05-网络互通命令参考
16-NAT命令
本章节下载: 16-NAT命令  (524.86 KB)
16-NAT命令
1 NAT
1.1 NAT配置命令
1.1.1 address
1.1.2 block-size
1.1.3 display nat address-group
1.1.4 display nat alg
1.1.5 display nat all
1.1.6 display nat dns-map
1.1.7 display nat eim
1.1.8 display nat inbound
1.1.9 display nat log
1.1.10 display nat no-pat
1.1.11 display nat outbound
1.1.12 display nat outbound port-block-group
1.1.13 display nat port-block
1.1.14 display nat port-block-group
1.1.15 display nat port-block-usage
1.1.16 display nat server
1.1.17 display nat server-group
1.1.18 display nat session
1.1.19 display nat static
1.1.20 display nat statistics
1.1.21 global-ip-pool
1.1.22 inside ip
1.1.23 local-ip-address
1.1.24 nat address-group
1.1.25 nat alg
1.1.26 nat dns-map
1.1.27 nat hairpin enable
1.1.28 nat icmp-error reply
1.1.29 nat inbound
1.1.30 nat inbound rule move
1.1.31 nat log alarm
1.1.32 nat log enable
1.1.33 nat log flow-active
1.1.34 nat log flow-begin
1.1.35 nat log flow-end
1.1.36 nat log port-block usage threshold
1.1.37 nat log port-block-assign
1.1.38 nat log port-block-withdraw
1.1.39 nat mapping-behavior
1.1.40 nat outbound
1.1.41 nat outbound port-block-group
1.1.42 nat outbound rule move
1.1.43 nat port-block global-share enable
1.1.44 nat port-block-group
1.1.45 nat server
1.1.46 nat server rule move
1.1.47 nat server-group
1.1.48 nat static enable
1.1.49 nat static inbound
1.1.50 nat static inbound net-to-net
1.1.51 nat static inbound object-group
1.1.52 nat static inbound rule move
1.1.53 nat static outbound
1.1.54 nat static outbound net-to-net
1.1.55 nat static outbound object-group
1.1.56 nat static outbound rule move
1.1.57 nat timestamp delete
1.1.58 port-block
1.1.59 port-range
1.1.60 reset nat count statistics
1.1.61 reset nat session
1 NAT
1.1  NAT配置命令
1.1.1  address
address命令用来添加地址成员。
undo address命令用来删除地址成员。
address start-address end-address
undo address start-address end-address
不存在地址成员。
NAT地址组视图
start-address end-address:地址成员的起始IP地址和结束IP地址。end-address必须大于或等于start-address,如果start-address和end-address相同,则表示只有一个地址。start-address和end-address之间的IP地址数量不能超过65535个。
一个NAT地址组是多个地址成员的集合。当需要对到达外部网络的数据报文进行地址转换时,报文的源地址将被转换为地址成员中的某个地址。
在同一NAT地址组中多次执行本命令添加的地址成员不能互相重叠,且不同NAT地址组中地址成员的IP地址段不能互相重叠。
# 在NAT地址组2中添加地址成员。
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] address 10.1.1.20 10.1.1.30
·     address interface
·     nat address-group
1.1.2  block-size
block-size命令用来设置端口块大小。
undo block-size命令用来恢复缺省情况。
block-size block-size
undo block-size
一个端口块中包含256个端口。
NAT端口块组视图
block-size:端口块大小,即一个端口块中所包含的端口数,取值范围为1~max_number。其中max_number为65535。
在一个端口块组中,需要根据私网IP地址个数,以及公网IP地址个数及其端口范围,确定一个合理的端口块大小值。端口块大小值不能超过公网地址的端口范围值。
# 配置端口块组1的端口块大小为1024。
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] block-size 1024
·     nat port-block-group
display nat address-group命令用来显示NAT地址组配置信息。
display nat address-group [ group-id ]
group-id:地址组的编号,取值范围为0~65535。如果不设置该值,则显示所有地址组。
# 显示所有地址组的配置信息。
<Sysname> display nat address-group
NAT address group information:
  Totally 5 NAT address groups.
  Address group ID: 1    Address group name: a
    Port range: 1-65535
    Address information:
      Start address         End address
      202.110.10.10         202.110.10.15
  Address group ID: 2
    Port range: 1-65535
      202.110.10.20         202.110.10.25
      202.110.10.30         202.110.10.35
  Address group ID: 3
    Port range: 1024-65535
      202.110.10.40         202.110.10.50
  Address group ID: 4
    Port range: 10001-65535
    Port block size: 500
    Extended block number: 1
      202.110.10.60         202.110.10.65
  Address group ID: 6
    Port range: 1-65535
# 显示指定地址组的配置信息。
<Sysname> display nat address-group 1
    Port range: 1-65535
表1-1 display nat address-group命令显示信息描述表
NAT地址组信息
Totally n NAT address groups
当前有n个地址组
Address group ID
地址组的编号
Address group name
地址组名称。如果未配置,则不显示该字段
Port range
地址的端口范围
Port block size
端口块大小。如果未配置,则不显示
增量端口块数。如果未配置,则不显示
Address information
地址组成员信息
·     通过address命令添加地址成员:
¡     Start address:地址组成员的起始地址。如果没有地址成员,则显示“---”
¡     End address:地址组成员的结束地址。如果没有地址成员,则显示“---”
·     通过address interface命令将接口地址作为地址成员:
¡     20.1.1.1 (Vlan-interface10):将接口Vlan-interface10的地址20.1.1.1作为地址成员
¡     --- (Vlan-interface20):无法将接口Vlan-interface20的地址作为地址成员,原因是该接口未配置IP地址
·     nat address-group
display nat alg用来显示所有协议类型的NAT ALG功能的开启状态。
display nat alg
# 显示所有协议类型的NAT ALG功能的开启状态。
<Sysname> display nat alg
NAT ALG:
  DNS        : Enabled
  FTP        : Disabled
  H323       : Disabled
  ICMP-ERROR : Disabled
  ILS        : Disabled
  MGCP       : Disabled
  NBT        : Disabled
  PPTP       : Disabled
  RTSP       : Disabled
  RSH        : Disabled
  SCCP       : Disabled
  SIP        : Disabled
  SQLNET     : Disabled
  TFTP       : Disabled
  XDMCP      : Disabled
表1-2 display nat alg命令显示信息描述表
Enabled
协议的NAT ALG功能处于开启状态
Disabled
协议的NAT ALG功能处于关闭状态
·     display nat all
display nat all命令用来显示所有的NAT配置信息。
display nat all
# 显示所有的NAT配置信息。
<Sysname> display nat all
  Address group 1:
    Port range: 1-65535
  Address group 2:
    Port range: 1-65535
  Address group 3:
  Address group 4:
  Address group 6:
    Port range: 1-65535
NAT server group information:
  Totally 3 NAT server groups.
  Group Number        Inside IP             Port        Weight
  1                   192.168.0.26          23          100
                      192.168.0.27          23          500
  2                   ---                   ---         ---
  3                   192.168.0.26          69          100
NAT inbound information:
  Totally 1 NAT inbound rules.
  Interface: Vlan-interface10
    ACL: 2038
    Address group ID: 2
    Add route: Y        NO-PAT: Y  Reversible: N
    Rule name: abcdefg
    Priority: 1000
    NAT counting : 0
    Config status: Active
NAT outbound information:
  Totally 2 NAT outbound rules.
  Interface: Vlan-interface20
    ACL: 2036
    Address group ID: 1
    Port-preserved: Y        NO-PAT: N  Reversible: N
    Rule name: cdefg
    Priority: 1001
    NAT counting : 0
    Config status: Inactive
    Reasons for inactive status:
      The following items don't exist or aren't effective: address group, and ACL.
    ACL: 2037
    Address group ID: 1
    Port-preserved: N        NO-PAT: Y  Reversible: Y
    Rule name: blue
    Priority: 1002
    NAT counting : 0
NAT internal server information (object-group):
  Totally 1 object-group-based NAT server rules.
  Rule name: aaa
    Local IP/Port: 1.1.1.1/80
    DestIP Object group: abc
    NAT counting  : 0
    Config status : Active
Static NAT mappings:
  Totally 2 inbound static NAT mappings.
  Net-to-net:
    Global IP    : 2.2.2.1 – 2.2.2.255
    Local IP     : 1.1.1.0
    Netmask      : 255.255.255.0
    ACL          : 2000
    Reversible   : Y
    Rule name     : pink
    Priority      : 1000
    NAT counting : 0
  IP-to-IP:
    Global IP    : 5.5.5.5
    Local IP     : 4.4.4.4
    ACL          : 2001
    Reversible   : Y
    Rule name    : yellow
    Priority     : 1000
    NAT counting : 0
      The following items don't exist or aren't effective: ACL.
  Totally 2 outbound static NAT mappings.
  Net-to-net:
    Local IP     : 1.1.1.1 - 1.1.1.255
    Global IP    : 2.2.2.0
    ACL          : 2000
    Reversible   : Y
    Rule name    : grey
    Priority     : 1000
    NAT counting : 0
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    ACL:         : 2001
    Reversible   : Y
    Rule name    : orange
    Priority     : 10000
    NAT counting : 0
Interfaces enabled with static NAT:
  Totally 2 interfaces enabled with static NAT.
  Interface: Vlan-interface40
  Interface: Vlan-interface50
NAT DNS mappings:
  Totally 2 NAT DNS mappings.
  Domain name  : www.server.com
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Domain name  : www.service.com
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
    The following items don't exist or aren't effective: interface IP address.
NAT logging:
  Log enable          : Enabled(ACL 2000)
  Flow-begin          : Disabled
  Flow-end            : Disabled
  Flow-active         : Enabled(10 minutes)
  Port-block-assign   : Disabled
  Port-block-withdraw : Disabled
  Alarm               : Disabled
  NO-PAT IP usage     : Disabled
NAT hairpinning:
  Totally 2 interfaces enabled with NAT hairpinning.
NAT mapping behavior:
  Mapping mode : Endpoint-Independent
  ACL          : 2050
NAT ALG:
  DNS        : Enabled
  FTP        : Enabled
  H323       : Enabled
  ICMP-ERROR : Enabled
  ILS        : Enabled
  MGCP       : Enabled
  NBT        : Enabled
  PPTP       : Enabled
  RTSP       : Enabled
  RSH        : Enabled
  SCCP       : Enabled
  SIP        : Enabled
  SQLNET     : Enabled
  TFTP       : Enabled
  XDMCP      : Disabled
NAT port block group information:
  Totally 3 NAT port block groups.
  Port block group 1:
    Port range: 1-65535
    Block size: 256
    Local IP address information:
      Start address        End address          VPN instance
      172.16.1.1           172.16.1.254         ---
      192.168.1.1          192.168.1.254        ---
      192.168.3.1          192.168.3.254        ---
    Global IP pool information:
      201.1.1.1            201.1.1.10
      201.1.1.21           201.1.1.25
  Port block group 2:
    Port range: 10001-30000
    Block size: 500
      10.1.1.1             10.1.10.255          ---
      202.10.10.101        202.10.10.120
  Port block group 3:
    Port range: 1-65535
    Block size: 256
NAT outbound port block group information:
  Totally 2 outbound port block group items.
    port-block-group: 2
    Rule name: stone
    NAT counting: 0
    port-block-group: 10
    NAT counting: 0
    Config status   : Inactive
      The following items don't exist or aren't effective: port block group.
