01-硬件描述
本章节下载: 01-硬件描述 (2.96 MB)
S7600E-X机箱外观请以实际发货为准。
图1-1 S7606E-X前、后面板示意图
1: 业务板槽位(0~5号槽位) |
2: 电源模块槽位 |
3: 风扇框槽位 |
4: 主控板槽位(6、8号槽位) |
5: 交换网板槽位(7、9、10号槽位) 需要注意的是,7号槽位仅当需要满配交换网板时使用。 |
图1-2 S7610E-X前、后面板示意图
1:业务板槽位(0~9号槽位) |
2: 电源模块槽位 |
3: 风扇框槽位 |
4: 主控板槽位(10、12号槽位) |
5:交换网板槽位(11、13、14号槽位) 需要注意的是,11号槽位仅当需要满配交换网板时使用。 |
S7600E-X系列交换机采用了可插拔设计,交换机整机重量与所插的可插拔部件的类型及数量有关。具体计算公式为:设备最终重量=机箱重量+单板总重量+电源总重量+可插拔接口模块总重量+其它可插拔部件总重量。
机型 |
整机最大配置重量 |
尺寸 |
高(H) |
宽(W) |
深(D) |
S7606E-X |
满配:<85kg |
397mm(9RU) |
440mm |
660mm |
S7610E-X |
满配:<130kg |
664mm(15RU) |
440mm |
660mm |
· RU(Rack Unit)是表示机柜高度的度量单位,1RU=44.45mm(1.75inch)。
· 表1-1中的尺寸数据为机箱本身的尺寸数值,不包括挂耳、走线架、单板、电源等现场安装部件和附件装配后的尺寸。
单板丝印 |
净重 |
尺寸 |
高(H) |
宽(W) |
深(D) |
LSUM1MPUS06XEC3 |
2.20kg |
40mm |
292mm |
318mm |
LSUM1MPUS10XE3 |
3.75kg |
40mm |
463mm |
318mm |
LSUM1MPUS10XEC3 |
3.30kg |
40mm |
463mm |
318mm |
LSUM1FAB06XEB3 |
1.95kg |
40mm |
292mm |
318mm |
LSUM1FAB10XEA3 |
2.80kg |
40mm |
463mm |
318mm |
LSUM1CGS8SH3 |
3.10kg |
40mm |
399mm |
355mm |
LSUM1CGS2FE3 |
2.82kg |
40mm |
399mm |
355mm |
LSUM2GT24PTSSC3 |
2.80kg |
40mm |
399mm |
355mm |
LSUM2GT24TSSC3 |
2.60kg |
40mm |
399mm |
355mm |
LSUM2GP40TS8FD3 |
3.15kg |
40mm |
399mm |
355mm |
LSUM1TGS48SH3 |
3.55kg |
40mm |
399mm |
355mm |
LSUM2TGS48SG3 |
3.55kg |
40mm |
399mm |
355mm |
LSUM2GP44TSSC3 |
3.00kg |
40mm |
399mm |
355mm |
LSUM2GP24TSSC3 |
2.85kg |
40mm |
399mm |
355mm |
LSUM1TGS24FD3 |
3.05kg |
40mm |
399mm |
355mm |
LSUM1TGS16FD3 |
2.91kg |
40mm |
399mm |
355mm |
LSUM2TGS16SF3 |
3.00kg |
40mm |
399mm |
355mm |
LSUM1GP48FD3 |
3.10kg |
40mm |
399mm |
355mm |
LSUM1GT48FD3 |
3.45kg |
40mm |
399mm |
355mm |
LSUM2GT48SC3 |
2.71kg |
40mm |
399mm |
355mm |
LSUM1GP48FC3 |
3.10kg |
40mm |
399mm |
355mm |
LSUM1GT48FC3 |
3.45kg |
40mm |
399mm |
355mm |
LSUM1FWDEC0 |
3.80kg |
40mm |
399mm |
355mm |
LSUM1NSDEC0 |
3.80kg |
40mm |
399mm |
355mm |
LSUM1WCMX20RT |
4.00kg |
40mm |
399mm |
355mm |
LSUM1WCMX40RT |
4.00kg |
40mm |
399mm |
355mm |
LSUM1ACGDEC0 |
3.80kg |
40mm |
399mm |
355mm |
LSUM1WBCZ720XRT |
3.5kg |
40mm |
399mm |
355mm |
S7600E-X系列交换机的单板尺寸以高(H)×宽(W)×深(D)形式表示。其中各项含义见以下说明:
· 高(H):指单板前面板的高度。
· 宽(W):指单板前面板的宽度。
· 深(D):指单板由前面板到连接器的深度。
表1-3 电源模块重量及尺寸列表
电源型号 |
净重 |
尺寸 |
高(H) |
宽(W) |
深(D) |
LSUM1AC1200 |
