07-IP组播命令参考
13-IPv6 PIM命令
本章节下载 13-IPv6 PIM命令  (604.19 KB)
13-IPv6 PIM命令
  录
1 IPv6 PIM
1.1 IPv6 PIM配置命令
1.1.1 anycast-rp (IPv6 PIM view)
1.1.2 bsm-fragment enable (IPv6 PIM view)
1.1.3 bsm-reflection enable (IPv6 PIM view)
1.1.4 bsr-policy (IPv6 PIM view)
1.1.5 bsr-rp-mapping rfc2362  (IPv6 PIM view)
1.1.6 c-bsr (IPv6 PIM view)
1.1.7 c-bsr holdtime (IPv6 PIM view)
1.1.8 c-bsr interval (IPv6 PIM view)
1.1.9 c-rp (IPv6 PIM view)
1.1.10 crp-policy (IPv6 PIM view)
1.1.11 display ipv6 pim bsr-info
1.1.12 display ipv6 pim claimed-route
1.1.13 display ipv6 pim c-rp
1.1.14 display ipv6 pim interface
1.1.15 display ipv6 pim neighbor
1.1.16 display ipv6 pim routing-table
1.1.17 display ipv6 pim rp-info
1.1.18 display ipv6 pim statistics
1.1.19 dscp
1.1.20 embedded-rp
1.1.21 hello-option dr-priority (IPv6 PIM view)
1.1.22 hello-option holdtime (IPv6 PIM view)
1.1.23 hello-option lan-delay (IPv6 PIM view)
1.1.24 hello-option neighbor-tracking (IPv6 PIM view)
1.1.25 hello-option override-interval (IPv6 PIM view)
1.1.26 holdtime join-prune (IPv6 PIM view)
1.1.27 ipv6 pim
1.1.28 ipv6 pim bfd enable
1.1.29 ipv6 pim bsr-boundary
1.1.30 ipv6 pim dm
1.1.31 ipv6 pim hello-option dr-priority
1.1.32 ipv6 pim hello-option holdtime
1.1.33 ipv6 pim hello-option lan-delay
1.1.34 ipv6 pim hello-option neighbor-tracking
1.1.35 ipv6 pim hello-option override-interval
1.1.36 ipv6 pim holdtime join-prune
1.1.37 ipv6 pim join-policy
1.1.38 ipv6 pim log enable
1.1.39 ipv6 pim log suppress
1.1.40 ipv6 pim neighbor-policy
1.1.41 ipv6 pim non-stop-routing
1.1.42 ipv6 pim passive
1.1.43 ipv6 pim require-genid
1.1.44 ipv6 pim sm
1.1.45 ipv6 pim state-refresh-capable
1.1.46 ipv6 pim timer dr-elect-delay
1.1.47 ipv6 pim timer graft-retry
1.1.48 ipv6 pim timer hello
1.1.49 ipv6 pim timer join-prune
1.1.50 ipv6 pim triggered-hello-delay
1.1.51 ipv6 pim triggered-hello enable
1.1.52 jp-pkt-size (IPv6 PIM view)
1.1.53 register-policy (IPv6 PIM view)
1.1.54 register-suppression-timeout (IPv6 PIM view)
1.1.55 register-whole-checksum (IPv6 PIM view)
1.1.56 rpf-frr enable (IPv6 PIM view)
1.1.57 snmp-agent trap enable pim6
1.1.58 source-lifetime (IPv6 PIM view)
1.1.59 source-policy (IPv6 PIM view)
1.1.60 spt-switch-threshold (IPv6 PIM view)
1.1.61 ssm-policy (IPv6 PIM view)
1.1.62 state-refresh-hoplimit (IPv6 PIM view)
1.1.63 state-refresh-interval (IPv6 PIM view)
1.1.64 state-refresh-rate-limit (IPv6 PIM view)
1.1.65 static-rp (IPv6 PIM view)
1.1.66 timer hello (IPv6 PIM view)
1.1.67 timer join-prune (IPv6 PIM view)
1 IPv6 PIM
1.1  IPv6 PIM配置命令
anycast-rp命令用来配置Anycast-RP。
undo anycast-rp命令用来删除Anycast-RP。
anycast-rp ipv6-anycast-rp-address ipv6-member-address
undo anycast-rp ipv6-anycast-rp-address ipv6-member-address
不存在Anycast-RP。
IPv6 PIM视图
ipv6-anycast-rp-address:指定Anycast-RP地址。必须是合法的IPv6全球单播地址。
ipv6-member-address:指定Anycast-RP成员地址。必须是合法的IPv6全球单播地址。
处于同一个Anycast-RP集中的成员设备上,都必须存在相同的IPv6地址(LoopBack接口地址),并将该IPv6地址同时配置为Anycast-RP和C-RP。
多次执行本命令,可配置多个Anycast-RP。如果配置时指定了相同的Anycast-RP地址,则将Anycast-RP成员地址添加到该Anycast-RP地址所属的Anycast-RP集中。
Anycast-RP成员地址不能与Anycast-RP地址相同。
# 在公网实例中配置如下Anycast-RP集:Anycast-RP地址为1:1::0,两个成员的地址分别为1:1::1和1:2::1(前者为本地接口LoopBack1的地址)。
[Sysname] ipv6 pim
[Sysname-pim6] c-rp 1:1::0
[Sysname-pim6] anycast-rp 1:1::0 1:1::1
[Sysname-pim6] anycast-rp 1:1::0 1:2::1
·     display ipv6 pim rp-info
bsm-fragment enable命令用来开启自举报文语义分片功能。
undo bsm-fragment enable命令用来关闭自举报文语义分片功能。
bsm-fragment enable
自举报文语义分片功能处于开启状态。
IPv6 PIM视图
当IPv6 PIM-SM域中存在不支持自举报文语义分片的设备时,请关闭本功能。
# 在公网实例中关闭自举报文语义分片功能。
[Sysname] ipv6 pim
[Sysname-pim6] undo bsm-fragment enable
bsm-reflection enable命令用来开启自举报文往报文入接口方向转发功能。
undo bsm-reflection enable命令用来关闭自举报文往报文入接口方向转发功能。
自举报文往报文入接口方向转发功能处于开启状态。
IPv6 PIM视图
当IPv6 PIM-SM域中不需要自举报文往报文入接口方向转发时,请关闭本功能。
# 在公网实例中关闭自举报文往报文入接口方向转发功能。
[Sysname] ipv6 pim
[Sysname-pim6] undo bsm-reflection enable
bsr-policy命令用来配置合法的BSR地址范围。
undo bsr-policy命令用来恢复缺省情况。
bsr-policy ipv6-acl-number
undo bsr-policy
BSR的地址范围不受限制,即认为来自任意源的自举报文都是合法的。
IPv6 PIM视图
ipv6-acl-number:指定IPv6基本ACL的编号,取值范围为2000~2999。
配置合法的BSR地址范围可以防止BSR欺骗。
该ACL规则中的source参数用来指定合法BSR的源地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
多次执行本命令,最后一次执行的命令生效。
# 在公网实例中配置合法的BSR地址范围,只允许网段2001::2/64中的设备充当BSR。
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source 2001::2 64
[Sysname] ipv6 pim
[Sysname-pim6] bsr-policy 2000
·     c-bsr (IPv6 PIM view)
bsr-rp-mapping rfc2362命令用来配置RP映射采用RFC 2362中规定的哈希算法。
undo bsr-rp-mapping rfc2362命令用来恢复缺省情况。
RP映射采用RFC 4601中规定的哈希算法。
IPv6 PIM视图
为了确保本网络内各路由器上RP映射信息一致,请在所有路由器上配置相同的RP映射哈希算法。
# 在公网实例中RP映射采用RFC 2362中规定的哈希算法。
[Sysname] ipv6 pim
[Sysname-pim6] bsr-rp-mapping rfc2362
c-bsr命令用来配置C-BSR。
undo c-bsr命令用来删除C-BSR的相关配置。
c-bsr ipv6-address [ scope scope-id ] [ hash-length hash-length | priority priority ] *
undo c-bsr ipv6-address [ scope scope-id ]
不存在C-BSR。
IPv6 PIM视图
ipv6-address:指定C-BSR的IPv6地址,C-BSR的IPv6地址必须是本地接口的IPv6地址,且该接口上必须使能IPv6 PIM,否则配置不会生效。
scope scope-id:指定IPv6管理域的编号,取值范围为3~15。如果未指定本参数,表示配置服务于Global域的C-BSR。
hash-length hash-length:指定哈希掩码长度,取值范围为0~128,缺省值为126。
priority priority:指定C-BSR的优先级,取值范围为0~255,缺省值为64。数值越大,优先级越高。
如果对同一个域多次执行本命令,最后一次执行的命令生效;而针对不同域的C-BSR则允许指定相同的IPv6地址。
# 在公网实例中将IPv6地址为1101::1的设备配置为Global域的C-BSR。
[Sysname] ipv6 pim
[Sysname-pim6] c-bsr 1101::1
c-bsr holdtime命令用来配置C-BSR等待接收来自BSR的自举报文的超时时间。
undo c-bsr holdtime命令用来恢复缺省情况。
c-bsr holdtime hold-time
undo c-bsr holdtime
C-BSR等待接收来自BSR的自举报文超时时间为130秒。
IPv6 PIM视图
hold-time:C-BSR等待接收来自BSR的自举报文的超时时间(自举超时时间),取值范围为1~2147483647,单位为秒。
C-BSR一旦通过自举机制竞选为BSR后,其他C-BSR会在等待接收来自BSR的自举报文的超时时间内,停止向其所服务的区域内的其他设备发送自举报文,BSR选举过程暂停。当自举超时时间超时后,所有的C-BSR之间会互相发送自举报文,触发新一轮的BSR选举过程。
配置自举报文的超时时间(holdtime)和自举报文发送时间间隔(interval)时,需要注意:
·     如果同时配置了interval和holdtime,请保证interval小于holdtime,否则将导致频繁触发BSR选举过程。
·     如果只配置了其中之一,那么另一个取值可由以下公式计算得出:interval=(holdtime-10)÷2。
·     只配置了holdtime时,若根据公式计算得出的interval小于interval取值范围的最小值(1秒),interval的取值为1秒。
·     只配置了interval时,若根据公式计算得出的holdtime大于holdtime取值范围的最大值(2147483647秒),则holdtime取值为2147483647秒。
·     属于同一个IPv6 PIM域的所有C-BSR必须配置相同的interval和holdtime。如果配置值不同,则可能导致BSR选举不稳定,从而引发组播流量转发故障。
# 在公网实例中,配置自举超时时间为150秒。
[Sysname] ipv6 pim
[Sysname-pim6] c-bsr holdtime 150
# 在VPN实例mvpn中,配置自举超时时间为150秒。
[Sysname] ipv6 pim vpn-instance mvpn
[Sysname-pim6-mvpn] c-bsr holdtime 150
·     c-bsr interval (IPv6 PIM view)
c-bsr interval命令用来配置C-BSR发送自举报文的时间间隔。
undo c-bsr interval命令用来恢复缺省情况。
