
AttrID: 0xffffffff
Flags: 0x1008c OrigNextHop: 192.168.47.4
Label: NULL RealNextHop: 192.168.47.4
Tunnel ID: Invalid IPInterface: Vlan-interface11
SID: N/A
BkSID: N/A
# 显示所有VPN实例内所有路由的详细信息。
<Sysname> display ip routing-table all-vpn-instance verbose
VPN instance: vpn1
Destinations : 1 Routes : 1
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 08h34m37s
OrigTblID: 0x0 OrigVrf: vpn1
NibID: 0x10000000 LastAs: 0
AttrID: 0xffffffff
SID: N/A
BkSID: N/A
VPN instance: vpn2
Protocol: Static
Process ID: 0
OrigTblID: 0x0 OrigVrf: vpn2
AttrID: 0xffffffff
SID: N/A
BkSID: N/A
表1-2 display ip routing-table verbose命令显示信息描述表
VPN instance |
Destinations |
目的地址个数 |
Routes |
路由条数 |
Destination |
目的地址/掩码 |
Protocol |
发现该路由的路由协议类型 |
Process ID |
进程号 |
SubProtID |
路由子协议ID |
Age |
此路由在路由表中存在的时间 |
Cost |
路由的度量值 |
Preference |
路由的优先级 |
IpPre |
IP优先级值 |
QosLocalID |
QoS本地ID |
Tag |
路由标记 |
State |
路由状态描述: · Active:有效的单播路由 · Adv:允许对外发送的路由 · Inactive:非激活路由标志 · NoAdv:不允许发布的路由 · Vrrp:VRRP产生的路由 · Nat:NAT产生的路由 · Backup:备份路由的标志 · IPSGT:IP-SGT(IP address-Security Group Tag,IP地址-安全组)策略产生的路由 |
OrigTblID |
原始路由表ID |
OrigVrf |
路由所属的原始VPN,显示为default-vrf表示公网 |
TableID |
路由所在路由表的ID |
OrigAs |
初始AS号 |
NibID |
下一跳ID |
LastAs |
最后AS号 |
AttrID |
路由属性ID号 |
BkAttrID |
备份路由的属性ID号,仅支持显示BGP协议添加到IP路由表中的备份路由的属性ID号 |
Neighbor |
路由协议的邻居地址 |
Flags |
路由标志位 |
OrigNextHop |
此路由的下一跳地址 |
Label |
(暂不支持)标签 |
RealNextHop |
路由真实下一跳 |
BkLabel |
(暂不支持)备份标签 |
BkNexthop |
备份下一跳地址 |
SRLabel |
(暂不支持)SR(Segment Routing)标签 |
BkSRLabel |
(暂不支持)SR(Segment Routing)备份标签 |
BkInterface |
备份出接口 |
Tunnel ID |
隧道ID |
IPInterface |
IP出接口 |
BkTunnel ID |
备份隧道ID |
BkIPInterface |
备份IP出接口 |
LinkCost |
IGP物理链路开销值 |
MicroSegID |
路由携带的微分段ID |
RealFIRType |
(暂不支持)等价路由FIR模式中真实下一跳所在链路的类型,取值包括: · Normal:表示普通链路 · Primary:表示主用链路 · Secondary:表示备用链路 真实下一跳是路由经过迭代找到的直连下一跳 |
RealThres |
(暂不支持)等价路由FIR模式中,真实下一跳所在主用链路的带宽使用率上限阈值,单位为百分比 |
InLabel |
(暂不支持)路由入标签 |
ColorInterface |
Color出接口,即通过SR-MPLS TE Policy或SRv6 TE Policy迭代的出接口 |
SIDIndex |
(暂不支持)SID的相对值 |
BkColorInterface |
备份Color出接口 |
FtnIndex |
FTN表项索引 |
TunnelInterface |
Tunnel出接口 |
TrafficIndex |
流量统计索引值,取值范围为1~64,N/A表示无效值 |
BkTunnelInterface |
备份Tunnel出接口 |
Connector |
表示BGP为MD VPN特性所携带的Connector属性,具体取值为BGP对等体在交换VPN-IPv4路由时携带源PE的地址,N/A表示没有该属性 |
PathID |
BGP路由的Add-Path ID |
SID Type |
SID类型,N/A表示没有该属性 |
NID |
路由协议下刷的NHLFE(Next Hop Label Forwarding Entry,下一跳标签转发项)表项索引 |
FlushNID |
实际向FIB下刷的NHLFE表项索引 |
BkNID |
路由协议下刷的备份NHLFE表项索引 |
BkFlushNID |
实际向FIB下刷的备份NHLFE表项索引 |
StatFlags |
SRv6流量统计标记 |
SID |
主用SID(Segment Identifier,段标识),N/A表示没有该属性 |
BkSID |
备用SID,N/A表示没有该属性 |
CommBlockLen |
Locator中的公共前缀长度 |
SRTunnelID |
SR隧道ID |
MemberPort |
聚合组成员端口编号,N/A表示没有该属性 |
ExtFlags |
扩展路由标志位 |
SliceID |
网络切片实例ID |
BkSliceID |
备份网络切片实例ID |
display ip routing-table acl命令用来显示通过指定ACL过滤的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
ipv4-acl-number:基本ACL的编号,取值范围为2000~2999。
verbose:显示通过指定ACL过滤的所有路由的详细信息。如果未指定本参数,将只显示通过指定ACL过滤的激活路由的概要信息。
引用ACL时,需要注意的是:
· 若引用的ACL不存在,或者引用的ACL中没有配置规则,则显示所有的路由信息。
· 在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
# 配置ACL 2000,并设置路由过滤规则。
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# 显示通过ACL 2000过滤的激活路由的概要信息。
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24 Direct 0 0 192.168.1.111 Vlan11
192.168.1.0/32 Direct 0 0 192.168.1.111 Vlan11
192.168.1.111/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.111 Vlan11
以上显示信息解释请参见“display ip routing-table”中的显示信息描述表。
# 显示通过ACL 2000过滤的所有路由的详细信息。
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
Protocol: Direct
Process ID: 0
SubProtID: 0x1 Age: 04h20m37s
AttrID: 0xffffffff
Flags: 0x10080 OrigNextHop: 192.168.1.111
Label: NULL RealNextHop: 192.168.1.111
SID: N/A
BkSID: N/A
Destination: 192.168.1.0/32
Protocol: Direct
Process ID: 0
AttrID: 0xffffffff
Flags: 0x1008c OrigNextHop: 192.168.1.111
SID: N/A
BkSID: N/A
Destination: 192.168.1.111/32
Protocol: Direct
Process ID: 0
AttrID: 0xffffffff
Flags: 0x10004 OrigNextHop: 127.0.0.1
SID: N/A
BkSID: N/A
Destination: 192.168.1.255/32
Protocol: Direct
Process ID: 0
AttrID: 0xffffffff
SID: N/A
BkSID: N/A
display ip routing-table ip-address命令用来显示指定目的地址的路由信息。
display ip routing-table ip-address1 to ip-address2命令用来显示指定目的地址范围内的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
ip-address:目的IP地址,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
longer-match:显示与指定目的网络匹配的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ip-address1 to ip-address2:IP地址范围。ip-address1和ip-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
使用不同的可选参数,命令的输出也不相同,以下是对该命令不同形式的输出说明:
· display ip routing-table ip-address
显示满足如下条件的所有激活路由:
¡ 用户输入的目的IP地址同路由表中各条路由的子网掩码值进行与运算。
¡ 路由表中各条路由的目的IP地址同其自身子网掩码值进行与运算。
¡ 两次运算结果相同的路由条目将被显示出来。
· display ip routing-table ip-address mask
显示满足如下条件的所有激活路由:
¡ 用户输入的目的IP地址同用户输入的子网掩码值进行与运算。
¡ 路由表中各条路由的目的IP地址同用户输入的子网掩码值进行与运算。
¡ 两次运算结果相同,并且掩码小于等于用户输入的子网掩码的路由条目将被显示出来。
· display ip routing-table ip-address longer-match
显示满足如下条件的所有激活路由:
¡ 用户输入的目的IP地址同子网掩码值进行与运算,有以下三种情况:
- 判断用户输入的目的IP地址所属的地址类别(A、B或C类)。A、B和C类地址对应的子网掩码分别为255.0.0.0、255.255.0.0和255.255.255.0。将用户输入的目的IP地址与对应的子网掩码值进行与运算。
- 如果用户输入的目的IP地址是0.0.0.0,使用掩码0.0.0.0与其进行与运算。
- 除上述两种情况外(如组播地址、环回地址),使用掩码255.255.255.255与用户输入的目的IP地址进行与运算。
¡ 路由表中各条路由的目的IP地址同上一步得到的子网掩码值进行与运算。
¡ 两次运算结果相同的所有路由条目将被显示出来。
· display ip routing-table ip-address mask longer-match
显示满足如下条件的所有激活路由:
· display ip routing-table ip-address1 to ip-address2
显示ip-address1/32到ip-address2/32之间的激活路由,目的地址与掩码(32位)同时在指定范围内才会显示。
# 显示目的地址为11.0.0.1的路由信息。
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8 Static 60 0 0.0.0.0 NULL0
11.0.0.0/16 Static 60 0 0.0.0.0 NULL0
11.0.0.0/24 Static 60 0 0.0.0.0 NULL0