2.27kg |
41mm |
102mm |
400mm |
LSUM1AC2500 |
2.50kg |
41mm |
102mm |
400mm |
LSUM1DC2400 |
2.40kg |
41mm |
102mm |
400mm |
表1-4 风扇框重量及尺寸列表
风扇框 |
净重 |
尺寸(风扇框平放到桌面上) |
高(H) |
宽(W) |
深(D) |
S7606E-X主风扇框 |
3.95kg |
66mm |
291mm |
643mm |
S7606E-X次风扇框 |
1.60kg |
40mm |
291mm |
300mm |
S7610E-X主风扇框 |
6.55kg |
66mm |
463mm |
645mm |
S7610E-X次风扇框 |
2.25kg |
40mm |
463mm |
301mm |
S7600E-X系列交换机支持的单板种类丰富,不同单板的功耗有所不同,而且同一块单板在不同状态下的功耗也存在差异,具体型号单板的功耗请参见表1-5。
· 单板静态功耗是指单板已上电运行、所有端口均处于DOWN状态且单板的光接口上无可插拔接口模块的情况下,单板所产生的功耗。
· 单板动态功耗是指单板所有端口满配,广播风暴情况下所产生的功耗。
单板丝印 |
单板静态功耗 min |
单板动态功耗 max |
LSUM1MPUS06XEC3 |
74W |
135W |
LSUM1MPUS10XE3 |
139W |
240W |
LSUM1MPUS10XEC3 |
152W |
240W |
LSUM1FAB06XEB3 |
56W |
95W |
LSUM1FAB10XEA3 |
69W |
95W |
LSUM1CGS8SH3 |
58W |
138W |
LSUM1CGS2FE3 |
55W |
77W |
LSUM2GT24PTSSC3 |
38W |
60W |
LSUM2GT24TSSC3 |
35W |
45W |
LSUM2GP40TS8FD3 |
45W |
84W |
LSUM1TGS48SH3 |
54W |
130W |
LSUM2TGS48SG3 |
82W |
173W |
LSUM2GP44TSSC3 |
39W |
70W |
LSUM2GP24TSSC3 |
36W |
55W |
LSUM1TGS24FD3 |
50W |
104W |
LSUM1TGS16FD3 |
54W |
96W |
LSUM2TGS16SF3 |
45W |
75W |
LSUM1GP48FD3 |
49W |
78W |
LSUM1GT48FD3 |
48W |
65W |
LSUM2GT48SC3 |
37W |
51W |
LSUM1GP48FC3 |
49W |
78W |
LSUM1GT48FC3 |
48W |
65W |
LSUM1FWDEC0 |
156W |
170W |
LSUM1NSDEC0 |
156W |
170W |
LSUM1WCMX20RT |
125W |
180W |
LSUM1WCMX40RT |
125W |
180W |
LSUM1ACGDEC0 |
157W |
170W |
LSUM1WBCZ720XRT |
160W |
210W |
S7600E-X系列交换机的风扇框中均采用了具有自动调速功能的风扇(风扇的转速会随着设备散热需要进行自动调节)。在不同风扇速率下,风扇框产生的功耗有所不同,具体机型风扇框的功耗请参见表1-6。
表1-6 机箱风扇框功耗列表
机型 |
风扇框功耗 min |
风扇框功耗 max |
S7606E-X主风扇框 |
20W |
193W |
S7606E-X次风扇框 |
10W |
61W |
S7610E-X主风扇框 |
26W |
303W |
S7610E-X次风扇框 |
10W |
61W |
对于S7600E-X交换机,总功耗等于交换机整机功耗。
交换机整机功耗是指交换机所有在位运行的单板功耗及风扇框功耗的和。S7600E-X系列交换机整机功耗与所插的单板类型及数量、风扇框功耗有关,具体计算方式为:
· 交换机整机最小功耗=单板静态总功耗+风扇框最小功耗(例如,有一台S7610E-X交换机插有2块LSUM1MPUS10XE3主控板、2块LSUM1CGS2FE3业务板、2块LSUM1FAB10XEA3网板和1个S7610E-X风扇框,那么该交换机当前的最小功耗为2×139+2×55+2×69+26=552W)。
· 交换机整机最大功耗=单板动态总功耗+风扇框最大功耗(例如,有一台S7610E-X交换机插有2块LSUM1MPUS10XE3主控板、2块LSUM1CGS2FE3业务板、2块LSUM1FAB10XEA3网板和1个S7610E-X风扇框,那么该交换机当前的最大功耗为2×240+2×77+2×95+303=1127W)。
设备的发热量和设备功耗密切相关。计算S7600E-X系列交换机发热量时,一般假定:90%的功耗转换成热量,电源的转换效率为90%。因此S7600E-X系列交换机每小时散热量的计算公式为:交换机每小时散热量=0.9*(单板总功耗+风扇框功耗)/0.9*3.4121。
表1-7 设备每小时散热量列表
主机型号 |
热耗散(BTU/H) |
