09-ACL和QoS命令参考
02-QoS命令
本章节下载 02-QoS命令  (875.17 KB)
02-QoS命令
  录
1 QoS策略
1.1 定义类的命令
1.1.1 description
1.1.2 display traffic classifier
1.1.3 if-match
1.1.4 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 nest top-most
1.2.6 packet-rate
1.2.7 redirect
1.2.8 remark customer-vlan-id
1.2.9 remark dot1p
1.2.10 remark drop-precedence
1.2.11 remark dscp
1.2.12 remark ip-precedence
1.2.13 remark local-precedence
1.2.14 remark service-vlan-id
1.2.15 remark source-mac
1.2.16 traffic behavior
1.3 定义和应用QoS策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 control-plane management
1.3.4 display qos policy
1.3.5 display qos policy control-plane
1.3.6 display qos policy control-plane management
1.3.7 display qos policy control-plane management pre-defined
1.3.8 display qos policy control-plane pre-defined
1.3.9 display qos policy control-plane rule-statistics
1.3.10 display qos policy global
1.3.11 display qos policy global rule-statistics
1.3.12 display qos policy interface
1.3.13 display qos policy interface rule-statistics
1.3.14 display qos policy l2vpn-ac
1.3.15 display qos policy l2vpn-ac rule-statistics
1.3.16 display qos vlan-policy
1.3.17 display qos vlan-policy rule-statistics
1.3.18 qos apply policy (Ethernet service instance view, interface view, control plane view, control-plane management view)
1.3.19 qos apply policy global
1.3.20 qos policy
1.3.21 qos vlan-policy
1.3.22 reset qos policy control-plane
1.3.23 reset qos policy control-plane management
1.3.24 reset qos policy global
1.3.25 reset qos policy l2vpn-ac
1.3.26 reset qos vlan-policy
2 优先级映射
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 display qos map-table color
2.1.3 import
2.1.4 qos map-table
2.1.5 qos map-table color
2.1.6 display qos trust interface
2.1.7 qos trust
2.1.8 qos trust (system view)
2.2 端口优先级配置命令
2.2.1 qos priority
3 流量整形和限速
3.1 流量整形配置命令
3.1.1 display qos gts interface
3.1.2 qos gts
3.2 限速配置命令
3.2.1 display qos lr interface
3.2.2 qos lr
4 拥塞管理
4.1 拥塞管理公共配置命令
4.1.1 display qos queue interface
4.2 严格优先级队列配置命令
4.2.1 display qos queue sp interface
4.2.2 qos sp (interface view)
4.3 加权轮询队列配置命令
4.3.1 display qos queue wrr interface
4.3.2 qos wrr (interface view)
4.3.3 qos wrr { byte-count | weight }
4.3.4 qos wrr group sp
4.4 加权公平队列配置命令
4.4.1 display qos queue wfq interface
4.4.2 qos bandwidth queue
4.4.3 qos wfq (interface view)
4.4.4 qos wfq { byte-count | weight }
4.4.5 qos wfq group sp
4.5 队列调度策略配置命令
4.5.1 bandwidth queue
4.5.2 display qos qmprofile configuration
4.5.3 display qos qmprofile interface
4.5.4 qos apply qmprofile
4.5.5 qos qmprofile
4.5.6 queue
5 拥塞避免
5.1 WRED配置命令
5.1.1 display qos wred interface
5.1.2 display qos wred table
5.1.3 qos wred apply
5.1.4 qos wred queue table
5.1.5 queue (Wred table view)
6 全局CAR
6.1 全局CAR配置命令
6.1.1 car name
6.1.2 display qos car name
6.1.3 qos car (system view)
6.1.4 reset qos car name
7 大小流区分调度
7.1 大小流区分调度配置命令
7.1.1 elephant-flow action
7.1.2 elephant-flow rate
7.1.3 qos mice-elephant-flow
8 端口队列统计
8.1 端口队列统计配置命令
8.1.1 display qos queue-statistics interface outbound
1 QoS策略
如无特殊说明,手册中的QoS策略均指通用类型QoS策略。
1.1  定义类的命令
1.1.1  description
description命令用来配置类的描述信息。
undo description命令用来恢复缺省情况。
未配置类的描述信息。
类视图
text:表示类的描述信息,为1~127个字符的字符串,区分大小写。
多次执行本命令,最后一次执行的命令生效。
# 为类class1配置描述信息。
[Sysname-classifier-class1] description classifier
display traffic classifier命令用来显示类的配置信息。
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定成员设备的流分类的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示主用设备的类的配置信息。‌‌
# 显示用户定义类的配置信息。
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
表1-1 display traffic classifier命令显示信息描述表
用户自定义类的信息
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
1.1.3  if-match
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match match-criteria
undo if-match match-criteria
未定义匹配数据包的规则。
类视图
表1-2 类的匹配规则取值
取值
acl [ ipv6 | mac ] { acl-number | name acl-name }
定义匹配ACL的规则
·     acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999
·     acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
ACL规则中未指定VPN实例时,表示该规则对非VPN报文和VPN报文均有效
any
定义匹配所有数据包的规则
control-plane protocol protocol-name&<1-8>
定义匹配控制平面协议的规则,protocol-name&<1-8>为系统预定义匹配协议报文类型名称的列表,具体如表1-3所示,&<1-8>表示前面的参数最多可以输入8次
control-plane protocol-group protocol-group-name
定义匹配控制平面协议组的规则,protocol-group-name取值为criticalimportantmanagementmonitornormalredirect
customer-dot1p dot1p-value&<1-8>
定义匹配内层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
customer-vlan-id vlan-id-list
定义匹配内层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
destination-mac mac-address [ mac-address-mask ]
定义匹配目的MAC地址的规则,仅对以太网接口生效
dscp dscp-value&<1-8>
定义匹配DSCP的规则,dscp-value&<1-8>为DSCP取值的列表,DSCP的取值范围为0~63,&<1-8>表示前面的参数最多可以输入8次;也可以输入关键字,具体如remark dscp所示
forwarding-layer { bridge | route }
定义匹配转发报文的二、三层属性的规则,其中bridge表示只匹配二层转发报文,route表示只匹配三层转发报文
inbound-interface interface-type interface-number
定义匹配入接口的规则,interface-type interface-number为接口类型和接口编号
在“and”模式的流分类中如果配置了本规则,然后将入接口所在单板或子卡拔出,会导致流分类失效,此时如果将单板或子卡恢复,则流分类会重新生效。但如果不恢复单板或子卡,请删除该流分类并按需重新配置。否则,即使再向该流分类中新增其他匹配规则,该流分类也不会生效
ip-precedence ip-precedence-value&<1-8>
定义匹配IP优先级的规则,ip-precedence-value&<1-8>为IP优先级的列表,IP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
outbound-interface interface-type interface-number
定义匹配出接口的规则,interface-type interface-number为接口类型和接口编号
该匹配项仅支持匹配二层以太网接口、三层以太网接口的出方向。
定义匹配协议的规则,protocol-name取值为ipipv6
service-dot1p dot1p-value&<1-8>
定义匹配外层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
service-vlan-id vlan-id-list
定义匹配外层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID规则来匹配
source-mac mac-address
定义匹配源MAC地址的规则,仅对以太网接口生效
tunnel-id tunnel-id
定义匹配指定隧道内的报文,且匹配该规则的QoS策略仅支持应用在入方向
表1-3 系统预定义匹配协议报文类型名称的列表
报文类型
arp
ARP协议
arp-snooping
ARP Snooping协议
bfd
BFD协议
bgp
BGP协议
bgp4+
IPv6 BGP
dhcp
DHCP协议
dhcp-snooping
DHCP Snooping协议
dhcp6
IPv6 DHCP协议
dldp
DLDP协议
dot1x
802.1p 协议
icmp
ICMP协议
icmp6
IPv6 ICMP协议
isis
IS-IS协议
lacp
LACP协议
ldp
LDP协议
ldp6
IPv6 LDP协议
lldp
LLDP协议
mld
MLD协议
msdp
MSDP协议
mvrp
MVRP协议(包含GVRP协议)
nd
ND协议
ntp
NTP协议
oam
OAM协议
ospf-multicast
OSPF组播
ospf-unicast
OSPF单播
ospf3-multicast
OSPFv3组播
ospf3-unicast
OSPFv3单播
pim-multicast
PIM组播
pim-unicast
PIM单播
pim6-multicast
IPv6 PIM组播
pim6-unicast
IPv6 PIM单播
portal
PORTAL协议
pvst
PVST协议
rip
RIP协议
ripng
RIPng协议
rrpp
RRPP协议
rsvp
RSVP协议
smart-link
Smart Link协议
snmp
SNMP协议
stp
STP协议
udp-helper
UDP中继转发
vrrp
VRRP协议
vrrp6
IPv6 VRRP协议
一个类下可配置多条匹配命令,各个配置之间互相不覆盖。
在接口出方向应用QoS策略时,如果流分类引用的二层ACL中包含匹配MAC地址的规则,则该规则无法匹配IPv6报文。
在定义匹配规则(DSCP、VLAN ID、802.1p优先级和IP优先级)时,请注意:
·     一条命令可以配置多个规则,如果指定了多个相同的规则,系统默认为一个;一条命令中多个不同的规则是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配的规则时,必须与该规则中定义的完全相同才会删除,顺序可以不同。
在定义匹配ACL的规则时,类中引用的ACL必须已经存在。
if-match中引用的ACL规则的动作为deny时,则直接忽略ACL规则的动作,以流行为中定义的动作为准,报文匹配只使用ACL中的分类域。
当QoS策略的匹配对象为IPv6报文时,流分类中需额外配置匹配IPv6报文的规则。规则可配置为匹配IPv6协议类型。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的802.1p优先级为3。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1或6或9的报文。
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# 定义类class1的匹配规则为:匹配IP优先级值为1或6的报文。
[Sysname-classifier-class1] if-match ip-precedence 1 6
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的VLAN ID值为1或6或9的报文。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的VLAN ID值为2或7或10的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# 在流分类class1中配置匹配上送控制平面的normal协议组报文。
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# 在流分类class1中定义匹配隧道编号为2的报文。
[Sysname-classifier-class1] if-match tunnel-id 2
traffic classifier命令用来创建一个类,并进入类视图。如果指定的类已经存在,则直接进入类视图。
undo traffic classifier命令用来删除一个类。
未配置类。
operator:指定各规则之间的逻辑运算符。缺省情况为and
# 定义一个名为class1的类。
·     display traffic classifier
1.2  定义流行为的命令
1.2.1  accounting
accounting命令用来配置流量统计动作。
undo accounting命令用来恢复缺省情况。
accounting [ byte | packet ]
undo accounting
未配置流量统计动作。
流行为视图
byte:表示报文基于字节进行统计。
packet:表示报文基于包进行统计。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
若配置流量统计动作但不指定bytepacket参数,设备将以包和字节为单位进行报文统计。
# 为流行为配置流量统计动作,基于字节进行统计。
[Sysname-behavior-database] accounting byte
1.2.2  car
car命令用来配置流量监管动作。
undo car命令用来恢复缺省情况。
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
未配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。流量的平均速率,单位为kbps。取值范围为16~100000000且必须为8的整数倍。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
·     如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过67092480。
·     如果指定cbs参数,取值范围512~67092480且必须为512的整数倍。
ebs excess-burst-size:超出突发尺寸,单位为byte。取值范围为512~67092480且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps,取值范围为16~100000000且必须为8的整数倍。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass。绿色报文不支持动作discard