# 显示目的地址/掩码为11.0.0.1/20的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# 显示目的地址为11.0.0.1并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 3
# 显示目的地址/掩码为11.0.0.1/20并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 3
# 显示目的地址从1.1.1.0到5.5.5.0范围内的路由信息。
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 4
1.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.0/24 Direct 0 0 2.2.2.1 Vlan2
3.3.3.1/32 Direct 0 0 127.0.0.1 InLoop0
4.4.4.1/32 Direct 0 0 127.0.0.1 InLoop0
# 显示目的地址为1.2.3.4的路由的详细信息。
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
Destination: 1.2.3.4/32
Protocol: Direct
Process ID: 0
SubProtID: 0x1 Age: 00h00m37s
TableID: 0x2 OrigAs: 200
NibID: 0x15000000 LastAs: 200
AttrID: 0x0
BkAttrID: 0x0 Neighbor: 192.168.47.2
Flags: 0x10060 OrigNextHop: 192.168.47.2
Label: NULL RealNextHop: 192.168.47.2
SID: N/A
BkSID: N/A
以上显示信息的解释请参见“display ip routing-table”中的显示信息描述表。
display ip routing-table prefix-list命令用来显示通过指定前缀列表过滤的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name:前缀列表名称,为1~63个字符的字符串,区分大小写。
verbose:当使用该参数时,显示通过过滤规则的所有路由的详细信息。如果未指定本参数,将只显示通过过滤规则的激活路由的概要信息。
如果指定的前缀列表不存在,将显示所有的路由信息。
# 配置地址前缀列表test允许前缀为1.1.1.0,掩码长度为24的路由通过。
[Sysname] ip prefix-list test permit 1.1.1.0 24
# 显示通过前缀列表test过滤的激活路由的概要信息。
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24 Direct 0 0 1.1.1.2 Vlan11
# 显示通过前缀列表test过滤的所有路由的详细信息。
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
Protocol: Direct
Process ID: 0
AttrID: 0xffffffff Neighbor: 0.0.0.0
Flags: 0x1008c OrigNextHop: 1.1.1.2
Label: NULL RealNextHop: 1.1.1.2
SRLabel: NULL BkSRLabel: NULL
SIDIndex: NULL InLabel: NULL
Tunnel ID: Invalid Interface: Vlan-interface11
BkTunnel ID: Invalid BkInterface: N/A
FtnIndex: 0x0 TrafficIndex: N/A
display ip routing-table protocol命令用来显示指定协议生成或发现的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
protocol:显示指定路由协议的信息。
inactive:显示未激活路由的信息。如果未指定本参数,则显示激活路由和未激活路由的信息。
verbose:当使用该参数时,显示路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有直连路由的概要信息。
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
2.2.2.0/32 Direct 0 0 2.2.2.1 Vlan2
2.2.2.2/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.255/32 Direct 0 0 2.2.2.1 Vlan2
Direct Routing table status : <Inactive>
Summary count : 0
# 显示静态路由表。
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
1.2.3.0/24 Static 60 0 1.2.4.5 Vlan10
<Sysname> display ip routing-table protocol ospf verbose
Summary count : 1
Destination: 12.1.1.0/24
Protocol: O_INTRA
Process ID: 1
SubProtID: 0x1 Age: 00h01m06s
Cost: 1 Preference: 10
Tag: 0 State: Inactive Adv
NibID: 0x13000001 LastAs: 0
AttrID: 0xffffffff
BkAttrID: 0xc77f0000 Neighbor: 0.0.0.0
Flags: 0x10c1 OrigNextHop: 0.0.0.0
Label: NULL RealNextHop: 0.0.0.0
SRLabel: NULL Interface: Vlan-interface10
Tunnel ID: Invalid IPInterface: Vlan-interface10
LinkCost: 1 MicroSegID: 0
SIDIndex: 0 BkColorInterface: N/A
SID: N/A
BkSID: N/A
display ip routing-table statistics命令用来显示路由表中的综合路由统计信息。综合路由统计信息包括路由总数目、路由协议添加/删除路由数目、激活路由数目。
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] statistics
all-routes:显示公网和所有VPN实例的信息。
all-vpn-instance:显示所有VPN实例的信息。
# 显示公网路由表中的综合路由统计信息。
<Sysname> display ip routing-table statistics
Total prefixes: 15 Active prefixes: 15
Proto Routes Active Added Deleted
DIRECT 12 12 30 18
STATIC 3 3 5 2
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
BGP 0 0 0 0
Total 15 15 35 20
# 显示公网和所有VPN实例路由表中的综合路由统计信息。
<Sysname> display ip routing-table all-routes statistics
Total prefixes: 11 Active prefixes: 11
DIRECT 8 8 8 0
STATIC 3 3 5 2
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
BGP 0 0 0 0
Total 11 11 13 2
# 显示指定VPN实例路由表中的综合路由统计信息。
<Sysname> display ip routing-table vpn-instance vpn1 statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
BGP 0 0 0 0
Total 11 11 13 2
# 显示所有VPN实例路由表中的综合路由统计信息。
<Sysname> display ip routing-table all-vpn-instance statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
BGP 0 0 0 0
Total 11 11 13 2
表1-3 display ip routing-table statistics命令显示信息描述表
Total prefixes |
总的前缀数目 |
Active prefixes |
总的激活前缀数目 |
Proto |
路由协议 |
Routes |
总的路由数目 |
Active |
活跃的、正在使用的路由数目 |
Added |
路由器启动后或在上一次清除路由表后,路由表中添加的路由数目 |
Deleted |
标记为删除的路由数目(此类路由在等待一段时间后会被释放) |
Total |
各种类型路由数目的总和 |
display ip routing-table summary命令用来显示路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ip routing-table [ vpn-instance vpn-instance-name ] summary
# 显示公网的路由表概要信息。
<Sysname> display ip routing-table summary
Max ECMP: 16
Max Active Route: 819200
Remain Active Route: 819187
# 显示vpn1实例的路由表概要信息。
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 16
Remain Active Route: 819192
Threshold value percentage of max active routes: 100%
表1-4 display ip routing-table summary命令显示信息描述表
Max ECMP |
最大等价路由数 |
Max Active Route |
最多支持激活路由前缀数 |
Remain Active Route |
剩余可激活路由前缀数 |
Threshold value xxx |
显示最多支持激活路由前缀数的告警门限: · 如果在VPN实例中配置了命令routing-table limit number simply-alert,则显示信息字段为Threshold value of active routes alert,取值表示产生告警的门限值。当VPN实例的激活路由前缀数超过该取值时,可以继续激活新的路由前缀,但会产生Trap告警和日志信息 · 若在VPN实例中配置了命令routing-table limit number warn-threshold,则显示信息字段为Threshold value percentage of max active routes,取值表示当(VPN实例中的激活路由前缀数/最多支持激活路由前缀数×100)达到warn-threshold时,产生Trap告警和日志信息,但仍然允许增加激活路由前缀。当VPN实例中的激活路由前缀由数达到最多支持激活路由前缀数目时,不再激活新的路由前缀 |
display ipv6 rib attribute命令用来显示IPv6 RIB的路由属性信息。
attribute-id:路由属性ID值,取值范围为十六进制数0~ffffffff。
# 显示IPv6 RIB的路由属性信息。
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
Flag: 0x0
Protocol: BGP4+ instance default
Address family: IPv6
Reference count: 0
Local preference: 0
Ext-communities number: 0
Ext-communities value: N/A
Communities number: 0
Communities value: N/A
AS-path number: 0
AS-path value: N/A
以上显示信息的解释请参见“display rib attribute”中的显示信息描述表。
display ipv6 rib graceful-restart命令用来显示IPv6 RIB的GR状态信息。
# 显示IPv6 RIB的GR状态信息。
<Sysname> display ipv6 rib graceful-restart
RIB GR state : Phase2-calculation end
