16-IPoE命令
本章节下载: 16-IPoE命令 (870.00 KB)
1.1.1 display ip subscriber interface-leased
1.1.2 display ip subscriber interface-leased statistics
1.1.3 display ip subscriber offline statistics
1.1.4 display ip subscriber session
1.1.5 display ip subscriber session statistics
1.1.6 display ip subscriber subnet-leased
1.1.7 display ip subscriber subnet-leased statistics
1.1.9 ip subscriber access-user log enable
1.1.10 ip subscriber dhcp domain
1.1.11 ip subscriber dhcp max-session
1.1.12 ip subscriber dhcp password option60
1.1.13 ip subscriber dhcp username
1.1.16 ip subscriber initiator dhcp enable
1.1.17 ip subscriber initiator unclassified-ip enable
1.1.18 ip subscriber interface-leased
1.1.19 ip subscriber nas-port-id format
1.1.20 ip subscriber nas-port-id nasinfo-insert
1.1.21 ip subscriber nas-port-type
1.1.23 ip subscriber service-identify
1.1.24 ip subscriber session static
1.1.25 ip subscriber subnet-leased
1.1.26 ip subscriber timer quiet
1.1.27 ip subscriber timer traffic
1.1.29 ip subscriber unclassified-ip domain
1.1.30 ip subscriber unclassified-ip ip match
1.1.31 ip subscriber unclassified-ip max-session
1.1.32 ip subscriber unclassified-ip username
1.1.33 ip subscriber user-detect
1.1.35 ip subscriber whitelist enable
1.1.36 reset ip subscriber offline statistics
1.1.37 reset ip subscriber session
1.2.1 display ipv6 subscriber interface-leased
1.2.2 display ipv6 subscriber interface-leased statistics
1.2.3 display ipv6 subscriber offline statistics
1.2.4 display ipv6 subscriber session
1.2.5 display ipv6 subscriber session statistics
1.2.6 display ipv6 subscriber subnet-leased
1.2.7 display ipv6 subscriber subnet-leased statistics
1.2.9 ipv6 subscriber access-user log enable
1.2.10 ipv6 subscriber dhcp domain
1.2.11 ipv6 subscriber dhcp max-session
1.2.12 ipv6 subscriber dhcp password option16
1.2.13 ipv6 subscriber dhcp username
1.2.16 ipv6 subscriber initiator dhcp enable
1.2.17 ipv6 subscriber initiator ndrs enable
1.2.18 ipv6 subscriber initiator unclassified-ip enable
1.2.19 ipv6 subscriber interface-leased
1.2.20 ipv6 subscriber nas-port-id format
1.2.21 ipv6 subscriber nas-port-id nasinfo-insert
1.2.22 ipv6 subscriber nas-port-type
1.2.23 ipv6 subscriber ndrs domain
1.2.24 ipv6 subscriber ndrs max-session
1.2.25 ipv6 subscriber ndrs username
1.2.26 ipv6 subscriber password
1.2.27 ipv6 subscriber service-identify
1.2.28 ipv6 subscriber session static
1.2.29 ipv6 subscriber subnet-leased
1.2.30 ipv6 subscriber timer quiet
1.2.31 ipv6 subscriber timer traffic
1.2.33 ipv6 subscriber unclassified-ip domain
1.2.34 ipv6 subscriber unclassified-ip max-session
1.2.35 ipv6 subscriber unclassified-ip username
1.2.36 ipv6 subscriber user-detect
1.2.38 ipv6 subscriber whitelist enable
1.2.39 reset ipv6 subscriber offline statistics
1.2.40 reset ipv6 subscriber session
display ip subscriber interface-leased命令用来显示IPv4 IPoE接口专线用户信息。
display ip subscriber interface-leased [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的IPv4 IPoE接口专线用户信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv4 IPoE接口专线用户信息。
slot slot-number:显示指定成员设备上的IPv4 IPoE接口专线用户信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv4 IPoE接口专线用户信息。
# 显示接口GigabitEthernet1/0/1上的IPv4 IPoE接口专线用户信息。
<Sysname> display ip subscriber interface-leased interface gigabitethernet 1/0/1
Basic:
Access interface : GE1/0/1
VPN instance : N/A
Username : a
User ID : 0x30000000
State : Online
Service node : Slot 1 CPU 0
Domain : radius
Login time : May 14 20:04:42 2014
Online time (hh:mm:ss) : 00:16:37
AAA:
IP pool : ipoe
Session idle time : N/A
Session duration : N/A, remaining: N/A
Remaining traffic : N/A
Max multicast addresses : 4
Multicast address list : N/A
QoS:
User profile : h3c (active)
Session group profile : N/A
Inbound CAR : CIR 100kbps PIR 200kbps CBS 500bit (active)
Outbound CAR : CIR 300kbps PIR 400kbps CBS 500bit (active)
Flow statistic:
Uplink packets/bytes : 0/0
Downlink packets/bytes : 0/0
ITA:
Level-1 Uplink packets/bytes: 0/0
Downlink packets/bytes: 0/0
Level-2 Uplink packets/bytes: 0/0
表1-1 display ip subscriber interface-leased命令显示信息描述表
Basic |
IPoE会话的基本信息 |
Access interface |
用户所在的接口名称 |
VPN instance |
用户所属的MPLS L3VPN实例,N/A表示用户属于公网 |
Username |
用户认证时使用的用户名 |
User ID |
用户ID,只有用户在线后才会由系统分配,0xffffffff表示暂未分配 |
State |
用户状态: · Init:初始化 · Offline:正在下线 · Auth:认证中 · AuthFail:认证失败 · AuthPass :认证通过 · AssignedIP:用户已具备IP地址 · Online:用户在线 · Backup:备份状态,表示该用户是由对端备份到本端的 |
Service node |
为用户提供认证服务的节点信息 |
Domain |
认证使用的认证域名 |
Login time |
用户登录时间,即用户授权成功的时间,格式为设备时间,如:MM-DD hh:mm:ss YYYY |
Online time (hh:mm:ss) |
用户本次上线的在线时长 |
AAA |
IPoE会话的AAA授权信息 |
IP pool |
AAA授权的DHCP地址池名称,N/A表示AAA未授权该属性 |
Session idle time |
用户闲置切断时间,单位为秒,N/A表示不进行闲置切断 |
Session duration |
AAA授权的IPoE会话超时时间,单位为秒 · N/A:表示未下发会话时长 · Unlimited:表示会话时长无限制 |
remaining |
AAA授权的IPoE会话剩余时长 · 当AAA未授权IPoE会话超时时间时,该字段始终显示为N/A · 当AAA授权IPoE会话超时时间时 ¡ 如果用户通过三层以太网接口/三层以太网子接口上线,该字段始终显示具体的剩余时长或Unlimited(表示会话时长无限制) ¡ 如果用户通过三层聚合接口/三层聚合子接口上线,则只有在本命令中指定Service node所在的slot或接口时,才会显示具体的剩余时长或Unlimited(表示会话时长无限制),否则显示为N/A |
Remaining traffic |
授权的剩余流量,单位为字节,N/A表示未对用户指定授权流量 |
Max multicast addresses |
AAA授权用户可加入的组播组的最大数目 |
Multicast address list |
AAA授权用户可加入的组播组地址列表,N/A表示AAA未授权该属性 |
QoS |
IPoE会话的QoS信息 |
Session group profile |
AAA授权的Session Group Profile名称。若未授权Session Group Profile,则显示为N/A。授权状态包括如下: · active:AAA授权Session Group Profile成功 · inactive:AAA授权Session Group Profile失败或者设备上不存在该Session Group Profile · 授权结果未知 |
Inbound CAR |
入方向CAR值(CIR:入方向平均速率,单位为kbps;PIR:入方向峰值速率,单位为kbps;CBS:入方向突发尺寸,单位为bit) 若未授权CAR,则显示为N/A。授权状态包括如下: · active:表示入方向CAR限速下发成功 · inactive:表示入方向CAR限速下发失败 |
Outbound CAR |
出方向CAR值(CIR:出方向平均速率,单位为kbps;PIR:出方向峰值速率,单位为kbps;CBS:出方向突发尺寸,单位为bit) 若未授权CAR,则显示为N/A。授权状态包括如下: · active:表示出方向CAR限速下发成功 · inactive:表示出方向CAR限速下发失败 |
Flow statistic |
IPoE会话的流量统计信息 |
Uplink packets/bytes |
上行流量报文数/字节数 |
Downlink packets/bytes |
下行流量报文数/字节数 |
ITA |
IPoE会话的ITA(Intelligent Target Accounting,智能靶向计费)业务流量统计信息 |
Level-n Uplink packets/bytes |
计费等级为n的上行流量报文数/字节数,n的取值范围为1~8 |
计费等级为n的下行流量报文数/字节数,n的取值范围为1~8 |
· ip subscriber enable
display ip subscriber interface-leased statistics命令用来显示IPv4 IPoE接口专线用户统计信息。
display ip subscriber interface-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的IPv4 IPoE接口专线用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPv4 IPoE接口专线用户已经上线和正在上线的统计信息。
slot slot-number:显示指定成员设备上的IPv4 IPoE接口专线用户统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv4 IPoE接口专线用户统计信息。
# 显示设备上IPv4 IPoE接口专线用户统计信息。
<Sysname> display ip subscriber interface-leased statistics
Total : 100
Init : 0
Authenticating : 20
Authenticate fail : 0
Authenticate pass : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-2 display ip subscriber interface-leased statistics命令显示信息描述表
Total |
接入的总用户数 |
Init |
处于初始状态的用户数 |
Authenticating |
处于正在认证状态的用户数 |
Authenticate fail |
处于认证失败状态的用户数 |
Authenticate pass |
处于认证成功状态的用户数 |
Assigned IP |
处于拥有IP地址状态的用户数 |
Online |
处于在线状态的用户数 |
Backup |
处于备份状态的用户数 |
display ip subscriber offline statistics命令用来显示IPv4 IPoE用户下线原因的统计信息。
display ip subscriber offline statistics [ interface interface-type interface-number ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上IPoE用户下线原因的统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPoE用户下线原因的统计信息。
# 显示接口GigabitEthernet1/0/1上IPv4 IPoE用户下线原因的统计信息。
<Sysname> display ip subscriber offline statistics interface gigabitethernet 1/0/1
Total : 100
User request : 0
DHCP lease expire : 0
AAA lease expire : 0
Command cut : 80
AAA terminate : 0
Authorization fail : 0
Idle timeout : 10
Detect fail : 10
Not enough resource : 0
Interface down : 0
Interface shutdown : 0
VSRP event : 0
DHCP notify : 0
Other : 0
表1-3 display ip subscriber offline statistics命令显示信息描述表
Total |
下线的总用户数 |
User request |
用户主动要求下线的用户数 |
DHCP lease expire |
DHCP租约到期正常下线的用户数 |
AAA lease expire |
AAA租约到期正常下线的用户数 |
Command cut |
通过命令行下线的用户数 |
AAA terminate |
AAA强制下线的用户数 |
Authenticate fail |
认证失败的用户数 |
Authorization fail |
授权失败的用户数 |
Idle timeout |
用户空闲超时下线的用户数 |
Detect fail |
在线探测失败下线的用户数 |
Not enough resource |
硬件资源不足下线的用户数 |
Interface down |
因接口状态为down下线的用户数 |
Interface shutdown |
主动shutdown接口导致下线的用户数 |
VSRP event |
收到VSRP(Virtual Service Redundancy Protocol,虚拟业务冗余协议) 事件通知而下线的用户数 |
DHCP notify |
DHCP通知下线的用户数 |
Other |
其它状况触发下线的用户数 |
· reset ip subscriber offline statistics
display ip subscriber session命令用来显示IPv4 IPoE个人会话信息。
display ip subscriber session [ interface interface-type interface-number ] [ domain domain-name | ip ip-address [ vpn-instance vpn-instance-name ] | mac mac-address | static | username name ] [ slot slot-number ] [ verbose ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的IPv4 IPoE个人会话,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv4 IPoE个人会话。
domain domain-name:显示使用指定ISP域认证的IPv4 IPoE个人会话,domain-name为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。
ip ip-address:显示指定源IP地址的IPv4 IPoE个人会话,ip-address为指定的IP地址。
vpn-instance vpn-instance-name:指定用户所属的VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示IPv4个人 IPoE会话位于公网中。
mac mac-address:显示指定源MAC地址的IPv4 IPoE个人会话,形式为H-H-H。
static:显示静态配置的IPv4 IPoE个人会话,不指定该参数时将显示静态配置的IPv4 IPoE个人会话和动态触发创建的IPv4 IPoE个人会话。
username name:显示指定用户名的IPv4 IPoE个人会话,其中,name为1~255个字符的字符串,区分大小写。
slot slot-number:显示指定成员设备上的IPv4 IPoE个人会话,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv4 IPoE个人会话。
verbose:显示IPv4 IPoE个人会话的详细信息。如果不指定该参数,则只显示IPoE会话的简要信息。
# 显示用户IP为1.1.1.1,所属VPN实例为vpn1的IPv4 IPoE会话简要信息。
<Sysname> display ip subscriber session ip 1.1.1.1 vpn-instance vpn1
Type: D-DHCP S-Static U-Unclassified-IP
Interface IP address MAC address Type State
GE1/0/1 1.1.1.1 000d-88f8-0eab D Online
# 显示所有IPv4 IPoE个人会话的详细信息。
<Sysname> display ip subscriber session verbose
Basic:
Description : -
Username : abc
Domain : radius
VPN instance : N/A