c-bsr interval interval
undo c-bsr interval
C-BSR发送自举报文的时间间隔为60秒。
IPv6 PIM视图
interval:C-BSR发送自举报文的时间间隔,取值范围为1~1073741818,单位为秒。
C-BSR一旦通过自举机制竞选为BSR后,其他C-BSR会在等待接收来自BSR的自举报文的超时时间(holdtime,可通过c-bsr holdtime命令进行配置)内,停止向其所服务的区域内的其他设备发送自举报文,BSR选举过程暂停。之后,将由BSR会周期性地(发送的周期通过本命令配置)向其所服务的区域内的其他设备发送携带自己的IP地址、RP-Set信息和RP实际老化时间的自举报文,其他设备根据RP-Set信息计算出特定组播组范围所对应的RP。当自举超时时间超时后,所有的C-BSR之间会互相发送自举报文,触发新一轮的BSR选举过程。
在存在主备RP的IPv6双向PIM组网中,当主RP所在的组播流量转发链路发生故障时,备RP必须要等待主RP老化后才能将组播流量切换到备RP,导致组播流量转发中断时间较长。由于RP老化时间必须大于自举报文的发送时间间隔,因此,若要缩小RP老化时间,需要先通过本命令调小自举报文的发送时间间隔。
配置interval和holdtime时,请注意:
·     只配置了holdtime时,若根据公式计算得出的interval小于interval取值范围的最小值(1秒),则interval取值为1秒;
·     属于同一个IPv6 PIM域的所有C-BSR必须配置相同的interval和holdtime。如果配置值不同,有可能导致BSR选举不稳定,从而引发组播流量转发故障。
# 在公网实例中,配置C-BSR发送自举报文的时间间隔为30秒。
[Sysname] ipv6 pim
[Sysname-pim6] c-bsr interval 30
# 在VPN实例mvpn中,配置C-BSR发送自举报文的时间间隔为30秒。
[Sysname-pim6-mvpn] c-bsr interval 30
·     c-bsr holdtime (IPv6 PIM view)
c-rp命令用来配置C-RP。
undo c-rp命令用来删除C-RP的相关配置。
c-rp ipv6-address [ advertisement-interval adv-interval | { group-policy { ipv6-acl-number | name ipv6-acl-name } | scope scope-id } | holdtime hold-time | priority priority ] *
undo c-rp ipv6-address
不存在C-RP。
IPv6 PIM视图
ipv6-address:指定C-RP的IPv6地址,C-RP的IPv6地址必须有对应的本地接口,且该接口上必须使能IPv6 PIM,否则配置不会生效。
advertisement-interval adv-interval:指定发送宣告报文的间隔时间,取值范围为1~65535,单位为秒,缺省值为60。
group-policy:指定C-RP服务IPv6组播组的策略。如果未指定本参数,C-RP将为所有IPv6组播组服务。如果未指定本参数、指定的ACL名称不存在或ACL中未配置有效规则,则该C-RP将为所有IPv6组播组服务。其中:
·     ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。如果指定了本参数,该C-RP将只为ACL规则所允许的IPv6组播组服务。
·     name ipv6-acl-name:指定IPv6基本或高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定了本参数,该C-RP将只为ACL规则所允许的IPv6组播组服务。
holdtime hold-time:指定C-RP的超时时间,取值范围为1~65535,单位为秒,缺省值为150。
priority priority:指定C-RP的优先级,取值范围为0~255,缺省值为192。该数值越大,优先级越低。
如果设备想要成为多个组范围的C-RP,则需要在配置group-policy所对应的ACL时将多个组范围用多个rule规则表示出来。
本命令通过ACL规则中的source参数指定C-RP所服务的IPv6组播组范围(若指定的不是IPv6组播组地址,则此规则不生效),而其它可选参数都将被忽略。该ACL规则用来定义该C-RP所服务的IPv6组播组范围,只有permit的IPv6组播组才会作为RP的服务组范围通告出去。
如果对同一IPv6地址多次执行本命令,最后一次执行的命令生效。
# 在公网实例中将IPv6地址为2001::1配置为组播组FF0E:0:1391::/96的C-RP,且C-RP的优先级为10。
[Sysname-acl-ipv6-basic-2000] rule permit source ff0e:0:1391:: 96
[Sysname] ipv6 pim
[Sysname-pim6] c-rp 2001::1 group-policy 2000 priority 10
crp-policy命令用来配置合法的C-RP地址范围及其服务的IPv6组播组范围。
undo crp-policy命令用来恢复缺省情况。
crp-policy ipv6-acl-number
undo crp-policy
C-RP地址范围及其服务的IPv6组播组范围不受限制,即认为所有收到的C-RP报文都是合法的。
IPv6 PIM视图
ipv6-acl-number:指定IPv6高级ACL的编号,取值范围为3000~3999。
配置合法的C-RP地址范围及其服务的IPv6组播组范围可以防止C-RP欺骗。
本命令在对C-RP所宣告的IPv6组播组范围进行过滤时,只取其前缀部分进行匹配。例如,C-RP宣告的IPv6组播组范围为FF0E:0:1::/96,如果其前缀部分“FF0E:0:1::”能匹配上本命令所引用的ACL规则,就认为整个IPv6组播组范围“FF0E:0:1::/96”都通过了过滤。
该ACL规则中的source参数用来指定合法C-RP所服务的IPv6地址范围,destination参数用来指定该C-RP所服务的IPv6组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
# 在公网实例中配置C-RP策略,只允许2001::2/64范围内的设备充当C-RP,且只允许其为FF03::101/64范围内的IPv6组播组服务。
[Sysname-acl-ipv6-adv-3000] rule permit ipv6 source 2001::2 64 destination ff03::101 64
[Sysname-acl-ipv6-adv-3000] quit
[Sysname] ipv6 pim
[Sysname-pim6] crp-policy 3000
·     c-rp (IPv6 PIM view)
display ipv6 pim bsr-info命令用来显示IPv6 PIM-SM域中的BSR信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] bsr-info
vpn-instance vpn-instance-name:显示指定VPN实例的BSR信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的BSR信息。
# 显示公网实例IPv6 PIM-SM域中的BSR信息。
<Sysname> display ipv6 pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:01:44
     Elected BSR address: 12:12::1
       Priority: 64
       Hash mask length: 126
       Uptime: 00:21:56
 Scope: 5
     State: Accept Any
     Scope-zone expiry timer: 00:21:12
 Scope: 6
     State: Elected
     Bootstrap timer: 00:00:26
     Elected BSR address: 17:11::1
       Priority: 64
       Uptime: 02:53:37
     Candidate BSR address: 17:11::1
       Priority: 64
 Scope: 7
     State: Candidate
     Bootstrap timer: 00:01:56
     Elected BSR address: 61:37::1
       Priority: 64
       Uptime: 02:53:32
     Candidate BSR address: 17:12::1
       Priority: 64
 Scope: 8
     State: Pending
     Bootstrap timer: 00:00:07
     Candidate BSR address: 17:13::1
       Priority: 64
表1-1 display ipv6 pim bsr-info命令显示信息描述表
Scope
域状态
Bootstrap timer
BSR定时器
域老化定时器
Elected BSR address
当选BSR的地址
候选BSR的地址
Priority
BSR的优先级
Hash mask length
哈希掩码长度
Uptime
BSR已存在的时间
display ipv6 pim claimed-route命令用来显示IPv6 PIM所使用的路由信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] claimed-route [ ipv6-source-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的路由信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的路由信息。
ipv6-source-address:组播源的IPv6地址,显示到达指定组播源的路由信息。如果未指定本参数,将显示IPv6 PIM所使用的所有路由信息。
# 显示IPv6 PIM在公网实例中使用的所有路由信息。
<Sysname> display ipv6 pim claimed-route
 RPF-route selecting rule: longest-match
 Route/mask: 7:11::/64 (unicast (direct))
     RPF interface: Vlan-interface2, RPF neighbor: 8::2
     Total number of (S,G) or (*,G) dependent on this route entry: 4
     (7:11::10, ff1e::1)
     (7:11::10, ff1e::2)
     (7:11::10, ff1e::3)
     (*, ff1e::4)
 Route/mask: 7:12::/64 (unicast)
     RPF interface: Vlan-interface2, RPF neighbor: 8::3,
     Total number of (S,G) or (*,G) dependent on this route entry: 2
     (7:12::10, ff1e::1)
     (7:12::10, ff1e::2)
表1-2 display ipv6 pim claimed-route命令显示信息描述表
RPF路由的选择规则
Route/mask
路由项。括号内为路由类型,包括:
·     igp:单播路由(内部网关协议)
·     egp:单播路由(外部网关协议)
·     unicast (direct):单播路由(直连)
·     unicast:其它单播路由(如单播静态路由等)
·     mbgp:IPv6 MBGP路由
RPF interface
RPF接口的名称
RPF neighbor
RPF邻居的IPv6地址
on this route entry
基于此RPF路由的(S,G)或(*,G)个数及列表
display ipv6 pim c-rp命令用来显示IPv6 PIM-SM域中的C-RP信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] c-rp [ local ]
vpn-instance vpn-instance-name:显示指定VPN实例的C-RP信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的C-RP信息。
local:显示本地配置且生效的C-RP信息。如果未指定本参数,将显示所有学习到的C-RP信息。
只有当选的BSR上才会有学习到的C-RP信息,其它设备上只能查看到本地配置生效的C-RP信息。
# 显示公网实例中学习到的C-RP信息。
<Sysname> display ipv6 pim c-rp
 Scope: non-scoped
     Group/MaskLen: FF00::/8 [B]
       C-RP address             Priority  HoldTime  Uptime    Expires
       8:12::2 (local)          192       150       00:27:48  00:01:43
     Group/MaskLen: FF23::/92 Expires: 00:02:07
# 显示本地配置生效的C-RP信息。
<Sysname> display ipv6 pim c-rp local
 Candidate RP: 8:12::2(Loop1)
     Priority: 192
     HoldTime: 150
     Advertisement interval: 60
     Next advertisement scheduled at: 00:00:46
