05-三层技术-IP路由命令参考
01-IP路由基础命令
本章节下载 01-IP路由基础命令  (742.93 KB)
01-IP路由基础命令
  录
1 IP路由基础
1.1 IP路由基础配置命令
1.1.1 address-family ipv4
1.1.2 address-family ipv6
1.1.3 display ecmp mode
1.1.4 display hardware-resource routing-mode
1.1.5 display ip routing-table
1.1.6 display ip routing-table acl
1.1.7 display ip routing-table ip-address
1.1.8 display ip routing-table prefix-list
1.1.9 display ip routing-table protocol
1.1.10 display ip routing-table statistics
1.1.11 display ip routing-table summary
1.1.12 display ipv6 rib attribute
1.1.13 display ipv6 rib graceful-restart
1.1.14 display ipv6 rib nib
1.1.15 display ipv6 route-direct nib
1.1.16 display ipv6 routing-table
1.1.17 display ipv6 routing-table acl
1.1.18 display ipv6 routing-table ipv6-address
1.1.19 display ipv6 routing-table prefix-list
1.1.20 display ipv6 routing-table protocol
1.1.21 display ipv6 routing-table statistics
1.1.22 display ipv6 routing-table summary
1.1.23 display rib attribute
1.1.24 display rib ecmp-group
1.1.25 display rib graceful-restart
1.1.26 display rib nib
1.1.27 display route-direct nib
1.1.28 ecmp-group
1.1.29 ecmp mode
1.1.30 ecmp mode fir primary threshold
1.1.31 fib lifetime
1.1.32 flush route-attribute
1.1.33 hardware-resource routing-mode
1.1.34 inter-protocol fast-reroute
1.1.35 interface nexthop
1.1.36 ip route fast-switchover enable
1.1.37 ipv6 route fast-switchover enable
1.1.38 maintenance-probe enable
1.1.39 path-id
1.1.40 primary-path-detect bfd
1.1.41 protocol lifetime
1.1.42 protocol nexthop recursive-lookup
1.1.43 reset ip routing-table statistics protocol
1.1.44 reset ipv6 routing-table statistics protocol
1.1.45 rib
1.1.46 routing-table limit
1.1.47 snmp-agent trap enable ipv6 rib
1.1.48 snmp-agent trap enable rib
1 IP路由基础
1.1  IP路由基础配置命令
address-family ipv4命令用来创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
undo address-family ipv4命令用来删除RIB IPv4地址族和RIB IPv4地址族视图下的所有配置。
address-family ipv4
不存在RIB IPv4地址族。
RIB视图
# 创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6命令用来创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
undo address-family命令用来删除RIB IPv6地址族和RIB IPv6地址族视图下的所有配置。
address-family ipv6
undo address-family ipv6
不存在RIB IPv6地址族。
RIB视图
# 创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
display ecmp mode命令用来显示等价路由模式信息。
display ecmp mode
# 显示等价路由模式信息。
<Sysname> display ecmp mode
  ECMP-Mode in use: Default
  ECMP-Mode at the next reboot: Enhanced
表1-1 display ecmp mode命令显示信息描述表
ECMP-Mode in use
当前ECMP模式:
·     Default:等价路由普通模式
·     Compressed:等价路由压缩模式
·     Eligible:等价路由Eligibility模式
¡     Default flowset inactive time xx:流的非活跃时间间隔缺省值,该值为xx模式
¡     Flowset inactive time xx:手工设置的流的非活跃时间间隔,该时间间隔为xx模式
·     Enhanced:等价路由增强模式
·     FIR:等价路由FIR模式
¡     Default flowset inactive time xx:流的非活跃时间间隔缺省值,该值为xx毫秒
¡     Flowset inactive time xx:手工设置的流的非活跃时间间隔,该时间间隔为xx毫秒
¡     Default flowset size xx:一个FIR ECMP组内报文流数量等级的缺省值,该值为xx
¡     Flowset size xx:手工设置的一个FIR ECMP组内报文流数量等级,该值为xx
¡     Default flowset hash mode xx:缺省的FIR子模式,该值为xx
¡     Flowset hash mode xx:手工设置的FIR子模式,该值为xx
·     Fixed:等价路由固定模式
·     Spray:等价路由Spray模式
下次启动后ECMP模式:
·     Default:等价路由普通模式
·     Enhanced:等价路由增强模式
·     FIR:等价路由FIR模式
¡     Default flowset size xx:一个FIR ECMP组内报文流的数量等级的缺省值,该值为xx
¡     Flowset inactive hash mode xx:手工设置的FIR子模式,该值为xx
·     Fixed:等价路由固定模式
·     Spray:等价路由Spray模式
·     ecmp mode
display hardware-resource routing-mode命令用来显示Routing-mode的硬件资源模式。
# 显示Routing-mode的硬件资源模式。
<Sysname> display hardware-resource routing-mode
Routing-mode resource(routing-mode), all supported modes:
  ipv6-64           IPv6-64 supported
  ipv6-128          IPv6-128 supported
  Default         Current         Next
  ipv6-128        ipv6-128        ipv6-128
表1-2 display hardware-resource routing-mode命令显示信息描述表
设备支持的Routing-mode硬件资源模式,取值包括:
·     ipv6-64:只支持ipv6 小于等于64位掩码路由
·     ipv6-128:支持ipv6大于64位路由
Routing-mode的缺省硬件资源模式
Current
Routing-mode的当前硬件资源模式
Next
最新配置的Routing-mode硬件资源模式
·     hardware-resource routing-mode
display ip routing-table命令用来显示路由表的信息。
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ip routing-table all-routes
all-vpn-instance:显示所有VPN实例的路由表信息。
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
all-routes:显示公网和所有VPN实例的路由表信息。
verbose:显示全部路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
如果不指定任何参数时,则显示公网的信息。
# 显示路由表中当前激活路由的概要信息。
<Sysname> display ip routing-table
Destinations : 14        Routes : 14
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
1.1.1.0/24          Static 60   0            192.168.47.4    Vlan12
                                             192.168.47.4    Vlan13
192.168.1.0/24      Direct 0    0            192.168.1.40    Vlan11
192.168.1.0/32      Direct 0    0            192.168.1.40    Vlan11
192.168.1.40/32     Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.40    Vlan11
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
# 显示公网和所有VPN实例中当前激活路由的概要信息。
<Sysname> display ip routing-table all-routes
VPN instance: public instance
Destinations : 11        Routes : 11
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
1.1.1.0/24          Static 60   0            192.168.47.4    Vlan11
                                             192.168.47.4    Vlan12
VPN instance: vpn1
Destinations : 9        Routes : 9
1.1.2.0/24          Static 60   0            2.2.1.1         Vlan11
# 显示所有VPN实例下的IPv4路由信息。
<Sysname> display ip routing-table all-vpn-instance
VPN instance: vpn1
Destinations : 10        Routes : 10
                                             2.2.1.1         Vlan13
VPN instance: vpn2
1.1.3.0/24          Static 60   0            3.3.1.1         Vlan13
表1-3 display ip routing-table命令显示信息描述表
VPN instance
路由表所属的公网或VPN实例信息,公网路由显示为public instance,私网路由显示为VPN实例名称
Destinations
目的地址个数
Routes
路由条数
Destination/Mask
目的地址/掩码长度
Proto
发现该路由的路由协议类型
Pre
路由的优先级
Cost
路由的度量值
NextHop
此路由的下一跳地址
出接口,即到该目的网段的数据包将从此接口发出
Summary count
路由数目
# 显示路由表的全部详细信息。
<Sysname> display ip routing-table verbose
Destinations : 2        Routes : 2
Destination: 0.0.0.0/32
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 08h34m37s
       Cost: 0               Preference: 0
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active NoAdv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x10000000          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 0.0.0.0
      Flags: 0x1000c        OrigNextHop: 127.0.0.1
      Label: NULL           RealNextHop: 127.0.0.1
    BkLabel: NULL             BkNextHop: N/A
    SRLabel: NULL             BkSRLabel: NULL
   SIDIndex: NULL               InLabel: NULL
  Tunnel ID: Invalid          Interface: InLoopBack0
BkTunnel ID: Invalid        BkInterface: N/A
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A                 PathID: 0x0
   LinkCost: 0               MicroSegID: 0
RealFIRType: Normal           RealThres: 0
Destination: 1.1.1.0/24
   Protocol: Static
 Process ID: 0
  SubProtID: 0x0                    Age: 04h20m37s
       Cost: 0               Preference: 60
        Tag: 0                    State: Active Adv
      NibID: 0x10000003          LastAs: 0
      Flags: 0x1008c        OrigNextHop: 192.168.47.4
      Label: NULL           RealNextHop: 192.168.47.4
  Tunnel ID: Invalid          Interface: Vlan-interface11
# 显示所有VPN实例内所有路由的详细信息。
<Sysname> display ip routing-table all-vpn-instance verbose
VPN instance: vpn1
Destinations : 1        Routes : 1
   Protocol: Direct
 Process ID: 0
  OrigTblID: 0x0                OrigVrf: vpn1
VPN instance: vpn2
   Protocol: Static
 Process ID: 0
  OrigTblID: 0x0                OrigVrf: vpn2
表1-4 display ip routing-table verbose命令显示信息描述表
VPN instance
Destinations
目的地址个数
Routes
路由条数
Destination
目的地址/掩码
Protocol
发现该路由的路由协议类型
Process ID
进程号
SubProtID
路由子协议ID
Age
此路由在路由表中存在的时间
Cost
路由的度量值
Preference
路由的优先级
IpPre
IP优先级值
QosLocalID
QoS本地ID
Tag
路由标记
路由状态描述:
·     Active:有效的单播路由
·     Adv:允许对外发送的路由
·     Inactive:非激活路由标志
·     NoAdv:不允许发布的路由
·     Vrrp:VRRP产生的路由
·     Nat:NAT产生的路由
·     TunE:Tunnel隧道的标志
·     Backup:备份路由的标志
·     IPSGT:IP-SGT(IP address-Security Group Tag,IP地址-安全组)策略产生的路由
OrigTblID
原始路由表ID
OrigVrf
路由所属的原始VPN,显示为default-vrf表示公网
TableID
路由所在路由表的ID
OrigAs
初始AS号
NibID
下一跳ID
LastAs
最后AS号
AttrID
路由属性ID号
Neighbor
路由协议的邻居地址
Flags
路由标志位
OrigNextHop
此路由的下一跳地址
Label
标签
RealNextHop
路由真实下一跳
BkLabel
备份标签
BkNexthop
备份下一跳地址
SRLabel
SR(Segment Routing)标签
BkSRLabel
SR(Segment Routing)备份标签
SIDIndex
SID的相对值
InLabel