IP address : 1.1.1.1
MAC address : 000d-88f8-0eab
Service-VLAN/Customer-VLAN : -/-
User ID : 0x380800b5
DHCP lease : N/A
DHCP remain lease : N/A
Login time : May 9 08:56:29 2014
Type : Static
State : Online
AAA:
IP pool : N/A
QoS:
User profile : abc (active)
Flow statistic:
Uplink packets/bytes : 594341/76075648
ITA:
Level-1 Uplink packets/bytes: 66038/8452864
Level-2 Uplink packets/bytes: 66038/8452864
表1-4 display ip subscriber session命令显示信息描述表
Basic |
IPoE会话的基本信息 |
IPoE会话的描述信息(“-”表示没有描述信息) |
Username |
用户认证时使用的用户名 |
Domain |
用户认证时使用的认证域名 |
VPN instance |
IP address |
用户的IP地址 |
MAC address |
用户的MAC地址 |
Service-VLAN/Customer-VLAN |
用户所在的公网VLAN/私网VLAN(“-”表示没有VLAN信息) |
Access interface |
用户接入的接口名称 |
User ID |
DHCP lease |
DHCP服务器分配给用户的IP地址租约时间,单位为秒 · N/A:表示无DHCP租约 · Unlimited:表示租约无限长 |
DHCP remain lease |
DHCP服务器分配给用户的IP地址租约剩余时长 只在Service node上可以查看到有效的剩余时长,非Service node上该字段显示为N/A |
Login time |
用户本次上线的在线时长 |
Service node |
为用户提供认证服务的节点信息 |
Type |
IPoE会话的创建类型: · DHCP:DHCP报文触发创建 · Unclassified-IP:未知源IP报文触发创建 · Static:静态配置 |
State |
用户状态: · Init:初始化 · Offline:正在下线中 · Auth:认证中 · AuthFail:认证失败 · AuthPass:认证通过 · AssignedIP:会话已具备IP地址 · Online:用户在线 · Backup:备份状态,表示该用户是由对端备份到本端的 |
AAA |
IPoE会话的AAA授权信息 |
IP pool |
Session idle time |
Session duration |
AAA授权的IPoE会话超时时间,单位为秒 · N/A:表示未授权会话时长 · Unlimited:表示会话时长无限制 |
remaining |
Remaining traffic |
QoS |
IPoE会话的QoS信息 |
User profile |
AAA授权的User Profile名称。若未授权User Profile,则显示为N/A。授权状态包括如下: · active:AAA授权User Profile成功 · inactive:AAA授权User Profile失败或者设备上不存在该User Profile · 授权结果未知 |
Inbound CAR |
Outbound CAR |
Flow statistic |
IPoE会话的流量统计信息 |
上行流量报文数/字节数 |
下行流量报文数/字节数 |
ITA |
display ip subscriber session statistics命令用来显示IPv4 IPoE个人用户统计信息。
display ip subscriber session statistics [ session-type { dhcp | static | unclassified-ip } ] [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
session-type:用户上线类型。不指定该参数,则表示显示所有类型的IPv4 IPoE个人用户统计信息。
dhcp:表示DHCP用户。
static:表示静态个人用户。
unclassified-ip:表示未知源IP用户。
interface interface-type interface-number:显示指定接口上的IPv4 IPoE个人用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上已经上线和正在上线的IPv4 IPoE个人用户统计信息。
slot slot-number:显示指定成员设备上的IPv4 IPoE个人用户统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv4 IPoE个人用户统计信息。
# 显示接口GigabitEthernet1/0/1上的IPv4 IPoE个人用户统计信息。
<Sysname> display ip subscriber session statistics session-type dhcp interface gigabitethernet 1/0/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-5 display ip subscriber session statistics命令显示信息描述表
Total |
接入的总用户数 |
Init |
处于初始状态的用户数 |
Authenticating |
处于正在认证状态的用户数 |
Authenticate fail |
处于认证失败状态的用户数 |
Authenticate pass |
处于认证成功状态的用户数 |
Assigned IP |
处于成功分配到IP地址状态的用户数 |
Online |
处于在线状态的用户数 |
Backup |
处于备份状态的用户数 |
· reset ip subscriber session
display ip subscriber subnet-leased命令用来显示IPv4 IPoE子网专线用户信息。
display ip subscriber subnet-leased [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的IPv4 IPoE子网专线用户信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv4 IPoE子网专线用户信息。
slot slot-number:显示指定成员设备上的IPv4 IPoE子网专线用户信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv4 IPoE子网专线用户信息。
# 显示接口GigabitEthernet1/0/1上的IPv4 IPoE子网专线用户信息。
<Sysname> display ip subscriber subnet-leased interface gigabitethernet 1/0/1
Basic:
VPN instance : N/A
Username : a
Network : 11.11.11.0/24
User ID : 0x30000001
State : Online
Domain : radius
Login time : May 14 20:08:35 2014
AAA:
IP pool : N/A
QoS:
User profile : cc (active)
Flow statistic:
ITA:
表1-6 display ip subscriber subnet-leased命令显示信息描述表
Basic |
IPoE会话的基本信息 |
Access interface |
用户所在的接口名称 |
VPN instance |
User name |
用户认证时使用的用户名 |
Network |
用户所在的子网地址 |
User ID |
State |
用户的认证状态 · Init:初始化 · Offline:正在下线中 · Auth:认证中 · AuthFail:认证失败 · AuthPass:认证通过 · AssignedIP:会话已具备IP地址 · Online:用户在线 · Backup:备份状态,表示该用户是由对端备份到本端的 |
Service node |
为用户提供认证服务的节点信息 |
Domain |
用户认证时使用的认证域名 |
Login time |
用户本次上线的在线时长 |
AAA |
IPoE会话的AAA授权信息 |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
IPoE会话的QoS信息 |
Inbound CAR |
Outbound CAR |
Flow statistic |
IPoE会话的流量统计信息 |
上行流量报文数/字节数 |
下行流量报文数/字节数 |
ITA |
display ip subscriber subnet-leased statistics命令用来显示IPv4 IPoE子网专线用户统计信息。
display ip subscriber subnet-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的IPv4 IPoE子网专线用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPv4 IPoE用户已经上线和正在上线的子网专线统计信息。
slot slot-number:显示指定成员设备上的IPv4 IPoE子网专线用户统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv4 IPoE子网专线用户统计信息。
# 显示接口GigabitEthernet1/0/1上的IPv4 IPoE子网专线用户统计信息。
<Sysname> display ip subscriber subnet-leased statistics interface gigabitethernet 1/0/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-7 display ip subscriber subnet-leased statistics命令显示信息描述表
Total |
接入的总用户数 |
Init |
处于初始状态的用户数 |
Authenticating |
处于正在认证状态的用户数 |
Authenticate fail |
处于认证失败状态的用户数 |
Authenticate pass |
处于认证成功状态的用户数 |
Assigned IP |
处于成功分配到IP地址状态的用户数 |
Online |
处于在线状态的用户数 |
Backup |
处于备份状态的用户数 |
ip subscriber 8021p命令用来配置IPv4接入用户的IP报文的内/外层VLAN tag中的802.1p值与认证域的映射关系。
undo ip subscriber 8021p命令用来删除指定802.1p值与认证域的映射关系。
ip subscriber 8021p 8021p-list domain domain-name
undo ip subscriber 8021p 8021p-list
未配置IPv4接入用户的IP报文的内/外层VLAN tag中的802.1p值与认证域的映射关系。
三层以太网子接口视图/三层聚合子接口视图/VLAN接口视图
context-admin
8021p-list:802.1p值列表,表示一个或多个802.1p值,表示方式为8021p-list = { 8021p-value [ to 8021p-value ] }&<1-8>,其中,8021p-value为指定8021p的编号,取值范围为0~7。&<1-8>表示前面的参数最多可以输入8次。
domain domain-name:表示与指定的8021p范围相关联的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。
本命令用来配置指定802.1p值范围内的IPv4接入用户(包括未知源IP接入用户、静态IPoE接入用户和IPoE子网/接口专线用户)认证时使用的认证域,通过指定的认证域对进行认证、授权、计费。
# 在子接口GigabitEthernet1/0/1.100上配置内层VLAN TAG中802.1p值范围为2到5的IPv4接入用户认证使用的认证域为1pdm。
[Sysname] interface gigabitethernet 1/0/1.100
[Sysname-GigabitEthernet1/0/1.100] ip subscriber service-identify 8021p second-vlan
[Sysname-GigabitEthernet1/0/1.100] ip subscriber 8021p 2 to 5 domain 1pdm
· ip subscriber service-identify
ip subscriber access-user log enable命令用来开启IPv4 IPoE接入用户日志信息功能。
undo ip subscriber access-user log enable命令用来关闭IPv4 IPoE接入用户日志信息功能。
ip subscriber access-user log enable [ successful-login | failed-login | logout [ normal ] [ abnormal ] ] *
undo ip subscriber access-user log enable [ successful-login | failed-login | logout [ normal ] [ abnormal ] ] *
IPv4 IPoE接入用户日志信息功能处于关闭状态。
context-admin
successful-login:表示IPv4 IPoE接入用户上线成功日志功能。
failed-login:表示IPv4 IPoE接入用户上线失败日志功能。
logout:表示IPv4 IPoE接用户下线日志功能。
normal:表示IPv4 IPoE接用户正常下线日志功能。
abnormal:表示IPv4 IPoE接用户异常下线日志功能。
为了防止设备输出过多的IPv4 IPoE日志信息,一般情况下建议不要开启此功能。
IPv4 IPoE接入用户日志是为了满足网络管理员维护的需要,对用户的上线成功、上线失败、正常下线和异常下线的信息进行记录,包括用户名、IP地址、接口名称、两层VLAN、MAC地址、上线失败原因、下线原因等。设备生成的IPv4 IPoE日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
配置本命令时,如果未指定任何参数,将同时开启用户的上线成功、上线失败、正常下线和异常下线日志功能。
通过undo命令关闭日志功能时,如果未指定任何参数,将同时关闭用户的上线成功、上线失败、正常下线和异常下线日志功能。
# 开启IPv4 IPoE接入用户日志信息功能。
[Sysname] ip subscriber access-user log enable
ip subscriber dhcp domain命令用来配置IPv4 DHCP个人接入用户使用的认证域。
undo ip subscriber dhcp domain命令用来恢复缺省情况。
ip subscriber dhcp domain domain-name
IPv4 DHCP个人接入用户的认证域为缺省认证域。
三层以太网接口视图/三层以太网子接口视图/三层聚合接口视图/三层聚合子接口视图/VLAN接口视图
context-admin
domain-name:指定认证使用的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。
本命令用来配置DHCP报文触发接入的IPv4 DHCP个人接入用户在认证时使用的域名,该域名必须在接入设备上存在且配置完整。
· 配置ip subscriber dhcp domain命令后,如果DHCP报文中携带Option 60,Option 60内容符合域名的格式要求,并且接口配置了ip subscriber trust option60命令,则IPoE用户使用Option 60中的信息作为指定的认证域进行认证;否则,使用本命令指定的认证域。
· 如果不配置ip subscriber dhcp domain命令,且DHCP报文中未携带Option 60,则使用缺省认证域认证。
当用户需要将Option 60字段中的信息按字符串形式解析时,请确保Option 60字段内容中不出现字符串结束字符和不可见字符,否则在生成域名时将产生异常。
# 配置接口GigabitEthernet1/0/1上的IPv4 DHCP个人接入用户使用的认证域为ipoe。
[Sysname-GigabitEthernet1/0/1] ip subscriber dhcp domain ipoe
· ip subscriber initiator dhcp enable
· ip subscriber trust
ip subscriber dhcp max-session命令用来配置接口上允许DHCPv4报文触发创建的IPv4 IPoE会话的最大数目。
undo ip subscriber dhcp max-session命令用来恢复缺省情况。
ip subscriber dhcp max-session max-number
未配置接口上允许DHCPv4报文触发创建的IPv4 IPoE会话的最大数目。
context-admin
max-number:允许DHCPv4报文触发创建的IPv4 IPoE会话的最大数目,取值范围为1~64000。
DHCPv4报文触发创建的IPv4 IPoE会话数目达到最大值后,后续DHCPv4报文不能触发创建IPv4 IPoE会话。
# 配置接口GigabitEthernet1/0/1上允许DHCPv4报文触发创建的IPv4 IPoE会话的最大数目为100。
[Sysname-GigabitEthernet1/0/1] ip subscriber dhcp max-session 100
· display ip subscriber session
ip subscriber dhcp password option60命令用来配置IPv4 DHCP个人接入用户使用DHCPv4报文中的Option 60作为认证密码。
undo ip subscriber dhcp password option60命令用来恢复缺省情况。
ip subscriber dhcp password option60 [ offset offset ] [ length length ]
IPv4 DHCP个人接入用户未使用DHCPv4报文中的Option 60作为认证密码。
context-admin
offset offset:表示从Option 60首部偏移指定字节后的内容作为认证密码,offset表示字节偏移量,取值范围为1~63,单位为字节。如果未指定本参数,将从Option 60首部后的内容作为认证密码。
length length:表示从Option 60首部偏移offset所处的位置开始,取指定长度的字节作为认证密码,length表示获取字节的长度,取值范围为1~63,单位为字节。如果未指定本参数,将从Option 60首部偏移offset所处的位置开始取剩余的所有内容作为认证密码。
IPv4 DHCP个人接入用户支持通过多种方式获取认证密码,并按如下优先顺序选择第一个可用的认证密码进行认证:
· 同时满足如下条件时,则使用本命令配置方式获取的密码作为认证密码:
¡ 接口上配置了ip subscriber dhcp password option60命令;
¡ 接口上配置了ip subscriber trust option60命令并且DHCPv4报文中携带的Option 60中内容符合可见字符的格式要求。
· 使用ip subscriber password命令配置的密码作为认证密码。
· 使用缺省字符串vlan作为认证密码。
· ip subscriber dhcp password option60命令用来配置IPv4 DHCP用户在认证时使用的密码,该密码必须与认证服务器上配置的密码保持一致。
· 当用户需要将Option 60字段中的信息作为认证密码时,请确保Option 60字段内容中不出现字符串结束字符和不可见字符,否则在生成用户密码时将产生异常。
# 配置接口GigabitEthernet1/0/1上的IPv4 DHCP个人接入用户使用从Option 60首部偏移10个字节后的20个字节内容作为认证密码。
[Sysname-GigabitEthernet1/0/1] ip subscriber dhcp password option60 offset 10 length 20
· ip subscriber password
· ip subscriber dhcp username
ip subscriber dhcp username命令用来配置IPv4 DHCP个人接入用户的认证用户名的命名规则。
undo ip subscriber dhcp username命令用来恢复缺省情况。
ip subscriber dhcp username include { circuit-id [ separator separator ] | client-id [ separator separator ] | nas-port-id [ separator separator ] | port [ separator separator ] | remote-id [ separator separator ] | second-vlan [separator separator ] | slot [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [separator separator ] | sysname [separator separator ] | vendor-class [ separator separator ] | vendor-specific [ separator separator ] | vlan [separator separator ] } *