RCOM GR state : Flush end
Protocol GR state:
No. Protocol Lifetime FD State Start/End
1 DIRECT 900 29 End No/No
2 STATIC 900 32 End No/No
3 ISISV6 900 30 End No/No
以上显示信息的解释请参见“display rib graceful-restart”中的显示信息描述表。
display ipv6 rib nib命令用来显示IPv6 RIB的下一跳信息。
self-originated:路由管理自己生成的下一跳。
nib-id:路由下一跳ID值,取值范围为十六进制数0~ffffffff。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议的下一跳信息。
# 显示IPv6 RIB的下一跳信息。
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
NibID: 0x20000000 Sequence: 0
Type: 0x1 Flushed: Yes
Age: 00h01m50s
UserKey0: 0x0 VrfNthp: 0
UserKey1: 0x0 Nexthop: ::
IFIndex: 0x111 LocalAddr: ::
MemberPort: 0x0
NewUK0: 0x0 NewUK1: 0x0
NewUK2: 0x0 NewUK3: 0x0
NewUK4: 0x0 NewUK5: 0x0
NewUK6: 0x0 NewUK7: 0x0
TopoNthp: Invalid ExtType: 0x0
FIRType: Normal Threshold: 0
ExtBandwidth:0x0
AS-path: 0 0
TopoNthp: Invalid ExtType1: 0x0
ExtType2: 0x0
Color: 0 COFlag: 0x0
SIDIndex: 0x0 SRPName:
OriNexthop: ::
NextHopDevID: 1.1.1.1 RemoteDevID: 6.6.6.6
NibID: 0x20000001 Sequence: 1
Age: 00h01m50s
UserKey1: 0x0 Nexthop: ::1
IFIndex: 0x112 LocalAddr: ::1
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
ExtType2: 0x0
OriNexthop: ::
# 显示IPv6 RIB下一跳的详细信息。
<Sysname> display ipv6 rib nib verbose
Age: 00h01m50s
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
ExtType2: 0x0
OriNexthop: ::
RefCnt: 4 FlushRefCnt: 1
Flag: 0x84 Version: 1
ExtFlag: 0x0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::
RelyDepth: 0 RealNexthop: ::
Interface: NULL0 LocalAddr: ::
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology:
Weight: 0 Flags: 0x0
SRPolicyNID: 4294967295 SRInterface: N/A
ColorWeight: 0 Locator: N/A
MemberPort: N/A uiFlags: 0x0
Bandwidth: 0
Age: 00h01m50s
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 10 20
ExtType2: 0x0
OriNexthop: ::
ExtFlag: 0x0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::1
RelyDepth: 0 RealNexthop: ::1
Interface: InLoop0 LocalAddr: ::1
Bandwidth: 0
display ipv6 route-direct nib命令用来显示IPv6直连路由下一跳信息。
nib-id:路由邻居ID值,取值范围为十六进制数0~ffffffff。
# 显示IPv6直连路由下一跳信息。
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
Age: 00h01m50s
Age: 00h01m50s
# 显示IPv6直连路由下一跳详细信息。
<Sysname> display ipv6 route-direct nib verbose
Age: 00h01m50s
RefCnt: 1 FlushRefCnt: 0
Flag: 0x2 Version: 1
ExtFlag: 0x0
1 nexthop(s):
Age: 00h01m50s
ExtFlag: 0x0
1 nexthop(s):
以上显示信息的解释请参见“display route-direct nib”中的显示信息描述表。
display ipv6 routing-table命令用来显示IPv6路由表的信息。
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ipv6 routing-table all-routes
all-vpn-instance:显示所有VPN实例的路由信息。
verbose:显示IPv6路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
# 显示当前路由表的概要信息。
<Sysname> display ipv6 routing-table
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: FE80::/10 Protocol : Direct
NextHop : :: Preference: 0
Destination: 100:1::/128 Protocol : SRv6
NextHop : ::1 Preference: 4
<Sysname> display ipv6 routing-table all-routes
VPN instance: vpn1
Destination: 1:2::3:4/128 Protocol : Static
NextHop : :: Preference: 60
Interface : NULL0 Cost : 0
# 显示所有VPN实例下的IPv6路由信息。
<Sysname> display ipv6 routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
表1-5 display ipv6 routing-table命令显示信息描述表
VPN instance |
Destinations |
目的地址个数 |
Routes |
路由条数 |
Destination |
目的网络/主机的IPv6地址和前缀 |
NextHop |
下一跳地址 |
Preference |
路由优先级 |
出接口,即到该目的地址的数据包将从此接口发出 |
Protocol |
发现该路由的路由协议类型 |
Cost |
路由的开销值 |
Summary count |
路由数目 |
# 显示路由表的详细路由信息。
<Sysname> display ipv6 routing-table verbose
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 22h19m03s
OrigTblID: 0xa OrigVrf: default-vrf
TableID: 0xa OrigAs: 0
NibID: 0x20000002 LastAs: 0
AttrID: 0xffffffff
BkAttrID: 0x1000000 Neighbor: ::
Flags: 0x10004 OrigNextHop: ::1
Label: NULL RealNextHop: ::1
SID: N/A
BkSID: N/A
Destination: 12::/96
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 02h27m40s
NibID: 0x20000004 LastAs: 0
AttrID: 0xffffffff
BkAttrID: 0xd5ec7ab7 Neighbor: ::
Flags: 0x10014 OrigNextHop: ::
SRLabel: NULL Interface: Vlan-interface11
SID: N/A
BkSID: N/A
<Sysname> display ipv6 routing-table all-vpn-instance verbose
VPN instance: vpn1
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h18m54s
OrigTblID: 0x20a OrigVrf: vpn1
TableID: 0x20a OrigAs: 0
NibID: 0x20000006 LastAs: 0
AttrID: 0xffffffff
BkAttrID: 0x0 Neighbor: ::
SID: N/A
BkSID: N/A
Destination: 12::1/128
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h14m58s
AttrID: 0xffffffff
Flags: 0x10000 OrigNextHop: ::1
SID: N/A
BkSID: N/A
表1-6 display ipv6 routing-table verbose命令显示信息描述表
VPN instance |
Destination |
目的网络/主机的IPv6地址和前缀 |
Protocol |
发现该路由的路由协议类型 |
Process ID |
进程号 |
SubProtID |
路由子协议ID |
Age |
此路由在路由表中存在的时间 |
Cost |
路由的度量值 |
Preference |
路由的优先级 |
IpPre |
IP优先级值 |
QosLocalID |
QoS本地ID |
Tag |
路由标记 |
State |
路由状态描述: · Active:有效的单播路由 · Adv:允许对外发送的路由 · Inactive:非激活路由标志 · NoAdv:不允许发布的路由 · Vrrp:VRRP产生的路由 · Nat:NAT产生的路由 · IPSGT:IP-SGT策略产生的路由 |
OrigTblID |
原始路由表ID |
OrigVrf |
TableID |
路由所在路由表的ID |
OrigAs |
初始AS号 |
NibID |
下一跳ID |
LastAs |
最后AS号 |
AttrID |
路由属性ID号 |
BkAttrID |
Neighbor |
路由协议的邻居地址 |
Flags |
路由标志位 |
OrigNextHop |
此路由的下一跳地址 |
Label |
(暂不支持)标签 |
RealNextHop |
路由真实下一跳 |
BkLabel |
(暂不支持)备份标签 |
BkNexthop |
备份下一跳地址 |
SRLabel |
BkSRLabel |
(暂不支持)SR(Segment Routing))备份标签 |
BkInterface |
备份出接口 |
Tunnel ID |
隧道ID |
IPInterface |
IP出接口,即到该目的网段的数据包将从此接口发出 |
BkTunnel ID |
备份隧道ID |
BkIPInterface |
备份IP出接口 |
LinkCost |
IGP物理链路开销值 |
MicroSegID |
路由携带的微分段ID |
RealFIRType |
RealThres |
InLabel |
路由入标签 |
ColorInterface |
SIDIndex |
SID的相对值 |
BkColorInterface |
备份Color出接口 |
FtnIndex |
FTN表项索引 |
TunnelInterface |
Tunnel出接口 |
TrafficIndex |
BkTunnelInterface |
备份Tunnel出接口 |
Connector |
PathID |
BGP路由的Add-Path ID |
SID Type |
SID类型,N/A表示没有该属性 |
NID |
FlushNID |
BkNID |
BkFlushNID |
StatFlags |
SRv6流量统计标记 |
SID |
BkSID |