路由入标签
Tunnel ID
隧道ID
BkTunnel ID
备份隧道ID
BkInterface
备份出接口
FtnIndex
FTN表项索引
TrafficIndex
流量统计索引值,取值范围为1~64,N/A表示无效值
Connector
表示BGP为MD VPN特性所携带的Connector属性,具体取值为BGP对等体在交换VPN-IPv4路由时携带源PE的地址,N/A表示没有该属性
Summary count
路由数目
PathID
BGP路由的Add-Path ID
LinkCost
IGP物理链路开销值
MicroSegID
路由携带的微分段ID
RealFIRType
等价路由FIR模式中真实下一跳所在链路的类型,取值包括:
·     Normal:表示普通链路
·     Primary:表示主用链路
·     Secondary:表示备用链路
真实下一跳是路由经过迭代找到的直连下一跳
RealThres
等价路由FIR模式中,真实下一跳所在主用链路的带宽使用率上限阈值,单位为百分比
display ip routing-table acl命令用来显示通过指定ACL过滤的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
ipv4-acl-number:基本ACL的编号,取值范围为2000~2999。
verbose:显示通过指定ACL过滤的所有路由的详细信息。如果未指定本参数,将只显示通过指定ACL过滤的激活路由的概要信息。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则显示所有的路由信息。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
# 配置ACL 2000,并设置路由过滤规则。
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# 显示通过ACL 2000过滤的激活路由的概要信息。
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24      Direct 0    0            192.168.1.111   Vlan11
192.168.1.0/32      Direct 0    0            192.168.1.111   Vlan11
192.168.1.111/32    Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.111   Vlan11
以上显示信息解释请参见表1-3
# 显示通过ACL 2000过滤的所有路由的详细信息。
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x1                    Age: 04h20m37s
      Flags: 0x10080        OrigNextHop: 192.168.1.111
      Label: NULL           RealNextHop: 192.168.1.111
Destination: 192.168.1.0/32
   Protocol: Direct
 Process ID: 0
      Flags: 0x1008c        OrigNextHop: 192.168.1.111
Destination: 192.168.1.111/32
   Protocol: Direct
 Process ID: 0
      Flags: 0x10004        OrigNextHop: 127.0.0.1
Destination: 192.168.1.255/32
   Protocol: Direct
 Process ID: 0
以上显示信息解释请参见表1-4
display ip routing-table ip-address命令用来显示指定目的地址的路由信息。
display ip routing-table ip-address1 to ip-address2命令用来显示指定目的地址范围内的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
ip-address:目的IP地址,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
longer-match:显示与指定目的网络匹配的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ip-address1 to ip-address2:IP地址范围。ip-address1ip-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
使用不同的可选参数,命令的输出也不相同,以下是对该命令不同形式的输出说明:
·     display ip routing-table ip-address
显示满足如下条件的所有激活路由:
¡     用户输入的目的IP地址同路由表中各条路由的子网掩码值进行与运算。
¡     路由表中各条路由的目的IP地址同其自身子网掩码值进行与运算。
¡     两次运算结果相同的路由条目将被显示出来。
·     display ip routing-table ip-address mask
显示满足如下条件的所有激活路由:
¡     用户输入的目的IP地址同用户输入的子网掩码值进行与运算。
¡     路由表中各条路由的目的IP地址同用户输入的子网掩码值进行与运算。
¡     两次运算结果相同,并且掩码小于等于用户输入的子网掩码的路由条目将被显示出来。
·     display ip routing-table ip-address longer-match
显示满足如下条件的所有激活路由:
¡     用户输入的目的IP地址同子网掩码值进行与运算,有以下三种情况:
-     判断用户输入的目的IP地址所属的地址类别(A、B或C类)。A、B和C类地址对应的子网掩码分别为255.0.0.0、255.255.0.0和255.255.255.0。将用户输入的目的IP地址与对应的子网掩码值进行与运算。
-     如果用户输入的目的IP地址是0.0.0.0,使用掩码0.0.0.0与其进行与运算。
-     除上述两种情况外(如组播地址、环回地址),使用掩码255.255.255.255与用户输入的目的IP地址进行与运算。
¡     路由表中各条路由的目的IP地址同上一步得到的子网掩码值进行与运算。
¡     两次运算结果相同的所有路由条目将被显示出来。
·     display ip routing-table ip-address mask longer-match
显示满足如下条件的所有激活路由:
·     display ip routing-table ip-address1 to ip-address2
显示ip-address1/32到ip-address2/32之间的激活路由,目的地址与掩码(32位)同时在指定范围内才会显示。
# 显示目的地址为11.0.0.1的路由信息。
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.0.0.0/16         Static 60   0            0.0.0.0         NULL0
11.0.0.0/24         Static 60   0            0.0.0.0         NULL0
# 显示目的地址/掩码为11.0.0.1/20的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# 显示目的地址为11.0.0.1并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 3
# 显示目的地址/掩码为11.0.0.1/20并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 3
# 显示目的地址从1.1.1.0到5.5.5.0范围内的路由信息。
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 4
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1         Vlan2
3.3.3.1/32          Direct 0    0            127.0.0.1       InLoop0
4.4.4.1/32          Direct 0    0            127.0.0.1       InLoop0
# 显示目的地址为1.2.3.4的路由的详细信息。
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
Destination: 1.2.3.4/32
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x1                    Age: 00h00m37s
    TableID: 0x2                 OrigAs: 200
      NibID: 0x15000000          LastAs: 200
     AttrID: 0x0               Neighbor: 192.168.47.2
      Flags: 0x10060        OrigNextHop: 192.168.47.2
      Label: NULL           RealNextHop: 192.168.47.2
以上显示信息的解释请参见表1-3
display ip routing-table prefix-list命令用来显示通过指定前缀列表过滤的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name:前缀列表名称,为1~63个字符的字符串,区分大小写。
verbose:当使用该参数时,显示通过过滤规则的所有路由的详细信息。如果未指定本参数,将只显示通过过滤规则的激活路由的概要信息。
如果指定的前缀列表不存在,将显示所有的路由信息。
# 配置地址前缀列表test允许前缀为1.1.1.0,掩码长度为24的路由通过。
[Sysname] ip prefix-list test permit 1.1.1.0 24
# 显示通过前缀列表test过滤的激活路由的概要信息。
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24          Direct 0    0            1.1.1.2         Vlan11
以上显示信息的解释请参见表1-3
# 显示通过前缀列表test过滤的所有路由的详细信息。
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
 Process ID: 0
      Flags: 0x1008c        OrigNextHop: 1.1.1.2
      Label: NULL           RealNextHop: 1.1.1.2
以上显示信息的解释请参见表1-4
display ip routing-table protocol命令用来显示指定协议生成或发现的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
protocol:显示指定路由协议的信息。
inactive:显示未激活路由的信息。如果未指定本参数,则显示激活路由和未激活路由的信息。
verbose:当使用该参数时,显示路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有直连路由的概要信息。
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
2.2.2.0/32          Direct 0    0            2.2.2.1         Vlan2
2.2.2.2/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.255/32        Direct 0    0            2.2.2.1         Vlan2
Direct Routing table status : <Inactive>
Summary count : 0
# 显示静态路由表。
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
1.2.3.0/24          Static 60   0            1.2.4.5        Vlan10
# 显示所有OSPF路由的详细信息。
<Sysname> display ip routing-table protocol ospf verbose
Summary count : 1
Destination: 1.1.1.2/32
   Protocol: O_INTRA
 Process ID: 0
  SubProtID: 0x6                    Age: 00h03m54s
       Cost: 0               Preference: 255
      NibID: 0x16000000          LastAs: 200
以上显示信息的解释请参见表1-3
display ip routing-table statistics命令用来显示路由表中的综合路由统计信息。综合路由统计信息包括路由总数目、路由协议添加/删除路由数目、激活路由数目。
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] statistics
all-routes:显示公网和所有VPN实例的信息。
all-vpn-instance:显示所有VPN实例的信息。
# 显示公网路由表中的综合路由统计信息。
<Sysname> display ip routing-table statistics
Total prefixes: 15        Active prefixes: 15
Proto      Routes      Active      Added       Deleted
DIRECT     12          12          30          18
STATIC     3           3           5           2
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
BGP        0           0           0           0
Total      15          15          35          20
# 显示公网和所有VPN实例路由表中的综合路由统计信息。
<Sysname> display ip routing-table all-routes statistics
Total prefixes: 11        Active prefixes: 11
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
# 显示指定VPN实例路由表中的综合路由统计信息。
<Sysname> display ip routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
# 显示所有VPN实例路由表中的综合路由统计信息。
<Sysname> display ip routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
表1-5 display ip routing-table statistics命令显示信息描述表
Total prefixes
总的前缀数目
Active prefixes
总的激活前缀数目
Proto
路由协议
Routes
总的路由数目
Active
活跃的、正在使用的路由数目
Added
路由器启动后或在上一次清除路由表后,路由表中添加的路由数目
Deleted
标记为删除的路由数目(此类路由在等待一段时间后会被释放)
Total
各种类型路由数目的总和
display ip routing-table summary命令用来显示路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ip routing-table [ vpn-instance vpn-instance-name ] summary
# 显示公网的路由表概要信息。
<Sysname> display ip routing-table summary
Max ECMP: 128
Max Active Route: 163840
Remain Active Route: 163825
# 显示vpn1实例的路由表概要信息。
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 128
Remain Active Route: 163832
Threshold value percentage of max active routes: 100%
表1-6 display ip routing-table summary命令显示信息描述表
Max ECMP
最大等价路由数
Max Active Route
最多支持激活路由前缀数
Remain Active Route
剩余可激活路由前缀数
Threshold value xxx
显示最多支持激活路由前缀数的告警门限:
·     如果在VPN实例中配置了命令routing-table limit number simply-alert,则显示信息字段为Threshold value of active routes alert,取值表示产生告警的门限值。当VPN实例的激活路由前缀数超过该取值时,可以继续激活新的路由前缀,但会产生Trap告警和日志信息
·     若在VPN实例中配置了命令routing-table limit number warn-threshold,则显示信息字段为Threshold value percentage of max active routes,取值表示当(VPN实例中的激活路由前缀数/最多支持激活路由前缀数×100)达到warn-threshold时,产生Trap告警和日志信息,但仍然允许增加激活路由前缀。当VPN实例中的激活路由前缀由数达到最多支持激活路由前缀数目时,不再激活新的路由前缀
display ipv6 rib attribute命令用来显示IPv6 RIB的路由属性信息。