IPv4 DHCP个人接入用户使用报文源MAC地址作为认证用户名。
context-admin
circuit-id:表示以DHCP报文中的Option82 sub-option1字段中的信息为用户名。
client-id:表示以DHCP报文中的Option61字段中的信息作为用户名。
nas-port-id:表示以认证报文中的NAS-PORT-ID属性作为用户名。
port:表示以用户接入的端口号作为用户名。
remote-id:表示以DHCP报文中的Option82 sub-option2字段中的信息作为用户名。
second-vlan:表示以认证报文中的内层VLAN作为用户名。
slot:表示以用户接入的槽位号作为用户名。
source-mac:表示以用户报文的源MAC地址作为用户名。
address-separator address-separator:MAC地址分隔符,可以为任意可配置的可见字符。若指定了分隔符,例如“-”,则用户名形如xxxx-xxxx-xxxx;若不指定该参数,则用户名为xxxxxxxxxxxx形式。建议不要使用@作为分隔符,避免携带@字符的用户名在AAA服务器端不能被正确解析。
subslot:表示以用户接入的子卡号作为用户名。
sysname:表示以用户接入设备的设备名作为用户名。
vendor-class:表示以DHCP报文中的Option60字段中的信息作为用户名。
vendor-specific:表示以DHCP报文中的Option82 sub-option9字段中的信息作为用户名。
vlan:表示以认证报文中的外层VLAN作为用户名。
separator separator:当前字段分隔符,用在当前字段后面以连接后面的一个字段,可以为任意可配置的可见字符。建议不要使用@作为分隔符,避免携带@字符的用户名在AAA服务器端不能被正确解析。
该命令用来配置IPv4 DHCP用户在认证时使用的用户名的命名规则,根据该命名规则获取的用户名必须与认证服务器上配置的用户名保持一致。
在允许的用户名类型范围内,该命令支持任意形式、任意顺序的用户名组合。例如:若配置ip subscriber dhcp username include vendor-class vendor-specific,则用户名为Option60字段内容和Option82 sub9字段内容的拼接,且两个字段之间无分隔符。
为保证设备对Option字段中的信息进行正确解析,请确保Option字段内容中不出现字符串结束符和不可见字符,否则可能生成错误的用户名。
# 配置接口GigabitEthernet1/0/1上IPv4 DHCP个人接入用户使用Client Identifier Option字段中的信息作为用户名。
[Sysname-GigabitEthernet1/0/1] ip subscriber dhcp username include client-id
# 配置接口GigabitEthernet1/0/1上IPv4 DHCP个人接入用户使用接入设备的设备名、接入的槽位号、接入的子卡号、接入的端口号和认证报文中的外层VLAN信息作为用户名,所选用的字段之间均使用#作为分隔符。
[Sysname-GigabitEthernet1/0/1] ip subscriber dhcp username include sysname separator # slot separator # subslot separator # port separator # vlan
ip subscriber dscp命令用来配置IPv4接入用户的IP报文的DSCP值与认证域的映射关系。
undo ip subscriber dscp命令用来删除指定DSCP值与认证域的映射关系。
ip subscriber dscp dscp-value-list domain domain-name
undo ip subscriber dscp dscp-value-list
未配置IPv4接入用户的IP报文的DSCP值与认证域的映射关系。
context-admin
dscp-value-list:DSCP值列表,表示一个或多个DSCP的值,表示方式为dscp-value-list = dscp-value [ to dscp-value ] }&<1-8>。其中,dscp-value为指定的DSCP的值,取值范围为0~63。&<1-8>表示前面的参数最多可以输入8次。
domain domain-name:表示与指定的DSCP范围相关联的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。
本命令用来配置指定DSCP范围内的IPv4接入用户(包括未知源IP接入用户、静态IPoE接入用户和IPoE子网/接口专线用户)认证时使用的认证域,通过指定的认证域进行认证、授权、计费。
# 在接口GigabitEthernet1/0/1上配置DSCP值范围为1到4的IPv4接入用户认证使用的认证域为dscpdm。
[Sysname-GigabitEthernet1/0/1] ip subscriber service-identify dscp
[Sysname-GigabitEthernet1/0/1] ip subscriber dscp 1 to 4 domain dscpdm
ip subscriber enable命令用来在接口上开启IPv4 IPoE功能并指定用户的接入模式。
undo ip subscriber enable命令用来关闭接口上的IPv4 IPoE功能。
ip subscriber { l2-connected | routed } enable
undo ip subscriber { l2-connected | routed } enable
接口上的IPv4 IPoE功能处于关闭状态。
context-admin
l2-connected:指定二层接入模式。
routed:指定三层接入模式。
只有在接口上开启了IPv4 IPoE功能后,其它的IPv4 IPoE相关配置才能生效。
不能通过重复执行本命令修改IPoE的接入模式。如需修改IPoE的接入模式,请先通过undo ip subscriber enable命令关闭IPoE功能,再执行ip subscriber enable命令。
# 在接口GigabitEthernet1/0/1上开启二层接入模式的IPv4 IPoE功能。
[Sysname-GigabitEthernet1/0/1] ip subscriber l2-connected enable
ip subscriber initiator dhcp enable命令用来在接口上开启DHCPv4报文触发生成IPv4 IPoE会话的功能。
undo ip subscriber initiator dhcp enable 命令用来关闭接口上DHCPv4报文触发生成IPv4 IPoE会话的功能。
接口上DHCPv4报文触发生成IPv4 IPoE会话的功能处于关闭状态。
context-admin
接口上开启该功能后,收到的首个DHCP Discover报文或直接申请地址的DHCP Request报文会触发生成IPv4 IPoE会话;关闭该功能后,该接口上收到的DHCPv4报文不能触发生成IPv4 IPoE会话,已有的由DHCPv4报文触发生成的IPv4 IPoE会话不会被删除。
接口上可同时配置DHCPv4报文和未知源IPv4报文触发生成IPv4 IPoE会话的功能。
# 在接口GigabitEthernet1/0/1上开启DHCPv4报文触发生成IPv4 IPoE会话的功能。
[Sysname-GigabitEthernet1/0/1] ip subscriber initiator dhcp enable
· ip subscriber initiator unclassified-ip enable
ip subscriber initiator unclassified-ip enable命令用来在接口上开启未知源IPv4报文触发生成IPv4 IPoE会话的功能。
undo ip subscriber initiator unclassified-ip enable命令用来关闭接口上的未知源IPv4报文触发生成IPv4 IPoE会话的功能。
接口上的未知源IPv4报文触发生成IPv4 IPoE会话的功能处于关闭状态。
context-admin
接口开启该功能后,收到的未知源IPv4报文会触发生成IPv4 IPoE会话;关闭该功能后,该接口上收到的未知源IPv4报文不能触发生成IPv4 IPoE会话,已有的由未知源IPv4报文触发生成的IPv4 IPoE会话不会被删除。
# 在接口GigabitEthernet1/0/1上开启未知源IPv4报文触发生成IPv4 IPoE会话的功能。
[Sysname-GigabitEthernet1/0/1] ip subscriber initiator unclassified-ip enable
ip subscriber interface-leased命令用来配置IPv4 IPoE接口专线用户。
undo ip subscriber interface-leased命令用来恢复缺省情况。
ip subscriber interface-leased username name password { ciphertext | plaintext } string [ domain domain-name ]
未配置IPv4 IPoE接口专线用户。
context-admin
username name:指定用户认证时使用的用户名,其中name为1~255个字符的字符串,区分大小写。
password:指定用户认证时使用的密码。
ciphertext:以密文方式设置密码。
plaintext:以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为1~63个字符的字符串,密文密码为1~117个字符的字符串。
domain domain-name:指定认证使用的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。如果未指定该参数,将使用缺省认证域来认证用户。关于缺省认证域的相关配置请参见“安全配置指导”中的“AAA”。
一个IPv4 IPoE接口专线用户代表了该接口接入的所有IPv4用户,接口上接入的所有IPv4用户统一认证、授权和计费。该IPoE专线用户认证成功后,接口上接入的所有IPv4用户流量均允许通过,且共享一个IPv4 IPoE会话,并基于接口进行授权和计费。
· 每个接口只能配置一个IPv4 IPoE接口专线用户,并且不能通过重复执行本命令修改已配置的IPv4 IPoE接口专线用户的username、password或domain参数。如需修改这些参数,请先通过undo ip subscriber interface-leased命令删除已配置的IPv4 IPoE接口专线用户,再执行ip subscriber interface-leased命令。
· 同一接口下,IPoE个人接入用户、IPoE接口专线用户和IPoE子网专线用户的配置互斥,只能选择其中的一种配置。
# 在接口GigabitEthernet1/0/1上配置一个IPv4 IPoE接口专线用户:认证使用的用户名为intuser,认证使用的密码为明文pw123。
[Sysname-GigabitEthernet1/0/1] ip subscriber interface-leased username intuser password plaintext pw123
· display ip subscriber interface-leased
ip subscriber nas-port-id format命令用来配置IPv4 IPoE接入用户进行认证时,接入设备向RADIUS服务器发送的NAS-PORT-ID属性的封装格式。
undo ip subscriber nas-port-id format命令用来恢复缺省情况。
ip subscriber nas-port-id format cn-telecom { version1.0 | version2.0 }
按version 1.0的格式填充RADIUS的NAS-PORT-ID属性。
context-admin
version1.0:封装格式为version 1.0,表示发送给RADIUS服务器的NAS-PORT-ID属性以电信163大后台要求的格式填充。不同接口类型的封装内容形式有所不同,具体请参见表1-8。其中,封装内容中的各参数含义为:
· slot_num:表示BRAS接入接口的槽位号。
· subslot_num:表示BRAS接入接口的子槽位号。
· port_num:表示BRAS接入接口的端口号。
· vlan_id:表示接入用户的VLAN ID。
· inner-vlan:表示接入用户的内层VLAN ID。
· outer-vlan:表示接入用户的外层VLAN ID。
· vpi:表示BRAS接入接口的VPI。
· vci:表示BRAS接入接口的VCI。
表1-8 version 1.0封装格式
接口类型 |
封装内容形式 |
三层以太网接口和三层聚合接口 |
slot=slot_num;subslot=subslot_num;port=port_num;vlanid=0 |
三层以太网子接口和三层聚合子接口(携带单层VLAN Tag接入) |
slot=slot_num;subslot=subslot_num;port=port_num;vlanid=vlan_id |
三层以太网子接口和三层聚合子接口(携带双层VLAN Tag接入) |
slot=slot_num;subslot=subslot_num;port=port_num;vlanid=inner-vlan;vlanid2=outer-vlan |
version2.0:封装格式为version 2.0,表示发送给RADIUS服务器的NAS-PORT-ID属性以YDT 2275-2011宽带接入用户线路(端口)标识要求的格式填充。version 2.0封装格式的内容形式为:{eth|trunk|atm} NAS_slot/NAS_subslot/NAS_port:svlan.cvlan AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port。其中,各字段的含义请参见表1-9:
表1-9 version 2.0封装格式
{eth|trunk} |
表示BRAS接入接口的类型,包括以太接口、trunk类型的以太网接口 |
NAS_slot |
表示BRAS接入接口的槽位号 |
NAS_subslot |
表示BRAS接入接口的子槽位号 |
NAS_port |
表示BRAS接入接口的端口号 |
svlan |
表示接入用户的SVLAN ID |
cvlan |
表示接入用户的CVLAN ID |
AccessNodeIdentifier |
表示接入节点的标识 |
ANI_rack |
表示接入节点机架号 |
ANI_frame |
表示接入节点机框号 |
ANI_slot |
表示接入节点槽位号 |
ANI_subslot |
表示接入节点子槽位号 |
ANI_port |
表示接入节点端口号 |
# 在接口GigabitEthernet1/0/1上配置设备使用version 2.0格式封装RADIUS的NAS-PORT-ID属性。
[Sysname-GigabitEthernet1/0/1] ip subscriber nas-port-id format cn-telecom version2.0
· ip subscriber nas-port-id nasinfo-insert
ip subscriber nas-port-id nasinfo-insert命令用来配置设备提取出DHCPv4报文的Option 82 Circuit-ID子选项内容并和NAS信息一起作为NAS-PORT-ID属性字符串。
undo ip subscriber nas-port-id nasinfo-insert命令用来恢复缺省情况。
如果收到的DHCPv4报文带有Option 82 Circuit-ID子选项,则直接使用该子选项内容作为NAS-PORT-ID属性字符串。
context-admin
在DHCP中继组网环境下,接入设备能捕获用户的DHCPv4报文,并从报文中提取出DHCP Option82 Circuit-ID子选项信息。在配置了NAS-PORT-ID属性的封装格式为version 2.0格式,且信任DHCP Option 82的情况下,若配置了本命令,则接入设备处理如下:
· 如果收到的DHCP报文带有Option82 Circuit-ID子选项,则从收到的DHCP报文中解析Option82 Circuit-ID子选项,并按version 2.0格式要求将提取出的DHCPv4报文的Option 82 Circuit-ID子选项内容和NAS信息一起作为RADIUS的NAS-PORT-ID属性内容。
· 如果收到的DHCP报文不带Option82 Circuit-ID子选项,则按version 2.0格式要求封装,填充NAS-PORT-ID属性中的NAS信息字段(NAS_slot/NAS_subslot/NAS_port:svlan.cvlan),并将AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port部分修改为0/0/0/0/0/0。
本功能对原DHCP报文中Option82子选项不产生任何影响。
# 在接口GigabitEthernet1/0/1上配置设备使用DHCPv4客户端上报的Option82信息,并在其中插入NAS信息,然后将其封装为RADIUS的NAS-PORT-ID属性。
[Sysname-GigabitEthernet1/0/1] ip subscriber nas-port-id nasinfo-insert
· ip subscriber nas-port-id format
ip subscriber nas-port-type命令用来配置接口的IPv4 IPoE接入端口类型。
undo ip subscriber nas-port-type命令用来恢复缺省情况。
ip subscriber nas-port-type { adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax || piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
IPv4 IPoE接入端口类型为Ethernet类型。
context-admin
adsl-cap:ADSL-CAP(Asymmetric DSL,Carrierless Amplitude Phase Modulation)接口类型,对应的编码值为12。
adsl-dmt:ADSL-DMT(Asymmetric DSL,Discrete Multi-Tone)接口类型,对应的编码值为13。
async:Async接口类型,对应的编码值为0。
cable:Cable接口类型,对应的编码值为17。
ethernet:Ethernet接口类型,对应的编码值为15。
g.3-fax:G.3 Fax接口类型,对应的编码值为10。
piafs:符合PIAFS(PHS(Personal Handyphone System)Internet Access Forum Standard)标准的接口类型,对应的编码值为6。
sdsl:SDSL(Symmetric DSL)接口类型,对应的编码值为11。
sync:Sync接口类型,对应的编码值为1。
virtual:Virtual接口类型,对应的编码值为5。
wireless-other:Wireless-other接口类型,对应的编码值为18。
x.25:X.25接口类型,对应的编码值为8。
x.75:X.75接口类型,对应的编码值为9。
xdsl:XDSL(Digital Subscriber Line of unknown type)接口类型,对应的编码值为16。
此处配置的端口接入类型值将作为向RADIUS服务器发送的RADIUS请求报文的NAS-Port-Type属性值,用于向RADIUS服务器正确传递用户的接入端口信息。
# 配置接口GigabitEthernet1/0/1的IPv4 IPoE接入端口类型为SDSL。
[Sysname-GigabitEthernet1/0/1] ip subscriber nas-port-type sdsl
ip subscriber password命令用来配置IPv4 IPoE个人接入用户的认证密码。
undo ip subscriber password命令用来恢复缺省情况。
ip subscriber password { ciphertext | plaintext } string
IPv4 IPoE个人接入用户的认证密码为字符串vlan。
context-admin
ip subscriber password命令用来配置IPv4 IPoE个人接入用户(包括动态和静态IPoE个人接入用户)的认证密码,该密码必须与认证服务器上配置的密码保持一致。
其中,对于动态IPv4 DHCP个人接入用户支持通过多种方式获取认证密码,具体请参见ip subscriber dhcp password option60命令。
# 配置接口GigabitEthernet1/0/1上IPoE个人接入用户认证时使用的密码为明文123。
[Sysname-GigabitEthernet1/0/1] ip subscriber password plaintext 123
· ip subscriber unclassified-ip username
