08-设备管理命令
本章节下载: 08-设备管理命令 (936.97 KB)
1.1.2 auto-register cmcc device-management enable
1.1.3 auto-register telecom device-management enable
1.1.16 display cpu-usage configuration
1.1.17 display cpu-usage history
1.1.19 display device manuinfo
1.1.20 display device manuinfo chassis-only
1.1.21 display diagnostic-information
1.1.22 display disk-information
1.1.24 display fabric utilization
1.1.26 display hardware-failure-detection
1.1.27 display hardware-failure-protection
1.1.30 display memory-threshold
1.1.31 display memory-threshold dma
1.1.34 display scheduler logfile
1.1.35 display scheduler reboot
1.1.36 display scheduler schedule
1.1.38 display system stable state
1.1.39 display transceiver alarm
1.1.40 display transceiver diagnosis
1.1.41 display transceiver interface
1.1.42 display transceiver manuinfo
1.1.44 display version-update-record
1.1.48 hardware-failure-protection aggregation
1.1.55 monitor cpu-usage enable
1.1.56 monitor cpu-usage interval
1.1.57 monitor cpu-usage logging
1.1.58 monitor cpu-usage statistics-interval core
1.1.59 monitor cpu-usage threshold
1.1.60 monitor cpu-usage threshold core
1.1.61 monitor memory-usage logging
1.1.62 monitor resend cpu-usage core-interval
1.1.63 monitor resend memory-threshold dma
1.1.64 monitor resource-usage { bridge-aggregation | route-aggregation } threshold
1.1.65 monitor resource-usage bandwidth inbound threshold
1.1.66 monitor resource-usage blade-controller-team context
1.1.67 monitor resource-usage context threshold
1.1.68 monitor resource-usage session-count threshold
1.1.69 monitor resource-usage session-rate threshold
1.1.70 password-recovery enable
1.1.73 power-supply policy priority
1.1.75 reset scheduler logfile
1.1.76 reset version-update-record
1.1.77 restore factory-default
1.1.85 switch-fabric removal-signal-suppression
1.1.92 transceiver third-party alarm enable
1.1.93 transceiver phony-alarm-disable
accelerate命令用来开启单板的加速转发功能。
undo accelerate命令用来关闭单板的加速转发功能。
accelerate slot slot-number
undo accelerate slot slot-number
accelerate chassis chassis-number slot slot-number
undo accelerate chassis chassis-number slot slot-number
所有单板的加速转发功能处于关闭状态。
slot slot-number:表示单板所在的槽位号。
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。
使用该命令开启指定单板的加速转发功能可以提升单板的转发性能。但如果同时开启多块单板的加速转发功能,会给交换网板带来较大的突发流量,可能导致丢包。建议您在工程师指导下谨慎使用该功能,不要自行配置。
仅缺省Context支持本命令。
执行该命令后,需使用reboot命令重启单板,配置才能生效。
# 开启指定slot的加速转发功能。
[Sysname] accelerate slot 3
Forwarding acceleration configured. Please reboot the card to place it into effect.
auto-register cmcc device-management enable命令用来开启向中国移动管理平台注册功能。
undo auto-register cmcc device-management enable命令关闭向中国移动管理平台注册功能。
中国移动管理平台注册功能处于关闭状态。
context-admin
开启中国移动管理平台注册功能后,设备将自动向中国移动管理平台注册,从而向管理平台发送设备信息并在管理平台展示。
# 开启向中国移动管理平台注册功能。
[Sysname] auto-register cmcc device-management enable
auto-register telecom device-management enable命令用来开启向电信天翼管理平台注册功能。
undo auto-register telecom device-management enable命令关闭向电信天翼管理平台注册功能。
电信天翼管理平台注册功能处于关闭状态。
context-admin
开启电信天翼管理平台注册功能后,设备将自动向电信天翼管理平台注册,从而向管理平台发送设备信息并在管理平台展示。
# 开启向电信天翼管理平台注册功能。
[Sysname] auto-register telecom device-management enable
brand命令用来配置主控板的品牌标识。
brand { hp | h3c } [ slot slot-number ]
brand { hp | h3c } [ chassis chassis-number slot slot-number ]
本命令的缺省情况与主控板的型号有关,请以设备的实际情况为准。
hp:表示配置主控板的品牌标识为hp。
h3c:表示配置主控板的品牌标识为h3c。
slot slot-number:表示主控板所在的槽位号。不指定该参数时,表示对所有主控板进行操作。
chassis chassis-number slot slot-number:表示指定成员设备上的指定主控板。chassis-number表示设备在IRF中的成员编号,slot-number表示主控板所在的槽位号。不指定该参数时,则表示IRF中的所有主控板。
仅缺省Context支持本命令。
修改主控板的品牌标识后,需要重启该主控板,新品牌标识才能生效。
# 修改主控板的品牌标识为HP。
<Sysname> brand hp
Configuration will take effect after next reboot, do you want to continue? [Y/N]: Y
Configuration is successful.
· display brand
clock datetime命令用来配置设备的系统时间。
clock datetime time date
设备的系统时间为UTC(Coordinated Universal Time,国际协调时间)时间2011年1月1日零点。
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
执行本命令会修改设备的系统时间,会影响和系统时间相关特性的执行(例如定时执行任务功能),以及和其他设备的协同操作(例如日志上报和统计),请谨慎执行。
仅缺省Context支持本命令。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
# 配置设备的系统时间为2015年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2015
# 配置设备的系统时间为2015年1月1日8时10分。
<Sysname> clock datetime 8:10 2015/1/1
· clock protocol
· clock summer-time
· clock timezone
· display clock
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来配置从缺省Context通过NTP协议获取时间作为系统时间。
clock protocol { none | ntp context context-id }
undo clock protocol
RXX60之前的版本是从缺省Context通过NTP协议获取时间。
RXX60之后的版本的缺省情况如下:
· 出厂配置启动时是通过命令行配置系统时间
· 空配置启动时是从缺省Context通过NTP协议获取时间
有关出厂配置和空配置的详细介绍,请参见“基础配置指导”中的“配置文件管理”。
none:表示通过命令行配置系统时间。
gnss:表示从GNSS(Global Navigation Satellite System,全球导航卫星系统)周期性获取UTC取时间。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议周期性从网络获取UTC时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
context context-id:表示从指定Context获取时间。context-id表示Context的编号,关于context的取值范围及相关介绍,请参见“虚拟化技术命令参考”中的“Context”。
仅缺省Context支持本命令。
· 配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
· 配置clock protocol ntp命令后,如果时钟信号失效,不能按周期同步时间,则使用内部晶体震荡器产生的时钟信号继续计时,待时钟信号恢复后,再重新同步。
设备获取到UTC时间后,会和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。
多次执行本命令,最后一次执行的命令生效。
所有Context的系统时间相同。当设备从某个Context获取时钟后,会同步给其它Context。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
· 直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
· 分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:January、February、March、April、May、June、July、August、September、October、November或December;然后输入开始的星期,用当月的第几个星期表示,取值如下:first、second、third、fourth、fifth或last;最后输入起始日,取值为Sunday、Monday、Tuesday、Wednesday、Thursday、Friday或Saturday。
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
· 直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
仅缺省Context支持本命令。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
· clock datetime
· clock timezone
· display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用UTC时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
仅缺省Context支持本命令。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
· clock datetime
· clock summer-time
· display clock
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
context-admin
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnet、ftp、ssh2和monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口GigabitEthernet1/0/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
· scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
context-admin
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
display alarm命令用来显示设备的告警信息。
display alarm [ slot slot-number ]
slot slot-number:显示指定成员设备的告警信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,则表示所有成员设备。
仅缺省Context支持本命令。
# 显示设备的告警信息。
<Sysname> display alarm
Slot CPU Level Info
1 0 ERROR faulty
表1-1 display alarm命令显示信息描述表
Slot |
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上 |
CPU |
告警CPU的编号 |
Level |
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO |
Info |
告警的详细信息。取值为: · faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态) · Fan n is absent:风扇n当前不在位 · Power n is absent:电源n当前不在位 · Power n is faulty:电源n处于异常状态 · The temperature of sensor n exceeds the lower limit:传感器n的温度低于低温门限 · The temperature of sensor n exceeds the upper limit:传感器n的温度高于高温门限 |
display brand命令用来显示主控板的品牌标识。
display brand
仅缺省Context支持本命令。
# 显示设备的品牌标识。
<Sysname> display brand
Current BRANDs:
Slot 1: H3C.
New BRANDs:
Slot 1: H3C.
表1-2 display brand命令显示信息描述表
Current BRANDs |
设备上当前生效的品牌标识 |
New BRANDs |
通过brand命令修改后的品牌标识,该标识在主控板重启后生效 |
· brand
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
context-admin
context-operator
显示信息中,时间的格式采用“时:分:秒.毫秒”的格式。
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00.211 Z5 Fri 03/16/2015
· clock datetime
· clock timezone
· clock summer-time
display copyright命令用来显示设备的版权信息。
context-admin
context-operator
display cpu-usage命令用来显示CPU利用率的统计信息。
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
control-plane:显示控制平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
data-plane:显示数据平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
slot slot-number:显示指定成员设备的CPU利用率的统计信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示的是所有成员设备的相应信息。
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。不指定该参数时,显示所有CPU核的平均利用率。
登录Context后执行该命令,会显示该Context可使用的CPU的利用率统计信息。
当最近5秒、最近1分钟、最近5分钟的CPU利用率取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 以段的形式显示当前CPU利用率统计信息。
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。
<Sysname> display cpu-usage summary
Slot CPU Last 5 sec Last 1 min Last 5 min
1 0 17% 29% 28%
表1-3 display cpu-usage命令显示信息描述表
1% in last 5 seconds |
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率 |
Last 5 sec |
1% in last 1 minute |
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率 |
Last 1 min |
1% in last 5 minutes |
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率 |
Last 5 min |
display cpu-usage configuration命令用来显示CPU利用率监控功能的相关配置。
context-admin
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,显示的是主设备上的相应信息。
cpu cpu-number:表示CPU的编号,不指定该参数时,显示的是指定slot上的所有CPU的相关配置。
登录Context后执行该命令,会显示该Context可使用的CPU的对应信息。
# 显示CPU利用率监控功能的相关配置。
<Sysname> display cpu-usage configuration slot 4
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 90%.