attribute-id:路由属性ID值,取值范围为十六进制数0~ffffffff。
# 显示IPv6 RIB的路由属性信息。
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
                  Flag: 0x0
              Protocol: BGP4+ instance default
        Address family: IPv6
       Reference count: 0
      Local preference: 0
Ext-communities number: 0
 Ext-communities value: N/A
    Communities number: 0
     Communities value: N/A
        AS-path number: 0
         AS-path value: N/A
以上显示信息的解释请参见表1-10
display ipv6 rib graceful-restart命令用来显示IPv6 RIB的GR状态信息。
# 显示IPv6 RIB的GR状态信息。
<Sysname> display ipv6 rib graceful-restart
RIB GR state     : Phase2-calculation end
RCOM GR state    : Flush end
Protocol GR state:
 No.  Protocol   Lifetime FD   State    Start/End
 1    DIRECT     900      29   End      No/No
 2    STATIC     900      32   End      No/No
 3    ISISV6     900      30   End      No/No
以上显示信息的解释请参见表1-12
display ipv6 rib nib命令用来显示IPv6 RIB的下一跳信息。
self-originated:路由管理自己生成的下一跳。
nib-id:路由下一跳ID值,取值范围为十六进制数1~ffffffff。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议的下一跳信息。
# 显示IPv6 RIB的下一跳信息。
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
      NibID: 0x20000000        Sequence: 0
       Type: 0x1                Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x0                VrfNthp: 0
   UserKey1: 0x0                Nexthop: ::
    IFIndex: 0x111            LocalAddr: ::
     NewUK0: 0x0                 NewUK1: 0x0
     NewUK2: 0x0                 NewUK3: 0x0
     NewUK4: 0x0                 NewUK5: 0x0
     NewUK6: 0x0                 NewUK7: 0x0
   TopoNthp: Invalid            ExtType: 0x0
    FIRType: Normal           Threshold: 0
ExtBandwidth:0x0                AS-path: 0 0
  EcmpGroup: 0
      NibID: 0x20000001        Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: ::1
    IFIndex: 0x112            LocalAddr: ::1
  EcmpGroup: 0
# 显示IPv6 RIB下一跳的详细信息。
<Sysname> display ipv6 rib nib verbose
        Age: 00h01m50s
  EcmpGroup: 0
     RefCnt: 4              FlushRefCnt: 1
       Flag: 0x84               Version: 1
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::
  RelyDepth: 0              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology:
     Weight: 0                    Flags: 0x0
  Bandwidth: 0
        Age: 00h01m50s
ExtBandwidth:0x0                AS-path: 10 20
  EcmpGroup: 0
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::1
  RelyDepth: 0              RealNexthop: ::1
  Interface: InLoop0          LocalAddr: ::1
  Bandwidth: 0
以上显示信息的解释请参见表1-13表1-14
display ipv6 route-direct nib命令用来显示IPv6直连路由下一跳信息。
nib-id:路由邻居ID值,取值范围为十六进制数1~ffffffff。
# 显示IPv6直连路由下一跳信息。
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
        Age: 00h01m50s
        Age: 00h01m50s
# 显示IPv6直连路由下一跳详细信息。
<Sysname> display ipv6 route-direct nib verbose
        Age: 00h01m50s
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x2                Version: 1
    ExtFlag: 0x0
 1 nexthop(s):
        Age: 00h01m50s
    ExtFlag: 0x0
 1 nexthop(s):
以上显示信息的解释请参见表1-15表1-16
display ipv6 routing-table命令用来显示IPv6路由表的信息。
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ipv6 routing-table all-routes
all-vpn-instance:显示所有VPN实例的路由信息。
verbose:显示IPv6路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
# 显示当前路由表的概要信息。
<Sysname> display ipv6 routing-table
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
<Sysname> display ipv6 routing-table all-routes
VPN instance: vpn1
Destination: 1:2::3:4/128                                Protocol  : Static
NextHop    : ::                                          Preference: 60
Interface  : NULL0                                       Cost      : 0
# 显示所有VPN实例下的IPv6路由信息。
<Sysname> display ipv6 routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
表1-7 display ipv6 routing-table命令显示信息描述表
VPN instance
Destinations
目的地址个数
Routes
路由条数
Destination
目的网络/主机的IPv6地址和前缀
NextHop
下一跳地址
Preference
路由优先级
出接口,即到该目的地址的数据包将从此接口发出
Protocol
发现该路由的路由协议类型
Cost
路由的开销值
Summary count
路由数目
# 显示路由表的详细路由信息。
<Sysname> display ipv6 routing-table verbose
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 19h23m02s
    TableID: 0xa                 OrigAs: 0
      NibID: 0x20000000          LastAs: 0
     AttrID: 0xffffffff        Neighbor: ::
      Flags: 0x10004        OrigNextHop: ::1
      Label: NULL           RealNextHop: ::1
Destination: 12::/96
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h01m47s
      NibID: 0x20000003          LastAs: 0
      Flags: 0x10080        OrigNextHop: ::
<Sysname> display ipv6 routing-table all-vpn-instance verbose
VPN instance: vpn1
   Protocol: Direct
 Process ID: 0
Destination: 12::1/128
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h01m45s
表1-8 display ipv6 routing-table verbose命令显示信息描述表
VPN instance
Destination
目的网络/主机的IPv6地址和前缀
Protocol
发现该路由的路由协议类型
Process ID
进程号
SubProtID
路由子协议ID
Age
此路由在路由表中存在的时间
Cost
路由的度量值
Preference
路由的优先级
IpPre
IP优先级值
QosLocalID
QoS本地ID
Tag
路由标记
路由状态描述:
·     Active:有效的单播路由
·     Adv:允许对外发送的路由
·     Inactive:非激活路由标志
·     NoAdv:不允许发布的路由
·     Vrrp:VRRP产生的路由
·     Nat:NAT产生的路由
·     TunE:Tunnel隧道的标志
·     IPSGT:IP-SGT策略产生的路由
OrigTblID
原始路由表ID
OrigVrf
TableID
路由所在路由表的ID
OrigAs
初始AS号
NibID
下一跳ID
LastAs
最后AS号
AttrID
路由属性ID号
Neighbor
路由协议的邻居地址
Flags
路由标志位
OrigNextHop
此路由的下一跳地址
Label
标签
RealNextHop
路由真实下一跳
BkLabel
备份标签
BkNexthop
备份下一跳地址
SRLabel
BkSRLabel
SR(Segment Routing))备份标签
Tunnel ID
隧道ID
BkTunnel ID
备份隧道ID
BkInterface
备份出接口
FtnIndex
FTN表项索引
TrafficIndex
Connector
Summary count
路由数目
PathID
BGP路由的Add-Path ID
LinkCost
IGP物理链路开销值
MicroSegID
路由携带的微分段ID
RealFIRType
·     Normal:表示普通链路
·     Primary:表示主用链路
·     Secondary:表示备用链路
RealThres
display ipv6 routing-table acl命令用来显示通过指定IPv6 ACL过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
ipv6-acl-number:基本IPv6 ACL编号,取值范围为2000~2999。
verbose:显示通过指定IPv6 ACL过滤的所有路由的详细信息。如果未指定本参数,只显示通过IPv6 ACL过滤的激活路由的概要信息。
引用IPv6 ACL时,需要注意的是:
·     若引用的IPv6 ACL不存在,或者引用的IPv6 ACL中没有配置规则,则显示所有的IPv6路由信息。
·     在引用的IPv6 ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
# 显示通过IPv6 ACL 2000过滤的激活路由的概要信息。
<Sysname> display ipv6 routing-table acl 2000
Summary count : 6
Destination : ::1/128                                    Protocol  : Direct
Destination: 12::/96                                     Protocol  : Direct
Interface  : Vlan11                                      Cost      : 0
Destination: 12::1/128                                   Protocol  : Direct
Destination: 11::1/128                                   Protocol  : O_INTER
NextHop    : FE80::A1F:3FFF:FE45:206                     Preference: 10
Interface  : Vlan11                                      Cost      : 2
Destination: FF00::/8                                    Protocol  : Direct
以上显示信息的解释请参见表1-7
# 显示通过IPv6 ACL 2000过滤的所有路由的详细信息。
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 19h29m12s
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h07m57s
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h07m55s
   Protocol: O_INTER
 Process ID: 1
  SubProtID: 0x2                    Age: 00h06m43s
       Cost: 2               Preference: 10
      NibID: 0x23000003          LastAs: 0
     AttrID: 0x ffffffff       Neighbor: ::
      Flags: 0x10041        OrigNextHop: FE80::A1F:3FFF:FE45:206
      Label: NULL           RealNextHop: FE80::A1F:3FFF:FE45:206
   Protocol: Direct
 Process ID: 0
      NibID: 0x20000002          LastAs: 0
      Flags: 0x10084        OrigNextHop: ::
   Protocol: Direct
 Process ID: 0
      NibID: 0x20000001          LastAs: 0
      Flags: 0x10014        OrigNextHop: ::
  Tunnel ID: Invalid          Interface: NULL0
以上显示信息的解释请参见表1-8
display ipv6 routing-table ipv6-address命令用来显示指定目的地址的IPv6路由信息。
display ipv6 routing-table ipv6-address1 to ipv6-address2命令用来显示指定目的地址范围内的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address:IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
longer-match:显示满足匹配条件的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ipv6-address1 to ipv6-address2:IPv6地址范围。ipv6-address1ipv6-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示激活路由的概要信息。
·     display ipv6 routing-table ipv6-address
显示满足如下条件的所有激活路由:
¡     用户输入的目的IPv6地址同路由表中各条路由的前缀长度值进行与运算。
¡     路由表中各条路由的目的IPv6地址同其自身前缀长度值进行与运算。
·     display ipv6 routing-table ipv6-address prefix-length
显示满足如下条件的所有激活路由:
¡     用户输入的目的IPv6地址同用户输入的前缀长度值进行与运算。
¡     路由表中各条路由的目的IPv6地址同用户输入的前缀长度值进行与运算。
¡     两次运算结果相同,并且路由表中前缀长度小于等于用户输入的前缀长度的路由条目将被显示出来。