ip subscriber service-identify命令用来配置IPv4接入用户的业务识别方式。
undo ip subscriber service-identify命令用来恢复缺省情况。
三层以太网接口视图/三层聚合口视图
ip subscriber service-identify { dscp | vlan }
VLAN接口视图
未配置IPv4接入用户的业务识别方式。
context-admin
dscp:表示基于DSCP值识别业务。
vlan:表示基于VLAN ID识别业务。
IPv4接入用户(包括未知源IP接入用户、静态IPoE接入用户和IPoE子网/接口专线用户)认证时使用的认证域由报文中携带的业务信息来决定。不同的业务特征可以对应不同的认证域,每一个接口可以指定仅识别某种类型业务的报文。例如,接口上若指定了基于DSCP值识别业务,且通过ip subscriber dscp 1 domain example命令指定了DSCP值1与认证域example的映射关系,则IP报文DSCP值为1的用户认证时将会使用认证域example。
一个接口上只能指定一个业务识别方式。
# 配置接口GigabitEthernet1/0/1上的IPv4接入用户认证使用基于DSCP的业务识别方式。
· ip subscriber 8021p
· ip subscriber dscp
· ip subscriber vlan
ip subscriber session static命令用来配置静态IPv4 IPoE会话。
undo ip subscriber session static命令用来删除指定的静态IPv4 IPoE会话。
ip subscriber session static ip ip-address [ vlan vlan-id [ second-vlan vlan-id ] ] [ mac mac-address ] [ domain domain-name ] [ description string ]
undo ip subscriber session static ip ip-address [ vlan vlan-id [ second-vlan vlan-id ] ]
未配置静态IPv4 IPoE会话。
context-admin
ip ip-address:表示用户的IPv4地址。
vlan vlan-id:表示用户报文的外层VLAN。其中vlan-id表示VLAN ID,取值范围为1~4094。本参数仅子接口支持,非子接口不支持。
second-vlan vlan-id:表示用户报文的内层VLAN。其中vlan-id表示VLAN ID,取值范围为1~4094。本参数仅子接口支持,非子接口不支持。
mac mac-address:表示用户的MAC地址,形式为H-H-H。
description string:指定静态会话的描述信息,为1~31个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。如果未指定该参数,则静态会话无描述信息。
静态IPoE会话的匹配优先级高于动态IPoE会话。若已经存在静态IPoE会话,则与之匹配的IP报文不会触发新的动态IPoE会话;若存在一个未知源IP报文、DHCP报文触发建立的动态IPoE会话,则再配置一个能与该未知源IP报文、DHCP接入用户IP报文匹配的静态IPoE会话,会覆盖已经存在的动态IPoE会话。
当静态会话中指定的IP地址与DHCP地址池中可分配的IP地址存在交集时,则对于DHCPv4地址池需要通过命令dhcp server forbidden-ip或forbidden-ip配置交集IP地址为不参与自动分配的IP地址。有关配置不参与自动分配IP地址命令的详细介绍,请参见“三层技术-IP业务命令参考”中的“DHCP”。
系统支持配置多个静态IPoE会话,并根据命令中指定参数的不同分为如下三种情况:
· IP(无外层VLAN和内层VLAN)相同的静态IPoE会话;
· IP、外层VLAN(无内层VLAN)两个参数相同的静态IPoE会话;
· IP、外层VLAN、内层VLAN三个参数相同的静态IPoE会话。
上述三种情况的静态IPoE会话每种情况最多只能存在一条,并且不能通过重复执行本命令修改上述三种中的mac和domain参数。如需修改mac和domain参数,请先通过undo ip subscriber session static命令删除指定静态IPoE会话对应的当前配置后再执行ip subscriber session static命令。
同一接口下,静态IPoE会话、接口专线用户和子网专线用户的配置互斥,只能选择其中的一种配置。
# 在接口GigabitEthernet1/0/1上配置一条静态IPv4 IPoE会话:用户IP地址为1.1.1.1,认证使用的认证域为dm1。
[Sysname-GigabitEthernet1/0/1] ip subscriber session static ip 1.1.1.1 domain dm1
ip subscriber subnet-leased命令用来配置IPv4 IPoE子网专线用户。
undo ip subscriber subnet-leased命令用来删除指定的IPv4 IPoE子网专线用户。
ip subscriber subnet-leased ip ip-address { mask | mask-length } username name password { ciphertext | plaintext } string [ domain domain-name ]
undo ip subscriber subnet-leased ip ip-address { mask | mask-length }
未配置IPv4 IPoE子网专线用户。
context-admin
mask:IP地址的网络掩码,为点分十进制形式。
mask-length:IP地址的网络掩码长度,取值范围为1~31。
一个IPv4 IPoE子网专线用户代表了该接口接入的所有该子网内IPv4用户,该子网内的所有IPv4用户统一认证、授权和计费。该IPoE专线用户认证成功后,接口上接入的所有该子网内IPv4用户流量均允许通过,且共享一个IPv4 IPoE会话,并基于子网进行授权和计费。
每个子网只能配置一个IPv4 IPoE子网专线用户。
# 在接口GigabitEthernet1/0/1上配置一个IPv4 IPoE子网专线用户:子网网段为1.1.1.1/24,认证使用的用户名为netuser,认证使用的明文密码为pw123。
[Sysname-GigabitEthernet1/0/1] ip subscriber subnet-leased ip 1.1.1.1 24 username netuser password plaintext pw123
· display ip subscriber subnet-leased
ip subscriber timer quiet命令用来配置IPv4 IPoE用户的静默时间。
undo ip subscriber timer quiet命令用来恢复缺省情况。
ip subscriber timer quiet time
IPv4 IPoE用户的静默时间功能处于关闭状态。
context-admin
time:IPoE用户的静默时间,取值范围为10~3600,单位为秒。
本命令用来设置用户认证失败以后,设备需要等待的时间间隔。在静默期间,设备不对来自认证失败用户的报文进行认证处理,直接丢弃,可以防止该类用户报文持续发送给服务器认证而对设备性能造成影响。静默期后,如果设备再次收到该用户的报文,则依然可以对其进行认证处理。
# 在接口GigabitEthernet1/0/1上配置IPv4 IPoE用户的静默时间为100秒。
[Sysname-GigabitEthernet1/0/1] ip subscriber timer quiet 100
ip subscriber timer traffic命令用来配置IPv4 IPoE会话的流量统计信息的更新时间间隔。
undo ip subscriber timer traffic命令用来恢复缺省情况。
ip subscriber timer traffic value
undo ip subscriber timer traffic value
IPv4 IPoE会话的流量统计信息的更新时间间隔为60000毫秒。
context-admin
value:IPv4 IPoE会话的流量统计信息的更新时间间隔,取值范围为100~1200000,单位为毫秒,步长为100,即本参数值只支持配置为100的整数倍。
本命令对所有动态和静态IPv4 IPoE会话均生效,并且设备会根据配置的时间间隔定期更新IPoE会话的流量统计信息。
# 配置IPv4 IPoE会话的流量统计信息的更新时间间隔为300毫秒。
[Sysname] ip subscriber timer traffic 300
ip subscriber trust命令用来配置信任DHCPv4报文中的指定Option。
undo ip subscriber trust命令用来取消信任DHCPv4报文中指定的Option。
ip subscriber trust { option60 | option82 }
undo ip subscriber trust { option60 | option82 }
不信任DHCPv4报文中的任何Option。
context-admin
option60:表示信任DHCPv4报文中的Option 60。
option82:表示信任DHCPv4报文中的Option 82。
DHCP组网环境中,接入设备可以提取用户的DHCP-DISCOVER报文中的Option 60信息。如果接入设备信任DHCPv4报文中的Option 60信息,则:
· 在Option 60内容有效(无非法字符“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”等),且没有域名分隔符@字符的情况下,IPoE用户使用整个Option 60的内容作为指定的认证域进行认证。
· 在Option 60内容有效(无非法字符“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”等),且其中包含了域名分隔符@字符的情况下,IPoE用户使用@字符之后的字符串作为指定的认证域进行认证。如果在Option 60内容中包括多个@字符,则使用最后一个@字符之后的字符串作为IPoE用户的认证域名。
如果接入设备不信任DHCPv4报文中的Option 60信息,但是接口上配置了ip subscriber dhcp domain命令,则IPoE用户使用该命令指定的认证域进行认证;否则,使用缺省认证域进行认证。
DHCP中继组网环境中,接入设备可以提取用户的DHCP-DISCOVER报文中的Option 82信息。如果接入设备信任DHCPv4报文中的Option 82,则:
· 接入设备在采用version 2.0格式封装RADIUS NAS-PORT-ID属性时,会根据Option 82信息中的Circuit-ID子选项内容封装发往RADIUS服务器的NAS-PORT-ID属性;
· 接入设备会根据Option 82中的Circuit-ID子选项内容封装发往RADIUS服务器的DSL_AGENT_CIRCUIT_ID属性;
· 接入设备会根据Option 82中的Remote-ID子选项内容封装发往RADIUS服务器的DSL_AGENT_REMOTE_ID属性。
如果不信任DHCPv4报文中的Option 82,则接入设备在封装以上RADIUS属性时,不采用Option 82中的任何信息。
# 在接口GigabitEthernet1/0/1上配置设备信任DHCPv4报文中的Option 82。
[Sysname-GigabitEthernet1/0/1] ip subscriber trust option82
· ip subscriber dhcp domain
ip subscriber unclassified-ip domain命令用来配置IPv4接入用户使用的认证域。
undo ip subscriber unclassified-ip domain命令用来恢复缺省情况。
ip subscriber unclassified-ip domain domain-name
IPv4接入用户的认证域为缺省认证域。
context-admin
domain-name:认证使用的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。
该命令用来配置IPv4报文触发接入的IPv4接入用户(包括未知源IP接入用户、静态IPoE接入用户和IPoE子网/接口专线用户)在认证时使用的认证域,该域名必须在接入设备上存在且配置完整。
如果指定接口上配置了ip subscriber service-identify,则优先使用ip subscriber service-identify指定的业务识别方式获取对应的认证域。只有在未匹配到ip subscriber service-identify命令指定的认证域时,才使用ip subscriber unclassified-ip domain命令指定的认证域。如果ip subscriber unclassified-ip domain命令也未配置,则使用缺省认证域。
# 配置接口GigabitEthernet1/0/1上的IPv4接入用户使用的认证域为ipoe。
[Sysname-GigabitEthernet1/0/1] ip subscriber unclassified-ip domain ipoe
ip subscriber unclassified-ip ip match命令用来配置未知源IP报文触发认证时信任的用户IP地址/地址范围。
undo ip subscriber unclassified-ip ip match命令用来恢复缺省情况。
ip subscriber unclassified-ip ip match start-ip-address [ end-ip-address ]
undo ip subscriber unclassified-ip ip match start-ip-address [ end-ip-address ]
未配置信任任何未知源IP报文的源IP地址,接口开启未知源IP报文触发方式后,接口上收到的所有未知源IP报文都会触发IPoE认证。
context-admin
start-ip-address:需要IPoE认证的用户的起始IPv4地址。
end-ip-address:需要IPoE认证的用户的结束IPv4地址,不能小于start-ip-address。如果不指定本参数或指定的本参数和start-ip-address相同时,则表示只有一个用户IPv4地址,即start-ip-address;否则,表示start-ip-address到end-ip-address之间的IPv4地址均需要IPoE认证。
当接口同时开启Portal功能和未知源IPv4报文触发生成IPoE会话功能时,如果未知源IP报文能够匹配静态IPoE会话,则直接走IPoE静态用户上线流程,否则按如下原则处理:
· 如果配置了ip subscriber unclassified-ip ip match命令,则只有当未知源IP报文的IP地址与ip subscriber unclassified-ip ip match命令指定的IP地址匹配时,未知源IP报文才会触发IPoE接入认证,否则报文走Portal流程。有关Portal的相关介绍请参见“安全配置指导”中的“Portal”。
· 如果未配置ip subscriber unclassified-ip ip match命令,则IP报文不会触发IPoE接入认证,报文走Portal流程。
当接口仅开启未知源IPv4报文触发生成IPv4 IPoE会话功能,但未开启Portal功能时,如果未知源IP报文能够匹配静态IPoE会话,则直接走IPoE静态用户上线流程,否则按如下原则处理:
· 如果配置了ip subscriber unclassified-ip ip match命令,则只有当未知源IP报文的IP地址与ip subscriber unclassified-ip ip match命令指定的IP地址匹配时,未知源IP报文才会触发IPoE接入认证,否则丢弃报文。
· 如果未配置ip subscriber unclassified-ip ip match命令,则按未知源IP接入用户上线流程处理。
执行undo ip subscriber unclassified-ip ip match命令取消IPoE认证信任的IP地址/地址范围时,指定的地址/地址范围必须与执行ip subscriber unclassified-ip ip match命令时指定的地址/地址范围保持一致。如果需要取消已配置IPoE认证的IP地址为某一地址范围,则只能同时取消该地址范围内所有IP地址的配置,不能单独取消其中某个IP地址的配置。
多次执行ip subscriber unclassified-ip ip match命令,可以配置多个IPoE认证时信任的IP地址/地址范围。
# 在接口GigabitEthernet1/0/1上配置只有IP地址在192.168.1.10~192.168.1.100地址范围的IPv4个人用户需要进行IPoE认证。
[Sysname-GigabitEthernet1/0/1] ip subscriber unclassified-ip ip match 192.168.1.10 192.168.1.100
ip subscriber unclassified-ip max-session命令用来配置接口上允许未知源IPv4报文触发创建的动态IPv4 IPoE会话的最大数目。
undo ip subscriber unclassified-ip max-session命令用来恢复缺省情况。
ip subscriber unclassified-ip max-session max-number
未配置接口上允许未知源IPv4报文创建的动态IPv4 IPoE会话的最大数目。
context-admin
max-number:允许未知源IPv4报文触发创建的IPv4 IPoE会话的最大数目,取值范围为1~64000。
未知源IPv4报文触发创建的IPv4 IPoE会话数目达到最大值后,后续未知源IPv4报文不能触发创建IPv4 IPoE会话。
# 配置接口GigabitEthernet1/0/1上允许未知源IPv4报文触发创建的IPv4 IPoE会话的最大数目为100。
[Sysname-GigabitEthernet1/0/1] ip subscriber unclassified-ip max-session 100
ip subscriber unclassified-ip username命令用来配置IPv4未知源IP接入用户和静态个人用户的认证用户名的命名规则。
undo ip subscriber unclassified-ip username命令用来恢复缺省情况。
ip subscriber unclassified-ip username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [separator separator ] | slot [ separator separator ] | source-ip [ address-separator address-separator ] [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
IPv4未知源IP接入用户和静态个人用户采用用户报文的源IPv4地址作为认证用户名。
context-admin
nas-port-id:表示使用用户的NAS-PORT-ID属性作为用户名。
source-ip:表示使用用户报文的源IPv4地址作为用户名。
address-separator address-separator:IPv4地址分隔符,可以为任意可配置的可见字符。若指定了分隔符,例如“-”,则用户名形如192-168-1-1;若不指定该参数,则用户名为x.x.x.x形式。建议不要使用@作为分隔符,避免携带@字符的用户名在AAA服务器端不能被正确解析。
source-mac:表示使用用户报文的源MAC地址作为用户名。
本命令用来配置未知源IP接入用户和静态个人用户在认证时使用的用户名的命名规则,根据该命名规则获取的用户名必须与认证服务器上配置的用户名保持一致。
在允许的用户名类型范围内,该命令支持任意形式、任意顺序的用户名组合。例如:若配置ip subscriber unclassified-ip username include source-ip source-mac,则用户名为源IPv4地址字段和源MAC地址字段内容的拼接,且两个字段之间无分隔符。
# 配置接口GigabitEthernet1/0/1上的未知源IP接入用户和静态个人用户使用用户报文的源IPv4地址作为用户名。
[Sysname-GigabitEthernet1/0/1] ip subscriber unclassified-ip username include source-ip
# 配置接口GigabitEthernet1/0/1上的未知源IP接入用户和静态个人用户使用接入设备的设备名、接入的槽位号、接入的子卡号、接入的端口号和认证报文中的外层VLAN信息作为用户名,所选用的字段之间均使用#作为分隔符。
[Sysname-GigabitEthernet1/0/1] ip subscriber unclassified-ip username include sysname separator # slot separator # subslot separator # port separator # vlan
ip subscriber user-detect命令用来开启静态/动态IPv4 IPoE个人接入用户在线探测功能,并配置其探测方式。
undo ip subscriber user-detect命令用来关闭静态/动态IPv4 IPoE个人接入用户在线探测功能。
