12-三层技术-IP路由命令参考
06-BGP命令
本章节下载: 06-BGP命令  (1.63 MB)
06-BGP命令
1 BGP
1.1 BGP配置命令
1.1.1 additional-paths select-best
1.1.2 address-family ipv4
1.1.3 address-family ipv6
1.1.4 address-family link-state
1.1.5 advertise-rib-active
1.1.6 aggregate
1.1.7 balance
1.1.8 balance as-path-neglect
1.1.9 balance as-path-relax
1.1.10 bestroute as-path-neglect
1.1.11 bestroute compare-med
1.1.12 bestroute igp-metric-ignore
1.1.13 bestroute med-confederation
1.1.14 bestroute router-id-ignore
1.1.15 bgp
1.1.16 bgp update-delay on-startup
1.1.17 bgp update-delay on-startup prefix-list
1.1.18 compare-different-as-med
1.1.19 confederation id
1.1.20 confederation nonstandard
1.1.21 confederation peer-as
1.1.22 dampening
1.1.23 default local-preference
1.1.24 default med
1.1.25 default-route imported
1.1.26 display bgp dampening parameter
1.1.27 display bgp group
1.1.28 display bgp instance-info
1.1.29 display bgp link-state
1.1.30 display bgp network
1.1.31 display bgp non-stop-routing status
1.1.32 display bgp paths
1.1.33 display bgp peer
1.1.34 display bgp routing-table dampened
1.1.35 display bgp routing-table flap-info
1.1.36 display bgp routing-table ipv4 multicast
1.1.37 display bgp routing-table ipv4 rtfilter
1.1.38 display bgp routing-table ipv4 unicast
1.1.39 display bgp routing-table ipv6 multicast
1.1.40 display bgp routing-table ipv6 unicast
1.1.41 display bgp routing-table ipv6 unicast inlabel
1.1.42 display bgp routing-table ipv6 unicast outlabel
1.1.43 display bgp update-group
1.1.44 domain-distinguisher
1.1.45 ebgp-interface-sensitive
1.1.46 fast-reroute route-policy
1.1.47 filter-policy export
1.1.48 filter-policy import
1.1.49 flush suboptimal-route
1.1.50 graceful-restart
1.1.51 graceful-restart timer purge-time
1.1.52 graceful-restart timer restart
1.1.53 graceful-restart timer wait-for-rib
1.1.54 group
1.1.55 ignore-first-as
1.1.56 import-route
1.1.57 import-route-append
1.1.58 ip vpn-instance (BGP instance view)
1.1.59 isolate enable
1.1.60 label-allocation-mode
1.1.61 log-peer-change
1.1.62 network
1.1.63 network short-cut
1.1.64 non-stop-routing
1.1.65 peer additional-paths
1.1.66 peer advertise additional-paths best
1.1.67 peer advertise-community
1.1.68 peer advertise-ext-community
1.1.69 peer advertise-policy exist-policy
1.1.70 peer advertise-policy non-exist-policy
1.1.71 peer allow-as-loop
1.1.72 peer as-number (for a BGP peer group)
1.1.73 peer as-number (for a BGP peer)
1.1.74 peer as-path-acl
1.1.75 peer bfd
1.1.76 peer capability-advertise conventional
1.1.77 peer capability-advertise route-refresh
1.1.78 peer capability-advertise suppress-4-byte-as
1.1.79 peer connect-interface
1.1.80 peer default-route-advertise
1.1.81 peer description
1.1.82 peer ebgp-max-hop
1.1.83 peer enable
1.1.84 peer fake-as
1.1.85 peer filter-policy
1.1.86 peer group
1.1.87 peer high-priority
1.1.88 peer ignore
1.1.89 peer ignore-first-as
1.1.90 peer ignore-originatorid
1.1.91 peer ipsec-profile
1.1.92 peer keep-all-routes
1.1.93 peer keychain
1.1.94 peer label-route-capability
1.1.95 peer log-change
1.1.96 peer low-memory-exempt
1.1.97 peer next-hop-local
1.1.98 peer password
1.1.99 peer preferred-value
1.1.100 peer prefix-list
1.1.101 peer public-as-only
1.1.102 peer reflect-client
1.1.103 peer route-limit
1.1.104 peer route-policy
1.1.105 peer route-update-interval
1.1.106 peer soo
1.1.107 peer source-address
1.1.108 peer substitute-as
1.1.109 peer timer
1.1.110 peer timer connect-retry
1.1.111 peer ttl-security
1.1.112 pic
1.1.113 preference
1.1.114 primary-path-detect bfd
1.1.115 reflect between-clients
1.1.116 reflect change-path-attribute
1.1.117 reflector cluster-id
1.1.118 refresh bgp
1.1.119 reset bgp
1.1.120 reset bgp all
1.1.121 reset bgp dampening
1.1.122 reset bgp flap-info
1.1.123 retain local-label
1.1.124 router id
1.1.125 router-id (BGP instance view)
1.1.126 router-id (BGP-VPN instance view)
1.1.127 shutdown process
1.1.128 snmp context-name
1.1.129 snmp-agent trap enable bgp
1.1.130 summary automatic
1.1.131 timer
1.1.132 timer connect-retry
1 BGP
非缺省vSystem不支持本特性的部分命令,具体情况请见本文相关描述。有关vSystem的详细介绍请参见“虚拟化技术配置指导”中的“vSystem”。
1.1  BGP配置命令
additional-paths select-best命令用来配置Add-Path优选路由的最大条数。
undo additional-paths select-best命令用来恢复缺省情况。
Add-Path优选路由的最大条数为1。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP-VPN VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
context-admin
best-number:Add-Path优选路由的最大条数,取值范围为2~64。
本地实际优选的路由条数不能大于best-number。
# 在BGP IPv4单播地址族视图下,配置Add-Path优选路由的最大条数为3。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] additional-paths select-best 3
·     peer additional-paths
·     peer advertise additional-paths best
address-family ipv4命令用来创建BGP IPv4单播地址族、BGP-VPN IPv4单播地址族、BGP IPv4 RT-Filter地址族或BGP IPv4组播地址族,并进入相应地址族视图。如果BGP IPv4单播地址族、BGP-VPN IPv4单播地址族、BGP IPv4 RT-Filter地址族或BGP IPv4组播地址族已经存在,则直接进入BGP IPv4单播地址族、BGP-VPN IPv4单播地址族、BGP IPv4 RT-Filter地址族或BGP IPv4组播地址族视图。
undo address-family ipv4命令用来删除BGP IPv4单播地址族、BGP-VPN IPv4单播地址族、BGP IPv4 RT-Filter地址族或BGP IPv4组播地址族,及相应地址族视图下的所有配置。
BGP实例视图:
address-family ipv4 [ multicast | rtfilter | unicast ]
undo address-family ipv4 [ multicast | rtfilter | unicast ]
BGP-VPN实例视图:
undo address-family ipv4 [ unicast ]
不存在BGP IPv4单播地址族、BGP-VPN IPv4单播地址族、BGP IPv4 RT-Filter地址族视图和BGP IPv4组播地址族。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
multicast:指定IPv4组播地址族。
rtfilter:指定BGP IPv4 RT-Filter地址族。
unicast:指定IPv4单播地址族。如果在BGP实例视图下执行本命令并指定本参数,则进入BGP IPv4单播地址族视图;如果在BGP-VPN实例视图下执行本命令并指定本参数,则进入BGP-VPN IPv4单播地址族视图。
非缺省vSystem仅支持创建BGP-VPN IPv4单播地址族。
BGP IPv4单播地址族视图下的配置,只对公网BGP IPv4单播地址族的路由和对等体生效。
BGP-VPN IPv4单播地址族视图下的配置,只对指定VPN实例内BGP IPv4单播地址族的路由和对等体生效。
BGP IPv4组播地址族视图下的配置,只对BGP IPv4组播地址族的路由和对等体生效。
BGP IPv4 RT-Filter地址族视图下的配置,只对BGP IPv4 RT-Filter地址族的路由和对等体生效。
如果没有指定multicast、rtfilter和unicast参数,则缺省为unicast。
# 在BGP实例视图下,创建BGP IPv4单播地址族,并进入BGP IPv4单播地址族视图。
[Sysname] bgp 100
address-family ipv6命令用来创建BGP IPv6单播地址族、BGP-VPN IPv6单播地址族或BGP IPv6组播地址族,并进入相应地址族视图。如果BGP IPv6单播地址族、BGP-VPN IPv6单播地址族或BGP IPv6组播地址族已经存在,则直接进入BGP IPv6单播地址族、BGP-VPN IPv6单播地址族或BGP IPv6组播地址族视图。
undo address-family ipv6命令用来删除BGP IPv6单播地址族、BGP-VPN IPv6单播地址族或BGP IPv6组播地址族,及相应地址族视图下的所有配置。
BGP实例视图:
address-family ipv6 [ multicast | unicast ]
undo address-family ipv6 [ multicast | unicast ]
BGP-VPN实例视图:
undo address-family ipv6 [ unicast ]
不存在BGP IPv6单播地址族、BGP-VPN IPv6单播地址族和BGP IPv6组播地址族。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
unicast:指定IPv6单播地址族。如果在BGP实例视图下执行本命令并指定本参数,则进入BGP IPv6单播地址族视图;如果在BGP-VPN实例视图下执行本命令并指定本参数,则进入BGP-VPN IPv6单播地址族视图。
multicast:指定IPv6组播地址族。
非缺省vSystem仅支持创建BGP-VPN IPv6单播地址族。
BGP IPv6单播地址族视图下的配置,只对公网BGP IPv6单播地址族的路由和对等体生效。
BGP-VPN IPv6单播地址族视图下的配置,只对指定VPN实例内BGP IPv6单播地址族的路由和对等体生效。
BGP IPv6组播地址族视图下的配置,只对BGP IPv6组播地址族的路由和对等体生效。
如果没有指定multicast和unicast参数,则缺省为unicast。
# 在BGP实例视图下,创建BGP IPv6单播地址族,并进入BGP IPv6单播地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 unicast
[Sysname-bgp-default-ipv6]
address-family link-state命令用来创建BGP LS地址族,并进入LS地址族视图。如果BGP LS地址族已经存在,直接进入BGP LS地址族视图。
undo address-family link-state命令用来删除BGP LS地址族,及相应地址族视图下的所有配置。
不存在BGP LS地址族。
BGP实例视图
context-admin
非缺省vSystem不支持本命令。
BGP LS地址族视图下的配置,只对公网BGP LS地址族的路由和对等体生效。
# 在BGP实例视图下,创建BGP LS地址族,并进入BGP LS地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family link-state
[Sysname-bgp-default-ls]
advertise-rib-active命令用来配置BGP发布IP路由表中的最优路由。
undo advertise-rib-active命令用来恢复缺省情况。
BGP实例视图下,BGP发布BGP路由表中的最优路由,不管该路由在IP路由表中是否为最优路由;其他视图下,与BGP实例视图下的配置保持一致。
BGP实例视图
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族
context-admin
非缺省vSystem不支持本命令。
配置advertise-rib-active命令后可以保证发送出去的BGP路由在IP路由表中是最优的,以减少BGP发送的路由数量。
以下路由不受advertise-rib-active命令的影响:
·     通过import-route命令引入的路由
·     通过network命令发布的路由
·     通过default-route imported引入的缺省路由
·     VPNv4的路由
·     VPNv6的路由
·     IPv4组播路由
·     IPv6组播路由
本命令只对配置改变后生成的路由生效。若想对配置改变前生成的路由生效,则需要通过reset bgp命令复位BGP会话。
BGP实例视图和BGP单播地址族视图下的配置不同时,以BGP单播地址族视图下的配置为准。
# 配置BGP发布IP路由表中的最优路由。
[Sysname] bgp 100
[Sysname-bgp-default] advertise-rib-active
1.1.6  aggregate
aggregate命令用来在BGP路由表中创建一条聚合路由。
undo aggregate命令用来删除指定的聚合路由。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP IPv4组播地址族视图:
undo aggregate ipv4-address { mask-length | mask }
BGP IPv6单播地址族视图/BGP-VPN IPv6单播地址族视图/BGP IPv6组播地址族视图:
undo aggregate ipv6-address prefix-length
未配置聚合路由。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
ipv4-address:聚合路由的目的IPv4地址。
mask:聚合路由的网络掩码,点分十进制格式。
ipv6-address:聚合路由的目的IPv6地址。
prefix-length:聚合路由的前缀长度,取值范围为0~128。
as-set:指定聚合路由的AS_PATH属性中包含所有具体路由的AS路径信息,该AS_PATH属性为AS_SET类型,即属性中的AS号没有顺序要求。如果没有指定本参数,则聚合路由的AS_PATH属性中不会包含具体路由的AS路径信息,只包含当前路由器所在的AS号。
attribute-policy route-policy-name:根据指定的路由策略设置聚合路由的属性。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。
detail-suppressed:指定仅通告聚合路由,不通告生成该聚合路由的具体路由。如果没有指定本参数,则同时通告聚合路由和生成该聚合路由的具体路由。
origin-policy route-policy-name:根据指定的路由策略选择用于聚合的源路由,即仅选择符合路由策略的具体路由来生成聚合路由。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。
suppress-policy route-policy-name:根据指定的路由策略过滤具体路由,不通告通过路由策略过滤的具体路由,通告未通过路由策略过滤的具体路由。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。
非缺省vSystem仅支持在BGP-VPN IPv4单播地址族视图和BGP-VPN IPv6单播地址族视图下配置本命令。
本命令用来手动聚合BGP路由。如果BGP路由表中存在属于指定的聚合路由的更具体的路由,即存在目的网络地址属于聚合路由的目的网络地址、且掩码长度大于聚合路由掩码长度的路由,则会在BGP路由表中添加该聚合路由。例如,BGP路由表中存在目的网络地址为10.1.1.0/24和10.1.2.0/24的路由,则配置aggregate 10.1.0.0 16命令后,会生成到达目的网络10.1.0.0/16的聚合路由。
如果参与聚合的具体路由所包含的Origin属性不同,那么聚合路由按照Incomplete、EGP、IGP的顺序选择Origin属性。例如,存在Origin属性为Incomplete和IGP的具体路由时,聚合路由的Origin属性为Incomplete。
如果参与聚合的具体路由包含不同的团体属性(或扩展团体属性)值,且聚合后的路由中不包含ATOMIC_AGGREGATE属性(原子聚合属性),则生成的聚合路由的团体属性(或扩展团体属性)中携带所有的团体属性(或扩展团体属性)值。
本命令中各参数的用法及注意事项如表1-1所示。
表1-1 参数的用法及注意事项
参数
用法及注意事项
as-set
如果指定了该参数,则可以通过AS_PATH属性中携带的AS号避免路由环路。当聚合的具体路由的AS路径信息较多时,如果具体路由的变化较频繁,则指定as-set参数会导致聚合路由随之频繁改变,引起路由震荡。在这种情况下,不建议指定as-set参数
attribute-policy
该参数用来设置聚合路由的属性。通过peer route-policy等方式也可以实现相同的功能
该参数不能设置聚合路由的AS_PATH属性
detail-suppressed
该参数用来抑制所有具体路由的通告。如果只想对一部分具体路由进行抑制,可以使用本命令中的suppress-policy参数或peer filter-policy命令
origin-policy
该参数用来通过路由策略选择生成聚合路由的具体路由
如果某条路由属于聚合路由,但是该路由没有通过路由策略的过滤,则该路由不作为聚合路由的具体路由。路由通告时,该路由不受本命令中detail-suppressed和suppress-policy参数的控制
origin-policy参数指定的路由策略中不需要配置apply子句,即便配置了apply子句,该子句也不会生效
suppress-policy
该参数用来抑制部分具体路由的通告。可以使用route-policy的if-match子句有选择地抑制一部分具体路由,其它具体路由仍被通告
suppress-policy参数指定的路由策略中不需要配置apply子句,即便配置了apply子句,该子句也不会生效
# 在BGP IPv4单播地址族视图下,配置在BGP路由表中创建一条聚合路由1.1.0.0/16。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] aggregate 1.1.0.0 255.255.0.0
·     display bgp routing-table ipv4 multicast
·     display bgp routing-table ipv4 unicast
·     display bgp routing-table ipv6 multicast
·     display bgp routing-table ipv6 unicast
·     summary automatic
1.1.7  balance
balance命令用来配置进行BGP负载分担的路由条数。
undo balance命令用来取消BGP负载分担功能。
balance [ ebgp | eibgp | ibgp ] number
undo balance [ ebgp | eibgp | ibgp ]
不会进行BGP负载分担。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
ebgp:为EBGP路由配置进行负载分担的路由条数,即只在指定数目的EBGP路由之间进行负载分担。
eibgp:为EBGP和IBGP路由配置进行负载分担的路由条数,且可以在EBGP和IBGP路由之间进行负载分担。
ibgp:为IBGP路由配置进行负载分担的路由条数,即只在指定数目的IBGP路由之间进行负载分担。
number:进行负载分担的BGP路由条数。取值为1时,表示不进行负载分担。
BGP与IGP的负载分担不同,BGP没有明确的度量值来决定是否对路由进行负载分担。BGP的负载分担需要通过改变BGP选路规则来实现。
当路由同时满足如下条件时,设备根据本命令配置的进行BGP负载分担的路由条数,从这些路由中选择指定数目的路由进行负载分担:
·     ORIGIN属性、LOCAL_PREF属性、和MED属性完全相同。
·     AS_PATH属性满足如下要求:
¡     只要配置了balance as-path-neglect命令,则AS_PATH属性可以不同。
¡     如果配置了balance as-path-relax命令,但未配置balance as-path-neglect命令,则AS_PATH属性内容不同但长度相同的路由之间能够形成BGP负载分担。
¡     如果未配置balance as-path-neglect和balance as-path-relax命令,则要求AS_PATH属性也必须相同。
·     路由下一跳的IGP路由的Metric值满足如下要求:
¡     若未配置bestroute igp-metric-ignore命令,则路由下一跳的IGP的Metric值必须相同。
¡     配置了bestroute igp-metric-ignore命令后,不同路由下一跳的IGP Metric值不同也能形成BGP负载分担。
·     同为标签路由(具有对应MPLS标签值的路由)或同为非标签路由。
BGP路由形成负载分担后,设备向IBGP对等体传递这些路由时,按照如下规则处理路由的下一跳地址:
·     未配置BGP Add-Path功能时,设备仅向IBGP对等体传递形成了负载分担的路由中的最优路由,并将该路由的下一跳地址修改为本地的地址。
·     配置了BGP Add-Path功能时,设备按照Add-Path优选路由的最大条数向IBGP对等体传递形成了负载分担的路由,并将其中的最优路由的下一跳地址修改为本地的地址,不修改其他路由的下一跳地址。
本命令中number参数的取值范围和max-ecmp-num命令相关。通过max-ecmp-num命令配置系统支持的最大等价路由条数为m,并重启设备后,number参数的取值范围将修改为1~m。
如果没有指定ebgp、eibgp和ibgp参数,则表示ebgp和ibgp,即同时为EBGP路由和IBGP路由配置进行负载分担的路由条数,但是不能在EBGP和IBGP路由之间进行负载分担。
执行balance eibgp number命令后,其配置只能通过undo balance eibgp命令取消。
执行balance eibgp number命令后,不能再执行balance [ ebgp | ibgp ] number命令;反之亦然。
# 在BGP IPv4单播地址族视图下,配置BGP负载分担的路由条数为2条。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] balance 2
·     balance as-path-neglect
·     balance as-path-relax
·     bestroute igp-metric-ignore
balance as-path-neglect命令用来配置不同AS_PATH属性的路由能够形成BGP负载分担。
undo balanceas-path-neglect命令用来恢复缺省情况。
undo balance as-path-neglect
不同AS_PATH属性的路由之间不能形成BGP负载分担。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
执行balance as-path-neglect命令后,只是在进行负载分担时忽略AS_PATH属性,要使得两条或者两条以上的路由形成负载分担,还需要配置balance命令。
执行本命令后,BGP向外发布的路由只携带最佳路由的路由属性,参与负载分担的路由的AS_PATH属性丢失,因此,存在发生环路的风险。并且,执行本命令后,可能会对Netstream的统计信息造成影响。请谨慎使用本命令。
# 在BGP IPv4单播地址族视图下,配置不同AS_PATH属性的路由能够形成BGP负载分担。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] balance as-path-neglect
·     balance
balance as-path-relax命令用来配置内容不同但长度相同的AS_PATH属性的路由能够形成BGP负载分担。
undo balance as-path-relax命令用来恢复缺省情况。
内容不同但长度相同的AS_PATH属性的路由不能形成BGP负载分担。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
执行balance as-path-relax命令后,要使得两条或者两条以上的路由形成负载分担,还需要配置balance命令。
如果同时配置了命令balance as-path-relax和balance as-path-neglect,则以命令balance as-path-neglect的配置为准。
# 在BGP IPv4单播地址族视图下,配置内容不同但长度相同的AS_PATH属性的路由能够形成BGP负载分担。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] balance as-path-relax
bestroute as-path-neglect命令用来配置BGP在选择最优路由时忽略AS_PATH属性。
undo bestroute as-path-neglect命令用来恢复缺省情况。
BGP实例视图:
bestroute as-path-neglect [ all-instance ]
undo bestroute as-path-neglect [ all-instance ]
BGP-VPN实例视图:
BGP将AS_PATH属性作为选择最优路由的一个条件。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
all-instance:表示在BGP实例和实例下创建的所有BGP-VPN实例中开启本功能。
非缺省vSystem仅支持在BGP-VPN实例视图下配置本命令。
执行本命令时,如果没有指定all-instance参数,则仅在当前BGP实例或BGP-VPN实例下开启本功能。
BGP实例视图下执行bestroute as-path-neglect all-instance命令后,将在此BGP实例以及其中所有的BGP-VPN实例下开启本功能。此时,在BGP实例或BGP-VPN实例视图下执行undo bestroute as-path-neglect命令,无法关闭本功能。如需仅在部分实例中开启本功能,请在对应BGP实例或BGP-VPN实例视图下配置bestroute as-path-neglect命令,并且确保BGP实例视图下未配置bestroute as-path-neglect all-instance命令。
# 在BGP实例视图下,配置BGP在选择最优路由时忽略AS_PATH属性。
[Sysname] bgp 100
[Sysname-bgp-default] bestroute as-path-neglect
bestroute compare-med命令用来配置对来自同一AS的路由进行MED排序优选。
undo bestroute compare-med命令用来恢复缺省情况。
BGP实例视图:
bestroute compare-med [ all-instance ]
undo bestroute compare-med [ all-instance ]
BGP-VPN实例视图:
不会对来自同一AS的路由进行MED排序优选。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
缺省情况下,系统不会对来自同一AS的路由进行MED排序优选,即BGP选择最优路由时是将新的路由和当前BGP路由表中的最优路由进行比较,只要新的路由比当前BGP路由表中的最优路由更优,新的路由将成为最优路由,路由学习的顺序有可能会影响最优路由的选择结果。
如果执行了本命令,则路由器学习到新的路由后,首先按照路由来自的AS分组,对来自同一AS的路由根据MED值的大小进行优选,选出MED值最小的路由,然后再对优选出来的、来自不同AS的路由进行优选,从而避免路由优选结果的不确定性。
BGP实例视图下执行bestroute compare-med all-instance命令后,将在此BGP实例以及其中所有的BGP-VPN实例下开启本功能。此时,在BGP实例或BGP-VPN实例视图下执行undo bestroute compare-med命令,无法关闭本功能。如需仅在部分实例中开启本功能,请在对应BGP实例或BGP-VPN实例视图下配置bestroute compare-med命令,并且确保BGP实例视图下未配置bestroute compare-med all-instance命令。
# 在BGP实例视图下,设置在选择最佳路由时,对来自同一AS的路由进行MED排序优选。
[Sysname] bgp 100
[Sysname-bgp-default] bestroute compare-med
bestroute igp-metric-ignore命令用来配置BGP在选择最优路由时忽略IGP Metric的比较。
undo bestroute igp-metric-ignore命令用来恢复缺省情况。
BGP实例视图:
bestroute igp-metric-ignore [ all-instance ]
undo bestroute igp-metric-ignore [ all-instance ]
BGP-VPN实例视图:
BGP在选择最优路由时会比较这些路由下一跳的IGP路由的Metric值,并优选IGP Metric值最小的路由。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
BGP实例视图下执行bestroute igp-metric-ignore all-instance命令后,将在此BGP实例以及其中所有的BGP-VPN实例下开启本功能。此时,在BGP实例或BGP-VPN实例视图下执行undo bestroute igp-metric-ignore命令,无法关闭本功能。如需仅在部分实例中开启本功能,请在对应BGP实例或BGP-VPN实例视图下配置bestroute igp-metric-ignore命令,并且确保BGP实例视图下未配置bestroute igp-metric-ignore all-instance命令。
# 在BGP实例视图下,配置BGP在选择最优路由时忽略IGP Metric的比较。
[Sysname] bgp 100
[Sysname-bgp-default] bestroute igp-metric-ignore
bestroute med-confederation命令用来配置允许比较来自同一联盟不同子自治系统邻居路由的MED属性值。
undo bestroute med-confederation命令用来恢复缺省情况。
BGP实例视图:
bestroute med-confederation [ all-instance ]
undo bestroute med-confederation [ all-instance ]
BGP-VPN实例视图:
不比较来自同一联盟不同子自治系统邻居路由的MED属性值。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
BGP实例视图下执行bestroute med-confederation all-instance命令后,将在此BGP实例以及其中所有的BGP-VPN实例下开启本功能。此时,在BGP实例或BGP-VPN实例视图下执行undo bestroute med-confederation命令,无法关闭本功能。如需仅在部分实例中开启本功能,请在对应BGP实例或BGP-VPN实例视图下配置bestroute med-confederation命令,并且确保BGP实例视图下未配置bestroute med-confederation all-instance命令。
# 在BGP实例视图下,配置允许比较来自同一联盟不同子自治系统邻居路由的MED属性值。
[Sysname] bgp 100
[Sysname-bgp-default] bestroute med-confederation
bestroute router-id-ignore命令用来配置BGP在选择最优路由时忽略Router ID。
undo bestroute router-id-ignore命令用来恢复缺省情况。
BGP实例视图:
bestroute router-id-ignore [ all-instance ]
undo bestroute router-id-ignore [ all-instance ]
BGP-VPN实例视图:
BGP在选择最优路由时会优选Router ID最小的路由器发布的路由。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
BGP实例视图下执行bestroute router-id-ignore all-instance命令后,将在此BGP实例以及其中所有的BGP-VPN实例下开启本功能。此时,在BGP实例或BGP-VPN实例视图下执行undo bestroute router-id-ignore命令,无法关闭本功能。如需仅在部分实例中开启本功能,请在对应BGP实例或BGP-VPN实例视图下配置bestroute router-id-ignore命令,并且确保BGP实例视图下未配置bestroute router-id-ignore all-instance命令。
# 在BGP实例视图下,配置BGP在选择最优路由时忽略Router ID。
[Sysname] bgp 1
[Sysname-bgp-default] bestroute router-id-ignore
1.1.15  bgp
bgp命令用来启动指定的BGP实例,并进入BGP实例视图。
undo bgp命令用来关闭指定的BGP实例。
undo bgp [ as-number [ instance instance-name ] ]
没有运行BGP,不存在BGP实例。
context-admin
vsys-admin
as-number:本地AS号,取值范围为1~4294967295。
instance instance-name:启动指定BGP实例。instance-name表示BGP实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示启动default实例。
路由器支持四字节AS号。
一台BGP路由器上可以同时启动多个BGP进程,每个BGP进程对应一个BGP实例。BGP为不同的BGP实例维护独立的路由表。
BGP对BGP实例具有如下要求:
·     一个BGP实例下可以创建多个公网地址族,但不同BGP实例下不能创建相同的公网地址族(公网VPNv4地址族和公网VPNv6地址族除外)。
·     一个BGP实例下可以创建多个VPN实例,每个VPN实例下可以创建多个地址族,但不同BGP实例下不能创建相同的VPN实例。
·     不能通过公网内的不同BGP实例与相同地址的对等体建立BGP会话。
·     IPv4组播与IPv6组播地址族同时配置时,只能配置在一个BGP实例下。
·     不同BGP实例对应的AS号可以相同,不同BGP实例的实例名称不能相同。
# 启动实例default,指定该BGP实例的本地AS号为100,并进入BGP实例视图。
[Sysname] bgp 100
bgp update-delay on-startup命令用来配置设备重启且BGP进程恢复后,延迟发布路由更新消息。
undo bgp update-delay on-startup命令用来恢复缺省情况。
设备重启且BGP进程恢复后,立刻向Established状态的BGP邻居发布路由更新消息。
BGP实例视图
context-admin
seconds:设备重启且BGP进程恢复后,发送更新消息的延迟时间,取值范围为0~3600,单位为秒。取值为0表示一直不发布路由更新消息。
非缺省vSystem不支持本命令。
配置了本命令时,在经过了重启且BGP进程恢复后,设备不能立刻向邻居发布更新消息,而是在一段延迟时间之后才能发送。这段延迟时间的作用是,设备重启后可以等待路由接收完成并优选后再向其他设备发布,以避免设备重启后路由信息不全,就发布给其他设备导致流量丢失的情况。
# 在BGP实例视图下,配置设备重启且BGP进程恢复后,经过100秒的延迟时间才能发送更新消息。
[Sysname] bgp 100
[Sysname-bgp-default] bgp update-delay on-startup 100
·     bgp update-delay on-startup prefix-list
bgp update-delay on-startup prefix-list命令用来配置通过前缀列表控制BGP更新消息延迟发布。
undo bgp update-delay on-startup prefix-list命令用来恢复缺省情况。
未配置通过前缀列表控制BGP更新消息延迟发布。
BGP实例视图
context-admin
ipv4-prefix-list-name:IPv4地址前缀列表名称,为1~63个字符的字符串,区分大小写。
非缺省vSystem不支持本命令。
配置bgp update-delay on-startup命令后,如果需要部分路由前缀不受延迟发布控制,可以使用前缀列表进行控制,通过过滤的路由不受延迟发布的影响。
目前只支持IPv4地址前缀列表。
# 在BGP实例视图下,配置设备重启且BGP进程恢复后,发布路由更新消息的延迟时间为100秒,并配置通过IPv4地址前缀列表aaa过滤的路由不受延迟发布的影响。
[Sysname] bgp 100
[Sysname-bgp-default] bgp update-delay on-startup prefix-list aaa
compare-different-as-med命令用来配置允许比较来自不同AS路由的MED属性值。
undo compare-different-as-med命令用来恢复缺省情况。
不允许比较来自不同AS路由的MED属性值。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
当一个BGP路由器通过不同的EBGP对等体得到目的地址相同但下一跳不同的多条路由时,在其它条件相同的情况下,将优先选择MED值较小者作为最佳路由。
通常情况下,BGP只比较来自同一个AS的路由的MED属性值。在某些特殊的应用中,如需强制BGP比较来自不同AS的路由的MED属性值,则需要执行compare-different-as-med命令。
除非能够确认不同的AS采用了同样的IGP和路由选择方式,否则不要使用此命令。
# 在BGP实例视图下,允许比较来自不同AS路由的MED属性值。
[Sysname] bgp 100
[Sysname-bgp-default] compare-different-as-med
confederation id命令用来配置联盟的ID。
undo confederation id命令用来恢复缺省情况。
confederation id as-number
未配置联盟的ID。
BGP实例视图
context-admin
as-number:联盟ID,即标识联盟这一整体的自治系统号,取值范围为1~4294967295。
非缺省vSystem不支持本命令。
联盟是指将一个大的自治系统划分为几个较小的子自治系统,每个子自治系统中均保持IBGP全连接的状态,这些子自治系统组成一个联盟体。路由的一些关键属性(如下一跳、MED、本地优先级)在通过每个子自治系统时没有丢弃,因此每个子自治系统之间虽然存在EBGP关系,但是从联盟外部来看这些子自治系统是一个整体,即一个自治系统,这个自治系统的AS号就是联盟ID。
采用联盟的方法既可以保证自治系统的完整性,同时还可以缓解自治系统中IBGP连接数过多的问题。
属于同一个联盟的所有路由器上,都需要配置相同的联盟ID。
在联盟外的BGP路由器看来,联盟体内路由器的AS号为联盟ID。
# 在BGP实例default下,ID号是9的联盟体由38、39、40、41四个子自治系统组成;对等体10.1.1.1是子自治系统38中的成员;对等体200.1.1.1是AS联盟体的外部成员,属于AS 98;对于外部成员来讲,9号联盟体就是一个统一的自治系统,该自治系统的AS号为9。以子自治系统41为例,子自治系统中路由器的配置如下。
[Sysname] bgp 41
[Sysname-bgp-default] confederation id 9
[Sysname-bgp-default] confederation peer-as 38 39 40
[Sysname-bgp-default] group Confed38 external
[Sysname-bgp-default] peer Confed38 as-number 38
[Sysname-bgp-default] peer 10.1.1.1 group Confed38
[Sysname-bgp-default] group Remote98 external
[Sysname-bgp-default] peer Remote98 as-number 98
[Sysname-bgp-default] peer 200.1.1.1 group Remote98