Current monitor recovery threshold is 40%.
Current statistics-interval is 90 seconds for the following cores: 0 to 31.
表1-4 display cpu-usage configuration命令显示信息描述表
CPU usage monitor is enabled. |
CPU利用率历史记录功能处于开启状态 |
Current monitor interval is 60 seconds. |
CPU利用率历史记录的采样周期为60秒 |
Current monitor threshold is 90%. |
CPU利用率阈值 |
Current monitor recovery threshold is 40%. |
CPU利用率的恢复阈值 |
Current statistics-interval is 90 seconds for the following cores: xx to xx. |
CPU核利用率的统计周期 |
· monitor cpu-usage enable
· monitor cpu-usage interval
· monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
context-admin
context-operator
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定成员设备的CPU利用率的历史信息。slot-number表示设备在IRF中的成员编号。当不指定job和该参数时,显示的是所有成员设备上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是主设备上指定进程的相应信息。
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
· 纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
· 横坐标表示时间,时间越靠左表示距离当前时间越近。
· 用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
display device [harddisk | usb ][ slot slot-number [ subslot subslot-number ] | verbose ]
context-admin
context-operator
harddisk:显示硬盘的信息。
usb:显示USB接口的信息。
slot slot-number:显示指定成员设备的信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。
subslot subslot-number:显示指定接口模块的信息。subslot-number表示接口模块所在的子槽位号(对应设备面板上的SLOT编号)。不指定该参数时,不会显示接口模块的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
不指定cf-card、harddisk和usb参数时,显示成员设备的信息。
在缺省Context和非缺省Context下执行该命令,显示信息相同,且均显示物理设备的对应信息。
# 显示设备信息。
<Sysname> display device
Slot.No Cpu.Id Brd Type Brd Status Subslot Sft Ver Patch Ver
1 0 T5020 Normal 0 8524P08 None
1 0 NONE Absent 1 None None
表1-5 display device命令显示信息描述表
Slot.No |
成员编号 |
Cpu.Id |
CPU编号 |
Brd Type |
设备类型 |
Brd Status |
成员设备的状态,取值为: · Normal:表示该成员设备处于正常工作状态 · Absent:表示该成员设备不存在 · Fault:表示该成员设备不能正常工作 |
Soft Ver |
设备上运行的软件版本 |
Patch Ver |
当前设备上运行的、最新发布的热补丁版本。取值为None时表示没有安装热补丁 若同时安装了叠加补丁和非叠加补丁,则显示最新发布的叠加补丁。关于叠加补丁和非叠加补丁的介绍请参见“基础配置指导”中的“软件升级” |
display device manuinfo命令用来显示设备的电子标签信息。
context-admin
context-operator
slot slot-number:显示指定成员设备的电子标签信息。slot-number表示设备在IRF中的成员编号。不输入该参数时,显示所有成员设备的相应信息。
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
本命令仅缺省Context支持。
# 显示设备的电子标签信息。
<Sysname> display device manuinfo
Slot 1 CPU 0:
DEVICE_NAME : SecPath T5020
DEVICE_SERIAL_NUMBER : 210235A1RSH163000006
MAC_ADDRESS : 50DA-00F2-1772
MANUFACTURING_DATE : 2016-03-22
VENDOR_NAME : H3C
表1-6 display device manuinfo命令信息显示描述表
Slot 1 CPU 0: |
表示设备的电子标签信息,包括: · DEVICE_NAME:表示设备的名称 · DEVICE_SERIAL_NUMBER:表示设备的序列号 · MAC_ADDRESS:表示设备出厂MAC地址 · MANUFACTURING_DATE:表示设备的调测日期 · VENDOR_NAME:表示设备制造商的名称 · PRODUCT ID:表示产品代码 |
Subslot 1: |
表示子卡的电子标签信息 |
Fan 1: |
表示风扇的电子标签信息 |
Power 1: |
表示电源的电子标签信息 |
display device manuinfo chassis-only命令用来显示背板的电子标签信息。
display device manuinfo chassis chassis-number chassis-only
context-admin
context-operator
本命令仅缺省Context支持。
# 显示机框背板的电子标签信息。
<Sysname> display device manuinfo chassis-only
Chassis self:
DEVICE_NAME : XXXX
DEVICE_SERIAL_NUMBER : XXXXXXXXXXXXXXXXXXXX
MAC_ADDRESS : NONE
MANUFACTURING_DATE : XXXX-XX-XX
VENDOR_NAME : H3C
PRODUCT_ID : XX-XXXX-XX
本命令的显示信息描述请参见“display device manuinfo命令信息显示描述表”。
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ context context-name ] [ key-info ] [ filename ]
context-admin
context-operator
hardware:收集硬件相关的诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
context context-name:收集指定Context的诊断信息。context-name表示Context的名称,为1~15个字符的字符串,区分大小写。不指定该参数时,收集缺省Context的诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1) 使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2) 使用gunzip命令将文件XXXX.gz解包成文件XXXX。
(3) 使用more命令查看文件XXXX的内容。
如果收集诊断文件过程半途中止,可能导致gunzip命令无法正常解压,但诊断文件中仍包括已经生成的诊断信息,可以将诊断文件传输到PC上使用Linux系统下的gunzip -c命令解压查看。
不指定filename参数执行display diagnostic-information命令时,系统会要求用户选择显示诊断信息还是将诊断信息保存到文件中。如果用户选择保存诊断信息,且当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
未指定hardware、infrastructure、l2、l3和service参数时,将收集设备产生的所有诊断信息。
该命令不支持“|”、“>”和“>>”参数。
执行本命令收集诊断信息时,请不要配置设备,以免影响收集结果。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2015
显示信息略……。
# 将收集到的诊断信息保存到缺省诊断文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
· gunzip(基础配置命令参考/文件系统管理)
· more(基础配置命令参考/文件系统管理)
· tar extract(基础配置命令参考/文件系统管理)
display disk-information命令用来收集硬盘信息。
display disk-information [ slot slot-number [ cpu cpu-number ] ]
display disk-information [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示单板上指定CPU对应的硬盘信息。slot-number表示单板所在的槽位号。不指定该参数时,表示主用主控板。
slot slot-number:显示成员设备上指定CPU对应的硬盘信息。slot-number表示IRF中设备的成员编号。不指定该参数时,表示主设备。
chassis chassis-number slot slot-number:显示单板上指定CPU对应的硬盘信息。chassis-number表示IRF中设备的成员编号,slot-number表示指定成员设备上的指定单板。不指定该参数时,表示全局主用主控板。
cpu cpu-number:显示指定CPU对应的硬盘信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
当存储介质故障或者需要查看硬盘状态时,可以通过本命令收集设备硬盘信息,来诊断故障。
该命令会收集设备上所有硬盘信息并显示,通过diskid进行区分。
# 收集硬盘信息。(适用于NVME硬盘)
<Sysname> display disk-information slot 1
Slot 1:
DiskID: nvme0n1
smartctl 7.2 2022-06-08 r635726:636193M [aarch64-linux-4.4.65] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: FORESEE 256GB SSD
Serial Number: LD1ZS4H000022
Firmware Version: V2.2
PCI Vendor ID: 0x2263
PCI Vendor Subsystem ID: 0x1d97
IEEE OUI Identifier: 0x000000
Total NVM Capacity: 256,060,514,304 [256 GB]
Unallocated NVM Capacity: 0
Controller ID: 1
NVMe Version: 1.3
Number of Namespaces: 1
Namespace 1 Size/Capacity: 256,060,514,304 [256 GB]
Namespace 1 Formatted LBA Size: 512
Local Time is: Mon Apr 10 15:58:42 2023 UTC
Firmware Updates (0x02): 1 Slot
Optional Admin Commands (0x0007): Security Format Frmw_DL
Optional NVM Commands (0x0015): Comp DS_Mngmt Sav/Sel_Feat
Log Page Attributes (0x0a): Cmd_Eff_Lg Telmtry_Lg
Maximum Data Transfer Size: 32 Pages
Warning Comp. Temp. Threshold: 85 Celsius
Critical Comp. Temp. Threshold: 90 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 5.00W - - 0 0 0 0 0 0
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 34 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 1%
Data Units Read: 3,752,041 [1.92 TB]
Data Units Written: 89,005 [45.5 GB]
Host Read Commands: 22,919,229
Host Write Commands: 659,876
Controller Busy Time: 57
Power Cycles: 52
Power On Hours: 4,575
Unsafe Shutdowns: 45
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 34 Celsius
Thermal Temp. 2 Transition Count: 37
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
# 收集硬盘信息。(适用于SATA硬盘)
Slot 16:
DiskID: sda
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-4.4.65] (local build)
Model Family: Micron 5100 Pro / 52x0 / 5300 SSDs
Device Model: Micron_5300_MTFDDAV480TDS
Serial Number: 20122744FA44
LU WWN Device Id: 5 00a075 12744fa44
Firmware Version: D3MU001
User Capacity: 480,103,981,056 bytes [480 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: Solid State Device
Form Factor: M.2
TRIM Command: Available, deterministic, zeroed
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Apr 10 20:15:55 2023 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 1674) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 6) minutes.