表1-3 display ipv6 pim c-rp命令显示信息描述表
Scope
Group/MaskLen
C-RP所服务的IPv6组播组
[B]
(暂不支持IPv6双向PIM)表示C-RP服务于IPv6双向PIM。如果未显示本字段,则表示服务于IPv6 PIM-SM
C-RP address
C-RP的IPv6地址,local表示本地地址
Priority
C-RP的优先级
HoldTime
C-RP的超时时间
Uptime
C-RP已存在的时间,w表示星期,d表示天,h表示小时
Expires
C-RP/组播组的超时剩余时间
Candidate RP
本地C-RP的IPv6地址
本地C-RP发送通告报文时间间隔
本地C-RP发送下一个通告报文的剩余时间
display ipv6 pim interface命令用来显示接口上的IPv6 PIM信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM信息。
interface-type interface-number:显示指定接口上的IPv6 PIM信息。如果未指定本参数,将显示所有接口上的IPv6 PIM信息。
# 显示公网实例所有接口上的IPv6 PIM概要信息。
<Sysname> display ipv6 pim interface
 Interface: Vlan1
   NbrCnt: 1
   HelloInt: 30
   DR priority: 1
   DR address: FE80::200:5EFF:FE04:8700
表1-4 display ipv6 pim interface命令显示信息描述表
接口名称
NbrCnt
IPv6 PIM邻居的数量
HelloInt
发送Hello报文的时间间隔
DR priority
竞选DR的优先级
DR address
DR的IPv6地址(链路本地地址)
# 显示公网实例接口Vlan-interface1上的IPv6 PIM详细信息。
<Sysname> display ipv6 pim interface vlan-interface 1 verbose
 Interface: Vlan-interface1, FE80::200:5EFF:FE04:8700
     PIM version: 2
     PIM mode: Sparse
     PIM DR: FE80::200:AFF:FE01:101
     PIM DR Priority (configured): 1
     PIM neighbors count: 1
     PIM hello interval: 30 s
     PIM LAN delay (negotiated): 500 ms
     PIM LAN delay (configured): 500 ms
     PIM override interval (negotiated): 2500 ms
     PIM override interval (configured): 2500 ms
     PIM neighbor tracking (negotiated): disabled
     PIM neighbor tracking (configured): disabled
     PIM generation ID: 0xF5712241
     PIM require generation ID: disabled
     PIM hello hold interval: 105 s
     PIM assert hold interval: 180 s
     PIM triggered hello delay: 5 s
     PIM J/P interval: 60 s
     PIM J/P hold interval: 210 s
     PIM state-refresh capable (negotiated): enabled
     PIM state-refresh capable (configured): enabled
     PIM state-refresh interval: 60 s
     PIM state-refresh rate limit: 30 s
     PIM state-refresh hop limit: 255
     PIM graft retry interval: 3 s
     PIM BSR domain border: disabled
     PIM BFD: disabled
     PIM passive: disabled
     PIM DR elect delay: 80 s
     PIM DR remaining elect delay: 15 s
     Number of routers on network not using DR priority: 0
     Number of routers on network not using LAN delay: 0
     Number of routers on network not using neighbor tracking: 2
表1-5 display ipv6 pim interface verbose命令显示信息描述表
接口名称与IPv6地址(链路本地地址)
PIM version
IPv6 PIM协议的版本号
PIM mode
IPv6 PIM协议的模式,是密集模式还是稀疏模式
PIM DR
DR的IPv6地址(链路本地地址)
竞选DR优先级的配置值
PIM neighbors count
IPv6 PIM邻居的总数
PIM hello interval
发送Hello报文的时间间隔
剪枝报文传输延迟的协商值
剪枝报文传输延迟的配置值
剪枝否决时间的协商值
剪枝否决时间的配置值
邻居跟踪开启与否的协商情况
邻居跟踪开启与否的配置情况
PIM generation ID
Generation_ID参数值
是否开启不接受无Generation ID的Hello报文
保持IPv6 PIM邻居的可达状态的时间
保持断言状态的时间
发送Hello报文的最大延迟时间
PIM J/P interval
发送加入/剪枝报文的时间间隔
加入/剪枝状态的保持时间
状态刷新能力的协商值
状态刷新能力的配置值
发送状态刷新报文的时间间隔
接收新状态刷新报文的等待时间
接收新状态刷新报文的跳数限制
嫁接报文的重传时间
该接口是否配置了BSR的服务边界
PIM BFD
该接口是否开启了IPv6 PIM与BFD联动功能
PIM passive
该接口是否配置了IPv6 PIM消极模式
PIM DR elect delay time
配置的DR选举延迟时间,单位为秒。如果未开启DR延迟选举功能,则不显示该字段
PIM DR remaining elect delay time
DR选举延迟时间剩余的时间,单位为秒
如果未开启DR延迟选举功能或定时器超时,则不显示该字段;如果定时器超时,则显示为“--”
该接口所在网段上没有使用DR优先级字段的路由器数量
该接口所在网段上未使用LAN-delay字段的路由器数量
该接口所在网段上未开启邻居跟踪的路由器数量
display ipv6 pim neighbor命令用来显示IPv6 PIM邻居信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] neighbor [ ipv6-neighbor-address | interface interface-type interface-number | verbose ] *
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM邻居信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM邻居信息。
ipv6-neighbor-address:IPv6 PIM邻居的IPv6地址,显示指定IPv6 PIM邻居的信息。如果未指定本参数,将显示所有IPv6 PIM邻居的信息。
interface interface-type interface-number:接口类型和接口编号,显示指定接口上的IPv6 PIM邻居信息。如果未指定本参数,将显示所有接口上的IPv6 PIM邻居信息。
# 显示公网实例所有IPv6 PIM邻居的概要信息。
<Sysname> display ipv6 pim neighbor
 Total IPv6 pim neighbors: 2
  Neighbor: FE80::A01:101:1
    Interface: Vlan1
    Uptime: 02:50:49
    Expiry time: 00:01:31
    DR priority: 1
    Mode: N/A
  Neighbor: FE80::A01:102:1
    Interface: Vlan2
    Uptime: 02:49:39
    Expiry time: 00:01:42
    DR priority: 1
    Mode: N/A
# 显示公网实例中IPv6地址为FE80::A01:101:1的IPv6 PIM邻居的详细信息。
<Sysname> display ipv6 pim neighbor fe80::a01:101:1 verbose
   Interface: Vlan-interface3
   Uptime: 00:00:10
   Expiry time: 00:00:30
   DR priority: 1
   Generation ID: 0x2ACEFE15
   Holdtime: 105 s
   LAN delay: 500 ms
   Override interval: 2500 ms
   State refresh interval: 60 s
   Neighbor tracking: Disabled
   Bidirectional PIM: Disabled
   RPF proxy vector: Disabled
   Secondary address(es):
     1::1
表1-6 display ipv6 pim neighbor命令显示信息描述表
Total Number of Neighbors
IPv6 PIM邻居的总数
Neighbor
IPv6 PIM邻居的IPv6主地址(链路本地地址)
IPv6 PIM邻居所在接口的名称
Uptime
IPv6 PIM邻居已存在的时间
Expiry time
IPv6 PIM邻居超时的剩余时间,never表示IPv6 PIM邻居永不超时,即永远可达
DR priority
IPv6 PIM邻居的优先级
Mode
(暂不支持IPv6双向PIM)IPv6 PIM邻居的模式:
·     B表示IPv6双向PIM模式
·     N/A:表示非IPv6双向PIM模式
Generation ID
IPv6 PIM邻居的Generation ID(状态随机数)
Holdtime
IPv6 PIM邻居的生存时间,forever表示IPv6 PIM邻居永远存在,即永远可达
LAN delay
IPv6 PIM报文在共享网段中的传输延迟
Override interval
剪枝否决的时间间隔
状态刷新的时间间隔,只有当IPv6 PIM邻居工作在IPv6 PIM-DM模式下且具备状态刷新能力时才会显示本字段
Neighbor tracking
邻居跟踪功能是否开启
Bidirectional PIM
(暂不支持IPv6双向PIM)IPv6双向PIM是否使能
RPF proxy vector
IPv6 PIM邻居是否支持RPF代理向量功能(请参见“IP组播配置指导”中的“组播VPN”)
IPv6 PIM邻居的IPv6从地址(非链路本地地址)
display ipv6 pim routing-table命令用来显示IPv6 PIM路由表的内容。
display ipv6 pim [ vpn-instance vpn-instance-name ] routing-table [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number ] *
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM路由项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM路由项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6 PIM路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的IPv6 PIM路由项。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6 PIM路由项。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
flags flag-value:IPv6 PIM标志,显示包含指定标志的IPv6 PIM路由项。如果未指定本参数,将显示包含所有标志的IPv6 PIM路由项。flag-value的取值及含义如下
·     act:表示已经有实际数据到达的IPv6 PIM路由项;
·     del:表示计划删除的IPv6 PIM路由项;
·     exprune:表示某些出接口被其它IPv6组播路由协议剪枝的IPv6 PIM路由项;
·     ext:表示包含了由其它IPv6组播路由协议提供出接口的IPv6 PIM路由项;
·     loc:表示在与IPv6组播源处于同一网段的设备上的IPv6 PIM路由项;
·     niif:表示未确定入接口的IPv6 PIM路由项;
·     nonbr:表示IPv6 PIM邻居查找失败的IPv6 PIM路由项;
·     rpt:表示向RP方向发送过(S,G)RPT位剪枝的IPv6 PIM路由项;
·     rq:表示Data-MDT切换接收端的IPv6 PIM路由项;
·     spt:表示SPT上的IPv6 PIM路由项;
·     sq:表示Data-MDT切换发起端的IPv6 PIM路由项;
·     swt:表示正处于向SPT切换过程中的IPv6 PIM路由项;
·     wc:表示带WC通配符的IPv6 PIM路由项。
fsm:显示有限状态机的详细信息。