Static NAT load balancing:     Disabled
上述显示信息是目前所有NAT配置信息的集合。由于部分NAT配置(nat address-group、nat server-group、nat inbound、nat outbound、nat server、nat static、nat static net-to-net、nat static enable、nat dns-map、nat log、nat port-block-group和nat outbound port-block-group)有自己独立的显示命令,且此处显示信息的格式与各命令对应的显示信息的格式相同的,所以此处不对这些配置的显示字段的含义进行详细解释,如有需要,请参考各独立的显示命令。下面的表格将给出相关显示命令的参见信息并仅解释nat hairpin enable、nat mapping-behavior和nat alg配置的显示字段的含义。
表1-3 display nat all命令显示信息描述表
NAT地址组的配置信息,详细字段解释请参见“表1-1”
NAT内部服务器组的配置信息,详细字段解释请参见“表1-15”
入方向动态地址转换的配置信息,详细字段解释请参见“表1-6”
出方向动态地址转换的配置信息,详细字段解释请参见“表1-9”
NAT内部服务器的配置信息,详细字段解释请参见“表1-14”
Static NAT mappings
静态地址转换的配置信息,详细字段解释请参见“表1-17”
NAT DNS mappings
NAT DNS mapping的配置信息,详细字段解释请参见“表1-4”
NAT logging
NAT日志功能的配置信息,详细字段解释请参见“表1-7”
NAT hairpinning
NAT hairpin功能
Totally n interfaces enabled NAT hairpinning
当前有n个接口开启NAT hairpin功能
开启NAT hairpin功能的接口
Rule name
NAT规则的名称
NAT counting
NAT地址转换的计数信息
Priority
NAT规则的匹配优先级
Config status
显示NAT hairpin配置的状态
·     Active:生效
·     Inactive:不生效
当Config status字段为Inactive时,显示NAT hairpin配置不生效的原因
·     Service card not specified:没有指定提供NAT处理的业务板
PAT方式下的地址转换模式
·     Endpoint-Independent:表示不关心对端地址和端口
·     Address and Port-Dependent:表示关心对端地址和端口
ACL
引用的ACL编号或名称。如果未配置,则显示“---”
Config status
显示NAT mapping behavior配置的状态
·     Active:生效
·     Inactive:不生效
当Config status字段为Inactive时,显示NAT mapping behavior配置不生效的原因
·     The following items don't exist or aren't effective: ACL:引用的ACL不存在
NAT ALG
各协议的NAT ALG功能开启信息
NAT端口块组的配置信息,详细字段解释请参见“表1-12”
NAT444端口块静态映射的配置信息,详细字段解释请参见“表1-10”
display nat dns-map命令用来显示NAT DNS mapping配置信息。
display nat dns-map
# 显示NAT DNS mapping的配置信息。
<Sysname> display nat dns-map
NAT DNS mapping information:
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
表1-4 display nat dns-map命令显示信息描述表
NAT DNS mapping配置信息
Totally n NAT DNS mappings
当前有n条DNS mapping配置
Domain name
DNS域名
Global IP
外网地址。如果配置使用的是Easy IP方式,则此处显示指定的接口的地址。“---”表示接口下未配置外网地址
Global port
外网端口号
Protocol
协议名称以及协议编号
Config status
显示DNS mapping配置的状态
·     Active:生效
·     Inactive:不生效
当Config status字段为Inactive时,显示DNS mapping配置不生效的原因
·     The following items don't exist or aren't effective: interface IP address:引用的接口未配置IP地址
·     nat dns-map
display nat eim命令用来显示NAT EIM表项信息。
display nat eim [ slot slot-number ]
slot slot-number:显示指定成员设备上的EIM表项信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上的EIM表项信息。
EIM三元组表项是报文在进行Endpoint-Independent Mapping方式的PAT转换时创建的,它记录了内网和外网的转换关系(内网地址和端口<-->NAT地址和端口),该表项有以下两个作用:
·     保证后续来自相同源地址和源端口的新建连接与首次连接使用相同的转换关系。
·     允许外网主机向NAT地址和端口发起的新建连接根据EIM表项进行反向地址转换。
# 显示指定slot上的NAT EIM表项信息。
<Sysname> display nat eim slot 1
Slot 1:
Local  IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
Protocol: TCP(6)
Local  IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
表1-5 display nat eim命令显示信息描述表
Protocol
协议名称以及协议编号
Total entries found
当前查找到的EIM表项的个数
·     nat mapping-behavior
·     nat outbound
display nat inbound命令用来显示NAT入方向动态地址转换的配置信息。
display nat inbound
# 显示NAT入接口动态地址转换的配置信息。
<Sysname> display nat inbound
  Totally 2 NAT inbound rules.
    ACL: 2038
    Address group ID: 2
    Rule name: abcd
    Priority: 1000
    NAT counting: 0
Interface: Vlan-interface30
    ACL: 2037
    Address group ID: 1
    Rule name: eif
    Priority: 1001
    NAT counting: 0
表1-6 display nat inbound命令显示信息描述表
NAT入方向动态地址转换的配置信息
Totally n NAT inbound rules
当前存在n条入入方向动态地址转换配置
入方向动态地址转换配置所在的接口
ACL
引用的ACL编号或名称
Address group ID
入方向动态地址转换使用的地址组
Address group name
入方向动态地址转换使用的地址组名称。如果未配置,则不显示该字段
Add route
是否添加路由。若其值为“Y”,则表示有报文命中此项入接口动态地址转换配置时,设备会自动添加一条路由;若其值为“N”,则不添加
NO-PAT
是否使用NO-PAT方式进行地址转换。若其值为“Y”,则表示使用NO-PAT方式;若其值为“N”,则表示使用PAT方式
Reversible
是否允许反向地址转换。若其值为“Y”,则表示在某方向上发起的连接已成功建立地址转换表项的情况下,允许反方向发起的连接使用已建立的地址转换表项进行地址转换;若其值为“N”,则不允许
Rule name
NAT规则的名称
Priority
NAT规则的匹配优先级
NAT counting
NAT入方向动态地址转换的计数信息
Config status
显示NAT配置的状态
·     Active:生效
·     Inactive:不生效
当Config status字段为Inactive时,显示NAT入方向动态地址转换的配置不生效的原因
·     The following items don't exist or aren't effective:以下一个或多个配置项不存在或不生效
¡     address group:地址组不存在或不生效
¡     ACL:ACL不存在或不生效
·     nat inbound
display nat log命令用来显示NAT日志功能的配置信息。
display nat log
# 显示NAT日志功能的配置信息。
<Sysname> display nat log
NAT logging:
  Flow-end            : Disabled
  Alarm               : Disabled
表1-7 display nat log命令显示信息描述表
NAT logging
NAT日志功能的配置信息
Log enable
NAT日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
Flow-begin
NAT会话新建日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
Flow-end
NAT会话删除日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
Flow-active
NAT活跃流日志功能开关
·     Enabled:表示处于开启状态。该状态下,将同时显示配置的生成活跃流日志的时间间隔(单位为分)
·     Disabled:表示处于关闭状态
Port-block-assign
‌端口块分配的NAT444用户日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
Port-block-withdraw
‌端口块回收的NAT444用户日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
Alarm
‌NAT444告警信息日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
·     nat log enable
·     nat log flow-active
·     nat log flow-begin
display nat no-pat命令用来显示NAT NO-PAT表项信息。
display nat no-pat [ slot slot-number ]
slot slot-number:显示指定成员设备上的NO-PAT表项信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上的NO-PAT表项信息。
NO-PAT表项记录了动态分配的一对一地址映射关系,该表项有两个作用:
·     保证后续同方向的新连接使用与第一个连接相同的地址转换关系。
·     反方向的新连接可以使用NO-PAT表进行地址转换。
nat inbound和nat outbound配置的NO-PAT方式在转换报文地址之后都需要创建NO-PAT表。这两种配置创建的NO-PAT表类型不同,不能互相使用,因此分成两类进行显示。
# 显示指定slot的NAT NO-PAT表项。
<Sysname> display nat no-pat slot 1
Slot 1:
Global  IP: 200.100.1.100
Local   IP: 192.168.100.100
Reversible: N
Type      : Inbound
Local   IP: 192.168.100.200
Global  IP: 200.100.1.200
Reversible: Y
Type      : Outbound
表1-8 display nat no-pat命令显示信息描述表
Global IP
外网IP地址
Local IP
内网IP地址
Reversible
是否允许反向地址转换。若其值为“Y”,则表示在某方向上发起的连接已成功建立地址转换表项的情况下,允许反方向发起的连接使用已建立的地址转换表项进行地址转换;若其值为“N”,则表示不允许
NO-PAT表项类型
·     Inbound:入方向动态地址转换过程中创建的NO-PAT表项
·     Outbound:出方向动态地址转换过程中创建的NO-PAT表项
Total entries found
当前查找到的NO-PAT表项的个数
·     nat inbound
·     nat outbound
display nat outbound命令用来显示出方向动态地址转换的配置信息。
# 显示出方向动态地址转换的配置信息。
<Sysname> display nat outbound
    ACL: 2036
    Address group ID: 1
    Rule name: abefg
    Priority: 1000
    NAT counting: 0
    ACL: 2037
    Address group ID: 2
    Rule name: cdefg
    Priority: 1001
    NAT counting: 0
    DS-Lite B4 ACL: 2100
    Address group ID: 2
    Port-preserved: N             NO-PAT: N  Reversible: N
    Priority: 0
    NAT counting: 0
表1-9 display nat outbound命令显示信息描述表
出方向动态地址转换的配置信息
Totally n NAT outbound rules
当前存在n条出方向动态地址转换
出方向动态地址转换配置所在的接口
ACL
引用的IPv4 ACL编号或名称。如果未配置,则显示“---”
DS-Lite B4 ACL
(暂不支持)DS-Lite B4引用的IPv6 ACL编号或名称
Address group ID
出方向动态地址转换使用的地址组编号。如果未配置,则显示“---”
Address group name
出方向动态地址转换使用的地址组名称。如果未配置,则不显示该字段
Port-preserved
PAT方式下,是否尽量不转换端口。若其值为“Y”,则表示PAT方式下分配端口时尽量不转换端口;若其值为“N”,则允许并接受PAT方式下分配端口时转换端口
NO-PAT
是否使用NO-PAT方式进行转换。若其值为“N”,则表示使用PAT方式
Reversible
Rule name
NAT规则的名称
Priority
NAT规则的匹配优先级
NAT counting
出方向动态地址转换的计数信息
Config status
显示配置的状态
·     Active:生效
·     Inactive:不生效
当Config status字段为Inactive时,显示配置不生效的原因
¡     interface IP address:接口地址不存在或不生效
¡     ACL:ACL不存在或不生效
·     NAT address conflicts:NAT地址冲突
·     nat outbound
display nat outbound port-block-group命令用来显示NAT444端口块静态映射的配置信息。
# 显示NAT444端口块静态映射的配置信息。
<Sysname> display nat outbound port-block-group
    port-block-group: 2
    Rule name: abcdefg
    NAT counting: 0
    Rule name: abcfg
    NAT counting: 0
表1-10 display nat outbound port-block-group 命令显示信息描述表
NAT444端口块静态映射的配置信息
Totally n outbound port block group items
当前存在n条NAT444端口块静态映射配置
NAT444端口块静态映射配置所在的接口
port-block-group
端口块组编号
Rule name
NAT规则的名称
NAT counting
NAT444端口块静态映射的计数信息
Config status
显示配置的状态
·     Active:生效
·     Inactive:不生效
·     The following items don't exist or aren't effective: port block group:配置中端口块组不存在或不生效
·     nat outbound port-block-group
display nat port-block命令用来显示端口块表项。
display nat port-block { dynamic [ address-group { group-id | name group-name } ] | static [ port-block-group group-id ] } [ slot slot-number ]
dynamic:显示动态端口块表项。
address-group:显示指定地址组的端口块表项。如果不指定该参数,则显示所有地址组的端口块表项信息。
name group-name:地址组的名称,为1~63个字符的字符串,不区分大小写。
static:显示静态端口块表项。
port-block-group group-id:显示指定NAT端口块组的端口块表项。group-id为NAT端口块组的编号,取值范围为0~65535。如果不指定该参数,则显示所有NAT端口块组的端口块表项信息。
slot slot-number:显示指定成员设备上的端口块表项信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上的端口块表项信息。
# 显示指定slot上的静态端口块表项。
<Sysname> display nat port-block static slot 1
Slot 1:
Local VPN     Local IP         Global IP        Port block   Connections
---           100.100.100.111  202.202.100.101  10001-10256  0
---           100.100.100.112  202.202.100.101  10257-10512  0
---           100.100.100.113  202.202.100.101  10513-10768  0
---           100.100.100.113  202.202.100.101  10769-11024  0
Total mappings found: 4
# 显示指定slot上的动态端口块表项。
<Sysname> display nat port-block dynamic slot 1
Slot 1:
---           101.1.1.12       192.168.135.201  10001-11024  1
Total mappings found: 1
表1-11 display nat port-block 命令显示信息描述表
Local VPN
(暂不支持)私网IP地址所属VPN实例,“---”表示不属于任何VPN实例
Local IP
私网IP地址
Global IP
公网IP地址
Port block
端口块(起始端口-结束端口)
Connections
当前使用本端口块中的端口建立的连接数
display nat port-block-group命令用来显示NAT端口块组配置信息。
display nat port-block-group [ group-id ]
group-id:端口块组的编号,取值范围为0~65535。如果不设置该值,则显示所有端口块组的配置信息。
# 显示所有端口块组的配置信息。
<Sysname> display nat port-block-group
  Port block group 1:
    Port range: 1-65535
    Block size: 256
  Port block group 2:
    Block size: 500
  Port block group 3:
    Port range: 1-65535
    Block size: 256
# 显示端口块组1的配置信息。
<Sysname> display nat port-block-group 1
  Port block group 1:
    Port range: 1-65535
    Block size: 256
表1-12 display nat port-block-group 命令显示信息描述表
NAT端口块组信息
Totally n NAT port block groups
当前有n个端口块组
Port block group
端口块组的编号
Port range
公网地址的端口范围
Block size
端口块大小
私网IP地址成员信息
公网IP地址成员信息
Start address
私网/公网IP地址成员的起始IP地址。如果未配置,则显示“---”
End address
私网/公网IP地址成员的成员结束IP地址。如果未配置,则显示“---”
VPN instance
(暂不支持)私网IP地址成员所属的VPN实例。如果未配置,则显示“---”
display nat port-block-usage命令用来显示动态NAT444地址组中端口块的使用率。
display nat port-block-usage [ address-group group-id ] [ slot slot-number ]
address-group group-id:显示某一指定地址组的端口块使用率。group-id表示地址组编号,取值范围为0~65535。若不指定该参数,则显示所有地址组的端口块使用率。
slot slot-number:显示指定成员设备上动态NAT444地址组中端口块的使用率,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上动态NAT444地址组中端口块的使用率。
# 显示指定slot上动态NAT444地址组中端口块的使用率。
<Sysname> display nat port-block-usage slot 1
Slot 1:
Address group 0 on channel 0:
  Total port block entries :10
  Active port block entries:9
  Current port block usage :90%
Total NAT address groups found: 1
表1-13 display nat port-block-usage命令显示信息描述表
CPU
CPU编号
Address group
地址组的编号
channel
FPGA(Field-Programmable Gate Array,现场可编程门阵列)编号
地址组中端口块总数
地址组中已分配端口块数
地址组中当前端口块使用率
当前地址组的个数
display nat server命令用来显示NAT内部服务器的配置信息。
display nat server
# 显示NAT内部服务器的信息。
<Sysname> display nat server
NAT internal server information:
  Totally 5 internal servers.