备用SID,N/A表示没有该属性 |
CommBlockLen |
Locator中的公共前缀长度 |
SRTunnelID |
SR隧道ID |
MemberPort |
ExtFlags |
扩展路由标志位 |
SliceID |
网络切片实例ID |
BkSliceID |
备份网络切片实例ID |
display ipv6 routing-table acl命令用来显示通过指定IPv6 ACL过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
ipv6-acl-number:基本IPv6 ACL编号,取值范围为2000~2999。
verbose:显示通过指定IPv6 ACL过滤的所有路由的详细信息。如果未指定本参数,只显示通过IPv6 ACL过滤的激活路由的概要信息。
引用IPv6 ACL时,需要注意的是:
· 若引用的IPv6 ACL不存在,或者引用的IPv6 ACL中没有配置规则,则显示所有的IPv6路由信息。
· 在引用的IPv6 ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
# 显示通过IPv6 ACL 2000过滤的激活路由的概要信息。
<Sysname> display ipv6 routing-table acl 2000
Summary count : 6
Destination : ::1/128 Protocol : Direct
Destination: 12::/96 Protocol : Direct
Interface : Vlan11 Cost : 0
Destination: 12::1/128 Protocol : Direct
Destination: 11::1/128 Protocol : O_INTER
NextHop : FE80::A1F:3FFF:FE45:206 Preference: 10
Interface : Vlan11 Cost : 2
Destination: FF00::/8 Protocol : Direct
以上显示信息的解释请参见“display ipv6 routing-table”中的显示信息描述表。
# 显示通过IPv6 ACL 2000过滤的所有路由的详细信息。
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h35m02s
AttrID: 0xffffffff
SID: N/A
BkSID: N/A
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h35m31s
NibID: 0x20000000 LastAs: 0
AttrID: 0xffffffff
Flags: 0x10080 OrigNextHop: ::
SID: N/A
BkSID: N/A
Protocol: Direct
Process ID: 0
AttrID: 0xffffffff
SID: N/A
BkSID: N/A
Destination: FF::11/128
Protocol: O_INTER
Process ID: 1
SubProtID: 0x1 Age: 00h02m23s
NibID: 0x23000001 LastAs: 0
AttrID: 0xffffffff
BkAttrID: 0x1b7f0000 Neighbor: ::
Flags: 0x10c1 OrigNextHop: ::
SID: N/A
BkSID: N/A
Protocol: Direct
Process ID: 0
AttrID: 0xffffffff
SID: N/A
BkSID: N/A
Protocol: Direct
Process ID: 0
AttrID: 0xffffffff
SRLabel: NULL Interface: NULL0
Tunnel ID: Invalid IPInterface: NULL0
SID: N/A
BkSID: N/A
display ipv6 routing-table ipv6-address命令用来显示指定目的地址的IPv6路由信息。
display ipv6 routing-table ipv6-address1 to ipv6-address2命令用来显示指定目的地址范围内的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address:IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
longer-match:显示满足匹配条件的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ipv6-address1 to ipv6-address2:IPv6地址范围。ipv6-address1和ipv6-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示激活路由的概要信息。
· display ipv6 routing-table ipv6-address
显示满足如下条件的所有激活路由:
¡ 用户输入的目的IPv6地址同路由表中各条路由的前缀长度值进行与运算。
¡ 路由表中各条路由的目的IPv6地址同其自身前缀长度值进行与运算。
· display ipv6 routing-table ipv6-address prefix-length
显示满足如下条件的所有激活路由:
¡ 用户输入的目的IPv6地址同用户输入的前缀长度值进行与运算。
¡ 路由表中各条路由的目的IPv6地址同用户输入的前缀长度值进行与运算。
¡ 两次运算结果相同,并且路由表中前缀长度小于等于用户输入的前缀长度的路由条目将被显示出来。
· display ipv6 routing-table ipv6-address longer-match
用户未指定前缀长度时,显示结果与display ipv6 routing-table命令的显示结果相同。
· display ipv6 routing-table ipv6-address prefix-length longer-match
显示满足如下条件的所有激活路由:
· display ipv6 routing-table ipv6-address1 to ipv6-address2
显示ipv6-address1/128到ipv6-address2/128之间的路由,目的IPv6地址与前缀长度(128位)同时在指定范围内才会显示。
# 显示目的IPv6地址/前缀为10::1/127的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64 Protocol : Static
Destination: 10::/68 Protocol : Static
Destination: 10::/120 Protocol : Static
# 显示目的IPv6地址/前缀为10::1/127并且满足匹配条件的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 3
# 显示目的IPv6地址从100::到300::范围内的IPv6路由信息。
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64 Protocol : Static
Destination: 200::/64 Protocol : Static
Destination: 300::/64 Protocol : Static
# 显示目的IPv6地址/前缀为1:2::3:4/128的IPv6路由的详细信息。
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
Protocol: O_INTER
Process ID: 1
AttrID: 0xffffffff
SID: N/A
BkSID: N/A
display ipv6 routing-table prefix-list命令用来显示通过指定前缀列表过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name:IPv6前缀列表的名称,为1~63个字符的字符串,区分大小写。
verbose:显示所有路由的详细信息。如果未指定本参数,只显示激活路由的概要信息。
# 配置地址前缀列表test允许前缀为::1,前缀长度为128的IPv6路由通过。
[Sysname] ipv6 prefix-list test permit ::1 128
# 显示通过前缀列表test过滤的IPv6激活路由的概要信息。
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
# 显示通过前缀列表test过滤的所有IPv6路由的详细信息。
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h35m34s
AttrID: 0xffffffff
SID: N/A
BkSID: N/A
display ipv6 routing-table protocol命令用来显示指定协议生成或发现的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
inactive:如果配置了该参数,此命令只显示未激活路由信息。如果未指定本参数,将显示所有激活和未激活路由信息。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有IPv6直连路由的概要信息。
<Sysname> display ipv6 routing-table protocol direct
Summary count : 3
Summary count : 3
Summary count : 0
# 显示IPv6静态路由表。
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128 Protocol : Static
NextHop : fe80::2 Preference: 60
Interface : Vlan12 Cost : 0
NextHop : fe80::3 Preference: 60
Destination: 3::3/128 Protocol : Static
NextHop : 2::2 Preference: 60
Summary count : 0
# 显示所有OSPFv3路由的详细信息。
<Sysname> display ipv6 routing-table protocol ospfv3 verbose
Summary count : 1
Destination: 1001::/64
Protocol: O_INTRA
Process ID: 1
SubProtID: 0x1 Age: 00h44m52s
AttrID: 0xffffffff
SID: N/A
BkSID: N/A
display ipv6 routing-table statistics命令用来显示IPv6路由表中的综合路由统计信息。综合路由统计信息包括路由总数、路由协议添加/删除路由数目、激活路由数目。
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] statistics
# 显示公网路由表中综合路由统计信息。
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8 Active prefixes: 8
DIRECT 5 5 5 0
STATIC 3 3 3 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
BGP4+ 0 0 0 0
Total 8 8 8 0
<Sysname> display ipv6 routing-table all-routes statistics
Total prefixes: 6 Active prefixes: 6
DIRECT 3 3 3 0
STATIC 3 3 5 2
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
BGP4+ 0 0 0 0
Total 6 6 8 2
<Sysname> display ipv6 routing-table vpn-instance vpn1 statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
BGP4+ 0 0 0 0
Total 11 11 13 2
<Sysname> display ipv6 routing-table all-vpn-instance statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
BGP4+ 0 0 0 0
Total 11 11 13 2