incoming-interface interface-type interface-number:显示指定入接口的IPv6 PIM路由项。如果未指定本参数,将显示所有入接口的PIM路由项。
mode mode-type:IPv6 PIM模式,显示指定模式下的IPv6 PIM路由项。如果未指定本参数,将显示所有模式下的IPv6 PIM路由项。mode-type的取值及含义如下:
·     dm:表示IPv6 PIM-DM模式;
·     sm:表示IPv6 PIM-SM模式;
·     ssm:表示IPv6 PIM-SSM模式。
outgoing-interface { exclude | include | match } interface-type interface-number:显示指定出接口的IPv6 PIM路由项。其中,exclude表示不包含指定接口;include表示包含指定接口;match表示包含且仅包含指定接口。如果未指定本参数,将显示所有出接口的IPv6 PIM路由项。
# 显示公网实例IPv6 PIM路由表的内容。
<Sysname> display ipv6 pim routing-table
 Total 0 (*, G) entries; 1 (S, G) entries
 (2001::2, FFE3::101)
     RP: FE80::A01:100:1
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: Vlan-interface1
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Backup upstream interface: Vlan-interface2
         Upstream neighbor: FE81::1
         RPF prime neighbor: FE81::1
         Join/Prune FSM: [SPT: J] [RPT: NP]
     Downstream interface information:
         1: Vlan-interface3
             Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
# 显示公网实例IPv6 PIM路由表的状态机信息。
<Sysname> display ipv6 pim routing-table fsm
 Abbreviations for FSM states:
     NI - no info, J - joined, NJ - not joined, P - pruned,
     NP - not pruned, PP - prune pending, W - winner, L - loser,
     F - forwarding, AP - ack pending, DR - designated router,
     NDR - non-designated router, RCV - downstream receivers
     RP: FE80::A01:100:1
     UpTime: 02:54:43
         1: Vlan-interface2
             DR state: [DR]
             Join/Prune FSM: [NI]
             Assert FSM: [NI]
     FSM information for non-downstream interfaces: None
# 显示跨VPN组播的IPv6 PIM路由项信息。
<Sysname> display ipv6 pim vpn-instance vpn1 routing-table extranet receive-vpn-instance vpn2
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, FFE3::101)
     RP: FE80::A01:100:1
     Protocol: pim-sm, Flag: WC
     UpTime: 07:06:11
     Upstream interface: Register-Tunnel0
     Total number of downstream interfaces: 2
         1: Vlan-interface1
             Protocol: pim-sm, UpTime: 07:06:11, Expires: -
         2: Extranet (VPN: vpn2)
             Protocol: MD, UpTime: 01:12:52, Expires: -
     RP: FE80::A01:100:1
     UpTime: 07:06:10
     Upstream interface: MTunnel0
         Upstream neighbor: FE80::1
         RPF prime neighbor: FE80::1
         1: Vlan-interface1
             Protocol: MD, UpTime: 01:29:07, Expires: -
表1-7 display ipv6 pim routing-table命令显示信息描述表
IPv6 PIM路由表中(S,G)表项的总数与(*,G)表项的总数
NI - no info, J - joined, NJ - not joined, P – pruned
NP - not pruned, PP - prune pending, W - winner, L – loser
状态机的缩写:NI表示初始状态,J表示加入状态,P表示剪枝状态,NP表示未剪枝状态,PP表示剪枝未决状态,W表示断言当选,L表示断言落选,F表示转发状态,AP表示嫁接确认状态,DR表示指定路由器,NDR表示非指定路由器,RCV表示下游接收者
IPv6 PIM路由表中的(S,G)表项
RP
RP的地址
Protocol
IPv6 PIM的模式
Flag
IPv6 PIM路由表中(S,G)或(*,G)表项的标志:
·     ACT:表示已有实际数据到达
·     DEL:表示计划要删除
·     EXPRUNE:表示某些出接口被其它IPv6组播路由协议剪枝
·     EXT:表示包含了由其它IPv6组播路由协议提供的出接口
·     LOC:表示与IPv6组播源处于同一网段
·     NIIF:表示未确定入接口
·     NONBR:表示IPv6 PIM邻居查找失败
·     RPT:表示向RP方向发送过(S,G)RPT位剪枝
·     RQ:表示Data-MDT切换接收端的PIM路由项
·     SPT:表示在SPT上
·     SQ:表示Data-MDT切换发起端的PIM路由项
·     SWT:表示正在向SPT切换
·     WC:表示带WC通配符
Uptime
(S,G)或(*,G)表项已存在的时间
Upstream interface
(S,G)或(*,G)表项的入接口
(S,G)或(*,G)表项的备入接口,使能了nbma模式的ADVPN隧道口,显示远端连接IPv6地址;当(S,G)或(*,G)表项的IPv6组播FRR功能生效且存在备入接口时,才显示该字段
Upstream neighbor
(S,G)或(*,G)表项的上游邻居
RPF prime neighbor
(S,G)或(*,G)表项的RPF邻居:
·     对(*,G)表项来说,当该路由器是RP时,(*,G)表项的RPF邻居是NULL
·     对(S,G)表项来说,当该路由器直连源时,(S,G)表项的RPF邻居是NULL
DR state
DR的状态
Join/Prune FSM
加入/剪枝状态机
Assert FSM
断言状态机
下游接口的信息,包括:
·     下游接口的总数
·     下游接口的名称
·     下游接口使用的协议类型
·     下游接口的存在时间
·     下游接口的超时时间
非下游接口的状态机信息
display ipv6 pim rp-info命令用来显示IPv6 PIM-SM域中的RP的信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] rp-info [ ipv6-group-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的RP信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的RP信息。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组所对应的RP信息,取值范围为FFxy::/16(但不包括下列地址: FFx1::/16、FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组对应的RP信息。
# 显示公网实例中IPv6组播组FF73:130:7:12::1所对应的RP信息。
<Sysname> display ipv6 pim rp-info ff73:130:7:12::1
 Embedded RP address is: 7:12::1
     Configured ACL: 2000
 BSR RP address is: 7:12::1
     Priority: 192
     HoldTime: 180
     Uptime: 03:01:10
     Expires: 00:02:30
 Static RP address is: 7:12::1
     Preferred: No
     Configured ACL: 2003
 RP mapping for this group is: 7:12::1 (local host)
 Anycast-RP 7:12::1 members:
     Member address           State
     1:1::1                   Active
     1:1::2                   Local
     1:2::1                   Remote
# 显示所有IPv6组播组对应的RP信息。
 IPv6 PIM-SM embedded RP information:
   Embedded RP ACL: 2000
       Group                    RP address
       FF73:230:8:12::          8:12::2
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: FF73:230:8:12::/64
       8:12::2 (local)          192       180       03:01:36  00:02:29
     Group/MaskLen: FF23::/92 [B]
       7:12::1 (local)          192       180       00:00:39  00:02:57
 Static RP information:
       RP address               ACL   Mode    Preferred
       3:3::1                   2000  pim-sm  No
       3:3::2                   2001  pim-sm  Yes
       3:3::3                   2002  pim-sm  No
       3:3::4                         pim-sm  No
       3:3::5                   2002  pim-sm  Yes
 Anycast-RP information:
       RP address               Member address           State
       3:3::1                   1:1::1 Active
       3:3::1                   1:1::2 Local
       3:3::1                   1:2::1                   Remote
表1-8 display ipv6 pim rp-info命令显示信息描述表
嵌入式RP的IPv6地址
IPv6 PIM-SM Embedded RP information
嵌入式RP的信息
Embedded RP ACL
嵌入式RP关联的ACL
Group
嵌入式RP对应的IPv6组播组
BSR RP address is
RP的IPv6地址
BSR RP information
BSR RP信息
Scope
Group/MaskLen
RP所服务的IPv6组播组
[B]
(暂不支持IPv6双向PIM)表示RP服务于IPv6双向PIM。如果不显示该字段,则表示RP服务于IPv6 PIM-SM
RP address
Priority
RP的优先级
HoldTime
RP的超时时间
Uptime
RP已存在的时间
Expires
RP超时的剩余时间
静态RP信息
Static RP address is/RP address
静态RP的IPv6地址
Preferred
是否指定了静态RP优先
Configured ACL/ACL
配置的RP所关联的ACL
Mode
为IPv6 PIM-SM服务
服务于当前组播组的RP的IPv6地址
Anycast-RP 7:12::1的成员
Member address
Anycast-RP成员的IPv6地址
Anycast-RP成员地址的来源:
·     Active:表示本端激活接口的地址
·     Local:表示本端未激活接口的地址
·     Remote:表示远端的地址
Anycast-RP信息
display ipv6 pim statistics命令用来显示IPv6 PIM协议报文的统计信息。