    Global ACL    : 2000
    Local IP/port : 192.168.10.1/23
    Rule name     : cdefgab
    Priority      : 1000
    NAT counting  : 0
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23
    Local IP/port : 192.168.10.15/23
    Rule name     : ace
    NAT counting  : 0
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23-30
    Local IP/port : 192.168.10.15-192.168.10.22/23
    Rule name     : abcdef
    NAT counting  : 0
    Protocol: 255(Reserved)
    Global IP/port: 50.1.1.100/---
    Local IP/port : 192.168.10.150/---
    Rule name     : cdefg
    NAT counting  : 0
    Protocol: 17(UDP)
    Global IP/port: 50.1.1.2/23
    Local IP/port : server group 1
                    1.1.1.1/21            (Connections: 10)
                    192.168.100.200/80    (Connections: 20)
    Rule name     : white
    NAT counting  : 0
表1-14 display nat server命令显示信息描述表
NAT内部服务器的配置信息
Totally n internal servers
当前存在n条内部服务器配置
内部服务器配置所在的接口
Protocol
内部服务器的协议编号以及协议名称
Global IP/port
内部服务器的外网地址/端口号
·     Global IP可以是单个地址,也可以是一个连续的地址段。如果使用Easy IP方式,则此处显示指定的接口的地址;如果接口下未配置地址,则Global IP显示为“---”
·     port可以是单个端口,也可以是一个连续的端口段。如果指定的协议没有端口的概念,则port显示为“---”
Local IP/port
对于普通内部服务器和基于对象组的内部服务器,显示服务器的内网地址/端口号
·     Local IP可以是单个地址,也可以是一个连续的地址段
对于负载分担内部服务器,显示内部服务器组编号以及服务器组成员的IP地址、端口和连接数
ACL
引用的ACL编号或名称。如果未配置,则不显示该字段
Rule name
NAT规则的名称
NAT counting
NAT内部服务器地址转换的计数信息
Config status
显示配置的状态
·     Active:生效
·     Inactive:不生效
当Config status字段为Inactive时,显示NAT内部服务器的配置不生效的原因
¡     server group:服务器组不存在或不生效
¡     ACL:ACL不存在或不生效
·     Server configuration conflicts:NAT内部服务器配置冲突
·     nat server
display nat server-group命令用来显示NAT内部服务器组的配置信息。
display nat server-group [ group-id ]
group-id:NAT内部服务器组的编号,取值范围0~65535。如果不指定该参数,则显示所有内部服务器组。
# 显示所有NAT内部服务器组的配置信息。
<Sysname> display nat server-group
                      192.168.0.27          23          500
  2                   ---                   ---         ---
# 显示指定NAT内部服务器组的配置信息。
<Sysname> display nat server-group 1
                      192.168.0.27          23          500
表1-15 display nat server-group命令显示信息描述表
NAT内部服务器组信息
Totally n NAT server groups
当前有n个内部服务器组
Group Number
内部服务器组的编号
Inside IP
内部服务器组成员在内网的IP地址。如果未配置,则显示“---”
Port
内部服务器组成员在内网的端口。如果未配置,则显示“---”
Weight
内部服务器组成员的权重值。如果未配置,则显示“---”
·     nat server-group
display nat session命令用来显示NAT会话,即经过NAT地址转换处理的会话。
display nat session [ [ responder ] { source-ip source-ip | destination-ip destination-ip } * ] [ slot slot-number ] [ verbose ]
responder:表示以响应方的信息筛选显示NAT会话表项。若不指定该参数时,则以发起方的信息筛选显示NAT会话表项。
source-ip source-ip:显示指定源地址的会话。source-ip表示源地址,该地址必须是创建会话的报文的源地址。
destination-ip destination-ip:显示指定目的地址的会话。destination-ip表示目的地址,该地址必须是创建会话的报文的目的地址。
slot slot-number:显示指定成员设备上的NAT会话,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的NAT会话。
verbose:显示NAT会话的详细信息。如果不配置则显示会话的概要信息。
如果不指定任何参数,则显示所有的NAT会话。
# 显示指定slot上NAT会话的详细信息。
<Sysname> display nat session slot 1 verbose
Slot 1:
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: Vlan-interface10
  Source security zone: SrcZone
Responder:
  Source      IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.10/1877
  Protocol: TCP(6)
  Inbound interface: Vlan-interface20
  Source security zone: DestZone
State: TCP_SYN_SENT
Application: SSH
Rule ID: -/-/-
Rule name:
Start time: 2011-07-29 19:12:36  TTL: 28s
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
Total sessions found: 1
表1-16 display nat session命令显示信息描述表
Initiator
发起方的会话信息
Responder
响应方的会话信息
Source IP/port
源IP地址/端口号
Destination IP/port
目的IP地址/端口号
DS-Lite tunnel peer
DS-Lite隧道对端地址。会话不属于任何DS-Lite隧道时,本字段显示为“-”
会话所属的MPLS L3VPN(暂不支持)/二层转发时会话所属的VLAN ID/二层转发时会话所属的INLINE。如果未指定则显示“-/-/-”
Protocol
传输层协议类型,包括:DCCP、ICMP、Raw IP 、SCTP、TCP、UDP、UDP-Lite
Inbound interface
报文的入接口
会话状态
Application
应用层协议类型,取值包括:FTP、DNS等,OTHER表示未知协议类型,其对应的端口为非知名端口
Rule ID
安全策略规则的ID
Rule name
安全策略规则的名称
Start time
会话创建时间
TTL
会话剩余存活时间,单位为秒
发起方到响应方的报文数、报文字节数
响应方到发起方的报文数、报文字节数
当前查找到的会话的总数
·     reset nat session
display nat static命令用来显示NAT静态地址转换的配置信息。
display nat static
# 显示NAT静态地址转换的配置信息。
<Sysname> display nat static
  Net-to-net:
    Global IP    : 1.1.1.1 - 1.1.1.255
    Local IP     : 2.2.2.0
    ACL          : 2000
    Reversible   : Y
    Rule name    : adefg
    Priority     : 1000
    NAT counting : 0
  IP-to-IP:
    Global IP   : 5.5.5.5
    Local IP     : 4.4.4.4
    ACL          : 2001
    Reversible   : Y
    Rule name    : abefg
    Priority     : 1000
    NAT counting : 0
  Net-to-net:
    Global IP    : 2.2.2.0
    ACL          : 2000
    Reversible   : Y
    Rule name    : abcd
    Priority     : 1000
    NAT counting : 0
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    ACL:         : 2000
    Rule name    : defg
    Priority     : 1000
    NAT counting : 0
    Reversible   : Y
  Totally 1 interfaces enabled with static NAT.
表1-17 display nat static命令显示信息描述表
Static NAT mappings
静态地址转换的配置信息
Totally n inbound static NAT mappings
当前存在n条入方向静态地址转换的配置
Totally n outbound static NAT mappings
当前存在n条出方向静态地址转换的配置
Net-to-net
网段到网段的静态地址转换映射
IP-to-IP
IP到IP的静态地址转换映射
Local IP
内网IP地址或地址范围
Global IP
外网IP地址或地址范围
Netmask
IP地址掩码
ACL
Reversible
如果未配置,则不显示该字段
静态地址转换在接口下的开启情况
Totally n interfaces enabled with static NAT
当前有n个接口开启了静态地址转换
开启静态地址转换功能的接口
Rule name
NAT规则的名称
Priority
NAT规则的匹配优先级
NAT counting
静态地址转换的计数信息
Config status
显示配置的状态
·     Active:生效
·     Inactive:不生效
当Config status字段为Inactive时,显示静态地址转换的配置不生效的原因
¡     ACL:ACL不存在或不生效
·     nat static enable
·     nat static inbound
·     nat static inbound net-to-net
·     nat static inbound object-group
·     nat static outbound
·     nat static outbound net-to-net
·     nat static outbound object-group
display nat statistics命令用来显示NAT统计信息。
display nat statistics [ summary ] [ slot slot-number ]
summary:显示NAT统计信息的摘要信息。不指定该参数时,显示NAT统计信息的详细信息。
slot slot-number:显示指定成员设备上的NAT统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的NAT统计信息。
# 显示所有NAT统计信息的详细信息。
<Sysname> display nat statistics
Slot 1:
  Total session entries: 100
  Session creation rate: 0
  Total EIM entries: 1
  Total inbound NO-PAT entries: 0
  Total outbound NO-PAT entries: 0
  Total static port block entries: 10
  Total dynamic port block entries: 15
  Active static port block entries: 0
  Active dynamic port block entries: 0
表1-18 display nat statistics命令显示信息描述表
NAT会话表项个数
新建NAT会话的速率,单位为每秒个
Total EIM entries
EIM表项个数
入方向的NO-PAT表项个数
出方向的NO-PAT表项个数
‌当前配置创建的静态端口块表项个数
‌当前配置可创建的动态端口块表项个数,即可分配的动态端口块总数,包括已分配的端口块和尚未分配的端口块
‌当前正在使用的静态端口块表项个数
‌当前已创建的动态端口块表项个数,即已分配的动态端口块个数
# 显示所有NAT统计信息的概要信息。
<Sysname> display nat statistics summary
EIM: Total EIM entries.