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。红色报文不支持动作pass。
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass
action:对数据包采取的动作,有以下几种:
discard:丢弃数据包。
pass:允许数据包通过。
remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
如果未配置峰值速率,则表示所配置的是单速率流量监管,否则表示双速率流量监管。
如果需要对红色、黄色和绿色报文进行流量统计,则需要在流行为同时配置accounting流量统计动作。
# 为流行为配置流量监管。报文正常流速为256kbps,承诺突发尺寸为51200bytes。
[Sysname-behavior-database] car cir 256 cbs 51200
display traffic behavior命令用来显示流行为的配置信息。
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定成员设备的流行为的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的流行为的配置信息。‌‌
# 显示用户定义行为的配置信息。
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      -none-
    Behavior: 3 (ID 102)
      -none-
表1-4 display traffic behavior命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名称及其内容,内容可以有多种类型
Marking
标记相关信息
Remark dscp
重新标记报文的DSCP优先级值
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
EBS
超出突发尺寸,单位为byte
Green action
对绿色报文的动作
Red action
对红色报文的动作
Yellow action
对黄色报文的动作
none
表示未配置其他流行为
1.2.4  filter
filter命令用来配置流量过滤动作。
undo filter命令用来恢复缺省情况。
filter { deny | permit }
undo filter
未配置流量过滤动作。
流行为视图
deny:丢弃命中规则的数据包。
permit:不丢弃命中规则的数据包。
MQC方式的QoS策略中如果执行了filter命令配置流量过滤动作,存在以下不同的处理方式:
·     丢弃报文(Drop):即filter命令指定deny参数。如果报文命中了该CB对中的流量匹配规则,则直接丢弃报文,报文不再受低优先级应用的处理动作影响。
·     不丢弃报文(Drop Cancel):即filter命令指定permit参数。如果报文命中了该CB对中的流量匹配规则,则标记为不丢弃报文,报文不再受低优先级应用的处理动作影响,即使低优先级应用的处理动作为丢弃数据报文,该报文也不会被丢弃。
# 为流行为database配置丢弃数据包的过滤动作。
1.2.5  nest top-most
nest top-most命令用来配置添加报文的外层VLAN Tag动作。
undo nest top-most命令用来恢复缺省情况。
nest top-most vlan vlan-id
undo nest top-most
未配置添加报文外层VLAN Tag动作。
流行为视图
vlan vlan-id:添加的VLAN ID,取值范围为1~4094。
引用了添加VLAN Tag动作的QoS策略只能应用到接口的入方向上。
引用了添加VLAN Tag动作的QoS策略,请勿应用到聚合组成员端口、VSI和AC上
当报文被添加外层VLAN编号后,在该报文的出接口上必须确保该报文内层VLAN编号也能通过。否则,报文无法正常转发。
执行本命令后的二层转发报文无法进行三层转发。
设备不支持将流行为配置为添加报文的外层VLAN Tag动作与流分类定义匹配指定隧道内的报文配置到同一QoS策略中。
以下流行为配置存在如下限制,仅filter permitaccounting可以和nest top-most vlan同时配置。
# 在流行为b1上配置如下动作:添加VLAN ID为123的外层VLAN Tag。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
1.2.6  packet-rate
packet-rate命令用来配置协议报文限速动作。
undo packet-rate命令用来恢复缺省情况。
packet-rate { value | attack-defense-threshold threshold-value } *
undo packet-rate
未配置协议报文限速动作。
流行为视图
value:协议报文速率,单位为包每秒(pps)。取值范围为1~10000。
attack-defense-threshold threshold-value:接口协议报文防攻击限速功能的监控门限。threshold-value为门限阈值,达到此阈值则启动接口协议报文防攻击限速功能,单位为包每秒(pps)。取值范围为1~10000。
通过QoS策略配置协议报文限速后,可实现对上送CPU的协议报文的防攻击功能。
设备缺省会对上送CPU的各协议报文进行限速(即COPP上存在系统预定义的QoS策略),以防止出现大量协议报文同时上送CPU、对CPU产生冲击的情况。一旦某协议报文上送CPU的速率达到或超过限速值,设备就会自动开启接口防攻击限速功能(即在接口上对接收的该协议报文进行限速),以降低该协议报文上送CPU的速率。
·     通过packet-rate value命令可以对上送CPU的各协议报文的限速值进行修改。
·     通过packet-rate attack-defense-threshold threshod-value命令配置接口协议报文防攻击限速功能的监控门限时:
¡     当配置的门限值小于等于上送CPU的协议报文限速值时,一旦协议报文上送CPU的实际速率达到门限值,设备就会自动开启接口防攻击限速功能。
¡     当配置的门限值大于上送CPU的协议报文限速值时,等效于不开启接口协议报文防攻击限速功能。
# 为流行为copp配置CPU报文限速动作。
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
# 为流行为copp1配置CPU报文限速值为1600pps,并配置接口协议报文防攻击限速功能的监控门限为1400pps。
[Sysname] traffic behavior copp1
[Sysname-behavior-copp1] packet-rate 1600 attack-defense-threshold 1400
·     display qos policy
·     display qos policy control-plane
·     display qos policy control-plane pre-defined
1.2.7  redirect
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来恢复缺省情况。
redirect { cpu | interface interface-type interface-number | next-hop { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] } [ fail-action { discard | forward } ] }
undo redirect { cpu | interface interface-type interface-number | next-hop }
未配置流量重定向动作。
流行为视图
cpu:重定向到CPU。
interface:重定向到指定的接口。
next-hop:重定向到指定的下一跳。在配置重定向到下一跳的动作时,指定的下一跳地址必须路由可达,如果同时配置了优选和备选地址,则至少需要有一个地址路由可达,否则将导致重定向失败。在配置生效后,重定向功能会定期查询路由表,检查下一跳地址是否有效;如果配置了Track项,则通过Track检测结果来判断下一跳地址是否有效。如果检测到优选和备选地址均失效,则重定向到下一跳的动作将不再生效。
ipv4-add1:优选的下一跳IPv4地址。如果重定向到优选的IPv4地址失败,则会重定向到备选IPv4地址。
ipv4-add2:备选的下一跳IPv4地址。
ipv6-add1:优选的下一跳IPv6地址。如果重定向到优选的IPv6地址失败,则会重定向到备选IPv6地址。
ipv6-add2:备选的下一跳IPv6地址。
track track-entry-number:指定下一跳关联的Track项,优选和备选的地址可以分别指定不同的Track项。track-entry-number取值范围为1~1024。通过指定Track项,可实现与监测特性(如NQA、BFD)的联动,详情请参见“可靠性配置指导”中的“Track”。
fail-action:当下一跳的地址不存在时,对报文采取的处理动作。未配置本参数时,若下一跳地址不存在,不进行重定向,正常转发此报文。
discard:表示丢弃此报文。
forward:表示不进行重定向,正常转发此报文。
引用了重定向流行为动作的QoS策略只能应用到入方向上。
在配置重定向到下一跳的动作时,指定的下一跳地址必须路由可达,如果同时配置了优选和备选地址,则至少需要有一个地址路由可达,否则将导致重定向失败。在配置生效后,重定向功能会定期查询路由表,检查下一跳地址是否有效。
# 为流行为配置流量重定向动作,重定向到接口GigabitEthernet1/0/1。
[Sysname-behavior-database] redirect interface gigabitethernet 1/0/1
# 为流行为配置流量重定向到下一跳的动作,优选IPv4地址为10.55.66.1,备选IPv4地址为10.55.88.1,为优选和备选地址分别关联Track项1和2,当下一跳的地址不存在时,丢弃报文。
[Sysname-behavior-database] redirect next-hop 10.55.66.1 track 1 10.55.88.1 track 2 fail-action discard
·     classifier behavior
·     qos policy
·     traffic behavior
remark customer-vlan-id命令用来重新标记报文的CVLAN。
undo remark customer-vlan-id命令用来恢复缺省情况。
未配置重新标记报文CVLAN的动作。
流行为视图
vlan-id:表示重新标记报文内层VLAN(CVLAN)的编号,取值范围为1~4094。
引用了重新标记报文内层VLAN Tag动作的QoS策略只能应用到入方向上。
引用了重新标记报文内层VLAN Tag动作的QoS策略请勿应用到聚合组成员端口、VSI和AC上。
设备不支持将流行为配置为重新标记报文的CVLAN与流分类定义匹配指定隧道内的报文配置到同一QoS策略中。
以下流行为配置存在如下限制,仅filter permitaccountingremark dot1premark service-vlan-id可以和remark customer-vlan-id同时配置。
# 在流行为b1上配置重新标记报文的CVLAN为VLAN 111。
[Sysname-behavior-b1] remark customer-vlan-id 111
1.2.9  remark dot1p
remark dot1p命令用来配置重新标记报文的802.1p优先级。
undo remark dot1p命令用来恢复缺省情况。
remark dot1p dot1p-value
undo remark dot1p
未配置重新标记报文802.1p优先级。
流行为视图
dot1p-value:802.1p优先级,取值范围为0~7。
设备支持在出和入方向上应用将引用了重新标记报文的802.1p优先级动作的QoS策略。需要注意的是,出方向上重新标记的802.1p优先级仅在出方向转发后的报文中生效。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence命令用来重新标记报文的丢弃优先级。
undo remark drop-precedence命令用来恢复缺省情况。
remark drop-precedence drop-precedence-value
未配置重新标记报文丢弃优先级的动作。
流行为视图
drop-precedence-value:丢弃优先级,取值范围为0~2。
仅QoS策略应用在入方向时,重新标记报文的丢弃优先级的动作才会生效。
# 重新标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.11  remark dscp
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来恢复缺省情况。
remark dscp dscp-value
undo remark dscp
未配置重新标记报文DSCP值的动作。
流行为视图
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
表1-5 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
交换机只支持对入方向的报文重标记报文的DSCP值。
# 重新标记报文的DSCP值为6。
remark ip-precedence命令用来重新标记报文的IP优先级。
undo remark ip-precedence命令用来恢复缺省情况。
remark ip-precedence ip-precedence-value
未配置重新标记报文IP优先级的动作。
流行为视图
ip-precedence-value:IP优先级,取值范围为0~7。
# 重新标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来恢复缺省情况。
remark [ green | red | yellow ] local-precedence local-precedence-value [ green | red | yellow ]
undo remark [ green | red | yellow ] local-precedence [ green | red | yellow ]
未配置重新标记报文本地优先级的动作。
流行为视图
green:对绿色报文进行重新标记。
red:对红色报文进行重新标记。
yellow:对黄色报文进行重新标记。
local-precedence-value:本地优先级,取值范围为0~15。
green:重标记报文为绿色报文。
red:重标记报文为红色报文。
yellow:重标记报文为黄色报文。
设备仅支持在入方向应用QoS策略配置重新标记报文的本地优先级。
工作机制
重新标记报文的本地优先级即将命中QoS策略中流分类规则的报文送入指定的优先级队列中,实现报文在本设备中的差分服务。通过display qos queue-statistics interface outbound命令可查看端口队列出方向的统计信息。
使用本命令标记报文的本地优先级时,还可以标记报文的颜色,通过16个不同的LP(Local Precedence,本地优先级)值和红、黄、绿三种颜色组合可以实现总计48种不同标记,大大增加了对报文的分类标记数量。可以先在接收报文的接口入方向上应用QoS策略,在该QoS策略中定义标记本地优先级和颜色的流行为,实现对入方向报文的分类。
使用本功能标记本地优先级LP和颜色之后,在报文转发的出方向上应用带颜色的LP到DSCP的优先级映射表,即执行qos map-table color命令并指定lp-tunnel-dscp参数,根据本地优先级和颜色来修改报文外层DSCP值的功能。
注意事项
目前,带颜色的LP到DSCP的优先级映射表仅对报文的出方向为VXLAN隧道和VXLAN-DCI隧道时生效。
当本地优先级取值为8~15时,必须指定重标记报文的颜色参数。
# 重新标记报文的本地优先级值为2。
remark service-vlan-id命令用来重新标记报文的SVLAN。
undo remark service-vlan-id命令用来恢复缺省情况。
未配置重新标记报文的SVLAN的动作。
流行为视图
vlan-id:表示重新标记报文外层VLAN(SVLAN)的编号,取值范围为1~4094。
引用了重新标记报文外层VLAN Tag动作的QoS策略只能应用到入方向上。
引用了重新标记报文外层VLAN Tag动作的QoS策略请勿应用到聚合组成员端口、VSI和AC上。
重新标记报文外层VLAN编号时,在该报文的出接口上必须确保报文重新标记前的外层VLAN编号可以通过并且VLAN Tag不会被删除。否则将导致外层VLAN编号修改失败。
设备不支持将流行为配置为重新标记报文的SVLAN与流分类定义匹配指定隧道内的报文配置到同一QoS策略中。
以下流行为配置存在如下限制,仅filter permitaccountingremark dot1premark customer-vlan-id可以和remark service-vlan-id同时配置。
# 在流行为b1上配置重新标记报文的SVLAN为VLAN 222。
[Sysname-behavior-b1] remark service-vlan-id 222
remark source-mac命令用来配置重新标记报文的源MAC地址。
undo remark source-mac命令用来恢复缺省情况。
remark source-mac mac-address
未配置重新标记报文的源MAC地址。
流行为视图
mac-address:源MAC地址,形式为H-H-H。
# 在流行为behavior1中配置重新标记报文的源MAC地址为600b-038a-a395。
[Sysname-behavior-behavior1] remark source-mac 600b-038a-a395
·     traffic behavior
traffic behavior命令用来创建一个流行为,并进入流行为视图。如果指定的流行为已经存在,则直接进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
不存在流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
# 定义一个名为behavior1的流行为。
·     display traffic behavior
1.3  定义和应用QoS策略的命令
classifier behavior命令用来为类指定流行为,即配置CB(Classifier-Behavior)对。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [  mode { dcbx | loose } | insert-before before-classifier-name ] *