ip subscriber user-detect { arp | icmp } retry retries interval interval
静态/动态IPv4 IPoE个人接入用户在线探测功能处于关闭状态。
context-admin
arp:表示使用ARP请求报文作为探测报文。
icmp:表示使用ICMP请求报文作为探测报文。
retry retries:探测失败后允许重复尝试的最大次数,取值范围为2~255。例如,retries值为2表示连续三次失败就认为用户不在线。
interval interval:探测的时间间隔,取值范围为20~1200,单位为秒。
接口上的静态/动态IPoE个人接入用户上线后,设备会定时统计用户流量。若一个探测间隔(interval)内用户流量无变化,则该探测间隔结束后,设备将发送一次探测报文。如果设备在探测间隔内未收到用户的报文,则认为一次探测失败。
若设备首次探测失败,将继续做指定次数(retries)的重复探测,若全部探测尝试都失败(即一直未收到该用户报文),则认为此用户不在线,停止发送探测报文并删除用户;若设备在探测中收到用户的报文,则认为用户在线,重置探测定时器并开始下一次探测。
对于与接口在同一网段内的静态/动态IPv4 IPoE个人接入用户,可使用ARP请求或ICMP请求报文对用户进行探测;对于与接口不在同一网段内的静态/动态IPv4 IPoE个人接入用户,应使用ICMP请求报文对用户进行探测。
接口上不可同时启用两种方式对静态/动态IPv4 IPoE个人接入用户进行探测。
# 开启接口GigabitEthernet1/0/1上使用ARP请求报文对静态/动态IPv4 IPoE个人接入用户进行在线探测,探测失败后允许重复尝试5次,探测的时间间隔为100秒。
[Sysname-GigabitEthernet1/0/1] ip subscriber user-detect arp retry 5 interval 100
ip subscriber vlan命令用来配置IPv4接入用户的IP报文的内/外层VLAN值与认证域的映射关系。
undo ip subscriber vlan命令用来删除指定内/外层VLAN值与认证域的映射关系。
ip subscriber vlan vlan-list domain domain-name
undo ip subscriber vlan vlan-list
未配置IPv4接入用户的IP报文的内/外层VLAN与认证域的映射关系。
context-admin
vlan-list:VLAN列表,表示一个或多个VLAN,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
domain domain-name:表示与指定的VLAN范围相关联的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。
本命令用来配置指定VLAN范围内IPv4接入用户(包括未知源IP接入用户、静态IPoE接入用户和IPoE子网/接口专线用户)进行认证时使用的认证域,通过指定的认证域进行认证、授权、计费。
# 在子接口GigabitEthernet1/0/1.100上配置内层VLAN ID范围为2到100的IPv4接入用户认证使用的认证域为vlandm。
[Sysname-GigabitEthernet1/0/1.100] ip subscriber service-identify second-vlan
[Sysname-GigabitEthernet1/0/1.100] ip subscriber vlan 2 to 100 domain vlandm
ip subscriber whitelist enable命令用来开启IPv4 IPoE白名单功能。
undo ip subscriber whitelist enable命令用来关闭IPv4 IPoE白名单功能。
IPv4 IPoE白名单功能处于关闭状态。
context-admin
开启IPv4 IPoE白名单功能后,仅匹配到静态IPv4 IPoE会话的IPv4流量才会触发IPoE认证,其余流量IPoE不做任何处理,均直接放行。
在一些组网环境中,接口上可能需要同时开启IPoE和Portal功能,例如:监控摄像头等哑终端使用IPoE进行免认证上线,同时宽带拨号用户使用Portal进行Web认证上线;这种组网环境可配置IPoE白名单功能。当接口同时开启IPv4 IPoE白名单功能和Portal功能时:
· 如果用户IPv4流量可以匹配到静态IPv4 IPoE会话,则按静态IPv4 IPoE认证流程处理。当需要对IPoE用户进行免认证时,domain认证域下的IPoE认证及授权方式必须配置为none。
· 如果用户IPv4流量未匹配任何静态IPv4 IPoE会话,则进入Portal认证流程处理。
# 在接口GigabitEthernet1/0/1上开启IPv4 IPoE白名单功能。
[Sysname-GigabitEthernet1/0/1] ip subscriber whitelist enable
reset ip subscriber offline statistics命令用来清除IPv4 IPoE用户下线统计信息。
reset ip subscriber offline statistics [ interface interface-type interface-number ]
context-admin
interface interface-type interface-number:表示清除指定接口上的IPv4 IPoE用户下线统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将清除所有接口上的IPv4 IPoE用户下线统计信息。
# 清除接口GigabitEthernet1/0/1上的IPv4 IPoE用户下线统计信息。
<Sysname> reset ip subscriber offline statistics interface gigabitethernet 1/0/1
· display ip subscriber offline statistics
reset ip subscriber session命令用来清除动态个人IPv4 IPoE会话,强制用户下线。
reset ip subscriber session [ interface interface-type interface-number ] [ domain domain-name | ip ip-address [ vpn-instance vpn-instance-name ] | mac mac-address | username name ]
context-admin
interface interface-type interface-number:表示清除指定接口动态个人IPv4 IPoE会话,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将清除所有接口动态个人IPv4 IPoE会话。
domain domain-name:表示清除使用指定ISP域认证的IPv4 IPoE会话,domain-name为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。
ip ip-address:表示清除指定IP地址的IPv4 IPoE会话,ip-address为指定的IP地址。
vpn-instance vpn-instance-name:表示清除指定VPN实例的IPv4 IPoE会话,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示IPv4 IPoE会话位于公网中。
mac mac-address:表示清除指定源MAC地址的IPv4 IPoE会话,形式为H-H-H。
username name:表示清除指定用户名的IPv4 IPoE会话,name为1~255个字符的字符串,区分大小写。
本命令用来清除动态个人IPv4 IPoE会话信息,并强制用户下线,如果不指定条件,则表示删除所有动态IPv4 IPoE会话。
专线用户和静态个人用户的会话不能通过reset ip subscriber session命令清除,只能通过相应的undo命令删除配置的方式清除。
# 清除接口GigabitEthernet1/0/1上动态个人IPv4 IPoE会话,强制用户下线。
<Sysname> reset ip subscriber session interface gigabitethernet 1/0/1
display ipv6 subscriber interface-leased命令用来显示IPv6 IPoE接口专线用户信息。
display ipv6 subscriber interface-leased [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的IPv6 IPoE接口专线用户信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv6 IPoE接口专线用户信息。
slot slot-number:显示指定成员设备上的IPv6 IPoE接口专线用户信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv6 IPoE接口专线用户信息。
# 显示接口GigabitEthernet1/0/1上的IPv6 IPoE接口专线用户信息。
<Sysname> display ipv6 subscriber interface-leased interface gigabitethernet 1/0/1
Basic:
VPN instance : N/A
Username : a
User ID : 0x40000000
State : Online
Domain : radius6
Login time : May 14 20:20:11 2014
AAA:
IP pool : ipoe
QoS:
User profile : h3c6 (active)
Flow statistic:
ITA:
表1-10 display ipv6 subscriber interface-leased命令显示信息描述表
Basic |
IPoE会话的基本信息 |
Access interface |
用户所在的接口名称 |
VPN instance |
Username |
用户认证时使用的用户名 |
User ID |
State |
用户的认证状态 · Init:初始化 · Offline:正在下线 · Auth:认证中 · AuthFail:认证失败 · AuthPass :认证通过 · AssignedIP:用户已具备IP地址 · Online:用户在线 · Backup:备份状态,表示该用户是由对端备份到本端的 |
Service node |
为用户提供认证服务的节点信息 |
Domain |
认证使用的认证域名 |
Login time |
用户本次上线的在线时长 |
AAA |
IPoE会话的AAA授权信息 |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
IPoE会话的QoS信息 |
Inbound CAR |
Outbound CAR |
Flow statistic |
IPoE会话的流量统计信息 |
上行流量报文数/字节数 |
下行流量报文数/字节数 |
ITA |
· ipv6 subscriber enable
display ipv6 subscriber interface-leased statistics 命令用来显示IPv6 IPoE接口专线用户统计信息。
display ipv6 subscriber interface-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的IPv6 IPoE接口专线用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPv4 IPoE接口专线用户已经上线和正在上线的统计信息。
slot slot-number:显示指定成员设备上的IPv6 IPoE接口专线用户统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv6 IPoE接口专线用户统计信息。
# 显示设备上IPv6 IPoE接口专线用户统计信息。
<Sysname> display ipv6 subscriber interface-leased statistics
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-11 display ipv6 subscriber interface-leased statistics命令显示信息描述表
Total |
接入的总用户数 |
Init |
处于初始状态的用户数 |
Authenticating |
处于正在认证状态的用户数 |
Authenticate fail |
处于认证失败状态的用户数 |
Authenticate pass |
处于认证成功状态的用户数 |
Assigned IP |
处于成功分配到IP地址状态的用户数 |
Online |
处于在线状态的用户数 |
Backup |
处于备份状态的用户数 |
display ipv6 subscriber offline statistics 命令用来显示IPv6 IPoE用户下线原因的统计信息。
display ipv6 subscriber offline statistics [ interface interface-type interface-number ]
context-admin
context-operator
# 显示接口GigabitEthernet1/0/1上IPv6 IPoE用户下线原因的统计信息
<Sysname> display ipv6 subscriber offline statistics interface gigabitethernet 1/0/1
Total : 100
User request : 0
Command cut : 80
AAA terminate : 0
Idle timeout : 10
Detect fail : 10
Interface down : 0
VSRP event : 0
DHCP notify : 0
Other : 0
表1-12 display ipv6 subscriber offline statistics命令显示信息描述表
Total |
下线的总用户数 |
User request |
用户主动要求下线的用户数 |
DHCP lease expired |
DHCP租约到期正常下线的用户数 |
AAA lease expired |
AAA租约到期正常下线的用户数 |
Command cut |
通过命令行下线的用户数 |
AAA terminate |
AAA强制下线的用户数 |
Authenticate fail |
认证失败的用户数 |
授权失败的用户数 |
Idle timeout |
用户空闲超时下线的用户数 |
Detect fail |
在线探测失败下线的用户数 |
硬件资源不足下线的用户数 |
Interface down |
因接口状态为down下线的用户数 |
VSRP event |
DHCP notify |
DHCP通知下线的用户数 |
Other |
其它状况触发下线的用户数 |
· reset ipv6 subscriber offline statistics
display ipv6 subscriber session命令用来显示IPv6 IPoE个人会话信息。
display ipv6 subscriber session [ interface interface-type interface-number ] [ domain domain-name | ipv6 ipv6-address [ vpn-instance vpn-instance-name ] | mac mac-address | static | username name ] [ slot slot-number ] [ verbose ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的IPv6 IPoE个人会话,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv6 IPoE个人会话。
domain domain-name:显示使用指定ISP域认证的IPv6 IPoE个人会话,domain-name为1~255个字符的字符串,不区分大小写,不能包括 “/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。
ipv6 ipv6-address:显示指定源IP地址的IPv6 IPoE个人会话,ipv6-address为指定的IPv6地址。
vpn-instance vpn-instance-name:指定用户所属的VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示IPv6 IPoE个人会话位于公网中。
mac mac-address:显示指定源MAC地址的IPv6 IPoE个人会话,形式为H-H-H。
static:显示静态配置的IPv6 IPoE个人会话,不指定该参数时将显示静态配置的IPv6 IPoE个人会话和动态触发创建的IPv6 IPoE个人会话。
username name:显示指定用户名的IPv6 IPoE个人会话,其中,name为1~255个字符的字符串,区分大小写。
slot slot-number:显示指定成员设备上IPv6 IPoE个人会话,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上IPv6 IPoE会话。
verbose:显示IPv6 IPoE个人会话的详细信息。如果不指定该参数,则只显示IPoE会话的简要信息。
# 显示用户IP为2000::1,所属VPN实例为vpn1的IPv6 IPoE会话简要信息。
<Sysname> display ipv6 subscriber session ipv6 2000::1 vpn-instance vpn1
Type: D-DHCP S-Static U-Unclassified-IP N-NDRS
RAGG1024 2000::1 000d-88f8-0eab D Online
# 显示所有IPv6 IPoE个人会话的详细信息。
<Sysname> display ipv6 subscriber session verbose
Basic:
Description : -
Username : abc
Domain : radius6
VPN instance : N/A
IP address : 2000::1
User ID : 0x48080008
DHCP lease : N/A
Login time : May 9 09:10:01 2014
Type : Unclassified-IP
State : Online
AAA:
IP pool : N/A
QoS:
Flow statistic:
ITA:
表1-13 display ipv6 subscriber session命令显示信息描述表
Basic |
IPoE会话的基本信息 |
Username |
用户认证时使用的用户名 |
Domain |
用户认证时使用的认证域名 |
VPN instance |
IP address |
用户的IP地址 |
MAC address |
用户的MAC地址 |
Access interface |
用户接入的接口名称 |
User ID |
DHCP lease |
DHCP remain lease |
Login time |
用户本次上线的在线时长 |
Service node |
为用户提供认证服务的节点信息 |
Type |
IPoE会话的创建类型 · DHCP:DHCP报文触发创建 · Unclassified-IP:未知源IP报文触发创建 · Static:静态配置 · NDRS:IPv6 ND RS报文触发创建 |
State |
用户状态: · Init:初始化 · Offline:正在下线 · Auth:认证中 · AuthFail:认证失败 · AuthPass:认证通过 · AssignedIP:会话已具备IP地址 · Online:用户在线 · Backup:备份状态,表示该用户是由对端备份到本端的 |
AAA |
IPoE会话的AAA授权信息 |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
IPoE会话的QoS信息 |
Inbound CAR |
Outbound CAR |
Flow statistic: |
IPoE会话的流量统计信息 |
上行流量报文数/字节数 |
下行流量报文数/字节数 |
ITA |
· ipv6subscriber enable
display ipv6 subscriber session statistics 命令用来显示IPv6 IPoE个人用户统计信息。
display ipv6 subscriber session statistics [ session-type { dhcp | ndrs | static | unclassified-ip } ] [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
session-type:用户上线类型。不指定该参数,则表示显示所有类型的IPv6 IPoE个人用户统计信息。
dhcp:表示DHCP用户。
ndrs:表示RS报文触发认证的用户。
static:表示静态个人用户。
interface interface-type interface-number:显示指定接口上的IPv6 IPoE个人用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPv4 IPoE个人用户已经上线和正在上线的统计信息。