表1-7 display ipv6 routing-table statistics命令显示信息描述表
Total prefixes |
总的前缀数目 |
Active prefixes |
总的激活前缀数目 |
Proto |
路由协议 |
Routes |
总的路由数目 |
Active |
激活的、正在使用的路由数目 |
Added |
Deleted |
Total |
各种类型路由数目的总和 |
display ipv6 routing-table summary命令用来显示IPv6路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
# 显示公网的路由表概要信息。
<Sysname> display ipv6 routing-table summary
Max ECMP: 16
Max Active Route: 262144
Remain Active Route: 262141
# 显示实例vpn1的路由表概要信息。
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 16
以上显示信息的解释请参见“display ip routing-table summary”中的显示信息描述表。
display max-ecmp-num命令用来显示系统支持IPv4最大等价路由的条数。
# 显示系统支持IPv4最大等价路由的条数。
<Sysname> display max-ecmp-num
Max-ECMP-Num in use: 6
Max-ECMP-Num at the next reboot: 10
表1-8 display max-ecmp-num命令显示信息描述表
Max-ECMP-Num in use |
当前使用的最大等价路由的条数 |
Max-ECMP-Num at the next reboot |
下次启动后的最大等价路由的条数 |
· max-ecmp-num
display rib attribute命令用来显示RIB的路由属性信息。
# 显示RIB的路由属性信息。
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
Flag: 0x0
Protocol: BGP instance default
Address family: IPv4
Reference count: 0
Act-RT reference count: 0
Flush flag: 0
Local preference: 0
Ext-communities number: 26
Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
> <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
: 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
<RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
AS-path number: 0
AS-path value: N/A
SFlow AS-path length: 0
SFlow AS-path value: N/A
Detailed information of attribute 0x1:
Flag: 0x0
Protocol: BGP
Reference count: 0
Flush flag: 0
Local prefrence: 0
Ext-communities number: 1
Ext-communities value: <RT: 1:2>
AS-path number: 0
AS-path value: N/A
表1-9 display rib attribute命令显示信息描述表
Total number of attribute(s): |
attribute的总个数 |
Flag |
标志位 |
Protocol |
产生该属性的协议 |
Address family |
地址簇类型 |
Reference count |
引用计数 |
Act-RT reference count |
被激活路由引用次数 |
Flush flag |
下刷FIB标记,0表示属性没有下刷FIB,1表示属性已经下刷FIB |
Local prefrence |
本地优先级 |
Ext-communities number |
扩展团体属性个数 |
Ext-communities value |
扩展团体属性值(个数为0显示N/A,最多显示20个,超出部分用…表示) |
Communities number |
团体属性个数 |
Communities value |
AS-path number |
AS-path个数(AS-path个数为所有AS号之和) |
AS-path value |
AS-path值(AS-path值不区分AS-set、AS-sequence、联盟AS-set、联盟AS-sequence;个数为0显示N/A,最多显示20个,超出部分用…表示) |
SFlow AS-path length |
sFlow AS-path属性长度 |
SFlow AS-path value |
sFlow AS-path值(长度为0显示N/A,最多显示80个,超出部分用…表示) |
display rib graceful-restart命令用来显示RIB的GR状态信息。
# 显示RIB的GR状态信息。
<Sysname> display rib graceful-restart
Protocol GR state:
1 DIRECT 900 30 End No/No
2 STATIC 900 34 End No/No
3 OSPF 900 36 End No/No
4 ISIS 900 32 End No/No
5 BGP instance abc
900 22 End No/No
6 BGP instance default
900 25 End No/No
表1-10 display rib graceful-restart命令显示信息描述表
RIB GR state |
RIB GR状态: · Start:协议GR开始 · IGP end:所有IGP协议GR结束 · VPN-triggering end:VPN路由触发优选结束 · VPN-calculation end:VPN路由优选结束 · Routing protocol end:所有路由协议GR结束 · NSR-calculation unfinished:NSR优选未完成状态 · Triggering start:所有路由触发优选开始 · Triggering end:所有路由触发优选结束 · Phase1-calculation end:第一阶段优选结束 · All end:所有协议GR结束 · Phase2-calculation end:第二阶段优选结束 |
RCOM GR state |
RCOM GR状态: · Start:协议GR开始 · VPN-calculation end:VPN路由优选结束 · VPN-notification end:VPN路由上报结束 · Routing protocol end:所有路由协议GR结束 · NSR-calculation unfinished:NSR优选未完成状态 · Phase1-calculation end:第一阶段优选结束 · Notification end:所有路由上报结束 · Phase2-calculation end:第二阶段优选结束 · Flush start:开始下刷FIB · Flush end:下刷FIB结束 |
Protocol GR state |
协议GR状态 |
No. |
编号 |
Protocol |
协议名称 |
Lifetime |
倒换过程中协议的路由信息在RIB中的存活时间,单位为秒 |
FD |
协议进程与RIB连接的句柄 |
State |
协议GR状态: · Init:协议GR初始化状态 · Listen:协议GR监听状态 · Idle:协议GR空闲状态 · Active:协议GR激活状态 · Start:协议GR开始状态 · End:协议GR结束状态 |
Start/End |
· No:表示该消息未发送 · Yes:表示该消息已发送 |
display rib nib命令用来显示RIB的下一跳信息。
self-originated:路由管理自己生成的下一跳信息。
nib-id:路由下一跳信息的ID值,取值范围为十六进制数0~ffffffff。
protocol protocol:显示指定路由协议生成的下一跳信息。
如果不指定任何参数,将显示RIB中所有下一跳的概要信息。
# 显示RIB的下一跳信息。
<Sysname> display rib nib
Total number of nexthop(s): 176
NibID: 0x10000000 Sequence: 0
Age: 00h01m50s
UserKey1: 0x0 Nexthop: 0.0.0.0
IFIndex: 0x111 LocalAddr: 0.0.0.0
MemberPort: 0x0
TopoNthp: 0 ExtType: 0x0
ExtBandwidth:0x0
AS-path: 0 0
TopoNthp: 0 ExtType1: 0x0
ExtType2: 0x0
OriNexthop: 0.0.0.0
NibID: 0x10000001 Sequence: 1
Age: 00h01m50s
UserKey1: 0x0 Nexthop: 127.0.0.1
IFIndex: 0x112 LocalAddr: 127.0.0.1
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
ExtType2: 0x0
OriNexthop: 0.0.0.0
NextHopDevID: 0 RemoteDevID: 0
NibID: 0x10000002 Sequence: 2
Type: 0x5 Flushed: Yes
Age: 00h01m50s
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
ExtType2: 0x0
OriNexthop: 0.0.0.0
NibID: 0x16000000 Sequence: 3
Type: 0x21 Flushed: No
Age: 00h01m50s
UserKey1: 0x0 Nexthop: 12.1.1.2
IFIndex: 0x0 LocalAddr: 0.0.0.0
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
ExtType2: 0x0
OriNexthop: 0.0.0.0
Instance: abc
表1-11 display rib nib命令显示信息描述表
Total number of nexthop(s) |
总的下一跳个数 |
NibID |
下一跳ID |
Sequence |
下一跳序列号 |
Type |
下一跳类型 |
Flushed |
是否下刷 |
Age |
下一跳信息最近一次更新的时间 |
UserKey0 |
第一个协议保留数据 |
UserKey1 |
第二个协议保留数据 |
VrfNthp |
下一跳所在VPN索引,显示为0表示公网 |
Nexthop |
下一跳地址 |
IFIndex |
接口索引 |
LocalAddr |
本地接口地址 |
MemberPort |
聚合组成员端口的索引值 |
NewUK0 |
第一个新的协议保留数据 |
NewUK1 |
第二个新的协议保留数据 |
NewUK2 |
第三个新的协议保留数据 |
NewUK3 |
第四个新的协议保留数据 |
NewUK4 |
第五个新的协议保留数据 |
NewUK5 |
第六个新的协议保留数据 |
NewUK6 |
第七个新的协议保留数据 |
NewUK7 |
第八个新的协议保留数据 |
TopoNthp |
(暂不支持子拓扑)下一跳所在拓扑索引,显示为0表示公网拓扑,显示为其他数值表示子拓扑(目前IPv6不支持子拓扑,显示为Invalid) |
ExtType |
下一跳扩展类型 |
FIRType |
(暂不支持)等价路由FIR模式中下一跳所在链路的类型,取值包括: · Normal:表示普通链路 · Primary:表示主用链路 · Secondary:表示备用链路 |
Threshold |
(暂不支持)等价路由FIR模式中主用链路的带宽使用率上限阈值,单位为百分比 |
ExtBandwidth |
来自BGP协议的链路带宽属性值 |
AS-path |
下一跳携带的AS号,从左到右的两个AS号含义分别为: · 第一个AS号:BGP路由AS_PATH属性中到达本地AS前的倒数第二个AS号 · 第二个AS号:BGP路由AS_PATH属性中到达本地AS前的最后一个AS号 两个AS号以空格分隔,如果不存在这样的AS号,则显示为0 |
TopoNthp |