S7606E-X |
5330 |
S7610E-X |
9756 |
· S7600E-X系列交换机各型号单板及风扇框的功耗请参见“1.3 模块功耗列表及整机功耗计算方式”。
· 热量单位一般为BTU/h,1瓦=3.4121BTU/h。
表1-8 S7600E-X系列交换机环境适应性指标列表
指标 |
工作环境 |
贮存环境 |
温度 |
0°C~45°C |
-40°C~70°C |
相对湿度 |
5%~95%RH,无冷凝 |
5%~95%RH,无冷凝 |
S7600E-X系列交换机的风扇框中均采用了具有自动调速功能的风扇(风扇的转速会随着设备散热需要进行自动调节)。在不同风扇速率下,设备的噪声值有所不同,具体请参见表1-9。
表1-9 S7600E-X系列交换机噪声级别列表
常温下风扇调速设备噪声值 |
风扇全速设备噪声 |
S7606E-X |
56.1dBA |
73.3dBA |
S7610E-X |
66.2dBA |
75.5dBA |
单板与主机软件版本的适配情况,请参见对应版本的版本说明书。
单板与可插拔接口模块的适配关系,请参见《H3C S7600E-X系列交换机 单板与光模块适配关系表》。
S7600E-X系列交换机均支持双主控系统,同一机箱内所插的两块主控板的型号必须相同,您可根据实际需求为交换机配备1~2块主控板。
表2-1 主控板规格
单板丝印 |
Flash |
NVRAM |
SDRAM |
对外接口类型 |
适用的主机 |
LSUM1MPUS06XEC3 |
2GB |
1MB |
8GB |
· 1个Console口 · 1个USB Console接口 · 4个网管口(2个RJ45接口和2个SFP接口) · 1个USB接口 |
S7606E-X |
LSUM1MPUS10XE3 |
2GB |
1MB |
8GB |
S7610E-X |
LSUM1MPUS10XEC3 |
4GB |
1MB |
8GB |
S7610E-X |
· 设备启动过程中,主控板上的网管口,仅编号为0的网管口可以正常使用。
· 连接主控板上的SFP光网管口之前,请确保对端以太网接口的速率为1000Mbit/s,双工模式为全双工,否则可能会导致连接失败。
· USB接口不支持延长线。
S7600E-X系列交换机支持多种类型的业务板,每款业务板上提供的接口数量及类型有所不同,详见对应小节的介绍。
· 以太网接口板
· OAA单板
单板丝印 |
接口数量 |
接口类型 |
支持的可插拔接口模块 |
LSUM1CGS8SH3 |
8 |
8个100GBASE-R-QSFP28接口 |
· QSFP28模块 · QSFP28 DAC电缆 · QSFP28 AOC光缆 · QSFP28 to SFP28 DAC电缆 · QSFP+模块 · QSFP+ DAC电缆 · QSFP+ AOC光缆 · QSFP+ to SFP+ DAC电缆 |
LSUM1CGS2FE3 |
2 |
2个100GBASE-R-QSFP28光接口 |
QSFP28模块 |
LSUM2GT24PTSSC3 |
48 |
· 4个10GBASE-R-SFP+光接口 · 20个1000BASE-X-SFP光接口 · 24个10/100/1000BASE-T-RJ45电接口 |
· 万兆SFP+模块 · 万兆SFP+ DAC电缆 · 百兆/千兆SFP模块 · 超5类双绞线 |
LSUM2GT24TSSC3 |
28 |
· 4个10GBASE-R-SFP+光接口 · 24个10/100/1000BASE-T-RJ45电接口 |
LSUM2GP40TS8FD3 |
48 |
· 8个10GBASE-R-SFP+光接口 · 40个1000BASE-X-SFP光接口 |
· 万兆SFP+模块 · 万兆SFP+ DAC电缆 · 百兆/千兆SFP模块 |
LSUM1TGS48SH3 |
48 |
48个10GBASE-R-SFP+接口 |
· 万兆SFP+模块 · 万兆SFP+ DAC电缆 · 千兆SFP模块 |
LSUM2TGS48SG3 |
48 |
LSUM2GP44TSSC3 |
48 |
· 4个10GBASE-R-SFP+光接口 · 44个1000BASE-X-SFP光接口 |
LSUM2GP24TSSC3 |
28 |
· 4个10GBASE-R-SFP+光接口 · 24个1000BASE-X-SFP光接口 |
LSUM1TGS24FD3 |
24 |
24个10GBASE-R-SFP+光接口 |
LSUM1TGS16FD3 |
16 |
16个10GBASE-R-SFP+光接口 |
LSUM2TGS16SF3 |
16 |
10GBASE-R-SFP+光接口 |
LSUM1GP48FD3 |
48 |
1000BASE-X-SFP光接口 |
百兆/千兆SFP模块 |
LSUM1GP48FC3 |
48 |
1000BASE-X-SFP光接口 |
百兆/千兆SFP模块 |
LSUM1GT48FD3 |
48 |
超5类双绞线 |
LSUM2GT48SC3 |
48 |
超5类双绞线 |
LSUM1GT48FC3 |
48 |
超5类双绞线 |
S7600E-X目前支持以下型号的OAA单板。
表2-3 OAA业务板规格