SPB: Total static port block entries.
DPB: Total dynamic port block entries.
ASPB: Active static port block entries.
ADPB: Active dynamic port block entries.
Slot Sessions  EIM       SPB       DPB       ASPB      ADPB
2    0         0         0         1572720   0         0
表1-19 display nat statistics summary命令显示信息描述表
Sessions
NAT会话表项个数
EIM
EIM表项个数
SPB
‌当前配置创建的静态端口块表项个数
DPB
ASPB
‌当前正在使用的静态端口块表项个数
ADPB
global-ip-pool命令用来添加一个公网地址成员。
undo global-ip-pool命令用来删除一个公网地址成员。
global-ip-pool start-address end-address
undo global-ip-pool start-address [ end-address ]
不存在公网地址成员。
NAT端口块组视图
start-address end-address:公网地址成员的起始IP地址和结束IP地址。end-address必须大于或等于start-address;如果start-address和end-address相同,则表示只有一个地址。
在NAT444端口块静态映射中,端口基于公网地址成员的IP地址为私网地址成员的IP地址分配端口块。一个公网IP地址可对应的端口块个数,由端口块组配置的公网地址端口范围和端口块大小决定(端口范围除以端口块大小)。
一个端口块组内,一次添加的公网地址成员的数量不能超过255个,且各公网地址成员之间的IP地址不能重叠。
不同端口块组间的公网地址成员的IP地址可以重叠,但要保证在有地址重叠时端口范围不重叠。
# 在端口块组1中添加一个公网地址成员,IP地址从202.10.1.1到202.10.1.10。
[Sysname-port-block-group-1] global-ip-pool 202.10.1.1 202.10.1.10
1.1.22  inside ip
inside ip命令用来添加一个内部服务器组成员。
undo inside ip命令用来删除一个内部服务器组成员。
inside ip inside-ip port port-number [ weight weight-value ]
undo inside ip inside-ip port port-number
内部服务器组内没有内部服务器组成员。
内部服务器组视图
inside-ip:内部服务器组成员的IP地址。
port port-number:内部服务器组成员提供服务的端口号,取值范围为1~65535(FTP数据端口号20除外)。
weight weight-value:内部服务器组成员的权重。weight-value表示权值,取值范围为1~1000,缺省值为100。
内部服务器组成员按照权重比例对外提供服务,权重值越大的内部服务器组成员对外提供服务的比重越大。
# 为内部服务器组1添加一个内部服务器组成员,其IP地址为10.1.1.2,服务端口号为30。
[Sysname] nat server-group 1
[Sysname-nat-server-group-1] inside ip 10.1.1.2 port 30
·     nat server-group
local-ip-address命令用来添加一个私网地址成员。
undo local-ip-address命令用来删除一个私网地址成员。
local-ip-address start-address end-address
undo local-ip-address start-address [ end-address ]
不存在私网地址成员。
NAT端口块组视图
start-address end-address:私网地址成员的起始IP地址和结束IP地址。end-address必须大于或等于start-address;如果start-address和end-address相同,则表示只有一个地址。
私网地址成员的IP地址作为端口块的使用者,基于端口块组配置的公网地址成员的IP地址为其分配端口块。在一个端口块组内,一个私网IP地址只分配一个端口块。
如果一个端口块组中的私网地址总数超过可分配的端口块总数(端口范围除以端口块大小),则在进行NAT444端口块静态映射时,超出部分的私网地址将无法分配到端口块。
# 在端口块组1中添加一个私网地址成员,IP地址从172.16.1.1到172.16.1.255。
[Sysname-port-block-group-1] local-ip-address 172.16.1.1 172.16.1.255
nat address-group命令用来创建地址组,并进入地址组视图。如果指定的地址组已经存在,则直接进入地址组视图。
undo nat address-group命令用来删除指定的地址组。
nat address-group group-id [ name group-name ]
undo nat address-group group-id
不存在地址组。
group-id:地址组编号,取值范围为0~65535。
name group-name:地址组的名称,为1~63个字符的字符串,区分大小写。
一个地址组是多个地址组成员的集合,各个地址组成员通过address命令配置。当需要对数据报文进行动态地址转换时,其源地址将被转换为地址组成员中的某个地址。
# 创建一个地址组,编号为1,名称为abc。
[Sysname] nat address-group 1  name abc
·     address
·     display nat address-group
·     display nat all
·     nat inbound
·     nat outbound
1.1.25  nat alg
nat alg命令用来开启指定或所有协议类型的NAT ALG功能。
undo nat alg命令用来关闭指定或所有协议类型的NAT ALG功能。
nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
DNS、FTP、ICMP差错报文、RTSP、PPTP协议类型的NAT ALG功能处于开启状态,其他协议类型的NAT ALG功能处于关闭状态。
all:所有可指定的协议的ALG功能。
dns:表示DNS协议的ALG功能。
ftp:表示FTP协议的ALG功能。
h323:表示H323协议的ALG功能。
icmp-error:表示ICMP差错控制报文的ALG功能。
ils:表示ILS(Internet Locator Service,互联网定位服务)协议的ALG功能。
mgcp:表示MGCP(Media Gateway Control Protocol,媒体网关控制协议)协议的ALG功能。
nbt:表示NBT(NetBIOS over TCP/IP,基于TCP/IP的网络基本输入输出系统)协议的ALG功能。
pptp:表示PPTP(Point-to-Point Tunneling Protocol,点到点隧道协议)协议的ALG功能。
rsh:表示RSH(Remote Shell,远程外壳)协议的ALG功能。
rtsp:表示RTSP(Real Time Streaming Protocol,实时流协议)协议的ALG功能。
sccp:表示SCCP(Skinny Client Control Protocol,瘦小客户端控制协议)协议的ALG功能。
sip:表示SIP(Session Initiation Protocol,会话初始协议)协议的ALG功能。
sqlnet:表示SQLNET协议的ALG功能。
tftp:表示TFTP协议的ALG功能。
xdmcp:表示XDMCP(X Display Manager Control Protocol,X显示监控)协议的ALG功能。
ALG(Application Level Gateway,应用层网关)主要完成对应用层报文的解析和处理。通常情况下,NAT只对报文头中的IP地址和端口信息进行转换,不对应用层数据载荷中的字段进行分析和处理。然而对于一些应用层协议,它们的报文的数据载荷中可能包含IP地址或端口信息,这些载荷信息也必须进行有效的转换,否则可能导致功能不正常。
例如,FTP应用由数据连接和控制连接共同完成,而数据连接使用的地址和端口由控制连接协商报文中的载荷信息决定,这就需要ALG利用NAT的相关转换配置来完成载荷信息的转换,以保证后续数据连接的正确建立。
# 开启FTP协议的ALG功能。
[Sysname] nat alg ftp
·     display nat all
1.1.26  nat dns-map
nat dns-map命令用来配置一条域名到内部服务器的映射。
undo nat dns-map命令用来删除一条域名到内部服务器的映射。
nat dns-map domain domain-name protocol pro-type { interface interface-type interface-number | ip global-ip } port global-port
undo nat dns-map domain domain-name
不存在域名到内部服务器的映射。
domain domain-name:指定内部服务器的合法域名。domain-name表示内部服务器的域名,由“.”分隔的字符串组成(如aabbcc.com),每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。不区分大小写,字符串中可以包含字母、数字、“-”、“_”或“.”。
protocol pro-type:指定内部服务器的协议类型。pro-type表示具体的协议类型,取值为tcp或udp。
interface interface-type interface-number:表示使用指定接口的地址作为内部服务器的外网地址。interface-type interface-number表示接口类型和接口编号。
ip global-ip:指定内部服务器提供给外部网络访问的IP地址。global-ip表示外网IP地址。
port global-port:指定内部服务器提供给外部网络访问的服务端口号,可输入的形式如下:
数字:取值范围为1~65535。协议名称:为1~15个字符的字符串,例如ftp、telnet等。
NAT的DNS mapping功能需要和内部服务器配合使用,主要应用于DNS服务器在外网,应用服务器在内网(在NAT设备上有对应的nat server配置),内网用户需要通过域名访问内网应用服务器的场景。NAT设备对来自外网的DNS响应报文进行DNS ALG处理时,由于载荷中只包含域名和应用服务器的外网IP地址(不包含传输协议类型和端口号),当接口上存在多条NAT服务器配置且使用相同的外网地址而内网地址不同时,DNS ALG仅使用IP地址来匹配内部服务器可能会得到错误的匹配结果。因此需要借助DNS mapping的配置,指定域名与应用服务器的外网IP地址、端口和协议的映射关系,由域名获取应用服务器的外网IP地址、端口和协议,进而(在当前NAT接口上)精确匹配内部服务器配置获取应用服务器的内网IP地址。
设备可支持配置多条域名到内部服务器的映射。
# 某公司内部对外提供Web服务,内部服务器的域名为www.server.com,对外的IP地址为202.112.0.1,服务端口号为12345。配置一条域名到内部服务器的映射,使得公司内部用户可以通过域名访问内部Web服务器。
[Sysname] nat dns-map domain www.server.com protocol tcp ip 202.112.0.1 port 12345
·     display nat all
·     display nat dns-map
·     nat server
nat hairpin enable命令用来开启NAT hairpin功能。
undo nat hairpin enable用来关闭NAT hairpin功能。
nat hairpin enable
NAT hairpin功能处于关闭状态。
NAT hairpin功能用于满足位于内网侧的用户之间或用户与服务器之间通过NAT地址进行访问的需求,需要与内部服务器(nat server)、出方向动态地址转换(nat outbound)或出方向静态地址转换(nat static outbound)配合工作。开启NAT hairpin的内网侧接口上会对报文同时进行源地址和目的地址的转换。
# 在Vlan-interface10接口下开启NAT hairpin功能。
[Sysname-Vlan-interface10] nat hairpin enable
·     display nat all
nat icmp-error reply命令用来开启NAT转换失败时发送ICMP差错报文功能。
undo nat icmp-error reply命令用来恢复缺省情况。
NAT转换失败不发送ICMP差错报文。
缺省情况下,设备在NAT转换失败时,不发送ICMP差错报文,既可以减少网络上的无用报文,节约带宽,还可以避免将设备IP地址暴露在公网侧。
使用traceroute功能时,需要用到ICMP差错报文,需要开启发送ICMP差错报文的功能。
# 开启设备在NAT转换失败时,发送ICMP差错报文功能。
[Sysname] nat icmp-error reply
1.1.29  nat inbound
nat inbound命令用来配置入方向动态地址转换。
undo nat inbound命令用来删除指定的入方向动态地址转换。
nat inbound { ipv4-acl-number | name ipv4-acl-name } address-group { group-id | name group-name } [ no-pat [ reversible ] [ add-route ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
undo nat inbound { ipv4-acl-number | name ipv4-acl-name }
不存在入方向动态地址转换配置。
ipv4-acl-number:ACL的编号,取值范围为2000~3999。
name ipv4-acl-name:ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
address-group:指定地址转换使用的地址组。
no-pat:表示使用NO-PAT方式进行转换,即转换时不使用报文的端口信息。如果未指定本参数,则表示使用PAT方式进行转换,即转换时使用报文的端口信息。PAT方式仅支持TCP、UDP和ICMP查询报文,由于ICMP报文没有端口的概念,我们将ICMP ID作为ICMP报文的源端口。
reversible:表示允许反向地址转换。即,在外网用户主动向内网发起连接并成功触发建立地址转换表项的情况下,允许内网向该外网用户发起的连接使用已建立的地址转换表项进行目的地址转换。
add-route:为转换后的地址添加路由表,其目的地址是转换后的地址,出接口为进行地址转换的接口,下一跳为该报文转换前的源地址。
rule rule-name:NAT规则的名称,取值范围为1~63个字符的字符串,区分大小写,不能包括“\”、“/”、“:”、“*”、“?”、“<”、“>”、“|”、“””、和“@”。如果不指定该参数,则表示该规则无名称。
priority priority:NAT规则的匹配优先级,取值范围为0~2147483647,数值越小,优先级越高。如果不指定该参数,那么相应的NAT规则在同类NAT规则中,其匹配优先级最低。
disable:表示禁用该地址转换映射。如果不指定该参数,则地址转换映射处于启用状态。
description text:配置入方向动态地址转换的描述信息,text为1~63个字符的字符串,不区分大小写。
counting:NAT转换计数功能,即对每一次首报文地址转换进行计数。
从配置了入方向地址转换的接口接收到的符合ACL permit规则的报文,会使用地址组group-id中的地址进行源地址转换。
入方向地址转换有两种转换方式:
·     PAT方式:对于从外网到内网的报文,如果符合ACL,则使用地址组中的地址进行源地址转换,同时转换源端口(IP1/port1转换为IP2/port2)。
