15-镜像命令
本章节下载: 15-镜像命令 (323.20 KB)
1.1.3 mirroring-group mirroring-cpu
1.1.4 mirroring-group mirroring-port (interface view)
1.1.5 mirroring-group mirroring-port (system view)
1.1.6 mirroring-group mirroring-vlan
1.1.7 mirroring-group monitor-egress
1.1.8 mirroring-group monitor-port (interface view)
1.1.9 mirroring-group monitor-port (system view)
1.1.10 mirroring-group remote-probe vlan
2.1.1 display monitoring-group
2.1.4 mirror-to monitoring-group
display mirroring-group命令用来显示镜像组的信息。
display mirroring-group { group-id | all | local | remote-destination | remote-source }
group-id:显示镜像组的信息,取值范围为1~128。
all:显示所有镜像组的信息。
local:显示本地镜像组的信息。
remote-destination:显示远程目的镜像组的信息。
remote-source:显示远程源镜像组的信息。
显示信息的显示顺序按照镜像组的编号顺序排列,显示内容包括镜像组的类型、状态和构成等信息。
# 显示所有镜像组的信息。
<Sysname> display mirroring-group all
Mirroring group 1:
Type: Local
Status: Active
Mirroring port:
GigabitEthernet1/0/1 Inbound
Monitor port:
GigabitEthernet1/0/2
GigabitEthernet1/0/3
GigabitEthernet1/0/4
Mirroring group 2:
Type: Local
Status: Active
Mirroring port:
GigabitEthernet1/0/5 Inbound
Monitor port:
GigabitEthernet1/0/6
Encapsulation: Destination IP address 1.1.1.1
Source IP address 2.2.2.2
DSCP 1
VLAN 2
VRF Instance 3
Destination MAC address 0011-0200-0211
Mirroring group 3:
Type: Local
Status: Active
Mirroring port:
GigabitEthernet2/0/1 Inbound
Monitor port:
GigabitEthernet2/0/2
Encapsulation: Destination IPv6 address 100:100:100:100:100:100:100:100
Source IPv6 address 200:200:200:200:200:200:200:200
Destination MAC address 000f-e241-5e5b
表1-1 display mirroring-group命令显示信息描述表
Mirroring group |
镜像组的编号 |
Type |
镜像组的类型: · Local:本地镜像组 · Remote source:远程源镜像组 · Remote destination:远程目的镜像组 |
Status |
镜像组的状态: · Active:表示镜像组已经生效 · Incomplete:表示镜像组没有配完,暂不生效 |
Mirroring port |
镜像源端口 |
Mirroring VLAN |
镜像源VLAN |
Mirroring CPU |
镜像源CPU |
Monitor port |
镜像目的端口 |
Remote probe VLAN |
远程镜像VLAN |
Encapsulation |
镜像报文的封装参数 |
Destination IP address |
镜像报文封装的目的IP地址 |
Source IP address |
镜像报文封装的源IP地址 |
Destination IPv6 address |
镜像报文封装的目的IPv6地址 |
Source IPv6 address |
镜像报文封装的源IPv6地址 |
DSCP |
镜像报文封装的DSCP优先级 |
VLAN |
镜像报文所属的VLAN |
VRF Instance |
表示镜像报文由该VPN实例对应出接口的路由信息指导转发 |
Destination MAC address |
镜像报文封装的目的MAC地址 |
mirroring-group命令用来创建镜像组。
undo mirroring-group命令用来删除镜像组。
mirroring-group group-id { local | remote-destination | remote-source }
undo mirroring-group { group-id | all | local | remote-destination | remote-source }
未创建镜像组。
group-id:表示镜像组的编号,取值范围为1~128。设备最多支持创建9个镜像组,分别为4个镜像源是源端口,4个镜像源是源VLAN和1个镜像源是源CPU。
local:表示本地镜像组。
remote-destination:表示远程目的镜像组。