单板丝印 |
单板描述 |
接口类型与数量 |
支持的可插拔接口模块 |
LSUM1WCMX20RT |
无线控制器业务板 |
· 1个Console接口 · 1个100/1000Base-T带外管理以太网接口 |
5类双绞线 |
LSUM1WCMX40RT |
无线控制器业务板 |
5类双绞线 |
LSUM1FWDEC0 |
防火墙业务板 |
· 1个Console接口 · 1个USB接口(硬件预留,软件暂不支持) · 1个千兆以太网电接口 · 1个硬盘插槽 |
5类双绞线 |
LSUM1NSDEC0 |
流量分析业务板 |
5类双绞线 |
应用控制网关业务板 |
· 1个Console接口 · 1个USB接口(预留) · 1个10/100/1000BASE-T电接口 · 1个硬盘插槽 |
5类双绞线 |
LSUM1WBCZ720XRT |
多业务无线控制器模块 |
· 3个USB2.0(仅供技术人员调试使用,用户无法使用) · 1个VGA口 · 1个1000BASE-T管理以太网接口 · 1个CONSOLE口 |
5类双绞线 |
光类型接口不支持配置或自协商成半双工模式,关于以太网接口的双工模式的详细内容,请参见《H3C S7600E-X系列交换机 接口管理命令参考》中的“以太网接口”。
表2-4 交换网板规格
单板丝印 |
接口连接器类型 |
对外接口 |
LSUM1FAB06XEB3 |
RJ-45 |
1个Console口 |
LSUM1FAB10XEA3 |
RJ-45 |
1个Console口 |
S7600E-X交换机适配的交换网板型号以及可以配备的数量请参见表2-5。
机型 |
适配交换网板型号 |
单台主机配备交换网板数量 |
S7606E-X |
LSUM1FAB06XEB3 |
0~3块 |
S7610E-X |
LSUM1FAB10XEA3 |
0~3块 |
· 对于S7610E-X交换机,如果需要安装交换网板,请优先安装至编号为13、14的槽位,编号为11的槽位仅当满配交换网板时使用。
· 交换网板上的Console接口仅供H3C技术支持人员维护设备使用,没有经过专业培训的用户,请勿擅自操作。
S7600E-X系列交换机支持的交流电源模块型号为LSUM1AC1200和LSUM1AC2500,支持的直流电源模块型号为LSUM1DC2400。
项目 |
LSUM1AC1200电源模块 |
LSUM1AC2500电源模块 |
LSUM1DC2400电源模块 |
额定输入电压范围 |
100~240V AC;50/60Hz |
-48~-60V DC |
额定输出电压 |
12V DC |
12V DC |
12 V DC |
最大输入电流 |
16A |
16A |
60A |
最大输出电流 |
100A |
· 208A (220V AC) · 100A (110V AC) |
200A |
最大输出功率 |
1200W |
· 1200W (110V AC) · 2500W (220V AC) |
2400W |
配置数量 |
S7606E-X:1~4个 S7610E-X:1~6个 |
适用的主机类型 |
S7600E-X所有型号的主机 |
S7600E-X所有型号的主机 |
S7600E-X所有型号的主机 |
环境温度要求 |
工作温度 |
-10~50°C |
贮藏温度 |
-40~70°C |
您可根据S7600E-X系列交换机的实际功耗需求选配合适数量的电源模块。请确保交换机所配备电源模块的最大输出功率之和大于交换机整机功耗(建议预留20%的功率余量)。
· 不同型号的电源模块不能混插在同一台设备上。
· 当电源模块温度超过正常工作温度时,电源将自动关闭,当温度恢复到正常范围后,电源将会自动开启。
直流电源线用于交换机的直流电源模块与外部直流供电系统之间的连接,S7600E-X交换机支持的电源线请参见表2-7,请根据实际需求选配合适的直流电源线的型号和数量。
机型 |
直流电源线数量 |
支持的直流电源线编码及长度 |
S7606E-X |
1~4对 |
0404A0E1(3m) 0404A0E2(15m) |
直流电源线适用于S7600E-X系列交换机的LSUM1DC2400直流电源模块 |
S7610E-X |
1~6对 |
交流电源线用于交换机的交流电源模块与外部交流供电系统之间的连接。
¡ 电源模块的功率大小对交流电源线的载流能力具有要求,请根据实际的载流能力要求选择合适的交流电源线。
¡ 不同国家或地区的电源插头制式有所不同,请根据实际情况选择符合插头制式要求的交流电源线。
¡ S7600E-X系列交换机支持的交流电源模块需选配16A交流电源线,插头制式与国家或地区的对应关系请参见表2-8。
表2-8 16A交流电源线插头制式与国家或地区对应关系表
1 |
插头制式 |
编码(长度) |
符合安规认证要求、可以合法使用的国家或地区 |
其它主要使用的国家或地区 |
其它较少使用的国家或地区 |
I 型 |
04043396(3米) |
中国大陆 |
插头外形 |
电缆外形 |
连接器外形 |
2 |
插头制式 |
编码(长度) |
其他主要使用的国家或地区 |
其他较少使用的国家或地区 |
C20型 |
0404A0C2(3米) |
