20-网络管理与监控
21-SNMP-TARGET-MIB
本章节下载 21-SNMP-TARGET-MIB  (187.66 KB)
21-SNMP-TARGET-MIB
SNMP-TARGET-MIB
功能介绍
SNMP-TARGET-MIB提供了为SNMP实体确定消息的发送目标和相关SNMP参数的通用方法。应用程序可以通过查询该表,获取远端SNMP实体的传输域、用户名和安全级别等信息,然后发送消息。
snmpTargetAddrTable同snmpTargetParamsTable联合使用,用于创建目的主机,并且应该注意如下规则:
● 一个有效的目的主机需要在snmpTargetAddrTable产生一条实例,并同时在snmpTargetParamsTable中也产生一条实例;
● snmpTargetAddrName的实例值与snmpTargetAddrParams的实例值相同;
● snmpTargetAddrParams的实例值与snmpTargetParamsName的实例值相同;
● snmpTargetAddrName实例值的格式为:traphost+snmpTargetParamsSecurityName+IpAddress+VPNInstancename。其中的IpAddress是snmpTargetAddrTAddress值中的IP部分。如果不支持VPN那么不需要填写VPNInstancename;
● snmpTargetAddrTagList的实例值中必须 “TrapHost”或者“InformHost”;
● snmpTargetAddrStorageType实例值应该是nonVolatile;
● snmpTargetParamsSecurityName在snmpTargetAddrParams中的取值范围是1~32个字节;
● VPNInstancename在snmpTargetAddrParams中的取值范围是1~31个字节。
***** SNMP QUERY STARTED *****
1: [Loaded: SNMPv2-TM] snmpTargetAddrTDomain.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (object identifier) snmpUDPDomain
2: snmpTargetAddrTAddress.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (octet string) A9.FE.4C.4C.00.A2 (hex)
3: snmpTargetAddrTimeout.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) 1500
4: snmpTargetAddrRetryCount.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) 3
5: snmpTargetAddrTagList.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (octet string) TrapHost [54.72.61.70.48.6F.73.74 (hex)]
6: snmpTargetAddrParams.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (octet string) traphost.gl.169.254.76.76 [74.72.61.70.68.6F.73.74.2E.67.6C.2E.31.36.39.2E.32.35.34.2E.37.36.2E.37.36 (hex)]
7: snmpTargetAddrStorageType.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) nonVolatile(3)
8: snmpTargetAddrRowStatus.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) active(1)
9: snmpTargetParamsMPModel.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) 0
10: snmpTargetParamsSecurityModel.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) 1
11: snmpTargetParamsSecurityName.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (octet string) gl [67.6C (hex)]
12: snmpTargetParamsSecurityLevel.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) noAuthNoPriv(1)
13: snmpTargetParamsStorageType.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) nonVolatile(3)
14: snmpTargetParamsRowStatus.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) active(1)
15: snmpUnavailableContexts.0 (counter) 0
16: snmpUnknownContexts.0 (counter) 0
***** SNMP QUERY FINISHED *****
上面是一个目的主机实例的查询信息,该实例的索引是:
如果转化为字符串形式,则对应为:traphost.gl.169.254.76.76
● 第一部分:116.114.97.112.104.111.115.116.46,对应的字符串形式为traphost.。
● 第二部分:103.108.46,对应gl.。
● 第三部分:46.49.54.57.46.50.53.52.46.55.54.46.55.54,对应169.254.76.76。
MIB文件名
rfc2573-snmp-target.mib
根节点
iso(1).org(3).dod(6).internet(1).snmpV2(6).snmpModules(3).snmpTargetMIB(12)
全局节点详细描述
snmpTargetSpinLock (1.3.6.1.6.3.12.1.1)
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
read-write
TestAndIncr
同标准MIB取值
目标配置锁
实现与MIB文件定义一致