# 显示IPv6 PIM协议报文的统计信息。
<Sysname> display ipv6 pim statistics
 Received PIM packets: 3295
 Sent PIM packets    : 5975
                Valid       Invalid        Succeeded   Failed
     Hello    : 3128        0              4333        0
     Reg      : 14          0              0           0
     Reg-stop : 0           0              0           0
     JP       : 151         0              561         0
     BSM      : 0           0              1081        0
     Assert   : 0           0              0           0
     Graft    : 0           0              0           0
     Graft-ACK: 0           0              0           0
     C-RP     : 0           0              0           0
     SRM      : 0           0              0           0
     AutoRP   : 0           0              0           0
表1-9 display ipv6 pim statistics命令显示信息描述表
收到的IPv6 PIM协议报文总数
Sent PIM packets
发出的IPv6 PIM协议报文总数
Valid
收到的合法IPv6 PIM协议报文数量
Invalid
收到的非法IPv6 PIM协议报文数量
Succeeded
发送成功的IPv6 PIM协议报文数量
Failed
发送失败的IPv6 PIM协议报文数量
Hello
Hello报文统计
Reg
注册报文统计
Reg-stop
注册停止报文统计
JP
加入/剪枝报文统计
BSM
自举报文统计
Assert
断言报文统计
Graft
嫁接报文统计
Graft-ACK
嫁接应答报文统计
C-RP
C-RP报文统计
SRM
状态刷新报文统计
AutoRP
自动RP报文统计
1.1.19  dscp
dscp命令用来配置设备发送IPv6 PIM协议报文的DSCP优先级。
undo dscp命令用来恢复缺省情况。
dscp dscp-value
undo dscp
设备发送IPv6 PIM协议报文的DSCP优先级为48。
IPv6 PIM视图
dscp-value:DSCP值,取值范围为0~63。
DSCP(Differentiated Services Code Point,差分服务编码点)携带在IP报文中的ToS字段,用来体现报文自身的优先等级,决定报文传输的优先程度。DSCP优先级的取值越大,报文的优先级越高。
# 配置设备发送IPv6 PIM报文的DSCP优先级为63。
[Sysname] ipv6 pim
[Sysname-pim6] dscp 63
1.1.20  embedded-rp
embedded-rp命令用来开启嵌入式RP功能。
undo embedded-rp命令用来关闭嵌入式RP功能。
embedded-rp [ ipv6-acl-number ]
undo embedded-rp
嵌入式RP功能处于关闭状态。
IPv6 PIM视图
嵌入式RP(Embedded RP)是IPv6 PIM中特有的RP发现机制,该机制使用内嵌RP地址的IPv6组播地址,使得设备可以直接从该地址中解析出RP的地址。
只有组地址在为FF7x::/12或FFFx::/12,且符合格式要求的IPv6组播组支持嵌入式RP功能。有关嵌入式RP支持的组地址格式要求的详细介绍,请参见“IP组播”中的“IPv6 PIM”。
执行本命令时,如果未指定ipv6-acl-number参数,则对该范围内的所有IPv6组播组均开启嵌入式RP功能;如果指定了ipv6-acl-number参数,则只有在该范围内且通过了ACL检查的IPv6组播组才能开启嵌入式RP功能。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示对该范围内的所有IPv6组播组均开启嵌入式RP功能。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
# 为组地址在FF7E:140:20::101/64范围内的IPv6组播组开启嵌入式RP功能。
[Sysname-acl-ipv6-basic-2000] rule permit source ff7e:140:20::101 64
[Sysname] ipv6 pim
[Sysname-pim6] embedded-rp 2000
hello-option dr-priority命令用来全局配置竞选DR的优先级。
undo hello-option dr-priority命令用来恢复缺省情况。
竞选DR的优先级为1。
IPv6 PIM视图
priority:指定竞选DR的优先级,取值范围为0~4294967295。该数值越大,优先级越高。
本配置既可在IPv6 PIM视图又可在接口视图下进行,前者对所有接口都生效,而后者只对当前接口生效,但后者的配置优先级较高。
# 在公网实例中全局配置竞选DR的优先级为3。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option dr-priority 3
·     ipv6 pim hello-option dr-priority
hello-option holdtime命令用来全局配置保持IPv6 PIM邻居可达状态的时间。
undo hello-option holdtime命令用来恢复缺省情况。
hello-option holdtime time
保持IPv6 PIM邻居可达状态的时间为105秒。
IPv6 PIM视图
time:指定保持IPv6 PIM邻居可达状态的超时时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
# 在公网实例中全局配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option holdtime 120
·     ipv6 pim hello-option holdtime
hello-option lan-delay命令用来全局配置IPv6 PIM报文在共享网段中的传输延迟。
undo hello-option lan-delay命令用来恢复缺省情况。
hello-option lan-delay delay
IPv6 PIM报文在共享网段中的传输延迟为500毫秒。
IPv6 PIM视图
delay:指定IPv6 PIM报文在共享网段中的传输延迟,取值范围为1~32767,单位为毫秒。
# 在公网实例中全局配置IPv6 PIM报文在共享网段中的传输延迟为200毫秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option lan-delay 200
·     hello-option override-interval (IPv6 PIM view)
·     ipv6 pim hello-option lan-delay
·     ipv6 pim hello-option override-interval
hello-option neighbor-tracking命令用来全局开启邻居跟踪功能。
undo hello-option neighbor-tracking命令用来全局关闭邻居跟踪功能。
邻居跟踪功能处于关闭状态。
IPv6 PIM视图
# 在公网实例中全局开启邻居跟踪功能。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option neighbor-tracking
·     ipv6 pim hello-option neighbor-tracking
hello-option override-interval命令用来全局配置剪枝否决时间。
undo hello-option override-interval命令用来恢复缺省情况。
剪枝否决时间为2500毫秒。
IPv6 PIM视图
interval:指定剪枝的否决时间,取值范围为1~65535,单位为毫秒。
# 在公网实例中全局配置剪枝否决时间为2000毫秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option override-interval 2000
·     hello-option lan-delay (IPv6 PIM view)
holdtime join-prune命令用来全局配置加入/剪枝状态的保持时间。
undo holdtime join-prune命令用来恢复缺省情况。
holdtime join-prune time
加入/剪枝状态的保持时间为210秒。
IPv6 PIM视图
time:指定加入/剪枝状态的保持时间,取值范围为1~65535,单位为秒。
IPv6 PIM接口向上游邻居发送加入/剪枝报文的时间间隔必须小于加入/剪枝状态的保持时间,以免上游邻居老化超时。
# 在公网实例中全局配置加入/剪枝状态的保持时间为280秒。
[Sysname] ipv6 pim
[Sysname-pim6] holdtime join-prune 280
·     ipv6 pim holdtime join-prune
·     timer join-prune (IPv6 PIM view)
1.1.27  ipv6 pim
ipv6 pim命令用来进入IPv6 PIM视图。
undo ipv6 pim命令用来清除IPv6 PIM视图下的所有配置。
undo ipv6 pim [ vpn-instance vpn-instance-name ]
# 先使能公网实例中的IPv6组播路由,再进入公网实例的IPv6 PIM视图。
[Sysname] ipv6 multicast routing
[Sysname-mrib6] quit
[Sysname] ipv6 pim
[Sysname-pim6]
# 先使能VPN实例mvpn中的IPv6组播路由,再进入该VPN实例的IPv6 PIM视图。
[Sysname] ipv6 multicast routing vpn-instance mvpn
[Sysname-mrib6-mvpn] quit
[Sysname-pim6-mvpn]
ipv6 pim bfd enable命令用来开启IPv6 PIM与BFD联动功能。
undo ipv6 pim bfd enable命令用来关闭IPv6 PIM与BFD联动功能。
ipv6 pim bfd enable
IPv6 PIM与BFD联动功能处于关闭状态。
只有在接口上先使能了IPv6 PIM-DM或IPv6 PIM-SM,本命令才能生效。
# 使能公网实例中的IPv6组播路由,在接口Vlan-interface100上使能IPv6 PIM-DM,并开启IPv6 PIM与BFD联动功能。
[Sysname-Vlan-interface100] ipv6 pim dm
[Sysname-Vlan-interface100] ipv6 pim bfd enable
·     ipv6 pim dm
·     ipv6 pim sm
ipv6 pim bsr-boundary命令用来配置BSR的服务边界,即IPv6 PIM-SM域的边界。
undo ipv6 pim bsr-boundary命令用来恢复缺省情况。
不存在BSR的服务边界。
# 配置接口Vlan-interface100为BSR的服务边界。
[Sysname-Vlan-interface100] ipv6 pim bsr-boundary
·     ipv6 multicast boundary(IP组播命令参考/IPv6组播路由与转发)
1.1.30  ipv6 pim dm
ipv6 pim dm命令用来使能IPv6 PIM-DM。
undo ipv6 pim dm命令用来关闭IPv6 PIM-DM。
ipv6 pim dm
undo ipv6 pim dm
IPv6 PIM-DM处于关闭状态。
只有在相应实例中先使能了IPv6组播路由,本命令才能生效。
# 使能公网实例中的IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-DM。
·     ipv6 multicast routing(IP组播命令参考/IPv6组播路由与转发)
ipv6 pim hello-option dr-priority命令用来在接口上配置竞选DR的优先级。
undo ipv6 pim hello-option dr-priority命令用来恢复缺省情况。
ipv6 pim hello-option dr-priority priority
竞选DR的优先级为1。
# 在接口Vlan-interface100上配置竞选DR的优先级为3。
[Sysname-Vlan-interface100] ipv6 pim hello-option dr-priority 3
·     hello-option dr-priority (IPv6 PIM view)
ipv6 pim hello-option holdtime命令用来在接口上配置保持IPv6 PIM邻居的可达状态的时间。
undo ipv6 pim hello-option holdtime命令用来恢复缺省情况。
ipv6 pim hello-option holdtime time
time:指定保持IPv6 PIM邻居可达状态的时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