中国大陆 |
插头外形 |
电缆外形 |
连接器外形 |
3 |
插头制式 |
编码(长度) |
其它主要使用的国家或地区 |
其它较少使用的国家或地区 |
B 型 |
0404A063(3米) |
加拿大、美国 |
墨西哥、阿根廷、巴西、哥伦比亚、委内瑞拉、泰国、秘鲁、菲律宾、A6国 |
插头外形 |
电缆外形 |
连接器外形 |
4 |
插头制式 |
编码(长度) |
其它主要使用的国家或地区 |
其它较少使用的国家或地区 |
F 型 |
0404A061(3米) |
荷兰、丹麦、瑞典、芬兰、挪威、德国、法国、奥地利、比利时、意大利 |
印尼、土耳其、 俄罗斯、独联体 |
插头外形 |
电缆外形 |
连接器外形 |
5 |
插头制式 |
编码(长度) |
其它主要使用的国家或地区 |
其它较少使用的国家或地区 |
B 型 |
0404A062(3米) |
日本 |
插头外形 |
电缆外形 |
连接器外形 |
6 |
插头制式 |
编码(长度) |
其它主要使用的国家或地区 |
其它较少使用的国家或地区 |
I 型 |
0404A01A(3米) |
澳大利亚 |
插头外形 |
电缆外形 |
连接器外形 |
表2-8中“连接器外形”指的是用来连接设备端的连接器的形状。
S7600E-X系列交换机不同机箱支持的风扇框有所不同,具体如表2-9所示。
表2-9 S7600E-X系列交换机风扇框简介
风扇框 |
风扇框中风扇个数 |
风扇直径 |
最大风量 |
S7606E-X主风扇框 |
6 |
120mm |
680CFM |
S7606E-X次风扇框 |
2 |
120mm |
200CFM |
S7610E-X主风扇框 |
10 |
120mm |
980CFM |
S7610E-X次风扇框 |
2 |
120mm |
260CFM |
S7600E-X系列交换机风扇框随机箱发货,出厂时,S7606E-X、S7610E-X交换机0号槽位的风扇框已安装,1号槽位的风扇框可根据实际需要确定是否安装。如果设备的风扇框损坏需要单独购买并更换时,请注意选配与机箱配套的风扇框。
S7600E-X系列交换机提供种类丰富的指示灯,通过查看指示灯的状态,可以判断该指示灯所指示对象的运行状态。具体请参见表3-1。
表3-1 S7600E-X系列交换机指示灯
指示灯所在位置 |
指示灯 |
主控板 |
管理用以太网口状态指示灯 |
具体请参见3.2 2. |
风扇状态指示灯 |
具体请参见3.2 3. |
电源状态指示灯 |
具体请参见3.2 4. |
单板状态指示灯 |
具体请参见3.2 5. |
主控板主用/备用状态指示灯 |
具体请参见3.2 6. |
以太网接口板 |
RJ-45以太网端口状态指示灯 |
具体请参见3.3 1. |
SFP口状态指示灯 |
具体请参见3.3 2. |
SFP+口状态指示灯 |
具体请参见3.3 3. |
QSFP+口状态指示灯 |
具体请参见3.3 4. |
QSFP28口状态指示灯 |
具体请参见3.3 5. |
交换网板 |
交换网板状态指示灯 |
具体请参见3.4 |
风扇框 |
风扇框状态指示灯 |
具体请参见3.5 |
电源模块 |
电源模块状态指示灯 |
具体请参见3.6 |
图3-2 LSUM1MPUS10XE3主控板指示灯示意图
1: 管理用以太网口状态指示灯(LINK/ACT) |
2: 风扇状态指示灯(FAN) |
3: 电源状态指示灯(PWR) |
4: 单板状态指示灯(SLOT) |
5:主控板主用/备用状态指示灯(ACTIVE) |
LSUM1MPUS10XE3、LSUM1MPUS10XEC3和LSUM1MPUS06XEC3主控板指示灯类似,如图3-2所示。
主控板上提供有管理用以太网口状态指示灯,通过查看指示灯状态,可以判断出管理用以太网口的链路状态及当前数据收发状态,管理用以太网口状态指示灯含义请参见表3-2和表3-3。
表3-2 管理用以太网口状态指示灯含义(RJ-45接口)
管理用以太网口状态指示灯状态 |
指示灯含义 |
LINK |
ACT |
常亮 |
闪烁 |
管理用以太网口链路连通,且正在接收或发送数据 |
常亮 |
灯灭 |
管理用以太网口链路连通 |
灯灭 |
灯灭 |
管理用以太网口链路没有连通 |
表3-3 管理用以太网口状态指示灯含义(SFP接口)
管理用以太网口状态指示灯 |
指示灯状态 |
含义 |
LINK/ACT(绿色) |
闪烁 |
常亮 |
管理用以太网口链路连通 |
灯灭 |
管理用以太网口链路没有连通 |
主控板上提供有风扇状态指示灯FAN(OK/FAIL指示灯)。通过查看指示灯状态,可以判断出机箱风扇框的工作状态,具体请参见表3-4。
风扇状态指示灯状态 |
指示灯含义 |
绿灯常亮 |
风扇框正常工作 |
红灯常亮 |
风扇框中存在风扇故障或风扇框不在位 |
灯灭 |
交换机未上电启动 |
主控板上提供有电源状态指示灯PWR(OK/FAIL指示灯)。通过查看指示灯状态,可以判断出机箱电源模块的工作状态,具体请参见表3-5。
电源状态指示灯状态 |
指示灯含义 |
绿灯常亮 |
电源模块正常工作 |
红灯常亮 |
电源模块故障或电源模块不在位 |
灯灭 |
交换机未上电启动 |