Conveyance self-test routine
recommended polling time: ( 3) minutes.
SCT capabilities: (0x0035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 050 Pre-fail Always - 0
5 Reallocated_Sector_Ct 0x0032 100 100 001 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 1317
12 Power_Cycle_Count 0x0032 100 100 001 Old_age Always - 236
170 Reserved_Block_Pct 0x0033 100 100 010 Pre-fail Always - 0
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 001 Old_age Always - 0
173 Avg_Block-Erase_Count 0x0032 100 100 000 Old_age Always - 15
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 233
183 SATA_Int_Downshift_Ct 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 80
194 Temperature_Celsius 0x0022 062 028 000 Old_age Always - 38 (Min/Max 19/72)
195 Hardware_ECC_Recovered 0x0032 100 100 000 Old_age Always - 0
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
202 Percent_Lifetime_Remain 0x0030 100 100 001 Old_age Offline - 0
206 Write_Error_Rate 0x000e 100 100 000 Old_age Always - 0
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 18779935651
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 586907500
248 Bckgnd_Program_Page_Cnt 0x0032 100 100 000 Old_age Always - 52641458
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033 100 100 000 Pre-fail Always - 2161
210 RAIN_Success_Recovered 0x0032 100 100 000 Old_age Always - 0
211 Integ_Scan_Complete_Cnt 0x0032 100 100 000 Old_age Always - 176
212 Integ_Scan_Folding_Cnt 0x0032 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Self-test routine in progress 90% 1299 -
# 2 Short offline Self-test routine in progress 90% 1299 -
# 3 Short offline Self-test routine in progress 90% 1299 -
# 4 Short offline Self-test routine in progress 90% 1299 -
# 5 Short offline Self-test routine in progress 90% 1299 -
# 6 Short offline Self-test routine in progress 90% 1299 -
# 7 Short offline Self-test routine in progress 90% 1299 -
# 8 Short offline Self-test routine in progress 90% 1299 -
# 9 Short offline Self-test routine in progress 90% 1299 -
#10 Short offline Self-test routine in progress 90% 1299 -
#11 Short offline Self-test routine in progress 90% 1299 -
#12 Short offline Self-test routine in progress 90% 1299 -
#13 Short offline Self-test routine in progress 90% 1299 -
#14 Short offline Self-test routine in progress 90% 1299 -
#15 Short offline Self-test routine in progress 90% 1299 -
#16 Short offline Self-test routine in progress 90% 1299 -
#17 Short offline Self-test routine in progress 90% 1299 -
#18 Short offline Self-test routine in progress 90% 1299 -
#19 Short offline Self-test routine in progress 10% 1299 -
#20 Short offline Self-test routine in progress 90% 1299 -
#21 Extended captive Interrupted (host reset) 00% 177 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
表1-7 display disk-information命令显示信息描述表
Diskid |
硬盘ID。如果产品未分配,使用内核分配的可唯一标示硬盘的信息,否则使用产品分配的ID。 |
Model Family |
硬盘系列 |
Device Model |
型号 |
Serial Number |
序列号 |
LU WWN Device Id |
全球唯一ID |
Firmware Version |
固件版本号 |
User Capacity |
容量 |
Sector Sizes |
Sector大小 |
Rotation Rate |
机械硬盘转速,其他不涉及 |
Form Factor |
接口形式 |
TRIM Command |
Trim执行支持情况 |
Device is |
Smartctl database是否包含该硬盘 |
ATA Version is |
支持ATA协议版本 |
SATA Version is |
支持SATA协议版本 |
Local Time is |
当前时间 |
SMART support is |
硬盘是否支持Smart |
SMART support is |
Smart是否使能 |
SMART overall-health self-assessment test result |
硬盘健康状态,PASSED为健康 |
Model Number |
硬盘型号 |
PCI Vendor ID |
Vendor ID |
PCI Vendor Subsystem ID |
IEEE OUI Identifier |
组织唯一标示符 |
Total NVM Capacity |
容量 |
Unallocated NVM Capacity |
未分配容量 |
Controller ID |
控制器ID |
NVMe Version |
NVME版本 |
Number of Namespaces |
命名空间数量 |
Namespace n Size/Capacity |
命名空间n容量 |
Namespace n Formatted LBA Size |
命名空间n LBA大小 |
Firmware Updates |
支持的firmware slots数量 |
Optional Admin Commands |
支持的可选Admin命令 |
Optional NVM Commands |
支持的可选NVM命令 |
Log Page Attributes |
支持的log page |
Maximum Data Transfer Size |
单个命令最大传输大小 |
Warning Comp. Temp. Threshold |
过热警告温度 |
Critical Comp. Temp. Threshold |
过热临界温度 |
其余字段和硬盘型号、硬盘厂商有关,需要结合硬盘手册或者厂家FAE支持进行翻译。
display environment命令用来显示设备上温度传感器的温度信息。
context-admin
context-operator
slot slot-number:显示IRF中指定成员设备上的温度传感器的温度信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示的是IRF中所有温度传感器的温度信息。不指定该参数时,显示所有成员设备的对应信息。
本命令仅缺省Context支持。
# 显示设备上所有温度传感器的温度信息。
<Sysname> display environment
System Temperature information (degree centigrade):
Slot Sensor Temperature LowerLimit Warning-UpperLimit Alarm-UpperLimit Shutdown-UpperLimit
1 inflow 1 39 0 60 70 NA
1 outflow 1 64 0 80 92 NA
表1-8 display environment命令显示信息描述表
System Temperature information (degree centigrade) |
系统温度信息,单位为摄氏度 |
sensor |
温度传感器 · hotspot:表示热点温度传感器 · inflow:表示入风口温度传感器 · outflow:表示出风口温度传感器 |
Slot |
当显示数字时表示指定slot上温度传感器的温度信息 |
Temperature |
当前温度 |
LowerLimit |
低温告警门限。当显示为NA时,表示不支持该门限 |
Warning-UpperLimit |
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限 |
Alarm-UpperLimit |
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限 |
Shutdown-UpperLimit |
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭。当显示为NA时,表示不支持该门限 |
display fabric utilization命令用来显示接口板上交换芯片的通道利用率信息。
display fabric utilization [ slot slot-number ]
display fabric utilization [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上交换芯片的通道利用率信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。
仅缺省Context支持本命令。
# 显示接口板上交换芯片的通道利用率信息。
<System> display fabric utilization slot 2
Input Output
Chs Slot Chan Speed Usage Peak Usage Peak
0 2 0 10G 0% 0% 08:13:14 2012/10/30 0% 0% 08:13:14 2012/10/30
0 2 1 10G 0% 0% 08:13:14 2012/10/30 0% 0% 08:13:14 2012/10/30
0 2 2 10G 0% 0% 08:13:14 2012/10/30 0% 0% 08:13:14 2012/10/30
0 2 3 10G 0% 0% 08:13:14 2012/10/30 0% 0% 08:13:14 2012/10/30
表1-9 display fabric utilization命令显示信息描述表
Chs |
取值为0,无实际意义 Chassis的缩写,为设备在IRF中的成员编号 |
Slot |
单板所在的槽位号 |
Chan |
Channel的缩写,通道号 |
Speed |
通道的速率 |
Input |
入方向的统计数据 |
Output |
出方向的统计数据 |
Usage |
通道利用率 |
Peak |
通道利用率峰值以及峰值发生的时间 |
display fan命令用来显示风扇的工作状态。
display fan [ slot slot-number [ fan-id ] ]
context-admin
context-operator
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有风扇。
fan-id:表示设备内置风扇的编号。不指定该参数时,表示指定位置的所有风扇。
本命令仅缺省Context支持。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
SLOT 1 Fan 0 Status: Normal Speed:9500
SLOT 1 Fan 1 Status: Normal Speed:9500
SLOT 1 Fan 2 Status: Normal Speed:9500
表1-10 display fan命令显示信息描述表
SLOT 1 |
设备的成员编号 |
Fan 0 |
设备上风扇的编号 |
Status |
风扇状态: · Absent:风扇不在位 · Normal:风扇正常工作 · Fault:风扇故障 · FanDirectionFault:用户期望的风道方向与风扇框的实际风道方向不一致 |
Speed |
风扇速率 |
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息。
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息,包括各种故障对应的修复操作,以及系统中每个单板最近十次故障修复的历史信息。
硬件故障检测和修复的历史信息保存在主用主控板上,即使某个槽位单板已拔出或者更换过,只要在主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。
硬件故障检测和修复的历史信息保存在本地主用主控板上,即使某个槽位单板已拔出或者更换过,只要在本地主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当本地主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。
仅缺省Context支持本命令。
# 查看设备的硬件故障检测和故障修复信息。
<Sysname> display hardware-failure-detection
Current level:
chip : isolate
board : isolate
forwarding : warning
Recent record:
--------------------------Slot 0 executed records:-----------------------------
There is no record.
--------------------------Slot 0 trapped records:-----------------------------
There is no record.