·     NO-PAT方式:对于从外网到内网的报文,如果符合ACL,则使用地址组中的地址进行源地址转换,不转换源端口(IP1转换为IP2);如果用户配置了reversible,则允许内网通过IP2主动访问外网,对于此类访问报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并将目的地址转换为IP1,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能进行转换(将目的地址IP2转换为IP1),否则不予转换。
nat inbound命令通常与nat outbound、nat server或nat static配合使用,用于支持在外网侧口上对报文同时进行源和目的转换,即双向NAT。
指定入方向和出方向动态地址转换引用的地址组时,需要注意:
·     一个地址组被nat inbound配置引用后,就不能再被nat outbound配置引用。
·     一个地址组被PAT方式的nat inbound配置引用后,不能再被NO-PAT方式的nat inbound配置引用,反之亦然。
add-route参数不能应用在内网与外网地址重叠的组网场景中。在其他组网场景中:
·     如果指定了add-route参数,则有报文命中该配置时,设备会自动添加路由表项:目的地址为本次地址转换使用的地址组中的地址,出接口为本配置所在接口,下一跳地址为报文的源地址。
·     如果没有指定add-route参数,则用户需要在设备上手工添加路由。由于自动添加路由表项速度较慢,通常建议手工添加路由。
在一个接口下,一个ACL只能被一个nat inbound引用。
一个接口下可同时配置多条入方向地址转换。
对于入方向动态地址转换,当NAT规则的匹配优先级相同时,设备将按照ACL名称或ACL编号进行匹配,且ACL名称的优先级高于ACL编号的优先级,具体规则如下:
·     对于ACL名称,设备将根据名称的字符序对NAT规则进行排序,在字符序中的位置越靠前,相应的NAT规则的匹配优先级越高。
·     对于ACL编号,编号越大,优先级越高,设备将优先进行匹配。
# 配置ACL 2001,允许对10.110.10.0/24网段的主机进行地址转换。
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 10.110.10.0 0.0.0.255
[Sysname-acl-ipv4-basic-2001] rule deny
#  配置地址组1,并添加地址组成员:202.110.10.10、202.110.10.11、202.110.10.12。
[Sysname-address-group-1] address 202.110.10.10 202.110.10.12
[Sysname-address-group-1] quit
# 在接口Vlan-interface10上配置入方向动态地址转换,使用地址组1中的地址进行地址转换,在转换的时候不使用TCP/UDP的端口信息,且需要添加路由。同时指定该入方向动态NAT规则的名称为abc,匹配优先级为0。
[Sysname-Vlan-interface10] nat inbound 2001 address-group 1 no-pat add-route rule abc priority 0
·     display nat all
·     display nat inbound
·     display nat no-pat
nat inbound rule move命令用来调整入方向动态NAT规则的匹配优先级。
nat inbound rule move nat-rule-name1 { after | before } nat-rule-name2
nat-rule-name1:要移动的NAT规则的名称。
after:将nat-rule-name1移动到nat-rule-name2后面,nat-rule-name2的匹配优先级的值不变,nat-rule-name1的匹配优先级的值=nat-rule-name2的匹配优先级的值+1。
before:将nat-rule-name1移动到nat-rule-name2前面,nat-rule-name2的匹配优先级的值不变,nat-rule-name1的匹配优先级的值=nat-rule-name2的匹配优先级的值-1。
nat-rule-name2:要移动的NAT规则的名称。
本命令仅对指定了NAT规则名称的入方向动态NAT生效。
对于被移动到前面的NAT规则,设备将会优先进行匹配。
# 将入方向动态NAT规则abc移动到入方向动态NAT规则def的前面。
[Sysname-Vlan-interface10] nat inbound rule move abc before def
·     nat inbound
nat log alarm命令用来开启NAT告警信息日志功能。
undo nat log alarm命令用来关闭NAT告警信息日志功能。
nat log alarm
undo nat log alarm
NAT告警信息日志功能处于关闭状态。
在NAT地址转换中,如果可为用户分配的NAT资源用尽,后续连接由于没有可用的资源无法对其进行地址转换,相应的报文将被丢弃。本命令用来在NAT资源用尽时输出告警日志。在NO-PAT动态映射中,NAT资源是指公网IP地址;在EIM模式的PAT动态映射中,NAT资源是指公网IP地址和端口;在NAT444地址转换中,NAT资源是指公网IP、端口块和端口块中的端口。
NAT444端口块动态映射方式中,如果配置了增量端口块分配,则当首次分配的端口块中的端口用尽时,并不输出日志;只有当增量端口块中的端口也都用尽时,才会输出日志。
对于NAT告警日志,在配置NAT告警信息日志功能前,必须先配置将用户定制日志发送到日志主机的功能,否则无法产生NAT告警信息日志。详细配置请参见“设备管理配置指导”中的“信息中心”。
只有开启NAT日志功能(通过nat log enable命令)之后,NAT告警信息日志功能才能生效。
# 开启NAT告警信息日志功能。
[Sysname] nat log alarm
·     display nat all
·     display nat log
·     nat log enable
nat log enable命令用来开启NAT日志功能。
undo nat log enable用来关闭NAT日志功能。
nat log enable [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat log enable
NAT日志功能处于关闭状态。
acl:指定ACL的编号或名称。
必须开启NAT日志功能,NAT会话日志功能(包括NAT新建会话、NAT删除会话和NAT活跃流的日志功能)、NAT444用户日志功能(包括NAT444端口块分配和NAT444端口块回收的日志功能)、NAT告警信息日志功能和NAT NO-PAT日志功能才能生效。
acl参数只对NAT会话日志功能有效,对其他NAT日志功能无效。如果指定了ACL,则只有符合ACL permit规则的数据流才有可能触发输出NAT会话日志;如果没有指定ACL,则表示对所有被NAT处理过的数据流都有可能触发输出NAT会话日志。
# 开启NAT日志功能。
[Sysname] nat log enable
·     display nat all
·     display nat log
·     nat log alarm
·     nat log flow-end
·     nat log port-block-assign
·     nat log port-block-withdraw
nat log flow-active命令用来开启NAT活跃流日志功能,并设置生成活跃流日志的时间间隔。
undo nat log flow-active命令用来关闭NAT活跃流的日志功能。
nat log flow-active time-value
NAT活跃流的日志功能处于关闭状态。
time-value:表示触发输出NAT活跃流日志的时间间隔,取值范围为10~120,单位为分钟。
对于一些长时间没有断开的NAT会话(即活跃流),如果需要定期记录其连接情况,则可以通过活跃流日志功能来实现。
开启NAT活跃流日志功能后,对于NAT活跃流,每经过指定的时间间隔,设备就会记录一次NAT日志。
只有开启NAT日志功能之后,活跃流日志功能才能生效。
# 开启NAT活跃流日志功能,并设置输出NAT活跃流日志的时间间隔为10分钟。
[Sysname] nat log flow-active 10
·     display nat all
·     display nat log
·     nat log enable
nat log flow-begin命令用来开启NAT新建会话的日志功能,即新建NAT会话时,输出NAT日志。
undo nat log flow-begin命令用来关闭NAT新建会话的日志功能。
nat log flow-begin
NAT新建会话的日志功能处于关闭状态。
只有开启NAT日志功能之后,NAT新建会话的日志功能才能生效。
# 开启NAT新建会话的日志功能。
[Sysname] nat log flow-begin
·     display nat all
·     display nat log
·     nat log enable
nat log flow-end命令用来开启NAT删除会话的日志功能。
undo nat log flow-end命令用来关闭NAT删除会话的日志功能。
nat log flow-end
NAT删除会话的日志功能处于关闭状态。
只有开启NAT日志功能之后,NAT删除会话的日志功能才能生效。
# 开启NAT删除会话的日志功能。
[Sysname] nat log flow-end
·     display nat all
·     display nat log
·     nat log enable
nat log port-block usage threshold命令用来配置动态NAT444端口块使用率的阈值。
undo nat log port-block usage threshold命令用来恢复缺省情况。
nat log port-block usage threshold threshold-value
动态NAT444的端口块使用率的阈值为90%。
threshold-value:端口使用率的阈值,为百分比数值,取值范围为40~100。
创建动态端口块表项时,若端口块的使用率大于阈值,系统会输出告警日志。
# 配置动态NAT444端口块使用率的阈值为60%。
[Sysname] nat log port-block usage threshold 60
nat log port-block-assign命令用来开启端口块分配的NAT444用户日志功能。
undo nat log port-block-assign命令用来关闭端口块分配的NAT444用户日志功能。
端口块分配的NAT444用户日志功能处于关闭状态。
端口块静态映射方式下,在某私网IP地址的第一个新建连接通过端口块进行地址转换时,如果开启了端口块分配的NAT444用户日志功能,则会输出日志。
端口块动态映射方式下,在为某私网IP地址分配端口块或增量端口块时,如果开启了端口块分配的NAT444用户日志功能,则会输出日志。
只有开启NAT日志功能之后,端口块分配的NAT444用户日志功能才能生效。
# 开启端口块分配的NAT444用户日志功能。
[Sysname] nat log port-block-assign
·     display nat all
·     display nat log
·     nat log enable
nat log port-block-withdraw命令用来开启端口块回收的NAT444用户日志功能。
undo nat log port-block-withdraw命令用来关闭端口块回收的NAT444用户日志功能。
端口块回收的NAT444用户日志功能处于关闭状态。
端口块静态映射方式下,在某私网IP地址的最后一个连接拆除时,如果开启了端口块回收的NAT444用户日志功能,则会输出日志。
端口块动态映射方式下,在释放端口块资源(并删除端口块表项)时,如果开启了端口块回收的NAT444用户日志功能,则会输出日志。
只有开启NAT日志功能之后,端口块回收的NAT444用户日志功能才能生效。
# 开启端口块回收的NAT444用户日志功能。
[Sysname] nat log port-block-withdraw
·     display nat all
·     display nat log
·     nat log enable
nat mapping-behavior命令用来配置PAT方式出方向动态地址转换的模式。
undo nat mapping-behavior命令用来恢复缺省情况。
nat mapping-behavior endpoint-independent [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat mapping-behavior endpoint-independent
PAT出方向动态方式地址转换的模式为Address and Port-Dependent Mapping。
acl:指定ACL的编号或名称,用于控制需要遵守指定地址转换模式的报文范围。
PAT方式出方向动态地址转换支持两种模式:
·     Endpoint-Independent Mapping(不关心对端地址和端口的转换模式):只要是来自相同源地址和源端口号的报文,不论其目的地址是否相同,通过PAT映射后,其源地址和源端口号都被转换为同一个外部地址和端口号,该映射关系会被记录下来并生成一个EIM表项;并且NAT网关设备允许外部网络的主机通过该转换后的地址和端口来访问这些内部网络的主机。这种模式可以很好的支持位于不同NAT网关之后的主机间进行互访。
·     Address and Port-Dependent Mapping(关心对端地址和端口的转换模式):对于来自相同源地址和源端口号的报文,若其目的地址和目的端口号不同,由于相同的源地址和源端口号不要求被转换为相同的外部地址和端口号,所以通过PAT映射后,相同的源地址和源端口号通常会被转换成不同的外部地址和端口号。并且NAT网关设备只允许这些目的地址对应的外部网络的主机才可以通过该转换后的地址和端口来访问这些内部网络的主机。这种模式安全性好,但是不便于位于不同NAT网关之后的主机间进行互访。
该配置只对出方向动态地址转换的PAT方式起作用。入方向动态地址转换的PAT方式的转换模式始终为 Address and Port-Dependent Mapping。
如果配置了acl参数,则表示只有符合ACL permit规则的报文才采用Endpoint-Independent Mapping模式进行地址转换;如果没有配置acl参数,则表示所有的报文都采用Endpoint-Independent Mapping模式进行地址转换。
# 对所有报文都以Endpoint-Independent Mapping模式进行地址转换。
[Sysname] nat mapping-behavior endpoint-independent
# 仅对FTP和HTTP报文才以Endpoint-Independent Mapping模式进行地址转换,其它报文采用Address and Port-Dependent Mapping模式进行地址转换。
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 80
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 21
[Sysname] nat mapping-behavior endpoint-independent acl 3000
·     nat outbound
·     display nat eim
1.1.40  nat outbound
nat outbound命令用来配置出方向动态地址转换。
undo nat outbound命令用来删除指定的出方向动态地址转换。
不存在动态地址转换配置。
·     NO-PAT方式
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] address-group { group-id | name group-name } no-pat [ reversible ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
undo nat outbound [ ipv4-acl-number | name ipv4-acl-name ]
·     PAT方式
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] [ address-group { group-id | name group-name } ] [ port-preserved ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