·     confederation nonstandard
·     confederation peer-as
confederation nonstandard命令用来配置设备可以与未遵循RFC 3065实现联盟的路由器互通。
undo confederation nonstandard命令用来恢复缺省情况。
设备不能与未遵循RFC 3065实现联盟的路由器互通,只能与遵循RFC 3065实现联盟的路由器互通。
BGP实例视图
context-admin
非缺省vSystem不支持本命令。
如果联盟中存在未遵循RFC 3065的路由器,为了与其互通,保证联盟的正常建立,需要在联盟中所有遵循RFC 3065的路由器上配置本命令。
# 在BGP实例default下,ID号为100的联盟由64000、65000两个子自治系统组成,在该联盟内存在未遵循RFC 3065实现联盟的路由器。为了保证联盟的正常建立,在遵循RFC 3065的路由器上配置其可以与未遵循RFC 3065实现联盟的路由器互通。
[Sysname] bgp 64000
[Sysname-bgp-default] confederation id 100
[Sysname-bgp-default] confederation peer-as 65000
[Sysname-bgp-default] confederation nonstandard
·     confederation id
confederation peer-as命令用来配置联盟中的子自治系统。
undo confederation peer-as命令用来删除联盟中的子自治系统。
undo confederation peer-as [ as-number-list ]
未配置联盟中的子自治系统。
BGP实例视图
context-admin
as-number-list:子自治系统号列表,在同一条命令中最多可配置32个子自治系统,表示方式为as-number-list = as-number&<1-32>。其中,as-number为子自治系统号,取值范围为1~4294967295;&<1-32>表示前面的参数可以输入1~32次。
非缺省vSystem不支持本命令。
在配置本命令之前,必须通过confederation id命令指定联盟ID,否则本命令配置不成功。
执行undo confederation peer-as命令时,如果不指定as-number-list参数,则表示删除联盟中所有的子自治系统。
# 在BGP实例视图下,配置属于联盟10的子自治系统号为2000和2001。
[Sysname] bgp 100
[Sysname-bgp-default] confederation peer-as 2000 2001
·     confederation id
1.1.22  dampening
dampening命令用来配置BGP路由衰减。
undo dampening命令用来恢复缺省情况。
undo dampening
未配置BGP路由衰减。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
half-life-reachable:发生震荡的可达路由的半衰期,取值范围为1~45,单位为分钟,缺省值为15分钟。
half-life-unreachable:发生震荡的不可达路由的半衰期,取值范围为1~45,单位为分钟,缺省值为15分钟。
reuse:路由的再使用阈值,取值范围为1~20000,缺省值为750。当惩罚值降低到该值以下时,此路由变为可用路由,参与路由选择。路由的再使用阈值必须小于suppress。
suppress:路由的抑制阈值,取值范围为1~20000,缺省值为2000。当惩罚值超过该值时,此路由被抑制,不参与路由选择。
ceiling:惩罚值的上限,取值范围为1001~20000,缺省值为16000。惩罚值达到该值后,不再增加。惩罚值的上限必须大于suppress。
route-policy route-policy-name:通过路由策略指定对哪些路由进行路由衰减。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。
该命令只对EBGP路由生效,对IBGP路由无效。
配置本命令后,EBGP邻居down了之后,来自该邻居的路由不会被删除,而是进行路由衰减。
主备倒换后,BGP路由的衰减过程和衰减信息会被重置,设备需要重新计算BGP路由的衰减机制。
# 在BGP IPv4单播地址族视图下,配置BGP路由衰减,可达路由和不可达路由的半衰期均为10分钟,路由的再使用阈值为1000,抑制阈值为2000,惩罚值上限为10000。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] dampening 10 10 1000 2000 10000
·     display bgp dampening parameter
default local-preference命令用来配置本地优先级的缺省值。
undo default local-preference命令用来恢复缺省情况。
本地优先级的缺省值为100。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
value:本地优先级的缺省值,取值范围为0~4294967295。该值越大,则优先级越高。
除本命令外,还可以通过路由策略中的apply local-preference命令来配置BGP路由的本地优先级。如果未配置路由策略,则所有BGP路由的本地优先级均为本命令配置的值;如果配置了路由策略,则通过路由策略过滤的BGP路由的本地优先级为apply local-preference命令配置的值,未通过路由策略过滤的BGP路由的本地优先级为本命令配置的值。
# 在BGP IPv4单播地址族视图下,配置本地优先级的缺省值为180。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] default local-preference 180
·     apply local-preference(三层技术-IP路由命令参考/路由策略)
·     route-policy(三层技术-IP路由命令参考/路由策略)
1.1.24  default med
default med命令用来配置MED的缺省值。
undo default med命令用来恢复缺省情况。
default med med-value
undo default med
MED的缺省值为0。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
med-value:MED的缺省值,取值范围为0~4294967295。
可以通过多种方式配置BGP路由的MED值,按照优先级从高到底的顺序依次为:
(1)     通过路由策略中的apply cost命令设置的MED值;
(2)     通过import-route命令中的med参数设置的MED值;
(3)     通过default med命令配置的MED值;
(4)     学习到的BGP路由自身的MED值,或引入的IGP路由自身的metric值。
# 在BGP IPv4单播地址族视图下,配置MED的缺省值为25。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] default med 25
·     apply cost(三层技术-IP路由命令参考/路由策略)
·     import-route
default-route imported命令用来允许将缺省路由引入到BGP路由表中。
undo default-route imported命令用来恢复缺省情况。
BGP不允许将缺省路由引入到BGP路由表中。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
执行import-route命令引入IGP路由时,缺省情况下不会将IGP的缺省路由引入到BGP路由表中。如果执行import-route命令的同时,执行了default-route imported命令,则IGP的缺省路由可以引入到BGP路由表中。
# 在BGP IPv4单播地址族视图下,配置允许将OSPF进程1的缺省路由引入到BGP路由表中。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] default-route imported
[Sysname-bgp-default-ipv4] import-route ospf 1
·     import-route
display bgp dampening parameter命令用来显示BGP路由衰减参数。
display bgp [ instance instance-name ] dampening parameter { ipv4 | ipv6 } [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
display bgp [ instance instance-name ] dampening parameter vpnv4
context-admin
context-operator
vsys-admin
vsys-operator
ipv4:显示BGP IPv4路由的路由衰减参数。
ipv6:显示BGP IPv6路由的路由衰减参数。
multicast:显示BGP组播路由的路由衰减参数。非缺省vSystem不支持本参数。
unicast:显示BGP单播路由的路由衰减参数。
vpnv4:显示IBGP VPNv4路由的路由衰减参数。非缺省vSystem不支持本参数。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP路由衰减参数。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP路由衰减参数。
如果没有指定unicast和multicast参数,则缺省为unicast。
# 显示BGP IPv4单播路由的路由衰减参数。
<Sysname> display bgp dampening parameter ipv4
Maximum suppression time (in seconds)              : 3973
Ceiling value                                      : 16000
Reuse value                                        : 750
Half-life time for reachable routes (in seconds)   : 900
Half-life time for unreachable routes (in seconds) : 900
Suppression threshold                              : 2000
表1-2 display bgp dampening parameter命令显示信息描述表
最大抑制时间,即惩罚值从上限下降到再使用阈值所需要的最大时间,单位为秒
Ceiling value
惩罚值的上限
Reuse value
再使用阈值
可达路由的半衰期,单位为秒
不可达路由的半衰期,单位为秒
抑制阈值
·     dampening
·     dampening ibgp(MPLS命令参考/MPLS L3VPN)
display bgp group命令用来显示BGP对等体组的信息。
display bgp [ instance instance-name ] group ipv4 [ mdt | multicast | mvpn | rtfilter | sr-policy | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ group-name group-name ]
display bgp [ instance instance-name ] group ipv6 [ multicast | sr-policy | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ group-name group-name ]
display bgp [ instance instance-name ] group link-state [ group-name group-name ]
display bgp [ instance instance-name ] group vpnv4 [ vpn-instance vpn-instance-name ] [ group-name group-name ]
display bgp [ instance instance-name ] group vpnv6 [ group-name group-name ]
context-admin
context-operator
vsys-admin
vsys-operator
ipv4:显示BGP IPv4对等体组的信息。
ipv6:显示BGP IPv6对等体组的信息。
link-state:显示BGP LS对等体组的信息。
mdt:显示BGP MDT对等体组的信息。
multicast:显示BGP组播对等体组的信息。
mvpn:显示BGP IPv4 MVPN对等体组的信息。
rtfilter:显示BGP IPv4 RT-Filter对等体组的信息。
sr-policy:显示BGP SR Policy对等体组的信息。
unicast:显示BGP单播对等体组的信息。
vpnv4:显示BGP VPNv4对等体组的信息。
vpnv6:显示BGP VPNv6对等体组的信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP对等体组的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP对等体组的信息。
group-name group-name:显示指定BGP对等体组的详细信息,group-name为BGP对等体组的名称,为1~47个字符的字符串,区分大小写。如果没有指定本参数,则显示指定地址族所有BGP对等体组的简要信息。
非缺省vSystem仅支持显示BGP IPv4单播对等体组和BGP IPv6单播对等体组的信息。
如果没有指定unicast、multicast、mdt、mvpn和rtfilter参数,则缺省为unicast。
# 显示所有BGP IPv4单播对等体组的简要信息。
<Sysname> display bgp group ipv4
 BGP peer group: group1
 Remote AS: 600
 Type: external
 Members:
  1.1.1.10
 BGP peer group: group2
 Remote AS number: not specified
 Type: external
 Members:
  2.2.2.2
# 显示BGP IPv4单播对等体组group1的详细信息。
<Sysname> display bgp group ipv4 group-name group1
 Remote AS: 600
 Type: external
 Maximum number of prefixes allowed: 4294967295
 Threshold: 75%
 Configured hold time: 180 seconds
 Keepalive time: 60 seconds
 Minimum time between advertisements: 30 seconds
 Peer preferred value: 0
 Site-of-Origin: Not specified
 Routing policy configured:
 Members:
 * - Dynamically created peer
  1.1.1.10               600        0        0    0       0 00:00:55 Established
# 显示BGP IPv6单播对等体组group2的详细信息。
<Sysname> display bgp group ipv6 group-name group2
 Remote AS: 600
 Type: external
 Threshold: 75%
 Members:
  2::2                   600        0        0    0       0 00:00:45 Established
  3::3                   600        0        0    0       0 00:00:40 Established
表1-3 display bgp group命令输出信息描述表
BGP peer group
BGP对等体组名称
Remote AS
对等体组的AS号
对等体组类型,取值包括:
·     external:表示EBGP对等体组
·     internal:表示IBGP对等体组
允许从对等体学习的最大路由数
Threshold
路由器产生日志信息的阈值,即从对等体接收的路由前缀数量与允许的最大路由数的百分比达到此值时,路由器将产生日志信息
配置的保持时间间隔,单位为秒
Keepalive time
存活时间间隔,单位为秒
路由发布的最小时间间隔,单位为秒
为来自对等体的路由指定的首选值
Site-of-Origin
为对等体组指定的SoO属性值
为对等体组指定的路由策略
如果未指定路由策略,则显示为No routing policy is configured
Members
对等体组包括的对等体信息
如果对等体的地址前存在“*”,则表示该对等体为动态创建的对等体
Peer
对等体的IPv4地址或IPv6地址
AS
对等体所在的自治系统号
MsgRcvd
从该对等体收到的消息数目
MsgSent
向该对等体发送的消息数目
OutQ
等待发往该对等体的消息数目
PrefRcv
对于IPv4、IPv6、VPNv4和VPNv6地址族,表示从该对等体收到的前缀数目
对于IPv4 Flowspec地址族,表示从对等体接收到的IPv4 Flowspec信息数目
对于IPv4 MDT地址族,表示从对等体收到的MDT信息数目
Up/Down
BGP会话处于当前状态的时长
该对等体的状态
IPsec profile name
为BGP IPv6对等体组应用的IPsec安全框架名
display bgp instance-info命令用来显示所有BGP实例的信息。
context-admin
context-operator
非缺省vSystem不支持本命令。
# 显示所有BGP实例的信息。
<Sysname> display bgp instance-info
Total BGP instances: 3
  BGP instance name               AS
  BGP1                            100
  BGP2                            200
  BGP3                            300
表1-4 display bgp instance-info命令输出信息描述表
Total BGP instances
BGP实例总数
BGP instance name
BGP实例名称
AS
BGP实例对应的AS号
display bgp link-state命令用来显示BGP LS信息。
display bgp [ instance instance-name ] link-state [ ls-prefix [ advertise-info ] | peer { ipv4-address | ipv6-address } { advertised | received } [ statistics ] | statistics ]
context-admin
context-operator
ls-prefix:显示指定的LS信息。ls-prefix为指定的LS前缀。如果未指定本参数,则显示所有的LS信息。
advertise-info:显示向指定LS前缀的BGP LS地址族发布的信息。
ipv4-address:显示向指定对等体发布或者从指定对等体收到的BGP LS信息。ipv4-address为对等体的地址。
ipv6-address:显示向指定对等体发布或者从指定对等体收到的BGP LS信息。ipv6-address为对等体的地址。
advertised:显示发布的LS信息。
received:显示接收的LS信息。
statistics:显示LS信息的统计个数。
非缺省vSystem不支持本命令。
如果没有指定任何参数,则显示所有BGP LS的简要信息。
# 显示所有公网BGP LS地址族的简要信息。
<Sysname> display bgp link-state
 Total number of routes: 4
 BGP local router ID is 1.1.2.1
 Status codes: * - valid, > - best, d – dampened, h – history,
               s – suppressed, S – stale, i - internal, e - external
 Prefix codes: E link, V node, T4 IPv4, T6 IPv6 route, u/U unknown,
               I Identifier, N local node, R remote node, L link, P prefix,
               L1/L2 ISIS level-1/level-2, O OSPF, O3 OSPFv3
               D direct, S static,
               a area-ID, , l link-ID, t topology-ID, s ISO-ID,
               c confed-ID/ASN, b bgp-identifier, r router-ID,
               i if-address, n peer-address, o OSPF Route-type, p IP-prefix
               d designated router address/interface, ID Link Descriptor Identifier
* >e Network : [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376
     NextHop : 1.1.1.2                                  LocPrf    :
     MED     :
     Path/Ogn: 20i
* >  Network : [V][O3][I0x2][N[c100][b2.2.2.2][a0.0.0.0][r2.2.2.2]]/376
     NextHop : 0.0.0.0                                  LocPrf    :
     PrefVal : 32768                                    OutLabel  : NULL
     MED     :
     Path/Ogn: i
* >e Network : [T][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]][P[o0x1][p1.1.1.0/24]]/480
     MED     :
     Path/Ogn: 20i
* >  Network : [T6][O3][I0x2][N[c100][b2.2.2.2][a0.0.0.0][r2.2.2.2]][P[o0x02][p2
001:1::/64]]/520
     MED     :
     Path/Ogn: i
* >  Network : [E][B][I0x0][N[r2.2.2.2][c100]][R[r3.3.3.3][c200]][L[ID0.0.0.20.0.0.0.0][i12.1.1.2][n12.1.1.3]]/632
     MED     :
     Path/Ogn: i
表1-5 display bgp link-state命令简要显示信息描述表
路由的总数
BGP local router ID
本地的路由器ID
Status codes
路由状态代码:
·     * – valid:合法路由
·     > – best:优选最佳路由
·     d - dampened:震荡抑制路由
·     h – history:历史路由
·     s – suppressed:聚合抑制路由
·     S – stale:过期路由
·     i – internal:内部路由
·     e – external:外部路由
Prefix codes
路由状态代码:
·     E – link:链路描述信息
·     V – node:节点描述信息
·     T – IPv4route:IPv4可达描述信息
·     T6 – IPv6 route:IPv6可达描述信息
·     u/U – unknown:未知描述信息
·     I – Identifier:标识位
·     N – local node:本地节点
·     R – remote node:远端节点
·     L  – link:链路
·     P – prefix:前缀
·     L1/L2 – ISIS level-1/level-2:IS-IS协议的L1或L2层
·     O – OSPF:OSPF协议
·     O3 – OSPFv3:OSPFv3协议
·     D – direct:直连协议
·     S – static:静态路由协议
·     a – area-ID:区域标识
·     l – link-ID:链路标识
·     t – topology-ID:拓扑标识
·     s – ISO-ID:ISO标识
·     c – confed-ID/ASN:联盟或自治系统号
·     b – bgp-identifier:BGP LS标识
·     r – router-ID:路由器标识
·     i – if-address:接口地址
·     n – peer-address:邻居地址
·     o – OSPF Route-type:OSPF路由类型
·     p – IP-prefix:IP前缀
·     d – designated router addresss/interface:指定路由器地址/接口ID
·     ID Link Descriptor Identifier:链路描述符ID
Origin
路由信息的来源,取值包括:
·     i – IGP:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的。
·     ? – incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Network
LS的NLRI信息
NextHop
下一跳IP地址
LocPrf
本地优先级
OutLabel
路由的出标签值
MED
MED(Multi-Exit-Discriminator,多出口区分)属性值
Path/Ogn
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性,其中:
·     AS_PATH属性记录了此路由经过的所有AS,可以避免路由环路的出现
·     ORIGIN属性标记了此路由如何成为BGP路由
TEPOLICY
(暂不支持)标识此BGP-LS路由是SR-MPLS TE Policy或SRv6 TE Policy路由
SEGMENT-ROUTING
(暂不支持)Segment Routing协议
bgp-ls-identifier
BGP-LS的区域标识符
bgp-router-id
BGP Router ID
TE
流量工程
protocol-origin3
配置来源
Flag
标志位
endpoint
目的节点地址
color
(暂不支持)Color属性
originator-as
AS编号
originator-address
地址标识
discriminator
路径标识
# 显示指定LS前缀的BGP LS地址族的详细信息。
<Sysname> display bgp link-state [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376
 BGP local router ID: 1.1.1.2
 Local AS number: 20
 Paths:   1 available, 1 best
 BGP LS information of [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376:
 Imported route.
 Original nexthop: 0.0.0.0
 OutLabel        : NULL
 LS              : Node flag bits: 30[EA] , Local TE router ID: 3006::1
 AS-path         : (null)
 Origin          : igp
 Attribute value : pref-val 32768
 State           : valid, local, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
<Sysname> dis bgp link-state [E][B][I0x0][N[r2.2.2.1][c100]][R[r2.2.2.4][c200]][L[i1.1.1.4][n1.1.1.1]]/536
 BGP local router ID: 2.2.2.4
 Local AS number: 200
 BGP LS information of [E][B][I0x0][N[r2.2.2.1][c100]][R[r2.2.2.4][c200]][L[i1.1.1.4][n1.1.1.1]]/536:
 Rely nexthop    : 100.0.18.1
 Original nexthop: 100.0.18.1
 Out interface   : GigabitEthernet1/0/4
 Route age       : 00h03m49s
 OutLabel        : NULL
 LS               :Peer adj segment Identifier : flag bits: c0[VL] Metric: 0 Label: 2174, Peer set segment Identifier : flag bits: e0[VLB] Metric: 0 Label: 4200
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 100
 Origin          : igp
 Attribute value : pref-val 0
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
<Sysname> disp bgp link-state [TEPOLICY][SEGMENT-ROUTING][I0x0][N[c65009] [bgp-ls-identifier10.1.1.1][bgp-router-id10.1.1.3]][TE[protocol-origin3][Flag192][endpoint2::2][color20][originator-as0][originator-address::][discriminator100]]/664
 BGP local router ID: 1.2.3.4
 Local AS number: 65009
 BGP LS information of [TEPOLICY][SEGMENT-ROUTING][I0x0][N[c65009] [bgp-ls-identifier10.1.1.1][bgp-router-id10.1.1.3]][TE[protocol-origin3][Flag192][endpoint2::2][color20][originator-as0][originator-address::][discriminator100]]/664:
 Imported route.
 Out interface   : NULL0
 Route age       : 00h01m24s
 OutLabel        : NULL
 LS              : BSID: 5000::1:0:2 provisioned BSID:::, Flags(D/B/U/L/F):1/0/0/0/1
 Priority: 128,Flags(S/A/B/E/V/O/D/C/I/T): 0/0/0/0/0/0/0/0/0/0 Preference: 100
 CPathName: p2
 SR Segment List:Flags:0xE000,MTID:0,Alg:0,Weight:1
 Segment(<Type, Flags, SID, SIDDescriptor>):
 Segment(<2,53248,6000::2,0>
 RxPathID        : 0x0
 TxPathID        : 0x0
 Org-validation  : Valid
 AS-path         : (null)
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
表1-6 display bgp link-state命令详细显示信息描述表
Local AS number
本地的AS号
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
NLRI前缀字段
Imported route
该路由为引入的路由
Original nexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
LS
LS属性信息:
·     Node flag bits:节点属性位信息,16进制表示
¡     10[A]:OSPF/OSPFv3的ABR位
¡     20[E]:OSPF/OSPFv3的External位
¡     30[EA]:OSPF/OSPFv3的External位和ABR位
·     Metric:Link或Prefix的链路开销值
·     Local TE router ID:本地TE Router ID
·     flags:SID标志位
·     BSID:入节点的SID
·     Provisioned BSID:命令行配置的入节点SID
·     Flags(D/B/U/L/F):标记位
¡     D:BSID类型,置位时表示BSID为IPv6类型,未置位时表示BSID为IPv4类型
¡     B:置位时表示BSID是静态分配值
¡     U:置位表示命令行配置的BSID分配失败
¡     L:置位时表示BSID为SRLB分配的,未置位时表示BSID为动态分配
¡     F:置位表示BSID是动态分配的
·     Priority:优先级
·     Flags(S/A/B/E/V/O/D/C/I/T):标记位
¡     S:置位时表示候选路径处于shutdown状态
¡     A:置位时表示候选路径处于激活状态
¡     B:置位时表示候选路径为备路径
¡     E:置位时表示候选路径为有效
¡     V:置位时表示候选路径至少有一个有效的seglist
¡     O:置位时表示policy通过ODN生成
¡     D:置位时表示候选路径由PCE/控制器计算产生
¡     C:置位时表示候选路径由PCE/控制器下发
¡     I:置位时表示转发路径无效,丢弃报文
¡     T:置位时表示转发可用
·     Preference:候选路径优先级
·     CPathName:候选路径名称
·     SR Segment List:SID列表
·     Flags:SID列表的标志,用于指示SID列表的属性和状态。此标志位长度为2字节,其中前9个bit具有含义,从第一个bit开始,分别为D|E|C|V|R|F|A|T|M|,各个bit的具体含义分别为:
¡     D:置位时,表示SID列表由SRv6 SID组成。未置位时,表示SID列表由SR-MPLS标签组成
¡     E:置位时,表示SID列表与显式候选路径关联。未置位时,表示SID列表与动态候选路径关联
¡     C:置位时,表示SID列表计算用于动态路径
¡     V:置位时,表示SID列表已通过验证或无需验证。未置位时,表示SID列表未通过验证
¡     R:置位时,表示SID列表的第一个段已解析。未置位时,表示解析失败
¡     F:置位时,表示动态路径计算失败,未置位时,表示动态路径计算成功或不需要计算
¡     A:置位时,表示SID列表中的所有SID属于指定算法
¡     T:置位时,表示SID列表中的所有SID属于指定拓扑
¡     M:置位时,表示SID列表因为监控机制的故障检测而从转发平面中移除。未置位时,表示未检测到故障或未进行监控
·     MTID:多拓扑ID
·     Alg:算法
·     Weight:SID列表在候选路径中权重
·     Segment(<Type, Flags, SID, SID Descriptor>):SID列表信息
¡     Type:类型
¡     Flags:标志位
¡     SID:SID值
¡     SID Descriptor:SID描述符
AS-path
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
IP precedence
路由的IP优先级,取值范围为0~7,N/A表示无效值
QoS local ID
路由的Qos-Local-ID属性,取值范围为1~4095,N/A表示无效值
Traffic index
流量索引值,取值范围为1~64,N/A表示无效值
# 显示向指定LS前缀的BGP LS地址族发布的信息。
<Sysname> display bgp link-state [E][B][I0x0][N[r1.1.1.2]][c65008][R[r44.33.22.11]][c65009]][L[i2.1.1.3][n1.1.1.3]]/536 advertise-info
 Local AS number: 65008
 Paths:  1 best
 BGP LS information of [E][B][I0x0][N[r1.1.1.2]][c65008][R[r44.33.22.11]][c65009]][L[i2.1.1.3][n1.1.1.3]]/536
(TxPathID:0):
10.1.1.2
 LS attribute :
   Peer node segment identifier : Flag c0[VL], Metric 0, Label 23001
表1-7 display bgp link-state advertise-info命令详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
NLRI前缀字段
该信息已向哪些BGP对等体发布,以及对等体的数目
LS attribute
Link-state链路属性
SR邻居节点标识,包括:
·     Flag c0[VL]:
¡     V:Value flag,表示存在标签值
¡     L: Local Flag,表示SID中的值为本地有效
·     Metric:Link的链路开销值
·     Label:标签值
TxPathID
发送的路由的Add-Path ID值
display bgp network命令用来显示通过network命令发布的路由信息和通过network short-cut命令配置的Short-cut路由信息。
display bgp [ instance instance-name ] network { ipv4 | ipv6 } [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
context-admin
context-operator
vsys-admin
vsys-operator
ipv4:显示IPv4地址族的信息。
ipv6:显示IPv6地址族的信息。
multicast:显示BGP组播地址族的信息。非缺省vSystem不支持本参数。
unicast:显示BGP单播地址族的信息。
vpn-instance vpn-instance-name:显示指定VPN实例的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的信息。
# 显示BGP IPv4单播地址族下所有通过network命令通告的路由信息和通过network short-cut命令配置的Short-cut路由信息。
<Sysname> display bgp network ipv4
  Local AS number: 100
  Network           Mask            Route-policy        Short-cut
  20.1.1.0          255.255.255.0                       No
  40.1.1.0          255.255.255.0   abc                 No
  30.1.1.0          255.255.255.0                       Yes
# 显示BGP IPv6单播地址族下所有通过network命令通告的路由信息和通过network short-cut命令配置的Short-cut路由信息。
<Sysname> display bgp network ipv6
  Network           PrefixLen       Route-policy        Short-cut
  1::               24                                  No
  2::               24                                  No
  3::               64              policy1             No
  2::               24                                  Yes
表1-8 display bgp network命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Network
通过network命令发布的路由或Short-cut路由的目的网络地址
Mask
目的网络地址的掩码
PrefixLen
目的网络地址的前缀长度
Route-policy
为该路由应用的路由策略
Short-cut
该路由是否为Short-cut路由,取值包括Yes和No
display bgp non-stop-routing status命令用来显示BGP NSR的运行状态。
display bgp [ instance instance-name ] non-stop-routing status
context-admin
context-operator
非缺省vSystem不支持本命令。
# 显示BGP NSR的运行状态。
<Sysname> display bgp non-stop-routing status
BGP NSR status: Not ready
 Location of preferred standby process: -
 TCP NSR status: Not ready
表1-9 display bgp non-stop-routing status命令显示信息描述表
BGP NSR status
BGP NSR的备份状态,取值包括:
·     Ready:BGP NSR已经将BGP邻居和路由信息从主进程备份到备进程。若在该状态下进行主备进程倒换,则现有路由保持不变,不会影响数据转发
·     Not ready:BGP NSR正在将BGP邻居和路由信息从主进程备份到备进程。若在该状态下进行主备进程倒换,则可能需要重新建立BGP会话,导致数据转发中断
·     Not configured:BGP NSR功能未开启
优选备进程所在单板的槽位号(独立运行模式)
优选备进程所在成员设备的编号及单板的槽位号(IRF模式)
显示为“-”表示不存在备进程
TCP NSR status
TCP NSR的备份状态,取值包括:
·     Ready:TCP NSR已经将TCP连接等信息从主进程备份到备进程
·     Not ready:TCP NSR正在将TCP连接等信息从主进程备份到备进程
display bgp paths命令用来显示BGP的路由属性信息。
context-admin
context-operator
as-regular-expression:显示AS路径与指定正则表达式匹配的BGP路由属性的信息。as-regular-expression表示正则表达式,为1~256个字符的字符串。如果不指定本参数,则显示所有的BGP路由属性信息。
非缺省vSystem不支持本命令。
# 显示所有的BGP路由属性信息。
<Sysname> display bgp paths
  RefCount    MED         Path/Origin
  3           0           ?
  2           0           100i
  3           0           100i
  1           0           ?
  1           0           ?
  1           0           ?