下一跳所在拓扑索引,显示为0表示公网拓扑(目前IPv6不支持子拓扑,显示为Invalid) |
ExtType1 |
第一个下一跳扩展类型 |
ExtType2 |
第二个下一跳扩展类型 |
Color |
Color扩展团体属性 |
COFlag |
Color属性的标志位 |
SIDIndex |
SID的索引值 |
SRPName |
SR-MPLS TE Policy的名称 |
OriNexthop |
NextHopDevID |
下一跳的Device ID,不存在时显示为0 |
RemoteDevID |
下一跳对应的远端设备的Device ID,即远端Leaf设备的Device ID,不存在时显示为0 |
Instance |
BGP实例名称 |
SubNibID |
子下一跳的ID |
SubSeq |
子下一跳的序列号 |
NthpCnt |
子下一跳的下一跳计数 |
Samed |
子下一跳中相同下一跳计数 |
NthpType |
子下一跳类型: · IP:下一跳是IP转发类型 |
# 显示RIB下一跳详细信息。
<Sysname> display rib nib verbose
NibID: 0x10000000 Sequence: 6
Age: 01h33m56s
UserKey1: 0x0 Nexthop: 12.1.1.1
IFIndex: 0x1410 LocalAddr: 12.1.1.1
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
ExtType2: 0x0
OriNexthop: 0.0.0.0
RefCnt: 6 FlushRefCnt: 2
ExtFlag: 0x0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 12.1.1.1
RelyDepth: 0 RealNexthop: 12.1.1.1
Interface: Vlan11 LocalAddr: 12.1.1.1
TunnelID: N/A Topology: base
Weight: 100000 Flags: 0x0
Bandwidth: 0
NibID: 0x10000004 Sequence: 3
Age: 01h40m09s
IFIndex: 0x140e LocalAddr: 127.0.0.1
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
ExtType2: 0x0
OriNexthop: 0.0.0.0
RefCnt: 13 FlushRefCnt: 5
ExtFlag: 0x0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 127.0.0.1
RelyDepth: 0 RealNexthop: 127.0.0.1
Interface: InLoop0 LocalAddr: 127.0.0.1
Bandwidth: 0
表1-12 display rib nib verbose命令显示信息描述表
总的下一跳个数 |
NibID |
下一跳ID |
Sequence |
下一跳序列号 |
Type |
下一跳类型 |
Flushed |
是否下刷 |
Age |
下一跳信息最近一次更新的时间 |
UserKey0 |
第一个协议保留数据 |
VrfNthp |
UserKey1 |
第二个协议保留数据 |
Nexthop |
下一跳地址 |
IFIndex |
接口索引 |
LocalAddr |
本地接口地址 |
MemberPort |
聚合组成员端口的索引值 |
FIRType |
Threshold |
ExtBandwidth |
下一跳携带的链路带宽属性值 |
AS-path |
NewUK0 |
第一个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK1 |
第二个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK2 |
第三个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK3 |
第四个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK4 |
第五个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK5 |
第六个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK6 |
第七个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK7 |
第八个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK8 |
第九个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK9 |
第十个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK10 |
第十一个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK11 |
第十二个新的协议保留数据,如果没有此属性,则不显示该字段 |
NewUK12 |
第十三个新的协议保留数据,如果没有此属性,则不显示该字段 |
TopoNthp |
ExtType1 |
第一个下一跳扩展类型 |
ExtType2 |
第二个下一跳扩展类型 |
Color |
Color扩展团体属性 |
COFlag |
Color属性的标志位 |
SIDIndex |
SID的索引值 |
SRPName |
OriNexthop |
Instance |
BGP实例名称 |
RefCnt |
下一跳信息的引用计数 |
FlushRefCnt |
下一跳信息的下刷引用计数 |
Flag |
下一跳信息的标志位 |
Version |
下一跳信息的版本号 |
ExtFlag |
下一跳信息的扩展标志位 |
Policy |
隧道策略名 |
x nexthop (s) |
下一跳具体值(前面数值表示下一跳个数) |
PrefixIndex |
等价时下一跳序号 |
OrigNexthop |
原始下一跳 |
RelyDepth |
迭代深度 |
RealNexthop |
真实下一跳 |
出接口 |
LocalAddr |
本地接口地址 |
TunnelCnt |
迭代到隧道的个数 |
Vrf |
VPN实例名,显示为default-vrf表示公网 |
TunnelID |
迭代到隧道的ID |
Topology |
拓扑名称,显示为base表示公网拓扑(目前IPv6不支持子拓扑,显示为空) |
Weight |
等价路由各路由的权重,取值为0表示不是等价路由 |
Flags |
当前下一跳的标志位,取值包括: · 0x0001:下一跳不带Gateway · 0x0002:Permanent静态路由的下一跳 · 0x0004:直连网段路由下一跳 · 0x0008:隧道变化标记 · 0x0010:下一跳的Weight字段代表带宽 · 0x0020:LISP路由下一跳标记 · 0x0040:跨网段ARP学习标记 · 0x0080:出接口为VSI虚接口 · 0x0100:UCM下发的路由下一跳 · 0x0200:Color迭代变化标记 · 0x0400:SR防微环标记 · 0x0800:下一跳不迭代黑洞标记 · 0x1000:应用隧道策略的静态路由迭代隧道 · 0x2000:ECMP备用下一跳标记 · 0x4000:从隧道出接口获取的NID · 0x8000:跨VPN转发标记 取值为0x0表示下一跳未包含上述任意一个标志位 |
SRPolicyNID |
SR-MPLS TE Policy迭代路由的下一跳ID |
SRInterface |
SR-MPLS TE Policy迭代路由的出接口 |
ColorWeight |
SR-MPLS TE Policy中Color属性的权重值 |
Locator |
SID所属Locator段的IPv6前缀,N/A表示没有该属性 |
MemberPort |
uiFlags |
当前下一跳的标志位的扩展,取值包括: · 0x00000001:SRv6 TE Policy协议建立的SRv6多级主备NID · 0x00000002:从路由管理上报迭代获得NID · 0x00000004:SRv6转发标记 · 0x00000008:优先通过SRv6 TE方式选择转发路径 · 0x00000010:SRv6多级FRR。其中,主路径为SRv6 TE路径,备份路径为SRv6 BE路径 取值为0x0表示下一跳未包含上述任意一个标志位 |
RealFIRType |
RealThres |
Bandwidth |
来自IGP协议或接口配置的链路带宽属性值 |
display route-direct nib命令用来显示直连路由下一跳信息。
# 显示直连路由下一跳信息。
<Sysname> display route-direct nib
Total number of nexthop(s): 116
Age: 00h01m50s
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
ExtType2: 0x0
OriNexthop: 0.0.0.0
Age: 00h01m50s
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
ExtType2: 0x0
OriNexthop: 0.0.0.0
表1-13 display route-direct nib命令显示信息描述表
总的下一跳个数 |
NibID |
NIB ID号 |
Sequence |
NIB序列号 |
Type |
NIB类型 |
Flushed |
是否下刷FIB |
Age |
下一跳信息最近一次更新的时间 |
UserKey0 |
NIB协议保留数据1 |
UserKey1 |
NIB协议保留数据2 |
VrfNthp |
Nexthop |
下一跳信息 |
IFIndex |
接口索引 |
LocalAddr |
本地接口地址 |
MemberPort |
聚合组成员端口的索引值 |
NewUK0 |
第一个新的协议保留数据 |
NewUK1 |
第二个新的协议保留数据 |
NewUK2 |
第三个新的协议保留数据 |
NewUK3 |
第四个新的协议保留数据 |
NewUK4 |
第五个新的协议保留数据 |
NewUK5 |
第六个新的协议保留数据 |
NewUK6 |
第七个新的协议保留数据 |
NewUK7 |
第八个新的协议保留数据 |
TopoNthp |
ExtType |
下一跳扩展类型 |
FIRType |
Threshold |
ExtBandwidth |
来自BGP协议的链路带宽属性值 |
AS-path |
TopoNthp |
ExtType1 |
第一个下一跳扩展类型 |
ExtType2 |
第二个下一跳扩展类型 |
Color |
Color扩展团体属性 |
COFlag |
Color属性的标志位 |
SIDIndex |
SID的索引值 |
SRPName |
OriNexthop |
# 显示直连路由下一跳详细信息。
<Sysname> display route-direct nib verbose
NibID: 0x10000001 Sequence: 0
Age: 00h06m50s
IFIndex: 0x140d LocalAddr: 0.0.0.0
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
TopoNthp: 1 ExtType1: 0x0
ExtType2: 0x0
OriNexthop: 0.0.0.0
RefCnt: 2 FlushRefCnt: 0
ExtFlag: 0x0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 0.0.0.0
RelyDepth: 0 RealNexthop: 0.0.0.0
Interface: NULL0 LocalAddr: 0.0.0.0
TunnelID: N/A Topology: chris
MemberPort: N/A
Bandwidth: 0
NibID: 0x10000002 Sequence: 1
Age: 00h06m50s
MemberPort: 0x0
ExtBandwidth:0x0
AS-path: 0 0
ExtType2: 0x0
OriNexthop: 0.0.0.0
RefCnt: 4 FlushRefCnt: 0
ExtFlag: 0x0
1 nexthop(s):
MemberPort: N/A
Bandwidth: 0
表1-14 display route-direct nib verbose命令显示信息描述表
总的下一跳个数 |
NibID |
下一跳ID |
Sequence |