表1-11 display hardware-failure-detection命令显示信息描述表
Current level |
当前故障检测对应的修复操作 |
chip : |
器件类故障对应的修复操作 |
board : |
单板类故障对应的修复操作 |
forwarding : |
转发类故障对应的修复操作 |
Recent record: |
最近记录 |
Slot n executed records: |
主控板n上记录的各个单板的历史操作记录 |
Chassis n, Slot m executed records: |
成员设备n主控板m上记录的各个单板的历史操作记录 |
Slot n trapped records: |
主控板n上记录的各个单板的trap告警信息 |
Chassis n, Slot m trapped records: |
成员设备n主控板m上记录的各个单板的trap告警信息 |
display hardware-failure-protection命令用来显示设备上硬件故障保护的配置信息。
display hardware-failure-protection [ aggregation | port { auto-down | interface-type interface-number } ]
context-admin
context-operator
aggregation:显示聚合组的硬件故障保护配置信息。
port:显示端口硬件故障保护的配置信息。
auto-down:显示已配置端口硬件故障保护的端口列表。
interface-type interface-number:显示指定端口上硬件故障保护的配置信息。
如果不带参数,则显示设备上所有硬件故障保护的配置信息,包括是否配置了针对聚合组的硬件故障保护和所有配置了端口硬件故障保护的端口列表。
如要显示非缺省Context下的以太网接口硬件故障保护的配置信息,需要登录对应的Context,再执行此命令。
# 显示设备上所有硬件故障保护的配置信息。
<Sysname> display hardware-failure-protection
Aggregation: on
Port: GE1/0/1 GE1/0/2
# 显示配置了端口硬件故障保护的端口列表。
<Sysname> display hardware-failure-protection port auto-down
# 显示端口GE1/0/2是否配置了硬件故障保护。
<Sysname> display hardware-failure-protection port gigabitethernet 1/0/2
Auto-down is NOT allowed while hardware-failure happened.
表1-12 display hardware-failure-protection命令显示信息描述表
Aggregation |
显示是否配置了针对聚合组的硬件故障保护功能。取值为: · on:表示针对聚合组的硬件故障保护功能处于开启状态 · off:表示针对聚合组的硬件故障保护功能处于关闭状态 |
Port: |
显示配置了端口硬件故障保护的端口列表 |
display memory命令用来显示内存使用情况。
context-admin
context-operator
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。
cpu cpu-number:表示CPU编号。
登录Context后执行该命令,会显示该Context可使用的内存的使用情况。
当显示信息中某一行所有参数的取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 显示设备的内存使用情况的详细信息。
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 984560 456128 528432 0 4 45616 53.7%
-/+ Buffers/Cache: 410508 574052
Swap: 0 0 0
# 显示设备的内存使用情况的简要信息。
<Sysname> display memory summary
Slot CPU Total Used Free Buffers Caches FreeRatio
1 0 984560 456128 528432 4 45616 53.7%
表1-13 display memory命令显示信息描述表
Memory statistics are measured in KB: |
系统内存使用情况,以下统计信息均以KB为单位 |
Mem |
内存使用信息 |
Total |
系统可分配的物理内存的大小 设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销以及ISSU功能运行等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小 |
Used |
整个系统已用的物理内存大小 |
Free |
整个系统可用的物理内存大小 |
Shared |
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值 |
Buffers |
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值 |
Cached |
高速缓冲寄存器已使用的内存大小。取值为“--”时,表示不支持统计该参数的值 |
Caches |
高速缓冲寄存器已使用的内存大小 |
FreeRatio |
整个系统物理内存的空闲率 |
-/+ buffers/cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小 -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小 |
Swap |
交换分区的使用信息 |
display memory dma命令用来显示DMA内存的使用情况。
display memory dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示指定Master设备。
cpu cpu-number:表示CPU的编号。
# 显示slot1的DMA内存使用相关信息。
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total Used Free FreeRatio
16384 6140 10244 63%
表1-14 display memory dma 命令显示信息描述表
DMA memory statistics measured in KB |
系统使用DMA内存情况,单位为KB |
Total |
内存分片的总个数,为Free和Used之和 |
Used |
系统已使用的DMA内存大小 |
Free |
系统可使用的DMA内存大小 |
FreeRatio |
Free与Total的比率,可以反映系统DMA内存的空闲率 |
display memory-threshold命令用来显示内存告警门限相关信息。
context-admin
context-operator
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示主设备。
仅缺省Context支持本命令。
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 95%
Free-memory thresholds:
Minor: 397M
Severe: 318M
Critical: 238M
Normal: 477M
Early-warning: 556M
Secure: 636M
Current memory state: Normal
Event statistics:
[Back to normal state]
First notification: 0.0
Latest notification: 0.0
Total number of notifications sent: 0
[Enter minor low-memory state]
First notification at: 0.0
Latest notification at: 0.0
[Back to minor low-memory state]
[Enter severe low-memory state]
[Back to severe low-memory state]
[Enter critical low-memory state]
表1-15 display memory-threshold命令显示信息描述表
Memory usage threshold |
内存利用率阈值 |
Free-memory thresholds |
剩余内存门限阈值,包括: · Minor:一级告警门限,单位为MB · Severe:二级告警门限,单位为MB · Critical:三级告警门限,单位为MB · Normal:恢复到正常状态的阈值,单位为MB · Early-warning:预告警门限,单位为MB · Secure:预告警恢复门限,单位为MB |
Current free-memory state |
系统当前内存使用状态: · Normal:正常状态 · Minor:一级告警门限状态 · Severe:二级告警门限状态 · Critical:三级告警门限状态 · Normal (early-warning):预告警状态 · Normal (secure):安全状态 |
Free-memory event statistics: |
门限事件统计信息,事件分为: · Back to secure state:恢复到预警前的状态 · Entered early-warning state:进入预告警门限状态 · Back to normal state:内存恢复到正常状态 · Entered minor alarm state:进入一级告警门限状态 · Back to minor alarm state:恢复到一级告警前的状态 · Entered severe alarm state:进入二级告警门限状态 · Back to severe alarm state:恢复到二级告警前的状态 · Entered critical alarm state:进入三级告警门限状态 |
First notification at |
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification at |
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notifications send |
事件发生的总次数 |
display memory-threshold dma命令用来显示DMA内存告警相关信息。
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
# 显示DMA内存告警相关信息。
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
Critical: 2048KB
Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
[Entered to critcal state]
表1-16 display memory-threshold dma 命令显示信息描述表
Free DMA memory thresholds: Critical: Normal: |
DMA内存告警阈值(单位为KB): · Critical:告警阈值 · Normal:告警恢复阈值 |
Current DMA memory state |
DMA内存的当前状态: · Critical:告警状态 · Normal:正常状态 |
Free memory event statistics: |
告警事件统计信息,事件分为: · Back to normal state:内存恢复到正常状态 · Entered to critcal state:进入告警状态 |
First notification |
告警事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification |
告警事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notifications sent |
告警事件发生的总次数 |
display power命令用来显示设备电源的信息。
display power [ slot slot-number [ power-id ] ]
context-admin
context-operator
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有电源。
power-id:表示电源模块的编号。不指定该参数时,表示指定位置的所有电源。
本参数的取值范围为0~1。
本命令仅缺省Context支持。
# 显示设备电源的简要信息。
<Sysname> display power
Slot 1 Power 0 Status: Absent
Slot 1 Power 1 Status: Normal
表1-17 display power命令显示信息描述表
Power |
设备上的电源模块编号 |
Status |
电源模块的状态 · Absent:电源不在位 · Normal:电源正常工作 · Faulty:电源故障 · NoSupport:不支持电源 |
display scheduler job命令用来显示Job的配置信息。
context-admin
context-operator
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
context-admin
context-operator
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name : shutdown
Schedule name : shutdown
Execution time : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[Sysname-if-range]shutdown
表1-18 display scheduler logfile命令显示信息描述表
Logfile Size |
Schedule日志文件的大小,单位为字节 |
Job name |
Job的名称 |
Schedule name |
Schedule的名称 |
Execution time |
开始执行Job的时间 |
Completion time |
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息) |
Job output |
Job中的命令执行时的输出信息 |
· reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
context-admin
context-operator
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
· scheduler reboot at
· scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
context-admin
context-operator
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type : Run once after 0 hours 2 minutes
Start time : Tue Dec 27 10:44:42 2015
Last execution time : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts : 1
Job name Last execution status
shutdown Successful
表1-19 display scheduler schedule命令显示信息描述表
Schedule name |
Schedule的名称 |
Schedule type |
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息 |
Start time |
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息 |
Last execution time |
Schedule上一开始执行的时间 · 如果没有为Schedule配置执行时间,则不会显示该信息 · 如果还没有执行,则显示Yet to be executed |
Last completion time |
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息 |
Execution counts |
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息 |
Job name |
Schedule下关联的Job的名称 |
Last execution status |
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看) · Successful:表示执行成功 · Failed:表示执行失败 · Waiting:表示正在等待被执行 · In process:表示正在执行 · -NA-:表示还没有到执行时间 |
display switchover命令用来显示主备倒换的相关信息。
display switchover
display switchover [ chassis chassis-number ]
context-admin
context-operator