主控板上提供了单板状态指示灯(SLOT),不同编号的指示灯用于指示对应槽位的单板状态(包括主用主控板、备用主控板、所有业务板和所有交换网板)。指示灯的具体含义请参见表3-6。
单板状态指示灯状态 |
指示灯含义 |
RUN/ALM |
绿灯闪烁(1次/2秒) |
对应槽位单板正常工作 |
红灯闪烁(4次/秒) |
对应槽位的业务板/交换网板正在加载软件(如果持续处于此状态,设备当前运行的软件版本与该单板软件版本不匹配) |
红灯闪烁(1次/4秒) |
对应槽位单板温度异常(温度高于Warning或Alarm高温门限或者温度低于低温告警门限) |
红灯常亮 |
对应槽位单板运行故障 |
灯灭 |
对应槽位单板未上电或不在位 |
· 如果RUN/ALM指示灯处于快速闪烁(4次/秒)状态,表示对应槽位业务板或者交换网板正在加载软件,如果持续处于此状态,则设备当前运行的软件版本与该单板不匹配。
· 本节描述的是主用主控板正常启动后各指示灯的状态,如果主用主控板没有正常启动,所有指示灯状态均为“灯灭”。
主控板上提供有主控板主用/备用状态指示灯(ACTIVE)。通过查看指示灯状态,可以判断出主控板的主用/备用状态,具体请参见表3-7。
表3-7 主控板主用/备用状态指示灯含义
主控板主用/备用状态指示灯 |
指示灯状态 |
指示灯含义 |
ACTIVE |
常亮 |
该主控板工作在主用状态 |
灯灭 |
可能的情况如下: · 该主控板工作在备用状态 · 主控板有故障(具体判断主控板是否出现故障,请结合单板状态指示灯) |
S7600E-X系列交换机支持多种型号的业务板,不同型号业务板上的指示灯类型及数量存在差异。
具有RJ-45以太网端口的业务板上提供有RJ-45以太网端口状态指示灯。通过查看指示灯状态,可以判断出对应以太网端口的链路状态及当前数据收发状态,具体请参见表3-8。
表3-8 RJ-45以太网端口状态指示灯含义
指示灯 |
指示灯状态 |
指示灯含义 |
RJ-45以太网端口状态指示灯 |
灯闪烁 |
以太网端口正在接收或发送数据 |
灯亮 |
以太网端口链路已经连通 |
灯灭 |
以太网端口链路没有连通 |
您可以根据10GBase-T RJ-45以太网端口状态指示灯的颜色查看端口速率,绿色表示10Gbit/s,黄色表示1000M/100Mbit/s。
具有SFP口的业务板上提供有SFP口状态指示灯。通过查看指示灯状态,可以判断出对应SFP口的链路状态及当前数据收发状态,具体请参见表3-9。
表3-9 SFP口状态指示灯含义
指示灯 |
指示灯状态 |
指示灯含义 |
SFP口状态指示灯 |
灯闪烁 |
SFP口正在接收或发送数据 |
灯亮 |
SFP口链路已经连通 |
灯灭 |
SFP口链路没有连通 |
具有SFP+口的业务板上提供有SFP+口状态指示灯。通过查看指示灯状态,可以判断出对应SFP+口的链路状态及当前数据收发状态,具体请参见表3-10。
表3-10 SFP+口状态指示灯含义
指示灯 |
指示灯状态 |
指示灯含义 |
SFP+口状态指示灯 |
灯闪烁 |
SFP+口正在接收或发送数据 |
灯亮 |
SFP+口链路已经连通 |
灯灭 |
SFP+口链路没有连通 |
您可以根据SFP+口状态指示灯的颜色查看端口速率,绿色表示10Gbit/s,黄色表示1000Mbit/s。
具有QSFP+口的业务板上提供有QSFP+口状态指示灯。通过查看指示灯状态,可以判断出对应QSFP+口的链路状态及当前数据收发状态,具体请参见表3-11。
表3-11 QSFP+口状态指示灯含义
指示灯 |
指示灯状态 |
指示灯含义 |
QSFP+口状态指示灯 |
灯闪烁 |
QSFP+口正在接收或发送数据 |
灯亮 |
QSFP+口链路已经连通 |
灯灭 |
QSFP+口链路没有连通 |
具有QSFP28口的业务板上提供有QSFP28口状态指示灯。通过查看指示灯状态,可以判断出对应QSFP28口的链路状态及当前数据收发状态,具体请参见表3-12。
表3-12 QSFP28口状态指示灯含义
指示灯 |
指示灯状态 |
指示灯含义 |
QSFP28口状态指示灯 |
灯闪烁 |
QSFP28口正在接收或发送数据 |
灯亮 |
QSFP28口链路已经连通 |
灯灭 |
QSFP28口链路没有连通 |
S7600E-X系列交换机的交换网板上提供有交换网板状态指示灯。通过查看指示灯状态,可以判断出交换网板的工作状态,交换网板指示灯含义请参见表3-13。
交换网板状态指示灯状态 (RUN/ALM/OFL) |
指示灯含义 |
灯灭 |
交换网板不在位或者交换网板未上电 |
绿灯常亮 |
交换网板处于Offline状态 |
绿灯闪烁(0.5Hz) |
交换网板正常工作 |
红灯常亮 |
交换网板有严重告警或运行故障 |
红灯闪烁(0.25Hz) |
交换网板有温度告警等非严重告警 |
交换网板被隔离或按下交换网板上的offline按钮后,交换网板处于Offline状态,offline按钮仅供专业技术人员调试和定位问题使用,不推荐用户使用。
S7600E-X系列交换机的风扇框上提供有风扇框状态指示灯,通过查看指示灯状态,可以判断出风扇框的工作状态,S7600E-X交换机上的风扇框指示灯含义请参见表3-14。
风扇框状态指示灯状态 |