下一跳序列号 |
Type |
下一跳类型 |
Flushed |
是否下刷 |
Age |
下一跳信息最近一次更新的时间 |
UserKey0 |
第一个协议保留数据 |
VrfNthp |
UserKey1 |
第二个协议保留数据 |
Nexthop |
下一跳地址 |
IFIndex |
接口索引 |
LocalAddr |
本地接口地址 |
MemberPort |
聚合组成员端口的索引值 |
NewUK0 |
第一个新的协议保留数据 |
NewUK1 |
第二个新的协议保留数据 |
NewUK2 |
第三个新的协议保留数据 |
NewUK3 |
第四个新的协议保留数据 |
NewUK4 |
第五个新的协议保留数据 |
NewUK5 |
第六个新的协议保留数据 |
NewUK6 |
第七个新的协议保留数据 |
NewUK7 |
第八个新的协议保留数据 |
TopoNthp |
ExtType |
下一跳扩展类型 |
FIRType |
Threshold |
ExtBandwidth |
来自BGP协议的链路带宽属性值 |
AS-path |
TopoNthp |
ExtType1 |
第一个下一跳扩展类型 |
ExtType2 |
第二个下一跳扩展类型 |
Color |
Color扩展团体属性 |
COFlag |
Color属性的标志位 |
SIDIndex |
SID的索引值 |
SRPName |
OriNexthop |
RefCnt |
RefCnt |
FlushRefCnt |
下一跳信息的下刷引用计数 |
Flag |
下一跳信息的标志位 |
Version |
下一跳信息的版本号 |
ExtFlag |
下一跳信息的扩展标志位 |
x nexthop (s) |
PrefixIndex |
等价时下一跳序号 |
OrigNexthop |
原始下一跳 |
RelyDepth |
迭代深度 |
RealNexthop |
真实下一跳 |
出接口 |
LocalAddr |
本地接口地址 |
TunnelCnt |
迭代到隧道的个数 |
Vrf |
TunnelID |
迭代到隧道的ID |
Topology |
(暂不支持子拓扑)拓扑名称,显示为base表示公网拓扑,显示为其他表示子拓扑(目前IPv6不支持子拓扑,显示为空) |
Weight |
等价路由各路由的权重 |
Flags |
当前下一跳的标志位 |
SRPolicyNID |
SRInterface |
ColorWeight |
Locator |
MemberPort |
RealFIRType |
RealThres |
Bandwidth |
fib lifetime命令用来配置IPv4/IPv6路由在FIB中的最大存活时间。
undo fib lifetime命令用来恢复缺省情况。
fib lifetime seconds
undo fib lifetime
IPv4/IPv6路由在FIB中的最大存活时间为600秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
seconds:路由在FIB中的最大存活时间,取值范围为0~6000,单位为秒。取值为0时表示,协议或RIB进程倒换并重新恢复后,会立即通知FIB老化表项。
配置本命令后,协议在未配置GR或NSR的情况下,协议或RIB倒换重新恢复后,会延迟配置的seconds,再通知FIB老化表项。
# 配置IPv4路由在FIB中的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
flush route-attribute命令用来配置RIB向FIB下发路由时会携带属性消息。
undo flush route-attribute命令用来取消该配置。
flush route-attribute protocol
undo flush route-attribute protocol
RIB向FIB下发路由时不携带属性消息。
RIB IPv4地址族视图
protocol:路由协议,目前只支持BGP。
# 配置RIB向FIB下发BGP路由时会携带属性消息。
[Sysname] rib
[Sysname-rib-ipv4] flush route-attribute bgp
inter-protocol fast-reroute命令用来开启RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
undo inter-protocol fast-reroute命令用来关闭RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
不同协议间快速重路由功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
vpn-instance vpn-instance-name:开启指定VPN实例的不同协议间快速重路由功能。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则开启RIB IPv4/IPv6地址族中公网的不同协议间快速重路由功能。
通过配置不同协议间快速重路由功能,可将不同协议的下一跳作为备份下一跳。当路由器检测到网络故障时,将使用备份下一跳替换失效下一跳,通过备份下一跳来指导报文的转发,从而大大缩短了流量中断的时间。
如果RIB表中去往同一目的地的不同路由的下一跳和出接口均相同,使用该命令不会生成备份下一跳。
使用不同协议间的快速重路由功能生成备份下一跳时可能会造成环路。
# 开启RIB IPv4地址族中公网的不同协议间快速重路由功能。
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
ip route fast-switchover enable命令用来开启IPv4路由快速切换功能。
undo ip route fast-switchover enable命令用来关闭IPv4路由快速切换功能。
IPv4路由快速切换功能处于关闭状态。
在未开启本功能的情况下,当某个物理接口为大量路由(包括等价路由和主备路由的主路由)连接下一跳的出接口时,如果该接口所在的链路故障时,设备需要先删除失效链路对应的所有ARP表项,然后通知FIB删除失效的FIB表项,处理时间过长,流量无法快速切换到可用路径。通过开启本功能,当接口所在的链路故障时,设备直接通知FIB删除失效的FIB表项,以加快路由的切换、缩短流量中断的时间。
# 开启IPv4路由快速切换功能。
[Sysname] ip route fast-switchover enable
ipv6 route fast-switchover enable命令用来开启IPv6路由快速切换功能。
undo ipv6 route fast-switchover enable命令用来关闭IPv6路由快速切换功能。
IPv6路由快速切换功能处于关闭状态。
在未开启本功能的情况下,当某个物理接口为大量路由(包括等价路由和主备路由的主路由)连接下一跳的出接口时,如果该接口所在的链路故障时,设备需要先删除失效链路对应的所有ND表项,然后通知FIB删除失效的FIB表项,处理时间过长,流量无法快速切换到可用路径。通过开启本功能,当接口所在的链路故障时,设备直接通知FIB删除失效的FIB表项,以加快路由的切换、缩短流量中断的时间。
# 开启IPv6路由快速切换功能。
[Sysname] ipv6 route fast-switchover enable
max-ecmp-num命令用来配置系统支持IPv4最大等价路由的条数。
undo max-ecmp-num命令用来恢复缺省情况。
max-ecmp-num number
undo max-ecmp-num
系统支持最大等价路由的条数为16。
number:IPv4最大等价路由的条数,取值范围为1~16 。
本配置在设备重启后才能生效,进行设备重启前请评估重启对网络造成的影响,做好相关准备工作。
# 配置系统支持IPv4最大等价路由的条数为10。
[Sysname] max-ecmp-num 10
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Reboot device to make the configuration take effect.
重启后,系统支持IPv4最大等价路由的条数为10。
· display max-ecmp-num
maintenance-probe enable命令用来开启MTP(Maintain Probe,维护探测器)功能。
undo maintenance-probe enable命令用来关闭MTP功能。
MTP功能处于关闭状态。
开启MTP功能后,当与邻居间的路由协议报文超时时,设备会向超时的邻居发起Ping操作和Tracert操作并记录结果,相关信息可以通过display bgp troubleshooting等路由协议模块的显示命令查看,也可以通过display logbuffer命令查看MTP的详细信息。
# 开启MTP功能。
[Sysname] maintenance-probe enable
· display bgp troubleshooting(三层技术-IP路由命令参考/BGP)
· display logbuffer(网络管理和监控命令参考/信息中心)
non-stop-routing命令用来使能路由的NSR功能。
undo non-stop-routing命令用来关闭路由的NSR功能。
non-stop-routing
路由的NSR功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
# 使能IPv4路由的NSR功能。
[Sysname] rib
[Sysname-rib-ipv4] non-stop-routing
primary-path-detect bfd命令用来配置协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达。
undo primary-path-detect bfd命令用来取消协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达的配置。
primary-path-detect bfd { ctrl | echo } [ inter-protocol-frr | protocol-ecmp protocol ]
undo primary-path-detect bfd [ inter-protocol-frr | protocol-ecmp protocol ]
未配置协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达。
RIB IPv4地址族视图
RIB IPv6地址族视图
ctrl:配置通过控制报文方式的BFD会话检测主路由的下一跳是否可达。
echo:配置通过echo报文方式的BFD会话检测主路由的下一跳是否可达。
inter-protocol-frr:配置不同协议间快速重路由通过BFD会话检测主路由的下一跳是否可达。
protocol-ecmp protocol:配置指定路由协议的等价路由通过BFD会话检测主路由的下一跳是否可达。在RIB IPv4地址族视图中,该参数的取值包括bgp、isis、ospf和static。在RIB IPv6地址族视图中,对于控制报文方式的BFD会话,该参数的取值包括bgp4+、isisv6、ospfv3和static;对于echo报文方式的BFD会话,该参数的取值包括bgp4+和static。
配置本命令后,设备会自动创建一个协议类型为IPFRR的BFD会话,通过该BFD会话对主路由的下一跳进行检测,以提高主路由下一跳失效时流量切换到备路由下一跳上的收敛速度:
· 对于不同协议间的快速重路由,主路由指的是去往同一目的地的多条路由中优先级最高的路由。
· 对于指定路由协议的等价路由,主路由指的是形成等价路由的每一条路由。如果在配置路由协议的快速重路由功能时指定了ecmp-shared参数,设备会为包含等价路由的所有路由通过LFA算法选取备份下一跳信息。自动计算的备份下一跳也作为等价路由添加到路由表中,状态为backup,该路由不是主路由,BFD不会检测这种等价路由。
通过重复执行本命令,可以修改BFD会话的工作方式(echo报文方式或控制报文方式)。
执行本命令时,如果没有指定inter-protocol-frr和protocol-ecmp参数,表示同时配置或取消配置不同协议间快速重路由和所有路由协议的所有等价路由通过BFD会话检测主路由的下一跳是否可达的功能。以此种方式进行的配置,优先级高于通过指定inter-protocol-frr或protocol-ecmp参数进行的配置。例如,当执行了primary-path-detect bfd ctrl命令后,仅可通过primary-path-detect bfd echo 命令修改配置,或通过undo primary-path-detect bfd命令取消配置。