chassis chassis-number:显示指定成员设备上主备倒换相关信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。
# 显示主备倒换的相关信息。
<Sysname> display switchover
Index Date Master Cause
1 14:09:32 07/26 1/0 PlugOut
2 14:12:22 07/26 1/1 Reset
表1-20 display switchover命令显示信息描述表
Index |
记录的主备倒换事件的序号 |
Date |
主备倒换发生的时间 |
Master |
主备倒换完成后的主主控的槽位 |
Cause |
主备倒换的原因。取值为: · PlugOut:表示单板拔出 · Reset:表示单板重启 |
display system stable state命令用来显示系统的稳定状态。
display system stable state [ context { context-id | all } ]
context-admin
context-operator
context { context-id | all }:显示指定或所有Context的系统稳定状态。context-id表示Context的编号,关于context的取值范围及相关介绍,请参见“虚拟化技术命令参考”中的“Context” 。
不指定context参数时,显示系统的稳定状态。
在进行ISSU升级或主备倒换前,请先执行该命令,检查设备是否处于稳定状态。如果System State未处于Stable状态,不能进行ISSU升级;如果Redundancy Stable未处于Stable状态,不能进行主备倒换。
设备/Context启动需要一定的时间,才能达到Stable状态。如果设备/Context长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备/Context,根据其具体状态,采取进一步措施。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
· 通过display device命令查看设备是否处于故障状态。
· 通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
· 通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统的稳定状态。
<Sysname> display system stable state
System state : Stable
Redundancy state: No redundancy
Slot CPU Role State
1 0 Active Stable
表1-21 display system stable state命令显示信息描述表
System state |
系统状态: · Stable:稳定运行 · Not ready:未稳定,此时不能进行ISSU升级 |
Redundancy state |
主备状态: · Stable:主备状态稳定,可以倒换 · No redundancy:系统无冗余,不能倒换 · Not ready:未稳定,不可以倒换 |
Role |
成员设备在系统中的身份: · Active:主设备 · Standby:备设备,提供冗余备份 |
State |
成员设备状态: · Stable:成员设备稳定运行 · Board inserted:成员设备加入 · Kernel initiating:成员设备内核初始化 · Service starting:成员设备上的服务正在启动 · Service stopping:成员设备上的服务正在关闭 · HA Batch backup:HA批量备份中 · Interface data batch backup:接口管理批量备份未完成 · Context starting:Context正在启动 · Context stopping:Context正在关闭 |
当前对象处于未稳定状态 |
· display context(虚拟化技术命令参考/Context)
· display device
· display ha service-group(可靠性命令参考/进程分布优化)
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
context-admin
context-operator
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-22 SFP/SFP+的display transceiver alarm命令输出信息描述表
RX loss of signal |
接收信号丢失 |
RX power high |
接收光功率高 |
RX power low |
接收光功率低 |
TX fault |
发送错误 |
TX bias high |
偏置电流高 |
TX bias low |
偏置电流低 |
TX power high |
发送光功率高 |
TX power low |
发送光功率低 |
Temp high |
温度高 |
Temp low |
温度低 |
Voltage high |
电压高 |
Voltage low |
电压低 |
Transceiver info I/O error |
模块信息读写错误 |
Transceiver info checksum error |
模块信息校验和错误 |
Transceiver type and port configuration mismatch |
模块类型和端口配置不匹配 |
Transceiver type not supported by port hardware |
端口不支持该模块类型 |
# 显示接口GigabitEthernet1/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver current alarm information:
RX loss of signal
RX power low
表1-23 display transceiver alarm显示信息描述表
transceiver current alarm information |
接口光模块当前故障告警信息 |
RX loss of signal |
接收信号丢失 |
RX power low |
接收光功率低告警 |
context-admin
context-operator
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver diagnostic information:
Temp(°C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
Temp(℃) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
表1-24 display transceiver diagnosis显示信息描述表
transceiver diagnostic information |
接口插入的光模块的数字诊断信息 |
Current diagnostic parameters |
当前的诊断参数 |
Temp.(°C) |
数字诊断参数——温度,单位为°C,精确到1°C |
Voltage(V) |
数字诊断参数——电压,单位为V,精确到0.01V |
Bias(mA) |
数字诊断参数——偏置电流,单位为mA,精确到0.01mA |
RX power(dBm) |
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm |
TX power(dBm) |
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm |
Alarm thresholds |
告警门限 |
High |
高告警门限 |
Low |
低告警门限 |
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
context-admin
context-operator
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet1/0/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver information:
Transceiver Type : 1000_BASE_SX_SFP
Connector Type : LC
Wavelength(nm) : 850
Transfer Distance(m) : 550(50um),270(62.5um)
Digital Diagnostic Monitoring : YES
Vendor Name : H3C
Ordering Name : SFP-GE-SX-MM850
表1-25 display transceiver interface显示信息中光学参数统计信息描述表
Transceiver Type |
光模块的类型 |
Connector Type |
光连接器的类型 |
Wavelength(nm) |
· 对于光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块(例如10GBASE-LX4模块),各个波长值之间用逗号分隔 · 对于电模块:显示为“N/A” |
Transfer Distance(xx) |
传输距离,对于单模模块,xx显示为km,其他模块xx显示为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称: · 9um:表示9/125um单模光纤 · 50um:表示50/125um OM2多模光纤 · 62.5um:表示62.5/125um OM1多模光纤 · CX4:表示CX4电缆 · OM3:表示50um OM3多模光纤 · OM4:表示50um OM4多模光纤 · OM5:表示50um OM5多模光纤 · STACK:表示堆叠线 · TP:表示双绞线 |
Digital Diagnostic Monitoring |
对数字诊断功能的支持情况,其中: · YES:表示支持数字诊断 · NO:表示不支持数字诊断 |
Vendor Name |
模块生产或定制厂商名称 |
Ordering Name |
可插拔接口模块的对外型号 |
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
context-admin
context-operator
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet1/0/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver manufacture information:
Manu. Serial Number : 213410A0000054000251
Manufacturing Date : 2017-09-01
Vendor Name : H3C
表1-26 display transceiver manuinfo显示信息中光学参数统计信息描述表
Manu. Serial Number |
光模块的序列号 |
Manufacturing Date |
光模块的生产日期 |
Vendor Name |
光模块定制厂商的名称 |
display version命令用来显示系统版本信息。
display version
context-admin
context-operator
# 查看系统版本信息。
<Sysname> display version
H3C Comware Software, Version 7.1.064, Ess 8524P08
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath T5020 uptime is 0 weeks, 0 days, 5 hours, 11 minutes
Last reboot reason: User reboot
Boot image: cfa0:/t5000ips-cmw710-boot-E8524P08.bin
Boot image version: 7.1.064, Ess 8524P08
Compiled Jun 11 2018 16:00:00
System image: cfa0:/t5000ips-cmw710-system-E8524P08.bin
System image version: 7.1.064, Ess 8524P08
显示信息略……。
表1-27 display version命令显示信息描述表
H3C Comware Software, Version 7.1.064, Ess 8524P08 |
表示设备使用的软件版本 |
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved. |
表示设备的版权申明 |
H3C SecPath T5020 uptime is 0 weeks, 0 days, 5 hours, 11 minutes |
表示设备的型号以及本次启动后的持续运行时间 |
Last reboot reason |
表示设备上次重启的原因,主要取值有: · User reboot:表示用户通过命令行、SNMP等方式重启设备 · Cold reboot:表示断电导致的重启 · Kernel abnormality reboot:表示内核异常导致的重启 · DeadLoop reboot:表示内核死循环导致的重启 · DEV HandShake reboot:表示设备管理握手失败导致的重启 · SlaveSwitch reboot:表示主备倒换导致的重启 · IRF Merge reboot:表示IRF合并重启本设备 · Auto Update reboot:表示版本自动升级导致的重启 |
Boot image: cfa0:/t5000ips-cmw710-boot-E8524P08.bin Boot image version: 7.1.064, Ess 8524P08 Compiled Jun 11 2018 16:00:00 |
表示设备当前运行过程中使用的Boot包以及该软件包的版本、编译时间 |
display version-update-record命令用来显示启动软件包版本更新操作的记录。
仅缺省Context支持本命令。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1 (updated on Apr 18 2015 at 06:23:54):
*Name : boot-test.bin
Version : 7.1.070 Test 0001
Compile time: Mar 25 2015 15:52:43
*Name : system-test.bin
表1-28 display version-update-record命令显示信息描述表
Record n (updated on Apr 18 2014 at 06:23:54) |
最近的第n次更新的时间,Record 1为最新的一次更新 |
*Name |
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化 |
Version |
软件包的版本号 |
Compile time |
版本编译时间 |
· reset version-update-record
display xbar命令用来显示主控板的负载模式。
display xbar
display xbar [ chassis chassis-number ]
chassis chassis-number:用来显示指定成员设备上主用主控板和备用主控板的负载模式。chassis-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的对应信息。
仅缺省Context支持本命令。
配置的负载模式和当前运行的负载模式不一定相同。只有主用主控板和备用主控板同时在位时,配置的负载分担模式才会生效;否则,即便配置了负载分担模式,主用主控板也会自动切换到独立负载模式。
# 显示设备主用主控板和备用主控板的负载模式。
<Sysname> display xbar
The configured system HA xbar load mode is BALANCE
The activated system HA xbar load mode is SINGLE
以上显示信息表明:当前系统配置的负载模式为负载分担模式,但实际生效的是独立负载模式。
· xbar
downlink-mode命令用来配置下行链路的工作模式。
undo downlink-mode命令用来恢复缺省情况。
downlink-mode { 10g | 20g } slot slot-number
undo downlink-mode slot slot-number
下行链路工作在10G模式。
10g:配置下行链路工作在10G模式。
20g:配置下行链路工作在20G模式。
仅缺省Context支持本命令。
设备的下行链路有多种工作模式,但有些下行设备只有10G模式和20G模式。且下行链路和下行设备无法自动协商工作模式,此时,需要用户根据实际情况手动配置。
配置该命令后,设备上所有下行链路都会工作在这个模式。如果配置为20G模式,则要求下行链路和下行设备都具有20G的转发能力,否则,可能会发生丢包。
哪些接口对应的链路属于下行链路与设备的型号有关,请以设备的实际情况为准。
# 配置下行链路工作在10G模式。
[Sysname] downlink-mode 10g slot 1
Set the downlink mode successfully. Please reboot the device to make the setting take effect.