没有为类指定流行为。
QoS策略视图
mode dcbx:表示该流分类与流行为的关联模式为DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议)模式。有关DCBX的介绍,请参见“二层技术-以太网交换配置指导”中的“LLDP”。
mode loose:表示该流分类与流行为的关联模式为宽松模式。仅基于控制平面应用QoS策略时,本模式才会生效。
insert-before before-classifier-name:表示将配置的类插入到QoS策略中已存在的指定类之前。before-classifier-name表示QoS策略中已存在的类名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示新配置的类与流行为配对将添加到QoS策略最后。
QoS策略中可以配置多个CB(Classifier-Behavior)对,应用QoS策略之后,报文按顺序逐个匹配QoS策略中CB对,遵循“一旦命中即停止匹配”的逻辑。如果匹配到某个CB对,则报文直接执行该CB对中指定流行为的所有转发动作,报文不再继续匹配其他CB对。
QoS策略下每个类只能与一个流行为关联。
如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
# 在QoS策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
# 在QoS策略user1中为类database指定流行为test,并将该类插入到策略中已存在的类class-a前。
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
·     qos policy
1.3.2  control-plane
control-plane命令用来进入控制平面视图。
slot slot-number:指定成员设备。slot-number表示设备在IRF中的成员编号。‌‌
# 进入指定slot上的控制平面视图。‌‌
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
control-plane management命令用来进入管理口控制平面视图。
# 进入管理口控制平面视图。
[Sysname] control-plane management
[Sysname-cp-management]
display qos policy命令用来显示QoS策略的配置信息。
display qos policy user-defined [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
user-defined:用户定义QoS策略。
ipv6-matching:显示IPv6 Matching类型的QoS策略。
accounting:显示统计类型的QoS策略。
mirroring:显示镜像类型的QoS策略。
remarking:显示重标记类型的QoS策略。
tcp-erspan:显示TCP ERSPAN类型的QoS策略。
policy-name:QoS策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:QoS策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定成员设备的QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的QoS策略的配置信息。‌‌
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则显示用户定义的通用类型QoS策略的配置信息。
# 显示用户定义QoS策略的配置信息。
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
     Behavior: 2
      Accounting enable: Packet
      Filter enable: Permit
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
# 显示用户定义的统计类型QoS策略的配置信息。
<Sysname> display qos policy user-defined accounting
  Accounting policy: 1 (ID 100)
     Behavior: 1
# 显示用户定义的镜像类型QoS策略的配置信息。
<Sysname> display qos policy user-defined mirroring
  Mirroring policy: 1 (ID 100)
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# 显示用户定义的重标记类型QoS策略的配置信息。
<Sysname> display qos policy user-defined remarking
  Marking policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
# 显示用户定义的TCP ERSPAN类型QoS策略的配置信息。
<Sysname> display qos policy user-defined tcp-erspan
  TCP ERSPAN policy: 1 (ID 100)
     Behavior: 1
      Mirroring:
        Mirror to the interface: GigabitEthernet1/0/1
表1-6 display qos policy命令显示信息描述表
用户自定义QoS策略的信息
Policy
用户定义的QoS策略名
IPv6 Matching policy
用户定义的IPv6类型的QoS策略名
Accounting policy
用户定义的统计类型的QoS策略名
Mirroring policy
用户定义的镜像类型的QoS策略名
Marking policy
用户定义的重标记类型的QoS策略名
TCP ERSPAN policy
用户定义的TCP ERSPAN类型的QoS策略名
其它显示信息解释请参见display traffic classifierdisplay traffic behavior
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
slot slot-number:显示指定成员设备的控制平面应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。‌‌
# 显示应用到slot 1控制平面的QoS策略信息。‌‌
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Yellow packets: 0 (Packets) 0 (Bytes)
        Red packets   : 0 (Packets) 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets), 0 (Bytes)
        0 (pps), 0 (bps)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-7 display qos policy control-plane命令显示信息描述表
Direction
QoS策略应用的方向
display qos policy control-plane management命令用于显示管理口控制平面应用的QoS策略信息。
# 显示对进入管理口控制平面的报文应用的QoS策略信息。
<Sysname> display qos policy control-plane management
Control plane management
  Direction: Inbound
  Policy: a
   Classifier: default-class
     Matched : 0 (Packets) 0 (Bytes)
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: a
     Matched : 3 (Packets) 180 (Bytes)
     Operator: OR
     Rule(s) :
      If-match control-plane protocol arp
      If-match control-plane protocol rip
      If-match control-plane protocol-group critical
      If-match acl 3001
      If-match control-plane protocol bgp
      If-match control-plane protocol bgp4+
      If-match control-plane protocol ftp
      If-match control-plane protocol http https icmp icmp6 ripng snmp
     Behavior: a
        CIR 128 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 3 (Packets) 180 (Bytes)
表1-8 display qos policy control-plane management命令显示信息描述表
Direction
QoS策略应用的方向
display qos policy control-plane management pre-defined命令用来显示系统预定义的管理口控制平面应用QoS策略的信息。
# 显示系统预定义的管理口控制平面应用QoS策略的信息。
<Sysname> display qos policy control-plane management pre-defined
Pre-defined control plane policy management
  Protocol          Priority   Bandwidth                 Group
  Default           N/A        100000 (bps)             N/A
  ARP               N/A        128 (bps)                normal
  BGP               N/A        256 (bps)                critical
  BGPv6             N/A        256 (bps)                critical
  HTTP              N/A        512 (bps)                management
  HTTPS             N/A        512 (bps)                management
  ICMP              N/A        128 (bps)                monitor
  ICMPv6            N/A        128 (bps)                monitor
  OSPF Multicast    N/A        256 (bps)                critical
  OSPF Unicast      N/A        256 (bps)                critical
  OSPFv3 Multicast  N/A        256 (bps)                critical
  OSFPv3 Unicast    N/A        256 (bps)                critical
  RIP               N/A        1024 (bps)               critical
  RIPng             N/A        256 (bps)                critical
  SNMP              N/A        512 (bps)                management
  SSH               N/A        512 (bps)                management
  TELNET            N/A        512 (bps)                management
  FTP               N/A        512 (bps)                management
  TFTP              N/A        512 (bps)                management
表1-9 display qos policy control-plane management pre-defined命令显示信息描述表
预定义管理口控制平面策略内容
Protocol
系统预定义协议报文类型
Priority
优先级
Bandwidth
带宽
Group
协议组
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
任意视图‌
slot slot-number:显示指定成员设备的系统预定义的控制平面策略信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示所有成员设备的系统预定义的控制平面应用QoS策略的信息。‌‌
# 显示指定slot上的系统预定义的控制平面应用QoS策略的信息。‌‌
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
  Default           N/A        1000 (pps)         N/A
  IS-IS             18         1000 (pps)         critical
  VRRP              19         1000 (pps)         important
  OSPF Multicast    18         1000 (pps)         critical
  OSPF Unicast      18         1000 (pps)         critical
  IGMP              11         500 (pps)          important
  OSPFv3 Unicast    18         1000 (pps)         critical
  OSPFv3 Multicast  18         1000 (pps)         critical
  VRRPv6            19         1000 (pps)         important
  ARP               2          1000 (pps)         normal
  DHCP Snooping     10         300 (pps)          redirect
  DHCP              10         300 (pps)          normal
  802.1x            3          500 (pps)          important
  STP               17         300 (pps)          critical
  LACP              22         300 (pps)          critical
  MVRP              15         300 (pps)          critical
  BGP               16         1000 (pps)         critical
  ICMP              3          500 (pps)          monitor
  TTL Expires       5          300 (pps)          monitor
  IPOPTION          5          300 (pps)          normal
  BGPv6             16         1000 (pps)         critical
  Hop Limit Expires 5          300 (pps)          monitor
  IPOPTIONv6        5          300 (pps)          normal
  LLDP              14         300 (pps)          important
  DLDP              16         300 (pps)          critical
  TELNET            1          800 (pps)          management
  SSH               1          800 (pps)          management
  TACACS            1          800 (pps)          management
  RADIUS            1          800 (pps)          management
  HTTP              3          500 (pps)          management
  HTTPS             3          500 (pps)          management
  SNMP              4          800 (pps)          management
  ARP Snooping      2          1000 (pps)         redirect
  ICMPv6            3          300 (pps)          monitor
  DHCPv6            10         300 (pps)          normal
  BFD               21         1000 (pps)         critical
表1-10 display qos policy control-plane pre-defined命令显示信息描述表
预定义控制平面策略内容
Protocol
系统预定义协议报文类型
其他协议
Priority
优先级
Bandwidth
