12-PFC命令
本章节下载: 12-PFC命令 (291.29 KB)
1.1.1 display priority-flow-control
1.1.2 display priority-flow-control dscp-mapping statistics
1.1.3 priority-flow-control (Ethernet interface view)
1.1.4 priority-flow-control (System view)
1.1.5 priority-flow-control deadlock auto-recover action
1.1.6 priority-flow-control deadlock auto-recover cos
1.1.7 priority-flow-control deadlock cos
1.1.8 priority-flow-control deadlock enable
1.1.9 priority-flow-control deadlock precision
1.1.10 priority-flow-control deadlock recover
1.1.11 priority-flow-control deadlock recover-mode
1.1.12 priority-flow-control deadlock threshold
1.1.13 priority-flow-control dot1p headroom
1.1.14 priority-flow-control dot1p ingress-buffer dynamic
1.1.15 priority-flow-control dot1p ingress-buffer static
1.1.16 priority-flow-control dot1p ingress-threshold-offset
1.1.17 priority-flow-control dot1p reserved-buffer
1.1.18 priority-flow-control dscp-mapping
1.1.19 priority-flow-control early-warning inpps
1.1.20 priority-flow-control early-warning outpps
1.1.21 priority-flow-control no-drop dot1p (Ethernet interface view)
1.1.22 priority-flow-control no-drop dot1p (System view)
display priority-flow-control命令用来显示接口的PFC(Priority-based Flow Control,基于优先级的流量控制)信息。
display priority-flow-control interface [ interface-type [ interface-number ] ]
interface-type:显示指定类型接口的PFC信息。interface-type表示接口类型。不指定该参数时,则显示设备上所有以太网接口的PFC信息。
interface-number:显示指定接口的PFC信息。interface-number表示接口编号。不指定该参数时,显示设备上指定类型的以太网接口的PFC信息。
# 显示所有接口的PFC信息。
<Sysname> display priority-flow-control interface
Interface AdminMode OperMode Dot1pList Prio Recv
Send Inpps Outpps
GE1/0/1 Disabled Disabled 0 5
5 3 3
表1-1 display priority-flow-control interface命令显示信息描述表
接口简名 |
AdminMode |
本地配置的PFC功能的状态: · Disabled表示接口下未开启PFC功能 · Auto表示接口对端自动协商是否开启PFC功能 · Enabled表示接口下已开启PFC功能 |
OperMode |
PFC功能状态的协商结果: · Disabled表示接口PFC处于未开启状态 · Enabled表示接口PFC处于开启状态 |
Dot1pList |
开启PFC功能的802.1p优先级队列,共8个(0~7)优先级队列 |
Prio |
开启PFC功能的802.1p优先级队列中,有数据帧收发的优先级队列,收发帧数据为0的队列不显示 |
Recv |
对应优先级收到的流控事件数 |
Send |
对应优先级发送的流控事件数 |
Inpps |
对应优先级入方向接收PFC帧的速率,单位为pps |
Outpps |
对应优先级出方向发送PFC帧的速率,单位为pps |
· priority-flow-control
· priority-flow-control no-drop dot1p
display priority-flow-control dscp-mapping statistics命令用来显示匹配DSCP映射关系的报文的统计信息。