指示灯含义 |
OK |
FAIL |
常亮 |
灯灭 |
风扇框正常工作 |
灯灭 |
常亮 |
风扇框中存在风扇故障 |
灯灭 |
灯灭 |
风扇框未上电启动 |
S7600E-X系列交换机支持的电源模块型号为LSUM1AC1200、LSUM1AC2500 和LSUM1DC2400。
· LSUM1AC1200和LSUM1AC2500电源模块上提供有电源模块状态指示灯(AC指示灯和DC指示灯),通过查看指示灯状态,可以判断出电源模块的工作状态,具体请参见表3-15。
· LSUM1DC2400电源模块上提供有电源模块状态指示灯(INP OK指示灯和DC/FLT指示灯),通过查看指示灯状态,可以判断出电源模块的工作状态,具体请参见表3-16。
表3-15 LSUM1AC1200和LSUM1AC2500交流电源模块状态指示灯含义
指示灯 |
颜色 |
状态 |
AC |
灭 |
电源模块无系统输入 |
输入电压过低,电源模块进入自我保护状态 |
绿色 |
电源模块系统输入正常 |
DC |
绿色 |
电源模块系统输出正常 |
红色 |
电源模块系统输出异常(电源在输出短路、输出过流、输出过压、输入欠压、远程关闭等情况下告警,并进入自我保护状态) |
橙色 |
电源温度过高告警,电源模块进入自我保护状态 |
表3-16 LSUM1DC2400直流电源模块指示灯含义
指示灯 |
颜色 |
状态 |
INP OK |
灭 |
电源模块无系统输入 |
绿色 |
电源模块系统输入正常 |
DC/FLT |
绿色 |
电源模块系统输出正常 |
红色 |
电源模块系统输出异常(电源在输出短路、输出过流、输出过压、输入欠压、过温保护、远程关闭等情况下告警,并进入自我保护状态) |
橙色 |
电源温度过高告警,电源模块即将进入自我保护状态 |
S7600E-X系列交换机支持多种型号业务板,不同的业务板上的端口类型存在差异,不同类型的端口需要使用不同的线缆进行连接,具体请参见表4-1。
连接线缆 |
适用端口类型 |
用途 |
详细介绍 |
Console口配置电缆 |
一端为Console口,另一端为9芯(针)串口 |
用于连接交换机Console口/USB Console口和配置终端,使用户可以进行系统的调试、配置、维护、管理、主机软件程序加载等工作 |
请参见《H3C S7600E-X系列交换机 安装指南》 |
USB Console口配置电缆 |
一端为USB Console口,另一端为USB接口 |
以太网双绞线 |
RJ-45以太网端口 |
用于传输数据 |
光纤 |
SFP+/SFP/QSFP+/QSFP28口 |
SFP+ DAC电缆 |
SFP+口 |
QSFP+ DAC电缆 |
QSFP+/QSFP28口 |
QSFP28 DAC电缆 |
QSFP28口 |
QSFP+ AOC光缆 |
QSFP+/QSFP28口 |
QSFP28 AOC光缆 |
QSFP28口 |
一端QSFP+口,另一端SFP+口 |
以太网双绞线(Twisted-Pair Cable)由不同颜色的8根具有绝缘保护层的铜导线组成,每两根导线按一定规则绞合在一起,共组成4对对绞线。
以太网双绞线主要用于传输模拟信号,但也适用于传输数字信号,特别适用于较短距离的信息传输,是目前局域网上常用的传输介质。
以太网双绞线的最大传输距离为100m。
每条以太网双绞线通过两端安装的RJ-45连接器(俗称水晶头)将各种网络设备连接起来。RJ-45连接器引脚序号如图4-1所示。
图4-1 RJ-45连接器引脚序号示意图
RJ-45连接器引脚序号与铜导线颜色具有一定的对应关系,EIA/TIA的布线标准中规定了两种双绞线的线序568A和568B。
· 标准568A:白绿--1,绿--2,白橙--3,蓝--4,白蓝--5,橙--6,白棕--7,棕--8。
· 标准568B:白橙--1,橙--2,白绿--3,蓝--4,白蓝--5,绿--6,白棕--7,棕--8。
按照电气性能的不同,以太网双绞线可分为3类线、4类线、5类线、超5类线、6类线、6A类线和7类线等类型,数字越大,级别越高、带宽也越宽。
双绞线类型 |
介绍 |
5类 |
适用于最高传输速率为100Mbps的数据传输,传输带宽是100MHZ |
超5类 |
适用于最高传输速率为1000Mbps的数据传输,传输带宽是100MHZ |
6类 |
适用于传输速率高于1Gbps的数据传输,传输带宽是250MHZ |
6A类 |
适用于传输速率高于10Gbps的数据传输,传输带宽是500MHZ |
7类 |
适用于传输速率高于10Gbps的数据传输,传输带宽是600MHZ |
根据线序的不同,以太网双绞线可分为直通线(Straight-Through Twisted-Pair Cable)和交叉线(Crossover Twisted-Pair Cable)。
· 直通线:双绞线两端的线序都为标准568B,如图4-2所示。
· 交叉线:双绞线一端的线序为标准568B,另一端的线序为标准568A,如图4-3所示。
直通线或交叉线的使用原则:
· 直通线用于连接不同类型设备,比如连接交换机和PC、交换机和路由器等。
· 交叉线用于连接同种类型设备,比如连接交换机和交换机、路由器和路由器、PC和PC等。