表1-10 display bgp paths命令显示信息描述表
RefCount
使用该路由属性的BGP路由条数
MED
MED属性值
Path/Origin
·     ORIGIN属性标记了此路由如何成为BGP路由,取值包括:
¡     i:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
¡     e:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
¡     ?:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
display bgp peer命令用来显示BGP对等体或对等体组的状态和统计信息。
display bgp [ instance instance-name ] peer ipv4 [ mdt | multicast | mvpn | rtfilter | sr-policy | [ flowspec | unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer ipv6 [ multicast | sr-policy | [ flowspec | unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer ipv4 flowspec [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer ipv6 [ flowspec | unicast ] [ ipv4-address mask-length | ipv4-address log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer link-state [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer vpnv4 [ flowspec | vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer vpnv4 [ flowspec ] { ipv6-address prefix-length | ipv6-address { log-info | verbose } }
display bgp [ instance instance-name ] peer vpnv6 [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer vpnv6 flowspec [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer vpnv6 flowspec [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ]
context-admin
context-operator
vsys-admin
vsys-operator
ipv4:显示BGP IPv4对等体或对等体组的信息。
flowspec:显示BGP Flowspec对等体信息。
ipv6:显示BGP IPv6对等体或对等体组的信息。
link-state:显示BGP LS对等体或对等体组的信息。
vpnv4:显示BGP VPNv4对等体或对等体组的信息。
vpnv6:显示BGP VPNv6对等体或对等体组的信息。
mdt:显示BGP MDT对等体或对等体组的信息。
multicast:显示BGP组播对等体或对等体组的信息。
mvpn:显示BGP IPv4 MVPN对等体或对等体组的信息。
rtfilter:显示BGP IPv4 RT-Filter对等体或对等体组的信息。
sr-policy:显示BGP SR Policy地址族下的对等体或对等体组的信息。
unicast:显示BGP单播对等体或对等体组的信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP对等体或对等体组的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP对等体或对等体组的信息。
ipv4-address mask-length:显示指定网段内的动态对等体的信息。ipv4-address为对等体的IPv4地址;mask-length为网络掩码,取值范围为0~32。
ipv4-address:显示指定对等体的信息。ipv4-address为对等体的IPv4地址。
ipv6-address prefix-length:显示指定网段内的动态对等体的信息。ipv6-address为对等体的IPv6地址;prefix-length为前缀长度,取值范围为0~128。
ipv6-address:显示指定对等体的信息。ipv6-address为对等体的IPv6地址。
group-name group-name:显示指定对等体组内对等体的信息。group-name为对等体组的名称,为1~47个字符的字符串,区分大小写。
log-info:显示指定对等体或对等体组的日志信息。
verbose:显示对等体的详细信息。如果不指定本参数,则显示对等体的简要信息。
非缺省vSystem仅支持显示BGP IPv4和BGP IPv6单播对等体或对等体组的信息。
如果没有指定任何参数,则显示指定地址族所有BGP对等体的简要信息。
如果没有指定unicast、multicast、mdt、mvpn、rtfilter和flowspec参数,则缺省为unicast。
# 显示所有BGP IPv4单播对等体的简要信息。
<Sysname> display bgp peer ipv4
 BGP local router ID: 192.168.100.1
 Total number of peers: 1                  Peers in established state: 1
  10.2.1.2               200       13       16    0       0 00:10:34 Established
表1-11 display bgp peer命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
对等体的总数
处于Established状态的对等体的总数
Peer
对等体的IPv4地址或IPv6地址
AS
对等体所在的AS号
MsgRcvd
从对等体接收的消息数目
MsgSent
向对等体发送的消息数目
OutQ
等待发往对等体的消息数目
PrefRcv
对于IPv4、IPv6、VPNv4和VPNv6地址族,表示从对等体接收到的加入到本地BGP路由表中的前缀数目
对于IPv6 Flowspec地址族,表示从对等体接收到的IPv6 Flowspec信息数目
对于VPNv4 Flowspec地址族,表示从对等体接收到的VPNv4 Flowpsec信息数目
对于VPNv6 Flowspec地址族,表示从对等体接收到的VPNv6 Flowpsec信息数目
对于IPv4 MDT地址族,表示从对等体接收到的MDT信息数目
对于IPv4 RT-Filter地址族,表示从对等体接收到的Route Target信息数目
Up/Down
BGP会话处于当前状态的时长
本地路由器与该对等体之间BGP会话的当前状态
# 显示1.1.1.0/24网段范围内的动态对等体信息。
<Sysname> display bgp peer ipv4 1.1.1.0 24
 Type: EBGP link
 Dynamic address range: 1.1.1.0 24
 Configured: Active Hold Time: 3 sec     Keepalive Time: 1 sec
 Address family IPv4 Unicast: Configured
 Address family IPv4 Multicast: Configured
 Address family IPv4 Label: Configured
 Address family VPNv4: Configured
 Address family IPv4 RT-Filter: Configured
 Address family IPv6 Unicast: Configured
 Address family VPNv6: Configured
 Maximum allowed prefix number: 100
 Threshold: 75%
 Minimum time between advertisements is 100 seconds
 Optional capabilities:
 Nexthop self has been configured
 Keep-all-routes has been configured
 Send community has been configured
 Send extend community has been configured
 Default route originating has been configured
 Multi-hop ebgp has been enabled
 Peer preferred value: 100
 BFD: Enabled
 Site-of-Origin: 1:1
 No import as-path-acl list
 Export as-path-acl list is: 22
 No import prefix list
 Export prefix list is: p1
 No import route policy
 Export route policy is: p1
 No import filter-policy
 No export filter-policy
 Dynamic peers:
  1.1.1.3
# 显示1::/64网段范围内的动态对等体信息。
<Sysname> display bgp peer ipv6 1:: 64
 Type: IBGP link
 Dynamic address range: 1:: 64
 Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
 Threshold: 75%
 Minimum time between advertisements is 15 seconds
 Dynamic peers:
  1::1
表1-12 display bgp peer命令显示信息描述表(动态对等体)
本地路由器与该动态对等体之间的BGP连接类型,取值包括:
·     IBGP link:IBGP连接
·     EBGP link:EBGP连接
动态对等体的地址范围
Configured
本地配置的定时器值,包括会话保持时间间隔(Active Hold Time)和存活时间间隔(Keepalive Time),单位为秒
IPv4单播地址族能力
Address family IPv4 Flowspec
IPv4 Flowspec地址族能力
Address family link-state
LS地址族能力
IPv6单播地址族能力
Address family IPv6 Flowspec
IPv6 Flowspec地址族能力
IPv4组播地址族能力
Address family IPv6 Multicast
IPv6组播地址族能力
Address family MDT
IPv4 MDT地址族能力
IPv4 RT-Filter地址族能力
允许从对等体学习的最大路由数
Threshold
路由器产生日志信息的阈值,即从对等体接收的路由数量与允许的最大路由数的百分比达到此值时,路由器将产生日志信息
路由发布最小时间间隔,单位为秒
本端支持的可选扩展能力
本端支持BGP多协议扩展能力
本端支持BGP路由刷新能力
向对等体发布路由时,将下一跳属性修改为自身的地址
保存所有来自指定对等体的原始路由更新信息,不管这些路由是否通过了路由策略的过滤
向对等体发布团体属性
向对等体发布扩展团体属性
向对等体发送缺省路由
允许本地路由器同非直连网络上的邻居建立EBGP会话
Peer Preferred Value
为来自对等体的路由配置的首选值
BFD
是否配置通过BFD检测本地路由器和指定BGP对等体之间的链路
IPsec profile name
为BGP IPv6对等体应用的IPsec安全框架名
只有显示IPv6单播和IPv6组播地址族信息时,显示本字段
Site-of-Origin
为对等体指定的SoO属性值
为对等体指定的路由策略
Dynamic peers
动态对等体中包括的对等体的地址
# 显示BGP IPv4单播对等体10.2.1.2的详细信息。
<Sysname> display bgp peer ipv4 10.2.1.2 verbose
         Peer: 10.2.1.2          Local: 192.168.100.1
         Type: EBGP link
         BGP version 4, remote router ID 192.168.100.2
         BGP current state: Established, Up for 00h11m10s
         BGP current event: RecvKeepalive
         BGP last state: OpenConfirm
         Port:  Local - 179      Remote - 60672
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Peer optional capabilities:
         Peer supports BGP multi-protocol extension
         Peer supports BGP route refresh capability
         Peer supports BGP route AS4 capability
         Address family IPv4 Unicast: advertised and received
 InQ updates: 0, OutQ updates: 0
 NLRI statistics:
         Rcvd:   UnReach NLRI          0,      Reach NLRI          0
         Sent:   UnReach NLRI          0,      Reach NLRI          0
 Message statistics:
 Msg type     Last rcvd time/      Current rcvd count/      History rcvd count/
              Last sent time       Current sent count       History sent count
 Open         10:38:50-2013.7.23   1                        1
 Update       10:38:51-2013.7.23   1                        1
 Notification -                    0                        0
              -                    0                        0
 Keepalive    10:38:50-2013.7.23   1                        1
 RouteRefresh -                    0                        0
              -                    0                        0
 Total        -                    3                        3
              -                    3                        3
 Threshold: 75%
 Peer Preferred Value: 0
 GTSM has been enabled, and the maximum number of hops is 10
 BFD: Enabled
# 显示BGP IPv6单播对等体1::2的详细信息。
<Sysname> display bgp peer ipv6 1::2 verbose
         Peer: 1::2      Local: 192.168.1.136
         Type: EBGP link
         BGP version 4, remote router ID 192.168.1.135
         BGP current state: Established, Up for 00h05m48s
         Port:  Local - 13184    Remote - 179
 NLRI statistics:
         Sent:   UnReach NLRI          0,       Reach NLRI          3
 Message statistics:
 Open         18:59:15-2013.4.24   1                        1
              18:59:15-2013.4.24   1                        2
 Update       -                    0                        0
              18:59:16-2013.4.24   1                        1
 Notification -                    0                        0
              18:59:15-2013.4.24   0                        1
 Keepalive    18:59:15-2013.4.24   1                        1
 RouteRefresh -                    0                        0
              -                    0                        0
 Total        -                    2                        2
              -                    3                        5
 Threshold: 75%
 BFD: Enabled
# 显示地址为3.3.3.3的BGP IPv4 SR Policy对等体的详细信息。
<Sysname> dis bgp peer ipv4 sr-policy 3.3.3.3 verbose
         Peer: 3.3.3.3   Local: 2.2.2.2
         Type: IBGP link
         BGP version 4, remote router ID 3.3.3.3
         Update group ID: 0
         BGP current state: Established, Up for 01h20m52s
         Port:  Local - 35076    Remote - 179
         Address family IPv4 SR Policy: advertised and received
 NLRI statistics:
         Rcvd:   UnReach NLRI          0,      Reach NLRI          1
 Message statistics:
 Open         16:09:27-2019.3.29   1                        1
 Update       16:09:28-2019.3.29   2                        2
              16:09:28-2019.3.29   1                        1
 Notification -                    0                        0
              -                    0                        0
 Keepalive    17:29:30-2019.3.29   94                       94
              17:29:39-2019.3.29   82                       82
 RouteRefresh -                    0                        0
              -                    0                        0
 Total        -                    97                       97
              -                    84                       84
 Threshold: 75%
 Authentication type configured: None
 Connect-interface has been configured
表1-13 display bgp peer verbose命令显示信息描述表
Peer
对等体的IPv4地址或IPv6地址
Local
本地的路由器ID
本地路由器与该对等体之间的BGP连接类型,取值包括:
·     IBGP link:IBGP连接
·     EBGP link:EBGP连接
BGP version
协议版本号
remote router ID
对等体的路由器ID
BGP current state
Up for
BGP会话建立的持续时间
BGP current event
本地路由器与该对等体之间BGP会话的当前事件
BGP last state
BGP会话的前一个状态
Port
建立TCP连接时本地(Local)和对等体(Remote)使用的端口号
Configured
Received
收到的定时器值,即对等体上配置的定时器值,包括会话保持时间间隔(Active Hold Time),单位为秒
Negotiated
协商后的定时器值,包括会话保持时间间隔(Active Hold Time)和存活时间间隔(Keepalive Time),单位为秒
对等体支持的可选扩展能力
对等体支持BGP多协议扩展能力
对等体支持BGP路由刷新能力
对等体支持四字节AS号能力
IPv4单播地址族能力,可以接收(received)和发送(advertised)该地址族的路由
IPv4 Flowspec地址族能力,可以接收(received)和发送(advertised)该地址族的路由
IPv4 SR Policy地址族能力,可以接收(received)和发送(advertised)该地址族的路由
Address family LS
LS地址族能力,可以接收(received)和发送(advertised)该地址族的路由
IPv6单播地址族能力,可以接收(received)和发送(advertised)该地址族的路由
IPv6 Flowspec地址族能力:可以接收(received)和发送(advertised)该地址族的路由
IPv4组播地址族能力,可以接收(received)和发送(advertised)该地址族的路由
IPv6组播地址族能力,可以接收(received)和发送(advertised)该地址族的路由
Address family MDT
IPv4 MDT地址族能力,可以接收(received)和发送(advertised)该地址族的信息
IPv4 RT-Filter地址族能力:可以接收(received)和发送(advertised)Route Target filter信息
InQ updates
待处理的接收到的Update消息数目
OutQ updates
等待发送给对等体的Update消息数目
NLRI statistics
NLRI统计信息,包括建立BGP会话后,从对等体累计接收到的可达路由数目和不可达路由数目,向对等体累计发送的可达路由数目和不可达路由数目
Message statistics
BGP消息统计信息
Msg type
BGP消息类型
Last rcvd time/Last sent time
最近一次从对等体接收到BGP消息的时间/最近一次向对等体发送BGP消息的时间
Current rcvd count/Current sent count
在当前BGP会话上,从对等体接收到的BGP消息数目/在当前BGP会话上,向对等体发送的BGP消息数目
History rcvd count/History sent count
配置BGP对等体以来,累计从对等体接收到的BGP消息数目/累计向对等体发送的BGP消息数目
Total
接收/发送所有类型消息的总数
允许从对等体学习的最大路由数
Threshold
路由发布最小时间间隔,单位为秒
本端支持的可选扩展能力
本端支持BGP多协议扩展能力
本端支持BGP路由刷新能力
为来自对等体的路由配置的首选值
本端支持BGP报文的GTSM安全检测功能
指定对等体到达本地设备的最大跳数
BFD
IPsec profile name
Site-of-Origin
为对等体指定的SoO属性值
为对等体指定的路由策略
# 显示BGP IPv4单播对等体1.1.1.1的日志信息。
<Sysname> display bgp peer ipv4 1.1.1.1 log-info
 Peer : 1.1.1.1
     Date      Time    State Notification
                             Error/SubError
  06-Feb-2013 22:54:42 Down  Send notification with error 6/4
                             Cease/Administrative Reset
                             <administrative reset>
表1-14 display bgp peer log-info命令显示信息描述表
Peer
对等体的IPv4地址或IPv6地址
Date
发送或接收到Notification消息的日期
Time
发送或接收到Notification消息的时间
本地与对等体之间BGP会话的状态,取值包括:
·     Up:表示BGP会话处于Established状态
·     Down:表示BGP会话断开
Notification Error/SubError
Notification消息中的错误码,表明了BGP会话处于Down状态的原因
Error表示Notification消息差错码,指定错误类型;SubError表示Notification消息差错子码,指定错误类型的详细信息
如果是本端发送Notification消息通知对等体邻居异常断开,则会显示邻居断开的详细原因(详见表1-15)
表1-15 邻居断开的详细原因列表
差错码/差错子码
邻居断开的详细原因
1/1
connection not synchronized
连接不同步,目前实现为收到的报文的报文头前16字节不全为F
1/2
bad message length
报文长度无效
1/3
bad message type
报文的类型无效
3/1
the withdrawn length is too large
撤销信息长度过长
the attribute length is too large
属性长度过长
one attribute appears more than once
同一个属性在一个Update消息中出现了多次
the attribute length is too small
属性长度字段不足2字节
exntended length field is less than two octets
属性长度为可扩展长度,但长度字段不足2字节
the length field is less than one octet
属性长度为正常长度,但长度字段不足1字节
link-state attribute error
链路状态属性形式错误
3/2
unrecognized well-known attribute
不支持的公认属性
3/3
attribute-type attribute missed
attribute-type类型的属性丢失,attribute-type取值包括:
·     ORIGIN
·     AS_PATH
·     LOCAL_PREF
·     NEXT_HOP
3/4
attribute flags error
属性标记错误
3/5
attribute-type attribute length error
attribute-type类型的属性长度错误,attribute-type取值包括:
·     AS_PATH
·     AS4_PATH
·     CLUSTER_LIST
·     AGGREGATOR
·     AS4_AGGREGATOR
·     ORIGIN
·     NEXT_HOP
·     MED
·     LOCAL_PREF
·     ATOMIC_AGGREGATE
·     ORIGINATOR_ID
·     MP_REACH_NLRI
·     COMMUNITIES
·     extended communities
attribute length exceeds
属性长度越界
3/6
invalid ORIGIN attribute
ORIGIN属性无效
3/8
invalid NEXT_HOP attribute
下一跳属性无效
3/9
invalid nexthop length in MP_REACH_NLRI (address-family)
address-family地址族MP_REACH_NLRI属性的Nexthop长度错误,address-family的取值包括:
·     4u:表示IPv4单播地址族
·     IPv4 Flowspec:表示IPv4 Flowspec地址族
·     MPLS:表示MPLS地址族
·     VPNv4:表示VPNv4地址族
·     6u:表示IPv6单播地址族
·     VPNv6:表示VPNv6地址族
·     IPv4 RT-Filter:表示IPv4 RT-Filter地址族
the length of MP_UNREACH_NLRI is too small
MP_UNREACH_NLRI的长度小于3字节
the MP NLRI attribute length exceeds
MP_REACH_NLRI 或MP_UNREACH_NLRI属性长度越界
erroneous MP NLRI attribute end position
可达或不可达前缀结束位置与报文属性结束位置不同
3/10
invalid network field
网络字段无效
3/11
malformed AS_PATH
AS路径形式不对
4/0
hold timer expiration caused by local device
本地导致holdtimer超时
hold timer expiration caused by peer device
对端导致holdtimer超时
5/0
connection retry timer expires
ConnectRetry定时器超时
TCP_CR_Acked event received
收到了TCP_CR_Acked事件
TCP_Connection_Confirmed event received
收到了TCP_Connection_Confirmed事件
5/3
open message received
收到open消息
6/0
manualstop event received
收到manualstop事件
physical interface configuration changed
物理配置改变,比如接口变化
session down event received from BFD
收到BFD会话down事件
6/1
maximum number of prefixes reached
前缀数超过peer route-limit所配置的数目
maximum number of address-family prefixes reached
address-family地址族的前缀数超过peer route-limit所配置的数目,address-family的取值包括:
·     IPv4 unicast:表示IPv4单播地址族
·     IPv6 unicast:表示IPv6单播地址族
·     VPNv4:表示VPNv4地址族
·     VPNv6:表示VPNv6地址族
6/2
configuration of peer ignore changed
配置peer ignore命令
6/3
address family deleted
地址族被删除
peer disabled
关闭对等体
6/4
执行reset bgp命令或者配置改变导致BGP会话重启
6/5
connection rejected
连接被拒绝
6/6
other configuration change
其他配置变化
6/7
connection collision resolution
连接冲突
two connections exist and one uses MD5
存在两个连接,且其中一个配置了MD5认证
6/8
no memory to process the attribute
解析属性时内存不够
no memory for the route
生成路由或者标签块信息时,获取不到内存
no memory to generate unreachable NLRI
封装unreachable NLRI时申请不到内存
no memory to generate a message
封装报文时申请不到内存
can’t get the VPN RD
解析前缀时获取不到RD
can’t get the VPN routing table
解析前缀时获取不到VPN路由表
can’t get the attributes
解析前缀时获取不到属性
entered severe memory state
进入二级门限告警
entered critical memory state
进入三级门限告警
display bgp routing-table dampened命令用来显示衰减的BGP路由信息。
display bgp [ instance instance-name ] routing-table dampened { ipv4 | ipv6 } [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
display bgp [ instance instance-name ] routing-table dampened vpnv4
context-admin
context-operator
vsys-admin
vsys-operator
ipv4:显示衰减的BGP IPv4路由信息。
ipv6:显示衰减的BGP IPv6路由信息。
vpnv4:显示衰减的IBGP VPNv4路由信息。
multicast:显示衰减的BGP组播路由信息。
unicast:显示衰减的BGP单播路由信息。
vpn-instance vpn-instance-name:显示指定VPN实例内衰减的BGP路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网衰减的BGP路由信息。
非缺省vSystem仅支持显示衰减的BGP IPv4和BGP IPv6单播路由信息。
# 显示衰减的BGP IPv4单播路由信息。
<Sysname> display bgp routing-table dampened ipv4
 Total number of routes: 1
 BGP local router ID is 192.168.1.135
 Status codes: * - valid, > - best, d - dampened, h - history
     Network            From            Reuse                         Path/Ogn
  de 20.1.1.0/24        10.1.1.2        00:56:27                      100i
# 显示衰减的BGP IPv6单播路由信息。
<Sysname> display bgp routing-table dampened ipv6
 Total number of routes: 2
  de Network : 2::                                      PrefixLen : 64
     From    : 10.1.1.1                                 Reuse     : 00:39:49
     Path/Ogn: 100i
     From    : 1::1                                     Reuse     : 00:39:49
     Path/Ogn: 100i
表1-16 display bgp routing-table dampened命令显示信息描述表
衰减的路由总数
BGP local router ID
本地的路由器ID
Status codes
路由状态代码:
·     * – valid:合法路由
·     > – best:优选最佳路由
·     h – history:历史路由
·     S – stale:过期路由
·     i – internal:内部路由
·     e – external:外部路由
Origin
路由信息的来源,取值包括:
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
From
发布该路由的BGP对等体的IP地址
Reuse
路由恢复可用的时间,即还需要等待多长时间该路由将由不可用状态转为可用状态
Path/Ogn
·     dampening
·     reset bgp dampening
display bgp routing-table flap-info命令用来显示BGP路由的震荡统计信息。
display bgp [ instance instance-name ] routing-table flap-info ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl as-path-acl-number ]
display bgp [ instance instance-name ] routing-table flap-info ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length | as-path-acl as-path-acl-number ]
display bgp [ instance instance-name ] routing-table flap-info vpnv4 [ ipv4-address [ { mask | mask-length } [ longest-match ] ] | as-path-acl as-path-acl-number ]
context-admin
context-operator
vsys-admin
vsys-operator
ipv4:显示BGP IPv4路由的震荡统计信息。
ipv6:显示BGP IPv6路由的震荡统计信息。
vpnv4:显示IBGP VPNv4路由的震荡统计信息。非缺省vSystem不支持本参数。
multicast:显示BGP组播路由的震荡统计信息。非缺省vSystem不支持本参数。
unicast:显示BGP单播路由的震荡统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例内BGP路由的震荡统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP路由的震荡统计信息。
ipv4-address:显示匹配指定目的网络地址的BGP IPv4单播路由或组播路由的震荡统计信息。
mask-length:目的网络地址的掩码长度,取值范围为0~32。
mask:目的网络地址的掩码,点分十进制格式。
longest-match:指定根据如下方法判断显示哪条BGP IPv4单播路由或组播路由的震荡统计信息:
(1)     将用户输入的网络地址和路由的掩码进行与操作;
(2)     计算结果与路由的网段地址相同,且掩码小于等于用户输入子网掩码的路由中,子网掩码最长的路由将被显示出来。
ipv6-address prefix-length:显示匹配指定目的网络地址及前缀长度的BGP IPv6单播路由或组播路由的震荡统计信息。prefix-length为目的网络地址的前缀长度,取值范围为0~128。
as-path-acl as-path-acl-number:显示匹配指定AS路径过滤列表的BGP路由的震荡统计信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
执行display bgp routing-table flap-info ipv4命令时:
·     如果只指定了ipv4-address参数,则将指定的网络地址和路由的掩码进行与操作,若计算结果与路由的网段地址相同,则显示该BGP IPv4单播路由或组播路由的震荡统计信息。
·     如果指定了ipv4-address mask或ipv4-address mask-length参数,没有指定longest-match参数,则显示与指定目的网络IPv4地址和网络掩码(或掩码长度)精确匹配的BGP IPv4单播路由或组播路由的震荡统计信息。
# 显示所有BGP IPv4单播路由的震荡统计信息。
<Sysname> display bgp routing-table flap-info ipv4
     Network            From            Flaps  Duration  Reuse        Path/Ogn
  de 20.1.1.0/24        10.1.1.2        1      00:02:36  00:53:58     100i
# 显示所有BGP IPv6单播路由的震荡统计信息。
<Sysname> display bgp routing-table flap-info ipv6
     From    : 10.1.1.1                                 Flaps     : 5
     Duration: 00:03:25                                 Reuse     : 00:39:28
     Path/Ogn: 100i
     From    : 1::1                                     Flaps     : 5
     Path/Ogn: 100i
表1-17 display bgp routing-table flap-info命令显示信息描述表
震荡路由的总数
BGP local router ID
本地的路由器ID
Status codes
路由状态代码:
·     * – valid:合法路由
·     > – best:优选最佳路由
·     h – history:历史路由
·     S – stale:过期路由
·     i – internal:内部路由
·     e – external:外部路由
Origin
路由信息的来源,取值包括:
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
From
发布该路由的BGP对等体的IP地址
Flaps
路由震荡的次数,即路由从可达状态变为不可达状态,及可达路由的属性发生变化的次数
Duration
路由发生震荡的持续时间
Reuse
Path/Ogn
·     dampening
·     reset bgp flap-info
1.1.36  display bgp routing-table ipv4 multicast
display bgp routing-table ipv4 multicast命令用来显示BGP IPv4组播路由信息。
display bgp [ instance instance-name ] routing-table ipv4 multicast [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
context-admin
context-operator
ipv4-address:目的网络的IPv4地址。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
longest-match:指定根据如下方法判断显示哪条BGP IPv4组播路由信息:
advertise-info:显示BGP IPv4组播路由的通告信息。
as-path-acl as-path-acl-number:显示匹配指定AS路径过滤列表的BGP IPv4组播路由信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
community-list:显示匹配指定BGP团体列表的BGP IPv4组播路由信息。
basic-community-list-number:基本团体列表号,取值范围为1~99。
comm-list-name:团体属性列表名,为1~63个字符的字符串,区分大小写。
whole-match:精确匹配。如果指定了本参数,则只有路由的团体属性列表与指定的团体属性列表完全相同时,才显示该路由的信息;如果未指定本参数,则只要路由的团体属性列表中包含指定的团体属性列表,就显示该路由的信息。
adv-community-list-number:高级团体列表号,取值范围为100~199。
peer ipv4-address:显示向指定对等体发布或者从指定对等体收到的BGP IPv4组播路由信息。ipv4-address为对等体的地址。
advertised-routes:显示向指定的对等体发布的路由信息。
received-routes:显示从指定的对等体接收到的路由信息。
statistics:显示路由的统计信息。
非缺省vSystem不支持本命令。
如果没有指定任何参数,则显示所有BGP IPv4组播路由的简要信息。
如果只指定了ipv4-address参数,则将指定的网络地址和路由的掩码进行与操作,若计算结果与路由的网段地址相同,则显示该路由的详细信息。
如果指定了ipv4-address mask或ipv4-address mask-length参数,没有指定longest-match参数,则显示与指定目的网络IPv4地址和网络掩码(或掩码长度)精确匹配的BGP IPv4组播路由的详细信息。
# 显示所有BGP IPv4组播路由的简要信息。
<Sysname> display bgp routing-table ipv4 multicast
 Total number of routes: 3
 BGP local router ID is 192.168.1.62
               a – additional-path
* >  5.5.5.5/32         127.0.0.1       0                     32768   ?
* >  192.168.1.0        192.168.1.62    0                     32768   ?
* >  192.168.1.62/32    127.0.0.1       0                     32768   ?
# 显示匹配编号为20的AS路径过滤列表的BGP IPv4组播路由信息。
<Sysname> display bgp routing-table ipv4 multicast as-path-acl 20
               a – additional-path
# 显示匹配BGP团体列表100的BGP IPv4组播路由信息。
<Sysname> display bgp routing-table ipv4 multicast community-list 100
               a – additional-path
# 显示向对等体192.168.1.139发布的所有BGP IPv4组播路由信息。
<Sysname> display bgp routing-table ipv4 multicast peer 192.168.1.139 advertised-routes
               a – additional-path
     Network            NextHop         MED        LocPrf             Path/Ogn
* >  5.5.5.5/32         127.0.0.1       0          100                ?
* >  192.168.1.0        192.168.1.62    0          100                ?
# 显示从对等体192.168.1.139收到的所有BGP IPv4组播路由信息。
<Sysname> display bgp routing-table ipv4 multicast peer 192.168.1.139 received-routes
               a – additional-path
* >i 8.8.8.8/32         192.168.1.139   0          100        0       ?
*  i 192.168.1.0        192.168.1.139   0          100        0       ?
表1-18 display bgp routing-table ipv4 multicast命令简要显示信息描述表
路由总数
BGP local router ID
本地的路由器ID
Status codes
路由状态代码:
·     * – valid:合法路由
·     > – best:普通优选最佳路由
·     d – damped:震荡抑制路由
·     h – history:历史路由
·     S – Stale:过期路由
·     i – internal:内部路由
·     e – external:外部路由
·     a – additional-path:Add-Path优选路由
Origin
路由信息的来源,取值包括:
Network
目的网络地址
NextHop
下一跳IP地址
MED
LocPrf
本地优先级
PrefVal
路由首选值
Path/Ogn
·     ORIGIN属性标记了此BGP路由如何生成的
# 显示到达目的网络5.5.5.5/32的BGP IPv4组播路由的详细信息。
<Sysname> display bgp routing-table ipv4 multicast 5.5.5.5 32
 BGP local router ID: 192.168.1.139
 BGP routing table information of 5.5.5.5/32:
 Rely nexthop    : 192.168.1.62
 Original nexthop: 192.168.1.62
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : incomplete
 State           : valid, internal, best
 Originator      : 176.1.1.2
 Cluster list    : 80
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 VPN-Peer UserID : N/A
 DSCP            : N/A
 EXP             : N/A
表1-19 display bgp routing-table ipv4 multicast命令详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
到达目的网络5.5.5.5/32的BGP路由表项信息
From
发布该路由的BGP对等体的IP地址
Imported route
该路由为引入的路由
Rely Nexthop
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved”
Original nexthop
OutLabel
路由的出标签值
RxPathID
接收到的路由的Add-Path ID值
TxPathID
发送的路由的Add-Path ID值
AS-path
Origin
路由信息的来源,取值包括:
·     igp:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
Originator
将路由发布给路由反射器的对等体的Router ID
Cluster list
路由反射器的集群ID
IP precedence
QoS local ID
路由的QoS本地ID属性,取值范围为1~4095,N/A表示无效值
Traffic index
VPN-Peer UserID
路由所属的VPN peer ID值,取值范围为1~134217727,N/A表示无效值
DSCP
路由的DSCP优先级,取值范围为0~63,N/A表示无效值
EXP
路由的EXP优先级,N/A表示无效值
# 显示向对等体192.168.1.62发布的BGP IPv4组播路由的统计信息。
<Sysname> display bgp routing-table ipv4 multicast peer 192.168.1.62 advertised-routes statistics
 Advertised routes total: 2
# 显示从对等体192.168.1.62收到的BGP IPv4组播路由的统计信息。
<Sysname> display bgp routing-table ipv4 multicast peer 192.168.1.62 received-routes statistics
 Received routes total: 2
表1-20 display bgp routing-table ipv4 multicast peer statistics命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
# 显示IPv4组播的路由统计信息。
<Sysname> display bgp routing-table ipv4 multicast statistics
 Total number of routes: 5
表1-21 display bgp routing-table ipv4 multicast statistics命令显示信息描述表
路由总数
# 显示到达目的网段8.8.8.8/32的BGP IPv4组播路由的通告信息。
<Sysname> display bgp routing-table ipv4 multicast 8.8.8.8 32 advertise-info
 Paths:   1 best
 BGP routing table information of 8.8.8.8/32:
    192.168.1.62
表1-22 display bgp routing-table ipv4 multicast advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
到达指定目的网络的优选路由数目
到达目的网络8.8.8.8/32的BGP路由的通告信息
该路由已经向哪些对等体发送,以及对等体的数目
·     ip as-path(三层技术-IP路由命令参考/路由策略)
·     ip community-list(三层技术-IP路由命令参考/路由策略)
1.1.37  display bgp routing-table ipv4 rtfilter
display bgp routing-table ipv4 rtfilter命令用来显示BGP IPv4 RT-Filter路由信息。
display bgp [ instance instance-name ] routing-table ipv4 rtfilter [ default-rt [ advertise-info ] | [ origin-as as-number ] [ route-target [ advertise-info ] ] | peer ipv4-address { advertised-routes | received-routes } [ default-rt | [ origin-as as-number ] [ route-target ] | statistics ] | statistics ]
context-admin
context-operator
default-rt:显示Route Target为全0的BGP IPv4 rtfilter信息。
origin-as as-number:显示指定源AS的BGP IPv4 RT-Filter路由信息。
route-target:显示指定Route Target的BGP IPv4 RT-Filter路由信息,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
advertise-info:显示BGP IPv4 RT-Filter路由的通告信息。
peer ipv4-address:显示向指定对等体发布或者从指定对等体收到的BGP IPv4 RT-Filter路由信息。ipv4-address为对等体的地址。
非缺省vSystem不支持本命令。
如果没有指定任何参数,则显示所有BGP IPv4 RT-Filter路由的简要信息。
# 显示所有BGP IPv4 RT-Filter路由的简要信息。
<Sysname> display bgp routing-table ipv4 rtfilter
BGP local router ID is 192.168.1.136
               a – additional-path
Total number of routes from all PEs: 2
Origin AS: 100
* >e Network : <100:1>                                  PrefixLen : 96
     PrefVal : 0
     MED     :
     Path/Ogn: 100i
* >e Network : <1.1.1.1:1>                              PrefixLen : 96
     PrefVal : 0
     MED     :
     Path/Ogn: 100i
# 显示匹配源AS号为100的BGP IPv4 RT-Filter路由信息。
<Sysname> display bgp routing-table ipv4 rtfilter origin-as 100
               a – additional-path
Origin AS: 100
     PrefVal : 0
     MED     :
     Path/Ogn: 100i
     PrefVal : 0
     MED     :
     Path/Ogn: 100i
# 显示向对等体10.2.1.2发布的所有公网BGP IPv4 RT-Filter路由信息。
<Sysname> display bgp routing-table ipv4 rtfilter peer 10.2.1.2 advertised-routes
               a – additional-path
Origin AS: 100
* >  Network : <100:1>                                  PrefixLen : 96
     MED     : 0
     Path/Ogn: i
# 显示从对等体10.2.1.2收到的所有公网BGP IPv4 RT-Filter路由信息。
<Sysname> display bgp routing-table ipv4 rtfilter peer 10.2.1.2 received-routes
               a – additional-path
Origin AS: 100
     NextHop : 10.1.1.1                                LocPrf    :
     PrefVal : 0
     MED     : 0
     Path/Ogn: 100i
表1-23 display bgp routing-table ipv4 rtfilter命令简要显示信息描述表
来自所有PE设备且符合命令行过滤条件的Route Target过滤信息总数
Origin AS
RT-Filter路由源AS号
路由总数
BGP local router ID
本地的路由器ID
Status codes
路由状态代码:
·     * – valid:合法路由
·     > – best:普通优选最佳路由
·     h – history:历史路由
·     S – stale:过期路由
·     i – internal:内部路由
·     e – external:外部路由
Origin
路由信息的来源,取值包括:
Network
目的网络地址
NextHop
下一跳IP地址
MED
MED(Multi-Exit Discriminator,多出口区分)属性值
LocPrf
本地优先级
PrefVal
路由首选值
Path/Ogn
# 显示BGP IPv4 RT-Filter路由100:1的详细信息。
<Sysname> display bgp routing-table ipv4 rtfilter 100:1
 Origin AS: 100
 BGP routing table information of <100:1>/96:
 Imported route.