display priority-flow-control dscp-mapping statistics [ slot slot-number ]
slot slot-number:指定设备编号,取值只能为1。
# 显示匹配DSCP映射关系的报文的统计信息。
<Sysname> display priority-flow-control dscp-mapping statistics
O/N: Original/New
slot 1:
OutInterface Priority(O/N) DSCP(O/N) Count LastMappingTime
GE1/0/1 1/2 11/12 2001 2021-08-10 08:18:01
表1-2 display priority-flow-control dscp-mapping statistics命令显示信息描述表
O/N: Original/New |
O表示待调整的值,N表示映射后的值 |
OutInterface |
出接口 |
Priority(O/N) |
优先级映射关系 |
DSCP(O/N) |
DSCP映射关系 |
Count |
映射转换的统计报文个数 |
LastMappingTime |
最近一次进行DSCP映射的时间 |
· priority-flow-control dscp-mapping
priority-flow-control命令用来配置接口的PFC功能。
undo priority-flow-control命令用来关闭PFC功能。
priority-flow-control { auto | enable [ receive | send ] }
PFC功能处于关闭状态。
以太网接口视图
auto:表示与对端自动协商是否开启PFC功能。
enable:表示强制开启PFC功能。
receive:表示开启报文接收方向的PFC功能。
send:表示开启报文发送方向的PFC功能。
如果本端和对端设备的PFC功能处于使能状态,并配置了priority-flow-control no-drop dot1p dot1p-list命令,则当本端收到的802.1p优先级在dot1p-list范围内的报文发生拥塞时,会通知对端设备暂时停止向本端发送对应优先级的报文;拥塞解除后,再通知对端继续发送对应优先级的报文。从而保证本设备在转发802.1p优先级在dot1p-list范围内的报文时不丢包。
报文接收方向的PFC功能是指设备仅能接收的PFC PAUSE帧,不能发送PFC PAUSE帧。报文发送方向的PFC功能是指仅能发送的PFC PAUSE帧,不能接收PFC PAUSE帧。当未指定receive和send参数时,表示开启报文接收方向和报文发送方向的PFC功能。
多次在系统视图和接口视图下执行本命令,最后一次执行的命令生效。
# 在以太网接口GigabitEthernet1/0/1上开启PFC功能。
[Sysname-GigabitEthernet1/0/1] priority-flow-control enable
· display priority-flow-control
· priority-flow-control (System view)
priority-flow-control命令用来开启所有接口的PFC功能。
undo priority-flow-control命令用来关闭所有接口的PFC功能。
PFC功能处于关闭状态。
enable:表示强制开启PFC功能。
# 开启所有接口的PFC功能。
[Sysname] priority-flow-control enable
· priority-flow-control (Ethernet interface view)
priority-flow-control deadlock auto-recover action命令用来配置设备在自动恢复PFC死锁检测的延迟时间内对报文的处理动作。
undo priority-flow-control deadlock auto-recover action命令用来恢复缺省情况。
priority-flow-control deadlock auto-recover action { discard | forwarding }
设备在自动恢复PFC死锁检测的延迟时间内转发收到的数据报文。
discard:丢弃收到的数据报文。
forwarding:转发收到的数据报文。
当设备进入PFC死锁状态后,用户可以使用本命令配置设备在自动恢复死锁检测的延迟时间内对数据报文丢弃或者转发。
# 配置当设备进入PFC死锁状态后对数据报文进行丢弃。
[Sysname] priority-flow-control deadlock auto-recover action discard
· priority-flow-control deadlock cos
· priority-flow-control deadlock enable
priority-flow-control deadlock auto-recover cos命令用来配置PFC死锁检测自动恢复的延迟周期。
undo priority-flow-control deadlock auto-recover cos命令用来删除PFC死锁检测自动恢复的延迟周期。