remote-source:表示远程源镜像组。
all:表示所有镜像组。
# 创建本地镜像组1。
[Sysname] mirroring-group 1 local
mirroring-group mirroring-cpu命令用来为镜像组配置源CPU。
undo mirroring-group mirroring-cpu命令用来取消镜像组的源CPU。
mirroring-group group-id mirroring-cpu slot slot-number-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-cpu slot slot-number-list
未为镜像组配置源CPU。
group-id:表示镜像组的编号,该镜像组必须存在,取值范围为1~128。
slot slot-number-list:源CPU所在设备在IRF中的成员编号列表,表示多个成员。表示方式为slot-number-list = { slot-number [ to slot-number ] }&<1-8>。其中,slot-number为设备在IRF中的成员编号,&<1-8>表示前面的参数最多可以输入8次。当使用to参数配置设备范围时,终止设备的成员编号必须大于等于起始设备的成员编号。
both:表示对源CPU收发的报文都进行镜像。
inbound:表示仅对源CPU收到的报文进行镜像。
outbound:表示仅对源CPU发出的报文进行镜像。
只能为本地镜像组或远程源镜像组配置源CPU,不能为远程目的镜像组配置源CPU。
# 创建本地镜像组1,配置其源CPU为位于指定slot上的CPU,并对该CPU收到的报文进行镜像。
[Sysname] mirroring-group 1 mirroring-cpu slot 1 inbound
· mirroring-group
mirroring-group mirroring-port命令用来配置端口为镜像组的源端口。
undo mirroring-group mirroring-port命令用来恢复缺省情况。
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
未配置端口为镜像组的源端口。
both:表示对端口收发的报文都进行镜像。
inbound:表示仅对端口收到的报文进行镜像。
outbound:表示仅对端口发出的报文进行镜像。
只能为本地镜像组或远程源镜像组配置源端口,不能为远程目的镜像组配置源端口。
请不要将源端口加入到源VLAN中和远程镜像VLAN中,否则会影响镜像功能的正常使用。
一个源端口无论单向还是双向,都只能加入一个镜像组。
源端口不能再被用作本镜像组或其他镜像组的出端口或目的端口。
# 创建本地镜像组1,配置其源端口为GigabitEthernet1/0/1,并对该端口收发的报文都进行镜像。
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 mirroring-port both
# 创建远程源镜像组2,配置其源端口为GigabitEthernet1/0/2,并对该端口收发的报文都进行镜像。
[Sysname] mirroring-group 2 remote-source
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 mirroring-port both
· mirroring-group
mirroring-group mirroring-port命令用来为镜像组配置源端口。
undo mirroring-group mirroring-port命令用来取消镜像组的源端口配置。
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
未为镜像组配置源端口。
interface-list:源端口列表,表示一个或多个源端口。表示方式为interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-8>。其中,interface-type interface-number为端口类型和端口编号。&<1-8>表示前面的参数最多可以输入8次。当使用to参数配置端口范围时,起始端口和终止端口必须是相同slot上相同类型的端口,且终止端口的端口编号必须大于等于起始端口的端口编号。
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
[Sysname] mirroring-group 2 mirroring-port gigabitethernet 1/0/2 both
· mirroring-group
mirroring-group mirroring-vlan命令用来为镜像组配置源VLAN。
undo mirroring-group mirroring-vlan命令用来取消镜像组的源VLAN配置。
mirroring-group group-id mirroring-vlan vlan-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-vlan vlan-list
未为镜像组配置源VLAN。
vlan-list:源VLAN列表,表示一个或多个源VLAN。表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-8>。其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-8>表示前面的参数最多可以输入8次。当使用to参数配置VLAN范围时,终止VLAN的编号必须大于等于起始VLAN的编号。
both:表示对源VLAN收发的报文都进行镜像。
inbound:表示仅对源VLAN收到的报文进行镜像。
outbound:表示仅对源VLAN发出的报文进行镜像。