# 在接口Vlan-interface100上配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname-Vlan-interface100] ipv6 pim hello-option holdtime 120
·     hello-option holdtime (IPv6 PIM view)
ipv6 pim hello-option lan-delay命令用来在接口上配置IPv6 PIM报文在共享网段中的传输延迟。
undo ipv6 pim hello-option lan-delay命令用来恢复缺省情况。
ipv6 pim hello-option lan-delay delay
# 在接口Vlan-interface100上配置IPv6 PIM报文在共享网段中的传输延迟为200毫秒。
[Sysname-Vlan-interface100] ipv6 pim hello-option lan-delay 200
ipv6 pim hello-option neighbor-tracking命令用来在接口上开启邻居跟踪功能。
ipv6 pim hello-option neighbor-tracking disable命令用来在全局开启了邻居跟踪功能的情况下,关闭当前接口上的邻居跟踪功能。
undo ipv6 pim hello-option neighbor-tracking命令用来取消接口上的邻居跟踪功能配置,使得接口与全局配置保持一致。
接口上的邻居跟踪功能处于关闭状态。
# 在接口Vlan-interface100上开启邻居跟踪功能。
[Sysname-Vlan-interface100] ipv6 pim hello-option neighbor-tracking
# 在公网实例全局开启了邻居跟踪功能的情况下,关闭接口Vlan-interface100上的邻居跟踪功能。
[Sysname] ipv6 pim
[Sysname-pim6] quit
[Sysname-Vlan-interface100] ipv6 pim hello-option neighbor-tracking disable
·     hello-option neighbor-tracking (IPv6 PIM view)
ipv6 pim hello-option override-interval命令用来在接口上配置剪枝否决时间。
undo ipv6 pim hello-option override-interval命令用来恢复缺省情况。
ipv6 pim hello-option override-interval interval
剪枝否决时间为2500毫秒。
# 在接口Vlan-interface100上配置剪枝否决时间为2000毫秒。
[Sysname-Vlan-interface100] ipv6 pim hello-option override-interval 2000
ipv6 pim holdtime join-prune命令用来在接口上配置加入/剪枝状态的保持时间。
undo ipv6 pim holdtime join-prune命令用来恢复缺省情况。
ipv6 pim holdtime join-prune time
加入/剪枝状态的保持时间为210秒。
# 在接口Vlan-interface100上配置加入/剪枝状态的保持时间为280秒。
[Sysname-Vlan-interface100] ipv6 pim holdtime join-prune 280
·     holdtime join-prune (IPv6 PIM view)
·     ipv6 pim timer join-prune
ipv6 pim join-policy命令用来在接口上配置IPv6 PIM加入/剪枝报文中加入信息的过滤规则。
undo ipv6 pim join-policy命令用来恢复缺省情况。
ipv6 pim join-policy { { ipv6-acl-number | name ipv6-acl-name } | [ asm { ipv6-acl-number | name ipv6-acl-name } | ssm { ipv6-acl-number | name ipv6-acl-name } ] * }
不过滤IPv6 PIM加入/剪枝报文中的加入信息。
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。当指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有的加入信息。
name ipv6-acl-name:指定IPv6基本或高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有的加入信息。
asm { ipv6-acl-number| name ipv6-acl-name }:过滤组地址在ASM范围内的加入信息,取值范围为2000~3999。如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则过滤掉ASM范围内所有的加入信息。其中:
·     ipv6-acl-number指定IPv6基本或高级ACL的编号,取值范围为2000~3999
·     name ipv6-acl-name指定IPv6基本或者高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all
ssm { ipv6-acl-number | name ipv6-acl-name }:过滤组地址在SSM范围内的加入信息。如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则过滤掉SSM范围内所有的加入信息。其中:
·     name ipv6-acl-name:指定IPv6基本或者高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
此命令对IPv6 PIM-DM不生效。
为了防止设备受到非法IPv6 PIM加入/剪枝报文攻击,通过配置本功能可以配置过滤规则,限制IPv6 PIM加入/剪枝报文中(S,G)加入信息的合法源地址范围和组地址范围,丢弃不合法的(S,G)加入信息,不建立对应的(S,G)表项。
对于IPv6基本ACL,本命令通过ACL规则中的source参数指定IPv6 PIM加入/剪枝报文中加入信息的组播组地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
对于IPv6高级ACL,本命令通过ACL规则中的source参数指定IPv6 PIM加入/剪枝报文中加入信息的组播源地址范围,对于(*,G)信息,组播源地址视为::,destination参数用来指定加入信息的组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
# 在接口Vlan-interface100上配置过滤规则,只允许接收源地址范围是1::1/128、组地址范围是FF33::101/128的IPv6 PIM加入/剪枝报文。
[Sysname] acl ipv6 advanced 3005
[Sysname-acl-ipv6-adv-3005] rule permit ipv6 source 1::1 128 destination FF33::101 128
[Sysname-acl-ipv6-adv-3005] quit
[Sysname-Vlan-interface100] ipv6 pim join-policy ssm 3005
ipv6 pim log enable命令用来开启IPv6 PIM的日志信息功能。
undo ipv6 pim log enable命令用来关闭IPv6 PIM的日志信息功能。
ipv6 pim log enable [ dr | error-packet | neighbor | rp ] *
undo ipv6 pim log enable [ dr | error-packet | neighbor | rp ] *
IPv6 PIM的日志信息功能处于开启状态。
dr:DR选举相关的日志信息。
error-packet:IPv6 PIM错误报文类型的日志信息。
neighbor:IPv6 PIM邻居类型的日志信息。
rp:RP变化相关的日志信息。
IPv6 PIM日志信息可以方便管理员定位问题和解决问题,生成的日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。有关信息中心的详细描述,请参见“网络管理和监控配置指导”中的“信息中心”。
当设备输出大量IPv6 PIM日志信息时,会降低设备性能。此时,用户可以通过ipv6 pim log suppress命令开启IPv6 PIM日志限速功能。
执行本命令时,如果未指定任何参数,则表示开启或关闭IPv6 PIM所有类型日志信息功能。
# 开启IPv6 PIM所有类型日志信息功能。
[Sysname] ipv6 pim log enable
·     ipv6 pim log suppress
ipv6 pim log suppress命令用来开启IPv6 PIM日志限速功能。
undo ipv6 pim log suppress命令用来关闭IPv6 PIM日志限速功能。
ipv6 pim log suppress [ dr | error-packet | neighbor | rp ] *
undo ipv6 pim log suppress [ dr | error-packet | neighbor | rp ] *
IPv6 PIM的日志限速功能处于开启状态。
dr:DR选举相关的日志信息。
rp:RP变化相关的日志信息。
当设备输出大量IPv6 PIM日志信息时,会降低设备性能。此时,可以通过本命令开启IPv6 PIM日志限速功能。开启本功能后,IPv6 PIM模块输出到信息中心的日志速度将会被限制,从而减轻设备的负担。
开启本命令前,请确保已通过ipv6 pim log enable命令开启了PIM日志功能。
执行本命令时,如果未指定任何参数,则表示开启或关闭IPv6 PIM所有类型日志限速功能。
# 开启IPv6 PIM的所有类型日志限速功能。
[Sysname] ipv6 pim log suppress
·     ipv6 pim log enable
ipv6 pim neighbor-policy命令用来配置合法Hello报文的源地址范围。
undo ipv6 pim neighbor-policy命令用来恢复缺省情况。
ipv6 pim neighbor-policy { ipv6-acl-number | name ipv6-acl-name }
Hello报文的源地址范围不受限制,即认为所有收到的Hello报文都是合法的。
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。如果指定的ACL不存在或ACL中未配置有效规则,则过滤所有的Hello报文源地址,即认为所有收到的Hello报文都是非法的。
name ipv6-acl-name:指定IPv6基本或高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定的ACL不存在或ACL中未配置有效规则,则过滤所有的Hello报文源地址,即认为所有收到的Hello报文都是非法的。
配置合法Hello报文的源地址范围可以防止Hello报文欺骗。
本命令通过ACL规则中的source参数指定合法Hello报文的源组地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
# 在接口Vlan-interface100上配置合法Hello报文的源地址范围,只允许与来自网段FE80:101::101/64中的设备建立IPv6 PIM邻居关系。
[Sysname-acl-ipv6-basic-2000] rule permit source fe80:101::101 64
[Sysname-Vlan-interface100] ipv6 pim neighbor-policy 2000
ipv6 pim non-stop-routing命令用来开启IPv6 PIM协议的NSR功能。
undo ipv6 pim non-stop-routing命令用来关闭IPv6 PIM协议的NSR功能。
IPv6 PIM协议的NSR功能处于关闭状态。
# 开启IPv6 PIM NSR功能。
[Sysname] ipv6 pim non-stop-routing
ipv6 pim passive命令用来在接口上开启IPv6 PIM消极模式。
undo ipv6 pim passive命令用来在接口上关闭IPv6 PIM消极模式。
ipv6 pim passive
接口上的IPv6 PIM消极模式处于关闭状态。
# 使能公网实例中的IPv6组播路由,在接口Vlan-interface100上使能IPv6 PIM-DM,并开启IPv6 PIM消极模式。
[Sysname-Vlan-interface100] ipv6 pim passive
ipv6 pim require-genid命令用来配置拒绝无Generation ID的Hello报文。
undo ipv6 pim require-genid命令用来恢复缺省情况。
接受无Generation ID的Hello报文。
# 配置接口Vlan-interface100拒绝无Generation ID的Hello报文。
[Sysname-Vlan-interface100] ipv6 pim require-genid
1.1.44  ipv6 pim sm
ipv6 pim sm命令用来使能IPv6 PIM-SM。
undo ipv6 pim sm命令用来关闭IPv6 PIM-SM。
ipv6 pim sm
undo ipv6 pim sm
IPv6 PIM-SM处于关闭状态。
# 使能公网实例中的IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-SM。
[Sysname-Vlan-interface100] ipv6 pim sm
ipv6 pim state-refresh-capable命令用来开启状态刷新能力。
undo ipv6 pim state-refresh-capable命令用来关闭状态刷新能力。
状态刷新能力处于开启状态。