priority-flow-control deadlock auto-recover slot slot-number cos cos-value delay delay-time
undo priority-flow-control deadlock auto-recover slot slot-number cos [ cos-value ]
未配置PFC死锁检测的恢复周期。
cos cos-value:报文CoS值,取值范围为0~7。不同的CoS值对应不同的802.1p优先级,可以通过display qos map-table dot1p-lp命令查看。
delay delay-time:PFC死锁检测自动恢复的延迟周期,取值范围为1~15。
PFC死锁检测功能可以按周期检测携带指定CoS值的报文是否发生死锁,在设备进入PFC死锁状态后,设备自动恢复时会在延迟周期结束后恢复PFC死锁检测功能。延迟恢复周期由auto-recover-delay delay-time和PFC死锁检测定时器的精度共同决定。
本命令仅在PFC死锁检测功能的恢复方式为自动恢复时生效。
指定的CoS值必须在priority-flow-control no-drop dot1p命令配置的802.1p优先级内。
对于不同CoS值可以配置相同的延迟恢复周期。
对于同一CoS值,多次执行本命令,最后一次执行的命令生效。
# 配置CoS值为7的PFC死锁自动恢复的延迟周期为5。
[Sysname] priority-flow-control deadlock auto-recover cos 7 delay 5
· display qos map-table dot1p-lp(ACL和QoS/优先级映射)
· priority-flow-control deadlock precision
priority-flow-control deadlock cos命令用来配置PFC死锁检测的周期。
undo priority-flow-control deadlock cos命令用来删除PFC死锁检测的周期。
priority-flow-control deadlock slot slot-number cos cos-value interval interval
undo priority-flow-control deadlock slot slot-number cos [ cos-value ]
未配置PFC死锁检测的周期。
interval interval:PFC死锁检测周期,取值范围为1~15。
PFC死锁检测功能可以按周期检测携带指定CoS值的报文是否发生死锁。检测周期由interval interval和PFC死锁检测定时器的精度共同决定。
指定的CoS值必须在priority-flow-control no-drop dot1p命令配置的802.1p优先级内。不同的CoS值对应不同的802.1p优先级,可以通过display qos map-table dot1p-lp命令查看。
对于不同CoS值可以配置相同的检测周期。
# 配置指定slot上CoS值为7的PFC死锁检测周期为5。
[Sysname] priority-flow-control deadlock slot 1 cos 7 interval 5
priority-flow-control deadlock enable命令用来开启PFC死锁检测功能。
undo priority-flow-control deadlock enable命令用来关闭PFC死锁检测功能。
PFC死锁检测功能处于关闭状态。
以太网接口视图
开启指定802.1p优先级的PFC功能后(通过priority-flow-control和priority-flow-control no-drop dot1p命令配置),当指定优先级的报文形成环路时,会导致数据缓冲区内报文无法转发,此时设备进入PFC死锁状态。
通过配置本命令,可以定期检测设备是否处于PFC死锁状态,并解除PFC死锁状态。
# 在GigabitEthernet1/0/1下开启PFC死锁检测功能。
[Sysname-GigabitEthernet1/0/1] priority-flow-control deadlock enable
priority-flow-control deadlock precision命令用来配置PFC死锁检测定时器的精度。
undo priority-flow-control deadlock precision命令用来恢复缺省情况。
priority-flow-control deadlock slot slot-number precision { high | low | normal }
undo priority-flow-control deadlock slot slot-number precision
PFC死锁检测定时器的精度为普通精度。
high:表示使用高精度的PFC死锁检测定时器。
low:表示使用低精度的PFC死锁检测定时器。
normal:表示使用普通精度的PFC死锁检测定时器。
使用本命令可调整PFC死锁检测定时器的精度,从而控制PFC死锁检测时间。
# 配置指定slot上PFC死锁检测定时器精度为高精度。
[Sysname] priority-flow-control deadlock slot 1 precision high