只能为本地镜像组或远程源镜像组配置源VLAN,不能为远程目的镜像组配置源VLAN。
一个VLAN只能配置为一个镜像组的源VLAN。
# 创建本地镜像组1,配置其源VLAN为VLAN 1,并对该VLAN收发的报文都进行镜像。
[Sysname] mirroring-group 1 mirroring-vlan 1 both
# 创建远程源镜像组2,配置其源VLAN为VLAN 2,并对该VLAN收发的报文都进行镜像。
[Sysname] mirroring-group 2 mirroring-vlan 2 both
· mirroring-group
mirroring-group monitor-egress命令用来为远程源镜像组配置出端口。
undo mirroring-group monitor-egress命令用来恢复缺省情况。
在系统视图下:
mirroring-group group-id monitor-egress interface-type interface-number
undo mirroring-group group-id monitor-egress interface-type interface-number
在接口视图下:
未为远程源镜像组配置出端口。
interface-type interface-number:表示出端口。其中,interface-type interface-number为端口类型和端口编号。
只能为远程源镜像组配置出端口,不能为本地镜像组和远程目的镜像组配置出端口。
不能将出端口加入到源VLAN中,否则会影响镜像功能的正常使用。
不能在出端口上配置下列功能:生成树协议、802.1X、IGMP Snooping、静态ARP和MAC地址学习,否则会影响镜像功能的正常使用。
出端口不能是现有镜像组的成员端口。
出端口不能是聚合组的成员端口。
根据不同的镜像源,配置出端口时,需要注意:
· 如果镜像源是源端口,则出端口必须是源端口所在slot上的接口。
· 如果镜像源是源VLAN,则出端口必须是源VLAN的接口所在slot上的接口。
· 如果镜像源是源CPU,则出端口必须是源CPU所在slot上的接口。
# 创建远程源镜像组1,并在系统视图下配置其出端口为GigabitEthernet1/0/1。
[Sysname] mirroring-group 1 remote-source
[Sysname] mirroring-group 1 monitor-egress gigabitethernet 1/0/1
# 创建远程源镜像组2,并在接口视图下配置其出端口为GigabitEthernet1/0/2。
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 monitor-egress
· mirroring-group
mirroring-group monitor-port命令用来配置端口为镜像组的目的端口。
undo mirroring-group monitor-port命令用来恢复缺省情况。
mirroring-group group-id monitor-port [ { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ] | destination-mac mac-address ]
undo mirroring-group group-id monitor-port
未配置端口为镜像组的目的端口。
destination-ip destination-ip-address:镜像报文封装的目的IP地址,destination-ip-address表示封装的目的IP地址。
source-ip source-ip-address:镜像报文封装的源IP地址,source-ip-address表示封装的源IP地址。
destination-ipv6 destination-ipv6-address:镜像报文封装的目的IPv6地址,destination-ipv6-address表示封装的目的IPv6地址。
source-ipv6 source-ipv6-address:镜像报文封装的源IPv6地址,source-ipv6-address表示封装的源IPv6地址。
dscp dscp-value:镜像报文封装的DSCP优先级,dscp-value表示封装的DSCP优先级,取值范围为0~63,也可以是关键字,如表1-2所示。如果未指定本参数,DSCP优先级的缺省值为0。
表1-2 DSCP关键字与值的对应表
关键字 |
DSCP值(二进制) |
DSCP值(十进制) |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
vlan vlan-id:镜像报文所属的VLAN,vlan-id表示镜像报文所属VLAN的编号,取值范围为1~4094。
vrf-instance vrf-instance-name:表示流镜像到接口时,镜像报文由该VPN实例对应出接口的路由信息指导转发。vrf-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。
destination-mac mac-address:镜像报文封装的目的MAC地址,mac-address表示封装的目的MAC地址,格式为H-H-H。如果未指定本参数,将根据目的IP地址动态获取目的MAC地址,若获取不到,则缺省值为000f-e241-5e5b。
只能为本地镜像组或远程目的镜像组配置目的端口,不能为远程源镜像组配置目的端口。
请不要将目的端口加入到源VLAN中,或在目的端口上使能生成树协议,否则会影响镜像功能的正常使用。
当二层聚合接口作为目的端口时,请勿将其成员端口配置为源端口或将其加入源VLAN,否则会影响镜像功能的正常使用。