带宽
Group
协议所属的协议组
其它显示信息解释请参见if-matchdisplay traffic behavior
display qos policy control-plane rule-statistics命令用来显示应用在控制平面的QoS策略的统计信息。
display qos policy control-plane slot slot-number rule-statistics
slot slot-number:显示指定成员设备的控制平面应用QoS策略的统计信息,slot-number表示设备在IRF中的成员编号。‌‌
使用本命令可以显示QoS策略里流分类中多个匹配规则匹配到的报文统计数据。请在QoS策略里的流行为中执行accounting命令开启流量统计功能,保证统计的报文匹配数据信息正常显示。
# 显示应用在slot 0的控制平面QoS策略的统计信息。‌‌
<Sysname> display qos policy control-plane slot 0 rule-statistics
Control plane slot 0
  Direction: Inbound, Policy: p1, Status: Succeed
   Classifier: c1, Operator: AND, Behavior: b1, State: Succeed
   Accounting: Enabled, Car: Enabled
    if-match source-mac 0001-0001-0001
    if-match local-precedence 1
    if-match acl 3000
    rule 0 permit ip source 1.1.1.1 0
    Passed packets                     500, Passed pps                         5
    Dropped packets                    500, Dropped pps                        5
    Passed bytes                      5000, Passed bps                        50
    Dropped bytes                     5000, Dropped bps                       50
    if-match acl 3000
    rule 5 permit ip destination 2.2.2.2 0
表1-11 display qos policy control-plane rule-statistics命令显示信息描述表
Control plane slot
指定的单板号控制平面
Direction
QoS策略应用的方向
Policy
QoS策略名称
Status
QoS策略应用状态,取值包括:
·     Succeed:QoS策略应用成功
·     Failed:QoS策略应用失败,失败状态下无法正常显示统计信息
Classifier
QoS策略的流分类名称
Operator
流分类中各匹配规则之间的逻辑关系,取值包括:
·     AND:逻辑“与”的关系,报文要同时满足if-match所有匹配的分类规则,才作为统计为匹配的报文流量。需要注意的是如果使用的是if-match acl,ACL中的不同rule规则之间仍为“或”的关系
·     OR:逻辑“或”的关系,报文仅需要满足if-match的规则之一,就可以作为统计为匹配的报文流量
Behavior
QoS策略的流行为名称
Classifier和Behavior配置冲突和异常状态:
·     Succeed:Classifier和Behavior的配置正常
·     Failed:Classifier或Behavior的配置中存在异常,例如流分类中存在不可同时生效的匹配条件,流行为中的动作之间存在冲突,状态下无法正常显示统计信息
Accounting
流行为中accounting流量统计行为的配置状态:
·     Enabled:开启了流量统计行为
·     Disabled:未开启流量统计行为,流量数据无法统计
Car
流行为中流量监管的配置状态:
·     Enabled:配置了流量监管
·     Disabled:未配置流量监管,流量数据无法统计
if-match xx,
表示流分类中if-match命令定义的匹配分类规则
rule yy
ACL规则的详细信息,其中yy表示流分类中的ACL规则编号
Passed packets
统计到通过的报文数量,只有在流行为中配置accounting命令指定packet参数才会显示报文数统计
Passed bytes
统计到通过的字节数量,只有在流行为中配置accounting命令指定byte参数才会显示字节数统计
Passed pps
统计到每秒通过的报文数量,只有在流行为中配置accounting命令指定packet参数才会显示报文数统计
Passed bps
统计到每秒通过的字节数量,只有在流行为中配置accounting命令指定byte参数才会显示字节数统计
Dropped packets
统计到丢弃的报文数量,只有在流行为中配置accounting命令指定packet参数才会显示报文数统计
Dropped bytes
统计到丢弃的字节数量,只有在流行为中配置accounting命令指定byte参数才会显示字节数统计
Dropped pps
统计到每秒丢弃的报文数量,只有在流行为中配置accounting命令指定packet参数才会显示报文数统计
Dropped bps
统计到每秒丢弃的字节数量,只有在流行为中配置accounting命令指定byte参数才会显示字节数统计
·     qos apply policy(control plane view)
·     accounting
display qos policy global命令用来显示基于全局应用QoS策略的配置信息和运行情况。
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy global [ slot slot-number ] [ inbound | outbound ]
ipv6-matching:显示IPv6 Matching类型QoS策略的配置信息和运行情况。
accounting:显示统计类型QoS策略的配置信息和运行情况。
mirroring:显示镜像类型QoS策略的配置信息和运行情况。
remarking:显示重标记类型QoS策略的配置信息和运行情况。
tcp-erspan:显示TCP ERSPAN类型QoS策略的配置信息和运行情况。
inbound:显示入方向QoS策略的配置信息和运行情况。
outbound:显示出方向QoS策略的配置信息和运行情况。
slot slot-number:显示指定成员设备的基于全局应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于全局应用QoS策略的信息。‌‌
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则显示通用类型QoS策略的配置信息和运行情况。
如果未指定显示方向,则同时显示出入两个方向QoS策略的配置信息和运行情况。
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# 显示基于全局应用统计类型QoS策略的信息。
<Sysname> display qos accounting policy global
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
# 显示基于全局应用镜像类型QoS策略的信息。
<Sysname> display qos mirroring policy global
  Direction: Inbound
  Mirroring policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# 显示基于全局应用重标记类型QoS策略的信息。
<Sysname> display qos remarking policy global
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# 显示基于全局应用IPv6 Matching类型QoS策略的信息。
<Sysname> display qos ipv6-matching policy global
  Direction: Inbound
  IPv6 Matching policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl ipv6 3000
     Behavior: 1
      Marking:
        Remark dscp 3
# 显示基于全局应用TCP ERSPAN类型QoS策略的信息。
<Sysname> display qos tcp-erspan policy global
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: 1
      Mirroring:
表1-12 display qos policy global命令显示信息描述表
Direction
QoS策略应用的方向
Policy
用户定义的QoS策略名
用户定义的IPv6类型的QoS策略名
Accounting policy
用户定义的统计类型的QoS策略名
Mirroring policy
用户定义的镜像类型的QoS策略名
Marking policy
用户定义的重标记类型的QoS策略名
TCP ERSPAN policy
display qos policy global rule-statistics命令用来显示应用在全局的QoS策略的统计信息。
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy global [ slot slot-number ] [ inbound | outbound ] rule-statistics
inbound:显示入方向QoS策略的统计信息。
outbound:显示出方向QoS策略的统计信息。
slot slot-number:显示指定成员设备的基于全局应用QoS策略的统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于全局应用QoS策略的统计信息。‌‌
如果未指定显示方向,则同时显示出入两个方向QoS策略的统计信息。
# 显示应用在slot 0全局入方向的QoS策略的统计信息。‌‌
<Sysname> display qos policy global slot 0 inbound rule-statistics
Slot 0
    if-match acl 3000
    if-match acl 3000
表1-13 display qos policy global rule-statistics命令显示信息描述表
Direction
QoS策略应用的方向
Policy
QoS策略名称
Status
QoS策略应用状态,取值包括:
·     Succeed:QoS策略应用成功
Classifier
QoS策略的流分类名称
Operator
Behavior
QoS策略的流行为名称
Accounting
·     Enabled:开启了流量统计行为
Car
流行为中流量监管的配置状态:
·     Enabled:配置了流量监管
if-match xx,
rule yy
Passed packets
Passed bytes
Passed pps
Passed bps
Dropped packets
Dropped bytes
Dropped pps
Dropped bps
·     qos apply policy global
·     accounting
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy interface [ interface-type interface-number ] [ slot slot-number ]  [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的配置信息和运行情况。
slot slot-number:显示指定成员设备指定逻辑接口的QoS策略的配置信息和运行情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备逻辑接口QoS策略的配置信息和运行情况。‌‌
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则显示通用类型QoS策略的配置信息。
# 显示对接口GigabitEthernet1/0/1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     5-minute statistics:
      Forwarded: 0/0 (pps/bps)
      Dropped  : 0/0 (pps/bps)
     Operator: AND
     Rule(s) :
     Behavior: 2
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# 显示对接口GigabitEthernet1/0/1接收到的报文应用统计类型QoS策略的配置信息和运行情况。
<Sysname> display qos accounting policy interface gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Accounting Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Accounting enable:
        0 (pps), 0 (bps)
# 显示对接口GigabitEthernet1/0/1接收到的报文应用重标记类型QoS策略的配置信息和运行情况。
<Sysname> display qos remarking policy interface gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# 显示对接口GigabitEthernet1/0/1接收到的报文应用镜像类型QoS策略的配置信息和运行情况。
<Sysname> display qos mirroring policy interface gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Mirroring policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# 显示对接口GigabitEthernet1/0/1接收到的报文应用TCP ERSPAN类型QoS策略的配置信息和运行情况。
<Sysname> display qos tcp-erspan policy interface gigabitethernet 1/0/1 inbound
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the interface: GigabitEthernet1/0/2
# 显示所有接口上QoS策略的配置信息和运行情况。
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Interface: GigabitEthernet1/0/3
  Direction: Inbound
  Policy: b
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        Green action  : pass
        Green packets : 0(Packets)
Interface: GigabitEthernet1/0/4
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: GigabitEthernet1/0/5
        Green action  : pass
表1-14 display qos policy interface命令显示信息描述表
Direction
QoS策略应用的方向
Policy
用户定义的QoS策略名
IPv6类型的QoS策略名
Accounting policy
统计类型的QoS策略名
Mirorring policy
镜像类型的QoS策略名
Marking policy
重标记类型的QoS策略名
TCP ERSPAN policy
Matched
符合分类规则的数据包数目
5-minute statistics
最近5分钟的流速统计信息
Forwarded
符合分类规则的成功转发报文在统计周期内的平均速率
Dropped
符合分类规则的丢弃报文在统计周期内的平均速率
Green packets
(仅QoS策略配置了accounting流量统计动作才会有统计计数)绿色报文的流量统计
Yellow packets
(仅QoS策略配置了accounting流量统计动作才会有统计计数)黄色报文的流量统计
Red packets
(仅QoS策略配置了accounting流量统计动作才会有统计计数)红色报文的流量统计
display qos policy interface rule-statistics命令用来显示应用在接口上的QoS策略的统计信息。
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ] rule-statistics
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的统计信息。
slot slot-number:显示指定成员设备指定逻辑接口的QoS策略的统计信息。slot-number表示设备在IRF中的成员编号。仅对于逻辑接口才可以指定本参数。如果未指定本参数,则显示主设备逻辑接口QoS策略的统计信息。‌‌
# 显示应用在slot 1所有接口入方向的QoS策略的统计信息。‌‌
<Sysname> display qos policy global slot 1 inbound rule-statistics
Slot 1
    if-match acl 3000
    if-match acl 3000
表1-15 display qos policy interface rule-statistics命令显示信息描述表
接口编号和接口类型
Direction
QoS策略应用的方向
Policy
QoS策略名称
Status
QoS策略应用状态,取值包括:
·     Succeed:QoS策略应用成功
Classifier
QoS策略的流分类名称
Operator
Behavior
QoS策略的流行为名称
Accounting
·     Enabled:开启了流量统计行为
Car
流行为中流量监管的配置状态:
·     Enabled:配置了流量监管
if-match xx,