address-group group-id:指定地址转换使用的地址组。如果不指定该参数,则直接使用该接口的IP地址作为转换后的地址,即实现Easy IP功能。
no-pat:表示使用NO-PAT方式进行转换,即转换时不使用报文的端口信息;如果未指定本参数,则表示使用PAT方式进行转换,即转换时使用报文的端口信息。PAT方式仅支持TCP、UDP和ICMP查询报文,由于ICMP报文没有端口的概念,我们将ICMP ID作为ICMP报文的源端口。
reversible:表示允许反向地址转换。即,在内网用户主动向外网发起连接并成功触发建立地址转换表项的情况下,允许外网向该内网用户发起的连接使用已建立的地址转换表项进行目的地址转换。
port-preserved:PAT方式分配端口时尽量不转换端口。port-preserved参数对NAT444端口块动态映射无效。
description text:配置出方向动态地址转换的描述信息,text为1~63个字符的字符串,不区分大小写。
counting:开启NAT转换计数功能,即对每一次首报文地址转换进行计数。
一般情况下,出方向动态地址转换配置在和外部网络连接的接口上,一个接口下可同时配置多条出方向地址转换。动态地址转换有两种转换方式:
·     PAT方式:对于从内网到外网的报文,如果符合ACL permit规则,则使用地址组中的地址或该接口的地址(Easy IP方式)进行源地址转换,同时转换源端口(IP1/port1转换为IP2/port2);如果同时配置了PAT方式下的地址转换模式为EIM(Endpoint-Independent Mapping),则外网可以通过IP2/port2主动访问内网,NAT设备根据EIM表项转换目的地址和端口(IP2/port2转换为IP1/port1)。
·     NO-PAT方式:对于从内网到外网的报文,如果符合ACL permit规则,则使用地址组中的地址进行源地址转换,不转换源端口(IP1转换为IP2);如果同时配置了reversible,则允许外网通过IP2主动访问内网,对于此类报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并将目的地址转换为IP1,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能进行转换(将目的地址IP2转换为IP1),否则不予转换。NAT444端口块动态映射不支持该方式。
指定出方向和入方向动态地址转换引用的地址组时,需要注意:
·     一个地址组被nat outbound配置引用后,不能再被nat inbound引用。
·     一个地址组被PAT方式的nat outbound配置引用后,不能再被NO-PAT方式的nat outbound配置引用,反之亦然。
·     如果PAT方式的nat outbound所引用的地址组中配置了端口块参数,则将对匹配的报文进行NAT444端口块动态映射。port-preserved参数对NAT444端口块动态映射无效。
指定出方向动态地址转换引用的ACL时,需要注意:
·     在一个接口下,一个ACL只能被一个nat outbound引用。
·     配置多条出方向动态地址转换时,只有一个nat outbound可以不引用ACL。
·     不指定ACL编号或名称的情况下,不对转换对象进行限制。
·     对于同一接口下的出方向动态地址转换配置,指定了ACL的配置的优先级高于未指定ACL的配置的优先级;对于指定了ACL的出方向动态地址转换配置,其生效优先级由ACL编号的大小决定,编号越大,优先级越高。
对于引用了ACL的出方向动态地址转换,当NAT规则的匹配优先级相同时,设备将按照ACL名称或ACL编号进行匹配,且ACL名称的优先级高于ACL编号的优先级,具体规则如下:
# 配置ACL 2001,允许对10.110.10.0/24网段的主机报文进行地址转换。
# 在接口Vlan-interface10上配置出方向动态地址转换,允许对匹配ACL 2001的报文使用地址组1中的地址进行地址转换,且在转换的时候使用TCP/UDP的端口信息。
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1
[Sysname-Vlan-interface10] quit
# 如果在接口Vlan-interface10上不使用TCP/UDP的端口信息进行地址转换,可以使用如下配置。
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1 no-pat
# 如果直接使用接口Vlan-interface10接口的IP地址进行地址转换,可以使用如下的配置。
# 内网10.110.10.0/24网段的主机使用地址组1中的地址作为转换后的地址访问外部网络。如果要在内网用户向外网主动发起访问之后,允许外网用户主动向10.110.10.0/24网段的主机发起访问,并利用已建立的地址转换表项进行反向地址转换,可以使用如下配置。
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1 no-pat reversible
·     display nat eim
·     display nat outbound
nat outbound port-block-group命令用来配置NAT444端口块静态映射。
undo nat outbound port-block-group命令用来删除指定的NAT444端口块静态映射配置。
nat outbound port-block-group group-id [ rule rule-name ] [ counting ]
undo nat outbound port-block-group group-id
不存在NAT444端口块静态映射配置。
rule rule-name:NAT规则的名称,取值范围为1~63个字符的字符串,区分大小写,不能包括“\”、“/”、“:”、“*”、“?”、“<”、“>”、“|”、“””和“@”。如果不指定该参数,则表示该规则无名称。
该配置在接口下引用指定的端口块组,根据端口块组内的配置数据,按照固定的算法为每个私网IP地址分配一个静态端口块并创建静态端口块表项。当某私网IP地址向公网发起连接时,通过该私网IP地址查找静态端口块表项,使用表项中记录的公网IP地址进行地址转换,并从对应的端口块中动态分配一个端口进行TCP/UDP端口转换。
一个接口下可以配置多条基于不同端口块组的NAT444端口块静态映射。
# 在接口Vlan-interface10的出方向上配置基于端口组1的NAT444端口块静态映射。同时指定该NAT444端口块静态映射规则的名称为abc。
[Sysname-Vlan-interface10] nat outbound port-block-group 1 rule abc
·     display nat all
·     display nat outbound port-block-group
·     display nat port-block
nat outbound rule move命令用来调整出方向动态NAT规则的匹配优先级。
nat outbound rule move nat-rule-name1 { after | before } nat-rule-name2
本命令仅对指定了NAT规则名称的出方向动态NAT生效。
# 将出方向动态NAT规则abc移动到出方向动态NAT规则def的前面。
[Sysname-Vlan-interface10] nat outbound rule move abc before def
·     nat outbound
nat port-block global-share enable命令用来开启端口块全局共享功能。
undo nat port-block global-share enable命令用来关闭端口块全局共享功能。
端口块全局共享功能处于关闭状态。
在已配置NAT444端口块动态映射的情况下,当同一个源IP地址的报文从不同出接口进行NAT地址转换时,可能会分配到不同的端口块。如果需要使同一个源IP地址分配到相同的端口块,请开启端口块全局共享功能。
# 开启端口块全局共享功能。
[Sysname] nat port-block global-share enable
·     port-block
nat port-block-group命令用来创建NAT端口块组,并进入NAT端口块组视图。如果指定的NAT端口块组已经存在,则直接进入NAT端口块组视图。
undo nat port-block-group命令用来删除指定的NAT端口块组。
nat port-block-group group-id
undo nat port-block-group group-id
不存在NAT端口块组。
group-id:NAT端口块组的编号,取值范围为0~65535。
创建的NAT端口块组用于配置NAT444端口块静态映射。一个端口块组中包含如下内容:
·     一个或多个私网地址成员,通过local-ip-address命令配置。
·     一个或多个公网地址成员,通过global-ip-pool命令配置。
·     公网地址的端口范围,通过port-range命令配置。
·     端口块大小,通过block-size命令配置。
在进行NAT444端口块静态映射时,系统根据相应端口块组的配置计算出私网IP地址到公网IP地址、端口块的静态映射关系,并创建静态端口块表项。
# 创建一个NAT端口块组,编号为1。
<Sysname>system-view
[Sysname]nat port-block-group 1
·     block-size
·     display nat all
·     display nat port-block-group
·     global-ip-pool
·     local-ip-address
·     port-range
1.1.45  nat server
nat server命令用来配置NAT内部服务器,即定义内部服务器的外网地址和端口与内网地址和端口的映射表项。
undo nat server命令用来删除指定的内部服务器配置。
(1)     普通内部服务器
·     外网地址单一,未使用外网端口或外网端口单一
nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] inside local-address [ local-port ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ reversible ] [ rule rule-name ] [ disable ] [ counting ]
undo nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ]
·     外网地址单一,外网端口连续
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ rule rule-name ] [ disable ] [ counting ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2
·     外网地址连续,未使用外网端口或外网端口单一
nat server protocol pro-type global global-address1 global-address2 [ global-port ] inside { local-address | local-address1 local-address2 } [ local-port ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ rule rule-name ] [ disable ] [ counting ]
undo nat server protocol pro-type global global-address1 global-address2 [ global-port ]
·     外网地址连续,外网端口单一
nat server protocol pro-type global global-address1 global-address2 global-port inside local-address local-port1 local-port2 [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ rule rule-name ] [ disable ] [ counting ]
undo nat server protocol pro-type global global-address1 global-address2 global-port
(2)     负载均衡内部服务器
nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } inside server-group group-id [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ rule rule-name ] [ disable ] [ counting ]
undo nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port }
(3)     基于ACL的内部服务器
nat server global { ipv4-acl-number | name ipv4-acl-name } inside local-address [ local-port ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
undo nat server global { ipv4-acl-number | name ipv4-acl-name }
不存在内部服务器。
protocol pro-type:指定协议类型。只有当协议类型是TCP、UDP协议时,配置的内部服务器才能带端口参数。如果不指定协议类型,则表示对所有协议类型的报文都生效。pro-type可输入以下形式:
·     数字:取值范围为1~255。
·     协议名称:取值包括icmp、tcp和udp。
global:指定服务器向外提供服务的外网信息。
global-address:内部服务器向外提供服务时对外公布的外网IP地址。
global-address1、global-address2:外网IP地址范围,所包含的地址数目不能超过10000。global-address1表示起始地址,global-address2表示结束地址。global-address2必须大于global-address1。
current-interface:使用当前接口的主用IP地址作为内部服务器的外网地址,即实现Easy IP方式的内部服务器。
interface interface-type interface-number:表示使用指定接口的主用IP地址作为内部服务器的外网地址,即实现Easy IP方式的内部服务器。interface-type interface-number表示接口类型和接口编号。目前只支持Loopback接口。
global-port1、global-port2:外网端口范围,和内部主机的IP地址范围构成一一对应的关系。global-port1表示起始端口,global-port2表示结束端口。global-port2必须大于global-port1,且端口范围中的端口数目不能大于10000。外网端口可输入以下形式:
·     数字:取值范围为1~65535。起始端口和结束端口均支持此形式。
·     协议名称:为1~15个字符的字符串,例如http、telnet等。仅起始端口支持该形式。
inside:指定服务器的内网信息。
local-address1、local-address2:定义一组连续的内网IP地址范围,和外网端口范围构成一一对应的关系。local-address1表示起始地址,local-address2表示结束地址。local-address2必须大于local-address1。该地址范围的数量必须和global-port1、global-port2定义的端口数量相同。
local-port:内部服务器的内网端口号,可输入以下形式:
·     数字:取值范围为1~65535(FTP数据端口号20除外)。
global-port:外网端口号,缺省值以及取值范围的要求和local-port的规定一致。
local-address:服务器的内网IP地址。