fan auto-control-mode命令用来配置风扇的工作模式。
undo fan auto-control-mode命令用来恢复缺省情况。
fan auto-control-mode { low-temperature | silence }
fan auto-control-mode chassis chassis-number { low-temperature | silence }
undo fan auto-control-mode chassis chassis-number
风扇工作在低温模式。
context-admin
chassis chassis-number:表示设备在IRF中的成员编号。
low-temperature:配置风扇工作在低温模式。该模式下风扇转速较高,以便优先保证单板在较低的温度下工作。
silence:配置设备工作在静音模式。该模式下风扇转速较低、噪音较小,但是单板温度比低温模式略高。在对噪音比较敏感的场合推荐使用此模式。
# 配置风扇工作在静音模式。
[Sysname] fan auto-control-mode silence
hardware-failure-protection aggregation命令用来开启针对聚合组的硬件故障保护功能。
undo hardware-failure-protection aggregation命令用来关闭针对聚合组的硬件故障保护功能。
针对聚合组的硬件故障保护功能处于关闭状态。
只有配置hardware-failure-detection forwarding isolate命令后,该命令才生效。
配置该命令后,当系统检测到硬件故障时,会按顺序遵循如下原则处理:
· 如果聚合组成员端口配置undo hardware-failure-protection auto-down命令,而且该端口不是聚合组中最后一个UP状态的端口,则该端口会被自动关闭;
· 如果聚合组成员端口配置undo hardware-failure-protection auto-down命令,而该端口是聚合组中最后一个UP状态的端口,则该端口不会被关闭;
· 如果聚合组成员端口配置了hardware-failure-protection auto-down命令,则不管该端口是不是聚合组中最后一个UP状态的端口,该端口都会被关闭。
出现以下任意一种情况时,hardware-failure-protection aggregation命令会对聚合组中的该成员端口失效:
· 端口下配置了以太网接口环回测试功能,即loopback { external | internal }命令;
· 端口下配置了以太网接口的强制开启功能,即port up-mode命令;
· 该端口配置为IRF物理端口。
仅缺省ContextC支持本命令。
# 开启针对聚合组的硬件故障保护功能。
[Sysname] hardware-failure-protection aggregation
· hardware-failure-detection
· hardware-failure-protection auto-down
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { incoming | legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
context-admin
incoming:配置Modem登录用户登录进入用户视图时的欢迎信息。如果要求认证,则欢迎信息在通过认证后输出。
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
context-admin
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
· scheduler job
· scheduler schedule
locator blink blink-time命令用来定位设备的位置。
locator blink stop命令用来停止定位。
locator [ slot slot-number ] blink blink-time
locator [ slot slot-number ] blink stop
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示对所有设备进行操作。
blink-time:闪烁的持续时间,取值范围为5~120,单位为秒。
stop:停止闪烁。
仅缺省Context支持本命令。
配置locator blink blink-time命令后,指定设备上用于定位的LED灯会以间隔快闪的方式闪烁,并持续指定的时间。用户可根据LED灯的指示来定位设备所在的位置。
blink-time时间到或者执行locator blink stop命令,则定位闪烁的LED灯会恢复正常点亮状态。
# 开始定位。
<Sysname> locator blink 30
# 结束定位。
<Sysname> locator blink stop
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
memory-threshold [ slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
不同设备空闲内存告警的门限值可能不同,请先使用undo memory-threshold命令恢复缺省情况后,再通过display memory-threshold命令查看设备的缺省空闲内存告警门限。
ratio:表示以百分比形式配置门限。不指定该参数时,表示配置的是门限的大小,单位为MB。
minor minor-value:一级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
severe severe-value:二级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
critical critical-value:三级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小。输入该参数的值时可通过输入?,来获取该参数的取值范围。
仅缺省Context支持本命令。
系统实时监控系统剩余空闲内存大小,当条件达到一级、二级、三级告警门限或者恢复正常状态门限时,就产生相应的告警/告警解除通知,通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
除了一级、二级、三级告警,设备还支持预告警功能。预告警门限用于内存使用率尚处于正常范围内,但需要提醒用户提前关注内存的情况。预告警恢复门限用于解除预告警。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当系统剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
· display memory-threshold
memory-threshold dma命令用来配置DMA(Direct Memory Access,直接内存存取)内存告警阈值。
undo memory-threshold dma命令用来恢复缺省情况。
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
本命令的缺省情况与设备的型号有关,请以设备的实际情况为准。
ratio:以百分比配置阈值。
critical critical-value:告警阈值。当指定ratio参数时,critical-value为百分比,取值范围为0~100;当不指定ratio参数时,critical-value单位为KB,不同型号的设备取值范围不同,请以设备的实际情况为准 。
normal normal-value:告警恢复阈值。当指定ratio参数时,normal-value为百分比;当不指定ratio参数时,normal-value单位为KB。设备会根据critical-value的配置值自动调整normal-value的取值范围,请以设备的实际情况为准。
部分业务的运行需要使用DMA内存,如果DMA内存不足,会导致业务模块功能异常。系统周期监控DMA空闲内存大小:当DMA空闲内存小于或等于告警阈值,产生告警事件,表示DMA内存可能不足;当DMA空闲内存大于告警恢复阈值,产生告警解除事件,表示DMA内存充足。
# 配置Slot 1的DMA内存告警的阈值为32KB,告警恢复阈值为96KB。
[Sysname] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
仅缺省Context支持本命令。
系统每隔1分钟会对内存利用率进行采样,当采样值大于或等于用户配置的内存利用率阈值时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
context-admin
slot slot-number:表示设备在IRF中的成员编号,不指定表示主设备。
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
· display cpu-usage configuration
· display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
CPU利用率历史记录采样周期为1分钟。
context-admin
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage logging命令用来开启周期性输出CPU利用率日志功能。
undo monitor cpu-usage logging命令用来关闭周期性输出CPU利用率日志功能。
monitor cpu-usage logging slot slot-number cpu cpu-number interval interval-time
undo monitor cpu-usage logging slot slot-number cpu cpu-number
周期性输出CPU利用率日志功能处于关闭状态。
context-admin
interval interval-time:周期性输出CPU利用率日志的时间间隔,取值为5的整数倍,取值范围为5~300,单位为秒。
# 开启slot 1上0号CPU周期性输出CPU利用率日志信功能,且时间间隔为5秒。
[Sysname] monitor cpu-usage logging slot 1 cpu 0 interval 5
monitor cpu-usage statistics-interval core命令用来配置CPU核利用率的统计周期。
undo monitor cpu-usage statistics-interval core命令用来恢复缺省情况。
monitor cpu-usage statistics-interval interval slot slot-number cpu cpu-number core core-id-list
undo monitor cpu-usage statistics-interval slot slot-number cpu cpu-number core core-id-list
CPU核利用率的统计周期为60秒。
context-admin
interval:CPU核利用率信息的统计周期,取值范围为10~3600,单位为秒。配置的统计周期建议是采样周期的整数倍,采样周期是5秒,不是整数倍时,实际生效统计周期为最接近配置值、但小于配置值的、采样周期整数倍。例如,采样周期是5秒,配置统计周期为12秒,则实际生效的统计周期是10秒。
core-id-list:表示CPU核的编号列表。表示方式为core-id-list = { core-id1 [ to core-id2 ] }&<1-10>,core-id2的值要大于或等于core-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
系统按5秒周期对CPU核的利用率进行采样,然后对统计周期内的采样值进行计算,并将计算值和用户配置的CPU核利用率的阈值比较。当计算值大时,则认为CPU核利用率过高,设备会发送告警信息并记录日志。
# 配置产生告警的CPU利用率指定core平均时长为60秒。
[Sysname] monitor cpu-usage statistics-interval 60 slot 1 cpu 0 core 0
· monitor cpu-usage threshold core
· monitor resend cpu-usage core-interval
monitor cpu-usage threshold命令用来配置CPU利用率告警门限。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
monitor cpu-usage threshold severe-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ]
CPU利用率告警门限为70%,CPU利用率恢复门限为30%。
context-admin
severe-threshold:CPU利用率高级别告警门限,取值范围为2~100,单位为百分比。
recovery-threshold recovery-threshold:CPU利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为利用率过高,设备会进行相应的处理。
# 配置CPU利用率高级别告警门限为90%,恢复门限为70%。
[Sysname] monitor cpu-usage threshold 90 recovery-threshold 70
monitor cpu-usage threshold core命令用来配置CPU核利用率告警门限。
undo monitor cpu-usage threshold core命令用来恢复缺省情况。
monitor cpu-usage threshold severe-threshold slot slot-number cpu cpu-number core core-id-list
undo monitor cpu-usage threshold slot slot-number cpu cpu-number core core-id-list
CPU核利用率告警门限为100。
context-admin
severe-threshold:CPU核利用率告警门限,取值范围为2~100,单位为百分比。
当threshold severe-threshold参数值配置为100时,表示关闭CPU核利用率告警功能。此时,即CPU核利用率达到100%,设备不会发送告警信息,也不会记录日志。
当指定threshold severe-threshold参数但未指定recovery-threshold recovery-threshold参数时,CPU核利用率恢复门限值为threshold severe-threshold参数值的80%。如果指定recovery-threshold recovery-threshold参数,则CPU核利用率恢复门限值以实际配置的为准。
# 配置CPU核0利用率告警门限为90%。
[Sysname] monitor cpu-usage threshold 90 slot 1 cpu 0 core 0
· monitor cpu-usage statistics-interval core
monitor memory-usage logging命令用来开启周期性输出内存利用率日志功能。
undo monitor memory-usage logging命令用来关闭周期性输出内存利用率日志功能。
monitor memory-usage logging slot slot-number cpu cpu-number interval interval-time
undo monitor memory-usage logging slot slot-number cpu cpu-number
周期性输出内存利用率日志功能处于关闭状态。
context-admin
interval interval-time:周期性输出内存利用率日志的时间间隔,取值为5的整数倍,取值范围为5~300,单位为秒。