从目的端口发出的报文包括镜像报文和其他端口正常转发来的报文。为了保证数据监测设备只对镜像报文进行分析,请将目的端口只用于端口镜像,不作其他用途。
目的端口不能是现有镜像组的成员端口。
# 创建本地镜像组1,并配置其目的端口为GigabitEthernet1/0/1。
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 monitor-port
# 创建远程目的镜像组2,并配置其目的端口为GigabitEthernet1/0/2。
[Sysname] mirroring-group 2 remote-destination
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 monitor-port
# 创建本地镜像组3,配置其目的端口为GigabitEthernet1/0/1,并指定镜像报文封装的目的IP地址为1.1.1.1,源IP地址为3.3.3.3,DSCP优先级为1,所属VLAN为1,所属VPN实例名称为122。
[Sysname] mirroring-group 3 local
[Sysname-GigabitEthernet1/0/1] mirroring-group 3 monitor-port destination-ip 1.1.1.1 source-ip 3.3.3.3 dscp 1 vlan 1 vrf-instance 122
· mirroring-group
mirroring-group monitor-port命令用来为镜像组配置目的端口。
undo mirroring-group monitor-port命令用来取消镜像组的目的端口配置。
mirroring-group group-id monitor-port interface-list [ { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ] | destination-mac mac-address ]
undo mirroring-group group-id monitor-port interface-list
未为镜像组配置目的端口。
interface-list:目的端口列表。表示方式为interface-list = { interface-type interface-number1 [ to interface-type interface-number2 ] }&<1-8>,其中interface-type interface-number为端口类型和端口编号,interface-number2的值要大于或等于interface-number1的值,&<1-8>表示前面的参数最多可以输入8次。
dscp dscp-value:镜像报文封装的DSCP优先级,dscp-value表示封装的DSCP优先级,取值范围为0~63,也可以是关键字,如表1-3所示。如果未指定本参数,DSCP优先级的缺省值为0。
表1-3 DSCP关键字与值的对应表
关键字 |
DSCP值(二进制) |
DSCP值(十进制) |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
不能将目的端口加入到源VLAN中,或在目的端口上使能生成树协议,否则会影响镜像功能的正常使用。
目的端口不能是现有镜像组的成员端口。
[Sysname] mirroring-group 1 monitor-port gigabitethernet 1/0/1
[Sysname] mirroring-group 2 monitor-port gigabitethernet 1/0/2
# 创建本地镜像组4,配置其目的端口为GigabitEthernet1/0/1,并指定其封装的目的IP地址为1.1.1.1,源IP地址为3.3.3.3,DSCP优先级为1,所属VLAN为1,所属VPN实例名称为122。
[Sysname] mirroring-group 4 local
[Sysname] mirroring-group 4 monitor-port gigabitethernet 1/0/1 destination-ip 1.1.1.1 source-ip 3.3.3.3 dscp 1 vlan 1 vrf-instance 122
· mirroring-group
mirroring-group remote-probe vlan命令用来为镜像组配置远程镜像VLAN。
undo mirroring-group remote-probe vlan命令用来恢复缺省情况。
mirroring-group group-id remote-probe vlan vlan-id
undo mirroring-group group-id remote-probe vlan vlan-id
未为镜像组配置远程镜像VLAN。
vlan-id:表示远程镜像VLAN的编号。
只能为远程源镜像组和远程目的镜像组配置远程镜像VLAN,不能为本地镜像组配置远程镜像VLAN。
当一个VLAN已被指定为远程镜像VLAN后,请不要将该VLAN再作其他用途。
源设备和目的设备上的远程镜像组必须使用相同的远程镜像VLAN。
只能将已存在的静态VLAN配置为远程镜像VLAN,且一个VLAN只能配置为一个镜像组的远程镜像VLAN。
当某VLAN被配置为远程镜像VLAN后,必须先删除远程镜像VLAN的配置才能删除该VLAN。
# 创建远程源镜像组1,并为其配置远程镜像VLAN为VLAN 10。
[Sysname] mirroring-group 1 remote-probe vlan 10
# 创建远程目的镜像组2,并为其配置远程镜像VLAN为VLAN 20。
[Sysname] mirroring-group 2 remote-probe vlan 20
· mirroring-group