server-group group-id:服务器在内网所属的服务器组。若指定了该参数,则表示要配置一个负载分担内部服务器。group-id表示内部服务器组的编号,取值范围为0~65535。
acl:指定ACL的编号或名称。若指定了该参数,则表示与指定的ACL permit规则匹配的报文才可以使用内部服务器的映射表进行地址转换。
reversible:表示支持私网侧内部服务器主动访问外网。内部服务器主动访问外网时,将私网地址转换为内部服务器向外提供服务的外网IP地址。
description text:配置NAT内部服务器的描述信息,text为1~63个字符的字符串,不区分大小写。
通过该配置可以利用NAT设备将一些内部网络的服务器提供给外部网络使用,例如内部的Web服务器、FTP服务器、Telnet服务器、POP3服务器、DNS服务器等。
NAT内部服务器通常配置在NAT设备的外网侧接口上。外网用户可以通过global-address定义的外网地址和global-port定义的外网端口来访问内网地址和内网端口分别为local-address和local-port的内部服务器。当pro-type不是TCP(协议号为6)或UDP(协议号为17)时,用户只能设置内部IP地址与外部IP地址的一一对应的关系,无法设置端口号之间的映射。
NAT内部服务器支持以下几种内网和外网的地址、端口映射关系。
表1-20 NAT内部服务器的地址与端口映射关系
外网
内网
一个外网地址
一个内网地址
一个外网地址、一个端口号
一个内网地址、一个内网端口号
一个外网地址,N个连续的外网端口号
·     一个内网地址,一个内网端口
·     N个连续的内网地址,一个内网端口号
·     一个内网地址,N个连续的内网端口号
N个连续的外网地址
·     一个内网地址
·     N个连续的内网地址
N个连续的外网地址连续,一个外网端口号
·     一个内网地址,一个内网端口号
·     N个连续的内网地址,一个内网端口号
·     一个内网地址,N个连续的内网端口号
一个外网地址,一个外网端口号
一个内部服务器组
一个外网地址,N个连续的外网端口号
N个连续的外网地址,一个外网端口号
外网地址(通过ACL进行匹配)
·     一个内网地址
·     一个内网地址、一个内网端口号
对于同一个接口下配置的NAT服务器,其协议类型、外网地址和外网端口号的组合必须是唯一的,否则认为是配置冲突。本规则同样适用于Easy IP方式的NAT服务器。每个nat server命令下可以配置的NAT内部服务器数目为global-port2与global-port1的差值,即配置多少个外网端口就对应多少个NAT内部服务器。
由于Easy IP方式的NAT内部服务器使用了当前接口或其它接口的IP地址作为它的外网地址,因此强烈建议在配置了Easy IP方式的NAT内部服务器之后,其它NAT内部服务器不要再配置该接口的IP地址作为它的外网地址,反之亦然。
对于Easy IP方式的NAT服务器,如果其引用的接口的IP地址发生改变,导致跟现有的其它非Easy IP方式的NAT服务器冲突,则Easy IP方式的NAT服务器配置失效;如果接口地址又修改为不冲突的IP,或者之前与之冲突的NAT服务器被删除,则Easy IP方式的NAT配置重新生效。
在配置负载均衡内部服务器时,若配置一个外网地址,N个连续的外网端口号对应一个内部服务器组,或N个连续的外网地址,一个外网端口号对应一个内部服务器组,则内部服务器组的成员个数不能小于N,即同一用户不能通过不同的外网地址或外网端口号访问相同内网服务器的同一服务。
对于基于ACL的内部服务器,当NAT规则的匹配优先级相同时,设备将按照ACL名称或ACL编号进行匹配,且ACL名称的优先级高于ACL编号的优先级,具体规则如下:
在支持NAT内部服务器自动分配NAT规则名称的版本上执行配置回滚操作时,如果回滚配置文件中的NAT内部服务器不存在系统为其自动分配的NAT规则名称,会出现回滚失败的错误提示信息。比如,回滚配置文件中的配置为nat server global 112.1.1.1 inside 192.168.20.1,回滚操作完成后的配置为nat server global 112.1.1.1 inside 192.168.20.1 rule 内部服务器规则_10(内部服务器规则_10为系统自动分配的NAT规则名称),系统会将此配置与回滚文件中的配置进行比较,比较后发现两者不一致,会提示用户回滚失败。这种情况下,相关的命令已下发成功,用户无需处理。
# 在接口Vlan-interface10上配置NAT内部服务器,指定局域网内部的Web服务器的IP地址是10.110.10.10,希望外部通过http://202.110.10.10:8080可以访问Web服务器。
[Sysname-Vlan-interface10] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 http
# 正确的服务器地址为10.0.0.172,用户配置的错误地址为192.168.0.0/24网段的地址,在接口Vlan-interface10上配置基于ACL的内部服务器对这部分用户的配置错误进行纠正。
[Sysname-acl-ipv4-adv-3000] rule 5 permit ip destination 192.168.0.0 0.0.0.255
[Sysname-Vlan-interface10] nat server global 3000 inside 10.0.0.172
·     display nat all
·     display nat server
·     nat server-group
nat server rule move命令用来调整基于ACL内部服务器NAT规则的匹配优先级。
nat server rule move nat-rule-name1 { after | before } nat-rule-name2
本命令仅对指定了NAT规则名称的基于ACL内部服务器NAT生效。
# 将基于ACL内部服务器NAT规则abc移动到基于ACL内部服务器NAT规则def的前面。
[Sysname-Vlan-interface10] nat server rule move abc before def
·     nat server
nat server-group命令用来创建内部服务器组,并进入内部服务器组视图。如果指定的内部服务器组已经存在,则直接进入内部服务器组视图。
undo nat server-group命令用来删除指定的内部服务器组。
nat server-group group-id
undo nat server-group group-id
不存在内部服务器组。
group-id:服务器组编号,取值范围为0~65535。
一个内部服务器组中可以包括多个内部服务器组成员(通过inside ip命令配置)。
# 配置一个内部服务器组,编号为1。
·     display nat all
·     display nat server-group
·     inside ip
·     nat server
nat static enable命令用来开启接口上的NAT静态地址转换功能。
undo nat static enable命令用来关闭接口上的NAT静态地址转换功能。
nat static enable
NAT静态地址转换功能处于关闭状态。
接口下开启NAT静态地址转换功能后,所有已配置的静态地址转换映射都会在该接口上生效。
# 配置内网IP地址192.168.1.1到外网IP地址2.2.2.2的出方向一对一静态地址转换,并且在接口Vlan-interface10上开启静态地址转换功能。
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-Vlan-interface10] nat static enable
·     display nat all
·     display nat static
·     nat static
·     nat static net-to-net
nat static inbound命令用来配置入方向一对一静态地址转换映射。
undo nat static inbound命令用来删除指定的入方向一对一静态地址转换映射。
nat static inbound global-ip local-ip [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static inbound global-ip local-ip
不存在地址转换映射。
global-ip:外网IP地址。
local-ip:内网IP地址。
acl:指定ACL的编号或名称,本参数用于控制指定源地址的内网主机可以访问外网。
reversible:表示从内网主动访问外网的报文必须通过ACL反向匹配,才能使用该配置进行目的地址转换。
rule rule-name:NAT规则的名称,取值范围为1~63个字符的字符串,区分大小写,不能包括“\\”、“/”、“:”、“*”、“?”、“\”、“<”、“>”、“|”、“””和“@”。如果不指定该参数,则表示该规则无名称。
对于从外网到内网的报文,将其源地址global-ip转换为local-ip;对于从内网到外网的报文,将其目的地址local-ip转换为global-ip。
指定引用的ACL时,需要注意:
·     如果没有指定ACL,则所有从外网到内网的报文都可以使用该配置进行源地址转换;所有从内网到外网的报文都可以使用该配置进行目的地址转换。
·     如果仅指定了ACL,没有指定ACL反向匹配(即没有配置reversible),对于从外网到内网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从内网主动访问外网的报文,不能使用该配置进行目的地址转换。
·     如果既指定了ACL,又指定了ACL反向匹配(即配置了reversible),对于外网到内网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从内网主动访问外网的报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并根据配置转换目的地址,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能使用该配置进行转换,否则不予转换。
如果接口下既配置了NAT动态地址转换,又配置了NAT静态地址转换,则优先使用静态地址转换。
设备可支持配置多条入方向静态地址转换映射(包括nat static inbound和nat static inbound net-to-net)。
对于引用了ACL的入方向一对一静态地址转换映射,当NAT规则的匹配优先级相同时,设备将按照ACL名称或ACL编号进行匹配,且ACL名称的优先级高于ACL编号的优先级,具体规则如下:
# 配置外网IP地址2.2.2.2到内网IP地址192.168.1.1的入方向静态地址转换。
[Sysname] nat static inbound 2.2.2.2 192.168.1.1
·     display nat all
·     nat static enable
nat static inbound net-to-net命令用来配置入方向网段到网段的静态地址转换映射。
undo nat static inbound net-to-net命令用来删除指定的入方向网段到网段的静态地址转换映射。
nat static inbound net-to-net global-start-address global-end-address local local-network { mask-length | mask } [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static inbound net-to-net global-start-address global-end-address local local-network { mask-length | mask }
不存在地址转换映射。
global-start-address global-end-address:外网地址范围,所包含的地址数目不能超过255。global-start-address表示起始地址,global-end-address表示结束地址。global-end-address必须大于或等于global-start-address,如果二者相同,则表示只有一个地址。
local-network:内网网段地址。
mask-length:内网网络地址的掩码长度,取值范围为8~31。
mask:内网网络地址掩码。
外网网段通过起始地址和结束地址来指定,内网网段通过内网地址和掩码来指定。
对于从外网到内网的报文,使用其源地址匹配外网地址,将源地址转换为内网地址;对于从内网到外网的报文,使用其目的地址匹配内网地址,将目的地址转换为外网地址。
外网结束地址不能大于外网起始地址和内网掩码所决定的网段中的最大IP地址。比如:内网地址配置为2.2.2.0,掩码为255.255.255.0,外网起始地址为1.1.1.100,则外网结束地址不应该大于1.1.1.0/24网段中可用的最大IP地址,即1.1.1.255。
指定引用的ACL时,需要注意:
·     如果仅指定了ACL,没有指定ACL反向匹配(即没有配置reversible),对于从外网到内网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从内网到外网的报文,不能使用该配置进行目的地址转换。
·     如果既指定了ACL,又指定了ACL反向匹配(即配置了reversible),对于外网到内网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从内网到外网的报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并根据配置转换目的地址,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能使用该配置进行转换,否则不予转换。
设备支持配置多条入方向静态地址转换映射(包括nat static inbound和nat static inbound net-to-net)。
对于引用了ACL的入方向网段到网段的静态地址转换映射,当NAT规则的匹配优先级相同时,设备将按照ACL名称或ACL编号进行匹配,且ACL名称的优先级高于ACL编号的优先级,具体规则如下:
# 配置外网网段202.100.1.0/24到内网网段192.168.1.0/24的入方向静态地址转换。
[Sysname] nat static inbound net-to-net 202.100.1.1 202.100.1.255 local 192.168.1.0 24
·     display nat all
·     nat static enable
nat static inbound object-group命令用来配置基于对象组的入方向静态地址转换映射。
undo nat static inbound object-group命令用来删除指定的基于对象组的入方向静态地址转换映射。
nat static inbound object-group global-object-group-name object-group local-object-group-name [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ disable ] [ counting ]
undo nat static inbound object-group global-object-group-name
不存在地址转换映射。
object-group global-object-group-name:外网IPv4地址对象组。global-object-group-name表示IPv4地址对象组的名称,为1~31个字符的字符串,不区分大小写。
object-group local-object-group-name:内网IPv4地址对象组。local-object-group-name表示IPv4地址对象组的名称,为1~31个字符的字符串,不区分大小写。
acl:指定ACL的编号或名称,本参数用于控制指定访问范围的报文可以使用NAT规则进行地址转换。
外网地址通过外网IPv4地址对象组来指定,内网地址通过内网IPv4地址对象组来指定。
指定引用的object-group时,需要注意:
·     内网IPv4地址对象组和外网IPv4地址对象组内只能存在一个IPv4地址对象。
·     内网IPv4地址对象组内地址数应不小于外网IPv4地址对象组。
·     内网IPv4地址对象组的地址对象不能是地址范围。