# 开启slot 1上0号CPU周期性输出内存利用率日志信功能,且时间间隔为5秒。
[Sysname] monitor memory-usage logging slot 1 cpu 0 interval 5
monitor resend cpu-usage core-interval命令用来配置发送CPU核告警的间隔。
undo monitor resend cpu-usage core-interval命令用来恢复缺省情况。
monitor resend cpu-usage core-interval core-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ slot slot-number [ cpu cpu-number ] ]
发送CPU核告警的间隔为300。
context-admin
core-interval:CPU核告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
# 配置设备上所有CPU核发送告警事件的间隔为60秒。
[Sysname] monitor resend cpu-usage core-interval 60
monitor resend memory-threshold dma命令用来配置发送DMA内存告警事件的间隔。
undo monitor resend memory-threshold dma命令用来恢复缺省情况。
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
critical-interval:DMA内存告警事件周期发送的间隔,取值范围为10~3600,单位为秒。
设备定期对DMA内存使用率进行统计,并将统计值与告警门限进行比较。当统计值从小于或等于变成大于告警门限时,DMA内存将进入该告警状态并生成告警事件。
# 配置发送DMA内存告警事件的间隔为100秒。
[Sysname] monitor resend memory-threshold dma critical-interval 100
monitor resource-usage { bridge-aggregation | route-aggregation } threshold命令用来配置聚合接口数的告警阈值。
undo monitor resource-usage { bridge-aggregation | route-aggregation } threshold命令用来恢复缺省情况。
monitor resource-usage { bridge-aggregation | route-aggregation } threshold threshold-value
未配置聚合接口的告警阈值,不会触发告警。
context-admin
bridge-aggregation:表示对可创建的二层聚合接口数设置告警阈值。
route-aggregation:表示对可创建的三层聚合接口数设置告警阈值。
threshold-value:表示可创建聚合接口数的告警阈值,取值范围为1~4294967295。
配置此功能后,当设备上创建的二层聚合接口或三层聚合接口的数量达到告警阈值时,则输出告警信息。之后每3小时输出一次告警,直到设备上创建的二层聚合接口或三层聚合接口的数量低于告警阈值后,才停止输出告警。
# 配置二层聚合接口数的告警阈值为100。
[Sysname] monitor resource-usage bridge-aggregation threshold 100
# 配置三层聚合接口数的告警阈值为150。
[Sysname] monitor resource-usage route-aggregation threshold 150
monitor resource-usage bandwidth inbound threshold命令用来配置整机入方向带宽的告警阈值。
undo monitor resource-usage bandwidth inbound threshold命令用来恢复缺省情况。
monitor resource-usage bandwidth inbound threshold threshold-value [ duration duration-value ]
未配置整机入方向带宽的告警阈值,不会触发告警。
threshold-value:表示整机入方向带宽的告警阈值,取值范围为1~4294967295,单位为Mbps。
duration duration-value:表示整机入方向流量超过告警阈值的持续时间。duration-value是持续时间,取值范围为5~300,必须是5的倍数,单位为秒,缺省值为300秒。
当入方向流量在持续时间内一直大于或等于带宽告警阈值,则输出告警,且之后会每5秒输出一次告警;直到入方向流量低于带宽告警阈值后,才停止输出告警。
此命令仅缺省Context支持,非缺省Context不支持。
# 配置整机入方向带宽告警的阈值为1024Mbps,持续时间为60秒。
[Sysname] monitor resource-usage bandwidth inbound threshold 1024 duration 60
monitor resource-usage blade-controller-team context命令用来开启安全引擎组中Context个数告警功能。
undo monitor resource-usage blade-controller-team context命令用来关闭安全引擎组中Context个数告警功能。
安全引擎组中Context个数告警功能处于关闭状态。
开启此功能后,设备会按周期监测每个安全引擎组中的Context个数:
· 当某个安全引擎组中Context个数从小于变成大于等于一级告警阈值时,设备会立即输出该安全引擎组的一级告警并进入一级告警状态。若该安全引擎组一直处于一级告警状态,为避免告警频繁,后续一级告警会每6小时输出一次,直到该安全引擎组进入二级告警状态或者一级告警状态解除。
· 当某个安全引擎组中Context个数从小于变成大于等于二级告警阈值时,设备会立即输出该安全引擎组的二级告警并进入二级告警状态。若该安全引擎组一直处于二级告警状态,为避免告警频繁,后续二级告警会每6小时输出一次,直到该安全引擎组二级告警状态解除。
· 若某个安全引擎组处于二级告警状态,当Context个数降至二级阈值以下时,则解除二级告警状态,输出二级告警解除日志。
· 若某个安全引擎组处于一级告警状态,当Context个数降至一级阈值以下时,则解除一级告警状态,输出一级告警解除日志。
一级阈值和二级阈值在设备出厂时已固定,不支持修改,可从告警信息中查看。
# 开启安全引擎组中Context个数告警监控功能。
[Sysname] monitor resource-usage blade-controller-team context
monitor resource-usage context threshold命令用来配置Context个数的告警阈值。
undo monitor resource-usage context threshold命令用来恢复缺省情况。
monitor resource-usage context threshold threshold-value
未配置Context个数的告警阈值,不会触发告警。
threshold-value:表示可创建的Context个数的告警阈值,取值范围为1~4294967295。
配置此功能后,当设备上新建Context的数量达到告警阈值时,则输出告警信息。之后每6小时输出一次告警,直到设备上新建Context的数量低于告警阈值后,才停止输出告警。
# 配置Context数的告警阈值为16。
[Sysname] monitor resource-usage context threshold 16
monitor resource-usage session-count threshold命令用来配置会话连接数的告警阈值。
undo monitor resource-usage session-count threshold命令用来恢复缺省情况。
monitor resource-usage session-count [ slot slot-number ] threshold threshold-value
undo monitor resource-usage session-count [ slot slot-number ] threshold
未配置会话连接数的告警阈值,不会触发告警。
context-admin
threshold-value:表示会话连接数的告警阈值,取值范围为1~4294967295。
配置此功能后,当设备上的会话连接数达到告警阈值时,则输出告警信息。之后每10分钟输出一次告警,直到会话连接数低于告警阈值后,才停止输出告警。
# 配置整机会话连接数的告警阈值为100000。
[Sysname] monitor resource-usage session-count threshold 100000
monitor resource-usage session-rate threshold命令用来配置会话新建速率的告警阈值。
undo monitor resource-usage session-rate threshold命令用来恢复缺省情况。
monitor resource-usage session-rate [ slot slot-number ] threshold threshold-value
undo monitor resource-usage session-rate [ slot slot-number ] threshold
未配置会话新建速率的告警阈值,不会触发告警。
context-admin
threshold-value:表示会话新建速率的告警阈值,取值范围为1~4294967295。
配置此功能后,当设备上的会话新建速率达到告警阈值时,则输出告警信息。之后每10分钟输出一次告警,直到会话新建速率低于告警阈值后,才停止输出告警。
多次执行此命令,可以为不同的成员设备或单板配置会话新建速率的告警阈值。
# 配置会话新建速率的告警阈值为500。
[Sysname] monitor resource-usage session-rate threshold 500
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
仅缺省Context支持本命令。
清除认证密码的操作必须在主设备的启动过程中进入BootWare菜单进行。
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见设备的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
power-supply off命令用来强制给单板断电。
power-supply off slot slot-number [ subslot subslot-number ]
power-supply off chassis chassis-number slot slot-number [ subslot subslot-number ]
slot slot-number:表示单板所在的槽位号。
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。
subslot subslot-number:表示子卡所在的子槽位号。不指定该参数时,表示所有子卡。
强制给单板下电后,单板将无法收发报文,请谨慎使用。
仅缺省Context支持本命令。
如果设备电量不足,且某些接口板处于空闲状态或者连接的为非关键网络节点时,可以手工停止给这些接口板供电,以便节约电能保证给重要接口板供电。
请先开启电源管理功能,再配置本命令。否则,本命令配置失败。
在IRF中,当最后一个处于up状态的IRF物理端口都位于某接口板上时,不允许强制给该接口板断电,以免导致IRF分裂。
# 强制给指定slot的单板断电。
<Sysname> power-supply off slot 2
· power-supply policy enable
power-supply on命令用来手工给单板供电。
power-supply on slot slot-number [ subslot subslot-number ]
power-supply on chassis chassis-number slot slot-number [ subslot subslot-number ]
仅缺省Context支持本命令。
# 手工给指定slot的单板供电。
<Sysname> power-supply on slot 2
power-supply policy priority命令用来配置单板的供电优先级。
undo power-supply policy priority命令用来恢复缺省情况。
power-supply policy slot slot-number priority priority
undo power-supply policy slot slot-number priority
power-supply policy chassis chassis-number slot slot-number priority priority
undo power-supply policy chassis chassis-number slot slot-number priority
priority:单板的供电优先级,不同型号的设备支持的取值范围不同,请以设备的实际情况为准。本参数值越小表示单板的供电优先级越高。
仅缺省Context支持本命令。
请根据实际组网应用,将正在处理或将要处理重要业务的单板的优先级值减小,以便在系统供电不足或者电力恢复时,优先保证对该单板的供电。
开启电源管理功能后,本命令才会生效。
# 配置指定slot的单板的供电优先级为10。
[Sysname] power-supply policy slot 2 priority 10
reboot命令用来重启设备。
context-admin
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,会重启整个IRF。
cpu cpu-number:CPU的编号。不指定cpu和subslot参数时,会重启slot。
force:强制重启:
· 不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
· 指定该参数时,系统将不进行任何检查,直接执行重启操作。
· 重新启动可能会导致业务中断,请谨慎使用该命令。
· 使用force参数时,系统在重启时不会做任何保护性措施。重启后,可能导致文件系统损坏,请谨慎使用该参数。建议在系统故障或无法正常重启时,才使用该参数。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
重启主设备时,如果备设备不存在,会重启整个IRF;如果备设备存在并稳定运行,会引起主备倒换。当系统中有成员设备处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响IRF和成员设备的运行。可使用display system stable state命令来显示IRF的稳定状态。
# 重启设备,并保存配置文件。
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
· display system stable state
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
· display scheduler logfile
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
仅缺省Context支持本命令。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
· display version-update-record
restore factory-default命令用来将设备恢复到出厂状态。
使用本命令会将设备恢复到出厂状态,请谨慎使用。
仅缺省Context支持本命令。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data, and forcibly reboot the system. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait....Done.