priority-flow-control deadlock recover命令用来手工恢复PFC死锁检测功能。
以太网接口视图
当配置了手工恢复方式,设备能解除死锁状态,但同时死锁检测功能和PFC功能会暂时失效,需要手工执行本命令来恢复PFC死锁检测功能。恢复PFC死锁检测功能的同时可以让PFC功能继续生效。
# 在GigabitEthernet1/0/1下恢复PFC死锁检测功能。
[Sysname-GigabitEthernet1/0/1] priority-flow-control deadlock recover
· priority-flow-control deadlock recover-mode
priority-flow-control deadlock recover-mode命令用来配置PFC死锁检测功能的恢复方式。
undo priority-flow-control deadlock recover-mode命令用来恢复缺省情况。
priority-flow-control deadlock recover-mode { auto | manual }
PFC死锁检测功能恢复方式为自动恢复方式。
以太网接口视图
auto:配置PFC死锁检测功能的恢复方式为自动恢复。
manual:配置PFC死锁检测功能的恢复方式为手工恢复。
当设备检测到PFC死锁状态后,设备自动恢复时会在延迟周期结束后解除PFC死锁状态,恢复PFC功能和PFC死锁检测功能。在PFC死锁检测自动恢复的延迟周期内,设备将关闭PFC功能和PFC死锁检测功能,以便报文能够正常转发。PFC死锁状态解除后,用户可采用自动或手工方式来恢复PFC死锁检测功能。恢复PFC死锁检测功能会让PFC功能继续生效。所以,通常情况下,使用自动恢复方式即可。当报文环路无法消除,设备频繁处于PFC死锁状态时,用户可以使用手工恢复方式,并尽快排除故障,再执行priority-flow-control deadlock recover命令,恢复PFC死锁检测功能和PFC功能。
# 在GigabitEthernet1/0/1下配置PFC死锁检测功能恢复方式为手工恢复。
[Sysname-GigabitEthernet1/0/1] priority-flow-control deadlock recover-mode manual
priority-flow-control deadlock threshold命令用来配置在指定周期内发生PFC死锁的上限次数。
undo priority-flow-control deadlock threshold命令用来恢复缺省情况。
priority-flow-control deadlock threshold slot slot-number cos cos-value period period count count
undo priority-flow-control deadlock threshold slot slot-number cos [ cos-value ]
未配置指定周期内发生PFC死锁的上限次数。
period period:发生PFC死锁次数的检测周期,取值范围为1~60,单位为秒。
count count:指定周期内发生PFC死锁的上限次数,取值范围为1~500,单位为次数。
当配置该命令后,在指定周期内端口发生PFC死锁的次数达到配置值时,设备将关闭对应端口对应优先级的PFC功能,此时用户需要排除故障手工执行undo priority-flow-control deadlock threshold命令恢复对应端口的PFC功能。
本命令配置的发生PFC死锁次数的检测周期需要大于priority-flow-control deadlock cos命令配置的PFC死锁检测周期,以便确认设备是否频繁处于PFC死锁状态。
# 配置5秒周期内发生PFC死锁的上限次数为100。
[Sysname] priority-flow-control deadlock threshold cos 7 period 5 count 100
priority-flow-control dot1p headroom命令用来配置Headroom缓存门限。
undo priority-flow-control dot1p headroom命令用来恢复缺省情况。
priority-flow-control dot1p dot1p headroom headroom-number
undo priority-flow-control dot1p dot1p headroom
Headroom缓存门限为393216。
以太网接口视图
dot1p:802.1p优先级,取值范围为0~7。
headroom-number:Headroom缓存门限,取值范围为128~393216。
在配置本命令前,需执行priority-flow-control no-drop dot1p命令开启指定802.1p优先级的PFC功能,以及priority-flow-control enable命令开启接口的PFC功能。
多次执行本命令或者priority-flow-control no-drop dot1p (Ethernet interface view)命令,配置同一802.1p优先级的Headroom缓存门限,最后一次执行的命令中指定的headroom-number值生效。