rule yy
Passed packets
Passed bytes
Passed pps
Passed bps
Dropped packets
Dropped bytes
Dropped pps
Dropped bps
·     qos apply policy (Interface view)
·     accounting
display qos policy l2vpn-ac命令用来显示L2VPN AC承载的以太网服务实例上QoS策略的配置信息和运行情况。
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound ]
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口下以太网服务实例上QoS策略的配置信息和运行情况。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将显示接口下所有以太网服务实例上QoS策略的配置信息和运行情况。
slot slot-number:显示指定成员设备指定二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。‌‌
inbound:显示入方向QoS策略的配置信息和运行情况。指定与未指定本关键字时,命令的执行结果相同。
# 显示对接口GigabitEthernet1/0/1下以太网服务实例1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy l2vpn-ac interface gigabitethernet 1/0/1 service-instance 1 inbound
Interface: GigabitEthernet1/0/1    Service instance ID: 1
  Direction: Inbound
  Policy: p
   Classifier: c
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        CIR 88 (kbps), CBS 5632 (Bytes), EBS 0 (Bytes)
        Green action  : pass
表1-16 display qos policy l2vpn-ac命令显示信息描述表
Service instance ID
以太网服务实例ID
Direction
QoS策略应用的方向
Green action
对绿色报文的动作
Yellow action
对黄色报文的动作
Red action
对红色报文的动作
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
display qos policy l2vpn-ac rule-statistics 命令用来显示应用在L2VPN AC以太网服务实例上QoS策略的统计信息。
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound | outbound ] rule-statistics
ipv6-matching:指定IPv6 Matching类型的QoS策略。
accounting:指定统计类型的QoS策略。
mirroring:指定镜像类型的QoS策略。
remarking:指定重标记类型的QoS策略。
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口下以太网服务实例上QoS策略的统计信息。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将显示接口下所有以太网服务实例上QoS策略的统计信息。
slot slot-number:显示指定成员设备指定二层聚合接口下以太网服务实例的QoS策略的统计信息。slot-number表示设备在IRF中的成员编号。仅对于二层聚合口才可以指定本参数。如果未指定本参数,将显示所有成员设备上二层聚合接口下以太网服务实例的QoS策略的统计信息。‌‌
# 显示应用在slot 1接口GigabitEthernet1/0/1下以太网服务实例1应用QoS策略的统计信息。‌‌
<Sysname> display qos policy l2vpn-ac interface gigabitethernet 1/0/1 slot 1 inbound rule-statistics
Slot 1
    if-match acl 3000
    if-match acl 3000
表1-17 display qos policy l2vpn-ac rule-statistics命令显示信息描述表
接口编号和接口类型
Service instance ID
以太网服务实例ID
Direction
QoS策略应用的方向
Policy
QoS策略名称
Status
QoS策略应用状态,取值包括:
·     Succeed:QoS策略应用成功
Classifier
QoS策略的流分类名称
Operator
Behavior
QoS策略的流行为名称
Accounting
·     Enabled:开启了流量统计行为
Car
流行为中流量监管的配置状态:
·     Enabled:配置了流量监管
if-match xx,
rule yy
Passed packets
Passed bytes
Passed pps
Passed bps
Dropped packets
Dropped bytes
Dropped pps
Dropped bps
·     qos apply policy (Ethernet service instance view)
·     accounting
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的配置信息和运行情况。
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称,为1~31个字符的字符串,区分大小写。
vlan vlan-id:显示指定VLAN上应用QoS策略的信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
slot slot-number:显示指定成员设备上基于VLAN应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于VLAN应用QoS策略的信息。‌‌
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-18 display qos vlan-policy命令显示信息描述表
Direction
QoS策略应用的方向
display qos vlan-policy rule-statistics命令用来显示应用在指定VLAN上QoS策略的统计信息。
display qos vlan-policy vlan [ vlan-id ]  [ slot slot-number ] [ inbound | outbound ] rule-statistics
vlan vlan-id:显示指定VLAN上应用QoS策略的统计信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
slot slot-number:显示指定成员设备上基于VLAN应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于VLAN应用QoS策略的统计信息。‌‌
# 显示应用在Slot 1,VLAN 10入方向上QoS策略的统计信息。‌‌
<Sysname> display qos vlan-policy vlan 10 slot 1 inbound rule-statistics
Slot 0
Vlan 10
    if-match acl 3000
    if-match acl 3000
表1-19 display qos policy control-plane rule-statistics命令显示信息描述表
VLAN
VLAN ID值
Direction
QoS策略应用的方向
Policy
QoS策略名称
Status
QoS策略应用状态,取值包括:
·     Succeed:QoS策略应用成功
Classifier
QoS策略的流分类名称
Operator
Behavior
QoS策略的流行为名称
Accounting
·     Enabled:开启了流量统计行为
Car
流行为中流量监管的配置状态:
·     Enabled:配置了流量监管
if-match xx,
rule yy
Passed packets
Passed bytes
Passed pps
Passed bps
Dropped packets
Dropped bytes
Dropped pps
Dropped bps
·     qos vlan-policy
·     accounting
qos apply policy命令用来在控制平面、管理口控制平面、接口或以太网服务实例上应用QoS策略。
undo qos apply policy命令用来取消控制平面、管理口控制平面、接口或以太网服务实例上应用的QoS策略。
qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name { inbound | outbound } [ longest-match ]
undo qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name { inbound | outbound }
未应用QoS策略。
控制平面视图/管理口控制平面视图
以太网服务实例视图
ipv6-matching:指定IPv6 Matching类型的QoS策略。仅支持基于接口和以太网服务实例应用IPv6类型的QoS策略。
accounting:指定统计类型的QoS策略。仅支持基于接口和以太网服务实例应用统计类型的QoS策略。
mirroring:指定镜像类型的QoS策略。仅支持基于接口和以太网服务实例应用镜像类型的QoS策略。
remarking:指定重标记类型的QoS策略。仅支持基于接口和以太网服务实例应用重标记类型的QoS策略。
tcp-erspan:指定TCP ERSPAN类型的QoS策略。仅支持基于接口应用TCP ERSPAN类型的QoS策略。
policy-name:策略名,为1~31个字符的字符串,区分大小写。
inbound:入方向应用QoS策略。
outbound:出方向应用QoS策略。设备不支持在以太网服务实例和VSI虚接口出方向应用QoS策略。
longest-match:QoS策略中的流分类引用ACL规则指定源或目的地址时,源或目的地址的掩码最长的流分类优先匹配流量并优先执行该流分类对应的流行为。
三层聚合子接口和三层以太网子接口不支持应用QoS策略。
未指定longest-match参数应用QoS策略时,如果QoS策略中存在多个流分类和流分类绑定的流行为(即Classifier-Behavior对),则系统按照Classifier-Behavior对的配置顺序依次匹配流量,流分类匹配到流量后即执行该流分类对应的流行为,不再进行下一步匹配。
指定longest-match参数应用QoS策略时,如果流分类引用的ACL规则指定源或目的地址时,源或目的地址的掩码最长的流分类优先匹配流量并优先执行该流分类对应的流行为。例如,下列QoS策略A中按顺序配置了3对Classifier-Behavior,其中,Classifier 1中指定的ACL规则3001中未指定源和目的地址,Classifier 2中指定的ACL规则3002中目的地址为10.10.10.0,掩码长度为24,Classifier 3中指定的ACL规则3003中目的地址为10.10.10.10,掩码长度为32,则系统进行流量匹配时,掩码长度最长的Classifier 3的匹配优先顺序最高,优先进行报文匹配,再匹配掩码长度其次的Classifier 2,最后匹配Classifier 1。
QoS策略A:
Classifier 1 (if-match acl 3001) Behavior 1
Classifier 2 (if-match acl 3002) Behavior 2
Classifier 3 (if-match acl 3003) Behavior 3
如果多个流分类引用的ACL规则中同时指定源和目的地址,则先按照目的地址掩码长度排序,目的地址排序完成后,剩下的Classifier-Behavior对再按照源地址掩码长度继续排序。
# 将QoS策略TEST1应用到接口GigabitEthernet1/0/1的出方向上。
[Sysname-GigabitEthernet1/0/1] qos apply policy TEST1 outbound
# 将统计类型QoS策略TEST2应用到接口GigabitEthernet1/0/1的出方向上。
[Sysname-GigabitEthernet1/0/1] qos apply accounting policy TEST2 outbound
# 将镜像类型QoS策略TEST3应用到接口GigabitEthernet1/0/1的出方向上。
[Sysname-GigabitEthernet1/0/1] qos apply mirroring policy TEST3 outbound
# 将重标记类型QoS策略TEST4应用到接口GigabitEthernet1/0/1的出方向上。
[Sysname-GigabitEthernet1/0/1] qos apply remarking policy TEST4 outbound
# 将TCP ERSPAN类型QoS策略TEST4应用到接口GigabitEthernet1/0/1的出方向上。
[Sysname-GigabitEthernet1/0/1] qos apply tcp-erspan policy TEST4 outbound
# 对进入1号槽控制平面的报文应用QoS策略TEST5。
[Sysname] control-plane slot 1
[Sysname-cp-slot1] qos apply policy TEST5 inbound
# 对进入以太网服务实例的报文应用通用类型QoS策略TEST9。
[Sysname-GigabitEthernet1/0/1] service-instance 200
[Sysname-GigabitEthernet1/0/1-srv200] qos apply policy TEST9 inbound
# 将IPv6类型QoS策略TEST13应用到接口GigabitEthernet1/0/1的出方向上。
[Sysname-GigabitEthernet1/0/1] qos apply ipv6-matching policy TEST13 outbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
qos apply [ ipv6-matching |  accounting | mirroring | remarking | tcp-erspan ] policy policy-name global { inbound | outbound } [ longest-match ]
undo qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name global { inbound | outbound }
未在全局应用QoS策略。
inbound:入方向应用QoS策略。
全局应用的QoS策略对全部流量生效。
基于全局应用策略时,在相同方向最多可以应用六个不同类型的策略,包括一个通用类型的QoS策略、一个IPv6 Matching类型的QoS策略、一个统计类型的QoS策略、一个镜像类型的QoS策略、一个重标记类型的QoS策略和一个TCP ERSPAN类型的QoS策略。
QoS策略A:
# 将QoS策略user1应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
# 将镜像类型QoS策略user2应用到全局的入方向上。
[Sysname] qos apply mirroring policy user2 global inbound
1.3.20  qos policy
qos policy命令用来创建一个QoS策略,并进入QoS策略视图。如果指定的QoS策略已经存在,则直接进入QoS策略视图。
undo qos policy命令用来删除一个QoS策略。
qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name
undo qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name
不存在QoS策略。
创建QoS策略时:
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则表示通用类型的QoS策略。
·     不同类型的QoS策略不能使用相同的名称。
·     请避免使用“ipv6-matching”、“accounting”、“mirroring”、“remarking”、“tcp-erspan”做策略名称,也不要使用这些词的前几个字母做策略名称,例如“ipv6”、“acc”、“mirror”、“remark”、“tcp”等。如果这样做,会导致执行display qos policy user-defined policy-name命令时无相关信息显示,因为系统会认为输入的策略名是命令行关键字而非policy-name
如下各类型QoS策略的使用方法相同:
·     通用类型的QoS策略可以应用在所有支持的位置,包括接口、VLAN、全局等,能配置所有的流行为动作。
·     IPv6 Matching类型的QoS策略仅支持应用在接口、以太网服务实例或全局,常用于配置引用IPv6 ACL的流分类。
·     统计类型QoS策略仅支持应用在接口、以太网服务实例或全局,常用于配置流量统计动作。
·     镜像类型QoS策略仅支持应用在接口、以太网服务实例或全局,常用于配置镜像动作。
·     重标记类型QoS策略仅支持应用在接口、以太网服务实例或全局,常用于配置重标记动作。
·     TCP ERSPAN类型QoS策略仅支持应用在接口或全局,常用于配置erspan镜像动作。
TCP ERSPAN类型的QoS策略中流分类用来匹配TCP报文的标识(包括ACK、FIN、PSH、RST、SYN和URG等),QoS策略中的流量转发动作是流镜像ERSPAN,关于流镜像ERSPAN的详细介绍,请参见“网络管理和监控配置指导”中的“镜像”。
如果需要同时对用户业务流进行流镜像分析和流限速,则可以使用通用类型的QoS策略对上线用户进行带宽限速,使用TCP ERSPAN类型的QoS策略将用户业务流进行流镜像分析,两类QoS策略使用的硬件资源互不影响。
如果QoS策略已经被应用,则不允许删除,需要先在应用的位置上取消对QoS策略的应用,然后再使用undo qos policy命令删除。
# 定义一个名为user1的QoS策略。
# 定义一个名为user2的统计类型的QoS策略。
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# 定义一个名为user3的重标记类型的QoS策略。