通过控制报文方式的BFD会话检测主路由的下一跳是否可达时,由于控制报文方式的BFD会话需要两端进行协商才能成功建立,用户需要在下一跳设备上手工创建一个静态BFD会话。该BFD会话为控制报文方式的单跳BFD会话,并且会话源IP地址为本端自动创建的BFD会话的目的IP地址、会话目的IP地址为本端自动创建的BFD会话的源IP地址、远端标识符为本端自动创建的BFD会话的本地标识符。主路由下一跳设备上创建满足上述要求的静态BFD会话后,本端设备才能使用控制报文方式的BFD会话来检测主路由的下一跳。有关创建静态BFD会话的详细介绍,请参见“可靠性配置指导”中的“BFD”。
其他业务模块在通过BFD会话检测主路由的下一跳是否可达时,也会自动创建BFD会话(如BGP、OSPF、IS-IS等)。如果其他协议创建的自动BFD会话检测的路由下一跳与RIB主路由的下一跳相同,则设备不会重复自动创建同类型的BFD会话,而是复用其他协议的BFD会话。
通过echo报文方式的BFD会话检测主路由的下一跳是否可达时,由于echo报文方式的BFD会话报文源IPv6地址仅支持全球单播地址,对于主路由IPv6下一跳地址不是全球单播地址的场景,建议使用控制报文方式的BFD会话。
# 配置通过控制报文方式的BFD会话检测IS-IS协议所有等价路由的下一跳是否可达。
[Sysname] rib
[Sysname-rib-ipv4] primary-path-detect bfd ctrl protocol-ecmp isis
· fast-reroute(三层技术-IP路由命令参考/IS-IS)
· inter-protocol fast-reroute
protocol lifetime命令用来配置IPv4/IPv6路由在RIB中的最大存活时间。
undo protocol lifetime命令用来恢复缺省情况。
undo protocol protocol [ instance instance-name ] lifetime
IPv4/IPv6路由在RIB中的最大存活时间为900秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议。
instance instance-name:BGP实例名称,instance-name为1~31个字符的字符串,区分大小写。如果未指定本参数,将配置所有BGP实例的最大存活时间。只有当protocol是bgp时该参数可选。
seconds:最大存活时间,取值范围为1~6000,单位为秒。
如果配置了该命令,且协议配置GR的情况下,需要注意该时间不要与GR时间冲突,即必须要保证协议能够在该时间内完成GR并将全部表项下发RIB,否则会导致GR失败并断流。
# 配置RIB中RIP路由的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] protocol rip lifetime 60
protocol nexthop recursive-lookup命令用来配置路由按照路由策略进行迭代下一跳查找。
undo protocol nexthop recursive-lookup命令用来取消该配置。
protocol protocol nexthop recursive-lookup route-policy route-policy-name
undo protocol protocol nexthop recursive-lookup route-policy
未配置路由按路由策略进行下一跳迭代查找。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议,RIB IPv4地址族视图下支持bgp和static,RIB IPv6地址族视图下支持bgp4+和static。
route-policy-name:指定路由策略名,为1~63个字符的字符串,区分大小写。
通过配置按路由策略迭代下一跳,可以对路由迭代的结果进行控制。例如:当路由发生变化时,路由管理需要对非直连的下一跳重新进行迭代。如果不对迭代的结果路由进行任何限制,则路由管理可能会将下一跳迭代到一个错误的转发路径上,从而造成流量丢失。此时,可以通过配置本功能,将错误的依赖路由过滤掉,使路由迭代到通过路由策略过滤的指定依赖路由上。
配置路由策略时,如果配置了apply子句,apply子句不会生效。
配置路由策略时,请确保至少有一个正确的依赖路由能够通过该策略的过滤,否则可能导致相关路由不可达,无法正确指导转发。
# 配置静态路由按照路由策略policy1进行下一跳迭代查找。
[Sysname] rib
[Sysname-rib-ipv4] protocol static nexthop recursive-lookup route-policy policy1
reset ip routing-table statistics protocol命令用来清除路由表中的路由统计信息。
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name:清除指定VPN的路由统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
all-routes:清除公网和所有VPN实例的路由统计信息。
all-vpn-instance:清除所有VPN实例的路由统计信息。
protocol:清除IPv4路由表中指定路由协议的统计信息。
all:清除IPv4路由表中所有路由协议的统计信息。
如果没有指定all-routes、vpn-instance和all-vpn-instance参数,则清除公网的路由统计信息。
# 清除路由表中的路由统计信息。
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics protocol命令用来清除IPv6路由表中的综合路由统计信息。
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
protocol:清除IPv6路由表中指定路由协议的统计信息。
all:清除IPv6路由表中所有路由协议的统计信息。
# 清除IPv6路由表中所有路由协议的综合路由统计信息。
<Sysname> reset ipv6 routing-table statistics protocol all
rib命令用来进入RIB视图。
undo rib命令用来删除RIB视图下的所有配置。
rib
undo rib
# 进入RIB视图。
[Sysname] rib
[Sysname-rib]
routing-table limit命令用来配置设备支持的最大IPv4/IPv6激活路由前缀数。
undo routing-table limit命令用来恢复缺省情况。
不限制设备支持的最大IPv4/IPv6激活路由前缀数。
RIB IPv4地址族视图
RIB IPv6地址族视图
number:设备支持的最大IPv4/IPv6激活路由前缀数目,取值范围为1~4294967295。
warn-threshold:以百分比形式指定激活路由前缀数目告警阈值,取值范围为1~100。当设备中激活路由前缀数占最大支持激活路由前缀数的百分比达到告警阈值时,可以继续激活新的路由前缀,但会产生一条日志信息。当设备中的激活路由前缀数达到最大激活路由前缀数目时,将不再激活新的路由前缀,新增的路由前缀将被丢弃。
simply-alert:当设备的IPv4/IPv6激活路由前缀数超过最大支持的激活路由前缀数目时,可以继续激活新的路由前缀,但会产生一条日志信息。
RIB IPv4地址族视图下的配置用于控制公网和所有VPN实例内IPv4激活路由的总数。
RIB IPv6地址族视图下的配置用于控制公网和所有VPN实例内IPv6激活路由的总数。
多次执行本命令,最后一次执行的命令生效。
# 配置当前设备上的RIB IPv4地址族视图下公网和所有VPN实例内IPv4激活路由的总数超过1000时,可以继续激活新的路由前缀,但是会产生一条日志信息。
[Sysname] rib
[Sysname-rib-ipv4] routing-table limit 1000 simply-alert
snmp-agent trap enable ipv6 rib命令用来开启IPv6 RIB模块的告警功能。
undo snmp-agent trap enable ipv6 rib命令用来关闭IPv6 RIB模块的告警功能。
snmp-agent trap enable ipv6 rib [ prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
undo snmp-agent trap enable ipv6 rib [ prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
IPv6 RIB模块的告警功能处于开启状态。
prefix-exceed:整机IPv6路由前缀数量达到最大值的告警信息。
prefix-exceed-clear:整机IPv6路由前缀数量降到最大值以下的告警信息。
prefix-threshold-exceed:整机IPv6路由前缀数量达到告警阈值的告警信息。
prefix-thresholdexceed-clear:整机IPv6路由前缀数量降低到告警阈值以下的告警信息。
public-prefix-exceed:公网实例中IPv6路由前缀数量达到最大值的告警信息。
public-prefixexceed-clear:公网实例中IPv6路由前缀数量降到最大值以下的告警信息。
public-prefixthreshold-exceed:公网实例中IPv6路由前缀数量达到告警阈值的告警信息。
public-prefixthresholdexceed-clear:公网实例中IPv6路由前缀数量降到告警阈值以下的告警信息。
vrf-prefix-exceed:单个VPN实例中IPv6路由前缀数量达到最大值的告警信息。
vrf-prefixexceed-clear:单个VPN实例中IPv6路由前缀数量降到最大值以下的告警信息。
vrf-prefixthreshold-exceed:单个VPN实例中IPv6路由前缀数量达到告警阈值的告警信息。
vrf-prefixthresholdexceed-clear:单个VPN实例中IPv6路由前缀数量降到告警阈值以下的告警信息。
开启IPv6 RIB模块的告警功能后,IPv6 RIB模块会产生相应的告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
如果未指定任何参数,则表示开启或关闭IPv6 RIB的全部告警功能。
# 关闭IPv6 RIB模块的告警功能。
[Sysname] undo snmp-agent trap enable ipv6 rib
snmp-agent trap enable rib命令用来开启RIB模块的告警功能。
undo snmp-agent trap enable rib命令用来关闭RIB模块的告警功能。
snmp-agent trap enable rib [ prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
undo snmp-agent trap enable rib [ prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
RIB模块的告警功能处于开启状态。
prefix-exceed:整机IPv4路由前缀数量达到最大值的告警信息。
prefix-exceed-clear:整机IPv4路由前缀数量降到最大值以下的告警信息。
prefix-threshold-exceed:整机IPv4路由前缀数量达到告警阈值的告警信息。
prefix-thresholdexceed-clear:整机IPv4路由前缀数量降低到告警阈值以下的告警信息。
public-prefix-exceed:公网实例中IPv4路由前缀数量达到最大值的告警信息。
public-prefixexceed-clear:公网实例中IPv4路由前缀数量降到最大值以下的告警信息。
public-prefixthreshold-exceed:公网实例中IPv4路由前缀数量达到告警阈值的告警信息。
public-prefixthresholdexceed-clear:公网实例中IPv4路由前缀数量降到告警阈值以下的告警信息。
vrf-prefix-exceed:单个VPN实例中IPv4路由前缀数量达到最大值的告警信息。
vrf-prefixexceed-clear:单个VPN实例中IPv4路由前缀数量降到最大值以下的告警信息。
vrf-prefixthreshold-exceed:单个VPN实例中IPv4路由前缀数量达到告警阈值的告警信息。
vrf-prefixthresholdexceed-clear:单个VPN实例中IPv4路由前缀数量降到告警阈值以下的告警信息。
开启RIB模块的告警功能后,RIB模块会产生相应的告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
如果未指定任何参数,则表示开启或关闭RIB的全部告警功能。
# 关闭RIB模块的告警功能。