The system is rebooting...
· reboot
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
context-admin
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
· command
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
context-admin
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
context-admin
time:设备重启的时间,格式为HH:MM。HH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
· YYYY的取值范围为2000~2035;
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
本命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
· 配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
· 配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot at、scheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2015年6月6日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
context-admin
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
· 使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2015年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
context-admin
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1) 使用scheduler job命令创建Job。
(2) 在Job视图下,使用command命令配置需要执行的命令。
(3) 使用scheduler schedule命令创建Schedule。
(4) 在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5) 在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6) 在Schedule视图下,使用time at、time once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
· job
· time at
· time once
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
context-admin
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动检测端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
在开启环路检测功能或生成树协议的网络中,某些协议模块会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。在协议自动关闭端口的同时,系统会启动一个检测端口状态的定时器。如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,系统自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
· 若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
· 若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
switch-fabric isolate命令用来将网板从转发平面隔离出去,所有数据流量都不经过指定网板。
undo switch-fabric isolate命令用来取消对网板的隔离。
switch-fabric isolate slot slot-number [ channel channel-number ]
undo switch-fabric isolate slot slot-number [ channel channel-number ]
switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
undo switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
网板处于转发平面,数据流量会经过网板进行转发。
context-admin
slot slot-number:表示网板所在的槽位号。
channel channel-number:表示网板上数据通道的编号。不指定该参数时,表示隔离指定网板。
· 每块网板都有一定的转发带宽,隔离一块网板后会减少相应的转发带宽,使设备整体转发带宽降低。请根据需要配置。
· 当设备上仅存在一块网板时,请不要隔离该网板。
· 请先根据板卡情况人工判断设备是否能进行网板隔离。
本命令不支持对主控板进行隔离。
该命令主要用于定位网板是否能够正常转发,以及更换网板前,为避免报文丢失,可配置本命令。网板隔离后仍能与主控板正常通信,控制平面上协议报文的解析与协议的计算等功能均不受影响,从而保证取消隔离后可以快速恢复网板的转发能力。
网板隔离期间不要重启设备。
网板隔离后,请使用undo switch-fabric isolate命令对该网板取消隔离,网板才能恢复正常转发功能。
# 将10号槽位的网板隔离。
[Sysname] switch-fabric isolate slot 10
The command will isolate the switch fabric from the system. Continue? [Y/N]y
switch-fabric removal-signal-suppression命令用来抑制上报网板中断信号。
undo switch-fabric removal-signal-suppression命令用来恢复缺省情况。
不抑制上报网板中断信号。
context-admin
配置本命令后,网板拔出时可能会有流量丢包,导致业务中断,请谨慎使用。
正常情况下,网板拔出前,会触发一次中断信号。系统收到中断信号后会将网板的业务迁移到其他网板上,以便网板拔出的时候,不影响当前业务。当硬件故障或者受到信号干扰等异常情况下,网板可能频繁触发中断信号,导致设备需要不停处理该中断信号,甚至异常。为规避这种情况,可以使用本功能强制设备不处理网板中断信号,将影响减到最低。
# 抑制上报网板中断信号。
[Sysname] switch-fabric removal-signal-suppression
sysid命令用来配置设备的网元信息。
undo sysid命令用来恢复缺省情况。
sysid system-id
undo sysid
未配置设备的网元信息。
context-admin
system-id:表示设备的网元信息,可用于表示设备的位置信息、功能信息、用户自定义的名字标记等。
# 配置网元信息为position-hall,表明设备位置在大厅。
[Sysname] sysid positon-hall
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为NEC。
context-admin
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
temperature-limit slot slot-number { hotspot | inflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
不同温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
context-admin
slot slot-number:配置指定成员设备上温度传感器的温度门限。slot-number表示设备在IRF中的成员编号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
sensor-number:温度传感器的编号,输入该参数的值时可通过输入?,来获取该参数的取值范围。
lowlimit:低温告警门限,单位为摄氏度。不同温度传感器的低温告警门限取值范围不同,输入该参数的值时可通过输入?,来获取该参数的取值范围。
warninglimit:一般级高温告警门限,单位为摄氏度,必须大于低温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
alarmlimit:严重级高温告警门限,单位为摄氏度,必须大于一般级高温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
本命令仅缺省Context支持。
# 配置指定slot上热点1号温度传感器,低温门限为-10摄氏度,一般级高温门限为50摄氏度,严重级高温门限为60摄氏度。
[sysname] temperature-limit slot 1 hotspot 1 -10 50 60
· display environment
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
context-admin
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time at、time once或time repeating命令时,最后一次执行的命令生效。
# 配置2015年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
context-admin
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
context-admin
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
· 使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
transceiver third-party alarm enable命令用来开启第三方可插拔接口模块的告警信息开关。
undo transceiver third-party alarm enable命令用来关闭第三方可插拔接口模块的告警信息开关。
第三方可插拔接口模块的告警信息开关处于开启状态。
仅缺省MDC支持本命令。
设备根据光模块中记录的厂商信息来判断对应接口上插入的光模块的厂商是不是第三方。如果是第三方,则会输出Trap和Log信息提醒用户,要求用户更换成H3C的光模块,以便管理和维护光模块。用户可使用display transceiver manuinfo命令查看光模块的厂商信息。
# 开启第三方可插拔接口模块的告警信息开关。
[Sysname] transceiver third-party alarm enable
· display transceiver manuinfo
transceiver phony-alarm-disable命令用来关闭可插拔接口模块告警信息开关。
undo transceiver phony-alarm-disable命令用来恢复缺省情况。
可插拔接口模块告警信息开关处于开启状态。
仅缺省Context支持本命令。
设备根据光模块中记录的厂商信息来判断对应接口上插入的光模块的厂商是不是HPE。如果不是HPE,则会输出Trap和Log信息提醒用户,要求用户更换成HPE的光模块,以便管理和维护光模块。用户可使用display transceiver manuinfo命令查看光模块的厂商信息。
而HPE早期销售的光模块,可能没有记录厂商信息,为了保护用户投资,这样的光模块还能继续正常使用,但仍会输出Trap和Log信息。此时,可使用本命令,停止输出相关信息。
# 关闭可插拔接口模块告警信息开关。
[Sysname] transceiver phony-alarm-disable
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
context-admin
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、context-admin、context-operator、level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
# 配置执行定时任务test时使用的用户角色为rolename。
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
· command
xbar命令用来配置主控板的负载模式。
xbar { load-balance | load-single }
xbar chassis chassis-number { load-balance | load-single }
主控板的负载模式为load-balance。
chassis chassis-number:用来配置指定成员设备上主用主控板和备用主控板的负载模式。chassis-number表示设备在IRF中的成员编号。
load-balance:设备的主用主控板和备用主控板共同参与报文的处理和转发。
load-single:只有主用主控板能处理和转发报文,备用主控板仅备份主用主控板的数据、监控主用主控板的状态。
仅缺省Context支持本命令。
当设备上只有一块主控板时,只支持load-single模式,即便配置了load-balance模式,主控板也会自动切换到load-single模式。
# 配置主用主控板和备用主控板的负载模式为load-balance。
[Sysname] xbar load-balance
· display xbar