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
# 定义一个名为user4的镜像类型的QoS策略。
[Sysname] qos mirroring policy user4
[Sysname-qospolicy-user4]
# 定义一个名为user6的IPv6 Matching类型的QoS策略。
[Sysname] qos ipv6-matching policy user6
[Sysname-qospolicy-user6]
·     qos apply policy
·     qos vlan-policy
qos vlan-policy命令用来在VLAN上应用QoS策略。
undo qos vlan-policy命令用来取消VLAN上应用的QoS策略。
qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound } [ longest-match ]
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
未在VLAN上应用QoS策略。
policy-name:策略名称,为1~31个字符的字符串,区分大小写。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:入方向应用QoS策略。
在同一个VLAN的同一个方向上,不能同时应用扩展类型和普通类型策略,二者取其一。扩展型策略可以使用更多的硬件资源,但支持的参数类型较少。
QoS策略A:
# 在VLAN 200、300、400、500的入方向上应用策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
slot slot-number:清除指定成员设备的基于控制平面应用QoS策略的统计信息,slot-number表示设备在IRF中的成员编号。‌‌
# 清除应用到指定slot上的控制平面的QoS策略统计信息。‌‌
<Sysname> reset qos policy control-plane slot 1
reset qos policy control-plane management命令用来清除管理口控制平面QoS策略的统计信息。
# 清除管理口控制平面QoS策略的统计信息。
<Sysname> reset qos policy control-plane management
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
reset qos [ ipv6-matching | accounting | mirroring | remarking| tcp-erspan ] policy global [ inbound | outbound ]
inbound:清除入方向QoS策略的统计信息。
outbound:清除出方向QoS策略的统计信息。
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则清除通用类型QoS策略的统计信息。
如果未指定清除方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除全局入方向应用的通用类型QoS策略的统计信息。
<Sysname> reset qos policy global inbound
# 清除全局入方向应用的镜像类型QoS策略的统计信息。
<Sysname> reset qos mirroring policy global inbound
reset qos policy l2vpn-ac命令用来清除L2VPN AC承载的以太网服务实例上QoS策略的统计信息。
reset qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ] [ inbound ]
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将清除所有接口下以太网服务实例上QoS策略的统计信息。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将清除接口下所有以太网服务实例上QoS策略的统计信息。
# 清除接口GigabitEthernet1/0/1下以太网服务实例1入方向QoS策略的统计信息。
<Sysname> reset qos policy l2vpn-ac interface gigabitethernet 1/0/1 service-instance 1 inbound
# 清除接口GigabitEthernet1/0/1下以太网服务实例1收到的IPv6 Matching类型QoS策略的统计信息。
<Sysname> reset qos ipv6-matching policy l2vpn-ac interface gigabitethernet 1/0/1 service-instance 1 inbound
·     display qos policy l2vpn-ac
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
vlan vlan-id:指定VLAN。vlan-id为指定VLAN的ID号,取值范围为1~4094。
如果未指定方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射
2.1  优先级映射表配置命令
display qos map-table命令用来显示优先级映射表的配置情况。
display qos map-table  [ dot1p-lp | dscp-dscp | dscp-lp | exp-lp | lp-exp ]
表2-1 优先级映射表
优先级映射
dot1p-lp
802.1p优先级到本地优先级映射表
dscp-lp
DSCP到本地优先级映射表
dscp-dscp
DSCP到DSCP映射表
exp-lp
EXP到本地优先级映射表
lp-exp
本地优先级到EXP映射表
如果未指定表的类型,将显示所有映射表的配置情况。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名称
TYPE
映射表的类型
IMPORT
映射表的输入值
EXPORT
映射表的输出值
display qos map-table color命令用来显示带颜色优先级映射表配置情况。
display qos map-table color [ green | yellow | red ] [ lp-tunnel-dscp ]
green:绿色报文。
yellow:黄色报文。
red:红色报文。
表2-3 优先级映射表
优先级映射
lp-tunnel-dscp
本地优先级到隧道封装的外层DSCP映射表,这种类型的优先级映射表项主要应用在报文从VXLAN隧道或VXLAN-DCI隧道转发的场景,根据报文的本地优先级和颜色组合对应地封装报文外层DSCP信息
本映射表项需要配合qos vxlan-dci-tunnel outer dscpvxlan-tunnel outer dscp命令使用,关于命令的详细介绍,请参见“VXLAN命令参考”中的“VXLAN”。使能上述命令之后按照本地优先级到隧道封装的外层DSCP映射表来控制报文的封装时,会对所有VXLAN报文转发产生影响
经过流量监管处理的报文被分成了三种颜色(绿色、黄色、红色),为了对不同颜色报文进行优先级映射,设备提供了多张带颜色优先级映射表,分别对应相应颜色的优先级映射关系。流量监管对报文处理的相关内容请参见流量监管章节内容。
如果未指定颜色,则同时显示三种颜色的优先级映射表的配置情况。
如果未指定方向,则同时显示出和入两个方向的优先级映射表的配置情况。
如果未指定优先级映射表的类型,则同时显示所有优先级映射表的配置情况。
# 显示绿色报文的本地优先级到隧道封装的外层DSCP映射表的配置信息。
<Sysname> display qos map-table color green lp-tunnel-dscp
MAP-TABLE NAME: lp-tunnel-dscp   TYPE: pre-define   COLOR: green
IMPORT  :  EXPORT
   0    :    3
   1    :    7
   2    :   11
   3    :   15
   4    :   19
   5    :   23
   6    :   27
   7    :   31
   8    :   35
   9    :   39
  10    :   43
  11    :   47
  12    :   51
  13    :   55
  14    :   59
  15    :   63
表2-4 display qos map-table color命令显示信息描述表
MAP-TABLE NAME
映射表的名称
TYPE
映射表的类型
COLOR
映射表的颜色
DIRECTION
映射表的方向
IMPORT
映射表的输入值
EXPORT
映射表的输出值
·     vxlan-dci-tunnel outer dscp(VXLAN命令参考/VXLAN)
·     vxlan-tunnel outer dscp(VXLAN命令参考/VXLAN)
2.1.3  import
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 B。
优先级映射表视图
import-value-list:输入值列表。
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
# 配置802.1p优先级到本地优先级映射表的映射关系,与802.1p优先级4、5相对应的本地优先级为1。
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
·     display qos map-table
2.1.4  qos map-table
qos map-table { dot1p-lp | dscp-dscp | dscp-lp | exp-lp | lp-exp }
优先级映射参数请参见display qos map-table
# 进入802.1p优先级到本地优先级映射表视图。
·     import
qos map-table color命令用来进入指定的带颜色优先级映射表视图。
qos map-table color { green | yellow | red } lp-tunnel-dscp
green:绿色报文。
yellow:黄色报文。
red:红色报文。
表2-5 优先级映射表
优先级映射
lp-tunnel-dscp
本映射表项需要配合vxlan-dci-tunnel outer dscpvxlan-tunnel outer dscp命令使用,关于命令的详细介绍,请参见“VXLAN命令参考”中的“VXLAN”,使能上述命令之后按照本地优先级到隧道封装的外层DSCP映射表来控制报文的封装时,会对所有VXLAN报文转发产生影响
每个优先级映射(颜色也相同)存在双方向、接收报文方向、发送报文方向三张不同的映射表。如果未指定方向,则表示进入双方向的优先级映射表视图。
# 进入绿色报文的本地优先级到隧道封装的外层DSCP映射表视图。
[Sysname] qos map-table color green lp-tunnel-dscp
[Sysname-maptbl-green-lp-tunnel-dscp]
·     display qos map-table color
·     import
端口优先级信任模式配置命令
display qos trust interface命令用来显示端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示端口优先级信任模式信息。
<Sysname> display qos trust interface gigabitethernet 1/0/1
 Port priority information
  Port priority: 4
  Port dscp priority: -
  Port priority trust type: dscp
表2-6 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
端口优先级信任信息
Port priority
端口优先级
Port dscp priority
改写报文的DSCP优先级的值,-表示未配置修改报文的DSCP优先级的值
端口优先级信任类型,取值为:
·     dot1p:802.1p优先级
·     dscp:DSCP优先级
·     none:不信任任何优先级
2.1.7  qos trust
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { dot1p | dscp }
undo qos trust
设备不信任报文优先级。
二层以太网接口视图
三层以太网接口视图
三层聚合接口视图
# 在接口GigabitEthernet1/0/1上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname-GigabitEthernet1/0/1] qos trust dot1p
·     display qos trust interface
qos trust命令用来配置全局优先级信任模式。
qos trust tunnel-dscp
undo qos trust tunnel-dscp
未配置全局优先级信任模式。
如果希望VXLAN隧道接口信任VXLAN报文外层IP头的DSCP优先级,除了VXLAN隧道所在的以太网接口下配置qos trust dscp,系统视图下还需要配置qos trust tunnel-dscp
当系统工作模式为standard模式时,不支持配置qos trust tunnel-dscp。关于系统工作模式的详细介绍,请参见“基础配置指导”中的“设备管理”。
2.2  端口优先级配置命令
2.2.1  qos priority
qos priority命令用来配置端口的端口优先级。
undo qos priority命令用来恢复端口优先级为缺省值。
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
端口优先级的缺省值为0。
priority-value:端口优先级值,取值范围为0~7。当设备支持dscp类型的端口优先级时,优先级的取值范围0~63。
# 配置接口GigabitEthernet1/0/1的端口优先级为2。
[Sysname-GigabitEthernet1/0/1] qos priority 2
3 流量整形和限速
3.1  流量整形配置命令
display qos gts interface命令用来显示接口的流量整形配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量整形配置情况。
# 显示所有接口的流量整形配置情况。
 Rule: If-match queue 1
  CIR 512 (kbps), CBS 51200 (Bytes)
表3-1 display qos gts命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成
Rule
匹配规则
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
3.1.2  qos gts
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
undo qos gts queue queue-id
未配置流量整形。
queue queue-id:对队列上的数据包进行流量整形。queue-id为匹配的队列号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。万兆端口的取值范围为8~10000000,40GE端口的取值范围为8~40000000,100GE端口的取值范围为8~100000000。用户配置的数值必须是8的倍数。
cbs committed-burst-size:承诺突发尺寸,单位为byte。
·     如果不指定cbs参数,committed-burst-size缺省取值为62.5 × committed-information-rate,且必须为512的整数倍,如果乘积不是512的整数倍,就取比乘积大的最近的512的整数倍,最大不能超过8355840。
·     如果指定cbs参数,取值范围为512~8355840,committed-burst-size必须为512的整数倍。
仅支持对接口上出方向的报文进行流量整形。
# 在接口GigabitEthernet1/0/1上对队列1的报文进行流量整形。正常流速为256kbps,突发流量为51200bytes。
[Sysname-GigabitEthernet1/0/1] qos gts queue 1 cir 256 cbs 51200
3.2  限速配置命令
display qos lr interface命令用来显示接口上的限速配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的限速配置情况。
# 显示所有接口的接口限速配置情况。
 Direction: outbound
  CIR 2000 (kbps), CBS 20480 (Bytes)
表3-2 display qos lr命令显示信息描述表
Direction
接口限速应用的方向
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
3.2.2  qos lr
qos lr命令用来配置接口限速。
undo qos lr命令用来取消接口配置的限速。
undo qos lr { inbound | outbound }
未配置限速。
inbound:入方向限速。
outbound:出方向限速。
cbs committed-burst-size:承诺突发尺寸,单位为bytes。
# 对接口GigabitEthernet1/0/1上出方向的报文进行限速。正常流速为256kbps,突发流量为51200bytes,以后速率小于等于256kbps时正常发送,速率大于256kbps时,将进行限速。
[Sysname-GigabitEthernet1/0/1] qos lr outbound cir 256 cbs 51200
4 拥塞管理
4.1  拥塞管理公共配置命令
display qos queue interface命令用来显示接口上队列配置情况和统计信息。
display qos queue interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的接口队列配置情况和运行统计信息。
# 显示所有接口下的队列信息。
<Sysname> display qos queue interface
 Output queue: Strict Priority queuing
.....(省略部分显示信息)