 Original nexthop: 10.2.1.1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : igp
 Attribute value : MED 0, pref-val 32768, pre 0
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
表1-24 display bgp routing-table ipv4 rtfilter命令详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Origin AS
RT-Filter路由源AS号
路由总数
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
BGP routing table information of <1.1.1.1:1>/96
<1.1.1.1:1>/96的BGP Route-Target Filter路由表项信息
Imported route
该路由为本地生成的BGP Route-Target Filter路由
Original nexthop
OutLabel
路由的出标签值
RxPathID
接收到的路由的Add-Path ID值
TxPathID
发送的路由的Add-Path ID值
AS-path
Origin
路由信息的来源,取值包括:
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的。
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
From
发布该路由的BGP对等体的IP地址
Rely Nexthop
IP precedence
路由的IP优先级,取值范围是0~7,N/A表示无效值
QoS local ID
路由的Qos-Local-ID属性,取值范围是1~4095,N/A表示无效值
Traffic index
流量索引值,取值范围是1~64,N/A表示无效值
VPN-Peer UserID
DSCP
Backup route
该路由为备份的路由
# 显示向对等体10.2.1.2发布的BGP IPv4 RT-Filter路由的统计信息。
<Sysname> display bgp routing-table ipv4 rtfilter peer 10.2.1.2 advertised-routes statistics
# 显示从对等体10.2.1.2收到的BGP IPv4RT-Filter路由的统计信息。
<Sysname> display bgp routing-table ipv4 rtfilter peer 10.2.1.2 received-routes statistics
表1-25 display bgp routing-table ipv4 rtfilter peer statistics命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
# 显示BGP IPv4 RT-Filter路由的统计信息。
<Sysname> display bgp routing-table ipv4 rtfilter statistics
 Total number of routes from all PEs: 6
Origin AS: 100
 Origin AS: 200
表1-26 display bgp routing-table ipv4 rtfilter statistics命令显示信息描述表
Origin AS
RT-Filter路由源AS号
路由总数
# 显示BGP IPv4 rtfilter 1.1.1.1:1/96路由的通告信息。
<Sysname> display bgp routing-table ipv4 rtfilter 1.1.1.1:1 advertise-info
 Paths:   1 best
Origin AS: 100
 Paths:   1 best
 BGP route-target filter information of <1.1.1.1:1>/96:
1.1.1.2
 Origin AS: 200
 Paths:   1 best
    1.1.1.2
表1-27 display bgp routing-table ipv4 rtfilter advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Origin AS
RT-Filter路由源AS号
路由总数
Paths
到达指定目的网络的优选路由数目
1.1.38  display bgp routing-table ipv4 unicast
display bgp routing-table ipv4 unicast命令用来显示BGP IPv4单播路由信息。
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name:显示指定VPN实例的BGP IPv4单播路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP IPv4单播路由信息。
mask:网络掩码,点分十进制格式。
longest-match:指定根据如下方法判断显示哪条BGP IPv4单播路由信息:
advertise-info:显示BGP IPv4单播路由的通告信息。
as-path-acl as-path-acl-number:显示匹配指定AS路径过滤列表的BGP IPv4单播路由信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
community-list:显示匹配指定BGP团体列表的BGP IPv4单播路由信息。
peer ipv4-address:显示向指定对等体发布或者从指定对等体收到的BGP IPv4单播路由信息。ipv4-address为对等体的地址。
如果没有指定任何参数,则显示所有BGP IPv4单播路由的简要信息。
如果只指定了ipv4-address参数,则将指定的网络地址和路由的掩码进行与操作,若计算结果与路由的网段地址相同,则显示该路由的信息。
如果指定了ipv4-address mask或ipv4-address mask-length参数,没有指定longest-match参数,则显示与指定目的网络IPv4地址和网络掩码(或掩码长度)精确匹配的BGP IPv4单播路由的信息。
执行本命令时指定unicast参数和不指定unicast参数的效果相同。
# 显示所有BGP IPv4单播路由的简要信息。
 BGP local router ID is 192.168.100.1
               a – additional-path
* >  10.2.1.0/24        10.2.1.1        0                     0       i
   e                    10.2.1.2        0                     0       4294967295
 4294967294 4294967293 4294967292 4294967291 4294967290 4294967215 4294967225 4294967235 4294967245 4294967295 4294967294 4294967293 4294967292 4294967291 4294967290 i
* >  192.168.1.0        192.168.1.135   0                     0       i
*  e                    10.2.1.2        0                     0       200i
# 显示匹配AS路径过滤列表1的BGP IPv4单播路由信息。
<Sysname> display bgp routing-table ipv4 as-path-acl 1
               a – additional-path
* >e 30.1.1.0/24        20.1.1.1                              0       200i
# 显示向对等体10.2.1.2发布的所有公网BGP IPv4单播路由信息。
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 advertised-routes
 Status codes: * - valid, > - best, d - damped, h - history
               s - suppressed, S - Stale, i - internal, e - external
               a – additional-path
# 显示从对等体10.2.1.2收到的所有公网BGP IPv4单播路由信息。
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 received-routes
               a – additional-path
   e 10.2.1.0/24        10.2.1.2        0                     0       200i
*  e 192.168.1.0        10.2.1.2        0                     0       200i
表1-28 display bgp routing-table ipv4 unicast命令简要显示信息描述表
路由总数
BGP local router ID
本地的路由器ID
Status codes
路由状态代码:
·     * – valid:合法路由
·     > – best:普通优选最佳路由
·     h – history:历史路由
·     S – stale:过期路由
·     i – internal:内部路由
·     e – external:外部路由
Origin
路由信息的来源,取值包括:
Network
目的网络地址
NextHop
下一跳IP地址
MED
LocPrf
本地优先级
PrefVal
路由首选值
Path/Ogn
·     AS_PATH属性记录了此路由经过的所有AS,可以避免路由环路的出现。本字段最多显示16个AS号,超出的部分以“…”表示,被省略的部分可以通过显示路由的详细信息查看
# 显示到达目的网络10.2.1.0/24的BGP IPv4单播路由的详细信息。
<Sysname> display bgp routing-table ipv4 10.2.1.0 24
 Paths:   2 available, 1 best
 BGP routing table information of 10.2.1.0/24:
 Imported route.
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : igp
PrefixSID       : Label index 201
 SRMS-PrefixSID  : Label index 202
Attribute value : MED 0, pref-val 0, pre 0
 Cluster list    : 80
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 EXP             : N/A
 Rely nexthop    : not resolved
 Original nexthop: 10.2.1.2
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 Attribute value : MED 0, pref-val 0, pre 255
 State           : external
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 EXP             : N/A
# 显示到达目的网络1.1.1.1/32的BGP IPv4单播路由的详细信息。
<Sysname> display bgp routing-table ipv4 1.1.1.1 32
 BGP routing table information of 1.1.1.1/32:
 Rely nexthop    : 10.2.1.1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 EXP             : N/A
 Backup route.
 Rely nexthop    : 10.2.1.2
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 State           : external
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 EXP             : N/A
表1-29 display bgp routing-table ipv4 unicast命令详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
到达目的网络10.2.1.0/24的BGP路由表项信息
Imported route
该路由为引入的路由
Original nexthop
OutLabel
路由的出标签值
RxPathID
接收到的路由的Add-Path ID值
TxPathID
发送的路由的Add-Path ID值
AS-path
Origin
路由信息的来源,取值包括:
PrefixSID
SR前缀标签属性,取值包括:
·     Label index:标签索引
·     SRGB:分段路由全局标签段范围
SRMS-PrefixSID
SRMS的前缀标签属性,取值为Label index,表示标签索引
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
Originator
Cluster list
路由反射器的集群ID
From
发布该路由的BGP对等体的IP地址
Rely Nexthop
IP precedence
QoS local ID
Traffic index
VPN-Peer UserID
DSCP
Backup route
该路由为备份的路由
EXP
路由的EXP优先级,N/A表示无效值
Tunnel policy
路由生效的隧道策略,NULL表示无生效的隧道策略
Rely Tunnel IDs
路由迭代后的隧道索引值列表,存在等价隧道时,可能对应多个NHLFE表项索引值,如果未迭代隧道,显示为N/A
# 显示向对等体10.2.1.2发布的公网BGP IPv4单播路由的统计信息。
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 advertised-routes statistics
# 显示从对等体10.2.1.2收到的公网BGP IPv4单播路由的统计信息。
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 received-routes statistics
表1-30 display bgp routing-table ipv4 unicast peer statistics命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
# 显示BGP IPv4单播路由的统计信息。
<Sysname> display bgp routing-table ipv4 statistics
表1-31 display bgp routing-table ipv4 unicast statistics命令显示信息描述表
路由总数
# 显示到达目的网段10.2.1.0/24的BGP IPv4单播路由的通告信息。
<Sysname> display bgp routing-table ipv4 10.2.1.0 24 advertise-info
 Paths:   1 best
    10.2.1.2
表1-32 display bgp routing-table ipv4 unicast advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
到达指定目的网络的优选路由数目
到达目的网络10.2.1.0/24的BGP路由的通告信息
1.1.39  display bgp routing-table ipv6 multicast
display bgp routing-table ipv6 multicast命令用来显示BGP IPv6 组播路由信息。
display bgp [ instance instance-name ] routing-table ipv6 multicast  [ ipv6-address prefix-length [ advertise-info ] | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
context-admin
context-operator
ipv6-address prefix-length:显示与指定的目的网络地址和前缀长度精确匹配的BGP IPv6组播路由信息。prefix-length为目的网络地址的前缀长度,取值范围为0~128。如果没有指定本参数,则显示所有BGP IPv6组播路由的简要信息。
advertise-info:显示BGP IPv6组播路由的通告信息。如果没有指定本参数,则显示BGP IPv6组播路由表的信息。
as-path-acl as-path-acl-number:显示匹配指定AS路径过滤列表的BGP IPv6组播路由信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
communit-list:显示匹配指定BGP团体列表的BGP IPv6组播路由信息。
peer:显示向指定的对等体发布或者从指定的对等体收到的BGP IPv6组播路由信息。
ipv6-address:对等体的IPv6地址。
非缺省vSystem不支持本命令。
# 显示所有BGP IPv6组播路由的简要信息。
<Sysname> display bgp routing-table ipv6 multicast
 BGP local router ID is 192.168.1.139
               a – additional-path
* >  Network : 1::                                      PrefixLen : 64
     NextHop : ::                                       LocPrf    :
     MED     : 0
     Path/Ogn: ?
*  i Network : 1::                                      PrefixLen : 64
     NextHop : 1::1                                     LocPrf    : 100
     MED     : 0
     Path/Ogn: ?
* >  Network : 1::2                                     PrefixLen : 128
     NextHop : ::1                                      LocPrf    :
     MED     : 0
     Path/Ogn: ?
* >  Network : 2::2                                     PrefixLen : 128
     MED     : 0
     Path/Ogn: ?
* >i Network : 5::5                                     PrefixLen : 128
     MED     : 0
     Path/Ogn: ?
# 显示匹配AS路径过滤列表1的BGP IPv6组播路由信息。
<Sysname> display bgp routing-table ipv6 multicast as-path-acl 1
               a – additional-path
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
# 显示匹配BGP团体列表100的BGP IPv6组播路由信息。
<Sysname> display bgp routing-table ipv6 multicast community-list 100
               a – additional-path
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
# 显示向对等体1::1发布的所有BGP IPv6组播路由信息。
<Sysname> display bgp routing-table ipv6 multicast peer 1::1 advertised-routes
               a – additional-path
     NextHop : ::                                       LocPrf    : 100
     MED     : 0                                        OutLabel  : NULL
     Path/Ogn: ?
     NextHop : ::1                                      LocPrf    : 100
     Path/Ogn: ?
# 显示从对等体1::1收到的所有BGP IPv6组播路由信息。
<Sysname> display bgp routing-table ipv6 multicast peer 1::1 received-routes
               a – additional-path
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
表1-33 display bgp routing-table ipv6 multicast命令简要显示信息描述表
路由总数
BGP local router ID
本地的路由器ID
Status codes
路由状态代码:
·     * – valid:合法路由
·     > – best:普通优选最佳路由
·     d – damped:震荡抑制路由
·     h – history:历史路由
·     S – Stale:过期路由
·     i – internal:内部路由
·     e – external:外部路由
Origin
路由信息的来源,取值包括:
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
NextHop
下一跳IP地址
LocPrf
本地优先级
PrefVal
路由首选值
OutLabel
路由的出标签值
MED
Path/Ogn
# 显示到达目的网络2::2/128的BGP IPv6组播路由的详细信息。
<Sysname> display bgp routing-table ipv6 multicast 2::2 128
 BGP routing table information of 2::2/128:
 Imported route.
 Original nexthop: ::1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : incomplete
 Cluster list    : 80
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 EXP             : N/A
表1-34 display bgp routing-table ipv6 multicast命令详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
到达目的网络2::2/128的BGP路由表项信息
Imported route
该路由为引入的路由
Original nexthop
OutLabel
路由的出标签值
RxPathID
接收到的路由的Add-Path ID值
TxPathID
发送的路由的Add-Path ID值
AS-path
Origin
路由信息的来源,取值包括:
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     best:最佳路由
Originator
Cluster list
路由反射器的集群ID
From
发布该路由的BGP对等体的IP地址
Rely Nexthop
IP precedence
QoS local ID
Traffic index
VPN-Peer UserID
DSCP
EXP
路由的EXP优先级,N/A表示无效值
# 显示到达目的网段2::2/128的BGP IPv6组播路由的通告信息。
<Sysname> display bgp routing-table ipv6 multicast 2::2 128 advertise-info
 Paths:   1 best
    1::1
表1-35 display bgp routing-table ipv6 multicast advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
到达指定目的网络的优选路由数目
到达目的网络2::2/128的BGP路由的通告信息
# 显示向对等体1::1发布的BGP IPv6组播路由的统计信息。
<Sysname> display bgp routing-table ipv6 multicast peer 1::1 advertised-routes statistics
# 显示从对等体1::1收到的BGP IPv6组播路由的统计信息。
<Sysname> display bgp routing-table ipv6 multicast peer 1::1 received-routes statistics
表1-36 display bgp routing-table ipv6 multicast peer statistics命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
# 显示BGP IPv6组播的路由统计信息。
<Sysname> display bgp routing-table ipv6 multicast statistics
表1-37 display bgp routing-table ipv6 multicast statistics命令显示信息描述表
路由总数
1.1.40  display bgp routing-table ipv6 unicast
display bgp routing-table ipv6 unicast命令用来显示BGP IPv6单播路由信息。
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length [ advertise-info ] | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] peer ipv4-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ]
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name:显示指定VPN实例的BGP IPv6单播路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP IPv6单播路由信息。
ipv6-address prefix-length:显示与指定的目的网络地址和前缀长度精确匹配的BGP IPv6单播路由信息。prefix-length为目的网络地址的前缀长度,取值范围为0~128。如果没有指定本参数,则显示所有BGP IPv6单播路由的简要信息。
advertise-info:显示BGP IPv6单播路由的通告信息。如果没有指定本参数,则显示BGP IPv6单播路由表的信息。
as-path-acl as-path-acl-number:显示匹配指定AS路径过滤列表的BGP IPv6单播路由信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
communit-list:显示匹配指定BGP团体列表的BGP IPv6单播路由信息。
peer:显示向指定的对等体发布或者从指定的对等体收到的BGP IPv6单播路由信息。
ipv4-address:对等体的IPv4地址。
# 显示所有BGP IPv6单播路由的简要信息。
               a – additional-path
* >e Network : 3::                                      PrefixLen : 64
     NextHop : 1::2                                     LocPrf    :
     MED     :
     Path/Ogn: 4294967295 4294967294 4294967293 4294967292 4294967291 4294967290 4294967215 4294967225 4294967235 4294967245 4294967295 4294967294 4294967293 4294967292 4294967291 4294967290 i
# 显示匹配AS路径过滤列表1的BGP IPv6单播路由信息。
<Sysname> display bgp routing-table ipv6 as-path-acl 1
               a – additional-path
* >e Network : 2::                                      PrefixLen : 64
     MED     :
     Path/Ogn: 100i
     MED     :
     Path/Ogn: 100i
# 显示匹配BGP团体列表100的BGP IPv6单播路由信息。
<Sysname> display bgp routing-table ipv6 community-list 100
               a – additional-path
     MED     :
     Path/Ogn: 100i
     MED     :
     Path/Ogn: 100i
# 显示向对等体1::1发布的所有BGP IPv6单播路由信息。
<Sysname> display bgp routing-table ipv6 peer 1::1 advertised-routes
               a – additional-path
* >  Network : 2::                                      PrefixLen : 64
     Path/Ogn: i
# 显示从对等体1::1收到的所有BGP IPv6单播路由信息。
<Sysname> display bgp routing-table ipv6 peer 1::1 received-routes
               a – additional-path
     NextHop : ::FFFF:10.1.1.1                          LocPrf    :
     MED     : 0
     Path/Ogn: 100i
表1-38 display bgp routing-table ipv6 unicast命令简要显示信息描述表
路由总数
BGP local router ID
本地的路由器ID
Status codes
路由状态代码:
·     * – valid:合法路由
·     > – best:普通优选最佳路由
·     h – history:历史路由
·     S – stale:过期路由
·     i – internal:内部路由
·     e – external:外部路由
Origin
路由信息的来源,取值包括:
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
NextHop
下一跳IP地址
LocPrf
本地优先级
PrefVal
路由首选值
OutLabel
路由的出标签值
MED
Path/Ogn
# 显示到达目的网络2::/64的BGP IPv6单播路由的详细信息。
<Sysname> display bgp routing-table ipv6 2:: 64
 BGP routing table information of 2::/64:
 Rely nexthop    : ::FFFF:10.1.1.1
 Original nexthop: ::FFFF:10.1.1.1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 100
 Origin          : igp
 Cluster list    : 80
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 EXP             : N/A
 Backup route.
 Rely nexthop    : 1::1
 Original nexthop: 1::1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 100
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 EXP             : N/A
表1-39 display bgp routing-table ipv6 unicast命令详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
到达目的网络2::/64的BGP路由表项信息
Imported route
该路由为引入的路由
Original nexthop
OutLabel
路由的出标签值
RxPathID
接收到的路由的Add-Path ID值
TxPathID
发送的路由的Add-Path ID值
AS-path
Origin
路由信息的来源,取值包括:
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     best:最佳路由
Originator
Cluster list
路由反射器的集群ID
From
发布该路由的BGP对等体的IP地址
Rely Nexthop
IP precedence
QoS local ID
Traffic index
VPN-Peer UserID
DSCP
Backup route
该路由为备份的路由
EXP
路由的EXP优先级,N/A表示无效值
Tunnel policy
Rely Tunnel IDs
# 显示到达目的网段2::/64的BGP IPv6单播路由的通告信息。
<Sysname> display bgp routing-table ipv6 2:: 64 advertise-info
 BGP local router ID: 192.168.1.136
 Paths:   1 best
 Advertised to peers (2 in total):
    10.1.1.2
    1::2
表1-40 display bgp routing-table ipv6 unicast advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
到达指定目的网络的优选路由数目
到达目的网络2::/64的BGP路由的通告信息
# 显示向对等体1::1发布的BGP IPv6单播路由的统计信息。
<Sysname> display bgp routing-table ipv6 peer 1::1 advertised-routes statistics
 Advertised routes total: 1
# 显示从对等体1::1收到的BGP IPv6单播路由的统计信息。
<Sysname> display bgp routing-table ipv6 peer 1::1 received-routes statistics
 Received routes total: 1
表1-41 display bgp routing-table ipv6 unicast peer statistics命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
# 显示BGP IPv6单播路由的统计信息。
<Sysname> display bgp routing-table ipv6 statistics
表1-42 display bgp routing-table ipv6 unicast statistics命令显示信息描述表
路由总数
1.1.41  display bgp routing-table ipv6 unicast inlabel
display bgp routing-table ipv6 unicast inlabel命令用来显示BGP IPv6单播路由的入标签信息。
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] inlabel
context-admin
context-operator
非缺省vSystem不支持本命令。
# 显示所有BGP IPv6单播路由的入标签信息。
<Sysname> display bgp routing-table ipv6 inlabel
               a – additional-path
* >  Network : 1::1                                     PrefixLen : 128
     NextHop : 10::1                                    OutLabel  : NULL
     InLabel : 1279
* >  Network : 10::                                     PrefixLen : 64
     NextHop : ::                                       OutLabel  : NULL
     InLabel : 1278
表1-43 display bgp routing-table ipv6 unicast inlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码,请参见表1-38
Origin
路由起源代码,请参见表1-38
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
NextHop
下一跳IPv6地址
OutLabel
出标签值,即对端6PE设备为IPv6单播路由分配的标签值
InLabel
入标签值,即本地6PE设备为IPv6单播路由分配的标签值
1.1.42  display bgp routing-table ipv6 unicast outlabel
display bgp routing-table ipv6 unicast outlabel命令用来显示BGP IPv6单播路由的出标签信息。
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] outlabel
context-admin
context-operator
非缺省vSystem不支持本命令。
# 显示所有BGP IPv6单播路由的出标签信息。
<Sysname> display bgp routing-table ipv6 outlabel
               a – additional-path
* >i Network : 4::4                                     PrefixLen : 128
     NextHop : ::FFFF:3.3.3.3                           OutLabel  : 1279
* >i Network : 20::                                     PrefixLen : 64
     NextHop : ::FFFF:3.3.3.3                           OutLabel  : 1278
表1-44 display bgp routing-table ipv6 unicast outlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码,请参见表1-38
Origin
路由起源代码,请参见表1-38
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
NextHop
下一跳IPv6地址
OutLabel
1.1.43  display bgp update-group
display bgp update-group命令用来显示BGP打包组的相关信息。
display bgp [ instance instance-name ] update-group ipv4 [ mdt | multicast | mvpn | rtfilter | sr-policy | [ flowspec | unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address ]
display bgp [ instance instance-name ] update-group ipv4 flowspec [ vpn-instance vpn-instance-name ] [ ipv6-address ]
display bgp [ instance instance-name ] update-group ipv6 [ multicast | sr-policy | [ flowspec | unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address ]
display bgp [ instance instance-name ] update-group ipv6 [ unicast ] [ ipv4-address ]
display bgp [ instance instance-name ] update-group ipv6 flowspec [ vpn-instance vpn-instance-name ] [ ipv4-address ]
display bgp [ instance instance-name ] update-group link-state [ ipv4-address | ipv6-address ]
display bgp [ instance instance-name ] update-group vpnv4 [ flowspec | vpn-instance vpn-instance-name ] [ ipv4-address ]
display bgp [ instance instance-name ] update-group vpnv4 [ flowspec ] ipv6-address
display bgp [ instance instance-name ] update-group vpnv6 [ ipv4-address | ipv6-address ]
display bgp [ instance instance-name ] update-group vpnv6 flowspec [ ipv4-address | ipv6-address ]
context-admin
context-operator
vsys-admin
vsys-operator
ipv4:显示BGP IPv4地址族的打包组信息。
flowspec:显示Flowspec地址族的打包组信息。
ipv6:显示BGP IPv6地址族的打包组信息。
link-state:显示BGP LS地址族的打包组信息。
vpnv4:显示BGP VPNv4地址族的打包组信息。
vpnv6:显示BGP VPNv6地址族的打包组信息。
mdt:显示BGP MDT地址族的打包组信息。
multicast:显示BGP组播地址族的打包组信息。
mvpn:显示BGP IPv4 MVPN地址族的打包组信息。
rtfilter:显示BGP IPv4 RT-Filter地址族的打包组信息。
sr-policy:显示BGP SR Policy对等体组的信息。
unicast:显示BGP单播地址族的打包组信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的BGP打包组相关信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP打包组相关信息。
ipv4-address:显示指定对等体所在打包组的信息。ipv4-address为对等体的IPv4地址。
ipv6-address:显示指定对等体所在打包组的信息。ipv6-address为对等体的IPv6地址。
非缺省vSystem仅支持显示BGP IPv4和BGP IPv6单播地址族的打包组信息。
按组打包技术是指将出口策略相同的对等体归为一组,形成一个打包组,设备向打包组中的对等体发布路由时,统一对路由进行策略过滤,并构造路由更新报文(即打包),以避免重复地进行策略过滤和构造报文。
实现按组打包后,每条路由前缀信息只需要经过一次策略过滤并打包一次,然后发布给打包组内的所有对等体。例如,如果不采用按组打包,1000条路由向1000个对等体发布时,需要匹配1000×1000次策略,并进行1000×1000次打包处理;如果采用按组打包,1000个对等体的出口策略相同(如数据中心组网中)时,只需要匹配1000×1次策略,并进行1000×1次打包处理,打包效率提高了1000倍。
如果没有指定任何参数,则显示指定地址族公网所有BGP打包组信息。
如果没有指定unicast、mdt、mvpn、sr-policy、multicast、rtfilter和flowspec参数,则缺省为unicast。
# 显示BGP IPv4单播地址族的所有打包组信息。
<Sysname> display bgp update-group ipv4
  Update-group ID: 0
  Type: EBGP link
  4-byte AS number: Supported
  Site-of-Origin: Not specified
  Minimum time between advertisements: 30 seconds
  OutQ: 0
  Members: 1
    99.1.1.1
# 显示VPN实例vpn1的BGP VPNv4对等体1.1.1.2所在打包组的信息。
<Sysname> display bgp update-group vpnv4 vpn-instance vpn1 1.1.1.2
  Update-group ID: 0
  Type: EBGP link
  Nesting VPN: vpn1
  OutQ: 0
  Members: 2
    1.1.1.2
    1.1.1.3
表1-45 display bgp update-group命令显示信息描述表
Update-group ID
打包组ID
打包组中对等体的BGP连接类型,取值包括:
·     IBGP link:IBGP连接
·     EBGP link:EBGP连接
·     Confed IBGP link:联盟IBGP连接
·     Confed EBGP link:联盟EBGP连接
Label capability: Supported
打包组中的对等体具有交换带标签路由的能力
没有为打包组中的对等体使能4字节AS号抑制功能,即打包组中的对等体支持4字节AS号
4-byte AS number: Suppressed
Fake AS
为打包组中的对等体配置了虚拟的本地自治系统号number
Public-AS-Only: Yes
向打包组中的对等体发送BGP更新消息时只携带公有AS号,不携带私有AS号
取值为Yes时,如果对等体的AS号为私有AS号,则AS号作为打包组的分组条件;如果对等体的AS号为公有AS号,则AS号不作为打包组的分组条件
取值为No时,对等体的AS号不作为打包组的分组条件
Substitute-AS: Yes
用本地AS号替换AS_PATH属性里打包组中对等体的AS号
Site-of-Origin
为打包组中的对等体指定的SoO属性值
Minimum time between advertisements: number seconds
向打包组中对等体发布同一路由的最小时间间隔,单位为秒
Advertising community: Yes
向打包组中的对等体发布团体属性
Route-reflect client: Yes
打包组中的对等体是路由反射器的客户机
Advertising extended community: Yes
向打包组中的对等体发布扩展团体属性
Export AS-path-ACL
为打包组中的对等体设置了基于AS路径过滤列表的BGP路由出方向过滤策略
Export prefix list