·     display ipv6 routing-table ipv6-address longer-match
用户未指定前缀长度时,显示结果与display ipv6 routing-table命令的显示结果相同。
·     display ipv6 routing-table ipv6-address prefix-length longer-match
显示满足如下条件的所有激活路由:
·     display ipv6 routing-table ipv6-address1 to ipv6-address2
显示ipv6-address1/128到ipv6-address2/128之间的路由,目的IPv6地址与前缀长度(128位)同时在指定范围内才会显示。
# 显示目的IPv6地址/前缀为10::1/127的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64                                     Protocol  : Static
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# 显示目的IPv6地址/前缀为10::1/127并且满足匹配条件的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 3
# 显示目的IPv6地址从100::到300::范围内的IPv6路由信息。
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
# 显示目的IPv6地址/前缀为1:2::3:4/128的IPv6路由的详细信息。
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
   Protocol: Direct
 Process ID: 1
  SubProtID: 0x1                    Age: 00h01m14s
       Cost: 1               Preference: 0
      NibID: 0x23000002          LastAs: 0
以上显示信息的解释请参见表1-7
display ipv6 routing-table prefix-list命令用来显示通过指定前缀列表过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name:IPv6前缀列表的名称,为1~63个字符的字符串,区分大小写。
verbose:显示所有路由的详细信息。如果未指定本参数,只显示激活路由的概要信息。
# 配置地址前缀列表test允许前缀为::1,前缀长度为128的IPv6路由通过。
[Sysname] ipv6 prefix-list test permit ::1 128
# 显示通过前缀列表test过滤的IPv6激活路由的概要信息。
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
以上显示信息的解释请参见表1-7
# 显示通过前缀列表test过滤的所有IPv6路由的详细信息。
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 08h57m19s
以上显示信息的解释请参见表1-8
display ipv6 routing-table protocol命令用来显示指定协议生成或发现的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
inactive:如果配置了该参数,此命令只显示未激活路由信息。如果未指定本参数,将显示所有激活和未激活路由信息。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有IPv6直连路由的概要信息。
<Sysname> display ipv6 routing-table protocol direct
Summary count : 3
Summary count : 3
Summary count : 0
# 显示IPv6静态路由表。
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128                                    Protocol  : Static
NextHop    : fe80::2                                     Preference: 60
Interface  : Vlan12                                      Cost      : 0
NextHop    : fe80::3                                     Preference: 60
Destination: 3::3/128                                    Protocol  : Static
NextHop    : 2::2                                        Preference: 60
Summary count : 0
# 显示所有OSPFv3路由的详细信息。
<Sysname> display ipv6 routing-table protocol ospfv3 verbose
Summary count : 1
Destination: 22::22/128
   Protocol: O_INTER
 Process ID: 0
  SubProtID: 0x6                    Age: 00h04m15s
    TableID: 0xa                 OrigAs: 200
      NibID: 0x25000001          LastAs: 200
     AttrID: 0x3               Neighbor: 121::2
      Flags: 0x10060        OrigNextHop: 121::2
      Label: NULL           RealNextHop: 121::2
以上显示信息的解释请参见表1-7
display ipv6 routing-table statistics命令用来显示IPv6路由表中的综合路由统计信息。综合路由统计信息包括路由总数、路由协议添加/删除路由数目、激活路由数目。
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] statistics
# 显示公网路由表中综合路由统计信息。
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8        Active prefixes: 8
DIRECT     5           5           5           0
STATIC     3           3           3           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
BGP4+      0           0           0           0
Total      8           8           8           0
<Sysname> display ipv6 routing-table all-routes statistics
Total prefixes: 6        Active prefixes: 6
DIRECT     3           3           3           0
STATIC     3           3           5           2
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
BGP4+      0           0           0           0
Total      6           6           8           2
<Sysname> display ipv6 routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
BGP4+      0           0           0           0
Total      11          11          13          2
<Sysname> display ipv6 routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
BGP4+      0           0           0           0
Total      11          11          13          2
表1-9 display ipv6 routing-table statistics命令显示信息描述表
Total prefixes
总的前缀数目
Active prefixes
总的激活前缀数目
Proto
路由协议
Routes
总的路由数目
Active
激活的、正在使用的路由数目
Added
Deleted
Total
各种类型路由数目的总和
display ipv6 routing-table summary命令用来显示IPv6路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
# 显示公网的路由表概要信息。
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
# 显示实例vpn1的路由表概要信息。
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 32
Max Active Route: 1024
Remain Active Route: 1021
以上显示信息的解释请参见表1-6
display rib attribute命令用来显示RIB的路由属性信息。
# 显示RIB的路由属性信息。
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
                  Flag: 0x0
              Protocol: BGP instance default
        Address family: IPv4
       Reference count: 0
Act-RT reference count: 0
            Flush flag: 0
      Local preference: 0
Ext-communities number: 26
 Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
                        > <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
                        : 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
                         <RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
                        13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
        AS-path number: 0
         AS-path value: N/A
  SFlow AS-path length: 0
   SFlow AS-path value: N/A
Detailed information of attribute 0x1:
                  Flag: 0x0
              Protocol: BGP
       Reference count: 0
            Flush flag: 0
       Local prefrence: 0
Ext-communities number: 1
 Ext-communities value: <RT: 1:2>
        AS-path number: 0
         AS-path value: N/A
表1-10 display rib attribute命令显示信息描述表
attribute的总个数
Flag
标志位
Protocol
产生该属性的协议
Address family
地址簇类型
Reference count
引用计数
被激活路由引用次数
Flush flag
下刷FIB标记,0表示属性没有下刷FIB,1表示属性已经下刷FIB
Local prefrence
本地优先级
扩展团体属性个数
扩展团体属性值(个数为0显示N/A,最多显示20个,超出部分用…表示)
Communities number
团体属性个数
Communities value
AS-path number
AS-path个数(AS-path个数为所有AS号之和)
AS-path value
AS-path值(AS-path值不区分AS-set、AS-sequence、联盟AS-set、联盟AS-sequence;个数为0显示N/A,最多显示20个,超出部分用…表示)
sFlow AS-path属性长度
SFlow AS-path value
sFlow AS-path值(长度为0显示N/A,最多显示80个,超出部分用…表示)
display rib ecmp-group命令用来显示ECMP组信息。
display rib ecmp-group [ group-id ]
group-id:显示指定ECMP组的信息。如果未指定本参数,则显示所有的ECMP组信息。
# 显示所有ECMP组的信息。
<Sysname> display rib ecmp-group
Ecmp-group: 1
 Interface                                         NextHop
 HundredGigE1/0/1                              10.0.0.1
 HundredGigE1/0/2                              20.0.0.1
 HundredGigE1/0/3                              30.0.0.1
 Path-id                  Dscp                     Mask
 1                        10                       3
 2                        3                        3
Ecmp-group: 2
 Interface                                         NextHop
 HundredGigE1/0/4                              40.0.0.1
 HundredGigE1/0/5                              50.0.0.1
 HundredGigE1/0/6                              60.0.1.1
 Path-id                  Dscp                     Mask
 2                        3                        3
表1-11 display rib ecmp-group命令显示信息描述表
ECMP group
ECMP组ID
出接口
Next hop
路由的下一跳地址
Path ID
ECMP路径ID
DSCP
DSCP优先级
Mask
DSCP掩码值
display rib graceful-restart命令用来显示RIB的GR状态信息。
# 显示RIB的GR状态信息。
<Sysname> display rib graceful-restart
Protocol GR state:
 1    DIRECT     900      30   End      No/No
 2    STATIC     900      34   End      No/No
 3    OSPF       900      36   End      No/No
 4    ISIS       900      32   End      No/No
 5    BGP instance abc
                 900      22   End      No/No
 6    BGP instance default
                 900      25   End      No/No
 7    LDP        900      35   End      No/No
 8    SLSP       900      29   End      No/No
表1-12 display rib graceful-restart命令显示信息描述表
RIB GR state
RIB GR状态:
·     Start:协议GR开始
·     IGP end:所有IGP协议GR结束
·     VPN-triggering end:VPN路由触发优选结束
·     VPN-calculation end:VPN路由优选结束
·     Routing protocol end:所有路由协议GR结束
·     NSR-calculation unfinished:NSR优选未完成状态
·     Triggering start:所有路由触发优选开始
·     Triggering end:所有路由触发优选结束
·     Phase1-calculation end:第一阶段优选结束
·     All end:所有协议GR结束
·     Phase2-calculation end:第二阶段优选结束
RCOM GR state
RCOM GR状态:
·     Start:协议GR开始
·     VPN-notification end:VPN路由上报结束
·     Notification end:所有路由上报结束
·     Flush start:开始下刷FIB
·     Flush end:下刷FIB结束
Protocol GR state
协议GR状态
No.