指定引用的ACL时,需要注意:
设备可支持配置多条入方向静态地址转换映射(包括nat static inbound、nat static inbound net-to-net和nat static inbound object-group)。
基于地址对象组的入方向静态地址转换引用的IPv4地址对象组中,只能存在一个主机对象(host)或者一个子网对象(subnet),否则引用不生效。
# 配置外网IP地址2.2.2.2到内网IP地址192.168.1.1基于对象组的入方向静态地址转换。
[Sysname] object-group ip address global
[Sysname-obj-grp-ip-global] network host address 2.2.2.2
[Sysname-obj-grp-ip-global] quit
[Sysname] object-group ip address local
[Sysname-obj-grp-ip-local] network host address 192.168.1.1
[Sysname-obj-grp-ip-local] quit
[Sysname] nat static inbound object-group global object-group local
·     display nat all
·     nat static enable
nat static inbound rule move命令用来调整入方向一对一静态NAT规则的匹配优先级。
nat static inbound rule move nat-rule-name1 { after | before } nat-rule-name2
本命令仅对指定了NAT规则名称的入方向一对一静态NAT生效。
# 将入方向一对一静态NAT规则abc移动到入方向一对一静态NAT规则def的前面。
[Sysname] nat static inbound rule move abc before def
nat static outbound命令用来配置出方向一对一静态地址转换映射。
undo nat static outbound命令用来删除出方向一对一静态地址转换映射。
nat static outbound local-ip global-ip [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static outbound local-ip global-ip
不存在任何地址转换映射。
local-ip:内网IP地址。
global-ip:外网IP地址。
acl:指定ACL的编号或名称,本参数用于控制内网主机可以访问的目的地址。
reversible:表示从外网主动访问内网的报文必须通过ACL反向匹配,才能使用该配置进行目的地址转换。
对于从内网到外网的报文,将其源地址local-ip转换为global-ip;对于从外网到内网的报文,将其目的地址global-ip转换为local-ip。
指定引用的ACL时,需要注意:
·     如果没有指定ACL,则所有从内网到外网的报文都可以使用该配置进行源地址转换;所有从外网到内网的报文都可以使用该配置进行目的地址转换。
·     如果仅指定了ACL,没有指定ACL反向匹配(即没有配置reversible),对于从内网到外网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从外网主动访问内网的报文,不能使用该配置进行目的地址转换。
·     如果既指定了ACL,又指定了ACL反向匹配(即配置了reversible),对于从内网到外网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从外网主动访问内网的报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并根据配置转换目的地址,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能使用该配置进行转换,否则不予转换。
设备可支持配置多条出方向静态地址转换映射(包括nat static outbound和nat static outbound net-to-net)。
对于引用了ACL的出方向一对一静态地址转换映射,当NAT规则的匹配优先级相同时,设备将按照ACL名称或ACL编号进行匹配,且ACL名称的优先级高于ACL编号的优先级,具体规则如下:
# 配置内网IP地址192.168.1.1到外网IP地址2.2.2.2的出方向静态地址转换映射。
# 配置出方向静态地址转换映射,允许内网用户192.168.1.1访问外网网段3.3.3.0/24时,使用外网IP地址2.2.2.2。
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 2.2.2.2 acl 3001
·     display nat all
·     nat static enable
nat static outbound net-to-net命令用来配置出方向网段到网段的静态地址转换映射。
undo nat static outbound net-to-net命令用来删除出方向网段到网段的静态地址转换映射。
nat static outbound net-to-net local-start-address local-end-address global global-network { mask-length | mask } [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static outbound net-to-net local-start-address local-end-address global global-network { mask-length | mask }
不存在任何地址转换映射。
local-start-address local-end-address:内网地址范围,所包含的地址数目不能超过255。local-start-address 表示起始地址,local-end-address表示结束地址。local-end-address必须大于或等于local-start-address,如果二者相同,则表示只有一个地址。
global-network:外网网段地址。
mask-length:外网网络地址的掩码长度,取值范围为8~31。
mask:外网网络地址掩码。
内网网段通过起始地址和结束地址来指定,外网网段通过外网地址和掩码来指定。
对于从内网到外网的报文,使用其源地址匹配内网地址,将源地址转换为外网地址;对于从外网到内网的报文,使用其目的地址匹配外网地址,将目的地址转换为内网地址。
内网结束地址不能大于内网起始地址和外网掩码所决定的网段中的最大IP地址。比如:外网地址配置为2.2.2.0,掩码为255.255.255.0,内网起始地址为1.1.1.100,则内网结束地址不应该大于1.1.1.0/24网段中可用的最大IP地址,即1.1.1.255。
指定引用的ACL时,需要注意:
对于引用了ACL的出方向网段到网段的静态地址转换映射,当NAT规则的匹配优先级相同时,设备将按照ACL名称或ACL编号进行匹配,且ACL名称的优先级高于ACL编号的优先级,具体规则如下:
# 配置内网网段192.168.1.0/24到外网网段2.2.2.0/24的出方向静态地址转换映射。
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# 配置出方向网段到网段的静态地址转换映射,允许内网192.168.1.0/24网段的用户访问外网网段3.3.3.0/24时,使用外网网段2.2.2.0/24中的地址。
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24 acl 3001
·     display nat all
·     nat static enable
1.1.55  nat static outbound object-group
nat static outbound object-group命令用来配置基于对象组的出方向静态地址转换映射。
undo nat static outbound object-group命令用来删除指定基于对象组的出方向静态地址转换映射。
nat static outbound object-group local-object-group-name object-group global-object-group-name [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ disable ] [ counting ]
undo nat static outbound object-group local-object-group-name
不存在地址转换映射。
内网地址通过内网IPv4地址对象组来指定,外网地址通过外网IPv4地址对象组来指定。
·     内网IPv4地址对象组内地址数应不大于外网IPv4地址对象组。
·     外网IPv4地址对象组的地址对象不能是地址范围。
指定引用的ACL时,需要注意:
设备可支持配置多条出方向静态地址转换映射(包括nat static outbound、nat static outbound net-to-net和nat static outbound object-group)。
基于地址对象组的出方向静态地址转换引用的IPv4地址对象组中,只能存在一个主机对象(host)或者一个子网对象(subnet),否则引用不生效。
# 配置基于对象组的出方向静态地址转换映射,允许内网用户192.168.1.1访问外网网段3.3.3.0/24时,使用外网IP地址2.2.2.2。
[Sysname] nat static outbound object-group local object-group global
·     display nat all
1.1.56  nat static outbound rule move
nat static outbound rule move命令用来调整出方向一对一静态NAT规则的匹配优先级。
nat static outbound rule move nat-rule-name1 { after | before } nat-rule-name2
本命令仅对指定了NAT规则名称的出方向一对一静态NAT生效。
# 将出方向一对一静态NAT规则abc移动到出方向一对一NAT规则def的前面。
[Sysname] nat static outbound rule move abc before def
1.1.57  nat timestamp delete
nat timestamp delete命令用来开启对TCP SYN和SYN ACK报文中时间戳的删除功能。
undo nat timestamp delete命令用来恢复缺省情况。
不对TCP SYN和SYN ACK报文中的时间戳进行删除处理。
在PAT方式的动态地址转换(即接口上配置了nat inbound或nat outbound命令)组网环境中,若服务器上同时开启了tcp_timestams和tcp_tw_recycle功能,则Client与Server之间可能会出现无法建立TCP连接的现象。
为了解决以上问题,可在服务器上关闭tcp_tw_recycle功能或在设备上开启对TCP SYN和SYN ACK报文中时间戳的删除功能。
# 开启对公网上TCP SYN和SYN ACK报文中时间戳的删除功能。
[Sysname] nat timestamp delete
·     nat outbound
·     nat inbound
1.1.58  port-block
port-block命令用来配置NAT地址组的端口块参数。
undo port-block命令用来恢复缺省情况。
port-block block-size block-size [ extended-block-number extended-block-number ]
undo port-block
未配置NAT地址组的端口块参数。
NAT地址组视图
block-size block-size:端口块大小,即一个端口块中所包含的端口数,取值范围为1~65535。同一NAT地址组内,该参数的值不能超过port-range参数的值。
extended-block-number extended-block-number:增量端口块数,取值范围为1~5。当分配端口块中的端口资源耗尽(所有端口都被使用)时,如果对应的私网IP地址向公网发起新的连接,则无法从分配端口块中获取端口。此时,如果分配端口块的公网IP地址所属的NAT地址组中配置了增量端口块数,则可以为对应的私网IP地址进行增量端口块分配。一个私网IP地址最多可同时占有1+extended-block-number个端口块。
端口块动态映射方式下,配置出方向地址转换所引用的NAT地址组中必须配置端口块参数。当某私网IP地址首次向公网发起连接时,从所匹配的NAT地址组中获取一个公网IP地址,从获取的公网IP地址中分配一个动态端口块并创建动态端口块表项(该私网IP地址后续向公网发起连接时,通过私网IP地址查找动态端口块表项),使用公网IP地址进行IP地址转换,并从端口块中动态分配一个端口进行TCP/UDP端口转换。
# 配置NAT地址组2的端口块参数,端口块大小为256,增量端口块数为1。
[Sysname] nat address-group 2
[Sysname-address-group-2] port-block block-size 256 extended-block-number 1
·     nat address-group
1.1.59  port-range
port-range命令用来配置公网IP地址的端口范围。
undo port-range命令用来恢复缺省情况。
port-range start-port-number end-port-number
undo port-range
公网IP地址的端口范围为1~65535。
NAT地址组视图
NAT端口块组视图
start-port-number end-port-number:公网IP地址端口的起始端口号和结束端口号。end-port-number必须大于或等于start-port-number。建议将start-port-number配置为大于或等于1024的数值,避免出现应用协议识别错误的问题。
在NAT地址组(或NAT端口块组)视图下配置端口范围后,该NAT地址组(或NAT端口块组)内的所有公网IP地址可用于地址转换的端口都必须位于所指定的端口范围之内。
在NAT端口块组内配置端口范围时,端口范围不能小于端口块大小。在NAT地址组内配置端口范围时,如果地址组配置了端口块参数,则端口范围也不能小于端口块大小。
# 配置NAT地址组1的公网IP地址端口范围为1024~65535。
[Sysname-address-group-1] port-range 1024 65535
# 配置NAT端口块组1的公网IP地址端口范围为30001~65535。
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] port-range 30001 65535
·     nat address-group
·     nat port-block-group
1.1.60  reset nat count statistics
reset nat count statistics命令用来清除NAT转换计数信息。
reset nat count statistics { all | dynamic | server | static | static-port-block }
all:清除所有NAT转换计数信息。
dynamic:清除所有动态NAT转换计数信息。
server:清除NAT server转换计数信息。
static:清除所有静态NAT转换计数信息。
static-port-block:清除NAT444端口块静态映射转换计数信息。
# 清除所有静态NAT转换计数信息。
<Sysname> reset nat count statistics all
1.1.61  reset nat session
reset nat session命令用来删除NAT会话。
reset nat session [ slot slot-number ]
slot slot-number:删除指定成员设备上的NAT会话,slot-number表示设备在IRF中的成员编号。如果不指定该参数,则表示删除所有成员设备上的NAT会话。
# 删除指定slot上的NAT会话。
<Sysname> reset nat session slot 1
·     display nat session