当两个直接相连的接口传输数据时,需要使用接口的缓存空间来缓冲接收的数据。接口的传输距离越大,接口需要的数据缓存空间越大。可通过PFC功能配置设备在长距离传输的Headroom缓存门限,来实现报文的零丢弃。
# 配置Headroom缓存门限为1000。
<sysname> system-view
[Sysname-GigabitEthernet1/0/1] priority-flow-control dot1p 1 headroom 1000
priority-flow-control dot1p ingress-buffer dynamic命令用来配置动态反压帧触发门限。
undo priority-flow-control dot1p ingress-buffer dynamic命令用来恢复缺省情况。
priority-flow-control dot1p dot1p ingress-buffer dynamic ratio
undo priority-flow-control dot1p dot1p ingress-buffer
未配置动态反压帧触发门限。
以太网接口视图
ratio:动态反压帧触发门限,即可用空间的百分比,取值范围为0~100。
多次执行本命令,同一802.1p优先级的动态反压帧触发门限配置,最后一次执行的命令生效。
# 配置动态反压帧触发门限为30。
[Sysname-GigabitEthernet1/0/1] priority-flow-control dot1p 1 ingress-buffer dynamic 30
priority-flow-control dot1p ingress-buffer static命令用来配置静态反压帧触发门限。
undo priority-flow-control dot1p ingress-buffer static命令用来恢复缺省情况。
priority-flow-control dot1p dot1p ingress-buffer static threshold
静态反压帧触发门限为600。
以太网接口视图
threshold:静态反压帧触发门限,取值范围为128~196608。
多次执行本命令,同一802.1p优先级的静态反压帧触发门限配置,最后一次执行的命令生效。
# 配置静态反压帧触发门限为1000。
[Sysname-GigabitEthernet1/0/1] priority-flow-control dot1p 1 ingress-buffer static 1000
priority-flow-control dot1p ingress-threshold-offset命令用来配置反压帧停止门限与触发门限间的偏移量。
undo priority-flow-control dot1p ingress-threshold-offset命令用来恢复缺省情况。
priority-flow-control dot1p dot1p ingress-threshold-offset offset-number
undo priority-flow-control dot1p dot1p ingress-threshold-offset
反压帧停止门限与触发门限间的偏移量为1024。
以太网接口视图
offset-number:反压帧停止门限与触发门限间的偏移量,取值范围为128~196608。
# 配置反压帧停止门限与触发门限间的偏移量为1000。
[Sysname-GigabitEthernet1/0/1] priority-flow-control dot1p 1 ingress-threshold-offset 1000
priority-flow-control dot1p reserved-buffer命令用来配置PFC预留门限。
undo priority-flow-control dot1p reserved-buffer命令用来恢复缺省情况。
priority-flow-control dot1p dot1p reserved-buffer reserved-number
undo priority-flow-control dot1p dot1p reserved-buffer
PFC预留门限为600。
以太网接口视图
reserved-number:PFC预留门限,取值范围为128~196608。
多次执行本命令或者priority-flow-control no-drop dot1p (Ethernet interface view)命令,配置同一802.1p优先级的PFC预留门限,最后一次执行的命令中指定的reserved-number值生效。
# 配置PFC预留门限为1000。
[Sysname-GigabitEthernet1/0/1] priority-flow-control dot1p 1 reserved-buffer 1000
priority-flow-control dscp-mapping命令用来配置报文的DSCP映射关系。
undo priority-flow-control dscp-mapping命令用来恢复缺省情况。