# 在接口Vlan-interface100上关闭状态刷新能力。
[Sysname-Vlan-interface100] undo ipv6 pim state-refresh-capable
·     state-refresh-hoplimit (IPv6 PIM view)
·     state-refresh-interval (IPv6 PIM view)
·     state-refresh-rate-limit (IPv6 PIM view)
ipv6 pim timer dr-elect-delay命令用来在接口上配置DR选举的延迟时间。
undo ipv6 pim timer dr-elect-delay命令用来恢复缺省情况。
ipv6 pim timer dr-elect-delay delay-time
DR选举不延时。
delay-time:DR选举的延迟时间,取值范围为10~3600,单位为秒。
应用场景
在与接收者相连的共享网段上,通常同时连接着多台IPv6 PIM设备。多台IPv6 PIM设备会通过DR选举机制选举出一台负责转发组播报文的IPv6 PIM设备(即DR)。在某些场景下,比如原先故障的DR恢复正常后,发送IPv6 PIM Hello报文参与DR选举,会立即被选为DR,导致当前DR变成非DR。此时,恢复正常并当选为DR的那台设备尚未生成完整的组播转发表项,会导致短时间内有组播流量的丢失,造成组播数据断流。
工作机制
配置本命令后,原先故障的DR设备在恢复正常后,不会立即发送IPv6 PIM Hello报文参与DR选举,而是需要等待delay-time,设备才开始参与DR选举。此时,在延迟时间超时前,IPv6组播数据仍然由当前DR进行转发,减少了IPv6组播流量的断流。
推荐配置
建议在DR设备用户侧接口(开启了MLD功能的接口)上配置本命令,非DR设备不需要配置。若DR设备和非DR设备都配置,则设备均故障重启后,DR选举的延迟时间超时之前会出现断流。
建议配置的DR选举的延迟时间大于IPv6 PIM Hello报文的发送间隔,否则会导致DR设备故障恢复后出现短暂的多包。
# 在接口Vlan-interface100上配置DR选举的延迟时间为70秒。
[Sysname-Vlan-interface100] ipv6 pim timer dr-elect-delay 70
ipv6 pim timer graft-retry命令用来配置嫁接报文的重传时间。
undo ipv6 pim timer graft-retry命令用来恢复缺省情况。
ipv6 pim timer graft-retry interval
嫁接报文的重传时间为3秒。
interval:指定嫁接报文的重传时间,取值范围为1~65535,单位为秒。
# 在接口Vlan-interface100上配置嫁接报文的重传时间为80秒。
[Sysname-Vlan-interface100] ipv6 pim timer graft-retry 80
ipv6 pim timer hello命令用来在接口上配置发送Hello报文的时间间隔。
undo ipv6 pim timer hello命令用来恢复缺省情况。
ipv6 pim timer hello interval
发送Hello报文的时间间隔为30秒。
interval:指定发送Hello报文的时间间隔,取值范围为0~18000,单位为秒。0表示无穷大,即永不发送Hello报文。
# 在接口Vlan-interface100上配置发送Hello报文的时间间隔为40秒。
[Sysname-Vlan-interface100] ipv6 pim timer hello 40
·     timer hello (IPv6 PIM view)
ipv6 pim timer join-prune命令用来在接口上配置发送加入/剪枝报文的时间间隔。
undo ipv6 pim timer join-prune命令用来恢复缺省情况。
ipv6 pim timer join-prune interval
发送加入/剪枝报文的时间间隔为60秒。
interval:指定发送加入/剪枝报文的时间间隔,取值范围为0~18000,单位为秒。0表示无穷大,即永不发送加入/剪枝报文。
本命令不会立即生效,新配置的发送间隔将在当前发送间隔完成后生效。
# 在接口Vlan-interface100上配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname-Vlan-interface100] ipv6 pim timer join-prune 80
ipv6 pim triggered-hello-delay命令用来配置触发Hello报文的最大延迟时间。
undo ipv6 pim triggered-hello-delay命令用来恢复缺省情况。
ipv6 pim triggered-hello-delay delay
触发Hello报文的最大延迟时间为5秒。
delay:指定触发Hello报文的最大延迟时间,取值范围为1~60,单位为秒。
# 在接口Vlan-interface100上配置触发Hello报文的最大延迟时间为3秒。
[Sysname-Vlan-interface100] ipv6 pim triggered-hello-delay 3
ipv6 pim triggered-hello enable命令用来配置设备在端口链路状态发生变化时立刻发送Generation ID变化的Hello报文,以及时更新组播转发表项。
undo ipv6 pim triggered-hello enable命令用来取消在端口链路状态发生变化时立刻发送Generation ID变化的Hello报文。
ipv6 pim triggered-hello enable { port-down | port-up } *
undo ipv6 pim triggered-hello enable [ port-down | port-up ] *
设备不会因为端口链路状态发生变化而立刻发送Generation ID变化的Hello报文。
VLAN接口视图
port-down:指定端口状态变为down时,立刻发送Generation ID变化的Hello报文。
port-up:指定端口状态变为up时,立刻发送Generation ID变化的Hello报文。
为了提高可靠性,组播转发路径中的下游设备通过同一VLAN内的多个二层接口接入上游设备。当上游设备上的二层端口链路状态发生故障或者故障恢复时,下游设备需要切换到新的端口或者回切到该端口接入设备。在这些情况下,下游设备通常不会立即发送IPv6 PIM加入报文,导致组播数据不能及时切换到变更后的路径上。执行本命令后,设备上指定VLAN接口对应VLAN内的端口链路状态变化时,设备主动发送Generation ID变化的Hello报文,以触发下游设备立即发送IPv6 PIM加入报文,更新组播转发表项,将组播数据流迅速切换到新的转发路径上。
执行undo ipv6 pim triggered-hello enable命令时,如果没有指定任何参数,则表示端口状态变为down和up时,都不会立刻发送Generation ID变化的Hello报文。
# 配置设备在端口链路状态发生变化时立刻发送Generation ID变化的Hello报文。
[Sysname-Vlan-interface10] ipv6 pim triggered-hello enable port-down port-up
jp-pkt-size命令用来配置加入/剪枝报文的最大长度。
undo jp-pkt-size命令用来恢复缺省情况。
jp-pkt-size size
undo jp-pkt-size
加入/剪枝报文的最大长度为1200字节。
IPv6 PIM视图
size:指定加入/剪枝报文的最大长度,取值范围为100~64000,单位为字节。为了防止IPv6 PIM协议报文分片导致功能异常,建议配置该参数的值小于使能了IPv6 PIM功能的接口的MTU值。‌
# 在公网实例中配置加入/剪枝报文的最大长度为1500字节。
[Sysname] ipv6 pim
[Sysname-pim6] jp-pkt-size 1500
register-policy命令用来配置注册报文的过滤策略。
undo register-policy命令用来恢复缺省情况。
register-policy { ipv6-acl-number | name ipv6-acl-name }
不存在注册报文的过滤策略。
IPv6 PIM视图
ipv6-acl-number:指定IPv6高级ACL的编号,取值范围为3000~3999。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有的注册报文。
name ipv6-acl-name:指定IPv6高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有的注册报文。
本命令指定ACL规则中的source参数用来指定注册报文中的IPv6组播源地址范围,destination参数用来指定IPv6组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
只有与该ACL规则中的permit语句匹配的注册报文才会被RP接受。
# 在公网实例中配置RP上对注册报文的过滤策略,只接收来自3:1::/64网段的IPv6组播源发向FF0E:13::/64网段的IPv6组播组的注册报文。
[Sysname-acl-ipv6-adv-3000] rule permit ipv6 source 3:1:: 64 destination ff0e:13:: 64
[Sysname] ipv6 pim
[Sysname-pim6] register-policy 3000
register-suppression-timeout命令用来配置注册抑制时间。
undo register-suppression-timeout命令用来恢复缺省情况。
注册抑制时间为60秒。
IPv6 PIM视图
interval:指定注册抑制时间,取值范围为1~65535,单位为秒。
# 在公网实例中配置注册抑制时间为70秒。
[Sysname] ipv6 pim
[Sysname-pim6] register-suppression-timeout 70
register-whole-checksum命令用来配置根据注册报文的全部内容来计算校验和。
undo register-whole-checksum命令用来恢复缺省情况。
仅根据注册报文头来计算校验和。
IPv6 PIM视图
# 在公网实例中配置根据注册报文的全部内容来计算校验和。
[Sysname] ipv6 pim
[Sysname-pim6] register-whole-checksum
rpf-frr enable命令用来开启IPv6 PIM FRR功能。
undo rpf-frr enable命令用来关闭IPv6 PIM FRR功能。
rpf-frr enable [ policy { ipv6-acl-number | name ipv6-acl-name } ]
undo rpf-frr enable
IPv6 PIM FRR功能处于关闭状态。
IPv6 PIM视图
policy { ipv6-acl-number | name ipv6-acl-name }:指定IPv6 PIM FRR功能生效的IPv6组播表项范围。如果未指定本参数,则表示IPv6 PIM FRR功能对所有的IPv6组播表项生效;如果指定了本参数,但指定的ACL不存在或ACL中未配置有效规则,则表示IPv6 PIM FRR功能对所有的IPv6组播表项不生效。其中:
应用场景
当IPv6组播网络中的链路或某台路由器发生故障时,需要通过故障链路或故障路由器传输才能到达组播接收者的报文将会丢失或产生路由环路,组播数据流量将会中断。直到新的单播网络拓扑路由收敛并重新建立组播转发树后,被中断的组播流量才能恢复正常的传输。此时,组播流量中断时间较长,远远不能满足实时性要求高的业务的需求。
在组播链路经过的节点设备上开启PIM FRR(Fast Reroute,快速重路由)功能后,IPv6 PIM协议会根据备份RPF路由建立备份组播转发树。在主RPF路由可达时,主备组播转发路径上都有流量经过,但是只有主路径上收到的流量数据会通过主路径上的接口向接收者转发。当主RPF路由不可达时,组播流量会快速切换到已建立好的备份组播转发路径,通过备份组播转发树发送给接收者。通过该功能,可以大大缩短主路径上的设备或者链路故障发生后的组播数据的断流时间。
注意事项
·     设备上开启了IPv6 PIM FRR功能,只会对匹配的(S,G)表项生成备份的入接口,而不会生成备份的出接口。
·     仅PIM-SM和PIM-SSM模式中支持本功能。
·     组播跨VPN组网中不支持本功能。
·     IPv6 PIM FRR通过周期性检测流量的方式判断链路故障,仅适用于持续、大速率转发组播流量的场景。非此类场景下,如组播VPN场景中,请勿配置本功能。
·     多次执行本命令,最后一次执行的命令生效。
·     对于policy { ipv6-acl-number | name ipv6-acl-name }参数:
¡     若指定高级ACL:该ACL规则中的source参数用来指定组播源地址范围,destination参数用来指定组播组地址范围,只有sourcedestination参数均匹配该规则,该规则才生效。该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
¡     若指定基本ACL:该ACL规则中的source参数用来指定组播源地址范围。只要组播源地址匹配该规则,该规则便生效。该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
# 在公网中配置IPv6 PIM FRR功能只对源地址范围为2001::/80、组播组地址范围为ff1e:1::/80的表项生效。
[Sysname-acl-ipv6-adv-3005] rule permit ip source 2001:: 80 destination ff1e:1:: 80
[Sysname] ipv6 pim
[Sysname-pim6] rpf-frr enable policy 3005
snmp-agent trap enable pim6命令用来开启IPv6 PIM的告警功能。