为打包组中的对等体设置了基于地址前缀列表的BGP路由出方向过滤策略
Export route policy
对发布给打包组中对等体的路由应用了路由策略
Export filter-policy
为打包组中的对等体设置了基于ACL的BGP路由出发向过滤策略
OutQ
等待发往打包组中对等体的前缀数目
Members
打包组中对等体的数目及对等体的地址
Nesting VPN
打包组中的对等体使能了嵌套VPN功能
Nexthop invariable: Yes
向打包组中的对等体发布路由时不改变下一跳
UPE: Yes
打包组中的对等体为UPE
UPE export route policy
为打包组中的UPE对等体应用了出方向路由策略
1.1.44  domain-distinguisher
domain-distinguisher命令用来配置BGP LS信息的AS号和Router ID。
undo domain-distinguisher命令用来恢复缺省情况。
domain-distinguisher as-number:router-id
使用本BGP进程的AS号和Router ID。
BGP LS地址族视图
context-admin
as-number:router-id:LS信息的AS号和Router ID。as-number为AS号,取值范围为1~4294967295;router-id用IP地址的形式标识。
非缺省vSystem不支持本命令。
# 配置BGP LS信息的AS号为65009,Router ID为1.1.1.1。
[Sysname] bgp 100
[Sysname-bgp-default] address-family link-state
[Sysname-bgp-default-ls] domain-distinguisher 65009:1.1.1.1
1.1.45  ebgp-interface-sensitive
ebgp-interface-sensitive命令用来使能直连EBGP会话快速复位功能。
undo ebgp-interface-sensitive命令用来关闭直连EBGP会话快速复位功能。
直连EBGP会话快速复位功能处于使能状态。
BGP实例视图
context-admin
非缺省vSystem不支持本命令。
如果使能了本功能,则连接直连EBGP对等体的链路down后,本地路由器会立即断开与EBGP对等体的会话,并重新与该对等体建立EBGP会话。从而,实现快速发现链路故障,快速重建会话。
如果没有使能本功能,则连接直连EBGP对等体的链路down后,本地路由器不会立即断开与EBGP对等体的会话,而是等待会话保持时间(Holdtime)超时后,才断开该会话。没有使能本功能时,链路震荡不会影响EBGP会话的状态。
仅直连EBGP会话支持本功能。
# 使能直连EBGP会话快速复位功能。
[Sysname] bgp 100
[Sysname-bgp-default] ebgp-interface-sensitive
1.1.46  fast-reroute route-policy
fast-reroute route-policy命令用来在当前BGP地址族视图下指定快速重路由引用的路由策略。
undo fast-reroute route-policy命令用来恢复缺省情况。
BGP快速重路由未引用任何路由策略。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
context-admin
vsys-admin
route-policy-name:路由策略名称,为1~63个字符的字符串,区分大小写。
非缺省vSystem仅支持在BGP-VPN IPv4单播地址族视图和BGP-VPN IPv6单播地址族视图下配置本命令。
开启BGP快速重路由功能的方法有如下两种:
·     在BGP地址族视图下执行pic命令开启当前地址族的BGP快速重路由功能。采用这种方法时,BGP会为当前地址族的所有BGP路由自动计算备份下一跳,即只要从不同BGP对等体学习到了到达同一目的网络的路由,且这些路由不等价,就会生成主备两条路由。
·     在BGP地址族视图下执行fast-reroute route-policy命令指定快速重路由引用的路由策略,并在引用的路由策略中,通过apply [ ipv6 ] fast-reroute backup-nexthop命令指定备份下一跳的地址。采用这种方式时,只有为主路由计算出的备份下一跳地址与指定的地址相同时,才会为其生成备份下一跳;否则,不会为主路由生成备份下一跳。在引用的路由策略中,还可以配置if-match子句,用来决定哪些路由可以进行快速重路由保护,BGP只会为通过if-match子句过滤的路由生成备份下一跳。
引用路由策略方式的优先级高于通过pic命令开启BGP快速重路由方式。
# 在BGP IPv4单播地址族下,指定BGP快速重路由引用的路由策略为frr-policy。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4
[Sysname-bgp-default-ipv4] fast-reroute route-policy frr-policy
·     apply fast-reroute(三层技术-IP路由命令参考/路由策略)
·     apply ipv6 fast-reroute(三层技术-IP路由命令参考/路由策略)
·     pic
·     route-policy(三层技术-IP路由命令参考/路由策略)
1.1.47  filter-policy export
filter-policy export命令用来配置对发布的路由信息进行过滤。
undo filter-policy export命令用来取消对发布的路由信息进行过滤。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP VPNv4地址族视图/BGP IPv4组播地址族视图:
filter-policy { ipv4-acl-number | prefix-list ipv4-prefix-list-name } export [ direct | { isis | ospf | rip } process-id | static ]
undo filter-policy export [ direct | { isis | ospf | rip } process-id | static ]
BGP IPv6单播地址族视图/BGP-VPN IPv6单播地址族视图/BGP VPNv6地址族视图/BGP IPv6组播地址族视图:
filter-policy { ipv6-acl-number | prefix-list ipv6-prefix-list-name } export [ direct | { isisv6 | ospfv3 | ripng } process-id | static ]
undo filter-policy export [ direct | { isisv6 | ospfv3 | ripng } process-id | static ]
不对发布的路由信息进行过滤。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
ipv4-acl-number:指定用于匹配路由信息目的网络地址的访问列表号,取值范围为2000~3999。
ipv6-acl-number:指定用于匹配路由信息目的网络地址的IPv6 ACL编号,取值范围为2000~3999。
prefix-list ipv4-prefix-list-name:指定用于匹配路由信息目的网络地址的IPv4地址前缀列表。ipv4-prefix-list-name表示IPv4地址前缀列表名称,为1~63个字符的字符串,区分大小写。
prefix-list ipv6-prefix-list-name:指定用于匹配路由信息目的网络地址的IPv6地址前缀列表。ipv6-prefix-list-name表示IPv6地址前缀列表名称,为1~63个字符的字符串,区分大小写。
direct:对引入的直连路由进行过滤。
isis:对从ISIS协议引入的路由进行过滤。
isisv6:对从IPv6 ISIS协议引入的路由进行过滤。
ospf:对从OSPF协议引入的路由进行过滤。
ospfv3:对从OSPFv3协议引入的路由进行过滤。
rip:对从RIP协议引入的路由进行过滤。
ripng:对从RIPng路由协议引入的路由进行过滤。
static:对引入的静态路由进行过滤。
process-id:路由协议的进程号,取值范围为1~65535。
如果指定了路由协议参数(direct、isis等),则只对从这种协议引入到BGP的路由进行过滤,其他BGP路由不受影响。如果没有指定路由协议参数,则对所有BGP路由都进行过滤,包括从IGP引入的路由、使用network命令发布的路由、从BGP对等体学习的路由等。
通过基本ACL(2000~2999)对发布的路由信息进行过滤时,如果配置了rule [ rule-id ] { deny | permit } source source-address source-wildcard命令,则只要路由的目的网络地址与rule命令中的source-address source-wildcard匹配,则该路由与rule命令配置的规则匹配,不会再比较路由的目的网络地址掩码。
通过高级ACL(3000~3999)对发布的路由信息进行过滤时:
·     rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard命令配置的规则用来过滤指定目的网络地址的路由;
·     rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard命令配置的规则用来过滤指定目的网络地址和掩码的路由。其中source sour-addr sour-wildcard用来过滤路由目的网络地址,destination dest-addr dest-wildcard用来过滤路由掩码。destination dest-addr dest-wildcard指定的掩码应该是连续的,如果指定的掩码不连续,则该过滤掩码的条件不生效。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示所有BGP路由都可以通过本命令的过滤。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则会拒绝所有BGP路由通过过滤。
# 在BGP IPv4单播地址族视图下,使用编号为2000的IPv4基本ACL对BGP发布的所有路由进行过滤。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] filter-policy 2000 export
·     filter-policy import
·     peer as-path-acl
·     peer filter-policy
·     peer prefix-list
·     peer route-policy
1.1.48  filter-policy import
filter-policy import命令用来配置对接收的路由信息进行过滤。
filter-policy { ipv4-acl-number | prefix-list ipv4-prefix-list-name } import
filter-policy { ipv6-acl-number | prefix-list ipv6-prefix-list-name } import
不对接收的路由信息进行过滤。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
ipv6-acl-number:指定用于匹配路由信息目的网络地址的IPv6访问列表号,取值范围为2000~3999。
通过基本ACL(2000~2999)对接收的路由信息进行过滤时,如果配置了rule [ rule-id ] { deny | permit } source source-address source-wildcard命令,则只要路由的目的网络地址与rule命令中的source-address source-wildcard匹配,则该路由与rule命令配置的规则匹配,不会再比较路由的目的网络地址掩码。
通过高级ACL(3000~3999)对接收的路由信息进行过滤时:
引用ACL时,需要注意的是:
# 在BGP IPv4单播地址族视图下,使用编号为2000的IPv4基本ACL对BGP接收的路由进行过滤。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] filter-policy 2000 import
·     filter-policy export
·     peer as-path-acl
·     peer prefix-list
·     peer route-policy
1.1.49  flush suboptimal-route
flush suboptimal-route命令用来开启BGP次优路由下刷RIB功能。
undo flush suboptimal-route命令用来关闭BGP次优路由下刷RIB功能。
BGP次优路由下刷RIB功能处于关闭状态,即只有BGP最优路由可以下刷到RIB。
BGP实例视图
context-admin
非缺省vSystem不支持本命令。
开启BGP次优路由下刷RIB功能后,当BGP路由表中最优路由为通过network命令生成或import-route命令引入的路由,次优路由为从BGP对等体收到的路由时,次优路由会下刷到RIB表项中。在某些组网情况下,执行本命令下刷到达同一目的网络次优路由到RIB后,当最优路由发生故障时,系统可以快速切换到次优路由。例如,设备有一条到达1.1.1.0/24网络的静态路由,其优先级高于BGP路由,BGP本地引入该静态路由同时从对等体收到到达该网段的路由,执行本命令BGP将从对等体收到的路由作为次优路由下刷到RIB,这时如果开启协议间的FRR功能,当静态路由发生故障时,本地引入的静态路由不可达,系统可以快速切换到BGP次优路由,从而大大缩短了流量中断时间。
协议间的FRR功能的详细介绍,请参见“三层技术-IP路由配置指导”中的“IP路由基础”。
# 开启次优路由下刷RIB功能。
[Sysname] bgp 100
[Sysname-bgp-default] flush suboptimal-route
1.1.50  graceful-restart
graceful-restart命令用来使能BGP协议的GR能力。
undo graceful-restart命令用来关闭BGP协议的GR能力。
graceful-restart
BGP协议的GR能力处于关闭状态。
BGP实例视图
context-admin
非缺省vSystem不支持本命令。
BGP GR(Graceful Restart,平滑重启)是一种在主备倒换或BGP协议重启时保证转发业务不中断的机制。
BGP对等体之间通过Open消息交互GR能力。只有双方都具有GR能力时,建立起的BGP会话才具备GR能力。
执行本命令后,设备会重新建立BGP会话。
# 使能GR能力。
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart
·     graceful-restart timer purge-time
·     graceful-restart timer restart
·     graceful-restart timer wait-for-rib
1.1.51  graceful-restart timer purge-time
graceful-restart timer purge-time命令用来配置BGP GR过程中等待通知RIB(Routing Information Base,路由信息库)老化失效表项的时间。
undo graceful-restart timer purge-time命令用来恢复缺省情况。
BGP GR过程中等待通知RIB老化失效表项的时间为480秒。
BGP实例视图
context-admin
timer:BGP GR过程中等待通知RIB老化失效表项的时间,取值范围为1~6000,单位为秒。
非缺省vSystem不支持本命令。
GR Restarter发生主备倒换或BGP协议重启时,会启动RIB路由老化定时器,该定时器的值由本命令来配置。如果在RIB路由老化定时器超时时没有完成BGP路由信息的交互,则GR Restarter会强制退出GR过程,根据已经学习到的BGP路由信息更新RIB表项,删除老化的RIB表项。
在配置本命令之前,必须先使能BGP协议的GR能力。
BGP路由数量较多时,如果本命令配置的值过小,在RIB路由老化定时器超时前GR Restarter和GR Helper无法完成路由交互,则可能会导致流量中断。请根据实际情况,合理调整RIB路由老化定时器的值。
本命令配置的值建议大于graceful-restart timer wait-for-rib命令配置的值,小于protocol lifetime命令配置的值。
# 配置BGP GR过程中等待通知RIB老化失效表项的时间为300秒。
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart timer purge-time 300
·     graceful-restart
·     protocol lifetime(三层技术-IP路由命令参考/IP路由基础)
1.1.52  graceful-restart timer restart
graceful-restart timer restart命令用来配置对端等待重建BGP会话的时间。
undo graceful-restart timer restart命令用来恢复缺省情况。
对端等待重建BGP会话的时间为150秒。
BGP实例视图
context-admin
timer:对端等待重建BGP会话的最大时间,取值范围为3~600,单位为秒。
非缺省vSystem不支持本命令。
GR Restarter通过Open消息将本端配置的对端等待重建BGP会话的最大时间通告给GR Helper。GR Helper发现GR Restarter进行主备倒换或BGP协议重启后,保留从该GR Restarter学习到的路由,并对这些路由进行失效标记。GR Helper等待GR Restarter与其重建BGP会话。如果在GR Restarter通告的时间内,没有重建BGP会话,则删除标记为失效的路由。
执行本命令后,配置的时间不会立即生效,只有重建BGP会话后才会生效。
# 配置对端等待重建BGP会话的最大时间为300秒。
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart timer restart 300
·     graceful-restart
1.1.53  graceful-restart timer wait-for-rib
graceful-restart timer wait-for-rib命令用来配置本端等待End-Of-RIB标记的时间。
undo graceful-restart timer wait-for-rib命令用来恢复缺省情况。
本端等待End-Of-RIB标记的时间为180秒。
BGP实例视图
context-admin
timer:本端等待End-Of-RIB标记的时间,取值范围为3~3600,单位为秒。
非缺省vSystem不支持本命令。
本端配置的等待End-Of-RIB标记的时间不会通告给对端,只用来控制本端路由信息交互的时间,即GR Restarter上配置的时间只用来控制GR Restarter从GR Helper接收路由更新的时间,GR Helper上配置的时间只用来控制GR Helper从GR Restarter接收路由更新的时间。
GR Restarter主备倒换或BGP协议重启完成,并与GR Helper重新建立BGP会话后,GR Restarter和GR Helper应在本命令指定的时间内收到End-Of-RIB标记,即在本命令指定的时间内完成路由信息的交互。当路由信息的数量较多时,建议将本端等待End-Of-RIB标记的时间调大,以保证完成所有路由信息的交互。
通过本命令可以控制路由收敛的速度。本命令配置的值越小,路由收敛速度越快,但可能会导致接收的路由信息不完整。
# 配置本端等待End-Of-RIB标记的时间为100秒。
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart timer wait-for-rib 100
·     graceful-restart
1.1.54  group
group命令用来创建一个对等体组。
undo group命令用来删除指定的对等体组。
group group-name [ external | internal ]
undo group group-name
不存在对等体组。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
group-name:对等体组的名称,为1~47个字符的字符串,区分大小写。
external:创建EBGP对等体组。
internal:创建IBGP对等体组。
非缺省vSystem仅支持在BGP-VPN实例视图下配置本命令。
在大规模BGP网络中,对等体的数量很多,其中很多对等体具有相同的策略,在配置时会重复使用一些命令。此时,利用对等体组可以简化配置。
对等体组是具有某些相同属性的对等体的集合。当一个对等体加入对等体组中时,此对等体将获得与所在对等体组相同的配置。当对等体组的配置改变时,组内成员的配置也相应改变。
如果没有指定internal和external参数,则创建的是IBGP对等体组。
如果分别对对等体组和对等体组中的对等体进行了某项BGP配置,则以最后一次配置为准。
通过本命令创建对等体组后,还需要执行peer enable命令,本地路由器才具有与指定对等体组交换相应地址族路由信息的能力。
# 在BGP实例视图下,创建一个EBGP对等体组test,其AS号为200,并在test中添加EBGP对等体10.1.1.1和10.1.2.1。
[Sysname] bgp 100
[Sysname-bgp-default] group test external
[Sysname-bgp-default] peer test as-number 200
[Sysname-bgp-default] peer 10.1.1.1 group test
[Sysname-bgp-default] peer 10.1.2.1 group test
·     display bgp group
·     peer enable
1.1.55  ignore-first-as
ignore-first-as命令用来配置不检测EBGP路由的第一个AS号。
undo ignore-first-as命令用来恢复缺省情况。
ignore-first-as
从EBGP邻居学到路由后,会检测路由的第一个AS号。如果此AS号不是EBGP对等体的AS号,且不是私有AS号,则断开与该对等体的BGP会话。
BGP实例视图
context-admin
非缺省vSystem不支持本命令。
# 配置不检测EBGP路由的第一个AS号。
[Sysname] bgp 100
[Sysname-bgp-default] ignore-first-as
·     peer ignore-first-as
1.1.56  import-route
import-route命令用来将IGP路由协议的路由信息引入到BGP路由表中,以便通过BGP发布引入的路由信息。
undo import-route命令用来取消引入IGP路由协议的路由信息。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP IPv4组播地址族视图:
import-route { direct | guard | static } [ med med-value | route-policy route-policy-name ] *
undo import-route { direct | guard | { isis | ospf | rip } [ process-id | all-processes ] | static }
BGP IPv6单播地址族视图/BGP-VPN IPv6单播地址族视图/BGP IPv6组播地址族视图:
undo import-route { direct | guard | { isisv6 | ospfv3 | ripng } [ process-id | all-processes ] | static }
BGP不会引入IGP路由协议的路由信息。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
direct:引入直连路由。
guard:引入Guard路由。
isis:引入ISIS协议的路由。
isisv6:引入IPv6 ISIS协议的路由。
ospf:引入OSPF协议的路由。
ospfv3:引入OSPFv3协议的路由。
rip:引入RIP协议的路由。
ripng:引入RIPng协议的路由。
static:引入静态路由。
all-processes:引入指定路由协议所有进程的路由。
allow-direct:指定引入IGP路由协议的路由时,同时引入使能了该协议的接口网段路由。如果不指定本参数,则在引入协议路由时不会引入使能了该协议的接口网段路由。当allow-direct与route-policy route-policy-name参数一起使用时,需要注意路由策略中配置的匹配规则不要与接口路由信息存在冲突,否则会导致allow-direct配置失效。例如,当配置allow-direct参数引入OSPF路由时,在路由策略中不要配置if-match route-type匹配条件,否则,allow-direct参数失效。
med med-value:指定引入路由的MED度量值,取值范围为0~4294967295。如果没有指定MED度量值,则被引入路由的metric值将作为引入BGP之后路由的MED值。
route-policy route-policy-name:对引入的路由应用路由策略,以便过滤引入的路由或设置引入后路由的属性。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。
通过import-route命令引入指定IGP路由协议的路由时,不会引入该协议的缺省路由。只有同时执行default-route imported命令,才会引入该协议的缺省路由。
只能引入路由表中状态为active的路由。可以通过display ip routing-table protocol命令或display ipv6 routing-table protocol命令来查看路由的状态是否为active。
引入IS-IS、IPv6 ISIS、OSPF、OSPFv3、RIP或RIPng协议的路由时,如果没有指定任何参数,则引入process-id为1的IS-IS、IPv6 ISIS、OSPF、OSPFv3、RIP或RIPng协议的路由。
通过import-route命令引入到BGP路由表中的路由的ORIGIN属性为incomplete。
通过all-processes参数引入指定路由协议所有进程的路由后,对此协议的任意进程配置本命令均不生效。
# 在BGP IPv4单播地址族视图下,引入RIP进程1的路由,并指定引入后BGP路由的MED值为100。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] import-route rip 1 med 100
·     display ip routing-table protocol(三层技术-IP路由命令参考/IP路由基础)
·     display ipv6 routing-table protocol(三层技术-IP路由命令参考/IP路由基础)
·     import-route-append
1.1.57  import-route-append
import-route-append命令用来以附加的方式将IGP路由协议的路由信息引入到BGP路由表中,以便通过BGP发布引入的路由信息。
undo import-route-append命令用来取消以附加的方式引入IGP路由协议的路由信息。
import-route-append { isis | ospf | rip } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
import-route-append { direct | static } [ med med-value | route-policy route-policy-name ] *
undo import-route-append { direct | { isis | ospf | rip } [ process-id | all-processes ] | static }
import-route-append { isisv6 | ospfv3 | ripng } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
undo import-route-append { direct | { isisv6 | ospfv3 | ripng } [ process-id | all-processes ] | static }
BGP未以附加的方式引入IGP路由协议的路由信息。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
direct:引入直连路由。
isis:引入ISIS协议的路由。
ospf:引入OSPF协议的路由。
rip:引入RIP协议的路由。
ripng:引入RIPng协议的路由。
static:引入静态路由。
本命令与import-route命令在分别单独配置时功能完全一致,同时配置时本命令可以在不覆盖现有import-route命令配置的情况下附加引入IGP路由。
针对同一协议进程同时配置本命令与import-route命令时:
·     通过任意一条命令中路由策略过滤的路由将被引入到BGP路由表中,若引入的路由同时通过了两条命令中路由策略的过滤,则在被引入到BGP路由表中时,两条命令指定的路由策略包含的Apply子句在不冲突的情况下同时生效,否则仅import-route-append命令指定的路由策略中的Apply子句生效。
·     如果均指定了引入路由的MED度量值,以import-route-append命令的配置为准。
# 在BGP IPv4单播地址族视图下,附加引入ISIS进程1中通过路由策略policy1过滤的路由。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] import-route isis 1
[Sysname-bgp-default-ipv4] import-route-append isis 1 route-policy policy1
·     import-route
1.1.58  ip vpn-instance (BGP instance view)
ip vpn-instance命令用来创建BGP-VPN实例,并进入BGP-VPN实例视图。如果指定的BGP-VPN实例已经存在,则直接进入BGP-VPN实例视图。
undo ip vpn-instance命令用来删除BGP-VPN实例,及该视图下的所有配置。
不存在BGP-VPN实例。
BGP实例视图
context-admin
vsys-admin
vpn-instance-name:VPN实例名称,为1~31个字符的字符串,区分大小写。
在BGP-VPN实例视图下配置BGP对等体后,从该对等体学习到的BGP路由将被添加到指定VPN实例的路由表中。
在执行本命令前,必须通过系统视图下的ip vpn-instance命令创建VPN实例,并通过route-distinguisher命令配置该VPN实例的路由标识符。
# 为VPN实例vpn1创建BGP-VPN实例,并进入BGP-VPN实例视图。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1]
·     ip vpn-instance (system-view)
·     route-distinguisher(MPLS命令参考/MPLS L3VPN)
1.1.59  isolate enable
isolate enable命令用来把设备的BGP协议从当前组网中隔离出来。
undo isolate enable命令用来恢复缺省情况。
isolate enable
undo isolate enable
未配置BGP协议隔离功能。
BGP实例视图
context-admin
BGP isolate功能使得网络管理员在进行网络设备维护时,无需删除并重新进行对等体/对等体组相关配置,减少了网络维护的工作量,并减少了对当前网络中通过该设备发布的BGP路由指导转发的流量产生的影响。完成设备维护后,网络管理员可以关闭BGP isolate功能,以使该设备重新投入使用。
BGP isolate的具体工作机制如下:
(1)     开启BGP isolate功能的设备撤销发布给邻居的BGP路由(本设备直连路由除外),同时保留所有从邻居学习到的BGP路由。
(2)     远端邻居收到路由撤销消息后,重新进行路由优选并更新FIB表。在此期间,远端邻居仍然可以通过BGP isolate设备发布的BGP路由转发流量。
(3)     远端邻居删除所有BGP isolate设备发布的BGP路由并完成FIB表项更新后,除目的地为BGP isolate设备的流量外,其他流量不再经过BGP isolate设备。此时,BGP isolate设备完全从当前组网中隔离出来,可以对该设备上的BGP协议进行升级等处理。
(4)     对BGP isolate设备的维护结束后,关闭BGP isolate功能可让该设备重新加入网络。设备重新加入网络后,BGP路由的发布和学习机制如下:
¡     设备重新向邻居发布路由。
¡     设备隔离前保留了从邻居学习到的路由。如果设备隔离后没有对BGP协议进行重启等操作,则无需重新进行路由学习;否则,设备重新加入网络后需要重新进行路由学习。
设备进行GR或NSR期间,建议用户不要使用BGP isolate功能,否则无法保证执行操作后的结果与预期结果一致。
# 在BGP实例视图下,配置BGP isolate功能,把设备的BGP协议从当前网络中隔离出来。
[Sysname] bgp 100
[Sysname-bgp-default] isolate enable
1.1.60  label-allocation-mode
label-allocation-mode命令用来配置标签申请方式。
undo label-allocation-mode命令用来恢复缺省情况。
label-allocation-mode { per-prefix | per-vrf }
BGP按照每个下一跳分配一个标签的方式申请标签。
BGP实例视图
context-admin
per-prefix:为每条路由申请一个标签。
per-vrf:为每个VPN实例分配一个标签。
改变标签分配方式将重新下刷所有BGP路由,会导致业务的短暂中断,请慎重使用。
非缺省vSystem不支持本命令。
BGP为私网路由申请标签的方式有三种:
·     为每条路由申请一个标签:采用这种方式时,路由条目和标签一一对应;
·     为每个下一跳申请一个标签:当按照每条路由申请标签方式需要申请的标签数量大于设备支持的最大标签数目时,通过采用此方式,可以减少申请的标签数量;
·     为每个VPN实例申请一个标签:当存在大量需要申请标签的路由,并且采用下一跳申请标签的方式申请的标签数量仍然超过设备支持的最大标签数目时,可以采用此方式。
为每条路由或者每个下一跳申请标签方式可以与vpn popgo命令配合使用,可以实现报文根据标签查找出接口转发报文;为每个VPN实例申请标签方式与vpn popgo命令互斥,采用该方式时,只能根据标签查找FIB转发报文。
# 配置按照每条路由分配一个标签的方式申请标签。
[Sysname] bgp 100
[Sysname-bgp-default] label-allocation-mode per-prefix
·     vpn popgo(MPLS命令参考/MPLS L3VPN)
1.1.61  log-peer-change
log-peer-change命令用来全局使能BGP日志记录功能。
undo log-peer-change命令用来全局关闭BGP日志记录功能。
log-peer-change
全局BGP日志记录功能处于开启状态。
BGP实例视图
context-admin
非缺省vSystem不支持本命令。
通过log-peer-change命令全局使能BGP日志记录功能,并执行peer log-change命令使能与指定对等体/对等体组之间BGP会话的日志记录功能后,与该对等体/对等体组之间BGP会话建立以及断开时会生成日志信息,通过display bgp peer ipv4 unicast log-info命令或display bgp peer ipv6 unicast log-info命令可以查看记录的日志信息。生成的日志信息还将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。(有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。)
如果全局关闭BGP日志记录功能,或关闭与指定对等体/对等体组之间BGP会话的日志记录功能,则BGP会话建立或断开时不会生成日志信息。
# 全局使能BGP日志记录功能。
[Sysname] bgp 100
[Sysname-bgp-default] log-peer-change
·     display bgp peer
·     peer log-change
1.1.62  network
network命令用来配置BGP发布的本地网段路由,即将本地路由表中指定网段的路由添加到BGP路由表中,并发布给对等体。
undo network命令用来删除指定的BGP发布的本地网段路由。
undo network ipv4-address [ mask-length | mask ]
undo network ipv6-address prefix-length
BGP不发布本地的网段路由。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
ipv4-address:目的网络的IPv4地址。如果没有指定mask和mask-length参数,则采用自然掩码。
mask:网络掩码,点分十进制格式。
ipv6-address:目的网络的IPv6地址。
prefix-length:目的网络地址的前缀长度,取值范围为0~128。
route-policy route-policy-name:为指定网段的路由应用路由策略,通过路由策略设置路由属性或过滤路由。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。
network命令指定的网段路由必须存在于本地的IP路由表中,且处于Active状态,否则无法将该网段路由添加到BGP路由表中。
使用network命令添加到BGP路由表中的网段路由的ORIGIN属性为IGP。
执行undo network命令时指定的掩码、掩码长度或前缀长度必须与执行network命令时指定的掩码、掩码长度或前缀长度相同,否则无法删除配置。
# 在BGP IPv4单播地址族视图下,将本地路由表中到达10.0.0.0/16网段的路由添加到BGP路由表中。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] network 10.0.0.0 255.255.0.0
1.1.63  network short-cut
network short-cut命令用来提高接收到的指定EBGP路由的路由优先级,该EBGP路由称为Short-cut路由。
undo network short-cut命令用来取消该配置。
undo network ipv4-address [ mask-length | mask ] short-cut
undo network ipv6-address prefix-length short-cut
接收到的EBGP路由的路由优先级为255。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
mask:网络掩码,点分十进制格式。
缺省情况下,EBGP路由的优先级低于本地产生的BGP路由的优先级。设备上存在到达某一目的网络的EBGP路由和本地产生的BGP路由时,不会选择EBGP路由。通过执行network shortcut命令,可以使得指定EBGP路由的优先级与本地产生的BGP路由的优先级相同,从而提高该EBGP路由成为最佳路由的可能性。
用户可以通过preference命令修改EBGP路由和本地产生的BGP路由的优先级。
# 在BGP IPv4单播地址族视图下,配置提高EBGP路由10.0.0.0/16的路由优先级。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] network 10.0.0.0 255.255.0.0 short-cut
·     preference
1.1.64  non-stop-routing
non-stop-routing命令用来开启BGP NSR功能。
undo non-stop-routing命令用来关闭BGP NSR功能。
non-stop-routing
BGP NSR功能处于关闭状态。
BGP实例视图
context-admin
非缺省vSystem不支持本命令。
BGP NSR(Nonstop Routing,不间断路由)是一种通过在BGP协议主备进程之间备份必要的协议状态和数据(如BGP邻居信息和路由信息),使得BGP协议的主进程中断时,备份进程能够无缝地接管主进程的工作,从而确保对等体感知不到BGP协议中断,保持BGP路由,并保证转发不会中断的技术。
# 开启BGP NSR功能。
[Sysname] bgp 100
[Sysname-bgp-default] non-stop-routing
·     display bgp non-stop-routing status
1.1.65  peer additional-paths
peer additional-paths命令用来配置Add-Path功能。
undo peer additional-paths命令用来取消该配置。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP-VPN VPNv4地址族视图:
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
undo peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
BGP-VPN IPv6单播地址族视图:
peer { group-name | ipv6-address [ prefix-length ] } additional-paths { receive | send } *
undo peer { group-name | ipv6-address [ prefix-length ] } additional-paths { receive | send } *
BGP VPNv4地址族视图/BGP IPv6单播地址族视图/BGP VPNv6地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } additional-paths { receive | send } *
未配置Add-Path功能。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP-VPN VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
context-admin
ipv4-address:对等体的IPv4地址。指定的对等体必须已经创建。
ipv6-address:对等体的IPv6地址。指定的对等体必须已经创建。
prefix-length:前缀长度,取值范围为0~128。如果指定本参数,则表示指定网段内的动态对等体。
receive:接收能力。
send:发送能力。
Add-Path能力包括接收和发送两种。为了让对等体间的Add-Path能力协商成功,必须一端使能接收能力,另一端使能发送能力。
# 在BGP IPv4单播地址族视图下,使能与对等体1.1.1.1的Add-Path接收能力。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 additional-paths receive
1.1.66  peer advertise additional-paths best
peer advertise additional-paths best命令用来配置向指定对等体/对等体组发送的Add-Path优选路由的最大条数。
undo peer advertise additional-paths best命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
undo peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best
peer { group-name | ipv6-address [ prefix-length ] } advertise additional-paths best number
undo peer { group-name | ipv6-address [ prefix-length ] } advertise additional-paths best
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise additional-paths best
向指定对等体/对等体组发送的Add-Path优选路由的最大条数为1。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP-VPN VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
context-admin
number:发送Add-Path优选路由的数量,取值范围为2~64。
当发送的Add-Path优选路由的条数大于本地实际优选的路由条数时,以本地实际优选的路由条数为准。
# 在BGP IPv4单播地址族视图下,配置向对等体1.1.1.1发送Add-Path优选路由的最大条数为3。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise additional-paths best 3
·     additional-paths select-best
·     peer additional-paths
1.1.67  peer advertise-community
peer advertise-community命令用来配置向对等体/对等体组发布团体属性。
undo peer advertise-community命令用来取消向对等体/对等体组发布团体属性。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP IPv4组播地址族视图/BGP IPv4 MVPN地址族视图/BGP IPv4 SR Policy地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] } advertise-community
BGP IPv6单播地址族视图/BGP VPNv4地址族视图/BGP VPNv6地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-community
BGP IPv6组播地址族视图/BGP-VPN IPv6单播地址族视图/BGP IPv6 SR Policy地址族视图:
peer { group-name | ipv6-address [ prefix-length ] } advertise-community
undo peer { group-name | ipv6-address [ prefix-length ] } advertise-community
不向对等体/对等体组发布团体属性。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
BGP IPv4 MVPN地址族视图
context-admin
vsys-admin
团体属性是跟随路由一起发送出去的一组特殊数据。根据需要,一条路由可以携带一个或多个团体属性值(每个团体属性值用一个四字节的整数表示)。接收到该路由的路由器就可以根据团体属性值对路由作出适当的处理(比如决定是否发布该路由、在什么范围发布等),从而能够简化路由策略的应用和降低维护管理的难度。
执行peer advertise-community命令后,本地路由器向对等体/对等体组发布的路由中将可以携带团体属性;执行undo peer advertise-community命令后,如果接收到的路由中携带团体属性,则本地路由器删除该团体属性后,再将路由发布给对等体/对等体组。
# 在BGP IPv4单播地址族视图下,配置允许向对等体组test发布团体属性。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test advertise-community
·     apply community(三层技术-IP路由命令参考/路由策略)
·     if-match community(三层技术-IP路由命令参考/路由策略)
1.1.68  peer advertise-ext-community
peer advertise-ext-community命令用来配置向对等体/对等体组发布扩展团体属性。