编号
Protocol
协议名称
Lifetime
倒换过程中协议的路由信息/标签信息在RIB中的存活时间,单位为秒
FD
协议进程与RIB连接的句柄
协议GR状态:
·     Init:协议GR初始化状态
·     Listen:协议GR监听状态
·     Idle:协议GR空闲状态
·     Active:协议GR激活状态
·     Start:协议GR开始状态
·     End:协议GR结束状态
Start/End
·     No:表示该消息未发送
·     Yes:表示该消息已发送
display rib nib命令用来显示RIB的下一跳信息。
self-originated:路由管理自己生成的下一跳信息。
nib-id:路由下一跳信息的ID值,取值范围为十六进制数1~ffffffff。
protocol protocol:显示指定路由协议生成的下一跳信息。
如果不指定任何参数,将显示RIB中所有下一跳的概要信息。
# 显示RIB的下一跳信息。
<Sysname> display rib nib
Total number of nexthop(s): 176
      NibID: 0x10000000        Sequence: 0
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 0.0.0.0
    IFIndex: 0x111            LocalAddr: 0.0.0.0
   TopoNthp: 0                  ExtType: 0x0
  EcmpGroup: 0
      NibID: 0x10000001        Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 127.0.0.1
    IFIndex: 0x112            LocalAddr: 127.0.0.1
  EcmpGroup: 0
      NibID: 0x10000002        Sequence: 2
       Type: 0x5                Flushed: Yes
        Age: 00h01m50s
  EcmpGroup: 0
      NibID: 0x16000000        Sequence: 3
       Type: 0x21               Flushed: No
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 12.1.1.2
    IFIndex: 0x0              LocalAddr: 0.0.0.0
  EcmpGroup: 0
   Instance: abc
表1-13 display rib nib命令显示信息描述表
总的下一跳个数
NibID
下一跳ID
Sequence
下一跳序列号
下一跳类型
Flushed
是否下刷
Age
下一跳信息最近一次更新的时间
UserKey0
第一个协议保留数据
UserKey1
第二个协议保留数据
VrfNthp
下一跳所在VPN索引,显示为0表示公网
Nexthop
下一跳地址
IFIndex
接口索引
LocalAddr
本地接口地址
NewUK0
第一个新的协议保留数据
NewUK1
第二个新的协议保留数据
NewUK2
第三个新的协议保留数据
NewUK3
第四个新的协议保留数据
NewUK4
第五个新的协议保留数据
NewUK5
第六个新的协议保留数据
NewUK6
第七个新的协议保留数据
NewUK7
第八个新的协议保留数据
TopoNthp
(暂不支持子拓扑)下一跳所在拓扑索引,显示为0表示公网拓扑,显示为其他数值表示子拓扑(目前IPv6不支持子拓扑,显示为Invalid)
ExtType
下一跳扩展类型
FIRType
等价路由FIR模式中下一跳所在链路的类型,取值包括:
·     Normal:表示普通链路
·     Primary:表示主用链路
·     Secondary:表示备用链路
Threshold
等价路由FIR模式中主用链路的带宽使用率上限阈值,单位为百分比
ExtBandwidth
来自BGP协议的链路带宽属性值
AS-path
下一跳携带的AS号,从左到右的两个AS号含义分别为:
·     第一个AS号:BGP路由AS_PATH属性中到达本地AS前的倒数第二个AS号
·     第二个AS号:BGP路由AS_PATH属性中到达本地AS前的最后一个AS号
两个AS号以空格分隔,如果不存在这样的AS号,则显示为0
EcmpGroup
ECMP组ID
Instance
BGP实例名称
SubNibID
子下一跳的ID
SubSeq
子下一跳的序列号
NthpCnt
子下一跳的下一跳计数
Samed
子下一跳中相同下一跳计数
NthpType
子下一跳类型:
·     IP:下一跳是IP转发类型
·     MPLS:下一跳是MPLS转发类型
# 显示RIB下一跳详细信息。
<Sysname> display rib nib verbose
        Age: 00h01m50s
  EcmpGroup: 0
     RefCnt: 6              FlushRefCnt: 2
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 0.0.0.0
  RelyDepth: 0              RealNexthop: 0.0.0.0
  Interface: NULL0            LocalAddr: 0.0.0.0
   TunnelID: N/A               Topology: base
  Bandwidth: 0
        Age: 00h01m50s
  EcmpGroup: 0
     RefCnt: 11             FlushRefCnt: 5
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 127.0.0.1
  RelyDepth: 0              RealNexthop: 127.0.0.1
  Interface: InLoop0          LocalAddr: 127.0.0.1
  Bandwidth: 0
      NibID: 0x15000003        Sequence: 3
       Type: 0x43               Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x100010000        VrfNthp: 0
   UserKey1: 0x0                Nexthop: 22.22.22.22
  EcmpGroup: 0
   Instance: default
     RefCnt: 9              FlushRefCnt: 3
    ExtFlag: 0x0
     Policy: tnl-policy1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 22.22.22.22
  RelyDepth: 1              RealNexthop: 13.1.1.2
  Interface: Vlan11           LocalAddr: 13.1.1.1
  TunnelCnt: 1                      Vrf: default-vrf
   TunnelID: 1025              Topology: base
  Bandwidth: 0
表1-14 display rib nib verbose命令显示信息描述表
总的下一跳个数
NibID
下一跳ID
Sequence
下一跳序列号
下一跳类型
Flushed
是否下刷
Age
下一跳信息最近一次更新的时间
UserKey0
第一个协议保留数据
VrfNthp
下一跳所在VPN索引,显示为0表示公网
UserKey1
第二个协议保留数据
Nexthop
下一跳地址
IFIndex
接口索引
LocalAddr
本地接口地址
NewUK0
第一个新的协议保留数据
NewUK1
第二个新的协议保留数据
NewUK2
第三个新的协议保留数据
NewUK3
第四个新的协议保留数据
NewUK4
第五个新的协议保留数据
NewUK5
第六个新的协议保留数据
NewUK6
第七个新的协议保留数据
NewUK7
第八个新的协议保留数据
TopoNthp
ExtType
下一跳扩展类型
FIRType
·     Normal:表示普通链路
·     Primary:表示主用链路
·     Secondary:表示备用链路
Threshold
ExtBandwidth
下一跳携带的链路带宽属性值
AS-path
EcmpGroup
ECMP组ID
Instance
BGP实例名称
RefCnt
下一跳信息的引用计数
FlushRefCnt
下一跳信息的下刷引用计数
Flag
下一跳信息的标志位
Version
下一跳信息的版本号
ExtFlag
下一跳信息的扩展标志位
Policy
隧道策略名
x nexthop (s)
下一跳具体值(前面数值表示下一跳个数)
PrefixIndex
等价时下一跳序号
OrigNexthop
原始下一跳
RelyDepth
迭代深度
RealNexthop
真实下一跳
出接口
LocalAddr
本地接口地址
TunnelCnt
迭代到隧道的个数
Vrf
VPN实例名,显示为default-vrf表示公网
TunnelID
迭代到隧道的ID
Topology
(暂不支持子拓扑)拓扑名称,显示为base表示公网拓扑,显示为其他表示子拓扑(目前IPv6不支持子拓扑,显示为空)
Weight
等价路由各路由的权重,取值为0表示不是等价路由
Flags
当前下一跳的标志位
RealFIRType
·     Normal:表示普通链路
·     Primary:表示主用链路
·     Secondary:表示备用链路
RealThres
Bandwidth
来自IGP协议或接口配置的链路带宽属性值
display route-direct nib命令用来显示直连路由下一跳信息。
# 显示直连路由下一跳信息。
<Sysname> display route-direct nib
Total number of nexthop(s): 116
        Age: 00h01m50s
        Age: 00h01m50s
表1-15 display route-direct nib命令显示信息描述表
总的下一跳个数
NibID
NIB ID号
Sequence
NIB序列号
NIB类型
Flushed
是否下刷FIB
Age
下一跳信息最近一次更新的时间
UserKey0
NIB协议保留数据1
UserKey1
NIB协议保留数据2
VrfNthp
下一跳所在VPN索引,显示为0表示公网
Nexthop
下一跳信息
IFIndex
接口索引
LocalAddr
本地接口地址
NewUK0
第一个新的协议保留数据
NewUK1
第二个新的协议保留数据
NewUK2
第三个新的协议保留数据
NewUK3
第四个新的协议保留数据
NewUK4
第五个新的协议保留数据
NewUK5
第六个新的协议保留数据
NewUK6
第七个新的协议保留数据
NewUK7
第八个新的协议保留数据
TopoNthp
ExtType
下一跳扩展类型
FIRType
·     Normal:表示普通链路
·     Primary:表示主用链路
·     Secondary:表示备用链路
Threshold
# 显示直连路由下一跳详细信息。
<Sysname> display route-direct nib verbose
        Age: 00h01m50s
     RefCnt: 2              FlushRefCnt: 0
    ExtFlag: 0x0
 1 nexthop(s):
        Age: 00h01m50s
     RefCnt: 5              FlushRefCnt: 0
    ExtFlag: 0x0
 1 nexthop(s):
表1-16 display route-direct nib verbose命令显示信息描述表
总的下一跳个数
NibID
下一跳ID
Sequence
下一跳序列号
下一跳类型
Flushed
是否下刷
Age
下一跳信息最近一次更新的时间
UserKey0
第一个协议保留数据
VrfNthp
下一跳所在VPN索引,显示为0表示公网
UserKey1
第二个协议保留数据
Nexthop
下一跳地址
IFIndex
接口索引
LocalAddr
本地接口地址
NewUK0
第一个新的协议保留数据
NewUK1
第二个新的协议保留数据
NewUK2
第三个新的协议保留数据
NewUK3
第四个新的协议保留数据
NewUK4
第五个新的协议保留数据