slot slot-number:显示指定成员设备上的IPv6 IPoE个人用户统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv6 IPoE个人用户统计信息。
# 显示接口GigabitEthernet1/0/1上IPv6 IPoE个人用户统计信息。
<Sysname> display ipv6 subscriber session statistics session-type dhcp interface gigabitethernet 1/0/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-14 display ipv6 subscriber session statistics命令显示信息描述表
Total |
接入的总用户数 |
Init |
处于初始状态的用户数 |
Authenticating |
处于正在认证状态的用户数 |
Authenticate fail |
处于认证失败状态的用户数 |
Authenticate pass |
处于认证成功状态的用户数 |
Assigned IP |
处于成功分配到IP地址状态的用户数 |
Online |
处于在线状态的用户数 |
Backup |
处于备份状态的用户数 |
· reset ipv6 subscriber session
display ipv6 subscriber subnet-leased命令用来显示IPv6 IPoE子网专线用户信息。
display ipv6 subscriber subnet-leased [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的IPv6 IPoE子网专线用户信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv6 IPoE子网专线用户信息。
slot slot-number:显示指定成员设备上的IPv6 IPoE子网专线用户信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv6 IPoE子网专线用户信息。
# 显示接口GigabitEthernet1/0/1上的IPv6 IPoE子网专线用户信息。
<Sysname> display ipv6 subscriber subnet-leased interface gigabitethernet 1/0/1
Basic:
VPN instance : N/A
Username : a
Network : 99::/64
User ID : 0x40000001
State : Online
Domain : radius6
Login time : May 14 20:22:14 2014
AAA:
IP pool : N/A
QoS:
Flow statistic:
ITA:
表1-15 display ipv6 subscriber subnet-leased命令显示信息描述表
Basic |
IPoE会话的基本信息 |
Access interface |
用户所在的接口名称 |
VPN instance |
User name |
用户认证时使用的用户名 |
Network |
用户所在的子网地址 |
User ID |
State |
用户的认证状态 · Init:初始化 · Offline:正在下线 · Auth:认证中 · AuthFail:认证失败 · AuthPass:认证通过 · AssignedIP:会话已具备IP地址 · Online:用户在线 · Backup:备份状态,表示该用户是由对端备份到本端的 |
Service node |
为用户提供认证服务的节点信息 |
Domain |
用户认证时使用的认证域名 |
Login time |
用户本次上线的在线时长 |
AAA |
IPoE会话的AAA授权信息 |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
IPoE会话的QoS信息 |
Inbound CAR |
Outbound CAR |
Flow statistic: |
IPoE会话的流量统计信息 |
上行流量报文数/字节数 |
下行流量报文数/字节数 |
ITA |
display ipv6 subscriber subnet-leased statistics命令用来显示IPv6 IPoE子网专线用户统计信息。
display ipv6 subscriber subnet-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的IPv6 IPoE子网专线用户统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上IPv4 IPoE子网专线用户已经上线和正在上线的统计信息。
slot slot-number:显示指定单板上的IPv6 IPoE子网专线用户统计信息,slot-number表示
slot slot-number:显示指定成员设备上的IPv6 IPoE子网专线用户统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的IPv6 IPoE子网专线用户统计信息。
# 显示接口GigabitEthernet1/0/1上的IPv6 IPoE子网专线用户统计信息。
<Sysname> display ipv6 subscriber subnet-leased statistics interface gigabitethernet 1/0/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
表1-16 display ipv6 subscriber subnet-leased statistics命令显示信息描述表
Total |
接入的总用户数 |
Init |
处于初始状态的用户数 |
Authenticating |
处于正在认证状态的用户数 |
Authenticate fail |
处于认证失败状态的用户数 |
Authenticate pass |
处于认证成功状态的用户数 |
Assigned IP |
处于成功分配到IP地址状态的用户数 |
Online |
处于在线状态的用户数 |
Backup |
处于备份状态的用户数 |
ipv6 subscriber 8021p命令用来配置IPv6接入用户的IP报文的内/外层VLAN tag中的802.1p值与认证域的映射关系。
undo ipv6 subscriber 8021p命令用来删除指定802.1p值与认证域的映射关系。
ipv6 subscriber 8021p 8021p-list domain domain-name
undo ipv6 subscriber 8021p 8021p-list
未配置IPv6接入用户的IP报文的内/外层VLAN tag中的802.1p值与认证域的映射关系。
context-admin
8021p-list: 802.1p值列表,表示一个或多个802.1p值,表示方式为8021p-list = { 8021p-value [ to 8021p-value ] }&<1-8>,其中,8021p-value为指定8021p的编号,取值范围为0~7。&<1-8>表示前面的参数最多可以输入8次。
本命令用来配置指定802.1p值范围内的IPv6接入用户(包括IPv6未知源IP接入用户、静态IPv6 IPoE接入用户和IPv6 IPoE子网/接口专线用户)认证时使用的认证域,通过指定的认证域进行认证授权。
# 在子接口GigabitEthernet 1/0/1.100上配置内层VLAN TAG中802.1p值范围为2到5的IPv6接入用户认证使用的认证域为1pdm。
[Sysname-GigabitEthernet1/0/1.100] ipv6 subscriber service-identify 8021p second-vlan
[Sysname-GigabitEthernet1/0/1.100] ipv6 subscriber 8021p 2 to 5 domain 1pdm
· ipv6 subscriber service-identify
ipv6 subscriber access-user log enable命令用来开启IPv6 IPoE接入用户日志信息功能。
undo ipv6 subscriber access-user log enable命令用来关闭IPv6 IPoE接入用户日志信息功能。
ipv6 subscriber access-user log enable [ successful-login | failed-login | logout [ normal ] [ abnormal ] ] *
undo ipv6 subscriber access-user log enable [ successful-login | failed-login | logout [ normal ] [ abnormal ] ] *
IPv6 IPoE接入用户日志信息功能处于关闭状态。
context-admin
successful-login:表示IPv6 IPoE接入用户上线成功日志功能。
failed-login:表示IPv6 IPoE接入用户上线失败日志功能。
logout:表示IPv6 IPoE接用户下线日志功能。
normal:表示IPv6 IPoE接用户正常下线日志功能。
abnormal:表示IPv6 IPoE接用户异常下线日志功能。
为了防止设备输出过多的IPv6 IPoE日志信息,一般情况下建议不要开启此功能。
IPv6 IPoE接入用户日志是为了满足网络管理员维护的需要,对用户的上线成功、上线失败、正常下线和异常下线的信息进行记录,包括用户名、IPv6地址、接口名称、两层VLAN、MAC地址、上线失败原因、下线原因等。设备生成的IPv6 IPoE日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启IPv6 IPoE接入用户日志信息功能。
[Sysname] ipv6 subscriber access-user log enable
ipv6 subscriber dhcp domain命令用来配置IPv6 DHCP个人接入用户使用的认证域。
undo ipv6 subscriber dhcp domain命令用来恢复缺省情况。
ipv6 subscriber dhcp domain domain-name
IPv6 DHCP个人接入用户的认证域为缺省认证域。
context-admin
本命令用来配置DHCPv6报文触发接入的IPv6 DHCP个人接入用户在认证时使用的域名,该域名必须在接入设备上存在且配置完整。
配置ipv6 subscriber dhcp domain命令后,如果用户报文中携带Option 16,Option 16内容符合域名的格式要求,并且接口配置了ipv6 subscriber trust option16命令,则IPoE接入用户使用Option 16作为指定的认证域进行认证;否则,使用本命令指定的认证域。
如果不配置ipv6 subscriber dhcp domain命令,且DHCPv6报文中未携带Option 16,则使用缺省认证域认证。
当用户需要将Option 16字段中的信息按字符串形式解析时,请确保Option 16字段内容中不出现字符串结束字符和不可见字符,否则在生成域名时将产生异常。
# 配置接口GigabitEthernet1/0/1上IPv6 DHCP个人接入用户使用的认证域为ipoe。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dhcp domain ipoe
· ipv6 subscriber dhcp username
· ipv6 subscriber initiator dhcp enable
· ipv6 subscriber trust
ipv6 subscriber dhcp max-session命令用来配置接口上允许DHCPv6报文触发创建的IPv6 IPoE会话的最大数目。
undo ipv6 subscriber dhcp max-session命令用来恢复缺省情况。
ipv6 subscriber dhcp max-session max-number
未配置接口上允许DHCPv6报文触发创建的IPv6 IPoE会话的最大数目。
context-admin
max-number:允许DHCPv6触发创建的IPv6 IPoE会话的最大数目,取值范围为1~64000。
DHCPv6报文触发创建的IPv6 IPoE会话数目达到最大值后,后续DHCPv6报文不能触发创建IPv6 IPoE会话。
# 配置接口GigabitEthernet1/0/1上允许DHCPv6报文触发创建的IPv6 IPoE会话的最大数目为100。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dhcp max-session 100
· display ipv6 subscriber session
ipv6 subscriber dhcp password option16命令用来配置IPv6 DHCP个人接入用户使用DHCPv6报文中的Option 16作为认证密码。
undo ipv6 subscriber dhcp password option16命令用来恢复缺省情况。
ipv6 subscriber dhcp password option16 [ offset offset ] [ length length ]
IPv6 DHCP个人接入用户未使用DHCPv6报文中的Option 16作为认证密码。
context-admin
offset offset:表示从Option 16首部偏移指定字节后的内容作为认证密码,offset表示字节偏移量,取值范围为1~63,单位为字节。如果未指定本参数,将从Option 16中起始处后的内容作为认证密码。
length length:表示从Option 16首部偏移offset所处的位置开始,取指定长度的字节作为认证密码,length表示获取字节的长度,取值范围为1~63,单位为字节。如果未指定本参数,将从Option 16首部偏移offset所处的位置开始取剩余的所有内容作为认证密码。
IPv6 DHCP个人接入用户支持通过多种方式获取认证密码,并按如下优先顺序选择第一个可用的认证密码进行认证:
· 同时满足如下条件时,使用本命令配置方式获取的密码作为认证密码:
¡ 接口上配置了ipv6 subscriber dhcp password option16命令;
¡ 接口上配置了ipv6 subscriber trust option16命令并且DHCPv6报文中携带的Option 16中内容符合可见字符的格式要求。
· 使用ipv6 subscriber password命令配置的密码作为认证密码。
ipv6 subscriber dhcp password option16命令用来配置IPv6 DHCP用户在认证时使用的密码,该密码必须与认证服务器上配置的密码保持一致。
当用户需要将Option 16字段中的信息作为认证密码时,请确保Option 16字段内容中不出现字符串结束字符和不可见字符,否则在生成用户密码时将产生异常。
# 配置接口GigabitEthernet1/0/1上的IPv6 DHCP个人接入用户使用从Option 16首部偏移10个字节后的20个字节内容作为认证密码。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dhcp password option16 offset 10 length 20
· ipv6 subscriber password
ipv6 subscriber dhcp username命令用来配置IPv6 DHCP个人接入用户的认证用户名的命名规则。
undo ipv6 subscriber dhcp username命令用来恢复缺省情况。
ipv6 subscriber dhcp username include { circuit-id [ separator separator ] | client-id [ separator separator ] | nas-port-id [ separator separator ] | port [ separator separator ] | remote-id [ separator separator ] | second-vlan [ separator separator ] | slot [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vendor-class [ separator separator ] | vendor-specific [ separator separator ] | vlan [ separator separator ] } *
IPv6 DHCP个人接入用户使用报文源MAC地址作为认证用户名。
context-admin
circuit-id:表示以IPv6 DHCP报文中的Option18字段中的信息为用户名。
client-id:表示以IPv6 DHCP报文中的Option1字段中的信息作为用户名。
nas-port-id:表示以用户认证报文中的NAS-PORT-ID属性作为用户名。
remote-id:表示以IPv6 DHCP报文中的Option37字段中的信息作为用户名。
vendor-class:表示以IPv6 DHCP报文中的Option16字段中的信息作为用户名。
vendor-specific:表示以IPv6 DHCP报文中的Option17字段中的信息作为用户名。
该命令用来配置IPv6 DHCP接入用户在认证时使用的用户名的命名规则,根据该命名规则获取的用户名必须与认证服务器上配置的用户名保持一致。此类用户进行IPoE认证时使用的密码由ipv6 subscriber password命令配置。
在允许的用户名类型范围内,该命令支持任意形式、任意顺序的用户名组合。例如:若配置ipv6 subscriber dhcp username include vendor-class vendor-specific,则用户名为Option16字段内容和Option17字段内容的拼接,且两个字段之间无分隔符。
# 配置接口GigabitEthernet1/0/1上IPv6 DHCP个人接入用户使用Client Identifier Option字段中的信息作为用户名。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dhcp username include client-id
# 配置接口GigabitEthernet1/0/1上IPv6 DHCP个人接入用户使用接入设备的设备名、接入的槽位号、接入的子卡号、接入的端口号和认证报文中的外层VLAN信息作为用户名,所选用的字段之间均使用#作为分隔符。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dhcp username include sysname separator # slot separator # subslot separator # port separator # vlan
ipv6 subscriber dscp命令用来配置IPv6接入用户的IP报文的DSCP值与用户认证域的映射关系。
undo ipv6 subscriber dscp命令用来删除指定DSCP值与用户认证域的映射关系。
ipv6 subscriber dscp dscp-value-list domain domain-name
undo ipv6 subscriber dscp dscp-value-list
未配置IPv6接入用户的IP报文的DSCP值与认证域的映射关系。
context-admin
dscp-value-list:DSCP值列表,表示一个或多个DSCP的值,表示方式为dscp-value-list ={ dscp-value [ to dscp-value ] }&<1-8>。其中,dscp-value为指定的DSCP的值,取值范围为0~63。&<1-8>表示前面的参数最多可以输入8次。
本命令用来配置指定DSCP范围内的IPv6接入用户(包括IPv6未知源IP接入用户、静态IPv6 IPoE接入用户和IPv6 IPoE子网/接口专线用户)认证时使用的认证域,通过指定的认证域进行认证授权。
# 在接口GigabitEthernet1/0/1上配置DSCP值范围为1到4的IPv6接入用户认证使用的认证域为dscpdm。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber service-identify dscp
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dscp 1 to 4 domain dscpdm
ipv6 subscriber enable命令用来在接口上开启IPv6 IPoE功能并指定用户的接入模式。
undo ipv6 subscriber enable命令用来关闭接口上的IPv6 IPoE功能。
ipv6 subscriber { l2-connected | routed } enable
undo ipv6 subscriber { l2-connected | routed } enable
接口上的IPv6 IPoE功能处于关闭状态。
context-admin
l2-connected:指定二层接入模式,表示此接口上用户通过二层网络接入。
routed:指定三层接入模式,表示此接口上用户通过三层网络接入。
只有在接口上开启了IPv6 IPoE功能后,其它的IPv6 IPoE相关配置才能生效。