undo peer advertise-ext-community命令用来取消向对等体/对等体组发布扩展团体属性。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP IPv4组播地址族视图/BGP IPv4 SR Policy地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] } advertise-ext-community
BGP IPv6单播地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-ext-community
BGP IPv6组播地址族视图/BGP IPv6 SR Policy地址族视图:
peer { group-name | ipv6-address [ prefix-length ] } advertise-ext-community
undo peer { group-name | ipv6-address [ prefix-length ] } advertise-ext-community
不向对等体/对等体组发布扩展团体属性。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
非缺省vSystem仅支持在BGP-VPN IPv4单播地址族视图下配置本命令。
·     扩展团体属性为八字节,提供了更多的属性值。
·     扩展团体属性可以划分类型。在不同的组网应用中,可以使用不同类型的扩展团体属性对路由进行过滤和控制。与不区分类型、统一使用同一个属性值空间的团体属性相比,扩展团体属性的配置和管理更为简单。
执行peer advertise-ext-community命令后,本地路由器向对等体/对等体组发布的路由中将可以携带扩展团体属性;执行undo peer advertise-ext-community命令后,如果接收到的路由中携带扩展团体属性,则本地路由器删除该扩展团体属性后,再将路由发布给对等体/对等体组。
# 在BGP IPv4单播地址族视图下,配置允许向对等体组test发布扩展团体属性。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test advertise-ext-community
·     apply extcommunity(三层技术-IP路由命令参考/路由策略)
·     if-match extcommunity(三层技术-IP路由命令参考/路由策略)
·     ip extcommunity-list(三层技术-IP路由命令参考/路由策略)
1.1.69  peer advertise-policy exist-policy
peer advertise-policy exist-policy命令用来配置通过存在策略对BGP发布路由进行控制。
undo peer advertise-policy exist-policy命令用来取消该配置。
BGP IPv4单播地址族视图:
peer { group-name | ipv4-address [ mask-length ] } advertise-policy advertise-policy-name exist-policy exist-policy-name
undo peer { group-name | ipv4-address [ mask-length ] } advertise-policy exist-policy
BGP IPv6单播地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-policy exist-policy
不对发布的BGP路由进行控制。
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
context-admin
advertise-policy-name:指定路由发送策略的名称,为1~63个字符的字符串,区分大小写。
exist-policy exist-policy-name:指定路由发送策略所关联的存在策略的名称,为1~63个字符的字符串,区分大小写。
非缺省vSystem不支持本命令。
如果执行了本配置,则只有BGP路由表中存在与exist-policy策略匹配的前缀时,设备才会发布通过advertise-policy策略的路由;否则,不允许发布这些路由。
未通过advertise-policy策略的路由不受exist-policy策略的控制。
# 在BGP IPv4单播地址族视图下,配置通过存在策略对发布给对等体1.1.1.1的路由进行控制:当BGP路由表中存在与路由策略ex-policy匹配的前缀时,设备会将所有通过adv-policy策略的路由发布给该BGP对等体;否则,不允许发布这些路由。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise-policy adv-policy exist-policy ex-policy
·     peer as-path-acl
·     peer prefix-list
·     peer route-policy
·     peer advertise-policy non-exist-policy
1.1.70  peer advertise-policy non-exist-policy
peer advertise-policy non-exist-policy命令用来配置通过不存在策略对BGP发布路由进行控制。
undo peer advertise-policy non-exist-policy命令用来取消该配置。
BGP IPv4单播地址族视图:
peer { group-name | ipv4-address [ mask-length ] } advertise-policy advertise-policy-name non-exist-policy non-exist-policy-name
undo peer { group-name | ipv4-address [ mask-length ] } advertise-policy non-exist-policy
BGP IPv6单播地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-policy non-exist-policy
不对发布的BGP路由进行控制。
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
context-admin
non-exist-policy non-exist-policy-name:指定路由发送策略所关联的不存在策略的名称,为1~63个字符的字符串,区分大小写。
非缺省vSystem不支持本命令。
如果配置了non-exist-policy策略,则当BGP路由表中存在与non-exist-policy策略匹配的前缀时,设备不会发布所有通过advertise-policy策略的路由;否则,设备会发布这些路由。
未通过advertise-policy策略的路由不受non-exist-policy策略的控制。
# 在BGP IPv4单播地址族视图下,配置通过不存在策略对发布给对等体1.1.1.1的路由进行控制:当BGP路由表中存在与路由策略n-ex-policy匹配的前缀时,设备不会将通过adv-policy策略的路由发布给该BGP对等体;否则,允许发布这些路由。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise-policy adv-policy non-exist-policy n-ex-policy
·     peer as-path-acl
·     peer prefix-list
·     peer route-policy
·     peer advertise-policy exist-policy
1.1.71  peer allow-as-loop
peer allow-as-loop命令用来配置对于从对等体/对等体组接收的路由,允许本地AS号在接收路由的AS_PATH属性中出现,并配置允许出现的次数。
undo peer allow-as-loop命令用来取消该配置。
undo peer { group-name | ipv4-address [ mask-length ] } allow-as-loop
BGP IPv6单播地址族视图/BGP VPNv4地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } allow-as-loop
BGP-VPN IPv6单播地址族视图/BGP IPv6组播地址族视图/BGP IPv6 SR Policy地址族视图:
peer { group-name | ipv6-address [ prefix-length ] } allow-as-loop [ number ]
undo peer { group-name | ipv6-address [ prefix-length ] } allow-as-loop
不允许本地AS号在接收路由的AS_PATH属性中出现。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
number:允许本地AS号出现的次数,取值范围为1~10,缺省值为1。如果本地AS号出现的次数大于此值,则认为出现环路,丢弃该路由。
缺省情况下,BGP不会接受AS_PATH属性中已包含本地AS号的路由,以避免形成路由环路。但是,在某些特殊的组网环境下(如MPLS L3VPN的Hub&Spoke组网),需要允许本地AS号在接收路由的AS_PATH属性中出现,否则无法正确发布路由。
# 在BGP IPv4单播地址族视图下,配置从对等体组test接收路由时,允许本地AS号在接收路由的AS_PATH属性中出现,允许出现次数为2次。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test allow-as-loop 2
1.1.72  peer as-number (for a BGP peer group)
peer as-number命令用来指定对等体组的AS号。
undo peer as-number命令用来删除指定对等体组的AS号。
undo peer group-name as-number
未指定对等体组的AS号。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
as-number:对等体组的AS号,取值范围为1~4294967295。
只有当对等体组中不包含对等体时,才允许为对等体组配置AS号。
为对等体组配置AS号后,需要加入该对等体组的对等体的AS号必须与对等体组的AS号相同。
如果没有指定对等体组的AS号,则加入该对等体组的对等体保留自己的AS号,即对等体组中对等体的AS号可以相同,也可以不同。
# 在BGP实例视图下,指定对等体组test的AS号为100。
[Sysname] bgp 100
[Sysname-bgp-default] peer test as-number 100
·     peer group
1.1.73  peer as-number (for a BGP peer)
peer as-number命令用来创建BGP对等体,并指定对等体的AS号。
undo peer命令用来删除指定的BGP对等体。
peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-number as-number
undo peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] }
不存在BGP对等体。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
as-number:对等体的AS号,取值范围为1~4294967295。如果对等体的AS号与本地路由器的AS号相同,则该对等体为IBGP对等体;如果对等体的AS号与本地路由器的AS号不同,则该对等体为EBGP对等体。
除了本命令外,还可以通过peer group命令创建对等体。执行peer group命令创建对等体的同时,还可以将对等体加入对等体组。
不能通过重复执行peer as-number命令修改对等体的AS号。只能先删除对等体,再为对等体配置新的AS号。
通过本命令创建对等体后,还需要执行peer enable命令,本地路由器才具有与指定对等体交换相应地址族路由信息的能力。
配置动态对等体时,设备和邻居只能有一端配置网段地址,另一端必须配置实际IP地址。
# 在BGP实例视图下,创建BGP对等体1.1.1.1,指定对等体的AS号为100。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 100
·     display bgp peer
·     peer enable
·     peer group
1.1.74  peer as-path-acl
peer as-path-acl命令用来为对等体/对等体组设置基于AS路径过滤列表的BGP路由过滤策略。
undo peer as-path-acl命令用来删除为指定对等体/对等体组设置的基于AS路径过滤列表的BGP路由过滤策略。
peer { group-name | ipv4-address [ mask-length ] } as-path-acl as-path-acl-number { export | import }
undo peer { group-name | ipv4-address [ mask-length ] } as-path-acl { export | import }
BGP IPv6单播地址族视图:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl as-path-acl-number { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl { export | import }
BGP IPv6组播地址族视图:
peer { group-name | ipv6-address [ prefix-length ] } as-path-acl as-path-acl-number { export | import }
undo peer { group-name | ipv6-address [ prefix-length ] } as-path-acl { export | import }
未配置基于AS路径过滤列表的BGP路由过滤策略。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
as-path-acl-number:AS路径过滤列表号,取值范围为1~256。
export:对向指定对等体/对等体组发布的路由应用过滤策略。
import:对从指定对等体/对等体组接收的路由应用过滤策略。
配置peer as-path-acl命令时需要同时在系统视图下通过ip as-path命令配置对应的AS路径过滤列表。如果本命令中指定的AS路径过滤列表尚未创建,则所有路由均通过过滤。
本端设备在向EBGP对等体发布BGP路由时,先使用本命令指定的AS路径过滤列表对路由进行过滤,然后才为过滤后的BGP路由添加本地的AS号。
# 在BGP IPv4单播地址族视图下,配置利用编号为1的AS路径过滤列表过滤向对等体组test发布的路由。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test as-path-acl 1 export
·     ip as-path(三层技术-IP路由命令参考/路由策略)
·     peer prefix-list
·     peer route-policy
1.1.75  peer bfd
peer bfd命令用来配置通过BFD检测本地路由器和指定BGP对等体/对等体组之间的链路。
undo peer bfd命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bfd [ multi-hop | single-hop ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bfd
不使用BFD检测本地路由器和BGP对等体/对等体组之间的链路。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
multi-hop:采用BFD多跳检测方式。
single-hop:采用BFD单跳检测方式。
如果没有指定multi-hop和single-hop参数,则:
·     采用BFD多跳方式检测本地路由器和指定IBGP对等体/对等体组之间的链路。
·     如果采用直连的物理接口建立EBGP会话,且未配置peer ebgp-max-hop命令,则采用BFD单跳方式检测本地路由器和指定EBGP对等体/对等体组之间的链路;否则,采用BFD多跳方式检测。
BFD多跳和单跳检测方式的详细介绍,请参见“网络管理和监控配置指导”中的“BFD”。
配置BGP GR功能后,请慎用BGP与BFD联动功能。因为当链路故障时,系统可能还没来得及启用GR处理流程,BFD已经检测到链路故障,从而导致GR失败。如果设备上同时配置了BGP GR和BGP BFD,则在BGP GR期间请勿去使能BGP BFD,否则可能导致GR失败。
通过链路本地地址建立的BGP会话只能通过单跳BFD会话检测对等体之间的链路。
本地路由器和BGP对等体采用的BFD检测方式(单跳或多跳)必须相同,否则无法建立BFD会话。
# 在BGP实例视图下,配置通过BFD检测本地路由器和BGP对等体组test之间的链路。
[Sysname] bgp 100
[Sysname-bgp-default] peer test bfd
·     display bgp peer
·     display bfd session(网络管理和监控命令参考/BFD)
1.1.76  peer capability-advertise conventional
peer capability-advertise conventional命令用来关闭本地路由器与指定对等体/对等体组的BGP路由刷新、多协议扩展和4字节AS号功能。
undo peer capability-advertise conventional命令用来使能本地路由器与指定对等体/对等体组的BGP路由刷新、多协议扩展和4字节AS号功能。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise conventional
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise conventional
BGP路由刷新、多协议扩展和4字节AS号功能处于使能状态。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
路由刷新功能是指发送和接收Route-refresh消息的能力,它用来实现BGP会话的软复位。
多协议扩展功能是指发送和接收多协议扩展的Update消息的能力,它用来实现通过BGP发布不同协议的路由信息,如IPv6路由信息。
4字节AS号功能是指设备支持4字节的AS号,即AS号取值占用4字节,取值范围为1~4294967295。
如果同时执行了本命令和peer capability-advertise route-refresh命令,最后一次执行的命令生效。
# 在BGP实例视图下,关闭本地路由器与对等体1.1.1.1的BGP路由刷新、多协议扩展和4字节AS号功能。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise conventional
·     display bgp peer
·     peer capability-advertise route-refresh
1.1.77  peer capability-advertise route-refresh
peer capability-advertise route-refresh命令用来使能本地路由器与指定对等体/对等体组的BGP路由刷新功能。
undo peer capability-advertise route-refresh命令用来关闭本地路由器与指定对等体/对等体组的BGP路由刷新功能。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise route-refresh
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise route-refresh
BGP路由刷新功能处于使能状态。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
路由刷新(Route-refresh)功能是指发送和接收Route-refresh消息的能力。
路由刷新功能用来实现BGP会话的软复位:如果BGP的路由策略发生了变化,则本地路由器会向BGP对等体发送Route-refresh消息,收到此消息的对等体将其路由信息重新发给本地路由器,本地路由器根据新的路由策略对接收到的路由信息进行过滤。从而,实现在不中断BGP会话的情况下,对BGP路由表进行更新,使新的路由策略生效。
只有本地路由器和对等体都支持路由刷新功能时,本地路由器和对等体之间建立的BGP会话才具有路由刷新能力。
如果同时执行了本命令和peer capability-advertise conventional命令,最后一次执行的命令生效。
# 在BGP实例视图下,使能本地路由器与对等体1.1.1.1的BGP路由刷新功能。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise route-refresh
·     display bgp peer
·     peer capability-advertise conventional
·     peer keep-all-routes
·     refresh bgp
1.1.78  peer capability-advertise suppress-4-byte-as
peer capability-advertise suppress-4-byte-as命令用来使能4字节AS号抑制功能。
undo peer capability-advertise suppress-4-byte-as命令用来关闭4字节AS号抑制功能。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise suppress-4-byte-as
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise suppress-4-byte-as
4字节AS号抑制功能处于关闭状态。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
设备支持4字节的AS号,即AS号取值占用4字节,取值范围为1~4294967295。缺省情况下,设备在与对端设备建立BGP会话时,通过Open消息通告对端设备本端支持4字节的AS号。如果对端设备不支持4字节AS号(只支持2字节AS号),则会导致会话协商失败。此时,在本端与对端设备之间使能4字节AS号抑制功能,可以使得本端设备通过Open消息向对端设备谎称自己不支持4字节的AS号,从而确保本端和对端设备之间可以成功建立BGP会话。
如果对端设备支持4字节AS号,请不要使能4字节AS号抑制功能,否则会导致BGP会话无法建立。
# 在BGP实例视图下,使能本地路由器与对等体1.1.1.1的4字节AS号抑制功能。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise suppress-4-byte-as
·     display bgp peer
1.1.79  peer connect-interface
peer connect-interface命令用来指定与对等体/对等体组创建BGP会话时建立TCP连接使用的源接口,即采用指定源接口的IPv4地址/IPv6地址与对等体/对等体组建立TCP连接。
undo peer connect-interface命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } connect-interface interface-type interface-number
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } connect-interface
BGP使用到达BGP对等体的最佳路由出接口的主IPv4地址或IPv6地址与对等体/对等体组建立TCP连接。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
本命令的作用与peer source-address命令的作用类似:peer source-address命令直接指定建立TCP连接的源地址;本命令通过指定源接口,间接指定建立TCP连接的源地址。在一台BGP路由器上如果同时执行本命令和peer source-address命令,则后执行的配置覆盖之前的配置。
在如下场合需要通过本命令或peer source-address命令指定建立TCP连接使用的源接口或源地址:
·     当指定的对等体的IPv4地址/IPv6地址不是本地路由器与对等体之间直连接口的IPv4地址/IPv6地址时,需要在对等体上通过本配置将建立TCP连接使用的源接口指定为对等体IPv4地址/IPv6地址所在的接口或者指定TCP连接的源地址为对等体IP地址/IPv6地址。
·     当通过IPv6链路本地地址创建对等体或向对等体组中添加指定的对等体时,必须使用直连接口建立对等关系,且必须通过peer connect-interface命令将本地直连出接口指定为建立TCP连接使用的源接口。
·     当建立BGP连接的路由器之间存在冗余链路时,如果路由器上的一个接口发生故障,链路状态变为down,建立TCP连接的源地址可能会随之发生变化,导致BGP需要重新建立TCP连接,造成网络震荡。为了避免该情况的发生,建议网络管理员将建立TCP连接所使用的源地址配置为Loopback接口的地址,或将源接口配置为Loopback接口,以提高TCP连接的可靠性和稳定性。
·     当BGP对等体之间同时建立多条BGP会话时,如果没有明确指定建立TCP连接的源地址,可能会导致根据最优路由选择TCP连接源地址错误,并影响BGP会话的建立。如果多条BGP会话基于不同接口的IP地址建立,则建议用户在配置BGP对等体时,通过配置源接口或源地址明确指定每个BGP会话的TCP连接源地址;如果多条BGP会话基于同一接口的不同IP地址建立,则建议用户通过配置源地址,明确指定每个BGP会话的TCP连接源地址。
本地路由器源接口的地址和对等体源接口的地址之间必须路由可达。
如果在EBGP对等体上指定非直连接口作为源接口,则需要配置peer ebgp-max-hop命令允许本地路由器同非直连网络上的邻居建立EBGP连接。
如果接口上存在多个IPv4地址,则建立TCP连接时使用接口的主IPv4地址;如果接口上存在多个IPv6地址,则设备根据内部定义的原则从中选择一个IPv6地址作为TCP连接的源地址。源IPv6地址的选择具有不确定性,因此,在这种情况下,建议用户通过peer source-address命令明确指定TCP连接的源IPv6地址。
不能通过本命令指定建立TCP连接的源接口为VT(Virtual Template,虚拟模板)接口,因为VT口只能作为模板口并不处理相关业务。
# 在BGP实例视图下,配置与对等体组test创建BGP会话时,使用接口Loopback0作为建立TCP连接的源接口。
[Sysname] bgp 100
[Sysname-bgp-default] peer test connect-interface loopback 0
·     peer ebgp-max-hop
·     peer source-address
1.1.80  peer default-route-advertise
peer default-route-advertise命令用来向对等体/对等体组发送缺省路由。
undo peer default-route-advertise命令用来取消向指定对等体/对等体组发送缺省路由。
undo peer { group-name | ipv4-address [ mask-length ] } default-route-advertise
BGP VPNv4地址族视图:
peer { group-name | ipv4-address [ mask-length ] } default-route-advertise vpn-instance vpn-instance-name
undo peer { group-name | ipv4-address [ mask-length ] } default-route-advertise vpn-instance vpn-instance-name
BGP IPv6单播地址族视图:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise
peer { group-name | ipv6-address [ prefix-length ] } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ipv6-address [ prefix-length ] } default-route-advertise
BGP IPv4 RT-Filter地址族视图:
不向对等体/对等体组发送缺省路由。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
route-policy route-policy-name:为发布的缺省路由应用路由策略,以便修改路由的属性等。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则表示没有为发布的缺省路由应用路由策略。
vpn-instance vpn-instance-name:向对等体或对等体组发布指定VPN实例的缺省路由。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
如果配置了peer default-route-advertise命令,则本地路由器会向指定的对等体/对等体组发布一条下一跳为自身的缺省路由。在本地路由器的路由表中不需要存在缺省路由。
# 在BGP IPv4单播地址族视图下,设置向对等体组test发布缺省路由。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test default-route-advertise
1.1.81  peer description
peer description命令用来配置对等体/对等体组的描述信息。
undo peer description命令用来删除指定对等体/对等体组的描述信息。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } description text
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } description
对等体/对等体组没有描述信息。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
text:对等体的描述信息,为1~79个字符的字符串,区分大小写。
# 在BGP实例视图下,配置对等体组test的描述信息为ISP1。
[Sysname] bgp 100
[Sysname-bgp-default] peer test description ISP1
1.1.82  peer ebgp-max-hop
peer ebgp-max-hop命令用来配置允许本地路由器同非直连网络上的邻居建立EBGP会话,同时指定允许的最大跳数。
undo peer ebgp-max-hop命令用来禁止本地路由器同非直连网络上的指定邻居建立EBGP会话的配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ebgp-max-hop [ hop-count ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ebgp-max-hop
不允许同非直连网络上的邻居建立EBGP会话。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
hop-count:最大路由器跳数,取值范围为1~255,缺省值为64。
当前路由器要与另外一个路由器建立EBGP会话,它们之间必须具有直连的物理链路,且必须使用直连接口建立会话。如果不满足这一要求,则必须使用peer ebgp-max-hop命令允许它们经过多跳建立EBGP会话。
本命令只对配置改变后收到的路由生效。对于配置改变之前的路由,需要执行refresh bgp命令重新刷新路由后才能生效。
执行peer ttl-security命令后,只要本地设备和指定的对等体通过了GTSM检查,就允许在二者之间建立EBGP会话,不管二者之间的跳数是否超过peer ebgp-max-hop命令指定的跳数范围。
建议不要指定直连EBGP对等体/对等体组配置peer ebgp-max-hop命令,否则可能导致BGP路由无法正常迭代。
# 在BGP实例视图下,配置允许同非直连网络上的EBGP对等体组test建立会话,允许的最大跳数为缺省值64。
[Sysname] bgp 100
[Sysname-bgp-default] peer test ebgp-max-hop
·     peer ttl-security
1.1.83  peer enable
peer enable命令用来允许本地路由器与指定对等体/对等体组交换路由信息。
undo peer enable命令用来禁止本地路由器与指定对等体/对等体组交换路由信息。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP-VPN VPNv4地址族视图/BGP IPv4组播地址族视图/BGP IPv4 MDT地址族视图/BGP IPv4 RT-Filter地址族视图/BGP IPv4 MVPN地址族视图/BGP IPv4 SR Policy地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] } enable
BGP IPv6单播地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } enable
BGP LS地址族视图/BGP VPNv4地址族视图/BGP VPNv6地址族视图/BGP IPv4 Flowspec地址族视图/BGP-VPN IPv4 Flowspec地址族视图/BGP VPNv4 Flowspec地址族视图/BGP VPNv6 Flowspec地址族视图/BGP VPN IPv6 Flowspec地址族视图/BGP IPv6 Flowspec地址族视图:
peer { group-name | ipv6-address [ prefix-length ] } enable
undo peer { group-name | ipv6-address [ prefix-length ] } enable
本地路由器不能与对等体/对等体组交换路由信息。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP-VPN VPNv4地址族视图
BGP IPv6单播地址族视图
BGP LS地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
BGP IPv4 MDT地址族视图
BGP IPv4 MVPN地址族视图
context-admin
vsys-admin
在不同的视图下执行peer enable命令,可以使能本地路由器与指定对等体交换不同地址族路由信息的能力:
·     BGP IPv4单播地址族视图下,使能的是交换IPv4单播路由信息的能力,并且学习到的路由将添加到公网BGP路由表中。
·     BGP-VPN IPv4单播地址族视图下,使能的是交换IPv4单播路由信息的能力,并且学习到的路由将添加到指定VPN实例的BGP路由表中。
·     BGP VPNv4地址族视图下,使能的是交换VPNv4路由信息的能力。MPLS L3VPN组网中,需要在PE设备的BGP VPNv4地址族视图下执行本命令。
·     BGP IPv6单播地址族视图下,使能的是交换IPv6单播路由信息的能力,并且学习到的路由将添加到公网IPv6 BGP路由表中。
·     BGP-VPN IPv6单播地址族视图下,使能的是交换IPv6单播路由信息的能力,并且学习到的路由将添加到指定VPN实例的IPv6 BGP路由表中。
·     BGP VPNv6地址族视图下,使能的是交换VPNv6路由信息的能力。IPv6 MPLS L3VPN组网中,需要在PE设备的BGP VPNv6地址族视图下执行本命令。
·     BGP IPv4组播地址族视图下,使能的是交换用于RPF检查的IPv4单播路由信息的能力。
·     BGP IPv6组播地址族视图下,使能的是交换用于RPF检查的IPv6单播路由信息的能力。
·     BGP IPv4 MDT地址族视图下,使能的是交换MDT信息的能力。组播VPN组网中,需要在PE设备的BGP IPv4 MDT地址族视图下执行本命令。
·     BGP IPv4 Flowspec地址族视图下,使能的是交换IPv4 Flowspec路由信息的能力,并且学习到的路由将添加到BGP IPv4 Flowspec路由表中。
·     BGP IPv6 Flowspec地址族视图下,使能的是交换IPv6 Flowspec路由信息的能力,并且学习到的路由将添加到BGP IPv6 Flowspec路由表中。
·     BGP-VPN IPv4 Flowspec地址族视图下,使能的是交换IPv4 Flowspec路由信息的能力,并且学习到的路由将添加到指定VPN实例的BGP IPv4 Flowspec路由表中。
·     BGP-VPN IPv6 Flowspec地址族视图下,使能的是交换IPv6 Flowspec路由信息的能力,并且学习到的路由将添加到指定VPN实例的BGP IPv6 Flowspec路由表中。
·     BGP VPNv4 Flowspec地址族视图下,使能的是交换VPNv4 Flowspec路由信息的能力。MPLS L3VPN组网中,需要在PE设备的BGP VPNv4 Flowspec地址族视图下执行本命令。
·     BGP VPNv6 Flowspec地址族视图下,使能的是交换VPNv6 Flowspec路由信息的能力,并且学习到的路由将添加BGP VPNv6 Flowspec路由表中。IPv6 MPLS L3VPN组网中,需要在PE设备上使能交换VPNv6 Flowspec路由信息的能力。
·     BGP IPv4 RT-Filter地址族视图下,使能的是交换IPv4 RT-Filter路由信息的能力。MPLS L3VPN组网中,可以在PE设备的BGP IPv4 RT-Filter地址族视图下执行本命令。
·     BGP IPv4 SR Policy地址族视图下,使能的是交换IPv4 SR Policy路由信息的能力,并且学习到的路由将添加到公网BGP IPv4 SR Policy路由表中。
·     BGP IPv6 SR Policy地址族视图下,使能的是交换IPv6 SR Policy路由信息的能力,并且学习到的路由将添加到公网BGP IPv6 SR Policy路由表中。
如果在某个视图下执行了undo peer enable命令,则本地路由器与指定对等体之间不再交换对应地址族的路由信息。
# 在BGP IPv4单播地址族视图下,使能本地路由器与对等体1.1.1.1交换IPv4单播路由信息的能力。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 enable
·     display bgp peer
1.1.84  peer fake-as
peer fake-as命令用来为对等体/对等体组指定一个虚拟的本地自治系统号。
undo peer fake-as命令用来删除为指定对等体/对等体组配置的虚拟的本地自治系统号。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } fake-as as-number
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } fake-as
对等体/对等体组未配置虚拟的本地自治系统号。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
as-number:本地自治系统号,取值范围为1~4294967295。
进行系统移植时,例如,Router A原来位于AS 2,现在将它移植到AS 3里,网络管理员需要在Router A的所有EBGP对等体上修改Router A的AS号。通过在Router A上为EBGP对等体/对等体组配置一个虚拟的本地自治系统号2,可以将本地真实的AS号3隐藏起来。在EBGP对等体看来Router A始终位于AS 2,不需要改变EBGP对等体上的配置。
peer fake-as命令只适用于EBGP对等体和对等体组。
如果在本地路由器上执行了peer fake-as命令,则在指定的对等体上需要将本地路由器的AS号配置为本命令中指定的虚拟本地自治系统号。
# 在BGP实例视图下,为对等体组test指定虚拟的本地自治系统号为200。
[Sysname] bgp 100
[Sysname-bgp-default] peer test fake-as 200
1.1.85  peer filter-policy
peer filter-policy命令用来为对等体/对等体组设置基于ACL的BGP路由过滤策略。
undo peer filter-policy命令用来删除为指定对等体/对等体组设置基于ACL的BGP路由过滤策略。
peer { group-name | ipv4-address [ mask-length ] } filter-policy ipv4-acl-number { export | import }
undo peer { group-name | ipv4-address [ mask-length ] } filter-policy { export | import }
BGP IPv6单播地址族视图:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy ipv6-acl-number { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { export | import }
peer { group-name | ipv6-address [ prefix-length ] } filter-policy ipv6-acl-number { export | import }
undo peer { group-name | ipv6-address [ prefix-length ] } filter-policy { export | import }
BGP VPNv6地址族视图:
peer { group-name | ipv4-address [ mask-length ] } filter-policy ipv6-acl-number { export | import }
未配置基于ACL的BGP路由过滤策略。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
ipv4-acl-number:访问控制列表号,取值范围为2000~3999。
ipv6-acl-number:IPv6访问控制列表号,取值范围为2000~3999。
配置peer filter-policy命令时需要同时在系统视图下通过acl命令配置对应的ACL。如果本命令中指定的ACL尚未创建,则所有路由均通过过滤。
通过基本ACL(2000~2999)对BGP路由信息进行过滤时,如果配置了rule [ rule-id ] { deny | permit } source source-address source-wildcard命令,则只要路由的目的网络地址与rule命令中的source-address source-wildcard匹配,则该路由与rule命令配置的规则匹配,不会再比较路由的目的网络地址掩码。
通过高级ACL(3000~3999)对BGP路由信息进行过滤时,rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard命令配置的规则用来过滤指定目的网络地址的路由;rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard命令配置的规则用来过滤指定目的网络地址和掩码的路由,其中source sour-addr sour-wildcard用来过滤路由目的网络地址,destination dest-addr dest-wildcard用来过滤路由掩码。destination dest-addr dest-wildcard指定的掩码应该是连续的。如果指定的掩码不连续,则该过滤掩码的条件不生效。
引用ACL时,需要注意的是:
# 在BGP IPv4单播地址族视图下,配置利用编号为2000的访问控制列表过滤向对等体组test发布的路由。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test filter-policy 2000 export
·     acl(ACL和QoS命令参考/ACL)
·     peer as-path-acl
·     peer prefix-list
·     peer route-policy
1.1.86  peer group
peer group命令用来向对等体组中添加指定的对等体。
undo peer group命令用来从对等体组中删除指定的对等体。
peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } group group-name [ as-number as-number ]
undo peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } group group-name
对等体组中不存在任何对等体。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
as-number as-number:对等体的AS号,取值范围为1~4294967295。
可以通过以下方式将对等体加入对等体组:
(1)     先通过peer as-number命令创建对等体并指定对等体的AS号,再通过peer group命令将其加入对等体组。采用这种方式时,需要注意:
·     执行peer group命令时可以指定as-number参数,指定的as-number参数,必须与peer as-number命令中配置的对等体AS号相同。
·     如果通过peer as-number命令指定了对等体组的AS号,则对等体的AS号必须与对等体组的AS号相同,否则无法将对等体加入对等体组。
·     如果将对等体加入IBGP对等体组,则该对等体必须是IBGP对等体。
(2)     通过peer group命令创建对等体的同时,将其加入对等体组。采用这种方式时,需要注意:
·     如果通过peer as-number命令指定了对等体组的AS号,则执行peer group命令时无需指定as-number参数,对等体的AS号为该对等体组的AS号。执行peer group命令时如果指定了as-number参数,则as-number参数必须与对等体组的AS号相同。
·     如果没有指定对等体组的AS号,且该对等体组为EBGP对等体组,则执行peer group命令时必须指定as-number参数。
·     如果没有指定对等体组的AS号,且该对等体组为IBGP对等体组,则执行peer group命令时无需指定as-number参数,对等体的AS号为本地AS号。执行peer group命令时如果指定了as-number参数,则as-number参数必须与本地AS号相同。
如果通过peer as-number命令指定了对等体组的AS号,则只有与该对等体组AS号相同的对等体才能加入该对等体组,即对等体组中所有对等体的AS号均相同;如果没有指定对等体组的AS号,则加入该对等体组的对等体保留自己的AS号,即对等体组中对等体的AS号可以相同,也可以不同。
通过本命令将对等体加入对等体组后,还需要执行peer enable命令,本地路由器才具有与指定对等体组交换相应地址族路由信息的能力。
# 在BGP实例视图下,将IPv4地址为10.1.1.1的对等体加入到EBGP对等体组test。
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.1.1 group test as-number 2004
·     group
·     peer as-number
·     peer enable
1.1.87  peer high-priority
peer high-priority命令用来为指定对等体/对等体组设置高优先级,路由选路时优选从该对等体/对等体组学习到的路由。
undo peer high-priority命令用来取消该配置。