NewUK5
第六个新的协议保留数据
NewUK6
第七个新的协议保留数据
NewUK7
第八个新的协议保留数据
TopoNthp
ExtType
下一跳扩展类型
FIRType
·     Normal:表示普通链路
·     Primary:表示主用链路
·     Secondary:表示备用链路
Threshold
RefCnt
RefCnt
FlushRefCnt
下一跳信息的下刷引用计数
Flag
下一跳信息的标志位
Version
下一跳信息的版本号
ExtFlag
下一跳信息的扩展标志位
x nexthop (s)
下一跳具体值(前面数值表示下一跳个数)
PrefixIndex
等价时下一跳序号
OrigNexthop
原始下一跳
RelyDepth
迭代深度
RealNexthop
真实下一跳
出接口
LocalAddr
本地接口地址
TunnelCnt
迭代到隧道的个数
Vrf
TunnelID
迭代到隧道的ID
Topology
Weight
Flags
当前下一跳的标志位
RealFIRType
·     Normal:表示普通链路
·     Primary:表示主用链路
·     Secondary:表示备用链路
RealThres
1.1.28  ecmp-group
ecmp-group命令用来创建ECMP组,并进入ECMP组视图。
undo ecmp-group命令用来删除指定的ECMP组。
ecmp-group group-id
undo ecmp-group group-id
不存在ECMP组。
RIB IPv4地址族视图
group-id:ECMP组ID,本取值范围为1~64。
多次执行本命令,可以创建多个ECMP组。
如果设备上存在多条去往同一目的地址的等价路由,并且这些等价路由的下一跳和出接口都在同一个ECMP组里,则报文会匹配该ECMP组。通过ECMP组的相关配置,用户可以根据报文的DSCP优先级调整负载分担算法为报文选择的下一跳和出接口。
# 在RIB IPv4地址族下创建ID为1的ECMP组。
[Sysname] rib
[Sysname-rib-ipv4] ecmp-group 1
[Sysname-rib-ipv4-ecmp-group-1]
·     display rib ecmp-group
·     interface nexthop
·     path-id
1.1.29  ecmp mode
ecmp mode命令用来配置等价路由模式。
undo ecmp mode命令用来恢复缺省情况。
等价路由FIR模式受License限制,请在使用该功能前安装有效的License。有关License的详细介绍,请参见“基础配置指导”中的“License管理”。
ecmp mode { compressed | eligible [ flowset-inactive-time flowset-inactive-time ] | enhanced | fixed | spray }
ecmp mode fir [ flowset-inactive-time flowset-inactive-time ] [ flowset-size flowset-size ] [ hash-mode { eligible | fixed | spray } ]
undo ecmp mode
等价路由模式为普通模式。
compressed:配置等价路由压缩模式。
eligible:配置等价路由Eligibility模式,或等价路由FIR的子模式为Eligibility模式。
fir:配置等价路由FIR(Flexible Intelligent Routing,灵活智能路由)模式。
flowset-inactive-time flowset-inactive-time:设置流的非活跃时间间隔。flowset-inactive-time表示流的非活跃时间间隔,取值范围为16~32000,单位为微秒。本参数仅对等价路由Eligibility模式或FIR Eligibility子模式生效。
flowset-size flowset-size:设置一个FIR ECMP组流的数量。flowset-inactive-size表示流数量的等级,取值范围为1~8,1代表256条流,数字每增加1,流数扩大一倍。为了避免一个FIR ECMP组占用的资源过多,本参数建议配置为1~4。
enhanced:配置等价路由增强模式。
fixed:配置等价路由固定模式,或等价路由FIR的子模式为固定模式。
spray:配置等价路由Spray模式,或等价路由FIR的子模式为Spray模式。
hash-mode:配置等价路由FIR模式的子模式,缺省值为eligible
等价路由模式分为以下几种:
·     等价路由普通模式:当去往同一目的地址存在多条等价路由时,设备在转发去往该目的地址的报文时,会在各条路径间实现负载分担。这些等价路由组成一个等价路由组。如果其中一条或者多条路径失效,所有业务流量会在剩余的可用路径间重新进行一次分配,实现新的负载均衡。
·     等价路由增强模式:当去往同一目的地址存在多条等价路由时,如果其中一条或者多条路径失效,则将失效路径上的业务流量在剩余的可用路径间重新进行一次分配,保持在可用路径上转发的业务流量不改变转发路径,以保持业务的连续性。
·     等价路由Eligibility模式:设备以flowset-inactive-time为周期,计算出当前等价路由组中负载最轻的路径分担其他路径上的流量。同一流中,转发时间间隔小于等于flowset-inactive-time的报文组成一个FlowSet。Eligibility模式可以确保同一FlowSet中的数据包选取相同的转发路径进行转发。
·     等价路由压缩模式:可以将每个等价路由组占用的硬件资源进行压缩,从而允许设备上创建更多的等价路由组,以满足网络需求。
·     等价路由固定模式:待转发的数据包选取其所属流中上一个数据包的转发路径进行转发。若待转发的数据包是其所属流中的第一个数据包,则按照等价路由普通模式选取的路径进行转发。
·     等价路由Spray模式:设备基于数据包选取当前等价路由组中负载最轻的路径进行转发。
·     等价路由FIR模式:
¡     对于静态路由:
当去往同一目的地址存在多条等价静态路由时,可以将几条优先使用的链路配置为主用链路,将使用频率较低的链路配置为备用链路,流量将优先通过主用链路转发,并通过算法对主用链路和备用链路间的流量进行分配。
通过ip route-static命令的将一条静态路由配置为主链路或备链路。流量优先通过主用链路转发,并通过FIR子模式进行负载分担,当一条主用链路的带宽使用率接近所有主用链路整体的带宽使用率上限阈值时,该链路新增的流量将通过备用链路转发,在备用链路间通过FIR子模式进行负载分担。原本的流量依旧通过主用链路转发。有关静态路由primary thresholdsecondary参数、主用链路和备用链路的详细介绍,请参见“三层技术-IP路由配置指导”中的“静态路由”和“IPv6静态路由”。
对于未配置primary thresholdsecondary参数的等价静态路由,业务流量也会以等价路由FIR子模式实现负载分担,但不再区分主备链路。
¡     对于动态路由:
动态路由协议产生的等价路由将通过FIR子模式实现负载分担,不区分主备链路,效果与直接配置等价路由模式为Eligibility模式、固定模式或Spray模式相同。
本配置在设备重启后才能生效,进行设备重启前请评估重启对网络造成的影响,做好相关准备工作。
多次执行本命令,最后一次执行的命令生效。
本配置对IPv4和IPv6等价路由均生效。
IRF设备配置ecmp mode enhanced功能时,当同一数据流的报文从IRF设备不同成员设备的接口接收时,无法保证报文从相同的出接口转发。
配置等价路由FIR模式存在如下限制:
·     当所有主端口限速速率之和大于流量速率时,如果分配到各主端口的平均流量小于70%时,流量在各主端口哈希不均匀。
·     当所有主端口限速速率之和小于流量速率时,如果分配到各备端口的平均流量小于70%时,流量在各备端口哈希不均匀。
仅大于等于1024字节的流量支持等价路由FIR模式。
当设备采用等价路由FIR模式时卸载FIR License,此时流量将不能采用等价路由FIR模式实现负载分担,而是采用之前通过hash-mode参数配置的FIR子模式进行负载分担。另外如果之前没有配置hash-mode参数,则缺省采用Eligibility模式进行负载分担。
当等价路由模式为Eligibility模式、固定模式或Spray模式时,等价路由组中的等价路由不允许使用1G速率的端口。
# 配置等价路由增强模式。
[Sysname] ecmp mode enhanced
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Reboot device to make the configuration take effect.
·     display ecmp mode
ecmp mode fir primary threshold命令用来配置等价路由FIR模式中主用链路带宽使用率的下限和上限。
undo ecmp mode fir primary threshold命令用来恢复缺省情况。
ecmp mode fir primary threshold lower lower-threshold upper upper-threshold
未配置等价路由FIR模式中主用链路带宽使用率的下限和上限。
lower lower-threshold:等价路由FIR模式中主用链路带宽使用率的下限,单位为万分比,取值范围为1~10000。
upper upper-threshold:等价路由FIR模式中主用链路带宽使用率的上限,单位为万分比,实际取值范围与设置的带宽使用率的下限有关,取值为带宽使用率的下限值(lower-threshold~10000。
当同时满足如下条件时,本命令才生效:
·     设备配置了等价路由FIR模式。
·     设备上存在去往同一目的地址的多条等价静态路由,并且这些等价静态路由通过primary threshold-levelsecondary参数被配置为了主用链路和备用链路。
本命令和静态路由配置命令中的primary threshold-level参数配合使用。通过本命令指定了等价路由FIR模式中主用链路带宽使用率的下限和上限,同时通过静态路由配置命令中的primary threshold-level参数可以确定实际生效的主用链路带宽使用率上限阈值。有关静态路由的详细介绍,请参见“三层技术-IP路由”中的“静态路由”和“IPv6静态路由”。
# 配置等价路由FIR模式中主用链路带宽使用率的下限为80%,上限为90%。
[Sysname] ecmp mode fir primary threshold lower 8000 upper 9000
·     ip route-static(三层技术-IP路由/静态路由)
·     ipv6 route-static(三层技术-IP路由/IPv6静态路由)
1.1.31  fib lifetime
fib lifetime命令用来配置IPv4/IPv6路由在FIB中的最大存活时间。
undo fib lifetime命令用来恢复缺省情况。
fib lifetime seconds
undo fib lifetime
IPv4/IPv6路由在FIB中的最大存活时间为600秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
seconds:路由在FIB中的最大存活时间,取值范围为0~6000,单位为秒。取值为0时表示,协议或RIB进程倒换并重新恢复后,会立即通知FIB老化表项。
配置本命令后,协议在未配置GR的情况下,协议或RIB倒换重新恢复后,会延迟配置的seconds,再通知FIB老化表项。
# 配置IPv4路由在FIB中的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
flush route-attribute命令用来配置RIB向FIB下发路由时会携带属性消息。
undo flush route-attribute命令用来取消该配置。
flush route-attribute protocol
undo flush route-attribute protocol
RIB向FIB下发路由时不携带属性消息。
RIB IPv4地址族视图
protocol:路由协议,目前只支持BGP。
# 配置RIB向FIB下发BGP路由时会携带属性消息。
[Sysname] rib
[Sysname-rib-ipv4] flush route-attribute bgp
hardware-resource routing-mode命令用来配置Routing-mode的硬件资源模式。
undo hardware-resource routing-mode命令用来恢复缺省情况。
hardware-resource routing-mode { ipv6-64 | ipv6-128 }
Routing-mode的硬件资源模式为IPv6-128模式。
ipv6-64:表示IPv6-64模式。