不能通过重复执行本命令修改IPoE的接入模式。如需修改IPoE的接入模式,请先通过undo ipv6 subscriber enable命令关闭IPoE功能,再执行ipv6 subscriber enable命令。
# 在接口GigabitEthernet1/0/1上开启二层接入模式的IPv6 IPoE功能。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber l2-connected enable
ipv6 subscriber initiator dhcp enable命令用来在接口上开启DHCPv6报文触发生成IPv6 IPoE会话的功能。
undo ipv6 subscriber initiator dhcp enable命令用来关闭接口上DHCPv6报文触发生成IPv6 IPoE会话的功能。
接口上DHCPv6报文触发生成IPv6 IPoE会话的功能处于关闭状态。
context-admin
接口上开启该功能后,收到的首个DHCP Solicit报文或直接申请地址的DHCP Request报文会触发生成IPv6 IPoE会话;关闭该功能后,该接口上收到的DHCPv6报文不能触发生成IPv6 IPoE会话,已有的由DHCPv6报文触发生成的IPv6 IPoE会话不会被删除。
接口上可同时配置DHCPv6报文、IPv6 ND RS和未知源IPv6报文触发生成IPv6 IPoE会话的功能。
# 在接口GigabitEthernet1/0/1上开启DHCPv6报文触发生成IPv6 IPoE会话的功能。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber initiator dhcp enable
· ipv6 subscriber initiator ndrs enable
· ipv6 subscriber initiator unclassified-ip enable
ipv6 subscriber initiator ndrs enable命令用来在接口上开启IPv6 ND RS报文触发生成IPv6 IPoE会话的功能。
undo ipv6 subscriber initiator ndrs enable命令用来关闭接口上IPv6 ND RS报文触发生成IPv6 IPoE会话的功能。
接口上IPv6 ND RS报文触发生成IPv6 IPoE会话的功能处于关闭状态。
context-admin
接口上开启该功能后,收到的首个IPv6 ND RS报文会触发生成IPv6 IPoE会话;关闭该功能后,该接口上收到的IPv6 ND RS报文不能触发生成IPv6 IPoE会话,已有的由IPv6 ND RS报文触发生成的IPv6 IPoE会话不会被删除。
# 在接口GigabitEthernet1/0/1上开启IPv6 ND RS报文触发生成IPv6 IPoE会话的功能。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber initiator ndrs enable
ipv6 subscriber initiator unclassified-ip enable命令用来在接口上开启未知源IPv6报文触发生成IPv6 IPoE会话的功能。
undo ipv6 subscriber initiator unclassified-ip enable命令用来关闭接口上的未知源IPv6报文触发生成IPv6 IPoE会话的功能。
接口上的未知源IPv6报文触发生成IPv6 IPoE会话的功能处于关闭状态。
context-admin
接口开启该功能后,收到的未知源IPv6报文会触发生成IPv6 IPoE会话;关闭该功能后,该接口上收到的未知源IPv6报文不能触发生成IPv6 IPoE会话,已有的由未知源IPv6报文触发生成的IPv6 IPoE会话不会被删除。
# 在接口GigabitEthernet1/0/1上开启未知源IPv6报文触发生成IPv6 IPoE会话的功能。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber initiator unclassified-ip enable
ipv6 subscriber interface-leased命令用来配置IPv6接口专线用户。
undo ipv6 subscriber interface-leased命令用来恢复缺省情况。
ipv6 subscriber interface-leased username name password { ciphertext | plaintext } string [ domain domain-name ]
未配置IPv6接口专线用户。
context-admin
domain domain-name:指定认证使用的ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符,如果未配置该参数,将使用缺省认证域来认证用户。关于缺省认证域的相关配置请参见“安全配置指导”中的“AAA”。
一个IPv6 IPoE接口专线用户代表了该接口接入的所有IPv6用户,接口上接入的所有IPv6用户统一认证、授权和计费。该IPoE专线用户认证成功后,接口上接入的所有IPv6用户流量均允许通过,且共享一个IPv6 IPoE会话,并基于接口进行授权和计费。
· 每个接口只能配置一个IPv6 IPoE接口专线用户,并且不能通过重复执行本命令修改已配置的IPv6 IPoE接口专线用户的username、password或domain参数。如需修改这些参数,请先通过undo ipv6 subscriber interface-leased命令删除已配置的IPv6 IPoE接口专线用户,再执行ipv6 subscriber interface-leased命令。
# 在接口GigabitEthernet1/0/1上配置一个IPv6 IPoE接口专线用户:认证使用的用户名为intuser,认证使用的密码为明文pw123。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber interface-leased username intuser password plaintext pw123
· display ipv6 subscriber interface-leased
ipv6 subscriber nas-port-id format命令用来配置IPv6 IPoE接入用户进行认证时,接入设备向RADIUS服务器发送的NAS-PORT-ID属性的封装格式。
undo ipv6 subscriber nas-port-id format命令用来恢复缺省情况。
ipv6 subscriber nas-port-id format cn-telecom { version1.0 | version2.0 }
按version 1.0的格式要求填充发往RADIUS服务器的NAS-PORT-ID属性内容。
context-admin
version1.0:填充格式为version 1.0,表示发送给RADIUS服务器的NAS-PORT-ID属性以电信163大后台要求的格式填充。不同接口类型的封装内容形式有所不同,具体请参见表1-17。其中,封装内容中各参数的含义为:
接口类型 |
封装内容形式 |
三层以太网接口和三层聚合接口 |
version2.0:填充格式为version 2.0,表示发送给RADIUS服务器的NAS-PORT-ID属性以YDT 2275-2011宽带接入用户线路(端口)标识要求的格式填充。version 2.0封装格式的内容形式为:{eth|trunk|atm} NAS_slot/NAS_subslot/NAS_port:svlan.cvlan AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port。其中,各字段的含义请参见表1-18:
{eth|trunk} |
NAS_slot |
表示BRAS接入接口的槽位号 |
NAS_subslot |
表示BRAS接入接口的子槽位号 |
NAS_port |
表示BRAS接入接口的端口号 |
svlan |
表示接入用户的SVLAN ID |
cvlan |
表示接入用户的CVLAN ID |
表示接入节点的标识 |
ANI_rack |
表示接入节点机架号 |
ANI_frame |
表示接入节点机框号 |
ANI_slot |
表示接入节点槽位号 |
ANI_subslot |
表示接入节点子槽位号 |
ANI_port |
表示接入节点端口号 |
# 在接口GigabitEthernet1/0/1上配置设备使用RADIUS的NAS-PORT-ID属性封装格式为version 2.0。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber nas-port-id format cn-telecom version2.0
· ipv6 subscriber nas-port-id nasinfo-insert
ipv6 subscriber nas-port-id nasinfo-insert命令用来配置设备提取出DHCPv6报文的Option 18内容并和NAS信息一起作为NAS-PORT-ID属性字符串。
undo ipv6 subscriber nas-port-id nasinfo-insert命令用来恢复缺省情况。
如果收到的DHCPv6报文带有Option18选项,则直接使用该选项的内容作为NAS-PORT-ID属性字符串。
context-admin
在DHCP中继组网环境下,接入设备能捕获用户的DHCPv6报文,并从报文中提取出DHCPv6 Option18选项信息。在配置了NAS-PORT-ID属性封装格式为version 2.0且且信任DHCP Option 18的情况下,如果配置了本命令,则接入设备处理如下:
· 如果收到的DHCPv6报文带有Option18,则从收到的DHCPv6报文中解析Option18,并按version 2.0格式要求将提取出的DHCPv6报文的Option 18内容和NAS信息一起作为RADIUS的NAS-PORT-ID属性内容。
· 如果收到的DHCPv6报文不带Option18,则按version 2.0格式要求封装,填充NAS-PORT-ID属性中的NAS信息字段(NAS_slot/NAS_subslot/NAS_port:svlan.cvlan),并将AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port部分修改为0/0/0/0/0/0。
本功能对原DHCPv6报文中Option18选项不产生任何影响。
# 在接口GigabitEthernet1/0/1上配置设备使用DHCPv6客户端上报的Option18信息,并在其中插入NAS信息,然后将其封装为RADIUS的NAS-PORT-ID属性。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber trust option18
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber nas-port-id nasinfo-insert
· ipv6 subscriber nas-port-id format
ipv6 subscriber nas-port-type命令用来配置接口的IPv6 IPoE接入端口类型。
undo ipv6 subscriber nas-port-type命令用来恢复缺省情况。
ipv6 subscriber nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax | hdlc | idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
IPv6 IPoE接入端口类型为Ethernet类型。
context-admin
802.11:符合Wireless-IEEE 802.11标准的接口类型,对应的编码值为19。
hdlc:HDLC接口类型,对应的编码值为7。
idsl:IDSL(ISDN Digital Subscriber Line)接口类型,对应的编码值为14。
isdn-async-v110:ISDN Async V.110接口类型,对应的编码值为4。
isdn-async-v120:ISDN Async V.120接口类型,对应的编码值为3。
isdn-sync:ISDN Sync口类型,对应的编码值为2。
# 配置接口GigabitEthernet1/0/1的IPv6 IPoE接入端口类型为SDSL。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber nas-port-type sdsl
ipv6 subscriber ndrs domain命令用来配置IPv6 ND RS个人接入用户使用的认证域。
undo ipv6 subscriber ndrs domain命令用来恢复缺省情况。
ipv6 subscriber ndrs domain domain-name
IPv6 ND RS个人接入用户使用缺省认证域作为认证域。
context-admin
本命令用来配置IPv6 ND RS报文触发接入的IPv6 IPoE接入用户在认证时使用的域名,该域名必须与认证服务器上配置的域名保持一致。
配置ipv6 subscriber ndrs domain命令后,对于IPv6 ND RS报文触发认证的IPoE接入用户使用本命令指定的域名进行认证,否则使用缺省认证域认证。
# 配置接口GigabitEthernet1/0/1上IPv6 ND RS接入用户使用的认证域为ipoe。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber ndrs domain ipoe
ipv6 subscriber ndrs max-session命令用来配置接口上允许RS报文触发创建的IPv6 IPoE会话的最大数目。
undo ipv6 subscriber ndrs max-session命令用来恢复缺省情况。
ipv6 subscriber ndrs max-session max-number
未配置接口上允许创建的IPv6 IPoE会话的最大数目
context-admin
max-number:允许RS触发创建的IPv6 IPoE会话的最大数目,取值范围为1~64000。
RS报文触发创建的IPv6 IPoE会话数目达到最大值后,后续RS报文不能触发创建IPv6 IPoE会话,DHCPv6报文、未知源IPv6报文等触发创建IPv6 IPoE会话不会受此最大值限制。
# 配置接口GigabitEthernet1/0/1上允许RS报文触发创建的IPv6 IPoE会话的最大数目为100。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber ndrs max-session 100
ipv6 subscriber ndrs username命令用来配置IPv6 ND RS接入用户的认证用户名的命名规则。
undo ipv6 subscriber ndrs username命令用来恢复缺省情况。
ipv6 subscriber ndrs username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [ separator separator ] | slot [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
IPv6 ND RS接入用户采用用户报文的源MAC地址作为认证用户名。
context-admin
separator separator:MAC地址分隔符,可以为任意可配置的可见字符。若指定了分隔符,例如“-”,则用户名形如xxxx-xxxx-xxxx;若不指定该参数,则用户名为xxxxxxxxxxxx形式。建议不要使用@作为分隔符,避免携带@字符的用户名在AAA服务器端不能被正确解析。
本命令用来配置IPv6 RS报文触发接入的IPv6 IPoE接入用户在认证时使用的用户名的命名规则,根据该命名规则获取的用户名必须与认证服务器上配置的用户名保持一致。此类用户进行IPoE认证时使用的密码由ipv6 subscriber password命令配置。
在允许的用户名类型范围内,该命令支持任意形式、任意顺序的用户名组合。例如:若配置ipv6 subscriber ndrs username include nas-port-id source-mac,则用户名为NAS-PORT-ID属性字段和源MAC地址字段内容的拼接,且两个字段之间无分隔符
# 配置接口GigabitEthernet1/0/1上的IPv6 ND RS接入用户使用用户报文的源MAC地址作为用户名。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber ndrs username include source-mac
# 配置接口GigabitEthernet1/0/1上IPv6 ND RS接入用户使用接入设备的设备名、接入的槽位号、接入的子卡号、接入的端口号和认证报文中的外层VLAN信息作为用户名,所选用的字段之间均使用#作为分隔符。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber ndrs username include sysname separator # slot separator # subslot separator # port separator # vlan
ipv6 subscriber password命令用来配置IPv6 IPoE个人接入用户的认证密码。
undo ipv6 subscriber password命令用来恢复缺省情况。
ipv6 subscriber password { ciphertext | plaintext } string
IPv6 IPoE个人接入用户的认证密码为字符串vlan。
context-admin
ipv6 subscriber password命令用来配置IPv6 IPoE个人接入用户(包括动态和静态IPv6 IPoE个人接入用户)的认证密码,该密码必须与认证服务器上配置的密码保持一致。
其中,对于动态IPv6 DHCP个人接入用户支持通过多种方式获取认证密码,具体请参见ipv6 subscriber dhcp password option16命令。
# 配置接口GigabitEthernet1/0/1上IPv6 IPoE个人接入用户认证时使用的密码为明文的123。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber password plaintext 123
· ipv6 subscriber unclassified-ip username
· ipv6 subscriber dhcp password option16
ipv6 subscriber service-identify命令用来配置IPv6接入用户的业务识别方式。
undo ipv6 subscriber service-identify命令用来恢复缺省情况。
三层以太网接口视图/三层聚合口视图
ipv6 subscriber service-identify { dscp | vlan }
VLAN接口视图
未配置IPv6接入用户的业务识别方式。
context-admin
dscp:表示基于DSCP值识别业务。
对于IPv6接入用户(包括IPv6未知源IP接入用户、静态IPv6 IPoE接入用户和IPv6 IPoE子网/接口专线用户)认证时使用的认证域由报文中携带的业务信息来决定。不同的业务特征可以对应不同的认证域,每一个接口可以指定仅识别某种类型业务的报文。例如,接口上若指定了基于DSCP值识别业务,且通过ipv6 subscriber dscp 1 domain example命令指定了DSCP值1与认证域example的映射关系,则IPv6报文DSCP值为1的用户认证时将会使用认证域example。
一个接口上只能指定一个业务识别方式。
# 配置接口GigabitEthernet1/0/1上的IPv6接入用户认证使用基于DSCP的业务识别方式
· ipv6 subscriber 8021p
· ipv6 subscriber dscp
· ipv6 subscriber vlan
ipv6 subscriber session static命令用来配置静态IPv6 IPoE会话。
undo ipv6 subscriber session static命令用来删除指定的静态IPv6 IPoE会话。
ipv6 subscriber session static ipv6 ipv6-address [ vlan vlan-id [ second-vlan vlan-id ] ] [ mac mac-address ] [ domain domain-name ] [ description string ]
undo ipv6 subscriber session static ipv6 ipv6-address [ vlan vlan-id [ second-vlan vlan-id ] ]
未配置静态IPv6 IPoE会话。
context-admin
ipv6 ipv6-address:表示用户的IP地址。
静态IPoE会话的匹配优先级高于动态IPoE会话。若已经存在静态IPoE会话,则与之匹配IP报文不会触发新的动态IPoE会话;若存在一个未知源IP报文、DHCP报文或ND RS报文触发建立的动态IPoE会话,则再配置一个能与该未知源IP报文、DHCP接入用户IP报文或ND RS接入用户IP报文匹配的静态IPoE会话,会覆盖已经存在的动态IPoE会话。
当静态会话中指定的IP地址与DHCP地址池中可分配的IP地址存在交集时,则:对于DHCPv6地址池需要通过命令ipv6 dhcp server forbidden-address配置交集IPv6地址为不参与自动分配的IPv6地址。有关配置不参与自动分配IP地址命令的详细介绍,请参见“三层技术-IP业务命令参考”中的“DHCPv6”。