display monitoring-group命令用来显示监控组的配置信息。
display monitoring-group { group-id | all }
group-id:表示监控组的编号,取值范围为1~4112。
all:表示所有监控组。
# 显示所有监控组的配置信息。
<Sysname> display monitoring-group all
Monitoring group 1:
Monitoring ports: GigabitEthernet1/0/2
表2-1 display monitoring-group命令显示信息描述表
Monitoring group |
监控组的编号 |
Monitoring ports |
监控组的成员端口 |
# 显示所有监控组的配置信息。(支持配置封装参数)
Monitoring group 1:
Monitoring ports:
Monitoring ports:
DSCP 1
VLAN 2
VRF Instance aa
表2-2 display monitoring-group命令显示信息描述表
Monitoring group |
监控组的编号 |
Monitoring ports |
监控组的成员端口 |
Encapsulation |
镜像报文的封装参数 |
镜像报文封装的目的IP地址 |
Source IP address |
镜像报文封装的源IP地址 |
DSCP |
镜像报文封装的DSCP优先级 |
VLAN |
镜像报文所属的VLAN |
VRF Instance |
镜像报文封装的目的MAC地址 |
mirror-to cpu命令用来配置流镜像到CPU。
undo mirror-to命令用来取消流镜像到CPU。
mirror-to cpu
undo mirror-to cpu
未配置流镜像到CPU。
流行为视图
当通过mirror-to cpu命令配置流镜像到CPU时,不支持对接口出方向的报文进行镜像。
# 配置流行为1,并在该流行为中配置流镜像到CPU。
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to cpu
mirror-to interface命令用来配置流镜像到接口。
undo mirror-to interface命令用来取消流镜像到接口。
命令形式一
mirror-to interface interface-type interface-number [ backup-interface interface-type interface-number ] [ sampler sampler-name ] [ truncation ] [ { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * ] [ destination-mac mac-address ]
undo mirror-to interface interface-type interface-number
命令形式二
mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ sampler sampler-name ] [ truncation ] [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ]
undo mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address| destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address }
命令形式三
mirror-to interface interface-type interface-number reflector-port interface-type interface-number strip-vlan vlan-id
未配置流镜像到接口。
流行为视图
interface-type interface-number:表示流镜像接口的接口类型和接口编号。
backup-interface interface-type interface-number:表示流镜像的备份接口,interface-type interface-number为接口类型和接口编号。当interface interface-type interface-number参数指定的主接口所在成员设备下线或重启时,流量可以被镜像到备份接口。当主接口所在成员设备恢复正常后,流量会回切到主接口。
sampler sampler-name:表示流镜像引用的采样器,sampler-name为采样器的名称,为1~31个字符的字符串,不区分大小写。
truncation:支持报文截取功能,目前仅支持截取镜像后报文的前192字节。
destination-ip destination-ip-address:表示流镜像到接口时,镜像报文封装的目的IP地址,destination-ip-address表示封装的目的IP地址。
source-ip source-ip-address:表示流镜像到接口时,镜像报文封装的源IP地址,source-ip-address表示封装的源IP地址。
destination-ipv6 destination-ipv6-address:表示流镜像到接口时,镜像报文封装的目的IPv6地址,destination-ipv6-address表示封装的目的IPv6地址。
source-ipv6 source-ipv6-address:表示流镜像到接口时,镜像报文封装的源IPv6地址,source-ipv6-address表示封装的源IPv6地址。
dscp dscp-value:表示流镜像到接口时,镜像报文封装的DSCP优先级,dscp-value表示封装的DSCP优先级,取值范围为0~63,也可以是关键字,如表2-3所示。