表4-1 display qos queue interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列的相关信息
Queue ID
队列号
Queue name
队列名称
Group
分组号,说明队列属于哪一个分组
Byte count
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算
4.2  严格优先级队列配置命令
display qos queue sp interface命令用来显示接口的SP(Strict Priority,严格优先级)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的SP队列配置情况。
# 显示GigabitEthernet1/0/1的严格优先级队列配置情况。
<Sysname> display qos queue sp interface gigabitethernet 1/0/1
表4-2 display qos queue sp interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
qos sp命令用来在接口上配置严格优先队列。
undo qos sp命令用来恢复缺省情况。
qos sp
undo qos sp
接口使用SP队列调度算法。
# 在接口GigabitEthernet1/0/1上应用SP模式的队列调度。
[Sysname-GigabitEthernet1/0/1] qos sp
·     display qos queue sp interface
4.3  加权轮询队列配置命令
display qos queue wrr interface命令用来显示接口的WRR(Weighted Round Robin,加权轮询)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WRR队列配置情况。
# 显示接口GigabitEthernet1/0/1的WRR队列配置情况。
<Sysname> display qos queue wrr interface gigabitethernet 1/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Queue    name      Group           Byte count
 0               be              1               1
 1               af1             1               1
 2               af2             1               1
 3               af3             1               1
 4               af4             1               1
 5               ef              1               1
 6               cs6             1               1
 7               cs7             sp              N/A
表4-3 display qos queue wrr interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
Queue ID
队列号
Queue name
队列名称
Group
分组号,说明队列属于哪一个分组
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算,N/A表示该队列采用SP调度算法
Byte count
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算,N/A表示该队列采用SP调度算法
qos wrr命令用来在接口上开启WRR队列。
undo qos wrr命令用来恢复缺省情况。
undo qos wrr { byte-count | weight }
接口使用SP队列调度算法。
byte-count:表示按照每次轮询可发送的字节数进行计算。
weight:表示按照每次轮询可发送的报文个数进行计算。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行WRR配置。
# 在接口GigabitEthernet1/0/1上开启WRR队列,并按照每次轮询可发送的报文个数进行计算。
[Sysname-GigabitEthernet1/0/1] qos wrr weight
# 在接口GigabitEthernet1/0/1上开启WRR队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-GigabitEthernet1/0/1] qos wrr byte-count
·     display qos queue wrr interface
4.3.3  qos wrr { byte-count | weight }
qos wrr { byte-count | weight }命令用来配置WRR队列或修改WRR队列的参数。
undo qos wrr命令用来恢复指定队列的缺省情况。
qos wrr queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wrr queue-id
在使用WRR队列时,所有队列都处于WRR调度组1中,调度权重从队列0到7分别为1、2、3、4、5、9、13、15。
queue-id:队列序号。取值范围为0~7或表4-4中的关键字。
表4-4 queue-id数字和关键字对应表
queue-id数字
queue-id关键字
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
group { 1 | 2 }:表示该队列属于哪个WRR优先组,缺省为group 1。其中group 1表示该队列属于WRR优先组1,group 2表示该队列属于WRR优先组2。各组之间执行优先级调度,由组1至组2优先级依次降低。
schedule-value:配置队列的调度权重,取值范围为1~127。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行本配置。
# 在接口GigabitEthernet1/0/1上应用WRR队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
·     qos wrr
4.3.4  qos wrr group sp
qos wrr group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wrr group sp命令用来取消将队列加入SP组。
qos wrr queue-id group sp
当使用WRR队列时,所有队列都处于WRR调度组1中。
queue-id:队列序号。取值范围为0~7或对应队列的关键字be、af1、af2、af3、af4、ef、cs6、cs7。
本命令需要在端口队列为WRR调度模式下使用。
SP组与普通WRR优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WRR优先组。
# 在接口GigabitEthernet1/0/1上应用WRR队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group sp
·     qos wrr
4.4  加权公平队列配置命令
4.4.1  display qos queue wfq interface
display qos queue wfq interface命令用来显示接口的WFQ配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WFQ配置情况。
# 显示接口GigabitEthernet1/0/1的加权公平队列配置情况。
<Sysname> display qos queue wfq interface gigabitethernet 1/0/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Queue name      Group           Byte count      Min Bandwidth
 0               be              1               1               0
 1               af1             1               1               0
 2               af2             1               1               0
 3               af3             1               1               0
 4               af4             1               1               0
 5               ef              1               1               0
 6               cs6             1               1               0
 7               cs7             1               1               0
表4-5 display qos queue wfq interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
Queue ID
队列号
Queue name
队列名称
Group
分组号,说明队列属于哪一个分组
Byte-count
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算, N/A表示该队列采用SP调度算法
Min-Bandwidth
队列的最小保证带宽值
4.4.2  qos bandwidth queue
qos bandwidth queue命令用来配置端口队列的最小带宽保证。
undo qos bandwidth queue命令用来恢复缺省情况。
undo qos bandwidth queue queue-id
在使用WFQ队列时,未配置最小带宽保证。
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。万兆端口的取值范围为8~10000000,40GE端口的取值范围为8~40000000,100GE端口的取值范围为8~100000000,单位为kbps。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行本配置。
# 在接口GigabitEthernet1/0/1上配置队列0的最小保证带宽值为100kbps。
[Sysname-GigabitEthernet1/0/1] qos wfq weight
[Sysname-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
·     qos wfq
4.4.3  qos wfq (interface view)
qos wfq命令用来在接口上开启WFQ队列。
undo qos wfq命令用来恢复缺省情况。
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
接口使用SP队列调度算法。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行WFQ配置。
# 在接口GigabitEthernet1/0/1上开启WFQ队列,并按照每次轮询可发送的报文个数进行计算。
# 在接口GigabitEthernet1/0/1上开启WFQ队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-GigabitEthernet1/0/1] qos wfq byte-count
·     display qos queue wfq interface
4.4.4  qos wfq { byte-count | weight }
qos wfq { byte-count | weight }命令用来配置WFQ队列或修改WFQ队列的参数。
undo qos wfq命令用来恢复指定队列的缺省情况。
qos wfq queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wfq queue-id
在使用WFQ队列时,所有队列都处于WFQ调度组1中,各队列的调度权重均为1。
group { 1 | 2 }:表示该队列属于哪个WFQ优先组,缺省为group 1。其中group 1表示该队列属于WFQ优先组1,group 2表示该队列属于WFQ优先组2。各组之间执行优先级调度,由组1至组2优先级依次降低。
# 在接口GigabitEthernet1/0/1上应用WFQ队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
·     qos bandwidth queue
·     qos wfq
4.4.5  qos wfq group sp
qos wfq group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wfq group sp命令用来取消将队列加入SP组。
qos wfq queue-id group sp
当使用WFQ队列时,所有队列都处于WFQ调度组1中。
本命令需要在端口队列为WFQ调度模式下使用。
SP组与普通WFQ优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WFQ优先组。
# 在接口GigabitEthernet1/0/1上应用WFQ队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group sp
·     qos wfq
4.5  队列调度策略配置命令
4.5.1  bandwidth queue
bandwidth queue命令用来配置队列调度策略下队列的最小带宽保证。
undo bandwidth queue命令用来恢复缺省情况。
undo bandwidth queue queue-id
在队列调度策略中配置某个队列为WFQ队列后,该队列未配置最小带宽保证。
队列调度策略视图
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。取值范围为8~100000000。
必须先在队列调度策略中将某个队列配置为WFQ队列,才能为该队列配置最小带宽保证。
# 在队列调度策略myprofile中,配置队列7使用WFQ队列算法,使用字节数作为调度权重,权重值为1,分组为1,并为该队列配置最小保证带宽值为100kbps。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 7 wfq group 1 byte-count 1
[Sysname-qmprofile-myprofile] bandwidth queue 7 min 100
4.5.2  display qos qmprofile configuration
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有队列调度策略的配置情况。
slot slot-number:显示指定成员设备的队列调度策略的配置情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的队列调度策略的配置情况。‌‌
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID  Type  Group   Schedule   Schedule  Min
                         unit       value     bandwidth
 be        WFQ   1       byte-count 1         0
 af1       SP    N/A     N/A        N/A       0
 af2       SP    N/A     N/A        N/A       0
 af3       SP    N/A     N/A        N/A       0
 af4       SP    N/A     N/A        N/A       0
 ef        SP    N/A     N/A        N/A       0
 cs6       SP    N/A     N/A        N/A       0
 cs7       SP    N/A     N/A        N/A       0
表4-6 display qos qmprofile configuration命令显示信息描述表
队列调度策略名称
Queue ID
队列号
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)、WFQ(加权公平队列)
Group
优先组,N/A表示无效
Schedule unit
队列调度单位,包括weight和byte-count,N/A表示无效
Schedule vlaue
·     队列调度单位为weight时,表示报文个数
·     队列调度单位为byte-count时,表示字节个数
·     N/A表示无效
Min Bandwidth
最小保证带宽,N/A表示无效
4.5.3  display qos qmprofile interface
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface gigabitethernet 1/0/1
Direction: Outbound
表4-7 display qos qmprofile interface命令显示信息描述表
接口名称
Direction
队列调度策略应用的方向
队列调度策略名称
4.5.4  qos apply qmprofile
qos apply qmprofile命令用来在接口出方向上应用队列调度策略。
undo qos apply qmprofile命令用来恢复缺省情况。
接口上未应用队列调度策略。
每个接口在同一方向上只能应用一个队列调度策略。
# 在接口GigabitEthernet1/0/1出方向上应用队列调度策略myprofile。
[Sysname-GigabitEthernet1/0/1] qos apply qmprofile myprofile
·     display qos qmprofile interface
4.5.5  qos qmprofile