ipv6-128:表示IPv6-128模式。
该配置在设备重启后才能生效,进行设备重启前请评估重启对网络造成的影响,做好相关准备工作。
Routing-mode的硬件资源模式有两种:
·     ipv6-64模式:只支持IPv6小于等于64位掩码路由。
·     ipv6-128模式:支持IPv6大于64位路由。
关闭前缀大于64位的IPv6路由功能时,前缀为128位的IPv6主机路由不支持ECMP。
# 配置Routing-mode的硬件资源模式为IPv6-64模式。
[Sysname] hardware-resource routing-mode ipv6-64
·     display hardware-resource routing-mode
inter-protocol fast-reroute命令用来开启RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
undo inter-protocol fast-reroute命令用来关闭RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
不同协议间快速重路由功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
vpn-instance vpn-instance-name:开启指定VPN实例的不同协议间快速重路由功能。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则开启RIB IPv4/IPv6地址族中公网的不同协议间快速重路由功能。
通过配置不同协议间快速重路由功能,可将不同协议的下一跳作为备份下一跳。当路由器检测到网络故障时,将使用备份下一跳替换失效下一跳,通过备份下一跳来指导报文的转发,从而大大缩短了流量中断的时间。
如果RIB表中去往同一目的地的不同路由的下一跳和出接口均相同,使用该命令不会生成备份下一跳。
使用不同协议间的快速重路由功能生成备份下一跳时可能会造成环路。
# 开启RIB IPv4地址族中公网的不同协议间快速重路由功能。
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
interface nexthop命令用来为ECMP组配置出接口和下一跳。
undo interface nexthop命令用来删除ECMP组中指定的出接口和下一跳。
interface interface-type interface-number nexthop nexthop-address
undo interface interface-type interface-number nexthop nexthop-address
ECMP组中不存在出接口和下一跳信息。
ECMP组视图
interface-type interface-number:指定出接口的类型和编号。
nexthop-address:指定下一跳IPv4地址。
多次执行本命令,可以为ECMP组指定多个下一跳和出接口,最多可以配置的下一跳和出接口数量为16。配置ECMP组时,需要多次执行本命令将等价路由的所有出接口和下一跳都加入到同一个ECMP组里,否则该ECMP组不生效。
如果不同的ECMP组具有完全相同的下一跳和出接口,则ID较小的ECMP组生效。
# 为ECMP组1配置出接口和下一跳。
[Sysname] rib
[Sysname-rib-ipv4-ecmp-group-1] interface hundredgige 1/0/1 nexthop 10.1.1.2
[Sysname-rib-ipv4-ecmp-group-1] interface hundredgige 1/0/2 nexthop 11.1.1.2
·     ecmp-group
ip route fast-switchover enable命令用来开启IPv4路由快速切换功能。
undo ip route fast-switchover enable命令用来关闭IPv4路由快速切换功能。
IPv4路由快速切换功能处于关闭状态。
在未开启本功能的情况下,当某个物理接口为大量路由(包括等价路由和主备路由的主路由)连接下一跳的出接口时,如果该接口所在的链路故障时,设备需要先删除失效链路对应的所有ARP表项,然后通知FIB删除失效的FIB表项,处理时间过长,流量无法快速切换到可用路径。通过开启本功能,当接口所在的链路故障时,设备直接通知FIB删除失效的FIB表项,以加快路由的切换、缩短流量中断的时间。
# 开启IPv4路由快速切换功能。
[Sysname] ip route fast-switchover enable
ipv6 route fast-switchover enable命令用来开启IPv6路由快速切换功能。
undo ipv6 route fast-switchover enable命令用来关闭IPv6路由快速切换功能。
IPv6路由快速切换功能处于关闭状态。
在未开启本功能的情况下,当某个物理接口为大量路由(包括等价路由和主备路由的主路由)连接下一跳的出接口时,如果该接口所在的链路故障时,设备需要先删除失效链路对应的所有ND表项,然后通知FIB删除失效的FIB表项,处理时间过长,流量无法快速切换到可用路径。通过开启本功能,当接口所在的链路故障时,设备直接通知FIB删除失效的FIB表项,以加快路由的切换、缩短流量中断的时间。
# 开启IPv6路由快速切换功能。
[Sysname] ipv6 route fast-switchover enable
maintenance-probe enable命令用来开启MTP(Maintain Probe,维护探测器)功能。
undo maintenance-probe enable命令用来关闭MTP功能。
MTP功能处于关闭状态。
开启MTP功能后,当与邻居间的路由协议报文超时时,设备会向超时的邻居发起Ping操作和Tracert操作并记录结果,相关信息可以通过display bgp troubleshooting等路由协议模块的显示命令查看,也可以通过display logbuffer命令查看MTP的详细信息。
# 开启MTP功能。
[Sysname] maintenance-probe enable
·     display bgp troubleshooting(三层技术-IP路由命令参考/BGP)
·     display logbuffer(网络管理和监控命令参考/信息中心)
1.1.39  path-id
path-id命令用来创建ECMP路径。
undo path-id命令用来删除指定的ECMP路径。
path-id path-id dscp dscp-value mask mask-value
undo path-id path-id
不存在ECMP路径。
ECMP组视图
path-id:路径ID,取值范围为1~7。
dscp dscp-value:DSCP优先级,取值范围为0~63。
mask mask-value:DSCP的掩码值,取值范围为0~63。设备会将该掩码值与报文的DSCP值进行与运算,运算结果和dscp-value相同的报文才会匹配路径ID。
多次执行本命令时,如果指定不同的path-id值,则可以创建多条ECMP路径;如果指定相同的path-id,则最后一次执行的命令生效。
同一个ECMP组里不同路径的DSCP优先级不能相同,不同的ECMP组之间则无此限制。
在创建ECMP组之后,需要多次执行interface nexthop命令将等价路由的多个出接口和下一跳加入该ECMP组,然后通过path-id命令创建ECMP路径。ECMP路径会自动复制ECMP组里的所有下一跳和出接口,但会将这些下一跳和出接口按照不同的顺序排列。如果报文匹配到的路由有多个下一跳和出接口,并且这些下一跳和出接口都在同一个ECMP组里,则报文会匹配该ECMP组。然后报文会根据DSCP优先级与该ECMP组的ECMP路径的DSCP掩码值进行与运算,运算结果和ECMP路径的DSCP优先级相同的报文会匹配ECMP路径。
等价路由的多个下一跳和出接口在ECMP路径里会调整排列顺序,对于同一个数据流的报文,负载分担算法会为匹配到不同ECMP路径的报文选择不同的下一跳和出接口。例如,某个数据流报文的有多个下一跳和出接口,分别是1.1.1.1(出接口1)、2.2.2.2(出接口2)和3.3.3.3(出接口3),在未配置ECMP组时,负载分担算法会为该数据流的报文选择第三个下一跳和出接口3.3.3.3(出接口3),而该下一跳链路因延迟太高不能满足使用需求。配置了ECMP组之后,多个下一跳和出接口在ECMP路径的排列顺序不同,假如ECMP路径1里的排列顺序为2.2.2.2(出接口2)、3.3.3.3(出接口3)和1.1.1.1(出接口1),而负载分担算法此时仍然会选择第三个下一跳和出接口1.1.1.1(出接口1),而该下一跳链路可以满足用户的使用需求。用户修改报文的DSCP优先级可以调整匹配到的ECMP路径,从而修改报文的下一跳和出接口。
# 为ECMP组1和2创建ECMP路径。
<Sysname>system-view
[Sysname]rib
[Sysname-rib-ipv4-ecmp-group-1] path-id 1 dscp 20 mask 30
[Sysname-rib-ipv4-ecmp-group-1] path-id 2 dscp 24 mask 30
[Sysname-rib-ipv4-ecmp-group-1] quit
[Sysname-rib-ipv4] ecmp-group 2
[Sysname-rib-ipv4-ecmp-group-2] path-id 1 dscp 20 mask 30
[Sysname-rib-ipv4-ecmp-group-2] path-id 2 dscp 24 mask 30
·     ecmp-group
·     ip load-sharing mode(三层技术-IP业务/IP转发基础)
primary-path-detect bfd命令用来配置协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达。
undo primary-path-detect bfd命令用来取消协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达的配置。
primary-path-detect bfd { ctrl | echo } [ inter-protocol-frr | protocol-ecmp protocol ]
undo primary-path-detect bfd [ inter-protocol-frr | protocol-ecmp protocol ]
未配置协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达。
RIB IPv4地址族视图
RIB IPv6地址族视图
ctrl:配置通过控制报文方式的BFD会话检测主路由的下一跳是否可达。
echo:配置通过echo报文方式的BFD会话检测主路由的下一跳是否可达。
inter-protocol-frr:配置不同协议间快速重路由通过BFD会话检测主路由的下一跳是否可达。
protocol-ecmp protocol:配置指定路由协议的等价路由通过BFD会话检测主路由的下一跳是否可达。在RIB IPv4地址族视图中,该参数的取值包括bgpisisospfstatic。在RIB IPv6地址族视图中,对于控制报文方式的BFD会话,该参数的取值包括bgp4+isisv6ospfv3static;对于echo报文方式的BFD会话,该参数的取值包括bgp4+static
配置本命令后,设备会自动创建一个协议类型为IPFRR的BFD会话,通过该BFD会话对主路由的下一跳进行检测,以提高主路由下一跳失效时流量切换到备路由下一跳上的收敛速度:
·     对于不同协议间的快速重路由,主路由指的是去往同一目的地的多条路由中优先级最高的路由。
·     对于指定路由协议的等价路由,主路由指的是形成等价路由的每一条路由。如果在配置路由协议的快速重路由功能时指定了ecmp-shared参数,设备会为包含等价路由的所有路由通过LFA算法选取备份下一跳信息。自动计算的备份下一跳也作为等价路由添加到路由表中,状态为backup,该路由不是主路由,BFD不会检测这种等价路由。
通过重复执行本命令,可以修改BFD会话的工作方式(echo报文方式或控制报文方式)。
执行本命令时,如果没有指定inter-protocol-frrprotocol-ecmp参数,表示同时配置或取消配置不同协议间快速重路由和所有路由协议的所有等价路由通过BFD会话检测主路由的下一跳是否可达的功能。以此种方式进行的配置,优先级高于通过指定inter-protocol-frrprotocol-ecmp参数进行的配置。例如,当执行了primary-path-detect bfd ctrl命令后,仅可通过primary-path-detect bfd echo 命令修改配置,或通过undo primary-path-detect bfd命令取消配置。