undo snmp-agent trap enable pim6命令用来关闭IPv6 PIM的告警功能。
snmp-agent trap enable pim6 [ candidate-bsr-win-election | elected-bsr-lost-election | interface-election | invalid-join-prune | invalid-register | neighbor-loss | private-interface-election | private-neighbor-loss | private-new-neighbor | private-rp-mapping-change | rp-mapping-change ] *
undo snmp-agent trap enable pim6 [ candidate-bsr-win-election | elected-bsr-lost-election | interface-election | invalid-join-prune | invalid-register | neighbor-loss | private-interface-election | private-neighbor-loss | private-new-neighbor | private-rp-mapping-change | rp-mapping-change ] *
IPv6 PIM的告警功能处于开启状态。
candidate-bsr-win-election:表示C-BSR成功当选BSR的告警信息。
elected-bsr-lost-election:表示原BSR在新的选举中失败的告警信息。
interface-election:表示设备成功当选为DR的PIM-STD-MIB告警信息。
invalid-join-prune:表示IPv6 PIM收到无效的加入/剪枝报文的告警信息。
invalid-register:表示IPv6 PIM收到无效的注册报文的告警信息。
neighbor-loss:表示PIM邻居丢失的PIM-STD-MIB告警信息。
private-interface-election:表示设备成功当选为DR的告警信息。
private-neighbor-loss:表示IPv6 PIM邻居丢失的告警信息。
private-new-neighbor:表示IPv6 PIM邻居添加的告警信息。
private-rp-mapping-change:表示RP发生改变的告警信息。
rp-mapping-change:表示RP发生改变的PIM-STD-MIB告警信息。
如果未指定任何可选参数,表示开启或关闭IPv6 PIM的全部告警功能。
开启了IPv6 PIM的告警功能之后,IPv6 PIM会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭IPv6 PIM的全部告警功能。
[Sysname] undo snmp-agent trap enable pim6
source-lifetime命令用来配置IPv6组播源的生存时间。
undo source-lifetime命令用来恢复缺省情况。
source-lifetime time
IPv6组播源的生存时间为210秒。
IPv6 PIM视图
time:指定IPv6组播源的生存时间,取值范围为0~31536000,单位为秒。0表示无穷大,即IPv6组播源永不老化。
# 在公网实例中配置IPv6组播源的生存时间为200秒。
[Sysname] ipv6 pim
[Sysname-pim6] source-lifetime 200
source-policy命令用来配置IPv6组播数据过滤器。
undo source-policy命令用来恢复缺省情况。
source-policy { ipv6-acl-number | name ipv6-acl-name }
undo source-policy
不存在IPv6组播数据过滤器,不对组播数据进行过滤。
IPv6 PIM视图
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有IPv6组播数据。
name ipv6-acl-name:指定IPv6基本或高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有IPv6组播数据。
对于IPv6基本ACL,本命令指定ACL规则中的source参数用来指定IPv6组播数据报文的源地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
对于IPv6高级ACL,该ACL规则中的source参数用来指定IPv6组播数据报文的源地址范围,destination参数用来指定组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
# 在公网实例中配置接收IPv6组播源3121::1的IPv6组播数据报文,丢弃IPv6组播源3121::2的IPv6组播数据报文。
[Sysname-acl-ipv6-basic-2000] rule permit source 3121::1 128
[Sysname-acl-ipv6-basic-2000] rule deny source 3121::2 128
[Sysname] ipv6 pim
[Sysname-pim6] source-policy 2000
[Sysname-pim6] quit
spt-switch-threshold命令用来配置发起SPT切换的条件。
undo spt-switch-threshold命令用来删除指定的发起SPT切换的条件。
spt-switch-threshold { immediacy | infinity } [ group-policy ipv6-acl-number ]
undo spt-switch-threshold [ immediacy | infinity ] [ group-policy ipv6-acl-number ]
设备收到第一个IPv6组播数据包后便立即向SPT切换。
IPv6 PIM视图
immediacy:表示立即发起SPT切换。
infinity:表示永不发起SPT切换。
group-policy ipv6-acl-number:表示组策略列表中的一项,与该组策略匹配的IPv6组播组将应用本配置。ipv6-acl-number表示IPv6基本ACL的编号,取值范围为2000~2999。如果未指定本参数指定的ACL不存在或ACL中未配置有效规则,则本配置将应用于所有IPv6组播组。
该ACL规则中的source参数用来指定IPv6组播组地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
由于组播源侧DR在创建IPv6组播路由表项后,无法继续将IPv6组播报文封装在注册报文中发给RP,因此在可能成为RP的设备上仅支持配置立即发起SPT切换,否则会导致IPv6组播报文转发失败。
# 在接收者侧DR的公网实例中配置永不发起SPT切换。
[Sysname] ipv6 pim
[Sysname-pim6] spt-switch-threshold infinity
ssm-policy命令用来配置IPv6 SSM组播组的范围。
undo ssm-policy命令用来恢复缺省情况。
ssm-policy { ipv6-acl-number | name ipv6-acl-name }
undo ssm-policy
IPv6 SSM组播组的范围为FF3x::/32,其中x表示任意合法的scope。
IPv6 PIM视图
ipv6-acl-number:指定IPv6基本ACL的编号,取值范围为2000~2999。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有SSM组播组地址。
name ipv6-acl-name:指定IPv6基本ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有SSM组播组地址。
通过本命令可以定义允许或拒绝的IPv6组播组的地址范围:如果匹配通过,则组播运行模式为IPv6 PIM-SSM,否则为IPv6 PIM-SM。
本命令指定ACL规则中的source参数用来指定IPv6 SSM组播组范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
# 配置IPv6 SSM组播组的范围为FF3E:0:8192::/96。
[Sysname-acl-ipv6-basic-2000] rule permit source ff3e:0:8192:: 96
[Sysname] ipv6 pim
[Sysname-pim6] ssm-policy 2000
state-refresh-hoplimit命令用来配置状态刷新报文的Hop Limit值。
undo state-refresh-hoplimit命令用来恢复缺省情况。
state-refresh-hoplimit hoplimit-value
状态刷新报文的Hop Limit值为255。
IPv6 PIM视图
hoplimit-value:指定状态刷新报文的Hop Limit值,取值范围为1~255。
# 在公网实例中配置状态刷新报文的Hop Limit值为45。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-hoplimit 45
·     ipv6 pim state-refresh-capable
state-refresh-interval命令用来配置发送状态刷新报文的时间间隔。
undo state-refresh-interval命令用来恢复缺省情况。
发送状态刷新报文的时间间隔为60秒。
IPv6 PIM视图
interval:指定发送状态刷新报文的时间间隔,取值范围为1~255,单位为秒。
# 在公网实例中配置发送状态刷新报文的时间间隔为70秒。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-interval 70
state-refresh-rate-limit命令用来配置接收新状态刷新报文的等待时间。
undo state-refresh-rate-limit命令用来恢复缺省情况。
state-refresh-rate-limit time
接收新状态刷新报文的等待时间为30秒。
IPv6 PIM视图
time:指定接收新状态刷新报文的等待时间,取值范围为1~65535,单位为秒。
# 在公网实例中配置接收新状态刷新报文的等待时间为45秒。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-rate-limit 45
static-rp命令用来配置静态RP。
undo static-rp命令用来删除静态RP。
static-rp ipv6-rp-address [ { ipv6-acl-number| name ipv6-acl-name } | preferred ] *
undo static-rp ipv6-rp-address
不存在静态RP。
IPv6 PIM视图
ipv6-rp-address:指定静态RP的IPv6地址。该地址必须是合法的IPv6全球单播地址。
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。如果指定了本参数,该静态RP将只为能够通过该过滤规则的IPv6组播组服务;如果未指定本参数和name ipv6-acl-name、指定的ACL不存在或ACL中未配置有效规则,则该静态RP将为所有IPv6组播组服务。
name ipv6-acl-name:指定IPv6基本或高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定了本参数,该静态RP将只为能够通过该过滤规则的IPv6组播组服务;如果未指定本参数和ipv6-acl-number参数、指定的ACL名称不存在或ACL中未配置有效规则,则该静态RP将为所有IPv6组播组服务。
preferred:表示当网络中同时存在动态RP和静态RP时,优先选择静态RP,只有当静态RP失效时,动态RP才能生效。如果未指定本参数,则表示优先选择动态RP,只有当未配置动态RP或动态RP失效时,静态RP才能生效。
作为静态RP的接口不必使能IPv6 PIM。
本命令通过ACL规则中的source参数指定静态RP所服务的IPv6组播组范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
当某个静态RP引用的ACL规则发生变化时,需要为所有IPv6组播组重新选举RP。
重复执行本命令,可以配置多个静态RP。但是,如果配置时所指定的静态RP地址或ACL规则相同,最后一次执行的命令生效;如果存在多个静态RP服务于同一组播组的情况,则选择IPv6地址最大的静态RP为该组服务。
# 在公网实例中配置IPv6地址为2001::2的接口为静态RP,为IPv6组播组FF03::101/64提供服务,并优先选择静态RP。
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source ff03::101 64
[Sysname] ipv6 pim
[Sysname-pim6] static-rp 2001::2 2001 preferred
timer hello命令用来全局配置发送Hello报文的时间间隔。
undo timer hello命令用来恢复缺省情况。
undo timer hello
发送Hello报文的时间间隔为30秒。
IPv6 PIM视图
# 在公网实例中全局配置发送Hello报文的时间间隔为40秒。
[Sysname] ipv6 pim
[Sysname-pim6] timer hello 40
·     ipv6 pim timer hello
timer join-prune命令用来全局配置发送加入/剪枝报文的时间间隔。
undo timer join-prune命令用来恢复缺省情况。
发送加入/剪枝报文的时间间隔为60秒。
IPv6 PIM视图
# 在公网实例中全局配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname] ipv6 pim
[Sysname-pim6] timer join-prune 80