BGP IPv6单播地址族视图/BGP VPNv4地址族视图/BGP LS 地址族视图/BGP VPNv6地址族视图/BGP IPv4 Flowspec地址族视图/BGP IPv6 Flowspec地址族视图/BGP-VPN IPv4 Flowspec地址族视图/BGP-VPN IPv6 Flowspec地址族视图/BGP VPNv4 Flowspec地址族视图/BGP VPNv6 Flowspec地址族视图:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority
peer { group-name | ipv4-address [ mask-length ] } high-priority
undo peer { group-name | ipv4-address [ mask-length ] } high-priority
peer { group-name | ipv6-address [ prefix-length ] } high-priority
undo peer { group-name | ipv6-address [ prefix-length ] } high-priority
BGP不为指定对等体/对等体组设置高优先级,选路规则不发生变化。
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
BGP LS地址族视图
BGP VPNv4地址族视图/BGP VPNv6地址族视图/BGP-VPN VPNv4地址族视图
BGP-VPN IPv4单播地址族视图/BGP-VPN IPv6单播地址族视图
BGP-VPN LS地址族视图
BGP IPv4 MVPN地址族视图
BGP IPv4 MDT地址族视图
BGP IPv4 SR Policy地址族视图/BGP IPv6 SR Policy地址族视图
context-admin
配置本命令后,从本命令指定的对等体/对等体组、其他对等体/对等体组学习到相同前缀的路由时,优选从本命令指定的对等体/对等体组学习到路由。该选路规则应用于“依次选择从EBGP、联盟EBGP、联盟IBGP、IBGP学来的路由”之后,“优选IGP Metric值最小的路由”之前。
# 在BGP IPv4单播地址族视图下,为对等体组test设置高优先级,路由选路时优选从该对等体/对等体组学习到路由。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test high-priority
1.1.88  peer ignore
peer ignore命令用来禁止与指定对等体/对等体组建立会话。
undo peer ignore命令用来允许与指定的对等体/对等体组建立会话。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ignore
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ignore
允许与BGP对等体/对等体组建立会话。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
如果本设备和对等体的会话已经建立,则执行本命令后,会停止该会话,并且清除所有相关路由信息;如果本设备和对等体组的会话已经建立,则执行本命令后,会终止与对等体组内所有对等体之间的会话,并且清除所有相关路由信息。
由于网络升级维护等原因,需要暂时断开与某个对等体/对等体组的BGP会话时,可以通过peer ignore命令禁止与该对等体/对等体组建立会话。当网络恢复后,通过执行undo peer ignore命令恢复与对等体/对等体组的会话。这样,网络管理员无需删除并重新进行对等体/对等体组相关配置,减少了网络维护的工作量。
# 在BGP实例视图下,禁止与对等体1.1.1.1建立会话。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 ignore
1.1.89  peer ignore-first-as
peer ignore-first-as命令用来配置不检测从指定对等体/对等体组收到的EBGP路由的第一个AS号。
undo peer ignore-first-as命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ignore-first-as
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ignore-first-as
非缺省vSystem不支持本命令。
BGP实例视图
BGP-VPN实例视图
context-admin
本功能仅对配置peer ignore-first-as命令后,新收到的EBGP路由生效。
执行peer ignore-first-as命令后,再执行undo peer ignore-first-as命令取消配置,则本地设备会向此对等体/对等体组发送Refresh报文请求重新发送路由信息。
# 在BGP实例视图下,配置不检测从对等体组test收到的EBGP路由的第一个AS号。
[Sysname] bgp 100
[Sysname-bgp-default] peer test ignore-first-as
·     ignore-first-as
1.1.90  peer ignore-originatorid
peer ignore-originatorid命令用来配置忽略BGP路由的ORIGINATOR_ID属性。
undo peer ignore-originatorid命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ignore-originatorid
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ignore-originatorid
BGP路由器不会忽略BGP路由的ORIGINATOR_ID属性。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
请谨慎使用本命令。如果无法确保执行本命令后网络中不会产生环路,请不要执行本命令。
在某些特殊的组网中(如防火墙组网),如果需要接收ORIGINATOR_ID属性值与本地Router ID相同的路由,则需要执行本命令忽略BGP路由的ORIGINATOR_ID属性。
执行本命令后,BGP路由的CLUSTER_LIST属性也会被忽略。
# 在BGP实例视图下,配置忽略从对等体1.1.1.1收到BGP路由的ORIGINATOR_ID属性。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 ignore-originatorid
1.1.91  peer ipsec-profile
peer ipsec-profile命令用来为IPv6 BGP对等体/对等体组应用IPsec安全框架。
undo peer ipsec-profile命令用来取消为指定的IPv6 BGP对等体/对等体组应用IPsec安全框架。
peer { group-name | ipv6-address [ prefix-length ] } ipsec-profile profile-name
undo peer { group-name | ipv6-address [ prefix-length ] } ipsec-profile
没有为IPv6 BGP对等体/对等体组应用IPsec安全框架。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
profile-name:IPsec安全框架名称,为1~63个字符的字符串,区分大小写。
为了避免路由信息外泄或者非法者对设备进行恶意攻击,可以利用IPsec安全隧道对IPv6 BGP报文进行保护。通过IPsec提供的数据机密性、完整性、数据源认证等功能,确保IPv6 BGP报文不会被侦听或恶意篡改,并避免非法者构造IPv6 BGP报文对设备进行攻击。
在互为IPv6 BGP邻居的两台设备上都配置通过IPsec保护IPv6 BGP报文后,一端设备在发送IPv6 BGP报文时通过IPsec对报文进行加封装,另一端设备接收到报文后,通过IPsec对报文进行解封装。如果解封装成功,则接收该报文,正常建立IPv6 BGP对等体关系或学习IPv6 BGP路由;如果设备接收到不受IPsec保护的IPv6 BGP报文,或IPv6 BGP报文解封装失败,则会丢弃该报文。
配置通过IPsec保护IPv6 BGP报文包括如下步骤:
(1)     配置IPsec安全提议。
(2)     配置手工方式的IPsec安全框架。
(3)     通过本命令为IPv6 BGP对等体/对等体组应用IPsec安全框架。
IPsec安全提议和IPsec安全框架的详细介绍,请参见“VPN配置指导”中的“IPsec”。
本命令应用的IPsec安全框架必须是手工方式的IPsec安全框架。
如果在一台设备上配置了通过IPsec保护IPv6 BGP报文功能,那么在它的IPv6 BGP对等体上也必须配置该功能。否则,会导致IPv6 BGP报文无法正常接收。
# 在BGP实例视图下,为对等体组test应用安全框架profile001。
[Sysname] bgp 100
[Sysname-bgp-default] peer test ipsec-profile profile001
·     display bgp group
·     display bgp peer
1.1.92  peer keep-all-routes
peer keep-all-routes命令用来保存所有来自指定对等体/对等体组的原始路由更新信息,不管这些路由是否通过了路由策略的过滤。
undo peer keep-all-routes命令用来取消该配置。
undo peer { group-name | ipv4-address [ mask-length ] } keep-all-routes
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
peer { group-name | ipv6-address [ prefix-length ] } keep-all-routes
undo peer { group-name | ipv6-address [ prefix-length ] } keep-all-routes
不保存来自对等体/对等体组的原始路由更新信息。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
如果本地路由器和对等体不都支持路由刷新功能,那么要实现BGP会话的软复位,则需要通过配置本命令将从对等体/对等体组接收的所有原始路由更新信息保存在本地,当选路策略发生改变后,对保存在本地的所有路由使用新的路由策略重新进行过滤,以实现在不中断BGP会话的情况下,对BGP路由表进行更新,并应用新的选路策略。
# 在BGP IPv4单播地址族视图下,保存所有来自对等体1.1.1.1的路由更新信息。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 keep-all-routes
·     refresh bgp
1.1.93  peer keychain
peer keychain命令用来为指定对等体/对等体组配置BGP的keychain认证。
undo peer keychain命令用来取消为指定对等体/对等体组配置BGP的keychain认证。
peer { group-name | ip-address [ mask-length ] | ipv6-address [ prefix-length ] } keychain keychain-name
undo peer { group-name | ip-address [ mask-length ] | ipv6-address [ prefix-length ] } keychain
不进行BGP的keychain认证。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
ip-address:对等体的IP地址。指定的对等体必须已经创建。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。指定的keychain必须已经创建。
配置keychain认证可以提高TCP连接的安全性。为了保证正常建立TCP连接、正常交互BGP消息,BGP对等体两端必须同时配置keychain认证,且两端使用的keychain需要满足如下条件:
·     同一时间内使用的key的标识符相同。
·     相同标识符的key的认证算法和认证密钥必须一致。
对于keychain认证算法和key的标识符的范围,BGP的支持情况如下:
·     BGP支持HMAC-MD5、HMAC-SHA-256、HMAC-SM3、SM3和MD5认证算法,通过authentication-algorithm命令进行配置。
·     BGP仅支持标识符取值范围为0~63的key,通过key命令进行配置。
命令peer keychain和peer password互斥,不能同时配置。
# 在BGP实例视图下,配置IP地址为10.1.1.1的对等体使用名为abc的keychain认证。
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.1.1 as-number 100
[Sysname-bgp-default] peer 10.1.1.1 keychain abc
·     authentication-algorithm(安全命令参考/keychain)
·     key(安全命令参考/keychain)
·     peer password
1.1.94  peer label-route-capability
peer label-route-capability命令用来使能与指定对等体/对等体组交换带标签路由的能力。
undo peer label-route-capability命令用来关闭与指定对等体/对等体组交换带标签路由的能力。
peer { group-name | ipv4-address [ mask-length ] } label-route-capability
undo peer { group-name | ipv4-address [ mask-length ] } label-route-capability
不具有与对等体/对等体组交换带标签路由的能力。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
context-admin
vsys-admin
跨域VPN OptionC组网中,需要在BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图下执行本命令,使得本地设备和指定对等体/对等体组可以交互带标签的IPv4单播路由,以便建立跨域的公网LSP。
6PE组网中,需要在BGP IPv6单播地址族视图下执行本命令,使得本地设备和指定对等体/对等体组可以交互带标签的IPv6单播路由,以便实现跨越IPv4网络转发IPv6报文。
# 在BGP IPv4单播地址族视图下,使能与对等体2.2.2.2交换带标签IPv4路由的能力。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 2.2.2.2 label-route-capability
1.1.95  peer log-change
peer log-change命令用来使能与指定对等体/对等体组之间BGP会话的日志记录功能。
undo peer log-change命令用来关闭与指定对等体/对等体组之间BGP会话的日志记录功能。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } log-change
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } log-change
与所有对等体/对等体组之间BGP会话的日志记录功能均处于开启状态。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
通过log-peer-change命令全局使能BGP日志记录功能,并执行本命令后,与指定对等体/对等体组之间BGP会话建立以及断开时会生成日志信息,通过display bgp peer ipv4 unicast log-info命令或display bgp peer ipv6 unicast log-info命令可以查看记录的日志信息。生成的日志信息还将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。(有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。)
# 在BGP实例视图下,使能与对等体1.1.1.1之间BGP会话的日志记录功能。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 200
[Sysname-bgp-default] peer 1.1.1.1 log-change
·     display bgp peer
·     log-peer-change
1.1.96  peer low-memory-exempt
peer low-memory-exempt命令用来配置系统进入二级内存门限告警状态后,不断开与指定EBGP对等体/对等体组之间的会话。
undo peer low-memory-exempt命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } low-memory-exempt
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } low-memory-exempt
系统在二级内存门限告警状态下,会周期性地选择EBGP对等体,并断开与该对等体之间的BGP会话。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
当系统进入二级内存门限告警状态后,BGP会周期性地选择一个EBGP对等体,断开与该对等体之间的BGP会话,直到系统内存恢复为止。用户可以通过本命令来避免在二级内存门限告警状态下,断开与指定EBGP对等体/对等体组之间的BGP会话,以达到对特定EBGP对等体/对等体组进行保护的目的。关于内存门限告警的详细介绍,请参见“基础配置指导”中的“设备管理”。
# 在BGP实例视图下,配置系统进入二级内存门限告警状态后,不断开与EBGP对等体1.1.1.1之间的会话。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 low-memory-exempt
1.1.97  peer next-hop-local
peer next-hop-local命令用来配置向对等体/对等体组发布路由时,将下一跳属性修改为自身的地址。
undo peer next-hop-local命令用来取消该配置。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP VPNv4地址族视图/BGP IPv4组播地址族视图/BGP IPv4 SR Policy地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-local
BGP IPv6单播地址族视图/BGP IPv6组播地址族视图/BGP IPv6 SR Policy地址族视图:
peer { group-name | ipv6-address [ prefix-length ] } next-hop-local
undo peer { group-name | ipv6-address [ prefix-length ] } next-hop-local
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } next-hop-local
向EBGP对等体发布路由时,如果建立的是直连EBGP会话,且路由的下一跳与建立EBGP会话使用的直连接口在同一网段,则不修改路由的下一跳属性;其他情况下,都将下一跳属性修改为自身的地址。对于VPNv4和VPNv6路由,向IBGP对等体/对等体组发布EBGP路由时,将下一跳属性修改为自身的地址;对于其他地址族的路由,向IBGP对等体/对等体组发布EBGP路由时,不修改下一跳属性。设备向IBGP对等体发送形成了等价的BGP路由时,修改其中最优路由的下一跳地址为本地地址。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
缺省情况下,路由器向IBGP对等体/对等体组发布路由时,不修改下一跳属性。但有的时候为了保证IBGP对等体能够找到下一跳,可以通过本命令将下一跳属性修改为自身的地址。
本命令与peer next-hop-invariable命令互斥,同一个对等体或对等体组只能选择其中之一进行配置,此外:
·     为对等体组配置本命令后,无法再为组内任意对等体配置peer next-hop-invariable命令。
·     为单个对等体配置本命令后,若再为其所属的对等体组配置peer next-hop-invariable命令,则对等体上本命令的配置将被覆盖,向对等体发布路由时不改变下一跳。
# 在BGP IPv4单播地址族视图下,配置向对等体组test发布BGP路由时,将下一跳属性修改为自身的地址。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test next-hop-local
·     peer next-hop-invariable(MPLS命令参考/MPLS L3VPN)
1.1.98  peer password
peer password命令用来为指定对等体/对等体组配置BGP的MD5认证。
undo peer password命令用来取消为指定对等体/对等体组配置BGP的MD5认证。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } password { cipher | simple } password
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } password
不进行BGP的MD5认证。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
password:密钥字符串,区分大小写。密文密钥为33~137个字符的字符串,明文密钥为1~80个字符的字符串。
通过为BGP对等体配置BGP的MD5认证,可以在以下两方面提高BGP的安全性:
·     为BGP建立TCP连接时进行MD5认证,只有两台路由器配置的密钥相同时,才能建立TCP连接,从而避免与非法的BGP路由器建立TCP连接。
·     传递BGP报文时,对封装BGP报文的TCP报文段进行MD5运算,从而保证BGP报文不会被篡改。
命令peer password和mk:@MSITStore:C:\Documents%20and%20Settings\c07617\桌面\VRP%20%20命令参考(VRP5.70-06_01)\VRP%20%20命令参考(VRP5.70-06_01).chm::/vrp/peer_password.htmlkeychain互斥,不能同时配置。
# 在BGP实例视图下,配置本地路由器10.1.100.1与对等体10.1.100.2之间的BGP会话使用MD5认证,密钥为明文字符串aabbcc。
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.100.2 password simple aabbcc
·     peer keychain
1.1.99  peer preferred-value
peer preferred-value命令用来为从指定对等体/对等体组接收的路由分配首选值。
undo peer preferred-value命令用来取消该配置。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP IPv4组播地址族视图/BGP IPv4 RT-Filter地址族视图/BGP IPv4 SR Policy地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] } preferred-value
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } preferred-value
peer { group-name | ipv6-address [ prefix-length ] } preferred-value value
undo peer { group-name | ipv6-address [ prefix-length ] } preferred-value
从对等体/对等体组接收的路由的首选值为0。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
value:为路由分配的首选值,取值范围为0~65535。
非缺省vSystem仅支持在BGP-VPN IPv4单播地址族视图和BGP-VPN IPv6单播地址族视图下配置本命令。
当从不同对等体都学习到了到达同一目的网络的路由时,可以使用本命令为从不同对等体学习的路由分配不同的首选值,首选值最大的路由将优先被选作最优路由,从而达到控制BGP路径选择的目的。
路由首选值只用于本地路由器的路由选择,不会通告给对等体,只具有本地意义。
既可以通过本命令配置路由的首选值,也可以通过路由策略中的apply preferred-value命令为路由配置首选值。如果同时配置了二者,则优先选择路由策略中配置的首选值。只有当路由策略中未配置首选值,或未配置路由策略时,才会选取peer preferred-value命令设置的值。
# 在BGP IPv4单播地址族视图下,配置来自对等体1.1.1.1的路由的首选值为50。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] peer 1.1.1.1 preferred-value 50
·     apply preferred-value(三层技术-IP路由命令参考/路由策略)
·     route-policy(三层技术-IP路由命令参考/路由策略)
1.1.100  peer prefix-list
peer prefix-list命令用来为对等体/对等体组设置基于地址前缀列表的BGP路由过滤策略。
undo peer prefix-list命令用来删除为指定对等体/对等体组设置基于地址前缀列表的BGP路由过滤策略。
peer { group-name | ipv4-address [ mask-length ] } prefix-list ipv4-prefix-list-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] } prefix-list { export | import }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list { export | import }
peer { group-name | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name { export | import }
undo peer { group-name | ipv6-address [ prefix-length ] } prefix-list { export | import }
未配置基于地址前缀列表的BGP路由过滤策略。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
ipv4-prefix-list-name:IPv4地址前缀列表名称,为1~63个字符的字符串,区分大小写。
ipv6-prefix-list-name:IPv6地址前缀列表名称,为1~63个字符的字符串,区分大小写。
配置peer prefix-list命令时需要同时在系统视图下通过ip prefix-list命令配置对应的IPv4地址前缀列表或通过ipv6 prefix-list命令配置对应的IPv6地址前缀列表。如果本命令中指定的IPv4地址前缀列表/IPv6地址前缀列表尚未创建,则所有路由均通过过滤。
# 在BGP IPv4单播地址族视图下,配置利用IPv4地址前缀列表list1过滤向对等体组test发布的路由。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test prefix-list list1 export
·     filter-policy export
·     filter-policy import
·     ip prefix-list(三层技术-IP路由命令参考/路由策略)
·     ipv6 prefix-list(三层技术-IP路由命令参考/路由策略)
·     peer as-path-acl
·     peer filter-policy
·     peer route-policy
1.1.101  peer public-as-only
peer public-as-only命令用来配置向指定EBGP对等体/对等体组发送BGP更新消息时只携带公有AS号,不携带私有AS号。
undo peer public-as-only命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] } public-as-only
undo peer { group-name | ipv4-address [ mask-length ] } public-as-only
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only
peer { group-name | ipv6-address [ prefix-length ] } public-as-only
undo peer { group-name | ipv6-address [ prefix-length ] } public-as-only
向EBGP对等体/对等体组发送BGP更新消息时,既可以携带公有AS号,又可以携带私有AS号。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
执行本命令后:
·     如果向EBGP对等体/对等体组发送的BGP更新消息中AS_PATH属性只包括私有AS号,则删除私有AS号后,将BGP更新消息发送给对等体/对等体组。
·     如果AS_PATH属性中同时带有公有AS号和私有AS号,则本命令不生效,即不删除私有AS号,直接将BGP更新消息发送给对等体/对等体组。
·     如果AS_PATH属性中包括对等体/对等体组的AS号,则本命令不生效,即不删除私有AS号,直接将BGP更新消息发送给对等体/对等体组。
本命令只适用于EBGP对等体和对等体组。
# 在BGP IPv4单播地址族视图下,配置向EBGP对等体组test发送BGP更新消息时只携带公有AS号,不携带私有AS号。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test public-as-only
1.1.102  peer reflect-client
peer reflect-client命令用来配置本机作为路由反射器,对等体/对等体组作为路由反射器的客户机。
undo peer reflect-client命令用来取消该配置。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP IPv4组播地址族视图/BGP IPv4 MDT地址族视图/BGP IPv4 RT-Filter地址族视图/BGP IPv4 MVPN地址族视图/BGP IPv4 SR Policy地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] } reflect-client
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } reflect-client
BGP LS地址族视图:
peer { group-name | ipv6-address [ prefix-length ] } reflect-client
undo peer { group-name |  ipv6-address [ prefix-length ] } reflect-client
未配置路由反射器及其客户机。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP LS地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
BGP IPv4 MDT地址族视图
BGP IPv4 MVPN地址族视图
context-admin
vsys-admin
路由反射用来解决IBGP对等体需要全连接的问题。在AS内配置路由反射器后,路由反射器发布路由的规则如下:
·     将从IBGP对等体中非客户机设备收到的路由,发布给本反射器的所有客户机;
·     将从IBGP对等体中客户机收到的路由,发布给本反射器所有的非客户机和客户机;
·     将从所有EBGP对等体收到的路由,发布给本反射器所有的非客户机和客户机。
# 在BGP IPv4单播地址族视图下,配置本地设备作为路由反射器,IBGP对等体组test作为路由反射器的客户机。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test reflect-client
·     reflect between-clients
·     reflect change-path-attribute
·     reflector cluster-id
1.1.103  peer route-limit
peer route-limit命令用来设置允许从指定对等体/对等体组收到的路由数量。
undo peer route-limit命令用来取消该配置。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP VPNv4地址族视图/BGP VPNv6地址族视图/BGP IPv4组播地址族视图/BGP IPv4 SR Policy地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] } route-limit
BGP IPv6单播地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-limit
peer { group-name | ipv6-address [ prefix-length ] } route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
undo peer { group-name | ipv6-address [ prefix-length ] } route-limit
不限制从对等体/对等体组接收的路由数量。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
prefix-number:允许路由器接收的路由的数量,取值范围为1~4294967295。如果没有指定alert-only、discard和reconnect参数,则从指定对等体/对等体组接收的路由的数量大于prefix-number值时,路由器自动断开与指定对等体/对等体组的会话。对于BGP动态对等体,本地设备不会尝试与其重新建立会话,但是接收到对等体的BGP会话建立请求后会接受该请求;对于其他非BGP动态对等体,本地设备不会尝试与其重新建立会话,可以通过reset bgp命令重启BGP会话,使得本地设备与对等体重新建立BGP会话。
alert-only:如果路由器从指定对等体/对等体组接收的路由的数量大于prefix-number值,仅打印日志信息,路由器保持与指定对等体/对等体组的会话,并可以继续接收路由。
discard:如果路由器从指定对等体/对等体组接收的路由的数量大于prefix-number值,路由器保持与指定对等体/对等体组的会话,但丢弃超出限制的路由,并打印日志信息。从指定对等体/对等体组接收的路由数量小于prefix-number后,路由器可以继续接收路由。如果用户想恢复之前丢弃的路由,则需要执行refresh bgp import命令请求对等体/对等体组重新发布路由。
reconnect reconnect-time:如果路由器从指定对等体/对等体组接收的路由的数量大于prefix-number值,则等待指定的时间间隔后重新与对等体/对等体组建立会话。reconnect-time为路由器与指定对等体/对等体组重建会话的时间间隔,取值范围为1~65535,单位为秒。对于BGP动态对等体,本参数不会生效。
percentage-value:配置路由器产生日志信息的阈值(即路由器接收的路由数量与prefix-number的百分比达到percentage-value时,路由器将产生日志信息),取值范围为1~100,缺省值为75。
配置discard参数时,如果路由器从指定对等体/对等体组接收到的路由数量已经大于prefix-number值,则已经接收的路由不会被丢弃,而是丢弃后续从该对等体/对等体组接收到的路由。
# 在BGP IPv4单播地址族视图下,设置允许从对等体1.1.1.1收到的路由数量为10000。如果从对等体1.1.1.1收到的路由数量超过10000,则断开与该对等体的会话。
[Sysname] bgp 109
[Sysname-bgp-default-ipv4] peer 1.1.1.1 route-limit 10000
1.1.104  peer route-policy
peer route-policy命令用来对来自对等体/对等体组的路由或发布给对等体/对等体组的路由应用路由策略,以便对路由进行过滤、修改路由的属性等。
undo peer route-policy命令用来取消该配置。
undo peer { group-name | ipv4-address [ mask-length ] } route-policy { export | import }
BGP-VPN VPNv4地址族视图:
peer { group-name | ipv4-address [ mask-length ] } route-policy route-policy-name import
undo peer { group-name | ipv4-address [ mask-length ] } route-policy import
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy { export | import }
peer { group-name | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
undo peer { group-name | ipv6-address [ prefix-length ] } route-policy { export | import }
没有为对等体/对等体组指定路由策略。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP-VPN VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
route-policy-name:路由策略名称,为1~63个字符的字符串,区分大小写。
export:对向对等体/对等体组发布的路由应用路由策略。
import:对从对等体/对等体组接收的路由应用路由策略。
配置peer route-policy命令时需要同时在系统视图下通过route-policy命令配置对应的路由策略。如果本命令中指定的路由策略尚未创建,则所有路由均通过过滤。
通过本命令为向IBGP对等体/对等体组发布的路由应用路由策略时,如果指定的路由策略中包含修改BGP路由信息AS_PATH属性的apply字句,那么该子句不生效。
如果在本命令指定的路由策略中配置了if-match interface命令,则在路由过滤时忽略此匹配规则,认为所有路由均通过该规则。
# 在BGP IPv4单播地址族视图下,配置对向对等体组test发布的路由应用名为test-policy的路由策略。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test route-policy test-policy export
·     peer as-path-acl
·     peer prefix-list
1.1.105  peer route-update-interval
peer route-update-interval命令用来配置向指定对等体/对等体组发布同一路由的时间间隔。
undo peer route-update-interval命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-update-interval interval
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-update-interval
向IBGP对等体发布同一路由的时间间隔为15秒,向EBGP对等体发布同一路由的时间间隔为30秒。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
interval:发布同一路由的最小时间间隔,取值范围为0~600,单位为秒。
非缺省vSystem仅支持在BGP-VPN实例视图下配置本命令。
BGP路由发生变化时,BGP路由器会发送Update消息通知对等体。如果同一路由频繁变化,BGP路由器会频繁发送Update消息更新路由,导致路由震荡。通过本命令指定向对等体/对等体组发布同一路由的更新时间间隔,可以避免每次路由变化都发送Update消息,避免路由震荡。对于需要撤销的路由,BGP路由器会立即向邻居发送路由撤销消息,不受本命令的控制。
# 在BGP实例视图下,配置向对等体组test发布同一路由的时间间隔为10秒。
[Sysname] bgp 100
[Sysname-bgp-default] peer test route-update-interval 10
1.1.106  peer soo
peer soo命令用来为对等体/对等体组配置SoO(Site of Origin,源站点)属性。
undo peer soo命令用来取消为指定对等体/对等体组配置的SoO属性。
BGP IPv4单播地址族视图/BGP-VPN IPv4单播地址族视图/BGP-VPN VPNv4地址族视图/BGP IPv4组播地址族视图:
undo peer { group-name | ipv4-address [ mask-length ] } soo
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } soo
BGP-VPN IPv6单播地址族视图/BGP IPv6组播地址族视图:
peer { group-name | ipv6-address [ prefix-length ] } soo site-of-origin
undo peer { group-name | ipv6-address [ prefix-length ] } soo
没有为BGP对等体/对等体组配置SoO属性。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP-VPN VPNv4地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
site-of-origin:SoO扩展团体属性,为3~21个字符的字符串。site-of-origin有三种形式:
·     32位自治系统号:16位用户自定义数,其中的自治系统号最小值为65536。例如:65536:1。
PE使用不同接口连接同一站点的多个CE时,如果配置了BGP的AS号替换功能,则会导致路由环路。这种情况下,需要在PE上通过本命令为从同一站点不同CE学习到的路由添加相同的SoO属性,且PE向CE发布路由时检查SoO属性,如果路由的SoO属性与为CE配置的SoO属性相同,则不将该路由发布给CE,从而避免路由环路。
# 在BGP IPv4单播地址族视图下,为对等体1.1.1.1配置SoO属性为100:1。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 soo 100:1
·     peer substitute-as
1.1.107  peer source-address
peer source-address命令用来指定与对等体/对等体组创建BGP会话时建立TCP连接使用的源IPv4地址/IPv6地址。
undo peer source-address命令用来取消该配置。
peer ipv4-address [ mask-length ] source-address source-ipv4-address
peer ipv6-address [ prefix-length ] source-address source-ipv6-address
undo peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } source-address
peer group-name source-address { source-ipv4-address | source-ipv6-address } *
undo peer group-name source-address [ source-ipv4-address | source-ipv6-address ]
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
source-ipv4-address:源IPv4地址。
source-ipv6-address:源IPv6地址。
本命令的作用与peer connect-interface命令的作用类似:本命令直接指定建立TCP连接的源地址;peer connect-interface命令通过指定源接口,间接指定建立TCP连接的源地址。在一台BGP路由器上如果同时执行本命令和peer connect-interface命令,则后执行的配置覆盖之前的配置。
在如下场合需要通过本命令或peer connect-interface命令指定建立TCP连接使用的源地址:
本地路由器的源地址和对等体的源地址之间必须路由可达。
如果在EBGP对等体上指定非直连接口的地址作为源地址,则需要配置peer ebgp-max-hop命令允许本地路由器同非直连网络上的邻居建立EBGP连接。
可以为BGP对等体组同时指定source-ipv4-address和source-ipv6-address参数。本地路由器与对等体组中IPv4地址的对等体建立BGP会话时,采用source-ipv4-address作为TCP连接的源IPv4地址;本地路由器与对等体组中IPv6地址的对等体建立BGP会话时,采用source-ipv6-address作为TCP连接的源IPv6地址。
# 在BGP实例视图下,配置与对等体组test创建BGP会话时,TCP连接的源地址为1.1.1.1。
[Sysname] bgp 100
[Sysname-bgp-default] peer test source-address 1.1.1.1
·     peer connect-interface
·     peer ebgp-max-hop
1.1.108  peer substitute-as
peer substitute-as命令用来配置用本地AS号替换AS_PATH属性中指定对等体/对等体组的AS号。
undo peer substitute-as命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } substitute-as
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } substitute-as
不会用本地AS号替换AS_PATH属性中指定对等体/对等体组的AS号。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
如果物理位置不同的CE复用相同的AS号,则需要在PE上指定本端连接的CE设备配置BGP的AS号替换功能。配置AS号替换功能后,PE向指定对等体发布路由时,如果路由的AS_PATH属性中存在指定对等体所在的AS号,则PE将该AS号替换成PE的AS号后,再发布该路由,以保证私网路由能够正确发布。
# 在BGP实例视图下,配置用本地AS号替换对等体1.1.1.1的AS号。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 substitute-as
·     peer soo
1.1.109  peer timer
peer timer命令用来配置本地路由器与指定对等体/对等体组之间BGP会话的存活时间间隔和保持时间。
undo peer timer命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } timer keepalive keepalive hold holdtime
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } timer
本地路由器与指定对等体/对等体组之间BGP会话的存活时间间隔为60秒,保持时间为180秒。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
keepalive keepalive:指定存活时间间隔。keepalive的取值范围为0~21845,单位为秒。
hold holdtime:指定保持时间。holdtime的取值范围为0或3~65535,单位为秒。保持时间必须大于或等于存活时间的三倍。