priority-flow-control dscp-mapping { original-dscp original-dscp-value to priority priority dscp dscp-value }&<1-2>
未配置报文的DSCP映射关系。
以太网接口视图
original-dscp original-dscp-value:指定待调整的报文的DSCP值,取值范围为0~63。
priority priority:指定报文的Dot1p优先级,取值范围为0~7。
dscp dscp-value:指定映射后的报文的DSCP值,取值范围为0~63。
&<1-2>:表示前面的参数最多可以输入2次。
设备收到报文后,会根据报文的DSCP值以及设备上dscp-dot1p的映射关系,将该报文加入指定Dot1p优先级的队列转发。当同一Dot1p优先级的流量成环,报文所经过的路径上每一个节点都出现PFC反压,导致每一个节点停止发送对应DSCP值的报文,即产生PFC死锁。为了避免以上问题,可以修改报文的DSCP值和对应的Dot1p优先级,以便修改后报文可以在新的Dot1p优先级队列中使用新的DSCP值转发,避免该DSCP值的报文持续处于PFC死锁状态。
当某一Dot1p优先级的队列的缓冲区资源消耗过快时,缓存资源容易超过PFC XOFF门限,引起PFC死锁。通过配置本功能,可以修改报文所属的Dot1p优先级,使用其他Dot1p优先级队列转发报文,预防PFC死锁,保证流量正常转发。因此,该功能也被称为PFC死锁预防功能。
配置本命令后,设备将在发送报文时更改报文的Dot1p优先级和DSCP值。
每个接口最多可配置两个映射配置,且源DSCP值必须不同。
# 在GigabitEthernet1/0/1下将DSCP值为2的报文映射为DSCP值为4的报文,并在Dot1p优先级为3的队列中转发。
[Sysname-GigabitEthernet1/0/1] priority-flow-control dscp-mapping original-dscp 2 to priority 3 dscp 4
priority-flow-control early-warning inpps命令用来配置入方向PFC报文的预警门限。
undo priority-flow-control early-warning inpps命令用来删除入方向PFC报文的预警门限。
priority-flow-control early-warning dot1p dot1p-list inpps pps-value
undo priority-flow-control early-warning [ dot1p dot1p-list ] inpps
未配置入方向PFC报文的预警门限。
以太网接口视图
dot1p dot1p-list:802.1p优先级(dot1p优先级)列表,例如:1,3-5。(表示数值区间时使用连字符“-”,数值之间用英文格式的逗号“,”分隔,最多可配置16个字符)
inpps pps-value:指定接口每秒接收的PFC帧数量,单位为pps,取值范围为1~159783010。
用户可根据实际组网情况,配置接口入方向PFC报文的预警门限。预警门限用于PFC报文传输速率处于正常范围内,但需要提醒用户提前关注的情况。
当接口接收PFC报文的速率达到预警门限时,系统会生成Trap和日志信息来提醒用户,以提前发现网络中的一些异常问题。例如:
· 对端设备网卡故障,不停地持续高速发送PFC帧,可以配置入方向预警门限进行监控。
· 本设备故障后不停发送PFC帧,可以配置出方向预警门限进行监控。
· 如果有双向监控需求的,可以在入和出方向都配置预警门限进行监控。
仅当PFC功能处于开启状态时,才会统计该接口接收的PFC帧数量,本命令配置的预警门限才能生效。
# 配置入方向802.1p优先级为7的PFC报文的预警门限为80pps。
[Sysname-GigabitEthernet1/0/1] priority-flow-control early-warning dot1p 7 inpps 80
priority-flow-control early-warning outpps命令用来配置出方向PFC报文的预警门限。
undo priority-flow-control early-warning outpps命令用来删除出方向PFC报文的预警门限。
priority-flow-control early-warning dot1p dot1p-list outpps pps-value
undo priority-flow-control early-warning [ dot1p dot1p-list ] outpps
未配置出方向PFC报文的预警门限。
以太网接口视图
outpps pps-value:指定接口每秒发送PFC帧数量,单位为pps,取值范围为1~159783010。
用户可根据实际组网情况,配置接口出方向PFC报文的预警门限。预警门限用于PFC报文传输速率处于正常范围内,但需要提醒用户提前关注的情况。
当接口发送PFC报文的速率达到预警门限时,系统会生成Trap和日志信息来提醒用户,以提前发现网络中的一些异常问题。例如:
仅当PFC功能处于开启状态时,才会统计该接口发送的PFC帧数量,本命令配置的预警门限才能生效。