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入相应的队列调度策略视图。如果指定的队列调度策略已经存在,则直接进入该队列调度策略视图。
undo qos qmprofile命令用来删除用户自定义的队列调度策略。
qos qmprofile profile-name
undo qos qmprofile profile-name
不存在用户自定义的队列调度策略。
如果需要删除已经应用到接口的队列调度策略,必须先在应用的位置上取消对该队列调度策略的应用,然后再删除该队列调度策略。
# 创建队列调度策略myprofile,并进入队列调度策略视图。
·     queue
4.5.6  queue
queue命令用来配置队列调度参数。
undo queue命令用来取消队列调度参数的配置。
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
缺省情况下,队列调度策略的内容是所有队列均采用SP方式调度。
队列调度策略视图
queue-id:队列序号。取值范围为0~7或0~7对应队列的关键字be、af1、af2、af3、af4、ef、cs6、cs7。
sp:配置队列为严格优先级调度。
wfq:配置队列为加权公平调度。
wrr:配置队列为加权轮询调度。
group group-id:优先组号。group-id取值范围为1~2。
schedule-value:配置队列的调度权重。取值范围为1~127。
# 创建自定义的队列调度策略myprofile,并配置队列0为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 0 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,权重为10,分组为1。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 byte-count 10
·     qos qmprofile
5 拥塞避免
5.1  WRED配置命令
5.1.1  display qos wred interface
display qos wred interface命令用来显示接口上WRED配置情况和统计信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的WRED配置情况和统计信息。
# 显示所有接口下应用的WRED表配置情况和统计信息。
<Sysname> display qos wred interface
 Current WRED configuration:
 Applied WRED table name: q1
表5-1 display qos wred interface命令显示信息描述表
接口名,由接口类型和接口编号组成
当前WRED的配置情况
当前应用的WRED表的名称
5.1.2  display qos wred table
display qos wred table命令用来显示WRED表的配置情况。
name table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则显示所有WRED表配置情况。
slot slot-number:显示指定成员设备的WRED表配置情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的WRED表配置情况。‌‌
# 显示WRED表1的配置情况,表1是一个已经配置好的WRED参数表。
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rpro
0     100   1000  10     100   1000  10     100   1000  10
1     100   1000  10     100   1000  10     100   1000  10
2     100   1000  10     100   1000  10     100   1000  10
3     100   1000  10     100   1000  10     100   1000  10
4     100   1000  10     100   1000  10     100   1000  10
5     100   1000  10     100   1000  10     100   1000  10
6     100   1000  10     100   1000  10     100   1000  10
7     100   1000  10     100   1000  10     100   1000  10
表5-2 display qos wred table命令显示信息描述表
Table name
WRED表名
Table type
WRED表类型
QID
队列ID
gmin
绿色报文的队列下限
gmax
绿色报文的队列上限
gpro
绿色报文的丢弃概率
ymin
黄色报文的队列下限
ymax
黄色报文的队列上限
ypro
黄色报文的丢弃概率
rmin
红色报文的队列下限
rmax
红色报文的队列上限
rpro
红色报文的丢弃概率
5.1.3  qos wred apply
qos wred apply命令用来在接口上应用WRED表。
undo qos wred apply命令用来恢复缺省情况。
qos wred apply [ table-name ]
undo qos wred apply
接口没有应用WRED表,即接口采用尾丢弃。
table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则在接口上应用缺省WRED表。
# 在接口GigabitEthernet1/0/1上应用WRED表。
[Sysname-GigabitEthernet1/0/1] qos wred apply table1
·     display qos wred interface
·     display qos wred table
·     qos wred queue table
5.1.4  qos wred queue table
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。如果指定的WRED表已经存在,则直接进入WRED表视图。
undo qos wred queue table命令用来删除WRED表。
undo qos wred queue table table-name
设备上不存在WRED表。
table table-name:指定WRED表的名称,为1~32个字符的字符串,区分大小写。
设备不允许删除正在使用的WRED表。如果需要删除正在使用的表,请先在接口上取消应用的WRED表。
缺省WRED表可以通过display qos wred table命令显示,不允许修改和删除。
# 创建基于queue的WRED表queue-table1。
[Sysname-wred-table-queue-table1]
5.1.5  queue (Wred table view)
queue命令用来配置基于队列的WRED表的内容。
undo queue命令用来恢复缺省情况。
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id [ drop-level drop-level ] | all }
WRED表在创建之后,low-limit的缺省取值为100,high-limit的缺省取值为1000,discard-prob的缺省取值为10。
WRED表视图
all:表示所有队列。
queue-id:队列编号。取值范围为0~7。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:队列平均长度的下限。取值范围为0~16383,单位为288byte。
high-limit high-limit:队列平均长度的上限。取值范围为0~16383且必须大于丢弃下限,单位为288byte。
discard-probability discard-prob:丢弃概率,取值越大,计算出的丢弃概率越大。取值范围为0~100。
当队列平均长度小于下限时,不丢弃报文。当队列平均长度在上限和下限之间时,设备随机丢弃报文,队列越长,丢弃概率越高。当队列平均长度超过上限时,丢弃所有到来的报文。
设备最多支持配置6个不同的WRED规则。当配置了6个WRED规则,且某个规则所在的WRED表被应用到多个接口上时,若修改该规则,则需要先取消该规则所在的WRED表在这些接口上的应用,修改规则后重新将WRED表应用在这些接口上。
# 配置基于队列的WRED表queue-table1中队列1的丢弃参数:丢弃级别为1,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30%。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
6 全局CAR
6.1  全局CAR配置命令
6.1.1  car name
car name命令用来配置全局CAR动作。
undo car用来恢复缺省情况。
car name car-name
undo car
未配置全局CAR动作。
流行为视图
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
# 配置流行为be1的聚合CAR动作为aggcar-1。
·     display qos car name
·     display traffic behavior user-defined
6.1.2  display qos car name
display qos car name命令用来显示全局CAR的配置和统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。显示指定全局CAR的配置和统计信息。如果未指定本参数,将显示所有全局CAR的配置和统计信息。
# 显示全局CAR的配置和统计信息。‌‌
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
   Green action  : pass
   Yellow action : pass
   Red action    : discard
  Slot 0:
   Green packets : 0 (Packets), 0 (Bytes)
   Yellow packets: 0 (Packets), 0 (Bytes)
   Red packets   : 0 (Packets), 0 (Bytes)
表6-1 display qos car name命令显示信息描述表
Name
全局CAR的名称
Mode
聚合CAR的类型,取值为aggregative(聚合CAR)
CIR  CBS  PIR  EBS
流量监管流量的参数配置
Green action
对绿色报文的动作
Yellow action
对黄色报文的动作
Red action
对红色报文的动作
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
6.1.3  qos car (system view)
qos car命令用来配置聚合CAR。
undo qos car命令用来取消聚合CAR的配置。
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
未配置聚合CAR。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为16~100000000且必须为8的整数倍。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
·     如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过67092480。
·     如果指定cbs参数,取值范围512~67092480且必须为512的整数倍。
ebs excess-burst-size:过度突发尺寸,单位为byte。本参数仅全局CAR为聚合模式时支持。
配置pir参数后:
·     如果不指定ebs,则ebs缺省取值为与62.5 × peak-information-rate的乘积最接近且不小于512的整数倍,但是最大值不能超过67092480。
·     如果指定ebs,取值范围0~67092480且必须为512的整数倍。
未配置pir参数时,ebs的取值范围为0~67092480且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为16~100000000且必须为8的整数倍。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass
action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。仅入方向支持。
聚合CAR配置需要在策略中引用后才能生效,且该策略在同一视图下不能同时应用到出入两个方向上。
当黄色报文配置为discard动作时,红色报文只支持配置为discard动作。
不配置峰值速率表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 配置聚合CAR采取的CAR参数取值,cir取值为25600,cbs取值为512000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
6.1.4  reset qos car name
reset qos car name命令用来清除全局CAR的统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。清除指定全局CAR的统计信息。如果未指定本参数,将清除所有全局CAR的统计信息。
# 清除全局CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
7 大小流区分调度
7.1  大小流区分调度配置命令
7.1.1  elephant-flow action
elephant-flow action命令用来配置大流的处理动作。
undo elephant-flow action命令用来恢复缺省情况。
elephant-flow action { drop-precedence drop-precedence-value | dot1p dot1p-value | local-precedence local-precedence-value | none }
未配置大流的处理动作。
大小流视图
drop-precedence drop-precedence-value:指定丢弃优先级,其中drop-precedence-value的取值范围为0~2。
dot1p dot1p-value:指定802.1p优先级,dot1p-value的取值范围为0~7。
local-precedence local-precedence-value:指定本地优先级,local-precedence-value的取值范围为0~7。
none:无后续处理动作,此时大小流功能仅将大流识别出来,不做处理。
# 配置大流的丢弃优先级为2。
<Sysname> system-View
[Sysname] qos mice-elephant-flow
[Sysname-mice-elephant-flow] elephant-flow action drop-precedence 2
·     elephant-flow rate
7.1.2  elephant-flow rate
elephant-flow rate命令用来配置大流识别参数。
undo elephant-flow rate命令用来取消已配置的大流识别参数。
elephant-flow rate rate [ gbps | kbps | mbps ] [ size size [ bytes | kbytes | mbytes ] ]
未配置大流识别参数。
大小流视图
rate:大流速率,缺省单位为kbps,取值范围为1~1000。
·     gbps:指定大流速率的单位为gbps。
·     kbps:指定大流速率的单位为kbps。
·     mbps:指定大流速率的单位为mbps。
size size:大流尺寸,缺省单位为bytes,取值范围为1~1000。
·     bytes:指定大流尺寸的单位为bytes。
·     kbytes:指定大流尺寸的单位为kbytes。
·     mbytes:指定大流尺寸的单位为mbytes。
配置本命令后,设备将依据本命令中指定的流量识别参数区分大流和小流:
·     不对小流进行额外处理。
·     将大流的丢弃优先级修改为elephant-flow rate命令中指定的优先级。
一旦发生拥塞,设备优先保证无丢弃优先级或丢弃优先级小的流量的转发。
# 配置大流识别参数,速率为20kbps,尺寸为100kbytes。
[Sysname-mice-elephant-flow] elephant-flow rate 20 kbps size 100 kbytes
·     elephant-flow action
7.1.3  qos mice-elephant-flow
qos mice-elephant-flow命令用来进入大小流视图。
# 进入大小流视图。
8 端口队列统计
8.1  端口队列统计配置命令
8.1.1  display qos queue-statistics interface outbound
display qos queue-statistics interface outbound命令用来显示端口队列出方向的统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列出方向统计信息。
# 显示接口GigabitEthernet1/0/1的队列出方向统计信息。
<Sysname> display qos queue-statistics interface gigabitethernet 1/0/1 outbound
 Direction: outbound
 Forwarded: 0 packets, 0 bytes
 Queue 0
  Current queue length: 0 packets
 Queue 1
 Queue 2
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
表8-1 display qos queue-statistics interface outbound命令显示信息描述表
端口队列统计的端口
Direction
端口队列统计的方向
Forwarded
转发的数据包数目、字节数
Queue 0、Queue 1、Queue 2、Queue 3、Queue 4、Queue 5、Queue 6、Queue 7
某端口队列统计信息
当前队列长度
·     reset counters interface(接口管理命令参考/以太网接口)
本站点使用Cookies,继续浏览表示您同意我们使用Cookies。 Cookies和隐私政策>