使用该命令配置的定时器比使用timer命令配置的定时器优先级高。
如果当前路由器上配置的保持时间与对端设备(对等体)上配置的保持时间不一致,则数值较小者作为协商后的保持时间。
保持时间为0时,不向该对等体发送keepalive消息,与该对等体之间的会话永远不会超时断开;当保持时间和存活时间间隔都不为0时,将协商的保持时间的三分之一与配置的存活时间间隔比较,取最小值作为存活时间间隔。
配置该命令后,不会马上断开会话,而是等到其他条件触发会话重建(如复位BGP会话)时,再以配置的保持时间协商建立会话。
# 在BGP实例视图下,配置本地路由器与对等体组test之间BGP会话的存活时间间隔与保持时间分别为60秒和180秒。
[Sysname] bgp 100
[Sysname-bgp-default] peer test timer keepalive 60 hold 180
·     display bgp peer
·     timer
1.1.110  peer timer connect-retry
peer timer connect-retry命令用来配置本地路由器与指定对等体/对等体组之间重新建立BGP会话的时间间隔。
undo peer timer connect-retry命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } timer connect-retry retry-time
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } timer connect-retry
本地路由器与指定对等体/对等体组之间重新建立BGP会话的时间间隔为32秒。
BGP视图
BGP-VPN实例视图
context-admin
vsys-admin
retry-time:指定重新建立BGP会话的时间间隔,取值范围为1~65535,单位为秒。
如果要加快本地路由器与指定对等体/对等体组之间重新建立BGP会话的速度,可以将retry-time的值调小,便于路由快速收敛。如果BGP会话反复up/down,可以将retry-time的值调大,从而减轻路由震荡。
使用本命令配置的定时器比使用timer connect-retry命令配置的定时器优先级高。
# 在BGP实例视图下,配置本地路由器与对等体1.1.1.1之间重新建立BGP会话的时间间隔为30秒。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 timer connect-retry 30
·     timer connect-retry
1.1.111  peer ttl-security
peer ttl-security命令用来使能对等体/对等体组的BGP GTSM(Generalized TTL Security Mechanism,通用TTL安全保护机制)功能。
undo peer ttl-security命令用来关闭指定对等体/对等体组的BGP GTSM功能。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ttl-security hops hop-count
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ttl-security hops
BGP GTSM功能处于关闭状态。
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
hops hop-count:指定本地设备到达指定对等体的最大跳数。hop-count表示最大跳数,取值范围为1~254。
执行本命令为对等体/对等体组使能BGP报文的GTSM安全检测功能后,当设备收到指定对等体发送的BGP报文时,会判断报文的TTL是否在255-“hop-count”+1到255之间。如果在,则上送CPU处理;如果不在,则直接丢弃报文。从而,使设备能够避免受到CPU利用(CPU-utilization)类型的攻击(如CPU过载),增强系统的安全性。
执行本命令后,设备会将发送报文的初始TTL设置为255。
配置本命令后,只要本地设备和指定的对等体通过了GTSM检查,就允许在二者之间建立EBGP会话,不管二者之间的跳数是否超过peer ebgp-max-hop命令指定的跳数范围。
使用BGP GTSM功能时,要求本设备和对等体设备上同时配置本特性,指定的hop-count值可以不同,只要能够满足合法性检查即可。
# 在BGP实例视图下,为已经创建的对等体组test使能BGP GTSM功能,并指定对等体组中的对等体到达本地设备的最大跳数为1。
[Sysname] bgp 100
[Sysname-bgp-default] peer test ttl-security hops 1
·     peer ebgp-max-hop
1.1.112  pic
pic命令用来开启当前地址族的BGP快速重路由功能。
undo pic命令用来关闭当前地址族的BGP快速重路由功能。
pic
undo pic
BGP快速重路由功能处于关闭状态。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
context-admin
vsys-admin
FRR(Fast Reroute,快速重路由)功能用来在双归属的组网环境下,通过为流量转发的主路由指定备份下一跳,并通过ARP(IPv4组网)、BFD(IPv4组网)或ND(IPv6组网)检测主路由的状态,实现主路由出现故障时,将流量迅速切换到备份路径,大大缩短了故障恢复时间。
通过本命令开启当前地址族的BGP快速重路由功能后,BGP会为当前地址族的所有BGP路由自动计算备份下一跳,即只要从不同BGP对等体学习到了到达同一目的网络的路由,且这些路由不等价,就会生成主备两条路由。
除了执行本命令外,执行fast-reroute route-policy命令指定BGP快速重路由引用的路由策略,也可以开启快速重路由功能。该方式的优先级高于本命令。路由策略的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
在某些组网情况下,执行pic命令为所有BGP路由生成备份下一跳后,可能会导致路由环路,请谨慎使用本命令。
# 开启IPv4单播地址族的BGP快速重路由功能。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] pic
·     fast-reroute route-policy
1.1.113  preference
preference命令用来配置BGP路由的优先级。
undo preference命令用来恢复缺省情况。
undo preference
EBGP路由的优先级为255,IBGP路由的优先级为255,本地产生的BGP路由的优先级为130。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
context-admin
vsys-admin
external-preference:EBGP路由(从EBGP对等体学来的路由)的优先级,取值范围为1~255,数值越小代表路由的优先级越高。
internal-preference:IBGP路由(从IBGP对等体学来的路由)的优先级,取值范围为1~255,数值越小代表路由的优先级越高。
local-preference:本地产生的BGP路由的优先级,取值范围为1~255,数值越小代表路由的优先级越高。
route-policy route-policy-name:根据路由策略设置路由的优先级。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。指定本参数后,可以为通过路由策略中匹配条件过滤的特定路由设置优先级,没有通过过滤的路由使用缺省的优先级。
本命令用来设置BGP路由的优先级,以改变BGP路由被选为最优路由的可能性。
根据路由策略设置路由的优先级时,需要在指定的路由策略中通过apply preference命令配置路由的优先级。如果没有在路由策略中配置apply preference命令,则通过匹配规则过滤的路由使用缺省的优先级。
# 在BGP IPv4单播地址族视图下,配置EBGP路由、IBGP路由和本地产生的BGP路由的优先级分别为20、20和200。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] preference 20 20 200
1.1.114  primary-path-detect bfd
primary-path-detect bfd命令用来配置BGP快速重路由通过BFD会话检测主路由的下一跳是否可达。
undo primary-path-detect bfd命令用来恢复缺省情况。
primary-path-detect bfd { ctrl | echo }
BGP快速重路由通过ARP检测主路由的下一跳是否可达。
BGP实例视图
context-admin
ctrl:配置通过控制报文方式的BFD会话检测主路由的下一跳是否可达。
echo:配置通过Echo方式的BFD会话检测主路由的下一跳是否可达。
非缺省vSystem不支持本命令。
配置本命令后,设备会自动创建一个协议类型为IPFRR的BFD会话,通过该BFD会话对主路由的下一跳检测,以提高主路由下一跳失效时,流量切换到备路由下一跳上的收敛速度。
只有存在已经生成了备份下一跳的主路由时,本命令才会生效并自动创建BFD会话。
由于BGP暂不支持为负载分担路由计算备份下一跳,本命令无法为等价路由作为主路由的场景提供通过BFD会话检测功能。
通过控制报文方式的BFD会话检测主路由的下一跳是否可达时,由于控制报文方式的BFD会话需要两端进行协商才能成功建立,如需设备成功使用控制报文方式的BFD会话来检测主链路的下一跳,可以通过以下两种方式进行配置:
·     在主链路的对端设备上也执行primary-path-detect bfd命令。此方式适用于主链路两端设备均配置快速重路由功能的场景。
·     在主链路的对端设备上手工创建一个静态BFD会话,该静态BFD会话指定的会话源IP地址为本端自动创建的BFD会话的会话目的IP地址、会话目的IP地址为本端自动创建的BFD会话的源IP地址、远端标识符为本端自动创建的BFD会话的本地标识符。
其他业务模块在通过BFD会话检测主路由的下一跳是否可达时,也会自动创建BFD会话(如OSPF、IS-IS等)。如果其他协议创建的自动BFD会话检测的链路与BGP主路由下一跳所在的链路相同,则BGP不会重复自动创建同类型的BFD会话,而是复用其他协议的BFD会话。
多次执行本命令时,以最后一次执行的命令为准。
# 在BGP实例视图下,配置BGP快速重路由通过Echo方式的BFD会话检测主路由的下一跳是否可达。
[Sysname] bgp 100
[Sysname-bgp-default] primary-path-detect bfd echo
·     pic
1.1.115  reflect between-clients
reflect between-clients命令用来允许路由反射器在客户机之间反射路由。
undo reflect between-clients命令用来禁止路由反射器在客户机之间反射路由。
允许路由反射器在客户机之间反射路由。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP LS地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
BGP IPv4 MDT地址族视图
BGP IPv4 MVPN地址族视图
context-admin
vsys-admin
如果配置了路由反射器后,由于组网需要在路由反射器的客户机之间建立了全连接,则客户机之间可以直接交换路由信息,客户机到客户机之间的路由反射是没有必要的。此时,不需要修改网络配置或改变网络拓扑,只需在路由反射器上通过本命令禁止其在客户机之间反射路由,就可以避免路由反射,减少占用的带宽资源。
# 在BGP IPv4单播地址族视图下,禁止路由反射器在客户机之间反射路由。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] undo reflect between-clients
·     peer reflect-client
1.1.116  reflect change-path-attribute
reflect change-path-attribute命令用来配置允许路由反射器反射路由时修改路由属性。
undo reflect change-path-attribute命令用来恢复缺省情况。
不允许路由反射器反射路由时修改路由属性。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP VPNv6地址族视图
context-admin
在某些场景下,需要执行本配置,允许路由反射器在出方向修改路由属性。例如通过路由反射器实现分层VPN时,需要在路由反射器上改变路由下一跳并分配标签。
在路由反射器上配置本命令后,设备上所有在出方向上修改路由属性的配置均可生效。
# 在BGP IPv4单播地址族视图下,配置允许路由反射器反射路由时修改路由属性。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] reflect change-path-attribute
1.1.117  reflector cluster-id
reflector cluster-id命令用来配置路由反射器的集群ID。
undo reflector cluster-id命令用来恢复缺省情况。
每个路由反射器都使用自己的Router ID作为集群ID。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP VPNv4地址族视图
BGP IPv6单播地址族视图
BGP LS地址族视图
BGP VPNv6地址族视图
BGP IPv4组播地址族视图
BGP IPv6组播地址族视图
BGP IPv4 MDT地址族视图
BGP IPv4 MVPN地址族视图
context-admin
vsys-admin
cluster-id:指定数值形式的集群ID,取值范围为1~4294967295。
ipv4-address:指定点分十进制地址形式的集群ID。
路由反射器及其客户机形成了一个集群。通常情况下,一个集群中只有一个路由反射器,该反射器的Router ID就作为集群ID,用于识别该群。
为了提高网络的可靠性、避免单点故障,一个集群中可以设置多个路由反射器。此时,应使用本命令为集群中所有路由反射器配置相同的集群ID,以便集群具有统一的标识,避免路由环路的产生。
配置的集群ID不要与客户机的Router ID相同。
# 在BGP IPv4单播地址族视图下,本地路由器是集群中的路由反射器之一,在本地路由器上配置集群ID为80。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] reflector cluster-id 80
1.1.118  refresh bgp
refresh bgp命令用来手工对BGP会话进行软复位。
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 [ multicast | mvpn | rtfilter | sr-policy | [ flowspec | unicast ] [ vpn-instance vpn-instance-name ] ]
refresh bgp [ instance instance-name ] { ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } ipv6 [ multicast | [ flowspec | unicast ] [ vpn-instance vpn-instance-name ] | sr-policy ]
refresh bgp [ instance instance-name ] ipv6-address [ prefix-length ] { export | import } ipv4 flowspec [ vpn-instance vpn-instance-name ]
refresh bgp [ instance instance-name ] ipv4-address [ mask-length ] { export | import } ipv6 [ unicast ]
refresh bgp [ instance instance-name ] ipv4-address [ mask-length ] { export | import } ipv6 flowspec [ vpn-instance vpn-instance-name ]
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } link-state
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } vpnv4 vpn-instance vpn-instance-name
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } { vpnv4 | vpnv6 } [ flowspec ]
context-admin
vsys-admin
instance instance-name:软复位指定BGP实例内的BGP会话。instance-name表示BGP实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示软复位BGP实例default内的BGP会话。
ipv4-address:软复位与指定对等体的BGP会话。ipv4-address为对等体的IPv4地址。
ipv6-address:软复位与指定对等体的BGP会话。ipv6-address为对等体的IPv6地址。
prefix-length:前缀长度,取值范围为0~128。如果指定本参数,则表示指定网段内的动态对等体。
all:软复位指定地址族下的所有BGP会话。
external:软复位指定地址族下的所有EBGP会话。
group group-name:软复位与指定对等体组中对等体的BGP会话。group-name表示对等体组的名称,为1~47个字符的字符串,区分大小写。
internal:软复位指定地址族下的所有IBGP会话。
export:触发出方向的软复位,即采用新的配置对向对等体发布的路由进行过滤。
import:触发入方向的软复位,即采用新的配置对从对等体接收的路由进行过滤。
ipv4:软复位IPv4地址族下的BGP会话。
ipv6:软复位IPv6地址族下的BGP会话。
link-state:软复位LS地址族下的BGP会话。
multicast:软复位组播地址族下的BGP会话。
mvpn:软复位BGP IPv4 MVPN地址族下的BGP会话。
rtfilter:软复位IPv4 RT-Filter地址族下的BGP会话。
unicast:软复位单播地址族下的BGP会话。
vpnv4:软复位VPNv4地址族下的BGP会话。
vpnv6:软复位VPNv6地址族下的BGP会话。
flowspec:软复位Flowspec地址族下的BGP会话。
vpn-instance vpn-instance-name:软复位指定VPN实例内指定地址族下的BGP会话。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则软复位公网指定地址族下的BGP会话。
sr-policy:软复位SR Policy地址族下的BGP会话。
非缺省vSystem仅支持软复位IPv4和IPv6单播地址族下的BGP会话。
软复位BGP会话是指在不断开BGP邻居关系的情况下,更新BGP路由信息,使新的配置生效。
选路策略发生改变后,如果指定了export参数,则会触发本地路由器根据新的路由发布策略过滤路由信息,并将通过过滤的路由信息发送给BGP对等体;如果指定了import参数,则本地路由器会向BGP对等体发送Route-refresh消息,收到Route-refresh消息的对等体将其路由信息重新发给本地路由器,以便本地路由器根据新的路由策略对接收到的路由信息进行过滤。
执行本命令软复位BGP会话时,要求当前路由器和对等体都支持Route-refresh功能,否则本命令不会生效。
配置peer keep-all-routes命令后,执行refresh bgp import命令不会生效。
如果没有指定unicast、multicast、rtfilter和flowspec参数,则缺省为unicast。
# 手工对所有IPv4单播地址族下的BGP会话进行入方向的软复位。
<Sysname> refresh bgp all import ipv4
1.1.119  reset bgp
reset bgp命令用来复位指定地址族下的BGP会话。
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 [ mdt | multicast | mvpn | rtfilter | sr-policy | [ flowspec | unicast ] [ vpn-instance vpn-instance-name ] ]
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 [ multicast | [ flowspec | unicast ] [ vpn-instance vpn-instance-name ] | sr-policy ]
reset bgp [ instance instance-name ] ipv6-address [ prefix-length ] ipv4 flowspec [ vpn-instance vpn-instance-name ]
reset bgp [ instance instance-name ] ipv4-address [ mask-length ] ipv6 [ unicast ]
reset bgp [ instance instance-name ] ipv4-address [ mask-length ] ipv6 flowspec [ vpn-instance vpn-instance-name ]
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } link-state
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } vpnv4 vpn-instance vpn-instance-name
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { vpnv4 | vpnv6 } [ flowspec ]
context-admin
vsys-admin
instance instance-name:复位指定BGP实例内的BGP会话。instance-name表示BGP实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示复位BGP实例default内的BGP会话。
as-number:复位与指定自治系统内对等体的BGP会话。as-number为自治系统号,取值范围为1~4294967295。
ipv4-address:复位与指定对等体的BGP会话。ipv4-address为对等体的IPv4地址。
ipv6-address:复位与指定对等体的BGP会话。ipv6-address为对等体的IPv6地址。
all:复位指定地址族下的所有BGP会话。
external:复位指定地址族下的所有EBGP会话。
group group-name:复位与指定对等体组中对等体的BGP会话。group-name表示对等体组的名称,为1~47个字符的字符串,区分大小写。
internal:复位指定地址族下的所有IBGP会话。
ipv4:复位IPv4地址族下的BGP会话。
ipv6:复位IPv6地址族下的BGP会话。
link-state:复位LS地址族下的BGP会话。
mdt:复位MDT地址族下的BGP会话。
multicast:复位组播地址族下的BGP会话。
rtfilter:复位IPv4 RT-Filter地址族下的BGP会话。
sr-policy:复位SR Policy地址族下的BGP会话。
unicast:复位单播地址族下的BGP会话。
vpnv4:复位VPNv4地址族下的BGP会话。
vpnv6:复位VPNv6地址族下的BGP会话。
flowspec:复位Flowspec地址族下的BGP会话。
vpn-instance vpn-instance-name:复位指定VPN实例内指定地址族下的BGP会话。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则复位公网指定地址族下的BGP会话。
复位BGP会话时,会造成短暂的BGP会话中断。
非缺省vSystem仅支持复位IPv4和IPv6单播地址族下的BGP会话。
BGP的选路策略改变后,为了使新的策略生效,可以复位BGP会话,即删除并重新建立BGP会话,以便重新发布路由信息,并应用新的策略对路由信息进行过滤。
如果没有指定unicast、mdt、mvpn、multicast、rtfilter、flowspec和sr-policy参数,则缺省为unicast。
# 复位公网IPv4单播地址族下的所有BGP会话。
<Sysname> reset bgp all ipv4
1.1.120  reset bgp all
reset bgp all命令用来复位所有BGP会话。
context-admin
vsys-admin
# 复位所有BGP会话。
1.1.121  reset bgp dampening
reset bgp dampening命令用来清除BGP路由的衰减信息,并解除对BGP路由的抑制。
reset bgp [ instance instance-name ] dampening ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address [ mask-length | mask ] ]
reset bgp [ instance instance-name ] dampening ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length ]
reset bgp [ instance instance-name ] dampening vpnv4 [ ipv4-address [ mask | mask-length ] ]
context-admin
vsys-admin
instance instance-name:清除指定BGP实例的BGP路由衰减信息,并解除对指定BGP实例的BGP路由的抑制。instance-name表示BGP实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示default实例。
ipv4:清除BGP IPv4路由的衰减信息,并解除对BGP IPv4路由的抑制。
ipv6:清除BGP IPv6路由的衰减信息,并解除对BGP IPv6路由的抑制。
vpnv4:清除IBGP VPNv4路由的衰减信息,并解除对IBGP VPNv4路由的抑制。非缺省vSystem不支持本参数。
multicast:清除BGP组播路由的衰减信息,并解除对BGP组播路由的抑制。非缺省vSystem不支持本参数。
unicast:清除BGP单播路由的衰减信息,并解除对BGP单播路由的抑制。
vpn-instance vpn-instance-name:清除指定VPN实例内BGP路由的衰减信息,并解除对BGP路由的抑制。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除公网BGP路由的衰减信息,并解除对BGP路由的抑制。
ipv4-address:清除匹配指定目的网络IPv4地址的BGP路由的衰减信息,并解除对该路由的抑制。如果不指定本参数,则清除所有BGP路由的衰减信息,并解除对所有BGP路由的抑制。
mask-length:目的网络IPv4地址的掩码长度,取值范围为0~32。
mask:目的网络IPv4地址的掩码,点分十进制格式。
ipv6-address:清除匹配指定目的网络IPv6地址的BGP路由的衰减信息,并解除对该路由的抑制。如果不指定本参数,则清除所有BGP路由的衰减信息,并解除对所有BGP路由的抑制。
prefix-length:目的网络IPv6地址的前缀长度,取值范围为0~128。
执行reset bgp dampening ipv4命令时:
·     如果只指定了ipv4-address参数,则将指定的网络地址和路由的掩码进行与操作,若计算结果与路由的网段地址相同,则清除该BGP IPv4单播路由或组播路由的衰减信息,并解除对该路由的抑制。
·     如果指定了ipv4-address mask或ipv4-address mask-length参数,则清除与指定目的网络IPv4地址和网络掩码(或掩码长度)精确匹配的BGP IPv4单播路由或组播路由的衰减信息,并解除对该路由的抑制。
如果没有指定unicast和multicast参数,则缺省为unicast。
# 清除到达网络20.1.0.0/16的BGP IPv4单播路由的衰减信息,并解除对该路由的抑制。
<Sysname> reset bgp dampening ipv4 20.1.0.0 255.255.0.0
·     dampening
·     dampening ibgp(MPLS命令参考/MPLS L3VPN)
·     display bgp routing-table dampened
1.1.122  reset bgp flap-info
reset bgp flap-info命令用来清除BGP路由的震荡统计信息。
reset bgp [ instance instance-name ] flap-info ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv4-address [ mask-length | mask ] | as-path-acl as-path-acl-number | peer ipv4-address [ mask-length ] ]
reset bgp [ instance instance-name ] flap-info ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ] [ ipv6-address prefix-length | as-path-acl as-path-acl-number | peer ipv6-address [ prefix-length ] ]
reset bgp [ instance instance-name ] flap-info vpnv4 [ ipv4-address [ mask | mask-length ] | as-path-acl as-path-acl-number | peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ]
context-admin
vsys-admin
instance instance-name:清除指定BGP实例的BGP路由震荡统计信息。instance-name表示BGP实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示清除default实例的BGP路由震荡统计信息。
ipv4:清除BGP IPv4路由的震荡统计信息。
ipv6:清除BGP IPv6路由的震荡统计信息。
vpnv4:清除IBGP VPNv4路由的震荡统计信息。非缺省vSystem不支持本参数。
multicast:清除BGP组播路由的震荡统计信息。非缺省vSystem不支持本参数。
unicast:清除BGP单播路由的震荡统计信息。
vpn-instance vpn-instance-name:清除指定VPN实例内BGP路由的震荡统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除公网BGP路由的震荡统计信息。
ipv4-address:清除匹配指定目的网络IPv4地址的BGP路由的震荡统计信息。
ipv6-address:清除匹配指定目的网络IPv6地址的BGP路由的震荡统计信息。
as-path-acl as-path-acl-number:清除匹配指定AS路径过滤列表的BGP路由的震荡统计信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
peer ipv4-address [ mask-length ]:清除从指定BGP对等体学习到的BGP路由的震荡统计信息。ipv4-address为BGP对等体的IPv4地址。mask-length为网络掩码,取值范围为0~32,如果指定本参数,则表示指定网段内的动态对等体。
peer ipv6-address [ prefix-length ]:清除从指定BGP对等体学习到的BGP路由的震荡统计信息。ipv6-address为对等体的IPv6地址。prefix-length为前缀长度,取值范围为0~128,如果指定本参数,则表示指定网段内的动态对等体。
执行reset bgp flap-info ipv4命令时:
·     如果只指定了ipv4-address参数,则将指定的网络地址和路由的掩码进行与操作,若计算结果与路由的网段地址相同,则清除该BGP IPv4单播路由或组播路由的震荡统计信息。
·     如果指定了ipv4-address mask或ipv4-address mask-length参数,则清除与指定目的网络IPv4地址和网络掩码(或掩码长度)精确匹配的BGP IPv4单播路由或组播路由的震荡统计信息。
# 清除到达网络20.1.0.0/16的BGP IPv4单播路由的震荡统计信息。
<Sysname> reset bgp flap-info ipv4 20.1.0.0 16
·     dampening
·     display bgp routing-table flap-info
1.1.123  retain local-label
retain local-label命令用来配置删除本地标签的延迟时间。
undo retain local-label命令用来恢复缺省情况。
retain local-label retain-time
删除本地标签的延迟时间为60秒。
BGP实例视图
context-admin
retain-time:删除本地标签的延迟时间,取值范围为1~21845,单位为秒。
非缺省vSystem不支持本命令。
本地标签是指本地设备通过VPNv4路由、VPNv6路由、带标签的IPv4单播路由或带标签的IPv6单播路由分配给其他BGP对等体的MPLS标签。为路由分配的本地标签发生变化时,如果立即删除本地标签,则BGP对等体可能尚未收到新的标签,仍然采用旧的标签转发报文,从而导致流量中断。为了避免上述情况发生,BGP需要延迟一段时间再删除本地标签。通过本命令可以调整本地标签的延迟删除时间。
# 配置删除本地标签的延迟时间为100秒。
[Sysname] bgp 100
[Sysname-bgp-default] retain local-label 100
1.1.124  router id
router id命令用来配置全局Router ID。
undo router id命令用来恢复缺省情况。
router id router-id
undo router id
未配置全局Router ID。
context-admin
router-id:全局Router ID,用IP地址的形式标识。
非缺省vSystem不支持本命令。
一些动态路由协议要求使用Router ID,如果在启动这些路由协议时没有指定Router ID,则缺省使用全局Router ID。
如果配置了全局Router ID,则使用配置的值作为Router ID。如果未配置全局Router ID,则按照下面的规则进行选择:
(1)     如果存在配置IP地址的Loopback接口,则选择Loopback接口地址中最大的作为Router ID。
(2)     如果未配置IP地址的Loopback接口,则从其他接口的IP地址中选择最大的作为Router ID(不考虑接口的up/down状态)。
(3)     如果所有接口上都未配置IP地址,则Router ID为无效值0.0.0.0,BGP不能使用该Route ID来建立BGP会话。
存在主备的情况下,系统将备份命令行配置的Router ID或从接口地址中选择出来的Router ID。主备倒换后,系统将检查从地址中选出的Router ID的有效性,如果无效将重新进行选择。
当且仅当被选为Router ID的接口IP地址被删除或被修改时,才触发重新选择过程,其他情况(例如:接口down;已经选取了一个非Loopback接口地址后又配置了一个Loopback接口地址;配置一个更大的接口地址等)不触发重新选择的过程。
全局Router ID改变后,执行reset命令重启BGP会话,不会改变BGP路由器的Router ID。只能在BGP实例视图下通过Router ID命令改变BGP路由器的Router ID。
# 配置全局Router ID为1.1.1.1。
[Sysname] router id 1.1.1.1
·     router-id (BGP instance view)
·     router-id (BGP-VPN instance view)
1.1.125  router-id (BGP instance view)
router-id命令用来为指定的BGP实例配置BGP路由器的Router ID。
undo router-id命令用来恢复缺省情况。
router-id router-id
undo router-id
未配置BGP路由器在BGP实例内的Router ID,为系统视图下通过router id命令配置的全局Router ID。
BGP实例视图
context-admin
router-id:BGP路由器的Router ID,用IP地址的形式标识。
非缺省vSystem不支持本命令。
如果要在BGP实例下运行BGP协议,则必须为BGP实例指定Router ID。它是一个32比特无符号整数,是一台路由器在自治系统中的唯一标识。
BGP路由器的Router ID一旦确定为非零值后不会随着系统视图下router id命令配置的改变而改变。只能在BGP实例视图下通过router-id命令改变BGP路由器的Router ID。
为了增加网络的可靠性,建议将Router ID手工配置为Loopback接口的IP地址。
在同一个视图下多次执行本命令,最后一次执行的命令生效。
不同BGP实例的Router ID可以相同。
# 在BGP实例视图下,指定BGP路由器的Router ID为1.1.1.1。
[Sysname] bgp 100
[Sysname-bgp-default] router-id 1.1.1.1
·     router id
1.1.126  router-id (BGP-VPN instance view)
router-id命令用来为指定的VPN实例配置BGP路由器的Router ID。
undo router-id
未配置BGP路由器在VPN实例内的Router ID。如果在BGP实例视图下执行了router-id命令,则BGP路由器在VPN实例内的Router ID为该命令配置的Router ID;否则,为系统视图下通过router id命令配置的全局Router ID。
BGP-VPN实例视图
context-admin
vsys-admin
auto-select:自动选取该VPN实例内BGP路由器的Router ID。
一个BGP实例如果要在某个VPN实例内运行BGP协议,则必须为其指定在该VPN实例内的Router ID。Router ID是一个32比特无符号整数,是一台路由器在自治系统中的唯一标识。
执行router-id auto-select命令后,该VPN实例内BGP路由器的Router ID选取原则为:
(1)     如果存在属于当前VPN实例、且已配置IP地址的Loopback接口,则选择Loopback接口地址中最大的作为Router ID。
(2)     如果不存在满足上述条件的Loopback接口,则从其他属于当前VPN实例的接口中,选择最大的接口IP地址作为Router ID(不考虑接口的up/down状态)。
(3)     如果不存在属于当前VPN实例的接口地址,则Router ID为无效值0.0.0.0,BGP不能使用该Route ID来建立BGP会话。
当前VPN实例内BGP路由器的Router ID一旦确定为非零值,即使存在满足选取原则的更优的接口地址,系统也不会重新选择Router ID。
在同一台设备上,可以为不同的VPN实例指定不同的Router ID。
# 在BGP-VPN实例视图下,指定VPN实例vpn1内BGP路由器的Router ID为1.1.1.1。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] router-id 1.1.1.1
·     router id
1.1.127  shutdown process
shutdown process命令用来配置BGP shutdown功能,禁止与所有对等体/对等体组建立会话。
undo shutdown process命令用来恢复缺省情况。
shutdown process
设备允许与所有BGP对等体/对等体组建立会话。
BGP实例视图
context-admin
由于网络升级维护等原因,需要暂时断开与所有对等体/对等体组的BGP会话时,可以通过shutdown process命令禁止与所有对等体/对等体组建立BGP会话。当网络恢复后,通过执行undo shutdown process命令恢复与所有对等体/对等体组的BGP会话。这样,网络管理员在网络升级维护过程中,无需删除并重新进行对等体/对等体组相关配置,减少了网络维护的工作量。
如果本设备和对等体/对等体组的会话已经建立,则执行shutdown process命令后,会断开本设备和对等体/对等体组的会话,并清除所有路由信息。
同时配置本命令和peer ignore命令时,若任一命令禁止与所有或指定对等体/对等体组建立会话,则设备不能与相应的对等体/对等体组建立BGP会话。
# 在BGP实例视图下,配置禁止与所有对等体/对等体组建立会话,将BGP进程从当前网络中隔离出来。
[Sysname] bgp 100
[Sysname-bgp-default] shutdown process
1.1.128  snmp context-name
snmp context-name命令用来配置BGP实例的SNMP上下文。
未配置BGP实例的SNMP上下文。
BGP实例视图
context-admin
context-name:SNMP上下文名称,为1~32个字符的字符串,区分大小写。
非缺省vSystem不支持本命令。
通过MIB(Management Information Base,管理信息库)节点对BGP进行管理时,BGP无法获知被管理的节点属于哪个BGP实例。为不同的BGP实例配置不同的SNMP上下文可以解决上述问题。
·     对于SNMPv3报文:
¡     如果报文中不携带上下文,且没有为default实例配置SNMP上下文,则对BGP default实例的MIB节点进行相应处理。
¡     如果报文中携带上下文,设备上存在对应的SNMP上下文(通过系统视图下的snmp-agent context命令创建),且该上下文与为某一个BGP实例配置的上下文相同,则对该BGP实例的MIB节点进行相应处理。
¡     其他情况下,不允许对任何MIB节点进行处理。
·     对于SNMPv1/v2c报文:
¡     如果设备上没有通过系统视图下的snmp-agent community-map命令将报文中的团体名映射为SNMP上下文,且没有为default实例配置SNMP上下文,则对BGP default实例的MIB节点进行相应处理。
¡     如果设备上将团体名映射为SNMP上下文,设备上存在对应的SNMP上下文,且该上下文与为某一个BGP实例配置的上下文相同,则对该BGP实例的MIB节点进行相应处理。
SNMP上下文和团体名的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
为不同BGP实例配置的SNMP上下文不能相同。
在同一个BGP实例下多次执行本命令,最后一次执行的命令生效。
# 配置BGP实例abc的SNMP上下文为bgp-abc。
[Sysname-bgp-abc] snmp context-name bgp-abc
·     snmp-agent context(网络管理和监控命令参考/SNMP)
·     snmp-agent community-map(网络管理和监控命令参考/SNMP)
1.1.129  snmp-agent trap enable bgp
snmp-agent trap enable bgp命令用来开启BGP模块的告警功能。
undo snmp-agent trap enable bgp命令用来关闭BGP模块的告警功能。
snmp-agent trap enable bgp [ instance instance-name ]
undo snmp-agent trap enable bgp [ instance instance-name ]
BGP模块的告警功能处于开启状态。
context-admin
instance instance-name:开启指定BGP实例的告警功能。instance-name表示BGP实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示开启default实例的BGP告警功能。
非缺省vSystem不支持本命令。
开启BGP模块的告警功能后,当BGP的邻居状态变化时BGP会产生RFC 4273中规定的告警信息,该信息包含邻居地址、最近一次出现错误的错误码和错误子码、当前的邻居状态。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 开启BGP告警功能。
[Sysname] snmp-agent trap enable bgp
1.1.130  summary automatic
summary automatic命令用来配置对引入的IGP子网路由进行自动聚合。
undo summary automatic命令用来恢复缺省情况。
summary automatic
不对引入的IGP子网路由进行自动聚合。
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP IPv4组播地址族视图
context-admin
vsys-admin
非缺省vSystem仅支持在BGP-VPN IPv4单播地址族视图下配置本命令。
配置summary automatic命令后,BGP将对通过import-route命令引入的IGP子网路由进行聚合,从而减少路由信息的数量。
自动聚合生成的路由可以参与手动聚合。
自动聚合生成的路由不会加入到IP路由表中。
# 在BGP IPv4单播地址族视图下,对引入的IGP子网路由进行自动聚合。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] summary automatic
·     aggregate
·     import-route
1.1.131  timer
timer命令用来配置BGP会话的存活时间间隔和保持时间。
undo timer命令用来恢复缺省情况。
undo timer
BGP实例视图
BGP-VPN实例视图
context-admin
vsys-admin
keepalive keepalive:指定BGP会话的存活时间间隔。keepalive取值范围为0~21845,单位为秒。
hold holdtime:指定BGP会话的保持时间。holdtime取值范围为0或3~65535,单位为秒。保持时间必须大于或等于存活时间的三倍。
timer命令用来配置本地路由器与所有对等体之间BGP会话的存活时间间隔和保持时间;peer timer命令用来配置本地路由器与指定对等体之间BGP会话的存活时间间隔和保持时间。如果同时配置了二者,则使用timer命令配置的定时器比使用peer timer命令配置的定时器优先级要低。
保持时间为0时,不向该对等体发送Keepalive消息,与该对等体之间的会话永远不会超时断开;当保持时间和存活时间间隔都不为0时,将协商的保持时间的三分之一与配置的存活时间间隔比较,取最小值作为存活时间间隔。
配置timer命令后,不会影响已建立的BGP会话,只对新建立的会话生效。
配置timer命令后,不会马上断开会话,而是等到其他条件触发会话重建(如复位BGP会话)时,再以配置的保持时间协商建立会话。
# 在BGP实例视图下,配置BGP会话的存活时间间隔和保持时间分别为60秒和180秒。
[Sysname] bgp 100
[Sysname-bgp-default] timer keepalive 60 hold 180
·     display bgp peer
·     peer timer
1.1.132  timer connect-retry
timer connect-retry命令用来配置本地路由器与所有对等体/对等体组之间重新建立BGP会话的时间间隔。
undo timer connect-retry命令用来恢复缺省情况。
本地路由器与所有对等体/对等体组之间重新建立BGP会话的时间间隔为32秒。
BGP视图
context-admin
vsys-admin
使用本命令配置的定时器比使用peer timer connect-retry命令配置的定时器优先级要低。
# 在BGP实例视图下,配置本地路由器与所有对等体之间重新建立BGP会话的时间间隔为30秒。
[Sysname] bgp 100
[Sysname-bgp-default] timer connect-retry 30
·     peer timer connect-retry