通过控制报文方式的BFD会话检测主路由的下一跳是否可达时,由于控制报文方式的BFD会话需要两端进行协商才能成功建立,用户需要在下一跳设备上手工创建一个静态BFD会话。该BFD会话为控制报文方式的单跳BFD会话,并且会话源IP地址为本端自动创建的BFD会话的目的IP地址、会话目的IP地址为本端自动创建的BFD会话的源IP地址、远端标识符为本端自动创建的BFD会话的本地标识符。主路由下一跳设备上创建满足上述要求的静态BFD会话后,本端设备才能使用控制报文方式的BFD会话来检测主路由的下一跳。有关创建静态BFD会话的详细介绍,请参见“可靠性配置指导”中的“BFD”。
其他业务模块在通过BFD会话检测主路由的下一跳是否可达时,也会自动创建BFD会话(如BGP、OSPF、IS-IS等)。如果其他协议创建的自动BFD会话检测的路由下一跳与RIB主路由的下一跳相同,则设备不会重复自动创建同类型的BFD会话,而是复用其他协议的BFD会话。
# 配置通过控制报文方式的BFD会话检测IS-IS协议所有等价路由的下一跳是否可达。
[Sysname] rib
[Sysname-rib-ipv4] primary-path-detect bfd ctrl protocol-ecmp isis
·     fast-reroute(三层技术-IP路由命令参考/IS-IS)
·     inter-protocol fast-reroute
protocol lifetime命令用来配置IPv4/IPv6路由和标签在RIB中的最大存活时间。
undo protocol lifetime命令用来恢复缺省情况。
undo protocol protocol [ instance instance-name ] lifetime
IPv4/IPv6路由和标签在RIB中的最大存活时间为900秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议。
instance instance-name:BGP实例名称,instance-name为1~31个字符的字符串,区分大小写。如果未指定本参数,将配置所有BGP实例的最大存活时间。只有当protocolbgp时该参数可选。
seconds:最大存活时间,取值范围为1~6000,单位为秒。
如果配置了该命令,且协议配置GR的情况下,需要注意该时间不要与GR时间冲突,即必须要保证协议能够在该时间内完成GR并将全部表项下发RIB,否则会导致GR失败并断流。
# 配置RIB中RIP路由和标签的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] protocol rip lifetime 60
protocol nexthop recursive-lookup命令用来配置路由按照路由策略进行迭代下一跳查找。
undo protocol nexthop recursive-lookup命令用来取消该配置。
protocol protocol nexthop recursive-lookup route-policy route-policy-name
undo protocol protocol nexthop recursive-lookup route-policy
未配置路由按路由策略进行下一跳迭代查找。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议,RIB IPv4地址族视图下支持bgpstatic,RIB IPv6地址族视图下支持bgp4+static
route-policy-name:指定路由策略名,为1~63个字符的字符串,区分大小写。
通过配置按路由策略迭代下一跳,可以对路由迭代的结果进行控制。例如:当路由发生变化时,路由管理需要对非直连的下一跳重新进行迭代。如果不对迭代的结果路由进行任何限制,则路由管理可能会将下一跳迭代到一个错误的转发路径上,从而造成流量丢失。此时,可以通过配置本功能,将错误的依赖路由过滤掉,使路由迭代到通过路由策略过滤的指定依赖路由上。
配置路由策略时,如果配置了apply子句,apply子句不会生效。
配置路由策略时,请确保至少有一个正确的依赖路由能够通过该策略的过滤,否则可能导致相关路由不可达,无法正确指导转发。
# 配置静态路由按照路由策略policy1进行下一跳迭代查找。
[Sysname] rib
[Sysname-rib-ipv4] protocol static nexthop recursive-lookup route-policy policy1
reset ip routing-table statistics protocol命令用来清除路由表中的路由统计信息。
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name:清除指定VPN的路由统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
all-routes:清除公网和所有VPN实例的路由统计信息。
all-vpn-instance:清除所有VPN实例的路由统计信息。
protocol:清除IPv4路由表中指定路由协议的统计信息。
all:清除IPv4路由表中所有路由协议的统计信息。
如果没有指定all-routesvpn-instanceall-vpn-instance参数,则清除公网的路由统计信息。
# 清除路由表中的路由统计信息。
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics protocol命令用来清除IPv6路由表中的综合路由统计信息。
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
protocol:清除IPv6路由表中指定路由协议的统计信息。
all:清除IPv6路由表中所有路由协议的统计信息。
# 清除IPv6路由表中所有路由协议的综合路由统计信息。
<Sysname> reset ipv6 routing-table statistics protocol all
1.1.45  rib
rib命令用来进入RIB视图。
undo rib命令用来删除RIB视图下的所有配置。
rib
undo rib
# 进入RIB视图。
[Sysname] rib
[Sysname-rib]
routing-table limit命令用来配置设备支持的最大IPv4/IPv6激活路由前缀数。
undo routing-table limit命令用来恢复缺省情况。
不限制设备支持的最大IPv4/IPv6激活路由前缀数。
RIB IPv4地址族视图
RIB IPv6地址族视图
number:设备支持的最大IPv4/IPv6激活路由前缀数目,取值范围为1~4294967295。
warn-threshold:以百分比形式指定激活路由前缀数目告警阈值,取值范围为1~100。当设备中激活路由前缀数占最大支持激活路由前缀数的百分比达到告警阈值时,可以继续激活新的路由前缀,但会产生一条日志信息。当设备中的激活路由前缀数达到最大激活路由前缀数目时,将不再激活新的路由前缀,新增的路由前缀将被丢弃。
simply-alert:当设备的IPv4/IPv6激活路由前缀数超过最大支持的激活路由前缀数目时,可以继续激活新的路由前缀,但会产生一条日志信息。
RIB IPv4地址族视图下的配置用于控制公网和所有VPN实例内IPv4激活路由的总数。
RIB IPv6地址族视图下的配置用于控制公网和所有VPN实例内IPv6激活路由的总数。
当配置的激活路由前缀数最大值小于当前设备已经存在的激活路由的数目时,此时设备上超过最大值的激活路由不会失效。如果有路由出现震荡,超出激活路由前缀数最大值的部分不能被激活。
# 配置当前设备上的RIB IPv4地址族视图下公网和所有VPN实例内IPv4激活路由的总数超过1000时,可以继续激活新的路由前缀,但是会产生一条日志信息。
[Sysname] rib
[Sysname-rib-ipv4] routing-table limit 1000 simply-alert
snmp-agent trap enable ipv6 rib命令用来开启IPv6 RIB模块的告警功能。
undo snmp-agent trap enable ipv6 rib命令用来关闭IPv6 RIB模块的告警功能。
snmp-agent trap enable ipv6 rib [ prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
undo snmp-agent trap enable ipv6 rib [ prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
IPv6 RIB模块的告警功能处于开启状态。
prefix-exceed:整机IPv6路由前缀数量达到最大值的告警信息。
prefix-exceed-clear:整机IPv6路由前缀数量降到最大值以下的告警信息。
prefix-threshold-exceed:整机IPv6路由前缀数量达到告警阈值的告警信息。
prefix-thresholdexceed-clear:整机IPv6路由前缀数量降低到告警阈值以下的告警信息。
public-prefix-exceed:公网实例中IPv6路由前缀数量达到最大值的告警信息。
public-prefixexceed-clear:公网实例中IPv6路由前缀数量降到最大值以下的告警信息。
public-prefixthreshold-exceed:公网实例中IPv6路由前缀数量达到告警阈值的告警信息。
public-prefixthresholdexceed-clear:公网实例中IPv6路由前缀数量降到告警阈值以下的告警信息。
vrf-prefix-exceed:单个VPN实例中IPv6路由前缀数量达到最大值的告警信息。
vrf-prefixexceed-clear:单个VPN实例中IPv6路由前缀数量降到最大值以下的告警信息。
vrf-prefixthreshold-exceed:单个VPN实例中IPv6路由前缀数量达到告警阈值的告警信息。
vrf-prefixthresholdexceed-clear:单个VPN实例中IPv6路由前缀数量降到告警阈值以下的告警信息。
开启IPv6 RIB模块的告警功能后,IPv6 RIB模块会产生相应的告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
如果未指定任何参数,则表示开启或关闭IPv6 RIB的全部告警功能。
# 关闭IPv6 RIB模块的告警功能。
[Sysname] undo snmp-agent trap enable ipv6 rib
snmp-agent trap enable rib命令用来开启RIB模块的告警功能。
undo snmp-agent trap enable rib命令用来关闭RIB模块的告警功能。
snmp-agent trap enable rib [ prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
undo snmp-agent trap enable rib [ prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
RIB模块的告警功能处于开启状态。
prefix-exceed:整机IPv4路由前缀数量达到最大值的告警信息。
prefix-exceed-clear:整机IPv4路由前缀数量降到最大值以下的告警信息。
prefix-threshold-exceed:整机IPv4路由前缀数量达到告警阈值的告警信息。
prefix-thresholdexceed-clear:整机IPv4路由前缀数量降低到告警阈值以下的告警信息。
public-prefix-exceed:公网实例中IPv4路由前缀数量达到最大值的告警信息。
public-prefixexceed-clear:公网实例中IPv4路由前缀数量降到最大值以下的告警信息。
public-prefixthreshold-exceed:公网实例中IPv4路由前缀数量达到告警阈值的告警信息。
public-prefixthresholdexceed-clear:公网实例中IPv4路由前缀数量降到告警阈值以下的告警信息。
vrf-prefix-exceed:单个VPN实例中IPv4路由前缀数量达到最大值的告警信息。
vrf-prefixexceed-clear:单个VPN实例中IPv4路由前缀数量降到最大值以下的告警信息。
vrf-prefixthreshold-exceed:单个VPN实例中IPv4路由前缀数量达到告警阈值的告警信息。
vrf-prefixthresholdexceed-clear:单个VPN实例中IPv4路由前缀数量降到告警阈值以下的告警信息。
开启RIB模块的告警功能后,RIB模块会产生相应的告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
如果未指定任何参数,则表示开启或关闭RIB的全部告警功能。
# 关闭RIB模块的告警功能。
[Sysname] undo snmp-agent trap enable rib