· IPv6(无外层VLAN和内层VLAN)相同的静态IPv6 IPoE会话;
· IPv6、外层VLAN(无内层VLAN)两个参数相同的静态IPv6 IPoE会话;
· IPv6、外层VLAN、内层VLAN三个参数相同的静态IPv6 IPoE会话。
上述三种情况的静态IPv6 IPoE会话每种情况最多只能存在一条,并且不能通过重复执行本命令修改上述三种中已配置的mac和domain参数。如需修改mac和domain参数,请先通过undo ipv6 subscriber session static命令删除指定静态IPv6会话对应的当前配置后再执行ipv6 subscriber session static命令。
# 在接口GigabitEthernet1/0/1上配置一条静态IPv6 IPoE会话:用户IPv6地址为2000::1,认证使用的认证域为dm1。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber session static ipv6 2000::1 domain dm1
ipv6 subscriber subnet-leased 命令用来配置IPv6 IPoE子网专线用户。
undo ipv6 subscriber subnet-leased 命令用来删除指定的IPv6 IPoE子网专线用户。
ipv6 subscriber subnet-leased ipv6 ipv6-address prefix-length username name password { ciphertext | plaintext } string [ domain domain-name ]
undo ipv6 subscriber subnet-leased ipv6 ipv6-address prefix-length
未配置IPv6 IPoE子网专线用户。
context-admin
ipv6 ipv6-address:表示用户的IPv6地址。
prefix-length:IPv6子网前缀长度,取值范围为1~127。
一个IPv6 IPoE子网专线用户代表了该接口接入的所有该子网内IPv6用户,该子网内的所有IPv6用户统一认证、授权和计费。该IPoE专线用户认证成功后,接口上接入的所有该子网内IPv6用户流量均允许通过,且共享一个IPv6 IPoE会话,并基于子网进行授权和计费。
每个子网只能配置一个IPv6 IPoE子网专线用户。
# 在接口GigabitEthernet1/0/1上配置一个IPv6 IPoE子网专线用户:用户IPv6地址和前缀为2001:10::100/64,认证使用的用户名为netuser,认证使用的密码为明文pw123。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber subnet-leased ipv6 2001:10::100 64 username netuser password plaintext pw123
· display ipv6 subscriber subnet-leased
ipv6 subscriber timer quiet命令用来配置IPv6 IPoE用户的静默时间。
undo ipv6 subscriber timer quiet命令用来恢复缺省情况。
ipv6 subscriber timer quiet time
IPv6 IPoE用户的静默时间功能处于关闭状态。
context-admin
# 在接口GigabitEthernet1/0/1上配置IPv6 IPoE用户的静默时间为100秒。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber timer quiet 100
ipv6 subscriber timer traffic命令用来配置IPv6 IPoE会话的流量统计信息的更新时间间隔。
undo ipv6 subscriber timer traffic命令用来恢复缺省情况。
ipv6 subscriber timer traffic value
undo ipv6 subscriber timer traffic value
IPv6 IPoE会话的流量统计信息的更新时间间隔为60000毫秒。
context-admin
value:IPv6 IPoE会话的流量统计信息的更新时间间隔,取值范围为100~1200000,单位为毫秒,步长为100,即本参数值只支持配置为100的整数倍。
本命令对所有动态和静态IPv6 IPoE会话均生效,并且设备会根据配置的时间间隔定期更新IPv6 IPoE会话的流量统计信息。
# 配置IPv6 IPoE会话的流量统计信息的更新时间间隔为300毫秒。
[Sysname] ipv6 subscriber timer traffic 300
ipv6 subscriber trust命令用来配置信任DHCPv6报文中的指定Option。
undo ipv6 subscriber trust命令用来取消信任DHCPv6报文中指定的Option。
ipv6 subscriber trust { option16 | option18 | option37 }
undo ipv6 subscriber trust { option16 I option18 | option37 }
不信任DHCPv6报文中的任何Option。
context-admin
option16:表示信任DHCPv6报文中的Option 16。
option18:表示信任DHCPv6报文中的Option18。
option37:表示信任DHCPv6报文中的Option37。
DHCP组网环境中,接入设备可以提取用户DHCPv6报文中的Option 16信息。如果接入设备信任DHCPv6报文中的Option 16信息,则:
· 在Option 16内容有效(无非法字符“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”等),且没有域名分隔符@字符的情况下,IPoE用户使用整个Option 16的内容作为指定的认证域进行认证。
· 在Option 16内容有效(无非法字符“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”等),且其中包含了域名分隔符@字符的情况下,IPoE用户使用@字符之后的字符串作为指定的认证域进行认证。如果在Option 16内容中包括多个@字符,则使用最后一个@字符之后的字符串作为IPoE用户的认证域名。
如果接入设备不信任DHCPv6报文中的Option 16信息,但是接口上配置了ipv6 subscriber dhcp domain命令,则IPoE用户使用该命令指定的认证域进行认证;否则,使用缺省认证域进行认证。
DHCP中继组网环境中,接入设备可以提取用户DHCPv6报文中的指定Option信息。如果接入设备信任DHCPv6报文中的Option 18,则:
· 接入设备在采用version 2.0格式封装RADIUS NAS-PORT-ID属性时,会根据Option 18选项内容封装发往RADIUS服务器的NAS-PORT-ID属性;
· 接入设备会根据Option 18选项的内容封装发往RADIUS服务器的DSL_AGENT_CIRCUIT_ID属性。
如果接入设备信任DHCPv6报文中的Option 37,则接入设备会根据Option 37选项的内容封装发往RADIUS服务器的DSL_AGENT_REMOTE_ID属性。
# 在接口GigabitEthernet1/0/1上配置设备信任DHCPv6报文中的Option18。
· ipv6 subscriber dhcp domain
ipv6 subscriber unclassified-ip domain命令用来配置IPv6接入用户使用的认证域。
undo ipv6 subscriber unclassified-ip domain命令用来恢复缺省情况。
ipv6 subscriber unclassified-ip domain domain-name
IPv6接入用户的认证域为缺省认证域。
三层以太网接口视图/三层以太网子接口视图/三层聚合接口视图/三层聚合子接口视图/VLAN接口视图
context-admin
该命令用来配置IPv6报文触发接入的IPv6接入用户(包括IPv6未知源IP接入用户、静态IPv6 IPoE接入用户和IPv6 IPoE子网/接口专线用户)在认证时使用的缺省域名,该域名必须在接入设备上存在且配置完整。
如果指定接口上配置了ipv6 subscriber service-identify,则优先使用ipv6 subscriber service-identify指定的业务识别方式获取对应的认证域。只有在未匹配到ipv6 subscriber service-identify命令指定的认证域时,才使用ipv6 subscriber unclassified-ip domain命令指定的认证域。如果 ipv6 subscriber unclassified-ip domain命令也未配置,则使用缺省认证域。
# 配置接口GigabitEthernet1/0/1上的IPv6接入用户使用的认证域为ipoe。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber unclassified-ip domain ipoe
ipv6 subscriber unclassified-ip max-session命令用来配置接口上允许未知源IPv6报文触发创建的动态IPv6 IPoE会话的最大数目。
undo ipv6 subscriber unclassified-ip max-session命令用来恢复缺省情况。
ipv6 subscriber unclassified-ip max-session max-number
未配置接口上允许未知源IPv6报文创建的动态IPv6 IPoE会话的最大数目。
context-admin
max-number :允许未知源IPv6报文触发创建的IPv6 IPoE会话的最大数目,取值范围为1~64000。
未知源IPv6报文触发创建的IPv6 IPoE会话数目达到最大值后,后续未知源IPv6报文不能触发创建IPv6 IPoE会话。DHCPv6报文触发创建IPv6 IPoE会话不会受此最大值限制。
# 配置接口GigabitEthernet1/0/1上允许未知源IPv6报文触发创建的IPv6 IPoE会话的最大数目为100。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber unclassified-ip max-session 100
ipv6 subscriber unclassified-ip username命令用来配置IPv6未知源IP接入用户和IPv6静态个人用户的认证用户名的命名规则。
undo ipv6 subscriber unclassified-ip username命令用来恢复缺省情况。
ipv6 subscriber unclassified-ip username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [ separator separator ] | slot [ separator separator ] | source-ip [ address-separator address-separator ] [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
IPv6未知源IP接入用户和IPv6静态个人用户采用用户报文的源IPv6地址作为认证用户名。
context-admin
source-ip:表示使用用户报文的源IPv6地址作为用户名。
address-separator address-separator:IPv6地址分隔符,可以为任意可配置的可见字符。若指定了分隔符,例如“-”,则用户名形如1-2-3;若不指定该参数,则用户名形如1::2:3。建议不要使用@作为分隔符,避免携带@字符的用户名在AAA服务器端不能被正确解析。
本命令用来配置IPv6未知源IP接入用户和IPv6静态个人用户在认证时使用的用户名的命名规则,根据该命名规则获取的用户名必须与认证服务器上配置的用户名保持一致。
在允许的用户名类型范围内,该命令支持任意形式、任意顺序的用户名组合。例如:若配置ipv6 subscriber unclassified-ip username include source-ip source-mac,则用户名为源IPv6地址字段和源MAC地址字段内容的拼接,且两个字段之间无分隔符。
# 配置接口GigabitEthernet1/0/1上的IPv6未知源IP接入用户和IPv6静态个人用户使用用户报文的源IPv6地址作为用户名。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber unclassified-ip username include source-ip
# 配置接口GigabitEthernet1/0/1上的IPv6未知源IP接入用户和IPv6静态个人用户使用接入设备的设备名、接入的槽位号、接入的子卡号、接入的端口号和认证报文中的外层VLAN信息作为用户名,所选用的字段之间均使用#作为分隔符。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber unclassified-ip username include sysname separator # slot separator # subslot separator # port separator # vlan
ipv6 subscriber user-detect命令用来开启静态/动态IPv6 IPoE个人接入用户在线探测功能,并配置其探测方式。
undo ipv6 subscriber user-detect命令用来关闭静态/动态IPv6 IPoE个人接入用户在线探测功能。
ipv6 subscriber user-detect { icmpv6 | nd } retry retries interval interval
静态/动态IPv6 IPoE个人接入用户在线探测功能处于关闭状态。
context-admin
icmpv6:表示使用ICMPv6请求报文作为探测报文。
nd:表示使用ND协议中的NS报文作为探测报文。
接口上的静态/动态IPv6 IPoE个人接入用户上线后,设备会定时统计用户流量。若一个探测间隔(interval)内用户流量无变化,则该探测间隔结束后,设备将发送一次探测报文。如果设备在探测间隔内未收到用户的报文,则认为一次探测失败。
对于与接口在同一网段内的静态/动态IPv6 IPoE个人接入用户,可使用IPv6 ND协议中的NS或ICMPv6请求报文对用户进行探测;对于与接口不在同一网段内的静态/动态IPv6 IPoE个人接入用户,应使用ICMPv6请求报文对用户进行探测。
接口上不可同时启用两种方式对IPv6 IPoE个人接入用户进行探测。
# 配置接口GigabitEthernet1/0/1上使用IPv6 ND协议中的NS报文对静态/动态IPv6 IPoE个人接入用户进行在线检测,探测失败后允许重复尝试3次,探测的时间间隔为50秒。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber user-detect nd retry 3 interval 50
ipv6 subscriber vlan命令用来配置IPv6接入用户的IP报文的内/外层VLAN值与认证域的映射关系。
undo ipv6 subscriber vlan命令用来删除指定内/外层VLAN值与认证域的映射关系。
ipv6 subscriber vlan vlan-list domain domain-name
undo ipv6 subscriber vlan vlan-list
未配置IPv6接入用户的IP报文的内/外层VLAN与认证域的映射关系。
三层以太网子接口视图/三层聚合子接口视图/VLAN接口视图
context-admin
本命令用来配置指定VLAN范围内IPv6接入用户(包括IPv6未知源IP接入用户、静态IPv6 IPoE接入用户和IPv6 IPoE子网/接口专线用户)进行认证时使用的认证域,通过指定的认证域进行认证授权。
# 在子接口GigabitEthernet 1/1.100上配置内层VLAN ID范围为2到100的IPv6接入用户认证使用的认证域为vlandm。
[Sysname] interface gigabitethernet 1/0/1.100
[Sysname-GigabitEthernet1/0/1.100] ipv6 subscriber service-identify second-vlan
[Sysname-GigabitEthernet1/0/1.100] ipv6 subscriber vlan 2 to 100 domain vlandm
ipv6 subscriber whitelist enable命令用来开启IPv6 IPoE白名单功能。
undo ipv6 subscriber whitelist enable命令用来关闭IPv6 IPoE白名单功能。
IPv6 IPoE白名单功能处于关闭状态。
context-admin
开启IPv6 IPoE白名单功能后,仅匹配到静态IPv6 IPoE会话的IPv6流量才会触发IPoE认证,其余流量IPoE不做任何处理,均直接放行。
在一些组网环境中,接口上可能需要同时开启IPoE和Portal功能,例如:监控摄像头等哑终端使用IPoE进行免认证上线,同时宽带拨号用户使用Portal进行Web认证上线;这种组网环境可配置IPoE白名单功能。当接口上同时开启IPv6 IPoE白名单功能和Portal功能时:
· 如果用户IPv6流量可以匹配到静态IPv6 IPoE会话,则按静态IPv6 IPoE认证流程处理。当需要对IPv6 IPoE用户进行免认证时,domain认证域下的IPv6 IPoE认证及授权方式必须配置为none。
· 如果用户IPv6流量未匹配任何静态IPv6 IPoE会话,则进入Portal认证流程处理。
# 在接口GigabitEthernet1/0/1上开启IPv6 IPoE白名单功能。
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber whitelist enable
reset ipv6 subscriber offline statistics命令用来清除IPv6 IPoE用户下线统计信息。
reset ipv6 subscriber offline statistics [ interface interface-type interface-number ]
context-admin
interface interface-type interface-number:表示清除指定接口上的IPv6 IPoE用户下线统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将清除所有接口上的IPv6 IPoE用户下线统计信息。
# 清除所有接口上的IPv6 IPoE用户的下线统计信息。
<Sysname> reset ipv6 subscriber offline statistics
· display ipv6 subscriber offline statistics
reset ipv6 subscriber session命令用来清除动态个人IPv6 IPoE会话,强制用户下线。
reset ipv6 subscriber session [ interface interface-type interface-number ] [ domain domain-name | ipv6 ipv6-address [ vpn-instance vpn-instance-name ] | mac mac-address | username name ]
context-admin
interface interface-type interface-number:表示清除指定接口动态个人IPv6 IPoE会话,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将清除所有接口动态个人IPv6 IPoE会话。
domain domain-name:表示清除使用指定ISP域认证的IPv6 IPoE会话,domain-name为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、““”、“:”、“*”、“?”、“<”、“>”以及“@”字符。
ipv6 ipv6-address:表示清除指定IP地址的IPv6 IPoE会话,ipv6-address为指定的IPv6地址。
vpn-instance vpn-instance-name:表示清除指定VPN实例的IPv6 IPoE会话,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示IPv6 IPoE会话位于公网中。
mac mac-address:表示清除指定源MAC地址的IPv6 IPoE会话,形式为H-H-H。
username name:表示清除指定用户名的IPv6 IPoE会话,name为1~255个字符的字符串,区分大小写。
本命令用来清除动态个人IPv6 IPoE会话,并强制用户下线,如果不指定条件,则表示删除所有动态IPv6 IPoE会话。
专线用户和静态个人用户的会话不能通过reset ipv6 subscriber session命令清除,只能通过相应的undo命令删除配置的方式清除。
# 清除接口GigabitEthernet1/0/1上动态个人IPv6 IPoE会话,强制用户下线。
<Sysname> reset ipv6 subscriber session interface gigabitethernet 1/0/1