表2-3 DSCP关键字与值的对应表
关键字 |
DSCP值(二进制) |
DSCP值(十进制) |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
destination-mac mac-address:表示流镜像到接口时,镜像报文封装的目的MAC地址,mac-address表示封装的目的MAC地址,格式为H-H-H。如果未指定本参数,将根据目的IP地址动态获取目的MAC地址。
reflector-port interface-type interface-number:表示流镜像的反射端口,interface-type interface-number为端口类型和端口编号。
strip-vlan vlan-id:镜像报文在指定VLAN中广播,vlan-id表示镜像报文广播的VLAN ID,取值范围为1~4094。
同一流行为中只能配置一个目的接口,多次执行该命令,仅最后一次执行的命令生效。
采样器用来从一组固定数量的报文中选出一个报文。流镜像通过引用采样器,可以对镜像报文进行采样而减少镜像报文的数量。流镜像支持引用一个未创建的采样器。如果在流镜像多次配置采样器,最后一次执行的命令生效。有关采样器的相关配置,请参见“网络管理和监控配置指导”中的“Sampler”。
使用命令形式一配置流镜像到接口时,设备会将报文镜像到指定出接口。
使用命令形式二配置流镜像到接口时,设备会先给镜像报文封装指定的参数,并根据镜像报文封装的目的IP地址进行查表转发,路由出接口即为镜像报文的目的端口。通过配置路由协议的负载分担,支持多个接口同时作为镜像报文的目的端口。若当前镜像目的端口故障,则使用路由协议重新计算出来的出接口继续转发镜像报文。若目的端口为VLAN接口且未配置镜像报文所属VLAN时,此时是否封装VLAN ID由该VLAN接口对应的二层以太网接口的VLAN配置决定,封装的VLAN ID则为VLAN接口所属的VLAN ID。
使用命令形式三配置流镜像到接口时,设备将进入镜像源的报文复制一份给目的端口,目的端口再将报文发送给反射端口,反射端口将镜像报文在指定的VLAN中广播。此命令形式仅适用于镜像报文带VLAN Tag且要求此镜像报文出设备时不带VLAN Tag的应用场景。
使用命令形式三配置的流镜像接口和反射端口均必须加入流镜像类型的业务环回组。有关业务环回组的详细介绍,请参见“二层技术-以太网交换配置指导”中的“业务环回组”。
不支持配置流镜像到Tunnel接口。
# 配置流行为1,并在该流行为中配置流镜像到接口GigabitEthernet1/0/1。
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0/1
# 配置流行为1,在该流行为中配置流镜像到接口GigabitEthernet1/0/1并引用采样器samp。
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0/1 sampler samp
# 配置流行为1,在该流行为中配置流镜像到接口GigabitEthernet1/0/1时,镜像报文封装的目的IP地址为1.1.1.1、源IP地址为2.2.2.2、DSCP优先级为20、VLAN ID为100,镜像报文所属的VPN实例名称为vrf1。
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0/1 destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf1
# 配置流行为1,在该流行为中配置流镜像到接口,镜像报文封装的目的IP地址为1.1.1.1、源IP地址为2.2.2.2。
[Sysname-behavior-1] mirror-to interface destination-ip 1.1.1.1 source-ip 2.2.2.2
# 配置流行为1,并在该流行为中配置流镜像接口为GigabitEthernet1/0/1,反射端口为GigabitEthernet1/0/2,并将镜像报文在VLAN 100中广播。
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0/1 reflector-port gigabitethernet 1/0/2 strip-vlan 100
mirror-to monitoring-group命令用来配置流镜像到监控组。
undo mirror-to monitoring-group命令用来取消流镜像到监控组。
mirror-to monitoring-group group-id
undo mirror-to monitoring-group group-id
未配置流镜像到监控组。
流行为视图
group-id:表示监控组的编号,取值范围为4097~4112。
# 配置流行为b1,在该流行为中配置流镜像到监控组1。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] mirror-to monitoring-group 1
monitoring-group命令用来创建监控组,并进入监控组视图。如果指定的监控组已存在,则直接进入该监控组的视图。
undo monitoring-group命令用来删除监控组。
undo monitoring-group { group-id | all }
未创建监控组。
all:表示所有监控组。
# 创建端口组1。
[Sysname] monitoring-group 1
monitoring-port命令用来配置监控组的成员端口。
undo monitoring-port命令用来删除监控组的成员端口。
monitoring-port interface-list [ { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ] ]