如果RJ-45以太网端口支持MDI/MDIX自适应特性,当MDI/MDIX自适应启用时,端口能自动适应不同线序(自动适应直通线或交叉线)。
S7600E-X系列交换机RJ-45以太网端口支持MDI/MDIX自适应特性。缺省情况下,端口启用MDI/MDIX自适应。
当选用光纤连接网络设备时,同一通信线路中使用的可插拔接口模块、尾纤、跳纤、光缆的类型必须保持一致。即如果采用单模光纤进行连接,该通信线路中使用的可插拔接口模块、尾纤、跳纤、光缆都必须是单模类型。
光纤是光导纤维(Optical Fiber)的简称,是一种传输光能的波导介质,一般由纤芯和包层组成。
光纤传输方式损耗低,传输距离远,在长距离传输方面具有优势。
按光在光纤中的传输模式不同,光纤可分为单模光纤(SMF,Single Mode Fiber)和多模光纤(MMF,Multi Mode Fiber)。
· 单模光纤:中心玻璃芯较细(10μm或更小),只能传一种模式的光。模间色散较小,适用于远程通讯。
· 多模光纤:中心玻璃芯较粗(50μm、62.5μm或更大),可传多种模式的光。模间色散较大,传输距离比较短,一般只有几公里。
光纤的最大拉伸力和压扁力如表4-3所示。
受力时间 |
拉伸力(N) |
压扁力(N/mm) |
短暂受力 |
150 |
500 |
长期受力 |
80 |
100 |
由于户外长距离传输的需要而将多根光纤封装在一起而组成的线缆称为光缆,光缆外皮一般为黑色,里面有钢丝保护。按封装的光纤类型不同,光缆有单模、多模之分。
两端都有连接器的光纤为跳纤。跳纤用来做从设备到光纤布线链路的跳接线,一般用于连接光端机和终端盒。常见的跳纤有单模跳纤和多模跳纤。
· 单模跳纤:外皮一般为黄色,接头和保护套为蓝色,传输距离较长。
· 多模跳纤:外皮一般为橙色,接头和保护套为米色或者黑色,传输距离较短。
按接口类型来分,跳纤还分为SC跳纤、LC跳纤、FC跳纤等多种类型。跳纤长度的规格一般有0.5m、1m、2m、3m、5m、10m等。
只有一端有连接器,而另一端是纤芯断头的光纤为尾纤。尾纤通过熔接与光缆的纤芯相连,常出现在光纤终端盒内,主要用于连接光缆和光纤收发器。(光纤熔接是指用熔纤机将光纤和光纤或光纤和尾纤连接,把光缆中的裸纤和光纤尾纤熔合在一起变成一个整体。)
尾纤可分为单模尾纤(黄色)和多模尾纤(橙色)。按接口类型来分,尾纤还分为SC尾纤、LC尾纤、FC尾纤等多种类型。
光纤连接器是光纤通信系统中不可缺少的无源器件,它的使用实现了光通道间的可拆式连接,使光系统的调测与维护更为方便。光纤连接器的种类很多,SC、LC型光纤连接器外观分别如图4-4、图4-5所示。
图4-5 LC型光纤连接器外观示意图
S7600E-X系列交换机的SFP+/SFP/QSFP+/QSFP28口使用光纤进行连接。在使用光纤进行连接时,请注意以下内容:
· 请确认光纤连接器及光纤的类型是否与所采用的可插拔接口模块的类型相符。
· S7600E-X系列交换机的部分配套单板上的光接口具有屏蔽堵头,当需要使用这些光接口时,需要先取下屏蔽堵头。请妥善保管取下的屏蔽堵头,当不再使用这些光接口时,需要在这些光接口上重新安装上屏蔽堵头。
· 光纤连接器上具有防尘帽,在使用光纤连接器时,请妥善保管防尘帽。当不再使用时,光纤连接器上必须盖好防尘帽,以免在装配过程中将光纤连接器插芯端面划伤而影响其性能指标。如果防尘帽过松或有污染,请您及时更换。
· 使用光纤连接前,请用无尘纸沾无水酒精将光纤连接器插芯端面擦净,擦拭时只能向一个方向擦,同时也要擦拭与其对接的光纤接头端面。
· 请勿扭曲、弯折光纤,安装后光纤的弯曲半径不得小于40mm(动态弯曲情况下最小弯曲半径为20D,静态情况下为10D,D为光纤防尘帽外径)。
· 连接时,如果光纤需要穿过金属板孔,那么该金属板孔应具有光滑的、经过充分倒圆的表面(倒圆半径R应不小于2mm),穿过金属板孔及沿结构件锐边转弯时,应加保护套或衬垫。
· 插拔光纤连接器时请勿用力过猛,避免用力拉、压、挤光纤。光纤允许的拉伸力和压扁力的最大值请参见表4-3。
SFP+口可以采用SFP+ DAC电缆进行连接。SFP+ DAC电缆支持SFP+电气和协议标准,采用10G SFP+ Cu标准电缆。外观示意如图4-6所示。
图4-6 SFP+ DAC电缆示意图
1: 插头 |
2: 拉手 |
QSFP+口可以采用QSFP+ DAC电缆进行连接。QSFP+ DAC电缆外观示意如图4-7所示。
QSFP28口可以采用QSFP28 DAC电缆进行连接,外观与QSFP+ DAC电缆类似。
图4-7 QSFP+ DAC电缆示意图
1: 插头 |
2: 拉手 |
QSFP+口可以采用QSFP+ AOC光缆进行连接。QSFP+ AOC光缆外观示意如图4-8所示。
QSFP28口可以采用QSFP28 AOC光缆进行连接,外观与QSFP+AOC光缆类似。
图4-8 QSFP+ AOC光缆示意图
1: 插头 |
2: 拉手 |
QSFP+ to SFP+ DAC电缆:一端是1个QSFP+模块;另一端分成4个SFP+模块。QSFP+ to SFP+ DAC电缆外观示意如图4-9所示。
1: QSFP+插头 |
2: QSFP+拉手 |
3: SFP+插头 |
4: SFP+拉手 |