snmpUnavailableContexts (1.3.6.1.6.3.12.1.4)
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
read-only
Counter32
同标准MIB取值
由于消息中包含的上下文不可用,SNMP引擎收到的数据包被丢弃的总数
实现与MIB文件定义一致
snmpUnknownContexts (1.3.6.1.6.3.12.1.5)
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
read-only
Counter32
同标准MIB取值
由于消息中包含了未知的上下文,SNMP引擎收到的数据包被丢弃的总数
实现与MIB文件定义一致
表节点详细描述
snmpTargetAddrTable
【功能描述】
该表用来指定在生成SNMP消息时使用的目的地址。
【操作支持情况】
创建约束:支持
修改约束:支持
删除约束:支持
读取约束:支持
【表节点信息】
该表的索引节点是IMPLIED snmpTargetAddrName。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
snmpTargetAddrName (1.3.6.1.6.3.12.1.2.1.1)
not-accessible
SnmpAdminString
OCTET STRING (1..32)
索引该表的唯一标识符
snmpTargetAddrName有效范围为是1~255个字节
只能使用可显示字符且不能包含问号
snmpTargetAddrParams (1.3.6.1.6.3.12.1.2.1.7)
read-create
SnmpAdminString
该对象的值标识snmpTargetParamsTable中的表项
snmpTargetAddrParams有效范围为是1~255个字节
只能使用可显示字符且不能包含问号
snmpTargetAddrRetryCount (1.3.6.1.6.3.12.1.2.1.5)
read-create
Integer32
Integer32 (0..255)
该对象指定在未收到生成的消息的响应时的默认重试次数
实现与MIB文件定义一致
snmpTargetAddrRowStatus (1.3.6.1.6.3.12.1.2.1.9)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
行状态
实现与MIB文件定义一致
snmpTargetAddrStorageType (1.3.6.1.6.3.12.1.2.1.8)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
行存储类型
该节点只有 ‘nonVolatile’才可以生效,可以设置为其他值但是不会生效
snmpTargetAddrTAddress (1.3.6.1.6.3.12.1.2.1.3)
read-create
TAddress
OCTET STRING (1..255)
此对象包含传输地址
 该地址的格式取决于snmpTargetAddrTDomain对象的值
实现与MIB文件定义一致
snmpTargetAddrTagList (1.3.6.1.6.3.12.1.2.1.6)
read-create
SnmpTagList
OCTET STRING (0..255)
该对象包含用于为特定操作选择目标地址的标签值列表
有效值只能是 “TrapHost”或者“InformHost”
只能使用可显示字符且不能包含问号
snmpTargetAddrTDomain (1.3.6.1.6.3.12.1.2.1.2)
read-create
TDomain
同标准MIB取值
该对象表示包含在snmpTargetAddrTAddress对象中的地址的传输类型
该节点应该使用snmpUDPDomain
snmpTargetAddrTimeout (1.3.6.1.6.3.12.1.2.1.4)
read-create
TimeInterval
Integer32 (0..2147483647)
该对象应反映与通过此行定义的传输地址进行通信的预期最大往返时间
实现与MIB文件定义一致
【功能描述】
该表用来实现设置当生成一个到目的地的消息时应该使用该表的SNMP参数。
【操作支持情况】
创建约束:支持
修改约束:支持
删除约束:支持
读取约束:支持
【表节点信息】
该表的索引节点是IMPLIED snmpTargetParamsName。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
snmpTargetParamsMPModel (1.3.6.1.6.3.12.1.3.1.2)
read-create
SnmpMessageProcessingModel
当生成SNMP消息时使用的消息处理模型
实现与MIB文件定义一致
snmpTargetParamsName (1.3.6.1.6.3.12.1.3.1.1)
not-accessible
SnmpAdminString
索引该表的唯一标识符
snmpTargetParamsName有效范围为是1~255个字节
只能使用可显示字符且不能包含问号
snmpTargetParamsRowStatus (1.3.6.1.6.3.12.1.3.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
行状态
实现与MIB文件定义一致
snmpTargetParamsSecurityLevel (1.3.6.1.6.3.12.1.3.1.5)
read-create
SnmpSecurityLevel
noAuthNoPriv(1),
authNoPriv(2),
authPriv(3)
当生成SNMP消息时使用的消息处理安全级别
实现与MIB文件定义一致
snmpTargetParamsSecurityModel (1.3.6.1.6.3.12.1.3.1.3)
read-create
SnmpSecurityModel
Integer32 (1..2147483647)
使用此表项生成SNMP消息时使用的安全模型
如果尝试将此变量设置为不支持的安全模型的值,则可能返回取值不一致的错误
实现与MIB文件定义一致
snmpTargetParamsSecurityName (1.3.6.1.6.3.12.1.3.1.4)
read-create
SnmpAdminString
安全名,其标识将使用此表项生成SNMP消息的主体
实现与MIB文件定义一致
snmpTargetParamsStorageType (1.3.6.1.6.3.12.1.3.1.6)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
行存储类型
该节点只有nonVolatile才可以生效,可以设置为其他值但是不会生效