# 配置出方向802.1p优先级为1的PFC报文的预警门限为50pps。
[Sysname-GigabitEthernet1/0/1] priority-flow-control early-warning dot1p 1 outpps 50
priority-flow-control no-drop dot1p命令用来开启指定802.1p优先级的PFC功能,并配置PFC门限。
undo priority-flow-control no-drop dot1p命令用来关闭指定802.1p优先级的PFC功能。
priority-flow-control no-drop dot1p dot1p-list [ pause-threshold { threshold-value | ratio threshold-ratio } [ headroom headroom-value | pause-threshold-offset offset-value | reserved-buffer reserved-value ] * ]
undo priority-flow-control no-drop dot1p [ dot1p dot1p-list ]
所有802.1p优先级的PFC功能都处于关闭状态。
以太网接口视图
dot1p-list:802.1p优先级(dot1p优先级)列表,例如:1,3-5(表示数值区间时使用连字符“-”,数值之间用英文格式的逗号“,”分隔,最多可配置16个字符)。如果执行undo命令时未指定本参数,则表示关闭所有802.1p优先级的PFC功能。
pause-threshold:指定反压帧触发门限。如果未指定本参数,则表示各个PFC门限采用缺省值。
threshold-value:以绝对值方式配置反压帧触发门限,取值范围为128~196608。
ratio threshold-ratio:以百分比方式配置反压帧触发门限,取值范围为1~90。
headroom headroom-value:表示指定队列的Headroom缓冲区资源上限,用cell个数表示,取值范围为128~393216。
pause-threshold-offset offset-value:反压帧停止门限与触发门限间的偏移量,取值范围为128~196608。
reserved-buffer reserved-value:表示指定队列的PFC预留门限,取值范围为128~196608。
开启指定802.1p优先级的PFC功能后,会为PFC的各种门限设置一个缺省值,此缺省值在一般的组网环境下是效果较好的参数组合,不建议用户自行调整使用。
设备提供对PFC门限进行配置,合理利用接口存储空间。目前提供以下门限设置:
· Headroom缓存门限:Headroom是接口转发芯片上的一种存储空间,它里面包含更小的存储单元cell,用于缓存接口收到的报文。指定队列最多可使用的cell资源的个数后,当队列已使用的cell资源达到上限后,接口会丢弃收到的报文。
· 反压帧触发门限:Herdroom缓冲区中某802.1p优先级报文在该存储空间的使用cell资源上限。达到上限后,会触发PFC功能。反压帧触发门限的配置方式为:
¡ 绝对值方式:指定反压帧触发门限大小,即静态态反压帧触发门限。
¡ 百分比方式:指定反压帧触发门限百分比,即动态反压帧触发门限。
· 反压帧停止门限与触发门限间的偏移量:当触发反压帧触发门限后,当某802.1p优先级报文使用的cell资源减小了一个固定值时,不会再触发PFC功能。
· PFC预留门限:Herdroom缓冲区中为某802.1p优先级报文预留的cell资源。
# 在以太网接口GigabitEthernet1/0/1上配置PFC功能的开启模式为自动协商模式,并开启802.1p优先级5的PFC功能。
[Sysname-GigabitEthernet1/0/1] priority-flow-control auto
[Sysname-GigabitEthernet1/0/1] priority-flow-control no-drop dot1p 5
· priority-flow-control no-drop dot1p (System view)
priority-flow-control no-drop dot1p命令用来开启所有接口下指定802.1p优先级的PFC功能。
undo priority-flow-control no-drop dot1p命令用来关闭所有接口下指定802.1p优先级的PFC功能。
所有接口下802.1p优先级的PFC功能都处于关闭状态。
如果本端和对端设备的PFC功能处于使能状态,并配置了本命令,则当本端收到的802.1p优先级在dot1p-list范围内的报文发生拥塞时,会通知对端设备暂时停止向本端发送对应优先级的报文;拥塞解除后,再通知对端继续发送对应优先级的报文。从而保证本设备在转发802.1p优先级在dot1p-list范围内的报文时不丢包。有关802.1p优先级的介绍,请参见“ACL和QoS配置指导”中的“QoS”。
# 开启所有接口802.1p优先级5的PFC功能。
[Sysname] priority-flow-control no-drop dot1p 5
· priority-flow-control no-drop dot1p (Ethernet interface view)