undo monitoring-port interface-list
命令形式二
monitoring-port { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ]
undo monitoring-port { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address }
未配置监控组的成员端口。
监控组视图
interface-list:表示方式为interface-list = { interface-type interface-number1 [ to interface-type interface-number2 ] }&<1-8>,其中interface-type interface-number为端口类型和端口编号,interface-number2的值要大于或等于interface-number1的值,&<1-8>表示前面的参数最多可以输入8次。
destination-ip destination-ip-address:表示流镜像到监控组时,镜像报文封装的目的IPv4地址,destination-ip-address表示封装的目的IPv4地址。
source-ip source-ip-address:表示流镜像到监控组时,镜像报文封装的源IPv4地址,source-ip-address表示封装的源IPv4地址。
destination-ipv6 destination-ipv6-address:表示流镜像到监控组时,镜像报文封装的目的IPv6地址,destination-ipv6-address表示封装的目的IPv6地址。
source-ipv6 source-ipv6-address:表示流镜像到监控组时,镜像报文封装的源IPv6地址,source-ipv6-address表示封装的源IPv6地址。
dscp dscp-value:表示流镜像到监控组时,镜像报文封装的DSCP优先级,dscp-value表示封装的DSCP优先级,取值范围为0~63,也可以是关键字,如表2-4所示。
表2-4 DSCP关键字与值的对应表
关键字 |
DSCP值(二进制) |
DSCP值(十进制) |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
vlan vlan-id:表示流镜像到监控组时,镜像报文所属的VLAN,vlan-id表示镜像报文所属VLAN的编号,取值范围为1~4094。
vrf-instance vrf-instance-name:表示流镜像到监控组时,镜像报文由该VPN实例对应出接口的路由信息指导转发。vrf-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。
destination-mac mac-address:表示流镜像到监控组时,镜像报文封装的目的MAC地址,mac-address表示封装的目的MAC地址,格式为H-H-H。如果未指定本参数,将根据目的IP地址动态获取目的MAC地址,若获取不到,则缺省值为000f-e241-5e5b。
为了保证数据监测设备只对镜像报文进行分析,监控组的端口只用于流镜像,不作其他用途。
对于命令形式一,如果监控组中配置了多个成员端口,设备将根据配置的封装参数将镜像报文封装为协议号是0x88BE的GRE报文,然后复制成多份,分别从多个指定的端口发出。
对于命令形式二,设备将根据配置的封装参数将镜像报文封装为协议号是0x88BE的GRE报文,然后根据镜像报文封装的目的IP地址进行查表转发,路由出接口即为镜像报文的目的端口。通过配置路由协议的负载分担,支持多个接口同时作为镜像报文的目的端口。若当前镜像目的端口故障,则使用路由协议重新计算出来的出接口继续转发镜像报文。若目的端口为VLAN接口且未配置镜像报文所属VLAN时,此时是否封装VLAN ID由该VLAN接口对应的二层以太网接口的VLAN配置决定,封装的VLAN ID则为VLAN接口所属的VLAN ID。
配置流镜像到监控组时,若需要指定封装参数,则配置流镜像到监控组成员端口的封装参数格式必须与第一个成员端口的封装参数格式相同。
# 创建监控组1,并配置监控组的成员端口为GigabitEthernet1/0/1和GigabitEthernet1/0/2。
[Sysname-monitoring-group-1] monitoring-port gigabitethernet 1/0/1 to gigabitethernet 1/0/2
# 创建监控组2,并配置监控报文封装的目的IP地址为1.1.1.1、源IP地址为2.2.2.2,DSCP优先级为20、VLAN ID为100,且该镜像报文由名称为vrf1的VPN实例的路由信息指导转发。
[Sysname] monitoring-group 2
[Sysname-monitoring-group-2] monitoring-port destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf1
# 创建监控组3,并配置监控组的成员端口为GigabitEthernet1/0/1,镜像报文封装的目的IP地址为1.1.1.1、源IP地址为2.2.2.2、DSCP优先级为20、VLAN ID为100,且该镜像报文由名称为vrf2的VPN实例的路由信息指导转发。
[Sysname] monitoring-group 3
[Sysname-monitoring-group-3] monitoring-port gigabitethernet 1/0/1 destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf2
· monitoring-group
